  4. sourceanalytix -Fehler keine Rücksetzung der Werte
    6.4k
sourceanalytixfehlerproblem
49 Beiträge 7 Kommentatoren 2.5k Aufrufe 5 Beobachtet
  • Q Offline
    Q Offline
    quinti
    Hallo @zsmmn,
    habe beim sourceanalytix Adapter seit eingen Wochen das Porblem, dass Montags die Tageseswerte nicht zurück gesetzt werden.
    Es schein ein Problem mit den Wochenwerten zu sein.
    Log:
    sourceanalytix.1	2026-04-13 00:00:00.750	error	Error: DB closed
    sourceanalytix.1	2026-04-13 00:00:00.617	error	Error: DB closed
    sourceanalytix.1	2026-04-13 00:00:00.617	warn	get state error: Connection is closed.
    sourceanalytix.1	2026-04-13 00:00:00.616	warn	Could not perform strict object check of state sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.meterReadings.currentWeek.03_Wednesday: DB closed
    sourceanalytix.1	2026-04-13 00:00:00.475	warn	State "sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.costs.currentWeek.03_Wednesday" has no existing object, this might lead to an error in future versions
    sourceanalytix.1	2026-04-13 00:00:00.472	warn	State "sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.costs.previousWeek.03_Wednesday" has no existing object, this might lead to an error in future versions
    sourceanalytix.1	2026-04-13 00:00:00.416	warn	State "sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.costs.currentWeek.02_Tuesday" has no existing object, this might lead to an error in future versions
    sourceanalytix.1	2026-04-13 00:00:00.372	warn	State "sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.costs.previousWeek.02_Tuesday" has no existing object, this might lead to an error in future versions
    sourceanalytix.1	2026-04-13 00:00:00.298	warn	State "sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.costs.currentWeek.01_Monday" has no existing object, this might lead to an error in future versions
    sourceanalytix.1	2026-04-13 00:00:00.255	warn	State "sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.costs.previousWeek.01_Monday" has no existing object, this might lead to an error in future versions
    sourceanalytix.1	2026-04-13 00:00:00.203	warn	State "sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.costs.currentWeek.07_Sunday" has no existing object, this might lead to an error in future versions
    sourceanalytix.1	2026-04-13 00:00:00.137	warn	State "sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.costs.previousWeek.07_Sunday" has no existing object, this might lead to an error in future versions
    habe letzten Montag den State der im log auftauchte gelöscht. Diese Woche ist jetzt aber ein anderer Wert betroffen.
    crunchipC Ro75R 2 Antworten Letzte Antwort
    • Q quinti
      Hallo @zsmmn,
      Log:
      crunchipC Offline
      crunchipC Offline
      @quinti was soll nicht zurückgesetzt werden und warum löscht du etwas?
      Error: DB closed scheinst wohl eher andere Probleme zu haben
      • Q Offline
        Q Offline
        quinti
        es sollen wir immer die Werte
        sourceanalytix.xxx.currentYear.consumed.01_currentDay
        verarbeitet und auf null für den den neuen Tag gesetzt werden.
        Hat immer zuverlässig funktioniert. Jetzt aber nicht mehr
        • Q quinti
          crunchipC Offline
          crunchipC Offline
          @quinti und was hast du vor ner Woche gemacht? Aus heiterem Himmel ändert sich ja nichts
          • skvarelS Offline
            skvarelS Offline
            skvarel
            schrieb am zuletzt editiert von skvarel
            War das nicht schon immer so? Ich habe mir dafür extra Scripte erstellt, damit ich mit einer leeren Woche anfange.
            EDIT:
            Das wurde bei irgendeinem Update gefixed. Ich erinnere mich schwach daran.
            #TeamInventwo
            Unsere Adapter:
            • skvarelS skvarel
              EDIT:
              crunchipC Offline
              crunchipC Offline
              @skvarel sagte:
              @quinti sagte:
              currentDay startet immer um 0:00 bei 0
              was steht denn direkt darunter für ein Wert bei ....previousDay?
              @quinti sagte:
              stimmt vllt bei deinem System etwas nicht, z.b. erster Tag der Woche
              • Q Offline
                Q Offline
                quinti
                ich nutze den Adapter seit Jahren, hatte nie Probleme und auch bewusst nicht am System geändert. Grundeinstellung vom iobroker habe ich glaube ich noch nie geändert.
                Seit ein paar Wochen habe ich Montags, dass die Tageswerte nicht zurück gesetzt werden, also die states mit currentYear.consumed.01_currentDay hinten.
                Beim Wechsel Monat auf Dienstag wurden dann die Berechnungen immer normal durchgeführt.
                Heute dann zum ersten Mal der Fall das 2 Tage nach Gang nicht funktioniert.
                Die previousDay Werte werden nicht dabei geschrieben, siehe screenshots von gerade 14.04.2026. Heute noch der Wert vom Wechsel Samstag/Sonntag.
                Ich werde mal die beteilgten Adapter auf loglevel info stellen über MItternacht, also
                -sourceanalytix
                -sql (ist als Standard im iobroker hinterlegt)
                -javascript
                • Q quinti
                  Hallo @zsmmn,
                  Log:
                  Ro75R Offline
                  Ro75R Offline
                  Ro75
                  @quinti sagte:
                  Was ist denn damit?
