  3. Einsteigerfragen
  4. ioBroker: Wärmpepumpe - Nachtabsenkung nicht deaktiviert
    5.3k
27 Beiträge 8 Kommentatoren 1.2k Aufrufe 6 Beobachtet
  • dogfight76D dogfight76
    @Samson71 sagte in ioBroker: Wärmpepumpe - Nachtabsenkung nicht deaktiviert:
    aktuelle Ausgabe eines iob diag
    gerne, hier die aktuelle Ausgabe:
    ```bash
    Script v.2025-12-30
    *** BASE SYSTEM ***
     Static hostname: ioBroker-neu
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     15:01:27 up 14 days,  1:58,  2 users,  load average: 0.22, 0.11, 0.17
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest        stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2026-01-31 15:01:27 CET
               Universal time: Sat 2026-01-31 14:01:27 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    dogfight76
    HOME=/home/dogfight76
    GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input r        ender netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.0G        1.4G        886M        1.2M        1.8G        2.6G
    Swap:           536M          0B        536M
    Total:          4.5G        1.4G        1.4G
    Active iob-Instances:   14
             3796 M total memory
             1338 M used memory
             1253 M active memory
             1463 M inactive memory
              844 M free memory
              237 M buffer memory
             1480 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 15:01:27 up 14 days,  1:58,  2 users,  load average: 0.22, 0.11, 0.17
    Tasks: 184 total,   1 running, 183 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3796.9 total,    843.0 free,   1340.2 used,   1718.2 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2456.6 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/mmcblk0p2 ext4      117G  6.5G  105G   6% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   57M  454M  12% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sat Jan 17 13:03:25 2026] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8        -424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Sat Jan 17 13:03:27 2026] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87        a2-cd44114eb820 r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.9G    /var/
    829M    /var/cache
    823M    /var/cache/apt
    709M    /var/cache/apt/archives
    395M    /var/log/journal/315631fcd59a4024812d772dc3286c6f
    Archived and active journals take up 394.2M in the file system.
    /opt/iobroker/backups:
    87M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    207M    /opt/iobroker/iobroker-data/
    147M    /opt/iobroker/iobroker-data/files
    51M     /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-Djx0nwYT.j        s
    7.7M    /opt/iobroker/iobroker-data/objects.jsonl
    5.4M    /opt/iobroker/iobroker-data/files/jarvis/js/index-2c99918a.js
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescrip        t/tsWorker.js
    3.7M    /opt/iobroker/iobroker-data/files/javascript.admin/custom/assets/index-D        Xg_kRe6.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.0
    /usr/bin/node           v22.22.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.0-1nodesource1
      Candidate: 22.22.0-1nodesource1
      Version table:
     *** 22.22.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker-neu        ioBroker-neu (version: 7.0.7, hostname: ioBroker-neu  , aliv        e, uptime: 25248)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.11
    nodejs modules from github:     1
    +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker-neu                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : ioBroker-neu                             -  enabled
    + system.adapter.chromecast.0             : chromecast            : ioBroker-neu                             -  enabled
    + system.adapter.cloud.0                  : cloud                 : ioBroker-neu                             -  enabled
      system.adapter.discovery.0              : discovery             : ioBroker-neu                             - disabled
      system.adapter.fritzdect.0              : fritzdect             : ioBroker-neu                             - disabled
    + system.adapter.history.0                : history               : ioBroker-neu                             -  enabled
      system.adapter.hm-rega.0                : hm-rega               : ioBroker-neu                             - disabled
      system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-neu                             - disabled, port: 18701
      system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-neu                             - disabled, port: 12001
      system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker-neu                             - disabled, port: 12010
      system.adapter.influxdb.0               : influxdb              : ioBroker-neu                             - disabled, port: 8086
    + system.adapter.jarvis.0                 : jarvis                : ioBroker-neu                             -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker-neu                             -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker-neu                             -  enabled, port: 8885, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : ioBroker-neu                             -  enabled
    + system.adapter.ping.0                   : ping                  : ioBroker-neu                             -  enabled
      system.adapter.solarlog.0               : solarlog              : ioBroker-neu                             - disabled, port: 80
    + system.adapter.time-switch.0            : time-switch           : ioBroker-neu                             -  enabled
      system.adapter.tr-064.0                 : tr-064                : ioBroker-neu                             - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-neu                             -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-neu                             - disabled
