    apollon77A
lovelace uinspanelsonoff
8.1k Beiträge 281 Kommentatoren 10.1m Aufrufe 260 Beobachtet
  • MichaelFM MichaelF
    @ticaki sagte:
    Hm ich glaube nicht das du das skript auf debug stehen hast - aber kann den FEhler nicht nachvollziehen, das skript verwendet für alle pageItems die gleiche logic und wenn grid geht, geht auch thermo2
    Log-Größe: 172.0 KB
    Zeit
    info
    Nachricht
    javascript.0
    2026-04-08 15:01:21.662	info	State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
    javascript.0
    2026-04-08 15:01:19.447	info	State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
    admin.0
    2026-04-08 15:01:04.744	info	<== Disconnect system.user.admin from ::ffff:192.168.178.52 javascript
    admin.0
    javascript.0
    2026-04-08 15:01:00.312	info	script.js.common.WZ_test: End MQTT-Port-Check ---------------------------------------
    javascript.0
    2026-04-08 15:01:00.311	info	script.js.common.WZ_test: - MQTT-Port-Check OK: Instance of Adapter: mqtt.3 is running on Port:1886
    javascript.0
    2026-04-08 15:01:00.311	info	script.js.common.WZ_test: -- web.0 - 8082
    javascript.0
    2026-04-08 15:01:00.311	info	script.js.common.WZ_test: -- telegram.0 - 8443
    javascript.0
    2026-04-08 15:01:00.311	info	script.js.common.WZ_test: -- synology.1 - 5000
    javascript.0
    2026-04-08 15:01:00.311	info	script.js.common.WZ_test: -- synology.0 - 5000
    javascript.0
    2026-04-08 15:01:00.311	info	script.js.common.WZ_test: -- sql.0 - Kein Port gefunden
    javascript.0
    2026-04-08 15:01:00.311	info	script.js.common.WZ_test: -- sonoff.0 - 1883
    javascript.0
    2026-04-08 15:01:00.311	info	script.js.common.WZ_test: -- simple-api.0 - 8087
    javascript.0
    2026-04-08 15:01:00.311	info	script.js.common.WZ_test: -- sainlogic.0 - 4500
    javascript.0
    2026-04-08 15:01:00.311	info	script.js.common.WZ_test: -- pioneer_sc_vsx.0 - 23
    javascript.0
    2026-04-08 15:01:00.311	info	script.js.common.WZ_test: -- pi-hole2.0 - 80
    javascript.0
    2026-04-08 15:01:00.311	info	script.js.common.WZ_test: -- mqtt.3 - 1886
    javascript.0
    2026-04-08 15:01:00.311	info	script.js.common.WZ_test: -- mqtt.1 - 1883
    javascript.0
    2026-04-08 15:01:00.310	info	script.js.common.WZ_test: -- mihome-vacuum.0 - 5432
    javascript.0
    2026-04-08 15:01:00.310	info	script.js.common.WZ_test: -- influxdb.2 - 8428
    javascript.0
    2026-04-08 15:01:00.310	info	script.js.common.WZ_test: -- influxdb.1 - 8086
    javascript.0
    2026-04-08 15:01:00.310	info	script.js.common.WZ_test: -- influxdb.0 - 8086
    javascript.0
    2026-04-08 15:01:00.310	info	script.js.common.WZ_test: -- hm-rpc.3 - 0
    javascript.0
    2026-04-08 15:01:00.310	info	script.js.common.WZ_test: -- hm-rpc.2 - 0
    javascript.0
    2026-04-08 15:01:00.310	info	script.js.common.WZ_test: -- hm-rpc.1 - 0
    javascript.0
    2026-04-08 15:01:00.310	info	script.js.common.WZ_test: -- hm-rpc.0 - 0
    javascript.0
    2026-04-08 15:01:00.310	info	script.js.common.WZ_test: -- admin.0 - 8081
    javascript.0
    2026-04-08 15:01:00.310	info	script.js.common.WZ_test: Start MQTT-Port-Check -------------------------------------
    javascript.0
    2026-04-08 15:00:59.593	info	script.js.common.WZ_test: hidden Cards disabled
    javascript.0
    2026-04-08 15:00:57.324	info	script.js.common.WZ_test: Debug mode disabled
    javascript.0
    2026-04-08 15:00:57.107	info	script.js.common.WZ_test: Installed TFT Firmware: 61 / v5.1.1
    javascript.0
    2026-04-08 15:00:57.107	info	script.js.common.WZ_test: Desired TFT Firmware: 61 / v5.1.1
    javascript.0
    2026-04-08 15:00:56.677	info	script.js.common.WZ_test: 2.1 W
    javascript.0
    2026-04-08 15:00:56.485	info	script.js.common.WZ_test: {"Status":{"Module":0,"DeviceName":"Tasmota","FriendlyName":["Tasmota",""],"Topic":"tasmota_A4ED44","ButtonTopic":"0","Power":"00","PowerLock":"00","PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin","RestartReason":"Software reset CPU","Uptime":"0T00:39:21","StartupUTC":"2026-04-08T12:21:34","Sleep":50,"CfgHolder":4617,"BootCount":42,"BCResetTime":"2024-04-13T18:49:31","SaveCount":1149},"StatusFWR":{"Version":"15.2.0(release-tasmota32)","BuildDateTime":"2025.12.12 11:08:19","Core":"3.3.4","SDK":"5.3.4.251205","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.1","CR":"469/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":2,"FileLog":0,"SysLog":0,"LogHost":"192.168.178.69","LogPort":514,"SSId":["WLAN 7270",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000001"]},"StatusMEM":{"ProgramSize":2087,"Free":792,"Heap":124,"StackLowMark":3,"PsrMax":2048,"PsrFree":2021,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"1640C8","FlashFrequency":80,"FlashMode":"DIO","Features":["0407","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80F1","00000814"],"Drivers":"1,2,!3,!4,!5,7,!8,9,10,11,12,!14,!16,!17,!20,!21,24,26,!27,29,!34,!35,38,50,52,!59,!60,62,!63,!66,!67,!68,!73,!75,82,!86,!87,!88,!91,!121","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82,89"},"StatusNET":{"Hostname":"tasmota-A4ED44-3396","IPAddress":"192.168.178.58","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.36","DNSServer2":"fd63:a0ea:8156:0:9a9b:cbff:feae:d11b","Mac":"08:D1:F9:A4:ED:44","IP6Global":"2003:df:3714:d400:ad1:f9ff:fea4:ed44","IP6Local":"fe80::ad1:f9ff:fea4:ed44%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.36","DNSServer2":"fd63:a0ea:8156:0:9a9b:cbff:feae:d11b","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16},"StatusMQT":{"MqttHost":"192.168.178.69","MqttPort":1886,"MqttClientMask":"NS_Panel2","MqttClient":"NS_Panel2","MqttUser":"Mikeldk","MqttCount":1,"MqttTLS":0,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2026-04-08T13:00:55Z","Local":"2026-04-08T15:00:55","StartDST":"2026-03-29T02:00:00","EndDST":"2026-10-25T03:00:00","Timezone":99,"Sunrise":"07:13","Sunset":"20:30"},"StatusSNS":{"Time":"2026-04-08T15:00:55","ANALOG":{"Temperature1":18.1},"ESP32":{"Temperature":36.7},"TempUnit":"C"},"StatusSTS":{"Time":"2026-04-08T15:00:55","Uptime":"0T00:39:21","UptimeSec":2361,"Heap":122,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":22,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":220},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"WLAN 7270","BSSId":"F0:B0:14:F6:67:A2","Channel":11,"Mode":"HT40","RSSI":58,"Signal":-71,"LinkCount":1,"Downtime":"0T00:00:03"},"Hostname":"tasmota-A4ED44-3396","IPAddress":"192.168.178.58"}}
    javascript.0
    2026-04-08 15:00:56.360	info	script.js.common.WZ_test: {"DeviceName":"Tasmota"}
    MichaelFM
    MichaelFM
    MichaelF
    #8044
    Ist hier vielleicht irgendetwas Falsch?
    Das ist der Alias der Heizung.
    T 2 Antworten Letzte Antwort
      T
      T
      TT-Tom
      #8045
      @MichaelF
      ja das wäre noch mal eine Option, im Servicemenü unter Einstellungen -> Script kannst du den DebugModus aktivieren. mach das mal und poste dann die log Ausgabe noch mal. Vielleicht sehen wir da dann mehr.
      Gruß Tom
      Public Transport
      NSPanel Adapter Wiki
      MichaelFM 1 Antwort Letzte Antwort
      • T TT-Tom
        @MichaelF
        MichaelFM
        MichaelFM
        MichaelF
        #8046
        @TT-Tom sagte:
        @MichaelF
        Grade gesehen, Sorry... hier müsste alles sein:
        javascript.0	15:28:10.585	info
        Stopping script
        javascript.0	15:28:11.796	info
        Compiling TypeScript source
        javascript.0	15:28:12.259	info
        source code did not change, using cached compilation result...
        javascript.0	15:28:12.265	info
        findLocaleServMenu: service_pages - de-DE -> Service Seiten
        javascript.0	15:28:12.266	info
        findLocaleServMenu: service_menu - de-DE -> Service Menü
        findLocaleServMenu: infos - de-DE -> Infos
        javascript.0	15:28:12.267	info
        findLocaleServMenu: more - de-DE -> mehr...
        findLocaleServMenu: settings - de-DE -> Einstellungen
        javascript.0	15:28:12.268	info
        findLocaleServMenu: firmware - de-DE -> Firmware
        javascript.0	15:28:12.269	info
        findLocaleServMenu: reboot - de-DE -> Reboot NSPanel
        findLocaleServMenu: start - de-DE -> Start
        javascript.0	15:28:12.270	info
        javascript.0	15:28:12.271	info
        javascript.0	15:28:12.272	info
        javascript.0	15:28:12.273	info
        javascript.0	15:28:12.274	info
        findLocaleServMenu: nspanel_infos - de-DE -> NSPanel Info's
        findLocaleServMenu: wifi - de-DE -> WLAN
        javascript.0	15:28:12.275	info
        findLocaleServMenu: sensors_hardware - de-DE -> Sensoren/Hardware
        javascript.0	15:28:12.276	info
        findLocaleServMenu: info_iobroker - de-DE -> ioBroker-Infos
        javascript.0	15:28:12.277	info
        findLocaleServMenu: update_message - de-DE -> Update Mitteilungen
        findLocaleServMenu: nspanel_wifi1 - de-DE -> NSPanel WLAN (1)
        javascript.0	15:28:12.278	info
        findLocaleServMenu: ip_address - de-DE -> IP-Adresse
        findLocaleServMenu: mac_address - de-DE -> MAC-Adresse
        javascript.0	15:28:12.279	info
        findLocaleServMenu: rssi - de-DE -> RSSI
        findLocaleServMenu: wifi_signal - de-DE -> Wifi-Signal
        javascript.0	15:28:12.280	info
        findLocaleServMenu: nspanel_wifi2 - de-DE -> NSPanel WLAN (2)
        findLocaleServMenu: ssid - de-DE -> SSId
        javascript.0	15:28:12.281	info
        findLocaleServMenu: mode - de-DE -> Modus
        findLocaleServMenu: channel - de-DE -> Kanal
        findLocaleServMenu: accesspoint - de-DE -> AP
        javascript.0	15:28:12.282	info
        findLocaleServMenu: sensors1 - de-DE -> Sensoren (1)
        findLocaleServMenu: room_temperature - de-DE -> Raum-Temperatur
        javascript.0	15:28:12.283	info
        findLocaleServMenu: esp_temperature - de-DE -> ESP-Temperatur
        findLocaleServMenu: temperature_unit - de-DE -> Temperatur Einheit
        javascript.0	15:28:12.284	info
        findLocaleServMenu: refresh - de-DE -> Aktualisierung
        findLocaleServMenu: hardware2 - de-DE -> Hardware (2)
        javascript.0	15:28:12.285	info
        findLocaleServMenu: product - de-DE -> Produkt
        findLocaleServMenu: esp32_hardware - de-DE -> ESP32-Hardware
        findLocaleServMenu: nspanel_version - de-DE -> Display-Version
        javascript.0	15:28:12.286	info
        findLocaleServMenu: operating_time - de-DE -> Betriebszeit
        javascript.0	15:28:12.287	info
        findLocaleServMenu: script_version_nspanelts - de-DE -> NSPanelTs.ts Version
        findLocaleServMenu: nodejs_version - de-DE -> NodeJS Version
        javascript.0	15:28:12.288	info
        findLocaleServMenu: instance_javascript - de-DE -> JS-Adapterinstanz
        findLocaleServMenu: scriptname - de-DE -> Skriptname
        javascript.0	15:28:12.289	info
        findLocaleServMenu: screensaver - de-DE -> Screensaver
        javascript.0	15:28:12.290	info
        findLocaleServMenu: relays - de-DE -> Relais
        javascript.0	15:28:12.291	info
        findLocaleServMenu: temp_unit - de-DE -> Temp. Einheit
        javascript.0	15:28:12.292	info
        findLocaleServMenu: language - de-DE -> Sprache
        findLocaleServMenu: script - de-DE -> Skript
        javascript.0	15:28:12.293	info
        findLocaleServMenu: dimmode - de-DE -> Dimmmodus
        javascript.0	15:28:12.294	info
        findLocaleServMenu: brightness - de-DE -> Helligkeit
        findLocaleServMenu: layout - de-DE -> Layout
        javascript.0	15:28:12.295	info
        findLocaleServMenu: weather - de-DE -> Wetter
        findLocaleServMenu: date_format - de-DE -> Datumsformat
        findLocaleServMenu: indicators - de-DE -> Indikatoren
        javascript.0	15:28:12.296	info
        findLocaleServMenu: brightness_day - de-DE -> Helligkeit (Tag)
        javascript.0	15:28:12.297	info
        findLocaleServMenu: brightness_night - de-DE -> Helligkeit (Nacht)
        findLocaleServMenu: hour_day - de-DE -> Stunde (Tag)
        javascript.0	15:28:12.298	info
        findLocaleServMenu: hour_night - de-DE -> Stunde (Nacht)
        javascript.0	15:28:12.299	info
        findLocaleServMenu: brightness_activ - de-DE -> Helligkeit Aktiv
        findLocaleServMenu: screensaver_timeout - de-DE -> Screensaver Timeout
        javascript.0	15:28:12.307	info
        findLocaleServMenu: wakeup_doublecklick - de-DE -> Doppelklick Weakup
        javascript.0	15:28:12.308	info
        findLocaleServMenu: alternative_layout - de-DE -> Alternativ Layout
        findLocaleServMenu: advanced_layout - de-DE -> Erweitertes Layout
        javascript.0	15:28:12.309	info
        findLocaleServMenu: easyview_layout - de-DE -> Einfaches Layout
        findLocaleServMenu: weather_parameters - de-DE -> Wetterparameter
        javascript.0	15:28:12.310	info
        findLocaleServMenu: weather_forecast_offon - de-DE -> Vorhersage Aus/An
        findLocaleServMenu: weather_forecast_change_switch - de-DE -> Vorhersage Wechsel
        javascript.0	15:28:12.311	info
        findLocaleServMenu: weather_forecast_change_time - de-DE -> Wechselzeit/s
        findLocaleServMenu: weather_forecast_icon_colors - de-DE -> Symbolfarben
        javascript.0	15:28:12.312	info
        findLocaleServMenu: weekday_large - de-DE -> Wochentag (lang)
        javascript.0	15:28:12.313	info
        findLocaleServMenu: month_large - de-DE -> Monat (lang)
        javascript.0	15:28:12.314	info
        findLocaleServMenu: mr_icon1_size - de-DE -> Icon 1 (klein/groß)
        findLocaleServMenu: mr_icon2_size - de-DE -> Icon 2 (klein/groß)
        javascript.0	15:28:12.315	info
        findLocaleServMenu: relay1_onoff - de-DE -> Relais 1 (aus/an)
        findLocaleServMenu: relay2_onoff - de-DE -> Relais 2 (aus/an)
        javascript.0	15:28:12.316	info
        findLocaleServMenu: debugmode_offon - de-DE -> Debugmodus (aus/an)
        javascript.0	15:28:12.317	info
        findLocaleServMenu: port_check_offon - de-DE -> Port-Check (aus/an)
        findLocaleServMenu: hiddencards_offon - de-DE -> ausgeblendete Seiten (an/aus)
        javascript.0	15:28:12.318	info
        findLocaleServMenu: automatically_updates - de-DE -> Auto-Updates
        findLocaleServMenu: tasmota_firmware - de-DE -> Tasmota-Firmware
        javascript.0	15:28:12.319	info
        findLocaleServMenu: berry_driver - de-DE -> Berry-Driver
        javascript.0	15:28:12.320	info
        findLocaleServMenu: nextion_tft_firmware - de-DE -> Nextion-TFT Firmware
        javascript.0	15:28:12.321	info
        findLocaleServMenu: tasmota - de-DE -> Tasmota
        javascript.0	15:28:12.322	info
        findLocaleServMenu: installed_release - de-DE -> Installierte Version
        findLocaleServMenu: available_release - de-DE -> Verfügbare Version
        findLocaleServMenu: update_tasmota - de-DE -> Tasmota Update
        javascript.0	15:28:12.323	info
        javascript.0	15:28:12.324	info
        javascript.0	15:28:12.325	info
        findLocaleServMenu: update_berry_driver - de-DE -> Berry-Driver Update
        javascript.0	15:28:12.326	info
        findLocaleServMenu: nextion_tft - de-DE -> Nextion-TFT
        javascript.0	15:28:12.327	info
        findLocaleServMenu: desired_release - de-DE -> Benötigte Version
        findLocaleServMenu: nspanel_model - de-DE -> NSPanel Version
        javascript.0	15:28:12.328	info
        javascript.0	15:28:12.333	info
        --- start of NsPanelTs: 0_userdata.0.NSPanel.8. ---
        javascript.0	15:28:12.334	info
        Number of weatherAdapterInstance: 0
        • MichaelFM
          MichaelFM
          MichaelF
          #8047
          javascript.0	15:28:12.353	info
          setObjects enabled - create Alias Channels possible
          javascript.0	15:28:12.355	info
          weather alias for pirate-weather.0. already exists
          function SendToPanel val-payload: dimmode~8~100~6371~65535
          function ScreensaverDimmode Background rgb_dec565: 6371
          javascript.0	15:28:12.356	info
          function ScreensaverDimmode Dimmode=true
          function ScreensaverDimmode -> Day NSPanel.Payload: dimmode~8~100
          Requesting locales
          javascript.0	15:28:12.359	info
          Requesting locales Service Menu
          javascript.0	15:28:12.362	info
          get_current_tasmota_ip_address: 192.168.178.58
          javascript.0	15:28:12.363	info
          registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0	15:28:12.372	info
          javascript.0	15:28:12.373	info
          function SendToPanel val-payload: time~15:28
          function SendToPanel val-payload: date~Mittwoch, 8. April 2026
          Requesting tasmota status0
          javascript.0	15:28:12.374	info
          Check-Updates
          Tasmota-Firmware => Automatische Updates aus, manuelles Update nötig
          Already the latest Berry driver on NSPanel
          Already the latest display firmware on NSPanel
          javascript.0	15:28:12.388	info
          renderCurrentPage
          javascript.0	15:28:12.389	info
          renderCurrentPage
          javascript.0	15:28:12.390	info
          renderCurrentPage```
          • MichaelFM
            MichaelFM
            MichaelF
            #8048
