    apollon77A
lovelace uinspanelsonoff
8.1k Beiträge 281 Kommentatoren 9.7m Aufrufe 260 Beobachtet
  • MichaelFM MichaelF
    javascript.0	15:28:12.499	info
    renderCurrentPage
    javascript.0	15:28:12.505	info
    2.1 W
    javascript.0	15:28:12.535	info
    {"DeviceName":"Tasmota"}
    javascript.0	15:28:12.656	info
    {"Status":{"Module":0,"DeviceName":"Tasmota","FriendlyName":["Tasmota",""],"Topic":"tasmota_A4ED44","ButtonTopic":"0","Power":"00","PowerLock":"00","PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin","RestartReason":"Software reset CPU","Uptime":"0T01:06:38","StartupUTC":"2026-04-08T12:21:34","Sleep":50,"CfgHolder":4617,"BootCount":42,"BCResetTime":"2024-04-13T18:49:31","SaveCount":1149},"StatusFWR":{"Version":"15.2.0(release-tasmota32)","BuildDateTime":"2025.12.12 11:08:19","Core":"3.3.4","SDK":"5.3.4.251205","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.1","CR":"469/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":2,"FileLog":0,"SysLog":0,"LogHost":"192.168.178.69","LogPort":514,"SSId":["WLAN 7270",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000001"]},"StatusMEM":{"ProgramSize":2087,"Free":792,"Heap":115,"StackLowMark":3,"PsrMax":2048,"PsrFree":2023,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"1640C8","FlashFrequency":80,"FlashMode":"DIO","Features":["0407","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80F1","00000814"],"Drivers":"1,2,!3,!4,!5,7,!8,9,10,11,12,!14,!16,!17,!20,!21,24,26,!27,29,!34,!35,38,50,52,!59,!60,62,!63,!66,!67,!68,!73,!75,82,!86,!87,!88,!91,!121","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82,89"},"StatusNET":{"Hostname":"tasmota-A4ED44-3396","IPAddress":"192.168.178.58","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.36","DNSServer2":"fd63:a0ea:8156:0:9a9b:cbff:feae:d11b","Mac":"08:D1:F9:A4:ED:44","IP6Global":"2003:df:3714:d400:ad1:f9ff:fea4:ed44","IP6Local":"fe80::ad1:f9ff:fea4:ed44%st2","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.36","DNSServer2":"fd63:a0ea:8156:0:9a9b:cbff:feae:d11b","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16},"StatusMQT":{"MqttHost":"192.168.178.69","MqttPort":1886,"MqttClientMask":"NS_Panel2","MqttClient":"NS_Panel2","MqttUser":"Mikeldk","MqttCount":2,"MqttTLS":0,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2026-04-08T13:28:12Z","Local":"2026-04-08T15:28:12","StartDST":"2026-03-29T02:00:00","EndDST":"2026-10-25T03:00:00","Timezone":99,"Sunrise":"07:13","Sunset":"20:30"},"StatusSNS":{"Time":"2026-04-08T15:28:12","ANALOG":{"Temperature1":18.7},"ESP32":{"Temperature":39.4},"TempUnit":"C"},"StatusSTS":{"Time":"2026-04-08T15:28:12","Uptime":"0T01:06:38","UptimeSec":3998,"Heap":113,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":171,"MqttCount":2,"Berry":{"HeapUsed":16,"Objects":220},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"WLAN 7270","BSSId":"98:9B:CB:AE:D1:1E","Channel":6,"Mode":"HT40","RSSI":80,"Signal":-60,"LinkCount":1,"Downtime":"0T00:00:03"},"Hostname":"tasmota-A4ED44-3396","IPAddress":"192.168.178.58"}}
    javascript.0	15:28:12.712	info
    Desired TFT Firmware: 61 / v5.1.1
    javascript.0	15:28:12.713	info
    Installed TFT Firmware: 61 / v5.1.1
    javascript.0	15:28:12.814	info
    renderCurrentPage
    javascript.0	15:28:13.134	info
    Debug mode disabled
    javascript.0	15:28:16.241	info
    hidden Cards disabled
    javascript.0	15:28:16.508	info
    Start MQTT-Port-Check -------------------------------------
    -- admin.0                   - 8081
    -- hm-rpc.0                  - 0
    -- hm-rpc.1                  - 0
    javascript.0	15:28:16.509	info
    -- hm-rpc.2                  - 0
    -- hm-rpc.3                  - 0
    -- influxdb.0                - 8086
    -- influxdb.1                - 8086
    -- influxdb.2                - 8428
    -- mihome-vacuum.0           - 5432
    -- mqtt.1                    - 1883
    -- mqtt.3                    - 1886
    -- pi-hole2.0                - 80
    -- pioneer_sc_vsx.0          - 23
    -- sainlogic.0               - 4500
    -- simple-api.0              - 8087
    -- sonoff.0                  - 1883
    -- sql.0                     - Kein Port gefunden
    -- synology.0                - 5000
    -- synology.1                - 5000
    -- telegram.0                - 8443
    -- web.0                     - 8082
    - MQTT-Port-Check OK: Instance of Adapter: mqtt.3 is running on Port:1886
    End MQTT-Port-Check ---------------------------------------
    T
    T
    TT-Tom
    #8052
    @MichaelF
    okay nicht den den ganzen Start, es reicht der Teil wenn du auf den Button kickst
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    • T TT-Tom
      @tobiasp
      zeige mal diese Einstellungen. Liegen im alias
      MichaelFM
      MichaelFM
      MichaelF
      #8053
      @TT-Tom
      MichaelFM 1 Antwort Letzte Antwort
      • MichaelFM
        MichaelFM
        MichaelF
        #8054
        Jetzt hatte ich was neues:
        avascript.0
        2026-04-08 15:44:25.300	info	State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
        javascript.0
