  3. Einsteigerfragen
  4. ioBroker: Wärmpepumpe - Nachtabsenkung nicht deaktiviert
    5.3k
27 Beiträge 8 Kommentatoren 1.2k Aufrufe 6 Beobachtet
  • dogfight76D dogfight76
    @Homoran sagte in ioBroker: Wärmpepumpe - Nachtabsenkung nicht deaktiviert:
    Ich nehme an dass um 04:30 irgendein Zeittrigger läuft, da nutzt auch nur 1 Sekunde später keinerlei Eingreifen mehr. Das verwischt nur noch alle Spuren.
    Warum zeigst du nicht dein log um +/- 0430?
    Um die Uhrzeit steht da nichts:
    2026-01-31 01:05:37.589 - info: admin.0 (9521) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 01:05:45.801 - info: web.0 (9801) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 01:09:02.616 - info: admin.0 (9521) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
    2026-01-31 01:10:15.820 - info: web.0 (9801) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
    2026-01-31 02:09:16.228 - info: admin.0 (9521) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 02:09:26.350 - info: web.0 (9801) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 02:12:56.240 - info: admin.0 (9521) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
    2026-01-31 02:13:56.370 - info: web.0 (9801) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
    2026-01-31 03:05:35.970 - info: admin.0 (9521) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 03:05:45.318 - info: web.0 (9801) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 03:08:56.004 - info: admin.0 (9521) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
    2026-01-31 03:10:15.795 - info: web.0 (9801) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
    2026-01-31 03:37:25.236 - info: cloud.0 (752835) Connection changed: disconnect
    2026-01-31 03:38:25.269 - info: cloud.0 (752835) Trying to connect as system.user.admin to cloud
    2026-01-31 03:38:25.447 - info: cloud.0 (752835) Connection changed: connect
    2026-01-31 05:04:38.083 - info: mqtt.0 (9669) Client [HeishaMon] connection closed: timeout
    2026-01-31 05:04:42.882 - info: mqtt.0 (9669) Client [HeishaMon] connected with secret 1769832282875_1277
    2026-01-31 05:04:42.907 - info: mqtt.0 (9669) Client [HeishaMon] subscribes on "Waermepumpe/commands/#" with regex /^Waermepumpe\.commands\..*/
    2026-01-31 05:04:42.908 - info: mqtt.0 (9669) Client [HeishaMon] subscribes on "Waermepumpe/commands/#" with regex /^mqtt\.0\.Waermepumpe\.commands\..*/
    2026-01-31 05:04:42.917 - info: mqtt.0 (9669) Client [HeishaMon] subscribes on "Waermepumpe/gpio/#" with regex /^Waermepumpe\.gpio\..*/
    2026-01-31 05:04:42.918 - info: mqtt.0 (9669) Client [HeishaMon] subscribes on "Waermepumpe/gpio/#" with regex /^mqtt\.0\.Waermepumpe\.gpio\..*/
    2026-01-31 05:04:42.918 - info: mqtt.0 (9669) Client [HeishaMon] subscribes on "mqtt.0.Waermepumpe.SendRawValue"
    2026-01-31 07:57:30.060 - info: admin.0 (9521) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 07:57:35.939 - info: web.0 (9801) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 07:57:40.008 - info: web.0 (9801) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
    2026-01-31 07:57:40.687 - info: web.0 (9801) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 07:58:11.993 - info: admin.0 (9521) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
    2026-01-31 07:58:12.065 - info: admin.0 (9521) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 07:58:12.142 - info: admin.0 (9521) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
    2026-01-31 07:58:12.915 - info: admin.0 (9521) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 07:58:47.436 - info: web.0 (9801) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
    2026-01-31 07:58:50.040 - info: web.0 (9801) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 07:59:28.746 - info: web.0 (9801) State value to set for "0_userdata.0.Waermepumpe.Heizkurve_ein_aus" has to be type "boolean" but received type "number"
    2026-01-31 07:59:35.465 - info: web.0 (9801) State value to set for "0_userdata.0.Waermepumpe.Heizkurve_ein_aus" has to be type "boolean" but received type "number"
    2026-01-31 07:59:40.680 - info: web.0 (9801) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
    2026-01-31 07:59:41.117 - info: web.0 (9801) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 08:00:11.502 - info: web.0 (9801) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
    2026-01-31 08:00:11.975 - info: web.0 (9801) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 08:00:25.450 - info: admin.0 (9521) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 08:00:28.885 - info: admin.0 (9521) <== Disconnect system.user.admin from ::ffff:192.168.178.53
    2026-01-31 08:00:43.363 - warn: web.0 (9801) setTimeout called, but adapter is shutting down
    2026-01-31 08:00:43.359 - info: admin.0 (9521) terminating http server on port 8081
    2026-01-31 08:00:43.375 - info: cloud.0 (752835) Connection changed: disconnect
    2026-01-31 08:00:43.376 - info: admin.0 (9521) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
    2026-01-31 08:00:43.382 - info: cloud.0 (752835) Connection lost
    2026-01-31 08:00:43.359 - info: chromecast.0 (9630) Destroying chromecast scanner
    2026-01-31 08:00:43.372 - info: chromecast.0 (9630) Shield Gästezimmer - client disconnected
    2026-01-31 08:00:43.373 - info: chromecast.0 (9630) SHIELD - client disconnected
    2026-01-31 08:00:43.355 - info: jarvis.0 (9723) Adapter stopped und unloaded.
