  5. Script zum Laden/Entladen von Zendure Solarflow
310 Beiträge 17 Kommentatoren 52.5k Aufrufe 15 Beobachtet
  • L Online
    L Online
    lesiflo
    #154
    Ja, sollte gehen.
    • T tege0
      @lesiflo Moin,
        <variables>
          <variable id="O}e3|VjTzH+.dHc-BE_:">output_Abzug</variable>
          <variable id="Pmn^Rfs2`%vXob$!J=UX">input_Abzug</variable>
          <variable id="C3%p`nQ`AJ8yklMQKidv">entladen_ab_PV_Leistung</variable>
          <variable id="[ZaP{gfTZqGf@aQ2FZ~q">min_PV_Leistung_laden</variable>
          <variable id="8]~yHC.tW6]*GfkCbq)^">ausgang_max_soll</variable>
          <variable id="u8CL)Wex?DocZ58y(/n*">output</variable>
          <variable id="s3oTgk^d]QTYtWfpyOk6">input</variable>
          <variable type="timeout" id="timeout4">timeout4</variable>
          <variable id="4.#!}3STBog53dwlcFl-">ausgang_max</variable>
        </variables>
        <block type="comment" id="aB?G:5$JZsZVN]k[FMf$" x="2512" y="-1538">
          <field name="COMMENT">Setzen der Variablen </field>
          <next>
            <block type="variables_set" id="%T^F?(~}g~8Mo.96hbPc">
              <field name="VAR" id="O}e3|VjTzH+.dHc-BE_:">output_Abzug</field>
              <value name="VALUE">
                <block type="math_number" id="Cd-LtKS?ZQR;3fE)1OfR">
                  <field name="NUM">50</field>
                </block>
              </value>
              <next>
                <block type="variables_set" id="Kd6%X$(E%a#8:/4N[o[d">
                  <field name="VAR" id="Pmn^Rfs2`%vXob$!J=UX">input_Abzug</field>
                    <block type="math_number" id="6chO$JcvEJqo#aCjc+es">
                    </block>
                  </value>
                  <next>
                    <block type="variables_set" id="uB]{;BN[bdupMg$7^N%|">
                      <field name="VAR" id="C3%p`nQ`AJ8yklMQKidv">entladen_ab_PV_Leistung</field>
                        <block type="math_number" id="[h?+?1Bkt{sL]3tL~hWI">
                          <field name="NUM">100</field>
                        </block>
                      </value>
                      <next>
                        <block type="variables_set" id="Nh!l?R;)f=75+K9:iO@v">
                          <field name="VAR" id="[ZaP{gfTZqGf@aQ2FZ~q">min_PV_Leistung_laden</field>
                            <block type="math_number" id="oOA~o%:[)dg2rqcignZi">
                            </block>
                          </value>
                          <next>
                            <block type="variables_set" id="C7WP.yVY.~yLboTO)--M">
                              <field name="VAR" id="8]~yHC.tW6]*GfkCbq)^">ausgang_max_soll</field>
                                <block type="math_number" id="!o~v`/:*+;(]p]{H?WTA">
                                  <field name="NUM">1200</field>
                                </block>
                              </value>
                              <next>
                                <block type="comment" id="DJvkJQJ02otHqWQ#`O-O">
                                  <field name="COMMENT">Entladen</field>
                                  <next>
                                    <block type="on_ext" id="/S(;`QABriIC^M+!}7T:">
                                      <value name="OID0">
                                        <shadow type="field_oid" id="w^]7^w1{B-!$n`7Iy491">
                                          <field name="oid">mqtt.0.iot.smartmeter.sensor.1.obis.1-0:16.7.0.255.value</field>
                                        </shadow>
                                      </value>
                                      <statement name="STATEMENT">
                                        <block type="comment" id="cN$0iHH^ClAq2iXC%h2f">
                                          <field name="COMMENT">Setzen der Ausgangsleistung</field>
                                          <next>
                                            <block type="variables_set" id="S2o8L=RQS++7ipXOjjW5">
                                              <field name="VAR" id="u8CL)Wex?DocZ58y(/n*">output</field>
                                                <block type="math_arithmetic" id="hYf4Qb{Ih$jw*N;WscVV">
                                                  <field name="OP">ADD</field>
                                                  <value name="A">
                                                    <shadow type="math_number" id="9gy04mb1^QNucYMt=}0h">
                                                    </shadow>
                                                    <block type="math_arithmetic" id="*1]Xu7P5!!NOH(N|hVz:">
                                                      <value name="A">
                                                        <shadow type="math_number" id="b{`6?WEyk*89jf,ZZB$.">
