  4. Admin startet nicht mehr
    6.4k
22 Beiträge 4 Kommentatoren 883 Aufrufe 3 Beobachtet
  • N nettworker
    ```bash
    Script v.2026-01-31
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-42-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org
    OS is similar to:
    model name      : QEMU Virtual CPU version 2.5+
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     15:48:50 up  1:02,  3 users,  load average: 0.23, 0.22, 0.18
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2026-04-12 15:48:50 CEST
               Universal time: Sun 2026-04-12 13:48:50 UTC
                     RTC time: Sun 2026-04-12 13:48:50
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    dieter
    HOME=/home/dieter
    GROUPS=dieter cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:             16G        1.6G         14G        552K        887M         15G
    Swap:           1.0G          0B        1.0G
    Total:           17G        1.6G         15G
    Active iob-Instances:   12
            15992 M total memory
             1523 M used memory
              448 M active memory
             1432 M inactive memory
            13907 M free memory
               89 M buffer memory
              756 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    top - 15:48:50 up  1:02,  3 users,  load average: 0.21, 0.22, 0.18
    Tasks: 116 total,   1 running, 115 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  15992.6 total,  13907.4 free,   1524.4 used,    846.3 buff/cache
    MiB Swap:    975.0 total,    975.0 free,      0.0 used.  14468.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  7.8G     0  7.8G   0% /dev
    tmpfs          tmpfs     1.6G  540K  1.6G   1% /run
    /dev/sda1      ext4       31G   11G   19G  35% /
    tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
    [Sun Apr 12 14:46:24 2026] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Apr 12 14:46:25 2026] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    1.4G    /var/
    769M    /var/log
    753M    /var/log/journal/329f6d851eba4ad5910570e6874c071a
    448M    /var/cache
    Archived and active journals take up 59.3M in the file system.
    /opt/iobroker/backups:
    2.1G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    514M    /opt/iobroker/iobroker-data/
    396M    /opt/iobroker/iobroker-data/files
    86M     /opt/iobroker/iobroker-data/files/vis-2
    83M     /opt/iobroker/iobroker-data/backup-objects
    75M     /opt/iobroker/iobroker-data/files/vis
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
    8.0M    /opt/iobroker/iobroker-data/files/daswetter.admin/assets/index-84bRrRlB.js
    7.0M    /opt/iobroker/iobroker-data/files/vis/widgets/echarts/static/js/vendors-node_modules_mui_icons-material_esm_index_js.bfab266f.chunk.js.map
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** ZigBee Settings ***
    ⚠ HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'.
    Please check your setting:
    /dev/ttyUSB0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.0
    /usr/bin/node           v22.22.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.0-1nodesource1
      Candidate: 22.22.2-1nodesource1
      Version table:
         22.22.2-1nodesource1 1001
         22.22.1-1nodesource1 1001
     *** 22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://debian.inf.tu-dresden.de/debian bookworm/main amd64 Packages
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    The current Node.js version (v22.22.0) is vulnerable to the following CVEs:
    CVE-2026-21637(high): A flaw in Node.js TLS error handling leaves `SNICallback` invocations unprotected against synchronous exceptions, while the equivalent ALPN and PSK callbacks were already addressed in CVE-2026-21637. This represents an incomplete fix of that prior vulnerability.
    When an `SNICallback` throws synchronously on unexpected input the exception bypasses TLS error handlers and propagates as an uncaught exception, crashing the Node.js process.
    * This vulnerability affects all Node.js versions that received the CVE-2026-21637 fix, including **20.x, 22.x, 24.x, and 25.x**, on any TLS server where `SNICallback` may throw on unexpected `servername` input.
    Patched versions: ^20.20.2 || ^22.22.2 || ^24.14.1 || ^25.8.2
    CVE-2026-21710(high): A flaw in Node.js HTTP request handling causes an uncaught `TypeError` when a request is received with a header named `__proto__` and the application accesses `req.headersDistinct`.
    When this occurs, `dest["__proto__"]` resolves to `Object.prototype` rather than `undefined`, causing `.push()` to be called on a non-array. This exception is thrown synchronously inside a property getter and cannot be intercepted by `error` event listeners, meaning it cannot be handled without wrapping every `req.headersDistinct` access in a `try/catch`.
    * This vulnerability affects all Node.js HTTP servers on **20.x, 22.x, 24.x, and v25.x**
    CVE-2026-21713(medium): A flaw in Node.js HMAC verification uses a non-constant-time comparison when validating user-provided signatures, potentially leaking timing information proportional to the number of matching bytes. Under certain threat models where high-resolution timing measurements are possible, this behavior could be exploited as a timing oracle to infer HMAC values.
    Node.js already provides timing-safe comparison primitives used elsewhere in the codebase, indicating this is an oversight rather than an intentional design decision.
    This vulnerability affects **20.x, 22.x, 24.x, and 25.x**.
    CVE-2026-21714(medium): A memory leak occurs in Node.js HTTP/2 servers when a client sends WINDOW_UPDATE frames on stream 0 (connection-level) that cause the flow control window to exceed the maximum value of 2³¹-1. The server correctly sends a GOAWAY frame, but the Http2Session object is never cleaned up.
    This vulnerability affects HTTP2 users on Node.js 20, 22, 24 and 25.
    CVE-2026-21715(low): A flaw in Node.js Permission Model filesystem enforcement leaves `fs.realpathSync.native()` without the required read permission checks, while all comparable filesystem functions correctly enforce them.
    As a result, code running under `--permission` with restricted `--allow-fs-read` can still use `fs.realpathSync.native()` to check file existence, resolve symlink targets, and enumerate filesystem paths outside of permitted directories.
    This vulnerability affects **20.x, 22.x, 24.x, and 25.x** processes using the Permission Model where `--allow-fs-read` is intentionally restricted.
    CVE-2026-21716(low): An incomplete fix for CVE-2024-36137 leaves `FileHandle.chmod()` and `FileHandle.chown()` in the promises API without the required permission checks, while their callback-based equivalents (`fs.fchmod()`, `fs.fchown()`) were correctly patched.
    As a result, code running under `--permission` with restricted `--allow-fs-write` can still use promise-based `FileHandle` methods to modify file permissions and ownership on already-open file descriptors, bypassing the intended write restrictions.
    This vulnerability affects **20.x, 22.x, 24.x, and 25.x** processes using the Permission Model where `--allow-fs-write` is intentionally restricted.
    CVE-2026-21717(medium): A flaw in V8's string hashing mechanism causes integer-like strings to be hashed to their numeric value, making hash collisions trivially predictable. By crafting a request that causes many such collisions in V8's internal string table, an attacker can significantly degrade performance of the Node.js process.
    The most common trigger is any endpoint that calls `JSON.parse()` on attacker-controlled input, as JSON parsing automatically internalizes short strings into the affected hash table.
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 3741)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     0
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
      system.adapter.history.0                : history               : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
    + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
      system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
      system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "echarts"      : 3.1.0    , installed 3.1.0
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "history"      : 4.0.0    , installed 3.0.1  [Updatable]
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
    Adapter    "reolink"      : 1.4.2    , installed 1.2.3  [Updatable]
    Adapter    "shuttercontrol": 2.0.12  , installed 2.0.12
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
    Adapter    "vis-2"        : 2.13.8   , installed 2.13.8
    Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
    Adapter    "vis-2-widgets-inventwo": 0.5.5, installed 0.5.5
    Adapter    "vis-2-widgets-material": 1.6.1, installed 1.4.10 [Updatable]
    Adapter    "vis-icontwo"  : 2.11.1   , installed 2.11.1
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
    Objects and States
    Objects:        4632
    States:         4222
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://debian.inf.tu-dresden.de/debian bookworm InRelease
    Hit:3 http://debian.inf.tu-dresden.de/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 22
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17431      517/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15114      517/iobroker.js-con
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       17218      1526/io.mqtt.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       17217      1526/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       13109      2056/io.sonoff.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15101      528/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12565      1/init
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19739      2981/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15103      528/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          14453      1/init
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          261        1/init
    udp6       0      0 :::111                  :::*                                0          14454      1/init
    2026-04-12 14:47:42.945  - info: sonoff.0 (2056) Client [Ofen_Wohnzimmer] connected with secret 1775998062944_6360
    2026-04-12 14:47:42.948  - info: sonoff.0 (2056) Client [Kuehlschrank-links] connected with secret 1775998062947_6402
    2026-04-12 14:47:43.019  - info: sonoff.0 (2056) Client [Steckdose-Garage] connected with secret 1775998063018_9056
    2026-04-12 14:47:43.122  - info: sonoff.0 (2056) Client [Lampe-Kommode-WZ] connected with secret 1775998063121_901
    2026-04-12 14:47:43.151  - info: sonoff.0 (2056) Client [Schalter-Spuelmaschine] connected with secret 1775998063150_1032
    2026-04-12 14:47:43.222  - info: sonoff.0 (2056) Client [Lampe_Erker] connected with secret 1775998063221_7975
    2026-04-12 14:47:43.384  - info: sonoff.0 (2056) Client [Anbau] connected with secret 1775998063383_370
    2026-04-12 14:47:43.439  - info: sonoff.0 (2056) Client [3er_Naehmaschine_WZ] connected with secret 1775998063438_7759
    2026-04-12 14:47:43.481  - info: sonoff.0 (2056) Client [Schalter-Trockner] connected with secret 1775998063481_8348
    2026-04-12 14:47:49.659  - info: sonoff.0 (2056) Client [Zaehler-Haus] connected with secret 1775998069658_1644
    2026-04-12 14:47:52.062  - info: sonoff.0 (2056) Client [Rolladen-Erker-1] connected with secret 1775998072061_5897
    2026-04-12 14:47:52.224  - info: sonoff.0 (2056) Client [Teich] connected with secret 1775998072220_1412
    2026-04-12 14:47:52.432  - info: sonoff.0 (2056) Client [Rolladen-Erker-4] connected with secret 1775998072429_4012
    2026-04-12 14:47:52.460  - info: sonoff.0 (2056) Client [Rolladen-Erker-2] connected with secret 1775998072457_7453
    2026-04-12 14:47:52.483  - info: sonoff.0 (2056) Client [Rolladen-Bakontuer] connected with secret 1775998072472_9722
    2026-04-12 14:47:52.506  - info: sonoff.0 (2056) Client [Rolladen-Erker-3] connected with secret 1775998072503_3325
    2026-04-12 14:47:52.531  - info: sonoff.0 (2056) Client [Einspeisung-Holzplatz] connected with secret 1775998072527_1114
    2026-04-12 14:47:56.138  - info: sonoff.0 (2056) Client [Schalter-A1-Mini] connected with secret 1775998076137_4931
    2026-04-12 14:47:57.036  - info: sonoff.0 (2056) Client [Poolpumpe] connected with secret 1775998077036_1247
    2026-04-12 14:48:03.036  - info: sonoff.0 (2056) Client [Einspeisung-Victron] connected with secret 1775998083032_8005
    2026-04-12 14:48:03.515  - info: sonoff.0 (2056) Client [Luefterklappe] connected with secret 1775998083512_2056
    2026-04-12 14:56:40.843  - info: influxdb.0 (577) Store 21 buffered influxDB history points
    2026-04-12 15:12:18.447  - info: web.0 (2981) ==> Connected system.user.admin from ::ffff:192.168.30.68
    2026-04-12 15:46:32.489  - info: host.iobroker Delete log file iobroker.2026-04-03.log.gz
    2026-04-12 15:46:32.490  - info: host.iobroker Delete log file iobroker.2026-04-04.log.gz
    @nettworker sagte:
    Bring es auf das aktuelle Stable 'Trixie'
    Bring es auf multi-user.target
    Setz den 'dieter' in die Gruppe 'adm'.
    Verwende den link-by-id.
    Update das System, inkl. nodejs.
    Update die ioBroker-Adapter.
    Danach nochmal ein
    iob start admin.0
    • N Offline
      N Offline
      nettworker
      Leider keine Besserung:
      ```bash
      Script v.2026-01-31
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
               Chassis: vm 🖴
          AF_VSOCK CID: 1
        Virtualization: kvm
                Kernel: Linux 6.12.74+deb13+1-amd64
         Firmware Date: Tue 2014-04-01
          Firmware Age: 12y 1w 4d
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
       19:52:40 up 1 min,  1 user,  load average: 1.53, 0.77, 0.29
      CPU threads: 4
      Operating System is the current Debian stable version codenamed 'trixie'!
                     Local time: Sun 2026-04-12 19:52:41 CEST
                 Universal time: Sun 2026-04-12 17:52:41 UTC
                       RTC time: Sun 2026-04-12 17:52:41
                    NTP service: active
                RTC in local TZ: no
      dieter
      HOME=/home/dieter
      GROUPS=dieter adm cdrom floppy sudo audio dip video plugdev users netdev iobroker
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/dieter
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:             16G        1.5G         14G        3.2M        614M         15G
      Swap:           1.0G          0B        1.0G
      Total:           17G        1.5G         16G
              15999 M total memory
               1393 M used memory
               1184 M active memory
                348 M inactive memory
              14287 M free memory
                 52 M buffer memory
                533 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      top - 19:52:41 up 1 min,  1 user,  load average: 1.53, 0.77, 0.29
      Tasks: 142 total,   1 running, 141 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  2.4 us,  0.0 sy,  0.0 ni, 97.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  15999.2 total,  14286.9 free,   1393.0 used,    586.8 buff/cache
      MiB Swap:    975.0 total,    975.0 free,      0.0 used.  14606.2 avail Mem
      *** FILESYSTEM ***
      tmpfs          tmpfs     1.6G  532K  1.6G   1% /run
      /dev/sda1      ext4       31G  9.9G   19G  35% /
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      tmpfs          tmpfs     7.9G  2.6M  7.9G   1% /tmp
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
      tmpfs          tmpfs     1.6G  8.0K  1.6G   1% /run/user/1000
      [Sun Apr 12 19:51:02 2026] EXT4-fs (sda1): mounted filesystem df561f55-661e-45be-a648-a04511a85931 ro with ordered data mode. Quota mode: none.
      [Sun Apr 12 19:51:04 2026] EXT4-fs (sda1): re-mounted df561f55-661e-45be-a648-a04511a85931 r/w.
      /var:
      1.1G    /var/
      794M    /var/log
      777M    /var/log/journal/329f6d851eba4ad5910570e6874c071a
      187M    /var/lib
      Archived and active journals take up 776.4M in the file system.
      545M    /opt/iobroker/iobroker-data/
      408M    /opt/iobroker/iobroker-data/files
      97M     /opt/iobroker/iobroker-data/files/vis-2
      41M     /opt/iobroker/iobroker-data/objects.jsonl
      USB-Devices by-id:
      ⚠ HINT:
      /dev/ttyUSB0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/nodejs         v22.22.2
      /usr/bin/node           v22.22.2
      /usr/bin/npm            10.9.7
      /usr/bin/npx            10.9.7
      nodejs:
        Installed: 22.22.2-1nodesource1
        Version table:
       *** 22.22.2-1nodesource1 1001
           20.19.2+dfsg-1+deb13u2 500
              500 http://security.debian.org/debian-security trixie-security/main amd64 Packages
           20.19.2+dfsg-1 500
              500 http://debian.inf.tu-dresden.de/debian trixie/main amd64 Packages
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 93)
      admin:          7.7.22
      javascript:     9.0.18
      Adapter State
      + instance is alive
      Adapter    "history"      : 4.0.0    , installed 4.0.0
      Adapter    "reolink"      : 1.4.2    , installed 1.4.2
      Adapter    "vis-2-widgets-material": 1.6.1, installed 1.6.1
      Objects and States
      Objects:        4636
      States:         4241
      Hit:1 http://security.debian.org/debian-security trixie-security InRelease
      Hit:2 http://debian.inf.tu-dresden.de/debian trixie InRelease
      Hit:3 http://debian.inf.tu-dresden.de/debian trixie-updates InRelease
      Pending systemupdates: 0
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       7754       1991/io.mqtt.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       7753       1991/io.mqtt.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       6862       2494/io.sonoff.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1439       1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7329       764/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7384       952/exim4
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6002       688/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8343       688/iobroker.js-con
      tcp6       0      0 :::111                  :::*                    LISTEN      0          4411       1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          7339       764/sshd: /usr/sbin
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7385       952/exim4
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9889       3470/io.web.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1440       1/init
      udp6       0      0 :::111                  :::*                                0          109        1/init
      2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
      2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:   ]
      2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]: }
      2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[1]: Node.js v22.22.2
      2026-04-12 19:51:59.064  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2026-04-12 19:51:59.064  - info: host.iobroker Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      2026-04-12 19:51:59.354  - info: vis-2.0 (3954) starting. Version 2.13.8 in /opt/iobroker/node_modules/iobroker.vis-2, node: v22.22.2, js-controller: 7.0.7
      2026-04-12 19:51:59.491  - info: vis-2.0 (3954) vis-2 license is OK.
      2026-04-12 19:52:01.854  - info: host.iobroker instance system.adapter.reolink.0 in version "1.4.2" started with pid 3983
      2026-04-12 19:52:02.786  - info: reolink.0 (3983) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.reolink, node: v22.22.2, js-controller: 7.0.7
      2026-04-12 19:52:02.808  - info: reolink.0 (3983) Reolink adapter has started
      2026-04-12 19:52:02.838  - info: reolink.0 (3983) Current IP: 192.168.3.126
      2026-04-12 19:52:03.488  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
      2026-04-12 19:52:04.224  - warn: reolink.0 (3983) State "reolink.0.Device.Name" has no existing object, this might lead to an error in future versions
      2026-04-12 19:52:04.322  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
      2026-04-12 19:52:13.874  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
      2026-04-12 19:52:24.279  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
      2026-04-12 19:52:34.627  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
      2026-04-12 19:52:45.029  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
      2026-04-12 19:52:55.431  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
      2026-04-12 19:52:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Schedulescript läuft, Verbraucher 'sonoff.0.Lampe_Erker.POWER' wird geschaltet auf: true
      2026-04-12 19:52:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Wert ist               : true
      2026-04-12 19:52:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Letzter_Verbraucher ist: true
      2026-04-12 19:52:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Abendlichtstatus wird gesetzt auf: true
      2026-04-12 19:53:05.864  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
      crunchipC Thomas BraunT 2 Antworten Letzte Antwort
        Kommt nichts in der Konsole bei iob start admin.0? Ich weiß gar nicht ob das auch mit dem flag --debug geht, also iob start admin.0 --debug
        • N nettworker
          ```bash
          Script v.2026-01-31
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
              AF_VSOCK CID: 1
            Virtualization: kvm
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
                        NTP service: active
                    RTC in local TZ: no
          dieter
          HOME=/home/dieter
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:           1.0G          0B        1.0G
          Total:           17G        1.5G         16G
                   1393 M used memory
                  14287 M free memory
                     52 M buffer memory
                    533 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          *** FILESYSTEM ***
          /var:
          1.1G    /var/
          794M    /var/log
          187M    /var/lib
          USB-Devices by-id:
          ⚠ HINT:
          /dev/ttyUSB0
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.7
          /usr/bin/npx            10.9.7
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.22
          javascript:     9.0.18
          Adapter State
          + instance is alive
          Objects and States
          Objects:        4636
          States:         4241
          crunchipC Offline
          crunchipC Offline
          @nettworker probiert mal
          iobroker upload admin
          Und danach nochmal starten
          N 1 Antwort Letzte Antwort
          • N nettworker
            ```bash
            Script v.2026-01-31
            *** BASE SYSTEM ***
                     Chassis: vm 🖴
                AF_VSOCK CID: 1
              Virtualization: kvm
            OS is similar to:
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
            CPU threads: 4
                          NTP service: active
                      RTC in local TZ: no
            dieter
            HOME=/home/dieter
            iobroker
            HOME=/home/iobroker
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Swap:           1.0G          0B        1.0G
            Total:           17G        1.5G         16G
                     1393 M used memory
                    14287 M free memory
                       52 M buffer memory
                      533 M swap cache
                      974 M total swap
                        0 M used swap
                      974 M free swap
            *** FILESYSTEM ***
            /var:
            1.1G    /var/
            794M    /var/log
            187M    /var/lib
            USB-Devices by-id:
            ⚠ HINT:
            /dev/ttyUSB0
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.9.7
            /usr/bin/npx            10.9.7
            nodejs:
              Version table:
                 20.19.2+dfsg-1 500
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.7.22
            javascript:     9.0.18
            Adapter State
            + instance is alive
            Objects and States
            Objects:        4636
            States:         4241
            @nettworker sagte:
            Setz da den Link 'by-id' rein. Ansonsten schaut das System jetzt aber gut aus.
