  4. Iobroker backitup error.. Wo liegt das problem
    6.4k
283 Beiträge 14 Kommentatoren 39.4k Aufrufe 8 Beobachtet
  • S SpeedyBlade
    ihr seid meine Helden ....vielen vielen Dank
    20:38:29.959INFOguiBackup gestartet ...
    20:38:30.152DEBUGmountmount activ... umount is started before mount!!
    20:38:30.195DEBUGmountumount successfully completed
    20:38:40.147DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=ioBroker,password=****,noserverino,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.1.1/fritz.nas/iobbackup /opt/iobroker/backups"
    20:38:40.238DEBUGmountmount successfully completed
    20:38:40.240DEBUGmountdone
    20:38:44.550DEBUGiobrokerhost.RaspberryPi4 2340 objects saved
    20:38:44.876DEBUGiobrokerhost.RaspberryPi4 1700 states saved
    20:38:44.879DEBUGiobrokerhost.RaspberryPi4 Validating backup ...
    20:38:44.893DEBUGiobrokerhost.RaspberryPi4 "config.json" is valid
    host.RaspberryPi4 "objects.jsonl" exists
    20:38:44.906DEBUGiobrokerhost.RaspberryPi4 "states.jsonl" exists
    20:38:45.304DEBUGiobrokerhost.RaspberryPi4 JSONL lines are valid
    20:38:45.317DEBUGiobrokerhost.RaspberryPi4 The backup is valid!
    20:38:46.171DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2026_03_15-20_38_40_backupiobroker.tar.gz
    20:38:46.221DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
    20:38:47.214DEBUGiobrokerdone
    20:38:49.332DEBUGnoderedTry deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
    20:38:49.399DEBUGnoderednode-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
    20:38:49.404DEBUGnoderedCreated new nodered tmp directory
    20:38:49.775DEBUGnoderedNode-Red tmp copy finish
    20:38:49.953DEBUGnoderedBackup created: /opt/iobroker/backups/nodered.0_2026_03_15-20_38_49_backupiobroker.tar.gz
    20:38:49.956DEBUGnoderedTry deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
    20:38:50.020DEBUGnoderednode-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
    20:38:50.022DEBUGnoderedfound node-red database: node-red.0
    20:38:50.063DEBUGnodereddone
    20:38:50.621DEBUGcifsused copy path: /fritz.nas/iobbackup
    20:38:50.626DEBUGcifsdone
    20:38:51.243WARNcleanNo older backup files are deleted, because this backup was started manually
    20:38:51.246DEBUGcleandone
    20:38:51.451DEBUGhistoryHTMLnew history html values created
    20:38:51.462DEBUGhistoryHTMLdone
    20:38:51.630DEBUGhistoryJSONnew history json values created
    20:38:51.674DEBUGhistoryJSONdone
    20:38:51.794DEBUGumountmount active, umount is started ...
    20:38:56.922DEBUGumountumount successfully completed
    20:38:56.925DEBUGumountdone
    20:38:59.279DEBUGnotificationdone
    20:38:59.440INFOguiDas Backup wurde erfolgreich erstellt!
    #256
    @SpeedyBlade Da hätten wir nach 3 Posts sein können wenn du geantwortet hättest 😢
    Dann hast du ja jetzt dein externes Backup und kannst Trixie lite aufsetzen
      SpeedyBlade
      #257
      @Homoran war mir so nicht bewusst, dass dies jemand umgestellt hat, zudem es ja bei fritz.nas auch korrekt angezeigt wurde.
      Aber dafür hab ich wieder einiges dazu gelernt.
      Nun noch die Frage wegen dem Update auf neues Betriebssytsem.
      sudo sed -i 's/bookworm/trixie/g' /etc/apt/sources.list
      sudo sed -i 's/bookworm/trixie/g' /etc/apt/sources.list.d/*.list
      sudo apt update
      sudo apt upgrade -y
      sudo apt full-upgrade -y
      sudo apt autoremove -y
      sudo apt autoclean
      sudo reboot
      cat /etc/debian_version
      • S SpeedyBlade
        sudo apt update
        sudo apt upgrade -y
        sudo apt autoclean
        sudo reboot
        #258
        @SpeedyBlade sagte in Iobroker backitup error.. Wo liegt das problem:
        NEIN. Du springst nicht über ein Release drüber.
