  4. Tuya-Adapter wird nach kurzer Zeit Orange (Status Gelb)
    6.4k
30 Beiträge 4 Kommentatoren 1.6k Aufrufe 3 Beobachtet
    @Horst-Böttcher sagte in Tuya-Adapter wird nach kurzer Zeit Orange (Status Gelb):
    oder an einer Ressourcen-Knappheit (bei 36 Instanzen auf knapp 5GB RAM) liegt.
    Könnte man an der Ausgabe von
    iob diag
    eher sehen.
    Horst BöttcherH Offline
    Horst Böttcher
    @Thomas-Braun sagte in Tuya-Adapter wird nach kurzer Zeit Orange (Status Gelb):
    iob diag
    ```bash
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Ubuntu 24.04.4 LTS
     Static hostname: ioBroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-18-pve
        Architecture: x86-64
    OS is similar to: debian
    model name      : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     19:34:00 up 19 days, 11:51,  3 users,  load average: 0.75, 0.74, 0.66
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Ubuntu LTS release codenamed 'noble'!
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2026-03-22 19:34:00 CET
               Universal time: Sun 2026-03-22 18:34:00 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi sudo users iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev users
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            5.2G        2.9G        2.0G         86K        324M        2.4G
    Swap:           1.1G        1.1G         86K
    Total:          6.3G        4.0G        2.0G
    Active iob-Instances:   37
             5000 M total memory
             2743 M used memory
             1407 M active memory
             1487 M inactive memory
             1946 M free memory
                0 M buffer memory
              309 M swap cache
             1024 M total swap
             1023 M used swap
                0 M free swap
    top - 19:34:00 up 19 days, 11:51,  3 users,  load average: 0.77, 0.74, 0.66
    Tasks:  76 total,   1 running,  75 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  4.5 us,  4.5 sy,  0.0 ni, 90.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   5000.0 total,   1945.1 free,   2745.2 used,    309.9 buff/cache
    MiB Swap:   1024.0 total,      0.1 free,   1023.9 used.   2254.8 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * dev-hugepages.mount  loaded failed failed Huge Pages File System
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    * apparmor.service     loaded failed failed Load AppArmor profiles
    * postfix@-.service    loaded failed failed Postfix Mail Transport Agent (instance -)
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    4 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--101--disk--0 ext4    20G   11G  8.4G  55% /
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs  3.9G     0  3.9G   0% /dev/shm
    tmpfs                            tmpfs  1.6G  156K  1.6G   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs  779M  8.0K  779M   1% /run/user/1001
    [Tue Mar  3 07:24:16 2026] EXT4-fs (dm-1): mounted filesystem 9a217619-e46b-4485-87d5-060a033d8eb8 ro with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:24:16 2026] EXT4-fs (dm-1): re-mounted 9a217619-e46b-4485-87d5-060a033d8eb8 r/w.
    [Tue Mar  3 07:25:55 2026] EXT4-fs (dm-13): mounted filesystem 7c89b478-6c41-4c63-8acf-64c8b824f8d2 r/w with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:25:57 2026] EXT4-fs (dm-6): warning: mounting fs with errors, running e2fsck is recommended
    [Tue Mar  3 07:25:57 2026] EXT4-fs (dm-6): mounted filesystem 3cb29323-3f31-48bf-85fa-4669576c6456 r/w with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:26:00 2026] EXT4-fs (dm-14): mounted filesystem 7a1fe54e-bfb1-4545-b3b4-e51abe58f799 r/w with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:26:03 2026] EXT4-fs (dm-9): mounted filesystem fa472f3a-f7f0-490d-ba69-4b70c4fcf4d5 r/w with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:26:06 2026] EXT4-fs (dm-8): mounted filesystem 9f2296d1-1174-4921-82ea-ccedf30fd71d r/w with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:26:09 2026] EXT4-fs (dm-15): mounted filesystem 7705a036-1824-42cb-8916-286fa4487659 r/w with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:26:12 2026] EXT4-fs (dm-16): mounted filesystem 148a236c-c4d2-476f-91da-7038b68abb67 r/w with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:26:15 2026] EXT4-fs (dm-17): warning: mounting fs with errors, running e2fsck is recommended
    [Tue Mar  3 07:26:15 2026] EXT4-fs (dm-17): mounted filesystem 054ab45e-076f-49c5-8986-9991b37a84e7 r/w with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:26:23 2026] EXT4-fs (dm-18): mounted filesystem a09f3a7a-af85-40b8-a17d-4b8158c89550 r/w with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:27:00 2026] EXT4-fs (dm-10): mounted filesystem fb7945d7-0d68-47d2-be43-54432eb7b263 r/w with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:27:03 2026] EXT4-fs (dm-11): warning: mounting fs with errors, running e2fsck is recommended
    [Tue Mar  3 07:27:03 2026] EXT4-fs (dm-11): mounted filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c r/w with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:27:15 2026] EXT4-fs (dm-12): mounted filesystem 7cb3234b-1eb0-434f-87f5-300efd22ce60 r/w with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:31:24 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Tue Mar  3 07:31:24 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Tue Mar  3 07:31:24 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Tue Mar  3 07:31:24 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Tue Mar  3 07:31:24 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Tue Mar  3 07:31:24 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Tue Mar  3 07:31:53 2026] EXT4-fs (dm-11): unmounting filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c.
    [Tue Mar  3 07:31:54 2026] EXT4-fs (dm-11): warning: mounting fs with errors, running e2fsck is recommended
    [Tue Mar  3 07:31:54 2026] EXT4-fs (dm-11): mounted filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c r/w with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:37:16 2026] EXT4-fs (dm-11): unmounting filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c.
    [Tue Mar  3 07:37:47 2026] EXT4-fs (dm-11): warning: mounting fs with errors, running e2fsck is recommended
    [Tue Mar  3 07:37:47 2026] EXT4-fs (dm-11): mounted filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c r/w with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:39:36 2026] EXT4-fs (dm-11): unmounting filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c.
    [Tue Mar  3 07:41:15 2026] EXT4-fs (dm-11): warning: mounting fs with errors, running e2fsck is recommended
    [Tue Mar  3 07:41:15 2026] EXT4-fs (dm-11): mounted filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c r/w with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:42:01 2026] EXT4-fs (dm-11): unmounting filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c.
    [Tue Mar  3 07:42:21 2026] EXT4-fs (dm-11): warning: mounting fs with errors, running e2fsck is recommended
    [Tue Mar  3 07:42:21 2026] EXT4-fs (dm-11): mounted filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c r/w with ordered data mode. Quota mode: none.
    [Tue Mar  3 07:47:47 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Tue Mar  3 07:47:47 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Tue Mar  3 07:47:47 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Tue Mar  3 13:12:26 2026] EXT4-fs (dm-27): write access unavailable, skipping orphan cleanup
    [Tue Mar  3 13:12:26 2026] EXT4-fs (dm-27): mounted filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c ro without journal. Quota mode: none.
    [Tue Mar  3 13:16:48 2026] EXT4-fs (dm-27): unmounting filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c.
