  4. Hilfestellung Raspi4: Zigbee2Mqtt, InfluxDB, Grafana
    6.4k
75 Beiträge 8 Kommentatoren 6.9k Aufrufe 7 Beobachtet
    marcelinho
    @thomas-braun bringt er mir das:
    pi@raspberrypi:~ $ sudo apt update
    apt policy influxdb2-cli
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
    Get:5 https://repos.influxdata.com/debian stable InRelease [6,913 B]
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://deb.nodesource.com/node_24.x nodistro InRelease
    Get:8 https://repos.influxdata.com/debian stable/main arm64 Packages [23.9 kB]
    Get:9 https://repos.influxdata.com/debian stable/main armhf Packages [9,701 B]
    Fetched 40.5 kB in 0s (107 kB/s)
    1 package can be upgraded. Run 'apt list --upgradable' to see it.
    Warning: https://deb.nodesource.com/node_24.x/dists/nodistro/InRelease: Policy will reject signature w        ithin a year, see --audit for details
    influxdb2-cli:
      Installed: (none)
      Candidate: 2.7.5-3
      Version table:
         2.7.5-3 500
            500 https://repos.influxdata.com/debian stable/main arm64 Packages
         2.7.5-2 500
         2.7.5-1 500
         2.7.3-1 500
         2.7.1-2 500
         2.6.1 500
         2.6.0 500
         2.5.0 500
         2.4.0 500
         2.3.0 500
    lines 1-23...skipping...
    influxdb2-cli:
      Installed: (none)
      Candidate: 2.7.5-3
      Version table:
         2.7.5-3 500
         2.7.5-2 500
         2.7.5-1 500
         2.7.3-1 500
         2.7.1-2 500
         2.6.1 500
         2.6.0 500
         2.5.0 500
         2.4.0 500
         2.3.0 500
    und dann folgendes:
    pi@raspberrypi:~ $ sudo apt install influxdb2-cli
    Installing:
      influxdb2-cli
    Installing dependencies:
      influxdata-archive-keyring
    Summary:
      Upgrading: 0, Installing: 2, Removing: 0, Not Upgrading: 1
      Download size: 11.0 MB
      Space needed: 24.7 MB / 20.9 GB available
    Continue? [Y/n] y
    Get:1 https://repos.influxdata.com/debian stable/main arm64 influxdata-archive-keyring all 2026.01.09 [10.7 kB]
    Get:2 https://repos.influxdata.com/debian stable/main arm64 influxdb2-cli arm64 2.7.5-3 [11.0 MB]
    Fetched 11.0 MB in 5s (2,364 kB/s)
    Selecting previously unselected package influxdata-archive-keyring.
    (Reading database ... 115719 files and directories currently installed.)
    Preparing to unpack .../influxdata-archive-keyring_2026.01.09_all.deb ...
    Unpacking influxdata-archive-keyring (2026.01.09) ...
    Selecting previously unselected package influxdb2-cli.
    Preparing to unpack .../influxdb2-cli_2.7.5-3_arm64.deb ...
    Unpacking influxdb2-cli (2.7.5-3) ...
    dpkg: error processing archive /var/cache/apt/archives/influxdb2-cli_2.7.5-3_arm64.deb (--unpack):
     trying to overwrite '/usr/bin/influx', which is also in package influxdb-client (1.6.7~rc0-2+b12)
    dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
    Errors were encountered while processing:
    Error: Sub-process /usr/bin/dpkg returned an error code (1)
    pi@raspberrypi:~ $
    • M marcelinho
      influxdb2-cli:
        Installed: (none)
        Candidate: 2.7.5-3
        Version table:
           2.7.5-3 500
           2.7.5-2 500
           2.7.5-1 500
           2.7.3-1 500
           2.7.1-2 500
           2.6.1 500
           2.6.0 500
           2.5.0 500
           2.4.0 500
           2.3.0 500
      influxdb2-cli:
        Installed: (none)
        Candidate: 2.7.5-3
        Version table:
           2.7.5-3 500
           2.7.5-2 500
           2.7.5-1 500
           2.7.3-1 500
           2.7.1-2 500
           2.6.1 500
           2.6.0 500
           2.5.0 500
           2.4.0 500
           2.3.0 500
      und dann folgendes:
      Installing:
        influxdb2-cli
      Summary:
      Continue? [Y/n] y
      pi@raspberrypi:~ $
      @marcelinho sagte in Hilfestellung Raspi4: Zigbee2Mqtt, InfluxDB, Grafana:
      influxdb-client
      sudo apt remove influxdb-client
        marcelinho
        @thomas-braun ok danke müsste funktioniert haben, muss ich noch was machen oder einfach mal ein backitup machen lassen:
        pi@raspberrypi:~ $ sudo apt remove influxdb-client
        The following package was automatically installed and is no longer required:
        Use 'sudo apt autoremove' to remove it.