            Dann starte jetzt die Instanz mal und beobachte in einem zweiten Terminal das Log per
            iob logs --watch
            N 2 Antworten Letzte Antwort
              N Offline
              N Offline
              nettworker
              @crunchip sagte:
              Gleiches Ergebnis
                @nettworker sagte:
                iob logs --watch
                N Offline
                N Offline
                nettworker
                @Thomas-Braun sagte:
                Copy to Clipboard
                iob logs --watch
                Da kommt nix im Log
                • N nettworker
                  @crunchip sagte:
                  Gleiches Ergebnis
                  @nettworker
                  iob logs --watch
                    @nettworker sagte:
                    iob logs --watch
                    N Offline
                    N Offline
                    nettworker
                    2026-04-12 20:37:44.552  - info: reolink.0 (8456) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                    2026-04-12 20:37:55.045  - info: reolink.0 (8456) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                    2026-04-12 20:38:05.619  - info: reolink.0 (8456) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                    • N nettworker
                      @nettworker
                      iob restart admin
                      • N Offline
                        N Offline
                        nettworker
                        schrieb am zuletzt editiert von nettworker
                        Ist das log interessant?
                        ter@iobroker:~$ iob logs --watch
                        2026-04-12 19:51:38.652  - error: host.iobroker Caught by controller[0]: }
                        2026-04-12 19:51:38.652  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                        2026-04-12 19:51:38.652  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2026-04-12 19:51:38.652  - info: host.iobroker Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                        2026-04-12 19:51:38.652  - info: host.iobroker system.adapter.zigbee.0 will be rebuilt
                        2026-04-12 19:51:38.652  - warn: host.iobroker adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                        2026-04-12 19:51:38.653  - info: host.iobroker iobroker rebuild
                        2026-04-12 19:51:39.261  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                        2026-04-12 19:51:41.942  - info: host.iobroker instance system.adapter.echarts.0 in version "3.1.0" started with pid 2811
                        2026-04-12 19:51:42.573  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                        2026-04-12 19:51:43.250  - info: echarts.0 (2811) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.echarts, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:51:43.484  - info: vis.0 (2928) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:51:43.590  - info: host.iobroker iobroker npm-rebuild: exit 1
                        2026-04-12 19:51:43.926  - info: host.iobroker instance system.adapter.zigbee.0 in version "3.3.5" started with pid 2999
                        2026-04-12 19:51:44.486  - info: vis.0 (2928) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:   throw err;
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:   ^
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]: Require stack:
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:9:15)
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:   requireStack: [
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js',
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                        2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:   ]
                        2026-04-12 19:51:44.720  - error: host.iobroker Caught by controller[0]: }
                        2026-04-12 19:51:44.720  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                        2026-04-12 19:51:44.720  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2026-04-12 19:51:44.720  - info: host.iobroker Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                        2026-04-12 19:51:44.720  - info: host.iobroker system.adapter.zigbee.0 will be rebuilt
                        2026-04-12 19:51:44.720  - warn: host.iobroker adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                        2026-04-12 19:51:44.720  - info: host.iobroker iobroker rebuild
                        2026-04-12 19:51:45.362  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                        2026-04-12 19:51:46.846  - info: vis.0 (3052) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:51:47.268  - info: sonoff.0 (2494) Client [Sensor Heizung] connected with secret 1776016307264_6249
                        2026-04-12 19:51:47.785  - info: vis.0 (3052) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:51:48.322  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
                        2026-04-12 19:51:49.281  - info: sonoff.0 (2494) Client [Kuehlschrank-links] connected with secret 1776016309277_1671
                        2026-04-12 19:51:49.329  - info: sonoff.0 (2494) Client [Anbau] connected with secret 1776016309324_160
                        2026-04-12 19:51:49.415  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                        2026-04-12 19:51:49.531  - info: sonoff.0 (2494) Client [Lampe-Kommode-WZ] connected with secret 1776016309531_789
                        2026-04-12 19:51:49.677  - info: sonoff.0 (2494) Client [Gefrierschrank] connected with secret 1776016309677_277
                        2026-04-12 19:51:49.702  - info: sonoff.0 (2494) Client [Lampe-Haustuer] connected with secret 1776016309702_7757
                        2026-04-12 19:51:49.717  - info: sonoff.0 (2494) Client [Lampe_Erker] connected with secret 1776016309717_7258
                        2026-04-12 19:51:49.835  - info: sonoff.0 (2494) Client [3er_Naehmaschine_WZ] connected with secret 1776016309833_952
                        2026-04-12 19:51:49.889  - info: sonoff.0 (2494) Client [Schalter-Trockner] connected with secret 1776016309888_4791
                        2026-04-12 19:51:49.894  - info: sonoff.0 (2494) Client [Getraenkekuehlschrank] connected with secret 1776016309894_3392
                        2026-04-12 19:51:49.911  - info: host.iobroker instance system.adapter.web.0 in version "8.0.0" started with pid 3470
                        2026-04-12 19:51:49.918  - info: sonoff.0 (2494) Client [Schalter-Spuelmaschine] connected with secret 1776016309918_593
                        2026-04-12 19:51:49.939  - info: sonoff.0 (2494) Client [Steckdose-Garage] connected with secret 1776016309939_3586
                        2026-04-12 19:51:49.941  - info: sonoff.0 (2494) Client [PC-Buero] connected with secret 1776016309940_4961
                        2026-04-12 19:51:49.948  - info: sonoff.0 (2494) Client [Ofen_Wohnzimmer] connected with secret 1776016309947_4861
                        2026-04-12 19:51:50.012  - info: sonoff.0 (2494) Client [Einspeisung-Holzplatz] connected with secret 1776016310010_5066
                        2026-04-12 19:51:50.234  - info: sonoff.0 (2494) Client [Rolladen-Erker-4] connected with secret 1776016310230_5053
                        2026-04-12 19:51:50.418  - info: sonoff.0 (2494) Client [Rolladen-Erker-2] connected with secret 1776016310417_1234
                        2026-04-12 19:51:50.421  - info: sonoff.0 (2494) Client [Zaehler-Haus] connected with secret 1776016310420_4776
                        2026-04-12 19:51:50.434  - info: host.iobroker iobroker npm-rebuild: exit 1
                        2026-04-12 19:51:50.443  - info: sonoff.0 (2494) Client [Schalter-A1-Mini] connected with secret 1776016310442_6202
                        2026-04-12 19:51:50.521  - info: sonoff.0 (2494) Client [Rolladen-Erker-3] connected with secret 1776016310516_9585
                        2026-04-12 19:51:50.615  - info: sonoff.0 (2494) Client [Poolpumpe] connected with secret 1776016310614_8439
                        2026-04-12 19:51:50.631  - info: sonoff.0 (2494) Client [Teich] connected with secret 1776016310629_1446
                        2026-04-12 19:51:50.728  - info: vis.0 (3442) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:51:50.731  - info: sonoff.0 (2494) Client [Rolladen-Erker-1] connected with secret 1776016310730_379
                        2026-04-12 19:51:50.757  - info: host.iobroker instance system.adapter.zigbee.0 in version "3.3.5" started with pid 3478
                        2026-04-12 19:51:50.761  - info: sonoff.0 (2494) Client [Rolladen-Bakontuer] connected with secret 1776016310756_9974
                        2026-04-12 19:51:51.437  - info: sonoff.0 (2494) Client [Luefterklappe] connected with secret 1776016311433_4649
                        2026-04-12 19:51:51.667  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                        2026-04-12 19:51:51.667  - error: host.iobroker Caught by controller[0]:   throw err;
                        2026-04-12 19:51:51.667  - error: host.iobroker Caught by controller[0]:   ^
                        2026-04-12 19:51:51.667  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]: Require stack:
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:9:15)
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:   requireStack: [
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js',
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:   ]
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]: }
                        2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                        2026-04-12 19:51:51.668  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2026-04-12 19:51:51.668  - info: host.iobroker Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                        2026-04-12 19:51:51.668  - info: host.iobroker system.adapter.zigbee.0 will be rebuilt
                        2026-04-12 19:51:51.668  - warn: host.iobroker adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                        2026-04-12 19:51:51.669  - info: host.iobroker iobroker rebuild
                        2026-04-12 19:51:51.748  - info: sonoff.0 (2494) Client [Einspeisung-Victron] connected with secret 1776016311746_4299
                        2026-04-12 19:51:51.750  - info: vis.0 (3442) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:51:52.107  - info: web.0 (3470) starting. Version 8.0.0 in /opt/iobroker/node_modules/iobroker.web, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:51:52.407  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                        2026-04-12 19:51:52.456  - info: web.0 (3470) socket.io server listening on port 8082
                        2026-04-12 19:51:52.626  - info: web.0 (3470) Connecting extension "energiefluss-erweitert/lib/web.js"
                        2026-04-12 19:51:52.627  - info: web.0 (3470) [energiefluss-erweitert.0] Sharp was found and can be used for image processing!
                        2026-04-12 19:51:52.631  - info: web.0 (3470) http server listening on port 8082
                        2026-04-12 19:51:53.978  - info: host.iobroker instance system.adapter.energiefluss-erweitert.0 in version "0.8.1" started with pid 3537
                        2026-04-12 19:51:55.124  - info: energiefluss-erweitert.0 (3537) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:51:55.140  - warn: energiefluss-erweitert.0 (3537) Workspace configuration is NOT password protected!
                        2026-04-12 19:51:55.161  - info: energiefluss-erweitert.0 (3537) Adapter started. Loading config!
                        2026-04-12 19:51:55.545  - info: energiefluss-erweitert.0 (3537) Configuration loaded!
                        2026-04-12 19:51:55.546  - info: energiefluss-erweitert.0 (3537) Requesting the following states: energiefluss-erweitert.0.configuration,mqtt.0.VenusOS.PVGesamtLeistung,mqtt.0.VenusOS.Akku.Ladung_W,mqtt.0.VenusOS.Akku.SoC,mqtt.0.VenusOS.String1.PV_Status,mqtt.0.T2S-Garage.ACDISPLAY,mqtt.0.openDTU_Holzplatz.ac.power,mqtt.0.VenusOS.Hichi.VerbrauchAktuell,sonoff.0.Schalter-A1-Mini.ENERGY_Power,0_userdata.0.Visualisierung.Solar.Hausverbrauch,sonoff.0.Getraenkekuehlschrank.ENERGY_Power,sonoff.0.Schalter-Spuelmaschine.ENERGY_Power,sonoff.0.Gefrierschrank.ENERGY_Power,sonoff.0.Gefriertruhe.ENERGY_Power,sonoff.0.Schalter-Waschmaschine.ENERGY_Power,sonoff.0.Schalter-Trockner.ENERGY_Power,sonoff.0.Kuehlschrank-links.ENERGY_Power,sonoff.0.Kuehlschrank-rechts.ENERGY_Power,sonoff.0.Schalter-Heizungspumpe.ENERGY_Power,sonoff.0.PC-Buero.ENERGY_Power,sonoff.0.Schalter-A1-Mini.POWER,sonoff.0.Poolpumpe.ENERGY_Power,sonoff.0.Poolpumpe.POWER,mqtt.0.VenusOS.Akku.Volt,sonoff.0.Ofen_Wohnzimmer.ENERGY_Power
                        2026-04-12 19:51:56.638  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Schedulescript läuft, Verbraucher 'sonoff.0.Lampe-Haustuer.POWER' wird geschaltet auf: true
                        2026-04-12 19:51:56.638  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Wert ist               : true
                        2026-04-12 19:51:56.638  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Letzter_Verbraucher ist: true
                        2026-04-12 19:51:56.638  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Abendlichtstatus wird gesetzt auf: true
                        2026-04-12 19:51:56.662  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                        2026-04-12 19:51:57.514  - info: vis.0 (3926) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:51:57.725  - info: host.iobroker iobroker npm-rebuild: exit 1
                        2026-04-12 19:51:58.160  - info: host.iobroker instance system.adapter.vis-2.0 in version "2.13.8" started with pid 3954
                        2026-04-12 19:51:58.194  - info: web.0 (3470) ==> Connected system.user.admin from ::ffff:192.168.30.26
                        2026-04-12 19:51:58.216  - info: host.iobroker instance system.adapter.zigbee.0 in version "3.3.5" started with pid 3960
                        2026-04-12 19:51:58.429  - info: vis.0 (3926) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                        2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]:   throw err;
                        2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]:   ^
                        2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                        2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]: Require stack:
                        2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js
                        2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                        2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                        2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                        2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                        2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                        2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                        2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                        2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                        2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                        2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:9:15)
                        2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                        2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                        2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:   requireStack: [
                        2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js',
                        2026-04-12 19:53:16.271  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:53:26.689  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:53:37.091  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:53:47.528  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:53:56.634  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Schedulescript läuft, Verbraucher 'sonoff.0.3er_Naehmaschine_WZ.POWER1' wird geschaltet auf: true
                        2026-04-12 19:53:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Wert ist               : true
                        2026-04-12 19:53:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Letzter_Verbraucher ist: true
                        2026-04-12 19:53:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Abendlichtstatus wird gesetzt auf: true
                        2026-04-12 19:53:58.109  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:54:08.524  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:54:18.937  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:54:29.316  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:54:39.725  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:54:50.126  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:54:56.634  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Schedulescript läuft, Verbraucher 'sonoff.0.Lampe-Kommode-WZ.POWER' wird geschaltet auf: true
                        2026-04-12 19:54:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Wert ist               : true
                        2026-04-12 19:54:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Letzter_Verbraucher ist: true
                        2026-04-12 19:54:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Abendlichtstatus wird gesetzt auf: true
                        2026-04-12 19:55:00.511  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:55:10.879  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:55:21.300  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:55:31.719  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:55:42.092  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:55:52.708  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:56:03.204  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:56:13.628  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:56:24.024  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:56:34.407  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:56:40.641  - info: javascript.0 (1456) script.js.Pool.Ausschalttemperatur_aendern: Stopping script
                        2026-04-12 19:56:40.644  - warn: web.0 (3470) setTimeout called, but adapter is shutting down
                        2026-04-12 19:56:40.641  - info: javascript.0 (1456) script.js.Pool.Einschalttemperatur_aendern: Stopping script
                        2026-04-12 19:56:40.641  - info: javascript.0 (1456) script.js.Pool.Frostalarm_Huette: Stopping script
                        2026-04-12 19:56:40.641  - info: javascript.0 (1456) script.js.Schalter.Aquara_Doppelschalter_WZ: Stopping script
                        2026-04-12 19:56:40.641  - info: javascript.0 (1456) script.js.Schalter.Bewegungssensor_Flur: Stopping script
                        2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Schalter.Rollaeden: Stopping script
                        2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Schalter.Taster_Rollaeden: Stopping script
                        2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Solar.Solarwerte_addieren: Stopping script
                        2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Solar.Verbrauchsdaten_sichern: Stopping script
                        2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Solar.Werte_addieren: Stopping script
                        2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_Button: Stopping script
                        2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Stopping script
                        2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Zeitplaene.Fernseher_aus: Stopping script
                        2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Schalter.RundTaster_Rollaeden: Stopping script
                        2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Solar.MPPT_WatchDog: Stopping script
                        2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.common.Netzwerk: Stopping script
                        2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Solar.Hausverbrauch: Stopping script
                        2026-04-12 19:56:40.640  - info: host.iobroker received SIGTERM
                        2026-04-12 19:56:40.647  - info: energiefluss-erweitert.0 (3537) Cleared interval for relative values!
