  4. Test Adapter snmp v3.3.x
    6.3k
mcm1957snmp
20 Beiträge 4 Kommentatoren 844 Aufrufe 6 Beobachtet
  • OttiliO Offline
    OttiliO Offline
    Ottili
    Prima.
    Aber leider liest der Adapter bei Umstellung auf JSON die Daten nicht sauber ein:
    Hier JSON:
    [Brother MFC-L8390CDW] update Brother MFC-L8390CDW.ATTR_MAINTENANCE_Octett: {"type":"Buffer","data":[118,1,4,0,0,0,1,121,1,4,0,0,39,16,115,1,4,0,0,0,31,119,1,4,0,0,0,1,122,1,4,0,0,39,16,116,1,4,0,0,0,31,120,1,4,0,0,0,1,123,1,4,0,0,39,16,117,1,4,0,0,0,31,127,1,4,0,0,0,1,128,1,4,0,0,39,16,126,1,4,0,0,0,31,104,1,4,0,0,0,1,85,1,4,0,0,0,1,50,1,4,0,0,0,1,112,1,4,0,0,38,72,130,1,4,0,0,0,100,51,1,4,0,0,0,1,113,1,4,0,0,38,72,131,1,4,0,0,0,100,52,1,4,0,0,0,1,114,1,4,0,0,38,72,132,1,4,0,0,0,100,49,1,4,0,0,0,1,111,1,4,0,0,38,72,129,1,4,0,0,0,100,105,1,4,0,0,39,16,102,1,4,0,0,0,1,108,1,4,0,0,39,16,84,1,4,0,0,0,1,106,1,4,0,0,39,16,255]}
    Hier MIB-Browser:
    Name/OID: brInfoMaintenance.0; Value (OctetString): 0x76 01 04 00 00 00 01 79 01 04 00 00 27 10 73 01 04 00 00 00 1F 77 01 04 00 00 00 01 7A 01 04 00 00 27 10 74 01 04 00 00 00 1F 78 01 04 00 00 00 01 7B 01 04 00 00 27 10 75 01 04 00 00 00 1F 7F 01 04 00 00 00 01 80 01 04 00 00 27 10 7E 01 04 00 00 00 1F 68 01 04 00 00 00 01 55 01 04 00 00 00 01 32 01 04 00 00 00 01 70 01 04 00 00 26 48 82 01 04 00 00 00 64 33 01 04 00 00 00 01 71 01 04 00 00 26 48 83 01 04 00 00 00 64 34 01 04 00 00 00 01 72 01 04 00 00 26 48 84 01 04 00 00 00 64 31 01 04 00 00 00 01 6F 01 04 00 00 26 48 81 01 04 00 00 00 64 69 01 04 00 00 27 10 66 01 04 00 00 00 01 6C 01 04 00 00 27 10 54 01 04 00 00 00 01 6A 01 04 00 00 27 10 FF
    Zum einen werden Teilstrings wie 00 als 0 abgespeichert. Buchstaben werden gar nicht erkannt.
    Der MIB Browser den ich verwende: iReasoning MIB Browser verwendet für die Characters Encoding: ISO-8859-1.
    Vielleicht hilft dir diese Infos.
    Ciao Otti
    • mcm1957M Online
      mcm1957M Online
      mcm1957
      Welches Byte liest er nicht sauber ein?
      Kannst du das mal markieren? Ich hab mal nur die ersten Bytes vergleichen und die stimmen alle mit den Daten des MIB Browsers überein.
      EDIT:
      Du unterliegst da anscheinend einem Irrtum. Die Daten werden als BINARE BYTES gesendet. Der MIB Browser stellt diese als HEX String dar. Das Json stellt die Bytes einzeln numerisch als Array Elemente dar - so wie sie auch gesendet werden. Führende Nullen sind bei einer numerischen Darstellung nicht notwendig und Buchstaben gibt es bei dezimalzahlen nicht :-). Das JSON ist kein heaxadezimal kodierter String, die einzelnen Bytewerte werden numerisch im Zehnersystem dargestellt.
      Hexadezimal (MIB Bowser) 0x76   01   04   00   00   00   01   79 ...
