  4. Iobroker backitup error.. Wo liegt das problem
    6.4k
283 Beiträge 14 Kommentatoren 39.4k Aufrufe 8 Beobachtet
  • S SpeedyBlade
    @Homoran ok...schade...dann bleibt mir wohl nur der harte Weg
    kann aber dann direkt die beiden Backups von "iobroker" und "nodered" einspielen?
    oder sind noch mehr anpassungen zu tätigen?
    #261
    @SpeedyBlade sagte in Iobroker backitup error.. Wo liegt das problem:
    Wenn es keinen größeren Versionssprung gibt dann funktioniert das.
    Zeig mal die Ausgabe von
    iob diag
    im jetzigen Stand.
    • S SpeedyBlade
      ihr seid meine Helden ....vielen vielen Dank
      20:38:29.959INFOguiBackup gestartet ...
      20:38:30.152DEBUGmountmount activ... umount is started before mount!!
      20:38:30.195DEBUGmountumount successfully completed
      20:38:40.147DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=ioBroker,password=****,noserverino,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.1.1/fritz.nas/iobbackup /opt/iobroker/backups"
      20:38:40.238DEBUGmountmount successfully completed
      20:38:40.240DEBUGmountdone
      20:38:44.550DEBUGiobrokerhost.RaspberryPi4 2340 objects saved
      20:38:44.876DEBUGiobrokerhost.RaspberryPi4 1700 states saved
      20:38:44.879DEBUGiobrokerhost.RaspberryPi4 Validating backup ...
      20:38:44.893DEBUGiobrokerhost.RaspberryPi4 "config.json" is valid
      host.RaspberryPi4 "objects.jsonl" exists
      20:38:44.906DEBUGiobrokerhost.RaspberryPi4 "states.jsonl" exists
      20:38:45.304DEBUGiobrokerhost.RaspberryPi4 JSONL lines are valid
      20:38:45.317DEBUGiobrokerhost.RaspberryPi4 The backup is valid!
      20:38:46.171DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2026_03_15-20_38_40_backupiobroker.tar.gz
      20:38:46.221DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
      20:38:47.214DEBUGiobrokerdone
      20:38:49.332DEBUGnoderedTry deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
      20:38:49.399DEBUGnoderednode-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
      20:38:49.404DEBUGnoderedCreated new nodered tmp directory
      20:38:49.775DEBUGnoderedNode-Red tmp copy finish
      20:38:49.953DEBUGnoderedBackup created: /opt/iobroker/backups/nodered.0_2026_03_15-20_38_49_backupiobroker.tar.gz
      20:38:49.956DEBUGnoderedTry deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
      20:38:50.020DEBUGnoderednode-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
      20:38:50.022DEBUGnoderedfound node-red database: node-red.0
      20:38:50.063DEBUGnodereddone
      20:38:50.621DEBUGcifsused copy path: /fritz.nas/iobbackup
      20:38:50.626DEBUGcifsdone
      20:38:51.243WARNcleanNo older backup files are deleted, because this backup was started manually
      20:38:51.246DEBUGcleandone
      20:38:51.451DEBUGhistoryHTMLnew history html values created
      20:38:51.462DEBUGhistoryHTMLdone
      20:38:51.630DEBUGhistoryJSONnew history json values created
      20:38:51.674DEBUGhistoryJSONdone
      20:38:51.794DEBUGumountmount active, umount is started ...
      20:38:56.922DEBUGumountumount successfully completed
      20:38:56.925DEBUGumountdone
      20:38:59.279DEBUGnotificationdone
      20:38:59.440INFOguiDas Backup wurde erfolgreich erstellt!
      #262
      das wichtigste steht immer im log
      daher immer alles dort lesen
        SpeedyBlade
        #263
        @Homoran
        2026-03-15 20:36:33.181  - info: backitup.0 (3330) terminating
        2026-03-15 20:36:33.255  - info: host.RaspberryPi4 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2026-03-15 20:36:36.872  - info: host.RaspberryPi4 instance system.adapter.backitup.0 in version "3.3.14" started with pid 3417
        2026-03-15 20:36:39.742  - info: backitup.0 (3417) starting. Version 3.3.14 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.19.1, js-controller: 7.0.7
        2026-03-15 20:36:39.841  - info: backitup.0 (3417) [iobroker] backup will be activated at 03:00 every 5 day(s)
        2026-03-15 20:36:40.900  - error: backitup.0 (3417) Error: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,noserverino,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.1.1/ fritz.nas/iobbackup /opt/iobroker/backups
        mount: bad usage
        Try 'mount --help' for more information.
