  4. Zigbee v3.1.5 plötzlich keine Verbindung mehr
    6.8k
71 Beiträge 9 Kommentatoren 3.6k Aufrufe 8 Beobachtet
    @tilly
    Starte halt das zigbee subsystem.
    Und warum wird bei dir nodejs 18.20.8 als empfohlene Version angezeigt? Das muss auf aktuellen Kisten v22 sein.
    Zeig mal die Ausgabe von
    iob diag
    tilly
    @Thomas-Braun ```
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Ubuntu 22.04.5 LTS
     Static hostname: iobroker-ubuntu-22-04
           Icon name: computer-vm
             Chassis: vm
      Virtualization: kvm
              Kernel: Linux 5.15.0-164-generic
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    OS is similar to: debian
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     09:44:40 up 1 day, 19:47,  2 users,  load average: 1.10, 0.91, 0.79
    CPU threads: 8
    *** LIFE CYCLE STATUS ***
    Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to                                                      the latest LTS release 'noble' in due time!
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2026-01-26 09:44:40 CET
               Universal time: Mon 2026-01-26 08:44:40 UTC
                     RTC time: Mon 2026-01-26 08:44:40
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    user
    HOME=/home/user
    GROUPS=user adm cdrom sudo dip plugdev lxd iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi                                                     -user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix                                                     '
    *** MEMORY ***
    Mem:            1.8G        1.4G        251M        0.0K        208M        222M
    Swap:           3.0G        1.7G        1.3G
    Total:          4.8G        3.0G        1.5G
    Active iob-Instances:   26
             1811 M total memory
             1351 M used memory
              506 M active memory
              790 M inactive memory
              251 M free memory
               41 M buffer memory
              166 M swap cache
             2952 M total swap
             1670 M used swap
             1282 M free swap
    top - 09:44:41 up 1 day, 19:47,  2 users,  load average: 1.10, 0.91, 0.79
    Tasks: 160 total,   3 running, 157 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 25.3 us, 24.0 sy,  0.0 ni, 38.7 id,  0.0 wa,  0.0 hi,  1.3 si, 10.7 st
    MiB Mem :   1811.3 total,    250.5 free,   1351.6 used,    209.1 buff/cache
    MiB Swap:   2953.0 total,   1282.6 free,   1670.4 used.    221.8 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                        Type   Size  Used Avail Use% Mounted on
    tmpfs                             tmpfs  632M  1.1M  631M   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4    30G   16G   13G  56% /
    tmpfs                             tmpfs  3.1G     0  3.1G   0% /dev/shm
    tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/sda2                         ext4   2.0G  254M  1.6G  14% /boot
    tmpfs                             tmpfs  642M  4.0K  642M   1% /run/user/1000
    [Sat Jan 24 13:57:41 2026] EXT4-fs (dm-0): mounted filesystem with ordered data                                                      mode. Opts: (null). Quota mode: none.
    [Sat Jan 24 13:57:43 2026] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode:                                                      none.
    [Sat Jan 24 13:57:45 2026] EXT4-fs (sda2): mounted filesystem with ordered data                                                      mode. Opts: (null). Quota mode: none.
    Show mounted filesystems:
    TARGET              SOURCE                            FSTYPE   OPTIONS
    /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
    |-/snap/core20/2682 /dev/loop0                        squashfs ro,nodev,relatime                                                     ,errors=continue
    |-/snap/core20/2686 /dev/loop1                        squashfs ro,nodev,relatime                                                     ,errors=continue
    |-/snap/lxd/36558   /dev/loop2                        squashfs ro,nodev,relatime                                                     ,errors=continue
    |-/snap/lxd/36918   /dev/loop3                        squashfs ro,nodev,relatime                                                     ,errors=continue
    |-/snap/snapd/25577 /dev/loop4                        squashfs ro,nodev,relatime                                                     ,errors=continue
    |-/snap/snapd/25935 /dev/loop5                        squashfs ro,nodev,relatime                                                     ,errors=continue
    `-/boot             /dev/sda2                         ext4     rw,relatime
    /var:
    2.5G    /var/
    1.7G    /var/lib
    970M    /var/lib/snapd
    780M    /var/lib/snapd/cache
    589M    /var/log
    Archived and active journals take up 557.5M in the file system.