                  Zu wenig Speicher? Datenträger voll? beschädigt?
                  iob diag?
                  Ro75.
                  • Q quinti
                    -sourceanalytix
                    -javascript
                    crunchipC Offline
                    crunchipC Offline
                    @quinti sagte:
                    ich würde eher mal darauf achten ob Werte übertragen werden zu dem Zeitraum Mitternacht, denn wenn kein Wert reinkommt, wird auch nicht weitergezählt.
                    also würde ich eher da mal ansetzen
                    @quinti sagte:
                    • Q Offline
                      Q Offline
                      quinti
                      hatte ich vergessen anzuhängen :)
                      • Q quinti
                        crunchipC Offline
                        crunchipC Offline
                        @quinti ist Instanz 1 eigentlich bewusst beabsichtigt? oder laufen da sogar 2 Instanzen?
                        • Q Offline
                          Q Offline
                          quinti
                          ja, da laufen 2 instanzen. Instanz 1 aktiv. Instanz 0 ist nur noch da, weil da ein paar historische Werte drin sind, die ich gerne aufbewahren möchte.
                          • Q Offline
                            Q Offline
                            quinti
                            iob diagiob diag.txt
                            bash
                            Script v.2026-01-31
                            *** BASE SYSTEM ***
                             Static hostname: iobroker
                                   Icon name: computer-container
                                     Chassis: container ☐
                              Virtualization: lxc
                                      Kernel: Linux 6.8.4-3-pve
                                Architecture: x86-64
                            OS is similar to:
                            model name      : Intel(R) Core(TM) i7-6700T CPU @ 2.80GHz
                            Docker          : false
                            Virtualization  : lxc
                            Kernel          : x86_64
                            Userland        : 64 bit
                            Systemuptime and Load:
                             19:05:54 up 2 min,  2 users,  load average: 1.00, 1.24, 1.33
                            CPU threads: 3
                            *** LIFE CYCLE STATUS ***
                            Operating System is the current Debian stable version codenamed 'bookworm'!
                            *** TIME AND TIMEZONES ***
                                           Local time: Tue 2026-04-14 19:05:54 CEST
                                       Universal time: Tue 2026-04-14 17:05:54 UTC
                                             RTC time: n/a
                                          NTP service: n/a
                                      RTC in local TZ: no
                            *** Users and Groups ***
                            User that called 'iob diag':
                            hermann
                            HOME=/home/hermann
                            GROUPS=hermann adm dialout sudo plugdev users iobroker
                            js-controller is not running
                            *** DISPLAY-SERVER SETUP ***
                            Display-Server:         false
                            Unit display-manager.service could not be found.
                            Display-Manager:
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Mem:            8.6G         56M        8.1G        139K        409M        8.5G
                            Swap:           8.6G          0B        8.6G
                            Total:           17G         56M         16G
                            Active iob-Instances:   1
                                     8192 M total memory
                                       54 M used memory
                                      206 M active memory
                                      207 M inactive memory
                                     7747 M free memory
                                        0 M buffer memory
                                      390 M swap cache
                                     8191 M total swap
                                        0 M used swap
                                     8191 M free swap
                            top - 19:05:54 up 2 min,  2 users,  load average: 1.00, 1.24, 1.33
                            Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   8192.0 total,   7745.6 free,     55.6 used,    391.0 buff/cache
                            MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.   8136.4 avail Mem
                            *** FAILED SERVICES ***
                              UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                            * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                            * iobroker.service     loaded failed failed ioBroker Server
                            2 loaded units listed.
                            *** DMESG CRITICAL ERRORS ***
                            dmesg: read kernel buffer failed: Operation not permitted
                            No critical errors detected
                            *** FILESYSTEM ***
                            /dev/loop2     ext4       24G   10G   13G  45% /
                            none           tmpfs     492K  4.0K  488K   1% /dev
                            udev           devtmpfs   32G     0   32G   0% /dev/tty
                            tmpfs          tmpfs      32G     0   32G   0% /dev/shm
                            tmpfs          tmpfs      13G  132K   13G   1% /run
                            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                            tmpfs          tmpfs     6.3G     0  6.3G   0% /run/user/1000
                            Show mounted filesystems:
                            TARGET SOURCE     FSTYPE OPTIONS
                            /      /dev/loop2 ext4   rw,relatime
                            /var:
                            605M    /var/
                            282M    /var/log/journal/bb1a573610aa48a7948bbf161935960d
                            282M    /var/log
                            231M    /var/lib
                            Archived and active journals take up 281.1M in the file system.
                            /opt/iobroker/backups:
                            507M    /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            769M    /opt/iobroker/iobroker-data/
                            558M    /opt/iobroker/iobroker-data/files
                            217M    /opt/iobroker/iobroker-data/files/vis-2
                            141M    /opt/iobroker/iobroker-data/files/vis-2/assets
                            135M    /opt/iobroker/iobroker-data/backup-objects
                            43M     /opt/iobroker/iobroker-data/objects.jsonl
                            34M     /opt/iobroker/iobroker-data/states.jsonl
                            34M     /opt/iobroker/iobroker-data/files/vis-2/assets/index-DqJdyjgH.js.map
                            34M     /opt/iobroker/iobroker-data/files/vis-2/assets/index-CrLrNq4s.js.map
                            20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
                            USB-Devices by-id:
                            USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                            please always prefer the links 'by-id':
                            No Devices found 'by-id'
                            No nvbackup.json found.
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v24.5.0
                            /usr/bin/node           v24.5.0
                            /usr/bin/npm            11.5.1
                            /usr/bin/npx            11.5.1
                            ✓ Node.js installation is correct
                            nodejs:
                              Installed: 24.5.0-1nodesource1
                              Candidate: 24.14.1-1nodesource1
                              Version table:
                                 24.14.1-1nodesource1 600
                                    500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages
                                 24.14.0-1nodesource1 600
                                 24.13.1-1nodesource1 600
                                 24.13.0-1nodesource1 600
                                 24.12.0-1nodesource1 600
                                 24.11.1-1nodesource1 600
                                 24.11.0-1nodesource1 600
                                 24.10.0-1nodesource1 600
                                 24.9.0-1nodesource1 600
                                 24.8.0-1nodesource1 600
                                 24.7.0-1nodesource1 600
                                 24.6.0-1nodesource1 600
                             *** 24.5.0-1nodesource1 600
                                 24.4.1-1nodesource1 600
                                 24.4.0-1nodesource1 600
                                 24.3.0-1nodesource1 600
                                 24.1.0-1nodesource1 600
                                 24.0.2-1nodesource1 600
                                 24.0.1-1nodesource1 600
                                 24.0.0-1nodesource1 600
                                 18.20.4+dfsg-1~deb12u1 500
                                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                    500 http://security.debian.org bookworm-security/main amd64 Packages
                            No problems detected
                            Errors in npm tree: 0
                            The current Node.js version (v24.5.0) is vulnerable to the following CVEs:
                            CVE-2025-55130(high): A flaw in Node.js’s Permissions model allows attackers to bypass `--allow-fs-read` and `--allow-fs-write` restrictions using crafted relative symlink paths. By chaining directories and symlinks, a script granted access only to the current directory can escape the allowed path and read sensitive files. This breaks the expected isolation guarantees and enables arbitrary file read/write, leading to potential system compromise.
                            This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
                            Patched versions: ^20.20.0 || ^22.22.0 || ^24.13.0 || ^25.3.0
                            CVE-2025-55131(high): A flaw in Node.js's buffer allocation logic can expose uninitialized memory when allocations are interrupted, when using the `vm` module with the timeout option. Under specific timing conditions, buffers allocated with `Buffer.alloc` and other `TypedArray` instances like `Uint8Array` may contain leftover data from previous operations, allowing in-process secrets like tokens or passwords to leak or causing data corruption. While exploitation typically requires precise timing or in-process code execution, it can become remotely exploitable when untrusted input influences workload and timeouts, leading to potential confidentiality and integrity impact.
                            CVE-2025-55132(low): A flaw in Node.js's permission model allows a file's access and modification timestamps to be changed via `futimes()` even when the process has only read permissions. Unlike `utimes()`, `futimes()` does not apply the expected write-permission checks, which means file metadata can be modified in read-only directories. This behavior could be used to alter timestamps in ways that obscure activity, reducing the reliability of logs. This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
                            CVE-2025-59464(medium): A memory leak in Node.js’s OpenSSL integration occurs when converting `X.509` certificate fields to UTF-8 without freeing the allocated buffer. When applications call `socket.getPeerCertificate(true)`, each certificate field leaks memory, allowing remote clients to trigger steady memory growth through repeated TLS connections. Over time this can lead to resource exhaustion and denial of service.
                            CVE-2025-59465(high): A malformed `HTTP/2 HEADERS` frame with oversized, invalid `HPACK` data can cause Node.js to crash by triggering an unhandled `TLSSocket` error `ECONNRESET`. Instead of safely closing the connection, the process crashes, enabling a remote denial of service. This primarily affects applications that do not attach explicit error handlers to secure sockets, for example:
                            server.on('secureConnection', socket => {
                            socket.on('error', err => {
                            console.log(err)
                            CVE-2025-59466(medium): We have identified a bug in Node.js error handling where "Maximum call stack size exceeded" errors become uncatchable when `async_hooks.createHook()` is enabled. Instead of reaching `process.on('uncaughtException')`, the process terminates, making the crash unrecoverable. Applications that rely on `AsyncLocalStorage` (v22, v20) or `async_hooks.createHook()` (v24, v22, v20) become vulnerable to denial-of-service crashes triggered by deep recursion under specific conditions.
                            CVE-2026-21637(high): A flaw in Node.js TLS error handling leaves `SNICallback` invocations unprotected against synchronous exceptions, while the equivalent ALPN and PSK callbacks were already addressed in CVE-2026-21637. This represents an incomplete fix of that prior vulnerability.
                            When an `SNICallback` throws synchronously on unexpected input the exception bypasses TLS error handlers and propagates as an uncaught exception, crashing the Node.js process.
                            * This vulnerability affects all Node.js versions that received the CVE-2026-21637 fix, including **20.x, 22.x, 24.x, and 25.x**, on any TLS server where `SNICallback` may throw on unexpected `servername` input.