                                                        </shadow>
                                                        <block type="on_source" id="fT5WF[G1:geas5bB(dK_">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <shadow type="math_number" id="fm2M,2zo4VbkMa}j=/{E">
                                                          <field name="NUM">40</field>
                                                        </shadow>
                                                        <block type="variables_get" id="P_*d{TGR}~6)FGp?beAd">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <shadow type="math_number" id="3(GI4:w3kpQ]XWp!0hOr">
                                                      <field name="NUM">1</field>
                                                    </shadow>
                                                    <block type="get_value" id="Qo}VOqo;3/)bnhXo)WG?">
                                                      <field name="OID">zendure-solarflow.0.gDa3tb.nGY7x38q.outputHomePower</field>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <next>
                                                <block type="comment" id="jfTMAZ*=]Yc9N:)Y_sD1">
                                                  <field name="COMMENT">Setzen der Eingangsleistung</field>
                                                  <next>
                                                    <block type="variables_set" id="=I!*y|ga6BOdj=O!X0BN">
                                                      <field name="VAR" id="s3oTgk^d]QTYtWfpyOk6">input</field>
                                                        <block type="math_arithmetic" id="~LBc9fG5Z6lJd12/)jT4">
                                                          <value name="A">
                                                            </shadow>
                                                            <block type="math_arithmetic" id="7*xCVML~1.vqU9HsbESx">
                                                              <value name="A">
        </shadow>
        <block type="math_arithmetic" id="h8,cPd68a?7lws8h++F@">
        <field name="OP">MULTIPLY</field>
        <value name="A">
        <shadow type="math_number" id="K%zdB%]da)JMw$_M{`0A">
        </shadow>
        <block type="on_source" id="4-h:R`sm6~t8DD=?|~bF">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="ruG^sz:{eEwbTM5f6,,3">
        <field name="NUM">-1</field>
        </shadow>
        </value>
        </block>
                                                              </value>
                                                              <value name="B">
        <shadow type="math_number" id="$D6ZCKCT8FTu_$opwTau">
        <field name="NUM">80</field>
        </shadow>
        <block type="variables_get" id="l1AP,7Z]*amiz~W%-%1U">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </shadow>
                                                            <block type="get_value" id="^#eZ+R?)2{J(aB:7ue?R">
                                                              <field name="OID">zendure-solarflow.0.gDa3tb.nGY7x38q.gridInputPower</field>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <next>
                                                        <block type="controls_if" id="9{oE^c13a:31;2ut.DI$">
                                                          <mutation elseif="2" else="1"></mutation>
                                                          <value name="IF0">
                                                            <block type="logic_operation" id="FM{=CcWqi$cZiLrTUt|c" inline="false">
                                                              <field name="OP">AND</field>
                                                              <value name="A">
        <block type="logic_compare" id="8T*pvHzokS3$DFxF[cJw">
        <field name="OP">GT</field>
        <value name="A">
        <block type="variables_get" id="~PO!:gZkJmZA*2|eHeLF">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="[w:QpHOP~OO[[A!*WhCR">
        <field name="NUM">0</field>
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="B">
        <block type="logic_compare" id="h,i~#@yPRw(6/9i72ti]">
        <value name="A">
        <block type="get_value" id="-+SJ366xWJKVS[GlnD+M">
        <field name="OID">zendure-solarflow.0.gDa3tb.nGY7x38q.solarInputPower</field>
        </block>
        </value>
        <value name="B">
        <block type="variables_get" id="cH,sON~zP`WQrqn3m2ZP">
        </block>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <statement name="DO0">
                                                            <block type="comment" id="U9B/k%5s]K%^b3s)xv(L">
                                                              <field name="COMMENT">1. Entladen</field>