                        2026-04-12 19:56:40.641  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=false)
                        2026-04-12 19:56:40.641  - info: host.iobroker stopInstance system.adapter.history.0 (force=false, process=false)
                        2026-04-12 19:56:40.641  - info: host.iobroker stopInstance system.adapter.influxdb.0 (force=false, process=true)
                        2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=true)
                        2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.whatsapp-cmb.0 (force=false, process=true)
                        2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=false)
                        2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.mqtt.0 (force=false, process=true)
                        2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.ping.0 (force=false, process=true)
                        2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.proxmox.0 (force=false, process=false)
                        2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 (force=false, process=false)
                        2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.sonoff.0 (force=false, process=true)
                        2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.zigbee.0 (force=false, process=false)
                        2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.daswetter.0 (force=false, process=false)
                        2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.echarts.0 (force=false, process=true)
                        2026-04-12 19:56:40.643  - info: host.iobroker stopInstance system.adapter.jarvis.0 (force=false, process=false)
                        2026-04-12 19:56:40.643  - info: host.iobroker stopInstance system.adapter.linux-control.0 (force=false, process=false)
                        2026-04-12 19:56:40.648  - info: host.iobroker stopInstance system.adapter.vis-canvas-gauges.0 (force=false, process=false)
                        2026-04-12 19:56:40.648  - info: host.iobroker stopInstance system.adapter.vis-inventwo.0 (force=false, process=false)
                        2026-04-12 19:56:40.649  - info: host.iobroker stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
                        2026-04-12 19:56:40.649  - info: host.iobroker stopInstance system.adapter.vis-materialdesign.0 (force=false, process=false)
                        2026-04-12 19:56:40.649  - info: host.iobroker stopInstance system.adapter.vis.0 (force=false, process=false)
                        2026-04-12 19:56:40.649  - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
                        2026-04-12 19:56:40.649  - info: host.iobroker stopInstance system.adapter.discovery.0 (force=false, process=false)
                        2026-04-12 19:56:40.649  - info: host.iobroker stopInstance system.adapter.energiefluss-erweitert.0 (force=false, process=true)
                        2026-04-12 19:56:40.649  - info: host.iobroker stopInstance system.adapter.vis-2.0 (force=false, process=true)
                        2026-04-12 19:56:40.650  - info: host.iobroker stopInstance system.adapter.reolink.0 (force=false, process=true)
                        2026-04-12 19:56:40.658  - info: javascript.0 (1456) Got terminate signal TERMINATE_YOURSELF
                        2026-04-12 19:56:40.658  - info: mqtt.0 (1991) Got terminate signal TERMINATE_YOURSELF
                        2026-04-12 19:56:40.658  - info: whatsapp-cmb.0 (1782) Got terminate signal TERMINATE_YOURSELF
                        2026-04-12 19:56:40.659  - info: sonoff.0 (2494) Got terminate signal TERMINATE_YOURSELF
                        2026-04-12 19:56:40.659  - info: echarts.0 (2811) Got terminate signal TERMINATE_YOURSELF
                        2026-04-12 19:56:40.659  - info: ping.0 (2422) Got terminate signal TERMINATE_YOURSELF
                        2026-04-12 19:56:40.660  - info: web.0 (3470) Got terminate signal TERMINATE_YOURSELF
                        2026-04-12 19:56:40.661  - info: energiefluss-erweitert.0 (3537) Got terminate signal TERMINATE_YOURSELF
                        2026-04-12 19:56:40.662  - info: reolink.0 (3983) Got terminate signal TERMINATE_YOURSELF
                        2026-04-12 19:56:40.661  - info: vis-2.0 (3954) Got terminate signal TERMINATE_YOURSELF
                        2026-04-12 19:56:40.664  - info: mqtt.0 (1991) terminating
                        2026-04-12 19:56:40.666  - info: vis-2.0 (3954) terminating
                        2026-04-12 19:56:40.667  - info: vis-2.0 (3954) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:56:40.665  - info: energiefluss-erweitert.0 (3537) terminating
                        2026-04-12 19:56:40.666  - info: energiefluss-erweitert.0 (3537) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:56:40.665  - info: mqtt.0 (1991) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:56:40.668  - info: reolink.0 (3983) terminating
                        2026-04-12 19:56:40.669  - info: reolink.0 (3983) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:56:40.668  - info: host.iobroker stopInstance system.adapter.javascript.0 send kill signal
                        2026-04-12 19:56:40.670  - info: influxdb.0 (1085) terminating
                        2026-04-12 19:56:40.670  - info: influxdb.0 (1085) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.whatsapp-cmb.0 send kill signal
                        2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.mqtt.0 send kill signal
                        2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.ping.0 send kill signal
                        2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.sonoff.0 send kill signal
                        2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.echarts.0 send kill signal
                        2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
                        2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.energiefluss-erweitert.0 send kill signal
                        2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.vis-2.0 send kill signal
                        2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.reolink.0 send kill signal
                        2026-04-12 19:56:40.744  - info: javascript.0 (1456) terminating
                        2026-04-12 19:56:40.744  - info: javascript.0 (1456) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:56:41.144  - info: javascript.0 (1456) terminating
                        2026-04-12 19:56:41.144  - info: whatsapp-cmb.0 (1782) terminating
                        2026-04-12 19:56:41.145  - info: ping.0 (2422) terminating
                        2026-04-12 19:56:41.145  - info: whatsapp-cmb.0 (1782) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:56:41.146  - info: ping.0 (2422) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:56:41.146  - info: echarts.0 (2811) terminating
                        2026-04-12 19:56:41.147  - info: reolink.0 (3983) terminating
                        2026-04-12 19:56:41.147  - info: web.0 (3470) terminating
                        2026-04-12 19:56:41.147  - info: echarts.0 (2811) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:56:41.148  - info: web.0 (3470) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:56:41.148  - info: vis-2.0 (3954) terminating
                        2026-04-12 19:56:41.149  - info: sonoff.0 (2494) terminating
                        2026-04-12 19:56:41.149  - info: sonoff.0 (2494) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:56:41.150  - info: energiefluss-erweitert.0 (3537) terminating
                        2026-04-12 19:56:41.166  - info: mqtt.0 (1991) terminating
                        2026-04-12 19:56:41.170  - warn: mqtt.0 (1991) get state error: Connection is closed.
                        2026-04-12 19:56:41.208  - info: host.iobroker instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
                        2026-04-12 19:56:41.256  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
                        2026-04-12 19:56:41.256  - info: host.iobroker instance system.adapter.energiefluss-erweitert.0 terminated with code 0 (NO_ERROR)
                        2026-04-12 19:56:41.256  - info: host.iobroker instance system.adapter.vis-2.0 terminated with code 0 (NO_ERROR)
                        2026-04-12 19:56:41.256  - info: host.iobroker instance system.adapter.reolink.0 terminated with code 0 (NO_ERROR)
                        2026-04-12 19:56:41.284  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                        2026-04-12 19:56:41.685  - info: host.iobroker instance system.adapter.whatsapp-cmb.0 terminated with code 0 (NO_ERROR)
                        2026-04-12 19:56:41.723  - info: host.iobroker instance system.adapter.ping.0 terminated with code 0 (NO_ERROR)
                        2026-04-12 19:56:41.723  - info: host.iobroker instance system.adapter.sonoff.0 terminated with code 0 (NO_ERROR)
                        2026-04-12 19:56:41.724  - warn: host.iobroker instance system.adapter.echarts.0 terminated due to SIGSEGV
                        2026-04-12 19:56:41.724  - info: host.iobroker instance system.adapter.echarts.0 terminated with code null ()
                        2026-04-12 19:56:41.724  - info: host.iobroker instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
                        2026-04-12 19:56:41.724  - info: host.iobroker All instances are stopped.
                        2026-04-12 19:56:41.864  - info: host.iobroker terminated
                        2026-04-12 19:57:26.770  - info: host.iobroker iobroker.js-controller version 7.0.7 js-controller starting
                        2026-04-12 19:57:26.772  - info: host.iobroker Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                        2026-04-12 19:57:26.772  - info: host.iobroker hostname: iobroker, node: v22.22.2
                        2026-04-12 19:57:26.773  - info: host.iobroker ip addresses: 192.168.20.131 fe80::fc21:e4ff:fe0c:531d
                        2026-04-12 19:57:27.372  - info: host.iobroker connected to Objects and States
                        2026-04-12 19:57:27.382  - info: host.iobroker added notifications configuration of host
                        2026-04-12 19:57:27.638  - info: host.iobroker 31 instances found
                        2026-04-12 19:57:27.654  - info: host.iobroker starting 14 instances
                        2026-04-12 19:57:27.926  - info: host.iobroker instance system.adapter.admin.0 in version "7.7.22" started with pid 5427
                        2026-04-12 19:57:28.005  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                        2026-04-12 19:57:28.005  - error: host.iobroker Caught by controller[0]:   throw err;
                        2026-04-12 19:57:28.005  - error: host.iobroker Caught by controller[0]:   ^
                        2026-04-12 19:57:28.005  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                        2026-04-12 19:57:28.005  - error: host.iobroker Caught by controller[0]: Require stack:
                        2026-04-12 19:57:28.005  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/build/main.js
                        2026-04-12 19:57:28.005  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                        2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                        2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                        2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                        2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                        2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                        2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                        2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                        2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/build/main.js:13:17)
                        2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                        2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                        2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/build/main.js' ]
                        2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]: }
                        2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                        2026-04-12 19:57:28.006  - error: host.iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2026-04-12 19:57:28.006  - info: host.iobroker Adapter system.adapter.admin.0 needs rebuild and will be restarted afterwards.
                        2026-04-12 19:57:28.008  - info: host.iobroker system.adapter.admin.0 will be rebuilt
                        2026-04-12 19:57:28.009  - warn: host.iobroker adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                        2026-04-12 19:57:28.009  - info: host.iobroker iobroker rebuild
                        2026-04-12 19:57:28.584  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                        2026-04-12 19:57:32.040  - info: host.iobroker instance system.adapter.influxdb.0 in version "4.0.2" started with pid 5726
                        2026-04-12 19:57:32.502  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                        2026-04-12 19:57:33.363  - info: vis.0 (5839) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:57:33.390  - info: influxdb.0 (5726) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.influxdb, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:57:33.403  - info: influxdb.0 (5726) No stored data from last exit found
                        2026-04-12 19:57:33.404  - info: influxdb.0 (5726) Connecting http://192.168.20.133:8086/ ...
                        2026-04-12 19:57:33.404  - info: influxdb.0 (5726) Influx DB Version used: 1.x
                        2026-04-12 19:57:33.445  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Solar.SolarAktuell, Alias=false, 1 points now activated
                        2026-04-12 19:57:33.452  - info: host.iobroker iobroker npm-rebuild: exit 1
                        2026-04-12 19:57:33.445  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Solar.TagesGesamt, Alias=false, 2 points now activated
                        2026-04-12 19:57:33.445  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.GesamtVerbrauch, Alias=false, 3 points now activated
                        2026-04-12 19:57:33.446  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.Nachtverbrauch, Alias=false, 4 points now activated
                        2026-04-12 19:57:33.446  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.Tagverbrauch, Alias=false, 5 points now activated
                        2026-04-12 19:57:33.446  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.ZaehlerGestern, Alias=false, 6 points now activated
                        2026-04-12 19:57:33.447  - info: influxdb.0 (5726) enabled logging of mqtt.0.Gartenhaus.Solartemperatur.Temperature, Alias=false, 7 points now activated
                        2026-04-12 19:57:33.447  - info: influxdb.0 (5726) enabled logging of mqtt.0.T2S-Garage.ACDISPLAY, Alias=false, 8 points now activated
                        2026-04-12 19:57:33.447  - info: influxdb.0 (5726) enabled logging of mqtt.0.T2S-Garage.ACSETPOINT, Alias=false, 9 points now activated
                        2026-04-12 19:57:33.448  - info: influxdb.0 (5726) enabled logging of mqtt.0.T2S-Garage.VBAT, Alias=false, 10 points now activated
                        2026-04-12 19:57:33.448  - info: influxdb.0 (5726) enabled logging of sonoff.0.Einspeisung-Akku.ENERGY_Power, Alias=false, 11 points now activated
                        2026-04-12 19:57:33.448  - info: influxdb.0 (5726) enabled logging of sonoff.0.Einspeisung-Holzplatz.ENERGY_Power, Alias=false, 12 points now activated
                        2026-04-12 19:57:33.448  - info: influxdb.0 (5726) enabled logging of sonoff.0.Gefrierschrank.ENERGY_Power, Alias=false, 13 points now activated
                        2026-04-12 19:57:33.448  - info: influxdb.0 (5726) enabled logging of sonoff.0.Gefriertruhe.ENERGY_Power, Alias=false, 14 points now activated
                        2026-04-12 19:57:33.448  - info: influxdb.0 (5726) enabled logging of sonoff.0.Getraenkekuehlschrank.ENERGY_Power, Alias=false, 15 points now activated
                        2026-04-12 19:57:33.449  - info: influxdb.0 (5726) enabled logging of sonoff.0.Zaehler-Haus.MT681_Power_cur, Alias=false, 16 points now activated
                        2026-04-12 19:57:33.449  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.KuehlschrankRechtsTagesGesamt, Alias=false, 17 points now activated
                        2026-04-12 19:57:33.449  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.KuehlschrankLinksTagesGesamt, Alias=false, 18 points now activated
                        2026-04-12 19:57:33.449  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.GefriertruheTagesGesamt, Alias=false, 19 points now activated
                        2026-04-12 19:57:33.449  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.GefrierschrankTagesGesamt, Alias=false, 20 points now activated
                        2026-04-12 19:57:33.449  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.WaschmaschineTagesGesamt, Alias=false, 21 points now activated
                        2026-04-12 19:57:33.449  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.TrocknerTagesGesamt, Alias=false, 22 points now activated
                        2026-04-12 19:57:33.450  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.GetraenkeKuehlschrankTagesGesamt, Alias=false, 23 points now activated
                        2026-04-12 19:57:33.450  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.KuechenKuehlschrankTagesGesamt, Alias=false, 24 points now activated
                        2026-04-12 19:57:33.450  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.SummeVerbrauch, Alias=false, 25 points now activated
                        2026-04-12 19:57:33.933  - info: host.iobroker instance system.adapter.admin.0 in version "7.7.22" started with pid 5875
                        2026-04-12 19:57:34.028  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                        2026-04-12 19:57:34.028  - error: host.iobroker Caught by controller[0]:   throw err;
                        2026-04-12 19:57:34.028  - error: host.iobroker Caught by controller[0]:   ^
                        2026-04-12 19:57:34.028  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                        2026-04-12 19:57:34.028  - error: host.iobroker Caught by controller[0]: Require stack:
                        2026-04-12 19:57:34.028  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/build/main.js
                        2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                        2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                        2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                        2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                        2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                        2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                        2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                        2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                        2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/build/main.js:13:17)
                        2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                        2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                        2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/build/main.js' ]
                        2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]: }
                        2026-04-12 19:57:34.030  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                        2026-04-12 19:57:34.030  - error: host.iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2026-04-12 19:57:34.030  - info: host.iobroker Adapter system.adapter.admin.0 needs rebuild and will be restarted afterwards.
                        2026-04-12 19:57:34.030  - info: host.iobroker system.adapter.admin.0 will be rebuilt
                        2026-04-12 19:57:34.030  - warn: host.iobroker adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                        2026-04-12 19:57:34.030  - info: host.iobroker iobroker rebuild
                        2026-04-12 19:57:34.473  - info: vis.0 (5839) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:57:34.789  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                        2026-04-12 19:57:35.947  - info: host.iobroker instance system.adapter.javascript.0 in version "9.0.18" started with pid 5924
                        2026-04-12 19:57:37.660  - info: javascript.0 (5924) starting. Version 9.0.18 in /opt/iobroker/node_modules/iobroker.javascript, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:57:38.982  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                        2026-04-12 19:57:40.037  - info: host.iobroker iobroker npm-rebuild: exit 1
                        2026-04-12 19:57:40.050  - info: host.iobroker instance system.adapter.whatsapp-cmb.0 in version "0.3.0" started with pid 6382
                        2026-04-12 19:57:40.440  - info: host.iobroker instance system.adapter.admin.0 in version "7.7.22" started with pid 6390
                        2026-04-12 19:57:40.540  - info: vis.0 (6370) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                        2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]:   throw err;
                        2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]:   ^
                        2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                        2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]: Require stack:
                        2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/build/main.js
                        2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                        2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                        2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                        2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                        2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                        2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                        2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                        2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                        2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/build/main.js:13:17)
                        2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                        2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                        2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/build/main.js' ]
                        2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]: }
                        2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                        2026-04-12 19:57:40.635  - error: host.iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2026-04-12 19:57:40.635  - info: host.iobroker Adapter system.adapter.admin.0 needs rebuild and will be restarted afterwards.
