    apollon77A
lovelace uinspanelsonoff
8.1k Beiträge 281 Kommentatoren 9.8m Aufrufe 260 Beobachtet
  • J
    J
    JackONell
    #7922
    @tt-tom
    Script Version:
    TypeScript v4.3.1.7 zur Steuerung des SONOFF NSPanel mit dem ioBroker by @Armilar / @TT-Tom / @Sternmiere / @Britzelpuf / @ravenS0ne
    - abgestimmt auf TFT 53 / v4.3.1 / BerryDriver 9 / Tasmota 13.1.0
    Zur TFT Version habe ich leider nur folgendes im Script gefunden (ist das richtig ?):
    //Desired Firmware
    const tft_version: string = 'v4.3.1';
    const desired_display_firmware_version = 53;
    const berry_driver_version = 9;
    const tasmotaOtaUrl: string = 'http://ota.tasmota.com/tasmota32/release/';
    Die Tasmota Konsole gibt folgendes aus:
    20:22:30.841 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:22:36.741 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:22:42.741 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:22:48.741 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:22:54.641 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:23:00.641 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:23:06.541 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:23:12.541 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:23:17.933 MQT: SmartHome/tele/NSPanel_85E568/STATE = {"Time":"2026-02-21T20:23:17","Uptime":"0T01:45:08","UptimeSec":6308,"Heap":137,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":217},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Home24","BSSId":"08:B6:57:C2:D4:F9","Channel":5,"Mode":"HT20","RSSI":84,"Signal":-58,"LinkCount":1,"Downtime":"0T00:00:03"},"Hostname":"NSPanel-85E568-1384","IPAddress":"192.168.2.17"}
    20:23:17.945 MQT: SmartHome/tele/NSPanel_85E568/SENSOR = {"Time":"2026-02-21T20:23:17","ANALOG":{"Temperature1":25.6},"TempUnit":"C"}
    20:23:18.440 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:23:24.442 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:23:30.342 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:23:36.342 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:23:42.241 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:23:48.241 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:23:54.147 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:24:00.147 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:24:06.041 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:24:12.041 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:24:17.941 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:24:23.940 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:24:29.944 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:24:35.841 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:24:41.840 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:24:47.741 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:24:53.742 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:24:59.642 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:25:05.640 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:25:11.533 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:25:17.533 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:25:23.433 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    20:25:29.436 MQT: SmartHome/tele/NSPanel_85E568/RESULT = {"CustomRecv":"event,startup,53,eu"}
    • J JackONell
      @tt-tom
      Script Version:
      //Desired Firmware
      T
      T
      TT-Tom
      #7923
      @JackONell
      im Script was sehr sehr alt ist muss eine eine Variable geben die Debug heißt
      irgendwie sowas
      var Debug: boolean = false;
      ist ziemlich am Anfang vom Script, dort machst du aus false -> true und startest das script neu
      dann kommt unten im Logfenster eine menge Meldungen, die Kopieren und posten
      Gruß Tom
      Public Transport
      NSPanel Adapter Wiki
      • J
        J
        JackONell
        #7924
        @tt-tom Vielen Dank für deine Mühe !
        Im Skript habe ich nur folgendes gefunden, hab jetzt nichts "aktiviert" da es mir im im Log trotzdem was ausgibt:
        let Icons = new IconsSelector();
        let timeoutSlider: any;
        let vwIconColor = [];
        let weatherForecast: boolean;
        let Debug: boolean;
        auch wenn ich folgendes "aktiviere" wird nicht mehr ausgegeben
        let Debug: boolean = true;
        Das Log gibt folgendes aus:
        javascript.0	22:50:12.919	info
        Stopping script
        javascript.0	22:50:13.214	info
        Compiling TypeScript source
        javascript.0	22:50:25.453	error
        TypeScript compilation failed:
                    await setStateAsync(NSPanel_Path + 'PageNavi', <iobJS.State>{ val: { "pagetype": "page", "pageId": 0 }, ack: true });
        ERROR: Conversion of type '{ val: { pagetype: string; pageId: number; }; ack: true; }' to type 'State' may be a mistake because neither type sufficiently overlaps with the other. If this was intentional, convert the expression to 'unknown' first.