      system.adapter.vis.0                    : vis                   : ioBroker-neu                             -  enabled
    + system.adapter.web.0                    : web                   : ioBroker-neu                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "backitup"     : 3.3.13   , installed 3.3.13
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "net-tools"    : 1.2.3    , installed 1.2.3
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "solarlog"     : 2.4.0    , installed 2.4.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Objects and States
    Objects:        1349
    States:         1025
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 4
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8885            0.0.0.0:*               LISTEN      1001       8920163    811314/io.mqtt.0
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       8920278    811368/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6152       601/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8916940    811165/iobroker.js-
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8916935    811165/iobroker.js-
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6154       601/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8916988    811184/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8919507    811454/io.web.0
    udp        0      0 0.0.0.0:36953           0.0.0.0:*                           104        1835       462/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       8917894    811280/io.chromecas
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1833       462/avahi-daemon: r
    udp6       0      0 fe80::6a9e:ba30:f44:546 :::*                                0          1419233    539/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        1834       462/avahi-daemon: r
    udp6       0      0 :::36531                :::*                                104        1836       462/avahi-daemon: r
    2026-01-31 12:27:12.924  - info: cloud.0 (811299) User accessed from cloud: tNBrx86g5drrsBurC0oX
    2026-01-31 12:28:37.856  - info: cloud.0 (811299) User disconnected from cloud:  vis.0
    2026-01-31 12:34:29.683  - info: cloud.0 (811299) User accessed from cloud: Odp5mXlO_vibEsilC0rj
    2026-01-31 12:35:16.326  - info: cloud.0 (811299) User accessed from cloud: 8m2E7SxhJ4lofdizC0r7
    2026-01-31 12:35:29.735  - info: cloud.0 (811299) User disconnected from cloud:  vis.0
    2026-01-31 12:36:21.717  - info: cloud.0 (811299) User disconnected from cloud:  vis.0
    2026-01-31 12:49:19.473  - info: cloud.0 (811299) User accessed from cloud: 7nZxZtjYhn7GziboC0yY
    2026-01-31 12:49:21.558  - info: cloud.0 (811299) User disconnected from cloud:  vis.0
    2026-01-31 12:49:22.029  - info: cloud.0 (811299) User accessed from cloud: w04Y4I-eaOvFFIdGC0ya
    2026-01-31 12:49:45.200  - info: cloud.0 (811299) User disconnected from cloud:  vis.0
    2026-01-31 12:51:11.245  - info: chromecast.0 (811280) SHIELD - Playing -
    2026-01-31 13:04:27.859  - info: chromecast.0 (811280) SHIELD - Detached player
    2026-01-31 13:04:27.890  - info: chromecast.0 (811280) {"appId":"AndroidNativeApp","appType":"ANDROID_TV","displayName":"Kodi","iconUrl":"","isIdleScreen":false,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.media"}],"senderConnected":true,"sessionId":"e0ec1aa9-b94c-4c72-af12-f680c9f086fb","statusText":"Kodi","transportId":"e0ec1aa9-b94c-4c72-af12-f680c9f086fb","universalAppId":"AndroidNativeApp"}
    2026-01-31 13:04:48.025  - info: chromecast.0 (811280) SHIELD - Try to join player
    2026-01-31 13:04:48.028  - info: chromecast.0 (811280) SHIELD - Connected player
    2026-01-31 13:04:48.029  - info: chromecast.0 (811280) SHIELD - Player joint
    2026-01-31 13:04:48.035  - info: chromecast.0 (811280) SHIELD - Detached player
    2026-01-31 13:04:48.141  - info: chromecast.0 (811280) {"appId":"AndroidNativeApp","appType":"ANDROID_TV","displayName":"Kodi","iconUrl":"","isIdleScreen":false,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.media"}],"senderConnected":true,"sessionId":"e0ec1aa9-b94c-4c72-af12-f680c9f086fb","statusText":"Kodi","transportId":"e0ec1aa9-b94c-4c72-af12-f680c9f086fb","universalAppId":"AndroidNativeApp"}
    2026-01-31 14:35:31.823  - info: cloud.0 (811299) User accessed from cloud: d1AP3FnjcETADLr2C1iQ
    2026-01-31 14:35:43.889  - info: cloud.0 (811299) User disconnected from cloud:  vis.0
    2026-01-31 14:35:46.993  - info: cloud.0 (811299) User accessed from cloud: 3etmL2raCG4KxvJmC1iZ
    2026-01-31 14:36:40.088  - info: admin.0 (811184) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 14:36:47.471  - info: web.0 (811454) ==> Connected system.user.admin from ::ffff:192.168.178.53
    2026-01-31 14:36:52.189  - info: cloud.0 (811299) User disconnected from cloud:  vis.0
    2026-01-31 14:50:53.461  - info: admin.0 (811184) ==> Connected system.user.admin from ::ffff:192.168.178.53
    @dogfight76 sagte in ioBroker: Wärmpepumpe - Nachtabsenkung nicht deaktiviert:
    Mach das zeitnah.
    Spiel die Updates ein.
    Hat aber nichts mit dem Problem zu tun, nur mit der Systempflege.
    Edit: Und schau mal, ob du den iobroker.time-switch nicht durch den ioBroker.schedule-switcher Adapter ersetzen kannst.
    dogfight76D 1 Antwort Letzte Antwort
      @Homoran sagte in ioBroker: Wärmpepumpe - Nachtabsenkung nicht deaktiviert:
      Ich nehme an dass um 04:30 irgendein Zeittrigger läuft, da nutzt auch nur 1 Sekunde später keinerlei Eingreifen mehr. Das verwischt nur noch alle Spuren.
      Warum zeigst du nicht dein log um +/- 0430?
      Um die Uhrzeit steht da nichts:
      2026-01-31 01:05:37.589 - info: admin.0 (9521) ==> Connected system.user.admin from ::ffff:192.168.178.53
      2026-01-31 01:05:45.801 - info: web.0 (9801) ==> Connected system.user.admin from ::ffff:192.168.178.53
      2026-01-31 01:09:02.616 - info: admin.0 (9521) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