                        2026-04-12 19:57:40.635  - info: host.iobroker system.adapter.admin.0 will be rebuilt
                        2026-04-12 19:57:40.635  - warn: host.iobroker adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                        2026-04-12 19:57:40.636  - info: host.iobroker iobroker rebuild
                        2026-04-12 19:57:41.528  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                        2026-04-12 19:57:41.571  - info: whatsapp-cmb.0 (6382) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:57:41.621  - info: vis.0 (6370) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:57:44.016  - info: host.iobroker instance system.adapter.mqtt.0 in version "6.1.4" started with pid 6588
                        2026-04-12 19:57:45.724  - info: mqtt.0 (6588) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.mqtt, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:57:45.822  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                        2026-04-12 19:57:45.944  - info: mqtt.0 (6588) Starting MQTT server on 0.0.0.0:1884
                        2026-04-12 19:57:45.944  - info: mqtt.0 (6588) Starting MQTT-WebSocket server on 0.0.0.0:1885
                        2026-04-12 19:57:46.854  - info: host.iobroker iobroker npm-rebuild: exit 1
                        2026-04-12 19:57:47.328  - info: host.iobroker instance system.adapter.admin.0 in version "7.7.22" started with pid 6917
                        2026-04-12 19:57:47.439  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                        2026-04-12 19:57:47.439  - error: host.iobroker Caught by controller[0]:   throw err;
                        2026-04-12 19:57:47.439  - error: host.iobroker Caught by controller[0]:   ^
                        2026-04-12 19:57:47.439  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                        2026-04-12 19:57:47.439  - error: host.iobroker Caught by controller[0]: Require stack:
                        2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/build/main.js
                        2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                        2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                        2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                        2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                        2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                        2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                        2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                        2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                        2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/build/main.js:13:17)
                        2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                        2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                        2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/build/main.js' ]
                        2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]: }
                        2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                        2026-04-12 19:57:47.440  - error: host.iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2026-04-12 19:57:47.440  - info: host.iobroker Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                        2026-04-12 19:57:47.492  - info: vis.0 (6905) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:57:47.520  - info: mqtt.0 (6588) Client [OpenDTU-15427312] connected with secret 1776016667489_3478
                        2026-04-12 19:57:47.575  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_relative" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_relative/
                        2026-04-12 19:57:47.576  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_relative"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_relative/
                        2026-04-12 19:57:47.581  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_absolute" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_absolute/
                        2026-04-12 19:57:47.581  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_absolute"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_absolute/
                        2026-04-12 19:57:47.582  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_relative" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_relative/
                        2026-04-12 19:57:47.582  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_relative"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_relative/
                        2026-04-12 19:57:47.582  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_absolute" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_absolute/
                        2026-04-12 19:57:47.583  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_absolute"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_absolute/
                        2026-04-12 19:57:47.583  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/power" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.power/
                        2026-04-12 19:57:47.583  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/power"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.power/
                        2026-04-12 19:57:47.585  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/restart" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.restart/
                        2026-04-12 19:57:47.585  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/restart"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.restart/
                        2026-04-12 19:57:47.587  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_online_voltage"
                        2026-04-12 19:57:47.588  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_online_current"
                        2026-04-12 19:57:47.590  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_offline_voltage"
                        2026-04-12 19:57:47.614  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_offline_current"
                        2026-04-12 19:57:47.615  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.mode"
                        2026-04-12 19:57:47.662  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.powerlimiter.cmd.mode"
                        2026-04-12 19:57:47.776  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                        2026-04-12 19:57:47.781  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                        2026-04-12 19:57:47.782  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                        2026-04-12 19:57:47.783  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                        2026-04-12 19:57:47.784  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                        2026-04-12 19:57:47.785  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                        2026-04-12 19:57:47.790  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                        2026-04-12 19:57:47.791  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                        2026-04-12 19:57:47.815  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                        2026-04-12 19:57:47.862  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                        2026-04-12 19:57:47.957  - info: host.iobroker instance system.adapter.ping.0 in version "1.7.9" started with pid 6928
                        2026-04-12 19:57:48.503  - info: vis.0 (6905) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:57:49.163  - info: ping.0 (6928) starting. Version 1.7.9 in /opt/iobroker/node_modules/iobroker.ping, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:57:51.928  - info: host.iobroker instance system.adapter.sonoff.0 in version "3.3.0" started with pid 6982
                        2026-04-12 19:57:52.927  - info: sonoff.0 (6982) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.sonoff, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:57:52.947  - info: sonoff.0 (6982) Starting MQTT  server on port 1883
                        2026-04-12 19:57:53.595  - info: javascript.0 (5924) requesting all states
                        2026-04-12 19:57:53.596  - info: javascript.0 (5924) requesting all objects
                        2026-04-12 19:57:54.021  - info: javascript.0 (5924) received all objects
                        2026-04-12 19:57:54.055  - info: javascript.0 (5924) received all states
                        2026-04-12 19:57:54.143  - info: javascript.0 (5924) script.js.Pool.Ausschalttemperatur_aendern: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.157  - info: javascript.0 (5924) script.js.Pool.Ausschalttemperatur_aendern: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.157  - info: javascript.0 (5924) script.js.Pool.Einschalttemperatur_aendern: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.169  - info: javascript.0 (5924) script.js.Pool.Einschalttemperatur_aendern: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.169  - info: javascript.0 (5924) script.js.Pool.Frostalarm_Huette: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.172  - info: javascript.0 (5924) script.js.Pool.Frostalarm_Huette: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.172  - info: javascript.0 (5924) script.js.Schalter.Aquara_Doppelschalter_WZ: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.174  - info: javascript.0 (5924) script.js.Schalter.Aquara_Doppelschalter_WZ: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.174  - info: javascript.0 (5924) script.js.Schalter.Bewegungssensor_Flur: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.177  - info: javascript.0 (5924) script.js.Schalter.Bewegungssensor_Flur: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.177  - info: javascript.0 (5924) script.js.Schalter.Rollaeden: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.180  - info: javascript.0 (5924) script.js.Schalter.Rollaeden: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.180  - info: javascript.0 (5924) script.js.Schalter.Taster_Rollaeden: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.183  - info: javascript.0 (5924) script.js.Schalter.Taster_Rollaeden: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.184  - info: javascript.0 (5924) script.js.Solar.Solarwerte_addieren: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.187  - info: javascript.0 (5924) script.js.Solar.Solarwerte_addieren: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.187  - info: javascript.0 (5924) script.js.Solar.Verbrauchsdaten_sichern: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.210  - info: javascript.0 (5924) script.js.Solar.Verbrauchsdaten_sichern: registered 0 subscriptions, 3 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.211  - info: javascript.0 (5924) script.js.Solar.Werte_addieren: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.213  - info: javascript.0 (5924) script.js.Solar.Werte_addieren: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.213  - info: javascript.0 (5924) script.js.Zeitplaene.Abendlichter_Button: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.215  - info: javascript.0 (5924) script.js.Zeitplaene.Abendlichter_Button: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.223  - info: javascript.0 (5924) script.js.Zeitplaene.Abendlichter_automatik: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.233  - info: javascript.0 (5924) script.js.Zeitplaene.Abendlichter_automatik: registered 0 subscriptions, 8 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.233  - info: javascript.0 (5924) script.js.Zeitplaene.Fernseher_aus: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.238  - info: javascript.0 (5924) script.js.Zeitplaene.Fernseher_aus: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.240  - info: javascript.0 (5924) script.js.Schalter.RundTaster_Rollaeden: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.243  - info: javascript.0 (5924) script.js.Schalter.RundTaster_Rollaeden: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.244  - info: javascript.0 (5924) script.js.Solar.MPPT_WatchDog: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.247  - info: javascript.0 (5924) script.js.Solar.MPPT_WatchDog: registered 7 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.247  - info: javascript.0 (5924) script.js.common.Netzwerk: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.249  - info: javascript.0 (5924) script.js.common.Netzwerk: registered 8 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.250  - info: javascript.0 (5924) script.js.Solar.Hausverbrauch: start JavaScript (Javascript/js)
                        2026-04-12 19:57:54.253  - info: javascript.0 (5924) script.js.Solar.Hausverbrauch: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-04-12 19:57:54.255  - info: javascript.0 (5924) script.js.Schalter.Rollaeden: Es werden alle Rollo beim Auffahren gestoppt
                        2026-04-12 19:57:54.256  - info: javascript.0 (5924) script.js.Schalter.Rollaeden: Es werden alle Rollo beim Zufahren gestoppt
                        2026-04-12 19:57:54.261  - info: sonoff.0 (6982) Client "Rolladen-Erker-1" not connected
                        2026-04-12 19:57:54.262  - info: sonoff.0 (6982) Client "Rolladen-Erker-2" not connected
                        2026-04-12 19:57:54.262  - info: sonoff.0 (6982) Client "Rolladen-Erker-3" not connected
                        2026-04-12 19:57:54.263  - info: sonoff.0 (6982) Client "Rolladen-Erker-4" not connected
                        2026-04-12 19:57:54.263  - info: sonoff.0 (6982) Client "Rolladen-Erker-1" not connected
                        2026-04-12 19:57:54.264  - info: sonoff.0 (6982) Client "Rolladen-Erker-2" not connected
                        2026-04-12 19:57:54.265  - info: sonoff.0 (6982) Client "Rolladen-Erker-3" not connected
                        2026-04-12 19:57:54.265  - info: sonoff.0 (6982) Client "Rolladen-Erker-4" not connected
                        2026-04-12 19:57:55.315  - info: sonoff.0 (6982) Client [Sensor Heizung] connected with secret 1776016675311_705
                        2026-04-12 19:57:55.910  - info: host.iobroker instance system.adapter.zigbee.0 in version "3.3.5" started with pid 7013
                        2026-04-12 19:57:56.414  - info: mqtt.0 (6588) Client [nodered05568ac752885a52] connected with secret 1776016676408_6453
                        2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                        2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:   throw err;
                        2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:   ^
                        2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                        2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]: Require stack:
                        2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js
                        2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                        2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                        2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                        2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                        2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                        2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                        2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                        2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                        2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                        2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:9:15)
                        2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                        2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                        2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]:   requireStack: [
                        2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js',
                        2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                        2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]:   ]
                        2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]: }
                        2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                        2026-04-12 19:57:56.571  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2026-04-12 19:57:56.571  - info: host.iobroker Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                        2026-04-12 19:57:56.571  - info: host.iobroker system.adapter.zigbee.0 will be rebuilt
                        2026-04-12 19:57:56.571  - warn: host.iobroker adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                        2026-04-12 19:57:56.571  - info: host.iobroker iobroker rebuild
                        2026-04-12 19:57:57.209  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                        2026-04-12 19:57:59.981  - info: host.iobroker instance system.adapter.echarts.0 in version "3.1.0" started with pid 7313
                        2026-04-12 19:58:00.664  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                        2026-04-12 19:58:01.490  - info: echarts.0 (7313) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.echarts, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:58:01.679  - info: host.iobroker iobroker npm-rebuild: exit 1
                        2026-04-12 19:58:02.059  - info: host.iobroker instance system.adapter.zigbee.0 in version "3.3.5" started with pid 7506
                        2026-04-12 19:58:02.073  - info: vis.0 (7472) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:58:03.011  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                        2026-04-12 19:58:03.011  - error: host.iobroker Caught by controller[0]:   throw err;
                        2026-04-12 19:58:03.011  - error: host.iobroker Caught by controller[0]:   ^
                        2026-04-12 19:58:03.011  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                        2026-04-12 19:58:03.011  - error: host.iobroker Caught by controller[0]: Require stack:
                        2026-04-12 19:58:03.011  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js
                        2026-04-12 19:58:03.011  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                        2026-04-12 19:58:03.011  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                        2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                        2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                        2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                        2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                        2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                        2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                        2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                        2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:9:15)
                        2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                        2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                        2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:   requireStack: [
                        2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js',
                        2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                        2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:   ]
                        2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]: }
                        2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                        2026-04-12 19:58:03.012  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2026-04-12 19:58:03.012  - info: host.iobroker Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                        2026-04-12 19:58:03.012  - info: host.iobroker system.adapter.zigbee.0 will be rebuilt
                        2026-04-12 19:58:03.012  - warn: host.iobroker adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                        2026-04-12 19:58:03.012  - info: host.iobroker iobroker rebuild
                        2026-04-12 19:58:03.050  - info: vis.0 (7472) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:58:03.607  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                        2026-04-12 19:58:04.805  - info: vis.0 (7542) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:58:05.699  - info: vis.0 (7542) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:58:06.247  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
                        2026-04-12 19:58:07.706  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                        2026-04-12 19:58:07.987  - info: host.iobroker instance system.adapter.web.0 in version "8.0.0" started with pid 7955
                        2026-04-12 19:58:08.525  - info: vis.0 (7931) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:58:08.720  - info: host.iobroker iobroker npm-rebuild: exit 1
                        2026-04-12 19:58:09.128  - info: host.iobroker instance system.adapter.zigbee.0 in version "3.3.5" started with pid 7971
                        2026-04-12 19:58:09.443  - info: web.0 (7955) starting. Version 8.0.0 in /opt/iobroker/node_modules/iobroker.web, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:58:09.661  - info: vis.0 (7931) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:58:09.712  - info: web.0 (7955) socket.io server listening on port 8082
                        2026-04-12 19:58:09.756  - info: web.0 (7955) Connecting extension "energiefluss-erweitert/lib/web.js"
                        2026-04-12 19:58:09.757  - info: web.0 (7955) [energiefluss-erweitert.0] Sharp was found and can be used for image processing!
                        2026-04-12 19:58:09.760  - info: web.0 (7955) http server listening on port 8082
                        2026-04-12 19:58:09.835  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:   throw err;
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:   ^
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]: Require stack:
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:9:15)
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:   requireStack: [
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js',
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:   ]
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]: }
                        2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                        2026-04-12 19:58:09.836  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2026-04-12 19:58:09.836  - info: host.iobroker Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                        2026-04-12 19:58:09.836  - info: host.iobroker system.adapter.zigbee.0 will be rebuilt
                        2026-04-12 19:58:09.836  - warn: host.iobroker adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                        2026-04-12 19:58:09.837  - info: host.iobroker iobroker rebuild
                        2026-04-12 19:58:10.427  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                        2026-04-12 19:58:11.946  - info: host.iobroker instance system.adapter.energiefluss-erweitert.0 in version "0.8.1" started with pid 8011
                        2026-04-12 19:58:12.989  - info: energiefluss-erweitert.0 (8011) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:58:13.005  - warn: energiefluss-erweitert.0 (8011) Workspace configuration is NOT password protected!
                        2026-04-12 19:58:13.022  - info: energiefluss-erweitert.0 (8011) Adapter started. Loading config!
                        2026-04-12 19:58:13.565  - info: energiefluss-erweitert.0 (8011) Configuration loaded!
                        2026-04-12 19:58:13.565  - info: energiefluss-erweitert.0 (8011) Requesting the following states: energiefluss-erweitert.0.configuration,mqtt.0.VenusOS.PVGesamtLeistung,mqtt.0.VenusOS.Akku.Ladung_W,mqtt.0.VenusOS.Akku.SoC,mqtt.0.VenusOS.String1.PV_Status,mqtt.0.T2S-Garage.ACDISPLAY,mqtt.0.openDTU_Holzplatz.ac.power,mqtt.0.VenusOS.Hichi.VerbrauchAktuell,sonoff.0.Schalter-A1-Mini.ENERGY_Power,0_userdata.0.Visualisierung.Solar.Hausverbrauch,sonoff.0.Getraenkekuehlschrank.ENERGY_Power,sonoff.0.Schalter-Spuelmaschine.ENERGY_Power,sonoff.0.Gefrierschrank.ENERGY_Power,sonoff.0.Gefriertruhe.ENERGY_Power,sonoff.0.Schalter-Waschmaschine.ENERGY_Power,sonoff.0.Schalter-Trockner.ENERGY_Power,sonoff.0.Kuehlschrank-links.ENERGY_Power,sonoff.0.Kuehlschrank-rechts.ENERGY_Power,sonoff.0.Schalter-Heizungspumpe.ENERGY_Power,sonoff.0.PC-Buero.ENERGY_Power,sonoff.0.Schalter-A1-Mini.POWER,sonoff.0.Poolpumpe.ENERGY_Power,sonoff.0.Poolpumpe.POWER,mqtt.0.VenusOS.Akku.Volt,sonoff.0.Ofen_Wohnzimmer.ENERGY_Power
                        2026-04-12 19:58:14.533  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                        2026-04-12 19:58:15.170  - info: web.0 (7955) ==> Connected system.user.admin from ::ffff:192.168.30.26
                        2026-04-12 19:58:15.383  - info: vis.0 (8400) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:58:15.538  - info: host.iobroker iobroker npm-rebuild: exit 1
                        2026-04-12 19:58:16.095  - info: host.iobroker instance system.adapter.zigbee.0 in version "3.3.5" started with pid 8428
                        2026-04-12 19:58:16.101  - info: host.iobroker instance system.adapter.vis-2.0 in version "2.13.8" started with pid 8429
                        2026-04-12 19:58:16.616  - info: vis.0 (8400) Terminated (NO_ERROR): Without reason
                        2026-04-12 19:58:16.911  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:   throw err;
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:   ^
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]: Require stack:
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:9:15)
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:   requireStack: [
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js',
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:   ]
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]: }
                        2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                        2026-04-12 19:58:16.912  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2026-04-12 19:58:16.912  - info: host.iobroker Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                        2026-04-12 19:58:17.231  - info: vis-2.0 (8429) starting. Version 2.13.8 in /opt/iobroker/node_modules/iobroker.vis-2, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:58:17.369  - info: vis-2.0 (8429) vis-2 license is OK.
                        2026-04-12 19:58:19.918  - info: host.iobroker instance system.adapter.reolink.0 in version "1.4.2" started with pid 8456
                        2026-04-12 19:58:20.799  - info: reolink.0 (8456) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.reolink, node: v22.22.2, js-controller: 7.0.7
                        2026-04-12 19:58:20.867  - info: reolink.0 (8456) Reolink adapter has started
                        2026-04-12 19:58:20.904  - info: reolink.0 (8456) Current IP: 192.168.3.126
                        2026-04-12 19:58:21.611  - info: reolink.0 (8456) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:58:23.025  - warn: reolink.0 (8456) State "reolink.0.Device.Name" has no existing object, this might lead to an error in future versions
                        2026-04-12 19:58:23.114  - info: reolink.0 (8456) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                        2026-04-12 19:58:25.790  - info: sonoff.0 (6982) Client [Rolladen-Bakontuer] connected with secret 1776016705788_1973
                        2026-04-12 19:58:25.837  - info: sonoff.0 (6982) Client [3er_Naehmaschine_WZ] connected with secret 1776016705837_9664
                        2026-04-12 19:58:25.894  - info: sonoff.0 (6982) Client [Lampe_Erker] connected with secret 1776016705892_549
                        2026-04-12 19:58:25.908  - info: sonoff.0 (6982) Client [Schalter-Spuelmaschine] connected with secret 1776016705907_344
                        2026-04-12 19:58:25.913  - info: sonoff.0 (6982) Client [Getraenkekuehlschrank] connected with secret 1776016705911_3988
                        2026-04-12 19:58:25.915  - info: sonoff.0 (6982) Client [Ofen_Wohnzimmer] connected with secret 1776016705914_3495
                        2026-04-12 19:58:25.931  - info: sonoff.0 (6982) Client [PC-Buero] connected with secret 1776016705930_1307
                        2026-04-12 19:58:25.933  - info: sonoff.0 (6982) Client [Schalter-Trockner] connected with secret 1776016705931_77
                        2026-04-12 19:58:25.948  - info: sonoff.0 (6982) Client [Steckdose-Garage] connected with secret 1776016705945_4691
                        2026-04-12 19:58:26.041  - info: sonoff.0 (6982) Client [Einspeisung-Holzplatz] connected with secret 1776016706040_8480
                        2026-04-12 19:58:26.263  - info: sonoff.0 (6982) Client [Rolladen-Erker-4] connected with secret 1776016706253_4479
                        2026-04-12 19:58:26.292  - info: sonoff.0 (6982) Client [Anbau] connected with secret 1776016706292_5742
                        2026-04-12 19:58:26.313  - info: sonoff.0 (6982) Client [Kuehlschrank-links] connected with secret 1776016706313_9857
                        2026-04-12 19:58:26.463  - info: sonoff.0 (6982) Client [Rolladen-Erker-2] connected with secret 1776016706457_5187
                        2026-04-12 19:58:26.493  - info: sonoff.0 (6982) Client [Rolladen-Erker-3] connected with secret 1776016706488_7743
                        2026-04-12 19:58:26.542  - info: sonoff.0 (6982) Client [Lampe-Kommode-WZ] connected with secret 1776016706541_9177
                        2026-04-12 19:58:26.623  - info: sonoff.0 (6982) Client [Teich] connected with secret 1776016706620_9933
                        2026-04-12 19:58:26.679  - info: sonoff.0 (6982) Client [Gefrierschrank] connected with secret 1776016706679_8530
                        2026-04-12 19:58:26.707  - info: sonoff.0 (6982) Client [Lampe-Haustuer] connected with secret 1776016706706_4786
                        2026-04-12 19:58:26.714  - info: sonoff.0 (6982) Client [Rolladen-Erker-1] connected with secret 1776016706713_1746
                        2026-04-12 19:58:27.182  - info: sonoff.0 (6982) Client [Zaehler-Haus] connected with secret 1776016707181_5192
                        2026-04-12 19:58:27.211  - info: sonoff.0 (6982) Client [Schalter-A1-Mini] connected with secret 1776016707210_9991
                        2026-04-12 19:58:28.404  - info: sonoff.0 (6982) Client [Luefterklappe] connected with secret 1776016708399_2214
                        2026-04-12 19:58:28.628  - info: sonoff.0 (6982) Client [Poolpumpe] connected with secret 1776016708628_6869
                        • N nettworker
                          Ist das log interessant?
