  4. ...nicht in offiziellem Repo
  5. Life360 NextGeneration
    6.0k
Geplant Angeheftet Gesperrt Verschoben ...nicht in offiziellem Repo
copilotstandortgeo locationmap
155 Beiträge 17 Kommentatoren 13.4k Aufrufe 18 Beobachtet
  • Merlin123M Merlin123
    @skvarel Wie hast Du die Übersicht gemacht? Kannst Du das als Export teilen?
    skvarelS Online
    skvarelS Online
    skvarel
    schrieb am zuletzt editiert von skvarel
    #128
    @Merlin123
    Hier mit zwei Markern:
        "tpl": "tplOsm",
        "data": {
          "bindings": [
            "markersImage1",
            "markersImage2"
          "mCount": 2,
          "g_common": true,
          "maxZoom": 20,
          "markersLon-oid1": "life360ng.0.people.xxx.longitude",
          "markersLat-oid1": "life360ng.0.people.xxx.latitude",
          "markersSwap1": false,
          "markersImage1": "http://192.168.130.130:8082/vis-2.0/main/blue.png",
          "markersWidth1": 50,
          "markersHeight1": 50,
          "markersOffsetX1": 0,
          "markersOffsetY1": 0,
          "markersOpacity1": 1,
          "markersView1": null,
          "markersUrl1": null,
          "g_markers-1": true,
          "markersLon-oid2": "life360ng.0.people.xxx.longitude",
          "markersLat-oid2": "life360ng.0.people.xxx.latitude",
          "markersSwap2": null,
          "markersImage2": "http://192.168.130.130:8082/vis-2.0/main/red.png",
          "markersWidth2": 50,
          "markersHeight2": 50,
          "markersOffsetX2": 0,
          "markersOffsetY2": 0,
          "markersOpacity2": 1,
          "markersView2": null,
          "markersUrl2": null,
          "g_markers-2": true,
          "g_css_border": true,
          "g_css_shadow_padding": true
        "style": {
          "bindings": [
            "border-radius"
          "left": "10px",
          "top": "10px",
          "width": "1157px",
          "height": "659px",
          "z-index": "10",
          "border-radius": "{alias.0.VIS_Customizer.Radius_Ecken}px",
          "padding": null,
          "padding-left": null,
          "padding-top": null,
          "padding-right": null,
          "padding-bottom": null,
          "box-shadow": "3px 3px 5px #000000CC",
          "margin-left": null,
          "margin-top": null,
          "margin-right": null,
          "margin-bottom": null,
          "border-width": "",
          "border-color": "",
          "border-style": ""
        "widgetSet": "map",
        "_id": "i000001"
    #TeamInventwo
    Unsere Adapter:
    Merlin123M 1 Antwort Letzte Antwort
    • skvarelS skvarel
      @Merlin123
          "tpl": "tplOsm",
          "data": {
            "bindings": [
              "markersImage1",
              "markersImage2"
            "mCount": 2,
            "g_common": true,
            "maxZoom": 20,
          "style": {
            "bindings": [
              "border-radius"
            "left": "10px",
            "top": "10px",
            "width": "1157px",
            "height": "659px",
            "z-index": "10",
            "padding": null,
            "margin-top": null,
            "border-width": "",
            "border-color": "",
            "border-style": ""
          "widgetSet": "map",
          "_id": "i000001"
      Merlin123M Offline
      Merlin123M Offline
      Merlin123
      #129
      @skvarel Nutzt du da den vis-map für die vis1? Wird ja anscheinend nicht mehr weiter entwickelt.
      Beta-Tester
      skvarelS BananaJoeB 2 Antworten Letzte Antwort
        skvarelS Online
        skvarelS Online
        skvarel
        #130
        @Merlin123 .. das Widget funktioniert auch in VIS 2
        #TeamInventwo
        Unsere Adapter:
          BananaJoeB Online
          BananaJoeB Online
          BananaJoe
          #131
          @Merlin123 sagte:
          Wenn es einen Grund gibt, an den Widgets was zu ändern wird da dann wohl auch was gemacht. Da Google und OpenStreetMap aber wohl kaum was an ihren Aufrufen ändern werden, muss auch nichts angepasst werden.
          Bluefox hat da ja scheinbar persönlich ein Auge drauf.
          Bloß weil an einem Adapter länger was nichts passiert, heißt das nicht gleich das der "Tod" ist
          • BananaJoeB BananaJoe
            @Merlin123 sagte:
            Merlin123M Offline
            Merlin123M Offline
            Merlin123
            #132
            @BananaJoe eher wegen den nicht bearbeiteten Issues... Da würde ich schon denken, dass jemand die prüft.