        REMOVING:
          influxdb-client
        Summary:
          Upgrading: 0, Installing: 0, Removing: 1, Not Upgrading: 1
          1 not fully installed or removed.
          Freed space: 6,926 kB
        Continue? [Y/n] y
        (Reading database ... 115734 files and directories currently installed.)
        Removing influxdb-client (1.6.7~rc0-2+b12) ...
        Setting up influxdata-archive-keyring (2026.01.09) ...
        Processing triggers for man-db (2.13.1-1) ...
        Hit:5 https://apt.grafana.com stable InRelease
        Hit:6 https://repos.influxdata.com/debian stable InRelease
        Warning: https://deb.nodesource.com/node_24.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
        influxdb2-cli:
          Installed: (none)
          Candidate: 2.7.5-3
          Version table:
             2.7.5-3 500
             2.7.5-2 500
             2.7.5-1 500
             2.7.3-1 500
             2.7.1-2 500
             2.6.1 500
             2.6.0 500
             2.5.0 500
             2.4.0 500
             2.3.0 500
        Installing:
          influxdb2-cli
        Summary:
          Upgrading: 0, Installing: 1, Removing: 0, Not Upgrading: 1
          Download size: 0 B / 11.0 MB
        (Reading database ... 115727 files and directories currently installed.)
        Setting up influxdb2-cli (2.7.5-3) ...
        pi@raspberrypi:~ $
        • M marcelinho
          REMOVING:
            influxdb-client
          Summary:
          Continue? [Y/n] y
          influxdb2-cli:
            Installed: (none)
            Candidate: 2.7.5-3
            Version table:
               2.7.5-3 500
               2.7.5-2 500
               2.7.5-1 500
               2.7.3-1 500
               2.7.1-2 500
               2.6.1 500
               2.6.0 500
               2.5.0 500
               2.4.0 500
               2.3.0 500
          Installing:
            influxdb2-cli
          Summary:
          pi@raspberrypi:~ $
          @marcelinho
          Dann schmeiß das andere Update noch drauf.
          sudo apt update
          sudo apt full-upgrade
            marcelinho
            @thomas-braun danke perfekt, bei backitup meckert er wie folgt:
            13:17:13.829INFOguiBackup gestartet ...
            13:17:19.819DEBUGiobrokerhost.raspberrypi 6140 objects saved
            13:17:20.506DEBUGiobrokerhost.raspberrypi 4775 states saved
            13:17:20.514DEBUGiobrokerhost.raspberrypi Validating backup ...
            13:17:20.572DEBUGiobrokerhost.raspberrypi "config.json" is valid
            13:17:20.580DEBUGiobrokerhost.raspberrypi "objects.jsonl" exists
            host.raspberrypi "states.jsonl" exists
            13:17:21.307DEBUGiobrokerhost.raspberrypi JSONL lines are valid
            13:17:21.322DEBUGiobrokerhost.raspberrypi The backup is valid!
            13:17:22.375DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2026_01_10-13_17_13_backupiobroker.tar.gz
            This backup can only be restored with js-controller version 7.0 or higher
            13:17:23.436DEBUGiobrokerdone
            13:17:23.594DEBUGinfluxDBInfluxDB-Backup started ...
            13:17:23.646DEBUGinfluxDBStart InfluxDB Backup ...