        2026-03-15 20:37:29.940  - error: backitup.0 (3417) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,noserverino,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.1.1/ fritz.nas/iobbackup /opt/iobroker/backups
        2026-03-15 20:37:29.942  - error: backitup.0 (3417) [iobroker/mount] mount: bad usage
        2026-03-15 20:37:29.943  - error: backitup.0 (3417) [iobroker/mount] Try 'mount --help' for more information.
        2026-03-15 20:37:40.474  - error: backitup.0 (3417) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
        2026-03-15 20:38:20.738  - info: host.RaspberryPi4 stopInstance system.adapter.backitup.0 (force=false, process=true)
        2026-03-15 20:38:20.748  - info: backitup.0 (3417) Got terminate signal TERMINATE_YOURSELF
        2026-03-15 20:38:20.749  - info: backitup.0 (3417) cleaned everything up...
        2026-03-15 20:38:20.751  - info: backitup.0 (3417) terminating
        2026-03-15 20:38:20.752  - info: backitup.0 (3417) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2026-03-15 20:38:20.825  - info: host.RaspberryPi4 stopInstance system.adapter.backitup.0 send kill signal
        2026-03-15 20:38:21.255  - info: backitup.0 (3417) terminating
        2026-03-15 20:38:21.327  - info: host.RaspberryPi4 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2026-03-15 20:38:24.882  - info: host.RaspberryPi4 instance system.adapter.backitup.0 in version "3.3.14" started with pid 3553
        2026-03-15 20:38:27.781  - info: backitup.0 (3553) starting. Version 3.3.14 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.19.1, js-controller: 7.0.7
        2026-03-15 20:38:27.869  - info: backitup.0 (3553) [iobroker] backup will be activated at 03:00 every 5 day(s)
        2026-03-15 20:38:51.408  - warn: backitup.0 (3553) [iobroker/clean] No older backup files are deleted, because this backup was started manually
        • S SpeedyBlade
          @Homoran
          mount: bad usage
          #264
          @SpeedyBlade
          Alles.
            @SpeedyBlade
            Alles.
            SpeedyBlade
            #265
            @Thomas-Braun
            bash
            Script v.2026-01-31
            *** BASE SYSTEM ***
            Operating System: Raspbian GNU/Linux 11 (bullseye)
               Static hostname: RaspberryPi4
                     Icon name: computer
                        Kernel: Linux 6.1.54-v8+
                  Architecture: arm64
            OS is similar to: debian
            Model           : Raspberry Pi 4 Model B Rev 1.4
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 32 bit
            Outdated 32Bit architecture detected. Only a pure 64Bit-System will be supported in the future. You will have to reinstall your operating system with full 64Bit support or upgrade to more modern hardware soon.
            Systemuptime and Load:
             20:56:05 up 48 min,  1 user,  load average: 0.41, 0.27, 0.30
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** TIME AND TIMEZONES ***
                           Local time: Sun 2026-03-15 20:56:05 CET
                       Universal time: Sun 2026-03-15 19:56:05 UTC
                             RTC time: n/a
                            Time zone: Europe/Vienna (CET, +0100)
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            pi
            HOME=/home/pi
            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            *** DISPLAY-SERVER SETUP ***
            Display-Server:         false
            Unit display-manager.service could not be found.