            {"lights":{"Brightness":{"en-US":"Brightness","de-DE":"Helligkeit","nl-NL":"Helderheid","da-DK":"Lysstyrke","es-ES":"Brillo","fr-FR":"Luminosité","it-IT":"Luminosità","ru-RU":"Яркость","nb-NO":"Lysstyrke","nn-NO":"Lysstyrke","pl-PL":"Jasność","pt-PT":"Brilho","af-ZA":"Helderheid","ar-SY":"السطوع","bg-BG":"Яркост","ca-ES":"Brillantor","cs-CZ":"Jas","el-GR":"Φωτεινότητα","et-EE":"Heledus","fa-IR":"روشنایی","fi-FI":"Kirkkaus","he-IL":"בהירות","hr-xx":"Svjetlina","hu-HU":"Fényerő","hy-AM":"Պայծառություն","id-ID":"Kecerahan","is-IS":"Birtustig","lb-xx":"Hellegkeet","lt-LT":"Ryškumas","ro-RO":"Luminozitate","sk-SK":"Jas","sl-SI":"Svetlost","sv-SE":"Ljusstyrka","th-TH":"ความสว่าง","tr-TR":"Parlaklık","uk-UA":"Яскравість","vi-VN":"Độ sáng","zh-CN":"亮度","zh-TW":"亮度"},"Temperature":{"en-US":"Color temperature","de-DE":"Farbtemperatur","nl-NL":"Kleurtemperatuur","da-DK":"Farvetemperatur","es-ES":"Temperatura del color","fr-FR":"Température de couleur","it-IT":"Temperatura colore","ru-RU":"Цветовая температура","nb-NO":"Fargetemperatur","nn-NO":"Fargetemperatur","pl-PL":"Temperatura barwy","pt-PT":"Temperatura de cor","af-ZA":"Kleur temperatuur","ar-SY":"درجة حرارة اللون","bg-BG":"Цветова температура","ca-ES":"Temperatura de color","cs-CZ":"Teplota barvy","el-GR":"Θερμοκρασία χρώματος","et-EE":"Värvustemperatuur","fa-IR":"دمای رنگ","fi-FI":"Värilämpötila","he-IL":"טמפרטורת הצבע","hr-xx":"Temperatura boje","hu-HU":"Színhőmérséklet","hy-AM":"Գունային ջերմաստիճան","id-ID":"Temperatur warna","is-IS":"Litastig","lb-xx":"Faarf Temperatur","lt-LT":"Spalvos temperatūra","ro-RO":"Temperatură de culoare","sk-SK":"Teplota farby","sl-SI":"Temperatura barve","sv-SE":"Färgtemperatur","th-TH":"อุณหภูมิสี","tr-TR":"Renk sıcaklığı","uk-UA":"Кольорова температура","vi-VN":"Nhiệt độ màu","zh-CN":"色温","zh-TW":"色溫"}},"window":{"closed":{"en-US":"Closed","de-DE":"Geschlossen","nl-NL":"Dicht","da-DK":"Lukket","es-ES":"Cerrada","fr-FR":"Fermée","it-IT":"Chiusa","ru-RU":"Закрыто","nb-NO":"Lukket","nn-NO":"Lukka","pl-PL":"zamknięte","pt-PT":"Fechada","af-ZA":"Toe","ar-SY":"مغلق","bg-BG":"Затворен","ca-ES":"Tancada","cs-CZ":"Zavřeno","el-GR":"Κλειστό","et-EE":"Suletud","fa-IR":"بسته","fi-FI":"Suljettu","he-IL":"סגור","hr-xx":"Zatvoreno","hu-HU":"Zárva","hy-AM":"Փակված է","id-ID":"Tertutup","is-IS":"Loka","lb-xx":"Zou","lt-LT":"Uždaryta","ro-RO":"Închis","sk-SK":"Zatvorené","sl-SI":"Zaprto","sv-SE":"Stängt","th-TH":"ปิดแล้ว","tr-TR":"Kapalı","uk-UA":"Зачинене","vi-VN":"Đóng","zh-CN":"关闭","zh-TW":"關閉"},"opened":{"en-US":"Open","de-DE":"Offen","nl-NL":"Open","da-DK":"Åben","es-ES":"Abierta","fr-FR":"Ouverte","it-IT":"Aperta","ru-RU":"Открыто","nb-NO":"Åpent","nn-NO":"Open","pl-PL":"otwarte","pt-PT":"Aberta","af-ZA":"Oop","ar-SY":"مفتوح","bg-BG":"Отворен","ca-ES":"Oberta","cs-CZ":"Otevřeno","el-GR":"Ανοιχτό","et-EE":"Avatud","fa-IR":"باز","fi-FI":"Auki","he-IL":"פתוח","hr-xx":"Otvoreno","hu-HU":"Nyitva","hy-AM":"Բացել","id-ID":"Terbuka","is-IS":"Opna","lb-xx":"Op","lt-LT":"Atidaryta","ro-RO":"Deschis","sk-SK":"Otvorené","sl-SI":"Odprto","sv-SE":"Öppet","th-TH":"เปิด","tr-TR":"Açık","uk-UA":"Відчинене","vi-VN":"Mở","zh-CN":"开启","zh-TW":"開啟"}},"door":{"closed":{"en-US":"Closed","de-DE":"Geschlossen","nl-NL":"Dicht","da-DK":"Lukket","es-ES":"Cerrada","fr-FR":"Fermée","it-IT":"Chiusa","ru-RU":"Закрыта","nb-NO":"Lukket","nn-NO":"Lukka","pl-PL":"zamknięte","pt-PT":"Fechada","af-ZA":"Toe","ar-SY":"مغلق","bg-BG":"Затворена","ca-ES":"Tancada","cs-CZ":"Zavřeno","el-GR":"Κλειστή","et-EE":"Suletud","fa-IR":"بسته","fi-FI":"Suljettu","he-IL":"סגורה","hr-xx":"Zatvoreno","hu-HU":"Zárva","hy-AM":"Փակված է","id-ID":"Tertutup","is-IS":"Lokuð","lb-xx":"Zou","lt-LT":"Uždaryta","ro-RO":"Închis","sk-SK":"Zatvorené","sl-SI":"Zaprto","sv-SE":"Stängd","th-TH":"ปิดแล้ว","tr-TR":"Kapalı","uk-UA":"Зачинені","vi-VN":"Đóng","zh-CN":"关闭","zh-TW":"已關閉"},"opened":{"en-US":"Open","de-DE":"Offen","nl-NL":"Open","da-DK":"Åben","es-ES":"Abierta","fr-FR":"Ouverte","it-IT":"Aperta","ru-RU":"Открыта","nb-NO":"Åpen","nn-NO":"Open","pl-PL":"otwarte","pt-PT":"Aberta","af-ZA":"Oop","ar-SY":"مفتوح","bg-BG":"Отворена","ca-ES":"Oberta","cs-CZ":"Otevřeno","el-GR":"Ανοιχτή","et-EE":"Avatud","fa-IR":"باز","fi-FI":"Auki","he-IL":"פתוחה","hr-xx":"Otvori","hu-HU":"Nyitva","hy-AM":"Բացել","id-ID":"Terbuka","is-IS":"Opin","lb-xx":"Op","lt-LT":"Atidaryta","ro-RO":"Deschis","sk-SK":"Otvorené","sl-SI":"Odprto","sv-SE":"Öppen","th-TH":"เปิด","tr-TR":"Açık","uk-UA":"Відчинені","vi-VN":"Mở","zh-CN":"开启","zh-TW":"已開啟"}},"lock":{"LOCK":{"en-US":"Lock","de-DE":"Verriegeln","nl-NL":"Vergrendelen","da-DK":"Lås","es-ES":"Bloquear","fr-FR":"Verrouiller","it-IT":"Blocca","ru-RU":"Закрыть","nb-NO":"Lås","nn-NO":"Lås","pl-PL":"Zablokuj","pt-PT":"Bloquear","af-ZA":"Sluit toe","ar-SY":"قفل","bg-BG":"Заключване","ca-ES":"Bloquejar","cs-CZ":"Zamknout","el-GR":"Κλείδωμα","et-EE":"Lukusta","fa-IR":"قفل","fi-FI":"Lukitse","he-IL":"נעילה","hr-xx":"zaključati","hu-HU":"Bezár","hy-AM":"Կողպեք","id-ID":"Kunci","is-IS":"Læsa","lb-xx":"Spären","lt-LT":"Užrakinti","ro-RO":"Blocat","sk-SK":"Zamknúť","sl-SI":"Zakleni","sv-SE":"Lås","th-TH":"ล็อค","tr-TR":"Kilitle","uk-UA":"Блокувати","vi-VN":"Khóa","zh-CN":"锁定","zh-TW":"上鎖"},"UNLOCK":{"en-US":"Unlock","de-DE":"Entriegeln","nl-NL":"Ontgrendelen","da-DK":"Lås op","es-ES":"Desbloquear","fr-FR":"Déverrouiller","it-IT":"Sblocca","ru-RU":"Открыть","nb-NO":"Lås opp","nn-NO":"Lås opp","pl-PL":"Odblokuj","pt-PT":"Desbloquear","af-ZA":"Sluit oop","ar-SY":"فتح","bg-BG":"Отключване","ca-ES":"Desbloquejar","cs-CZ":"Odemknout","el-GR":"Ξεκλείδωμα","et-EE":"Ava","fa-IR":"باز کردن","fi-FI":"Avaa lukitus","he-IL":"ביטול נעילה","hr-xx":"Otključati","hu-HU":"Kinyit","hy-AM":"Բացել","id-ID":"Buka","is-IS":"Aflæsa","lb-xx":"Entspären","lt-LT":"Atrakinti","ro-RO":"Deblocare","sk-SK":"Odomknúť","sl-SI":"Odkleni","sv-SE":"Lås upp","th-TH":"ปลดล็อค","tr-TR":"Kilidi aç","uk-UA":"Розблокувати","vi-VN":"Mở khóa","zh-CN":"解锁","zh-TW":"解鎖"}},"blinds":{"Position":{"en-US":"Position","de-DE":"Position","nl-NL":"Positie","da-DK":"Position","es-ES":"Posición","fr-FR":"Position","it-IT":"Apertura","ru-RU":"Положение","nb-NO":"Posisjon","nn-NO":"Posisjon","pl-PL":"Pozycja","pt-PT":"Posição","af-ZA":"Posisie","ar-SY":"موضع","bg-BG":"Позиция","ca-ES":"Posició","cs-CZ":"Pozice","el-GR":"Θέση","et-EE":"Asend","fa-IR":"موقعیت","fi-FI":"Sijainti","he-IL":"מיקום","hr-xx":"Pozicija","hu-HU":"Pozíció","hy-AM":"Դիրք","id-ID":"Posisi","is-IS":"Staðsetning","lb-xx":"Positioun","lt-LT":"Padėtis","ro-RO":"Poziţie","sk-SK":"Poloha","sl-SI":"Položaj","sv-SE":"Position","th-TH":"ตำแหน่ง","tr-TR":"Pozisyon","uk-UA":"Положення","vi-VN":"Vị trí","zh-CN":"位置","zh-TW":"位置"},"tilt_position":{"en-US":"Tilt position","de-DE":"Kippstellung","nl-NL":"Kantelpositie","da-DK":"Vippeposition","es-ES":"Posición inclinada","fr-FR":"Inclinaison","it-IT":"Inclinazione","ru-RU":"Наклон","nb-NO":"Vend posisjon","nn-NO":"Tiltposisjon","pl-PL":"Pochylenie","pt-PT":"Posição de inclinação","af-ZA":"Kantel posisie","ar-SY":"وضع الإمالة","bg-BG":"Наклон","ca-ES":"Inclinació","cs-CZ":"Náklon","el-GR":"Θέση ανάκλισης","et-EE":"Kalde asend","fa-IR":"موقعیت شیب","fi-FI":"Kallistus","he-IL":"הטיה","hr-xx":"Položaj nagiba","hu-HU":"Döntési pozíció","hy-AM":"Դիրքի թեքությունը","id-ID":"Posisi kemiringan","is-IS":"Hallastaða","lb-xx":"Kippestellung","lt-LT":"Pakreipimo padėtis","ro-RO":"Poziție de înclinare","sk-SK":"Poloha sklonu","sl-SI":"Položaj nagiba","sv-SE":"Tilt position","th-TH":"ตำแหน่งการเอียง","tr-TR":"Tilt pozisyonu","uk-UA":"Положення нахилу","vi-VN":"Nghiêng vị trí","zh-CN":"倾斜位置","zh-TW":"葉片位置"}},"thermostat":{"Currently":{"en-US":"Currently","de-DE":"Aktuell","nl-NL":"Momenteel","da-DK":"Aktuelt","es-ES":"Actualmente","fr-FR":"Actuellement","it-IT":"Attualmente","ru-RU":"Сейчас","nb-NO":"Er nå","nn-NO":"Akkurat no","pl-PL":"Obecnie","pt-PT":"Atualmente","af-ZA":"Tans","ar-SY":"حاليا","bg-BG":"В момента","ca-ES":"Actual","cs-CZ":"Aktuálně","el-GR":"Αυτή τη στιγμή","et-EE":"Hetkel","fa-IR":"در حال حاضر","fi-FI":"Tällä hetkellä","he-IL":"כעת","hr-xx":"Trenutno","hu-HU":"Jelenleg","hy-AM":"Ներկայումս","id-ID":"Saat ini","is-IS":"Er núna","lb-xx":"Momentan","lt-LT":"Šiuo metu","ro-RO":"În prezent","sk-SK":"Aktuálne","sl-SI":"Trenutno","sv-SE":"Nuvarande","th-TH":"ในขณะนี้","tr-TR":"Şu an","uk-UA":"В даний час","vi-VN":"Hiện tại","zh-CN":"当前","zh-TW":"目前狀態"},"State":{"en-US":"State","de-DE":"Zustand","nl-NL":"Toestand","da-DK":"Tilstand","es-ES":"Estado","fr-FR":"État","it-IT":"Stato","ru-RU":"Состояние","nb-NO":"Tilstand","nn-NO":"Tilstand","pl-PL":"Stan","pt-PT":"Estado","af-ZA":"","ar-SY":"","bg-BG":"","ca-ES":"Estat","cs-CZ":"Stav","el-GR":"Κατάσταση","et-EE":"Olek","fa-IR":"","fi-FI":"Tila","he-IL":"מצב","hr-xx":"","hu-HU":"Állapot","hy-AM":"","id-ID":"Status","is-IS":"Staða","lb-xx":"","lt-LT":"","ro-RO":"","sk-SK":"Stav","sl-SI":"Stanje","sv-SE":"Tillstånd","th-TH":"สถานะ","tr-TR":"Durum","uk-UA":"Стан","vi-VN":"","zh-CN":"状态","zh-TW":"狀態"},"Action":{"en-US":"Operation","de-DE":"Aktion","nl-NL":"Werking","da-DK":"Drifttype","es-ES":"Modo","fr-FR":"Opération","it-IT":"Operazione","ru-RU":"Режим работы","nb-NO":"Operasjon","nn-NO":"Operasjon","pl-PL":"Tryb pracy","pt-PT":"Operação","af-ZA":"Operasie","ar-SY":"الوضع","bg-BG":"Режим","ca-ES":"Funcionament","cs-CZ":"Provoz","el-GR":"Λειτουργία","et-EE":"Töörežiim","fa-IR":"عملیات","fi-FI":"Toiminto","he-IL":"פעולה","hr-xx":"operacija","hu-HU":"Működés","hy-AM":"Գործողություն","id-ID":"Operasi","is-IS":"Aðgerð","lb-xx":"Aktioun","lt-LT":"Operacija","ro-RO":"Operație","sk-SK":"Prevádzka","sl-SI":"Delovanje","sv-SE":"Driftläge","th-TH":"การทำงาน","tr-TR":"İşlem","uk-UA":"Режим","vi-VN":"Chế độ hoạt động","zh-CN":"运行模式","zh-TW":"運轉模式"}},"button":{"press":{"en-US":"Press","de-DE":"Drücken","nl-NL":"Klik","da-DK":"Tryk","es-ES":"Pulsa","fr-FR":"Appui","it-IT":"Premi","ru-RU":"Нажать","nb-NO":"trykk","nn-NO":"","pl-PL":"Naciśnij","pt-PT":"Pressione","af-ZA":"","ar-SY":"","bg-BG":"","ca-ES":"Prem","cs-CZ":"Stisknutí","el-GR":"Πατήστε","et-EE":"Vajuta nuppu","fa-IR":"","fi-FI":"Paina","he-IL":"לחיצה","hr-xx":"","hu-HU":"Gombnyomás","hy-AM":"","id-ID":"Tekan","is-IS":"Ýttu á","lb-xx":"","lt-LT":"","ro-RO":"","sk-SK":"","sl-SI":"Pritisnite","sv-SE":"Tryck","th-TH":"กด","tr-TR":"Basınız","uk-UA":"Натисніть","vi-VN":"","zh-CN":"按下","zh-TW":"按下"}},"script":{"run":{"en-US":"Run","de-DE":"Ausführen","nl-NL":"Uitvoeren","da-DK":"Kør","es-ES":"Ejecutar","fr-FR":"Exécuter","it-IT":"Esegui","ru-RU":"Запустить","nb-NO":"Kjør","nn-NO":"Køyr","pl-PL":"Uruchom","pt-PT":"Executar","af-ZA":"","ar-SY":"تشغيل","bg-BG":"Изпълни","ca-ES":"Executa","cs-CZ":"Spustit","el-GR":"Εκτέλεση","et-EE":"Käivita","fa-IR":"","fi-FI":"Suorita","he-IL":"רוץ","hr-xx":"","hu-HU":"Futtatás","hy-AM":"","id-ID":"Jalankan","is-IS":"Keyra","lb-xx":"","lt-LT":"","ro-RO":"","sk-SK":"Spustiť","sl-SI":"Poženi","sv-SE":"Kör","th-TH":"","tr-TR":"Çalıştır","uk-UA":"Запустити","vi-VN":"","zh-CN":"运行","zh-TW":"執行"}},"scene":{"activate":{"en-US":"Activate","de-DE":"Aktivieren","nl-NL":"Activeren","da-DK":"Aktiver","es-ES":"Activar","fr-FR":"Activer","it-IT":"Attiva","ru-RU":"Активировать","nb-NO":"Aktiver","nn-NO":"Aktiver","pl-PL":"Aktywuj","pt-PT":"Ativar","af-ZA":"Aktiveer","ar-SY":"تفعيل","bg-BG":"Активирай","ca-ES":"Activar","cs-CZ":"Aktivovat","el-GR":"Ενεργοποίηση","et-EE":"Aktiveeri","fa-IR":"فعال سازی","fi-FI":"Aktivoi","he-IL":"הפעל","hr-xx":"Aktivirati","hu-HU":"Aktiválás","hy-AM":"Ակտիվացնել","id-ID":"Aktifkan","is-IS":"Virkja","lb-xx":"Aktivéieren","lt-LT":"Suaktyvinti","ro-RO":"Activați","sk-SK":"Aktivovať","sl-SI":"Aktiviraj","sv-SE":"Aktivera","th-TH":"กระตุ้น","tr-TR":"Etkinleştir","uk-UA":"Активувати","vi-VN":"Kích hoạt","zh-CN":"激活","zh-TW":"啟用"}},"vacuum":{"start_cleaning":{"en-US":"Start cleaning","de-DE":"Reinigung starten","nl-NL":"Begin schoonmaak","da-DK":"Start rengøring","es-ES":"Empezar la limpieza","fr-FR":"Commencer à nettoyer","it-IT":"Inizia pulizia","ru-RU":"Начать уборку","nb-NO":"Start rengjøring","nn-NO":"Start reingjering","pl-PL":"Rozpocznij sprzątanie","pt-PT":"Iniciar a limpeza","af-ZA":"Begin stofsuig","ar-SY":"بدء تنظيف","bg-BG":"Започнете почистването","ca-ES":"Comença neteja","cs-CZ":"Zahájit čištění","el-GR":"Έναρξη καθαρισμού","et-EE":"Alusta puhastamist","fa-IR":"شروع به تمیز کردن","fi-FI":"Aloita imurointi","he-IL":"התחל לנקות","hr-xx":"Započnite čišćenje","hu-HU":"Takarítás indítása","hy-AM":"Սկսել մաքրում ","id-ID":"Mulai membersihkan","is-IS":"Byrja að þrífa","lb-xx":"Fänk mam botzen un","lt-LT":"Pradėti valymą","ro-RO":"Începe curățarea","sk-SK":"Začať čistenie","sl-SI":"Začni čiščenje","sv-SE":"Börja städning","th-TH":"เริ่มทำความสะอาด","tr-TR":"Temizlemeye başla","uk-UA":"Почати прибирання","vi-VN":"Bắt đầu dọn dẹp","zh-CN":"开始清扫","zh-TW":"開始清掃"},"return_to_base":{"en-US":"Return to dock","de-DE":"Zurück zur Dockingstation","nl-NL":"Keer terug naar dock","da-DK":"Tilbage til dock","es-ES":"Volver a la base","fr-FR":"Retourner à la base","it-IT":"Ritorna alla base","ru-RU":"Вернуть к док-станции","nb-NO":"Returner til dokken","nn-NO":"Gå tilbake til ladestasjonen","pl-PL":"Powrót do stacji dokującej","pt-PT":"Voltar à doca","af-ZA":"Keer terug na die hawe","ar-SY":"العودة","bg-BG":"Върни се в базовата станция","ca-ES":"Retorna a la base","cs-CZ":"Vrátit do stanice","el-GR":"Επιστροφή στο φορτιστή","et-EE":"Tagasi dokki","fa-IR":"بازگشت به خانه","fi-FI":"Palaa telakkaan","he-IL":"חוזר לתחנת עגינה","hr-xx":"Povratak na dok","hu-HU":"Dokkolás","hy-AM":"Վերադառնալ նավահանգիստ","id-ID":"Kembali ke dock","is-IS":"Fara aftur í bryggju","lb-xx":"Zeréck zur Statioun kommen","lt-LT":"","ro-RO":"Întoarcere la doc","sk-SK":"Návrat do doku","sl-SI":"Vrni se na postajo","sv-SE":"Återgå till docka","th-TH":"กลับไปจุดเชื่อมต่อ","tr-TR":"Dock'a geri dönüş","uk-UA":"Повернутись на док-станцію","vi-VN":"Trở lại dock","zh-CN":"返回底座","zh-TW":"返回充電"}},"fan":{"speed":{"en-US":"Speed","de-DE":"Geschwindigkeit","nl-NL":"Snelheid","da-DK":"Hastighed","es-ES":"Velocidad","fr-FR":"Vitesse","it-IT":"Velocità","ru-RU":"Скорость","nb-NO":"Hastighet","nn-NO":"Fart","pl-PL":"Prędkość","pt-PT":"Velocidade","af-ZA":"Spoed","ar-SY":"Snelheid","bg-BG":"Скорост","ca-ES":"Velocitat","cs-CZ":"Rychlost","el-GR":"Ταχύτητα","et-EE":"Kiirus","fa-IR":"سرعت","fi-FI":"Nopeus","he-IL":"מהירות","hr-xx":"Brzina","hu-HU":"Sebesség","hy-AM":"Արագություն","id-ID":"Kecepatan","is-IS":"Hraði","lb-xx":"Vitesse","lt-LT":"Greitis","ro-RO":"Viteză","sk-SK":"Rýchlosť","sl-SI":"Hitrost","sv-SE":"Hastighet","th-TH":"ความเร็วลม","tr-TR":"Hız","uk-UA":"Швидкість","vi-VN":"Tốc độ","zh-CN":"风速","zh-TW":"風速"}},"timer":{"start":{"en-US":"start","de-DE":"Start","nl-NL":"start","da-DK":"start","es-ES":"Iniciar","fr-FR":"démarrer","it-IT":"avvia","ru-RU":"Запуск","nb-NO":"","nn-NO":"start","pl-PL":"start","pt-PT":"Iniciar","af-ZA":"","ar-SY":"بدء","bg-BG":"старт","ca-ES":"inicia","cs-CZ":"Spustit","el-GR":"Εκκίνηση","et-EE":"käivita","fa-IR":"شروع","fi-FI":"Aloita","he-IL":"התחלה","hr-xx":"početak","hu-HU":"indítás","hy-AM":"սկսել","id-ID":"mulai","is-IS":"byrja","lb-xx":"Start","lt-LT":"pradėti","ro-RO":"Începe","sk-SK":"Štart","sl-SI":"Zagon","sv-SE":"starta","th-TH":"เริ่มต้น","tr-TR":"başlat","uk-UA":"Запуск","vi-VN":"","zh-CN":"开始","zh-TW":"開始"},"pause":{"en-US":"pause","de-DE":"Pause","nl-NL":"pauze","da-DK":"pause","es-ES":"Pausar","fr-FR":"pause","it-IT":"pausa","ru-RU":"Пауза","nb-NO":"","nn-NO":"pause","pl-PL":"wstrzymaj","pt-PT":"pausa","af-ZA":"","ar-SY":"إيقاف مؤقت","bg-BG":"пауза","ca-ES":"pausa","cs-CZ":"pauza","el-GR":"Παύση","et-EE":"peata","fa-IR":"pauza","fi-FI":"tauko","he-IL":"השהיה","hr-xx":"pauza","hu-HU":"szünet","hy-AM":"ընդհատել","id-ID":"jeda","is-IS":"hlé","lb-xx":"Pause","lt-LT":"sustabdyti","ro-RO":"Pauză","sk-SK":"Pozastaviť","sl-SI":"pavza","sv-SE":"pausa","th-TH":"หยุดชั่วคราว","tr-TR":"duraklat","uk-UA":"Пауза","vi-VN":"","zh-CN":"暂停","zh-TW":"暫停"},"cancel":{"en-US":"cancel","de-DE":"Abbrechen","nl-NL":"annuleren","da-DK":"annuller","es-ES":"Cancelar","fr-FR":"annuler","it-IT":"annulla","ru-RU":"Отмена","nb-NO":"Avbryt","nn-NO":"avbryt","pl-PL":"anuluj","pt-PT":"Cancelar","af-ZA":"","ar-SY":"إلغاء","bg-BG":"прекратяване","ca-ES":"cancel·la","cs-CZ":"Zrušit","el-GR":"Ακύρωση","et-EE":"loobu","fa-IR":"anuleaza","fi-FI":"Peruuta","he-IL":"ביטול","hr-xx":"otkaži","hu-HU":"mégse","hy-AM":"չեղարկել","id-ID":"batalkan","is-IS":"hætta við","lb-xx":"Ofbriechen","lt-LT":"atšaukti","ro-RO":"anulare","sk-SK":"Zrušiť","sl-SI":"Prekliči","sv-SE":"avbryt","th-TH":"ยกเลิก","tr-TR":"iptal","uk-UA":"Скасувати","vi-VN":"","zh-CN":"取消","zh-TW":"取消"},"finish":{"en-US":"finish","de-DE":"Ende","nl-NL":"voltooien","da-DK":"afslut","es-ES":"Terminar","fr-FR":"terminer","it-IT":"termina","ru-RU":"Готово","nb-NO":"Ferdig","nn-NO":"fullfør","pl-PL":"koniec","pt-PT":"Terminar","af-ZA":"","ar-SY":"إنهاء","bg-BG":"финал","ca-ES":"finalitza","cs-CZ":"Dokončit","el-GR":"Ολοκληρώθηκαν","et-EE":"lõpeta","fa-IR":"termina","fi-FI":"Valmis","he-IL":"סיום","hr-xx":"Završiti","hu-HU":"befejezés","hy-AM":"ավարտել","id-ID":"selesai","is-IS":"lokið","lb-xx":"Ofschléissen","lt-LT":"užbaigti","ro-RO":"finalizează","sk-SK":"Dokončiť","sl-SI":"Dokončaj","sv-SE":"slutför","th-TH":"เสร็จสิ้น","tr-TR":"bitir","uk-UA":"Готово","vi-VN":"","zh-CN":"完成","zh-TW":"完成"},"active":{"en-US":"Active","de-DE":"aktiv","nl-NL":"Actief","da-DK":"aktiv","es-ES":"activo","fr-FR":"actif","it-IT":"attivo","ru-RU":"Отсчёт","nb-NO":"aktiv","nn-NO":"aktiv","pl-PL":"aktywny","pt-PT":"ativo","af-ZA":"aktief","ar-SY":"مفعل","bg-BG":"активен","ca-ES":"Actiu","cs-CZ":"aktivní","el-GR":"ενεργό","et-EE":"aktiivne","fa-IR":"فعال","fi-FI":"aktiivinen","he-IL":"פעיל","hr-xx":"aktivan","hu-HU":"Aktív","hy-AM":"ակտիվ","id-ID":"Aktif","is-IS":"virkur","lb-xx":"Aktiv","lt-LT":"aktyvus","ro-RO":"activ","sk-SK":"aktívny","sl-SI":"aktiven","sv-SE":"aktiv","th-TH":"ใช้งานอยู่","tr-TR":"Aktif","uk-UA":"активний","vi-VN":"hoạt động","zh-CN":"激活","zh-TW":"啟用"},"idle":{"en-US":"Idle","de-DE":"Leerlauf","nl-NL":"Inactief","da-DK":"inaktiv","es-ES":"inactivo","fr-FR":"en veille","it-IT":"inattivo","ru-RU":"Ожидание","nb-NO":"inaktiv","nn-NO":"tomgang","pl-PL":"nieaktywny","pt-PT":"Em espera","af-ZA":"onaktief","ar-SY":"خامل","bg-BG":"неработещ","ca-ES":"inactiu","cs-CZ":"nečinné","el-GR":"Σε αδράνεια","et-EE":"ootel","fa-IR":"بیکار ","fi-FI":"Lepotilassa","he-IL":"לא פעיל","hr-xx":"neaktivan","hu-HU":"Tétlen","hy-AM":"պարապ","id-ID":"Siaga","is-IS":"aðgerðalaus","lb-xx":"Waart","lt-LT":"","ro-RO":"inactiv","sk-SK":"nečinný","sl-SI":"V pripravljenosti","sv-SE":"inaktiv","th-TH":"ไม่ได้ใช้งาน","tr-TR":"Boşta","uk-UA":"очікування","vi-VN":"nhàn rỗi","zh-CN":"空闲","zh-TW":"暫停"},"on":{"en-US":"On","de-DE":"Ein"},"off":{"en-US":"Off","de-DE":"Aus"},"paused":{"en-US":"Paused","de-DE":"pausiert","nl-NL":"Gepauzeerd","da-DK":"pause","es-ES":"pausado","fr-FR":"en pause","it-IT":"in pausa","ru-RU":"Пауза","nb-NO":"pauset","nn-NO":"pausa","pl-PL":"wstrzymany","pt-PT":"Em pausa","af-ZA":"Onderbreek","ar-SY":"موقّف مؤقتا","bg-BG":"в пауза","ca-ES":"Pausat","cs-CZ":"pozastaveno","el-GR":"σε παύση","et-EE":"peatatud","fa-IR":"متوقف شد","fi-FI":"Pysäytetty","he-IL":"מושהה","hr-xx":"pauzirano","hu-HU":"Szünetel","hy-AM":"դադար ","id-ID":"Jeda","is-IS":"í bið","lb-xx":"Pauseiert","lt-LT":"pristabdytas","ro-RO":"În pauză","sk-SK":"pozastavený","sl-SI":"Na pavzi","sv-SE":"pausad","th-TH":"หยุดชั่วคราว","tr-TR":"Durduruldu","uk-UA":"на паузі","vi-VN":"tạm dừng","zh-CN":"暂停","zh-TW":"暫停"}},"alarm_control_panel":{"armed":{"en-US":"Armed","de-DE":"Aktiv","nl-NL":"Actief","da-DK":"Tilkoblet","es-ES":"Armada","fr-FR":"Activé","it-IT":"Attivo","ru-RU":"Охрана","nb-NO":"Aktivert","nn-NO":"Påslått","pl-PL":"uzbr","pt-PT":"Armado","af-ZA":"Gewapen","ar-SY":"مفعل","bg-BG":"Охрана","ca-ES":"Activad.","cs-CZ":"Zabezpečeno","el-GR":"Οπλισμένος","et-EE":"Valves","fa-IR":"مصلح شده","fi-FI":"Viritetty","he-IL":"דרוך","hr-xx":"Aktivirano","hu-HU":"Élesítve","hy-AM":"Զինված","id-ID":"Diaktifkan","is-IS":"Ekki á verði","lb-xx":"Aktivéiert","lt-LT":"Užrakinta","ro-RO":"Armat","sk-SK":"Zakód","sl-SI":"Aktiven","sv-SE":"Larmat","th-TH":"เปิดการป้องกัน","tr-TR":"Aktif","uk-UA":"Охороняється","vi-VN":"VT","zh-CN":"警戒中","zh-TW":"已警戒"},"armed_away":{"en-US":"Armed","de-DE":"Aktiv","nl-NL":"Actief","da-DK":"Tilkoblet","es-ES":"Armada","fr-FR":"Activé","it-IT":"Attivo","ru-RU":"Охрана","nb-NO":"Aktivert","nn-NO":"Påslått","pl-PL":"uzbr","pt-PT":"Armado","af-ZA":"Aktief","ar-SY":"مفعل","bg-BG":"Охрана","ca-ES":"Activad.","cs-CZ":"Zabezpečeno","el-GR":"Οπλισμένος","et-EE":"Valves","fa-IR":"تجهیزات بیرون","fi-FI":"Viritetty","he-IL":"דרוך","hr-xx":"Aktivirano","hu-HU":"Élesítve","hy-AM":"Զինված","id-ID":"Diaktifkan","is-IS":"Á verði","lb-xx":"Aktivéiert","lt-LT":"Užrakinta","ro-RO":"Armat","sk-SK":"Zakód","sl-SI":"Aktiven","sv-SE":"Larmat","th-TH":"เปิดการป้องกัน","tr-TR":"Aktif","uk-UA":"Охороняється","vi-VN":"VT","zh-CN":"警戒中","zh-TW":"已警戒"},"armed_custom_bypass":{"en-US":"Armed","de-DE":"Aktiv","nl-NL":"Ingeschakeld","da-DK":"Tilkoblet","es-ES":"Armada","fr-FR":"Activé","it-IT":"Attivo","ru-RU":"Охрана","nb-NO":"Aktivert","nn-NO":"Påslått","pl-PL":"uzbr","pt-PT":"Armado","af-ZA":"Gewapen","ar-SY":"مفعل","bg-BG":"Охрана","ca-ES":"Activad.","cs-CZ":"Zabezpečeno","el-GR":"Οπλισμένος","et-EE":"Valves","fa-IR":"مجهز","fi-FI":"Viritetty","he-IL":"דרוך","hr-xx":"Aktivirano","hu-HU":"Élesítve","hy-AM":"Զինված","id-ID":"Diaktifkan","is-IS":"Á verði","lb-xx":"Aktivéiert","lt-LT":"Užrakinta","ro-RO":"Armat","sk-SK":"Zakód","sl-SI":"Aktiven","sv-SE":"Larmat","th-TH":"เปิดการป้องกัน","tr-TR":"Aktif","uk-UA":"Охороняється","vi-VN":"VT","zh-CN":"警戒中","zh-TW":"已警戒"},"armed_home":{"en-US":"Armed","de-DE":"Aktiv","nl-NL":"Actief","da-DK":"Tilkoblet","es-ES":"Armada","fr-FR":"Activé","it-IT":"Attivo","ru-RU":"Охрана","nb-NO":"Aktivert","nn-NO":"Påslått","pl-PL":"uzbr","pt-PT":"Armado","af-ZA":"Gewapen","ar-SY":"مفعل","bg-BG":"Охрана","ca-ES":"Activad.","cs-CZ":"Zabezpečeno","el-GR":"Οπλισμένος","et-EE":"Valves","fa-IR":"تجهیزات