    2026-01-31 08:00:43.364 - info: javascript.0 (9579) script.js.common.Meine_Geraete.Heizung.Abtauungen_zaehlen: Stopping script
    2026-01-31 08:00:43.392 - info: javascript.0 (9579) script.js.common.Meine_Geraete.Heizung.Akt_VL: Stopping script
    2026-01-31 08:00:43.392 - info: javascript.0 (9579) script.js.common.Meine_Geraete.Heizung.COP_rechnen: Stopping script
    2026-01-31 08:00:43.397 - info: javascript.0 (9579) script.js.common.Meine_Geraete.Heizung.Kuehlen_1_Stunde: Stopping script
    2026-01-31 08:00:43.398 - info: javascript.0 (9579) script.js.common.Meine_Geraete.Heizung.Nachtabsenkung: Stopping script
    2026-01-31 08:00:43.398 - info: javascript.0 (9579) script.js.common.Meine_Geraete.Heizung.Warmwasser_1_Stunde: Stopping script
    2026-01-31 08:00:43.398 - info: javascript.0 (9579) script.js.common.Meine_Geraete.Heizung.Warmwassertimer: Stopping script
    2026-01-31 08:00:43.354 - info: host.ioBroker-neu received SIGTERM
    2026-01-31 08:00:43.382 - info: host.ioBroker-neu stopInstance system.adapter.admin.0 (force=false, process=true)
    2026-01-31 08:00:43.385 - info: host.ioBroker-neu stopInstance system.adapter.history.0 (force=false, process=true)
    2026-01-31 08:00:43.386 - info: host.ioBroker-neu stopInstance system.adapter.influxdb.0 (force=false, process=false)
    2026-01-31 08:00:43.389 - info: host.ioBroker-neu stopInstance system.adapter.javascript.0 (force=false, process=true)
    2026-01-31 08:00:43.390 - info: host.ioBroker-neu stopInstance system.adapter.backitup.0 (force=false, process=true)
    2026-01-31 08:00:43.391 - info: host.ioBroker-neu stopInstance system.adapter.chromecast.0 (force=false, process=true)
    2026-01-31 08:00:43.392 - info: host.ioBroker-neu stopInstance system.adapter.cloud.0 (force=false, process=true)
    2026-01-31 08:00:43.393 - info: host.ioBroker-neu stopInstance system.adapter.hm-rega.0 (force=false, process=false)
    2026-01-31 08:00:43.394 - info: host.ioBroker-neu stopInstance system.adapter.hm-rpc.0 (force=false, process=false)
    2026-01-31 08:00:43.394 - info: host.ioBroker-neu stopInstance system.adapter.hm-rpc.1 (force=false, process=false)
    2026-01-31 08:00:43.395 - info: host.ioBroker-neu stopInstance system.adapter.hm-rpc.2 (force=false, process=false)
    2026-01-31 08:00:43.395 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
    2026-01-31 08:00:43.396 - info: host.ioBroker-neu stopInstance system.adapter.net-tools.0 (force=false, process=true)
    2026-01-31 08:00:43.396 - info: host.ioBroker-neu stopInstance system.adapter.ping.0 (force=false, process=true)
    2026-01-31 08:00:43.397 - info: host.ioBroker-neu stopInstance system.adapter.solarlog.0 (force=false, process=false)
    2026-01-31 08:00:43.398 - info: host.ioBroker-neu stopInstance system.adapter.tr-064.0 (force=false, process=false)
    2026-01-31 08:00:43.398 - info: host.ioBroker-neu stopInstance system.adapter.discovery.0 (force=false, process=false)
    2026-01-31 08:00:43.399 - info: host.ioBroker-neu stopInstance system.adapter.fritzdect.0 (force=false, process=false)
    2026-01-31 08:00:43.399 - info: host.ioBroker-neu stopInstance system.adapter.jarvis.0 (force=false, process=true)
    2026-01-31 08:00:43.400 - info: host.ioBroker-neu stopInstance system.adapter.time-switch.0 (force=false, process=true)
    2026-01-31 08:00:43.401 - info: host.ioBroker-neu stopInstance system.adapter.vis-inventwo.0 (force=false, process=true)
    2026-01-31 08:00:43.402 - info: host.ioBroker-neu stopInstance system.adapter.vis-timeandweather.0 (force=false, process=false)
    2026-01-31 08:00:43.402 - info: host.ioBroker-neu stopInstance system.adapter.vis.0 (force=false, process=false)
    2026-01-31 08:00:43.402 - info: host.ioBroker-neu stopInstance system.adapter.web.0 (force=false, process=true)
    2026-01-31 08:00:43.416 - info: chromecast.0 (9630) Shield Gästezimmer - Connected client
    2026-01-31 08:00:43.367 - info: time-switch.0 (9736) cleaning everything up...