          Type '{ val: { pagetype: string; pageId: number; }; ack: true; }' is missing the following properties from type 'State': ts, lc, from
                    let name = page.heading !== undefined ? page.heading : o.common.name.de;
        ERROR: Property 'de' does not exist on type 'StringOrTranslated'.
          Property 'de' does not exist on type 'string'.
                let heading = page.heading !== undefined ? page.heading : o.common.name.de;
                    unsubscribe(value);
        ERROR: Argument of type 'unknown' is not assignable to parameter of type 'string | RegExp | string[]'.
        • J JackONell
          let Debug: boolean;
          Stopping script
                      unsubscribe(value);
          T
          T
          TT-Tom
          #7925
          @JackONell
          okay, das ist das Problem mit dem alten Script. Der JavaScript Adapter hat sich weiterentwickelt und ist jetzt genauer bei der Programmierung. Du musst auf die aktuelle Scriptversion wechseln. da deine Version über ein Jahr alt ist. Wirst du einiges an deiner Seiten config anpassen müssen.
          im wiki gibt es dazu einige Informationen zum Upgrade.
          https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Starthilfe-FAQ#hilfe-bei-update--upgrade
          Starte das leere Script erstmal und aktualisiere dann den Berry Treiber und danach die TFT-Firmware
          Dann kannst du anfangen die Seiten zu importieren. Stück für Stück.
          Wenn Probleme auf kommen melde dich
          Gruß Tom
          Public Transport
          • J
            J
            JackONell
            #7926
            @tt-tom
            Vielen Dank für deine Hilfe. Hab mal das neue Script eingebunden. Hab jetzt zumindest mal wieder eine funktionierende Oberfläche. Der Rest muss ich mir mal die nächsten Tage/Wochen anschauen :D
            Manchmal ist es echt besser kein Update zu machen, das spart gewisse Arbeit :D
            Falls ich nochmal Hilfe benötige, werde ich mich nochmal melden.
            Danke nochmals
            teletapiT T ilovegymI 3 Antworten Letzte Antwort
            • J JackONell
              @tt-tom
              Danke nochmals
              teletapiT
              teletapiT
              teletapi
              #7927
              @JackONell sagte in SONOFF NSPanel mit Lovelace UI:
              Im Falle einer Hausautomation ist meiner Meinung nach genau das Gegenteil die bessere Wahl, zeitliche Updates in kürzeren Intervallen.
              Man bleibt auf aktuellem Stand und weiß auch besser was zu tun ist im Fehlerfall
              • J JackONell
                @tt-tom
                Danke nochmals
                T
                T
                ticaki
                #7928
                Ist doch bei allem so - wenn du nie einen Ölwechsel am Auto machst spart das Geld und Arbeit bis es kracht - das gilt für Fensterscharniere, Garten, putzen usw. und natürlich auch Smarthome :)
                Spenden
                • J JackONell
                  @tt-tom
                  Danke nochmals
                  ilovegymI
                  ilovegymI
                  ilovegym
                  #7929
                  Oh, darauf steht Höchststrafe ! Die "never change a running system" Methode ist seit Jahren nicht mehr tragbar!
                  Selbst Satelliten, die Milliarden von KM entfernt um andere Planeten kreisen, bekamen schon neue Firmware, d.h. man hat ihn in einen Safemode versetzt, ( so wie bei Tasmota die Safeboot), um platz im Speicher zu bekommen, und dann eine komplett neue Firmware hochgeladen. - und der fliegt heute noch und sendet uns wichtige wissenschaftliche Daten!
                  Seit so gut, und plan für dich selbst alle 3 Monate Updates im Kalender ein, Systempflege ist heute wichtiger denn je!