      2026-01-31 01:10:15.820 - info: web.0 (9801) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
      2026-01-31 02:09:16.228 - info: admin.0 (9521) ==> Connected system.user.admin from ::ffff:192.168.178.53
      2026-01-31 02:09:26.350 - info: web.0 (9801) ==> Connected system.user.admin from ::ffff:192.168.178.53
      2026-01-31 02:12:56.240 - info: admin.0 (9521) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
      2026-01-31 02:13:56.370 - info: web.0 (9801) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
      2026-01-31 03:05:35.970 - info: admin.0 (9521) ==> Connected system.user.admin from ::ffff:192.168.178.53
      2026-01-31 03:05:45.318 - info: web.0 (9801) ==> Connected system.user.admin from ::ffff:192.168.178.53
      2026-01-31 03:08:56.004 - info: admin.0 (9521) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
      2026-01-31 03:10:15.795 - info: web.0 (9801) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
      2026-01-31 03:37:25.236 - info: cloud.0 (752835) Connection changed: disconnect
      2026-01-31 03:38:25.269 - info: cloud.0 (752835) Trying to connect as system.user.admin to cloud
      2026-01-31 03:38:25.447 - info: cloud.0 (752835) Connection changed: connect
      2026-01-31 05:04:38.083 - info: mqtt.0 (9669) Client [HeishaMon] connection closed: timeout
      2026-01-31 05:04:42.882 - info: mqtt.0 (9669) Client [HeishaMon] connected with secret 1769832282875_1277
      2026-01-31 05:04:42.907 - info: mqtt.0 (9669) Client [HeishaMon] subscribes on "Waermepumpe/commands/#" with regex /^Waermepumpe\.commands\..*/
      2026-01-31 05:04:42.908 - info: mqtt.0 (9669) Client [HeishaMon] subscribes on "Waermepumpe/commands/#" with regex /^mqtt\.0\.Waermepumpe\.commands\..*/
      2026-01-31 05:04:42.917 - info: mqtt.0 (9669) Client [HeishaMon] subscribes on "Waermepumpe/gpio/#" with regex /^Waermepumpe\.gpio\..*/
      2026-01-31 05:04:42.918 - info: mqtt.0 (9669) Client [HeishaMon] subscribes on "Waermepumpe/gpio/#" with regex /^mqtt\.0\.Waermepumpe\.gpio\..*/
      2026-01-31 05:04:42.918 - info: mqtt.0 (9669) Client [HeishaMon] subscribes on "mqtt.0.Waermepumpe.SendRawValue"
      2026-01-31 07:57:30.060 - info: admin.0 (9521) ==> Connected system.user.admin from ::ffff:192.168.178.53
      2026-01-31 07:57:35.939 - info: web.0 (9801) ==> Connected system.user.admin from ::ffff:192.168.178.53
      2026-01-31 07:57:40.008 - info: web.0 (9801) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
      2026-01-31 07:57:40.687 - info: web.0 (9801) ==> Connected system.user.admin from ::ffff:192.168.178.53
      2026-01-31 07:58:11.993 - info: admin.0 (9521) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
      2026-01-31 07:58:12.065 - info: admin.0 (9521) ==> Connected system.user.admin from ::ffff:192.168.178.53
      2026-01-31 07:58:12.142 - info: admin.0 (9521) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
      2026-01-31 07:58:12.915 - info: admin.0 (9521) ==> Connected system.user.admin from ::ffff:192.168.178.53
      2026-01-31 07:58:47.436 - info: web.0 (9801) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
      2026-01-31 07:58:50.040 - info: web.0 (9801) ==> Connected system.user.admin from ::ffff:192.168.178.53
      2026-01-31 07:59:28.746 - info: web.0 (9801) State value to set for "0_userdata.0.Waermepumpe.Heizkurve_ein_aus" has to be type "boolean" but received type "number"
      2026-01-31 07:59:35.465 - info: web.0 (9801) State value to set for "0_userdata.0.Waermepumpe.Heizkurve_ein_aus" has to be type "boolean" but received type "number"
      2026-01-31 07:59:40.680 - info: web.0 (9801) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
      2026-01-31 07:59:41.117 - info: web.0 (9801) ==> Connected system.user.admin from ::ffff:192.168.178.53
      2026-01-31 08:00:11.502 - info: web.0 (9801) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
      2026-01-31 08:00:11.975 - info: web.0 (9801) ==> Connected system.user.admin from ::ffff:192.168.178.53
      2026-01-31 08:00:25.450 - info: admin.0 (9521) ==> Connected system.user.admin from ::ffff:192.168.178.53
      2026-01-31 08:00:28.885 - info: admin.0 (9521) <== Disconnect system.user.admin from ::ffff:192.168.178.53
      2026-01-31 08:00:43.363 - warn: web.0 (9801) setTimeout called, but adapter is shutting down
      2026-01-31 08:00:43.359 - info: admin.0 (9521) terminating http server on port 8081
      2026-01-31 08:00:43.375 - info: cloud.0 (752835) Connection changed: disconnect
      2026-01-31 08:00:43.376 - info: admin.0 (9521) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
      2026-01-31 08:00:43.382 - info: cloud.0 (752835) Connection lost
      2026-01-31 08:00:43.359 - info: chromecast.0 (9630) Destroying chromecast scanner
      2026-01-31 08:00:43.372 - info: chromecast.0 (9630) Shield Gästezimmer - client disconnected
      2026-01-31 08:00:43.373 - info: chromecast.0 (9630) SHIELD - client disconnected
      2026-01-31 08:00:43.355 - info: jarvis.0 (9723) Adapter stopped und unloaded.
      2026-01-31 08:00:43.364 - info: javascript.0 (9579) script.js.common.Meine_Geraete.Heizung.Abtauungen_zaehlen: Stopping script
      2026-01-31 08:00:43.392 - info: javascript.0 (9579) script.js.common.Meine_Geraete.Heizung.Akt_VL: Stopping script
      2026-01-31 08:00:43.392 - info: javascript.0 (9579) script.js.common.Meine_Geraete.Heizung.COP_rechnen: Stopping script
      2026-01-31 08:00:43.397 - info: javascript.0 (9579) script.js.common.Meine_Geraete.Heizung.Kuehlen_1_Stunde: Stopping script
      2026-01-31 08:00:43.398 - info: javascript.0 (9579) script.js.common.Meine_Geraete.Heizung.Nachtabsenkung: Stopping script
      2026-01-31 08:00:43.398 - info: javascript.0 (9579) script.js.common.Meine_Geraete.Heizung.Warmwasser_1_Stunde: Stopping script
      2026-01-31 08:00:43.398 - info: javascript.0 (9579) script.js.common.Meine_Geraete.Heizung.Warmwassertimer: Stopping script
      2026-01-31 08:00:43.354 - info: host.ioBroker-neu received SIGTERM