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Mem:            7.8G        557M        6.6G        0.0K        573M        7.1G
            Swap:            99M          0B         99M
            Total:          7.9G        557M        6.7G
            Active iob-Instances:   9
                     7760 M total memory
                      557 M used memory
                      703 M active memory
                      306 M inactive memory
                     6629 M free memory
                       58 M buffer memory
                      514 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            top - 20:56:06 up 48 min,  1 user,  load average: 0.41, 0.27, 0.30
            Tasks: 147 total,   1 running, 146 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  1.5 us,  1.5 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   7760.8 total,   6629.6 free,    557.5 used,    573.8 buff/cache
            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   7081.6 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            /dev/root      ext4      916G  6.7G  863G   1% /
            devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
            tmpfs          tmpfs     3.8G     0  3.8G   0% /dev/shm
            tmpfs          tmpfs     1.6G  724K  1.6G   1% /run
            /dev/sda1      vfat      253M   52M  201M  21% /boot
            tmpfs          tmpfs     777M     0  777M   0% /run/user/1000
            [Sun Mar 15 20:07:32 2026] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
            [Sun Mar 15 20:07:32 2026] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
            [Sun Mar 15 20:07:36 2026] EXT4-fs (sda2): re-mounted. Quota mode: none.
            Show mounted filesystems:
            TARGET  SOURCE    FSTYPE OPTIONS
            /       /dev/sda2 ext4   rw,noatime,stripe=8191
            `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
            /var:
            2.0G    /var/
            1.3G    /var/log
            1.2G    /var/log/journal/3b31b8f74a5a4e889cadcd832f7f9b9a
            586M    /var/cache
            Archived and active journals take up 1.1G in the file system.
            /opt/iobroker/backups:
            36M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            204M    /opt/iobroker/iobroker-data/
            80M     /opt/iobroker/iobroker-data/backup-objects
            78M     /opt/iobroker/iobroker-data/files
            47M     /opt/iobroker/iobroker-data/files/admin.admin
            46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
            9.4M    /opt/iobroker/iobroker-data/objects.jsonl
            8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
            5.1M    /opt/iobroker/iobroker-data/objects.json.migrated
            5.1M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
            3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-NCiLc44Q.js
            USB-Devices by-id:
            USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
            please always prefer the links 'by-id':
            No Devices found 'by-id'
            No nvbackup.json found.
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.19.1
            /usr/bin/node           v20.19.1
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            ✓ Node.js installation is correct
            nodejs:
              Installed: 20.19.1-1nodesource1
              Candidate: 20.19.1-1nodesource1
              Version table:
             *** 20.19.1-1nodesource1 600
                    500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                 20.19.0-1nodesource1 600
                 20.18.3-1nodesource1 600
                 20.18.2-1nodesource1 600
                 20.18.1-1nodesource1 600
                 20.18.0-1nodesource1 600
                 20.17.0-1nodesource1 600
                 20.16.0-1nodesource1 600
                 20.15.1-1nodesource1 600
                 20.15.0-1nodesource1 600
                 20.14.0-1nodesource1 600
                 20.13.1-1nodesource1 600
                 20.13.0-1nodesource1 600
                 20.12.2-1nodesource1 600
                 20.12.1-1nodesource1 600
                 20.12.0-1nodesource1 600
                 20.11.1-1nodesource1 600
                 20.11.0-1nodesource1 600
                 20.10.0-1nodesource1 600
                 20.9.0-1nodesource1 600
                 20.8.1-1nodesource1 600
                 20.8.0-1nodesource1 600
                 20.7.0-1nodesource1 600
                 20.6.1-1nodesource1 600
                 20.6.0-1nodesource1 600
                 20.5.1-1nodesource1 600
                 20.5.0-1nodesource1 600
                 20.4.0-1nodesource1 600
                 20.3.1-1nodesource1 600
                 20.3.0-1nodesource1 600
                 20.2.0-1nodesource1 600
                 20.1.0-1nodesource1 600
                 20.0.0-1nodesource1 600
                 12.22.12~dfsg-1~deb11u7 500
            No problems detected
            Errors in npm tree: 0
            The current Node.js version (v20.19.1) is vulnerable to the following CVEs:
            CVE-2025-23166(high):  The C++ method SignTraits::DeriveBits() may incorrectly call ThrowException() based on user-supplied inputs when executing in a background thread, crashing the Node.js process. Such cryptographic operations are commonly applied to untrusted inputs. Thus, this mechanism potentially allows an adversary to remotely crash a Node.js runtime.