            Beta-Tester
            • skvarelS skvarel
              Merlin123M Offline
              Merlin123M Offline
              Merlin123
              #133
              @skvarel hab es auch mal eingebaut. Nett :)
              Beta-Tester
              • Merlin123M Offline
                Merlin123M Offline
                Merlin123
                #134
                Hier mal die aktuelle Version meines "Adresse und POI" Suchscriptes. die POIs werden leider nicht immer gefunden. Hängt anscheinend mit der Größe des Gebäudes und dem ermittelten Standorts zusammen. Wenn man den Radius um den Standort zu groß macht, findet er teilweise falsche Sachen, macht man ihn zu klein findet man nichts.
                Weiteres Problem:
                Wenn man zu viele Anfragen an die Openmap API schickt, blockiert die erstmal.
                Im Script sind deswegen (vor allem beim Start) Verzögerungen drin. Trotzdem kann es mal zu Problemen kommen und das Script liefert dann keine Werte.
                Was auch drin ist: Er ändert nur die alten Werte, wenn die neuen in nem gewissen Maße abweichen. Soll Probleme verhindern, wenn der aktuelle Standort mal leicht variiert. Hatte das zu Hause, dass er erst die richtige Adresse angezeigt hat, und als ich im Garten nahe bei den Nachbarn war ist er bei der Adresse umgesprungen. Passiert jetzt nicht.
                Halt mit dem Nachteil, das unter Umständen die alte Adresse bleibt, auch wenn man beim NAchbar ist. Abhängig halt von den Abständen....
                Ist aktuell für 3 Personen ausgelegt. Wenn man die Daten für eine Person leer läß werden nur 2 bearbeitet usw.
                 * Mehrpersonen-Standortscript für ioBroker + Life360
                 * Konfiguration:
                 * Nur Name + Life360-ID eintragen.
                 * Alles andere wird automatisch erzeugt.
                 * PERSONENKONFIGURATION
                const PERSON1_NAME = 'Oliver';
                const PERSON1_ID   = 'b9fxxxxa7e';
                const PERSON2_NAME = 'Hannah';
                const PERSON2_ID   = 'f7fxxxx8e9d';
                const PERSON3_NAME = 'Marleen';
                const PERSON3_ID   = '880xxxaea';
                 * ALLGEMEINE EINSTELLUNGEN
                const MIN_INTERVAL_MS                 = 60 * 1000;
                const MIN_DISTANCE_M                  = 40;
                const DEBOUNCE_MS                     = 5000;
                const POI_RADIUS_M                    = 25;
                const SECOND_TRY_RADIUS               = 80;
                const GAP_BETWEEN_CALLS               = 2500;
                const STARTUP_PERSON_DELAY_MS         = 8000;
                const OVERPASS_RETRY_DELAY_MS         = 3000;
                const ADDRESS_STABLE_DISTANCE_M       = 20;
                const POI_STABLE_DISTANCE_M           = 120;
                const KEEP_POI_IF_OVERPASS_FAILS_M    = 150;
                const USER_AGENT = 'ioBroker-Standortscript/1.0 (Kontakt: oliver@voelker123.de)';
                // Debug
                const DEBUG_LOG_POI_CANDIDATES = true;
                const DEBUG_LOG_REJECTED_POIS  = true;
                 * PERSONENLISTE AUTOMATISCH ERZEUGEN
                const PERSON_CONFIGS = [
                    { name: PERSON1_NAME, id: PERSON1_ID },
                    { name: PERSON2_NAME, id: PERSON2_ID },
                    { name: PERSON3_NAME, id: PERSON3_ID }
                const PERSONS = PERSON_CONFIGS
                    .filter(p => String(p.name || '').trim() && String(p.id || '').trim())
                    .map(p => {
                        const cleanName = String(p.name).trim();
                        const cleanId = String(p.id).trim();
                        return {
                            key: cleanName,
                            latState: `life360ng.0.people.${cleanId}.latitude`,
                            lonState: `life360ng.0.people.${cleanId}.longitude`,
                            targetState: `0_userdata.0.VIS.Position.Standort_${cleanName}`,
                            baseState: `0_userdata.0.VIS.Position.${cleanName}`
                if (!PERSONS.length) {
                    throw new Error('Keine Personen konfiguriert. Bitte mindestens NAME und ID für eine Person eintragen.');
                // Laufzeitstatus pro Person
                const runtime = {};
                 * Initialisierung
                for (const person of PERSONS) {
                    person.addressState  = `${person.baseState}.Standort_${person.key}_Adresse`;
                    person.poiState      = `${person.baseState}.Standort_${person.key}_POI`;
                    person.lastLatState  = `${person.baseState}.Standort_${person.key}_LastLat`;
                    person.lastLonState  = `${person.baseState}.Standort_${person.key}_LastLon`;
                    person.lastTsState   = `${person.baseState}.Standort_${person.key}_LastLookupTs`;
                    person.poiTypeState  = `${person.baseState}.Standort_${person.key}_POI_Type`;
                    person.poiDistState  = `${person.baseState}.Standort_${person.key}_POI_Distance`;
                    person.poiLatState   = `${person.baseState}.Standort_${person.key}_POI_Lat`;