      2026-01-31 08:00:43.382 - info: host.ioBroker-neu stopInstance system.adapter.admin.0 (force=false, process=true)
      2026-01-31 08:00:43.385 - info: host.ioBroker-neu stopInstance system.adapter.history.0 (force=false, process=true)
      2026-01-31 08:00:43.386 - info: host.ioBroker-neu stopInstance system.adapter.influxdb.0 (force=false, process=false)
      2026-01-31 08:00:43.389 - info: host.ioBroker-neu stopInstance system.adapter.javascript.0 (force=false, process=true)
      2026-01-31 08:00:43.390 - info: host.ioBroker-neu stopInstance system.adapter.backitup.0 (force=false, process=true)
      2026-01-31 08:00:43.391 - info: host.ioBroker-neu stopInstance system.adapter.chromecast.0 (force=false, process=true)
      2026-01-31 08:00:43.392 - info: host.ioBroker-neu stopInstance system.adapter.cloud.0 (force=false, process=true)
      2026-01-31 08:00:43.393 - info: host.ioBroker-neu stopInstance system.adapter.hm-rega.0 (force=false, process=false)
      2026-01-31 08:00:43.394 - info: host.ioBroker-neu stopInstance system.adapter.hm-rpc.0 (force=false, process=false)
      2026-01-31 08:00:43.394 - info: host.ioBroker-neu stopInstance system.adapter.hm-rpc.1 (force=false, process=false)
      2026-01-31 08:00:43.395 - info: host.ioBroker-neu stopInstance system.adapter.hm-rpc.2 (force=false, process=false)
      2026-01-31 08:00:43.395 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
      2026-01-31 08:00:43.396 - info: host.ioBroker-neu stopInstance system.adapter.net-tools.0 (force=false, process=true)
      2026-01-31 08:00:43.396 - info: host.ioBroker-neu stopInstance system.adapter.ping.0 (force=false, process=true)
      2026-01-31 08:00:43.397 - info: host.ioBroker-neu stopInstance system.adapter.solarlog.0 (force=false, process=false)
      2026-01-31 08:00:43.398 - info: host.ioBroker-neu stopInstance system.adapter.tr-064.0 (force=false, process=false)
      2026-01-31 08:00:43.398 - info: host.ioBroker-neu stopInstance system.adapter.discovery.0 (force=false, process=false)
      2026-01-31 08:00:43.399 - info: host.ioBroker-neu stopInstance system.adapter.fritzdect.0 (force=false, process=false)
      2026-01-31 08:00:43.399 - info: host.ioBroker-neu stopInstance system.adapter.jarvis.0 (force=false, process=true)
      2026-01-31 08:00:43.400 - info: host.ioBroker-neu stopInstance system.adapter.time-switch.0 (force=false, process=true)
      2026-01-31 08:00:43.401 - info: host.ioBroker-neu stopInstance system.adapter.vis-inventwo.0 (force=false, process=true)
      2026-01-31 08:00:43.402 - info: host.ioBroker-neu stopInstance system.adapter.vis-timeandweather.0 (force=false, process=false)
      2026-01-31 08:00:43.402 - info: host.ioBroker-neu stopInstance system.adapter.vis.0 (force=false, process=false)
      2026-01-31 08:00:43.402 - info: host.ioBroker-neu stopInstance system.adapter.web.0 (force=false, process=true)
      2026-01-31 08:00:43.416 - info: chromecast.0 (9630) Shield Gästezimmer - Connected client
      2026-01-31 08:00:43.367 - info: time-switch.0 (9736) cleaning everything up...
      2026-01-31 08:00:43.421 - info: chromecast.0 (9630) SHIELD - Connected client
      2026-01-31 08:00:43.376 - info: backitup.0 (9615) cleaned everything up...
      2026-01-31 08:00:43.371 - info: vis-inventwo.0 (9758) cleaned everything up...
      2026-01-31 08:00:43.479 - info: admin.0 (9521) Got terminate signal TERMINATE_YOURSELF
      2026-01-31 08:00:43.481 - info: javascript.0 (9579) Got terminate signal TERMINATE_YOURSELF
      2026-01-31 08:00:43.484 - info: chromecast.0 (9630) Got terminate signal TERMINATE_YOURSELF
      2026-01-31 08:00:43.483 - info: backitup.0 (9615) Got terminate signal TERMINATE_YOURSELF
      2026-01-31 08:00:43.486 - info: cloud.0 (752835) Got terminate signal TERMINATE_YOURSELF
      2026-01-31 08:00:43.488 - info: mqtt.0 (9669) Got terminate signal TERMINATE_YOURSELF
      2026-01-31 08:00:43.492 - info: time-switch.0 (9736) Got terminate signal TERMINATE_YOURSELF
      2026-01-31 08:00:43.493 - info: jarvis.0 (9723) Got terminate signal TERMINATE_YOURSELF
      2026-01-31 08:00:43.496 - info: chromecast.0 (9630) terminating
      2026-01-31 08:00:43.498 - info: mqtt.0 (9669) terminating
      2026-01-31 08:00:43.503 - info: admin.0 (9521) terminating
      2026-01-31 08:00:43.504 - info: cloud.0 (752835) terminating
      2026-01-31 08:00:43.497 - info: jarvis.0 (9723) terminating
      2026-01-31 08:00:43.505 - info: time-switch.0 (9736) terminating
      2026-01-31 08:00:43.499 - info: jarvis.0 (9723) Terminated (NO_ERROR): Without reason
      2026-01-31 08:00:43.506 - info: time-switch.0 (9736) Terminated (NO_ERROR): Without reason
      2026-01-31 08:00:43.502 - info: chromecast.0 (9630) Terminated (NO_ERROR): Without reason
      2026-01-31 08:00:43.509 - info: vis-inventwo.0 (9758) Got terminate signal TERMINATE_YOURSELF
      2026-01-31 08:00:43.505 - info: admin.0 (9521) Terminated (NO_ERROR): Without reason
      2026-01-31 08:00:43.506 - info: cloud.0 (752835) Terminated (NO_ERROR): Without reason
      2026-01-31 08:00:43.514 - info: web.0 (9801) Got terminate signal TERMINATE_YOURSELF
      2026-01-31 08:00:43.499 - info: mqtt.0 (9669) Terminated (NO_ERROR): Without reason
      2026-01-31 08:00:43.521 - info: host.ioBroker-neu stopInstance system.adapter.admin.0 send kill signal
      2026-01-31 08:00:43.528 - info: vis-inventwo.0 (9758) terminating
      2026-01-31 08:00:43.531 - info: host.ioBroker-neu stopInstance system.adapter.javascript.0 send kill signal
      2026-01-31 08:00:43.532 - info: host.ioBroker-neu stopInstance system.adapter.backitup.0 send kill signal
      2026-01-31 08:00:43.532 - info: host.ioBroker-neu stopInstance system.adapter.chromecast.0 send kill signal
      2026-01-31 08:00:43.532 - info: host.ioBroker-neu stopInstance system.adapter.cloud.0 send kill signal
      2026-01-31 08:00:43.533 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
      2026-01-31 08:00:43.533 - info: host.ioBroker-neu stopInstance system.adapter.net-tools.0 send kill signal
