  4. Test Adapter TP-Link Tapo
    6.6k
885 Beiträge 123 Kommentatoren 403.8k Aufrufe 107 Beobachtet
  • R Rawx17
    Hallo @thomas-braun , vielen dank!
    Ich habe jetzt auf Node22 umgestellt und erhalte weiterhin die meldungen:
    2025-12-28 21:36:23.459  - info: tapo.0 (5560) Login tp TAPO App
    2025-12-28 21:36:23.709  - info: tapo.0 (5560) Login succesfull
    2025-12-28 21:36:23.870  - info: tapo.0 (5560) Found 1 devices
    2025-12-28 21:36:24.082  - info: tapo.0 (5560) Init device 80224F4EA5ABF03668F23F09A573B7FB1D4BA8A5 type P100 with ip 192.168.178.50
    2025-12-28 21:36:29.114  - error: tapo.0 (5560) timeout of 5000ms exceeded
    2025-12-28 21:36:50.627  - error: tapo.0 (5560) Error: connect ETIMEDOUT 192.168.178.50:80
    2025-12-28 21:36:50.630  - error: tapo.0 (5560) New Handshake 1 failed
    2025-12-28 21:36:50.631  - error: tapo.0 (5560) Local seed auth hash doesn't match server hash. Please check if the mail and password are correct. And E-Mail is in same Upper/Lowercase as in the Tapo App
    2025-12-28 21:36:55.650  - error: tapo.0 (5560) 276 Error: timeout of 5000ms exceeded
    2025-12-28 21:36:55.662  - info: tapo.0 (5560) Initialized 80224F4EA5ABF03668F23F09A573B7FB1D4BA8A5
    2025-12-28 21:36:55.673  - info: tapo.0 (5560) Wait for connections for non camera devices
    2025-12-28 21:37:00.681  - info: tapo.0 (5560) 469 Error: timeout of 5000ms exceeded
    2025-12-28 21:37:00.682  - error: tapo.0 (5560) Malformed response sysinfo
    2025-12-28 21:37:00.683  - error: tapo.0 (5560) {"message":"timeout of 5000ms exceeded","name":"AxiosError","stack":"AxiosError: timeout of 5000ms exceeded\n    at RedirectableRequest.handleRequestTimeout (C:\\Program Files\\iobroker\\SmartHome\\node_modules\\iobroker.tapo\\node_modules\\axios\\dist\\node\\axios.cjs:3552:15)\n    at RedirectableRequest.emit (node:events:519:28)\n    at Timeout._onTimeout (C:\\Program Files\\iobroker\\SmartHome\\node_modules\\follow-redirects\\index.js:210:12)\n    at listOnTimeout (node:internal/timers:588:17)\n    at process.processTimers (node:internal/timers:523:7)\n    at Axios.request (C:\\Program Files\\iobroker\\SmartHome\\node_modules\\iobroker.tapo\\node_modules\\axios\\dist\\node\\axios.cjs:4731:41)\n    at process.processTicksAndRejections (node:internal/process/task_queues:105:5)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":5000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"*/*","Content-Type":"application/octet-stream","Connection":"Keep-Alive","Host":"192.168.178.50","User-Agent":"axios/1.13.2","Content-Length":"112","Accept-Encoding":"gzip, compress, deflate, br"},"responseType":"arraybuffer","params":{"seq":"124396006"},"method":"post","url":"http://192.168.178.50/app/request","data":{"type":"Buffer","data":[100,220,179,121,202,213,108,169,190,109,4,66,164,221,135,215,115,15,115,101,200,85,77,80,87,141,52,60,113,144,79,14,251,226,63,66,233,99,236,232,152,73,62,135,141,96,142,174,6,114,128,166,127,49,174,154,131,201,21,127,51,158,1,179,85,94,139,209,57,21,204,127,154,104,56,74,145,244,244,34,179,56,127,112,85,233,185,86,66,56,241,76,110,120,179,123,86,219,217,54,98,136,246,213,156,77,144,141,137,252,240,56]},"allowAbsoluteUrls":true},"code":"ECONNABORTED"}
    #779
    @Rawx17 sagte in Test Adapter TP-Link Tapo:
    Hast du geprüft?