            Patched versions: ^20.19.2 || ^22.15.1 || ^23.11.1 || ^24.0.2
            CVE-2025-23167(medium): A flaw in Node.js 20's HTTP parser allows improper termination of HTTP/1 headers using `\r\n\rX` instead of the required `\r\n\r\n`.
            This inconsistency enables request smuggling, allowing attackers to bypass proxy-based access controls and submit unauthorized requests.
            The issue was resolved by upgrading `llhttp` to version 9, which enforces correct header termination.
            Impact:
            * This vulnerability affects only Node.js 20.x users prior to the `llhttp` v9 upgrade.
            CVE-2025-55130(high): A flaw in Node.js’s Permissions model allows attackers to bypass `--allow-fs-read` and `--allow-fs-write` restrictions using crafted relative symlink paths. By chaining directories and symlinks, a script granted access only to the current directory can escape the allowed path and read sensitive files. This breaks the expected isolation guarantees and enables arbitrary file read/write, leading to potential system compromise.
            This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
            Patched versions: ^20.20.0 || ^22.22.0 || ^24.13.0 || ^25.3.0
            CVE-2025-55131(high): A flaw in Node.js's buffer allocation logic can expose uninitialized memory when allocations are interrupted, when using the `vm` module with the timeout option. Under specific timing conditions, buffers allocated with `Buffer.alloc` and other `TypedArray` instances like `Uint8Array` may contain leftover data from previous operations, allowing in-process secrets like tokens or passwords to leak or causing data corruption. While exploitation typically requires precise timing or in-process code execution, it can become remotely exploitable when untrusted input influences workload and timeouts, leading to potential confidentiality and integrity impact.
            CVE-2025-55132(low): A flaw in Node.js's permission model allows a file's access and modification timestamps to be changed via `futimes()` even when the process has only read permissions. Unlike `utimes()`, `futimes()` does not apply the expected write-permission checks, which means file metadata can be modified in read-only directories. This behavior could be used to alter timestamps in ways that obscure activity, reducing the reliability of logs. This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
            CVE-2025-59465(high): A malformed `HTTP/2 HEADERS` frame with oversized, invalid `HPACK` data can cause Node.js to crash by triggering an unhandled `TLSSocket` error `ECONNRESET`. Instead of safely closing the connection, the process crashes, enabling a remote denial of service. This primarily affects applications that do not attach explicit error handlers to secure sockets, for example:
            server.on('secureConnection', socket => {
              socket.on('error', err => {
                console.log(err)
            CVE-2025-59466(medium): We have identified a bug in Node.js error handling where "Maximum call stack size exceeded" errors become uncatchable when `async_hooks.createHook()` is enabled. Instead of reaching `process.on('uncaughtException')`, the process terminates, making the crash unrecoverable. Applications that rely on `AsyncLocalStorage` (v22, v20) or `async_hooks.createHook()` (v24, v22, v20) become vulnerable to denial-of-service crashes triggered by deep recursion under specific conditions.
            CVE-2026-21637(medium): A flaw in Node.js TLS error handling allows remote attackers to crash or exhaust resources of a TLS server when `pskCallback` or `ALPNCallback` are in use. Synchronous exceptions thrown during these callbacks bypass standard TLS error handling paths (tlsClientError and error), causing either immediate process termination or silent file descriptor leaks that eventually lead to denial of service. Because these callbacks process attacker-controlled input during the TLS handshake, a remote client can repeatedly trigger the issue. This vulnerability affects TLS servers using PSK or ALPN callbacks across Node.js versions where these callbacks throw without being safely wrapped.