      2026-01-31 08:00:43.533 - info: host.ioBroker-neu stopInstance system.adapter.ping.0 send kill signal
      2026-01-31 08:00:43.533 - info: host.ioBroker-neu stopInstance system.adapter.jarvis.0 send kill signal
      2026-01-31 08:00:43.534 - info: host.ioBroker-neu stopInstance system.adapter.time-switch.0 send kill signal
      2026-01-31 08:00:43.534 - info: host.ioBroker-neu stopInstance system.adapter.vis-inventwo.0 send kill signal
      2026-01-31 08:00:43.529 - info: vis-inventwo.0 (9758) Terminated (NO_ERROR): Without reason
      2026-01-31 08:00:43.489 - info: net-tools.0 (9684) Got terminate signal TERMINATE_YOURSELF
      2026-01-31 08:00:43.544 - info: net-tools.0 (9684) terminating
      2026-01-31 08:00:43.546 - info: net-tools.0 (9684) Terminated (NO_ERROR): Without reason
      2026-01-31 08:00:43.552 - info: host.ioBroker-neu stopInstance system.adapter.web.0 send kill signal
      2026-01-31 08:00:43.553 - info: backitup.0 (9615) terminating
      2026-01-31 08:00:43.556 - info: backitup.0 (9615) Terminated (NO_ERROR): Without reason
      2026-01-31 08:00:43.489 - info: ping.0 (9705) Got terminate signal TERMINATE_YOURSELF
      2026-01-31 08:00:43.497 - info: history.0 (9532) terminating
      2026-01-31 08:00:43.558 - info: history.0 (9532) Terminated (NO_ERROR): Without reason
      2026-01-31 08:00:43.644 - info: javascript.0 (9579) terminating
      2026-01-31 08:00:43.646 - info: javascript.0 (9579) Terminated (NO_ERROR): Without reason
      2026-01-31 08:00:43.861 - info: javascript.0 (9579) terminating
      2026-01-31 08:00:43.875 - info: ping.0 (9705) terminating
      2026-01-31 08:00:43.875 - info: net-tools.0 (9684) terminating
      2026-01-31 08:00:43.875 - info: web.0 (9801) terminating
      2026-01-31 08:00:43.877 - info: web.0 (9801) Terminated (NO_ERROR): Without reason
      2026-01-31 08:00:43.878 - info: ping.0 (9705) Terminated (NO_ERROR): Without reason
      2026-01-31 08:00:43.890 - info: chromecast.0 (9630) terminating
      2026-01-31 08:00:43.900 - info: cloud.0 (752835) terminating
      2026-01-31 08:00:43.900 - info: mqtt.0 (9669) terminating
      2026-01-31 08:00:43.901 - info: admin.0 (9521) terminating
      2026-01-31 08:00:43.909 - info: jarvis.0 (9723) terminating
      2026-01-31 08:00:43.914 - info: time-switch.0 (9736) terminating
      2026-01-31 08:00:43.937 - info: backitup.0 (9615) terminating
      2026-01-31 08:00:43.942 - info: vis-inventwo.0 (9758) terminating
      2026-01-31 08:00:44.216 - info: host.ioBroker-neu instance system.adapter.time-switch.0 terminated with code 0 (NO_ERROR)
      2026-01-31 08:00:44.330 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
      2026-01-31 08:00:44.330 - info: host.ioBroker-neu instance system.adapter.chromecast.0 terminated with code 0 (NO_ERROR)
      2026-01-31 08:00:44.342 - info: host.ioBroker-neu instance system.adapter.jarvis.0 terminated with code 0 (NO_ERROR)
      2026-01-31 08:00:44.430 - info: host.ioBroker-neu instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2026-01-31 08:00:44.431 - info: host.ioBroker-neu instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
      2026-01-31 08:00:44.431 - info: host.ioBroker-neu instance system.adapter.cloud.0 terminated with code 0 (NO_ERROR)
      2026-01-31 08:00:44.432 - info: host.ioBroker-neu instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
      2026-01-31 08:00:44.476 - info: host.ioBroker-neu instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      2026-01-31 08:00:44.477 - info: host.ioBroker-neu instance system.adapter.net-tools.0 terminated with code 0 (NO_ERROR)
      2026-01-31 08:00:44.534 - info: host.ioBroker-neu stopInstance timeout system.adapter.ping.0 killing pid 9705
      2026-01-31 08:00:44.560 - info: host.ioBroker-neu instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
      2026-01-31 08:00:44.594 - info: host.ioBroker-neu instance system.adapter.ping.0 terminated with code 0 (NO_ERROR)
      2026-01-31 08:00:44.594 - info: host.ioBroker-neu instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
      2026-01-31 08:00:44.595 - info: host.ioBroker-neu All instances are stopped.
      2026-01-31 08:00:44.755 - info: host.ioBroker-neu terminated
      2026-01-31 08:00:47.836 - info: host.ioBroker-neu iobroker.js-controller version 7.0.7 js-controller starting
      2026-01-31 08:00:47.842 - info: host.ioBroker-neu Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
      2026-01-31 08:00:47.844 - info: host.ioBroker-neu hostname: ioBroker-neu, node: v22.22.0
      2026-01-31 08:00:47.845 - info: host.ioBroker-neu ip addresses: 192.168.178.174 fda7:758:3dc4:0:b475:7f1b:ca88:b974 2a02:8206:bf7d:1201:1cb1:7c0a:4c99:3ca1 fe80::6a9e:ba30:f444:1f81
      2026-01-31 08:00:48.767 - info: host.ioBroker-neu connected to Objects and States
      2026-01-31 08:00:48.796 - info: host.ioBroker-neu added notifications configuration of host
      2026-01-31 08:00:49.247 - info: host.ioBroker-neu 24 instances found
      2026-01-31 08:00:49.280 - info: host.ioBroker-neu starting 14 instances
      2026-01-31 08:00:49.671 - info: host.ioBroker-neu Delete state "system.host.ioBroker-neu.versions.nodeCurrent"
      2026-01-31 08:00:49.708 - info: host.ioBroker-neu Delete state "system.host.ioBroker-neu.versions.nodeNewest"
      2026-01-31 08:00:49.739 - info: host.ioBroker-neu instance system.adapter.admin.0 in version "7.7.22" started with pid 811184
      2026-01-31 08:00:49.762 - info: host.ioBroker-neu Delete state "system.host.ioBroker-neu.versions.nodeNewestNext"
      2026-01-31 08:00:49.771 - info: host.ioBroker-neu Delete state "system.host.ioBroker-neu.versions.npmCurrent"
      2026-01-31 08:00:49.780 - info: host.ioBroker-neu Delete state "system.host.ioBroker-neu.versions.npmNewest"
      2026-01-31 08:00:49.788 - info: host.ioBroker-neu Delete state "system.host.ioBroker-neu.versions.npmNewestNext"
      2026-01-31 08:00:49.796 - info: host.ioBroker-neu Some obsolete host states deleted.