    R 1 Antwort Letzte Antwort
      Hast du geprüft?
      Rawx17
      schrieb am zuletzt editiert von Rawx17
      #780
      @Thomas-Braun Ja habe ich. Komplett neuen Account angelegt mail komplett klein geschrieben usw...
      EDIT: auch sofort drittanbieter apps Akitiviert!
      Ist folgendes nicht der Nachweiß dass der Login funktioniert?
      Wenns das nicht ist, was genau bedeutet dieser Fehler sonst?
      Es ist ja anschließend die Rede von einem Timeout, den ich mir absolut nicht erklären kann..
      • Ro75R Offline
        Ro75R Offline
        Ro75
        #781
        lies mal bissel weiter oben. Ich habe alle TAPO's rausgeschmissen. Bei mir lief der Adapter erst normal, dann bockig und am Ende gar nicht mehr verlässlich. Bei mir Ende aus die Maus. Ich habe unter GIT Probleme gemeldet, sorry aber da tut sich nichts.
        Ro75.
        • Ro75R Ro75
          Ro75.
          Rawx17
          #782
          @Ro75 Ich habe es jetzt über den Smartthings adapter gelöst. Damit kann man die tapos verlässlich schalten. Komisch, dass sowohl der Alexa adapter als auch der Smartthings adapter die Dosen problemlos schalten können aber der "hauseigene" adapter nicht.
          Info. Ich bin über smartthings gegangen weil bei dem Alexa sind nur extrem wenige befehle pro 10 minuten erlaubt was für eine bewegungsmeldersteuerung absolut unbrauchbar ist in einem Raum wo man sich häufiger aufhält...
          Wieso ist der Tapo adapter hier so komisch "sensitiv" auf die Accountdaten und andere adapter nicht?
          • Hant0rH Offline
            Hant0rH Offline
            Hant0r
            #783
            Moin zusammen,
            seit einiger Zeit bekomme ich folgende Meldungen im Log (dutzende an Tag):
            tapo.0 2026-01-03 23:39:22.435	error	Get Device Info failed for 80220719A059A5A7CC58B902714B8CC72xxxxxxx - TypeError: Cannot read properties of undefined (reading 'request')
            tapo.0 2026-01-03 23:39:22.432	error	671 Error Code: Bad control character in string literal in JSON at position 15, undefined 10.1.x.x
            tapo.0 2026-01-03 23:39:22.384	error	Get Device Info failed for 80220719A059A5A7CC58B902714B8CC72xxxxxxx - TypeError: Cannot read properties of undefined (reading 'request')
            tapo.0 2026-01-03 23:39:22.383	error	671 Error Code: Bad control character in string literal in JSON at position 15, undefined 10.1.x.x
            tapo.0 2026-01-03 23:29:23.214	error	Get Device Info failed for 80228BB16312291F3FD5F15569F80AB92xxxxxxx - TypeError: Cannot read properties of undefined (reading 'request')
            tapo.0 2026-01-03 23:29:23.205	error	671 Error Code: Bad control character in string literal in JSON at position 15, undefined 10.1.x.x
            Ebenso erhalte ich diese Warnings, weswegen ich das Log-Level vom Adapter schon auf Error gestellt habe:
            2026-01-03 22:51:21.090 - warn: tapo.0 (9428) State "tapo.0.802268495A79A6E4AAF9D82CD763EF4B1xxxxxxx.tod`y_runtime" has no existing object, this might lead to an error in future versions
            2026-01-03 22:51:21.130 - warn: tapo.0 (9428) State "tapo.0.8022ED528A7BD7C13A74EF75D64F9A452xxxxxxx.tod`y_runtime" has no existing object, this might lead to an error in future versions
            2026-01-03 22:51:21.142 - warn: tapo.0 (9428) State "tapo.0.80228BB16312291F3FD5F15569F80AB9xxxxxxx.tod`y_runtime" has no existing object, this might lead to an error in future versions