        2026-04-08 15:44:24.576	info	State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
        javascript.0
        2026-04-08 15:44:15.725	info	script.js.common.WZ_test: Installed TFT Firmware: 61 / v5.1.1
        javascript.0
        2026-04-08 15:44:15.725	info	script.js.common.WZ_test: Desired TFT Firmware: 61 / v5.1.1
        mqtt.3
        2026-04-08 15:44:10.897	info	Client [NS_Panel2] publishOnSubscribe send all known states
        mqtt.3
        mqtt.3
        javascript.0
        2026-04-08 15:44:10.761	info	script.js.common.WZ_test: Tasmota upgrade complete. New Version: 15.3.0(release-nspanel)
        mqtt.3
        2026-04-08 15:44:10.697	info	Client [NS_Panel2] subscribes on "cmnd/NS_Panel2_fb/#" with regex /^mqtt\.3\.cmnd\.NS_Panel2_fb\..*/
        mqtt.3
        2026-04-08 15:44:10.697	info	Client [NS_Panel2] subscribes on "cmnd/NS_Panel2_fb/#" with regex /^cmnd\.NS_Panel2_fb\..*/
        mqtt.3
        2026-04-08 15:44:10.697	info	Client [NS_Panel2] subscribes on "cmnd/tasmotas/#" with regex /^mqtt\.3\.cmnd\.tasmotas\..*/
        mqtt.3
        2026-04-08 15:44:10.697	info	Client [NS_Panel2] subscribes on "cmnd/tasmotas/#" with regex /^cmnd\.tasmotas\..*/
        mqtt.3
        2026-04-08 15:44:10.696	info	Client [NS_Panel2] subscribes on "cmnd/tasmota_A4ED44/#" with regex /^mqtt\.3\.cmnd\.tasmota_A4ED44\..*/
        mqtt.3
        2026-04-08 15:44:10.696	info	Client [NS_Panel2] subscribes on "cmnd/tasmota_A4ED44/#" with regex /^cmnd\.tasmota_A4ED44\..*/
        mqtt.3
        2026-04-08 15:44:10.635	info	Client [NS_Panel2] connected with secret 1775655850631_9681
        mqtt.3
        2026-04-08 15:44:04.383	info	Client [NS_Panel2] connection closed: closed
        mqtt.3
        2026-04-08 15:44:01.928	info	Client [NS_Panel2] publishOnSubscribe send all known states
        mqtt.3
        mqtt.3
        mqtt.3
        2026-04-08 15:44:01.728	info	Client [NS_Panel2] subscribes on "cmnd/NS_Panel2_fb/#" with regex /^mqtt\.3\.cmnd\.NS_Panel2_fb\..*/
        mqtt.3
        2026-04-08 15:44:01.728	info	Client [NS_Panel2] subscribes on "cmnd/NS_Panel2_fb/#" with regex /^cmnd\.NS_Panel2_fb\..*/
        mqtt.3
        2026-04-08 15:44:01.728	info	Client [NS_Panel2] subscribes on "cmnd/tasmotas/#" with regex /^mqtt\.3\.cmnd\.tasmotas\..*/
        mqtt.3
        2026-04-08 15:44:01.728	info	Client [NS_Panel2] subscribes on "cmnd/tasmotas/#" with regex /^cmnd\.tasmotas\..*/
        mqtt.3
        2026-04-08 15:44:01.727	info	Client [NS_Panel2] subscribes on "cmnd/tasmota_A4ED44/#" with regex /^mqtt\.3\.cmnd\.tasmota_A4ED44\..*/
        mqtt.3
        2026-04-08 15:44:01.727	info	Client [NS_Panel2] subscribes on "cmnd/tasmota_A4ED44/#" with regex /^cmnd\.tasmota_A4ED44\..*/
        mqtt.3
        2026-04-08 15:44:01.672	info	Client [NS_Panel2] connected with secret 1775655841668_6708
        javascript.0
        2026-04-08 15:44:01.256	warn	script.js.common.WZ_test: AxiosError: read ECONNRESET at Function.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:7:24) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:869:27) at RedirectableRequest.emit (node:events:519:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:49:24) at ClientRequest.emit (node:events:531:35) at ClientRequest.emit (node:domain:489:12) at emitErrorEvent (node:_http_client:108:11) at Socket.socketErrorListener (node:_http_client:575:5) at Socket.emit (node:events:519:28) at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:46:41) at processTicksAndRejections (node:internal/process/task_queues:103:5) { isAxiosError: true, code: 'ECONNRESET', config: { transitional: { silentJSONParsing: true, forcedJSONParsing: true, clarifyTimeoutError: false, legacyInterceptorReqResOrdering: true }, adapter: [ 'xhr', 'http', 'fetch' ], transformRequest: [ [Function: transformRequest] ], transformResponse: [ [Function: transformResponse] ], timeout: 0, xsrfCookieName: 'XSRF-TOKEN', xsrfHeaderName: 'X-XSRF-TOKEN', maxContentLength: -1, maxBodyLength: -1, env: { FormData: [Function], Blob: [class Blob] }, validateStatus: [Function: validateStatus], headers: Object [AxiosHeaders] { Accept: 'application/json, text/plain, */*', 'Content-Type': undefined, 'User-Agent': 'ioBroker', 'Accept-Encoding': 'gzip, compress, deflate, br' }, method: 'get', url: 'http://192.168.178.58/cm?cmnd=Upgrade 1', allowAbsoluteUrls: true, data: undefined }, request: <ref *1> Writable { _events: { close: undefined, error: [Function: handleRequestError], prefinish: undefined, finish: undefined, drain: undefined, response: [Function: handleResponse], socket: [Array], abort: undefined }, _writableState: WritableState { highWaterMark: 65536, length: 0, corked: 0, onwrite: [Function: bound onwrite], writelen: 0, bufferedIndex: 0, pendingcb: 0, [Symbol(kState)]: 17580812, [Symbol(kBufferedValue)]: null }, _options: { maxRedirects: 21, maxBodyLength: Infinity, protocol: 'http:', path: '/cm?cmnd=Upgrade%201', method: 'GET', headers: [Object: null prototype], agents: [Object], auth: undefined, family: undefined, beforeRedirect: [Function: dispatchBeforeRedirect], beforeRedirects: [Object], http2Options: undefined, hostname: '192.168.178.58', port: '', agent: undefined, nativeProtocols: [Object], pathname: '/cm', search: '?cmnd=Upgrade%201' }, _ended: true, _ending: true, _redirectCount: 0, _redirects: [], _requestBodyLength: 0, _requestBodyBuffers: [], _eventsCount: 3, _onNativeResponse: [Function (anonymous)], _currentRequest: ClientRequest { _events: [Object: null prototype], _eventsCount: 7, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: true, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, strictContentLength: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, _header: 'GET /cm?cmnd=Upgrade%201 HTTP/1.1\r\n' + 'Accept: application/json, text/plain, */*\r\n' + 'User-Agent: ioBroker\r\n' + 'Accept-Encoding: gzip, compress, deflate, br\r\n' + 'sentry-trace: 7b3a4f0912164ca996deb25e180b9ac5-a596eca9a258425b\r\n' + 'baggage: sentry-environment=production,sentry-release=iobroker.javascript%409.0.18,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=7b3a4f0912164ca996deb25e180b9ac5\r\n' + 'Host: 192.168.178.58\r\n' + 'Connection: keep-alive\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: [Agent], socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, joinDuplicateHeaders: undefined, path: '/cm?cmnd=Upgrade%201', _ended: false, res: null, aborted: false, timeoutCb: [Function: emitRequestTimeout], upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: '192.168.178.58', protocol: 'http:', _redirectable: [Circular *1], [Symbol(shapeMode)]: false, [Symbol(kCapture)]: false, [Symbol(kBytesWritten)]: 0, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kChunkedBuffer)]: [], [Symbol(kChunkedLength)]: 0, [Symbol(kSocket)]: [Socket], [Symbol(kOutHeaders)]: [Object: null prototype], [Symbol(errored)]: null, [Symbol(kHighWaterMark)]: 65536, [Symbol(kRejectNonStandardBodyWrites)]: false, [Symbol(kUniqueHeaders)]: null }, _currentUrl: 'http://192.168.178.58/cm?cmnd=Upgrade%201', _timeout: null, [Symbol(shapeMode)]: true, [Symbol(kCapture)]: false }, cause: Error: read ECONNRESET at TCP.onStreamRead (node:internal/stream_base_commons:216:20) { errno: -104, code: 'ECONNRESET', syscall: 'read' }}
        javascript.0
        2026-04-08 15:44:01.222	warn	script.js.common.WZ_test: AxiosError: read ECONNRESET at Function.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:7:24) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:869:27) at RedirectableRequest.emit (node:events:519:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:49:24) at ClientRequest.emit (node:events:531:35) at ClientRequest.emit (node:domain:489:12) at emitErrorEvent (node:_http_client:108:11) at Socket.socketErrorListener (node:_http_client:575:5) at Socket.emit (node:events:519:28) at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:46:41) at processTicksAndRejections (node:internal/process/task_queues:103:5) { isAxiosError: true, code: 'ECONNRESET', config: { transitional: { silentJSONParsing: true, forcedJSONParsing: true, clarifyTimeoutError: false, legacyInterceptorReqResOrdering: true }, adapter: [ 'xhr', 'http', 'fetch' ], transformRequest: [ [Function: transformRequest] ], transformResponse: [ [Function: transformResponse] ], timeout: 0, xsrfCookieName: 'XSRF-TOKEN', xsrfHeaderName: 'X-XSRF-TOKEN', maxContentLength: -1, maxBodyLength: -1, env: { FormData: [Function], Blob: [class Blob] }, validateStatus: [Function: validateStatus], headers: Object [AxiosHeaders] { Accept: 'application/json, text/plain, */*', 'Content-Type': undefined, 'User-Agent': 'ioBroker', 'Accept-Encoding': 'gzip, compress, deflate, br' }, method: 'get', url: 'http://192.168.178.58/cm?cmnd=OtaUrl http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin', allowAbsoluteUrls: true, data: undefined }, request: <ref *1> Writable { _events: { close: undefined, error: [Function: handleRequestError], prefinish: undefined, finish: undefined, drain: undefined, response: [Function: handleResponse], socket: [Array], abort: undefined }, _writableState: WritableState { highWaterMark: 65536, length: 0, corked: 0, onwrite: [Function: bound onwrite], writelen: 0, bufferedIndex: 0, pendingcb: 0, [Symbol(kState)]: 17580812, [Symbol(kBufferedValue)]: null }, _options: { maxRedirects: 21, maxBodyLength: Infinity, protocol: 'http:', path: '/cm?cmnd=OtaUrl%20http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin', method: 'GET', headers: [Object: null prototype], agents: [Object], auth: undefined, family: undefined, beforeRedirect: [Function: dispatchBeforeRedirect], beforeRedirects: [Object], http2Options: undefined, hostname: '192.168.178.58', port: '', agent: undefined, nativeProtocols: [Object], pathname: '/cm', search: '?cmnd=OtaUrl%20http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin' }, _ended: true, _ending: true, _redirectCount: 0, _redirects: [], _requestBodyLength: 0, _requestBodyBuffers: [], _eventsCount: 3, _onNativeResponse: [Function (anonymous)], _currentRequest: ClientRequest { _events: [Object: null prototype], _eventsCount: 7, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: true, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, strictContentLength: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, _header: 