  4. Test Adapter google-sharedlocations2
45 Beiträge 8 Kommentatoren 2.9k Aufrufe 14 Beobachtet
  • David G.D David G.
    @Garfonso
    Ich war mal so frei und hab einfach den Coockie im DP gelöscht, damit er sich über den Browser einloggen muss.
    Bleibt gelb und loggt sich nicht ein.
    Wenn ich manuell einen Coockie Einträge wird er grün.
    Ansonsten:
    google-sharedlocations2.0
    2026-02-06 17:30:20.115	error	Error in puppeteer: Timed out after waiting 30000ms
    2026-02-06 17:29:46.561	info	Trying to login to Google to get new cookies.
    2026-02-06 17:29:46.509	info	starting. Version 0.2.0 (non-npm: Garfonso/ioBroker.google-sharedlocations2#cb37556e09bc0a830094e90605e5beb7b2ed5439) in /opt/iobroker/node_modules/iobroker.google-sharedlocations2, node: v22.22.0, js-controller: 7.0.7
    2026-02-06 17:29:42.481	info	terminating
    2026-02-06 17:29:41.981	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-02-06 17:29:41.981	info	terminating
    2026-02-06 17:29:41.981	info	Got terminate signal TERMINATE_YOURSELF
    2026-02-06 17:29:20.066	error	Error in puppeteer: Timed out after waiting 30000ms
    2026-02-06 17:28:46.326	info	Trying to login to Google to get new cookies.
    2026-02-06 17:28:46.326	info	Current cookies state was cleared, trying to obtain new cookies.
    2026-02-06 17:28:39.033	info	starting. Version 0.2.0 (non-npm: Garfonso/ioBroker.google-sharedlocations2#cb37556e09bc0a830094e90605e5beb7b2ed5439) in /opt/iobroker/node_modules/iobroker.google-sharedlocations2, node: v22.22.0, js-controller: 7.0.7
    2026-02-06 17:28:35.036	info	terminating
    2026-02-06 17:28:34.536	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-02-06 17:28:34.535	info	terminating
    2026-02-06 17:28:34.535	info	Got terminate signal TERMINATE_YOURSELF
    2026-02-06 17:28:33.683	info	Obtained new cookies from Google login.
    2026-02-06 17:28:22.845	info	Trying to login to Google to get new cookies.
    2026-02-06 17:28:22.844	info	Current cookies state was cleared, trying to obtain new cookies.
    GarfonsoG Offline
    GarfonsoG Offline
    Garfonso
    @David-G. sagte in Test Adapter google-sharedlocations2:
    Hm.. aber da sollsten jetzt Daten im Verzeichnis liegen, oder?
    Timed out heißt, dass der Browser irgendwo nicht weiter kam... da musst du debug anmachen, um mehr zu sehen, leider.. (am besten letzten git-status vorher installieren, hab da das logging nochmal erweitert). Soll ich das vielleicht zu info machen? Oder ich versuche das zu speichern und gebe aus, wo es schiefgegangen ist, wenn der error fliegt. Hm.
    Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
    Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
      @Garfonso
      Ansonsten:
      GarfonsoG Offline
      GarfonsoG Offline
      Garfonso
      @David-G.
      Für das Problem bist du verantwortlich. :-p
      Wenn der Browser noch eingeloggt ist (weil er ja seine Cookies jetzt speichern darf), dann geht er direkt von der Loginseite zu google maps. Auf google maps findet puppeteer aber auch nach langer Wartezeit das Feld für die Login-Daten nicht. Folglich erfolgt ein timeout...
      0.3.1 kann das aber jetzt, sie checkt ob das accounts.google.com nach 3 Sekunden verschwunden ist und falls ja, liest den cookie und ist fertig.
      Hab auch noch einiges umgebaut zu Version 0.3.0, hauptsächlich intern. Ich speicher jetzt das cookie array mit den ganzen Daten und es werden jetzt veraltete cookies auch gelöscht und das ganze etwas sinnvoller aktualisiert.
      Es gab noch ein Problem mit refresh, da konnte es vorkommen, dass der browser die cookies nicht mag. Das hab ich abgefangen und versucht möglichst sinnvoll zu behandeln... und es gibt jetzt einen state mit dem man einen Refresh mit dem Browser erzwingen kann.