                          ter@iobroker:~$ iob logs --watch
                          2026-04-12 19:51:38.652  - error: host.iobroker Caught by controller[0]: }
                          2026-04-12 19:51:38.652  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                          2026-04-12 19:51:38.652  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2026-04-12 19:51:38.652  - info: host.iobroker Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                          2026-04-12 19:51:38.652  - info: host.iobroker system.adapter.zigbee.0 will be rebuilt
                          2026-04-12 19:51:38.652  - warn: host.iobroker adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                          2026-04-12 19:51:38.653  - info: host.iobroker iobroker rebuild
                          2026-04-12 19:51:39.261  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                          2026-04-12 19:51:41.942  - info: host.iobroker instance system.adapter.echarts.0 in version "3.1.0" started with pid 2811
                          2026-04-12 19:51:42.573  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                          2026-04-12 19:51:43.250  - info: echarts.0 (2811) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.echarts, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:51:43.484  - info: vis.0 (2928) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:51:43.590  - info: host.iobroker iobroker npm-rebuild: exit 1
                          2026-04-12 19:51:43.926  - info: host.iobroker instance system.adapter.zigbee.0 in version "3.3.5" started with pid 2999
                          2026-04-12 19:51:44.486  - info: vis.0 (2928) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:   throw err;
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:   ^
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]: Require stack:
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:9:15)
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:   requireStack: [
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js',
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                          2026-04-12 19:51:44.719  - error: host.iobroker Caught by controller[0]:   ]
                          2026-04-12 19:51:44.720  - error: host.iobroker Caught by controller[0]: }
                          2026-04-12 19:51:44.720  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                          2026-04-12 19:51:44.720  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2026-04-12 19:51:44.720  - info: host.iobroker Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                          2026-04-12 19:51:44.720  - info: host.iobroker system.adapter.zigbee.0 will be rebuilt
                          2026-04-12 19:51:44.720  - warn: host.iobroker adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                          2026-04-12 19:51:44.720  - info: host.iobroker iobroker rebuild
                          2026-04-12 19:51:45.362  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                          2026-04-12 19:51:46.846  - info: vis.0 (3052) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:51:47.268  - info: sonoff.0 (2494) Client [Sensor Heizung] connected with secret 1776016307264_6249
                          2026-04-12 19:51:47.785  - info: vis.0 (3052) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:51:48.322  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
                          2026-04-12 19:51:49.281  - info: sonoff.0 (2494) Client [Kuehlschrank-links] connected with secret 1776016309277_1671
                          2026-04-12 19:51:49.329  - info: sonoff.0 (2494) Client [Anbau] connected with secret 1776016309324_160
                          2026-04-12 19:51:49.415  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                          2026-04-12 19:51:49.531  - info: sonoff.0 (2494) Client [Lampe-Kommode-WZ] connected with secret 1776016309531_789
                          2026-04-12 19:51:49.677  - info: sonoff.0 (2494) Client [Gefrierschrank] connected with secret 1776016309677_277
                          2026-04-12 19:51:49.702  - info: sonoff.0 (2494) Client [Lampe-Haustuer] connected with secret 1776016309702_7757
                          2026-04-12 19:51:49.717  - info: sonoff.0 (2494) Client [Lampe_Erker] connected with secret 1776016309717_7258
                          2026-04-12 19:51:49.835  - info: sonoff.0 (2494) Client [3er_Naehmaschine_WZ] connected with secret 1776016309833_952
                          2026-04-12 19:51:49.889  - info: sonoff.0 (2494) Client [Schalter-Trockner] connected with secret 1776016309888_4791
                          2026-04-12 19:51:49.894  - info: sonoff.0 (2494) Client [Getraenkekuehlschrank] connected with secret 1776016309894_3392
                          2026-04-12 19:51:49.911  - info: host.iobroker instance system.adapter.web.0 in version "8.0.0" started with pid 3470
                          2026-04-12 19:51:49.918  - info: sonoff.0 (2494) Client [Schalter-Spuelmaschine] connected with secret 1776016309918_593
                          2026-04-12 19:51:49.939  - info: sonoff.0 (2494) Client [Steckdose-Garage] connected with secret 1776016309939_3586
                          2026-04-12 19:51:49.941  - info: sonoff.0 (2494) Client [PC-Buero] connected with secret 1776016309940_4961
                          2026-04-12 19:51:49.948  - info: sonoff.0 (2494) Client [Ofen_Wohnzimmer] connected with secret 1776016309947_4861
                          2026-04-12 19:51:50.012  - info: sonoff.0 (2494) Client [Einspeisung-Holzplatz] connected with secret 1776016310010_5066
                          2026-04-12 19:51:50.234  - info: sonoff.0 (2494) Client [Rolladen-Erker-4] connected with secret 1776016310230_5053
                          2026-04-12 19:51:50.418  - info: sonoff.0 (2494) Client [Rolladen-Erker-2] connected with secret 1776016310417_1234
                          2026-04-12 19:51:50.421  - info: sonoff.0 (2494) Client [Zaehler-Haus] connected with secret 1776016310420_4776
                          2026-04-12 19:51:50.434  - info: host.iobroker iobroker npm-rebuild: exit 1
                          2026-04-12 19:51:50.443  - info: sonoff.0 (2494) Client [Schalter-A1-Mini] connected with secret 1776016310442_6202
                          2026-04-12 19:51:50.521  - info: sonoff.0 (2494) Client [Rolladen-Erker-3] connected with secret 1776016310516_9585
                          2026-04-12 19:51:50.615  - info: sonoff.0 (2494) Client [Poolpumpe] connected with secret 1776016310614_8439
                          2026-04-12 19:51:50.631  - info: sonoff.0 (2494) Client [Teich] connected with secret 1776016310629_1446
                          2026-04-12 19:51:50.728  - info: vis.0 (3442) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:51:50.731  - info: sonoff.0 (2494) Client [Rolladen-Erker-1] connected with secret 1776016310730_379
                          2026-04-12 19:51:50.757  - info: host.iobroker instance system.adapter.zigbee.0 in version "3.3.5" started with pid 3478
                          2026-04-12 19:51:50.761  - info: sonoff.0 (2494) Client [Rolladen-Bakontuer] connected with secret 1776016310756_9974
                          2026-04-12 19:51:51.437  - info: sonoff.0 (2494) Client [Luefterklappe] connected with secret 1776016311433_4649
                          2026-04-12 19:51:51.667  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                          2026-04-12 19:51:51.667  - error: host.iobroker Caught by controller[0]:   throw err;
                          2026-04-12 19:51:51.667  - error: host.iobroker Caught by controller[0]:   ^
                          2026-04-12 19:51:51.667  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]: Require stack:
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:9:15)
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:   requireStack: [
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js',
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]:   ]
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]: }
                          2026-04-12 19:51:51.668  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                          2026-04-12 19:51:51.668  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2026-04-12 19:51:51.668  - info: host.iobroker Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                          2026-04-12 19:51:51.668  - info: host.iobroker system.adapter.zigbee.0 will be rebuilt
                          2026-04-12 19:51:51.668  - warn: host.iobroker adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                          2026-04-12 19:51:51.669  - info: host.iobroker iobroker rebuild
                          2026-04-12 19:51:51.748  - info: sonoff.0 (2494) Client [Einspeisung-Victron] connected with secret 1776016311746_4299
                          2026-04-12 19:51:51.750  - info: vis.0 (3442) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:51:52.107  - info: web.0 (3470) starting. Version 8.0.0 in /opt/iobroker/node_modules/iobroker.web, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:51:52.407  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                          2026-04-12 19:51:52.456  - info: web.0 (3470) socket.io server listening on port 8082
                          2026-04-12 19:51:52.626  - info: web.0 (3470) Connecting extension "energiefluss-erweitert/lib/web.js"
                          2026-04-12 19:51:52.627  - info: web.0 (3470) [energiefluss-erweitert.0] Sharp was found and can be used for image processing!
                          2026-04-12 19:51:52.631  - info: web.0 (3470) http server listening on port 8082
                          2026-04-12 19:51:53.978  - info: host.iobroker instance system.adapter.energiefluss-erweitert.0 in version "0.8.1" started with pid 3537
                          2026-04-12 19:51:55.124  - info: energiefluss-erweitert.0 (3537) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:51:55.140  - warn: energiefluss-erweitert.0 (3537) Workspace configuration is NOT password protected!
                          2026-04-12 19:51:55.161  - info: energiefluss-erweitert.0 (3537) Adapter started. Loading config!
                          2026-04-12 19:51:55.545  - info: energiefluss-erweitert.0 (3537) Configuration loaded!
                          2026-04-12 19:51:55.546  - info: energiefluss-erweitert.0 (3537) Requesting the following states: energiefluss-erweitert.0.configuration,mqtt.0.VenusOS.PVGesamtLeistung,mqtt.0.VenusOS.Akku.Ladung_W,mqtt.0.VenusOS.Akku.SoC,mqtt.0.VenusOS.String1.PV_Status,mqtt.0.T2S-Garage.ACDISPLAY,mqtt.0.openDTU_Holzplatz.ac.power,mqtt.0.VenusOS.Hichi.VerbrauchAktuell,sonoff.0.Schalter-A1-Mini.ENERGY_Power,0_userdata.0.Visualisierung.Solar.Hausverbrauch,sonoff.0.Getraenkekuehlschrank.ENERGY_Power,sonoff.0.Schalter-Spuelmaschine.ENERGY_Power,sonoff.0.Gefrierschrank.ENERGY_Power,sonoff.0.Gefriertruhe.ENERGY_Power,sonoff.0.Schalter-Waschmaschine.ENERGY_Power,sonoff.0.Schalter-Trockner.ENERGY_Power,sonoff.0.Kuehlschrank-links.ENERGY_Power,sonoff.0.Kuehlschrank-rechts.ENERGY_Power,sonoff.0.Schalter-Heizungspumpe.ENERGY_Power,sonoff.0.PC-Buero.ENERGY_Power,sonoff.0.Schalter-A1-Mini.POWER,sonoff.0.Poolpumpe.ENERGY_Power,sonoff.0.Poolpumpe.POWER,mqtt.0.VenusOS.Akku.Volt,sonoff.0.Ofen_Wohnzimmer.ENERGY_Power
                          2026-04-12 19:51:56.638  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Schedulescript läuft, Verbraucher 'sonoff.0.Lampe-Haustuer.POWER' wird geschaltet auf: true
                          2026-04-12 19:51:56.638  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Wert ist               : true
                          2026-04-12 19:51:56.638  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Letzter_Verbraucher ist: true
                          2026-04-12 19:51:56.638  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Abendlichtstatus wird gesetzt auf: true
                          2026-04-12 19:51:56.662  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                          2026-04-12 19:51:57.514  - info: vis.0 (3926) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:51:57.725  - info: host.iobroker iobroker npm-rebuild: exit 1
                          2026-04-12 19:51:58.160  - info: host.iobroker instance system.adapter.vis-2.0 in version "2.13.8" started with pid 3954
                          2026-04-12 19:51:58.194  - info: web.0 (3470) ==> Connected system.user.admin from ::ffff:192.168.30.26
                          2026-04-12 19:51:58.216  - info: host.iobroker instance system.adapter.zigbee.0 in version "3.3.5" started with pid 3960
                          2026-04-12 19:51:58.429  - info: vis.0 (3926) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                          2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]:   throw err;
                          2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]:   ^
                          2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                          2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]: Require stack:
                          2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js
                          2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                          2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                          2026-04-12 19:51:59.063  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                          2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                          2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                          2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                          2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                          2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                          2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                          2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:9:15)
                          2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                          2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                          2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:   requireStack: [
                          2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js',
                          2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                          2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]:   ]
                          2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[0]: }
                          2026-04-12 19:51:59.064  - error: host.iobroker Caught by controller[1]: Node.js v22.22.2
                          2026-04-12 19:51:59.064  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2026-04-12 19:51:59.064  - info: host.iobroker Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                          2026-04-12 19:51:59.354  - info: vis-2.0 (3954) starting. Version 2.13.8 in /opt/iobroker/node_modules/iobroker.vis-2, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:51:59.491  - info: vis-2.0 (3954) vis-2 license is OK.
                          2026-04-12 19:52:01.854  - info: host.iobroker instance system.adapter.reolink.0 in version "1.4.2" started with pid 3983
                          2026-04-12 19:52:02.786  - info: reolink.0 (3983) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.reolink, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:52:02.808  - info: reolink.0 (3983) Reolink adapter has started
                          2026-04-12 19:52:02.838  - info: reolink.0 (3983) Current IP: 192.168.3.126
                          2026-04-12 19:52:03.488  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:52:04.224  - warn: reolink.0 (3983) State "reolink.0.Device.Name" has no existing object, this might lead to an error in future versions
                          2026-04-12 19:52:04.322  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:52:13.874  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:52:24.279  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:52:34.627  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:52:45.029  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:52:55.431  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:52:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Schedulescript läuft, Verbraucher 'sonoff.0.Lampe_Erker.POWER' wird geschaltet auf: true
                          2026-04-12 19:52:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Wert ist               : true
                          2026-04-12 19:52:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Letzter_Verbraucher ist: true
                          2026-04-12 19:52:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Abendlichtstatus wird gesetzt auf: true
                          2026-04-12 19:53:05.864  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:53:16.271  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:53:26.689  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:53:37.091  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:53:47.528  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:53:56.634  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Schedulescript läuft, Verbraucher 'sonoff.0.3er_Naehmaschine_WZ.POWER1' wird geschaltet auf: true
                          2026-04-12 19:53:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Wert ist               : true
                          2026-04-12 19:53:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Letzter_Verbraucher ist: true
                          2026-04-12 19:53:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Abendlichtstatus wird gesetzt auf: true
                          2026-04-12 19:53:58.109  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:54:08.524  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:54:18.937  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:54:29.316  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:54:39.725  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:54:50.126  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:54:56.634  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Schedulescript läuft, Verbraucher 'sonoff.0.Lampe-Kommode-WZ.POWER' wird geschaltet auf: true
                          2026-04-12 19:54:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Wert ist               : true
                          2026-04-12 19:54:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Letzter_Verbraucher ist: true
                          2026-04-12 19:54:56.635  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Abendlichtstatus wird gesetzt auf: true
                          2026-04-12 19:55:00.511  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:55:10.879  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:55:21.300  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:55:31.719  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:55:42.092  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:55:52.708  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:56:03.204  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:56:13.628  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:56:24.024  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:56:34.407  - info: reolink.0 (3983) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:56:40.641  - info: javascript.0 (1456) script.js.Pool.Ausschalttemperatur_aendern: Stopping script
                          2026-04-12 19:56:40.644  - warn: web.0 (3470) setTimeout called, but adapter is shutting down
                          2026-04-12 19:56:40.641  - info: javascript.0 (1456) script.js.Pool.Einschalttemperatur_aendern: Stopping script
                          2026-04-12 19:56:40.641  - info: javascript.0 (1456) script.js.Pool.Frostalarm_Huette: Stopping script
                          2026-04-12 19:56:40.641  - info: javascript.0 (1456) script.js.Schalter.Aquara_Doppelschalter_WZ: Stopping script
                          2026-04-12 19:56:40.641  - info: javascript.0 (1456) script.js.Schalter.Bewegungssensor_Flur: Stopping script
                          2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Schalter.Rollaeden: Stopping script
                          2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Schalter.Taster_Rollaeden: Stopping script
                          2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Solar.Solarwerte_addieren: Stopping script
                          2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Solar.Verbrauchsdaten_sichern: Stopping script
                          2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Solar.Werte_addieren: Stopping script
                          2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_Button: Stopping script
                          2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Zeitplaene.Abendlichter_automatik: Stopping script
                          2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Zeitplaene.Fernseher_aus: Stopping script
                          2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Schalter.RundTaster_Rollaeden: Stopping script
                          2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Solar.MPPT_WatchDog: Stopping script
                          2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.common.Netzwerk: Stopping script
                          2026-04-12 19:56:40.642  - info: javascript.0 (1456) script.js.Solar.Hausverbrauch: Stopping script
                          2026-04-12 19:56:40.640  - info: host.iobroker received SIGTERM
                          2026-04-12 19:56:40.647  - info: energiefluss-erweitert.0 (3537) Cleared interval for relative values!
                          2026-04-12 19:56:40.641  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=false)
                          2026-04-12 19:56:40.641  - info: host.iobroker stopInstance system.adapter.history.0 (force=false, process=false)
                          2026-04-12 19:56:40.641  - info: host.iobroker stopInstance system.adapter.influxdb.0 (force=false, process=true)
                          2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=true)
                          2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.whatsapp-cmb.0 (force=false, process=true)
                          2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=false)
                          2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.mqtt.0 (force=false, process=true)
                          2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.ping.0 (force=false, process=true)
                          2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.proxmox.0 (force=false, process=false)
                          2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 (force=false, process=false)
                          2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.sonoff.0 (force=false, process=true)
                          2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.zigbee.0 (force=false, process=false)
                          2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.daswetter.0 (force=false, process=false)
                          2026-04-12 19:56:40.642  - info: host.iobroker stopInstance system.adapter.echarts.0 (force=false, process=true)
                          2026-04-12 19:56:40.643  - info: host.iobroker stopInstance system.adapter.jarvis.0 (force=false, process=false)
                          2026-04-12 19:56:40.643  - info: host.iobroker stopInstance system.adapter.linux-control.0 (force=false, process=false)
                          2026-04-12 19:56:40.648  - info: host.iobroker stopInstance system.adapter.vis-canvas-gauges.0 (force=false, process=false)
                          2026-04-12 19:56:40.648  - info: host.iobroker stopInstance system.adapter.vis-inventwo.0 (force=false, process=false)
                          2026-04-12 19:56:40.649  - info: host.iobroker stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
                          2026-04-12 19:56:40.649  - info: host.iobroker stopInstance system.adapter.vis-materialdesign.0 (force=false, process=false)
                          2026-04-12 19:56:40.649  - info: host.iobroker stopInstance system.adapter.vis.0 (force=false, process=false)
                          2026-04-12 19:56:40.649  - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
                          2026-04-12 19:56:40.649  - info: host.iobroker stopInstance system.adapter.discovery.0 (force=false, process=false)
                          2026-04-12 19:56:40.649  - info: host.iobroker stopInstance system.adapter.energiefluss-erweitert.0 (force=false, process=true)
                          2026-04-12 19:56:40.649  - info: host.iobroker stopInstance system.adapter.vis-2.0 (force=false, process=true)
                          2026-04-12 19:56:40.650  - info: host.iobroker stopInstance system.adapter.reolink.0 (force=false, process=true)
                          2026-04-12 19:56:40.658  - info: javascript.0 (1456) Got terminate signal TERMINATE_YOURSELF
                          2026-04-12 19:56:40.658  - info: mqtt.0 (1991) Got terminate signal TERMINATE_YOURSELF
                          2026-04-12 19:56:40.658  - info: whatsapp-cmb.0 (1782) Got terminate signal TERMINATE_YOURSELF
                          2026-04-12 19:56:40.659  - info: sonoff.0 (2494) Got terminate signal TERMINATE_YOURSELF
                          2026-04-12 19:56:40.659  - info: echarts.0 (2811) Got terminate signal TERMINATE_YOURSELF
                          2026-04-12 19:56:40.659  - info: ping.0 (2422) Got terminate signal TERMINATE_YOURSELF
                          2026-04-12 19:56:40.660  - info: web.0 (3470) Got terminate signal TERMINATE_YOURSELF
                          2026-04-12 19:56:40.661  - info: energiefluss-erweitert.0 (3537) Got terminate signal TERMINATE_YOURSELF
                          2026-04-12 19:56:40.662  - info: reolink.0 (3983) Got terminate signal TERMINATE_YOURSELF
                          2026-04-12 19:56:40.661  - info: vis-2.0 (3954) Got terminate signal TERMINATE_YOURSELF
                          2026-04-12 19:56:40.664  - info: mqtt.0 (1991) terminating
                          2026-04-12 19:56:40.666  - info: vis-2.0 (3954) terminating
                          2026-04-12 19:56:40.667  - info: vis-2.0 (3954) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:56:40.665  - info: energiefluss-erweitert.0 (3537) terminating
                          2026-04-12 19:56:40.666  - info: energiefluss-erweitert.0 (3537) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:56:40.665  - info: mqtt.0 (1991) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:56:40.668  - info: reolink.0 (3983) terminating
                          2026-04-12 19:56:40.669  - info: reolink.0 (3983) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:56:40.668  - info: host.iobroker stopInstance system.adapter.javascript.0 send kill signal
                          2026-04-12 19:56:40.670  - info: influxdb.0 (1085) terminating
                          2026-04-12 19:56:40.670  - info: influxdb.0 (1085) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.whatsapp-cmb.0 send kill signal
                          2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.mqtt.0 send kill signal
                          2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.ping.0 send kill signal
                          2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.sonoff.0 send kill signal
                          2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.echarts.0 send kill signal
                          2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
                          2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.energiefluss-erweitert.0 send kill signal
                          2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.vis-2.0 send kill signal
                          2026-04-12 19:56:40.710  - info: host.iobroker stopInstance system.adapter.reolink.0 send kill signal
                          2026-04-12 19:56:40.744  - info: javascript.0 (1456) terminating
                          2026-04-12 19:56:40.744  - info: javascript.0 (1456) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:56:41.144  - info: javascript.0 (1456) terminating
                          2026-04-12 19:56:41.144  - info: whatsapp-cmb.0 (1782) terminating
                          2026-04-12 19:56:41.145  - info: ping.0 (2422) terminating
                          2026-04-12 19:56:41.145  - info: whatsapp-cmb.0 (1782) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:56:41.146  - info: ping.0 (2422) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:56:41.146  - info: echarts.0 (2811) terminating
                          2026-04-12 19:56:41.147  - info: reolink.0 (3983) terminating
                          2026-04-12 19:56:41.147  - info: web.0 (3470) terminating
                          2026-04-12 19:56:41.147  - info: echarts.0 (2811) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:56:41.148  - info: web.0 (3470) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:56:41.148  - info: vis-2.0 (3954) terminating
                          2026-04-12 19:56:41.149  - info: sonoff.0 (2494) terminating
                          2026-04-12 19:56:41.149  - info: sonoff.0 (2494) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:56:41.150  - info: energiefluss-erweitert.0 (3537) terminating
                          2026-04-12 19:56:41.166  - info: mqtt.0 (1991) terminating
                          2026-04-12 19:56:41.170  - warn: mqtt.0 (1991) get state error: Connection is closed.