                            Patched versions: ^20.20.2 || ^22.22.2 || ^24.14.1 || ^25.8.2
                            CVE-2026-21710(high): A flaw in Node.js HTTP request handling causes an uncaught `TypeError` when a request is received with a header named `__proto__` and the application accesses `req.headersDistinct`.
                            When this occurs, `dest["__proto__"]` resolves to `Object.prototype` rather than `undefined`, causing `.push()` to be called on a non-array. This exception is thrown synchronously inside a property getter and cannot be intercepted by `error` event listeners, meaning it cannot be handled without wrapping every `req.headersDistinct` access in a `try/catch`.
                            * This vulnerability affects all Node.js HTTP servers on **20.x, 22.x, 24.x, and v25.x**
                            CVE-2026-21712(medium): A flaw in Node.js URL processing causes an assertion failure in native code when `url.format()` is called with a malformed internationalized domain name (IDN) containing invalid characters, crashing the Node.js process.
                            * This vulnerability affects **24.x and 25.x**.
                            Patched versions: ^24.14.1 || ^25.8.2
                            CVE-2026-21713(medium): A flaw in Node.js HMAC verification uses a non-constant-time comparison when validating user-provided signatures, potentially leaking timing information proportional to the number of matching bytes. Under certain threat models where high-resolution timing measurements are possible, this behavior could be exploited as a timing oracle to infer HMAC values.
                            Node.js already provides timing-safe comparison primitives used elsewhere in the codebase, indicating this is an oversight rather than an intentional design decision.
                            This vulnerability affects **20.x, 22.x, 24.x, and 25.x**.
                            CVE-2026-21714(medium): A memory leak occurs in Node.js HTTP/2 servers when a client sends WINDOW_UPDATE frames on stream 0 (connection-level) that cause the flow control window to exceed the maximum value of 2³¹-1. The server correctly sends a GOAWAY frame, but the Http2Session object is never cleaned up.
                            This vulnerability affects HTTP2 users on Node.js 20, 22, 24 and 25.
                            CVE-2026-21715(low): A flaw in Node.js Permission Model filesystem enforcement leaves `fs.realpathSync.native()` without the required read permission checks, while all comparable filesystem functions correctly enforce them.
                            As a result, code running under `--permission` with restricted `--allow-fs-read` can still use `fs.realpathSync.native()` to check file existence, resolve symlink targets, and enumerate filesystem paths outside of permitted directories.
                            This vulnerability affects **20.x, 22.x, 24.x, and 25.x** processes using the Permission Model where `--allow-fs-read` is intentionally restricted.
                            CVE-2026-21716(low): An incomplete fix for CVE-2024-36137 leaves `FileHandle.chmod()` and `FileHandle.chown()` in the promises API without the required permission checks, while their callback-based equivalents (`fs.fchmod()`, `fs.fchown()`) were correctly patched.
                            As a result, code running under `--permission` with restricted `--allow-fs-write` can still use promise-based `FileHandle` methods to modify file permissions and ownership on already-open file descriptors, bypassing the intended write restrictions.
                            This vulnerability affects **20.x, 22.x, 24.x, and 25.x** processes using the Permission Model where `--allow-fs-write` is intentionally restricted.
                            CVE-2026-21717(medium): A flaw in V8's string hashing mechanism causes integer-like strings to be hashed to their numeric value, making hash collisions trivially predictable. By crafting a request that causes many such collisions in V8's internal string table, an attacker can significantly degrade performance of the Node.js process.
                            The most common trigger is any endpoint that calls `JSON.parse()` on attacker-controlled input, as JSON parsing automatically internalizes short strings into the affected hash table.
                            *** ioBroker-Installation ***
                            ioBroker Status
                            iobroker is not running on this host.
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            iobroker            iobroker (version: 7.1.0, hostname: iobroker      , alive, uptime: 17)
                            Core adapters versions
                            js-controller:  7.1.0
                            admin:          7.8.20
                            javascript:     9.1.1
                            nodejs modules from github:     2
                            +-- iobroker.ecovacs-deebot@1.4.16-alpha.7 (git+ssh://git@github.com/mrbungle64/ioBroker.ecovacs-deebot.git#2b8cdedde82e5f0d7057d3403e9cf45fc7a02d0c)
                            +-- iobroker.klipper-moonraker@0.1.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.klipper-moonraker.git#0d2851e98f7443e85ebe29d98d8d725640dd0a8a)
                            Adapter State
                              system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                              system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                              system.adapter.awattar.0                : awattar               : iobroker                                 -  enabled
                              system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                              system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
                              system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 -  enabled
                              system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                              system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
                              system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                              system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                              system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
                              system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
                              system.adapter.gotify.0                 : gotify                : iobroker                                 -  enabled
                              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                              system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                              system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                              system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                              system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                              system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                              system.adapter.klipper-moonraker.0      : klipper-moonraker     : iobroker                                 - disabled
                              system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.101.102
                              system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
                              system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
                              system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                              system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                              system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
                              system.adapter.node-red.0               : node-red              : iobroker                                 - disabled, port: 1880, bind: 0.0.0.0
                              system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
                              system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                              system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                              system.adapter.pirate-weather.0         : pirate-weather        : iobroker                                 -  enabled
                              system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                              system.adapter.renault.0                : renault               : iobroker                                 -  enabled
                              system.adapter.rickshaw.0               : rickshaw              : iobroker                                 - disabled