      Dabei fällt mir wieder ein: Aktuell versucht der Code, wie es auch das Skript gemacht hat, den aktuellen Cookie an den Browser zu geben. Eigentlich ergibt das aber mit dem Storage im Browser nicht so viel Sinn, oder? Eigentlich sollte ich nur den Browser laden, gucken, ob der von der login-Seite zu maps wechselt und dann die cookies einsammeln, oder?
      David G.D B 2 Antworten Letzte Antwort
      • GarfonsoG Garfonso
        @David-G.
        David G.D Online
        David G.D Online
        David G.
        @Garfonso sagte in Test Adapter google-sharedlocations2:
        Hab da nicht so wirklich Ahnung von. Klingt aber plausibel.
        Zu meinem hausgemachten Coockie "Problem".
        Ist in der aktuellen Version auch.
        Hat Google auch eine logout URL die man vorher pauschal aufrufen kann? Dann würde die login Seite evtl immer klappen.
        2026-02-09 13:49:39.743	error	The step puppeteer failed was: filling in username.
        2026-02-09 13:49:39.743	error	Error in puppeteer: Timed out after waiting 30000ms
        2026-02-09 13:49:03.483	info	Trying to login to Google to get new cookies.
        2026-02-09 13:48:55.331	info	starting. Version 0.3.2 (non-npm: Garfonso/ioBroker.google-sharedlocations2#34a287aeaece01e35b1248eb760e60b50e52e8e5) in /opt/iobroker/node_modules/iobroker.google-sharedlocations2, node: v22.22.0, js-controller: 7.0.7
          @David-G.
          bommel_030
          @Garfonso
          Musste ein paar Tage pausieren und teste aktuell mit der 0.3.2
          Der Adapter kann sich mit Nutzer/PW anmelden und bekommt auch einen Cookie. Leider kann er sich mit dem nicht anmelden.
          Extrahiere ich manuell einen Cookie aus z.B. Chrome und füttere den Adapter damit startet er sofort.
          Er erkennt auch wenn der Cookie abgelaufen ist, loggt sich wieder ein und holt einen neuen Cookie.
          Dieser ist dann leider genau so unbrauchbar wie der erste.
          Was sagt die Cookielength im Log aus? Am Anfang hatte er eine von 3, dann 4. Die haben beide nicht funtkioniert. Die manuell kopierte hatte dann eine Länge von 23. Hatte gehofft es liegt daran, aber zwischenzeitlich hatte er sich einen neuen Cookie mit Länge 24 geholt der auch nicht funktionierte.
          Ich bin relativ ratlos... Der Adapter macht offensichtlich das was er soll, holt aber scheinbar die falschen Kekse....
          Wenn man nicht mitbekommt, dass der Adapter Offline geht versucht er so lange einen neuen Cookie zu holen bis Google wegen ungewöhnlicher Anmeldung dicht macht. Kannst du das einbauen, dass er nach x Versuchen aufhört und was im LOG hinterlässt oder nen Datenpunkt beschreibt?
          Der Teil mit "places" funktioniert auf jeden Fall einwandfrei.
          Der "alte" Adapter hatte noch ein "force update" Button, könntest du den bei Gelegenheit auch wieder reinbringen?
          • GarfonsoG Offline
            GarfonsoG Offline
            Garfonso
            schrieb am zuletzt editiert von Garfonso
            @bommel_030
            Hm.. also die Probleme beim Einloggen bzw. dass der Cookie dann nicht geht, kann ich nicht nachvollziehen... :-/
            Irgendwie kann ich auch gerade nicht nachvollziehen, warum der Adapter ständig versuchen sollte einen neuen Cookie zu holen. Das darf er eigentlich nur, wenn er es seit dem letzten Versuch einmal geschafft hat, die Positionen abzurufen. Hm... Ich hab mal eine neue Version gemacht, die das explizit loggt. Bitte mal mit Debug-Logging da rein gucken.
            Die "Länge" ist aktuell, wie viele Cookies der Adapter gelesen hat. Früher war das mal die Länge des Strings, wo alle hintereinander ausgeschrieben waren. Es reichen zum Einloggen aber die drei "richtigen" Cookies (vermutlich reicht sogar "der" richtige eine Cookie). Ich filter das aber aktuell nicht und behalte einfach alle, die Google schickt, damit man da nicht in Probleme mit Anpassung läuft.
            Ansonsten löscht die 0.3.3 jetzt auch die Cookies vom Browser, wenn man den Cookie-String löscht um sich gezwungen mit Username + Passwort einzuloggen. (hab ich hier zum testen genutzt ;-) - keine Ahnung, ob das bleibt. ).