'GET /cm?cmnd=OtaUrl%20http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin HTTP/1.1\r\n' + 'Accept: application/json, text/plain, */*\r\n' + 'User-Agent: ioBroker\r\n' + 'Accept-Encoding: gzip, compress, deflate, br\r\n' + 'sentry-trace: 7b3a4f0912164ca996deb25e180b9ac5-a596eca9a258425b\r\n' + 'baggage: sentry-environment=production,sentry-release=iobroker.javascript%409.0.18,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=7b3a4f0912164ca996deb25e180b9ac5\r\n' + 'Host: 192.168.178.58\r\n' + 'Connection: keep-alive\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: [Agent], socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, joinDuplicateHeaders: undefined, path: '/cm?cmnd=OtaUrl%20http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin', _ended: false, res: null, aborted: false, timeoutCb: [Function: emitRequestTimeout], upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: '192.168.178.58', protocol: 'http:', _redirectable: [Circular *1], [Symbol(shapeMode)]: false, [Symbol(kCapture)]: false, [Symbol(kBytesWritten)]: 0, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kChunkedBuffer)]: [], [Symbol(kChunkedLength)]: 0, [Symbol(kSocket)]: [Socket], [Symbol(kOutHeaders)]: [Object: null prototype], [Symbol(errored)]: null, [Symbol(kHighWaterMark)]: 65536, [Symbol(kRejectNonStandardBodyWrites)]: false, [Symbol(kUniqueHeaders)]: null }, _currentUrl: 'http://192.168.178.58/cm?cmnd=OtaUrl%20http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin', _timeout: null, [Symbol(shapeMode)]: true, [Symbol(kCapture)]: false }, cause: Error: read ECONNRESET at TCP.onStreamRead (node:internal/stream_base_commons:216:20) { errno: -104, code: 'ECONNRESET', syscall: 'read' }}
        mqtt.3
        2026-04-08 15:44:01.111	info	Client [NS_Panel2] connection closed: closed
        mqtt.3
        2026-04-08 15:43:28.009	info	Client [NS_Panel2] publishOnSubscribe send all known states
        mqtt.3
        2026-04-08 15:43:28.008	info	Client [NS_Panel2] publishOnSubscribe send all known states
        mqtt.3
        javascript.0
        2026-04-08 15:43:27.859	warn	script.js.common.WZ_test: Tasmota in Safeboot - Please wait while upgrading
        mqtt.3
        2026-04-08 15:43:27.808	info	Client [NS_Panel2] subscribes on "cmnd/NS_Panel2_fb/#" with regex /^mqtt\.3\.cmnd\.NS_Panel2_fb\..*/
        mqtt.3
        2026-04-08 15:43:27.808	info	Client [NS_Panel2] subscribes on "cmnd/NS_Panel2_fb/#" with regex /^cmnd\.NS_Panel2_fb\..*/
        mqtt.3
        2026-04-08 15:43:27.808	info	Client [NS_Panel2] subscribes on "cmnd/tasmotas/#" with regex /^mqtt\.3\.cmnd\.tasmotas\..*/
        mqtt.3
        2026-04-08 15:43:27.808	info	Client [NS_Panel2] subscribes on "cmnd/tasmotas/#" with regex /^cmnd\.tasmotas\..*/
        mqtt.3
        2026-04-08 15:43:27.808	info	Client [NS_Panel2] subscribes on "cmnd/tasmota_A4ED44/#" with regex /^mqtt\.3\.cmnd\.tasmota_A4ED44\..*/
        mqtt.3
        2026-04-08 15:43:27.807	info	Client [NS_Panel2] subscribes on "cmnd/tasmota_A4ED44/#" with regex /^cmnd\.tasmota_A4ED44\..*/
        mqtt.3
        2026-04-08 15:43:27.752	info	Client [NS_Panel2] connected with secret 1775655807747_5750
        mqtt.3
        2026-04-08 15:43:22.638	info	Client [NS_Panel2] connection closed: closed
        javascript.0
        2026-04-08 15:43:22.206	warn	script.js.common.WZ_test: Please wait a few seconds longer when launching the NSPanel. Not all parameters are loaded yet.
        javascript.0
        2026-04-08 15:43:22.205	warn	script.js.common.WZ_test: Please wait a few seconds longer when launching the NSPanel. Not all parameters are loaded yet.
        javascript.0
        2026-04-08 15:43:21.909	warn	script.js.common.WZ_test: Please wait a few seconds longer when launching the NSPanel. Not all parameters are loaded yet.
        javascript.0
        javascript.0
        2026-04-08 15:43:21.404	warn	script.js.common.WZ_test: Please wait a few seconds longer when launching the NSPanel. Not all parameters are loaded yet.
        javascript.0
        javascript.0
        2026-04-08 15:43:20.200	warn	script.js.common.WZ_test: Please wait a few seconds longer when launching the NSPanel. Not all parameters are loaded yet.
        javascript.0
        2026-04-08 15:43:20.199	warn	script.js.common.WZ_test: Please wait a few seconds longer when launching the NSPanel. Not all parameters are loaded yet.
        javascript.0
        2026-04-08 15:43:18.575	warn	script.js.common.WZ_test: Please wait a few seconds longer when launching the NSPanel. Not all parameters are loaded yet.
        javascript.0
        javascript.0
        2026-04-08 15:43:10.774	warn	script.js.common.WZ_test: Please wait a few seconds longer when launching the NSPanel. Not all parameters are loaded yet.
        javascript.0
          @TT-Tom
          MichaelFM
          MichaelFM
          MichaelF
          #8055
          Sorry Falscher Screen, das ist der Richtige vom Test:
          • T TT-Tom
            @road_runner31
            Es geht nicht mit Sonoff, da dieser den Topic anders verarbeitet und auch andersrum sortiert.