            2026-01-03 22:51:21.161 - warn: tapo.0 (9428) State "tapo.0.8022D96450916D7669A9FC0CC30766222xxxxxxx.tody_runtime" has no existing object, this might lead to an error in future versions
            2026-01-03 22:51:21.178 - warn: tapo.0 (9428) State "tapo.0.80220719A059A5A7CC58B902714B8CC72xxxxxxx.tod`y_runtime" has no existing object, this might lead to an error in future versions
            2026-01-03 22:51:21.223 - warn: tapo.0 (9428) State "tapo.0.8022ED528A7BD7C13A74EF75D64F9A45xxxxxxx.tod`y_runtime" has no existing object, this might lead to an error in future versions
            2026-01-03 22:53:21.124 - warn: tapo.0 (9428) State "tapo.0.8022ED528A7BD7C13A74EF75D64F9A452xxxxxxx.tod`y_runtime" has no existing object, this might lead to an error in future versions
            2026-01-03 22:53:21.155 - warn: tapo.0 (9428) State "tapo.0.80228BB16312291F3FD5F15569F80AB92xxxxxxx.tod`y_runtime" has no existing object, this might lead to an error in future versions
            2026-01-03 22:53:21.156 - warn: tapo.0 (9428) State "tapo.0.802268495A79A6E4AAF9D82CD763EF4B1xxxxxxx.tod`y_runtime" has no existing object, this might lead to an error in future versions
            2026-01-03 22:53:21.187 - warn: tapo.0 (9428) State "tapo.0.80220719A059A5A7CC58B902714B8CC7xxxxxxx.tod`y_runtime" has no existing object, this might lead to an error in future versions
            2026-01-03 22:53:21.188 - warn: tapo.0 (9428) State "tapo.0.8022ED528A7BD7C13A74EF75D64F9A45xxxxxxxx.tod`y_runtime" has no existing object, this might lead to an error in future versions
            Habt ihr eine Idee, ob ich was einstellen/ändern kann?
              swagner
              #784
              !! ACHTUNG !! bei der C310 V2 kein update der Firmware von 1.5.1 auf 1.9.1 machen, danach wird die Kamera beim init device gefunden und auch das Initialized funktioniet aber danach beim Start first Update kommt immer die Meldung "Get camera Status failed" und "No stok found for: xxxxx", ich habe eine baugleiche C310 V2 die funktioniert ohne Probleme mit 1.5.1.
              1.9.1 Build 251222 Rel.34614n -> die ist hat irgend ein neues "feature"
              1.5.1 Build 251011 Rel.56776n -> funktioniert ohne Probleme
              ich habe die Kamera aus der App gelöscht und neu hinzugefügt, das hilft nichts ich habe auch die IOBroker den Adapter gelöscht und neu installiert, ohne Erfolg.
              tapo version 0.4.8+615315d
              ich werde ein support ticket bei tapo öffnen ....
              S bautruppB 2 Antworten Letzte Antwort
              • S swagner
                swagner
                #785
                Ich habe jetzt die C310 V2 mit der Firmware 1.9.1 gegen eine C310 V2 mit der Firmware 1.5.1 ausgetauscht und die funktioniert ohne Probleme. Ich habe auch ein Support-Ticket für die Tapo C310 V2 mit der Firmware 1.9.1 bei TP-Link geöffnet und angefragt, wo ich die Firmware für ein Downgrade auf die Version 1.5.1 bekommen kann.
                • E Offline
                  Einstein67
                  #786
                  Danke für die Info. Bei meiner C310 und V120 wäre auch das Update auf 1.91 verfügbar. Ich warte mal ab ob es Neuigkeiten von Tapo gibt.
                  • T tombox
                    @arteck Teils teils.
                    Er loggt sich über die Cloud ein um alle Geräte mit IP zu finden
                    Dann versucht er sich lokal mit username und Password auf die Geräte zu verbinden und zu steuern.