                              system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                              system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                              system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                              system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                              system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                              system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
                              system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                              system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : iobroker                                 - disabled, port: 9000
                              system.adapter.sureflap.0               : sureflap              : iobroker                                 -  enabled
                              system.adapter.traccar.0                : traccar               : iobroker                                 -  enabled
                              system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                              system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                              system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: iobroker                                 -  enabled
                              system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 - disabled
                              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
                              system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                              system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
                              system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                              system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                              system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                              system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
                              system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                              system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                              system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                              system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                              system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                              system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
                              system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                            + instance is alive
                            ioBroker-Repositories
                            │ (index) │ name      │ url        │ auto upgrade │
                            │ 0       │ 'sources' │ 'conf/sources-dist.json'        │ false        │
                            │ 1       │ 'online'  │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json' │ false        │
                            │ 2       │ 'stable'  │ 'http://download.iobroker.net/sources-dist.json'                                            │ false        │
                            │ 3       │ 'beta'    │ 'http://download.iobroker.net/sources-dist-latest.json'                                     │ false        │
                            Active repo(s): online, beta
                            Upgrade policy: none
                            Installed ioBroker-Adapters
                            Used repositories: online, beta
                            Cannot download repository hash file from "https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist-hash.json": Request failed with status code 404
                            Adapter    "admin"        : 7.8.20   , installed 7.8.20
                            Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                            Adapter    "alias-manager": 2.1.0    , installed 2.1.0
                            Adapter    "awattar"      : 1.0.6    , installed 1.0.6
                            Adapter    "backitup"     : 3.3.15   , installed 3.3.15
                            Adapter    "denon"        : 1.15.12  , installed 1.15.12
                            Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.16-alpha.7
                            Adapter    "energiefluss-erweitert": 0.8.2, installed 0.8.2
                            Adapter    "evcc"         : 0.2.8    , installed 0.2.8
                            Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
                            Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
                            Adapter    "fullybrowser" : 3.1.3    , installed 3.1.3
                            Adapter    "gotify"       : 0.5.0    , installed 0.5.0
                            Adapter    "ical"         : 1.20.0   , installed 1.20.0
                            Adapter    "iot"          : 6.0.1    , installed 6.0.1
                            Adapter    "javascript"   : 9.2.0    , installed 9.1.1  [Updatable]
                            Controller "js-controller": 7.1.1    , installed 7.1.0  [Updatable]
                            Adapter    "knx"          : 2.0.39   , installed 2.0.39
                            Adapter    "mihome-vacuum": 5.3.0    , installed 5.3.0
                            Adapter    "nina"         : 0.0.26   , installed 0.0.26
                            Adapter    "node-red"     : 6.0.7    , installed 6.0.7
                            Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                            Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                            Adapter    "ping"         : 2.1.0    , installed 2.1.0
                            Adapter    "pirate-weather": 0.8.0   , installed 0.8.0
                            Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
                            Adapter    "renault"      : 0.0.22   , installed 0.0.22
                            Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                            Adapter    "scenes"       : 4.0.4    , installed 4.0.4
                            Adapter    "shelly"       : 10.6.1   , installed 10.6.1
                            Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                            Adapter    "socketio"     : 7.1.3    , installed 7.1.3
                            Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
                            Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                            Adapter    "sql"          : 3.0.1    , installed 3.0.1
                            Adapter    "squeezeboxrpc": 1.6.4    , installed 1.6.4
                            Adapter    "sureflap"     : 3.4.2    , installed 3.4.2
                            Adapter    "traccar"      : 1.1.7    , installed 1.1.6  [Updatable]
                            Adapter    "tuya"         : 3.17.0   , installed 3.17.0
                            Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                            Adapter    "unifi-network": 1.4.0    , installed 1.4.0
                            Adapter    "vis-2"        : 2.13.17  , installed 2.13.17
                            Adapter    "vis-2-widgets-collection": 2.4.1, installed 2.4.1
                            Adapter    "vis-2-widgets-inventwo": 0.6.5, installed 0.6.5
                            Adapter    "vis-2-widgets-material": 1.6.1, installed 1.6.1
                            Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
                            Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
                            Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                            Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
                            Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                            Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
                            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                            Adapter    "web"          : 8.1.0    , installed 8.1.0
                            Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                            Adapter    "worx"         : 3.3.0    , installed 3.3.0
                            Adapter    "ws"           : 4.1.0    , installed 4.1.0
                            Objects and States
                            Objects:        31715
                            States:         30867
                            W: https://packages.microsoft.com/ubuntu/16.04/prod/dists/xenial/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                            Hit:1 http://security.debian.org bookworm-security InRelease
                            Hit:2 http://deb.debian.org/debian bookworm InRelease
                            Hit:4 https://packages.microsoft.com/ubuntu/16.04/prod xenial InRelease
                            Hit:5 https://deb.nodesource.com/node_24.x nodistro InRelease
                            Reading package lists...