    /opt/iobroker/backups:
    6.6M    /opt/iobroker/backups/
    4.0K    /opt/iobroker/backups/redistmp
    /opt/iobroker/iobroker-data:
    606M    /opt/iobroker/iobroker-data/
    425M    /opt/iobroker/iobroker-data/files
    108M    /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/echarts.admin
    61M     /opt/iobroker/iobroker-data/files/echarts
    53M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41c                                                     ee985.js.map
    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.j                                                     s.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw                                                     ays prefer the links 'by-id':
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DA                                                     P_L43002RW-if03
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DA                                                     P_L43002RW-if00
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.0
    /usr/bin/node           v22.22.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.22.0-1nodesource1
      Candidate: 22.22.0-1nodesource1
      Version table:
     *** 22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         12.22.9~dfsg-1ubuntu3.6 500
            500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Pac                                                     kages
            500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Pa                                                     ckages
         12.22.9~dfsg-1ubuntu3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker slave      iobroker slave (version: 7.0.7, hostname: iobroker slave, alive, uptime: 157613)
    iobroker-ubuntu-22-04 iobroker-ubuntu-22-04 (version: 7.0.7, hostname: iobroker-ubuntu-22-04, alive, uptime: 157640)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.11
    nodejs modules from github:     1
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    Adapter State
    + system.adapter.admin.1                  : admin                 : iobroker-ubuntu-22-04                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker-ubuntu-22-04                    -  enabled
      system.adapter.backitup.0               : backitup              : iobroker-ubuntu-22-04                    - disabled
      system.adapter.bring.0                  : bring                 : iobroker-ubuntu-22-04                    - disabled
    + system.adapter.discovery.0              : discovery             : iobroker-ubuntu-22-04                    -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker-ubuntu-22-04                    -  enabled
      system.adapter.echarts.0                : echarts               : iobroker-ubuntu-22-04                    - disabled
      system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker-ubuntu-22-04                    - disabled
      system.adapter.flot.0                   : flot                  : iobroker-ubuntu-22-04                    - disabled
    + system.adapter.hass.0                   : hass                  : iobroker-ubuntu-22-04                    -  enabled, port: 8123
      system.adapter.ical.0                   : ical                  : iobroker-ubuntu-22-04                    -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-ubuntu-22-04                    - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-ubuntu-22-04                    -  enabled
    + system.adapter.info.0                   : info                  : iobroker-ubuntu-22-04                    -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker-ubuntu-22-04                    -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker-ubuntu-22-04                    -  enabled
      system.adapter.kecontact.0              : kecontact             : iobroker-ubuntu-22-04                    - disabled
    + system.adapter.midea.0                  : midea                 : iobroker-ubuntu-22-04                    -  enabled
      system.adapter.mihome-lamp.0            : mihome-lamp           : iobroker-ubuntu-22-04                    - disabled, port: 54321
    + system.adapter.modbus.0                 : modbus                : iobroker-ubuntu-22-04                    -  enabled
    + system.adapter.modbus.1                 : modbus                : iobroker-ubuntu-22-04                    -  enabled
      system.adapter.modbus.2                 : modbus                : iobroker-ubuntu-22-04                    - disabled
    + system.adapter.modbus.3                 : modbus                : iobroker-ubuntu-22-04                    -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker-ubuntu-22-04                    -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.mqtt.1                   : mqtt                  : iobroker-ubuntu-22-04                    - disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : iobroker-ubuntu-22-04                    -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.octoprint.0              : octoprint             : iobroker-ubuntu-22-04                    - disabled
      system.adapter.openweathermap.0         : openweathermap        : iobroker-ubuntu-22-04                    -  enabled
      system.adapter.parser.0                 : parser                : iobroker-ubuntu-22-04                    - disabled
      system.adapter.pvforecast.0             : pvforecast            : iobroker-ubuntu-22-04                    - disabled
      system.adapter.sayit.0                  : sayit                 : iobroker-ubuntu-22-04                    - disabled