                                                              <next>
        <block type="controls_if" id="lqfMN+oTfpMH$r=IF.]*">
        <value name="IF0">
        <block type="logic_compare" id="jraX-U4NvmG~iU5_!b_-">
        <value name="A">
        <block type="get_value" id="RJ{ZOBC`JZxk?Wh2AUqw">
        </block>
        </value>
        <value name="B">
        <block type="variables_get" id="a81S}b!V{aCPJeQ@5ZVB">
        </block>
        </value>
        </block>
        </value>
        <block type="comment" id="BCb_o;s~#Iozzv%Cas0r">
        <field name="COMMENT">PV Leistung in Hausverbrauch</field>
        <next>
        <block type="variables_set" id="^q}qt_N]BU5Q%/J!*t]v">
        <field name="VAR" id="4.#!}3STBog53dwlcFl-">ausgang_max</field>
        <block type="math_arithmetic" id="8~SRMHO?%%VAP*(QC#;f">
        <value name="A">
        <shadow type="math_number" id="Oro!0u03Bc+Eq-2~1;/v">
        </shadow>
        <block type="get_value" id="2aEM-Q)HyYfnX|7M~YPe">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="`~i$BG^Jk:{8Au^!MQP:">
        </shadow>
        <block type="variables_get" id="}/~/H[`cKB?7xVui=l;-">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <statement name="ELSE">
        <block type="variables_set" id="/3-);`|8@{UwDnWT6ksK">
        <block type="variables_get" id="I%qi{|oZzXlO9z5nSJu?">
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="controls_if" id="C##I)|jndO21{Wa2E/f)">
        <value name="IF0">
        <block type="logic_compare" id="}iB?SwpSesKSeva}j?mw">
        <value name="A">
        <block type="variables_get" id="*SIAUI61WHJZJ[9o%^2d">
        </block>
        </value>
        <value name="B">
        <block type="variables_get" id="B2Z^A/08Ee)7/RPmaoO:">
        </block>
        </value>
        </block>
        </value>
        <block type="variables_set" id="SagM`KaJL1rMfwm7Y#3k">
        <block type="variables_get" id="Pte_tl99JT[=-/(cgh{3">
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="controls_if" id="ot$lj:w=.bWFXSy+#U!!">
        <value name="IF0">
        <block type="logic_compare" id="S]$B_(:yN`iD@#4cnrbt">
        <field name="OP">NEQ</field>
        <value name="A">
        <block type="get_value" id="tKYKdGEvJ{(Ap`z33|3/">
        <field name="OID">zendure-solarflow.0.gDa3tb.nGY7x38q.acMode</field>
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="*-lP0bAkarz+MWbKMpD!">
        <field name="NUM">2</field>
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="hkXp_(9CI|Tlx6@w4O;-">
        <field name="OID">zendure-solarflow.0.gDa3tb.nGY7x38q.control.acMode</field>
        <block type="math_number" id="5kp15tIIz~ILp@rb3kgW">
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="control" id=";Db^:4O1EN|E83*|k[36">
        <field name="OID">zendure-solarflow.0.gDa3tb.nGY7x38q.control.setOutputLimit</field>
        <block type="variables_get" id="cj|vI+5rE;a$Z}XkQz`B">
        </block>
        </value>
        <next>
        <block type="timeouts_cleartimeout" id="cP-3iM|ldCLOjhu8Y-ws">
        <field name="NAME">output_Abzug</field>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </statement>
                                                          <value name="IF1">
                                                            <block type="logic_multi_and" id="rcwQ-{!+**l.RM.=S8yt">
                                                              <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation>
                                                              <value name="AND0">
        <block type="logic_compare" id="vOs6dWh(3vUrB_2{m/NV">
        <field name="OP">GTE</field>
        <value name="A">
        <block type="get_value" id="cyB@uS2tIbt2~(|B$ZF]">
        <field name="OID">zendure-solarflow.0.gDa3tb.nGY7x38q.electricLevel</field>
        </block>
        </value>
        <value name="B">
        <block type="math_number" id=";3DCR]/^X8u}`5XE|_-(">
        <field name="NUM">99</field>
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="AND1">
        <block type="logic_compare" id="[0jp6f!|5%:|l7y7[6t=">
        <field name="OP">EQ</field>
        <value name="A">
        <block type="get_value" id="x`(O@JLy{A,mc*K[~glM">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="h{g.7y^5fuBZ(x}%o,8!">
        </block>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <statement name="DO1">
                                                            <block type="comment" id="%R+{KG.$/r5$P+|4?%Cw">
                                                              <field name="COMMENT">2. Bypass ein wenn Akku voll, AC Modus auf Output 2. Mode</field>
                                                              <next>
        <block type="control" id=";naGVGNG%EO3]/D7la@,">
        <block type="math_number" id="_1woz/)YsVt:d!FqS=:i">