            Die Fehlermeldung können vom Screensaver. Bitte immer Logauszüge mit senden. Vom Scriptstart und vom Fehler.
            R
            R
            road_runner31
            #8056
            @TT-Tom Danke! Ich hab alles (Panel und Script) neu gestartet, aktuell sehe ich die Fehler vom Wetteradapter nicht (merkwürdig..).
            Im Log erscheint nur zyklisch folgendes:
            8.4.2026, 15:47:17.623	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: Stopping script
            8.4.2026, 15:47:24.574	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: Compiling TypeScript source
            8.4.2026, 15:47:25.185	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: source code did not change, using cached compilation result...
            8.4.2026, 15:47:25.269	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
            8.4.2026, 15:47:25.274	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: setObjects enabled - create Alias Channels possible
            8.4.2026, 15:47:25.278	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: weather alias for pirate-weather.0. already exists
            8.4.2026, 15:47:25.287	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            8.4.2026, 15:47:25.338	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: Desired TFT Firmware: 61 / v5.1.1
            8.4.2026, 15:47:25.338	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: Installed TFT Firmware: 53 / v[object Object]
            8.4.2026, 15:47:25.386	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: Debug mode disabled
            8.4.2026, 15:47:25.792	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: hidden Cards disabled
            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: Start MQTT-Port-Check -------------------------------------
            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: -- admin.0                   - 8081
            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: -- bambulab.0                - 8883
            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: -- evcc.0                    - 7070
            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: -- mqtt.0                    - 1889
            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: -- sonoff.0                  - 1888
            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: -- sun2000.0                 - 502
            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: -- web.0                     - 8082
            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1889
            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: End MQTT-Port-Check ---------------------------------------
            8.4.2026, 15:47:52.803	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: Desired TFT Firmware: 61 / v5.1.1
            8.4.2026, 15:47:52.803	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: Installed TFT Firmware: 53 / v[object Object]
            8.4.2026, 15:48:03.185	[warn ]: javascript.0 (22192)     at HandleScreensaverUpdate (script.js.NSPanel.NSPanels:14476:31)
            8.4.2026, 15:48:03.185	[warn ]: javascript.0 (22192)     at HandleScreensaver (script.js.NSPanel.NSPanels:13990:5)
            8.4.2026, 15:48:03.186	[warn ]: javascript.0 (22192)     at HandleMessage (script.js.NSPanel.NSPanels:5806:21)
            8.4.2026, 15:48:03.186	[warn ]: javascript.0 (22192)     at script.js.NSPanel.NSPanels:5493:21
            8.4.2026, 15:48:03.186	[warn ]: javascript.0 (22192)     at step (script.js.NSPanel.NSPanels:33:23)
            8.4.2026, 15:48:03.186	[warn ]: javascript.0 (22192)     at Object.next (script.js.NSPanel.NSPanels:14:53)
            8.4.2026, 15:48:03.186	[warn ]: javascript.0 (22192)     at script.js.NSPanel.NSPanels:8:71
            8.4.2026, 15:48:03.186	[warn ]: javascript.0 (22192)     at HandleScreensaverUpdate (script.js.NSPanel.NSPanels:14476:31)
            8.4.2026, 15:48:03.188	[warn ]: javascript.0 (22192)     at HandleScreensaver (script.js.NSPanel.NSPanels:13990:5)
            8.4.2026, 15:48:03.188	[warn ]: javascript.0 (22192)     at HandleMessage (script.js.NSPanel.NSPanels:5806:21)
            8.4.2026, 15:48:03.188	[warn ]: javascript.0 (22192)     at script.js.NSPanel.NSPanels:5493:21
            8.4.2026, 15:48:03.188	[warn ]: javascript.0 (22192)     at step (script.js.NSPanel.NSPanels:33:23)
            8.4.2026, 15:48:03.188	[warn ]: javascript.0 (22192)     at Object.next (script.js.NSPanel.NSPanels:14:53)
            8.4.2026, 15:48:03.188	[warn ]: javascript.0 (22192)     at script.js.NSPanel.NSPanels:8:71
            8.4.2026, 15:48:03.189	[warn ]: javascript.0 (22192)     at HandleScreensaverUpdate (script.js.NSPanel.NSPanels:14476:31)
            8.4.2026, 15:48:03.189	[warn ]: javascript.0 (22192)     at HandleScreensaver (script.js.NSPanel.NSPanels:13990:5)
            8.4.2026, 15:48:03.189	[warn ]: javascript.0 (22192)     at HandleMessage (script.js.NSPanel.NSPanels:5806:21)
            8.4.2026, 15:48:03.189	[warn ]: javascript.0 (22192)     at script.js.NSPanel.NSPanels:5493:21
            8.4.2026, 15:48:03.189	[warn ]: javascript.0 (22192)     at step (script.js.NSPanel.NSPanels:33:23)
            8.4.2026, 15:48:03.189	[warn ]: javascript.0 (22192)     at Object.next (script.js.NSPanel.NSPanels:14:53)
            8.4.2026, 15:48:03.189	[warn ]: javascript.0 (22192)     at script.js.NSPanel.NSPanels:8:71
            8.4.2026, 15:48:03.190	[warn ]: javascript.0 (22192)     at HandleScreensaverUpdate (script.js.NSPanel.NSPanels:14476:31)
            8.4.2026, 15:48:03.190	[warn ]: javascript.0 (22192)     at HandleScreensaver (script.js.NSPanel.NSPanels:13990:5)
            8.4.2026, 15:48:03.190	[warn ]: javascript.0 (22192)     at HandleMessage (script.js.NSPanel.NSPanels:5806:21)
            8.4.2026, 15:48:03.190	[warn ]: javascript.0 (22192)     at script.js.NSPanel.NSPanels:5493:21