    + system.adapter.shelly.0                 : shelly                : iobroker-ubuntu-22-04                    -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iobroker-ubuntu-22-04                    -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker-ubuntu-22-04                    -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.sonoff.0                 : sonoff                : iobroker-ubuntu-22-04                    - disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : iobroker-ubuntu-22-04                    -  enabled
      system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker-ubuntu-22-04                    - disabled
    + system.adapter.sql.0                    : sql                   : iobroker-ubuntu-22-04                    -  enabled, port: 3306
      system.adapter.sun2000.0                : sun2000               : iobroker-ubuntu-22-04                    - disabled, port: 502
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker slave                           -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker-ubuntu-22-04                    -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : iobroker-ubuntu-22-04                    - disabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker-ubuntu-22-04                    -  enabled
      system.adapter.tuya.0                   : tuya                  : iobroker-ubuntu-22-04                    - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-ubuntu-22-04                    - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-ubuntu-22-04                    -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-ubuntu-22-04                    - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker-ubuntu-22-04                    -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-ubuntu-22-04                    -  enabled
      system.adapter.vis.0                    : vis                   : iobroker-ubuntu-22-04                    -  enabled
    + system.adapter.web.0                    : web                   : iobroker-ubuntu-22-04                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wled.0                   : wled                  : iobroker-ubuntu-22-04                    - disabled
    + system.adapter.yahka.0                  : yahka                 : iobroker-ubuntu-22-04                    -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker-ubuntu-22-04                    -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.13   , installed 3.3.13
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
    Adapter    "firetv"       : 2.1.0    , installed 2.1.0
    Adapter    "haassohn"     : 1.0.9    , installed 1.0.9
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "kecontact"    : 3.4.0    , installed 3.4.0
    Adapter    "midea"        : 0.0.7    , installed 0.0.7
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "parser"       : 2.2.4    , installed 2.2.4
    Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "shelly"       : 10.5.2   , installed 10.5.2
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "sprinklecontrol": 0.2.19 , installed 0.2.19
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "sun2000"      : 2.3.5    , installed 2.3.5
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "yahka"        : 1.1.5    , installed 1.1.5
    Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
    Objects and States
    Objects:        19511
    States:         13675
    [AHit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       806        658/iobroker.js-con
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       21342      658/iobroker.js-con
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          18706      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          23414      723/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:39345         0.0.0.0:*               LISTEN      1001       5420566    1191/io.yahka.0
    tcp        0      0 0.0.0.0:33060           0.0.0.0:*               LISTEN      115        22187      773/mysqld
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       25660      1033/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       5550982    3870554/io.mqtt.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       26638      1219/io.shelly.1
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       5550983    3870554/io.mqtt.0
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        491        638/systemd-resolve
    tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      115        23543      773/mysqld
    tcp6       0      0 :::111                  :::*                    LISTEN      0          18707      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          23425      723/sshd: /usr/sbin
    tcp6       0      0 :::45471                :::*                    LISTEN      1001       24749      1191/io.yahka.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21417      947/io.admin.1
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       26414      1917/io.web.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       25078      1391/io.simple-api.
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       24730      1172/io.sonos.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22509      1191/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22508      1191/io.yahka.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24709      1157/io.shelly.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        490        638/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          164        1/init
    udp6       0      0 fe80::3cf8:f2ff:fe8:546 :::*                                101        496        636/systemd-network
    udp6       0      0 :::111                  :::*                                0          165        1/init
    2026-01-26 09:46:26.843  - info: hass.0 (19952) State changed for unknown object entities.sensor.keba_p30_max_current.device_class. Please restart the adapter to resync the objects.