            13:17:23.647DEBUGinfluxDBInfluxDB Backup tmp directory created
            13:17:23.986DEBUGinfluxDBTry deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2026_01_10-13_17_23_backupiobroker"
            13:17:23.990DEBUGinfluxDBInfluxDB tmp directory "/opt/iobroker/backups/influxDB_2026_01_10-13_17_23_backupiobroker" successfully deleted
            [DEBUG] [influxDB] -
            13:17:24.072ERRORinfluxDBError: Command failed: influx backup --bucket admin --host http://localhost:8086 -t glsa_WGijBfr5pXcOhQGUa6854B3rQDxteA1a_ce61e1c9 "/opt/iobroker/backups/influxDB_2026_01_10-13_17_23_backupiobroker"
            2026/01/10 13:17:23 INFO: Downloading metadata snapshot
            Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: unauthorized access
            13:17:24.074DEBUGinfluxDBInfluxDB-Backup for is finish
            13:17:24.076DEBUGinfluxDBdone
            13:17:25.026DEBUGzigbee2mqttCreated zigbee2mqtt directory
            13:17:25.037DEBUGzigbee2mqttcompress from Zigbee2MQTT started ...
            13:17:25.059DEBUGzigbee2mqttZigbee2MQTT tmp copy finish
            13:17:25.108DEBUGzigbee2mqttBackup created: /opt/iobroker/backups/zigbee2mqtt_2026_01_10-13_17_24_backupiobroker.tar.gz
            13:17:25.111DEBUGzigbee2mqttTry deleting the old zigbee2mqtt tmp directory: "/opt/iobroker/backups/zigbee2mqtt_tmp"
            13:17:25.155DEBUGzigbee2mqttzigbee2mqtt tmp directory "/opt/iobroker/backups/zigbee2mqtt_tmp" successfully deleted
            13:17:25.209DEBUGzigbee2mqttdone
            13:17:25.227DEBUGgrafanaStart Grafana Backup ...
            13:17:25.231DEBUGgrafanaCreated grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
            13:17:25.238DEBUGgrafanaCreated dashboard directory
            13:17:25.242DEBUGgrafanaCreated folder directory
            13:17:25.243DEBUGgrafanaCreated dashboards_manually_restore directory
            13:17:25.283DEBUGgrafanaCreated datasource directory
            13:17:25.286DEBUGgrafanastart Grafana request ...
            13:17:25.347DEBUGgrafanaGrafana is available ... Status: 200
            13:17:25.638DEBUGgrafanafound Dashboard: home-mathis
            13:17:25.951DEBUGgrafanaSaved dashboard-folder mapping
            13:17:26.014DEBUGgrafanaSave Folder "Shared with me"
            13:17:26.325DEBUGgrafanastart Grafana backup compress ...
            13:17:31.339DEBUGgrafanaBackup created: /opt/iobroker/backups/grafana_2026_01_10-13_17_26_backupiobroker.tar.gz
            13:17:31.344DEBUGgrafanaTry deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
            13:17:31.355DEBUGgrafanaGrafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
            13:17:31.388DEBUGgrafanadone
            13:17:31.839DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
            13:17:31.919DEBUGjavascriptsfound Script: Daikin_PV_Überschuss
            13:17:32.026DEBUGjavascriptsfound Script: Flur_Türsensor_+_Bewegungsmelder
            13:17:32.176DEBUGjavascriptsfound Script: Gaszähler
            13:17:32.326DEBUGjavascriptsfound Script: Hausspeicher_Laden_Entladen
            13:17:32.476DEBUGjavascriptsfound Script: Hausspeicher_gerechnet
            13:17:32.626DEBUGjavascriptsfound Script: Hausspeicher_gespart
            13:17:32.776DEBUGjavascriptsfound Script: Hausverbrauch_aktuell
            13:17:32.925DEBUGjavascriptsfound Script: Heizung_Badezimmer_Keller
            13:17:33.077DEBUGjavascriptsfound Script: Heizung_Kinderzimmer
            13:17:33.226DEBUGjavascriptsfound Script: Heizung_Wohnzimmer
            13:17:33.377DEBUGjavascriptsfound Script: Kosten_Strom_Tag
            13:17:33.525DEBUGjavascriptsfound Script: LEDPanel
            13:17:33.676DEBUGjavascriptsfound Script: Licht_Keller_Kontakt
            13:17:33.827DEBUGjavascriptsfound Script: Licht_Schlafzimmer
            13:17:33.977DEBUGjavascriptsfound Script: Licht_Speisekammer
            13:17:34.128DEBUGjavascriptsfound Script: Licht_Umkleide
            13:17:34.278DEBUGjavascriptsfound Script: Netzeinspeisung
            13:17:34.427DEBUGjavascriptsfound Script: PV_Leistung
            13:17:34.577DEBUGjavascriptsfound Script: PV_Tagesertrag
            13:17:34.728DEBUGjavascriptsfound Script: Rolladen_Auf
            13:17:34.878DEBUGjavascriptsfound Script: Rolladen_Sonnenaufgang
            13:17:35.028DEBUGjavascriptsfound Script: Rolladen_Sonnenuntergang
            13:17:35.178DEBUGjavascriptsfound Script: Rolladen_Zu