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            RaspberryPi4        RaspberryPi4 (version: 7.0.7, hostname: RaspberryPi4  , alive, uptime: 2915)
            Core adapters versions
            admin:          7.7.22
            javascript:     "javascript" not found
            nodejs modules from github:     0
            Adapter State
            + system.adapter.admin.0                  : admin                 : RaspberryPi4                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.backitup.0               : backitup              : RaspberryPi4                             -  enabled
              system.adapter.ble.0                    : ble                   : RaspberryPi4                             - disabled
            + system.adapter.discovery.0              : discovery             : RaspberryPi4                             -  enabled
            + system.adapter.hue.0                    : hue                   : RaspberryPi4                             -  enabled, port: 443
              system.adapter.info.0                   : info                  : RaspberryPi4                             -  enabled
            + system.adapter.knx.0                    : knx                   : RaspberryPi4                             -  enabled, bind: 192.168.1.6
              system.adapter.mielecloudservice.0      : mielecloudservice     : RaspberryPi4                             -  enabled
              system.adapter.mqtt.0                   : mqtt                  : RaspberryPi4                             - disabled, port: 1883, bind: 0.0.0.0
            + system.adapter.node-red.0               : node-red              : RaspberryPi4                             -  enabled, port: 1880, bind: 0.0.0.0
            + system.adapter.rpi2.0                   : rpi2                  : RaspberryPi4                             -  enabled
            + system.adapter.shelly.0                 : shelly                : RaspberryPi4                             -  enabled, port: 1882, bind: 192.168.1.6
              system.adapter.unifi.0                  : unifi                 : RaspberryPi4                             - disabled
            + instance is alive
            ioBroker-Repositories
            │ (index) │ name               │ url                                                     │ auto upgrade │
            │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
            │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
            Upgrade policy: none
            Installed ioBroker-Adapters
            Adapter    "admin"        : 7.7.22   , installed 7.7.22
            Adapter    "backitup"     : 3.3.14   , installed 3.3.14
            Adapter    "ble"          : 0.14.0   , installed 0.14.0
            Adapter    "hue"          : 3.16.2   , installed 3.16.2
            Controller "js-controller": 7.0.7    , installed 7.0.7
            Adapter    "knx"          : 2.0.30   , installed 2.0.30
            Adapter    "mielecloudservice": 6.5.10, installed 6.5.10
            Adapter    "node-red"     : 5.2.1    , installed 5.2.1
            Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
            Adapter    "shelly"       : 10.5.2   , installed 10.5.2
            Adapter    "unifi"        : 0.7.0    , installed 0.7.0
            Objects and States
            Objects:        2338
            States:         1700
            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists...
            Pending systemupdates: 0
            *** Listening Ports ***
            tcp        0      0 192.168.1.6:1882        0.0.0.0:*               LISTEN      1001       13059      899/io.shelly.0
            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       17409      736/node-red
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12752      452/iobroker.js-con
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13739      452/iobroker.js-con
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12708      500/sshd: /usr/sbin
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12836      559/io.admin.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          12710      500/sshd: /usr/sbin
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12152      369/avahi-daemon: r
            udp        0      0 192.168.1.6:52153       0.0.0.0:*                           1001       17545      736/node-red
            udp        0      0 192.168.1.6:44985       0.0.0.0:*                           1001       17446      832/io.knx.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13735      652/dhcpcd
            udp        0      0 0.0.0.0:49676           0.0.0.0:*                           108        12154      369/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        12153      369/avahi-daemon: r
            udp6       0      0 :::36371                :::*                                108        12155      369/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          15246      652/dhcpcd
            mount: bad usage
            • S SpeedyBlade
              @Thomas-Braun
              bash
              Script v.2026-01-31
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : 32 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                       7760 M total memory
                        557 M used memory
                        703 M active memory
                       6629 M free memory
                         58 M buffer memory
                        514 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              *** FILESYSTEM ***
              /var:
              2.0G    /var/
              1.3G    /var/log
              586M    /var/cache
              USB-Devices by-id:
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
              Impact:
                  console.log(err)
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.7.22
              Adapter State
              + instance is alive
              Objects and States
              Objects:        2338
              States:         1700
              mount: bad usage
              #266
              also unbedingt trixie lite 64Bit installieren
              • S SpeedyBlade
                @Thomas-Braun
                bash
                Script v.2026-01-31
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : 32 bit
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                iobroker
                HOME=/home/iobroker
                Display-Manager:
                Desktop:
                Session:                tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                         7760 M total memory
                          557 M used memory
                          703 M active memory
                         6629 M free memory
                           58 M buffer memory
                          514 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                *** FILESYSTEM ***
                /var:
                2.0G    /var/
                1.3G    /var/log
                586M    /var/cache
                USB-Devices by-id:
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                Impact:
                    console.log(err)
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          7.7.22
                Adapter State
                + instance is alive
                Objects and States
                Objects:        2338
                States:         1700
                mount: bad usage
                #267
                Userland : 32 bit
                Damit bist du ohnehin für inline-Upgrades disqualifiziert. Kannst du nur neuinstallieren.