    2026-01-26 09:46:26.984  - info: hass.0 (19952) State changed for unknown object entities.sensor.shellypro3em_34987a44206c_phase_a_apparent_power.state. Please restart the adapter to resync the objects.
    2026-01-26 09:46:26.985  - info: hass.0 (19952) State changed for unknown object entities.sensor.shellypro3em_34987a44206c_phase_a_apparent_power.state_class. Please restart the adapter to resync the objects.
    2026-01-26 09:46:26.985  - info: hass.0 (19952) State changed for unknown object entities.sensor.shellypro3em_34987a44206c_phase_a_apparent_power.device_class. Please restart the adapter to resync the objects.
    2026-01-26 09:46:26.985  - info: hass.0 (19952) State changed for unknown object entities.sensor.shellypro3em_34987a44206c_phase_b_apparent_power.state. Please restart the adapter to resync the objects.
    2026-01-26 09:46:26.985  - info: hass.0 (19952) State changed for unknown object entities.sensor.shellypro3em_34987a44206c_phase_b_apparent_power.state_class. Please restart the adapter to resync the objects.
    2026-01-26 09:46:26.985  - info: hass.0 (19952) State changed for unknown object entities.sensor.shellypro3em_34987a44206c_phase_b_apparent_power.device_class. Please restart the adapter to resync the objects.
    2026-01-26 09:46:26.986  - info: hass.0 (19952) State changed for unknown object entities.sensor.shellypro3em_34987a44206c_phase_c_apparent_power.state. Please restart the adapter to resync the objects.
    2026-01-26 09:46:26.986  - info: hass.0 (19952) State changed for unknown object entities.sensor.shellypro3em_34987a44206c_phase_c_apparent_power.state_class. Please restart the adapter to resync the objects.
    2026-01-26 09:46:26.986  - info: hass.0 (19952) State changed for unknown object entities.sensor.shellypro3em_34987a44206c_phase_c_apparent_power.device_class. Please restart the adapter to resync the objects.
    2026-01-26 09:46:26.988  - info: hass.0 (19952) State changed for unknown object entities.sensor.shellypro3em_34987a44206c_total_apparent_power.state. Please restart the adapter to resync the objects.
    2026-01-26 09:46:26.988  - info: hass.0 (19952) State changed for unknown object entities.sensor.shellypro3em_34987a44206c_total_apparent_power.state_class. Please restart the adapter to resync the objects.
    2026-01-26 09:46:26.988  - info: hass.0 (19952) State changed for unknown object entities.sensor.shellypro3em_34987a44206c_total_apparent_power.device_class. Please restart the adapter to resync the objects.
    2026-01-26 09:46:28.180  - info: hass.0 (19952) State changed for unknown object entities.image.fritz_box_7490_fritz_box_gastzugang.state. Please restart the adapter to resync the objects.
    2026-01-26 09:46:28.181  - info: hass.0 (19952) State changed for unknown object entities.image.fritz_box_7490_fritz_box_gastzugang.access_token. Please restart the adapter to resync the objects.
    2026-01-26 09:46:28.181  - info: hass.0 (19952) State changed for unknown object entities.image.fritz_box_7490_fritz_box_gastzugang.entity_picture. Please restart the adapter to resync the objects.
    2026-01-26 09:46:29.500  - info: hass.0 (19952) State changed for unknown object entities.sensor.grid_l1.state. Please restart the adapter to resync the objects.
    2026-01-26 09:46:29.506  - info: hass.0 (19952) State changed for unknown object entities.sensor.grid_l2.state. Please restart the adapter to resync the objects.
    2026-01-26 09:46:29.568  - info: hass.0 (19952) State changed for unknown object entities.sensor.grid_l3.state. Please restart the adapter to resync the objects.