                    person.poiLonState   = `${person.baseState}.Standort_${person.key}_POI_Lon`;
                    runtime[person.key] = {
                        debounceTimer: null,
                        lookupRunning: false
                    createStateIfMissing(person.targetState, '', 'string', `${person.key} Standort`);
                    createStateIfMissing(person.addressState, '', 'string', `${person.key} Adresse`);
                    createStateIfMissing(person.poiState, '', 'string', `${person.key} POI`);
                    createStateIfMissing(person.lastLatState, 0, 'number', `${person.key} letzte Lookup-Latitude`);
                    createStateIfMissing(person.lastLonState, 0, 'number', `${person.key} letzte Lookup-Longitude`);
                    createStateIfMissing(person.lastTsState, 0, 'number', `${person.key} letzter Lookup-Zeitstempel`);
                    createStateIfMissing(person.poiTypeState, '', 'string', `${person.key} POI Typ`);
                    createStateIfMissing(person.poiDistState, 0, 'number', `${person.key} POI Distanz`);
                    createStateIfMissing(person.poiLatState, 0, 'number', `${person.key} POI Latitude`);
                    createStateIfMissing(person.poiLonState, 0, 'number', `${person.key} POI Longitude`);
                    on({ id: person.latState, change: 'ne' }, () => scheduleLookup(person, false));
                    on({ id: person.lonState, change: 'ne' }, () => scheduleLookup(person, false));
                 * Initial-Refresh beim Start: immer erzwingen, aber gestaffelt
                setTimeout(() => {
                    PERSONS.forEach((person, index) => {
                        setTimeout(() => {
                            scheduleLookup(person, true);
                        }, index * STARTUP_PERSON_DELAY_MS);
                }, 2000);
                 * Hauptlogik
                function scheduleLookup(person, force) {
                    const rt = runtime[person.key];
                    if (rt.debounceTimer) clearTimeout(rt.debounceTimer);
                    rt.debounceTimer = setTimeout(() => {
                        runLookup(person, !!force).catch(err => log(`${person.key}: Standortscript Fehler: ${err}`, 'error'));
                    }, force ? 500 : DEBOUNCE_MS);
                async function runLookup(person, force) {
                    if (rt.lookupRunning) {
                        log(`${person.key}: Lookup läuft bereits, überspringe parallelen Aufruf.`, 'debug');
                        return;
                    const lat = parseFloat(getState(person.latState).val);
                    const lon = parseFloat(getState(person.lonState).val);
                    if (!isFinite(lat) || !isFinite(lon)) {
                        log(`${person.key}: Ungültige Koordinaten, Lookup abgebrochen.`, 'warn');
                        return;
                    const previousLat = parseFloat(getState(person.lastLatState).val);
                    const previousLon = parseFloat(getState(person.lastLonState).val);
                    const moveDistance = (isFinite(previousLat) && isFinite(previousLon) && !(previousLat === 0 && previousLon === 0))
                        ? distanceMeters(previousLat, previousLon, lat, lon)
                        : 999999;
                    if (!force && !shouldLookup(person, lat, lon)) {
                        log(`${person.key}: Lookup übersprungen (Cooldown oder Bewegung zu gering).`, 'debug');
                        return;
                    rt.lookupRunning = true;
                    try {
                        log(`${person.key}: Starte Lookup für ${lat}, ${lon}${force ? ' (forced)' : ''}`, 'info');
                        const oldAddress = String(getState(person.addressState).val || '').trim();
                        const oldPoi = String(getState(person.poiState).val || '').trim();
                        const oldPoiType = String(getState(person.poiTypeState).val || '').trim();
                        const oldPoiLat = parseFloat(getState(person.poiLatState).val);
                        const oldPoiLon = parseFloat(getState(person.poiLonState).val);
                        const addressInfo = await getAddressFromNominatim(lat, lon);
                        const rawAddressText = buildAddressText(addressInfo);
                        const addressText = stabilizeAddress(oldAddress, rawAddressText, moveDistance);
                        setState(person.addressState, addressText || '', true);
                        setState(person.targetState, addressText || 'Unbekannter Standort', true);
                        setState(person.lastLatState, lat, true);
                        setState(person.lastLonState, lon, true);
                        setState(person.lastTsState, Date.now(), true);
                        await sleep(GAP_BETWEEN_CALLS);
                        let poi = null;
                        let finalText = addressText || 'Unbekannter Standort';
                        let overpassFailed = false;
                        try {
                            const firstPoiResult = await getNearbyNamedPoi(person, lat, lon, POI_RADIUS_M, addressText);