    [Wed Mar  4 07:57:13 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Wed Mar  4 07:57:13 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Wed Mar  4 07:57:13 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Wed Mar  4 07:57:13 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Wed Mar  4 07:57:13 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Wed Mar  4 07:57:13 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Wed Mar  4 07:57:13 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Wed Mar  4 07:57:13 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Wed Mar  4 07:57:13 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Thu Mar  5 08:25:14 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Thu Mar  5 08:25:14 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Thu Mar  5 08:25:14 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Thu Mar  5 08:25:14 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Thu Mar  5 08:25:14 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Thu Mar  5 08:25:14 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Thu Mar  5 08:25:14 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Thu Mar  5 08:25:14 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Thu Mar  5 08:25:14 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Fri Mar  6 08:53:14 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Fri Mar  6 08:53:14 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Fri Mar  6 08:53:14 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Fri Mar  6 08:53:14 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Fri Mar  6 08:53:14 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Fri Mar  6 08:53:14 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Fri Mar  6 08:53:14 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Fri Mar  6 08:53:14 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Fri Mar  6 08:53:14 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Sat Mar  7 09:21:14 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Sat Mar  7 09:21:14 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Sat Mar  7 09:21:14 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Sat Mar  7 09:21:14 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Sat Mar  7 09:21:14 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Sat Mar  7 09:21:14 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Sat Mar  7 09:21:14 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Sat Mar  7 09:21:14 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Sat Mar  7 09:21:14 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Sun Mar  8 09:49:14 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Sun Mar  8 09:49:14 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Sun Mar  8 09:49:14 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Sun Mar  8 09:49:14 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Sun Mar  8 09:49:14 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Sun Mar  8 09:49:14 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Sun Mar  8 09:49:14 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Sun Mar  8 09:49:14 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Sun Mar  8 09:49:14 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Mon Mar  9 10:17:14 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Mon Mar  9 10:17:14 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Mon Mar  9 10:17:14 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Mon Mar  9 10:17:14 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Mon Mar  9 10:17:14 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Mon Mar  9 10:17:14 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Mon Mar  9 10:17:14 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Mon Mar  9 10:17:14 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Mon Mar  9 10:17:14 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Tue Mar 10 10:45:15 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Tue Mar 10 10:45:15 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Tue Mar 10 10:45:15 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Tue Mar 10 10:45:15 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Tue Mar 10 10:45:15 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Tue Mar 10 10:45:15 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Tue Mar 10 10:45:15 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Tue Mar 10 10:45:15 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Tue Mar 10 10:45:15 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Wed Mar 11 11:13:15 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Wed Mar 11 11:13:15 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Wed Mar 11 11:13:15 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Wed Mar 11 11:13:15 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Wed Mar 11 11:13:15 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Wed Mar 11 11:13:15 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Wed Mar 11 11:13:15 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Wed Mar 11 11:13:15 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Wed Mar 11 11:13:15 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Thu Mar 12 11:41:15 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Thu Mar 12 11:41:15 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Thu Mar 12 11:41:15 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Thu Mar 12 11:41:15 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Thu Mar 12 11:41:15 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Thu Mar 12 11:41:15 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Thu Mar 12 11:41:15 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Thu Mar 12 11:41:15 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Thu Mar 12 11:41:15 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Fri Mar 13 12:09:15 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Fri Mar 13 12:09:15 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Fri Mar 13 12:09:15 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Fri Mar 13 12:09:15 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Fri Mar 13 12:09:15 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Fri Mar 13 12:09:15 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Fri Mar 13 12:09:15 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Fri Mar 13 12:09:15 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Fri Mar 13 12:09:15 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Sat Mar 14 12:37:16 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Sat Mar 14 12:37:16 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Sat Mar 14 12:37:16 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Sat Mar 14 12:37:16 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Sat Mar 14 12:37:16 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Sat Mar 14 12:37:16 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Sat Mar 14 12:37:16 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Sat Mar 14 12:37:16 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Sat Mar 14 12:37:16 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Sun Mar 15 13:05:16 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Sun Mar 15 13:05:16 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Sun Mar 15 13:05:16 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Sun Mar 15 13:05:16 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Sun Mar 15 13:05:16 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Sun Mar 15 13:05:16 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Sun Mar 15 13:05:16 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Sun Mar 15 13:05:16 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Sun Mar 15 13:05:16 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Mon Mar 16 13:33:16 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Mon Mar 16 13:33:16 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Mon Mar 16 13:33:16 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Mon Mar 16 13:33:16 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Mon Mar 16 13:33:16 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Mon Mar 16 13:33:16 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Mon Mar 16 13:33:16 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Mon Mar 16 13:33:16 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Mon Mar 16 13:33:16 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Tue Mar 17 14:01:16 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Tue Mar 17 14:01:16 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Tue Mar 17 14:01:16 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Tue Mar 17 14:01:16 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Tue Mar 17 14:01:16 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Tue Mar 17 14:01:16 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Tue Mar 17 14:01:16 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Tue Mar 17 14:01:16 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Tue Mar 17 14:01:16 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Wed Mar 18 14:29:17 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Wed Mar 18 14:29:17 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Wed Mar 18 14:29:17 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Wed Mar 18 14:29:17 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Wed Mar 18 14:29:17 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Wed Mar 18 14:29:17 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Wed Mar 18 14:29:17 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Wed Mar 18 14:29:17 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Wed Mar 18 14:29:17 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Thu Mar 19 14:57:17 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Thu Mar 19 14:57:17 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Thu Mar 19 14:57:17 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Thu Mar 19 14:57:17 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Thu Mar 19 14:57:17 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Thu Mar 19 14:57:17 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Thu Mar 19 14:57:17 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Thu Mar 19 14:57:17 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Thu Mar 19 14:57:17 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Fri Mar 20 15:25:17 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Fri Mar 20 15:25:17 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Fri Mar 20 15:25:17 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Fri Mar 20 15:25:17 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Fri Mar 20 15:25:17 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Fri Mar 20 15:25:17 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Fri Mar 20 15:25:17 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Fri Mar 20 15:25:17 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Fri Mar 20 15:25:17 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Sat Mar 21 15:53:17 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Sat Mar 21 15:53:17 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Sat Mar 21 15:53:17 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    [Sat Mar 21 15:53:17 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Sat Mar 21 15:53:17 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Sat Mar 21 15:53:17 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Sat Mar 21 15:53:17 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Sat Mar 21 15:53:17 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Sat Mar 21 15:53:17 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Sun Mar 22 16:21:18 2026] EXT4-fs (dm-17): error count since last fsck: 1
    [Sun Mar 22 16:21:18 2026] EXT4-fs (dm-11): error count since last fsck: 4
    [Sun Mar 22 16:21:18 2026] EXT4-fs (dm-17): initial error at time 1771125090: ext4_journal_check_start:84
    [Sun Mar 22 16:21:18 2026] EXT4-fs (dm-11): initial error at time 1771121398: ext4_reserve_inode_write:5882
    [Sun Mar 22 16:21:18 2026] EXT4-fs (dm-11): last error at time 1771121398: ext4_journal_check_start:84
    [Sun Mar 22 16:21:18 2026] EXT4-fs (dm-17): last error at time 1771125090: ext4_journal_check_start:84
    [Sun Mar 22 16:21:18 2026] EXT4-fs (dm-6): error count since last fsck: 4
    [Sun Mar 22 16:21:18 2026] EXT4-fs (dm-6): initial error at time 1771110127: ext4_reserve_inode_write:5882
    [Sun Mar 22 16:21:18 2026] EXT4-fs (dm-6): last error at time 1771110130: ext4_journal_check_start:84
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
    /var:
    1.3G    /var/
    786M    /var/log
    770M    /var/log/journal/3cb36adc397d4355ba4179a97085f566
    332M    /var/lib
          Users in the 'systemd-journal' group can see all messages. Pass -q to
          turn off this notice.
    Archived and active journals take up 23.3M in the file system.
    /opt/iobroker/backups:
    955M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    3.0G    /opt/iobroker/iobroker-data/
    1.4G    /opt/iobroker/iobroker-data/n8n-engine/node_modules
    916M    /opt/iobroker/iobroker-data/history
    422M    /opt/iobroker/iobroker-data/files
    45M     /opt/iobroker/iobroker-data/objects.jsonl
    32M     /opt/iobroker/iobroker-data/n8n-engine/node_modules/@napi-rs/canvas-linux-x64-gnu/skia.linux-x64-gnu.node
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.1
    /usr/bin/node           v22.22.1
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.1-1nodesource1
      Candidate: 22.22.1-1nodesource1
      Version table:
     *** 22.22.1-1nodesource1 600
         22.22.0-1nodesource1 600
         22.21.0-1nodesource1 600
         22.20.0-1nodesource1 600
         22.19.0-1nodesource1 600
         22.18.0-1nodesource1 600
         22.17.1-1nodesource1 600
         22.17.0-1nodesource1 600
         22.16.0-1nodesource1 600
         22.15.1-1nodesource1 600
         22.15.0-1nodesource1 600
         22.14.0-1nodesource1 600
         22.13.1-1nodesource1 600
         22.13.0-1nodesource1 600
         22.12.0-1nodesource1 600
         22.11.0-1nodesource1 600
         22.10.0-1nodesource1 600
         22.9.0-1nodesource1 600
         22.8.0-1nodesource1 600
         22.7.0-1nodesource1 600
         22.6.0-1nodesource1 600
         22.5.1-1nodesource1 600
         22.5.0-1nodesource1 600
         22.4.1-1nodesource1 600
         22.4.0-1nodesource1 600
         22.3.0-1nodesource1 600
         22.2.0-1nodesource1 600
         22.1.0-1nodesource1 600
         22.0.0-1nodesource1 600
         18.19.1+dfsg-6ubuntu5 500
            500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
    No problems detected
    Errors in npm tree: 0
    ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
    • Horst BöttcherH Horst Böttcher
      iob diag
      ```bash
      Script v.2026-01-31
      *** BASE SYSTEM ***
        Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           1.1G        1.1G         86K
               5000 M total memory
               2743 M used memory
               1946 M free memory
                  0 M buffer memory
                309 M swap cache
               1024 M total swap
               1023 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      1.3G    /var/
      786M    /var/log
      332M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      nodejs:
        Version table:
      *** MEMORY ***
      total used free shared buff/cache available
      Swap: 1.1G 1.1G 86K
      Du hast ein schwer ausgelastetes Swap.
      • dev-hugepages.mount loaded failed failed Huge Pages File System
      • run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
      • apparmor.service loaded failed failed Load AppArmor profiles
      • postfix@-.service loaded failed failed Postfix Mail Transport Agent (instance -)
      Da klemmen diverse Services.
      Mit dem Dateisystem stimmt was nicht.
      • Horst BöttcherH Offline
        Horst Böttcher
        ```bash
        Script v.2026-01-31
        *** BASE SYSTEM ***
          Virtualization: lxc
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
         20:09:02 up 7 min,  1 user,  load average: 1.04, 2.06, 1.76
        CPU threads: 4
                       Local time: Sun 2026-03-22 20:09:02 CET
                   Universal time: Sun 2026-03-22 19:09:02 UTC
                         RTC time: n/a
                  RTC in local TZ: no
        pi
        HOME=/
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Mem:            5.2G        3.4G        1.2G        147K        676M        1.9G
        Swap:           1.1G        8.2K        1.1G
        Total:          6.3G        3.4G        2.3G
        Active iob-Instances:   33
                 5000 M total memory
                 3229 M used memory
                 2298 M active memory
                 1212 M inactive memory
                 1125 M free memory
                    0 M buffer memory
                  645 M swap cache
                 1024 M total swap
                    0 M used swap
                 1023 M free swap
        top - 20:09:02 up 7 min,  1 user,  load average: 1.04, 2.06, 1.76
        Tasks:  59 total,   2 running,  57 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 22.0 us, 14.6 sy,  0.0 ni, 58.5 id,  0.0 wa,  0.0 hi,  4.9 si,  0.0 st
        MiB Mem :   5000.0 total,   1124.3 free,   3230.8 used,    645.0 buff/cache
        MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   1769.2 avail Mem
        2 loaded units listed.