    2026-01-26 09:46:32.147  - info: hass.0 (19952) State changed for unknown object entities.sensor.keba_p30_max_current.state. Please restart the adapter to resync the objects.
    2026-01-26 09:46:32.148  - info: hass.0 (19952) State changed for unknown object entities.sensor.keba_p30_max_current.max_current_hardware. Please restart the adapter to resync the objects.
    2026-01-26 09:46:32.148  - info: hass.0 (19952) State changed for unknown object entities.sensor.keba_p30_max_current.device_class. Please restart the adapter to resync the objects.
    2026-01-26 09:46:32.249  - info: hass.0 (19952) State changed for unknown object entities.sensor.keba_p30_max_current.state. Please restart the adapter to resync the objects.
    2026-01-26 09:46:32.249  - info: hass.0 (19952) State changed for unknown object entities.sensor.keba_p30_max_current.max_current_hardware. Please restart the adapter to resync the objects.
    2026-01-26 09:46:32.250  - info: hass.0 (19952) State changed for unknown object entities.sensor.keba_p30_max_current.device_class. Please restart the adapter to resync the objects.
    iob diag has finished.
    • AsgothianA Asgothian
      @tilly sagte in Zigbee v3.1.5 plötzlich keine Verbindung mehr:
      Plötzlich bekomme ich keine Verbindung mehr zum Zigbee Stick.
      Plötzlich.. direkt nach einem Update auf 3.1.5. Dieses Detail hast du nicht erwähnt.
      Kann mir jemand helfen?
      Bestimmt. Kannst du auch selber. Doku Lesen:
      https://github.com/ioBroker/ioBroker.zigbee/wiki und/oder https://github.com/ioBroker/ioBroker.zigbee/blob/master/docs/en/readme.md
      Ansonsten: @mickemup hat den entscheidenden Hinweis bereits gegeben.
      A.
      tilly
      @Asgothian
      Ne nicht nach dem Update
      Aber es läuft wieder, ich glaube unter Bindings war ein Button zum Koppeln, seitdem läuft es.
      arteckA AsgothianA 2 Antworten Letzte Antwort
      • T tilly
        @Asgothian
        arteckA Offline
        arteckA Offline
        arteck
        und was hat das mit deinem Problem zu tun ???
        • T tilly
          @Asgothian
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @Asgothian
          Muss entweder nach update, oder es hat jemand gespielt. (Backup zurück gespielt oder ähnliches).
          Der Haken ist mit dem Update 2.x auf 3.x dazu gekommen. Vielleicht hast du nach dem update einmal 'manuell' start gedrückt. Den Haken kann man nicht via Script / Binding / Sonstiges setzen / löschen. Der verschwindet also nicht 'von alleine'. Und auch nicht ohne das der Adapter neu gestartet wird, von demjenigen der den Haken entfernt.
          A.
            @Asgothian
            A.
            tilly
            @Asgothian das wird es gewesen sein.
            Kann mir noch jemand sagen, warum mir noch nodejs 18.20.8 als empfohlene Version angezeigt wird?
            • T tilly
              wo und wie?
              bitte zeigen.
                tilly
                • T tilly
                  @Thomas-Braun ```
                  Script v.2025-08-09
                  *** BASE SYSTEM ***
                           Chassis: vm
                    Virtualization: kvm
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                  CPU threads: 8
                                NTP service: active
                            RTC in local TZ: no
                  user
                  HOME=/home/user
                  iobroker
                  HOME=/home/iobroker
                  Display-Manager:
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                           1811 M total memory
                           1351 M used memory
                            506 M active memory
                            251 M free memory
                             41 M buffer memory
                            166 M swap cache
                           2952 M total swap
                           1670 M used swap
                           1282 M free swap
                  *** FILESYSTEM ***
                  /var:
                  2.5G    /var/
                  1.7G    /var/lib
                  970M    /var/lib/snapd
                  589M    /var/log
                  USB-Devices by-id:
                  HINT:
                  /dev/ttyACM0
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/npm            10.9.4
                  /usr/bin/npx            10.9.4
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  admin:          7.7.22
                  javascript:     9.0.11
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        19511
                  States:         13675
                  Pending Updates: 0
                  arteckA Offline
                  arteckA Offline
                  arteck
                  im ernst
                  • T tilly
                    @tilly
                    Da ist mit Sicherheit der Rest auch komplett veraltet.
