  3. Entwicklung
  4. How to fork and work on an existing adapter?
16 Beiträge 6 Kommentatoren 622 Aufrufe 4 Beobachtet
  • Frederic BeisterF
    Frederic BeisterF
    Frederic Beister
    I am currently in the process of refactoring my javascripts because they have grown significantly and become harder and harder to maintain.
    I have an ancient workflow where I have multiple global/ scripts I concatenate with a bash script because - in my case - order matters.
    I want to get rid of that and tried to find out, in what order global scripts are concatenated. It seems like it is only mandated by the order they come out of the DB.
    Now I want to fork the iobroker.javascript adapter, add debug logging and potentially make the load order deterministic (if it isn't yet). How do I do that?
    I tried the following:
    • fork the adapter
    • modify code (added log statements only for now)
    • replaced all github.com/iobroker/iobroker.javascript with github.com/fbeister/iobroker.javascript
    • Commited changes and pushed to master of fork
    • In iobroker, "install from github" with my URL
    This correctly picks up my commit hash and also puts a package.json containing my version, URL, etc. into the node_modules folder of iobroker.
    Nevertheless, my changes are nowhere to be seen - I know that TS is transpiled to JS, but my changes are inside log strings for testing and main.js contains the "old" ones.
    Could someone shed some light on the local dev loop for this?
    • mcm1957M
      mcm1957M
      mcm1957
      You might try to joind the english developer group at telegram: t.me/ioBroker_dev_en
      But be warned - there are very few english speaking devs around an the javascript adapter is for sure not the best place to start developing an ioBroker adapter.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • Frederic BeisterF
        Frederic BeisterF
        Frederic Beister
        Ich crossposte mal nach DE
        • Frederic BeisterF
          Frederic BeisterF
          Frederic Beister
          Korrektur - ich darf das wohl nicht.
          • Frederic BeisterF Frederic Beister
            @Frederic-Beister ich schieb dich mal komplett rüber
            • HomoranH Homoran verschob dieses Thema von Development am
            • mcm1957M
              mcm1957M
              mcm1957
              Ok, dann epfehle ich die deutschen Entwicklergruppen auf Telegram / Discord.
              • T
                T
                ticaki
                Wo hast du was geändert - wenn in einer .ts Datei, hast du transpiliert?
                Spenden
                • Frederic BeisterF
                  Frederic BeisterF
                  Frederic Beister
                  Ich habe in main.ts einfach ein paar this.log.infos angepasst und auch hinzugefügt. Ich ging davon aus, dass der "Installiere von GitHub" Workflow in ioBroker das transpilieren macht - weil ich die besagten logmessages nirgends sonst in der codebase gefunden habe, am Ende aber ein main.js mit der (unmodifizierten) message liegt.
                  T OliverIOO 2 Antworten Letzte Antwort
                    • fork the adapter
                    OliverIOO
                    OliverIOO
                    OliverIO
                    @Frederic-Beister
                    Jetzt muss ich mal fragen:
                    Du willst am javascript Adapter etwas machen?
                    Oder dein Skripte überarbeiten?
                    Wenn du am Adapter etwas machen möchtest, dann Forke den Adapter auf t GitHub in dein persönliches Account
                    Und clone dann dieses Repository auf die lokale Maschine.
                    Mit dem Iobroker dev-Server kannst du dann eine lokale Iobroker Instanz laufen lassen und auch debuggen
                    Wenn du deine Skripte besser debuggen willst dann gibt es für vscode eine Erweiterung, die dir deine Skripte synchronisiert.
                    Leider stehen wir unter VS Code die Iobroker Funktionen nicht zur Verfügung, aber mit stub Funktionen kann man sich behelfen.
                    Wenn du es richtig umfangreich machen möchtest, könntest du deine Funktionalitäten auch alle in einem eigenen Adapter legen, da hast du dann alle Möglichkeiten
                    Meine Adapter und Widgets
                    Links im Profil
                      T
                      T
                      ticaki
                      @Frederic-Beister sagte in How to fork and work on an existing adapter?:
                      Nein macht er nicht. Der transpilierte Code liegt in ./build. Darin code zu ändern wäre nix für mich.
                      Heißt: Mach das was Oliver schreibst - lokale Entwicklungsumgebung einrichten und mit dev-server oder npm run build den code transpilieren
                      Spenden
                        OliverIOO
                        OliverIOO
                        OliverIO
                        @Frederic-Beister
                        In der Package.json sind die scripte hinterlegt mit der Build ausgeführt wird.
                        Suche nach Build
                        Links im Profil
                        • T
                          T
                          ticaki
                          Kenne jetzt nicht seinen wissenstand - die ist da aber sehr umfangreich - daher npm run build
                          Spenden
                          • Frederic BeisterF
                            Frederic BeisterF
                            Frederic Beister
                            Argh! Meine IDE war "hilfreich" und hat den build/ Ordner ausgeblendet. Da kann die Volltextsuche auch nix finden. Sorry for the noise!
                              OliverIOO
                              OliverIOO
                              OliverIO
                              @Frederic-Beister welche ide?
                              Links im Profil
                              • Frederic BeisterF
                                Frederic BeisterF
                                Frederic Beister
                                Ich verwende IntelliJ IDEA
                                • A
                                  A
                                  azamir
                                  Die globalen Skripte werden in der Reihenfolge konkateniert, in der sie hinzugefüht wurden. Ich habe eine Option hinzugefügt, sie alphabetisch zu sortieren: https://github.com/ioBroker/ioBroker.javascript/pull/2167
                                  83.8k