        *** FILESYSTEM ***
        /dev/mapper/pve-vm--101--disk--0 ext4    20G   11G  8.5G  55% /
        tmpfs                            tmpfs  1.6G  140K  1.6G   1% /run
        [Sun Mar 22 19:55:30 2026] EXT4-fs (dm-11): unmounting filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c.
        [Sun Mar 22 19:55:31 2026] EXT4-fs (dm-11): warning: mounting fs with errors, running e2fsck is recommended
        [Sun Mar 22 19:55:31 2026] EXT4-fs (dm-11): mounted filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c r/w with ordered data mode. Quota mode: none.
        [Sun Mar 22 19:58:57 2026] EXT4-fs (dm-11): unmounting filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c.
        [Sun Mar 22 20:01:02 2026] EXT4-fs (dm-11): mounted filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c r/w with ordered data mode. Quota mode: none.
        /var:
        1.3G    /var/
        793M    /var/log
        777M    /var/log/journal/3cb36adc397d4355ba4179a97085f566
        332M    /var/lib
        Archived and active journals take up 34.9M in the file system.
        3.1G    /opt/iobroker/iobroker-data/
        91M     /opt/iobroker/iobroker-data/objects.jsonl
        USB-Devices by-id:
        /usr/bin/npm            10.9.4
        /usr/bin/npx            10.9.4
        nodejs:
          Version table:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 484)
        Core adapters versions
        js-controller:  7.0.7
        admin:          7.7.22
        javascript:     9.0.18
        nodejs modules from github:     7
        +-- iobroker.info@2.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.info.git#863fada0c02d8c0f718022943bb783f40514f059)
        +-- iobroker.matter@1.0.0 (git+ssh://git@github.com/ioBroker/ioBroker.matter.git#c168966ff8fe911c1392d2cdc1b065401fec6010)
        +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
        +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
        +-- iobroker.unifi-network@1.3.4 (git+ssh://git@github.com/Scrounger/ioBroker.unifi-network.git#3989edbb0f48ca1fe5666054de88eb495aaf7b43)
        +-- iobroker.vis-material-advanced@1.7.4 (git+ssh://git@github.com/EdgarM73/ioBroker.vis-material-advanced.git#bc6d068391b6f241f28ef2e1603e4baa1c0bc3f2)
        +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#6da1d9b2fce0d33c4572a55c5e44e5fae6db507e)
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
          system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
        + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        + system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
          system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 - disabled
          system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
        + system.adapter.discovergy.0             : discovergy            : ioBroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
        + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
          system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
          system.adapter.flexcharts.0             : flexcharts            : ioBroker                                 -  enabled
        + system.adapter.history.0                : history               : ioBroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
        + system.adapter.homekit-controller.0     : homekit-controller    : ioBroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
          system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
          system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
          system.adapter.ical.3                   : ical                  : ioBroker                                 -  enabled
          system.adapter.ical.4                   : ical                  : ioBroker                                 -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
        + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
          system.adapter.net-tools.0              : net-tools             : ioBroker                                 - disabled
        + system.adapter.nuki-extended.0          : nuki-extended         : ioBroker                                 -  enabled
          system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
          system.adapter.radar2.0                 : radar2                : ioBroker                                 - disabled
        + system.adapter.rssfeed.0                : rssfeed               : ioBroker                                 -  enabled
          system.adapter.sayit.0                  : sayit                 : ioBroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
        + system.adapter.systeminfo.0             : systeminfo            : ioBroker                                 -  enabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
        + system.adapter.tapo.0                   : tapo                  : ioBroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
          system.adapter.twinkly.0                : twinkly               : ioBroker                                 - disabled
        + system.adapter.unifi-network.0          : unifi-network         : ioBroker                                 -  enabled, port: 11443
        + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
          system.adapter.universal-fetcher.0      : universal-fetcher     : ioBroker                                 -  enabled
        + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 -  enabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 -  enabled
        + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : ioBroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
        │ 1       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │ true         │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "accuweather"  : 2.2.0    , installed 2.2.0
        Adapter    "admin"        : 7.7.22   , installed 7.7.22
        Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
        Adapter    "alias-manager": 2.1.0    , installed 2.1.0
        Adapter    "backitup"     : 3.3.14   , installed 3.3.14
        Adapter    "chromecast"   : 4.1.1    , installed 4.1.1
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "devices"      : 1.2.14   , installed 1.2.14
        Adapter    "discovergy"   : 0.6.0    , installed 0.6.0
        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
        Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
        Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
        Adapter    "flexcharts"   : 0.6.1    , installed 0.6.1
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "homekit-controller": 0.5.11, installed 0.5.11
        Adapter    "ical"         : 1.18.1   , installed 1.18.1
        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
        Adapter    "iot"          : 5.0.7    , installed 5.0.7
        Adapter    "javascript"   : 9.0.18   , installed 9.0.18
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "matter"       : 0.5.6    , installed 1.0.0
        Adapter    "net-tools"    : 1.2.3    , installed 1.2.3
        Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
        Adapter    "openweathermap": 1.1.2   , installed 1.3.0
        Adapter    "radar2"       : 2.4.0    , installed 2.4.0
        Adapter    "rssfeed"      : 3.6.1    , installed 3.6.1
        Adapter    "sayit"        : 5.0.0    , installed 5.0.0
        Adapter    "shelly"       : 10.5.2   , installed 10.5.2
        Adapter    "socketio"     : 6.7.1    , installed 7.0.8
        Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "tuya"         : 3.16.0   , installed 3.17.0
        Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "unifi-network": 1.3.1    , installed 1.3.4
        Adapter    "upnp"         : 1.1.0    , installed 1.1.0
        Adapter    "vis-2-widgets-icontwo": 1.25.0, installed 1.25.0
        Adapter    "vis-2-widgets-inventwo": 0.5.5, installed 0.5.5
        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "web"          : 7.0.8    , installed 7.0.9
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Adapter    "ws"           : 2.6.2    , installed 3.0.19
        Adapter    "zigbee2mqtt"  : 3.0.21   , installed 3.0.21
        Objects and States
        Objects:        83810
        States:         63490
        Hit:1 http://archive.ubuntu.com/ubuntu noble InRelease
        Hit:2 http://archive.ubuntu.com/ubuntu noble-updates InRelease
        Hit:3 https://deb.nodesource.com/node_22.x nodistro InRelease
        Hit:4 http://archive.ubuntu.com/ubuntu noble-security InRelease
        Reading package lists...
        Pending systemupdates: 8
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       122938488  1148/io.shelly.0
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       122925294  276/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       122922564  276/iobroker.js-con
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          122921534  1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          122922359  1/init
        tcp        0      0 192.168.10.5:9292       0.0.0.0:*               LISTEN      1000       122934692  1099/io.hm-rpc.0
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      992        122924177  251/systemd-resolve
        tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      992        122924179  251/systemd-resolve
        tcp6       0      0 :::111                  :::*                    LISTEN      0          122921536  1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          122925139  1/init
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       122954378  3124/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       122927939  600/io.admin.0
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       122953640  3148/io.simple-api.
        udp        0      0 127.0.0.54:53           0.0.0.0:*                           992        122924178  251/systemd-resolve
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           992        122924176  251/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          122921535  1/init
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       122953153  2214/io.homekit-con
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       122943528  1977/io.chromecast.