                Dann gleich einen anderen user als 'pi' verwenden.
                Das würde dann auch
                gleich mit erledigen.
                  Userland : 32 bit
                  Das würde dann auch
                  SpeedyBlade
                  #268
                  @Thomas-Braun
                  https://downloads.raspberrypi.com/raspios_lite_arm64/images/raspios_lite_arm64-2025-12-04/2025-12-04-raspios-trixie-arm64-lite.img.xz
                  das ist dann mit der neuen Version erledigt oder muss ich da was speziell tun?
                  • S SpeedyBlade
                    @Thomas-Braun
                    #269
                    @SpeedyBlade
                    Mach doch nicht schon wieder was 'neben der Spur'...
                    So geht das am unfallfreisten:
                    https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                      @SpeedyBlade
                      SpeedyBlade
                      schrieb am zuletzt editiert von SpeedyBlade
                      #270
                      @Thomas-Braun das hab ich eh auch drauf
                      wo ist der Unterschied zw. 64-bit und Legacy, 64-bit?
                      macht es nicht sinn dann direkt auf forky oder duke zu warten / gehen?
                      Und kann ich dieses image nur auf einen pi spielen oder jeden anderen mini-server auch?
                      wäre dann das hier
                      HomoranH Thomas BraunT 4 Antworten Letzte Antwort
                      • S SpeedyBlade
                        wäre dann das hier
                        #271
                        das willst du nicht!
                        Die Paketquellen für bookworm werden nicht mehr gepflegt.
                        • S SpeedyBlade
                          wäre dann das hier
                          #272
                          @SpeedyBlade
                          Nein, du kannst nicht auf ein Release weit in der Zukunft warten, dein System ist JETZT vergammelt und muss JETZT auf einen noch unterhaltenen Stand gehievt werden.
                          Die 64Bit-Lite ist richtig für deinen Raspberry4
                          • S SpeedyBlade
                            wäre dann das hier
                            #273
                            Bei RaspberryOS gibt es hardwarespezifische Anpassungen, das kannst du nicht für anderes verwenden.
                            • S SpeedyBlade
                              wäre dann das hier
                              #274
                              Legacy ist das sog. 'oldstable'-Release, also der Vorgänger zum jeweilig aktuellen Release.
                              Im Moment ist das 'bookworm' (Debian 12).
                                SpeedyBlade
                                #275
                                @Thomas-Braun sagte in Iobroker backitup error.. Wo liegt das problem:
                                alle klar...danke
                                  SpeedyBlade
                                  #276
                                  @Thomas-Braun verstanden...danke
                                  • S SpeedyBlade
                                    alle klar...danke
                                    #277
                                    @SpeedyBlade
                                    Du könntest aber auf dem jetzigen System schon mal (versuchen) nodejs@22 zu fahren.
                                    Dann ist der Versionssprung auf dem neuen System kleiner.
                                    Geht per
                                    iob nodejs-update
                                      SpeedyBlade
                                      #278
                                      @Homoran aber das heißt ja dann...ca. alle 2 Jahre neues BS aufspielen?! 😒
                                        @SpeedyBlade
                                        Geht per
                                        iob nodejs-update
                                        #279
                                        Geht per
                                        auch bei 32bittigem bullseye?
                                        • S SpeedyBlade
                                          #280
                                          Die Standardaussage von RaspberryOS ist ohnehin:
                                          Only new installations are supported.
                                          Das heißt aber nicht, das es u. U. nicht doch geht.
                                          Bei deinem 32bit-Bookworm Bullsyeye geht es aber in der Tat nicht.
                                          Müsste man mal schauen, wo man da auskommt. Soweit ich weiß gibt es aber zumindest ein älteres nodejs22 noch für 32bit.