            13:17:35.329DEBUGjavascriptsfound Script: Trinkbrunnen
            13:17:35.479DEBUGjavascriptsfound Script: Wasserzähler
            13:17:35.629DEBUGjavascriptsfound Script: Weihnachtsbaum
            13:17:35.779DEBUGjavascriptsfound Script: Wochentage&Wochenende
            13:17:35.945DEBUGjavascriptsTry deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
            13:17:35.988DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
            13:17:35.993DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2026_01_10-13_17_31_backupiobroker.tar.gz
            13:17:35.995DEBUGjavascriptsdone
            13:17:37.455ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
            13:17:37.495DEBUGcleandone
            13:17:37.608DEBUGhistoryHTMLnew history html values created
            13:17:37.701DEBUGhistoryHTMLdone
            13:17:37.875DEBUGhistoryJSONnew history json values created
            13:17:37.880DEBUGhistoryJSONdone
            13:17:40.376DEBUGnotificationAdmin notification will be sent
            13:17:40.417DEBUGnotificationdone
            13:17:40.533INFOguiDas Backup wurde erfolgreich erstellt!
            • M marcelinho
              Falsches Token? Bei influx selber bin ich dann aber raus.
                marcelinho
                weiß jemand wieso mein Backitup bei Influxdb nicht geht, habe die Token neu erstellt mit allen rechten aber irgendwie läuft es nicht:
                19:56:58.888DEBUGinfluxDBInfluxDB-Backup started ...
                19:56:58.892DEBUGinfluxDBStart InfluxDB Backup ...
                19:56:58.901DEBUGinfluxDBInfluxDB Backup tmp directory created
                19:56:59.372ERRORinfluxDBError: Command failed: influx backup --bucket admin --host http://localhost:8086 -t tX9aUgElHh8iiEJKoYay0Zhsxjr1OTuAnSaiR73lfwUAXzYlD3MlJeu_g6_WbjAnLKMFsAPylqSJ2f7Ke4BfZg== "/opt/iobroker/backups/influxDB_2026_01_10-19_56_58_backupiobroker"
                2026/01/10 19:56:59 INFO: Downloading metadata snapshot
                Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
                19:56:59.382DEBUGinfluxDBInfluxDB-Backup for is finish
                19:56:59.385DEBUGinfluxDBdone
                Die Tokens stimmen, die Adapter sind grün. Wüsste nicht wo es hakt. Kann es mit Debian 13 zu tun haben bei Influx 2.x ? auf meiner anderen Micro SD mit Debian 12 geht es mit den Einstellungen.
                HomoranH Thomas BraunT crunchipC 3 Antworten Letzte Antwort
                • M marcelinho
                  das heisst gar nix!
                  für backitup brauchst du das admin token
                  • M marcelinho
                    #66
                    Nein.
                    • M marcelinho
                      crunchipC Offline
                      crunchipC Offline
                      #67
                      https://docs.influxdata.com/influxdb/v2/admin/backup-restore/backup/
                      The root authorization token (the token created for the first user in the InfluxDB setup process).
                      https://docs.influxdata.com/influxdb/v2/admin/tokens/
                        marcelinho
                        #68
                        versteht jemand warum ich mich beim Backup im Kreis drehe? Bei der InfluxDB Adapter ist grün Daten kommen in Grafana an. Token läuft. Aber wenn ich ein All Access API Token erstelle kommt immer der Fehler:
                        "401 Unauthorized"
                        pi@raspberrypi:~ $ rm influxdb2-client-2.7.5-linux-amd64.tar.gz
                        pi@raspberrypi:~ $ rm -rf ~/.influxdbv2
                        pi@raspberrypi:~ $ rm -f ~/influxdb2-client-*.tar.gz
                        sudo rm -f /usr/bin/influx
                        sudo rm -f /usr/local/bin/influx
                        pi@raspberrypi:~ $ curl -sL https://repos.influxdata.com/influxdata-archive.key | sudo gpg --dearmor -o /usr/share/keyrings/influxdata-archive.gpg
                        echo "deb [signed-by=/usr/share/keyrings/influxdata-archive.gpg] https://repos.influxdata.com/debian stable main" | sudo tee /etc/apt/sources.list.d/influxdata.list
                        sudo apt update
                        File '/usr/share/keyrings/influxdata-archive.gpg' exists. Overwrite? (y/N) y
                        Hit:5 https://repos.influxdata.com/debian stable InRelease
                        All packages are up to date.