خانه","fi-FI":"Viritetty","he-IL":"דרוך","hr-xx":"Aktivirano","hu-HU":"Élesítve","hy-AM":"Զինված","id-ID":"Diaktifkan","is-IS":"Á verði","lb-xx":"Aktivéiert","lt-LT":"Užrakinta","ro-RO":"Armat","sk-SK":"Zakód","sl-SI":"Aktiven","sv-SE":"Larmat","th-TH":"เฝ้าระวังอยู่","tr-TR":"Aktif","uk-UA":"Охороняється","vi-VN":"Đã kích hoạt","zh-CN":"警戒中","zh-TW":"在家警戒"},"armed_night":{"en-US":"Armed","de-DE":"Aktiv","nl-NL":"Actief","da-DK":"Tilkoblet","es-ES":"Armada","fr-FR":"Activé","it-IT":"Attivo","ru-RU":"Охрана","nb-NO":"Aktivert","nn-NO":"Påslått","pl-PL":"uzbr","pt-PT":"Armado","af-ZA":"Aktief","ar-SY":"مفعل","bg-BG":"Охрана","ca-ES":"Activad.","cs-CZ":"Zabezpečeno","el-GR":"Οπλισμένος","et-EE":"Valves","fa-IR":"مصلح شده","fi-FI":"Viritetty","he-IL":"דרוך","hr-xx":"Aktivirano","hu-HU":"Élesítve","hy-AM":"Զինված","id-ID":"Diaktifkan","is-IS":"Á verði","lb-xx":"Aktivéiert","lt-LT":"Užrakinta","ro-RO":"Armat","sk-SK":"Zakód","sl-SI":"Aktiven","sv-SE":"Larmat","th-TH":"เปิดการป้องกัน","tr-TR":"Aktif","uk-UA":"Охороняється","vi-VN":"VT","zh-CN":"警戒中","zh-TW":"已警戒"},"armed_vacation":{"en-US":"Armed","de-DE":"Aktiv","nl-NL":"Ingeschakeld","da-DK":"Tilkoblet","es-ES":"Armada","fr-FR":"Armé","it-IT":"Attivo","ru-RU":"Охрана","nb-NO":"Aktivert","nn-NO":"Armert","pl-PL":"uzbr","pt-PT":"Armado","af-ZA":"","ar-SY":"","bg-BG":"Охрана","ca-ES":"Activad.","cs-CZ":"Zabezpečeno","el-GR":"Οπλισμένος","et-EE":"Valvestatud","fa-IR":"","fi-FI":"Kytketty","he-IL":"דרוך","hr-xx":"","hu-HU":"Élesítve","hy-AM":"","id-ID":"Diaktifkan","is-IS":"Á verði","lb-xx":"","lt-LT":"","ro-RO":"","sk-SK":"Pripravený","sl-SI":"Aktiven","sv-SE":"Larmat","th-TH":"","tr-TR":"Aktif","uk-UA":"","vi-VN":"","zh-CN":"警戒中","zh-TW":"已警戒"},"arming":{"en-US":"Arming","de-DE":"Aktiv.","nl-NL":"Gaat aan","da-DK":"Tilkobler","es-ES":"Armando","fr-FR":"Activer","it-IT":"In att.","ru-RU":"Постановка на охрану","nb-NO":"Aktivererer","nn-NO":"Slår på","pl-PL":"uzbr","pt-PT":"A armar","af-ZA":"Bewapen Tans","ar-SY":"جاري التفعيل","bg-BG":"Активиране","ca-ES":"Activan.","cs-CZ":"Zabezpečování","el-GR":"Όπλιση","et-EE":"Valvestab","fa-IR":"در حال مسلح کردن","fi-FI":"Virittyy","he-IL":"דורך","hr-xx":"Aktiviranje","hu-HU":"Élesítés","hy-AM":"Զինել","id-ID":"Mengaktifkan","is-IS":"set á vörð","lb-xx":"Aktivéieren","lt-LT":"Užrakinama","ro-RO":"Armare","sk-SK":"Aktivácia","sl-SI":"Vklapljam","sv-SE":"Tillkopplar","th-TH":"กำลังเปิดการป้องกัน","tr-TR":"Etkinleşiyor","uk-UA":"Ставиться","vi-VN":"Đang VT","zh-CN":"警戒准备","zh-TW":"開啟警戒中"},"disarmed":{"en-US":"Disarm","de-DE":"Inaktiv","nl-NL":"Uit","da-DK":"Frakoblet","es-ES":"Desarmar","fr-FR":"Désactivé","it-IT":"Disatt.","ru-RU":"Снято с охраны","nb-NO":"Deaktivere","nn-NO":"Deaktiver","pl-PL":"rozbr","pt-PT":"Desarm","af-ZA":"Ontwapen","ar-SY":"غير مفعّل","bg-BG":"Деактивирана","ca-ES":"Desacti.","cs-CZ":"Nezabezpečeno","el-GR":"Αφόπλιση","et-EE":"Maas","fa-IR":"غیر مسلح","fi-FI":"Ei viritetty","he-IL":"לא דרוך","hr-xx":"Deaktiviraj","hu-HU":"Hatást.","hy-AM":"Զինաթափել","id-ID":"Nonaktif","is-IS":"Ekki á verði","lb-xx":"Desaktivéieren","lt-LT":"Atrakinta","ro-RO":"Dezar","sk-SK":"Odkód","sl-SI":"Off","sv-SE":"Larma av","th-TH":"ปลดการป้องกัน","tr-TR":"Etkisiz","uk-UA":"Знято","vi-VN":"Vô hiệu hoá","zh-CN":"警戒解除","zh-TW":"解除警戒"},"disarming":{"en-US":"Disarm","de-DE":"Deakt.","nl-NL":"Gaat uit","da-DK":"Frakob","es-ES":"Desarmar","fr-FR":"Désarmement","it-IT":"In disat.","ru-RU":"Снятие с охраны","nb-NO":"Deaktivere","nn-NO":"Slå av","pl-PL":"rozbr","pt-PT":"Desarmar","af-ZA":"Ontwapen","ar-SY":"تعطيل","bg-BG":"Деактивирaне","ca-ES":"Desacti.","cs-CZ":"Odbezpečování","el-GR":"Αφόπλιση","et-EE":"Maas...","fa-IR":"در حال غیر مسلح کردن","fi-FI":"Ei viritetty","he-IL":"מבטל","hr-xx":"Deaktiviraj","hu-HU":"Hatást.","hy-AM":"Անջատել տագնապը","id-ID":"Nonaktif","is-IS":"tek af verði","lb-xx":"Desaktivéieren","lt-LT":"Atrakinti","ro-RO":"Dezar","sk-SK":"Deakt","sl-SI":"Izklopi","sv-SE":"Frånkopplar","th-TH":"กำลังปลดการป้องกัน","tr-TR":"Etkisiz","uk-UA":"Знято","vi-VN":"Giải giáp","zh-CN":"警戒解除","zh-TW":"關閉警戒"},"pending":{"en-US":"Pend","de-DE":"Warte","nl-NL":"Wacht","da-DK":"Venter","es-ES":"Pendiente","fr-FR":"En cours","it-IT":"Sosp.","ru-RU":"Ожидание","nb-NO":"Venter","nn-NO":"Ventar","pl-PL":"oczek","pt-PT":"Pend","af-ZA":"Hangend","ar-SY":"معلق","bg-BG":"Изчаква","ca-ES":"Pendent","cs-CZ":"Čeká","el-GR":"Εκκρεμής","et-EE":"Ootel","fa-IR":"در انتظار","fi-FI":"Odot","he-IL":"ממתין","hr-xx":"U tijeku","hu-HU":"Függő","hy-AM":"Պենդ","id-ID":"Tunda","is-IS":"Í bið","lb-xx":"Ustoend","lt-LT":"Vykdoma","ro-RO":"În curs","sk-SK":"Čaká","sl-SI":"V teku","sv-SE":"Väntar","th-TH":"ค้างอยู่","tr-TR":"Askıda","uk-UA":"Очікування","vi-VN":"Chờ","zh-CN":"挂起","zh-TW":"等待中"},"triggered":{"en-US":"Trig","de-DE":"Ausgel.","nl-NL":"Gaat af","da-DK":"Udløst","es-ES":"Activada","fr-FR":"Déclenchée","it-IT":"Attiv.","ru-RU":"Тревога","nb-NO":"Utløs","nn-NO":"Utløys","pl-PL":"wyzw","pt-PT":"Desp","af-ZA":"Lui","ar-SY":"تشغيل","bg-BG":"Задействана","ca-ES":"Dispara.","cs-CZ":"Spuštěn","el-GR":"Ενεργ","et-EE":"Häire","fa-IR":"راه انداخته شده","fi-FI":"Lauennut","he-IL":"מופעל","hr-xx":"Okinut","hu-HU":"Riaszt","hy-AM":"թրիգ","id-ID":"Picu","is-IS":"Kveik","lb-xx":"Ausgeléist","lt-LT":"Paleidiklis","ro-RO":"Decl","sk-SK":"Alarm","sl-SI":"Sprožen","sv-SE":"Utlöst","th-TH":"ถูกกระตุ้น","tr-TR":"Tetiklendi","uk-UA":"Тривога","vi-VN":"Kích hoạt","zh-CN":"触发","zh-TW":"觸發"},"arm_away":{"en-US":"Arm away","de-DE":"Aktivieren - Unterwegs","nl-NL":"Inschakelen voor vertrek","da-DK":"Tilkobl ude","es-ES":"Armar ausente","fr-FR":"Armer (absent)","it-IT":"Attiva fuori casa","ru-RU":"Охрана (не дома)","nb-NO":"Aktiver borte","nn-NO":"Bortemodus","pl-PL":"Uzbrój (poza domem)","pt-PT":"Armado ausente","af-ZA":"Bewapen weg","ar-SY":"تفعيل خارج المنزل","bg-BG":"Под охрана","ca-ES":"Activar, fora","cs-CZ":"Aktivovat režim nepřítomnost","el-GR":"Οπλισμός εκτός","et-EE":"Valvesta eemal","fa-IR":"حفاظت بیرون","fi-FI":"Viritä (poissa)","he-IL":"דרוך לא בבית","hr-xx":"Aktiviran odsutno","hu-HU":"Élesít (távozás)","hy-AM":"Ձեռք բերեք","id-ID":"Aktifkan utk keluar","is-IS":"Vörður úti","lb-xx":"Aktivéiert Ënnerwee","lt-LT":"Išvykęs","ro-RO":"Armat plecat","sk-SK":"Zakódovať odchod","sl-SI":"Vklopi odsoten","sv-SE":"Larma bortaläge","th-TH":"ล็อคแบบออกข้างนอก","tr-TR":"Dışarıda","uk-UA":"ARM AWAY","vi-VN":"Đi vắng","zh-CN":"离家警戒","zh-TW":"離家警戒"},"arm_custom_bypass":{"en-US":"Custom bypass","de-DE":"Benutzerdefinierter Bypass","nl-NL":"Inschakelen met overbrugging","da-DK":"Brugerdefineret bypass","es-ES":"Bypass personalizada","fr-FR":"Bypass personnalisé","it-IT":"Bypass personalizzato","ru-RU":"Охрана с исключениями","nb-NO":"Tilpasset bypass","nn-NO":"Tilpassa bypass","pl-PL":"Niestandardowy bypass","pt-PT":"Desvio personalizado","af-ZA":"Pasgemaakte omseil","ar-SY":"تجاوز مخصص","bg-BG":"Потребителски байпас","ca-ES":"Bypass personalitzat","cs-CZ":"Vlastní obejítí","el-GR":"Προσαρμοσμένη παράκαμψη","et-EE":"Eranditega","fa-IR":"بایگانی سفارشی","fi-FI":"Mukautettu ohitus","he-IL":"מעקף מותאם אישית","hr-xx":"Prilagođena premosnica","hu-HU":"Egyéni áthidalás","hy-AM":"Պատվերով շրջանցիկ","id-ID":"Diaktifkan khusus","is-IS":"Sérsniðin hjáleið","lb-xx":"Personaliséierte Bypass","lt-LT":"Individualizuotas apėjimas","ro-RO":"Bypass personalizat","sk-SK":"Prispôsobené vylúčenie","sl-SI":"Izjeme po meri","sv-SE":"Larm förbikopplat","th-TH":"ปล่อยผ่านตามที่กำหนด","tr-TR":"Özel atlatma","uk-UA":"Охорона з винятками","vi-VN":"Bỏ qua tùy chỉnh","zh-CN":"自定义略过条件","zh-TW":"警戒模式狀態"},"arm_home":{"en-US":"Arm home","de-DE":"Aktivieren - Zuhause","nl-NL":"Inschakelen voor thuis","da-DK":"Tilkobl hjemme","es-ES":"Armar en casa","fr-FR":"Armer (présent)","it-IT":"Attiva in casa","ru-RU":"Охрана (дома)","nb-NO":"Aktiver hjemme","nn-NO":"Heimemodus","pl-PL":"Uzbrój (w domu)","pt-PT":"Armado casa","af-ZA":"Bewapen Huis","ar-SY":"تفعيل في المنزل","bg-BG":"Под охрана - вкъщи","ca-ES":"Activar, a casa","cs-CZ":"Aktivovat režim domov","el-GR":"Οπλισμός εντός","et-EE":"Valvesta kodus","fa-IR":"حفاظت خانه","fi-FI":"Viritä (kotona)","he-IL":"דרוך בבית","hr-xx":"Aktiviran doma","hu-HU":"Élesít (otthon)","hy-AM":"Arm տուն","id-ID":"Aktifkan utk di rumah","is-IS":"Vörður heima","lb-xx":"Aktivéiert Doheem","lt-LT":"Namų apsauga","ro-RO":"Armat acasă","sk-SK":"Zakódovať doma","sl-SI":"Vklopi doma","sv-SE":"Larma hemmaläge","th-TH":"ล็อคแบบอยู่บ้าน","tr-TR":"Evde","uk-UA":"ARM HOME","vi-VN":"Ở nhà","zh-CN":"在家警戒","zh-TW":"在家警戒"},"arm_night":{"en-US":"Arm night","de-DE":"Aktivieren - Nacht","nl-NL":"Inschakelen voor 's nachts","da-DK":"Tilkoblet nat","es-ES":"Armar noche","fr-FR":"Armer nuit","it-IT":"Attiva notte","ru-RU":"Охрана (ночь)","nb-NO":"Aktiver natt","nn-NO":"Aktiver natt","pl-PL":"Uzbrój (noc)","pt-PT":"Armado noite","af-ZA":"Nag alarm","ar-SY":"تفعيل بالليل","bg-BG":"Под охрана - нощ","ca-ES":"Activar, nocturn","cs-CZ":"Aktivovat noční režim","el-GR":"Οπλισμός νυκτός","et-EE":"Valvesta öine","fa-IR":"نوبت شب","fi-FI":"Viritä yöksi","he-IL":"דריכה לילית","hr-xx":"Aktiviran nočni","hu-HU":"Élesít (éjszakai)","hy-AM":"Զինել - Գիշերային ռեժիմ","id-ID":"Aktifkan utk malam","is-IS":"Vörður nótt","lb-xx":"Aktivéiert Nuecht","lt-LT":"Naktinė apsauga","ro-RO":"Armat noaptea","sk-SK":"Zakódovať na noc","sl-SI":"Vklopi nočni način","sv-SE":"Larma nattläge","th-TH":"เฝ้ายามกลางคืน","tr-TR":"Geceyi etkinleştir","uk-UA":"ARM NIGHT","vi-VN":"An ninh ban đêm","zh-CN":"夜间警戒","zh-TW":"夜間警戒"},"arm_vacation":{"en-US":"Arm vacation","de-DE":"Aktiviere Urlaub","nl-NL":"Inschakelen voor vakantie","da-DK":"Tilkobl ferie","es-ES":"Armar por vacaciones","fr-FR":"Armer vacances","it-IT":"Attiva in vacanza","ru-RU":"Охрана (отпуск)","nb-NO":"Aktiver ferie","nn-NO":"Armert feriemodus","pl-PL":"Uzbrój (tryb wakacyjny)","pt-PT":"","af-ZA":"","ar-SY":"","bg-BG":"Под охрана - ваканция","ca-ES":"Activa en mode vacances","cs-CZ":"Aktivovat režim dovolená","el-GR":"Οπλισμός διακοπών","et-EE":"Valvesta puhkuse režiimis","fa-IR":"","fi-FI":"Aktivoi lomatila","he-IL":"דריכה - חופשה","hr-xx":"","hu-HU":"Élesítés (vakáció)","hy-AM":"","id-ID":"Aktifkan utk liburan","is-IS":"Vörður frí","lb-xx":"","lt-LT":"","ro-RO":"Armat vacanță","sk-SK":"Zakódovať dovolenku","sl-SI":"","sv-SE":"Larma semesterläge","th-TH":"","tr-TR":"Dışarıda","uk-UA":"","vi-VN":"","zh-CN":"度假警戒","zh-TW":"度假警戒"},"clear_code":{"en-US":"Clear","de-DE":"Löschen","nl-NL":"Wis","da-DK":"Ryd","es-ES":"Limpiar","fr-FR":"Effacer","it-IT":"Canc","ru-RU":"Сброс","nb-NO":"Tøm","nn-NO":"Slett alt","pl-PL":"Wyczyść","pt-PT":"Apagar","af-ZA":"Maak skoon","ar-SY":"مسح","bg-BG":"Изчистване","ca-ES":"Borrar","cs-CZ":"Zrušit","el-GR":"Καθαρισμός","et-EE":"Puhasta","fa-IR":"پاک کردن","fi-FI":"Tyhjennä","he-IL":"נקה","hr-xx":"Vedro","hu-HU":"Törlés","hy-AM":"Մաքրել","id-ID":"Hapus","is-IS":"Hreinsa","lb-xx":"Kloer","lt-LT":"Išvalyti","ro-RO":"Şterge","sk-SK":"Zrušiť","sl-SI":"Počisti","sv-SE":"Rensa","th-TH":"ล้าง","tr-TR":"Temizle","uk-UA":"CLEAR","vi-VN":"Xóa","zh-CN":"清除","zh-TW":"清除"},"code":{"en-US":"Code","de-DE":"Code","nl-NL":"Code","da-DK":"Kode","es-ES":"Código","fr-FR":"Code","it-IT":"Codice","ru-RU":"Код","nb-NO":"Kode","nn-NO":"Kode","pl-PL":"Kod","pt-PT":"Código","af-ZA":"Kode","ar-SY":"الرمز","bg-BG":"Код","ca-ES":"Codi","cs-CZ":"Kód","el-GR":"Κωδικός","et-EE":"Kood","fa-IR":"کد","fi-FI":"Koodi","he-IL":"קוד","hr-xx":"Kod","hu-HU":"Kód","hy-AM":"Կոդ","id-ID":"Kode","is-IS":"Kóði","lb-xx":"Code","lt-LT":"Kodas","ro-RO":"Cod","sk-SK":"Kód","sl-SI":"Koda","sv-SE":"Kod","th-TH":"รหัส","tr-TR":"Kod","uk-UA":"Код","vi-VN":"Mã số","zh-CN":"密码","zh-TW":"密碼"},"disarm":{"en-US":"Disarm","de-DE":"Deaktivieren","nl-NL":"Uitschakelen","da-DK":"Frakobl","es-ES":"Desarmar","fr-FR":"Désarmer","it-IT":"Disattiva","ru-RU":"Снять с охраны","nb-NO":"Deaktivere","nn-NO":"Skru av","pl-PL":"Rozbrój","pt-PT":"Desarmar","af-ZA":"Skakel Af","ar-SY":"تعطيل","bg-BG":"Деактивирaне","ca-ES":"Desactivar","cs-CZ":"Odbezpečit","el-GR":"Αφοπλισμός","et-EE":"Valvest maha","fa-IR":"دزدگیر خاموش","fi-FI":"Poista hälytys","he-IL":"לא דרוך","hr-xx":"Deaktiviraj","hu-HU":"Hatástalanít","hy-AM":"Զինաթափել","id-ID":"Nonaktifkan","is-IS":"Taka af verði","lb-xx":"Desaktivéieren","lt-LT":"Atrakinti","ro-RO":"Dezarmat","sk-SK":"Odkódovať","sl-SI":"Izklopi","sv-SE":"Larma från","th-TH":"ปิดระบบสัญญาณกันขโมย","tr-TR":"Etkisiz hale getir","uk-UA":"DISARM","vi-VN":"Vô hiệu hoá","zh-CN":"解除警戒","zh-TW":"解除警戒"}},"hvac_action":{"cooling":{"en-US":"Cooling","de-DE":"Kühlung","nl-NL":"Koelen","da-DK":"Køling","es-ES":"Enfriando","fr-FR":"Refroidissement","it-IT":"Raffreddamento","ru-RU":"Охлаждение","nb-NO":"Kjøling","nn-NO":"Nedkjøling","pl-PL":"chłodzenie","pt-PT":"Resfriar","af-ZA":"Koel Af","ar-SY":"تبريد","bg-BG":"Охлаждане","ca-ES":"Refredant","cs-CZ":"Chlazení","el-GR":"Ψύξη","et-EE":"Jahutamine","fa-IR":"خنک کننده","fi-FI":"Jäähdytys","he-IL":"קירור","hr-xx":"Hlađenje","hu-HU":"Hűtés","hy-AM":"հովացում","id-ID":"Mendinginkan","is-IS":"Kæling","lb-xx":"Ofkillen","lt-LT":"Aušinimas","ro-RO":"Racește","sk-SK":"Chladenie","sl-SI":"Hlajenje","sv-SE":"Kyler","th-TH":"โหมดเย็น","tr-TR":"Soğutma","uk-UA":"Охолодження","vi-VN":"Làm mát","zh-CN":"制冷","zh-TW":"冷氣"},"drying":{"en-US":"Drying","de-DE":"Trocknen","nl-NL":"Ontvochtigen","da-DK":"Tørring","es-ES":"Secando","fr-FR":"Séchage","it-IT":"Deumidificazione","ru-RU":"Осушение","nb-NO":"Tørking","nn-NO":"Tørkar","pl-PL":"osuszanie","pt-PT":"Secagem","af-ZA":"Droog Uit","ar-SY":"تجفيف","bg-BG":"Изсушаване","ca-ES":"Assecant","cs-CZ":"Sušení","el-GR":"Αφύγρανση","et-EE":"Kuivatamine","fa-IR":"خشك كردن","fi-FI":"Kuivaus","he-IL":"מייבש","hr-xx":"Sušenje","hu-HU":"Párátlanítás","hy-AM":"Չորացում","id-ID":"Mengeringkan","is-IS":"Þurrkun","lb-xx":"Dréchnen","lt-LT":"Džiovinimas","ro-RO":"Usucă","sk-SK":"Sušenie","sl-SI":"Sušenje","sv-SE":"Avfuktar","th-TH":"โหมดแห้ง","tr-TR":"Kurutma","uk-UA":"Осушення","vi-VN":"Làm khô","zh-CN":"除湿","zh-TW":"除濕"},"fan":{"en-US":"Fan","de-DE":"Ventilator","nl-NL":"Ventilator","da-DK":"Blæser","es-ES":"Ventilador","fr-FR":"Ventilateur","it-IT":"Ventilatore","ru-RU":"Вентиляция","nb-NO":"Vifte","nn-NO":"Vifte","pl-PL":"wentylator","pt-PT":"Ventoinha","af-ZA":"Waaier","ar-SY":"مروحة","bg-BG":"Вентилатор","ca-ES":"Ventilació","cs-CZ":"Ventilátor","el-GR":"Ανεμιστήρας","et-EE":"Ventilaator","fa-IR":"فن","fi-FI":"Tuuletin","he-IL":"מאוורר","hr-xx":"Ventilator","hu-HU":"Ventilátor","hy-AM":"Երկրպագու","id-ID":"Kipas","is-IS":"Vifta","lb-xx":"Ventilator","lt-LT":"Ventiliatorius","ro-RO":"Ventilator","sk-SK":"Ventilátor","sl-SI":"Ventilator","sv-SE":"Fläkt","th-TH":"พัดลม","tr-TR":"Fan","uk-UA":"Вентилятор","vi-VN":"Quạt","zh-CN":"送风","zh-TW":"風速"},"heating":{"en-US":"Heating","de-DE":"Heizung","nl-NL":"Verwarmen","da-DK":"Opvarmning","es-ES":"Calentando","fr-FR":"En chauffe","it-IT":"Riscaldamento","ru-RU":"Обогрев","nb-NO":"Oppvarming","nn-NO":"Oppvarming","pl-PL":"grzanie","pt-PT":"Aquecimento","af-ZA":"Verhit","ar-SY":"تدفئة","bg-BG":"Отопление","ca-ES":"Escalfant","cs-CZ":"Topení","el-GR":"Θέρμανση","et-EE":"Küte","fa-IR":"گرمایش","fi-FI":"Lämmitys","he-IL":"חימום","hr-xx":"Grijanje","hu-HU":"Fűtés","hy-AM":"Տաքացում","id-ID":"Memanaskan","is-IS":"Kynding","lb-xx":"Hëtzen","lt-LT":"Šildymas","ro-RO":"Încălzește","sk-SK":"Kúrenie","sl-SI":"Ogrevanje","sv-SE":"Värmer","th-TH":"โหมดอบอุ่น","tr-TR":"Isıtma","uk-UA":"Нагрівання","vi-VN":"Làm ấm","zh-CN":"制热","zh-TW":"暖氣"},"idle":{"en-US":"Idle","de-DE":"Leerlauf","nl-NL":"Inactief","da-DK":"Inaktiv","es-ES":"Inactivo","fr-FR":"Inactif","it-IT":"Inattivo","ru-RU":"Бездействие","nb-NO":"Inaktiv","nn-NO":"Tomgang","pl-PL":"nieaktywny","pt-PT":"Em espera","af-ZA":"Onaktief","ar-SY":"خامل","bg-BG":"Неработещ","ca-ES":"Inactiu","cs-CZ":"Nečinný","el-GR":"Σε αδράνεια","et-EE":"Ootel","fa-IR":"بیکار","fi-FI":"Lepotilassa","he-IL":"כבוי","hr-xx":"Neaktivan","hu-HU":"Tétlen","hy-AM":"Պարապ","id-ID":"Diam","is-IS":"Aðgerðalaus","lb-xx":"Waart","lt-LT":"Laukimo režimas","ro-RO":"Inactiv","sk-SK":"Nečinný","sl-SI":"V pripravljenosti","sv-SE":"Inaktiv","th-TH":"ไม่ได้ใช้งาน","tr-TR":"Boşta","uk-UA":"Очікування","vi-VN":"Nhàn rỗi","zh-CN":"空闲","zh-TW":"閒置"},"off":{"en-US":"Off","de-DE":"Aus","nl-NL":"Uit","da-DK":"Fra","es-ES":"Apagado","fr-FR":"Éteint","it-IT":"Spento","ru-RU":"Выключено","nb-NO":"Av","nn-NO":"Av","pl-PL":"wył.","pt-PT":"Desligado","af-ZA":"Af","ar-SY":"متوقف","bg-BG":"Изключен","ca-ES":"Apagat","cs-CZ":"Vypnuto","el-GR":"Κλειστό","et-EE":"Väljas","fa-IR":"خاموش","fi-FI":"Sammutettu","he-IL":"כבוי","hr-xx":"Isključen","hu-HU":"Ki","hy-AM":"Անջատած","id-ID":"Mati","is-IS":"Slökkt","lb-xx":"Aus","lt-LT":"Išjungta","ro-RO":"Oprit","sk-SK":"Vypnutý","sl-SI":"Izključen","sv-SE":"Av","th-TH":"ปิด","tr-TR":"Kapalı","uk-UA":"Вимкнено","vi-VN":"Tắt","zh-CN":"关闭","zh-TW":"關閉"}},"climate":{"off":{"en-US":"Off","de-DE":"Aus","nl-NL":"Uit","da-DK":"Fra","es-ES":"Apagado","fr-FR":"Inactif","it-IT":"Spento","ru-RU":"Выключено","nb-NO":"Av","nn-NO":"Av","pl-PL":"wyłączony","pt-PT":"Desligado","af-ZA":"Af","ar-SY":"إيقاف","bg-BG":"Изключен","ca-ES":"Apagat","cs-CZ":"Neaktivní","el-GR":"Ανενεργό","et-EE":"Väljas","fa-IR":"خاموش","fi-FI":"Pois","he-IL":"כבוי","hr-xx":"Isključen","hu-HU":"Ki","hy-AM":"Անջատված","id-ID":"Off","is-IS":"Slökkt","lb-xx":"Aus","lt-LT":"Išjungta","ro-RO":"Oprit","sk-SK":"Vypnuté","sl-SI":"Izključen","sv-SE":"Av","th-TH":"ปิด","tr-TR":"Kapalı","uk-UA":"Вимкнено","vi-VN":"Tắt","zh-CN":"关","zh-TW":"關閉"},"heat":{"en-US":"Heat","de-DE":"Heizen","nl-NL":"Verwarmen","da-DK":"Varme","es-ES":"Calor","fr-FR":"Chauffe","it-IT":"Caldo","ru-RU":"Обогрев","nb-NO":"Varme","nn-NO":"Varme","pl-PL":"grzanie","pt-PT":"Quente","af-ZA":"Hitte","ar-SY":"تدفئة","bg-BG":"Отопление","ca-ES":"Escalfar","cs-CZ":"Topení","el-GR":"Θερμό","et-EE":"Soojenda","fa-IR":"حرارت","fi-FI":"Lämmitys","he-IL":"חימום","hr-xx":"Grijanje","hu-HU":"Fűtés","hy-AM":"Ջերմություն","id-ID":"Panas","is-IS":"Hitun","lb-xx":"Heizen","lt-LT":"","ro-RO":"Căldură","sk-SK":"Kúrenie","sl-SI":"Toplo","sv-SE":"Värme","th-TH":"ร้อน","tr-TR":"Sıcak","uk-UA":"Обігрівання","vi-VN":"Nhiệt","zh-CN":"制热","zh-TW":"暖氣"},"cool":{"en-US":"Cool","de-DE":"Kühlen","nl-NL":"Koelen","da-DK":"Køl","es-ES":"Frío","fr-FR":"Frais","it-IT":"Freddo","ru-RU":"Охлаждение","nb-NO":"Kjøling","nn-NO":"Kjøle","pl-PL":"chłodzenie","pt-PT":"Frio","af-ZA":"Koel","ar-SY":"تبريد","bg-BG":"Охлаждане","ca-ES":"Refredar","cs-CZ":"Chlazení","el-GR":"Δροσερό","et-EE":"Jahuta","fa-IR":"خنک","fi-FI":"Jäähdytys","he-IL":"קרור","hr-xx":"Hlađenje","hu-HU":"Hűtés","hy-AM":"Հովացում","id-ID":"Sejuk","is-IS":"Kæling","lb-xx":"Kill","lt-LT":"","ro-RO":"Rece","sk-SK":"Chladenie","sl-SI":"Mrzlo","sv-SE":"Kyla","th-TH":"เย็น","tr-TR":"Serin","uk-UA":"Охолодження","vi-VN":"Mát mẻ","zh-CN":"制冷","zh-TW":"冷氣"},"heat_cool":{"en-US":"Heat/Cool","de-DE":"Heizen/Kühlen","nl-NL":"Verwarmen/Koelen","da-DK":"Opvarm/køl","es-ES":"Calor/Frío","fr-FR":"Chaud/Froid","it-IT":"Caldo/Freddo","ru-RU":"Обогрев / Охлаждение","nb-NO":"Varme/kjøling","nn-NO":"Oppvarming/Nedkjøling","pl-PL":"grzanie/chłodzenie","pt-PT":"Calor / Frio","af-ZA":"Verhit/Verkoel","ar-SY":"","bg-BG":"Отопление/Охлаждане","ca-ES":"Escalfar/Refredar","cs-CZ":"Vytápění/Chlazení","el-GR":"Θέρμανση / Ψύξη","et-EE":"Küta/jahuta","fa-IR":"","fi-FI":"Lämmitys/jäähdytys","he-IL":"חימום/קירור","hr-xx":"Grijanje/Hlađenje","hu-HU":"Fűtés/Hűtés","hy-AM":"Ջեռուցում/Հովացում","id-ID":"Panas/Dingin","is-IS":"Hita/Kæla","lb-xx":"Hëtzen/Ofkillen","lt-LT":"","ro-RO":"Încălzire / Răcire","sk-SK":"Vykurovanie / Chladenie","sl-SI":"Gretje/Hlajenje","sv-SE":"Värme/Kyla","th-TH":"ร้อน/เย็น","tr-TR":"Isıtma / Soğutma","uk-UA":"Опалення/Охолодження","vi-VN":"Nóng/Lạnh","zh-CN":"制热/制冷","zh-TW":"暖氣/冷氣"},"auto":{"en-US":"Auto","de-DE":"Automatisch","nl-NL":"Auto","da-DK":"Auto","es-ES":"Automático","fr-FR":"Auto","it-IT":"Auto","ru-RU":"Авто","nb-NO":"Auto","nn-NO":"Auto","pl-PL":"automatyczny","pt-PT":"Auto","af-ZA":"Outo","ar-SY":"تلقائي","bg-BG":"Автоматичен","ca-ES":"Automàtic","cs-CZ":"Automatika","el-GR":"Αυτόματο","et-EE":"Automaatne","fa-IR":"خودکار","fi-FI":"Automaatilla","he-IL":"אוטומטי","hr-xx":"Auto","hu-HU":"Automatikus","hy-AM":"Ավտոմատ","id-ID":"Auto","is-IS":"Sjálfvirkt","lb-xx":"Auto","lt-LT":"","ro-RO":"Auto","sk-SK":"Automatika","sl-SI":"Samodejno","sv-SE":"Automatisk","th-TH":"อัตโนมัติ","tr-TR":"Otomatik","uk-UA":"Автоматичний","vi-VN":"Tự động","zh-CN":"自动","zh-TW":"自動"},"dry":{"en-US":"Dry","de-DE":"Entfeuchten","nl-NL":"Droog","da-DK":"Tør","es-ES":"Seco","fr-FR":"Sec","it-IT":"Secco","ru-RU":"Осушение","nb-NO":"Tørr","nn-NO":"Tørr","pl-PL":"osuszanie","pt-PT":"Desumidificar","af-ZA":"Droog","ar-SY":"جاف","bg-BG":"Сух","ca-ES":"Assecar","cs-CZ":"Vysoušení","el-GR":"Ξηρό","et-EE":"Kuiv","fa-IR":"خشک","fi-FI":"Kuivaus","he-IL":"יבש","hr-xx":"Suho","hu-HU":"Száraz","hy-AM":"Չոր","id-ID":"Kering","is-IS":"Þurrt","lb-xx":"Dréchen","lt-LT":"","ro-RO":"Uscat","sk-SK":"Sušenie","sl-SI":"Suho","sv-SE":"Avfuktning","th-TH":"แห้ง","tr-TR":"Kuru","uk-UA":"Осушення","vi-VN":"Khô","zh-CN":"除湿","zh-TW":"除濕模式"},"fan_only":{"en-US":"Fan only","de-DE":"Nur Ventilator","nl-NL":"Alleen ventilatie","da-DK":"Kun blæser","es-ES":"Sólo ventilador","fr-FR":"Ventilateur seul","it-IT":"Solo ventilatore","ru-RU":"Вентиляция","nb-NO":"Kun vifte","nn-NO":"Berre vifte","pl-PL":"tylko wentylator","pt-PT":"Apenas ventilar","af-ZA":"Slegs waaier","ar-SY":"المروحة فقط","bg-BG":"Само вентилатор","ca-ES":"Només ventilador","cs-CZ":"Pouze ventilátor","el-GR":"Ανεμιστήρας μόνο","et-EE":"Ainult ventilaator","fa-IR":"فقط پنکه","fi-FI":"Tuuletus","he-IL":"מאוורר בלבד","hr-xx":"Samo ventilator","hu-HU":"Csak ventilátor","hy-AM":"Օդափոխիչ","id-ID":"Hanya kipas","is-IS":"Vifta eingöngu","lb-xx":"Nëmme Ventilator","lt-LT":"","ro-RO":"Numai ventilator","sk-SK":"Iba ventilátor","sl-SI":"Samo ventilator","sv-SE":"Endast fläkt","th-TH":"เฉพาะพัดลม","tr-TR":"Sadece fan","uk-UA":"Лише вентилятор","vi-VN":"Chỉ có quạt","zh-CN":"仅送风","zh-TW":"僅送風"}},"qr":{"ssid":{"en-US":"SSID","de-DE":"SSID","nl-NL":"SSID","da-DK":"SSID","es-ES":"SSID","fr-FR":"SSID","it-IT":"SSID","ru-RU":"SSID","nb-NO":"SSID","nn-NO":"SSID","pl-PL":"SSID","pt-PT":"SSID","af-ZA":"SSID","ar-SY":"SSID","bg-BG":"SSID","ca-ES":"SSID","cs-CZ":"SSID","el-GR":"SSID","et-EE":"SSID","fa-IR":"SSID","fi-FI":"SSID","he-IL":"SSID","hr-xx":"SSID","hu-HU":"SSID","hy-AM":"SSID","id-ID":"SSID","is-IS":"SSID","lb-xx":"SSID","lt-LT":"SSID","ro-RO":"SSID","sk-SK":"SSID","sl-SI":"SSID","sv-SE":"SSID","th-TH":"SSID","tr-TR":"SSID","uk-UA":"SSID","vi-VN":"SSID","zh-CN":"SSID","zh-TW":"SSID"},"password":{"en-US":"Password","de-DE":"Passwort","nl-NL":"Wachtwoord","da-DK":"Adgangskode","es-ES":"Contraseña","fr-FR":"Mot de passe","it-IT":"Parola d'ordine","ru-RU":"Пароль","nb-NO":"Passord","nn-NO":"Passord","pl-PL":"Hasło","pt-PT":"Senha","af-ZA":"Wagwoord","ar-SY":"كلمة المرور","bg-BG":"Парола","ca-ES":"Contrasenya","cs-CZ":"Heslo","el-GR":"Κωδικός πρόσβασης","et-EE":"Parool","fa-IR":"کلمه عبور","fi-FI":"Salasana","he-IL":"סיסמה","hr-xx":"Lozinka","hu-HU":"Jelszó","hy-AM":"Գաղտնաբառ","id-ID":"Kata sandi","is-IS":"Lykilorð","lb-xx":"Passwuert","lt-LT":"Slaptažodis","ro-RO":"Parola","sk-SK":"heslo","sl-SI":"Geslo","sv-SE":"Lösenord","th-TH":"รหัสผ่าน","tr-TR":"Şifre","uk-UA":"Пароль","vi-VN":"Mật khẩu","zh-CN":"密码","zh-TW":"密碼"},"Wlan enabled":{"en-US":"Wlan enabled","de-DE":"Wlan aktiviert"},"Wlan disabled":{"en-US":"Wlan disabled","de-DE":"Wlan deaktiviert"}},"media":{"no_music_to_control":{"en-US":"No music to control","de-DE":"Keine Musik zum Steuern","nl-NL":"Geen muziek om te bedienen","da-DK":"Ingen musik at styre","es-ES":"Sin música para controlar","fr-FR":"Pas de musique à contrôler","it-IT":"Nessuna musica da controllare","ru-RU":"Нет музыки для управления","nb-NO":"Ingen musikk å kontrollere","nn-NO":"Ingen musikk å kontrollere","pl-PL":"Brak muzyki do kontrolowania","pt-PT":"Sem música para controlar","af-ZA":"Geen musiek om te beheer nie","ar-SY":"لا توجد موسيقى للتحكم","bg-BG":"Няма музика за контрол","ca-ES":"No hi ha música per controlar","cs-CZ":"Žádná hudba k ovládání","el-GR":"Δεν υπάρχει μουσική για έλεγχο","et-EE":"Pole muusikat, mida juhtida","fa-IR":"موسیقی برای کنترل وجود ندارد","fi-FI":"Ei ohjattavaa musiikkia","he-IL":"אין מוזיקה לשליטה","hr-xx":"Nema glazbe za kontrolu","hu-HU":"Nincs irányítható zene","hy-AM":"Կառավարելու երաժշտություն չկա","id-ID":"Tidak ada musik yang bisa dikontrol","is-IS":"Engin tónlist til að stjórna","lb-xx":"Keng Musek ze kontrolléieren","lt-LT":"Nėra muzikos, kurią būtų galima valdyti","ro-RO":"Fără muzică de controlat","sk-SK":"Žiadna hudba na ovládanie","sl-SI":"Ni glasbe za nadzor","sv-SE":"Ingen musik att kontrollera","th-TH":"ไม่มีเพลงที่จะควบคุม","tr-TR":"Kontrol edilecek müzik yok","uk-UA":"Немає музики для керування","vi-VN":"Không có âm nhạc để kiểm soát","zh-CN":"没有音乐可以控制","zh-TW":"沒有音樂可以控制"},"on":{"en-US":"On","de-DE":"An"},"off":{"en-US":"Off","de-DE":"Aus"},"seek":{"en-US":"Seek","de-DE":"Suchen"},"crossfade":{"en-US":"Crossfade","de-DE":"Überblenden"},"tools":{"en-US":"Tools","de-DE":"Tools"},"speaker":{"en-US":"Speakerlist","de-DE":"Wiedergabegeräte","nl-NL":"Afspeelapparaten","da-DK":"Afspilningsenheder","es-ES":"Dispositivos de reproducción","fr-FR":"Lecteurs de musique","it-IT":"Appareils à playback","ru-RU":"Устройства воспроизведения","nb-NO":"Avspillingsenheter","nn-NO":"Avspillingsenheter","pl-PL":"Urządzenia do odtwarzania","pt-PT":"Dispositivos de reprodução","af-ZA":"Afspeel toestelle","ar-SY":"تشغيل الأجهزة","bg-BG":"Устройства за възпроизвеждане","ca-ES":"Dispositius de reproducció","cs-CZ":"Přehrávací zařízení","el-GR":"Συσκευές αναπαραγωγής","et-EE":"Taasesitusseadmed","fa-IR":"دستگاه های پخش","fi-FI":"Toistolaitteet","he-IL":"מכשירי השמעה","hr-xx":"Uređaji za reprodukciju","hu-HU":"Lejátszó eszközök","hy-AM":"Նվագարկման սարքեր","id-ID":"Perangkat pemutaran","is-IS":"Spilunartæki","lb-xx":"Playback Apparater","lt-LT":"Atkūrimo įrenginiai","ro-RO":"Dispozitive de redare","sk-SK":"Prehrávacie zariadenia","sl-SI":"Naprave za predvajanje","sv-SE":"Uppspelningsenheter","th-TH":"อุปกรณ์การเล่น","tr-TR":"Oynatma aygıtları","uk-UA":"Пристрої відтворення","vi-VN":"Thiết bị phát lại","zh-CN":"播放设备","zh-TW":"播放設備"},"playlist":{"en-US":"Playlist","de-DE":"Wiedergabeliste","nl-NL":"afspeellijst","da-DK":"afspilningsliste","es-ES":"Lista de reproducción","fr-FR":"Playlist","it-IT":"elenco di riproduzione","ru-RU":"Плейлист","nb-NO":"Spilleliste","nn-NO":"Spilleliste","pl-PL":"Lista odtwarzania","pt-PT":"Lista de reprodução","af-ZA":"Snitlys","ar-SY":"قائمة التشغيل","bg-BG":"Плейлист","ca-ES":"Llista de reproducció","cs-CZ":"Seznam skladeb","el-GR":"Λίστα αναπαραγωγής","et-EE":"Esitusloend","fa-IR":"لیست پخش","fi-FI":"Soittolista","he-IL":"רשימת השמעה","hr-xx":"Popis pjesama","hu-HU":"lejátszási lista","hy-AM":"Երգացանկ","id-ID":"Daftar putar","is-IS":"Lagalisti","lb-xx":"Playlist","lt-LT":"Grojaraštis","ro-RO":"Lista de redare","sk-SK":"Zoznam skladieb","sl-SI":"Seznam predvajanja","sv-SE":"Spellista","th-TH":"เพลย์ลิสต์","tr-TR":"Çalma listesi","uk-UA":"Список відтворення","vi-VN":"Danh sách phát","zh-CN":"播放列表","zh-TW":"播放清單"},"tracklist":{"en-US":"Tracklist","de-DE":"Titelliste","nl-NL":"Tracklijst","da-DK":"Sporliste","es-ES":"Lista de pistas","fr-FR":"Liste des pistes","it-IT":"Elenco dei brani","ru-RU":"Список треков","nb-NO":"Sporliste","nn-NO":"Sporliste","pl-PL":"Lista utworów","pt-PT":"Tracklist","af-ZA":"Snitlys","ar-SY":"قائمة المسار","bg-BG":"Списък с песни","ca-ES":"Llista de pistes","cs-CZ":"Seznam skladeb","el-GR":"Λίστα κομματιών","et-EE":"Lugude loend","fa-IR":"لیست آهنگ","fi-FI":"Kappaleluettelo","he-IL":"רשימת רצועות","hr-xx":"Popis pjesama","hu-HU":"Számlista","hy-AM":"Հետևողների ցուցակ","id-ID":"Daftar lagu","is-IS":"Lagalisti","lb-xx":"Streck Lëscht","lt-LT":"Kūrinių sąrašas","ro-RO":"Lista de urmărire","sk-SK":"Zoznam skladieb","sl-SI":"Seznam skladb","sv-SE":"Spårlista","th-TH":"รายการเพลง","tr-TR":"Parça listesi","uk-UA":"Список треків","vi-VN":"Danh sách theo dõi","zh-CN":"曲目列表","zh-TW":"曲目表"},"equalizer":{"en-US":"Equalizer","de-DE":"Equalizer","nl-NL":"Equalizer","da-DK":"Equalizer","es-ES":"Igualada","fr-FR":"Égaliseur","it-IT":"Equalizzatore","ru-RU":"Эквалайзер","nb-NO":"Equalizer","nn-NO":"Equalizer","pl-PL":"Wyrównywacz","pt-PT":"Equalizador","af-ZA":"Equalizer","ar-SY":"المعادل","bg-BG":"Еквалайзер","ca-ES":"Equalitzador","cs-CZ":"Ekvalizér","el-GR":"Εξισωτής","et-EE":"Ekvalaiser","fa-IR":"اکولایزر","fi-FI":"Taajuuskorjain","he-IL":"שַׁויָן","hr-xx":"Ekvilajzer","hu-HU":"Kiegyenlítő","hy-AM":"Հավասարիչ","id-ID":"Ekualiser","is-IS":"Tónjafnari","lb-xx":"Equalizer","lt-LT":"Ekvalaizeris","ro-RO":"Egalizator","sk-SK":"Ekvalizér","sl-SI":"Izenačevalnik","sv-SE":"Utjämnare","th-TH":"อีควอไลเซอร์","tr-TR":"Ekolayzer","uk-UA":"Еквалайзер","vi-VN":"Bộ chỉnh âm","zh-CN":"均衡器","zh-TW":"均衡器"},"favorites":{"en-US":"Favorites","de-DE":"Favoriten","nl-NL":"Favorieten","da-DK":"Favoritter","es-ES":"Favoritos","fr-FR":"Favoris","it-IT":"Preferiti","ru-RU":"Избранное","nb-NO":"Favoritter","nn-NO":"Favoritter","pl-PL":"Ulubione","pt-PT":"Favoritos","af-ZA":"Gunstelinge","ar-SY":"المفضلة","bg-BG":"Любими","ca-ES":"Preferits","cs-CZ":"Oblíbené","el-GR":"Αγαπημένα","et-EE":"Lemmikud","fa-IR":"موارد دلخواه","fi-FI":"Suosikit","he-IL":"מועדפים","hr-xx":"Favoriti","hu-HU":"Kedvencek","hy-AM":"Ֆավորիտներ","id-ID":"Favorit","is-IS":"Uppáhalds","lb-xx":"Favoritten","lt-LT":"Mėgstamiausi","ro-RO":"Favorite","sk-SK":"Obľúbené","sl-SI":"Priljubljene","sv-SE":"Favoriter","th-TH":"รายการโปรด","tr-TR":"Favoriler","uk-UA":"Вибране","vi-VN":"Yêu thích","zh-CN":"收藏夹","zh-TW":"收藏夾"},"no_speaker_found":{"en-US":"No Speaker found","de-DE":"Kein Lautsprecher gefunden","nl-NL":"Geen luidspreker gevonden","da-DK":"Ingen højttaler fundet","es-ES":"No se encontró ningún orador","fr-FR":"Aucun haut-parleur trouvé","it-IT":"Nessun altoparlante trovato","ru-RU":"Динамик не найден","nb-NO":"Ingen høyttaler funnet","nn-NO":"Ingen høyttaler funnet","pl-PL":"Nie znaleziono głośnika","pt-PT":"Nenhum alto-falante encontrado","af-ZA":"Geen spreker gevind nie","ar-SY":"لم يتم العثور على مكبر صوت","bg-BG":"Няма намерен високоговорител","ca-ES":"No s'ha trobat cap altaveu","cs-CZ":"Nebyl nalezen žádný reproduktor","el-GR":"Δεν βρέθηκε ηχείο","et-EE":"Kõlarit ei leitud","fa-IR":"بلندگو پیدا نشد","fi-FI":"Kaiutinta ei löytynyt","he-IL":"לא נמצא רמקול","hr-xx":"Govornik nije pronađen","hu-HU":"Nem található hangszóró","hy-AM":"Բարձրախոս չի գտնվել","id-ID":"Tidak ada pembicara yang ditemukan","is-IS":"Enginn hátalari fannst","lb-xx":"Kee Spriecher fonnt","lt-LT":"Garsiakalbis nerastas","ro-RO":"Nu a fost găsit niciun difuzor","sk-SK":"Nu a fost găsit niciun difuzor","sl-SI":"Ni zvočnika","sv-SE":"Ingen högtalare hittades","th-TH":"ไม่พบลำโพง","tr-TR":"Hoparlör bulunamadı","uk-UA":"Динамік не знайдено","vi-VN":"Không tìm thấy loa","zh-CN":"未找到扬声器","zh-TW":"未找到揚聲器"}}}
            • MichaelFM
              MichaelFM
              MichaelF
              #8049
              {"default":{"en-US":"englisch","de-DE":"deutsch","nl-NL":"niederländisch","da-DK":"dänisch","es-ES":"spanisch","fr-FR":"französisch","it-IT":"italienisch","ru-RU":"russisch","nb-NO":"norwegisch","nn-NO":"norwegisch","pl-PL":"polnisch","pt-PT":"portugiesisch","af-ZA":"africaans","ar-SY":"arabisch","bg-BG":"bulgarisch","ca-ES":"katalanisch","cs-CZ":"tschechisch","el-GR":"griechisch","et-EE":"estnisch","fa-IR":"persisch","fi-FI":"finnisch","he-IL":"hebräisch","hr-xx":"kroatisch","hu-HU":"ungarisch","hy-AM":"armenisch","id-ID":"indonesisch","is-IS":"isländisch","lb-xx":"luxemburgisch","lt-LT":"litauisch","ro-RO":"rumänisch","sk-SK":"slowakisch","sl-SI":"slowenisch","sv-SE":"schwedisch","th-TH":"thailändisch","tr-TR":"türkisch","uk-UA":"ukrainisch","vi-VN":"vietnamesisch","zh-CN":"chinesischSimp","zh-TW":"chinesischTrad"},"service_menu":{"en-US":"Service Menu","de-DE":"Service Menü","nl-NL":"Servicemenu","da-DK":"Service menu","es-ES":"Menú de servicio","fr-FR":"Menu des services","it-IT":"Menù di servizio","ru-RU":"Сервисное меню","nb-NO":"Servicemeny","nn-NO":"Servicemeny","pl-PL":"Menu serwisowe","pt-PT":"Menu de serviço","af-ZA":"Diens Spyskaart","ar-SY":"قائمة الخدمة","bg-BG":"Сервизно меню","ca-ES":"Menú de servei","cs-CZ":"Servisní menu","el-GR":"Μενού υπηρεσίας","et-EE":"Teenindusmenüü","fa-IR":"منوی خدمات","fi-FI":"Palveluvalikko","he-IL":"תפריט שירות","hr-xx":"Servisni izbornik","hu-HU":"Szerviz menü","hy-AM":"Ծառայության մենյու","id-ID":"Menu Layanan","is-IS":"Þjónustumatseðill","lb-xx":"Service Menu","lt-LT":"Aptarnavimo meniu","ro-RO":"Meniul de servicii","sk-SK":"Servisné menu","sl-SI":"Servisni meni","sv-SE":"Servicemeny","th-TH":"เมนูบริการ","tr-TR":"Servis Menüsü","uk-UA":"Сервісне меню","vi-VN":"Thực đơn dịch vụ","zh-CN":"服务菜单","zh-TW":"服務選單"},"service_pages":{"en-US":"Service Pages","de-DE":"Service Seiten","nl-NL":"Servicepagina's","da-DK":"Service sider","es-ES":"Páginas de servicio","fr-FR":"Pages de services","it-IT":"Pagine di servizio","ru-RU":"Страницы услуг","nb-NO":"Tjenestesider","nn-NO":"Tjenestesider","pl-PL":"Strony serwisowe","pt-PT":"Páginas de serviço","af-ZA":"Diensbladsye","ar-SY":"صفحات الخدمة","bg-BG":"Сервизни страници","ca-ES":"Pàgines de servei","cs-CZ":"Servisní stránky","el-GR":"Σελίδες υπηρεσίας","et-EE":"Teeninduslehed","fa-IR":"صفحات خدمات","fi-FI":"Palvelusivut","he-IL":"דפי שירות","hr-xx":"Stranice usluga","hu-HU":"Szolgáltatási oldalak","hy-AM":"Ծառայությունների էջեր","id-ID":"Halaman Layanan","is-IS":"Þjónustusíður","lb-xx":"Service Säiten","lt-LT":"Paslaugų puslapiai","ro-RO":"Pagini de servicii","sk-SK":"Servisné stránky","sl-SI":"Storitvene strani","sv-SE":"Servicesidor","th-TH":"หน้าบริการ","tr-TR":"Hizmet Sayfaları","uk-UA":"Сервісні сторінки","vi-VN":"Trang dịch vụ","zh-CN":"服务页面","zh-TW":"服務頁面"},"more":{"en-US":"more...","de-DE":"mehr...","nl-NL":"meer...","da-DK":"mere...","es-ES":"más...","fr-FR":"plus...","it-IT":"più...","ru-RU":"более...","nb-NO":"mer...","nn-NO":"mer...","pl-PL":"więcej...","pt-PT":"mais...","af-ZA":"meer...","ar-SY":"أ...كثر","bg-BG":"Повече","ca-ES":"més","cs-CZ":"více","el-GR":"περισσότερο...","et-EE":"rohkem...","fa-IR":"ب...یشتر","fi-FI":"lisää...","he-IL":"יותר...","hr-xx":"više...","hu-HU":"több...","hy-AM":"ավելին...","id-ID":"lagi...","is-IS":"meira...","lb-xx":"méi...","lt-LT":"daugiau...","ro-RO":"mai...","sk-SK":"viac...","sl-SI":"več...","sv-SE":"Mer...","th-TH":"มากกว่า...","tr-TR":"Daha...","uk-UA":"більше...","vi-VN":"hơn...","zh-CN":"更多的...","zh-TW":"更多的..."},"start":{"en-US":"start","de-DE":"Start","nl-NL":"begin","da-DK":"Start","es-ES":"comenzar","fr-FR":"commencer","it-IT":"inizio","ru-RU":"начинать","nb-NO":"start","nn-NO":"start","pl-PL":"początek","pt-PT":"começar","af-ZA":"begin","ar-SY":"يبدأ","bg-BG":"започнете","ca-ES":"començar","cs-CZ":"Start","el-GR":"αρχή","et-EE":"alustada","fa-IR":"شروع کنید","fi-FI":"alkaa","he-IL":"הַתחָלָה","hr-xx":"početak","hu-HU":"Rajt","hy-AM":"սկսել","id-ID":"awal","is-IS":"byrja","lb-xx":"ufänken","lt-LT":"pradėti","ro-RO":"start","sk-SK":"začať","sl-SI":"začetek","sv-SE":"Start","th-TH":"เริ่ม","tr-TR":"başlangıç","uk-UA":"почати","vi-VN":"bắt đầu","zh-CN":"开始","zh-TW":"開始"},"infos":{"en-US":"Infos","de-DE":"Infos","nl-NL":"Info","da-DK":"Infos","es-ES":"Información","fr-FR":"Infos","it-IT":"Informazioni","ru-RU":"Информацияю","Info":"Servicemeny","pl-PL":"Informacje","pt-PT":"Informações","af-ZA":"Inligting","ar-SY":"قائمعلومات","bg-BG":"Информацияю","ca-ES":"Infos","cs-CZ":"Informace","el-GR":"Πληροφορίεςς","et-EE":"Teave","fa-IR":"اطلاعات","fi-FI":"Tietoja","he-IL":"מידע","hr-xx":"Infos","hu-HU":"Infos","hy-AM":"Տեղեկություններ","id-ID":"Menu Layanan","is-IS":"informasi","lb-xx":"Infos","lt-LT":"Informacija","ro-RO":"Informații","sk-SK":"Informácie","sl-SI":"Infos","sv-SE":"Info","th-TH":"ข้อมูลการ","tr-TR":"Bilgiler","uk-UA":"Інформаціяю","vi-VN":"Thông tin","zh-CN":"信息","zh-TW":"資訊"},"settings":{"en-US":"Settings","de-DE":"Einstellungen","nl-NL":"Instellingen","da-DK":"Indstillinger","es-ES":"Ajustes","fr-FR":"Paramètres","it-IT":"Impostazioni","ru-RU":"Настройки","nb-NO":"Innstillinger","nn-NO":"Innstillinger","pl-PL":"Ustawienia","pt-PT":"Configurações","af-ZA":"Instellings","ar-SY":"إعدادات","bg-BG":"Настройки","ca-ES":"Configuració","cs-CZ":"Nastavení","el-GR":"Ρυθμίσεις","et-EE":"Seaded","fa-IR":"تنظیمات","fi-FI":"asetukset","he-IL":"הגדרות","hr-xx":"postavke","hu-HU":"Beállítások","hy-AM":"Կարգավորումներ","id-ID":"Pengaturan","is-IS":"Stillingar","lb-xx":"Astellungen","lt-LT":"Nustatymai","ro-RO":"Setări","sk-SK":"nastavenie","sl-SI":"nastavitve","sv-SE":"inställningar","th-TH":"การตั้งค่า","tr-TR":"Ayarlar","uk-UA":"Налаштування","vi-VN":"Cài đặt","zh-CN":"设置","zh-TW":"設定"},"firmware":{"en-US":"Firmware","de-DE":"Firmware","nl-NL":"Firmware","da-DK":"Firmware","es-ES":"firmware","fr-FR":"Micrologiciel","it-IT":"Firmware","ru-RU":"Прошивка","nb-NO":"Fastvare","nn-NO":"Fastvare","pl-PL":"Oprogramowanie","pt-PT":"Firmware","af-ZA":"Firmware","ar-SY":"البرامج الثابتة","bg-BG":"фърмуер","ca-ES":"Firmware","cs-CZ":"Firmware","el-GR":"Υλικολογισμικό","et-EE":"Püsivara","fa-IR":"سیستم عامل","fi-FI":"Laiteohjelmisto","he-IL":"קושחה","hr-xx":"Firmware","hu-HU":"Firmware","hy-AM":"Որոնվածը","id-ID":"Firmware","is-IS":"Firmware","lb-xx":"Firmware","lt-LT":"Firmware","ro-RO":"Firmware","sk-SK":"Firmvér","sl-SI":"Firmware","sv-SE":"Firmware","th-TH":"เฟิร์มแวร์","tr-TR":"Firmware์","uk-UA":"Прошивка","vi-VN":"Phần sụn","zh-CN":"固件","zh-TW":"韌體"},"reboot":{"en-US":"Reboot","de-DE":"Reboot NSPanel","nl-NL":"Start opnieuw op","da-DK":"Genstart","es-ES":"Reiniciar","fr-FR":"Redémarrer","it-IT":"Riavviare","ru-RU":"Перезагрузить","nb-NO":"Start på nytt","nn-NO":"Start på nytt","pl-PL":"Ponowne uruchomienie","pt-PT":"Reinício","af-ZA":"Herlaai","ar-SY":"اعادة التشغيل","bg-BG":"Рестартирайте","ca-ES":"Reinicieu","cs-CZ":"Restartujte","el-GR":"Επανεκκίνηση","et-EE":"Taaskäivitage","fa-IR":"راه اندازی مجدد","fi-FI":"Käynnistä uudelleen","he-IL":"לְאַתחֵל","hr-xx":"Ponovno pokretanje","hu-HU":"Indítsa újra","hy-AM":"Վերագործարկեք","id-ID":"Menyalakan ulang","is-IS":"Endurræstu","lb-xx":"Neistarten","lt-LT":"Perkraukite","ro-RO":"Reporniți","sk-SK":"Reštartovať","sl-SI":"Znova zaženite","sv-SE":"Starta om","th-TH":"รีบูต","tr-TR":"Yeniden başlat","uk-UA":"Перезавантаження","vi-VN":"Khởi động lại","zh-CN":"重启","zh-TW":"重啟"},"sensors1":{"en-US":"Sensors (1)","de-DE":"Sensoren (1)","nl-NL":"Sensoren (1)","da-DK":"Sensorer (1)","es-ES":"Sensores (1)","fr-FR":"Capteurs (1)","it-IT":"Sensori (1)","ru-RU":"Датчики (1)","nb-NO":"Sensorer (1)","nn-NO":"Sensorer (1)","pl-PL":"Czujniki (1)","pt-PT":"Sensores (1)","af-ZA":"Sensors (1)","ar-SY":"مجسات (1)","bg-BG":"Сензори (1)","ca-ES":"Sensors (1)","cs-CZ":"Senzory (1)","el-GR":"Αισθητήρες (1)","et-EE":"Andurid (1)","fa-IR":"حسگرها (1)","fi-FI":"Anturit (1)","he-IL":"חיישנים (1)","hr-xx":"Senzori (1)","hu-HU":"Érzékelők (1)","hy-AM":"Սենսորներ (1)","id-ID":"Sensor (1)","is-IS":"Skynjarar (1)","lb-xx":"Sensoren (1)","lt-LT":"Jutikliai (1)","ro-RO":"Senzori (1)","sk-SK":"Senzory (1)","sl-SI":"Senzorji (1)","sv-SE":"Sensorer (1)","th-TH":"เซนเซอร์ (1)","tr-TR":"Sensörler (1)","uk-UA":"Датчики (1)","vi-VN":"Cảm biến (1)","zh-CN":"传感器 (1)","zh-TW":"感測器 (1)"},"hardware2":{"en-US":"Hardware (2)","de-DE":"Hardware (2)","nl-NL":"Hardware (2)","da-DK":"Hardware (2)","es-ES":"Hardware (2)","fr-FR":"Matériel (2)","it-IT":"Hardware (2)","ru-RU":"Аппаратное обеспечение (2)","nb-NO":"Maskinvare (2)","nn-NO":"Maskinvare (2)","pl-PL":"Sprzęt (2)","pt-PT":"Hardware (2)","af-ZA":"Hardware (2)","ar-SY":"الأجهزة (2)","bg-BG":"Хардуер (2)","ca-ES":"Maquinari (2)","cs-CZ":"Hardware (2)","el-GR":"Υλικό (2)","et-EE":"riistvara (2)","fa-IR":"سخت افزار (2)","fi-FI":"Laitteisto (2)","he-IL":"חומרה (2)","hr-xx":"Hardver (2)","hu-HU":"Hardver (2)","hy-AM":"Սարքավորումներ (2)","id-ID":"Perangkat Keras (2)","is-IS":"Vélbúnaður (2)","lb-xx":"Hardware (2)","lt-LT":"Aparatūra (2)","ro-RO":"Hardware (2)","sk-SK":"Hardvér (2)","sl-SI":"Strojna oprema (2)","sv-SE":"Hårdvara (2)","th-TH":"ฮาร์ดแวร์ (2)์","tr-TR":"Donanım (2)","uk-UA":"Обладнання (2)","vi-VN":"Phần cứng (2)","zh-CN":"硬件 (2)","zh-TW":"硬體 (2)"},"sensors_hardware":{"en-US":"Sensors/Hardware","de-DE":"Sensoren/Hardware","nl-NL":"Sensoren/Hardware","da-DK":"Sensorer/Hardware","es-ES":"Sensores/Hardware","fr-FR":"Capteurs/Matériel","it-IT":"Sensori/Hardware","ru-RU":"Датчики/Оборудование","nb-NO":"Sensorer/maskinvare","nn-NO":"Sensorer/maskinvare","pl-PL":"Czujniki/sprzęt","pt-PT":"Sensores/Hardware","af-ZA":"Sensors/Hardware","ar-SY":"أجهزة الاستشعار/الأجهزة","bg-BG":"Сензори/хардуер","ca-ES":"Sensors/Maquinari","cs-CZ":"Senzory/Hardware","el-GR":"Αισθητήρες/Υλικό","et-EE":"Andurid/riistvara","fa-IR":"سنسور/سخت افزار","fi-FI":"Anturit/laitteisto","he-IL":"חיישנים/חומרה","hr-xx":"Senzori/Hardver","hu-HU":"Érzékelők/Hardver","hy-AM":"Սենսորներ / Սարքավորումներ","id-ID":"Sensor/Perangkat Keras","is-IS":"Skynjarar/vélbúnaður","lb-xx":"Sensoren / Hardware","lt-LT":"Jutikliai / aparatūra","ro-RO":"Senzori/Hardware","sk-SK":"Senzory/Hardvér","sl-SI":"Senzorji/strojna oprema","sv-SE":"Sensorer/Hårdvara","th-TH":"เซนเซอร์/ฮาร์ดแวร์","tr-TR":"Sensörler/Donanım","uk-UA":"Датчики/Апаратне забезпечення","vi-VN":"Cảm biến/Phần cứng","zh-CN":"传感器/硬件","zh-TW":"感測器/硬體"},"refresh":{"en-US":"Refresh","de-DE":"Aktualisierung","nl-NL":"Vernieuwen","da-DK":"Opdater","es-ES":"Actualizar","fr-FR":"Rafraîchir","it-IT":"ricaricare","ru-RU":"Обновить","nb-NO":"Forfriske","nn-NO":"Forfriske","pl-PL":"Odświeżać","pt-PT":"Atualizar","af-ZA":"Verfris","ar-SY":"ينعش","bg-BG":"Опресняване","ca-ES":"Actualització","cs-CZ":"Obnovit","el-GR":"Φρεσκάρω","et-EE":"Värskenda","fa-IR":"تازه کردن","fi-FI":"virkistää","he-IL":"לְרַעֲנֵן","hr-xx":"Osvježiti","hu-HU":"Frissítés","hy-AM":"Թարմացնել","id-ID":"Menyegarkan","is-IS":"Endurnýja","lb-xx":"Erfrëschen","lt-LT":"Atnaujinti","ro-RO":"Reîmprospăta","sk-SK":"Obnoviť","sl-SI":"Osveži","sv-SE":"Uppdatera","th-TH":"รีเฟรช","tr-TR":"Yenile","uk-UA":"Оновити","vi-VN":"Làm cho khỏe lại","zh-CN":"刷新","zh-TW":"重新整理"},"room_temperature":{"en-US":"Room Temperature","de-DE":"Raum-Temperatur","nl-NL":"Kamertemperatuur","da-DK":"Stuetemperatur","es-ES":"Temperatura ambiente","fr-FR":"Température ambiante","it-IT":"Temperatura ambiente","ru-RU":"Комнатная температура","nb-NO":"Romtemperatur","nn-NO":"Romtemperatur","pl-PL":"Temperatura pokojowa","pt-PT":"Temperatura do quarto","af-ZA":"Kamertemperatuur","ar-SY":"درجة حرارة الغرفة","bg-BG":"Стайна температура","ca-ES":"Temperatura ambient","cs-CZ":"Pokojová teplota","el-GR":"Θερμοκρασία δωματίου","et-EE":"Toatemperatuuril","fa-IR":"دمای اتاق","fi-FI":"Huonelämpötila","he-IL":"טמפרטורת חדר","hr-xx":"Sobna temperatura","hu-HU":"Szobahőmérséklet","hy-AM":"Սենյակի ջերմաստիճան","id-ID":"Suhu kamar","is-IS":"Stofuhiti","lb-xx":"Raumtemperatur","lt-LT":"Kambario temperatūra","ro-RO":"Temperatura camerei","sk-SK":"Izbová teplota","sl-SI":"Sobna temperatura","sv-SE":"Rumstemperatur","th-TH":"อุณหภูมิห้อง","tr-TR":"Oda sıcaklığı","uk-UA":"Кімнатна температура","vi-VN":"Nhiệt độ phòng","zh-CN":"室内温度","zh-TW":"室內溫度"},"esp_temperature":{"en-US":"ESP Temperature","de-DE":"ESP-Temperatur","nl-NL":"ESP-temperatuur","da-DK":"ESP temperatur","es-ES":"Temperatura ESP","fr-FR":"Température ESP","it-IT":"Temperatura ESP","ru-RU":"Температура ЭЦН","nb-NO":"ESP temperatur","nn-NO":"ESP temperatur","pl-PL":"Temperatura ESP","pt-PT":"Temperatura ESP","af-ZA":"ESP temperatuur","ar-SY":"درجة حرارة ESP","bg-BG":"ESP температура","ca-ES":"Temperatura ESP","cs-CZ":"Teplota ESP","el-GR":"Θερμοκρασία ESP","et-EE":"ESP temperatuur","fa-IR":"دمای ESP","fi-FI":"ESP lämpötila","he-IL":"טמפרטורת ESP","hr-xx":"ESP temperatura","hu-HU":"ESP hőmérséklet","hy-AM":"ESP ջերմաստիճան","id-ID":"Suhu ESP","is-IS":"ESP hitastig","lb-xx":"ESP Temperatur","lt-LT":"ESP temperatūra","ro-RO":"Temperatura ESP","sk-SK":"Teplota ESP","sl-SI":"Temperatura ESP","sv-SE":"ESP temperatur","th-TH":"อุณหภูมิอีเอสพี","tr-TR":"ESP Sıcaklığı","uk-UA":"Температура ESP","vi-VN":"Nhiệt độ ESP","zh-CN":"静电除尘器温度","zh-TW":"靜電除塵器溫度"},"temperature_unit":{"en-US":"Temperature unit","de-DE":"Temperatur Einheit","nl-NL":"Temperatuureenheid","da-DK":"Temperaturenhed","es-ES":"Unidad de temperatura","fr-FR":"Unité de température","it-IT":"Unità di temperatura","ru-RU":"Единица измерения температуры","nb-NO":"Temperaturenhet","nn-NO":"Temperaturenhet","pl-PL":"Jednostka temperatury","pt-PT":"Unidade de temperatura","af-ZA":"Temperatuur eenheid","ar-SY":"درجة الحرارة وحدة","bg-BG":"Температурна единица","ca-ES":"Unitat de temperatura","cs-CZ":"Jednotka teploty","el-GR":"Μονάδα θερμοκρασίας","et-EE":"Temperatuuri ühik","fa-IR":"واحد دما","fi-FI":"Lämpötilayksikkö","he-IL":"יחידת טמפרטורה","hr-xx":"Jedinica za temperaturu","hu-HU":"Hőmérséklet mértékegysége","hy-AM":"Ջերմաստիճանի միավոր","id-ID":"Satuan suhu","is-IS":"Hitastigseining","lb-xx":"Temperatur Eenheet","lt-LT":"Temperatūros vienetas","ro-RO":"Unitate de temperatură","sk-SK":"Jednotka teploty","sl-SI":"Temperaturna enota","sv-SE":"Temperaturenhet","th-TH":"หน่วยอุณหภูมิ","tr-TR":"Sıcaklık birimi","uk-UA":"Одиниця вимірювання температури","vi-VN":"Đơn vị nhiệt độ","zh-CN":"温度单位","zh-TW":"溫度單位"},"screensaver":{"en-US":"Screensaver","de-DE":"Screensaver","nl-NL":"Screensaver","da-DK":"Pauseskærm","es-ES":"Protector de pantalla","fr-FR":"Économiseur d'écran","it-IT":"Salvaschermo","ru-RU":"Заставка","nb-NO":"Skjermsparer","nn-NO":"Skjermsparer","pl-PL":"Wygaszacz ekranu","pt-PT":"Protetor de tela","af-ZA":"Skermbeveiliging","ar-SY":"شاشة التوقف","bg-BG":"Скрийнсейвър","ca-ES":"Salvapantalles","cs-CZ":"Spořič obrazovky","el-GR":"Προφύλαξη οθόνης","et-EE":"Ekraanisäästja","fa-IR":"محافظ صفحه نمایش","fi-FI":"Näytönsäästäjä","he-IL":"שומר מסך","hr-xx":"Čuvar zaslona","hu-HU":"Képernyőkímélő","hy-AM":"Էկրանապահիչ","id-ID":"Screen saver","is-IS":"Skjáhvíla","lb-xx":"Screensaver","lt-LT":"Ekrano užsklanda","ro-RO":"Screen saver","sk-SK":"Šetrič obrazovky","sl-SI":"Ohranjevalnik zaslona","sv-SE":"Skärmsläckare","th-TH":"สกรีนเซฟเวอร์","tr-TR":"Ekran koruyucusu","uk-UA":"Заставка","vi-VN":"Bảo vệ màn hình","zh-CN":"屏幕保护程序","zh-TW":"螢幕保護程式"},"product":{"en-US":"Product","de-DE":"Produkt","nl-NL":"Product","da-DK":"Produkt","es-ES":"Producto","fr-FR":"Produit","it-IT":"Prodotto","ru-RU":"Продукт","nb-NO":"Produkt","nn-NO":"Produkt","pl-PL":"Produkt","pt-PT":"produtos","af-ZA":"Produk","ar-SY":"منتج","bg-BG":"Продукт","ca-ES":"Producte","cs-CZ":"Produkt","el-GR":"Προϊόν","et-EE":"Toode","fa-IR":"تولید - محصول","fi-FI":"Tuote","he-IL":"מוצר","hr-xx":"Proizvod","hu-HU":"Termék","hy-AM":"Արտադրանք","id-ID":"Produk","is-IS":"Vara","lb-xx":"Produit","lt-LT":"Produktas","ro-RO":"Produs","sk-SK":"Produkt","sl-SI":"Izdelek","sv-SE":"Produkt","th-TH":"ผลิตภัณฑ์","tr-TR":"Ürün","uk-UA":"Продукт","vi-VN":"Sản phẩm","zh-CN":"产品","zh-TW":"產品"},"operating_time":{"en-US":"Operating time","de-DE":"Betriebszeit","nl-NL":"Bedrijfstijd","da-DK":"Driftstid","es-ES":"Tiempo operacional","fr-FR":"Temps de fonctionnement","it-IT":"Tempo di operatività","ru-RU":"Время работы","nb-NO":"Operasjonstid","nn-NO":"Operasjonstid","pl-PL":"Czas operacyjny","pt-PT":"Tempo operacional","af-ZA":"Bedryfstyd","ar-SY":"وقت التشغيل","bg-BG":"Време на работа","ca-ES":"Temps de funcionament","cs-CZ":"Provozní doba","el-GR":"Χρόνος λειτουργίας","et-EE":"Tööaeg","fa-IR":"زمان عملیات","fi-FI":"Toiminta-aika","he-IL":"זמן הפעלה","hr-xx":"Vrijeme rada","hu-HU":"Üzemelési idő","hy-AM":"Գործող ժամանակ","id-ID":"Waktu pengoperasian","is-IS":"Rekstrartími","lb-xx":"Operatioun Zäit","lt-LT":"Veikimo laikas","ro-RO":"Timp de funcționare","sk-SK":"Prevádzkový čas","sl-SI":"Čas delovanja","sv-SE":"Drifttid","th-TH":"เวลาทำการ","tr-TR":"Operasyon zamanı","uk-UA":"Час роботи","vi-VN":"Thời gian hoạt động","zh-CN":"工作时间","zh-TW":"工作時間"},"ip_address":{"en-US":"IP address","de-DE":"IP-Adresse","nl-NL":"IP adres","da-DK":"IP-adresse","es-ES":"dirección IP","fr-FR":"Adresse IP","it-IT":"indirizzo IP","ru-RU":"айпи адрес","nb-NO":"IP adresse","nn-NO":"IP adresse","pl-PL":"adres IP","pt-PT":"endereço de IP","af-ZA":"IP adres","ar-SY":"عنوان IP","bg-BG":"IP адрес","ca-ES":"adreça IP","cs-CZ":"IP adresa","el-GR":"διεύθυνση IP","et-EE":"IP-aadress","fa-IR":"آدرس آی پی","fi-FI":"IP-osoite","he-IL":"כתובת ה - IP","hr-xx":"IP adresa","hu-HU":"IP-cím","hy-AM":"IP հասցե","id-ID":"alamat IP","is-IS":"IP tölu","lb-xx":"IP Adress","lt-LT":"IP adresas","ro-RO":"adresa IP","sk-SK":"IP adresa","sl-SI":"IP naslov","sv-SE":"IP-adress","th-TH":"ที่อยู่ IP","tr-TR":"IP adresi","uk-UA":"IP-адреса","vi-VN":"địa chỉ IP","zh-CN":"IP地址","zh-TW":"IP位址"},"mac_address":{"en-US":"MAC address","de-DE":"MAC-Adresse","nl-NL":"MAC adres","da-DK":"MAC-adresse","es-ES":"Dirección MAC","fr-FR":"Adresse MAC","it-IT":"Indirizzo MAC","ru-RU":"MAC-адрес","nb-NO":"MAC-adresse","nn-NO":"MAC-adresse","pl-PL":"Adres MAC","pt-PT":"Endereço MAC","af-ZA":"MAC adres","ar-SY":"عنوان ماك","bg-BG":"Мак адрес","ca-ES":"Adreça MAC","cs-CZ":"MAC adresa","el-GR":"Διεύθυνση MAC","et-EE":"MAC-aadress","fa-IR":"آدرس مک","fi-FI":"Mac osoite","he-IL":"כתובת MAC","hr-xx":"MAC adresa","hu-HU":"MAC cím","hy-AM":"MAC հասցեն","id-ID":"Alamat MAC","is-IS":"MAC heimilisfang","lb-xx":"MAC Adress","lt-LT":"MAC adresas","ro-RO":"Adresa MAC","sk-SK":"MAC adresa","sl-SI":"MAC naslov","sv-SE":"MAC-adress","th-TH":"หมายเลขทางกายภาพ","tr-TR":"MAC Adresi","uk-UA":"MAC cím","vi-VN":"Địa chỉ MAC","zh-CN":"MAC地址","zh-TW":"MAC位址"},"wifi_signal":{"en-US":"Wifi signal","de-DE":"Wifi-Signal","nl-NL":"Wifi-signaal","da-DK":"Wifi signal","es-ES":"señal wifi","fr-FR":"Signal Wi-Fi","it-IT":"Segnale Wi-Fi","ru-RU":"сигнал Wi-Fi","nb-NO":"Wifi-signal","nn-NO":"Wifi-signal","pl-PL":"Sygnał Wi-Fi","pt-PT":"Sinal Wi-Fi","af-ZA":"Wifi sein","ar-SY":"إشارة واي فاي","bg-BG":"Wifi сигнал","ca-ES":"Senyal wifi","cs-CZ":"Wifi signál","el-GR":"Σήμα Wi-Fi","et-EE":"Wifi signaal","fa-IR":"سیگنال وای فای","fi-FI":"Wifi signaali","he-IL":"אות Wifi","hr-xx":"Wifi signal","hu-HU":"Wifi jel","hy-AM":"Wifi ազդանշան","id-ID":"Sinyal Wi-Fi","is-IS":"Wifi merki","lb-xx":"Wifi Signal","lt-LT":"Wifi signalas","ro-RO":"Semnal Wifi","sk-SK":"Wifi signál","sl-SI":"Wifi signal","sv-SE":"Wifi-signal","th-TH":"สัญญาณไวไฟ","tr-TR":"Wi-Fi sinyali","uk-UA":"Wi-Fi сигнал","vi-VN":"Tín hiệu wifi","zh-CN":"无线网络信号","zh-TW":"無線網路訊號"},"rssi":{"en-US":"RSSI","de-DE":"RSSI","nl-NL":"RSSI","da-DK":"RSSI","es-ES":"RSSI","fr-FR":"RSSI","it-IT":"RSSI","ru-RU":"РССИ","nb-NO":"RSSI","nn-NO":"RSSI","pl-PL":"RSSI","pt-PT":"RSSI","af-ZA":"RSSI","ar-SY":"آر إس إس آي","bg-BG":"RSSI","ca-ES":"RSSI","cs-CZ":"RSSI","el-GR":"RSSI","et-EE":"RSSI","fa-IR":"RSSI","fi-FI":"RSSI","he-IL":"RSSI","hr-xx":"RSSI","hu-HU":"RSSI","hy-AM":"RSSI","id-ID":"RSSI","is-IS":"RSSI","lb-xx":"RSSI","lt-LT":"RSSI","ro-RO":"RSSI","sk-SK":"RSSI","sl-SI":"RSSI","sv-SE":"RSSI","th-TH":"อาร์เอสเอสไอ","tr-TR":"RSSI","uk-UA":"RSSI","vi-VN":"RSSI","zh-CN":"接收信号强度指数","zh-TW":"接收訊號強度指數"},"mode":{"en-US":"Mode","de-DE":"Modus","nl-NL":"Modus","da-DK":"Mode","es-ES":"Modo","fr-FR":"Mode","it-IT":"Modalità","ru-RU":"Режим","nb-NO":"Modus","nn-NO":"Modus","pl-PL":"Tryb","pt-PT":"Modo","af-ZA":"Wyse","ar-SY":"وضع","bg-BG":"Режим","ca-ES":"Mode","cs-CZ":"Režim","el-GR":"Τρόπος","et-EE":"Režiim","fa-IR":"حالت","fi-FI":"tila","he-IL":"מצב","hr-xx":"Način rada","hu-HU":"Mód","hy-AM":"Ռեժիմ","id-ID":"Mode","is-IS":"Mode","lb-xx":"Modus","lt-LT":"Režimas","ro-RO":"Modul","sk-SK":"Režim","sl-SI":"Način","sv-SE":"Läge","th-TH":"โหมด","tr-TR":"Mod","uk-UA":"Режим","vi-VN":"Cách thức","zh-CN":"模式","zh-TW":"模式"},"channel":{"en-US":"Channel","de-DE":"Kanal","nl-NL":"Kanaal","da-DK":"Kanal","es-ES":"Canal","fr-FR":"Canal","it-IT":"Canale","ru-RU":"Канал","nb-NO":"Kanal","nn-NO":"Kanal","pl-PL":"Kanał","pt-PT":"Canal","af-ZA":"Kanaal","ar-SY":"قناة","bg-BG":"Канал","ca-ES":"Canal","cs-CZ":"Kanál","el-GR":"Κανάλι","et-EE":"Kanal","fa-IR":"کانال","fi-FI":"kanava","he-IL":"עָרוּץ","hr-xx":"Kanal","hu-HU":"Csatorna","hy-AM":"Ալիք","id-ID":"Saluran","is-IS":"Rás","lb-xx":"Kanal","lt-LT":"Kanalas","ro-RO":"Canal","sk-SK":"kanál","sl-SI":"Kanal","sv-SE":"Kanal","th-TH":"ช่อง","tr-TR":"Kanal","uk-UA":"Канал","vi-VN":"Kênh","zh-CN":"渠道","zh-TW":"頻道"},"language":{"en-US":"Language","de-DE":"Sprache","nl-NL":"Taal","da-DK":"Sprog","es-ES":"Idioma","fr-FR":"Langue","it-IT":"Lingua","ru-RU":"Язык","nb-NO":"Språk","nn-NO":"Språk","pl-PL":"Język","pt-PT":"Linguagem","af-ZA":"Taal","ar-SY":"لغة","bg-BG":"език","ca-ES":"Llenguatge","cs-CZ":"Jazyk","el-GR":"Γλώσσα","et-EE":"Keel","fa-IR":"زبان","fi-FI":"Kieli","he-IL":"שפה","hr-xx":"Jezik","hu-HU":"Nyelv","hy-AM":"Լեզու","id-ID":"Bahasa","is-IS":"Tungumál","lb-xx":"Sprooch","lt-LT":"Kalba","ro-RO":"Limba","sk-SK":"Jazyk","sl-SI":"Jezik","sv-SE":"Språk","th-TH":"ภาษา","tr-TR":"Dil","uk-UA":"Мова","vi-VN":"Ngôn ngữ","zh-CN":"语言","zh-TW":"語言"},"relays":{"en-US":"Relays","de-DE":"Relais","nl-NL":"relais","da-DK":"Relæer","es-ES":"Relés","fr-FR":"Relais","it-IT":"Relè","ru-RU":"Реле","nb-NO":"Reléer","nn-NO":"Reléer","pl-PL":"Przekaźniki","pt-PT":"Relés","af-ZA":"Relais","ar-SY":"يمرر","bg-BG":"Релета","ca-ES":"Relleus","cs-CZ":"Relé","el-GR":"Ρελέ","et-EE":"Releed","fa-IR":"رله ها","fi-FI":"Releet","he-IL":"ממסרים","hr-xx":"Releji","hu-HU":"Relék","hy-AM":"Ռելեներ","id-ID":"Relai","is-IS":"Relays","lb-xx":"Relais","lt-LT":"Relės","ro-RO":"relee","sk-SK":"relé","sl-SI":"Releji","sv-SE":"Reläer","th-TH":"รีเลย์","tr-TR":"Röleler","uk-UA":"Реле","vi-VN":"Rơle","zh-CN":"继电器","zh-TW":"繼電器"},"weather":{"en-US":"Weather","de-DE":"Wetter","nl-NL":"Weer","da-DK":"Vejr","es-ES":"Clima","fr-FR":"Météo","it-IT":"Meteo","ru-RU":"Погода","nb-NO":"Vær","nn-NO":"Vær","pl-PL":"Pogoda","pt-PT":"Clima","af-ZA":"Weer","ar-SY":"طقس","bg-BG":"Времето","ca-ES":"El temps","cs-CZ":"Počasí","el-GR":"Καιρός","et-EE":"Ilm","fa-IR":"آب و هوا","fi-FI":"Sää","he-IL":"מזג אוויר","hr-xx":"Vrijeme","hu-HU":"Időjárás","hy-AM":"Եղանակ","id-ID":"Cuaca","is-IS":"Veður","lb-xx":"Wieder","lt-LT":"Orai","ro-RO":"Vreme","sk-SK":"Počasie","sl-SI":"Vreme","sv-SE":"Väder","th-TH":"สภาพอากาศ","tr-TR":"Hava durumu","uk-UA":"Погода","vi-VN":"Thời tiết","zh-CN":"天气","zh-TW":"天氣"},"info_iobroker":{"en-US":"ioBroker infos","de-DE":"ioBroker-Infos","nl-NL":"ioBroker-informatie","da-DK":"ioBroker info","es-ES":"Información ioBroker","fr-FR":"Inform sur ioBroker","it-IT":"Inform. su ioBroker","ru-RU":"информация ioBroker","nb-NO":"ioBroker info","nn-NO":"ioBroker info","pl-PL":"Informacje ioBroker","pt-PT":"Inform. do ioBroker","af-ZA":"ioBroker inligting","ar-SY":"معلومات ioBroker","bg-BG":"ioBroker информация","ca-ES":"Inform. de ioBroker","cs-CZ":"informace o ioBroker","el-GR":"Πληροφορίες ioBroker","et-EE":"ioBroker teave","fa-IR":"اطلاعات ioBroker","fi-FI":"ioBroker tiedot","he-IL":"מידע על ioBroker","hr-xx":"inform. o ioBroker","hu-HU":"ioBroker infó","hy-AM":"ioBroker տեղեկությունները","id-ID":"info ioBroker","is-IS":"ioBroker upplýsingar","lb-xx":"ioBroker Informatiounen","lt-LT":"ioBroker informacija","ro-RO":"Informații ioBroker","sk-SK":"inform. o ioBroker","sl-SI":"inform. o ioBroker","sv-SE":"ioBroker info","th-TH":"ข้อมูล ioBroker","tr-TR":"ioBroker bilgileri","uk-UA":"ioBroker інформація","vi-VN":"thông tin ioBroker","zh-CN":"io经纪商信息","zh-TW":"io經紀商資訊"},"instance_javascript":{"en-US":"JS Adapter Instance","de-DE":"JS-Adapterinstanz","nl-NL":"JS-adapterinstantie","da-DK":"JS Adapter Forekomst","es-ES":"Instancia de adaptador JS","fr-FR":"Instance d'adaptateur JS","it-IT":"Istanza dell'adattatore JS","ru-RU":"Экземпляр JS-адаптера","nb-NO":"JS-adapterforekomst","nn-NO":"JS-adapterforekomst","pl-PL":"Instancja adaptera JS","pt-PT":"Instância do adaptador JS","af-ZA":"JS Adapter Instance","ar-SY":"مثيل محول JS","bg-BG":"Екземпляр на JS адаптер","ca-ES":"Instància de l'adaptador JS","cs-CZ":"Instance adaptéru JS","el-GR":"Περίπτωση προσαρμογέα JS","et-EE":"JS-i adapteri eksemplar","fa-IR":"نمونه آداپتور JS","fi-FI":"JS-sovitininstanssi","he-IL":"מופע מתאם JS","hr-xx":"Instanca JS adaptera","hu-HU":"JS Adapter Példány","hy-AM":"JS ադապտերների օրինակ","id-ID":"Contoh Adaptor JS","is-IS":"JS millistykki tilvik","lb-xx":"JS Adapter Instanz","lt-LT":"JS adapterio egzempliorius","ro-RO":"Instanța adaptorului JS","sk-SK":"Inštancia adaptéra JS","sl-SI":"Primerek adapterja JS","sv-SE":"JS-adapterinstans","th-TH":"อินสแตนซ์อะแดปเตอร์ JS","tr-TR":"JS Bağdaştırıcı Örneği","uk-UA":"Екземпляр адаптера JS","vi-VN":"Phiên bản bộ điều hợp JS","zh-CN":"JS 适配器实例","zh-TW":"JS 適配器實例"},"script":{"en-US":"Script","de-DE":"Skript","nl-NL":"Script","da-DK":"Script","es-ES":"Guion","fr-FR":"Écriture","it-IT":"Copione","ru-RU":"Скрипт","nb-NO":"Script","nn-NO":"Script","pl-PL":"Pismo","pt-PT":"Escrita","af-ZA":"Skripsie","ar-SY":"النصي","bg-BG":"Скрипт","ca-ES":"Guió","cs-CZ":"Skript","el-GR":"Γραφή","et-EE":"Skript","fa-IR":"اسکریپت","fi-FI":"Script","he-IL":"תַסרִיט","hr-xx":"Skripta","hu-HU":"Szkript","hy-AM":"Սցենար","id-ID":"Skrip","is-IS":"Handrit","lb-xx":"Skripte","lt-LT":"Script","ro-RO":"Script","sk-SK":"Skript","sl-SI":"Skripta","sv-SE":"Script","th-TH":"สคริปต์","tr-TR":"Script","uk-UA":"Скрипт","vi-VN":"Kịch bản","zh-CN":"脚本","zh-TW":"腳本"},"temp_unit":{"en-US":"Temp. unit","de-DE":"Temp. Einheit","nl-NL":"Temp. eenheid","da-DK":"Temp. enhed","es-ES":"Temp. unidad","fr-FR":"Temp. unité","it-IT":"Temp. unità","ru-RU":"Темп. единица","nb-NO":"Temp. enhet","nn-NO":"Temp. enhet","pl-PL":"Temp. jednostka","pt-PT":"Temp. unidade","af-ZA":"Temp. eenheid","ar-SY":"درجة حرارة. وحدة","bg-BG":"темп. единица","ca-ES":"Temp. unitat","cs-CZ":"Temp. jednotka","el-GR":"Θερμ. μονάδα","et-EE":"Temp. üksus","fa-IR":"دما واحد","fi-FI":"Temp. yksikkö","he-IL":"טמפ' יחידה","hr-xx":"Temp. jedinica","hu-HU":"Temp. egység","hy-AM":"Ջերմաստիճանը միավոր","id-ID":"Suhu. satuan","is-IS":"Temp. eining","lb-xx":"Temp. Eenheet","lt-LT":"Temp. vienetas","ro-RO":"Temp. unitate","sk-SK":"tepl. jednotka","sl-SI":"Temp. enota","sv-SE":"Temp. enhet","th-TH":"อุณหภูมิ หน่วย","tr-TR":"Sıcaklık birim","uk-UA":"темп. одиниця","vi-VN":"Nhiệt độ. đơn vị","zh-CN":"温度。 单元","zh-TW":"溫度。 