                      tilly
                      Ok installiere gerade eine neue Version Ubuntu Server 24.04.3 LTS.
                      Kann ich ein komplettes Backup von Iobroker machen und in das neue System einspielen?
                      • T tilly
                        Klar. Dazu verwendet man am besten den Backitup-Adapter.
                        Es empfiehlt sich allerdings mit einem 'ioBroker auf aktuellem Stand' umzuziehen.
                        Abgesoffene Versionsstände bekommst du nämlich nur mit Schwierigkeiten wieder eingespielt.
                        Und statt Schnubbibuntu würde ich da auch das aktuelle Debian empfehlen.
                          tilly
                          Umzug geht weiter, leider bekomme ich zum Zigbee keine Verbindung.
                          zigbee.0
                          2026-02-07 11:19:02.483	error	Failed to start Zigbee: no message given
                          zigbee.0
                          2026-02-07 11:19:02.482	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
                          zigbee.0
                          2026-02-07 11:19:02.253	info	Unable to obtain herdsman settings
                          zigbee.0
                          2026-02-07 11:18:41.290	debug	getDevices called from system.adapter.admin.1 with command "getDevices" without ID
                          zigbee.0
                          2026-02-07 11:18:41.280	debug	getCoordinatorInfo result: {"installSource":"iobroker.zigbee@3.1.5","channel":"26","port":"/dev/ttyACM0","installedVersion":"3.1.5","type":"zstack","revision":"not connected","version":"not connected","herdsman":"6.4.2","converters":"25.31.0","autostart":true}
                          zigbee.0
                          2026-02-07 11:18:41.227	debug	get groupes called with {"command":"getGroups","message":{},"from":"system.adapter.admin.1","callback":{"message":{},"id":41,"ack":false,"time":1770459521168},"_id":64084252} disconnected
                          zigbee.0
                          2026-02-07 11:18:41.179	debug	get groupes called with {"command":"getGroups","message":{},"from":"system.adapter.admin.1","callback":{"message":{},"id":41,"ack":false,"time":1770459521168},"_id":64084252}
                          zigbee.0
                          2026-02-07 11:18:41.178	debug	Commands: Command getGroups is unknown
                          zigbee.0
                          2026-02-07 11:18:41.176	debug	readNvBackup returns {"channel":26,"precfgkey":"01030507090b0d0f00020406080a0c0d","extPanID":"d9dddddddcddddcd","panID":6728}
                          zigbee.0
                          2026-02-07 11:18:41.173	debug	readNvBackup called
                          zigbee.0
                          2026-02-07 11:18:35.581	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2026_02_07-11_18_35.tar.gz success
                          zigbee.0
                          2026-02-07 11:18:35.542	info	Starting Zigbee-Herdsman
                          zigbee.0
                          2026-02-07 11:18:35.541	info	configured transmit power : high
                          zigbee.0
                          2026-02-07 11:18:35.538	info	Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.4.2)
                          zigbee.0
                          2026-02-07 11:18:35.511	info	Starting Adapter npm ...
                          zigbee.0
                          2026-02-07 11:18:35.510	info	Autostart Zigbee subsystem
                          zigbee.0
                          2026-02-07 11:18:35.509	info	--- creating device debug ---
                          zigbee.0
                          2026-02-07 11:18:35.334	info	init localConfig
                          zigbee.0
                          2026-02-07 11:18:35.329	info	Adapter ready - starting subsystems. Adapter is running in silly mode.