    2026-01-31 08:00:43.421 - info: chromecast.0 (9630) SHIELD - Connected client
    2026-01-31 08:00:43.376 - info: backitup.0 (9615) cleaned everything up...
    2026-01-31 08:00:43.371 - info: vis-inventwo.0 (9758) cleaned everything up...
    2026-01-31 08:00:43.479 - info: admin.0 (9521) Got terminate signal TERMINATE_YOURSELF
    2026-01-31 08:00:43.481 - info: javascript.0 (9579) Got terminate signal TERMINATE_YOURSELF
    2026-01-31 08:00:43.484 - info: chromecast.0 (9630) Got terminate signal TERMINATE_YOURSELF
    2026-01-31 08:00:43.483 - info: backitup.0 (9615) Got terminate signal TERMINATE_YOURSELF
    2026-01-31 08:00:43.486 - info: cloud.0 (752835) Got terminate signal TERMINATE_YOURSELF
    2026-01-31 08:00:43.488 - info: mqtt.0 (9669) Got terminate signal TERMINATE_YOURSELF
    2026-01-31 08:00:43.492 - info: time-switch.0 (9736) Got terminate signal TERMINATE_YOURSELF
    2026-01-31 08:00:43.493 - info: jarvis.0 (9723) Got terminate signal TERMINATE_YOURSELF
    2026-01-31 08:00:43.496 - info: chromecast.0 (9630) terminating
    2026-01-31 08:00:43.498 - info: mqtt.0 (9669) terminating
    2026-01-31 08:00:43.503 - info: admin.0 (9521) terminating
    2026-01-31 08:00:43.504 - info: cloud.0 (752835) terminating
    2026-01-31 08:00:43.497 - info: jarvis.0 (9723) terminating
    2026-01-31 08:00:43.505 - info: time-switch.0 (9736) terminating
    2026-01-31 08:00:43.499 - info: jarvis.0 (9723) Terminated (NO_ERROR): Without reason
    2026-01-31 08:00:43.506 - info: time-switch.0 (9736) Terminated (NO_ERROR): Without reason
    2026-01-31 08:00:43.502 - info: chromecast.0 (9630) Terminated (NO_ERROR): Without reason
    2026-01-31 08:00:43.509 - info: vis-inventwo.0 (9758) Got terminate signal TERMINATE_YOURSELF
    2026-01-31 08:00:43.505 - info: admin.0 (9521) Terminated (NO_ERROR): Without reason
    2026-01-31 08:00:43.506 - info: cloud.0 (752835) Terminated (NO_ERROR): Without reason
    2026-01-31 08:00:43.514 - info: web.0 (9801) Got terminate signal TERMINATE_YOURSELF
    2026-01-31 08:00:43.499 - info: mqtt.0 (9669) Terminated (NO_ERROR): Without reason
    2026-01-31 08:00:43.521 - info: host.ioBroker-neu stopInstance system.adapter.admin.0 send kill signal
    2026-01-31 08:00:43.528 - info: vis-inventwo.0 (9758) terminating
    2026-01-31 08:00:43.531 - info: host.ioBroker-neu stopInstance system.adapter.javascript.0 send kill signal
    2026-01-31 08:00:43.532 - info: host.ioBroker-neu stopInstance system.adapter.backitup.0 send kill signal
    2026-01-31 08:00:43.532 - info: host.ioBroker-neu stopInstance system.adapter.chromecast.0 send kill signal
    2026-01-31 08:00:43.532 - info: host.ioBroker-neu stopInstance system.adapter.cloud.0 send kill signal
    2026-01-31 08:00:43.533 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
    2026-01-31 08:00:43.533 - info: host.ioBroker-neu stopInstance system.adapter.net-tools.0 send kill signal
    2026-01-31 08:00:43.533 - info: host.ioBroker-neu stopInstance system.adapter.ping.0 send kill signal
    2026-01-31 08:00:43.533 - info: host.ioBroker-neu stopInstance system.adapter.jarvis.0 send kill signal
    2026-01-31 08:00:43.534 - info: host.ioBroker-neu stopInstance system.adapter.time-switch.0 send kill signal
    2026-01-31 08:00:43.534 - info: host.ioBroker-neu stopInstance system.adapter.vis-inventwo.0 send kill signal
    2026-01-31 08:00:43.529 - info: vis-inventwo.0 (9758) Terminated (NO_ERROR): Without reason
    2026-01-31 08:00:43.489 - info: net-tools.0 (9684) Got terminate signal TERMINATE_YOURSELF