      2026-01-31 08:00:53.668 - info: host.ioBroker-neu instance system.adapter.history.0 in version "3.0.1" started with pid 811195
      2026-01-31 08:00:53.844 - info: admin.0 (811184) starting. Version 7.7.22 in /opt/iobroker/node_modules/iobroker.admin, node: v22.22.0, js-controller: 7.0.7
      2026-01-31 08:00:53.917 - info: admin.0 (811184) requesting all objects
      2026-01-31 08:00:54.947 - info: admin.0 (811184) received all objects
      2026-01-31 08:00:55.399 - info: admin.0 (811184) socket.io server listening on port 8081
      2026-01-31 08:00:55.404 - info: admin.0 (811184) http server listening on port 8081
      2026-01-31 08:00:55.405 - info: admin.0 (811184) Use link "http://127.0.0.1:8081" to configure.
      2026-01-31 08:00:55.876 - info: admin.0 (811184) ==> Connected system.user.admin from ::ffff:192.168.178.53
      2026-01-31 08:00:58.422 - info: host.ioBroker-neu instance system.adapter.javascript.0 in version "9.0.11" started with pid 811240
      2026-01-31 08:00:58.636 - info: history.0 (811195) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.history, node: v22.22.0, js-controller: 7.0.7
      2026-01-31 08:01:01.759 - info: host.ioBroker-neu instance system.adapter.backitup.0 in version "3.3.13" started with pid 811261
      2026-01-31 08:01:02.603 - info: javascript.0 (811240) starting. Version 9.0.11 in /opt/iobroker/node_modules/iobroker.javascript, node: v22.22.0, js-controller: 7.0.7
      2026-01-31 08:01:02.855 - info: javascript.0 (811240) requesting all states
      2026-01-31 08:01:02.857 - info: javascript.0 (811240) requesting all objects
      2026-01-31 08:01:03.711 - info: javascript.0 (811240) received all objects
      2026-01-31 08:01:03.714 - info: javascript.0 (811240) received all states
      2026-01-31 08:01:04.072 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Abtauungen_zaehlen: start JavaScript (Blockly)
      2026-01-31 08:01:04.113 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Abtauungen_zaehlen: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2026-01-31 08:01:04.117 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Akt_VL: start JavaScript (Blockly)
      2026-01-31 08:01:04.129 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Akt_VL: registered 6 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2026-01-31 08:01:04.130 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.COP_rechnen: start JavaScript (Blockly)
      2026-01-31 08:01:04.139 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.COP_rechnen: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2026-01-31 08:01:04.145 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Kuehlen_1_Stunde: start JavaScript (Blockly)
      2026-01-31 08:01:04.153 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Kuehlen_1_Stunde: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2026-01-31 08:01:04.154 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Nachtabsenkung: start JavaScript (Blockly)
      2026-01-31 08:01:04.162 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Nachtabsenkung: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2026-01-31 08:01:04.175 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Warmwasser_1_Stunde: start JavaScript (Blockly)
      2026-01-31 08:01:04.183 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Warmwasser_1_Stunde: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2026-01-31 08:01:04.183 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Warmwassertimer: start JavaScript (Blockly)
      2026-01-31 08:01:04.191 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Warmwassertimer: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2026-01-31 08:01:04.191 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Heizkurve: start JavaScript (Blockly)
      2026-01-31 08:01:04.199 - info: javascript.0 (811240) script.js.common.Meine_Geraete.Heizung.Heizkurve: registered 10 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2026-01-31 08:01:04.991 - info: backitup.0 (811261) starting. Version 3.3.13 in /opt/iobroker/node_modules/iobroker.backitup, node: v22.22.0, js-controller: 7.0.7
      2026-01-31 08:01:05.073 - info: backitup.0 (811261) [iobroker] backup will be activated at 02:40 every 1 day(s)
      2026-01-31 08:01:05.647 - info: host.ioBroker-neu instance system.adapter.chromecast.0 in version "4.0.0" started with pid 811280
      2026-01-31 08:01:08.081 - info: chromecast.0 (811280) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.chromecast, node: v22.22.0, js-controller: 7.0.7
      2026-01-31 08:01:08.152 - error: chromecast.0 (811280) Cannot get web port: TypeError: Cannot read properties of null (reading 'native')
      2026-01-31 08:01:08.719 - info: chromecast.0 (811280) Shield Gästezimmer - Connected client
      2026-01-31 08:01:08.729 - info: chromecast.0 (811280) SHIELD - Connected client
      2026-01-31 08:01:09.684 - info: host.ioBroker-neu instance system.adapter.cloud.0 in version "5.0.1" started with pid 811299
      2026-01-31 08:01:12.121 - info: cloud.0 (811299) starting. Version 5.0.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v22.22.0, js-controller: 7.0.7
      bis 03:10 / 03:38 warst du noch am iobroker tätig?
      Die Meldung
      hast du wahrscheinlich schon früher bekommen!
      Da steht ja, dass du falsche Typen verwendest
      ABER
      hier verbindet sich deine Wärmepumpe erst wieder.
      Der Umstellbefehl um 04:30, von dem
      leider kennen wir das exakte Vorgehen deines Skripts immer noch nicht
      • L Online
        L Online
        lesiflo
        schrieb am zuletzt editiert von lesiflo
        warum machst du überhaupt eine Nachtabsenkung? Am besten bei niedriger Temperatur durchlaufen lassen. Das Aufheizen kostet mehr Energie als durchlaufen lassen.
        Wenn du das trotzdem haben möchtest, dann solltest du das über die App von Panasonic machen.