      Dezimal (JSON)            118,   1,   4,   0,   0,   0,   1, 121 ...
      76 (hex) == 118 (dez)
      79 (hex) == 121 (dez)
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • OttiliO Offline
        OttiliO Offline
        Ottili
        Alles klar..
        Vielen Dank für die Nachhilfe 😉
        • mcm1957M Online
          mcm1957M Online
          mcm1957
          No problem. Wenn man nicht (fast=) täglich mit Bits und Bytes zu tun hat erkennt man die Kodierung nicht so schnell. :-)
          Hauptsache du kommst mal an deine gewünschten Daten ran.
          • C Offline
            chris299
            @mcm1957 ich bräuchte mal einen Tipp, warum ich die Konfiguration so nicht speichern kann bzw. was da faul ist, dass das rote Ausrufezeichen nicht weg geht.... Ich verstehe nicht was da beim Gerät falsch sein soll....
            • mcm1957M Online
              mcm1957M Online
              mcm1957
              Hmm - eigentlich seh ich da auch nix.
              Und ich muss gestehen dass ich das rote Rufzeichen am Tab noch nie gesehen habe. Keine Ahnung wann das in Admin implementiert wurde.
              Welche admin Version verwendest du?
              Kontrollier ev. ob 'Drucker' beide Male ohne trailing spaces eingetragen ist. Das ist im Moment das Einzige was mir dazu einfällt.
              Außerdem gab es mit einer älteren Admin Version ein Problem, wenn die Tabelle für die snmpv3 Authorisierung leer war,
              Siehe da https://github.com/iobroker-community-adapters/ioBroker.snmp/issues/332
              C 1 Antwort Letzte Antwort
              • mcm1957M mcm1957
                chris299
                schrieb am zuletzt editiert von chris299
                @mcm1957 direkt nach der Installation des Adapters waren an beiden Tabs diese roten Ausrufezeichen. Bei den Sets ist es aber verschwunden, nachdem ich was sinnvolles eingetragen habe....
                ich habe die Admin version 7.7.19 (latest) und auch keine trailing spaces in der Gruppe... :-(
                EDIT: was bei v3 einzugeben ändert auch nichts:
                • mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  Sorry, dann muss ich im Moment passen.
                  Kann mir das morgen ansehen ob ich das reproduzieren kann.
                  Wenn du dich damit auskennst öffne ev die Browserkonsole (F12) und schau ob da ein Fehler drinnen steht der irgendeinen Hinweis liefert.
                  Ansonsten kann ich nur versuchen das morgen mit einer Neuinstallation und dem latest Admin nachzustellen.
                  • mcm1957M mcm1957
                    chris299
                    @mcm1957 mir sagt das leider garnichts, aber könnte es sein, dass versucht wird die Gruppe mit den Sets abzugleichen, diese aber noch nicht gespeichert sind und das daher misslingt?
                    • mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      OK - ich kann den Fehler reproduzieren. Lt. Komnsolenoutput stellt admin die Daten die es anbieten sollte nicht zur Verfügung...
                      Da hat sich wohl was in admin geändert :-(
                      Sorry, muss ich mir ansehen. Kann im Moment leider keinen Workaround anibieten da ich nicht mal weiß wann das in Admin reingekommen ist. Ist (mir) heute schon zu spät für Detaiulsuche.
                      • mcm1957M mcm1957
                        chris299
                        @mcm1957 kein Problem, eilt nicht. danke für die schnelle Reaktion.
                        • mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          @chris299
                          Moment:
                          Wenn du dich sicher genug fühlst kannst du bitte mal admin auf die aktuelle LATEST (7.7.22) aktualisiseren.
                          Bei mir gehts mit der Version.
                          Im CHangelog steht zwar nix von einer Fehlerkorrektur in dem Bereich - aber ich hab jetzt nicht die COmmits studiert.
                          • mcm1957M mcm1957
                            @chris299
                            Moment:
                            chris299
                            @mcm1957 damit funktioniert es. vielen dank.
                            • mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              Keine Ahnung was da geändert / gefixed wurde.
                              Es gab eigentlich keine Änderung an den sourcen. Aber (fast) egal - Hauptsache es geht wieder alles.