              @bommel_030
              David G.D Online
              David G.D Online
              David G.
              @Garfonso
              Nachdem ich den Adapter gelöscht und neu jnsgaohan läuft er auch wieder. Evtl hab ich mit den Coockies was zerschossen gehabt......
              P. S.
              Das Feature Request auf git ist von mir ^^.
              Installiere nachher mal die neue Version von heute.
                @bommel_030
                bommel_030
                @Garfonso
                Ich kann mir auf die Cookies auch keinen Reim machen...
                v0.3.3 konnte mit Benutzername/Passwort keinen (für Google akzeptablen Cookie) holen. Manuell Cookie geholt, Adapter läuft.
                Nach 2h Cookie abgelaufen, er kann keinen neuen holen, versucht es weiter bis Google wegen Sicherheitsbedenken sperrt.
                Hab es leider erst zu spät mitbekommen. Google entsperrt, wieder mit manuellem Cookie gefüttert, seitdem läuft er jetzt gut 1 Woche.
                In der Zeit hat er einige 500er Fehler überlebt, mehrfach den abgelaufenen Cookie erneuert, Chromium Update über die Konsole überlebt und sich nach sogar nach einem ioBroker-Absturz eigenständig mit frischen Keksen versorgt...
                  Aktuelle Test Version 0.3.2
                  Veröffentlichungsdatum 9.02.2026
                  Github Link https://github.com/Garfonso/ioBroker.google-sharedlocations2
                  google-sharedlocations gibt es ja schon länger und hat das große Problem, dass der alte Login nicht mehr ging und jetzt mit Cookie herumkopiert werden muss, aber der läuft immer ab und mäh … :-/
                  @david-g. kam auf die grandiose Idee, ein Skript zu erstellen, das mit puppeteer (einem "ferngesteuerten" Browser) einen neuen Cookie holt und für den Adapter nutzbar macht. Das brachte mich auf die Idee, das einfach in den Adapter zu gießen. Damit der auch mal die Chance auf das Repository hat und um Altlasten loszuwerden, habe ich heute einfach von 0 angefangen. Vielen Dank für die Idee. :-)
                  Wie nutze ich den Adapter?
                  Ähnlich, wie der alte Adapter auch. Alte Nutzer also gerne überspringen. Man sollte für den Adapter einen neuen Google-Account anlegen. Also einen extra für ioBroker. Mit diesem Account teilt man dann den Standort von allen anderen Accounts, deren Position man gerne überwachen möchte.
                  Die Nutzerdaten vom ioBroker-Google-Account trägt man im Adapter ein und fertig.
                  2FA & Cookie
                  Wichtig: Aktuell wird kein 2FA unterstützt. Da der Account aber nur für ioBroker genutzt werden soll, ist das zu verkraften. So geht es sehr bequem. Wer das aber unbedingt 2FA möchte oder aus anderen Gründen keinen Benutzernamen / Passwort in der Config eintragen möchte, kann einfach Benutzername und Passwort leer lassen. Dann muss man weiterhin den Cookie von google.com/maps manuell kopieren und im Datenpunkt info.currentCookies eintragen.
                  Der Adapter ist nun auch so gebaut, dass er einen Cookie, der dort eingetragen wird, automatisch übernimmt. (Wenn man den state leer macht, versucht er sich auch erneut mit Benutzer und Passwort einzuloggen, wenn vorhanden).
                  Puppeteer & Ressourcen
                  Puppeteer ist ein kompletter Browser. Insofern muss man auf einem Raspberry Pi oder so beim ersten Start schon was länger rechnen, bis was passiert. Ich hoffe, es klappt überhaupt. Der Browser wird auch wieder beendet, wenn das Einloggen geklappt hat. Wenn der Cookie abgelaufen ist, wird wieder versucht, den Browser zu starten.
                  Status
                  Es funktioniert. :-) Mal sehen, wo überall noch kaputtgeht … Es ist das Werk von einem Tag. Viel Spaß beim Testen.