                            poi = firstPoiResult.poi;
                            overpassFailed = firstPoiResult.overpassFailed === true;
                            const mayRetryWithLargerRadius =
                                SECOND_TRY_RADIUS > POI_RADIUS_M &&
                                !overpassFailed &&
                                    firstPoiResult.hadCandidates ||
                                    addressLooksLikeBusiness(addressText)
                            if (!poi && mayRetryWithLargerRadius) {
                                await sleep(OVERPASS_RETRY_DELAY_MS);
                                const secondPoiResult = await getNearbyNamedPoi(person, lat, lon, SECOND_TRY_RADIUS, addressText);
                                poi = secondPoiResult.poi;
                                overpassFailed = secondPoiResult.overpassFailed === true;
                        } catch (poiErr) {
                            overpassFailed = true;
                            log(`${person.key}: POI-Suche fehlgeschlagen (${poiErr}). Verwende Adresse bzw. alten POI.`, 'warn');
                        if (!poi && oldPoi && isFinite(oldPoiLat) && isFinite(oldPoiLon) && !(oldPoiLat === 0 && oldPoiLon === 0)) {
                            const distToOldPoi = distanceMeters(lat, lon, oldPoiLat, oldPoiLon);
                            const allowedKeepDistance = overpassFailed ? KEEP_POI_IF_OVERPASS_FAILS_M : POI_STABLE_DISTANCE_M;
                            if (isStablePoiType(oldPoiType) && distToOldPoi <= allowedKeepDistance) {
                                poi = {
                                    typeLabel: oldPoiType || 'remembered',
                                    dist: distToOldPoi,
                                    lat: oldPoiLat,
                                    lon: oldPoiLon,
                                    remembered: true
                                log(
                                    `${person.key}: Behalte bisherigen POI '${oldPoi}' bei (Distanz ${distToOldPoi.toFixed(1)} m, OverpassFailed=${overpassFailed}).`,
                                    'info'
                        if (poi && poi.name) {
                            setState(person.poiState, poi.name, true);
                            setState(person.poiTypeState, poi.typeLabel || '', true);
                            setState(person.poiDistState, round1(poi.dist || 0), true);
                            setState(person.poiLatState, poi.lat || 0, true);
                            setState(person.poiLonState, poi.lon || 0, true);
                            if (addressText && !addressText.toLowerCase().includes(poi.name.toLowerCase())) {
                                finalText = poi.name + ', ' + addressText;
                            } else {
                                finalText = poi.name;
                        } else {
                            setState(person.poiState, '', true);
                            setState(person.poiTypeState, '', true);
                            setState(person.poiDistState, 0, true);
                            setState(person.poiLatState, 0, true);
                            setState(person.poiLonState, 0, true);
                        setState(person.targetState, finalText, true);
                        log(`${person.key}: Standort aktualisiert: ${finalText}`, 'info');
                    } catch (err) {
                        log(`${person.key}: Fehler beim Standort-Lookup: ${err}`, 'error');
                    } finally {
                        rt.lookupRunning = false;
                function shouldLookup(person, lat, lon) {
                    const lastTsRaw  = getState(person.lastTsState).val;
                    const lastLatRaw = getState(person.lastLatState).val;
                    const lastLonRaw = getState(person.lastLonState).val;
                    const lastTs  = Number(lastTsRaw || 0);
                    const lastLat = parseFloat(lastLatRaw);
                    const lastLon = parseFloat(lastLonRaw);
                    const now = Date.now();
                    if (lastTs > 0 && (now - lastTs) < MIN_INTERVAL_MS) {
                        return false;
                    if (isFinite(lastLat) && isFinite(lastLon) && !(lastLat === 0 && lastLon === 0)) {
                        const dist = distanceMeters(lastLat, lastLon, lat, lon);
                        if (dist < MIN_DISTANCE_M) {
                            return false;
                    return true;
                async function getAddressFromNominatim(lat, lon) {
                    const url =
                        'https://nominatim.openstreetmap.org/reverse' +
                        '?format=jsonv2' +
                        '&lat=' + encodeURIComponent(lat) +
                        '&lon=' + encodeURIComponent(lon) +
                        '&addressdetails=1' +
                        '&zoom=18';
                    const response = await httpGetAsync(url, {
                        'User-Agent': USER_AGENT,
                        'Accept': 'application/json'
                    if (response.statusCode < 200 || response.statusCode >= 300) {
                        throw new Error('Nominatim HTTP ' + response.statusCode);