    2026-01-31 08:00:43.544 - info: net-tools.0 (9684) terminating
    2026-01-31 08:00:43.546 - info: net-tools.0 (9684) Terminated (NO_ERROR): Without reason
    2026-01-31 08:00:43.552 - info: host.ioBroker-neu stopInstance system.adapter.web.0 send kill signal
    2026-01-31 08:00:43.553 - info: backitup.0 (9615) terminating
    2026-01-31 08:00:43.556 - info: backitup.0 (9615) Terminated (NO_ERROR): Without reason
    2026-01-31 08:00:43.489 - info: ping.0 (9705) Got terminate signal TERMINATE_YOURSELF
    2026-01-31 08:00:43.497 - info: history.0 (9532) terminating
    2026-01-31 08:00:43.558 - info: history.0 (9532) Terminated (NO_ERROR): Without reason
    2026-01-31 08:00:43.644 - info: javascript.0 (9579) terminating
    2026-01-31 08:00:43.646 - info: javascript.0 (9579) Terminated (NO_ERROR): Without reason
    2026-01-31 08:00:43.861 - info: javascript.0 (9579) terminating
    2026-01-31 08:00:43.875 - info: ping.0 (9705) terminating
    2026-01-31 08:00:43.875 - info: net-tools.0 (9684) terminating
    2026-01-31 08:00:43.875 - info: web.0 (9801) terminating
    2026-01-31 08:00:43.877 - info: web.0 (9801) Terminated (NO_ERROR): Without reason
    2026-01-31 08:00:43.878 - info: ping.0 (9705) Terminated (NO_ERROR): Without reason
    2026-01-31 08:00:43.890 - info: chromecast.0 (9630) terminating
    2026-01-31 08:00:43.900 - info: cloud.0 (752835) terminating
    2026-01-31 08:00:43.900 - info: mqtt.0 (9669) terminating
    2026-01-31 08:00:43.901 - info: admin.0 (9521) terminating
    2026-01-31 08:00:43.909 - info: jarvis.0 (9723) terminating
    2026-01-31 08:00:43.914 - info: time-switch.0 (9736) terminating
    2026-01-31 08:00:43.937 - info: backitup.0 (9615) terminating
    2026-01-31 08:00:43.942 - info: vis-inventwo.0 (9758) terminating
    2026-01-31 08:00:44.216 - info: host.ioBroker-neu instance system.adapter.time-switch.0 terminated with code 0 (NO_ERROR)
    2026-01-31 08:00:44.330 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
    2026-01-31 08:00:44.330 - info: host.ioBroker-neu instance system.adapter.chromecast.0 terminated with code 0 (NO_ERROR)
    2026-01-31 08:00:44.342 - info: host.ioBroker-neu instance system.adapter.jarvis.0 terminated with code 0 (NO_ERROR)
    2026-01-31 08:00:44.430 - info: host.ioBroker-neu instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2026-01-31 08:00:44.431 - info: host.ioBroker-neu instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
    2026-01-31 08:00:44.431 - info: host.ioBroker-neu instance system.adapter.cloud.0 terminated with code 0 (NO_ERROR)
    2026-01-31 08:00:44.432 - info: host.ioBroker-neu instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
    2026-01-31 08:00:44.476 - info: host.ioBroker-neu instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    2026-01-31 08:00:44.477 - info: host.ioBroker-neu instance system.adapter.net-tools.0 terminated with code 0 (NO_ERROR)
    2026-01-31 08:00:44.534 - info: host.ioBroker-neu stopInstance timeout system.adapter.ping.0 killing pid 9705
    2026-01-31 08:00:44.560 - info: host.ioBroker-neu instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
    2026-01-31 08:00:44.594 - info: host.ioBroker-neu instance system.adapter.ping.0 terminated with code 0 (NO_ERROR)
    2026-01-31 08:00:44.594 - info: host.ioBroker-neu instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
    2026-01-31 08:00:44.595 - info: host.ioBroker-neu All instances are stopped.