                          2026-04-12 19:56:41.208  - info: host.iobroker instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
                          2026-04-12 19:56:41.256  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
                          2026-04-12 19:56:41.256  - info: host.iobroker instance system.adapter.energiefluss-erweitert.0 terminated with code 0 (NO_ERROR)
                          2026-04-12 19:56:41.256  - info: host.iobroker instance system.adapter.vis-2.0 terminated with code 0 (NO_ERROR)
                          2026-04-12 19:56:41.256  - info: host.iobroker instance system.adapter.reolink.0 terminated with code 0 (NO_ERROR)
                          2026-04-12 19:56:41.284  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                          2026-04-12 19:56:41.685  - info: host.iobroker instance system.adapter.whatsapp-cmb.0 terminated with code 0 (NO_ERROR)
                          2026-04-12 19:56:41.723  - info: host.iobroker instance system.adapter.ping.0 terminated with code 0 (NO_ERROR)
                          2026-04-12 19:56:41.723  - info: host.iobroker instance system.adapter.sonoff.0 terminated with code 0 (NO_ERROR)
                          2026-04-12 19:56:41.724  - warn: host.iobroker instance system.adapter.echarts.0 terminated due to SIGSEGV
                          2026-04-12 19:56:41.724  - info: host.iobroker instance system.adapter.echarts.0 terminated with code null ()
                          2026-04-12 19:56:41.724  - info: host.iobroker instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
                          2026-04-12 19:56:41.724  - info: host.iobroker All instances are stopped.
                          2026-04-12 19:56:41.864  - info: host.iobroker terminated
                          2026-04-12 19:57:26.770  - info: host.iobroker iobroker.js-controller version 7.0.7 js-controller starting
                          2026-04-12 19:57:26.772  - info: host.iobroker Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                          2026-04-12 19:57:26.772  - info: host.iobroker hostname: iobroker, node: v22.22.2
                          2026-04-12 19:57:26.773  - info: host.iobroker ip addresses: 192.168.20.131 fe80::fc21:e4ff:fe0c:531d
                          2026-04-12 19:57:27.372  - info: host.iobroker connected to Objects and States
                          2026-04-12 19:57:27.382  - info: host.iobroker added notifications configuration of host
                          2026-04-12 19:57:27.638  - info: host.iobroker 31 instances found
                          2026-04-12 19:57:27.654  - info: host.iobroker starting 14 instances
                          2026-04-12 19:57:27.926  - info: host.iobroker instance system.adapter.admin.0 in version "7.7.22" started with pid 5427
                          2026-04-12 19:57:28.005  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                          2026-04-12 19:57:28.005  - error: host.iobroker Caught by controller[0]:   throw err;
                          2026-04-12 19:57:28.005  - error: host.iobroker Caught by controller[0]:   ^
                          2026-04-12 19:57:28.005  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                          2026-04-12 19:57:28.005  - error: host.iobroker Caught by controller[0]: Require stack:
                          2026-04-12 19:57:28.005  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/build/main.js
                          2026-04-12 19:57:28.005  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                          2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                          2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                          2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                          2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                          2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                          2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                          2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                          2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/build/main.js:13:17)
                          2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                          2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                          2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/build/main.js' ]
                          2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]: }
                          2026-04-12 19:57:28.006  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                          2026-04-12 19:57:28.006  - error: host.iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2026-04-12 19:57:28.006  - info: host.iobroker Adapter system.adapter.admin.0 needs rebuild and will be restarted afterwards.
                          2026-04-12 19:57:28.008  - info: host.iobroker system.adapter.admin.0 will be rebuilt
                          2026-04-12 19:57:28.009  - warn: host.iobroker adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                          2026-04-12 19:57:28.009  - info: host.iobroker iobroker rebuild
                          2026-04-12 19:57:28.584  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                          2026-04-12 19:57:32.040  - info: host.iobroker instance system.adapter.influxdb.0 in version "4.0.2" started with pid 5726
                          2026-04-12 19:57:32.502  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                          2026-04-12 19:57:33.363  - info: vis.0 (5839) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:57:33.390  - info: influxdb.0 (5726) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.influxdb, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:57:33.403  - info: influxdb.0 (5726) No stored data from last exit found
                          2026-04-12 19:57:33.404  - info: influxdb.0 (5726) Connecting http://192.168.20.133:8086/ ...
                          2026-04-12 19:57:33.404  - info: influxdb.0 (5726) Influx DB Version used: 1.x
                          2026-04-12 19:57:33.445  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Solar.SolarAktuell, Alias=false, 1 points now activated
                          2026-04-12 19:57:33.452  - info: host.iobroker iobroker npm-rebuild: exit 1
                          2026-04-12 19:57:33.445  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Solar.TagesGesamt, Alias=false, 2 points now activated
                          2026-04-12 19:57:33.445  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.GesamtVerbrauch, Alias=false, 3 points now activated
                          2026-04-12 19:57:33.446  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.Nachtverbrauch, Alias=false, 4 points now activated
                          2026-04-12 19:57:33.446  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.Tagverbrauch, Alias=false, 5 points now activated
                          2026-04-12 19:57:33.446  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.ZaehlerGestern, Alias=false, 6 points now activated
                          2026-04-12 19:57:33.447  - info: influxdb.0 (5726) enabled logging of mqtt.0.Gartenhaus.Solartemperatur.Temperature, Alias=false, 7 points now activated
                          2026-04-12 19:57:33.447  - info: influxdb.0 (5726) enabled logging of mqtt.0.T2S-Garage.ACDISPLAY, Alias=false, 8 points now activated
                          2026-04-12 19:57:33.447  - info: influxdb.0 (5726) enabled logging of mqtt.0.T2S-Garage.ACSETPOINT, Alias=false, 9 points now activated
                          2026-04-12 19:57:33.448  - info: influxdb.0 (5726) enabled logging of mqtt.0.T2S-Garage.VBAT, Alias=false, 10 points now activated
                          2026-04-12 19:57:33.448  - info: influxdb.0 (5726) enabled logging of sonoff.0.Einspeisung-Akku.ENERGY_Power, Alias=false, 11 points now activated
                          2026-04-12 19:57:33.448  - info: influxdb.0 (5726) enabled logging of sonoff.0.Einspeisung-Holzplatz.ENERGY_Power, Alias=false, 12 points now activated
                          2026-04-12 19:57:33.448  - info: influxdb.0 (5726) enabled logging of sonoff.0.Gefrierschrank.ENERGY_Power, Alias=false, 13 points now activated
                          2026-04-12 19:57:33.448  - info: influxdb.0 (5726) enabled logging of sonoff.0.Gefriertruhe.ENERGY_Power, Alias=false, 14 points now activated
                          2026-04-12 19:57:33.448  - info: influxdb.0 (5726) enabled logging of sonoff.0.Getraenkekuehlschrank.ENERGY_Power, Alias=false, 15 points now activated
                          2026-04-12 19:57:33.449  - info: influxdb.0 (5726) enabled logging of sonoff.0.Zaehler-Haus.MT681_Power_cur, Alias=false, 16 points now activated
                          2026-04-12 19:57:33.449  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.KuehlschrankRechtsTagesGesamt, Alias=false, 17 points now activated
                          2026-04-12 19:57:33.449  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.KuehlschrankLinksTagesGesamt, Alias=false, 18 points now activated
                          2026-04-12 19:57:33.449  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.GefriertruheTagesGesamt, Alias=false, 19 points now activated
                          2026-04-12 19:57:33.449  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.GefrierschrankTagesGesamt, Alias=false, 20 points now activated
                          2026-04-12 19:57:33.449  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.WaschmaschineTagesGesamt, Alias=false, 21 points now activated
                          2026-04-12 19:57:33.449  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.TrocknerTagesGesamt, Alias=false, 22 points now activated
                          2026-04-12 19:57:33.450  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.GetraenkeKuehlschrankTagesGesamt, Alias=false, 23 points now activated
                          2026-04-12 19:57:33.450  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.KuechenKuehlschrankTagesGesamt, Alias=false, 24 points now activated
                          2026-04-12 19:57:33.450  - info: influxdb.0 (5726) enabled logging of 0_userdata.0.Visualisierung.Verbrauch.SummeVerbrauch, Alias=false, 25 points now activated
                          2026-04-12 19:57:33.933  - info: host.iobroker instance system.adapter.admin.0 in version "7.7.22" started with pid 5875
                          2026-04-12 19:57:34.028  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                          2026-04-12 19:57:34.028  - error: host.iobroker Caught by controller[0]:   throw err;
                          2026-04-12 19:57:34.028  - error: host.iobroker Caught by controller[0]:   ^
                          2026-04-12 19:57:34.028  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                          2026-04-12 19:57:34.028  - error: host.iobroker Caught by controller[0]: Require stack:
                          2026-04-12 19:57:34.028  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/build/main.js
                          2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                          2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                          2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                          2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                          2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                          2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                          2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                          2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                          2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/build/main.js:13:17)
                          2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                          2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                          2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/build/main.js' ]
                          2026-04-12 19:57:34.029  - error: host.iobroker Caught by controller[0]: }
                          2026-04-12 19:57:34.030  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                          2026-04-12 19:57:34.030  - error: host.iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2026-04-12 19:57:34.030  - info: host.iobroker Adapter system.adapter.admin.0 needs rebuild and will be restarted afterwards.
                          2026-04-12 19:57:34.030  - info: host.iobroker system.adapter.admin.0 will be rebuilt
                          2026-04-12 19:57:34.030  - warn: host.iobroker adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                          2026-04-12 19:57:34.030  - info: host.iobroker iobroker rebuild
                          2026-04-12 19:57:34.473  - info: vis.0 (5839) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:57:34.789  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                          2026-04-12 19:57:35.947  - info: host.iobroker instance system.adapter.javascript.0 in version "9.0.18" started with pid 5924
                          2026-04-12 19:57:37.660  - info: javascript.0 (5924) starting. Version 9.0.18 in /opt/iobroker/node_modules/iobroker.javascript, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:57:38.982  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                          2026-04-12 19:57:40.037  - info: host.iobroker iobroker npm-rebuild: exit 1
                          2026-04-12 19:57:40.050  - info: host.iobroker instance system.adapter.whatsapp-cmb.0 in version "0.3.0" started with pid 6382
                          2026-04-12 19:57:40.440  - info: host.iobroker instance system.adapter.admin.0 in version "7.7.22" started with pid 6390
                          2026-04-12 19:57:40.540  - info: vis.0 (6370) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                          2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]:   throw err;
                          2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]:   ^
                          2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                          2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]: Require stack:
                          2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/build/main.js
                          2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                          2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                          2026-04-12 19:57:40.634  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                          2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                          2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                          2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                          2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                          2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                          2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/build/main.js:13:17)
                          2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                          2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                          2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/build/main.js' ]
                          2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]: }
                          2026-04-12 19:57:40.635  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                          2026-04-12 19:57:40.635  - error: host.iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2026-04-12 19:57:40.635  - info: host.iobroker Adapter system.adapter.admin.0 needs rebuild and will be restarted afterwards.
                          2026-04-12 19:57:40.635  - info: host.iobroker system.adapter.admin.0 will be rebuilt
                          2026-04-12 19:57:40.635  - warn: host.iobroker adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                          2026-04-12 19:57:40.636  - info: host.iobroker iobroker rebuild
                          2026-04-12 19:57:41.528  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                          2026-04-12 19:57:41.571  - info: whatsapp-cmb.0 (6382) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:57:41.621  - info: vis.0 (6370) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:57:44.016  - info: host.iobroker instance system.adapter.mqtt.0 in version "6.1.4" started with pid 6588
                          2026-04-12 19:57:45.724  - info: mqtt.0 (6588) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.mqtt, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:57:45.822  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                          2026-04-12 19:57:45.944  - info: mqtt.0 (6588) Starting MQTT server on 0.0.0.0:1884
                          2026-04-12 19:57:45.944  - info: mqtt.0 (6588) Starting MQTT-WebSocket server on 0.0.0.0:1885
                          2026-04-12 19:57:46.854  - info: host.iobroker iobroker npm-rebuild: exit 1
                          2026-04-12 19:57:47.328  - info: host.iobroker instance system.adapter.admin.0 in version "7.7.22" started with pid 6917
                          2026-04-12 19:57:47.439  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                          2026-04-12 19:57:47.439  - error: host.iobroker Caught by controller[0]:   throw err;
                          2026-04-12 19:57:47.439  - error: host.iobroker Caught by controller[0]:   ^
                          2026-04-12 19:57:47.439  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                          2026-04-12 19:57:47.439  - error: host.iobroker Caught by controller[0]: Require stack:
                          2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/build/main.js
                          2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                          2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                          2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                          2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                          2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                          2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                          2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                          2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                          2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/build/main.js:13:17)
                          2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                          2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                          2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/build/main.js' ]
                          2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]: }
                          2026-04-12 19:57:47.440  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                          2026-04-12 19:57:47.440  - error: host.iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2026-04-12 19:57:47.440  - info: host.iobroker Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                          2026-04-12 19:57:47.492  - info: vis.0 (6905) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:57:47.520  - info: mqtt.0 (6588) Client [OpenDTU-15427312] connected with secret 1776016667489_3478
                          2026-04-12 19:57:47.575  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_relative" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_relative/
                          2026-04-12 19:57:47.576  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_relative"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_relative/
                          2026-04-12 19:57:47.581  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_absolute" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_absolute/
                          2026-04-12 19:57:47.581  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_absolute"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_absolute/
                          2026-04-12 19:57:47.582  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_relative" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_relative/
                          2026-04-12 19:57:47.582  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_relative"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_relative/
                          2026-04-12 19:57:47.582  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_absolute" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_absolute/
                          2026-04-12 19:57:47.583  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_absolute"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_absolute/
                          2026-04-12 19:57:47.583  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/power" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.power/
                          2026-04-12 19:57:47.583  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/power"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.power/
                          2026-04-12 19:57:47.585  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/restart" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.restart/
                          2026-04-12 19:57:47.585  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/restart"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.restart/
                          2026-04-12 19:57:47.587  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_online_voltage"
                          2026-04-12 19:57:47.588  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_online_current"
                          2026-04-12 19:57:47.590  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_offline_voltage"
                          2026-04-12 19:57:47.614  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_offline_current"
                          2026-04-12 19:57:47.615  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.mode"
                          2026-04-12 19:57:47.662  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.powerlimiter.cmd.mode"
                          2026-04-12 19:57:47.776  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                          2026-04-12 19:57:47.781  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                          2026-04-12 19:57:47.782  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                          2026-04-12 19:57:47.783  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                          2026-04-12 19:57:47.784  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                          2026-04-12 19:57:47.785  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                          2026-04-12 19:57:47.790  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                          2026-04-12 19:57:47.791  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                          2026-04-12 19:57:47.815  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                          2026-04-12 19:57:47.862  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                          2026-04-12 19:57:47.957  - info: host.iobroker instance system.adapter.ping.0 in version "1.7.9" started with pid 6928
                          2026-04-12 19:57:48.503  - info: vis.0 (6905) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:57:49.163  - info: ping.0 (6928) starting. Version 1.7.9 in /opt/iobroker/node_modules/iobroker.ping, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:57:51.928  - info: host.iobroker instance system.adapter.sonoff.0 in version "3.3.0" started with pid 6982
                          2026-04-12 19:57:52.927  - info: sonoff.0 (6982) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.sonoff, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:57:52.947  - info: sonoff.0 (6982) Starting MQTT  server on port 1883
                          2026-04-12 19:57:53.595  - info: javascript.0 (5924) requesting all states
                          2026-04-12 19:57:53.596  - info: javascript.0 (5924) requesting all objects
                          2026-04-12 19:57:54.021  - info: javascript.0 (5924) received all objects
                          2026-04-12 19:57:54.055  - info: javascript.0 (5924) received all states