        • madingM Online
          madingM Online
          mading
          @dogfight76 Ist etwas Offtopic, hänge mich mal an @lesiflo‘s Frage an: warum die Nachtabsenkung? Egal ob du eine FBH oder Radiatoren im Altbau hast, die Absenkung macht zum Strom sparen und auch wegen der Trägheit m.E. keinen Sinn. Lasse mich aber gern eines Besseren überzeugen ;)
          • WinniW Offline
            WinniW Offline
            Winni
            Pauschal würde ich die Nachtabsenkung nicht verdammen. Ich denke man muss immer den Einzelfall sehen.
            https://www.energie-fachberater.de/heizung-lueftung/heizung/nachtabsenkung-der-heizung-sinn-oder-unsinn.php
            Ist aber ot.
            L 1 Antwort Letzte Antwort
            • WinniW Winni
              Ist aber ot.
              L Online
              L Online
              lesiflo
              @Winni sagte in ioBroker: Wärmpepumpe - Nachtabsenkung nicht deaktiviert:
              Ist aber ot.
              OK, man muss halt schauen was man für Bedingungen hat.
              @dogfight76: Wenn du die Nachtabsenkung trotzdem haben möchtest solltest du dich unabhängig von iobroker machen. Da kann immer mal wieder die Verbindung gestört sein und dann bleibt die Bude kalt. Ich würde zur Sicherheit, falls iobroker nicht schalten konnte, einen Fallback über die App einbauen. Mache ich bei meiner Warmwasseraufbereitung auch. Wenn genug PV Leistung da war aufheizen ansonsten über die App nach Zeit.
              Ansonsten wäre, wie meine Vorredner auch gefragt haben, es schön zu wissen wie dein Script aussieht.
              Zu deiner WP kann ich dir auch diesen Thread hier empfehlen: Link Text
              • L lesiflo
                Ist aber ot.
                @lesiflo sagte in ioBroker: Wärmpepumpe - Nachtabsenkung nicht deaktiviert:
                @dogfight76
                gibt es dazu keine Einstellung direkt in der WP?
                (Wenn es denn sein muss!)
                • dogfight76D Offline
                  dogfight76D Offline
                  dogfight76
                  danke für die vielen Antworten. Bin jetzt wieder am PC, daher erst jetzt die Antwort.
                  Muss wohl ein "Aufhänger" gewesen sein, heute morgen wieder alles wie immer. Das Log vom ioBroker sieht genauso aus wie das letzte oben
                  Das aktuelle von heute:
                  2026-02-01 01:05:37.243 - info: admin.0 (811184) ==> Connected system.user.admin from ::ffff:192.168.178.53
                  2026-02-01 01:05:46.489 - info: web.0 (811454) ==> Connected system.user.admin from ::ffff:192.168.178.53
                  2026-02-01 01:09:02.251 - info: admin.0 (811184) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
                  2026-02-01 01:10:16.510 - info: web.0 (811454) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
                  2026-02-01 02:09:17.659 - info: admin.0 (811184) ==> Connected system.user.admin from ::ffff:192.168.178.53
                  2026-02-01 02:09:26.763 - info: web.0 (811454) ==> Connected system.user.admin from ::ffff:192.168.178.53
                  2026-02-01 02:13:02.710 - info: admin.0 (811184) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
                  2026-02-01 02:13:56.797 - info: web.0 (811454) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
                  2026-02-01 03:05:36.864 - info: admin.0 (811184) ==> Connected system.user.admin from ::ffff:192.168.178.53
                  2026-02-01 03:05:46.871 - info: web.0 (811454) ==> Connected system.user.admin from ::ffff:192.168.178.53
                  2026-02-01 03:09:01.882 - info: admin.0 (811184) <== Disconnect system.user.admin from ::ffff:192.168.178.53 admin
                  2026-02-01 03:10:16.892 - info: web.0 (811454) <== Disconnect system.user.admin from ::ffff:192.168.178.53 vis.0
                  2026-02-01 03:36:43.548 - info: cloud.0 (811299) Connection changed: disconnect
                  2026-02-01 03:37:31.882 - info: cloud.0 (811299) Connection changed: connect
                  2026-02-01 08:00:56.700 - info: admin.0 (811184) Adapter rating updated
                  2026-02-01 10:04:38.318 - info: mqtt.0 (811314) Client [HeishaMon] connection closed: timeout
                  2026-02-01 10:04:38.495 - info: mqtt.0 (811314) Client [HeishaMon] connected with secret 1769936678490_1210
                  2026-02-01 10:04:38.520 - info: mqtt.0 (811314) Client [HeishaMon] subscribes on "Waermepumpe/commands/#" with regex /^Waermepumpe\.commands\..*/
                  2026-02-01 10:04:38.521 - info: mqtt.0 (811314) Client [HeishaMon] subscribes on "Waermepumpe/commands/#" with regex /^mqtt\.0\.Waermepumpe\.commands\..*/
                  2026-02-01 10:04:38.531 - info: mqtt.0 (811314) Client [HeishaMon] subscribes on "Waermepumpe/gpio/#" with regex /^Waermepumpe\.gpio\..*/
                  2026-02-01 10:04:38.532 - info: mqtt.0 (811314) Client [HeishaMon] subscribes on "Waermepumpe/gpio/#" with regex /^mqtt\.0\.Waermepumpe\.gpio\..*/
                  2026-02-01 10:04:38.533 - info: mqtt.0 (811314) Client [HeishaMon] subscribes on "mqtt.0.Waermepumpe.SendRawValue"
                  2026-02-01 11:15:26.274 - info: admin.0 (811184) ==> Connected system.user.admin from ::ffff:192.168.178.53
                  2026-02-01 11:15:34.839 - info: web.0 (811454) ==> Connected system.user.admin from ::ffff:192.168.178.53
                  Also Nachtabsenkung bedeutet hier das ich von 23:30 Uhr bis 04:30 Uhr die VL-Temp auf konstant 29 Grad stelle, also unabhängig von der Heizkurve. Somit kühlt das Haus nicht aus und die Fussbodenerwärmung im Bad hält die Fließen angenehm. Mache ich so weil bei z.b. -5 Grad AT muss die Stube ja nicht mitten in der Nacht 22 Grad warm sein. Durch "try&error" kam ich so auf die 29 Grad und in der Stube sind es dann auch bei -5Grad AT morgens noch immer so 20 Grad
                  Das dürfte doch stromsparender sein, auch wenn ab 04:30 Uhr dann wieder per Heizkurve gefahren wird, als wenn ich die ganze Nacht durchheize, oder ?