                            Pending systemupdates: 102
                            *** Listening Ports ***
                            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          839430941  330/master
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          839431662  1/init
                            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          839430942  330/master
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          839431664  1/init
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          839433330  1/init
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          839431663  1/init
                            udp        0      0 192.168.101.102:123     0.0.0.0:*                           0          839433415  168/ntpd
                            udp        0      0 192.168.0.102:123       0.0.0.0:*                           0          839433413  168/ntpd
                            udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          839433411  168/ntpd
                            udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          839433407  168/ntpd
                            udp6       0      0 :::111                  :::*                                0          839431665  1/init
                            udp6       0      0 fe80::be24:11ff:fe3:123 :::*                                106        839433669  168/ntpd
                            udp6       0      0 fd6d:f83d:ff15:0:be:123 :::*                                106        839433667  168/ntpd
                            udp6       0      0 fe80::be24:11ff:fe0:123 :::*                                106        839433665  168/ntpd
                            udp6       0      0 fd6d:f83d:ff15:0:be:123 :::*                                106        839433663  168/ntpd
                            udp6       0      0 ::1:123                 :::*                                0          839433417  168/ntpd
                            udp6       0      0 :::123                  :::*                                0          839433404  168/ntpd
                            2026-04-14 19:03:42.345  - warn: host.iobroker instance system.adapter.ping.0 terminated due to SIGKILL
                            2026-04-14 19:03:42.359  - warn: host.iobroker instance system.adapter.iot.0 terminated due to SIGKILL
                            2026-04-14 19:03:42.359  - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGKILL
                            2026-04-14 19:03:55.082  - warn: admin.0 (343) Cannot update news: ETIMEDOUT
                            2026-04-14 19:04:10.715  - error: host.iobroker Caught by controller[0]: (node:415) [DEP0176] DeprecationWarning: fs.F_OK is deprecated, use fs.constants.F_OK instead
                            2026-04-14 19:04:10.718  - error: host.iobroker Caught by controller[0]: (Use `node --trace-deprecation ...` to show where the warning was created)
                            2026-04-14 19:04:10.718  - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGTERM
                            2026-04-14 19:04:11.307  - warn: admin.0 (343) get state error: Connection is closed.
                            2026-04-14 19:04:11.345  - error: admin.0 (343) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2026-04-14 19:04:11.345  - error: admin.0 (343) unhandled promise rejection: Connection is closed.
                            2026-04-14 19:04:11.414  - error: admin.0 (343) Error: Connection is closed.
                                at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                at StateRedisClient.pushMessage (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1215:27)
                                at Admin.registerNotification (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7771:28)
                                at Admin.writeUpdateInfo (/opt/iobroker/node_modules/iobroker.admin/build/src/main.ts:890:20)
                            2026-04-14 19:04:11.604  - error: host.iobroker Caught by controller[0]: (node:343) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
                            2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[0]: (Use `node --trace-warnings ...` to show where the warning was created)
                            2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]: Error: Connection is closed.
                            2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                            2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]:     at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                            2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]:     at StateRedisClient.pushMessage (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1215:27)
                            2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]:     at Admin.registerNotification (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7771:28)
                            2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]:     at Admin.writeUpdateInfo (/opt/iobroker/node_modules/iobroker.admin/build/src/main.ts:890:20)
                            HomoranH crunchipC 2 Antworten Letzte Antwort
                            • Ro75R Offline
                              Ro75R Offline
                              Ro75
                              nodejs >22.x warum? Beta Repo warum?
                              Ro75.
                              • Q quinti
                                bash
                                Script v.2026-01-31
                                *** BASE SYSTEM ***
                                  Virtualization: lxc
                                OS is similar to:
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                CPU threads: 3
                                                 RTC time: n/a
                                              NTP service: n/a
                                          RTC in local TZ: no
                                hermann
                                HOME=/home/hermann
                                Display-Manager:
                                Desktop:
                                Session:                tty
                                *** MEMORY ***
                                Swap:           8.6G          0B        8.6G
                                Total:           17G         56M         16G
                                         8192 M total memory
                                           54 M used memory
                                          206 M active memory
                                         7747 M free memory
                                            0 M buffer memory
                                          390 M swap cache
                                         8191 M total swap
                                            0 M used swap
                                         8191 M free swap
                                *** FILESYSTEM ***
                                /var:
                                605M    /var/
                                282M    /var/log
                                231M    /var/lib
                                USB-Devices by-id:
                                /usr/bin/npm            11.5.1
                                /usr/bin/npx            11.5.1
                                nodejs:
                                  Version table:
                                console.log(err)
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin:          7.8.20
                                javascript:     9.1.1
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        31715
                                States:         30867
                                @quinti sagte:
                                Da stimmt was grundsätzlich nicht, diag würde nie lügen!
                                OS zu alt
                                @quinti sagte:
                                Läuft iobroker gar nicht?
                                @quinti sagte:
                                • iobroker.service loaded failed failed ioBroker Server
                                Was ist da los?
                                @quinti sagte:
                                Node 24 ist noch nicht für iob empfohlen
                                @quinti sagte:
                                Warum 2 repos gleichzeitig?
                                @quinti sagte:
                                A
                                updaten!