        • S SpeedyBlade
          sudo apt update
          sudo apt upgrade -y
          sudo apt autoclean
          sudo reboot
          #259
          es gibt kein Update für RaspBerry OS.
          und schon gar nicht über 2 Releases
          Das ist massiv verändert worden.
          Da musst du neu installieren
            SpeedyBlade
            #260
            @Homoran ok...schade...dann bleibt mir wohl nur der harte Weg
            kann aber dann direkt die beiden Backups von "iobroker" und "nodered" einspielen?
            oder sind noch mehr anpassungen zu tätigen?
            • S SpeedyBlade
              #261
              Wenn es keinen größeren Versionssprung gibt dann funktioniert das.
              Zeig mal die Ausgabe von
              iob diag
              im jetzigen Stand.
              • S SpeedyBlade
                #262
                das wichtigste steht immer im log
                daher immer alles dort lesen
                  SpeedyBlade
                  #263
                  @Homoran
                  2026-03-15 20:36:33.181  - info: backitup.0 (3330) terminating
                  2026-03-15 20:36:33.255  - info: host.RaspberryPi4 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2026-03-15 20:36:36.872  - info: host.RaspberryPi4 instance system.adapter.backitup.0 in version "3.3.14" started with pid 3417
                  2026-03-15 20:36:39.742  - info: backitup.0 (3417) starting. Version 3.3.14 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.19.1, js-controller: 7.0.7
                  2026-03-15 20:36:39.841  - info: backitup.0 (3417) [iobroker] backup will be activated at 03:00 every 5 day(s)
                  2026-03-15 20:36:40.900  - error: backitup.0 (3417) Error: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,noserverino,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.1.1/ fritz.nas/iobbackup /opt/iobroker/backups
                  mount: bad usage
                  Try 'mount --help' for more information.
                  2026-03-15 20:37:29.940  - error: backitup.0 (3417) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,noserverino,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.1.1/ fritz.nas/iobbackup /opt/iobroker/backups
                  2026-03-15 20:37:29.942  - error: backitup.0 (3417) [iobroker/mount] mount: bad usage
                  2026-03-15 20:37:29.943  - error: backitup.0 (3417) [iobroker/mount] Try 'mount --help' for more information.
                  2026-03-15 20:37:40.474  - error: backitup.0 (3417) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                  2026-03-15 20:38:20.738  - info: host.RaspberryPi4 stopInstance system.adapter.backitup.0 (force=false, process=true)
                  2026-03-15 20:38:20.748  - info: backitup.0 (3417) Got terminate signal TERMINATE_YOURSELF
                  2026-03-15 20:38:20.749  - info: backitup.0 (3417) cleaned everything up...
                  2026-03-15 20:38:20.751  - info: backitup.0 (3417) terminating
                  2026-03-15 20:38:20.752  - info: backitup.0 (3417) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2026-03-15 20:38:20.825  - info: host.RaspberryPi4 stopInstance system.adapter.backitup.0 send kill signal
                  2026-03-15 20:38:21.255  - info: backitup.0 (3417) terminating
                  2026-03-15 20:38:21.327  - info: host.RaspberryPi4 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2026-03-15 20:38:24.882  - info: host.RaspberryPi4 instance system.adapter.backitup.0 in version "3.3.14" started with pid 3553
                  2026-03-15 20:38:27.781  - info: backitup.0 (3553) starting. Version 3.3.14 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.19.1, js-controller: 7.0.7
                  2026-03-15 20:38:27.869  - info: backitup.0 (3553) [iobroker] backup will be activated at 03:00 every 5 day(s)
                  2026-03-15 20:38:51.408  - warn: backitup.0 (3553) [iobroker/clean] No older backup files are deleted, because this backup was started manually
                  • S SpeedyBlade
                    @Homoran
                    mount: bad usage
                    #264
                    @SpeedyBlade
                    Alles.
                      @SpeedyBlade
                      Alles.
                      SpeedyBlade
                      #265
                      @Thomas-Braun
                      bash
                      Script v.2026-01-31
                      *** BASE SYSTEM ***
                      Operating System: Raspbian GNU/Linux 11 (bullseye)
                         Static hostname: RaspberryPi4
                               Icon name: computer
                                  Kernel: Linux 6.1.54-v8+
                            Architecture: arm64
                      OS is similar to: debian
                      Model           : Raspberry Pi 4 Model B Rev 1.4
                      Docker          : false
                      Virtualization  : none
                      Kernel          : aarch64
                      Userland        : 32 bit
                      Outdated 32Bit architecture detected. Only a pure 64Bit-System will be supported in the future. You will have to reinstall your operating system with full 64Bit support or upgrade to more modern hardware soon.
                      Systemuptime and Load:
                       20:56:05 up 48 min,  1 user,  load average: 0.41, 0.27, 0.30
                      CPU threads: 4
                      *** LIFE CYCLE STATUS ***
                      Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
                      *** RASPBERRY THROTTLING ***
                      Current issues:
                      Previously detected issues:
                      *** TIME AND TIMEZONES ***
                                     Local time: Sun 2026-03-15 20:56:05 CET
                                 Universal time: Sun 2026-03-15 19:56:05 UTC
                                       RTC time: n/a
                                      Time zone: Europe/Vienna (CET, +0100)
                                    NTP service: active
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      pi
                      HOME=/home/pi
                      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                      iobroker
                      HOME=/home/iobroker
                      *** DISPLAY-SERVER SETUP ***
                      Display-Server:         false
                      Unit display-manager.service could not be found.
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Mem:            7.8G        557M        6.6G        0.0K        573M        7.1G
                      Swap:            99M          0B         99M
                      Total:          7.9G        557M        6.7G
                      Active iob-Instances:   9
                               7760 M total memory
                                557 M used memory
                                703 M active memory
                                306 M inactive memory
                               6629 M free memory
                                 58 M buffer memory
                                514 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      top - 20:56:06 up 48 min,  1 user,  load average: 0.41, 0.27, 0.30
                      Tasks: 147 total,   1 running, 146 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  1.5 us,  1.5 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   7760.8 total,   6629.6 free,    557.5 used,    573.8 buff/cache
                      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   7081.6 avail Mem
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** DMESG CRITICAL ERRORS ***
                      No critical errors detected
                      *** FILESYSTEM ***
                      /dev/root      ext4      916G  6.7G  863G   1% /
                      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                      tmpfs          tmpfs     3.8G     0  3.8G   0% /dev/shm
                      tmpfs          tmpfs     1.6G  724K  1.6G   1% /run
                      /dev/sda1      vfat      253M   52M  201M  21% /boot
                      tmpfs          tmpfs     777M     0  777M   0% /run/user/1000
                      [Sun Mar 15 20:07:32 2026] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Sun Mar 15 20:07:32 2026] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                      [Sun Mar 15 20:07:36 2026] EXT4-fs (sda2): re-mounted. Quota mode: none.
                      Show mounted filesystems:
                      TARGET  SOURCE    FSTYPE OPTIONS
                      /       /dev/sda2 ext4   rw,noatime,stripe=8191
                      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                      /var:
                      2.0G    /var/
                      1.3G    /var/log
                      1.2G    /var/log/journal/3b31b8f74a5a4e889cadcd832f7f9b9a
                      586M    /var/cache
                      Archived and active journals take up 1.1G in the file system.
                      /opt/iobroker/backups:
                      36M     /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      204M    /opt/iobroker/iobroker-data/
                      80M     /opt/iobroker/iobroker-data/backup-objects
                      78M     /opt/iobroker/iobroker-data/files
                      47M     /opt/iobroker/iobroker-data/files/admin.admin
                      46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                      9.4M    /opt/iobroker/iobroker-data/objects.jsonl
                      8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
                      5.1M    /opt/iobroker/iobroker-data/objects.json.migrated
                      5.1M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                      3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-NCiLc44Q.js
                      USB-Devices by-id:
                      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                      please always prefer the links 'by-id':
                      No Devices found 'by-id'
                      No nvbackup.json found.
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v20.19.1
                      /usr/bin/node           v20.19.1
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      ✓ Node.js installation is correct
                      nodejs:
                        Installed: 20.19.1-1nodesource1
                        Candidate: 20.19.1-1nodesource1
                        Version table:
                       *** 20.19.1-1nodesource1 600
                              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                           20.19.0-1nodesource1 600
                           20.18.3-1nodesource1 600
                           20.18.2-1nodesource1 600
                           20.18.1-1nodesource1 600
                           20.18.0-1nodesource1 600
                           20.17.0-1nodesource1 600
                           20.16.0-1nodesource1 600
                           20.15.1-1nodesource1 600
                           20.15.0-1nodesource1 600
                           20.14.0-1nodesource1 600
                           20.13.1-1nodesource1 600
                           20.13.0-1nodesource1 600
                           20.12.2-1nodesource1 600
                           20.12.1-1nodesource1 600
                           20.12.0-1nodesource1 600
                           20.11.1-1nodesource1 600
                           20.11.0-1nodesource1 600
                           20.10.0-1nodesource1 600
                           20.9.0-1nodesource1 600
                           20.8.1-1nodesource1 600
                           20.8.0-1nodesource1 600
                           20.7.0-1nodesource1 600
                           20.6.1-1nodesource1 600
                           20.6.0-1nodesource1 600
                           20.5.1-1nodesource1 600
                           20.5.0-1nodesource1 600
                           20.4.0-1nodesource1 600
                           20.3.1-1nodesource1 600
                           20.3.0-1nodesource1 600
                           20.2.0-1nodesource1 600
                           20.1.0-1nodesource1 600
                           20.0.0-1nodesource1 600
                           12.22.12~dfsg-1~deb11u7 500
                      No problems detected
                      Errors in npm tree: 0
                      The current Node.js version (v20.19.1) is vulnerable to the following CVEs:
                      CVE-2025-23166(high):  The C++ method SignTraits::DeriveBits() may incorrectly call ThrowException() based on user-supplied inputs when executing in a background thread, crashing the Node.js process. Such cryptographic operations are commonly applied to untrusted inputs. Thus, this mechanism potentially allows an adversary to remotely crash a Node.js runtime.
                      Patched versions: ^20.19.2 || ^22.15.1 || ^23.11.1 || ^24.0.2
                      CVE-2025-23167(medium): A flaw in Node.js 20's HTTP parser allows improper termination of HTTP/1 headers using `\r\n\rX` instead of the required `\r\n\r\n`.
                      This inconsistency enables request smuggling, allowing attackers to bypass proxy-based access controls and submit unauthorized requests.
                      The issue was resolved by upgrading `llhttp` to version 9, which enforces correct header termination.
                      Impact:
                      * This vulnerability affects only Node.js 20.x users prior to the `llhttp` v9 upgrade.
                      CVE-2025-55130(high): A flaw in Node.js’s Permissions model allows attackers to bypass `--allow-fs-read` and `--allow-fs-write` restrictions using crafted relative symlink paths. By chaining directories and symlinks, a script granted access only to the current directory can escape the allowed path and read sensitive files. This breaks the expected isolation guarantees and enables arbitrary file read/write, leading to potential system compromise.
                      This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
                      Patched versions: ^20.20.0 || ^22.22.0 || ^24.13.0 || ^25.3.0
                      CVE-2025-55131(high): A flaw in Node.js's buffer allocation logic can expose uninitialized memory when allocations are interrupted, when using the `vm` module with the timeout option. Under specific timing conditions, buffers allocated with `Buffer.alloc` and other `TypedArray` instances like `Uint8Array` may contain leftover data from previous operations, allowing in-process secrets like tokens or passwords to leak or causing data corruption. While exploitation typically requires precise timing or in-process code execution, it can become remotely exploitable when untrusted input influences workload and timeouts, leading to potential confidentiality and integrity impact.
                      CVE-2025-55132(low): A flaw in Node.js's permission model allows a file's access and modification timestamps to be changed via `futimes()` even when the process has only read permissions. Unlike `utimes()`, `futimes()` does not apply the expected write-permission checks, which means file metadata can be modified in read-only directories. This behavior could be used to alter timestamps in ways that obscure activity, reducing the reliability of logs. This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
                      CVE-2025-59465(high): A malformed `HTTP/2 HEADERS` frame with oversized, invalid `HPACK` data can cause Node.js to crash by triggering an unhandled `TLSSocket` error `ECONNRESET`. Instead of safely closing the connection, the process crashes, enabling a remote denial of service. This primarily affects applications that do not attach explicit error handlers to secure sockets, for example:
                      server.on('secureConnection', socket => {
                        socket.on('error', err => {
                          console.log(err)
                      CVE-2025-59466(medium): We have identified a bug in Node.js error handling where "Maximum call stack size exceeded" errors become uncatchable when `async_hooks.createHook()` is enabled. Instead of reaching `process.on('uncaughtException')`, the process terminates, making the crash unrecoverable. Applications that rely on `AsyncLocalStorage` (v22, v20) or `async_hooks.createHook()` (v24, v22, v20) become vulnerable to denial-of-service crashes triggered by deep recursion under specific conditions.
                      CVE-2026-21637(medium): A flaw in Node.js TLS error handling allows remote attackers to crash or exhaust resources of a TLS server when `pskCallback` or `ALPNCallback` are in use. Synchronous exceptions thrown during these callbacks bypass standard TLS error handling paths (tlsClientError and error), causing either immediate process termination or silent file descriptor leaks that eventually lead to denial of service. Because these callbacks process attacker-controlled input during the TLS handshake, a remote client can repeatedly trigger the issue. This vulnerability affects TLS servers using PSK or ALPN callbacks across Node.js versions where these callbacks throw without being safely wrapped.
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      RaspberryPi4        RaspberryPi4 (version: 7.0.7, hostname: RaspberryPi4  , alive, uptime: 2915)
                      Core adapters versions
                      admin:          7.7.22
                      javascript:     "javascript" not found
                      nodejs modules from github:     0
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : RaspberryPi4                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.backitup.0               : backitup              : RaspberryPi4                             -  enabled
                        system.adapter.ble.0                    : ble                   : RaspberryPi4                             - disabled
                      + system.adapter.discovery.0              : discovery             : RaspberryPi4                             -  enabled
                      + system.adapter.hue.0                    : hue                   : RaspberryPi4                             -  enabled, port: 443
                        system.adapter.info.0                   : info                  : RaspberryPi4                             -  enabled
                      + system.adapter.knx.0                    : knx                   : RaspberryPi4                             -  enabled, bind: 192.168.1.6
                        system.adapter.mielecloudservice.0      : mielecloudservice     : RaspberryPi4                             -  enabled
                        system.adapter.mqtt.0                   : mqtt                  : RaspberryPi4                             - disabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.node-red.0               : node-red              : RaspberryPi4                             -  enabled, port: 1880, bind: 0.0.0.0
                      + system.adapter.rpi2.0                   : rpi2                  : RaspberryPi4                             -  enabled
                      + system.adapter.shelly.0                 : shelly                : RaspberryPi4                             -  enabled, port: 1882, bind: 192.168.1.6
                        system.adapter.unifi.0                  : unifi                 : RaspberryPi4                             - disabled
                      + instance is alive
                      ioBroker-Repositories
                      │ (index) │ name               │ url                                                     │ auto upgrade │
                      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                      Upgrade policy: none
                      Installed ioBroker-Adapters
                      Adapter    "admin"        : 7.7.22   , installed 7.7.22
                      Adapter    "backitup"     : 3.3.14   , installed 3.3.14
                      Adapter    "ble"          : 0.14.0   , installed 0.14.0
                      Adapter    "hue"          : 3.16.2   , installed 3.16.2
                      Controller "js-controller": 7.0.7    , installed 7.0.7
                      Adapter    "knx"          : 2.0.30   , installed 2.0.30
                      Adapter    "mielecloudservice": 6.5.10, installed 6.5.10
                      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                      Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                      Adapter    "shelly"       : 10.5.2   , installed 10.5.2
                      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                      Objects and States
                      Objects:        2338
                      States:         1700
                      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Reading package lists...
                      Pending systemupdates: 0
                      *** Listening Ports ***
                      tcp        0      0 192.168.1.6:1882        0.0.0.0:*               LISTEN      1001       13059      899/io.shelly.0
                      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       17409      736/node-red
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12752      452/iobroker.js-con
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13739      452/iobroker.js-con
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12708      500/sshd: /usr/sbin
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12836      559/io.admin.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          12710      500/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12152      369/avahi-daemon: r
                      udp        0      0 192.168.1.6:52153       0.0.0.0:*                           1001       17545      736/node-red
                      udp        0      0 192.168.1.6:44985       0.0.0.0:*                           1001       17446      832/io.knx.0
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13735      652/dhcpcd
                      udp        0      0 0.0.0.0:49676           0.0.0.0:*                           108        12154      369/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                108        12153      369/avahi-daemon: r
                      udp6       0      0 :::36371                :::*                                108        12155      369/avahi-daemon: r
                      udp6       0      0 :::546                  :::*                                0          15246      652/dhcpcd
                      mount: bad usage
                      • S SpeedyBlade
                        @Thomas-Braun
                        bash
                        Script v.2026-01-31
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 32 bit
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        HOME=/home/pi
                        iobroker
                        HOME=/home/iobroker
                        Display-Manager:
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                        Swap:            99M          0B         99M
                                 7760 M total memory
                                  557 M used memory
                                  703 M active memory
                                 6629 M free memory
                                   58 M buffer memory
                                  514 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        *** FILESYSTEM ***
                        /var:
                        2.0G    /var/
                        1.3G    /var/log
                        586M    /var/cache
                        USB-Devices by-id:
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        Impact:
                            console.log(err)
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.7.22
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        2338
                        States:         1700
                        mount: bad usage
                        #266
                        also unbedingt trixie lite 64Bit installieren
                        • S SpeedyBlade
                          @Thomas-Braun
                          bash
                          Script v.2026-01-31
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 32 bit
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          iobroker
                          HOME=/home/iobroker
                          Display-Manager:
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Swap:            99M          0B         99M
                                   7760 M total memory
                                    557 M used memory
                                    703 M active memory
                                   6629 M free memory
                                     58 M buffer memory
                                    514 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          *** FILESYSTEM ***
                          /var:
                          2.0G    /var/
                          1.3G    /var/log
                          586M    /var/cache
                          USB-Devices by-id:
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          Impact:
                              console.log(err)
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.7.22
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        2338
                          States:         1700
                          mount: bad usage
                          #267
                          Userland : 32 bit
                          Damit bist du ohnehin für inline-Upgrades disqualifiziert. Kannst du nur neuinstallieren.
                          Dann gleich einen anderen user als 'pi' verwenden.
                          Das würde dann auch
                          gleich mit erledigen.
                            Userland : 32 bit
                            Das würde dann auch
                            SpeedyBlade
                            #268
                            @Thomas-Braun
                            https://downloads.raspberrypi.com/raspios_lite_arm64/images/raspios_lite_arm64-2025-12-04/2025-12-04-raspios-trixie-arm64-lite.img.xz
                            das ist dann mit der neuen Version erledigt oder muss ich da was speziell tun?
                            • S SpeedyBlade
                              @Thomas-Braun
                              #269
                              @SpeedyBlade
                              Mach doch nicht schon wieder was 'neben der Spur'...
                              So geht das am unfallfreisten:
                              https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                @SpeedyBlade
                                SpeedyBlade
                                schrieb am zuletzt editiert von SpeedyBlade
                                #270
                                @Thomas-Braun das hab ich eh auch drauf
                                wo ist der Unterschied zw. 64-bit und Legacy, 64-bit?
                                macht es nicht sinn dann direkt auf forky oder duke zu warten / gehen?
                                Und kann ich dieses image nur auf einen pi spielen oder jeden anderen mini-server auch?
                                wäre dann das hier
                                HomoranH Thomas BraunT 4 Antworten Letzte Antwort
                                • S SpeedyBlade
                                  wäre dann das hier
                                  #271
                                  das willst du nicht!
                                  Die Paketquellen für bookworm werden nicht mehr gepflegt.
                                  • S SpeedyBlade
                                    wäre dann das hier
                                    #272
                                    @SpeedyBlade
                                    Nein, du kannst nicht auf ein Release weit in der Zukunft warten, dein System ist JETZT vergammelt und muss JETZT auf einen noch unterhaltenen Stand gehievt werden.
                                    Die 64Bit-Lite ist richtig für deinen Raspberry4
                                    • S SpeedyBlade
                                      wäre dann das hier
                                      #273
                                      Bei RaspberryOS gibt es hardwarespezifische Anpassungen, das kannst du nicht für anderes verwenden.
                                      • S SpeedyBlade
                                        wäre dann das hier
                                        #274
                                        Legacy ist das sog. 'oldstable'-Release, also der Vorgänger zum jeweilig aktuellen Release.
                                        Im Moment ist das 'bookworm' (Debian 12).
                                          SpeedyBlade
                                          #275
                                          @Thomas-Braun sagte in Iobroker backitup error.. Wo liegt das problem:
                                          alle klar...danke