                    let data;
                    try {
                        data = JSON.parse(response.data);
                    } catch (e) {
                        throw new Error('Nominatim JSON konnte nicht geparst werden');
                    return data;
                function buildAddressText(data) {
                    if (!data) return '';
                    const a = data.address || {};
                    const road =
                        a.road ||
                        a.pedestrian ||
                        a.footway ||
                        a.path ||
                        a.cycleway ||
                    const houseNumber = a.house_number || '';
                    const postcode = a.postcode || '';
                    const city =
                        a.city ||
                        a.town ||
                        a.village ||
                        a.hamlet ||
                        a.municipality ||
                    let result = '';
                    if (road) {
                        result += road;
                        if (houseNumber) result += ' ' + houseNumber;
                    if (postcode || city) {
                        if (result) result += ', ';
                        result += [postcode, city].filter(Boolean).join(' ');
                    if (!result && data.display_name) {
                        result = data.display_name;
                    return cleanText(result);
                function stabilizeAddress(oldAddress, newAddress, moveDistance) {
                    const oldA = String(oldAddress || '').trim();
                    const newA = String(newAddress || '').trim();
                    if (!newA) return oldA;
                    if (!oldA) return newA;
                    if (oldA === newA) return newA;
                    if (moveDistance <= ADDRESS_STABLE_DISTANCE_M) {
                        log(`Adress-Stabilisierung aktiv: Behalte '${oldA}' statt neu '${newA}' bei (Bewegung ${moveDistance.toFixed(1)} m).`, 'info');
                        return oldA;
                    return newA;
                function addressLooksLikeBusiness(addressText) {
                    const a = String(addressText || '').toLowerCase();
                    return (
                        a.includes('luisenring') ||
                        a.includes('mannheim') ||
                        a.includes('industrie') ||
                        a.includes('gewerbe') ||
                        a.includes('business') ||
                        a.includes('park')
                function buildGeneralPoiQuery(lat, lon, radius) {
                    return `
                [out:json][timeout:10];
                  nwr(around:${radius},${lat},${lon})["name"]["shop"];
                  nwr(around:${radius},${lat},${lon})["name"]["amenity"];
                  nwr(around:${radius},${lat},${lon})["name"]["tourism"];
                  nwr(around:${radius},${lat},${lon})["name"]["leisure"];
                  nwr(around:${radius},${lat},${lon})["name"]["office"];
                out center tags;
                function buildBusinessPoiQuery(lat, lon, radius) {
                    return `
                [out:json][timeout:6];
                  nwr(around:${radius},${lat},${lon})["name"]["office"="company"];
                  nwr(around:${radius},${lat},${lon})["name"]["office"="energy_supplier"];
                  nwr(around:${radius},${lat},${lon})["name"]["building"="office"];
                out center tags;
                async function getNearbyNamedPoi(person, lat, lon, radius, addressText) {
                    const isBusinessAddress = addressLooksLikeBusiness(addressText);
                    const query = isBusinessAddress
                        ? buildBusinessPoiQuery(lat, lon, radius)
                        : buildGeneralPoiQuery(lat, lon, radius);
                    log(`${person.key}: Verwende ${isBusinessAddress ? 'Business' : 'General'}-POI-Query im Radius ${radius} m.`, 'info');
                    const response = await httpPostAsync(
                        'https://overpass-api.de/api/interpreter',
                        query,
                            'Content-Type': 'text/plain; charset=utf-8',
                    if (response.statusCode === 504 || response.statusCode === 502 || response.statusCode === 429) {
                        log(`${person.key}: Overpass HTTP ${response.statusCode}, verwende keinen neuen POI.`, 'warn');
                        return { poi: null, hadCandidates: false, overpassFailed: true };
                        throw new Error('Overpass HTTP ' + response.statusCode);
                    let data;
                    try {
                    } catch (e) {
                        throw new Error('Overpass JSON konnte nicht geparst werden');
                    if (!data.elements || !data.elements.length) {
                        log(`${person.key}: Keine POI-Kandidaten im Radius ${radius} m gefunden.`, 'info');
                        return { poi: null, hadCandidates: false, overpassFailed: false };
                    const candidates = data.elements
                        .map(el => {
