<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Sourceanalytix: db closed Fehler um 0.00 Uhr]]></title><description><![CDATA[<p dir="auto">Hallo @zsmmn,</p>
<p dir="auto">habe beim sourceanalytix Adapter jetzt 2x in Folge nachts beim berechnen der Tageswerte folgende Fehler. Tageswerte werden nicht zurück gesetzt:</p>
<pre><code>sourceanalytix.1	2026-04-07 00:11:10.638	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1775146808845,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1775146808845} | stateDetails {"consumption":true,"deviceName":"mqtt__1__evcc__loadpoints__1__chargeTotalImport","financialCategory":"costs","headCategory":"consumed","meter_values":true,"stateType":"Strompreis ","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1}
sourceanalytix.1	2026-04-07 00:00:22.655	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1775146808845,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1775146808845} | stateDetails {"consumption":true,"deviceName":"mqtt__1__evcc__loadpoints__1__chargeTotalImport","financialCategory":"costs","headCategory":"consumed","meter_values":true,"stateType":"Strompreis ","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1}
sourceanalytix.1	2026-04-07 00:00:00.638	error	Error: DB closed
sourceanalytix.1	2026-04-07 00:00:00.634	error	Error: DB closed
sourceanalytix.1	2026-04-07 00:00:00.633	error	Error: DB closed
sourceanalytix.1	2026-04-07 00:00:00.627	error	Error: DB closed
sourceanalytix.1	2026-04-07 00:00:00.626	error	Error: DB closed
sourceanalytix.1	2026-04-07 00:00:00.617	error	Error: DB closed
sourceanalytix.1	2026-04-07 00:00:00.616	error	Error: DB closed
sourceanalytix.1	2026-04-07 00:00:00.592	warn	get state error: Connection is closed.
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/84246/sourceanalytix-db-closed-fehler-um-0.00-uhr</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Apr 2026 20:16:57 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/84246.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Apr 2026 08:15:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Sourceanalytix: db closed Fehler um 0.00 Uhr on Mon, 13 Apr 2026 06:20:41 GMT]]></title><description><![CDATA[<p dir="auto">es war tatsächlich ein bug in evvc, der Wert wurde in einer Version nicht geschrieben und daher &lt;null&gt;.<br />
Ist behben, danke!</p>
]]></description><link>https://forum.iobroker.net/post/1334316</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334316</guid><dc:creator><![CDATA[quinti]]></dc:creator><pubDate>Mon, 13 Apr 2026 06:20:41 GMT</pubDate></item><item><title><![CDATA[Reply to Sourceanalytix: db closed Fehler um 0.00 Uhr on Tue, 07 Apr 2026 10:48:53 GMT]]></title><description><![CDATA[<p dir="auto">Prüfe den MQTT-Publisher von mqtt__1__evcc__loadpoints__1__chargeTotalImport: Der State muss als numerischer Zählerstand stabil ankommen, nicht sporadisch null.<br />
Prüfe in ioBroker den Verlauf des States direkt vor dem Fehlerzeitpunkt, ob dort val:null oder ein echter Zahlenwert steht.<br />
Wenn der Wert nach einem Neustart oder Reset kurz springt, kontrolliere die Reset-Erkennung und den Startwert, weil SourceAnalytix dafür explizite Logik verwendet.</p>
]]></description><link>https://forum.iobroker.net/post/1333382</link><guid isPermaLink="true">https://forum.iobroker.net/post/1333382</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 07 Apr 2026 10:48:53 GMT</pubDate></item></channel></rss>