        udp        0      0 0.0.0.0:46776           0.0.0.0:*                           1000       122954005  3063/io.upnp.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       122956053  3063/io.upnp.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       122938941  1301/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       122938942  1301/io.tuya.0
        udp6       0      0 :::111                  :::*                                0          122922078  1/init
        2026-03-22 20:09:28.232  - info: tapo.0 (3023) Get camera Status failed
        2026-03-22 20:09:28.232  - info: tapo.0 (3023) No stok found for: 80216A19019D84F2EF32CD71C40501B4237A9D4F this means the device is offline or connection lost. No update or commands possible
        2026-03-22 20:09:28.245  - debug: tuya.0 (1301) TuyaOpenMQ onMessage: topic = cloud/token/in/newddd0ea6f26a1837a7ea63595a2d8ea7a, message = {"protocol":4,"data":{"devId":"0478272848551959bf4f","dataId":"9d023e6a-0ff9-43f0-8c1a-8034d38114dd","productKey":"wifvoilfrqeo6hvu","status":[{"6":2255,"code":"cur_voltage","t":1774206568,"value":2255}]},"t":1774206568,"pv":"2.0","sign":"375e69fa7138c00961666df8bea6c13b"}
        2026-03-22 20:09:28.247  - debug: tuya.0 (1301) stateChange tuya.0.0478272848551959bf4f.6 {"val":225.5,"ack":true,"ts":1774206568000,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1774206568000}
        2026-03-22 20:09:29.821  - debug: tuya.0 (1301) TuyaOpenMQ onMessage: topic = cloud/token/in/newddd0ea6f26a1837a7ea63595a2d8ea7a, message = {"protocol":4,"data":{"devId":"4530056170039f47f981","dataId":"7738569a-31dd-4227-95cd-3dc2e3b3b6b8","productKey":"wifvoilfrqeo6hvu","status":[{"5":68,"code":"cur_power","t":1774206569,"value":68}]},"t":1774206569,"pv":"2.0","sign":"2e80ecc1bf3fa63c5dd7fac0d06672c3"}
        2026-03-22 20:09:29.823  - debug: tuya.0 (1301) stateChange tuya.0.4530056170039f47f981.5 {"val":6.8,"ack":true,"ts":1774206569000,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1774206569000}
        2026-03-22 20:09:32.596  - debug: tuya.0 (1301) TuyaOpenMQ onMessage: topic = cloud/token/in/newddd0ea6f26a1837a7ea63595a2d8ea7a, message = {"protocol":4,"data":{"devId":"4530056170039f4b4878","dataId":"373156d0-0db7-4f98-a8f5-62a6dbfd7c58","productKey":"wifvoilfrqeo6hvu","status":[{"4":402,"code":"cur_current","t":1774206572,"value":402},{"5":924,"code":"cur_power","t":1774206572,"value":924}]},"t":1774206572,"pv":"2.0","sign":"c0dde99cb34d3682b4747a6de2bec965"}
        2026-03-22 20:09:33.208  - debug: tuya.0 (1301) stateChange tuya.0.4530056170039f4b4878.4 {"val":402,"ack":true,"ts":1774206572000,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1774206572000}
        2026-03-22 20:09:33.209  - debug: tuya.0 (1301) stateChange tuya.0.4530056170039f4b4878.5 {"val":92.4,"ack":true,"ts":1774206572000,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1774206572000}
        2026-03-22 20:09:37.596  - debug: tuya.0 (1301) TuyaOpenMQ onMessage: topic = cloud/token/in/newddd0ea6f26a1837a7ea63595a2d8ea7a, message = {"protocol":4,"data":{"devId":"4530056170039f4b4878","dataId":"b7bc4fe9-6637-45f2-b2cc-dba7fb99bc48","productKey":"wifvoilfrqeo6hvu","status":[{"4":403,"code":"cur_current","t":1774206577,"value":403},{"5":926,"code":"cur_power","t":1774206577,"value":926}]},"t":1774206577,"pv":"2.0","sign":"914a839b78a7619d9aa065dab8ef6416"}
        2026-03-22 20:09:37.647  - debug: tuya.0 (1301) stateChange tuya.0.4530056170039f4b4878.4 {"val":403,"ack":true,"ts":1774206577000,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1774206577000}
        2026-03-22 20:09:37.734  - debug: tuya.0 (1301) stateChange tuya.0.4530056170039f4b4878.5 {"val":92.6,"ack":true,"ts":1774206577000,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1774206577000}
        2026-03-22 20:09:38.233  - info: tapo.0 (3023) Get camera Status failed
        2026-03-22 20:09:38.233  - info: tapo.0 (3023) No stok found for: 80216A19019D84F2EF32CD71C40501B4237A9D4F this means the device is offline or connection lost. No update or commands possible
        2026-03-22 20:09:38.251  - debug: tuya.0 (1301) TuyaOpenMQ onMessage: topic = cloud/token/in/newddd0ea6f26a1837a7ea63595a2d8ea7a, message = {"protocol":4,"data":{"devId":"0478272848551959bf4f","dataId":"45b7b910-3f0d-4120-be92-7fcb578ed949","productKey":"wifvoilfrqeo6hvu","status":[{"6":2270,"code":"cur_voltage","t":1774206578,"value":2270}]},"t":1774206578,"pv":"2.0","sign":"a6715124e26fc60a482bc4c5df632a97"}
        2026-03-22 20:09:39.191  - debug: tuya.0 (1301) stateChange tuya.0.0478272848551959bf4f.6 {"val":227,"ack":true,"ts":1774206578000,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1774206578000}
        2026-03-22 20:09:39.974  - debug: tuya.0 (1301) TuyaOpenMQ onMessage: topic = cloud/token/in/newddd0ea6f26a1837a7ea63595a2d8ea7a, message = {"protocol":4,"data":{"devId":"4530056170039f47f981","dataId":"1d80cbc1-fb5c-45ba-ba1d-3c58bcf05edb","productKey":"wifvoilfrqeo6hvu","status":[{"4":30,"code":"cur_current","t":1774206579,"value":30},{"5":69,"code":"cur_power","t":1774206579,"value":69}]},"t":1774206579,"pv":"2.0","sign":"9d33a7cbdce7625e277e3ae44e6857d3"}
        2026-03-22 20:09:39.976  - debug: tuya.0 (1301) stateChange tuya.0.4530056170039f47f981.4 {"val":30,"ack":true,"ts":1774206579000,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1774206579000}
        2026-03-22 20:09:40.059  - debug: tuya.0 (1301) stateChange tuya.0.4530056170039f47f981.5 {"val":6.9,"ack":true,"ts":1774206579000,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1774206579000}
        2026-03-22 20:09:42.630  - debug: tuya.0 (1301) TuyaOpenMQ onMessage: topic = cloud/token/in/newddd0ea6f26a1837a7ea63595a2d8ea7a, message = {"protocol":4,"data":{"devId":"4530056170039f4b4878","dataId":"e85162ef-b868-44b4-bdf3-6e3ed9f854e1","productKey":"wifvoilfrqeo6hvu","status":[{"4":405,"code":"cur_current","t":1774206582,"value":405},{"5":929,"code":"cur_power","t":1774206582,"value":929}]},"t":1774206582,"pv":"2.0","sign":"83efa2c80ef6b1070e15cb599f3c24bd"}
        2026-03-22 20:09:42.632  - debug: tuya.0 (1301) stateChange tuya.0.4530056170039f4b4878.4 {"val":405,"ack":true,"ts":1774206582000,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1774206582000}
        2026-03-22 20:09:42.714  - debug: tuya.0 (1301) stateChange tuya.0.4530056170039f4b4878.5 {"val":92.9,"ack":true,"ts":1774206582000,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1774206582000}
        2026-03-22 20:09:44.942  - debug: tuya.0 (1301) TuyaOpenMQ onMessage: topic = cloud/token/in/newddd0ea6f26a1837a7ea63595a2d8ea7a, message = {"protocol":4,"data":{"devId":"4530056170039f47f981","dataId":"7a58bb4c-26bf-4c26-8389-81fe71ecf754","productKey":"wifvoilfrqeo6hvu","status":[{"4":29,"code":"cur_current","t":1774206584,"value":29},{"5":68,"code":"cur_power","t":1774206584,"value":68}]},"t":1774206584,"pv":"2.0","sign":"158ec8b38a5acea6058e30a3d4fc07f2"}
        2026-03-22 20:09:44.944  - debug: tuya.0 (1301) stateChange tuya.0.4530056170039f47f981.4 {"val":29,"ack":true,"ts":1774206584000,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1774206584000}
        2026-03-22 20:09:45.026  - debug: tuya.0 (1301) stateChange tuya.0.4530056170039f47f981.5 {"val":6.8,"ack":true,"ts":1774206584000,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1774206584000}
        iob diag has finished.
        pi@ioBroker:/$
        • ilovegymI ilovegym
          Welche Tuya Adapter Version? Stimmen die Login Daten? Was steht im log bei Adapter Start?
          Horst Böttcher
          @ilovegym sagte in Tuya-Adapter wird nach kurzer Zeit Orange (Status Gelb):
          Tuya Adaper v3.17.0
          Mein Netz auf bau Fritzbox liefert Internet →
          VLAN 10 (Server & Dienste): Ideal für NAS, Docker-Hosts oder Proxmox.
          VLAN 30 (IoT / Smart Home): Die "untrustworthy" Zone für Cloud-basierte Geräte.
          mDNS ist aktiv
          tuya.0
          2026-03-22 20:14:27.607	info	4530056170039f4b4878: Error on Reconnect (5): connect EHOSTUNREACH 192.168.1.36:6668
          tuya.0
          2026-03-22 20:14:25.477	info	4530056170039f47f981: Error on Reconnect (5): connect EHOSTUNREACH 192.168.1.34:6668
          tuya.0
          2026-03-22 20:14:10.207	info	24300621c4dd5715010d: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.43:6668
          tuya.0
          2026-03-22 20:14:09.245	info	0478272848551959bf4f: Error on Reconnect (3): connect EHOSTUNREACH 192.168.10.15:6668
          tuya.0
          2026-03-22 20:14:07.917	info	bf69c9cb6e8b29050enrqt: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.67:6668
          tuya.0
          2026-03-22 20:14:06.727	info	854560468cce4e2b75c9: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.40:6668
          tuya.0
          2026-03-22 20:14:06.442	info	bf69083e6c2e9bca06fztj: Error on Reconnect (3): connection timed out
          tuya.0
          2026-03-22 20:14:06.441	info	bf99353ef5b6bc2c14xipv: Error on Reconnect (3): connection timed out
          tuya.0
          2026-03-22 20:14:06.436	info	80570248500291110eda: Error on Reconnect (3): connection timed out
          tuya.0
          2026-03-22 20:14:04.427	info	bf8d884890b913eb20ou9h: Error on Reconnect (3): connect EHOSTUNREACH 192.168.1.16:6668
          tuya.0
          2026-03-22 20:14:02.437	info	bfd620f47738859a5altai: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.58:6668
          tuya.0
          2026-03-22 20:14:02.427	info	bf514ea1c2db207be3qqrq: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.135:6668
          tuya.0
          2026-03-22 20:14:02.417	info	bf89bb336945c4453ewf1r: Error on Reconnect (3): connect EHOSTUNREACH 192.168.1.41:6668
          tuya.0
          2026-03-22 20:14:02.407	info	bfe738f15da8902f970vq3: Error on Reconnect (3): connect EHOSTUNREACH 192.168.1.42:6668
          tuya.0
          2026-03-22 20:13:47.207	info	24300621c4dd5715010d: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.43:6668
          tuya.0
          2026-03-22 20:13:46.141	info	0478272848551959bf4f: Error on Reconnect (1): connect EHOSTUNREACH 192.168.10.15:6668
          tuya.0
          2026-03-22 20:13:44.917	info	bf69c9cb6e8b29050enrqt: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.67:6668
          tuya.0
          2026-03-22 20:13:44.610	info	4530056170039f4b4878: Error on Reconnect (3): connection timed out
          tuya.0
          2026-03-22 20:13:44.394	info	Cloud MQTT connection established successfully.