單元"},"dimmode":{"en-US":"Dimmode","de-DE":"Dimmmodus","nl-NL":"Dimmodus","da-DK":"Dimmode","es-ES":"modo atenuado","fr-FR":"Mode gradation","it-IT":"Dimmoda","ru-RU":"Тусклый режим","nb-NO":"Dimmodus","nn-NO":"Dimmodus","pl-PL":"Tryb przyciemnienia","pt-PT":"Modo escuro","af-ZA":"Dimmodus","ar-SY":"ديمود","bg-BG":"Dimmode","ca-ES":"Dimmode","cs-CZ":"Špatný režim","el-GR":"Dimode","et-EE":"Hämar","fa-IR":"کمرنگ","fi-FI":"Himmeä tila","he-IL":"Dimmode","hr-xx":"Dimmode","hu-HU":"Dimmode","hy-AM":"Դիմմոդե","id-ID":"Mode redup","is-IS":"Dimmode","lb-xx":"Dimmode","lt-LT":"Pritemdytas režimas","ro-RO":"Dimmode","sk-SK":"Dimmode","sl-SI":"Dimmode","sv-SE":"Dimmode","th-TH":"หรี่แสง","tr-TR":"Loş mod","uk-UA":"Dimmode","vi-VN":"Chế độ làm mờ","zh-CN":"调光方式 ","zh-TW":"調光模式 "},"brightness":{"en-US":"Brightness","de-DE":"Helligkeit","nl-NL":"Helderheid","da-DK":"Lysstyrke","es-ES":"Brillo","fr-FR":"Luminosité","it-IT":"Luminosità","ru-RU":"Яркость","nb-NO":"Lysstyrke","nn-NO":"Lysstyrke","pl-PL":"Jasność","pt-PT":"Brilho","af-ZA":"Helderheid","ar-SY":"سطوع","bg-BG":"Яркост","ca-ES":"Brillantor","cs-CZ":"Jas","el-GR":"Λάμψη","et-EE":"Heledus","fa-IR":"روشنایی","fi-FI":"Kirkkaus","he-IL":"בְּהִירוּת","hr-xx":"Svjetlina","hu-HU":"Fényerősség","hy-AM":"Պայծառություն","id-ID":"Kecerahan","is-IS":"Birtustig","lb-xx":"Hellegkeet","lt-LT":"Ryškumas","ro-RO":"Luminozitate","sk-SK":"Jas","sl-SI":"Svetlost","sv-SE":"Ljusstyrka","th-TH":"ความสว่าง","tr-TR":"Parlaklık","uk-UA":"Яскравість","vi-VN":"độ sáng","zh-CN":"亮度","zh-TW":"亮度"},"layout":{"en-US":"Layout","de-DE":"Layout","nl-NL":"Layout","da-DK":"Layout","es-ES":"Diseño","fr-FR":"Layout","it-IT":"Layout","ru-RU":"Макет","nb-NO":"Layout","nn-NO":"Layout","pl-PL":"Układ","pt-PT":"Layout","af-ZA":"Layout","ar-SY":"نسق","bg-BG":"Оформление","ca-ES":"Maquetació","cs-CZ":"Rozložení","el-GR":"Διάταξη","et-EE":"Paigutus","fa-IR":"چیدمان","fi-FI":"Layout","he-IL":"מַעֲרָך","hr-xx":"Izgled","hu-HU":"Elrendezés","hy-AM":"Դասավորություն","id-ID":"Tata Letak","is-IS":"Skipulag","lb-xx":"Layout","lt-LT":"Išdėstymas","ro-RO":"Dispunerea","sk-SK":"Rozloženie","sl-SI":"Postavitev","sv-SE":"Layout","th-TH":"เค้าโครง","tr-TR":"Düzen","uk-UA":"Макет","vi-VN":"Bố cục","zh-CN":"布局","zh-TW":"佈局"},"date_format":{"en-US":"Date format","de-DE":"Datumsformat","nl-NL":"Datumnotatie","da-DK":"Datoformat","es-ES":"Formato de fecha","fr-FR":"Format de date","it-IT":"Formato data","ru-RU":"Формат даты","nb-NO":"Datoformat","nn-NO":"Datoformat","pl-PL":"Format daty","pt-PT":"Formato de data","af-ZA":"Datum formaat","ar-SY":"صيغة التاريخ","bg-BG":"Формат за дата","ca-ES":"Format de data","cs-CZ":"Datový formát","el-GR":"Μορφή ημερομηνίας","et-EE":"Kuupäevavorming","fa-IR":"فرمت تاریخ","fi-FI":"Päivämäärämuoto","he-IL":"פורמט תאריך","hr-xx":"Oblik datuma","hu-HU":"Dátum formátum","hy-AM":"Ամսաթվի ձևաչափ","id-ID":"Format tanggal","is-IS":"Dagsetningarsnið","lb-xx":"Datum Format","lt-LT":"Datos formatas","ro-RO":"Formatul datei","sk-SK":"Formát dátumu","sl-SI":"Format datuma","sv-SE":"Datumformat","th-TH":"รูปแบบวันที่","tr-TR":"Tarih formatı","uk-UA":"Формат дати","vi-VN":"Định dạng ngày","zh-CN":"日期格式","zh-TW":"日期格式"},"indicators":{"en-US":"Indicators","de-DE":"Indikatoren","nl-NL":"Indicatoren","da-DK":"Indikatorer","es-ES":"Indicadores","fr-FR":"Indicateurs","it-IT":"Indicatori","ru-RU":"Индикаторы","nb-NO":"Indikatorer","nn-NO":"Indikatorer","pl-PL":"Wskaźniki","pt-PT":"Indicadores","af-ZA":"Aanwysers","ar-SY":"المؤشرات","bg-BG":"Индикатори","ca-ES":"Indicadors","cs-CZ":"Ukazatele","el-GR":"δείκτες","et-EE":"Näitajad","fa-IR":"شاخص ها","fi-FI":"Indikaattorit","he-IL":"אינדיקטורים","hr-xx":"Indikatori","hu-HU":"Mutatók","hy-AM":"Ցուցանիշներ","id-ID":"Indikator","is-IS":"Vísar","lb-xx":"Indicateuren","lt-LT":"Rodikliai","ro-RO":"Indicatori","sk-SK":"Ukazovatele","sl-SI":"Indikatorji","sv-SE":"Indikatorer","th-TH":"ตัวชี้วัด","tr-TR":"Göstergeler","uk-UA":"Індикатори","vi-VN":"Các chỉ số","zh-CN":"指标","zh-TW":"指標"},"brightness_day":{"en-US":"Brightness (day)","de-DE":"Helligkeit (Tag)","nl-NL":"Helderheid (dag)","da-DK":"Lysstyrke (dag)","es-ES":"Brillo (día)","fr-FR":"Luminosité (jour)","it-IT":"Luminosità (giorno)","ru-RU":"Яркость (день)","nb-NO":"Lysstyrke (dag)","nn-NO":"Lysstyrke (dag)","pl-PL":"Jasność (dzień)","pt-PT":"Brilho (dia)","af-ZA":"Helderheid (dag)","ar-SY":"السطوع (اليوم)","bg-BG":"Яркост (ден)","ca-ES":"Brillantor (dia)","cs-CZ":"Jas (den)","el-GR":"Φωτεινότητα (ημέρα)","et-EE":"Heledus (päev)","fa-IR":"روشنایی (روز)","fi-FI":"Kirkkaus (päivä)","he-IL":"בהירות (יום)","hr-xx":"Svjetlina (dan)","hu-HU":"Fényerő (nappal)","hy-AM":"Պայծառություն (օր)","id-ID":"Kecerahan (hari)","is-IS":"Birtustig (dagur)","lb-xx":"Hellegkeet (Dag)","lt-LT":"Ryškumas (dieną)","ro-RO":"Luminozitate (zi)","sk-SK":"Jas (deň)","sl-SI":"Svetlost (dan)","sv-SE":"Ljusstyrka (dag)","th-TH":"ความสว่าง (วัน)","tr-TR":"Parlaklık (gün)","uk-UA":"Яскравість (день)","vi-VN":"Độ sáng (ngày)","zh-CN":"亮度(天)","zh-TW":"亮度(天)"},"brightness_night":{"en-US":"Brightness (night)","de-DE":"Helligkeit (Nacht)","nl-NL":"Helderheid (nacht)","da-DK":"Lysstyrke (nat)","es-ES":"Brillo (noche)","fr-FR":"Luminosité (nuit)","it-IT":"Luminosità (notte)","ru-RU":"Яркость (ночь)","nb-NO":"Lysstyrke (natt)","nn-NO":"Lysstyrke (natt)","pl-PL":"Jasność (noc)","pt-PT":"Brilho (noite)","af-ZA":"Helderheid (nag)","ar-SY":"السطوع (ليلة)","bg-BG":"Яркост (нощ)","ca-ES":"Brillantor (nit)","cs-CZ":"Jas (noc)","el-GR":"Φωτεινότητα (νύχτα)","et-EE":"Heledus (öö)","fa-IR":"روشنایی (شب)","fi-FI":"Kirkkaus (yö)","he-IL":"בהירות (לילה)","hr-xx":"Svjetlina (noć)","hu-HU":"Fényerő (éjszaka)","hy-AM":"Պայծառություն (գիշեր)","id-ID":"Kecerahan (malam)","is-IS":"Birtustig (nótt)","lb-xx":"Hellegkeet (Nuecht)","lt-LT":"Ryškumas (naktis)","ro-RO":"Luminozitate (noapte)","sk-SK":"Jas (noc)","sl-SI":"Svetlost (noč)","sv-SE":"Ljusstyrka (natt)","th-TH":"ความสว่าง (กลางคืน)","tr-TR":"Parlaklık (gece)","uk-UA":"Яскравість (ніч)","vi-VN":"Độ sáng (đêm)","zh-CN":"亮度(夜间)","zh-TW":"亮度(夜間)"},"hour_day":{"en-US":"Hour (day)","de-DE":"Stunde (Tag)","nl-NL":"Uur (dag)","da-DK":"Time (dag)","es-ES":"Hora (día)","fr-FR":"Heure (jour)","it-IT":"Ora (giorno)","ru-RU":"Час (день)","nb-NO":"Time (dag)","nn-NO":"Time (dag)","pl-PL":"Godzina (dzień)","pt-PT":"Hora (dia)","af-ZA":"Uur (dag)","ar-SY":"ساعة (يوم)","bg-BG":"час (ден)","ca-ES":"Hora (dia)","cs-CZ":"hodina (den)","el-GR":"Ώρα (ημέρα)","et-EE":"Tund (päev)","fa-IR":"ساعت (روز)","fi-FI":"Tunti (päivä)","he-IL":"שעה (יום)","hr-xx":"sat (dan)","hu-HU":"óra (nap)","hy-AM":"Ժամ (օր)","id-ID":"Jam (hari)","is-IS":"Klukkutími (dagur)","lb-xx":"Stonn (Dag)","lt-LT":"valanda (diena)","ro-RO":"Ora (zi)","sk-SK":"hodina (deň)","sl-SI":"ura (dan)","sv-SE":"timme (dag)","th-TH":"ชั่วโมง (วัน)","tr-TR":"Saat (gün)","uk-UA":"година (день)","vi-VN":"Giờ (ngày)","zh-CN":"小时(天)","zh-TW":"小時(天)"},"hour_night":{"en-US":"Hour (night)","de-DE":"Stunde (Nacht)","nl-NL":"Uur (nacht)","da-DK":"Time (nat)","es-ES":"Hora (noche)","fr-FR":"Heure (nuit)","it-IT":"Ora (notte)","ru-RU":"Час (ночь)","nb-NO":"Time (natt)","nn-NO":"Time (natt)","pl-PL":"Godzina (noc)","pt-PT":"Hora (noite)","af-ZA":"Uur (nag)","ar-SY":"الساعة (الليلة)","bg-BG":"час (нощен)","ca-ES":"Hora (nit)","cs-CZ":"hodina (noc)","el-GR":"Ώρα (νύχτα)","et-EE":"Tund (öö)","fa-IR":"ساعت (شب)","fi-FI":"Tunti (yö)","he-IL":"שעה (לילה)","hr-xx":"sat (noć)","hu-HU":"óra (éjszaka)","hy-AM":"Ժամ (գիշեր)","id-ID":"Jam (malam)","is-IS":"Klukkutími (nótt)","lb-xx":"Stonn (Nuecht)","lt-LT":"Valanda (naktis)","ro-RO":"Ora (noapte)","sk-SK":"hodina (noc)","sl-SI":"ura (noč)","sv-SE":"timme (natt)","th-TH":"ชั่วโมง (กลางคืน)","tr-TR":"Saat (gece)","uk-UA":"Година (ніч)","vi-VN":"Giờ (đêm)","zh-CN":"小时(夜间)","zh-TW":"小時(夜間)"},"relay1_onoff":{"en-US":"Relay 1 (off/on)","de-DE":"Relais 1 (aus/an)","nl-NL":"Relais 1 (uit/aan)","da-DK":"Relæ 1 (slukket/til)","es-ES":"Relé 1 (apagado/encendido)","fr-FR":"Relais 1 (arrêt/marche)","it-IT":"Relè 1 (spento/acceso)","ru-RU":"Реле 1 (выкл./вкл.)","nb-NO":"Relé 1 (av/på)","nn-NO":"Relé 1 (av/på)","pl-PL":"Przekaźnik 1 (wył./wł.)","pt-PT":"Relé 1 (desligado/ligado)","af-ZA":"Aflos 1 (af/aan)","ar-SY":"التتابع 1 (إيقاف / تشغيل)","bg-BG":"Реле 1 (изкл./вкл.)","ca-ES":"Relé 1 (apagat/encès)","cs-CZ":"Relé 1 (vypnuto/zapnuto)","el-GR":"Ρελέ 1 (off/on)","et-EE":"Relee 1 (väljas/sisse)","fa-IR":"رله 1 (خاموش/روشن)","fi-FI":"Rele 1 (pois/päällä)","he-IL":"ממסר 1 (כבוי/מופעל)","hr-xx":"Relej 1 (isključeno/uključeno)","hu-HU":"1. relé (ki/be)","hy-AM":"Ռելե 1 (անջատված/միացված)","id-ID":"Relai 1 (mati/hidup)","is-IS":"Relay 1 (slökkt/kveikt)","lb-xx":"Relais 1 (aus/an)","lt-LT":"1 relė (išjungta / įjungta)","ro-RO":"Releul 1 (oprit/pornit)","sk-SK":"Relé 1 (vypnuté/zapnuté)","sl-SI":"Rele 1 (izklop/vklop)","sv-SE":"Relä 1 (av/på)","th-TH":"รีเลย์ 1 (ปิด/เปิด)","tr-TR":"Röle 1 (kapalı/açık)","uk-UA":"Реле 1 (викл./вкл.)","vi-VN":"Rơ-le 1 (tắt/bật)","zh-CN":"继电器 1(关/开)","zh-TW":"繼電器 1(關/開)"},"relay2_onoff":{"en-US":"Relay 2 (off/on)","de-DE":"Relais 2 (aus/an)","nl-NL":"Relais 2 (uit/aan)","da-DK":"Relæ 2 (slukket/til)","es-ES":"Relé 2 (apagado/encendido)","fr-FR":"Relais 2 (arrêt/marche)","it-IT":"Relè 2 (spento/acceso)","ru-RU":"Реле 2 (выкл./вкл.)","nb-NO":"Relé 2 (av/på)","nn-NO":"Relé 2 (av/på)","pl-PL":"Przekaźnik 2 (wył./wł.)","pt-PT":"Relé 2 (desligado/ligado)","af-ZA":"Aflos 2 (af/aan)","ar-SY":"التتابع 2 (إيقاف / تشغيل)","bg-BG":"Реле 2 (изкл./вкл.)","ca-ES":"Relé 2 (apagat/encès)","cs-CZ":"Relé 2 (vypnuto/zapnuto)","el-GR":"Ρελέ 2 (off/on)","et-EE":"Relee 2 (väljas/sisse)","fa-IR":"رله 2 (خاموش/روشن)","fi-FI":"Rele 2 (pois/päällä)","he-IL":"ממסר 2 (כבוי/מופעל)","hr-xx":"Relej 2 (isključeno/uključeno)","hu-HU":"2. relé (ki/be)","hy-AM":"Ռելե 2 (անջատված/միացված)","id-ID":"Relai 2 (mati/hidup)","is-IS":"Relay 2 (slökkt/kveikt)","lb-xx":"Relais 2 (aus/an)","lt-LT":"2 relė (išjungta / įjungta)","ro-RO":"Releul 2 (oprit/pornit)","sk-SK":"Relé 2 (vypnuté/zapnuté)","sl-SI":"Rele 2 (izklop/vklop)","sv-SE":"Relä 2 (av/på)","th-TH":"รีเลย์ 2 (ปิด/เปิด)","tr-TR":"Röle 2 (kapalı/açık)","uk-UA":"Реле 2 (викл./вкл.)","vi-VN":"Rơ-le 2 (tắt/bật)","zh-CN":"继电器 2(关/开)","zh-TW":"繼電器 2(關/開)"},"debugmode_offon":{"en-US":"Debugmode (off/on)","de-DE":"Debugmodus (aus/an)","nl-NL":"Debug-modus (uit / aan)","da-DK":"Fejlretningstilstand","es-ES":"Modo de depuración","fr-FR":"Mode débogage (off/on)","it-IT":"Modalità debug","ru-RU":"Режим отладки (выкл./вкл.)","nb-NO":"Feilsøkingsmodus (av/på)","nn-NO":"Feilsøkingsmodus (av/på)","pl-PL":"Tryb debugowania (wył./wł.)","pt-PT":"Modo de depuração","af-ZA":"Ontfoutmodus (af/aan)","ar-SY":"وضع التصحيح (إيقاف/تشغيل)","bg-BG":"Режим за отстраняване на грешки","ca-ES":"Mode de depuració","cs-CZ":"Režim ladění ","el-GR":"Λειτουργία εντοπισμού σφαλμάτων (off/on)","et-EE":"Silumisrežiim (väljas/sisse)","fa-IR":"اشکال زدایی (خاموش/روشن)","fi-FI":"Virheenkorjaustila (pois/päällä)","he-IL":"ניפוי באגים (כבוי/מופעל)","hr-xx":"Način otklanjanja pogrešaka","hu-HU":"Debugmode (ki/be)","hy-AM":"Վրիպազերծման եղանակ","id-ID":"Mode debug (mati/hidup)","is-IS":"Villuleit (slökkt/kveikt)","lb-xx":"Debugmode (aus/an)","lt-LT":"Derinimo režimas","ro-RO":"Modul de depanare","sk-SK":"Režim ladenia ","sl-SI":"Način odpravljanja napak","sv-SE":"Debugmode (av/på)","th-TH":"โหมดดีบั๊ก (ปิด/เปิด)","tr-TR":"Hata ayıklama modu","uk-UA":"Режим налагодження","vi-VN":"Chế độ gỡ lỗi (tắt/bật)","zh-CN":"调试模式(关/开)","zh-TW":"調試模式(關/開)"},"port_check_offon":{"en-US":"Portscan (off/on)","de-DE":"Port-Check (aus/an)","nl-NL":"Poortscan (uit/aan)","da-DK":"Portscan (fra/til)","es-ES":"Exploración de puertos","fr-FR":"Analyse des ports","it-IT":"Portscan (off/on)","ru-RU":"Сканирование портов","nb-NO":"Portskanning (av/på)","nn-NO":"Portskanning (av/på)","pl-PL":"Skanowanie portów (wył./wł.)","pt-PT":"Portscan (desligado/ligado)","af-ZA":"Portscan (af/aan)","ar-SY":"بورتسكان (إيقاف/تشغيل)","bg-BG":"Portscan (изкл./вкл.)","ca-ES":"Portscan (off/on)","cs-CZ":"Portscan (off/on)","el-GR":"Portscan (off/on)","et-EE":"Portscan (väljas/sisse)","fa-IR":"پورت اسکن (خاموش/روشن)","fi-FI":"Portscan (pois/päällä)","he-IL":"Portscan (כבוי/מופעל)","hr-xx":"Portscan (off/on)","hu-HU":"Portscan (ki/be)","hy-AM":"Portscan (անջատված/միացված)","id-ID":"Portscan (mati/hidup)","is-IS":"Portscan (slökkt/kveikt)","lb-xx":"Portscan (aus/an)","lt-LT":"Portscan (išjungta / įjungta)","ro-RO":"Portscan (dezactivat/pornit)","sk-SK":"Portscan (vypnuté/zapnuté)","sl-SI":"Portscan (izklop/vklop)","sv-SE":"Portscan (av/på)","th-TH":"พอร์ตสแกน (ปิด/เปิด)","tr-TR":"Port tarama (kapalı/açık)","uk-UA":"Portscan (вимк./увімк.)","vi-VN":"Quét cổng (tắt/bật)","zh-CN":"端口扫描(关闭/打开)","zh-TW":"連接埠掃描(關閉/開啟)"},"weather_parameters":{"en-US":"Weather parameters","de-DE":"Wetterparameter","nl-NL":"Weerparameters","da-DK":"Vejrparametre","es-ES":"Meteorológicos","fr-FR":"Météorologiques","it-IT":"Meteorologici","ru-RU":"Параметры погоды","nb-NO":"Værparametere","nn-NO":"Værparametere","pl-PL":"Parametry pogodowe","pt-PT":"Meteorológicos","af-ZA":"Weer parameters","ar-SY":"معلمات الطقس","bg-BG":"Параметри на времето","ca-ES":"Meteorològics","cs-CZ":"Parametry počasí","el-GR":"Παράμετροι καιρού","et-EE":"Ilmastiku parameetrid","fa-IR":"پارامترهای آب و هوا","fi-FI":"Sääparametrit","he-IL":"פרמטרים של מזג אוויר","hr-xx":"Vremenski parametri","hu-HU":"Időjárási paraméterek","hy-AM":"Եղանակի պարամետրեր","id-ID":"Parameter cuaca","is-IS":"Veðurbreytur","lb-xx":"Wieder Parameteren","lt-LT":"Oro parametrai","ro-RO":"Parametrii vremii","sk-SK":"Parametre počasia","sl-SI":"Vremenski parametri","sv-SE":"Väderparametrar","th-TH":"พารามิเตอร์สภาพอากาศ","tr-TR":"Hava parametreleri","uk-UA":"Параметри погоди","vi-VN":"Thông số thời tiết","zh-CN":"天气参数","zh-TW":"天氣參數"},"brightness_activ":{"en-US":"Brightness Active","de-DE":"Helligkeit Aktiv","nl-NL":"Helderheid Actief","da-DK":"Lysstyrke aktiv","es-ES":"Brillo activo","fr-FR":"Luminosité active","it-IT":"Luminosità attiva","ru-RU":"Яркость активная","nb-NO":"Lysstyrke aktiv","nn-NO":"Lysstyrke aktiv","pl-PL":"Jasność Aktywna","pt-PT":"Brilho Ativo","af-ZA":"Helderheid aktief","ar-SY":"السطوع نشط","bg-BG":"Яркост Активна","ca-ES":"Brillantor activa","cs-CZ":"Jas Aktivní","el-GR":"Brightness Active","et-EE":"Heledus aktiivne","fa-IR":"روشنایی فعال","fi-FI":"Kirkkaus aktiivinen","he-IL":"בהירות פעיל","hr-xx":"Svjetlina Aktivna","hu-HU":"Fényerő aktív","hy-AM":"Պայծառություն Ակտիվ","id-ID":"Kecerahan Aktif","is-IS":"Birtustig Virkt","lb-xx":"Hellegkeet Aktiv","lt-LT":"Aktyvus ryškumas","ro-RO":"Luminozitate activă","sk-SK":"Jas aktívny","sl-SI":"Svetlost Aktivna","sv-SE":"Ljusstyrka aktiv","th-TH":"ความสว่างใช้งานอยู่","tr-TR":"Parlaklık Aktif","uk-UA":"Яскравість активна","vi-VN":"Độ sáng hoạt động","zh-CN":"亮度活跃","zh-TW":"亮度活躍"},"screensaver_timeout":{"en-US":"Timeout Screensaver","de-DE":"Screensaver Timeout","nl-NL":"Timeout Screensaver","da-DK":"Timeout pauseskærm","es-ES":"Timeout Screensaver","fr-FR":"Timeout Screensaver","it-IT":"Timeout Screensaver","ru-RU":"Заставка Таймаута","nb-NO":"Timeout Screensaver","nn-NO":"Timeout Screensaver","pl-PL":"Timeout Screensaver","pt-PT":"Timeout Screensaver","af-ZA":"Time-out skermbewaarder","ar-SY":"شاشة توقف المهلة","bg-BG":"Изтекъл скрийнсейвър","ca-ES":"Timeout Screensaver","cs-CZ":"Timeout Screensaver","el-GR":"Timeout Screensaver","et-EE":"Timeout Ekraanisäästja","fa-IR":"مهلت زمانی محافظ صفحه نمایش","fi-FI":"Timeout Screensaver","he-IL":"שומר מסך פסק זמן","hr-xx":"Timeout Screensaver","hu-HU":"Timeout Screensaver","hy-AM":"Ժամկետանց Էկրանապահ","id-ID":"Timeout Screensaver","is-IS":"Tímamörk skjávara","lb-xx":"Timeout Screensaver","lt-LT":"Timeout Screensaver","ro-RO":"Timeout Screensaver","sk-SK":"Timeout Screensaver","sl-SI":"Timeout Screensaver","sv-SE":"Timeout skärmsläckare","th-TH":"สกรีนเซฟเวอร์หมดเวลา","tr-TR":"Timeout Screensaver","uk-UA":"Тайм-аут Заставка","vi-VN":"Timeout Screensaver","zh-CN":"超时屏保","zh-TW":"超時螢幕保"},"wakeup_doublecklick":{"en-US":"Wakeup on doubleclick","de-DE":"Doppelklick Weakup"},"nspanel_infos":{"en-US":"NSPanel Infos","de-DE":"NSPanel Info's","nl-NL":"NSPanel-info","da-DK":"NSPanel-info","es-ES":"Información del NSPanel","fr-FR":"Informations NSPanel","it-IT":"Informazioni sul NSPanel","ru-RU":"Информация о NSPanel","nb-NO":"NSPanel info","nn-NO":"NSPanel info","pl-PL":"Informacje o NSPanel","pt-PT":"Informações do NSPanel","af-ZA":"NSPanel inligting","ar-SY":"معلومات NSPanel","bg-BG":"Информация за NSPanel","ca-ES":"Informació del NSPanel","cs-CZ":"Informace NPanel","el-GR":"Πληροφορίες NSPanel","et-EE":"NSPaneli teave","fa-IR":"اطلاعات NSPanel","fi-FI":"NSPanelin tiedot","he-IL":"מידע NSPanel","hr-xx":"NSPanel informacije","hu-HU":"NSPanel információ","hy-AM":"NSPanel-ի տվյալներ","id-ID":"info NSPanel","is-IS":"NSPanel upplýsingar","lb-xx":"NSPanel Info","lt-LT":"NSPanel informacija","ro-RO":"Informații NSPanel","sk-SK":"Informácie NPanel","sl-SI":"Informacije NSPanel","sv-SE":"NSPanel info","th-TH":"ข้อมูล NSPanel","tr-TR":"NSPanel bilgisi","uk-UA":"Інформація NSPanel","vi-VN":"Thông tin NSPanel","zh-CN":"NSPanel信息","zh-TW":"NS面板資訊"},"nspanel_wifi1":{"en-US":"NSPanel Wifi (1)","de-DE":"NSPanel WLAN (1)"},"nspanel_wifi2":{"en-US":"NSPanel Wifi (2)","de-DE":"NSPanel WLAN (2)"},"ssid":{"en-US":"SSId","de-DE":"SSId"},"accesspoint":{"en-US":"AP","de-DE":"AP"},"wifi":{"en-US":"Wifi","de-DE":"WLAN"},"esp32_hardware":{"en-US":"ESP32 Hardware","de-DE":"ESP32-Hardware"},"nspanel_version":{"en-US":"Display Version","de-DE":"Display-Version","nl-NL":"Weergaveversie","da-DK":"Vis version","es-ES":"Versión de visualización","fr-FR":"Version d'affichage","it-IT":"Visualizzazione della versione","ru-RU":"Версия дисплея","nb-NO":"Vis versjon","nn-NO":"Vis versjon","pl-PL":"Wersja wyświetlacza","pt-PT":"Versão de exibição","af-ZA":"Vertoon weergawe","ar-SY":"نسخة العرض","bg-BG":"Версия на дисплея","ca-ES":"Versió de visualització","cs-CZ":"Verze zobrazení","el-GR":"Έκδοση εμφάνισης","et-EE":"Kuva versioon","fa-IR":"نسخه نمایش","fi-FI":"Näytön versio","he-IL":"גרסה לתצוגה","hr-xx":"Prikazna verzija","hu-HU":"Megjelenítési verzió","hy-AM":"Ցուցադրման տարբերակը","id-ID":"Versi Tampilan","is-IS":"Sýna útgáfa","lb-xx":"Display Versioun","lt-LT":"Ekrano versija","ro-RO":"Versiunea de afișare","sk-SK":"Verzia zobrazenia","sl-SI":"Prikazna različica","sv-SE":"Visa version","th-TH":"เวอร์ชันการแสดงผล","tr-TR":"Ekran Sürümü","uk-UA":"Відображення версії","vi-VN":"Phiên bản hiển thị","zh-CN":"显示版本","zh-TW":"顯示版本"},"nodejs_version":{"en-US":"NodeJS Version","de-DE":"NodeJS Version","nl-NL":"NodeJS-versie","da-DK":"NodeJS version","es-ES":"Versión NodeJS","fr-FR":"Version NodeJS","it-IT":"Versione NodeJS","ru-RU":"Версия NodeJS","nb-NO":"NodeJS versjon","nn-NO":"NodeJS versjon","pl-PL":"Wersja NodeJS","pt-PT":"Versão NodeJS","af-ZA":"NodeJS weergawe","ar-SY":"نسخة NodeJS","bg-BG":"NodeJS версия","ca-ES":"Versió NodeJS","cs-CZ":"Verze NodeJS","el-GR":"Έκδοση NodeJS","et-EE":"NodeJS versioon","fa-IR":"نسخه NodeJS","fi-FI":"NodeJS-versio","he-IL":"גרסת NodeJS","hr-xx":"Verzija NodeJS","hu-HU":"NodeJS verzió","hy-AM":"NodeJS տարբերակը","id-ID":"Versi NodeJS","is-IS":"NodeJS útgáfa","lb-xx":"NodeJS Versioun","lt-LT":"NodeJS versija","ro-RO":"Versiunea NodeJS","sk-SK":"Verzia NodeJS","sl-SI":"Različica NodeJS","sv-SE":"NodeJS version","th-TH":"เวอร์ชัน NodeJS","tr-TR":"NodeJS sürümü","uk-UA":"Версія NodeJS","vi-VN":"Phiên bản NodeJS","zh-CN":"NodeJS版本","zh-TW":"NodeJS版本"},"script_version_nspanelts":{"en-US":"NSPanelTs.ts Version","de-DE":"NSPanelTs.ts Version","nl-NL":"NSPanelTs.ts-versie","da-DK":"NSPanelTs.ts version","es-ES":"Versión NSPanelTs.ts","fr-FR":"Version NSPanelTs.ts","it-IT":"Versione NSPanelTs.ts","ru-RU":"Версия NSPanelTs.ts","nb-NO":"NSPanelTs.ts versjon","nn-NO":"NSPanelTs.ts versjon","pl-PL":"Wersja NSPanelTs.ts","pt-PT":"Versão NSPanelTs.ts","af-ZA":"NSPanelTs.ts weergawe","ar-SY":"نسخة