                  0.1.0
                  Fences und places habe ich auch wieder implementiert. Sollte ähnlich sein, wie vorher. Sonst habe ich einiges umgebaut und auch etwas Cookie-Behandlung optimiert. Mal sehen, ob er sich jetzt nicht so oft neu einloggen muss. Oder ob überhaupt noch alles funktioniert. Hust ;-)
                  0.2.0
                  Chrome speichert jetzt Daten. Mal sehen, ob ihm das hilft. Außerdem schaut der Adapter erst einmal, was Chrome so aus dem Cookie macht und ob das schon reicht, um die Locationdata wieder abrufen zu können.
                  0.3.x
                  Hab intern viel am Cookie geändert. Aus Usersicht gibt es jetzt den State info.forceRefreshWithBrowser, den man auf true setzen kann. Dann startet der Adapter den Browser und liest den Cookie daraus aus.
                  Außerdem scheint der Refresh jetzt deutlich besser. Man kann den Adapter jetzt auch ohne User/Passwort in den Settings relativ gut nutzen. Vielleicht geht sogar 2FA, wenn man den Cookie in den State reinkopiert. Gerne mal jemand testen.
                  GaspodeG Offline
                  GaspodeG Offline
                  Gaspode
                  schrieb am zuletzt editiert von Gaspode
                  @Garfonso
                  Super, dass du dich um den Adapter kümmerst.
                  Edit: Nach dem 3. Versuch hat es jetzt einfach so funktioniert. keine Ahnung, warum es zunächst den Fehler gab. Jetzt läuft die Sache erst mal. Ich beobachte. Vielen Dank!
                  Ich hab jetzt mal getestet (unter Windows) und bekomme allerdings folgende Fehlermeldung:
                  2026-03-09 15:24:40.580 - info: google-sharedlocations2.0 (6680) starting. Version 0.3.3 (non-npm: Garfonso/ioBroker.google-sharedlocations2#861d3ca3b6b823f42e232d261e612220ab634de9) in C:/ioBroker/lonwolf/node_modules/iobroker.google-sharedlocations2, node: v22.21.0, js-controller: 7.0.7
                  2026-03-09 15:24:40.623 - debug: google-sharedlocations2.0 (6680) Loaded 0 cookies from state.
                  2026-03-09 15:24:40.624 - debug: google-sharedlocations2.0 (6680) No cookie found in states, trying to log in to get new one.
                  2026-03-09 15:24:40.625 - debug: google-sharedlocations2.0 (6680) Trying to refresh cookie by loading Google Maps with existing cookie in Browser.
                  2026-03-09 15:24:40.625 - debug: google-sharedlocations2.0 (6680) Starting browser.
                  2026-03-09 15:24:43.037 - debug: google-sharedlocations2.0 (6680) browser started, opening new page.
                  2026-03-09 15:24:45.277 - debug: google-sharedlocations2.0 (6680) Loading Google login page to refresh cookie.
                  2026-03-09 15:24:50.482 - debug: google-sharedlocations2.0 (6680) Waiting for page to load, currently waiting fixed 5 seconds, because network never gets idle for maps
                  2026-03-09 15:24:56.034 - info: google-sharedlocations2.0 (6680) Trying to login to Google to get new cookies.
                  2026-03-09 15:24:56.034 - debug: google-sharedlocations2.0 (6680) Starting browser.
                  2026-03-09 15:25:00.589 - debug: google-sharedlocations2.0 (6680) browser started, opening new page.
                  2026-03-09 15:25:01.197 - debug: google-sharedlocations2.0 (6680) going to google login page.
                  2026-03-09 15:25:05.681 - debug: google-sharedlocations2.0 (6680) waiting for login / maps page to load (fixed 3 seconds timeout)
                  2026-03-09 15:25:08.689 - debug: google-sharedlocations2.0 (6680) filling in username.
                  2026-03-09 15:25:09.774 - debug: google-sharedlocations2.0 (6680) clicking user next button.
                  2026-03-09 15:25:10.140 - debug: google-sharedlocations2.0 (6680) waiting for network idle before filling password
                  2026-03-09 15:25:14.094 - debug: google-sharedlocations2.0 (6680) filling in password.
                  2026-03-09 15:25:44.104 - error: google-sharedlocations2.0 (6680) Error in puppeteer: Timed out after waiting 30000ms
                  2026-03-09 15:25:44.104 - error: google-sharedlocations2.0 (6680) The step puppeteer failed was: filling in password.
                  Eine Idee, woran das liegen könnte?