          tuya.0
          2026-03-22 20:13:44.091	info	24300621c4dd5715010d Init with IP=192.168.178.43, Key=d8$Ysj&!Y97y}]B&, Version=3.3
          tuya.0
          2026-03-22 20:13:44.091	info	24300621c4dd5715010d: Connect locally to device
          tuya.0
          2026-03-22 20:13:43.727	info	854560468cce4e2b75c9: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.40:6668
          tuya.0
          2026-03-22 20:13:43.036	info	0478272848551959bf4f Init with IP=192.168.10.15, Key=Ri65>3j]r*X?oGv#, Version=3.3
          tuya.0
          2026-03-22 20:13:43.036	info	0478272848551959bf4f: Connect locally to device
          tuya.0
          2026-03-22 20:13:42.477	info	4530056170039f47f981: Error on Reconnect (3): connect EHOSTUNREACH 192.168.1.34:6668
          tuya.0
          2026-03-22 20:13:41.924	info	bf69c9cb6e8b29050enrqt Init with IP=192.168.178.67, Key=mf0JiL<+E8F-LOH>, Version=3.4
          tuya.0
          2026-03-22 20:13:41.924	info	bf69c9cb6e8b29050enrqt: Connect locally to device
          tuya.0
          2026-03-22 20:13:41.441	info	bf69083e6c2e9bca06fztj: Error on Reconnect (1): connection timed out
          tuya.0
          2026-03-22 20:13:41.441	info	bf99353ef5b6bc2c14xipv: Error on Reconnect (1): connection timed out
          tuya.0
          2026-03-22 20:13:41.439	info	4530056170039f4b4878: Error on Reconnect (1): connection timed out
          tuya.0
          2026-03-22 20:13:41.439	info	4530056170039f47f981: Error on Reconnect (1): connection timed out
          tuya.0
          2026-03-22 20:13:41.435	info	80570248500291110eda: Error on Reconnect (1): connection timed out
          tuya.0
          2026-03-22 20:13:41.428	info	bf8d884890b913eb20ou9h: Error on Reconnect (1): connection timed out
          tuya.0
          2026-03-22 20:13:40.990	info	bf7fc60a662c018abcpxgy: Connect locally to device
          tuya.0
          2026-03-22 20:13:40.949	info	bfbad50c821dc5105cetog: Connect locally to device
          tuya.0
          2026-03-22 20:13:40.905	info	bf73c5e2e4e7bed70f34bx: Connect locally to device
          tuya.0
          2026-03-22 20:13:40.903	info	bf030150d46da26483qfxh: Connect locally to device
          tuya.0
          2026-03-22 20:13:40.728	info	854560468cce4e2b75c9 Init with IP=192.168.178.40, Key=~f)O}0P`5KZokq>:, Version=3.3
          tuya.0
          2026-03-22 20:13:40.728	info	854560468cce4e2b75c9: Connect locally to device
          tuya.0
          2026-03-22 20:13:39.610	info	4530056170039f4b4878 Init with IP=192.168.1.36, Key=DO&TqrwC>f7J1Nqu, Version=3.3
          tuya.0
          2026-03-22 20:13:39.610	info	4530056170039f4b4878: Connect locally to device
          tuya.0
          2026-03-22 20:13:39.549	info	0478272848551959bf4f: Error on Reconnect (1): connect EHOSTUNREACH 192.168.10.15:6668
          tuya.0
          2026-03-22 20:13:39.437	info	bfd620f47738859a5altai: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.58:6668
          tuya.0
          2026-03-22 20:13:39.428	info	bf514ea1c2db207be3qqrq: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.135:6668
          tuya.0
          2026-03-22 20:13:39.427	info	bf69c9cb6e8b29050enrqt: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.67:6668
          tuya.0
          2026-03-22 20:13:39.417	info	bf89bb336945c4453ewf1r: Error on Reconnect (1): connect EHOSTUNREACH 192.168.1.41:6668
          tuya.0
          2026-03-22 20:13:39.417	info	854560468cce4e2b75c9: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.40:6668
          tuya.0
          2026-03-22 20:13:39.410	info	bfe738f15da8902f970vq3: Error on Reconnect (1): connect EHOSTUNREACH 192.168.1.42:6668
          tuya.0
          2026-03-22 20:13:39.409	info	24300621c4dd5715010d: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.43:6668
          tuya.0
          2026-03-22 20:13:38.651	info	bf9ae250213f3d5d915nv4: Connect locally to device
          tuya.0
          2026-03-22 20:13:38.651	info	bf12e9bd1526f64831nlog: Connect locally to device
          tuya.0
          2026-03-22 20:13:38.446	info	4530056170039f47f981 Init with IP=192.168.1.34, Key=[X4SuYo3fG3S`/m[, Version=3.3
          tuya.0
          2026-03-22 20:13:38.446	info	4530056170039f47f981: Connect locally to device
          tuya.0
          2026-03-22 20:13:37.552	info	bfd2494109784809ddntef: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.587	info	Listen for encrypted local Tuya devices on port 6667
          tuya.0
          2026-03-22 20:13:36.587	info	Listen for local Tuya devices on port 6666
          tuya.0
          2026-03-22 20:13:36.486	info	Try to sync devices from Cloud using stored cloud credentials
          tuya.0
          2026-03-22 20:13:36.483	info	Existing devices initialized
          tuya.0
          2026-03-22 20:13:36.482	info	bfbad50c821dc5105cetog: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.480	info	0478272848551959bf4f Init with IP=192.168.10.15, Key=Ri65>3j]r*X?oGv#, Version=3.3
          tuya.0
          2026-03-22 20:13:36.479	info	0478272848551959bf4f: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.478	info	bf9ae250213f3d5d915nv4: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.440	info	bf69083e6c2e9bca06fztj Init with IP=192.168.1.43, Key=s#28W56F#x>{VLJp, Version=3.3
          tuya.0
          2026-03-22 20:13:36.440	info	bf69083e6c2e9bca06fztj: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.440	info	bfd620f47738859a5altai Init with IP=192.168.178.58, Key=$:6<zL9.NL(RW(m[, Version=3.4
          tuya.0
          2026-03-22 20:13:36.439	info	bfd620f47738859a5altai: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.439	info	bf99353ef5b6bc2c14xipv Init with IP=192.168.1.46, Key=e;IAa$LXa(^a3ow$, Version=3.3
          tuya.0
          2026-03-22 20:13:36.439	info	bf99353ef5b6bc2c14xipv: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.439	info	bf73c5e2e4e7bed70f34bx: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.438	info	4530056170039f4b4878 Init with IP=192.168.1.36, Key=DO&TqrwC>f7J1Nqu, Version=3.3
          tuya.0
          2026-03-22 20:13:36.438	info	4530056170039f4b4878: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.438	info	4530056170039f47f981 Init with IP=192.168.1.34, Key=[X4SuYo3fG3S`/m[, Version=3.3
          tuya.0
          2026-03-22 20:13:36.438	info	4530056170039f47f981: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.437	info	bf7fc60a662c018abcpxgy: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.435	info	80570248500291110eda Init with IP=192.168.1.32, Key=|fS`[RN}v_vnNM:^, Version=3.3
          tuya.0
          2026-03-22 20:13:36.435	info	80570248500291110eda: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.433	info	bf514ea1c2db207be3qqrq Init with IP=192.168.178.135, Key=EuLp9|6nT{(SRc4), Version=3.3
          tuya.0
          2026-03-22 20:13:36.433	info	bf514ea1c2db207be3qqrq: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.427	info	bf8d884890b913eb20ou9h Init with IP=192.168.1.16, Key=jRJeUlr+E.s{vr~A, Version=3.5
          tuya.0
          2026-03-22 20:13:36.427	info	bf8d884890b913eb20ou9h: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.427	info	bf12e9bd1526f64831nlog: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.426	info	bf69c9cb6e8b29050enrqt Init with IP=192.168.178.67, Key=mf0JiL<+E8F-LOH>, Version=3.4
          tuya.0
          2026-03-22 20:13:36.425	info	bf69c9cb6e8b29050enrqt: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.423	info	bf89bb336945c4453ewf1r Init with IP=192.168.1.41, Key=LA.lq?NR:1&Y'~h~, Version=3.3
          tuya.0
          2026-03-22 20:13:36.423	info	bf89bb336945c4453ewf1r: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.422	info	854560468cce4e2b75c9 Init with IP=192.168.178.40, Key=~f)O}0P`5KZokq>:, Version=3.3
          tuya.0
          2026-03-22 20:13:36.422	info	854560468cce4e2b75c9: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.420	info	bf030150d46da26483qfxh: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.408	info	bfe738f15da8902f970vq3 Init with IP=192.168.1.42, Key=p)==E{hBC{Q9B8X~, Version=3.3
          tuya.0
          2026-03-22 20:13:36.408	info	bfe738f15da8902f970vq3: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.407	info	bfd2494109784809ddntef: Connect locally to device
          tuya.0
          2026-03-22 20:13:36.404	info	24300621c4dd5715010d Init with IP=192.168.178.43, Key=d8$Ysj&!Y97y}]B&, Version=3.3
          tuya.0
          2026-03-22 20:13:36.403	info	24300621c4dd5715010d: Connect locally to device
          tuya.0
          2026-03-22 20:13:35.676	info	starting. Version 3.17.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v22.22.1, js-controller: 7.0.7
            ```bash
            Script v.2026-01-31
            *** BASE SYSTEM ***
              Virtualization: lxc
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
            CPU threads: 4
                             RTC time: n/a
                      RTC in local TZ: no
            pi
            HOME=/
            iobroker
            HOME=/home/iobroker
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
                     5000 M total memory
                     3229 M used memory
                     1125 M free memory
                        0 M buffer memory
                      645 M swap cache
                     1024 M total swap
                        0 M used swap
                     1023 M free swap
            *** FILESYSTEM ***
            /var:
            1.3G    /var/
            793M    /var/log
            332M    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            10.9.4
            /usr/bin/npx            10.9.4
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.7.22
            javascript:     9.0.18
            Adapter State
            + instance is alive
            Objects and States
            Objects:        83810
            States:         63490
            pi@ioBroker:/$
            pi@ioBroker:/$
            Hat sich natürlich nix geändert.