                          zigbee.0
                          2026-02-07 11:18:35.249	info	starting. Version 3.1.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v22.22.0, js-controller: 7.0.7
                          zigbee.0
                          2026-02-07 11:18:34.653	debug	Plugin sentry Initialize Plugin (enabled=true)
                          zigbee.0
                          2026-02-07 11:18:34.559	debug	States connected to redis: 0.0.0.0:9000
                          zigbee.0
                          2026-02-07 11:18:34.425	debug	States create User PubSub Client
                          zigbee.0
                          2026-02-07 11:18:34.424	debug	States create System PubSub Client
                          zigbee.0
                          2026-02-07 11:18:34.379	debug	Redis States: Use Redis connection: 0.0.0.0:9000
                          zigbee.0
                          2026-02-07 11:18:34.279	debug	Objects connected to redis: 0.0.0.0:9001
                          zigbee.0
                          2026-02-07 11:18:34.267	debug	Objects client initialize lua scripts
                          zigbee.0
                          2026-02-07 11:18:34.111	debug	Objects create User PubSub Client
                          zigbee.0
                          2026-02-07 11:18:34.109	debug	Objects create System PubSub Client
                          zigbee.0
                          2026-02-07 11:18:34.106	debug	Objects client ready ... initialize now
                          zigbee.0
                          2026-02-07 11:18:34.028	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
                          Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
                          • T tilly
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            Verwende einen Link 'by-id' zu dem USB-Stick und zieh den danach raus, 1 Minute warten, wieder einstecken.
                              tilly
                              @Thomas-Braun weiß nicht genau was du damit meinst, aber wenn ich
                              ls -la /dev/serial/by-id
                              eingebe, erscheint folgendes, was auch beim Zigbee unter Hardware eingetragen ist.
                              • T tilly
                                @tilly
                                Du sollst da aber NICHT /dev/ttyACM0 eintragen sondern den Link 'by-id'.
                                (Denn ich wegen sinnfreier Screenshots von Konsolentext nicht kopieren kann. Sowas NIE als Screenshot, IMMER als Text in CodeTags hier rein)
                                  @tilly
                                  tilly
                                  @Thomas-Braun stehe gerade auf dem Schlauch. So?
                                  /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L43002RW-if00
                                  Das merkwürdige ist, ohne das ich was geändert habe, hat er plötzlich eine Verbindung?!
                                  total 0
                                  drwxr-xr-x 2 root root 80 Feb  7 11:11 .
                                  drwxr-xr-x 4 root root 80 Feb  7 11:11 ..
                                  lrwxrwxrwx 1 root root 13 Feb  7 11:11 usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L43002RW-if00 -> ../../ttyACM0
                                  lrwxrwxrwx 1 root root 13 Feb  7 11:11 usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L43002RW-if03 -> ../../ttyACM1
                                  superpoli@iobroker:~$
                                  • T tilly
                                    total 0
                                    Ja.
                                    Die Links stehen übrigens u. a. auch in der Ausgabe von
                                    iob diag
                                    drin. Fertig zum herauskopieren.
                                    • T tilly
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      -- hier stand usinn, sorry.--
                                        tilly
                                        Jetzt habe ich noch Proble mit SQL.
                                        sql.0
                                        2026-02-09 09:19:25.586	error	Error: connect ECONNREFUSED 127.0.0.1:3306
                                        sql.0
                                        2026-02-09 09:19:25.574	debug	Borrow connection from pool: 1 now
                                        Obwohl Backup gemacht und wieder eingespielt:
                                        Last login: Sat Feb  7 11:42:41 2026 from 192.168.115.26
                                        superpoli@iobroker:~$ systemctl status mysql.service
                                        Unit mysql.service could not be found.
                                        • T tilly
                                          sql.0
                                          sql.0
                                          Bitte einen neuen Thread für ein neues Problem.