        </block>
        </value>
        </block>
                                                              </next>
                                                            </block>
                                                          </statement>
                                                          <value name="IF2">
                                                            <block type="logic_multi_and" id="RpscAq3vo.ceGvt}lzM;">
                                                              <mutation xmlns="http://www.w3.org/1999/xhtml" items="3"></mutation>
                                                              <value name="AND0">
        <block type="time_compare_ex" id="4Mh;.M3%8}QAkhPEtcv$">
        <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
        <field name="USE_ACTUAL_TIME">TRUE</field>
        <field name="OPTION">between</field>
        <value name="START_TIME">
        <shadow type="text" id="2Km3*[bQnyaNB:XI6]9%">
        <field name="TEXT">06:00</field>
        </shadow>
        </value>
        <value name="END_TIME">
        <shadow type="text" id="KO`i!C([`f|6juoQ~d-d">
        <field name="TEXT">22:59</field>
        </shadow>
        </value>
        </block>
                                                              </value>
                                                              <value name="AND1">
        <block type="logic_compare" id="=;k+]!:`FgPIl(ffM)0z">
        <field name="OP">LT</field>
        <value name="A">
        <block type="get_value" id="o55n7*4D=LYnb:P_11Mb">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="`))[;%51tDu_Jj9qhYs}">
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="AND2">
        <block type="logic_compare" id="BdTZijA^#anVn3j{PwI*">
        <value name="A">
        <block type="variables_get" id="TtqY39_BvS=6H}t)mLEe">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="wjR@%Hg`by9T-|5Qupoe">
        </block>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <statement name="DO2">
                                                            <block type="comment" id="zC5_szd6=wy}Q*]%d_Rb">
                                                              <field name="COMMENT">3. Laden mit PV Überschuss Hyper</field>
                                                              <next>
        <block type="control" id=";512Sny^l9[8H~)*$JIi">
        <field name="OID">zendure-solarflow.0.gDa3tb.nGY7x38q.control.setInputLimit</field>
        <block type="variables_get" id="_p]0p.2.)e;=_p)|+$|v">
        </block>
        </value>
        <next>
        <block type="controls_if" id="0rLs]HZ7;/1{okt~*dfX">
        <value name="IF0">
        <block type="logic_compare" id="Wbb3SQ#qDz^yYA2cpc,Q">
        <value name="A">
        <block type="get_value" id=")^qtiMQK)k{e-0Ni$R*{">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="!F;R8(I#,#[B*X:#oO~.">
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="CCIQ_ICwzn9aV7t#9o%7">
        <block type="math_number" id="tX)1OdbEtqK(Q:y^C3Z^">
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="timeouts_cleartimeout" id="@T7,,}^VeetBp^h*!pnp">
        </block>
        </next>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </statement>
                                                            <block type="comment" id="T1mOiNRi*1jPnM#~?:mM">
                                                              <field name="COMMENT">4.  Ein/Ausgangsleistung auf 0 setzen</field>
                                                              <next>
        <block type="timeouts_settimeout" id="?(Ecr)F7}.Cd/9{8%v+=">
        <field name="NAME">timeout4</field>
        <field name="DELAY">30</field>
        <block type="control" id="Qhy=K`*Kim%|cM0RX[fs">
        <block type="math_number" id="_E5[`;YcRI]zD#G$VW2C">
        </block>
        </value>
        <next>
        <block type="control" id="|[L_^Xt!x3J6MHCL]Mbz">
        <block type="math_number" id="N!gtEfKU|I%=EMCI:Pm@">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
                                                              </next>
                                                            </block>
                                                          </statement>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </next>
        </block>
      </xml>
      Berny-K
      #155
      @tege0
      Hallo, ich teste gerade dieses Blockly zur Null-Einspeisung mit meinem Solarflow 800 Pro. Was ich noch nicht so ganz verstanden habe ist, dass ein Entladen (Einspeisung aus dem Akku ins Haus) nur erfolgt, wenn Leistung der Solarmodule > entladen_ab_pv_leistung ist. Ich hätte gedacht, dass eine Einspeisung erfolgen sollte wenn der Akku einen einen bestimmten Füllstand erreicht, oder sowas.