            Und du stehst im falschen Verzeichnis mit deinem User. In / hast du nix zu suchen.
            • ilovegymI Offline
              ilovegymI Offline
              ilovegym
              Du hast n Netzwerk problem, devices sind nicht unter der ip und Port erreichbar, also da auch schauen, dass subnet mask, firewall usw richtig ist.
              Die anderen Probleme sollten natürlich auch gefixed werden.
              Horst BöttcherH 1 Antwort Letzte Antwort
                Horst Böttcher
                ok hab heute er mal das doppelte nat entfernt
                  Horst Böttcher
                  ```bash
                  Script v.2026-01-31
                  *** BASE SYSTEM ***
                    Virtualization: lxc
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                   17:06:21 up 36 min,  1 user,  load average: 1.24, 1.00, 0.99
                  CPU threads: 4
                                 Local time: Mon 2026-03-23 17:06:21 CET
                             Universal time: Mon 2026-03-23 16:06:21 UTC
                                   RTC time: n/a
                            RTC in local TZ: no
                  pi
                  HOME=/
                  iobroker
                  HOME=/home/iobroker
                  Display-Manager:
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Mem:            5.2G        2.7G        2.0G         32K        499M        2.5G
                  Swap:           5.2G        547M        4.7G
                  Total:           10G        3.2G        6.7G
                           5000 M total memory
                           2574 M used memory
                            571 M active memory
                           2326 M inactive memory
                           1949 M free memory
                              0 M buffer memory
                            476 M swap cache
                           5000 M total swap
                            521 M used swap
                           4478 M free swap
                  top - 17:06:21 up 36 min,  1 user,  load average: 1.24, 1.00, 0.99
                  Tasks:  59 total,   1 running,  58 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  2.4 us,  4.8 sy,  0.0 ni, 92.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   5000.0 total,   1947.1 free,   2576.7 used,    476.2 buff/cache
                  MiB Swap:   5000.0 total,   4478.0 free,    522.0 used.   2423.3 avail Mem
                  1 loaded units listed.
                  *** FILESYSTEM ***
                  [Sun Mar 22 20:33:46 2026] EXT4-fs (dm-11): unmounting filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c.
                  [Sun Mar 22 20:35:19 2026] EXT4-fs (dm-11): mounted filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c r/w with ordered data mode. Quota mode: none.
                  [Sun Mar 22 20:38:07 2026] EXT4-fs (dm-11): unmounting filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c.
                  [Sun Mar 22 20:40:22 2026] EXT4-fs (dm-11): mounted filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c r/w with ordered data mode. Quota mode: none.
                  [Mon Mar 23 16:16:36 2026] EXT4-fs (dm-11): unmounting filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c.
                  [Mon Mar 23 16:16:37 2026] EXT4-fs (dm-11): mounted filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c r/w with ordered data mode. Quota mode: none.
                  [Mon Mar 23 16:27:48 2026] EXT4-fs (dm-11): unmounting filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c.
                  [Mon Mar 23 16:27:51 2026] EXT4-fs (dm-6): unmounting filesystem 3cb29323-3f31-48bf-85fa-4669576c6456.
                  [Mon Mar 23 16:29:34 2026] EXT4-fs (dm-11): mounted filesystem 8b553e73-2383-4a34-90b6-4bd392b7ac0c r/w with ordered data mode. Quota mode: none.
                  [Mon Mar 23 16:29:37 2026] EXT4-fs (dm-6): mounted filesystem 3cb29323-3f31-48bf-85fa-4669576c6456 r/w with ordered data mode. Quota mode: none.
                  [Mon Mar 23 16:35:21 2026] EXT4-fs (dm-17): unmounting filesystem 054ab45e-076f-49c5-8986-9991b37a84e7.
                  [Mon Mar 23 16:35:56 2026] EXT4-fs (dm-17): mounted filesystem 054ab45e-076f-49c5-8986-9991b37a84e7 r/w with ordered data mode. Quota mode: none.
                  /var:
                  1.3G    /var/
                  804M    /var/log
                  787M    /var/log/journal/3cb36adc397d4355ba4179a97085f566
                  332M    /var/lib
                  Archived and active journals take up 53.9M in the file system.
                  956M    /opt/iobroker/backups/
                  924M    /opt/iobroker/iobroker-data/history
                  66M     /opt/iobroker/iobroker-data/objects.jsonl
                  USB-Devices by-id:
                  /usr/bin/npm            10.9.4
                  /usr/bin/npx            10.9.4
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 2211)
                  admin:          7.7.22
                  javascript:     9.0.18
                  Adapter State
                  + instance is alive
                  Adapter    "ical"         : 1.19.7   , installed 1.19.7
                  Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                  Objects and States
                  Objects:        83806
                  States:         63324
                  Hit:1 https://deb.nodesource.com/node_22.x nodistro InRelease
                  Hit:2 http://archive.ubuntu.com/ubuntu noble InRelease
                  Hit:3 http://archive.ubuntu.com/ubuntu noble-updates InRelease
                  Pending systemupdates: 0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          128333610  1/init
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          128331329  1/init
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       128335989  289/iobroker.js-con
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       128334808  289/iobroker.js-con
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       128349341  1297/io.shelly.0
                  tcp        0      0 192.168.10.5:9292       0.0.0.0:*               LISTEN      1000       128345534  1201/io.hm-rpc.0
                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      992        128335251  278/systemd-resolve
                  tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      992        128335253  278/systemd-resolve
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          128333612  1/init
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          128328632  1/init
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1000       128341190  585/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       128363084  2339/io.web.0
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1000       128362147  2466/io.simple-api.
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          128331330  1/init
                  udp        0      0 0.0.0.0:58328           0.0.0.0:*                           1000       128360816  2124/io.upnp.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       128359760  1906/io.homekit-con
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       128350135  1725/io.chromecast.
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       128365633  2124/io.upnp.0
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       128351608  1348/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       128351609  1348/io.tuya.0
                  udp        0      0 127.0.0.54:53           0.0.0.0:*                           992        128335252  278/systemd-resolve
                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           992        128335250  278/systemd-resolve
                  udp6       0      0 :::111                  :::*                                0          128331331  1/init
                  2026-03-23 17:05:17.318  - info: tapo.0 (2105) No stok found for: 80216A19019D84F2EF32CD71C40501B4237A9D4F this means the device is offline or connection lost. No update or commands possible
                  2026-03-23 17:05:27.329  - info: tapo.0 (2105) Get camera Status failed
                  2026-03-23 17:05:27.329  - info: tapo.0 (2105) No stok found for: 80216A19019D84F2EF32CD71C40501B4237A9D4F this means the device is offline or connection lost. No update or commands possible
                  2026-03-23 17:05:35.055  - info: unifi-network.0 (2672) [updateIsOnlineState]: Fallback method - client '54:0b:b1:98:dc:97' (mac: 54:0b:b1:98:dc:97, ip: undefined) is offline, last_seen '23.03. - 17:01h' not updated since 216s
                  2026-03-23 17:05:37.318  - info: tapo.0 (2105) Get camera Status failed
                  2026-03-23 17:05:37.319  - info: tapo.0 (2105) No stok found for: 80216A19019D84F2EF32CD71C40501B4237A9D4F this means the device is offline or connection lost. No update or commands possible
                  2026-03-23 17:05:47.317  - info: tapo.0 (2105) Get camera Status failed
                  2026-03-23 17:05:47.317  - info: tapo.0 (2105) No stok found for: 80216A19019D84F2EF32CD71C40501B4237A9D4F this means the device is offline or connection lost. No update or commands possible
                  2026-03-23 17:05:57.321  - info: tapo.0 (2105) Get camera Status failed
                  2026-03-23 17:05:57.321  - info: tapo.0 (2105) No stok found for: 80216A19019D84F2EF32CD71C40501B4237A9D4F this means the device is offline or connection lost. No update or commands possible
                  2026-03-23 17:06:07.337  - info: tapo.0 (2105) Get camera Status failed
                  2026-03-23 17:06:07.338  - info: tapo.0 (2105) No stok found for: 80216A19019D84F2EF32CD71C40501B4237A9D4F this means the device is offline or connection lost. No update or commands possible
                  2026-03-23 17:06:17.323  - info: tapo.0 (2105) Get camera Status failed
                  2026-03-23 17:06:17.323  - info: tapo.0 (2105) No stok found for: 80216A19019D84F2EF32CD71C40501B4237A9D4F this means the device is offline or connection lost. No update or commands possible
                  2026-03-23 17:06:27.357  - info: tapo.0 (2105) Get camera Status failed
                  2026-03-23 17:06:27.357  - info: tapo.0 (2105) No stok found for: 80216A19019D84F2EF32CD71C40501B4237A9D4F this means the device is offline or connection lost. No update or commands possible
                  2026-03-23 17:06:37.328  - info: tapo.0 (2105) Get camera Status failed
                  2026-03-23 17:06:37.328  - info: tapo.0 (2105) No stok found for: 80216A19019D84F2EF32CD71C40501B4237A9D4F this means the device is offline or connection lost. No update or commands possible
                  2026-03-23 17:06:47.329  - info: tapo.0 (2105) Get camera Status failed
                  2026-03-23 17:06:47.329  - info: tapo.0 (2105) No stok found for: 80216A19019D84F2EF32CD71C40501B4237A9D4F this means the device is offline or connection lost. No update or commands possible
                  2026-03-23 17:06:57.321  - info: tapo.0 (2105) Get camera Status failed
                  2026-03-23 17:06:57.321  - info: tapo.0 (2105) No stok found for: 80216A19019D84F2EF32CD71C40501B4237A9D4F this means the device is offline or connection lost. No update or commands possible
                  2026-03-23 17:07:07.320  - info: tapo.0 (2105) Get camera Status failed
                  2026-03-23 17:07:07.320  - info: tapo.0 (2105) No stok found for: 80216A19019D84F2EF32CD71C40501B4237A9D4F this means the device is offline or connection lost. No update or commands possible
                  2026-03-23 17:07:08.309  - info: unifi-network.0 (2672) [eventHandler.client.connected]: client '54:0b:b1:98:dc:97' disconnected (mac: 54:0b:b1:98:dc:97)
                  pi@ioBroker:/opt/iobroker$
                  • ilovegymI Offline
                    ilovegymI Offline
                    ilovegym
                    Hmm also Double NAT muss es nicht gewesen sein, deine Tapo Devices sind auch nicht erreichbar vom ioBroker, und dein filesystem ist immer noch crashed..