            8.4.2026, 15:48:03.190	[warn ]: javascript.0 (22192)     at step (script.js.NSPanel.NSPanels:33:23)
            8.4.2026, 15:48:03.190	[warn ]: javascript.0 (22192)     at Object.next (script.js.NSPanel.NSPanels:14:53)
            8.4.2026, 15:48:03.190	[warn ]: javascript.0 (22192)     at script.js.NSPanel.NSPanels:8:71
            • T
              T
              ticaki
              #8057
              Nur um es mal erwähnt zu haben - der Adapter bietet da deutlich mehr Infos im Log - daher kommen da wohl weniger solche Fragen :)
              Spenden
                T
                T
                TT-Tom
                #8058
                @MichaelF sagte:
                sorry Falscher Screen, das ist der Richtige vom Test:
                das war nicht an dich gerichtet.
                Ist das TFT Update sauber durchgelaufen? Dann starte das Script noch einmal neu. Stell das Panel auf Debug und klick dann auf den Button. dann kopieren das Log vom Klick.
                Gruß Tom
                Public Transport
                • R road_runner31
                  T
                  T
                  TT-Tom
                  #8059
                  @road_runner31
                  zeigemal deine Screensaver Config aus dem Script und starte Tasmota nochmal neu.
                  Welche Version vom Script, Berry-Treiber und TFT läuft aktuell bei dir?
                  @road_runner31 sagte:
                  was meinst du mit zyklisch, startet das Script selber immer neu oder das Panel?
                  Gruß Tom
                  Public Transport
                    Ist hier vielleicht irgendetwas Falsch?
                    Das ist der Alias der Heizung.
                    T
                    T
                    TT-Tom
                    #8060
                    @MichaelF sagte:
                    setze mal bitte bei ON_ACTUAL auch den State ein. ist ein Versuch.
                    Gruß Tom
                    Public Transport
                    • T TT-Tom
                      @MichaelF sagte:
                      MichaelFM
                      MichaelFM
                      MichaelF
                      schrieb am zuletzt editiert von MichaelF
                      #8061
                      @TT-Tom sagte:
                      @MichaelF sagte:
                      Ändert sich leider nichts:
                      javascript.0
                      2026-04-09 12:11:34.406	warn	script.js.common.NsPanelWz: More than 100 subscriptions registered. Check your script!
                      javascript.0
                      2026-04-09 12:11:34.405	warn	script.js.common.NsPanelWz: More than 100 subscriptions registered. Check your script!
                      javascript.0
                      javascript.0
                      2026-04-09 12:11:34.209	info	State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
                      javascript.0
                      2026-04-09 12:11:34.208	info	State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
                      javascript.0
                      2026-04-09 12:11:28.997	info	State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
                      javascript.0
                      2026-04-09 12:11:26.055	info	State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
                      Das diese Meldung kommt mit den 100- 200 - 300 fängt auch erst an wenn die Temperatur und die Luftfeuchte anfangen zu blinken, also man meint das Panel würde ganz viele anfragen senden oder bekommen.
                      Ist mir bis jetzt noch nicht aufgefallen.
                      javascript.0
                      2026-04-09 12:14:55.955	info	script.js.common.NsPanelWz: Stopping script
                      javascript.0
                      2026-04-09 12:14:55.955	error	script.js.common.NsPanelWz: Script is calling setState more than 1000 times per minute! Stopping Script now! Please check your script!
                      sourceanalytix.0
                      2026-04-09 12:14:51.678	info	Device reset detected for 0_userdata.0.PV_Ersparnis, feature disabled processing normally)
                      host.IoBroker64Bit
                      2026-04-09 12:14:47.893	info	instance system.adapter.luftdaten.0 having pid 515161 terminated with code 0 (NO_ERROR)
                      luftdaten.0
                      2026-04-09 12:14:47.357	info	Terminated (NO_ERROR): Without reason
                      luftdaten.0
                      2026-04-09 12:14:47.007	info	starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
                      host.IoBroker64Bit
                      2026-04-09 12:14:44.040	info	instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 515161
                      javascript.0
                      2026-04-09 12:13:59.229	warn	script.js.common.NsPanelWz: More than 4100 subscriptions registered. Check your script!
                      javascript.0
                      2026-04-09 12:13:59.228	warn	script.js.common.NsPanelWz: More than 4100 subscriptions registered. Check your script!
                      javascript.0
                      javascript.0
                      2026-04-09 12:13:59.219	warn	script.js.common.NsPanelWz: More than 4000 subscriptions registered. Check your script!
                      javascript.0
                      javascript.0
                      • MichaelFM
                        MichaelFM
                        MichaelF
                        #8062
                        Hier sieht man es:
                        20260409_121617.mp4
                        • T
                          T
                          ticaki
                          #8063
                          Da werden rekursiv states subscripted - Das im Skript zu finden wird super lustig. Außer @tt-tom kennt das Problem
                          könnte ich dich nicht für den Adapter erwärmen - ab der nächsten Adapterversion kann man da auch über den admin grids und entities (einfach) anlegen und vereinfacht die Wartung und den Support.