                    Kuddel
                    schrieb am zuletzt editiert von Kuddel
                    Ich habe den Adapter gerdae installiert, um das Cookie Problem zu beheben:
                    google-sharedlocations2.0 	2026-03-24 04:41:50.548	error	The step puppeteer failed was: undefined
                    google-sharedlocations2.0 	2026-03-24 04:41:50.548	error	Error in puppeteer: Failed to launch the browser process: Code: 127 stderr: /home/iobroker/.cache/puppeteer/chrome/linux-146.0.7680.153/chrome-linux64/chrome: error while loading shared libraries: libatk-1.0.so.0: cannot open shared object file: No such file or directory TROUBLESHOOTING: https://pptr.dev/troubleshooting
                    ChatGPT konnte helfen
                    sudo apt update
                    sudo apt install -y \
                      libatk1.0-0 \
                      libatk-bridge2.0-0 \
                      libcups2 \
                      libxcomposite1 \
                      libxdamage1 \
                      libxrandr2 \
                      libgbm1 \
                      libasound2 \
                      libpangocairo-1.0-0 \
                      libpango-1.0-0 \
                      libgtk-3-0 \
                      libnss3 \
                      libxss1 \
                      libxtst6
                    • mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      Der Adapter ist noch nicht im Repro. Bitte in ".....nicht in offiziellem Repo" verschieben.
                      kein PR bekannt
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                      • GarfonsoG Offline
                        GarfonsoG Offline
                        Garfonso
                        Oh, danke für die Erinnerung.
                        • GaspodeG Offline
                          GaspodeG Offline
                          Gaspode
                          Hi @garfonso,
                          mit Version 0.3.5 beobachte ich folgendes:
                          Manuell gesetzter Cookie funktioniert (Shared Locations werden gelesen)
                          Im Betrieb erscheint regelmäßig (ca. alle 10 Minuten):
                          Failed improving cookie: 429
                          429 entspricht ja "Too Many Requests", daher wirkt es so, als würde Google den Aufruf von https://myaccount.google.com drosseln bzw. blockieren. Das Pollen der Koordinaten funktioniert dabei weiterhin.
                          Wenn ich die Cookies im State lösche, startet der Login-Versuch und läuft in den oben von dir beschriebenen Timeout beim Passwort-Schritt (weil Session schon angemeldet). Danach werden jedoch keine passenden Cookie-Daten gefunden.
                          Sollten in diesem Fall nicht trotzdem verwertbare Cookies vorhanden sein, wenn bereits eine eingeloggte Session erkannt wird?
                          GarfonsoG 1 Antwort Letzte Antwort
                          • GaspodeG Gaspode
                            Hi @garfonso,
                            GarfonsoG Offline
                            GarfonsoG Offline
                            Garfonso
                            @Gaspode
                            Hm... stimmt... was ist da denn passiert? kopfkratz Es scheint auch kein wirkliches Rate-Limit zu sein. Im Browser kann ich die Seite aufrufen. Die mag irgendwas an dem Aufruf nicht... Puh. Keine Ahnung, was da jetzt groß anders sein soll, als an dem Aufruf mit axios.
                            Naja. Ich habe eine 0.3.6 auf den Weg gebracht, die das erstmal deaktiviert und dafür den Browser alle 24h einmal startet (ab Adapter-Start). Oder sollte man da lieber einen Zeitpunkt einstellen können oder so? Im Grunde kann man das auch extern per Skript triggern durch den State info.forceRefreshWithBrowser.
                            @Gaspode sagte:
                            Welchen state hast du genau gelöscht? Wenn du info.currentCookies löschst, sollte er alles wegwerfen und auch dem Browser sagen, er soll seine Cookies löschen, und dann geht auch Login mit User & Passwort, eigentlich. kopfkratz
                            Das Problem mit dem Login-Versuch ist sonst, dass Google sich gemerkt hat, welcher User eingeloggt war, den da als Knopf anzeigt, aber der Code das Eingabefeld sucht. Ich hab es irgendwie bisher nicht geschafft den Knopf sicher zu identifizieren und drauf zu klicken... ich dachte, ich hätte was, aber das scheint nicht stabil zu gehen.
                            Daher kommt halt der Timeout beim Suchen nach dem Eingabefeld. Ich hab es jetzt so umgebaut, dass er dann, wenn das passiert, die Cookies vom Browser löscht und mit Benutzername und Passwort neu einloggt. Das geht in jedem Fall (solange die konfiguriert sind).