                          2026-04-12 19:57:54.143  - info: javascript.0 (5924) script.js.Pool.Ausschalttemperatur_aendern: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.157  - info: javascript.0 (5924) script.js.Pool.Ausschalttemperatur_aendern: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.157  - info: javascript.0 (5924) script.js.Pool.Einschalttemperatur_aendern: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.169  - info: javascript.0 (5924) script.js.Pool.Einschalttemperatur_aendern: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.169  - info: javascript.0 (5924) script.js.Pool.Frostalarm_Huette: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.172  - info: javascript.0 (5924) script.js.Pool.Frostalarm_Huette: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.172  - info: javascript.0 (5924) script.js.Schalter.Aquara_Doppelschalter_WZ: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.174  - info: javascript.0 (5924) script.js.Schalter.Aquara_Doppelschalter_WZ: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.174  - info: javascript.0 (5924) script.js.Schalter.Bewegungssensor_Flur: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.177  - info: javascript.0 (5924) script.js.Schalter.Bewegungssensor_Flur: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.177  - info: javascript.0 (5924) script.js.Schalter.Rollaeden: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.180  - info: javascript.0 (5924) script.js.Schalter.Rollaeden: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.180  - info: javascript.0 (5924) script.js.Schalter.Taster_Rollaeden: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.183  - info: javascript.0 (5924) script.js.Schalter.Taster_Rollaeden: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.184  - info: javascript.0 (5924) script.js.Solar.Solarwerte_addieren: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.187  - info: javascript.0 (5924) script.js.Solar.Solarwerte_addieren: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.187  - info: javascript.0 (5924) script.js.Solar.Verbrauchsdaten_sichern: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.210  - info: javascript.0 (5924) script.js.Solar.Verbrauchsdaten_sichern: registered 0 subscriptions, 3 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.211  - info: javascript.0 (5924) script.js.Solar.Werte_addieren: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.213  - info: javascript.0 (5924) script.js.Solar.Werte_addieren: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.213  - info: javascript.0 (5924) script.js.Zeitplaene.Abendlichter_Button: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.215  - info: javascript.0 (5924) script.js.Zeitplaene.Abendlichter_Button: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.223  - info: javascript.0 (5924) script.js.Zeitplaene.Abendlichter_automatik: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.233  - info: javascript.0 (5924) script.js.Zeitplaene.Abendlichter_automatik: registered 0 subscriptions, 8 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.233  - info: javascript.0 (5924) script.js.Zeitplaene.Fernseher_aus: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.238  - info: javascript.0 (5924) script.js.Zeitplaene.Fernseher_aus: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.240  - info: javascript.0 (5924) script.js.Schalter.RundTaster_Rollaeden: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.243  - info: javascript.0 (5924) script.js.Schalter.RundTaster_Rollaeden: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.244  - info: javascript.0 (5924) script.js.Solar.MPPT_WatchDog: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.247  - info: javascript.0 (5924) script.js.Solar.MPPT_WatchDog: registered 7 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.247  - info: javascript.0 (5924) script.js.common.Netzwerk: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.249  - info: javascript.0 (5924) script.js.common.Netzwerk: registered 8 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.250  - info: javascript.0 (5924) script.js.Solar.Hausverbrauch: start JavaScript (Javascript/js)
                          2026-04-12 19:57:54.253  - info: javascript.0 (5924) script.js.Solar.Hausverbrauch: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2026-04-12 19:57:54.255  - info: javascript.0 (5924) script.js.Schalter.Rollaeden: Es werden alle Rollo beim Auffahren gestoppt
                          2026-04-12 19:57:54.256  - info: javascript.0 (5924) script.js.Schalter.Rollaeden: Es werden alle Rollo beim Zufahren gestoppt
                          2026-04-12 19:57:54.261  - info: sonoff.0 (6982) Client "Rolladen-Erker-1" not connected
                          2026-04-12 19:57:54.262  - info: sonoff.0 (6982) Client "Rolladen-Erker-2" not connected
                          2026-04-12 19:57:54.262  - info: sonoff.0 (6982) Client "Rolladen-Erker-3" not connected
                          2026-04-12 19:57:54.263  - info: sonoff.0 (6982) Client "Rolladen-Erker-4" not connected
                          2026-04-12 19:57:54.263  - info: sonoff.0 (6982) Client "Rolladen-Erker-1" not connected
                          2026-04-12 19:57:54.264  - info: sonoff.0 (6982) Client "Rolladen-Erker-2" not connected
                          2026-04-12 19:57:54.265  - info: sonoff.0 (6982) Client "Rolladen-Erker-3" not connected
                          2026-04-12 19:57:54.265  - info: sonoff.0 (6982) Client "Rolladen-Erker-4" not connected
                          2026-04-12 19:57:55.315  - info: sonoff.0 (6982) Client [Sensor Heizung] connected with secret 1776016675311_705
                          2026-04-12 19:57:55.910  - info: host.iobroker instance system.adapter.zigbee.0 in version "3.3.5" started with pid 7013
                          2026-04-12 19:57:56.414  - info: mqtt.0 (6588) Client [nodered05568ac752885a52] connected with secret 1776016676408_6453
                          2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                          2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:   throw err;
                          2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:   ^
                          2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                          2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]: Require stack:
                          2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js
                          2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                          2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                          2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                          2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                          2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                          2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                          2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                          2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                          2026-04-12 19:57:56.570  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                          2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:9:15)
                          2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                          2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                          2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]:   requireStack: [
                          2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js',
                          2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                          2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]:   ]
                          2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]: }
                          2026-04-12 19:57:56.571  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                          2026-04-12 19:57:56.571  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2026-04-12 19:57:56.571  - info: host.iobroker Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                          2026-04-12 19:57:56.571  - info: host.iobroker system.adapter.zigbee.0 will be rebuilt
                          2026-04-12 19:57:56.571  - warn: host.iobroker adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                          2026-04-12 19:57:56.571  - info: host.iobroker iobroker rebuild
                          2026-04-12 19:57:57.209  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                          2026-04-12 19:57:59.981  - info: host.iobroker instance system.adapter.echarts.0 in version "3.1.0" started with pid 7313
                          2026-04-12 19:58:00.664  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                          2026-04-12 19:58:01.490  - info: echarts.0 (7313) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.echarts, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:58:01.679  - info: host.iobroker iobroker npm-rebuild: exit 1
                          2026-04-12 19:58:02.059  - info: host.iobroker instance system.adapter.zigbee.0 in version "3.3.5" started with pid 7506
                          2026-04-12 19:58:02.073  - info: vis.0 (7472) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:58:03.011  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                          2026-04-12 19:58:03.011  - error: host.iobroker Caught by controller[0]:   throw err;
                          2026-04-12 19:58:03.011  - error: host.iobroker Caught by controller[0]:   ^
                          2026-04-12 19:58:03.011  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                          2026-04-12 19:58:03.011  - error: host.iobroker Caught by controller[0]: Require stack:
                          2026-04-12 19:58:03.011  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js
                          2026-04-12 19:58:03.011  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                          2026-04-12 19:58:03.011  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                          2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                          2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                          2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                          2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                          2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                          2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                          2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                          2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:9:15)
                          2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                          2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                          2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:   requireStack: [
                          2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js',
                          2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                          2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]:   ]
                          2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]: }
                          2026-04-12 19:58:03.012  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                          2026-04-12 19:58:03.012  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2026-04-12 19:58:03.012  - info: host.iobroker Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                          2026-04-12 19:58:03.012  - info: host.iobroker system.adapter.zigbee.0 will be rebuilt
                          2026-04-12 19:58:03.012  - warn: host.iobroker adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                          2026-04-12 19:58:03.012  - info: host.iobroker iobroker rebuild
                          2026-04-12 19:58:03.050  - info: vis.0 (7472) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:58:03.607  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                          2026-04-12 19:58:04.805  - info: vis.0 (7542) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:58:05.699  - info: vis.0 (7542) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:58:06.247  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
                          2026-04-12 19:58:07.706  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                          2026-04-12 19:58:07.987  - info: host.iobroker instance system.adapter.web.0 in version "8.0.0" started with pid 7955
                          2026-04-12 19:58:08.525  - info: vis.0 (7931) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:58:08.720  - info: host.iobroker iobroker npm-rebuild: exit 1
                          2026-04-12 19:58:09.128  - info: host.iobroker instance system.adapter.zigbee.0 in version "3.3.5" started with pid 7971
                          2026-04-12 19:58:09.443  - info: web.0 (7955) starting. Version 8.0.0 in /opt/iobroker/node_modules/iobroker.web, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:58:09.661  - info: vis.0 (7931) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:58:09.712  - info: web.0 (7955) socket.io server listening on port 8082
                          2026-04-12 19:58:09.756  - info: web.0 (7955) Connecting extension "energiefluss-erweitert/lib/web.js"
                          2026-04-12 19:58:09.757  - info: web.0 (7955) [energiefluss-erweitert.0] Sharp was found and can be used for image processing!
                          2026-04-12 19:58:09.760  - info: web.0 (7955) http server listening on port 8082
                          2026-04-12 19:58:09.835  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:   throw err;
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:   ^
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]: Require stack:
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:9:15)
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:   requireStack: [
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js',
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]:   ]
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]: }
                          2026-04-12 19:58:09.836  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                          2026-04-12 19:58:09.836  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2026-04-12 19:58:09.836  - info: host.iobroker Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                          2026-04-12 19:58:09.836  - info: host.iobroker system.adapter.zigbee.0 will be rebuilt
                          2026-04-12 19:58:09.836  - warn: host.iobroker adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                          2026-04-12 19:58:09.837  - info: host.iobroker iobroker rebuild
                          2026-04-12 19:58:10.427  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                          2026-04-12 19:58:11.946  - info: host.iobroker instance system.adapter.energiefluss-erweitert.0 in version "0.8.1" started with pid 8011
                          2026-04-12 19:58:12.989  - info: energiefluss-erweitert.0 (8011) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:58:13.005  - warn: energiefluss-erweitert.0 (8011) Workspace configuration is NOT password protected!
                          2026-04-12 19:58:13.022  - info: energiefluss-erweitert.0 (8011) Adapter started. Loading config!
                          2026-04-12 19:58:13.565  - info: energiefluss-erweitert.0 (8011) Configuration loaded!
                          2026-04-12 19:58:13.565  - info: energiefluss-erweitert.0 (8011) Requesting the following states: energiefluss-erweitert.0.configuration,mqtt.0.VenusOS.PVGesamtLeistung,mqtt.0.VenusOS.Akku.Ladung_W,mqtt.0.VenusOS.Akku.SoC,mqtt.0.VenusOS.String1.PV_Status,mqtt.0.T2S-Garage.ACDISPLAY,mqtt.0.openDTU_Holzplatz.ac.power,mqtt.0.VenusOS.Hichi.VerbrauchAktuell,sonoff.0.Schalter-A1-Mini.ENERGY_Power,0_userdata.0.Visualisierung.Solar.Hausverbrauch,sonoff.0.Getraenkekuehlschrank.ENERGY_Power,sonoff.0.Schalter-Spuelmaschine.ENERGY_Power,sonoff.0.Gefrierschrank.ENERGY_Power,sonoff.0.Gefriertruhe.ENERGY_Power,sonoff.0.Schalter-Waschmaschine.ENERGY_Power,sonoff.0.Schalter-Trockner.ENERGY_Power,sonoff.0.Kuehlschrank-links.ENERGY_Power,sonoff.0.Kuehlschrank-rechts.ENERGY_Power,sonoff.0.Schalter-Heizungspumpe.ENERGY_Power,sonoff.0.PC-Buero.ENERGY_Power,sonoff.0.Schalter-A1-Mini.POWER,sonoff.0.Poolpumpe.ENERGY_Power,sonoff.0.Poolpumpe.POWER,mqtt.0.VenusOS.Akku.Volt,sonoff.0.Ofen_Wohnzimmer.ENERGY_Power
                          2026-04-12 19:58:14.533  - error: host.iobroker iobroker npm-rebuild: Rebuilding native modules failed
                          2026-04-12 19:58:15.170  - info: web.0 (7955) ==> Connected system.user.admin from ::ffff:192.168.30.26
                          2026-04-12 19:58:15.383  - info: vis.0 (8400) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:58:15.538  - info: host.iobroker iobroker npm-rebuild: exit 1
                          2026-04-12 19:58:16.095  - info: host.iobroker instance system.adapter.zigbee.0 in version "3.3.5" started with pid 8428
                          2026-04-12 19:58:16.101  - info: host.iobroker instance system.adapter.vis-2.0 in version "2.13.8" started with pid 8429
                          2026-04-12 19:58:16.616  - info: vis.0 (8400) Terminated (NO_ERROR): Without reason
                          2026-04-12 19:58:16.911  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:   throw err;
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:   ^
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]: Require stack:
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:9:15)
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:   requireStack: [
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js',
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]:   ]
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]: }
                          2026-04-12 19:58:16.912  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                          2026-04-12 19:58:16.912  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2026-04-12 19:58:16.912  - info: host.iobroker Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                          2026-04-12 19:58:17.231  - info: vis-2.0 (8429) starting. Version 2.13.8 in /opt/iobroker/node_modules/iobroker.vis-2, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:58:17.369  - info: vis-2.0 (8429) vis-2 license is OK.
                          2026-04-12 19:58:19.918  - info: host.iobroker instance system.adapter.reolink.0 in version "1.4.2" started with pid 8456
                          2026-04-12 19:58:20.799  - info: reolink.0 (8456) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.reolink, node: v22.22.2, js-controller: 7.0.7
                          2026-04-12 19:58:20.867  - info: reolink.0 (8456) Reolink adapter has started
                          2026-04-12 19:58:20.904  - info: reolink.0 (8456) Current IP: 192.168.3.126
                          2026-04-12 19:58:21.611  - info: reolink.0 (8456) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:58:23.025  - warn: reolink.0 (8456) State "reolink.0.Device.Name" has no existing object, this might lead to an error in future versions
                          2026-04-12 19:58:23.114  - info: reolink.0 (8456) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                          2026-04-12 19:58:25.790  - info: sonoff.0 (6982) Client [Rolladen-Bakontuer] connected with secret 1776016705788_1973
                          2026-04-12 19:58:25.837  - info: sonoff.0 (6982) Client [3er_Naehmaschine_WZ] connected with secret 1776016705837_9664
                          2026-04-12 19:58:25.894  - info: sonoff.0 (6982) Client [Lampe_Erker] connected with secret 1776016705892_549
                          2026-04-12 19:58:25.908  - info: sonoff.0 (6982) Client [Schalter-Spuelmaschine] connected with secret 1776016705907_344
                          2026-04-12 19:58:25.913  - info: sonoff.0 (6982) Client [Getraenkekuehlschrank] connected with secret 1776016705911_3988
                          2026-04-12 19:58:25.915  - info: sonoff.0 (6982) Client [Ofen_Wohnzimmer] connected with secret 1776016705914_3495
                          2026-04-12 19:58:25.931  - info: sonoff.0 (6982) Client [PC-Buero] connected with secret 1776016705930_1307
                          2026-04-12 19:58:25.933  - info: sonoff.0 (6982) Client [Schalter-Trockner] connected with secret 1776016705931_77
                          2026-04-12 19:58:25.948  - info: sonoff.0 (6982) Client [Steckdose-Garage] connected with secret 1776016705945_4691
                          2026-04-12 19:58:26.041  - info: sonoff.0 (6982) Client [Einspeisung-Holzplatz] connected with secret 1776016706040_8480
                          2026-04-12 19:58:26.263  - info: sonoff.0 (6982) Client [Rolladen-Erker-4] connected with secret 1776016706253_4479
                          2026-04-12 19:58:26.292  - info: sonoff.0 (6982) Client [Anbau] connected with secret 1776016706292_5742
                          2026-04-12 19:58:26.313  - info: sonoff.0 (6982) Client [Kuehlschrank-links] connected with secret 1776016706313_9857
                          2026-04-12 19:58:26.463  - info: sonoff.0 (6982) Client [Rolladen-Erker-2] connected with secret 1776016706457_5187
                          2026-04-12 19:58:26.493  - info: sonoff.0 (6982) Client [Rolladen-Erker-3] connected with secret 1776016706488_7743
                          2026-04-12 19:58:26.542  - info: sonoff.0 (6982) Client [Lampe-Kommode-WZ] connected with secret 1776016706541_9177
                          2026-04-12 19:58:26.623  - info: sonoff.0 (6982) Client [Teich] connected with secret 1776016706620_9933
                          2026-04-12 19:58:26.679  - info: sonoff.0 (6982) Client [Gefrierschrank] connected with secret 1776016706679_8530
                          2026-04-12 19:58:26.707  - info: sonoff.0 (6982) Client [Lampe-Haustuer] connected with secret 1776016706706_4786
                          2026-04-12 19:58:26.714  - info: sonoff.0 (6982) Client [Rolladen-Erker-1] connected with secret 1776016706713_1746
                          2026-04-12 19:58:27.182  - info: sonoff.0 (6982) Client [Zaehler-Haus] connected with secret 1776016707181_5192
                          2026-04-12 19:58:27.211  - info: sonoff.0 (6982) Client [Schalter-A1-Mini] connected with secret 1776016707210_9991
                          2026-04-12 19:58:28.404  - info: sonoff.0 (6982) Client [Luefterklappe] connected with secret 1776016708399_2214
                          2026-04-12 19:58:28.628  - info: sonoff.0 (6982) Client [Poolpumpe] connected with secret 1776016708628_6869
                          crunchipC Offline
                          crunchipC Offline
                          @nettworker sagte:
                          Ist das log interessant?
                          ja,
                          @nettworker sagte:
                          2026-04-12 19:51:38.652 - error: host.iobroker Caught by controller[0]: }
                          2026-04-12 19:51:38.652 - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                            @nettworker
                            iob restart admin
                            N Offline
                            N Offline
                            nettworker
                            @Thomas-Braun sagte:
                            iob restart admin
                            Jetzt gibt's ne Ausgabe im log:
                            2026-04-12 20:48:02.838  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]:   throw err;
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]:   ^
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]: Require stack:
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/build/main.js
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/build/main.js:13:17)
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/build/main.js' ]
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]: }
                            2026-04-12 20:48:02.839  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                            2026-04-12 20:48:02.839  - error: host.iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2026-04-12 20:48:02.839  - info: host.iobroker Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                            2026-04-12 20:49:42.949  - info: host.iobroker instance system.adapter.admin.0 in version "7.7.22" started with pid 10369
                            2026-04-12 20:49:43.029  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                            2026-04-12 20:49:43.029  - error: host.iobroker Caught by controller[0]:   throw err;
                            2026-04-12 20:49:43.029  - error: host.iobroker Caught by controller[0]:   ^
                            2026-04-12 20:49:43.029  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                            2026-04-12 20:49:43.029  - error: host.iobroker Caught by controller[0]: Require stack:
                            2026-04-12 20:49:43.029  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/build/main.js
                            2026-04-12 20:49:43.029  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                            2026-04-12 20:49:43.029  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                            2026-04-12 20:49:43.029  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                            2026-04-12 20:49:43.029  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                            2026-04-12 20:49:43.029  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                            2026-04-12 20:49:43.029  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                            2026-04-12 20:49:43.029  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                            2026-04-12 20:49:43.030  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                            2026-04-12 20:49:43.030  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/build/main.js:13:17)
                            2026-04-12 20:49:43.030  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                            2026-04-12 20:49:43.030  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                            2026-04-12 20:49:43.030  - error: host.iobroker Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/build/main.js' ]
                            2026-04-12 20:49:43.030  - error: host.iobroker Caught by controller[0]: }
                            2026-04-12 20:49:43.030  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                            2026-04-12 20:49:43.030  - error: host.iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2026-04-12 20:49:43.030  - info: host.iobroker Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                            • N nettworker
                              iob restart admin
                              @nettworker
                              Da muss aber noch mehr davor stehen.