NSPanelTs.ts","bg-BG":"NSPanelTs.ts версия","ca-ES":"Versió NSPanelTs.ts","cs-CZ":"Verze NSPanelTs.ts","el-GR":"Έκδοση NSPanelTs.ts","et-EE":"NSPanelTs.ts versioon","fa-IR":"نسخه NSPanelTs.ts","fi-FI":"NSPanelTs.ts-versio","he-IL":"גרסת NSPanelTs.ts","hr-xx":"Verzija NSPanelTs.ts","hu-HU":"NSPanelTs.ts verzió","hy-AM":"NSPanelTs.ts տարբերակը","id-ID":"Versi NSPanelTs.ts","is-IS":"NSPanelTs.ts útgáfa","lb-xx":"NSPanelTs.ts Versioun","lt-LT":"NSPanelTs.ts versija","ro-RO":"Versiunea NSPanelTs.ts","sk-SK":"Verzia NSPanelTs.ts","sl-SI":"Različica NSPanelTs.ts","sv-SE":"NSPanelTs.ts version","th-TH":"เวอร์ชัน NSPanelTs.ts","tr-TR":"NSPanelTs.ts sürümü","uk-UA":"Версія NSPanelTs.ts","vi-VN":"Phiên bản NSPanelTs.ts","zh-CN":"NSPanelTs.ts版本","zh-TW":"NSPanelTs.ts版本"},"alternative_layout":{"en-US":"Alternative Layout","de-DE":"Alternativ Layout","nl-NL":"Alternatieve indeling","da-DK":"Alternativ layout","es-ES":"Diseño alternativo","fr-FR":"Disposition alternative","it-IT":"Disposizione alternativa","ru-RU":"Альтернативная планировка","nb-NO":"Alternativ layout","nn-NO":"Alternativ layout","pl-PL":"Alternatywny układ","pt-PT":"Layout alternativo","af-ZA":"Alternatiewe uitleg","ar-SY":"تخطيط بديل","bg-BG":"Алтернативно оформление","ca-ES":"Distribució alternativa","cs-CZ":"Alternativní uspořádání","el-GR":"Εναλλακτική διάταξη","et-EE":"Alternatiivne paigutus","fa-IR":"چیدمان جایگزین","fi-FI":"Vaihtoehtoinen asettelu","he-IL":"פריסה חלופית","hr-xx":"Alternativni izgled","hu-HU":"Alternatív elrendezés","hy-AM":"Այլընտրանքային դասավորություն","id-ID":"Tata Letak Alternatif","is-IS":"Annað skipulag","lb-xx":"Alternativ Layout","lt-LT":"Alternatyvus išdėstymas","ro-RO":"Aspect alternativ","sk-SK":"Alternatívne rozloženie","sl-SI":"Alternativna postavitev","sv-SE":"Alternativ layout","th-TH":"เค้าโครงทางเลือก","tr-TR":"Alternatif Düzen","uk-UA":"Альтернативний макет","vi-VN":"Bố cục thay thế","zh-CN":"替代布局","zh-TW":"替代佈局"},"advanced_layout":{"en-US":"Advanced Layout","de-DE":"Erweitertes Layout","nl-NL":"Geavanceerde lay-out","da-DK":"Avanceret layout","es-ES":"Diseño avanzado","fr-FR":"Disposition avancée","it-IT":"Disposizione avanzata","ru-RU":"Расширенный макет","nb-NO":"Avansert layout","nn-NO":"Avansert layout","pl-PL":"Zaawansowany układ","pt-PT":"Layout Avançado","af-ZA":"Gevorderde uitleg","ar-SY":"تخطيط متقدم","bg-BG":"Разширено оформление","ca-ES":"Disseny avançat","cs-CZ":"Pokročilé rozvržení","el-GR":"Σύνθετη διάταξη","et-EE":"Täpsem paigutus","fa-IR":"طرح بندی پیشرفته","fi-FI":"Edistynyt asettelu","he-IL":"פריסה מתקדמת","hr-xx":"Napredni raspored","hu-HU":"Speciális elrendezés","hy-AM":"Ընդլայնված դասավորություն","id-ID":"Tata Letak Tingkat Lanjut","is-IS":"Ítarlegt útlit","lb-xx":"Fortgeschratt Layout","lt-LT":"Išplėstinis išdėstymas","ro-RO":"Aspect avansat","sk-SK":"Rozšírené rozloženie","sl-SI":"Napredna postavitev","sv-SE":"Avancerad layout","th-TH":"เค้าโครงขั้นสูง","tr-TR":"Gelişmiş Düzen","uk-UA":"Розширений макет","vi-VN":"Bố cục nâng cao","zh-CN":"高级布局","zh-TW":"進階佈局"},"weather_forecast_offon":{"en-US":"Forecast Off/On","de-DE":"Vorhersage Aus/An","nl-NL":"Voorspelling uit/aan","da-DK":"Vejrudsigt slukket/til","es-ES":"Previsión meteorológica","fr-FR":"Prévisions météo","it-IT":"Previsioni meteo","ru-RU":"Прогноз погоды","nb-NO":"Værmelding av/på","nn-NO":"Værmelding av/på","pl-PL":"Prognoza pogody","pt-PT":"Previsão do tempo","af-ZA":"Voorspelling af/aan","ar-SY":"إيقاف/تشغيل توقعات الطقس","bg-BG":"Прогнозата за времето","ca-ES":"Previsió meteorològica","cs-CZ":"Předpověď počasí","el-GR":"πρόγνωσης καιρού","et-EE":"Ilmateade väljas/sisse","fa-IR":"پیش بینی آب و هوا خاموش/روشن","fi-FI":"Sääennuste pois/päällä","he-IL":"תחזית מזג האוויר","hr-xx":"Vremenska prognoza","hu-HU":"Időjárás előrejelzés","hy-AM":"Եղանակի կանխատեսումը՝","id-ID":"Prakiraan cuaca","is-IS":"veðurspá","lb-xx":"Wiederprevisioun","lt-LT":"Orų prognozė","ro-RO":"Prognoza meteo","sk-SK":"Predpoveď počasia","sl-SI":"vremenske napovedi","sv-SE":"Väderprognos av/på","th-TH":"ปิด/เปิดพยากรณ์อากาศ","tr-TR":"Hava tahmini","uk-UA":"Прогноз погоди","vi-VN":"Dự báo thời tiết","zh-CN":"天气预报关闭/打开","zh-TW":"天氣預報關閉/打開"},"weather_forecast_change_switch":{"en-US":"Changing Forecast","de-DE":"Vorhersage Wechsel"},"weather_forecast_change_time":{"en-US":"Changetime/s","de-DE":"Wechselzeit/s"},"weather_forecast_icon_colors":{"en-US":"Colored icons","de-DE":"Symbolfarben","nl-NL":"Gekleurde icoontjes","da-DK":"Farvede ikoner","es-ES":"Iconos de colores","fr-FR":"Icônes colorées","it-IT":"Icone colorate","ru-RU":"Цветные значки","nb-NO":"Fargede ikoner","nn-NO":"Fargede ikoner","pl-PL":"Kolorowe ikony","pt-PT":"Ícones coloridos","af-ZA":"Gekleurde ikone","ar-SY":"أيقونات ملونة","bg-BG":"Цветни икони","ca-ES":"Icones de colors","cs-CZ":"Barevné ikony","el-GR":"Χρωματιστά εικονίδια","et-EE":"Värvilised ikoonid","fa-IR":"آیکون های رنگی","fi-FI":"Värilliset kuvakkeet","he-IL":"אייקונים צבעוניים","hr-xx":"Ikone u boji","hu-HU":"Színes ikonok","hy-AM":"Գունավոր սրբապատկերներ","id-ID":"Ikon berwarna","is-IS":"Lituð tákn","lb-xx":"Faarweg Symboler","lt-LT":"Spalvotos ikonėlės","ro-RO":"Icône colorate","sk-SK":"Farebné ikony","sl-SI":"Barvne ikone","sv-SE":"Färgade ikoner","th-TH":"ไอคอนสี","tr-TR":"Renkli simgeler","uk-UA":"Кольорові значки","vi-VN":"Biểu tượng màu","zh-CN":"彩色图标","zh-TW":"彩色圖示"},"weekday_large":{"en-US":"Weekday (long)","de-DE":"Wochentag (lang)","nl-NL":"Weekdag (lang)","da-DK":"Ugedag (lang)","es-ES":"Día laborable (largo)","fr-FR":"Jour de semaine (long)","it-IT":"Giorno feriale (lungo)","ru-RU":"Будний день (длинный)","nb-NO":"Ukedag (lang)","nn-NO":"Ukedag (lang)","pl-PL":"Dzień powszedni (długi)","pt-PT":"Dia da semana (longo)","af-ZA":"Weekdag (lank)","ar-SY":"أيام الأسبوع (طويلة)","bg-BG":"Делничен ден (дълъг)","ca-ES":"Dia laborable (llarg)","cs-CZ":"všední den (dlouhý)","el-GR":"Καθημερινή (μεγάλη)","et-EE":"Nädalapäev (pikk)","fa-IR":"روز هفته (طولانی)","fi-FI":"Arkipäivä (pitkä)","he-IL":"יום חול (ארוך)","hr-xx":"Radni dan (dugo)","hu-HU":"Hétköznap (hosszú)","hy-AM":"Շաբաթվա օր (երկար)","id-ID":"Hari kerja (panjang)","is-IS":"Vikudagur (langur)","lb-xx":"Wochendag (laang)","lt-LT":"Savaitės diena (ilgoji)","ro-RO":"Ziua săptămânii (lungă)","sk-SK":"pracovný deň (dlhý)","sl-SI":"Delovni dan (dolg)","sv-SE":"Vardag (lång)","th-TH":"วันธรรมดา (ยาว)","tr-TR":"Hafta içi (uzun)","uk-UA":"Будній (довгий)","vi-VN":"Ngày trong tuần (dài)","zh-CN":"平日(长)","zh-TW":"平日(長)"},"month_large":{"en-US":"Month (large)","de-DE":"Monat (lang)","nl-NL":"Maand (lang)","da-DK":"Måned (lang)","es-ES":"Mes (largo)","fr-FR":"Mois (long)","it-IT":"Mese (lungo)","ru-RU":"Месяц (длинный)","nb-NO":"Måned (lang)","nn-NO":"Måned (lang)","pl-PL":"Miesiąc (długi)","pt-PT":"Mês (longo)","af-ZA":"Maand (lank)","ar-SY":"شهر (طويل)","bg-BG":"Месец (дълъг)","ca-ES":"Mes (llarg)","cs-CZ":"měsíc (dlouhý)","el-GR":"Μήνας (μεγάλος)","et-EE":"Kuu (pikk)","fa-IR":"ماه (طولانی)","fi-FI":"Kuukausi (pitkä)","he-IL":"חודש (ארוך)","hr-xx":"Mjesec (dugo)","hu-HU":"Hónap (hosszú)","hy-AM":"Ամիս (երկար)","id-ID":"Bulan (panjang)","is-IS":"Mánuður (langur)","lb-xx":"Mount (laang)","lt-LT":"Mėnuo (ilgas)","ro-RO":"lună (lungă)","sk-SK":"mesiac (dlhý)","sl-SI":"Mesec (dolgo)","sv-SE":"Månad (lång)","th-TH":"เดือน (ยาว)","tr-TR":"Ay (uzun)","uk-UA":"Місяць (тривалий)","vi-VN":"Tháng (dài)","zh-CN":"月份(长)","zh-TW":"月份(長)"},"mr_icon1_size":{"en-US":"Icon 1 (small/large)","de-DE":"Icon 1 (klein/groß)"},"mr_icon2_size":{"en-US":"Icon 2 (small/large)","de-DE":"Icon 2 (klein/groß)"},"automatically_updates":{"en-US":"Autom. Updates","de-DE":"Auto-Updates"},"tasmota_firmware":{"en-US":"Tasmota Firmware","de-DE":"Tasmota-Firmware"},"nextion_tft_firmware":{"en-US":"Nextion TFT Firmware","de-DE":"Nextion-TFT Firmware"},"tasmota":{"en-US":"Tasmota","de-DE":"Tasmota","nl-NL":"Tasmota","da-DK":"Tasmota","es-ES":"Tasmota","fr-FR":"Tasmota","it-IT":"Tasmota","ru-RU":"Тасмота","nb-NO":"Tasmota","nn-NO":"Tasmota","pl-PL":"Tasmota","pt-PT":"Tasmota","af-ZA":"Tasmota","ar-SY":"Tasmota","bg-BG":"Tasmota","ca-ES":"Tasmota","cs-CZ":"Tasmota","el-GR":"Tasmota","et-EE":"Tasmota","fa-IR":"Tasmota","fi-FI":"Tasmota","he-IL":"Tasmota","hr-xx":"Tasmota","hu-HU":"Tasmota","hy-AM":"Tasmota","id-ID":"Tasmota","is-IS":"Tasmota","lb-xx":"Tasmota","lt-LT":"Tasmota","ro-RO":"Tasmota","sk-SK":"Tasmota","sl-SI":"Tasmota","sv-SE":"Tasmota","th-TH":"ทัสโมตา","tr-TR":"Tasmota","uk-UA":"Тасмота","vi-VN":"vietnamesisch","zh-CN":"塔斯莫塔","zh-TW":"塔斯莫塔"},"installed_release":{"en-US":"Installed version","de-DE":"Installierte Version","nl-NL":"Geïnstalleerde versie","da-DK":"Installeret version","es-ES":"Versión instalada","fr-FR":"Version installée","it-IT":"Versione installata","ru-RU":"Установленная версия","nb-NO":"Installert versjon","nn-NO":"Installert versjon","pl-PL":"Zainstalowana wersja","pt-PT":"Versão instalada","af-ZA":"Geïnstalleerde weergawe","ar-SY":"النسخة المثبتة","bg-BG":"Инсталирана версия","ca-ES":"Versió instal·lada","cs-CZ":"Nainstalovaná verze","el-GR":"Εγκατεστημένη έκδοση","et-EE":"Installitud versioon","fa-IR":"نسخه نصب شده","fi-FI":"Asennettu versio","he-IL":"גרסה מותקנת","hr-xx":"Instalirana verzija","hu-HU":"Telepített verzió","hy-AM":"Տեղադրված տարբերակը","id-ID":"Versi terinstal","is-IS":"Uppsett útgáfa","lb-xx":"Installéiert Versioun","lt-LT":"Įdiegta versija","ro-RO":"Versiune instalată","sk-SK":"Nainštalovaná verzia","sl-SI":"Nameščena različica","sv-SE":"Installerad version","th-TH":"เวอร์ชันที่ติดตั้ง","tr-TR":"Yüklü sürüm","uk-UA":"Встановлена ​​версія","vi-VN":"Phiên bản đã cài đặt","zh-CN":"安装版本","zh-TW":"安裝版本"},"available_release":{"en-US":"Available Version","de-DE":"Verfügbare Version","nl-NL":"Beschikbare versie","da-DK":"Tilgængelig version","es-ES":"Versión disponible","fr-FR":"Version disponible","it-IT":"Versione disponibile","ru-RU":"Доступная версия","nb-NO":"Tilgjengelig versjon","nn-NO":"Tilgjengelig versjon","pl-PL":"Dostępna wersja","pt-PT":"Versão disponível","af-ZA":"Beskikbare weergawe","ar-SY":"النسخة المتاحة","bg-BG":"Налична версия","ca-ES":"Versió disponible","cs-CZ":"Dostupná verze","el-GR":"Διαθέσιμη έκδοση","et-EE":"Saadaval versioon","fa-IR":"نسخه موجود","fi-FI":"Saatavilla oleva versio","he-IL":"גרסה זמינה","hr-xx":"Dostupna verzija","hu-HU":"Elérhető verzió","hy-AM":"Հասանելի տարբերակ","id-ID":"Versi yang tersedia","is-IS":"Laus útgáfa","lb-xx":"Verfügbar Versioun","lt-LT":"Galima versija","ro-RO":"Versiune disponibilă","sk-SK":"Dostupná verzia","sl-SI":"Razpoložljiva različica","sv-SE":"Tillgänglig version","th-TH":"รุ่นที่มีจำหน่าย","tr-TR":"Mevcut sürüm","uk-UA":"Доступна версія","vi-VN":"Phiên bản có sẵn","zh-CN":"可用版本","zh-TW":"可用版本"},"update_tasmota":{"en-US":"Update Tasmota","de-DE":"Tasmota Update"},"berry_driver":{"en-US":"Berry Driver","de-DE":"Berry-Driver","nl-NL":"Berry Driver","da-DK":"Berry Driver","es-ES":"Berry Driver","fr-FR":"Berry Driver","it-IT":"Berry Driver","ru-RU":"Berry Driver","nb-NO":"Berry Driver","nn-NO":"Berry Driver","pl-PL":"Berry Driver","pt-PT":"Berry Driver","af-ZA":"Berry Driver","ar-SY":"Berry Driver","bg-BG":"Berry Driver","ca-ES":"Berry Driver","cs-CZ":"Berry Driver","el-GR":"Berry Driver","et-EE":"Berry Driver","fa-IR":"Berry Driver","fi-FI":"Berry Driver","he-IL":"Berry Driver","hr-xx":"Berry Driver","hu-HU":"Berry Driver","hy-AM":"Berry Driver","id-ID":"Berry Driver","is-IS":"Berry Driver","lb-xx":"Berry Driver","lt-LT":"Berry Driver","ro-RO":"Berry Driver","sk-SK":"Berry Driver","sl-SI":"Berry Driver","sv-SE":"Berry Driver","th-TH":"Berry Driver","tr-TR":"Berry Driver","uk-UA":"Berry Driver","vi-VN":"Berry Driver","zh-CN":"Berry Driver","zh-TW":"Berry Driver"},"update_berry_driver":{"en-US":"Update Berry Driver","de-DE":"Berry-Driver Update"},"nextion_tft":{"en-US":"Nextion TFT","de-DE":"Nextion-TFT","nl-NL":"Nextion TFT","da-DK":"Nextion TFT","es-ES":"Nextion TFT","fr-FR":"Nextion TFT","it-IT":"Nextion TFT","ru-RU":"Nextion TFT","nb-NO":"Nextion TFT","nn-NO":"Nextion TFT","pl-PL":"Nextion TFT","pt-PT":"Nextion TFT","af-ZA":"Nextion TFT","ar-SY":"Nextion TFT","bg-BG":"Nextion TFT","ca-ES":"Nextion TFT","cs-CZ":"Nextion TFT","el-GR":"Nextion TFT","et-EE":"Nextion TFT","fa-IR":"Nextion TFT","fi-FI":"Nextion TFT","he-IL":"Nextion TFT","hr-xx":"Nextion TFT","hu-HU":"Nextion TFT","hy-AM":"Nextion TFT","id-ID":"Nextion TFT","is-IS":"Nextion TFT","lb-xx":"Nextion TFT","lt-LT":"Nextion TFT","ro-RO":"Nextion TFT","sk-SK":"Nextion TFT","sl-SI":"Nextion TFT","sv-SE":"Nextion TFT","th-TH":"Nextion TFT","tr-TR":"Nextion TFT","uk-UA":"Nextion TFT","vi-VN":"Nextion TFT","zh-CN":"Nextion TFT","zh-TW":"Nextion TFT"},"nspanel_model":{"en-US":"NSPanel Model","de-DE":"NSPanel Version"},"desired_release":{"en-US":"Desired Version","de-DE":"Benötigte Version","nl-NL":"Vereiste versie","da-DK":"Påkrævet version","es-ES":"Versión requerida","fr-FR":"Version requise","it-IT":"Versione richiesta","ru-RU":"Требуемая версия","nb-NO":"Nødvendig versjon","nn-NO":"Nødvendig versjon","pl-PL":"Wymagana wersja","pt-PT":"Versão necessária","af-ZA":"Vereiste weergawe","ar-SY":"النسخة المطلوبة","bg-BG":"Задължителна версия","ca-ES":"Versió obligatòria","cs-CZ":"Požadovaná verze","el-GR":"Απαιτούμενη έκδοση","et-EE":"Nõutav versioon","fa-IR":"نسخه مورد نیاز","fi-FI":"Vaadittu versio","he-IL":"גרסה נדרשת","hr-xx":"Potrebna verzija","hu-HU":"Kötelező verzió","hy-AM":"Պահանջվող տարբերակ","id-ID":"Versi yang diperlukan","is-IS":"Áskilin útgáfa","lb-xx":"Néideg Versioun","lt-LT":"Reikalinga versija","ro-RO":"Versiune obligatorie","sk-SK":"Požadovaná verzia","sl-SI":"Zahtevana različica","sv-SE":"Obligatorisk version","th-TH":"เวอร์ชันที่ต้องการ","tr-TR":"Gerekli sürüm","uk-UA":"Потрібна версія","vi-VN":"Phiên bản bắt buộc","zh-CN":"所需版本","zh-TW":"所需版本"},"update_nextion_tft":{"en-US":"Update Nextion TFT","de-DE":"Nextion TFT Update"},"update_message":{"en-US":"Update Notifications","de-DE":"Update Mitteilungen"},"scriptname":{"en-US":"Script name","de-DE":"Skriptname"},"hiddencards_offon":{"en-US":"hidden Cards (on/off)","de-DE":"ausgeblendete Seiten (an/aus)"},"easyview_layout":{"en-US":"Easyview Layout","de-DE":"Einfaches Layout"}}
              • MichaelFM
                MichaelFM
                MichaelF
                #8050
                javascript.0	15:28:12.499	info
                renderCurrentPage
                javascript.0	15:28:12.505	info
                2.1 W
                javascript.0	15:28:12.535	info
                {"DeviceName":"Tasmota"}
                javascript.0	15:28:12.656	info
                {"Status":{"Module":0,"DeviceName":"Tasmota","FriendlyName":["Tasmota",""],"Topic":"tasmota_A4ED44","ButtonTopic":"0","Power":"00","PowerLock":"00","PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin","RestartReason":"Software reset CPU","Uptime":"0T01:06:38","StartupUTC":"2026-04-08T12:21:34","Sleep":50,"CfgHolder":4617,"BootCount":42,"BCResetTime":"2024-04-13T18:49:31","SaveCount":1149},"StatusFWR":{"Version":"15.2.0(release-tasmota32)","BuildDateTime":"2025.12.12 11:08:19","Core":"3.3.4","SDK":"5.3.4.251205","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.1","CR":"469/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":2,"FileLog":0,"SysLog":0,"LogHost":"192.168.178.69","LogPort":514,"SSId":["WLAN 7270",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000001"]},"StatusMEM":{"ProgramSize":2087,"Free":792,"Heap":115,"StackLowMark":3,"PsrMax":2048,"PsrFree":2023,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"1640C8","FlashFrequency":80,"FlashMode":"DIO","Features":["0407","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80F1","00000814"],"Drivers":"1,2,!3,!4,!5,7,!8,9,10,11,12,!14,!16,!17,!20,!21,24,26,!27,29,!34,!35,38,50,52,!59,!60,62,!63,!66,!67,!68,!73,!75,82,!86,!87,!88,!91,!121","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82,89"},"StatusNET":{"Hostname":"tasmota-A4ED44-3396","IPAddress":"192.168.178.58","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.36","DNSServer2":"fd63:a0ea:8156:0:9a9b:cbff:feae:d11b","Mac":"08:D1:F9:A4:ED:44","IP6Global":"2003:df:3714:d400:ad1:f9ff:fea4:ed44","IP6Local":"fe80::ad1:f9ff:fea4:ed44%st2","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.36","DNSServer2":"fd63:a0ea:8156:0:9a9b:cbff:feae:d11b","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16},"StatusMQT":{"MqttHost":"192.168.178.69","MqttPort":1886,"MqttClientMask":"NS_Panel2","MqttClient":"NS_Panel2","MqttUser":"Mikeldk","MqttCount":2,"MqttTLS":0,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2026-04-08T13:28:12Z","Local":"2026-04-08T15:28:12","StartDST":"2026-03-29T02:00:00","EndDST":"2026-10-25T03:00:00","Timezone":99,"Sunrise":"07:13","Sunset":"20:30"},"StatusSNS":{"Time":"2026-04-08T15:28:12","ANALOG":{"Temperature1":18.7},"ESP32":{"Temperature":39.4},"TempUnit":"C"},"StatusSTS":{"Time":"2026-04-08T15:28:12","Uptime":"0T01:06:38","UptimeSec":3998,"Heap":113,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":171,"MqttCount":2,"Berry":{"HeapUsed":16,"Objects":220},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"WLAN 7270","BSSId":"98:9B:CB:AE:D1:1E","Channel":6,"Mode":"HT40","RSSI":80,"Signal":-60,"LinkCount":1,"Downtime":"0T00:00:03"},"Hostname":"tasmota-A4ED44-3396","IPAddress":"192.168.178.58"}}
                javascript.0	15:28:12.712	info
                Desired TFT Firmware: 61 / v5.1.1
                javascript.0	15:28:12.713	info
                Installed TFT Firmware: 61 / v5.1.1
                javascript.0	15:28:12.814	info
                renderCurrentPage
                javascript.0	15:28:13.134	info
                Debug mode disabled
                javascript.0	15:28:16.241	info
                hidden Cards disabled
                javascript.0	15:28:16.508	info
                Start MQTT-Port-Check -------------------------------------
                -- admin.0                   - 8081
                -- hm-rpc.0                  - 0
                -- hm-rpc.1                  - 0
                javascript.0	15:28:16.509	info
                -- hm-rpc.2                  - 0
                -- hm-rpc.3                  - 0
                -- influxdb.0                - 8086
                -- influxdb.1                - 8086
                -- influxdb.2                - 8428
                -- mihome-vacuum.0           - 5432
                -- mqtt.1                    - 1883
                -- mqtt.3                    - 1886
                -- pi-hole2.0                - 80
                -- pioneer_sc_vsx.0          - 23
                -- sainlogic.0               - 4500
                -- simple-api.0              - 8087
                -- sonoff.0                  - 1883
                -- sql.0                     - Kein Port gefunden
                -- synology.0                - 5000
                -- synology.1                - 5000
                -- telegram.0                - 8443
                -- web.0                     - 8082
                - MQTT-Port-Check OK: Instance of Adapter: mqtt.3 is running on Port:1886
                End MQTT-Port-Check ---------------------------------------
                • T tobiasp
                  Gute Morgen zusammen,
                  ich habe jetzt auch mal mein NSPANEL aktualisert nach langem. Ich habe aber ein Problem das sich die Daten im Bildschirmschoner nicht selbstständig aktualisieren. Wenn ich das Panel berühre und der Bildschirmschoner dann wieder aktiviert werden auch die Daten (Wetter) aktualisert.
                  Kennt das jemand? Oder weiß Rat wie oder was hier falsch läuft.