                            Der Cookie im Browser ist in dem Fall jedenfalls nicht verwertbar. Den Cookie vom Browser einfach zu verwenden für einen Request versucht der Code immer zuerst.
                            GaspodeG 1 Antwort Letzte Antwort
                              @Gaspode
                              @Gaspode sagte:
                              GaspodeG Offline
                              GaspodeG Offline
                              Gaspode
                              @garfonso
                              OK, ich hab jetzt mal die 0.3.6 installiert. Automatisches Einloggen klappt nach wie vor nicht (s.u.). Ich habe jetzt mal das Cookie wieder manuell gesetzt und beobachte.
                              @Garfonso sagte:
                              Ja, genau.
                              2026-04-27 14:12:04.511 - info: google-sharedlocations2.0 (17644) Current cookies state was cleared, trying to obtain new cookies.
                              2026-04-27 14:12:04.511 - debug: google-sharedlocations2.0 (17644) Converted cookie string to 0 cookies.
                              2026-04-27 14:12:04.512 - info: google-sharedlocations2.0 (17644) Trying to login to Google to get new cookies.
                              2026-04-27 14:12:04.512 - debug: google-sharedlocations2.0 (17644) Starting browser.
                              2026-04-27 14:12:05.894 - debug: google-sharedlocations2.0 (17644) browser started, opening new page.
                              2026-04-27 14:12:06.713 - debug: google-sharedlocations2.0 (17644) Force login enabled, clearing cookies and local storage.
                              2026-04-27 14:12:06.721 - debug: google-sharedlocations2.0 (17644) going to google login page.
                              2026-04-27 14:12:10.716 - debug: google-sharedlocations2.0 (17644) waiting for login / maps page to load (fixed 3 seconds timeout)
                              2026-04-27 14:12:13.722 - debug: google-sharedlocations2.0 (17644) Trying to click on username, if user was logged in before.
                              2026-04-27 14:12:13.740 - debug: google-sharedlocations2.0 (17644) No user element found, filling in username.
                              2026-04-27 14:12:14.524 - debug: google-sharedlocations2.0 (17644) clicking user next button.
                              2026-04-27 14:12:14.834 - debug: google-sharedlocations2.0 (17644) waiting for network idle before filling password
                              2026-04-27 14:12:16.880 - debug: google-sharedlocations2.0 (17644) filling in password.
                              2026-04-27 14:12:46.892 - error: google-sharedlocations2.0 (17644) Error in puppeteer: Timed out after waiting 30000ms
                              2026-04-27 14:12:46.893 - error: google-sharedlocations2.0 (17644) The step puppeteer failed was: filling in password.
                              2026-04-27 14:12:49.500 - debug: google-sharedlocations2.0 (17644) Cannot poll positions, no cookies available!
                              • GaspodeG Offline
                                GaspodeG Offline
                                Gaspode
                                @garfonso
                                Hoppla,
                                heute kam per Mail die Mitteilung, dass Google einen verdächtigen Login-Versuch blockiert hat. Anschließend musste ich mich per 2FA anmelden, obwohl ich das für den Account generell abgeschaltet habe.
                                Ich habe immer mehr den Eindruck, dass das mit dem automatischen Einloggen kaum zu stemmen ist. Evtl. wäre es der bessere Ansatz, wenn sich der Adapter auf das Halten/Erneuern der Cookies ohne neuen Login konzentriert. Was meinst du?
                                • GaspodeG Gaspode
                                  @garfonso
                                  Hoppla,
                                  GarfonsoG Offline
                                  GarfonsoG Offline
                                  Garfonso
                                  @Gaspode
                                  Keine Ahnung. Eigentlich (tm) läuft das mit dem Login hier problemlos.
                                  Aber du kannst dem Adapter verbieten, sich einzuloggen -> lösch einfach Username und Passwort aus den Einstellungen. Dann loggt er sich nur mit dem Cookie ein. Er versucht das dann auch mit dem Browser.
                                  • mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    Der Adapter wurde ins LATEST Repository aufgenommen
                                    • David G.D Online
                                      David G.D Online
                                      David G.
                                      Hat es schonmal jemand geschafft, ein über Family Link verwaltetes Gerät von einem der Kinder zu verbinden?
                                      Edit
                                      Es geht, wenn man den Account den man für den iobroker angelegt hat, als Elternteil hinterlegt. Nur kann meine Frau dann kein Elternteil mehr sein, man darf nur 2 Eltern vergeben (was ja Sinn macht....).