                            const cLat = el.lat || (el.center && el.center.lat);
                            const cLon = el.lon || (el.center && el.center.lon);
                            const rawName = el.tags && el.tags.name ? String(el.tags.name).trim() : '';
                            const name = cleanText(rawName);
                            const tags = el.tags || {};
                            const dist = (isFinite(cLat) && isFinite(cLon))
                                ? distanceMeters(lat, lon, cLat, cLon)
                                : 999999;
                            return {
                                tags: tags,
                                dist: dist,
                                lat: cLat || 0,
                                lon: cLon || 0,
                                priority: poiPriority(tags, name),
                                maxDistance: getPoiMaxDistance(tags, name, addressText),
                                typeLabel: getPoiTypeLabel(tags)
                        .filter(x => x.name);
                    if (!candidates.length) {
                        log(`${person.key}: Overpass lieferte Objekte, aber keinen benannten Kandidaten.`, 'info');
                    candidates.sort((a, b) => {
                        if (a.priority !== b.priority) return a.priority - b.priority;
                        return a.dist - b.dist;
                    if (DEBUG_LOG_POI_CANDIDATES) {
                        log(`${person.key}: POI-Kandidaten Radius ${radius} m: ${JSON.stringify(candidates)}`, 'info');
                    for (const candidate of candidates) {
                        if (candidate.dist <= candidate.maxDistance) {
                            log(
                                `${person.key}: POI akzeptiert: ${candidate.name} (${candidate.typeLabel}, Distanz ${candidate.dist.toFixed(1)} m, erlaubt ${candidate.maxDistance} m)`,
                                'info'
                            return { poi: candidate, hadCandidates: true, overpassFailed: false };
                        } else if (DEBUG_LOG_REJECTED_POIS) {
                            log(
                                `${person.key}: POI verworfen: ${candidate.name} (${candidate.typeLabel}, Distanz ${candidate.dist.toFixed(1)} m, erlaubt ${candidate.maxDistance} m)`,
                                'info'
                    log(`${person.key}: Kein POI bestand die Distanz-/Prioritätsprüfung im Radius ${radius} m.`, 'info');
                    return { poi: null, hadCandidates: true, overpassFailed: false };
                function poiPriority(tags, name) {
                    const poiName = String(name || '').toLowerCase();
                    if (tags.amenity === 'fire_station') return 1;
                    if (tags.amenity === 'school') return 1;
                    if (tags.amenity === 'kindergarten') return 1;
                    if (tags.amenity === 'hospital') return 1;
                    if (tags.amenity === 'clinic') return 1;
                    if (tags.shop === 'supermarket') return 1;
                    if (
                        poiName.includes('schule') ||
                        poiName.includes('grundschule') ||
                        poiName.includes('realschule') ||
                        poiName.includes('gymnasium')
                    ) return 1;
                    if (tags.office === 'energy_supplier') return 2;
                    if (tags.office === 'company') return 3;
                    if (tags.building === 'office') return 4;
                    if (tags.shop === 'bakery') return 8;
                    if (tags.shop === 'kiosk') return 8;
                    if (tags.shop === 'convenience') return 7;
                    if (tags.shop) return 2;
                    if (tags.amenity) return 3;
                    if (tags.tourism) return 4;
                    if (tags.leisure) return 5;
                    if (tags.office) return 6;
                    return 99;
                function getPoiMaxDistance(tags, name, addressText) {
                    const addr = String(addressText || '').toLowerCase();
                    if (tags.amenity === 'hospital') return 90;
                    if (tags.amenity === 'fire_station') return 70;
                    if (tags.amenity === 'school') {
                        let dist = 60;
                        if (
                            dist = 90;
                        if (
                            addr.includes('schulstraße') ||
                            addr.includes('schule') ||
                            addr.includes('bobenheim-roxheim')
                            dist = 130;
                        return dist;
                    if (tags.amenity === 'kindergarten') return 60;
                    if (tags.amenity === 'clinic') return 50;
                    if (tags.shop === 'supermarket') return 40;
                    if (tags.office === 'energy_supplier') return 40;
                    if (tags.office === 'company') return 35;
                    if (tags.building === 'office') return 30;
                    if (tags.shop === 'bakery') return 15;
                    if (tags.shop === 'kiosk') return 15;