                          einfach: die pageitems bieten erstmal nur die Basis einstellmöglichkeiten - id, navigation, icon, farbe
                          https://forum.iobroker.net/topic/80055/betatest-adapter-nspanel-lovelace-ui-v0.13.x
                          Spenden
                          • T ticaki
                            MichaelFM
                            MichaelFM
                            MichaelF
                            #8064
                            @ticaki sagte:
                            Ich hab mir den Adapter schon näher angeschaut, ich denke das ich dann wechseln werde. Die Seiten die ich benutze gibt es, es sind auch einige Seiten bei den Panels gleich. Wann kommt die nächste Version? Und muss dann wieder was an den Seiten geändert werden? Grüsse
                            • T
                              T
                              ticaki
                              #8065
                              Die nächste Version kommt wohl gleich ins latest wird dann im laufe des Tages verfügbar.
                              Es kommt sehr sehr sehr selten vor das man was an einem vorhandenen Skript ändern muß - nur ab und an muß das Skript updaten, wenn da die Version erhöht wurde (geht per klick) und dann angucken und neu an den adapter schicken - damit nix meckert (aber der Adapter meckert in 99,9% der Fälle nur das die Version falsch ist, ohne Konsequenzen.
                              Ah noch was - Expert immer an
                              Wenn du zu diesen Personen gehörst bitte etwas vorsichtig sein und den mal ausschalten - alles was im Admin bei Expert zusätzlich gezeigt wird ist entweder tatsächlich für experten oder experimentell oder entwicklerkram :)
                              Spenden
                              • T ticaki
                                MichaelFM
                                MichaelFM
                                MichaelF
                                #8066
                                @ticaki sagte:
                                Ahh ok, denke wenn es einmal eingerichtet ist wird es mit dem Adapter wirklich einfacher. Die Seiten Erstellung wird wieder spannend werden, aber wenn ich alles richtig verstanden habe bleiben die Aliase ja gleich. Das hieße dann ich müsste wirklich nur die Seiten neu erstellen. Und von Vorteil eine mqtt Instanz wäre auch weg, was dann der Adapter übernehmen würde. Die seiten selbst werden ja auch im Adapter erstellt, also ich brauche kein Script mehr in der Java Instanz?
                                  @ticaki sagte:
                                  T
                                  T
                                  ticaki
                                  #8067
                                  @MichaelF sagte:
                                  hab hier geantwortet: https://forum.iobroker.net/post/1333651
                                  Spenden
                                  • T TT-Tom
                                    @tobiasp
                                    T
                                    T
                                    tobiasp
                                    schrieb am zuletzt editiert von tobiasp
                                    #8068
                                    @TT-Tom sagte:
                                    Liegen im alias
                                    Grüß dich hier der Screenshot
                                    1462695a-e654-42c0-aca9-bc55b23e51c1-image.jpeg ![Bild Text](Bild Link)
                                    • T tobiasp
                                      @TT-Tom sagte:
                                      Liegen im alias
                                      T
                                      T
                                      TT-Tom
                                      #8069
                                      @tobiasp
                                      okay, welchen Screensaver nutzt du?
                                      Welche Felder genau, werden nichtaktualisiert?
                                      gibt es Fehlermeldungen vom Script?
                                      schalte bitte im Panel den Debugmodus ein und sehe im Log nach folgendem Eintrag, der beginnt mit
                                      HandleScreensaverUpdate payload: weatherUpdate~
                                      sollte immer zur vollen Minute erscheinen.
                                      Gruß Tom
                                      Public Transport
                                      • T
                                        T
                                        tobiasp
                                        #8070
                                        Falscher Post
                                        • T TT-Tom
                                          @tobiasp
                                          T
                                          T
                                          tobiasp
                                          #8071
                                          @TT-Tom
                                          Jetzt konnte ich eine aktualisierung am Display life sehen.
                                          Meistens in der früh sieht man, das die Wetterdaten nicht passen (alle Wettersymbole inkl. Werte von der Wetterstation). Drückt man dann auf das Display, aktualisieren sich die Werte.
                                          Nein ich habe keine Fehlermeldungen im Script
                                          12:41:43.664 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 97, Pld -99, Data 'color~0~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535'
                                          12:41:43.712 NXP: payload sent = bytes('55BB6100636F6C6F727E307E36353533357E36353533357E36353533357E3635...')
                                          12:41:43.724 MQT: stat/NS_Panel/RESULT = {"CustomSend":"Done"}
                                          12:41:43.750 SRC: MQTT
                                          12:41:43.751 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 161, Pld -99, Data 'weatherUpdate~~~~19017~~7.1 °C~~~~65168~Temperatur~9.1°C~~~~26095~Wind~1.4km/h~~~~26095~UV~0~~~~64333~Wolken~wechselhaft~~~~64333~Feuchte~99.0%~'
                                          12:41:43.820 BRY: GC from 109293 to 55205 bytes, objects freed 842/660 (in 29 ms) - slots from 2028/2039 to 424/730
                                          12:41:43.862 NXP: payload sent = bytes('55BBA100776561746865725570646174657E7E7EEE968F7E31393031377E7E37...')