                  Dankeschön
                  T
                  T
                  TT-Tom
                  #8051
                  @tobiasp
                  zeige mal diese Einstellungen. Liegen im alias
                  Gruß Tom
                  Public Transport
                  NSPanel Adapter Wiki
                  MichaelFM T 2 Antworten Letzte Antwort
                  • MichaelFM MichaelF
                    renderCurrentPage
                    2.1 W
                    renderCurrentPage
                    Debug mode disabled
                    -- admin.0                   - 8081
                    -- hm-rpc.0                  - 0
                    -- hm-rpc.1                  - 0
                    -- hm-rpc.2                  - 0
                    -- hm-rpc.3                  - 0
                    -- mqtt.1                    - 1883
                    -- mqtt.3                    - 1886
                    -- pi-hole2.0                - 80
                    -- sonoff.0                  - 1883
                    -- web.0                     - 8082
                    T
                    T
                    TT-Tom
                    #8052
                    @MichaelF
                    okay nicht den den ganzen Start, es reicht der Teil wenn du auf den Button kickst
                    Gruß Tom
                    Public Transport
                    • T TT-Tom
                      @tobiasp
                      MichaelFM
                      MichaelFM
                      MichaelF
                      #8053
                      @TT-Tom
                      MichaelFM 1 Antwort Letzte Antwort
                      • MichaelFM
                        MichaelFM
                        MichaelF
                        #8054
                        Jetzt hatte ich was neues:
                        avascript.0
                        2026-04-08 15:44:25.300	info	State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
                        javascript.0
                        2026-04-08 15:44:24.576	info	State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
                        javascript.0
                        2026-04-08 15:44:15.725	info	script.js.common.WZ_test: Installed TFT Firmware: 61 / v5.1.1
                        javascript.0
                        2026-04-08 15:44:15.725	info	script.js.common.WZ_test: Desired TFT Firmware: 61 / v5.1.1
                        mqtt.3
                        2026-04-08 15:44:10.897	info	Client [NS_Panel2] publishOnSubscribe send all known states
                        mqtt.3
                        mqtt.3
                        javascript.0
                        2026-04-08 15:44:10.761	info	script.js.common.WZ_test: Tasmota upgrade complete. New Version: 15.3.0(release-nspanel)
                        mqtt.3
                        2026-04-08 15:44:10.697	info	Client [NS_Panel2] subscribes on "cmnd/NS_Panel2_fb/#" with regex /^mqtt\.3\.cmnd\.NS_Panel2_fb\..*/
                        mqtt.3
                        2026-04-08 15:44:10.697	info	Client [NS_Panel2] subscribes on "cmnd/NS_Panel2_fb/#" with regex /^cmnd\.NS_Panel2_fb\..*/
                        mqtt.3
                        2026-04-08 15:44:10.697	info	Client [NS_Panel2] subscribes on "cmnd/tasmotas/#" with regex /^mqtt\.3\.cmnd\.tasmotas\..*/
                        mqtt.3
                        2026-04-08 15:44:10.697	info	Client [NS_Panel2] subscribes on "cmnd/tasmotas/#" with regex /^cmnd\.tasmotas\..*/
                        mqtt.3
                        2026-04-08 15:44:10.696	info	Client [NS_Panel2] subscribes on "cmnd/tasmota_A4ED44/#" with regex /^mqtt\.3\.cmnd\.tasmota_A4ED44\..*/
                        mqtt.3
                        2026-04-08 15:44:10.696	info	Client [NS_Panel2] subscribes on "cmnd/tasmota_A4ED44/#" with regex /^cmnd\.tasmota_A4ED44\..*/
                        mqtt.3
                        2026-04-08 15:44:10.635	info	Client [NS_Panel2] connected with secret 1775655850631_9681
                        mqtt.3
                        2026-04-08 15:44:04.383	info	Client [NS_Panel2] connection closed: closed
                        mqtt.3
                        2026-04-08 15:44:01.928	info	Client [NS_Panel2] publishOnSubscribe send all known states
                        mqtt.3
                        mqtt.3
                        mqtt.3
                        2026-04-08 15:44:01.728	info	Client [NS_Panel2] subscribes on "cmnd/NS_Panel2_fb/#" with regex /^mqtt\.3\.cmnd\.NS_Panel2_fb\..*/
                        mqtt.3
                        2026-04-08 15:44:01.728	info	Client [NS_Panel2] subscribes on "cmnd/NS_Panel2_fb/#" with regex /^cmnd\.NS_Panel2_fb\..*/
                        mqtt.3
                        2026-04-08 15:44:01.728	info	Client [NS_Panel2] subscribes on "cmnd/tasmotas/#" with regex /^mqtt\.3\.cmnd\.tasmotas\..*/
                        mqtt.3
                        2026-04-08 15:44:01.728	info	Client [NS_Panel2] subscribes on "cmnd/tasmotas/#" with regex /^cmnd\.tasmotas\..*/
                        mqtt.3
                        2026-04-08 15:44:01.727	info	Client [NS_Panel2] subscribes on "cmnd/tasmota_A4ED44/#" with regex /^mqtt\.3\.cmnd\.tasmota_A4ED44\..*/
                        mqtt.3
                        2026-04-08 15:44:01.727	info	Client [NS_Panel2] subscribes on "cmnd/tasmota_A4ED44/#" with regex /^cmnd\.tasmota_A4ED44\..*/
                        mqtt.3
                        2026-04-08 15:44:01.672	info	Client [NS_Panel2] connected with secret 1775655841668_6708
                        javascript.0
                        2026-04-08 15:44:01.256	warn	script.js.common.WZ_test: AxiosError: read ECONNRESET at Function.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:7:24) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:869:27) at RedirectableRequest.emit (node:events:519:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:49:24) at ClientRequest.emit (node:events:531:35) at ClientRequest.emit (node:domain:489:12) at emitErrorEvent (node:_http_client:108:11) at Socket.socketErrorListener (node:_http_client:575:5) at Socket.emit (node:events:519:28) at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:46:41) at processTicksAndRejections (node:internal/process/task_queues:103:5) { isAxiosError: true, code: 'ECONNRESET', config: { transitional: { silentJSONParsing: true, forcedJSONParsing: true, clarifyTimeoutError: false, legacyInterceptorReqResOrdering: true }, adapter: [ 'xhr', 'http', 'fetch' ], transformRequest: [ [Function: transformRequest] ], transformResponse: [ [Function: transformResponse] ], timeout: 0, xsrfCookieName: 'XSRF-TOKEN', xsrfHeaderName: 'X-XSRF-TOKEN', maxContentLength: -1, maxBodyLength: -1, env: { FormData: [Function], Blob: [class Blob] }, validateStatus: [Function: validateStatus], headers: Object [AxiosHeaders] { Accept: 'application/json, text/plain, */*', 'Content-Type': undefined, 'User-Agent': 'ioBroker', 'Accept-Encoding': 'gzip, compress, deflate, br' }, method: 'get', url: 'http://192.168.178.58/cm?cmnd=Upgrade 1', allowAbsoluteUrls: true, data: undefined }, request: <ref *1> Writable { _events: { close: undefined, error: [Function: handleRequestError], prefinish: undefined, finish: undefined, drain: undefined, response: [Function: handleResponse], socket: [Array], abort: undefined }, _writableState: WritableState { highWaterMark: 65536, length: 0, corked: 0, onwrite: [Function: bound onwrite], writelen: 0, bufferedIndex: 0, pendingcb: 0, [Symbol(kState)]: 17580812, [Symbol(kBufferedValue)]: null }, _options: { maxRedirects: 21, maxBodyLength: Infinity, protocol: 'http:', path: '/cm?cmnd=Upgrade%201', method: 'GET', headers: [Object: null prototype], agents: [Object], auth: undefined, family: undefined, beforeRedirect: [Function: dispatchBeforeRedirect], beforeRedirects: [Object], http2Options: undefined, hostname: '192.168.178.58', port: '', agent: undefined, nativeProtocols: [Object], pathname: '/cm', search: '?cmnd=Upgrade%201' }, _ended: true, _ending: true, _redirectCount: 0, _redirects: [], _requestBodyLength: 0, _requestBodyBuffers: [], _eventsCount: 3, _onNativeResponse: [Function (anonymous)], _currentRequest: ClientRequest { _events: [Object: null prototype], _eventsCount: 7, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: true, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, strictContentLength: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, _header: 'GET /cm?cmnd=Upgrade%201 HTTP/1.1\r\n' + 'Accept: application/json, text/plain, */*\r\n' + 'User-Agent: ioBroker\r\n' + 'Accept-Encoding: gzip, compress, deflate, br\r\n' + 'sentry-trace: 7b3a4f0912164ca996deb25e180b9ac5-a596eca9a258425b\r\n' + 'baggage: sentry-environment=production,sentry-release=iobroker.javascript%409.0.18,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=7b3a4f0912164ca996deb25e180b9ac5\r\n' + 'Host: 192.168.178.58\r\n' + 'Connection: keep-alive\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: [Agent], socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, joinDuplicateHeaders: undefined, path: '/cm?cmnd=Upgrade%201', _ended: false, res: null, aborted: false, timeoutCb: [Function: emitRequestTimeout], upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: '192.168.178.58', protocol: 'http:', _redirectable: [Circular *1], [Symbol(shapeMode)]: false, [Symbol(kCapture)]: false, [Symbol(kBytesWritten)]: 0, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kChunkedBuffer)]: [], [Symbol(kChunkedLength)]: 0, [Symbol(kSocket)]: [Socket], [Symbol(kOutHeaders)]: [Object: null prototype], [Symbol(errored)]: null, [Symbol(kHighWaterMark)]: 65536, [Symbol(kRejectNonStandardBodyWrites)]: false, [Symbol(kUniqueHeaders)]: null }, _currentUrl: 'http://192.168.178.58/cm?cmnd=Upgrade%201', _timeout: null, [Symbol(shapeMode)]: true, [Symbol(kCapture)]: false }, cause: Error: read ECONNRESET at TCP.onStreamRead (node:internal/stream_base_commons:216:20) { errno: -104, code: 'ECONNRESET', syscall: 'read' }}
                        javascript.0
                        2026-04-08 15:44:01.222	warn	script.js.common.WZ_test: AxiosError: read ECONNRESET at Function.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:7:24) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:869:27) at RedirectableRequest.emit (node:events:519:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:49:24) at ClientRequest.emit (node:events:531:35) at ClientRequest.emit (node:domain:489:12) at emitErrorEvent (node:_http_client:108:11) at Socket.socketErrorListener (node:_http_client:575:5) at Socket.emit (node:events:519:28) at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:46:41) at processTicksAndRejections (node:internal/process/task_queues:103:5) { isAxiosError: true, code: 'ECONNRESET', config: { transitional: { silentJSONParsing: true, forcedJSONParsing: true, clarifyTimeoutError: false, legacyInterceptorReqResOrdering: true }, adapter: [ 'xhr', 'http', 'fetch' ], transformRequest: [ [Function: transformRequest] ], transformResponse: [ [Function: transformResponse] ], timeout: 0, xsrfCookieName: 'XSRF-TOKEN', xsrfHeaderName: 'X-XSRF-TOKEN', maxContentLength: -1, maxBodyLength: -1, env: { FormData: [Function], Blob: [class Blob] }, validateStatus: [Function: validateStatus], headers: Object [AxiosHeaders] { Accept: 'application/json, text/plain, */*', 'Content-Type': undefined, 'User-Agent': 'ioBroker', 'Accept-Encoding': 'gzip, compress, deflate, br' }, method: 'get', url: 'http://192.168.178.58/cm?cmnd=OtaUrl http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin', allowAbsoluteUrls: true, data: undefined }, request: <ref *1> Writable { _events: { close: undefined, error: [Function: handleRequestError], prefinish: undefined, finish: undefined, drain: undefined, response: [Function: handleResponse], socket: [Array], abort: undefined }, _writableState: WritableState { highWaterMark: 65536, length: 0, corked: 0, onwrite: [Function: bound onwrite], writelen: 0, bufferedIndex: 0, pendingcb: 0, [Symbol(kState)]: 17580812, [Symbol(kBufferedValue)]: null }, _options: { maxRedirects: 21, maxBodyLength: Infinity, protocol: 'http:', path: '/cm?cmnd=OtaUrl%20http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin', method: 'GET', headers: [Object: null prototype], agents: [Object], auth: undefined, family: undefined, beforeRedirect: [Function: dispatchBeforeRedirect], beforeRedirects: [Object], http2Options: undefined, hostname: '192.168.178.58', port: '', agent: undefined, nativeProtocols: [Object], pathname: '/cm', search: '?cmnd=OtaUrl%20http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin' }, _ended: true, _ending: true, _redirectCount: 0, _redirects: [], _requestBodyLength: 0, _requestBodyBuffers: [], _eventsCount: 3, _onNativeResponse: [Function (anonymous)], _currentRequest: ClientRequest { _events: [Object: null prototype], _eventsCount: 7, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: true, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, strictContentLength: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, _header: 'GET /cm?cmnd=OtaUrl%20http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin HTTP/1.1\r\n' + 'Accept: application/json, text/plain, */*\r\n' + 'User-Agent: ioBroker\r\n' + 'Accept-Encoding: gzip, compress, deflate, br\r\n' + 'sentry-trace: 7b3a4f0912164ca996deb25e180b9ac5-a596eca9a258425b\r\n' + 'baggage: sentry-environment=production,sentry-release=iobroker.javascript%409.0.18,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=7b3a4f0912164ca996deb25e180b9ac5\r\n' + 'Host: 192.168.178.58\r\n' + 'Connection: keep-alive\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: [Agent], socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, joinDuplicateHeaders: undefined, path: '/cm?cmnd=OtaUrl%20http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin', _ended: false, res: null, aborted: false, timeoutCb: [Function: emitRequestTimeout], upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: '192.168.178.58', protocol: 'http:', _redirectable: [Circular *1], [Symbol(shapeMode)]: false, [Symbol(kCapture)]: false, [Symbol(kBytesWritten)]: 0, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kChunkedBuffer)]: [], [Symbol(kChunkedLength)]: 0, [Symbol(kSocket)]: [Socket], [Symbol(kOutHeaders)]: [Object: null prototype], [Symbol(errored)]: null, [Symbol(kHighWaterMark)]: 65536, [Symbol(kRejectNonStandardBodyWrites)]: false, [Symbol(kUniqueHeaders)]: null }, _currentUrl: 'http://192.168.178.58/cm?cmnd=OtaUrl%20http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin', _timeout: null, [Symbol(shapeMode)]: true, [Symbol(kCapture)]: false }, cause: Error: read ECONNRESET at TCP.onStreamRead (node:internal/stream_base_commons:216:20) { errno: -104, code: 'ECONNRESET', syscall: 'read' }}
                        mqtt.3
                        2026-04-08 15:44:01.111	info	Client [NS_Panel2] connection closed: closed
                        mqtt.3
                        2026-04-08 15:43:28.009	info	Client [NS_Panel2] publishOnSubscribe send all known states
                        mqtt.3
                        2026-04-08 15:43:28.008	info	Client [NS_Panel2] publishOnSubscribe send all known states
                        mqtt.3
                        javascript.0
                        2026-04-08 15:43:27.859	warn	script.js.common.WZ_test: Tasmota in Safeboot - Please wait while upgrading
                        mqtt.3
                        2026-04-08 15:43:27.808	info	Client [NS_Panel2] subscribes on "cmnd/NS_Panel2_fb/#" with regex /^mqtt\.3\.cmnd\.NS_Panel2_fb\..*/
                        mqtt.3
                        2026-04-08 15:43:27.808	info	Client [NS_Panel2] subscribes on "cmnd/NS_Panel2_fb/#" with regex /^cmnd\.NS_Panel2_fb\..*/
                        mqtt.3
                        2026-04-08 15:43:27.808	info	Client [NS_Panel2] subscribes on "cmnd/tasmotas/#" with regex /^mqtt\.3\.cmnd\.tasmotas\..*/
                        mqtt.3
                        2026-04-08 15:43:27.808	info	Client [NS_Panel2] subscribes on "cmnd/tasmotas/#" with regex /^cmnd\.tasmotas\..*/
                        mqtt.3
                        2026-04-08 15:43:27.808	info	Client [NS_Panel2] subscribes on "cmnd/tasmota_A4ED44/#" with regex /^mqtt\.3\.cmnd\.tasmota_A4ED44\..*/
                        mqtt.3
                        2026-04-08 15:43:27.807	info	Client [NS_Panel2] subscribes on "cmnd/tasmota_A4ED44/#" with regex /^cmnd\.tasmota_A4ED44\..*/
                        mqtt.3
                        2026-04-08 15:43:27.752	info	Client [NS_Panel2] connected with secret 1775655807747_5750
                        mqtt.3
                        2026-04-08 15:43:22.638	info	Client [NS_Panel2] connection closed: closed
                        javascript.0
                        2026-04-08 15:43:22.206	warn	script.js.common.WZ_test: Please wait a few seconds longer when launching the NSPanel. Not all parameters are loaded yet.
                        javascript.0
                        2026-04-08 15:43:22.205	warn	script.js.common.WZ_test: Please wait a few seconds longer when launching the NSPanel. Not all parameters are loaded yet.
                        javascript.0
                        2026-04-08 15:43:21.909	warn	script.js.common.WZ_test: Please wait a few seconds longer when launching the NSPanel. Not all parameters are loaded yet.
                        javascript.0
                        javascript.0
                        2026-04-08 15:43:21.404	warn	script.js.common.WZ_test: Please wait a few seconds longer when launching the NSPanel. Not all parameters are loaded yet.
                        javascript.0
                        javascript.0
                        2026-04-08 15:43:20.200	warn	script.js.common.WZ_test: Please wait a few seconds longer when launching the NSPanel. Not all parameters are loaded yet.
                        javascript.0
                        2026-04-08 15:43:20.199	warn	script.js.common.WZ_test: Please wait a few seconds longer when launching the NSPanel. Not all parameters are loaded yet.
                        javascript.0
                        2026-04-08 15:43:18.575	warn	script.js.common.WZ_test: Please wait a few seconds longer when launching the NSPanel. Not all parameters are loaded yet.
                        javascript.0
                        javascript.0
                        2026-04-08 15:43:10.774	warn	script.js.common.WZ_test: Please wait a few seconds longer when launching the NSPanel. Not all parameters are loaded yet.
                        javascript.0
                          @TT-Tom
                          MichaelFM
                          MichaelFM
                          MichaelF
                          #8055
                          Sorry Falscher Screen, das ist der Richtige vom Test:
                          • T TT-Tom
                            @road_runner31
                            Es geht nicht mit Sonoff, da dieser den Topic anders verarbeitet und auch andersrum sortiert.
                            Die Fehlermeldung können vom Screensaver. Bitte immer Logauszüge mit senden. Vom Scriptstart und vom Fehler.
                            R
                            R
                            road_runner31
                            #8056
                            @TT-Tom Danke! Ich hab alles (Panel und Script) neu gestartet, aktuell sehe ich die Fehler vom Wetteradapter nicht (merkwürdig..).
                            Im Log erscheint nur zyklisch folgendes:
                            8.4.2026, 15:47:17.623	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: Stopping script
                            8.4.2026, 15:47:24.574	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: Compiling TypeScript source
                            8.4.2026, 15:47:25.185	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: source code did not change, using cached compilation result...
                            8.4.2026, 15:47:25.269	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                            8.4.2026, 15:47:25.274	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: setObjects enabled - create Alias Channels possible
                            8.4.2026, 15:47:25.278	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: weather alias for pirate-weather.0. already exists
                            8.4.2026, 15:47:25.287	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                            8.4.2026, 15:47:25.338	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: Desired TFT Firmware: 61 / v5.1.1
                            8.4.2026, 15:47:25.338	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: Installed TFT Firmware: 53 / v[object Object]
                            8.4.2026, 15:47:25.386	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: Debug mode disabled
                            8.4.2026, 15:47:25.792	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: hidden Cards disabled
                            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: Start MQTT-Port-Check -------------------------------------
                            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: -- admin.0                   - 8081
                            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: -- bambulab.0                - 8883
                            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: -- evcc.0                    - 7070
                            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: -- mqtt.0                    - 1889
                            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: -- sonoff.0                  - 1888
                            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: -- sun2000.0                 - 502
                            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: -- web.0                     - 8082
                            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1889
                            8.4.2026, 15:47:27.263	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: End MQTT-Port-Check ---------------------------------------
                            8.4.2026, 15:47:52.803	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: Desired TFT Firmware: 61 / v5.1.1
                            8.4.2026, 15:47:52.803	[info ]: javascript.0 (22192) script.js.NSPanel.NSPanels: Installed TFT Firmware: 53 / v[object Object]
                            8.4.2026, 15:48:03.185	[warn ]: javascript.0 (22192)     at HandleScreensaverUpdate (script.js.NSPanel.NSPanels:14476:31)
                            8.4.2026, 15:48:03.185	[warn ]: javascript.0 (22192)     at HandleScreensaver (script.js.NSPanel.NSPanels:13990:5)
                            8.4.2026, 15:48:03.186	[warn ]: javascript.0 (22192)     at HandleMessage (script.js.NSPanel.NSPanels:5806:21)
                            8.4.2026, 15:48:03.186	[warn ]: javascript.0 (22192)     at script.js.NSPanel.NSPanels:5493:21
                            8.4.2026, 15:48:03.186	[warn ]: javascript.0 (22192)     at step (script.js.NSPanel.NSPanels:33:23)
                            8.4.2026, 15:48:03.186	[warn ]: javascript.0 (22192)     at Object.next (script.js.NSPanel.NSPanels:14:53)
                            8.4.2026, 15:48:03.186	[warn ]: javascript.0 (22192)     at script.js.NSPanel.NSPanels:8:71
                            8.4.2026, 15:48:03.186	[warn ]: javascript.0 (22192)     at HandleScreensaverUpdate (script.js.NSPanel.NSPanels:14476:31)
                            8.4.2026, 15:48:03.188	[warn ]: javascript.0 (22192)     at HandleScreensaver (script.js.NSPanel.NSPanels:13990:5)
                            8.4.2026, 15:48:03.188	[warn ]: javascript.0 (22192)     at HandleMessage (script.js.NSPanel.NSPanels:5806:21)
                            8.4.2026, 15:48:03.188	[warn ]: javascript.0 (22192)     at script.js.NSPanel.NSPanels:5493:21
                            8.4.2026, 15:48:03.188	[warn ]: javascript.0 (22192)     at step (script.js.NSPanel.NSPanels:33:23)
                            8.4.2026, 15:48:03.188	[warn ]: javascript.0 (22192)     at Object.next (script.js.NSPanel.NSPanels:14:53)
                            8.4.2026, 15:48:03.188	[warn ]: javascript.0 (22192)     at script.js.NSPanel.NSPanels:8:71
                            8.4.2026, 15:48:03.189	[warn ]: javascript.0 (22192)     at HandleScreensaverUpdate (script.js.NSPanel.NSPanels:14476:31)
                            8.4.2026, 15:48:03.189	[warn ]: javascript.0 (22192)     at HandleScreensaver (script.js.NSPanel.NSPanels:13990:5)
                            8.4.2026, 15:48:03.189	[warn ]: javascript.0 (22192)     at HandleMessage (script.js.NSPanel.NSPanels:5806:21)
                            8.4.2026, 15:48:03.189	[warn ]: javascript.0 (22192)     at script.js.NSPanel.NSPanels:5493:21
                            8.4.2026, 15:48:03.189	[warn ]: javascript.0 (22192)     at step (script.js.NSPanel.NSPanels:33:23)
                            8.4.2026, 15:48:03.189	[warn ]: javascript.0 (22192)     at Object.next (script.js.NSPanel.NSPanels:14:53)
                            8.4.2026, 15:48:03.189	[warn ]: javascript.0 (22192)     at script.js.NSPanel.NSPanels:8:71
                            8.4.2026, 15:48:03.190	[warn ]: javascript.0 (22192)     at HandleScreensaverUpdate (script.js.NSPanel.NSPanels:14476:31)
                            8.4.2026, 15:48:03.190	[warn ]: javascript.0 (22192)     at HandleScreensaver (script.js.NSPanel.NSPanels:13990:5)
                            8.4.2026, 15:48:03.190	[warn ]: javascript.0 (22192)     at HandleMessage (script.js.NSPanel.NSPanels:5806:21)
                            8.4.2026, 15:48:03.190	[warn ]: javascript.0 (22192)     at script.js.NSPanel.NSPanels:5493:21
                            8.4.2026, 15:48:03.190	[warn ]: javascript.0 (22192)     at step (script.js.NSPanel.NSPanels:33:23)
                            8.4.2026, 15:48:03.190	[warn ]: javascript.0 (22192)     at Object.next (script.js.NSPanel.NSPanels:14:53)
                            8.4.2026, 15:48:03.190	[warn ]: javascript.0 (22192)     at script.js.NSPanel.NSPanels:8:71
                            • T
                              T
                              ticaki
                              #8057
                              Nur um es mal erwähnt zu haben - der Adapter bietet da deutlich mehr Infos im Log - daher kommen da wohl weniger solche Fragen :)
                              Spenden
                                T
                                T
                                TT-Tom
                                #8058
                                @MichaelF sagte:
                                sorry Falscher Screen, das ist der Richtige vom Test:
                                das war nicht an dich gerichtet.
                                Ist das TFT Update sauber durchgelaufen? Dann starte das Script noch einmal neu. Stell das Panel auf Debug und klick dann auf den Button. dann kopieren das Log vom Klick.
                                Gruß Tom
                                Public Transport
                                • R road_runner31
                                  T
                                  T
                                  TT-Tom
                                  #8059
                                  @road_runner31
                                  zeigemal deine Screensaver Config aus dem Script und starte Tasmota nochmal neu.
                                  Welche Version vom Script, Berry-Treiber und TFT läuft aktuell bei dir?
                                  @road_runner31 sagte:
                                  was meinst du mit zyklisch, startet das Script selber immer neu oder das Panel?
                                  Gruß Tom
                                  Public Transport
                                    Ist hier vielleicht irgendetwas Falsch?
                                    Das ist der Alias der Heizung.
                                    T
                                    T
                                    TT-Tom
                                    #8060
                                    @MichaelF sagte:
                                    setze mal bitte bei ON_ACTUAL auch den State ein. ist ein Versuch.
                                    Gruß Tom
                                    Public Transport
                                    • T TT-Tom
                                      @MichaelF sagte:
                                      MichaelFM
                                      MichaelFM
                                      MichaelF
                                      schrieb am zuletzt editiert von MichaelF
                                      #8061
                                      @TT-Tom sagte:
                                      @MichaelF sagte:
                                      Ändert sich leider nichts:
                                      javascript.0
                                      2026-04-09 12:11:34.406	warn	script.js.common.NsPanelWz: More than 100 subscriptions registered. Check your script!
                                      javascript.0
                                      2026-04-09 12:11:34.405	warn	script.js.common.NsPanelWz: More than 100 subscriptions registered. Check your script!
                                      javascript.0
                                      javascript.0
                                      2026-04-09 12:11:34.209	info	State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
                                      javascript.0
                                      2026-04-09 12:11:34.208	info	State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
                                      javascript.0
                                      2026-04-09 12:11:28.997	info	State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
                                      javascript.0
                                      2026-04-09 12:11:26.055	info	State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
                                      Das diese Meldung kommt mit den 100- 200 - 300 fängt auch erst an wenn die Temperatur und die Luftfeuchte anfangen zu blinken, also man meint das Panel würde ganz viele anfragen senden oder bekommen.
                                      Ist mir bis jetzt noch nicht aufgefallen.
                                      javascript.0
                                      2026-04-09 12:14:55.955	info	script.js.common.NsPanelWz: Stopping script
                                      javascript.0
                                      2026-04-09 12:14:55.955	error	script.js.common.NsPanelWz: Script is calling setState more than 1000 times per minute! Stopping Script now! Please check your script!
                                      sourceanalytix.0
                                      2026-04-09 12:14:51.678	info	Device reset detected for 0_userdata.0.PV_Ersparnis, feature disabled processing normally)
                                      host.IoBroker64Bit
                                      2026-04-09 12:14:47.893	info	instance system.adapter.luftdaten.0 having pid 515161 terminated with code 0 (NO_ERROR)
                                      luftdaten.0
                                      2026-04-09 12:14:47.357	info	Terminated (NO_ERROR): Without reason
                                      luftdaten.0
                                      2026-04-09 12:14:47.007	info	starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
                                      host.IoBroker64Bit
                                      2026-04-09 12:14:44.040	info	instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 515161
                                      javascript.0
                                      2026-04-09 12:13:59.229	warn	script.js.common.NsPanelWz: More than 4100 subscriptions registered. Check your script!
                                      javascript.0
                                      2026-04-09 12:13:59.228	warn	script.js.common.NsPanelWz: More than 4100 subscriptions registered. Check your script!
                                      javascript.0
                                      javascript.0
                                      2026-04-09 12:13:59.219	warn	script.js.common.NsPanelWz: More than 4000 subscriptions registered. Check your script!
                                      javascript.0
                                      javascript.0
                                      • MichaelFM
                                        MichaelFM
                                        MichaelF
                                        #8062
                                        Hier sieht man es:
                                        20260409_121617.mp4
                                        • T
                                          T
                                          ticaki
                                          #8063
                                          Da werden rekursiv states subscripted - Das im Skript zu finden wird super lustig. Außer @tt-tom kennt das Problem
                                          könnte ich dich nicht für den Adapter erwärmen - ab der nächsten Adapterversion kann man da auch über den admin grids und entities (einfach) anlegen und vereinfacht die Wartung und den Support.
                                          einfach: die pageitems bieten erstmal nur die Basis einstellmöglichkeiten - id, navigation, icon, farbe
                                          https://forum.iobroker.net/topic/80055/betatest-adapter-nspanel-lovelace-ui-v0.13.x
                                          Spenden
                                          84.0k