                                @quinti sagte:
                                Dito
                                • Q quinti
                                  bash
                                  Script v.2026-01-31
                                  *** BASE SYSTEM ***
                                    Virtualization: lxc
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : 64 bit
                                  CPU threads: 3
                                                   RTC time: n/a
                                                NTP service: n/a
                                            RTC in local TZ: no
                                  hermann
                                  HOME=/home/hermann
                                  Display-Manager:
                                  Desktop:
                                  Session:                tty
                                  *** MEMORY ***
                                  Swap:           8.6G          0B        8.6G
                                  Total:           17G         56M         16G
                                           8192 M total memory
                                             54 M used memory
                                            206 M active memory
                                           7747 M free memory
                                              0 M buffer memory
                                            390 M swap cache
                                           8191 M total swap
                                              0 M used swap
                                           8191 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  605M    /var/
                                  282M    /var/log
                                  231M    /var/lib
                                  USB-Devices by-id:
                                  /usr/bin/npm            11.5.1
                                  /usr/bin/npx            11.5.1
                                  nodejs:
                                    Version table:
                                  console.log(err)
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  admin:          7.8.20
                                  javascript:     9.1.1
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        31715
                                  States:         30867
                                  crunchipC Offline
                                  crunchipC Offline
                                  @quinti da ist doch etwas mit deinem Arbeitsspeicher faul
                                    @quinti sagte:
                                    OS zu alt
                                    @quinti sagte:
                                    @quinti sagte:
                                    Was ist da los?
                                    @quinti sagte:
                                    @quinti sagte:
                                    @quinti sagte:
                                    A
                                    updaten!
                                    @quinti sagte:
                                    Dito
                                    @Homoran sagte:
                                    Kann ich nicht ausschließen...
                                    Aber die Diagnose basiert natürlich auf Daten aus dem System.
                                    basiert natürlich auf veralteten Informationen, da ja das running süstäm nie getascht wurde.
                                    Wäre das auf Stand wäre auch die Diagnose richtig.
                                    Insgesamt ist das Dig aber komplett inkonsistent aufgebaut. nodejs@24 auf einem ansonsten versumpften Bookworm mit iob-Beta-Quelle macht gar keinen Sinn. Wo soll es denn hingehen? Bleeding edge oder 'never tatsch irgendwas'? Beides kombiniert kann nicht gut funktionieren.
                                    Und wozu solll die microsoft/xenial-Quelle gut sein? Davon ganz abgesehen, dass sie natürlich nicht mehr funktioniert.
                                    • Q Offline
                                      Q Offline
                                      quinti
                                      sry, hatte iwie im kopf das iob diag mit gestopptem iobroker laufen muss. Habs wohl verwechselt mit iob fix --> alter mann
                                      Das microsoft repository ist drin da ich mal einen mssql client installiert habe.
                                      Bin noch auf bookworm da iobroker in einem proxmox container läuft und proxmox noch auf 8.2.2 mit bookworm ist. Möchte im moment proxmox nicht upgraden. Ist wohl z Zt ein bug drin der grub durcheinander bringt. Hat mir letzte Woche meinen tvheadend Rechner zerschossen.
                                      Hab mal updates durchgeführt.
                                      hier neues diag mit gestartetem iobroker ;)
                                      Script v.2026-01-31
                                      *** BASE SYSTEM ***
                                        Virtualization: lxc
                                      OS is similar to:
                                      Docker          : false
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                       20:13:47 up 16 min,  2 users,  load average: 1.74, 1.83, 1.82
                                      CPU threads: 3
                                      Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                                                     Local time: Tue 2026-04-14 20:13:47 CEST
                                                 Universal time: Tue 2026-04-14 18:13:47 UTC
                                                       RTC time: n/a
                                                    NTP service: n/a
                                                RTC in local TZ: no
                                      hermann
                                      HOME=/home/hermann
                                      iobroker
                                      HOME=/home/iobroker
                                      GROUPS=iobroker tty dialout audio video plugdev
                                      Display-Manager:
                                      Desktop:
                                      Session:                tty
                                      *** MEMORY ***
                                      Mem:            8.6G        4.3G        3.2G        143K        1.1G        4.3G
                                      Swap:           8.6G          0B        8.6G
                                      Total:           17G        4.3G         11G
                                      Active iob-Instances:   39
                                               8192 M total memory
                                               4116 M used memory
                                               3929 M active memory
                                                867 M inactive memory
                                               3032 M free memory
                                                  0 M buffer memory
                                               1043 M swap cache
                                               8191 M total swap
                                                  0 M used swap
                                               8191 M free swap
                                      top - 20:13:48 up 16 min,  2 users,  load average: 1.74, 1.83, 1.82
                                      Tasks:  69 total,   1 running,  68 sleeping,   0 stopped,   0 zombie
                                      MiB Mem :   8192.0 total,   3030.9 free,   4118.0 used,   1043.3 buff/cache
                                      MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.   4074.0 avail Mem
                                      1 loaded units listed.
                                      *** FILESYSTEM ***
                                      /dev/loop2     ext4       24G   11G   13G  45% /
                                      tmpfs          tmpfs      13G  136K   13G   1% /run
                                      /var:
                                      613M    /var/
                                      290M    /var/log/journal/bb1a573610aa48a7948bbf161935960d
                                      290M    /var/log
                                      231M    /var/lib
                                      Archived and active journals take up 289.1M in the file system.