                    if (tags.shop === 'convenience') return 20;
                    if (tags.shop) return 25;
                    if (tags.amenity) return 30;
                    if (tags.tourism) return 30;
                    if (tags.leisure) return 25;
                    if (tags.office) return 25;
                    return 20;
                function getPoiTypeLabel(tags) {
                    if (tags.amenity) return `amenity=${tags.amenity}`;
                    if (tags.shop) return `shop=${tags.shop}`;
                    if (tags.tourism) return `tourism=${tags.tourism}`;
                    if (tags.leisure) return `leisure=${tags.leisure}`;
                    if (tags.office) return `office=${tags.office}`;
                    if (tags.building) return `building=${tags.building}`;
                    return 'unknown';
                function isStablePoiType(typeLabel) {
                    const t = String(typeLabel || '').toLowerCase();
                    return (
                        t.includes('amenity=school') ||
                        t.includes('amenity=fire_station') ||
                        t.includes('amenity=hospital') ||
                        t.includes('amenity=clinic') ||
                        t.includes('amenity=kindergarten') ||
                        t.includes('shop=supermarket') ||
                        t.includes('office=company') ||
                        t.includes('office=energy_supplier') ||
                        t.includes('building=office')
                function httpGetAsync(url, headers) {
                    return new Promise((resolve, reject) => {
                        httpGet(url, { headers: headers, timeout: 15000 }, (err, response) => {
                            if (err) return reject(err);
                            resolve(response);
                function httpPostAsync(url, body, headers) {
                        httpPost(url, body, { headers: headers, timeout: 20000 }, (err, response) => {
                            resolve(response);
                function sleep(ms) {
                    return new Promise(resolve => setTimeout(resolve, ms));
                function distanceMeters(lat1, lon1, lat2, lon2) {
                    const R = 6371000;
                    const toRad = deg => deg * Math.PI / 180;
                    const dLat = toRad(lat2 - lat1);
                    const dLon = toRad(lon2 - lon1);
                    const a =
                        Math.sin(dLat / 2) * Math.sin(dLat / 2) +
                        Math.cos(toRad(lat1)) * Math.cos(toRad(lat2)) *
                        Math.sin(dLon / 2) * Math.sin(dLon / 2);
                    return 2 * R * Math.atan2(Math.sqrt(a), Math.sqrt(1 - a));
                function round1(v) {
                    return Math.round(Number(v || 0) * 10) / 10;
                function cleanText(str) {
                    return String(str || '')
                        .replace(/\s+/g, ' ')
                        .replace(/\s+,/g, ',')
                        .trim();
                function createStateIfMissing(id, def, type, name) {
                    if (!existsState(id)) {
                        createState(id, def, {
                            type: type,
                            role: type === 'number' ? 'value' : 'text',
                            read: true,
                            write: true
                Beta-Tester
                  BananaJoeB Online
                  BananaJoeB Online
                  BananaJoe
                  #135
                  @Merlin123 naja, alles von Bots.
                  Dann anders: Bluefox pflegt den Adapter. Das sollte wohl beruhigen.
                  • skvarelS Online
                    skvarelS Online
                    skvarel
                    #136
                    Ich bastel gerade an einem 'Fahrtenbuch'
                    Die erste Idee ist ein json alas Ausgabe. Pro Person ein json in der jeder Änderung der Koordinaten in eine Tabelle geschrieben werden.
                    An die Historie-Daten in der App komme ich leider nicht ran, also muss eine eigene Logik her.
                    Man könnte es auch über den History Adapter machen, da zwingt man aber User zu einem weiteren Adapter. Ich fänd es schöner, wenn dieser Adapter es direkt bereitstellt.
                    EDIT:
                    Ich teste es morgen bei mir mit einem Script und werde es dann ggf. in den Adapter setzen.
                    Erstmal nur als json (per Config de- und aktivierbar) .... dann vielleicht auch als Karte ?!
                    #TeamInventwo
                    Unsere Adapter:
                    • skvarelS Online
                      skvarelS Online
                      skvarel
                      #137
                      Ich schaue mir gearde das Thema 'GeoJSON' an. Das könnte genau das passende sein.
                      #TeamInventwo
                      Unsere Adapter:
                      • C Online
                        C Online
                        Chrille1507
                        #138
                        Ich bekomme gerade folgende Fehler im Log (siehe Anhang). Geht es anderen hier auch so?