                  • MichaelFM
                    MichaelFM
                    MichaelF
                    schrieb am zuletzt editiert von MichaelF
                    #7930
                    Hi, ich habe eben mal versucht die CardThermo bei meinem Panel einzufügen.
                    Hat auch eigentlich alles soweit Funktioniert, was ich leider nicht hin bekomme habe ist die Modus Umschaltung, der Boost Mode und die Batterieanzeige.
                    Thermostate sind von Homematic, vielleicht hat ja einer eine ähnliche Kombi und hat es hin bekommen.
                    Hier der Alias:
                    Die Datenpunkte des Thermostates:
                    teletapiT T 2 Antworten Letzte Antwort
                    • D
                      D
                      danny_v1
                      #7931
                      Hallo, wie nutzt man das popupLight2? Dazu habe ich in der Doku leider nichts gefunden. Und wie sieht das am Panel aus bzw, was ist der Unterschied zum normalen popupLight?
                      • D danny_v1
                        T
                        T
                        TT-Tom
                        #7932
                        @danny_v1
                        der parameter heist
                        popupVersion: 2
                        popup2
                        Gruß Tom
                        Public Transport
                        • MichaelFM MichaelF
                          Hier der Alias:
                          teletapiT
                          teletapiT
                          teletapi
                          schrieb am zuletzt editiert von teletapi
                          #7933
                          gelöscht wegen Unsinn
                            Hier der Alias:
                            T
                            T
                            TT-Tom
                            #7934
                            @MichaelF
                            Welche card willst du nutzen?? Type 1 ist hier eine Anleitung
                            https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-ALIAS-Definitionen#thermostat-cardthermo-channel-thermostat
                            Type 2 hier
                            https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-‐-cardThermo2-‐-Der-komplette-Leitfaden
                            Gruß Tom
                            Public Transport
                            MichaelFM 1 Antwort Letzte Antwort
                            • teletapiT teletapi
                              T
                              T
                              TT-Tom
                              #7935
                              @teletapi
                              ist das vom Adapter oder vom Script??
                              Gruß Tom
                              Public Transport
                              teletapiT 1 Antwort Letzte Antwort
                              • T TT-Tom
                                @teletapi
                                teletapiT
                                teletapiT
                                teletapi
                                #7936
                                @TT-Tom sagte in SONOFF NSPanel mit Lovelace UI:
                                @teletapi
                                Adapter
                                  @teletapi
                                  Adapter
                                  T
                                  T
                                  TT-Tom
                                  #7937
                                  @teletapi
                                  okay hier gehts um das Script, da gibt einige Unterschiede, grade bei den Funktion-Card
                                  Gruß Tom
                                  Public Transport
                                  • T TT-Tom
                                    @teletapi
                                    teletapiT
                                    teletapiT
                                    teletapi
                                    #7938
                                    @teletapi
                                    Habs gelöscht bringt sonstz ja nur verwirrung. Tschuldigúng hatte nicht aufgepasst
                                      @teletapi
                                      T
                                      T
                                      TT-Tom
                                      #7939
                                      @teletapi
                                      Kein Problem, jede Hilfe ist gerne gesehen. 👍🏻 Muss auch immer wieder nachschauen welcher Teil das ist.
                                      Gruß Tom
                                      Public Transport
                                      • MichaelFM
                                        MichaelFM
                                        MichaelF
                                        #7940
                                        @tt-tom
                                        DANKE :-), hätte ich das mal früher gefunden....
                                        Funktioniert alles, und es ist Type 1, allerdings Type 2 ist schon Moderner.
                                        Glaub das schau ich mir am WE nochmal genauer an.
                                        Danke nochmal und Grüße
                                        • 1
                                          13patrick37
                                          #7941
                                          ich hatte vorhin eben kurz mit @tt-tom geschrieben - zwei meiner 5 Panels sind gerade offline. Urplötzlich.
                                          Gibt es gerade mit Tasmota? Beide sind direkt offline - komme nicht auf die Tasmota IP.
                                          84.0k