                              N 1 Antwort Letzte Antwort
                              • N nettworker
                                iob restart admin
                                @nettworker
                                cd /opt/iobroker
                                npm ls
                                  @nettworker
                                  N Offline
                                  N Offline
                                  nettworker
                                  Nochmal neu, die Meldungen num 2 Uhr kannst du ignorieren, da findet ein Full Backup statt und der Rechner ist nicht erreichbar.
                                  dieter@iobroker:~$ iob logs --watch
                                  2026-04-13 02:00:36.040  - error: influxdb.0 (5726) getHistory: Error: connect ECONNREFUSED 192.168.20.133:8086
                                  2026-04-13 02:00:36.046  - error: influxdb.0 (5726) Error: connect ECONNREFUSED 192.168.20.133:8086
                                  2026-04-13 02:00:36.092  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:00:36.092  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:00:36.113  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:00:36.113  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:00:51.007  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:00:51.007  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:00:51.111  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:00:51.111  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:00:51.128  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:00:51.128  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:01:06.014  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:01:06.014  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:01:06.090  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:01:06.090  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:01:06.131  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:01:06.131  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:01:06.133  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:01:06.133  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:01:21.009  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:01:21.009  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:01:21.109  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:01:21.109  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:01:21.128  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:01:21.128  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:01:21.131  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:01:21.131  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:01:36.005  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:01:36.005  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:01:36.034  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:01:36.034  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:01:36.049  - info: influxdb.0 (5726) Not connected to InfluxDB, try later
                                  2026-04-13 02:01:36.049  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Not connected to InfluxDB, try later
                                  2026-04-13 02:01:50.462  - error: influxdb.0 (5726) getHistory: Error: connect EHOSTUNREACH 192.168.20.133:8086
                                  2026-04-13 02:01:50.462  - error: influxdb.0 (5726) Error: connect EHOSTUNREACH 192.168.20.133:8086
                                  2026-04-13 02:01:50.999  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:01:50.999  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:01:51.060  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:01:51.060  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:01:51.084  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:01:51.084  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:01:51.086  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:01:51.086  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:02:06.033  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:02:06.033  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:02:06.080  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:02:06.080  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:02:06.098  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:02:06.098  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:02:06.102  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:02:06.102  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:02:21.006  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:02:21.006  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:02:21.084  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:02:21.084  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:02:21.121  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:02:21.121  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:02:21.122  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:02:21.122  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:02:35.991  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:02:35.991  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:02:36.016  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:02:36.016  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:02:36.034  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:02:36.034  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:02:36.037  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:02:36.037  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:02:54.078  - error: influxdb.0 (5726) getHistory: Error: connect EHOSTUNREACH 192.168.20.133:8086
                                  2026-04-13 02:02:54.078  - error: influxdb.0 (5726) Error: connect EHOSTUNREACH 192.168.20.133:8086
                                  2026-04-13 02:02:54.110  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:02:54.110  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:02:54.127  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:02:54.127  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:02:54.129  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:02:54.129  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:03:05.995  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:03:05.995  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:03:06.013  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:03:06.013  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:03:06.031  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:03:06.031  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:03:06.034  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:03:06.034  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:03:21.007  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:03:21.007  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:03:21.079  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:03:21.079  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:03:21.107  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:03:21.107  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:03:21.108  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:03:21.108  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:03:36.004  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:03:36.004  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:03:36.077  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:03:36.077  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:03:36.094  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:03:36.094  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:03:36.095  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:03:36.096  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:03:50.988  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:03:50.988  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:03:51.005  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:03:51.006  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:03:51.017  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:03:51.017  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:03:51.018  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:03:51.018  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:04:09.086  - error: influxdb.0 (5726) getHistory: Error: connect EHOSTUNREACH 192.168.20.133:8086
                                  2026-04-13 02:04:09.086  - error: influxdb.0 (5726) Error: connect EHOSTUNREACH 192.168.20.133:8086
                                  2026-04-13 02:04:09.183  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:04:09.184  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:04:09.201  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:04:09.202  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:04:09.203  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:04:09.204  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:04:20.991  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:04:20.991  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:04:21.012  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:04:21.012  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:04:21.030  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:04:21.030  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:04:21.032  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:04:21.032  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:04:36.007  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:04:36.007  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:04:36.089  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:04:36.089  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:04:36.131  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:04:36.131  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:04:36.132  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:04:36.132  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:04:51.034  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:04:51.034  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:04:51.052  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:04:51.052  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:04:51.069  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:04:51.069  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:04:51.071  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:04:51.071  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:05:06.005  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:05:06.005  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:05:06.094  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:05:06.094  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:05:06.110  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:05:06.110  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:05:06.113  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:05:06.113  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:05:21.013  - error: influxdb.0 (5726) getHistory: Error: connect ECONNREFUSED 192.168.20.133:8086
                                  2026-04-13 02:05:21.014  - error: influxdb.0 (5726) Error: connect ECONNREFUSED 192.168.20.133:8086
                                  2026-04-13 02:05:21.092  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:05:21.092  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:05:21.125  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:05:21.125  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:05:21.126  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:05:21.126  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:05:36.003  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:05:36.003  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:05:36.022  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:05:36.023  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:05:36.039  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:05:36.039  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:05:36.040  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:05:36.040  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:05:50.990  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:05:50.990  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:05:51.013  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:05:51.013  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:05:51.032  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:05:51.032  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:05:51.034  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:05:51.034  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:06:06.001  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:06:06.001  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:06:06.021  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:06:06.021  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:06:06.045  - info: influxdb.0 (5726) Currently no hosts available, try later
                                  2026-04-13 02:06:06.045  - info: influxdb.0 (5726) Error storing buffered series for sonoff.0.Zaehler-Haus.MT681_Power_cur before GetHistory: Currently no hosts available, try later
                                  2026-04-13 02:06:06.047  - error: influxdb.0 (5726) getHistory: Error: No host available
                                  2026-04-13 02:06:06.047  - error: influxdb.0 (5726) Error: No host available
                                  2026-04-13 02:07:33.426  - info: influxdb.0 (5726) Store 2 buffered influxDB history points
                                  2026-04-13 02:57:26.774  - info: host.iobroker Delete log file iobroker.2026-04-05.log.gz
                                  2026-04-13 05:20:12.842  - info: mqtt.0 (6588) Client [OpenDTU-15427312] connection closed: Error: read ECONNRESET
                                  2026-04-13 05:20:14.892  - info: mqtt.0 (6588) Client [OpenDTU-15427312] connected with secret 1776050414888_2564
                                  2026-04-13 05:20:14.936  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_relative" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_relative/
                                  2026-04-13 05:20:14.937  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_relative"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_relative/
                                  2026-04-13 05:20:14.937  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_absolute" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_absolute/
                                  2026-04-13 05:20:14.937  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_absolute"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_absolute/
                                  2026-04-13 05:20:14.937  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_relative" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_relative/
                                  2026-04-13 05:20:14.937  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_relative"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_relative/
                                  2026-04-13 05:20:14.937  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_absolute" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_absolute/
                                  2026-04-13 05:20:14.938  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_absolute"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_absolute/
                                  2026-04-13 05:20:14.938  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/power" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.power/
                                  2026-04-13 05:20:14.938  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/power"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.power/
                                  2026-04-13 05:20:14.938  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/restart" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.restart/
                                  2026-04-13 05:20:14.938  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/restart"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.restart/
                                  2026-04-13 05:20:14.939  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_online_voltage"
                                  2026-04-13 05:20:14.957  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_online_current"
                                  2026-04-13 05:20:14.960  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_offline_voltage"
                                  2026-04-13 05:20:14.960  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_offline_current"
                                  2026-04-13 05:20:14.960  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.mode"
                                  2026-04-13 05:20:14.961  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.powerlimiter.cmd.mode"
                                  2026-04-13 05:20:15.138  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                                  2026-04-13 05:20:15.139  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                                  2026-04-13 05:20:15.140  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                                  2026-04-13 05:20:15.141  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                                  2026-04-13 05:20:15.142  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                                  2026-04-13 05:20:15.158  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                                  2026-04-13 05:20:15.160  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                                  2026-04-13 05:20:15.161  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                                  2026-04-13 05:20:15.162  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                                  2026-04-13 07:51:39.421  - info: mqtt.0 (6588) Client [OpenDTU-15427312] connection closed: Error: read ECONNRESET
                                  2026-04-13 07:51:41.474  - info: mqtt.0 (6588) Client [OpenDTU-15427312] connected with secret 1776059501471_5840
                                  2026-04-13 07:51:41.835  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_relative" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_relative/
                                  2026-04-13 07:51:41.835  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_relative"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_relative/
                                  2026-04-13 07:51:41.836  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_absolute" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_absolute/
                                  2026-04-13 07:51:41.836  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_absolute"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_absolute/
                                  2026-04-13 07:51:41.845  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_relative" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_relative/
                                  2026-04-13 07:51:41.845  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_relative"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_relative/
                                  2026-04-13 07:51:41.848  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_absolute" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_absolute/
                                  2026-04-13 07:51:41.848  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_absolute"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_absolute/
                                  2026-04-13 07:51:41.848  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/power" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.power/
                                  2026-04-13 07:51:41.848  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/power"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.power/
                                  2026-04-13 07:51:41.859  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/restart" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.restart/
                                  2026-04-13 07:51:41.859  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/restart"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.restart/
                                  2026-04-13 07:51:41.860  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_online_voltage"
                                  2026-04-13 07:51:41.860  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_online_current"
                                  2026-04-13 07:51:41.860  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_offline_voltage"
                                  2026-04-13 07:51:41.860  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_offline_current"
                                  2026-04-13 07:51:41.870  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.mode"
                                  2026-04-13 07:51:41.872  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.powerlimiter.cmd.mode"
                                  2026-04-13 07:51:42.036  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                                  2026-04-13 07:51:42.037  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                                  2026-04-13 07:51:42.045  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                                  2026-04-13 07:51:42.048  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                                  2026-04-13 07:51:42.060  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                                  2026-04-13 07:51:42.061  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                                  2026-04-13 07:51:42.062  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                                  2026-04-13 07:51:42.070  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                                  2026-04-13 07:51:42.072  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                                  2026-04-13 07:56:15.821  - info: web.0 (7955) <== Disconnect system.user.admin from ::ffff:192.168.30.59
                                  2026-04-13 07:56:18.529  - info: web.0 (7955) ==> Connected system.user.admin from ::ffff:192.168.30.59
                                  2026-04-13 07:56:20.271  - info: javascript.0 (5924) script.js.Schalter.Rollaeden: Es werden alle Rollo aufgefahren
                                  2026-04-13 07:56:45.959  - info: web.0 (7955) <== Disconnect system.user.admin from ::ffff:192.168.30.59
                                  2026-04-13 07:56:57.130  - info: web.0 (7955) ==> Connected system.user.admin from ::ffff:192.168.30.59
                                  2026-04-13 07:57:20.279  - info: javascript.0 (5924) script.js.Schalter.Rollaeden: Es werden alle Rollo beim Auffahren gestoppt
                                  2026-04-13 08:05:52.505  - info: web.0 (7955) ==> Connected system.user.admin from ::ffff:192.168.30.45
                                  2026-04-13 08:05:52.555  - info: javascript.0 (5924) script.js.Schalter.Rollaeden: Es werden alle Rollo aufgefahren
                                  2026-04-13 08:06:52.558  - info: javascript.0 (5924) script.js.Schalter.Rollaeden: Es werden alle Rollo beim Auffahren gestoppt
                                  2026-04-13 08:16:40.707  - info: web.0 (7955) <== Disconnect system.user.admin from ::ffff:192.168.30.45 vis.0
                                  2026-04-13 08:32:27.121  - info: mqtt.0 (6588) Client [nodered05568ac752885a52] connection closed: timeout
                                  2026-04-13 08:32:52.035  - info: mqtt.0 (6588) Client [noderede77888f8a908ae17] connected with secret 1776061971895_3974
                                  2026-04-13 09:00:00.008  - info: javascript.0 (5924) script.js.Solar.Verbrauchsdaten_sichern: Heute Nacht verbraucht = 0.00
                                  2026-04-13 09:11:17.868  - info: mqtt.0 (6588) Client [OpenDTU-15427312] connection closed: Error: read ECONNRESET
                                  2026-04-13 09:11:19.919  - info: mqtt.0 (6588) Client [OpenDTU-15427312] connected with secret 1776064279919_952
                                  2026-04-13 09:11:20.103  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_relative" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_relative/
                                  2026-04-13 09:11:20.103  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_relative"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_relative/
                                  2026-04-13 09:11:20.104  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_absolute" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_absolute/
                                  2026-04-13 09:11:20.104  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_persistent_absolute"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_persistent_absolute/
                                  2026-04-13 09:11:20.104  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_relative" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_relative/
                                  2026-04-13 09:11:20.104  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_relative"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_relative/
                                  2026-04-13 09:11:20.104  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_absolute" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_absolute/
                                  2026-04-13 09:11:20.104  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/limit_nonpersistent_absolute"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.limit_nonpersistent_absolute/
                                  2026-04-13 09:11:20.105  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/power" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.power/
                                  2026-04-13 09:11:20.105  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/power"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.power/
                                  2026-04-13 09:11:20.105  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/restart" with regex /openDTU_Holzplatz\.[^.]*\.cmd\.restart/
                                  2026-04-13 09:11:20.105  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "openDTU_Holzplatz/+/cmd/restart"  with regex /mqtt\.0\.openDTU_Holzplatz\.[^.]*\.cmd\.restart/
                                  2026-04-13 09:11:20.110  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_online_voltage"
                                  2026-04-13 09:11:20.127  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_online_current"
                                  2026-04-13 09:11:20.130  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_offline_voltage"
                                  2026-04-13 09:11:20.130  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.limit_offline_current"
                                  2026-04-13 09:11:20.130  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.huawei.cmd.mode"
                                  2026-04-13 09:11:20.130  - info: mqtt.0 (6588) Client [OpenDTU-15427312] subscribes on "mqtt.0.openDTU_Holzplatz.powerlimiter.cmd.mode"
                                  2026-04-13 09:11:20.304  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                                  2026-04-13 09:11:20.305  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                                  2026-04-13 09:11:20.306  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                                  2026-04-13 09:11:20.307  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe send all known states
                                  2026-04-13 09:11:20.310  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                                  2026-04-13 09:11:20.327  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                                  2026-04-13 09:11:20.330  - info: mqtt.0 (6588) Client [OpenDTU-15427312] publishOnSubscribe
                                  2026-04-13 11:57:27.800  - info: host.iobroker instance system.adapter.admin.0 in version "7.7.22" started with pid 28705
                                  2026-04-13 11:57:27.896  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1386
                                  2026-04-13 11:57:27.896  - error: host.iobroker Caught by controller[0]:   throw err;
                                  2026-04-13 11:57:27.896  - error: host.iobroker Caught by controller[0]:   ^
                                  2026-04-13 11:57:27.896  - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'axios'
                                  2026-04-13 11:57:27.896  - error: host.iobroker Caught by controller[0]: Require stack:
                                  2026-04-13 11:57:27.896  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/build/main.js
                                  2026-04-13 11:57:27.896  - error: host.iobroker Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                                  2026-04-13 11:57:27.896  - error: host.iobroker Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                                  2026-04-13 11:57:27.896  - error: host.iobroker Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                                  2026-04-13 11:57:27.896  - error: host.iobroker Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                                  2026-04-13 11:57:27.896  - error: host.iobroker Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                                  2026-04-13 11:57:27.896  - error: host.iobroker Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                  2026-04-13 11:57:27.896  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                                  2026-04-13 11:57:27.897  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                                  2026-04-13 11:57:27.897  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/build/main.js:13:17)
                                  2026-04-13 11:57:27.897  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1705:14) {
                                  2026-04-13 11:57:27.897  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                  2026-04-13 11:57:27.897  - error: host.iobroker Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/build/main.js' ]
                                  2026-04-13 11:57:27.897  - error: host.iobroker Caught by controller[0]: }
                                  2026-04-13 11:57:27.897  - error: host.iobroker Caught by controller[0]: Node.js v22.22.2
                                  2026-04-13 11:57:27.897  - error: host.iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  2026-04-13 11:57:27.897  - info: host.iobroker Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                    @nettworker
                                    cd /opt/iobroker
                                    npm ls
                                    N Offline
                                    N Offline
                                    nettworker
                                    cd /opt/iobroker
                                    npm ls
                                    iobroker.inst@3.0.0 /opt/iobroker
                                    ├── @iobroker-javascript.0/math.js@npm:math.js@1.1.46
                                    ├── @iobroker-javascript.0/moment-duration-format@npm:moment-duration-format@2.3        .2
                                    ├── @iobroker-javascript.0/moment-timezone@npm:moment-timezone@0.6.1
                                    ├── @iobroker-javascript.0/moment@npm:moment@2.30.1
                                    ├── @iobroker-javascript.0/wake_on_lan@npm:wake_on_lan@1.0.0
                                    ├── iobroker.admin@7.7.22
                                    ├── iobroker.backitup@3.3.14
                                    ├── iobroker.daswetter@4.5.3
                                    ├── iobroker.devices@1.2.14
                                    ├── iobroker.discovery@5.0.0
                                    ├── iobroker.echarts@3.1.0
                                    ├── iobroker.energiefluss-erweitert@0.8.1
                                    ├── iobroker.history@4.0.0
                                    ├── iobroker.influxdb@4.0.2
                                    ├── iobroker.jarvis@3.1.8
                                    ├── iobroker.javascript@9.0.18
                                    ├── iobroker.js-controller@7.0.7
                                    ├── iobroker.linux-control@1.1.5
                                    ├── iobroker.mqtt@6.1.4
                                    ├── iobroker.ping@1.7.9
                                    ├── iobroker.proxmox@2.4.10
                                    ├── iobroker.reolink@1.4.2
                                    ├── iobroker.shuttercontrol@2.0.12
                                    ├── iobroker.simple-api@3.0.7
                                    ├── iobroker.socketio@7.0.8
                                    ├── iobroker.sonoff@3.3.0
                                    ├── iobroker.vis-2-widgets-gauges@2.0.2
                                    ├── iobroker.vis-2-widgets-inventwo@0.5.5
                                    ├── iobroker.vis-2-widgets-material@1.6.1
                                    ├── iobroker.vis-2@2.13.8
                                    ├── iobroker.vis-canvas-gauges@1.0.1
                                    ├── iobroker.vis-icontwo@2.11.1
                                    ├── iobroker.vis-inventwo@3.3.5
                                    ├── iobroker.vis-jqui-mfd@1.1.3
                                    ├── iobroker.vis-materialdesign@0.5.9
                                    ├── iobroker.vis@1.5.6
                                    ├── iobroker.web@8.0.0
                                    ├── iobroker.whatsapp-cmb@0.3.0
                                    ├── iobroker.ws@4.0.0
                                    └── iobroker.zigbee@3.3.5
                                    • N Offline
                                      N Offline
                                      nettworker
                                      schrieb am zuletzt editiert von nettworker
                                      Da kam dann noch ne Meldung:
                                      Hab ich mal auf Verdacht gemacht und siehe da, Admin läuft
