  4. Sourceanalytix: db closed Fehler um 0.00 Uhr
    6.4k
db closxedsourceanalytix
3 Beiträge 2 Kommentatoren 140 Aufrufe 2 Beobachtet
  • Q Offline
    Q Offline
    quinti
    Hallo @zsmmn,
    habe beim sourceanalytix Adapter jetzt 2x in Folge nachts beim berechnen der Tageswerte folgende Fehler. Tageswerte werden nicht zurück gesetzt:
    sourceanalytix.1	2026-04-07 00:11:10.638	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1775146808845,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1775146808845} | stateDetails {"consumption":true,"deviceName":"mqtt__1__evcc__loadpoints__1__chargeTotalImport","financialCategory":"costs","headCategory":"consumed","meter_values":true,"stateType":"Strompreis ","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1}
    sourceanalytix.1	2026-04-07 00:00:22.655	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1775146808845,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1775146808845} | stateDetails {"consumption":true,"deviceName":"mqtt__1__evcc__loadpoints__1__chargeTotalImport","financialCategory":"costs","headCategory":"consumed","meter_values":true,"stateType":"Strompreis ","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1}
    sourceanalytix.1	2026-04-07 00:00:00.638	error	Error: DB closed
    sourceanalytix.1	2026-04-07 00:00:00.634	error	Error: DB closed
    sourceanalytix.1	2026-04-07 00:00:00.633	error	Error: DB closed
    sourceanalytix.1	2026-04-07 00:00:00.627	error	Error: DB closed
    sourceanalytix.1	2026-04-07 00:00:00.626	error	Error: DB closed
    sourceanalytix.1	2026-04-07 00:00:00.617	error	Error: DB closed
    sourceanalytix.1	2026-04-07 00:00:00.616	error	Error: DB closed
    sourceanalytix.1	2026-04-07 00:00:00.592	warn	get state error: Connection is closed.
    • crunchipC Offline
      crunchipC Offline
      Prüfe den MQTT-Publisher von mqtt__1__evcc__loadpoints__1__chargeTotalImport: Der State muss als numerischer Zählerstand stabil ankommen, nicht sporadisch null.
      Prüfe in ioBroker den Verlauf des States direkt vor dem Fehlerzeitpunkt, ob dort val:null oder ein echter Zahlenwert steht.
      Wenn der Wert nach einem Neustart oder Reset kurz springt, kontrolliere die Reset-Erkennung und den Startwert, weil SourceAnalytix dafür explizite Logik verwendet.
      • Q Offline
        Q Offline
        quinti
        es war tatsächlich ein bug in evvc, der Wert wurde in einer Version nicht geschrieben und daher <null>.
        Ist behben, danke!