                  Die beiden Blockly für Heizkurve und Nachtabsenkung hänge ich mal als .txt an.......
                  Heizkurve.txt
                  Nachtabsenkung.txt
                    Die Meldung
                    ABER
                    dogfight76D Offline
                    dogfight76D Offline
                    dogfight76
                    Nein, die Einträge sind anscheinend jede Nacht da. Die IP ist die von diesem PC der im Büro steht.
                    Das steht heute nicht im Log......hat das eventuell etwas mait zu tun das es sich "aufgehangen" hat. Diese Einträge finde ich den Tage davor auch nicht.
                      Mach das zeitnah.
                      dogfight76D Offline
                      dogfight76D Offline
                      dogfight76
                      @Thomas-Braun sagte in ioBroker: Wärmpepumpe - Nachtabsenkung nicht deaktiviert:
                      Mach das zeitnah.
                      Ist das beides getan mit dem Befehl:
                      sudo apt-get update && sudo apt-get upgrade -y
                      Und das System läuft nach dem Upgrade wie jetzt weiter oder muss das alles neu gemacht werden ?
                        Mach das zeitnah.
                        @dogfight76
                        OT, aber einen Wechsel auf die Trixie machst du so:
                        https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie
                          du hast das ja inzwischen behoben, oder doch nicht?
                          sehr seltsam!
                          du musst jetzt morgens die Energie, die der Fussboden (!) über Nacht verloren hat zusätzlich zum Heizerfolg wieder in die nicht unerhebliche Masse des Bodens wieder einbringen.
                          Die Wärmekapazität von Beton ist erheblich!
                            sehr seltsam!
                            dogfight76D Offline
                            dogfight76D Offline
                            dogfight76
                            Ich weiß nicht was ich beheben sol.
                            Wegen dem hier:
                            Also "boolean" und "number" ?
                            Wenn das so wäre , müsste die Meldung dann nicht täglich auftauchen ?
                            Du meinst es würde weniger Strom kosten einfach per Heizkurve durchzuheizen ?
                            Samson71S L 2 Antworten Letzte Antwort
                              Wegen dem hier:
                              Samson71S Offline
                              Samson71S Offline
                              Samson71
                              Bei einer FBH mit ziemlicher Sicherheit - ja.
                              Markus
                              Bitte beachten:
                                Wegen dem hier:
                                L Online
                                L Online
                                lesiflo
                                Wegen dem hier:
                                Hier mal 'ne schnelle Antwort von ChatGPT. Deckt sich mit den sonstigen Aussagen zu dem Thema.
                                Kurzfassung vorweg 😄
                                👉 Bei Wärmepumpen ist „durchheizen“ fast immer besser als Nachtabsenkung.
                                Jetzt die Erklärung, warum das so ist – und wann eine Nachtabsenkung doch Sinn machen kann 👇
                                🔥 Warum Durchheizen bei Wärmepumpen meist besser ist
                                Wärmepumpen lieben konstante, niedrige Vorlauftemperaturen.
                                Die wichtigsten Gründe:
                                Besserer COP / Wirkungsgrad
                                Je kleiner der Temperaturhub, desto effizienter arbeitet die Wärmepumpe.
                                Nachtabsenkung zwingt morgens zu höherer Leistung
                                → höhere Vorlauftemperatur
                                → schlechterer COP
                                → mehr Stromverbrauch
                                Träge Systeme (FBH!)
                                Fußbodenheizung reagiert langsam – die Absenkung bringt kaum echte Einsparung.
                                Mehr Taktung
                                Aufheizen am Morgen = höhere Last = mehr Starts → mehr Verschleiß.
                                👉 Ergebnis:
                                Oft ist 24 h konstant heizen günstiger, obwohl es sich erstmal „falsch“ anfühlt.
                                🌙 Wann Nachtabsenkung trotzdem sinnvoll sein kann
                                Es gibt ein paar Ausnahmen:
                                ✔️ Leichte Absenkung (nicht „aus“!)
                                −1 K bis −2 K
                                Keine starke Abkühlung der Gebäudehülle
                                Vor allem bei gut gedämmten Häusern
                                ✔️ Heizkörper statt FBH
                                Schnelle Reaktion
                                Weniger Speicher in der Masse
                                Trotzdem nur moderat absenken
                                ✔️ Sehr hohe Nacht-Strompreise
                                (z. B. bei dynamischem Tarif)
                                Dann kann eine Mini-Absenkung wirtschaftlich sein
                                Aber: lieber Vorlauf begrenzen als Raumtemperatur stark senken
                                🚫 Was man bei Wärmepumpen vermeiden sollte
                                ❌ Klassische Nachtabsenkung wie bei Gas/Öl
                                ❌ Absenkung um 3–5 K
                                ❌ Komplettes Abschalten nachts
                                ❌ Morgens „Turbo-Aufheizen“
                                🛠️ Praxis-Empfehlung (bewährt)
                                Durchheizen
                                Heizkurve sauber einstellen (so niedrig wie möglich)
                                Nachtabsenkung:
                                entweder aus
                                oder max. −1 K
                                Lieber lange Laufzeiten als kurze, harte Starts
                                Wenn du magst, sag mir kurz:
                                Fußbodenheizung oder Heizkörper?
                                Neubau oder Altbau?
                                Luft-WP oder Sole-WP?
                                Dann sag ich dir, was für genau dein Setup am effizientesten ist 👌
                                  dogfight76D Offline
                                  dogfight76
                                  Wie erwähnt heize ich ausschließlich über Heizkörper.
                                  Nur das Badezimmer oben hat Fussbodenerwärmung (keine FBH)
                                  Also mal die Temperatur der Nachtabsenkung etwas höher stellen.
                                  Damit morgens weniger Ausgleich „hochgeheizt“ werden muss.
                                  Doppelhaushälfte 139qm
                                  Bj. 1999
                                  Dach von innen gedämmt mit Glaswolle, Decke gedämmt mit Glaswolle und Holzdielen um auf dem Dachboden laufen zu können.
                                  Panasonic KIT-ADC07JE5C (WH-ADC0309J3E5C + WH-UD07JE5)