                    einige Services laufen nicht.. das System ist im Prinzip geschossen…
                    Setz doch einfach mal neu auf, spiel das Backup von ioBroker zurück und teste nochmal.
                    Schau nach dem Netzwerk, dass das richtig configuriert ist und die Devices auch erreichbar sind
                      Horst Böttcher
                      @ilovegym ja das kann ich aber erst heute abend machen muss leider zur arbeit
                        Horst Böttcher
                        schrieb am zuletzt editiert von Horst Böttcher
                        Ok allen neu und Backup ist drin und gleich mal auf Trixi umgestiegen jetzt sein es zu gehen
                        Tuya Adapter schaltet die Geräte wenn er sich diese geholt hat und danach aber orange schalten geht aber
                        ```bash
                        Script v.2026-01-31
                        *** BASE SYSTEM ***
                        Operating System: Debian GNU/Linux 13 (trixie)
                         Static hostname: iob
                               Icon name: computer-container
                                 Chassis: container ☐
                          Virtualization: lxc
                                  Kernel: Linux 6.17.13-2-pve
                            Architecture: x86-64
                        OS is similar to:
                        model name      : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
                        Docker          : false
                        Virtualization  : lxc
                        Kernel          : x86_64
                        Userland        : 64 bit
                        Systemuptime and Load:
                         20:34:40 up 23:42,  0 users,  load average: 0.34, 0.34, 0.30
                        CPU threads: 2
                        *** LIFE CYCLE STATUS ***
                        Operating System is the current Debian stable version codenamed 'trixie'!
                        *** TIME AND TIMEZONES ***
                                       Local time: Wed 2026-03-25 20:34:40 CET
                                   Universal time: Wed 2026-03-25 19:34:40 UTC
                                         RTC time: n/a
                                      NTP service: inactive
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        iob
                        HOME=/home/iob
                        GROUPS=iob sudo users iobroker
                        iobroker
                        HOME=/home/iobroker
                        SUDO_HOME=/home/iob
                        GROUPS=iobroker tty dialout audio video plugdev
                        *** DISPLAY-SERVER SETUP ***
                        Display-Server:         false
                        Unit display-manager.service could not be found.
                        Display-Manager:
                        Desktop:
                        Session:
                        *** MEMORY ***
                        Mem:            5.2G        2.4G        2.4G        2.9M        422M        2.9G
                        Swap:           5.2G        811M        4.4G
                        Total:           10G        3.2G        6.9G
                        Active iob-Instances:   26
                                 5000 M total memory
                                 2274 M used memory
                                  803 M active memory
                                 1689 M inactive memory
                                 2324 M free memory
                                    0 M buffer memory
                                  402 M swap cache
                                 5000 M total swap
                                  773 M used swap
                                 4226 M free swap
                        top - 20:34:41 up 23:42,  0 users,  load average: 0.34, 0.34, 0.30
                        Tasks:  52 total,   1 running,  51 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  4.8 us,  4.8 sy,  0.0 ni, 90.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   5000.0 total,   2323.4 free,   2276.3 used,    403.1 buff/cache
                        MiB Swap:   5000.0 total,   4226.3 free,    773.7 used.   2723.7 avail Mem
                        *** FAILED SERVICES ***
                          UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                        * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                        Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                                ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                                SUB    -> The low-level unit activation state, values depend on unit type.
                        *** DMESG CRITICAL ERRORS ***
                        dmesg: read kernel buffer failed: Operation not permitted
                        No critical errors detected
                        *** FILESYSTEM ***
                        Filesystem                       Type      Size  Used Avail Use% Mounted on
                        /dev/mapper/pve-vm--105--disk--0 ext4      9.8G  5.3G  4.0G  57% /
                        none                             tmpfs     492K  4.0K  488K   1% /dev
                        udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
                        tmpfs                            tmpfs     3.8G     0  3.8G   0% /dev/shm
                        tmpfs                            tmpfs     1.6G  104K  1.6G   1% /run
                        tmpfs                            tmpfs     3.8G  2.9M  3.8G   1% /tmp
                        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                        /      /dev/mapper/pve-vm--105--disk--0 ext4   rw,relatime,stripe=16
                        /var:
                        498M    /var/
                        312M    /var/cache
                        308M    /var/cache/apt
                        218M    /var/cache/apt/archives
                        161M    /var/lib
                        Archived and active journals take up 8M in the file system.
                        40M     /opt/iobroker/backups/
                        20K     /opt/iobroker/backups/zigbee2mqtt_tmp
                        1.2G    /opt/iobroker/iobroker-data/
                        534M    /opt/iobroker/iobroker-data/files
                        349M    /opt/iobroker/iobroker-data/history
                        68M     /opt/iobroker/iobroker-data/files/vis
                        67M     /opt/iobroker/iobroker-data/files/echarts.admin
                        130M    /opt/iobroker/iobroker-data/objects.jsonl
                        80M     /opt/iobroker/iobroker-data/states.jsonl
                        30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
                        USB-Devices by-id:
                        /usr/bin/npm            10.9.4
                        /usr/bin/npx            10.9.4
                        nodejs:
                          Version table:
                         *** 22.22.1-1nodesource1 1001
                             22.22.0-1nodesource1 1001
                             22.21.0-1nodesource1 1001
                             22.20.0-1nodesource1 1001
                             22.19.0-1nodesource1 1001
                             22.18.0-1nodesource1 1001
                             22.17.1-1nodesource1 1001
                             22.17.0-1nodesource1 1001
                             22.16.0-1nodesource1 1001
                             22.15.1-1nodesource1 1001
                             22.15.0-1nodesource1 1001
                             22.14.0-1nodesource1 1001
                             22.13.1-1nodesource1 1001
                             22.13.0-1nodesource1 1001
                             22.12.0-1nodesource1 1001
                             22.11.0-1nodesource1 1001
                             22.10.0-1nodesource1 1001
                             22.9.0-1nodesource1 1001
                             22.8.0-1nodesource1 1001
                             22.7.0-1nodesource1 1001
                             22.6.0-1nodesource1 1001
                             22.5.1-1nodesource1 1001
                             22.5.0-1nodesource1 1001
                             22.4.1-1nodesource1 1001
                             22.4.0-1nodesource1 1001
                             22.3.0-1nodesource1 1001
                             22.2.0-1nodesource1 1001
                             22.1.0-1nodesource1 1001
                             22.0.0-1nodesource1 1001
                             20.19.2+dfsg-1+deb13u1 500
                                500 http://security.debian.org trixie-security/main amd64 Packages
                             20.19.2+dfsg-1 500
                                500 http://deb.debian.org/debian trixie/main amd64 Packages
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        iob                 iob (version: 7.0.7, hostname: iob           , alive, uptime: 58925)
                        admin:          7.7.22
                        javascript:     9.0.18
                        nodejs modules from github:     4
                        Adapter State
                          system.adapter.accuweather.0            : accuweather           : iob                                      - disabled
                        + system.adapter.admin.0                  : admin                 : iob                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          system.adapter.alexa2.0                 : alexa2                : iob                                      - disabled
                        + system.adapter.backitup.0               : backitup              : iob                                      -  enabled
                        + system.adapter.chromecast.0             : chromecast            : iob                                      -  enabled
                          system.adapter.device-reminder.0        : device-reminder       : iob                                      - disabled
                          system.adapter.devices.0                : devices               : iob                                      - disabled
                          system.adapter.discovergy.0             : discovergy            : iob                                      -  enabled
                          system.adapter.discovery.0              : discovery             : iob                                      -  enabled
                          system.adapter.echarts.0                : echarts               : iob                                      -  enabled
                          system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iob                                      - disabled
                          system.adapter.feiertage.0              : feiertage             : iob                                      -  enabled
                          system.adapter.flexcharts.0             : flexcharts            : iob                                      -  enabled
                        + system.adapter.history.0                : history               : iob                                      -  enabled
                        + system.adapter.hm-rega.0                : hm-rega               : iob                                      -  enabled
                        + system.adapter.hm-rpc.0                 : hm-rpc                : iob                                      -  enabled, port: 0
                          system.adapter.homekit-controller.0     : homekit-controller    : iob                                      - disabled
                          system.adapter.ical.0                   : ical                  : iob                                      - disabled
                          system.adapter.ical.1                   : ical                  : iob                                      - disabled
                          system.adapter.ical.2                   : ical                  : iob                                      - disabled
                          system.adapter.ical.3                   : ical                  : iob                                      - disabled
                          system.adapter.ical.4                   : ical                  : iob                                      - disabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iob                                      - disabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iob                                      - disabled
                        + system.adapter.influxdb.0               : influxdb              : iob                                      -  enabled, port: 8086
                        + system.adapter.info.0                   : info                  : iob                                      -  enabled
                        + system.adapter.iot.0                    : iot                   : iob                                      -  enabled
                        + system.adapter.javascript.0             : javascript            : iob                                      -  enabled
                          system.adapter.net-tools.0              : net-tools             : iob                                      - disabled