    2026-01-31 08:00:44.755 - info: host.ioBroker-neu terminated
    2026-01-31 08:00:47.836 - info: host.ioBroker-neu iobroker.js-controller version 7.0.7 js-controller starting
    2026-01-31 08:00:47.842 - info: host.ioBroker-neu Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2026-01-31 08:00:47.844 - info: host.ioBroker-neu hostname: ioBroker-neu, node: v22.22.0
    2026-01-31 08:00:47.845 - info: host.ioBroker-neu ip addresses: 192.168.178.174 fda7:758:3dc4:0:b475:7f1b:ca88:b974 2a02:8206:bf7d:1201:1cb1:7c0a:4c99:3ca1 fe80::6a9e:ba30:f444:1f81
    2026-01-31 08:00:48.767 - info: host.ioBroker-neu connected to Objects and States
    2026-01-31 08:00:48.796 - info: host.ioBroker-neu added notifications configuration of host
    2026-01-31 08:00:49.247 - info: host.ioBroker-neu 24 instances found
    2026-01-31 08:00:49.280 - info: host.ioBroker-neu starting 14 instances
    2026-01-31 08:00:49.671 - info: host.ioBroker-neu Delete state "system.host.ioBroker-neu.versions.nodeCurrent"
    2026-01-31 08:00:49.708 - info: host.ioBroker-neu Delete state "system.host.ioBroker-neu.versions.nodeNewest"
    2026-01-31 08:00:49.739 - info: host.ioBroker-neu instance system.adapter.admin.0 in version "7.7.22" started with pid 811184
    2026-01-31 08:00:49.762 - info: host.ioBroker-neu Delete state "system.host.ioBroker-neu.versions.nodeNewestNext"
    2026-01-31 08:00:49.771 - info: host.ioBroker-neu Delete state "system.host.ioBroker-neu.versions.npmCurrent"
    2026-01-31 08:00:49.780 - info: host.ioBroker-neu Delete state "system.host.ioBroker-neu.versions.npmNewest"
    2026-01-31 08:00:49.788 - info: host.ioBroker-neu Delete state "system.host.ioBroker-neu.versions.npmNewestNext"
    2026-01-31 08:00:49.796 - info: host.ioBroker-neu Some obsolete host states deleted.
    2026-01-31 08:00:53.668 - info: host.ioBroker-neu instance system.adapter.history.0 in version "3.0.1" started with pid 811195
    2026-01-31 08:00:53.844 - info: admin.0 (811184) starting. Version 7.7.22 in /opt/iobroker/node_modules/iobroker.admin, node: v22.22.0, js-controller: 7.0.7
    2026-01-31 08:00:53.917 - info: admin.0 (811184) requesting all objects
    2026-01-31 08:00:54.947 - info: admin.0 (811184) received all objects
    2026-01-31 08:00:55.399 - info: admin.0 (811184) socket.io server listening on port 8081
    2026-01-31 08:00:55.404 - info: admin.0 (811184) http server listening on port 8081
    2026-01-31 08:00:55.405 - info: admin.0 (811184) Use link "http://127.0.0.1:8081" to configure.
    2026-01-31 08:00:55.876 - info: admin.0 (811184) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 08:00:58.422 - info: host.ioBroker-neu instance system.adapter.javascript.0 in version "9.0.11" started with pid 811240
    2026-01-31 08:00:58.636 - info: history.0 (811195) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.history, node: v22.22.0, js-controller: 7.0.7
    2026-01-31 08:01:01.759 - info: host.ioBroker-neu instance system.adapter.backitup.0 in version "3.3.13" started with pid 811261
    2026-01-31 08:01:02.603 - info: javascript.0 (811240) starting. Version 9.0.11 in /opt/iobroker/node_modules/iobroker.javascript, node: v22.22.0, js-controller: 7.0.7
    2026-01-31 08:01:02.855 - info: javascript.0 (811240) requesting all states
    2026-01-31 08:01:02.857 - info: javascript.0 (811240) requesting all objects
    2026-01-31 08:01:03.711 - info: javascript.0 (811240) received all objects
    2026-01-31 08:01:03.714 - info: javascript.0 (811240) received all states
    2026-01-31 08:01:04.072 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Abtauungen_zaehlen: start JavaScript (Blockly)
    2026-01-31 08:01:04.113 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Abtauungen_zaehlen: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2026-01-31 08:01:04.117 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Akt_VL: start JavaScript (Blockly)
    2026-01-31 08:01:04.129 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Akt_VL: registered 6 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2026-01-31 08:01:04.130 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.COP_rechnen: start JavaScript (Blockly)
    2026-01-31 08:01:04.139 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.COP_rechnen: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2026-01-31 08:01:04.145 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Kuehlen_1_Stunde: start JavaScript (Blockly)
    2026-01-31 08:01:04.153 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Kuehlen_1_Stunde: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2026-01-31 08:01:04.154 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Nachtabsenkung: start JavaScript (Blockly)
    2026-01-31 08:01:04.162 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Nachtabsenkung: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2026-01-31 08:01:04.175 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Warmwasser_1_Stunde: start JavaScript (Blockly)
    2026-01-31 08:01:04.183 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Warmwasser_1_Stunde: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2026-01-31 08:01:04.183 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Warmwassertimer: start JavaScript (Blockly)
    2026-01-31 08:01:04.191 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Warmwassertimer: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2026-01-31 08:01:04.191 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Heizkurve: start JavaScript (Blockly)
    2026-01-31 08:01:04.199 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Heizkurve: registered 10 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2026-01-31 08:01:04.991 - info: backitup.0 (811261) starting. Version 3.3.13 in /opt/iobroker/node_modules/iobroker.backitup, node: v22.22.0, js-controller: 7.0.7
    2026-01-31 08:01:05.073 - info: backitup.0 (811261) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2026-01-31 08:01:05.647 - info: host.ioBroker-neu instance system.adapter.chromecast.0 in version "4.0.0" started with pid 811280
    2026-01-31 08:01:08.081 - info: chromecast.0 (811280) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.chromecast, node: v22.22.0, js-controller: 7.0.7
    2026-01-31 08:01:08.152 - error: chromecast.0 (811280) Cannot get web port: TypeError: Cannot read properties of null (reading 'native')
    2026-01-31 08:01:08.719 - info: chromecast.0 (811280) Shield Gästezimmer - Connected client
    2026-01-31 08:01:08.729 - info: chromecast.0 (811280) SHIELD - Connected client
    2026-01-31 08:01:09.684 - info: host.ioBroker-neu instance system.adapter.cloud.0 in version "5.0.1" started with pid 811299
    2026-01-31 08:01:12.121 - info: cloud.0 (811299) starting. Version 5.0.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v22.22.0, js-controller: 7.0.7
    @dogfight76 sagte in ioBroker: Wärmpepumpe - Nachtabsenkung nicht deaktiviert:
    bis 03:10 / 03:38 warst du noch am iobroker tätig?