      Kann mir da vielleicht jemand auf die Sprünge helfen?
      L 1 Antwort Letzte Antwort
      • B Berny-K
        @tege0
        L Online
        L Online
        lesiflo
        schrieb am zuletzt editiert von lesiflo
        #156
        @Berny-K sagte in Script zum Laden/Entladen von Zendure Solarflow:
        @tege0
        Es soll erstmal die PV Leistung genommen werden. Erst wenn die nicht mehr ausreicht kommt der Akku ins Spiel.
        B 2 Antworten Letzte Antwort
        • L lesiflo
          @tege0
          Berny-K
          #157
          @lesiflo Guten Morgen und vielen Dank für die Klärung. Aktuell sieht es so aus als ob die Steuerung einwandfrei läuft. Muss es noch etwas beobachten um die Funktion noch besser zu verstehen.
          • R Offline
            redbull2906
            #158
            Hi Leute,
            wie muss ich meinen 800 Pro einstellen damit ich mir blockly die Steuerung machen kann? Habe keinen SmartMeter und würde die Einstellungen gerne über ioBroker entsprechend anpassen.
            Danke für eure Hilfe
            • L lesiflo
              @tege0
              Berny-K
              #159
              @lesiflo heißt das dann, dass der Akku in der Nacht nie ins Haus einspeist?
              Mein Akku hat jetzt gut 70% und sollte doch eigentlich einspeisen anstatt den Strom aus dem Netz zu beziehen, oder habe ich da einen Denkfehler?
              • B Berny-K
                L Online
                L Online
                lesiflo
                #160
                Nein eigentlich sollte er entladen. Stell mal dein Script hier ein.
                • L lesiflo
                  Berny-K
                  #161
                  @lesiflo Hier mein Script, entladen funktioniert nur wenn ich unter 1. Entladen die und Bedingung raus nehme.
                  • L Online
                    L Online
                    lesiflo
                    #162
                    Ok, macht Sinn. Weiß gar nicht mehr warum ich so gemacht habe. Das Script nutzte ich nicht mehr, hab auf Javascript umgestellt.
                    • L lesiflo
                      Berny-K
                      #163
                      @lesiflo Welche Vorteile siehst du durch die Umstellung auf Javascript?
                      Meinst du das wäre für meine Zwecke (wie das Blockly) auch zweckmäßig und würdest du es teilen?
                      • R redbull2906
                        Hi Leute,
                        Berny-K
                        #164
                        @redbull2906 Hi, ich habe als erstes den Zendure Solarflow Adapter im iobroker installiert, dann in der Zendure App das HEMS deaktiviert und MQTT aktiviert. Danach konnte ich mit dem Blockly die Null-Einspeisung steuern.