                    Ich könnte auch alles über cloud steuern aber das ist ja nicht notwendig
                    disko
                    #787
                    Hallo
                    versuche gerade die Verbindung herzustellen, was leider nicht klappt.
                    @tombox sagte in Test Adapter TP-Link Tapo:
                    bedeutet ich muss bei Tapo Care angemeldet sein?
                    Würde es reichen die 7-Tage Testversion zu benutzen und danach wieder abzumelden?
                    Was ist der MFA-Code?
                    Gruß Dirk
                    • S swagner
                      bautruppB Offline
                      bautruppB Offline
                      bautrupp
                      #788
                      @swagner sagte in Test Adapter TP-Link Tapo:
                      Das gleiche gilt leider auch für die C210 V2 Firmwareversion 1.5.2
                      Hier kommt auch nur noch: "Get camera Status failed"
                      • bautruppB bautrupp
                        swagner
                        #789
                        @bautrupp Es ist kein Problem mit der Kamera. TAPO hat das Ticket mit dem Vermerk „IOBroker wird nicht unterstützt” geschlossen. Das Problem wird zwar durch eine neue Funktion in der Firmware erzeugt, aber eine Anpassung des TP-Link Tapo Adapters ist nötig um dieses Problem zu beheben.
                        Anscheinend hat sich bei den Zertifikaten auf der Kamera und/oder die Verschlüsselung geändert und dadurch entsteht dieses Problem.
                        Ein Downgrade mit Hilfe einer SD Karte die zum booten verwendet wird funktioniert auch nicht.
                        Also warten ob es ein update gibt.
                        • S swagner
                          tombox
                          #790
                          @swagner Bitte details welche firmware welches gerät und exakte Wortlaut des tickets
                            swagner
                            #791
                            @tombox "C310 fw 1.9.1 (from 1.5.1) breaks ioBroker Tapo adapter connection" Ich habe auch diverse Einträge bei HA darüber gefunden. Ich weiß nicht, ob es erlaubt ist, aber ich hänge mal den interessantesten Forumeintrag an : https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/1183
                            • bautruppB Offline
                              bautruppB Offline
                              bautrupp
                              #792
                              @tombox
                              Wie schon weiter oben erwähnt: Das gleiche gilt leider auch für die C210 V2 Firmwareversion 1.5.2
                              Eine C210 V1, die noch Firmwareversion 1.5.1 hat, funktioniert mit deinem Adapter dagegen einwandfrei.
                                @tombox
                                tombox
                                #793
                                @bautrupp teste mal die GitHub version
                                  daniello
                                  #794
                                  @tombox Danke .. erstes Mal, das sich bei mir was tut .. sende mir via Bewegung einen Clip per Telegram. Tapo C200
                                  • bautruppB Offline
                                    bautruppB Offline
                                    bautrupp
                                    #795
                                    @tombox
                                    Daaaaanke, Geht einwandfrei!
                                    Getestet habe ich tapo.0.xxx.remote.setLensMaskConfig (Privatsphärenmodus).
                                    Lässt sich wieder einwandfrei in Objekte schalten. Ändert auch den Status wenn ich in der App umschalte.
                                      swagner
                                      #796
                                      @tombox , C310 Firmware 1.9.1 funktioniert jetzt ohne Problem
                                      IObroker log:
                                      80215D7DE5ABF9963D9040D28DD4AE79219Cxxxx Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.1 Build 251222 Rel.34614n","serialNumber":7461xxxx,"hardwareId":2}
                                      Danke dir für deine Zeit und Arbeit.
                                      • S swagner
                                        IObroker log:
                                        tombox
                                        #797
                                        @swagner Das ist alles KI Arbeit
                                        sie hat jetzt auch zusätzliche remotes hinzugefügt. bitte auch nochmal via GitHub installieren und testen
                                          daniello
                                          #798
                                          ich suche nach einem Objekt für die Personenerkennung. Das beste was ich finde wäre "notifications" auszuwählen, da diese nur bei Personenerkennung gesendet werden .. gibt es was Konkreteres?
                                          T S 2 Antworten Letzte Antwort