                                          12:41:43.872 MQT: stat/NS_Panel/RESULT = {"CustomSend":"Done"}
                                          12:41:43.908 SRC: MQTT
                                          12:41:43.909 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 35, Pld -99, Data 'statusUpdate~~17299~~17299~~~'
                                          12:41:43.932 NXP: payload sent = bytes('55BB23007374617475735570646174657EEE8CB47E31373239397EEE8CB47E31...')
                                          12:41:43.940 MQT: stat/NS_Panel/RESULT = {"CustomSend":"Done"}
                                          12:41:43.971 SRC: MQTT
                                          12:41:43.973 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 97, Pld -99, Data 'color~0~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535'
                                          12:41:44.021 NXP: payload sent = bytes('55BB6100636F6C6F727E307E36353533357E36353533357E36353533357E3635...')
                                          12:41:44.033 MQT: stat/NS_Panel/RESULT = {"CustomSend":"Done"}
                                          12:41:44.061 SRC: MQTT
                                          12:41:44.063 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 161, Pld -99, Data 'weatherUpdate~~~~19017~~7.1 °C~~~~65168~Temperatur~9.1°C~~~~26095~Wind~1.8km/h~~~~26095~UV~0~~~~64333~Wolken~wechselhaft~~~~64333~Feuchte~99.0%~'
                                          12:41:44.136 NXP: payload sent = bytes('55BBA100776561746865725570646174657E7E7EEE968F7E31393031377E7E37...')
                                          12:41:44.146 MQT: stat/NS_Panel/RESULT = {"CustomSend":"Done"}
                                          12:41:44.179 SRC: MQTT
                                          12:41:44.181 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 35, Pld -99, Data 'statusUpdate~~17299~~17299~~~'
                                          12:41:44.225 BRY: GC from 110432 to 54949 bytes, objects freed 873/660 (in 30 ms) - slots from 2088/2116 to 424/730
                                          12:41:44.237 NXP: payload sent = bytes('55BB23007374617475735570646174657EEE8CB47E31373239397EEE8CB47E31...')
                                          12:41:44.250 MQT: stat/NS_Panel/RESULT = {"CustomSend":"Done"}
                                          12:41:44.276 SRC: MQTT
                                          12:41:44.278 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 97, Pld -99, Data 'color~0~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535'
                                          12:41:44.325 NXP: payload sent = bytes('55BB6100636F6C6F727E307E36353533357E36353533357E36353533357E3635...')
                                          12:41:44.337 MQT: stat/NS_Panel/RESULT = {"CustomSend":"Done"}
                                          12:41:44.370 SRC: MQTT
                                          12:41:44.372 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 161, Pld -99, Data 'weatherUpdate~~~~19017~~7.1 °C~~~~65168~Temperatur~9.1°C~~~~26095~Wind~1.8km/h~~~~26095~UV~0~~~~64333~Wolken~wechselhaft~~~~64333~Feuchte~99.0%~'
                                          12:41:44.444 NXP: payload sent = bytes('55BBA100776561746865725570646174657E7E7EEE968F7E31393031377E7E37...')
                                          12:41:44.457 MQT: stat/NS_Panel/RESULT = {"CustomSend":"Done"}
                                          12:41:44.480 SRC: MQTT
                                          12:41:44.482 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 35, Pld -99, Data 'statusUpdate~~17299~~17299~~~'
                                          12:41:44.505 NXP: payload sent = bytes('55BB23007374617475735570646174657EEE8CB47E31373239397EEE8CB47E31...')
                                          12:41:44.516 MQT: stat/NS_Panel/RESULT = {"CustomSend":"Done"}
                                          12:41:44.536 SRC: MQTT
                                          12:41:44.538 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 97, Pld -99, Data 'color~0~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535'
                                          12:41:44.604 BRY: GC from 109933 to 55049 bytes, objects freed 865/659 (in 30 ms) - slots from 2071/2085 to 423/730
                                          12:41:44.621 NXP: payload sent = bytes('55BB6100636F6C6F727E307E36353533357E36353533357E36353533357E3635...')
                                          12:41:44.632 MQT: stat/NS_Panel/RESULT = {"CustomSend":"Done"}
                                          12:41:45.068 WIF: Checking connection...
                                          12:41:52.289 SRC: MQTT
                                          12:41:52.291 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 156, Pld -99, Data 'weatherUpdate~~~~19017~~7.1 °C~~~~25407~Fr~6° 11°~~~~38066~Sa~5° 18°~~~~19017~So~7° 14°~~~~19017~Mo~7° 13°~~~~64333~Feuchte~99.0%'
                                          12:41:52.367 NXP: payload sent = bytes('55BB9C00776561746865725570646174657E7E7EEE968F7E31393031377E7E37...')
                                          12:41:52.377 MQT: stat/NS_Panel/RESULT = {"CustomSend":"Done"}
                                          12:41:52.407 SRC: MQTT
                                          12:41:52.409 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 35, Pld -99, Data 'statusUpdate~~17299~~17299~~~'
                                          12:41:52.434 NXP: payload sent = bytes('55BB23007374617475735570646174657EEE8CB47E31373239397EEE8CB47E31...')
                                          12:41:52.445 MQT: stat/NS_Panel/RESULT = {"CustomSend":"Done"}
                                          12:41:52.470 SRC: MQTT
                                          12:41:52.471 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 97, Pld -99, Data 'color~0~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535~65535'
                                          12:41:52.518 NXP: payload sent = bytes('55BB6100636F6C6F727E307E36353533357E36353533357E36353533357E3635...')
                                          12:41:52.530 MQT: stat/NS_Panel/RESULT = {"CustomSend":"Done"}
                                          84.0k