                        skvarelS 2 Antworten Letzte Antwort
                        • C Chrille1507
                          skvarelS Online
                          skvarelS Online
                          skvarel
                          #139
                          @Chrille1507 .. lief der Adapter schon fehlerfrei bei dir oder ist das direkt nach der ersten Installation?
                          #TeamInventwo
                          Unsere Adapter:
                          C 1 Antwort Letzte Antwort
                          • C Chrille1507
                            skvarelS Online
                            skvarelS Online
                            skvarel
                            #140
                            @Chrille1507 .. der Fehler sieht nach einem falschen Token aus. Siehe hier: #29
                            #TeamInventwo
                            Unsere Adapter:
                            • skvarelS skvarel
                              C Online
                              C Online
                              Chrille1507
                              #141
                              @skvarel Hallo, der Adapter lief vorher schon und auch ohne Probleme.
                              Edit: Aktuell läuft er wieder sauber durch ohne Fehlermeldungen.
                              • skvarelS Online
                                skvarelS Online
                                skvarel
                                #142
                                Heute starte ich mit dem Testlauf vom 'Fahrtenbuch' :)
                                Jeden Tag wird ein neues GeoJSON mit dem Tagesdatum angelegt. In dem json sind dann alle Bewegungen über 20m hinterlegt.
                                Die 20m werden später über die Config einstellbar werden (wird benötigt um Gezappel zu unterbinden) und man dann auch auswählen, für welche Person man ein Fahrtenbuch möchte.
                                Per Datenpunkt lässt sich das Fahrtenbuch dann zusätzlich de-/aktivieren.
                                So zumindest der Plan ;)
                                Zur Zeit läuft es nur als Script in meinem ioBroker. Ich denke, zum Wochenende habe ich genügend Werte um es eventuell in den Adapter zu bauen.
                                #TeamInventwo
                                Unsere Adapter:
                                • skvarelS Online
                                  skvarelS Online
                                  skvarel
                                  #143
                                  Frage .... gibt es hier User, die die Anbindung an den Places-Adapter benötigen?
                                  Da ich ja den alten Code übernommen hatte, überlege ich gerade etwas aufzuräumen.
                                  Das wäre die neue Config, ohne Places-Adapter
                                  #TeamInventwo
                                  Unsere Adapter:
                                    Merlin123M Offline
                                    Merlin123
                                    #144
                                    ich brauche den Places Adapter mal nicht.... Hatte ja weiter oben schon gefragt, was der Vorteil davon wäre....
                                    Beta-Tester
                                    • skvarelS Online
                                      skvarelS Online
                                      skvarel
                                      #145
                                      Da ich vor habe, so viel wie möglich in dem Life360ng abzubilden, wird der Places auch nicht benötigt bzw. bietet dann aus meiner Sicht keinen Mehrwert. Gerade dann, wenn das mit dem Fahrtenbuch (History) sauber klappt.
                                      #TeamInventwo
                                      Unsere Adapter:
                                      • skvarelS Online
                                        skvarelS Online
                                        skvarel
                                        #146
                                        Info:
                                        Da bei der Aufmahme ins Latest-Repo einige Fehlern im Code angemerkt wurden, verzögert sich die Aufnahme ins Repo und dadurch auch das Fahrtenbuch. Das wird es diesen Monat leider noch nicht geben.
                                        Ich halte euch auf dem Laufenden!
                                        #TeamInventwo
                                        Unsere Adapter:
                                        • skvarelS Online
                                          skvarelS Online
                                          skvarel
                                          #147
                                          Kurzes Update:
                                          Wir arbeiten mit Hochdruck an der Aufnahme ins Latest-Repo. Ich habe eine Testversion auf Github geladen (noch nicht bei npm).
                                          Ich habe Hoffnung, das ich zusammen mit Perplexity das Meiste behoben habe. @jkvarel guckt da noch mal drüber.
                                          Neue Config: Integration des Places Adapter ist raus.
                                          Es wird einen Versionssprung geben. Von 1.0.21 auf 1.1.0 !!
                                          Da gibt es etwas zu beachten:
                                          Nach dem Update, einmal bitte alle Datenpunkte löschen und die Instanz neu starten
                                          Das betrifft nur User, die von der 1.0.x kommen.
                                          Bei einer Erstinstallation der zukünftigen 1.1.0 passt es direkt
                                          Es müssten KEINE Scripte oder Views angepasst werden! Die IDs haben sich NICHT geändert. Es ging hier nur um channel -> device ... device -> channel
                                          An den states hat sich nichts geändert.
                                          #TeamInventwo
                                          Unsere Adapter:
