  4. Harmony funktioniert seit einiger Zeit nicht mehr
    6.4k
25 Beiträge 10 Kommentatoren 1.5k Aufrufe 8 Beobachtet
  • mcm1957M Offline
    mcm1957M Offline
    mcm1957
    Changelog liest sich abe anders:
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    skvarelS 1 Antwort Letzte Antwort
    • Dr.PieD Dr.Pie
      @Meister-Mopper sagte in Harmony funktioniert seit einiger Zeit nicht mehr:
      @Dr.Pie
      Zeig doch erstmal mit iob diag wie du da unterwegs bist.
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
       Static hostname: nuc
             Icon name: computer-desktop
               Chassis: desktop 🖥️
                Kernel: Linux 6.1.0-40-amd64
          Architecture: x86-64
       Hardware Vendor: Intel Corporation
        Hardware Model: NUC7i3BNK
      Firmware Version: BNKBL357.86A.0083.2020.0714.1344
      OS is similar to:
      model name      : Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       12:20:12 up 26 days, 16:08,  2 users,  load average: 1.83, 1.45, 1.30
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Debian 'bookworm' is the current oldstable version. Please upgrade to the latest        stable release 'trixie' in due time!
      *** TIME AND TIMEZONES ***
                     Local time: Thu 2026-01-29 12:20:12 CET
                 Universal time: Thu 2026-01-29 11:20:12 UTC
                       RTC time: Thu 2026-01-29 11:20:12
                    NTP service: n/a
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      jens
      HOME=/home/jens
      GROUPS=jens cdrom floppy sudo audio dip video plugdev users netdev iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:             16G        3.3G         11G        1.1M        2.5G         13G
      Swap:           1.0G          0B        1.0G
      Total:           17G        3.3G         12G
      Active iob-Instances:   32
              15876 M total memory
               3170 M used memory
                648 M active memory
               4103 M inactive memory
              10696 M free memory
                 63 M buffer memory
               2288 M swap cache
                975 M total swap
                  0 M used swap
                975 M free swap
      top - 12:20:12 up 26 days, 16:08,  2 users,  load average: 1.83, 1.45, 1.30
      Tasks: 153 total,   1 running, 152 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  15876.1 total,  10696.4 free,   3171.0 used,   2351.8 buff/cache
      MiB Swap:    976.0 total,    976.0 free,      0.0 used.  12705.2 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  7.8G     0  7.8G   0% /dev
      tmpfs          tmpfs     1.6G  792K  1.6G   1% /run
      /dev/nvme0n1p1 ext4      116G   14G   97G  13% /
      tmpfs          tmpfs     7.8G     0  7.8G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
      [Fri Jan  2 20:12:10 2026] EXT4-fs (nvme0n1p1): mounted filesystem with ordered        data mode. Quota mode: none.
      [Fri Jan  2 20:12:11 2026] EXT4-fs (nvme0n1p1): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET SOURCE         FSTYPE OPTIONS
      /      /dev/nvme0n1p1 ext4   rw,relatime,errors=remount-ro
      /var:
      2.6G    /var/
      2.0G    /var/log/journal/71f4ccb046934bb889999d75429a60cc
      2.0G    /var/log
      380M    /var/cache
      Archived and active journals take up 87.1M in the file system.
      /opt/iobroker/backups:
      4.6G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      662M    /opt/iobroker/iobroker-data/
      368M    /opt/iobroker/iobroker-data/files
      139M    /opt/iobroker/iobroker-data/backup-objects
      60M     /opt/iobroker/iobroker-data/files/vis-2
      47M     /opt/iobroker/iobroker-data/files/admin.admin
      64M     /opt/iobroker/iobroker-data/states.jsonl
      42M     /opt/iobroker/iobroker-data/objects.jsonl
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc        3820.js.map
      13M     /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
      USB-Devices by-id:
      USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
      No Devices found 'by-id'
      *** ZigBee Settings ***
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.20.0
      /usr/bin/node           v20.20.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.34.1
      nodejs:
        Installed: 20.20.0-1nodesource1
        Candidate: 20.20.0-1nodesource1
        Version table:
       *** 20.20.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
           20.19.6-1nodesource1 1001
           20.19.5-1nodesource1 1001
           20.19.4-1nodesource1 1001
           20.19.3-1nodesource1 1001
           20.19.2-1nodesource1 1001
           20.19.1-1nodesource1 1001
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.20.4+dfsg-1~deb12u1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
              500 http://security.debian.org/debian-security bookworm-security/main am        d64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      nuc                 nuc (version: 7.0.7, hostname: nuc           , alive, uptime        : 7495)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.22
      javascript:     9.0.11
      nodejs modules from github:     4
      +-- iobroker.bambulab@0.4.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambula        b.git#53e3ab3393d16f1939ceadc25da611f21574cbc8)
      +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthin        gs.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
      +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/i        oBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332        aa6b1ab5be7fe8c57d3c68b0)
      Adapter State
      + system.adapter.admin.0                  : admin                 : nuc        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
      + system.adapter.backitup.0               : backitup              : nuc        -  enabled
      + system.adapter.bambulab.2               : bambulab              : nuc        -  enabled, port: 8883
        system.adapter.daswetter.0              : daswetter             : nuc        -  enabled
        system.adapter.daswetter.1              : daswetter             : nuc        -  enabled
      + system.adapter.denon.0                  : denon                 : nuc        -  enabled
      + system.adapter.discovery.0              : discovery             : nuc        -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : nuc        -  enabled
      + system.adapter.firetv.0                 : firetv                : nuc        -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : nuc        -  enabled
      + system.adapter.harmony.0                : harmony               : nuc        -  enabled
      + system.adapter.heos.0                   : heos                  : nuc        -  enabled
      + system.adapter.history.0                : history               : nuc        -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : nuc        -  enabled
        system.adapter.ical.0                   : ical                  : nuc        -  enabled
        system.adapter.ical.1                   : ical                  : nuc        -  enabled
        system.adapter.ical.2                   : ical                  : nuc        -  enabled
        system.adapter.ical.3                   : ical                  : nuc        -  enabled
      + system.adapter.javascript.0             : javascript            : nuc        -  enabled
      + system.adapter.shelly.0                 : shelly                : nuc        -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : nuc        -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.smartthings.0            : smartthings           : nuc        -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : nuc        -  enabled
      + system.adapter.sql.0                    : sql                   : nuc        -  enabled
      + system.adapter.synology.0               : synology              : nuc        -  enabled, port: 5000
      + system.adapter.synology.1               : synology              : nuc        -  enabled, port: 5002
      + system.adapter.synology.2               : synology              : nuc        -  enabled, port: 5003
      + system.adapter.tankerkoenig.0           : tankerkoenig          : nuc        -  enabled
      + system.adapter.tankerkoenig.1           : tankerkoenig          : nuc        -  enabled
      + system.adapter.telegram.0               : telegram              : nuc        -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : nuc        -  enabled
      + system.adapter.tr-064.2                 : tr-064                : nuc        -  enabled
      + system.adapter.tr-064.3                 : tr-064                : nuc        -  enabled
      + system.adapter.upnp.0                   : upnp                  : nuc        -  enabled
        system.adapter.vis-2.0                  : vis-2                 : nuc        - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : nuc        -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : nuc        -  enabled
        system.adapter.vis-lcars.0              : vis-lcars             : nuc        -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : nuc        -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : nuc        -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : nuc        -  enabled
        system.adapter.vis.0                    : vis                   : nuc        -  enabled
      + system.adapter.web.0                    : web                   : nuc        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
      + system.adapter.wled.0                   : wled                  : nuc        -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name     │ url                                                     │        auto upgrade │
      │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │        false        │
      │ 1       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │        false        │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.7.22   , installed 7.7.22
      Adapter    "backitup"     : 3.3.13   , installed 3.3.13
      Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
      Adapter    "firetv"       : 2.1.0    , installed 2.1.0
      Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
      Adapter    "harmony"      : 1.5.0    , installed 1.5.0
      Adapter    "heos"         : 2.2.1    , installed 2.2.1
      Adapter    "homeconnect"  : 1.5.2    , installed 1.5.2
      Adapter    "ical"         : 1.18.1   , installed 1.18.1
      Adapter    "javascript"   : 9.0.11   , installed 9.0.11
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "shelly"       : 10.5.2   , installed 10.5.2
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "upnp"         : 1.1.0    , installed 1.1.0
      Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
      Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Objects and States
      Objects:        41490
      States:         34394
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       74559729   171239/iobroker.js-
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       74557936   171239/iobroker.js-
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13828      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19043      552/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       74559438   171572/io.shelly.1
      tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       74559896   171426/adb
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      104        20356      524/influxd
      tcp6       0      0 :::111                  :::*                    LISTEN      0          13830      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          19045      552/sshd: /usr/sbin
      tcp6       0      0 :::8086                 :::*                    LISTEN      104        19147      524/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       74560732   171260/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       74563604   171871/io.web.0
      tcp6       0      0 :::8000                 :::*                    LISTEN      1001       74564383   171826/io.upnp.0
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       74559968   171464/io.harmony.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       74560056   171557/io.shelly.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12270      359/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13829      1/init
      udp        0      0 192.168.178.28:123      0.0.0.0:*                           0          20579      641/ntpd
      udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          20577      641/ntpd
      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          20573      641/ntpd
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       74562817   171826/io.upnp.0
      udp        0      0 0.0.0.0:60324           0.0.0.0:*                           1001       74561468   171826/io.upnp.0
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       74559969   171464/io.harmony.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       74563596   171886/io.wled.0
      udp        0      0 192.168.178.28:5353     0.0.0.0:*                           1001       74561543   171635/io.tr-064.0
      udp        0      0 0.0.0.0:54539           0.0.0.0:*                           1001       74560283   171762/io.heos.0
      udp6       0      0 :::111                  :::*                                0          13831      1/init
      udp6       0      0 fe80::96c6:91ff:fea:123 :::*                                0          20583      641/ntpd
      udp6       0      0 ::1:123                 :::*                                0          20581      641/ntpd
      udp6       0      0 :::123                  :::*                                0          20570      641/ntpd
      2026-01-29 12:12:42.051  - info: synology.0 (171583) Connecting to Synology 192.168.178.201:5000
      2026-01-29 12:13:15.428  - info: synology.0 (171583) Connecting to Synology 192.168.178.201:5000
      2026-01-29 12:13:49.093  - info: synology.0 (171583) Connecting to Synology 192.168.178.201:5000
      2026-01-29 12:14:22.499  - info: synology.0 (171583) Connecting to Synology 192.168.178.201:5000
      2026-01-29 12:14:55.910  - info: synology.0 (171583) Connecting to Synology 192.168.178.201:5000
      2026-01-29 12:15:29.316  - info: synology.0 (171583) Connecting to Synology 192.168.178.201:5000
      2026-01-29 12:15:49.008  - info: host.nuc instance system.adapter.daswetter.0 in version "3.2.8" started with pid 172285
      2026-01-29 12:15:50.503  - info: daswetter.0 (172285) starting. Version 3.2.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.20.0, js-controller: 7.0.7
      2026-01-29 12:15:53.014  - info: host.nuc instance system.adapter.daswetter.1 in version "3.2.8" started with pid 172300
      2026-01-29 12:15:55.068  - info: daswetter.1 (172300) starting. Version 3.2.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.20.0, js-controller: 7.0.7
      2026-01-29 12:15:56.760  - info: daswetter.0 (172285) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2026-01-29 12:15:57.269  - info: daswetter.0 (172285) cleaned everything up...
      2026-01-29 12:15:57.292  - info: host.nuc instance system.adapter.daswetter.0 having pid 172285 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2026-01-29 12:15:59.406  - info: daswetter.1 (172300) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2026-01-29 12:16:00.103  - info: daswetter.1 (172300) cleaned everything up...
      2026-01-29 12:16:00.144  - info: host.nuc instance system.adapter.daswetter.1 having pid 172300 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2026-01-29 12:16:02.850  - info: synology.0 (171583) Connecting to Synology 192.168.178.201:5000
      2026-01-29 12:16:36.291  - info: synology.0 (171583) Connecting to Synology 192.168.178.201:5000
      2026-01-29 12:17:09.636  - info: synology.0 (171583) Connecting to Synology 192.168.178.201:5000
      2026-01-29 12:17:43.138  - info: synology.0 (171583) Connecting to Synology 192.168.178.201:5000
      2026-01-29 12:18:16.675  - info: synology.0 (171583) Connecting to Synology 192.168.178.201:5000
      2026-01-29 12:18:50.307  - info: synology.0 (171583) Connecting to Synology 192.168.178.201:5000
      2026-01-29 12:19:23.715  - info: synology.0 (171583) Connecting to Synology 192.168.178.201:5000
      2026-01-29 12:19:57.156  - info: synology.0 (171583) Connecting to Synology 192.168.178.201:5000
      2026-01-29 12:20:30.530  - info: synology.0 (171583) Connecting to Synology 192.168.178.201:5000
      iob diag has finished.
      jens@nuc:~$
      @Dr.Pie sagte in Harmony funktioniert seit einiger Zeit nicht mehr:
      Losgelöst vom Problem:
      Bring deine Kiste jetzt auf nodejs@22 und in Kürze auf Debian 13 'Trixie'.
      Dr.PieD 1 Antwort Letzte Antwort
      • mcm1957M mcm1957
        skvarelS Online
        skvarelS Online
        skvarel
        schrieb am zuletzt editiert von skvarel
        @mcm1957 sagte in Harmony funktioniert seit einiger Zeit nicht mehr:
        Ich möchte hier jetzt ungern den privaten Chat mit Bluefox posten ;) Ich sollte die activities testen, weil wegen Alexa neue States hinzugefügt werden mussten.
        Stimmt, das war die 2.0.2 Wie gesagt, ich nutze die 2.0.3 und die hat so keine Probleme, ausser bei frischen Installationen. Da wurden die activities nicht angelegt. Bei bestehenden Installationen gab es so keine Probleme. Da swurde mit der 2.0.3 gefixed. Das hast du (@mcm1957) im Issue bestätigt ;)
        EDIT:
        @dr.pie ... ab der v2.x.x musst du deine Buttons umbauen! Die activities werden jetzt mit true/false und bei der v1.5.x mit 0 und 2 gesteuert.
        #TeamInventwo
        Unsere Adapter:
        • skvarelS skvarel
          EDIT:
          @skvarel sagte in Harmony funktioniert seit einiger Zeit nicht mehr:
          dann wäre das ja extrem wichtig für alle Scripte!
          aber so interpretiere ich
          das auch nicht!
          Demnach ist ein weiterer DP hinzugekommen
            das auch nicht!
            skvarelS Online
            skvarelS Online
            skvarel
            @Homoran sagte in Harmony funktioniert seit einiger Zeit nicht mehr:
            Ich will hier jetzt KEINE Verwirrung stiften aber ich habe keine Datenpunkte mehr, die über Nummer gesteuert werden. Nur noch true/false.
            Eventuell ist DAS jetzt bei der 2.0.4 behoben worden !? Das kann ich nachher bei mir überprüfen.
            EDIT:
            Auch nach dem Update auf 2.0.4, alle activities doppelt vorhanden. Einmal als Boolean und einmal mit einer Auswahlliste.
            #TeamInventwo
            Unsere Adapter:
            • skvarelS Online
              skvarelS Online
              skvarel
              Nach dem Update auf 2.0.4:
              #TeamInventwo
              Unsere Adapter:
              • mcm1957M Offline
                mcm1957M Offline
                mcm1957
                Im kern geht es um einen Punkt:
                Kann der Adapetr in Release 2.0.x n ach der Umstellung auf Typescript durch Bluefox nun verwendet werden oder nicht.
                Wenn etwas nicht funktioniert muss es angepasst / gefixed werden. Wenn es funktioniert soll es mir natürlich recht sein. Bitte daher bei Problemen ein Issue anlegen / existierendes Issue kommentieren. Ich triggre Bluefox gerne bei Bedarf.
                  Dr.PieD Offline
                  Dr.PieD Offline
                  Dr.Pie
                  @Thomas-Braun sagte in Harmony funktioniert seit einiger Zeit nicht mehr:
                  erledigt ;-)
                  • Dr.PieD Offline
                    Dr.PieD Offline
                    Dr.Pie
                    Da bin ich wieder.
                    Leider funktioniert der Adapter wieder nicht.
                    Warum auch immer.
                    harmony.0 2026-03-05 18:59:18.189	debug	executeCleanUp()
                    Diese Meldung bekomme ich am laufenden Band.
                    Der Adapter selber zeigt aber grün an.
                    Diese Einstellungen sind auch schon immer drin
                    Hat da jemand ein Tipp ??
                    1000 Dank
                    • Dr.PieD Dr.Pie
                      Da bin ich wieder.
                      Warum auch immer.
                      1000 Dank
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      ° Fixer ---> iob fix
                      • NegaleinN Negalein
                        Dr.PieD Offline
                        Dr.PieD Offline
                        Dr.Pie
                        schrieb am zuletzt editiert von Dr.Pie
                        @Negalein Da steht eigentlich schon immer 255.255.255.0 drin.
                        Selbst wenn ich dort die IP eintrage oder das Datum des Mauerfalls, ändert es nichts daran das es nicht funktioniert ... seeeehr seltsam wieder mal.
                        Der Adapter zeigt grün egal was da steht.
                        • mcm1957M Offline
                          mcm1957M Offline
                          mcm1957
                          Die Bennenung der Paramater ist - sagen wir mal - nicht optimal. Schau dir mal den Beitrag hier an:
                          https://github.com/iobroker-community-adapters/ioBroker.harmony/issues/331#issuecomment-3992878043
                          Nachdem ich mir das Repository von swissmanu harmonyhubjs-discover angesehen habe, der die Netzwerkerkennung für Harmony Hubs ursprünglich entwickelt hat, verstehe ich die Funktionsweise nun besser: Das Feld „discovery-subnets“ enthält die Broadcast-Adresse, also die letzte Adresse Ihres IP-Subnetzes. Mein Netzwerk reicht beispielsweise von 192.168.0.1 bis 192.168.1.255 (Subnetzmaske 255.255.254.0/23). In diesem Fall trage ich 192.168.1.255 in das Feld „Discovery-Subnets“ ein. Und siehe da, alle meine Hubs werden erkannt und gemäß der (optionalen) Geräteliste verbunden.
                          Ev hilft das ja
                          • skvarelS Online
                            skvarelS Online
                            skvarel
                            Ichhabe den Eintrag des Subnetz nie sellbst bearbeitet. Ich habe lediglich den Hub fest eingetragen. Der Adapter in der Versin v2.0.5 läuft hier sehr gut.
                            Ich steuere allerdings nur zwei Fernseher und einen Vodafon Kabel-Receiver darüber.
                            Ich konnte heute auch alles ganz normal per VIS bedienen.
                            EDIT:
                            Meine Subnetzmaske in der Fritzbox: 255.255.128.0
                            Fritzbox läuft auf 192.168.130.1
                            ioBroker auf 192.168.130.130
                            Harmony Hub auf 192.168.140.220
                            #TeamInventwo
                            Unsere Adapter:
                              Schnubby666
                              Bei mir wird das Log auch vollgemüllt mit der Meldung. Schon md eine Idee woran es liegt oder was man machen könnte?
                              • Meister MopperM Offline
                                Meister Mopper
                                Mit 255.255.255.255 findet der Adapter jeden Hub im (sichtbaren) Netzwerk und man muss die IP der Hubs nicht mitgeben, so läuft es zumindest bei mir.
                                Proxmox und HA ...
                                  Schnubby666
                                  schrieb am zuletzt editiert von Schnubby666
                                  Ich habe diverse Einstellung bei Discovery-Subnetze ausprobiert. Weithin so gut wie jede Sekunde im Log executeCleanUp. Nach downgrade auf 1.5 habe ich die Meldungen nicht mehr