    Die Meldung
    hast du wahrscheinlich schon früher bekommen!
    Da steht ja, dass du falsche Typen verwendest
    ABER
    hier verbindet sich deine Wärmepumpe erst wieder.
    Der Umstellbefehl um 04:30, von dem
    leider kennen wir das exakte Vorgehen deines Skripts immer noch nicht
    dogfight76D 1 Antwort Letzte Antwort
    • L Online
      L Online
      lesiflo
      schrieb am zuletzt editiert von lesiflo
      warum machst du überhaupt eine Nachtabsenkung? Am besten bei niedriger Temperatur durchlaufen lassen. Das Aufheizen kostet mehr Energie als durchlaufen lassen.
      Wenn du das trotzdem haben möchtest, dann solltest du das über die App von Panasonic machen.
      • madingM Online
        madingM Online
        mading
        @dogfight76 Ist etwas Offtopic, hänge mich mal an @lesiflo‘s Frage an: warum die Nachtabsenkung? Egal ob du eine FBH oder Radiatoren im Altbau hast, die Absenkung macht zum Strom sparen und auch wegen der Trägheit m.E. keinen Sinn. Lasse mich aber gern eines Besseren überzeugen ;)
        • WinniW Offline
          WinniW Offline
          Winni
          Pauschal würde ich die Nachtabsenkung nicht verdammen. Ich denke man muss immer den Einzelfall sehen.
          https://www.energie-fachberater.de/heizung-lueftung/heizung/nachtabsenkung-der-heizung-sinn-oder-unsinn.php
          Ist aber ot.
          L 1 Antwort Letzte Antwort
          • WinniW Winni
            Ist aber ot.
            L Online
            L Online
            lesiflo
            @Winni sagte in ioBroker: Wärmpepumpe - Nachtabsenkung nicht deaktiviert:
            Ist aber ot.
            OK, man muss halt schauen was man für Bedingungen hat.
            @dogfight76: Wenn du die Nachtabsenkung trotzdem haben möchtest solltest du dich unabhängig von iobroker machen. Da kann immer mal wieder die Verbindung gestört sein und dann bleibt die Bude kalt. Ich würde zur Sicherheit, falls iobroker nicht schalten konnte, einen Fallback über die App einbauen. Mache ich bei meiner Warmwasseraufbereitung auch. Wenn genug PV Leistung da war aufheizen ansonsten über die App nach Zeit.
            Ansonsten wäre, wie meine Vorredner auch gefragt haben, es schön zu wissen wie dein Script aussieht.
            Zu deiner WP kann ich dir auch diesen Thread hier empfehlen: Link Text
            • L lesiflo
              Ist aber ot.
              @lesiflo sagte in ioBroker: Wärmpepumpe - Nachtabsenkung nicht deaktiviert:
              @dogfight76
              gibt es dazu keine Einstellung direkt in der WP?
              (Wenn es denn sein muss!)
              • dogfight76D Offline
                dogfight76D Offline
                dogfight76
                danke für die vielen Antworten. Bin jetzt wieder am PC, daher erst jetzt die Antwort.