                                      742M    /opt/iobroker/iobroker-data/
                                      36M     /opt/iobroker/iobroker-data/objects.jsonl
                                      14M     /opt/iobroker/iobroker-data/states.jsonl
                                      USB-Devices by-id:
                                      /usr/bin/nodejs         v24.14.1
                                      /usr/bin/node           v24.14.1
                                      /usr/bin/npm            11.11.0
                                      /usr/bin/npx            11.11.0
                                      nodejs:
                                        Installed: 24.14.1-1nodesource1
                                        Version table:
                                       *** 24.14.1-1nodesource1 600
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      iobroker            iobroker (version: 7.1.1, hostname: iobroker      , alive, uptime: 316)
                                      js-controller:  7.1.1
                                      admin:          7.8.20
                                      javascript:     9.2.0
                                      Adapter State
                                      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                      + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
                                      + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 -  enabled
                                      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                                      + system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
                                      + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
                                      + system.adapter.gotify.0                 : gotify                : iobroker                                 -  enabled
                                      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                      + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.101.102
                                      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                                      + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
                                      + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
                                      + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                                      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                      + system.adapter.pirate-weather.0         : pirate-weather        : iobroker                                 -  enabled
                                      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                                      + system.adapter.renault.0                : renault               : iobroker                                 -  enabled
                                      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                                      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                                        system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
                                      + system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
                                      + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                                      + system.adapter.sureflap.0               : sureflap              : iobroker                                 -  enabled
                                      + system.adapter.traccar.0                : traccar               : iobroker                                 -  enabled
                                      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                      + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                                      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                                      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                      + system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                                      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
                                      + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                                      + instance is alive
                                      Active repo(s): beta
                                      Used repository: beta
                                      Adapter    "javascript"   : 9.2.0    , installed 9.2.0
                                      Controller "js-controller": 7.1.1    , installed 7.1.1
                                      Adapter    "traccar"      : 1.1.7    , installed 1.1.7
                                      Objects and States
                                      Objects:        31783
                                      States:         31368
                                      Hit:4 https://deb.nodesource.com/node_24.x nodistro InRelease
                                      Hit:5 https://packages.microsoft.com/ubuntu/16.04/prod xenial InRelease
                                      Pending systemupdates: 0
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       840021606  4327/iobroker.js-co
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       840021611  4327/iobroker.js-co
                                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          839861821  333/master
                                      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       840025688  4603/io.mqtt.0
                                      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       840042633  4802/io.sonoff.0
                                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       840037661  4785/io.shelly.0
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          839864060  1/init
                                      tcp6       0      0 :::51989                :::*                    LISTEN      1001       840031495  4736/io.nuki-extend
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          839864062  1/init
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          839864218  1/init
                                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       840056132  5058/io.simple-api.
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       840057907  5156/io.web.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       840021668  4348/io.admin.0
                                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          839861822  333/master
                                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       840042801  4851/io.tuya.0
                                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       840042802  4851/io.tuya.0
                                      udp        0      0 192.168.101.102:54278   0.0.0.0:*                           1001       840025951  4719/io.knx.0
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          839864061  1/init
                                      udp        0      0 192.168.101.102:123     0.0.0.0:*                           0          839859795  164/ntpd
                                      udp        0      0 192.168.0.102:123       0.0.0.0:*                           0          839859793  164/ntpd
                                      udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          839859791  164/ntpd
                                      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          839859787  164/ntpd
                                      udp6       0      0 :::111                  :::*                                0          839864063  1/init
                                      udp6       0      0 fe80::be24:11ff:fe3:123 :::*                                106        839862059  164/ntpd
                                      udp6       0      0 fd6d:f83d:ff15:0:be:123 :::*                                106        839862057  164/ntpd
                                      udp6       0      0 fe80::be24:11ff:fe0:123 :::*                                106        839862055  164/ntpd
                                      udp6       0      0 fd6d:f83d:ff15:0:be:123 :::*                                106        839862053  164/ntpd
                                      udp6       0      0 ::1:123                 :::*                                0          839859797  164/ntpd
                                      udp6       0      0 :::123                  :::*                                0          839859784  164/ntpd
                                      • Ro75R Offline
                                        Ro75R Offline
                                        Ro75
                                        ändert nichts an der Tatsache nodejs >22 warum? Beta-Repo warum? OS läuft aus. ...
                                        Ro75.
                                        • Q quinti
                                          Script v.2026-01-31
                                          *** BASE SYSTEM ***
                                            Virtualization: lxc
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                          CPU threads: 3
                                                           RTC time: n/a
                                                        NTP service: n/a
                                                    RTC in local TZ: no
                                          hermann
                                          HOME=/home/hermann
                                          iobroker
                                          HOME=/home/iobroker
                                          Display-Manager:
                                          Desktop:
                                          Session:                tty
                                          *** MEMORY ***
                                          Swap:           8.6G          0B        8.6G
                                          Total:           17G        4.3G         11G
                                                   8192 M total memory
                                                   4116 M used memory
                                                   3032 M free memory
                                                      0 M buffer memory
                                                   1043 M swap cache
                                                   8191 M total swap
                                                      0 M used swap
                                                   8191 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          613M    /var/
                                          290M    /var/log
                                          231M    /var/lib
                                          USB-Devices by-id:
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          admin:          7.8.20
                                          javascript:     9.2.0
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        31783
                                          States:         31368
                                          @quinti sagte:
                                          Dann schmeiß den alten Mist da raus. xenial ist 10 Jahre alt!!!