                        + system.adapter.nuki-extended.0          : nuki-extended         : iob                                      -  enabled
                          system.adapter.openweathermap.0         : openweathermap        : iob                                      -  enabled
                        + system.adapter.pushover.0               : pushover              : iob                                      -  enabled
                        + system.adapter.radar2.0                 : radar2                : iob                                      -  enabled
                        + system.adapter.rssfeed.0                : rssfeed               : iob                                      -  enabled
                        + system.adapter.sayit.0                  : sayit                 : iob                                      -  enabled
                        + system.adapter.shelly.0                 : shelly                : iob                                      -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.simple-api.0             : simple-api            : iob                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        + system.adapter.sourceanalytix.0         : sourceanalytix        : iob                                      -  enabled
                        + system.adapter.systeminfo.0             : systeminfo            : iob                                      -  enabled
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : iob                                      -  enabled
                          system.adapter.tapo.0                   : tapo                  : iob                                      - disabled
                        + system.adapter.telegram.0               : telegram              : iob                                      -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.tuya.0                   : tuya                  : iob                                      -  enabled
                          system.adapter.twinkly.0                : twinkly               : iob                                      - disabled
                          system.adapter.unifi-network.0          : unifi-network         : iob                                      - disabled, port: 11443
                          system.adapter.unifi.0                  : unifi                 : iob                                      - disabled
                          system.adapter.upnp.0                   : upnp                  : iob                                      -  enabled
                          system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iob                                      - disabled
                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iob                                      - disabled
                          system.adapter.vis-inventwo.0           : vis-inventwo          : iob                                      -  enabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob                                      - disabled
                          system.adapter.vis.0                    : vis                   : iob                                      -  enabled
                        + system.adapter.weather-warnings.0       : weather-warnings      : iob                                      -  enabled
                          system.adapter.weatherunderground.0     : weatherunderground    : iob                                      - disabled
                        + system.adapter.web.0                    : web                   : iob                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iob                                      - disabled
                        + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iob                                      -  enabled
                        + instance is alive
                        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                        Adapter    "weather-warnings": 0.10.0, installed 0.10.0
                        Objects and States
                        Objects:        84083
                        States:         63491
                        Hit:1 http://deb.debian.org/debian trixie InRelease
                        Hit:2 http://security.debian.org trixie-security InRelease
                        Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                        Pending systemupdates: 1
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          2053665    288/master
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       4213707    10153/io.shelly.0
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       4079761    3783/iobroker.js-co
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4079753    3783/iobroker.js-co
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2049816    1/init
                        tcp        0      0 127.0.0.1:9292          0.0.0.0:*               LISTEN      1001       4100129    5140/io.hm-rpc.0
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          2053666    288/master
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          2049818    1/init
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          2051641    1/init
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       4213701    10161/io.simple-api
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       4077300    3811/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       4133658    9214/io.web.0
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       4152394    9871/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       4152395    9871/io.tuya.0
                        udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       4216069    10117/io.radar2.0
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          2051880    192/dhclient
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2049817    1/init
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       4092446    4654/io.chromecast.
                        udp6       0      0 :::111                  :::*                                0          2049819    1/init
                        2026-03-25 20:24:42.609  - info: admin.0 (3811) ==> Connected system.user.admin from ::ffff:192.168.20.19
                        2026-03-25 20:24:44.407  - info: admin.0 (3811) <== Disconnect system.user.admin from ::ffff:192.168.20.19 admin
                        iob@iob:/opt/iobroker$
                        • ilovegymI Offline
                          ilovegymI Offline
                          ilovegym
                          orange ? zeig doch bitte das log vom tuya adapter beim starten, bis er orange wird.. da steht bestimmt, wo es haengt.
                          Und update denselben bitte auf die aktuelle Version 3.17, falls die noch nicht im stable ist, schalte mal kurz auf beta repo um und nach dem update wieder zurueck.
                            Horst Böttcher
                            kann aber auch an Trix liegen hab bei einen anderen auch ganz krasse Probleme
                            hab jetzt auf die 3.17 aktualisiert
                            tuya.0
                            2026-03-29 20:24:54.143	info	bf69c9cb6e8b29050enrqt: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:54.143	info	854560468cce4e2b75c9: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:54.143	info	bfd2494109784809ddntef: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:54.101	info	bf73c5e2e4e7bed70f34bx: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:54.062	info	4530056170039f47f981: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:54.058	info	bf9ae250213f3d5d915nv4: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:54.057	info	bf030150d46da26483qfxh: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:54.053	info	24300621c4dd5715010d: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:54.048	info	bfbad50c821dc5105cetog: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:54.048	info	bf7fc60a662c018abcpxgy: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:54.048	info	0478272848551959bf4f: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:54.048	info	bf12e9bd1526f64831nlog: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:54.044	info	4530056170039f4b4878: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:53.819	info	Cloud MQTT connection established successfully.
                            tuya.0
                            2026-03-29 20:24:52.712	info	Listen for encrypted local Tuya devices on port 6667
                            tuya.0
                            2026-03-29 20:24:52.711	info	Listen for local Tuya devices on port 6666
                            tuya.0
                            2026-03-29 20:24:52.615	info	Try to sync devices from Cloud using stored cloud credentials
                            tuya.0
                            2026-03-29 20:24:52.613	info	Existing devices initialized
                            tuya.0
                            2026-03-29 20:24:52.613	info	0478272848551959bf4f: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:52.612	info	854560468cce4e2b75c9: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:52.570	info	4530056170039f47f981: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:52.569	info	bf12e9bd1526f64831nlog: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:52.569	info	4530056170039f4b4878: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:52.565	info	bfd2494109784809ddntef: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:52.564	info	bf69c9cb6e8b29050enrqt: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:52.564	info	bf7fc60a662c018abcpxgy: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:52.564	info	bf9ae250213f3d5d915nv4: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:52.564	info	bf030150d46da26483qfxh: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:52.563	info	bf73c5e2e4e7bed70f34bx: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:52.563	info	bfbad50c821dc5105cetog: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:52.516	info	24300621c4dd5715010d: Connect locally to device
                            tuya.0
                            2026-03-29 20:24:51.837	info	starting. Version 3.17.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v20.20.2, js-controller: 7.0.7
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              tuya.0
                              @Horst-Böttcher sagte in Tuya-Adapter wird nach kurzer Zeit Orange (Status Gelb):
                              node: v20.20.2,
                              Liegt eher an deiner alten nodejs-Version...
                              UPDATEN!!!
                                node: v20.20.2,
                                UPDATEN!!!
                                Horst Böttcher
                                @Thomas-Braun nee hat nix gebracht
                                  Hab ich auch nicht behauptet. Nur das deine Version 20 zu alt ist und in ein paar Wochen abgekündigt werden wird.
                                  BTW: Hier läuft der Adapter auf Trixie ganz wunderbar in aktueller Version. Liegt also nicht grundsätzlich am Betriebssystem.
                                  Eher an deinem komplexen Netzwerk, würde ich behaupten.
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    tuya.0
                                    crunchipC Offline
                                    crunchipC Offline
                                    node: v20.20.2
                                    frag mich eher, woher die plötzlich kommt, denn vor 4 Tagen war da noch
                                    /usr/bin/npm 10.9.4
                                    /usr/bin/npx 10.9.4
                                    und in der Instanzeinstellung alles korrekt, passend zur App?
                                    • ilovegymI Offline
                                      ilovegymI Offline
                                      ilovegym
                                      im log das du zeigst, sind keine Fehler vom Tuya adapter, also wird er nach Start gruen und geht spaeter auf gelb, weil ein Fehler auftritt oder er ist noch nicht fertig mit der Initialisierung und du hast zuwenig vom Log gezeigt.. ??
                                      Ich denke auch, deine Grundinstallation ist broken - weil error 25 bei npm .. ist ja bekannt - und den Info-Adapter schmeiss raus, der wurde doch abgekuendigt soviel ich weiss.. den haste von git installiert, wie auch andere.. warum ?
                                        Horst Böttcher
                                        Hab dem adapter mal auf debug laufen lassen neu 2.txt
                                        • ilovegymI Offline
                                          ilovegymI Offline
                                          ilovegym
                                          wie gehabt Netzwerkprobleme, kein udp zu den devices... aber auch in dem log kein fehler, warum der adapter stoppt, wenn lokal kein zugriff, versucht er es ja ueber die Cloud.. wenn der Adapter auf Error geht, muss was im Log stehen.. oder es ist was anderes..