                Muss wohl ein "Aufhänger" gewesen sein, heute morgen wieder alles wie immer. Das Log vom ioBroker sieht genauso aus wie das letzte oben
                Das aktuelle von heute:
                2026-02-01 01:05:37.243 - info: admin.0 (811184) ==> Connected system.user.admin from ::ffff:192.168.178.53
                2026-02-01 01:05:46.489 - info: web.0 (811454) ==> Connected system.user.admin from ::ffff:192.168.178.53
                2026-02-01 01:09:02.251 - info: admin.0 (811184) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
                2026-02-01 01:10:16.510 - info: web.0 (811454) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
                2026-02-01 02:09:17.659 - info: admin.0 (811184) ==> Connected system.user.admin from ::ffff:192.168.178.53
                2026-02-01 02:09:26.763 - info: web.0 (811454) ==> Connected system.user.admin from ::ffff:192.168.178.53
                2026-02-01 02:13:02.710 - info: admin.0 (811184) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
                2026-02-01 02:13:56.797 - info: web.0 (811454) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
                2026-02-01 03:05:36.864 - info: admin.0 (811184) ==> Connected system.user.admin from ::ffff:192.168.178.53
                2026-02-01 03:05:46.871 - info: web.0 (811454) ==> Connected system.user.admin from ::ffff:192.168.178.53
                2026-02-01 03:09:01.882 - info: admin.0 (811184) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
                2026-02-01 03:10:16.892 - info: web.0 (811454) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
                2026-02-01 03:36:43.548 - info: cloud.0 (811299) Connection changed: disconnect
                2026-02-01 03:37:31.882 - info: cloud.0 (811299) Connection changed: connect
                2026-02-01 08:00:56.700 - info: admin.0 (811184) Adapter rating updated
                2026-02-01 10:04:38.318 - info: mqtt.0 (811314) Client [HeishaMon] connection closed: timeout
                2026-02-01 10:04:38.495 - info: mqtt.0 (811314) Client [HeishaMon] connected with secret 1769936678490_1210
                2026-02-01 10:04:38.520 - info: mqtt.0 (811314) Client [HeishaMon] subscribes on "Waermepumpe/commands/#" with regex /^Waermepumpe\.commands\..*/
                2026-02-01 10:04:38.521 - info: mqtt.0 (811314) Client [HeishaMon] subscribes on "Waermepumpe/commands/#" with regex /^mqtt\.0\.Waermepumpe\.commands\..*/
                2026-02-01 10:04:38.531 - info: mqtt.0 (811314) Client [HeishaMon] subscribes on "Waermepumpe/gpio/#" with regex /^Waermepumpe\.gpio\..*/
                2026-02-01 10:04:38.532 - info: mqtt.0 (811314) Client [HeishaMon] subscribes on "Waermepumpe/gpio/#" with regex /^mqtt\.0\.Waermepumpe\.gpio\..*/
                2026-02-01 10:04:38.533 - info: mqtt.0 (811314) Client [HeishaMon] subscribes on "mqtt.0.Waermepumpe.SendRawValue"
                2026-02-01 11:15:26.274 - info: admin.0 (811184) ==> Connected system.user.admin from ::ffff:192.168.178.53
                2026-02-01 11:15:34.839 - info: web.0 (811454) ==> Connected system.user.admin from ::ffff:192.168.178.53
                Also Nachtabsenkung bedeutet hier das ich von 23:30 Uhr bis 04:30 Uhr die VL-Temp auf konstant 29 Grad stelle, also unabhängig von der Heizkurve. Somit kühlt das Haus nicht aus und die Fussbodenerwärmung im Bad hält die Fließen angenehm. Mache ich so weil bei z.b. -5 Grad AT muss die Stube ja nicht mitten in der Nacht 22 Grad warm sein. Durch "try&error" kam ich so auf die 29 Grad und in der Stube sind es dann auch bei -5Grad AT morgens noch immer so 20 Grad
                Das dürfte doch stromsparender sein, auch wenn ab 04:30 Uhr dann wieder per Heizkurve gefahren wird, als wenn ich die ganze Nacht durchheize, oder ?
                Die beiden Blockly für Heizkurve und Nachtabsenkung hänge ich mal als .txt an.......
                Heizkurve.txt
                Nachtabsenkung.txt
                  Die Meldung
                  ABER
                  dogfight76D Offline
                  dogfight76D Offline
                  dogfight76
                  Nein, die Einträge sind anscheinend jede Nacht da. Die IP ist die von diesem PC der im Büro steht.
                  Das steht heute nicht im Log......hat das eventuell etwas mait zu tun das es sich "aufgehangen" hat. Diese Einträge finde ich den Tage davor auch nicht.
                    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                    Mach das zeitnah.
                    Pending systemupdates: 4
                    Spiel die Updates ein.
                    Hat aber nichts mit dem Problem zu tun, nur mit der Systempflege.
                    Edit: Und schau mal, ob du den iobroker.time-switch nicht durch den ioBroker.schedule-switcher Adapter ersetzen kannst.
                    dogfight76D Offline
                    dogfight76D Offline
                    dogfight76
                    @Thomas-Braun sagte in ioBroker: Wärmpepumpe - Nachtabsenkung nicht deaktiviert:
                    Mach das zeitnah.
                    Ist das beides getan mit dem Befehl:
                    sudo apt-get update && sudo apt-get upgrade -y
                    Und das System läuft nach dem Upgrade wie jetzt weiter oder muss das alles neu gemacht werden ?
                      Mach das zeitnah.