                        R 1 Antwort Letzte Antwort
                        • L Online
                          L Online
                          lesiflo
                          #165
                          Mit Javascript kann man wesentlich mehr machen ist aber für Laien etwas schwieriger zu verstehen. Teilen kann ich gerne, es ist aber für 2 Hyper und sehr auf meine Bedürfnisse angepasst. Mein Tipp nimm das Blockly füttere damit eine KI, z.B. ChatGpt und sag das es das Script in JavaScript umwandeln soll. So habe ich auch angefangen. Man sollte aber verstehen was das Javascript macht um Fehler zu finden oder was zu verändern.
                          • L lesiflo
                            Berny-K
                            #166
                            @lesiflo Das ist ne gute Idee die Ki mit dem Blockly zu füttern und ein Javascript daraus zu erstellen. Denke auch, dass man mit JS flexibler und weniger eingeschränkt ist wie mit Blockly. Vielen Dank für den Tipp!
                            • B Berny-K
                              redbull2906
                              #167
                              @Berny-K danke Berny für deine Antwort.
                              Kann ich dazu den mqtt Adapter nutzen?
                              Werden dann auch noch Daten in der Zendure App gezeigt oder brauch ich die dann eigentlich nicht mehr?
                              L B 2 Antworten Letzte Antwort
                              • R redbull2906
                                L Online
                                L Online
                                lesiflo
                                #168
                                @redbull2906 sagte in Script zum Laden/Entladen von Zendure Solarflow:
                                Den MQTT Adapter brauchst du nicht. Im Zendure Adapter auf MQTT stellen. Die App hat dann keine Funktion mehr da du dann komplett lokal arbeitest.
                                • R redbull2906
                                  Berny-K
                                  #169
                                  @redbull2906 Also ich haben keinen zusätzlichen mqtt Broker/Client im iobroker installiert, das geht mit dem integrierten mit dem ich eh schon Tasmota Geräte etc. auslese bzw. Steuere. Die mqtt Daten vom iobroker muss man nur in der App eintragen. In der App sieht man dann nicht mehr all zu viel aber das braucht man auch nicht. Was man sehen möchte kann man auch mit dem VIS oder dem Energiefluss Adapter visualisieren.
                                  • R Offline
                                    redbull2906
                                    #170
                                    Danke für eure Hilfe @berny-k und @lesiflo aber iwie bin ich glaub zu doof dafür, sorry.
                                    Wenn ich im Zendure Adapter Matt auswähle möchte er eine DeviceID - woher bekomme ich die?
                                    Ein weiterer Test mit dem MQTT-Adapter und dessen Dateneingabe in der App liefert mir zwar Daten aber iwie nur alle 1-2 Minuten - das ist doch ein zu großer Delay wie ich finde.
                                    Hab ich da irgendwie einen falschen Ansatz?
                                    • R redbull2906
                                      Berny-K
                                      #171
                                      @redbull2906 Also ich habe im Zendure-Solarflow adapter als Verbindungsmodus Authorization Auth Key ausgewählt und darunter den Auth Key eingeragen (den gab es irgendwie bei der Zendure Cloud Anmeldung.
                                      Ansonsten habe ich in der App nur noch auf Mqtt umgestellt und die iobroker-IP, MQTT-Port, Benutzername und Kennwort eingetragen. Damit funktioniert bei mir auch die Reglung gut und flott.
                                      • R Offline
                                        redbull2906
                                        #172
                                        @berny-k ok, verstehe. dann hab ich schon mal meinen Fehler. Ich hatte den Auth Key geändert auf lokale Mqtt. Dann will der Adapter eine Device ID.
                                        Thx für den Tip werde ich mal so probieren.
                                        Wie ist es in Sachen "Sicherheitsabschlatung" sollte mal z.b. was mit dem Akku sein - macht ihr das ebenfalls über ein Blockly oder laufen trotz der Umstellung diese "Sicherheitsrelevanten" Sachen weiter?
                                        • R redbull2906
                                          Berny-K
                                          #173
                                          @redbull2906 Ich würde sagen, dass man sich da nicht selbst kümmern muss, das sollte das BMS des Akkus regeln, so ist zumindest meine Sicht der Dinge.