                      @dogfight76
                      OT, aber einen Wechsel auf die Trixie machst du so:
                      https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie
                        du hast das ja inzwischen behoben, oder doch nicht?
                        sehr seltsam!
                        du musst jetzt morgens die Energie, die der Fussboden (!) über Nacht verloren hat zusätzlich zum Heizerfolg wieder in die nicht unerhebliche Masse des Bodens wieder einbringen.
                        Die Wärmekapazität von Beton ist erheblich!
                          sehr seltsam!
                          dogfight76D Offline
                          dogfight76D Offline
                          dogfight76
                          Ich weiß nicht was ich beheben sol.
                          Wegen dem hier:
                          Also "boolean" und "number" ?
                          Wenn das so wäre , müsste die Meldung dann nicht täglich auftauchen ?
                          Du meinst es würde weniger Strom kosten einfach per Heizkurve durchzuheizen ?
                          Samson71S L 2 Antworten Letzte Antwort
                            Wegen dem hier:
                            Samson71S Offline
                            Samson71S Offline
                            Samson71
                            Bei einer FBH mit ziemlicher Sicherheit - ja.
                            Markus
                            Bitte beachten:
                              Wegen dem hier:
                              L Online
                              L Online
                              lesiflo
                              Wegen dem hier:
                              Hier mal 'ne schnelle Antwort von ChatGPT. Deckt sich mit den sonstigen Aussagen zu dem Thema.
                              Kurzfassung vorweg 😄
                              👉 Bei Wärmepumpen ist „durchheizen“ fast immer besser als Nachtabsenkung.
                              Jetzt die Erklärung, warum das so ist – und wann eine Nachtabsenkung doch Sinn machen kann 👇
                              🔥 Warum Durchheizen bei Wärmepumpen meist besser ist
                              Wärmepumpen lieben konstante, niedrige Vorlauftemperaturen.
                              Die wichtigsten Gründe:
                              Besserer COP / Wirkungsgrad
                              Je kleiner der Temperaturhub, desto effizienter arbeitet die Wärmepumpe.
                              Nachtabsenkung zwingt morgens zu höherer Leistung
                              → höhere Vorlauftemperatur
                              → schlechterer COP
                              → mehr Stromverbrauch
                              Träge Systeme (FBH!)
                              Fußbodenheizung reagiert langsam – die Absenkung bringt kaum echte Einsparung.
                              Mehr Taktung
                              Aufheizen am Morgen = höhere Last = mehr Starts → mehr Verschleiß.
                              👉 Ergebnis:
                              Oft ist 24 h konstant heizen günstiger, obwohl es sich erstmal „falsch“ anfühlt.
                              🌙 Wann Nachtabsenkung trotzdem sinnvoll sein kann
                              Es gibt ein paar Ausnahmen:
                              ✔️ Leichte Absenkung (nicht „aus“!)
                              −1 K bis −2 K
                              Keine starke Abkühlung der Gebäudehülle
                              Vor allem bei gut gedämmten Häusern
                              ✔️ Heizkörper statt FBH
                              Schnelle Reaktion
                              Weniger Speicher in der Masse
                              Trotzdem nur moderat absenken
                              ✔️ Sehr hohe Nacht-Strompreise
                              (z. B. bei dynamischem Tarif)
                              Dann kann eine Mini-Absenkung wirtschaftlich sein
                              Aber: lieber Vorlauf begrenzen als Raumtemperatur stark senken
                              🚫 Was man bei Wärmepumpen vermeiden sollte
                              ❌ Klassische Nachtabsenkung wie bei Gas/Öl
                              ❌ Absenkung um 3–5 K
                              ❌ Komplettes Abschalten nachts
                              ❌ Morgens „Turbo-Aufheizen“
                              🛠️ Praxis-Empfehlung (bewährt)
                              Durchheizen
                              Heizkurve sauber einstellen (so niedrig wie möglich)
                              Nachtabsenkung:
                              entweder aus
                              oder max. −1 K
                              Lieber lange Laufzeiten als kurze, harte Starts
                              Wenn du magst, sag mir kurz:
                              Fußbodenheizung oder Heizkörper?
                              Neubau oder Altbau?
                              Luft-WP oder Sole-WP?
                              Dann sag ich dir, was für genau dein Setup am effizientesten ist 👌
                                dogfight76D Offline
                                dogfight76
                                Wie erwähnt heize ich ausschließlich über Heizkörper.
                                Nur das Badezimmer oben hat Fussbodenerwärmung (keine FBH)
                                Also mal die Temperatur der Nachtabsenkung etwas höher stellen.
                                Damit morgens weniger Ausgleich „hochgeheizt“ werden muss.
                                Doppelhaushälfte 139qm
                                Bj. 1999
                                Dach von innen gedämmt mit Glaswolle, Decke gedämmt mit Glaswolle und Holzdielen um auf dem Dachboden laufen zu können.
                                Panasonic KIT-ADC07JE5C (WH-ADC0309J3E5C + WH-UD07JE5)