                        pi@raspberrypi:~ $ sudo apt install influxdb2-cli -y
                        Installing:
                          influxdb2-cli
                        Summary:
                          Upgrading: 0, Installing: 1, Removing: 0, Not Upgrading: 0
                        (Reading database ... 115732 files and directories currently installed.)
                        pi@raspberrypi:~ $ influx version
                        Influx CLI dev (git: a79a2a1b825867421d320428538f76a4c90aa34c) build_date: 2024-04-16T14:34:26Z
                        pi@raspberrypi:~ $ export INFLUX_TOKEN=xjIUdQBiweNaUi4jNnq7t0QiCRMYahTp1k8O91CNfOHobTWtFNfjI6R3gaeA8msuoxeeouI_eIGu6g7KmRfxew==
                        pi@raspberrypi:~ $ influx org list
                        ID                      Name
                        9fc10391e54f07c7        admin
                        pi@raspberrypi:~ $ mkdir -p /home/pi/influx-backup-test
                        influx backup --org admin /home/pi/influx-backup-test
                        2026/01/13 15:06:54 INFO: Downloading metadata snapshot
                        pi@raspberrypi:~ $ rm -rf /home/pi/influx-backup-test
                        pi@raspberrypi:~ $
                        • M marcelinho
                          "401 Unauthorized"
                          sudo apt update
                          Installing:
                            influxdb2-cli
                          Summary:
                          ID                      Name
                          pi@raspberrypi:~ $
                          Marc BergM Online
                          Marc BergM Online
                          Marc Berg
                          #69
                          Falscher Token-Typ. Schau bitte in die Doku zum Backitup Adapter
                          https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup#operator-token-für-influxdb-2x-wiederherstellen
                            marcelinho
                            #70
                            @marc-berg danke vielmals, hat geklappt.
                            Jetzt habe ich alles konfiguriert :) Nur noch eine "Fehlermeldung" ist die zu vernachlässigen?
                            Get:3 http://deb.debian.org/debian-security trixie-security InRelease [43.4 kB]
                            Fetched 43.4 kB in 0s (88.8 kB/s)
                            pi@raspberrypi:~ $
                            • M marcelinho
                              pi@raspberrypi:~ $
                              #71
                              @marcelinho
                              Ja, für den Moment vernachlässigen.
                              In nächster Zeit müssten aber die Schlüssel für das nodesource Repo aktualisiert werden.
                              Die sind aber noch nicht verfügbar.
                              • M marcelinho
                                @crunchip ich weis nicht genau was du meinst. Ich hatte Mosquitto wohl nur für Testzwecke installiert (damals nur Benutzer und Passwort aufgeschrieben) mqtt Adapter ist auf Server mit 0.0.0.0:1885 eingestellt gewesen. Der Z2M war auf Websocket. Da ich mir meine alte Karte Debian 12 wohl mit Trixie upgrade zerschossen hab und nicht mehr per SSH drauf komme kann ich leider nicht mehr schauen welcher Port Mosquitto war. Die alte Karte geht noch, aber per SSH leider nicht mehr. Ich würde ungern alle meine Geräte neu einbinden müssen. Obwohl ich denke das ich seit 1 Woche schon versuche Yaml, mqtt und z2m anzupassen es schon längst erledigt wäre. Ich versteh glaube ich das ganze Konstrukt nicht wirklich. Wer mit wem kommuniziert und wer was genau braucht. Wenn ich es schaffe die Adapter grün zu bekommen dann bekomme ich nicht die Geräte rein durch das Backup. Irgendwie dreh ich mich leider im Kreis...
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #72
                                @marcelinho
                                na was heisst den wer mit wem kommuniziert..
                                z2m braucht ein mqtt .punkt.,. obs der mosquitto oder der iobroker mqtt server.. oder den startet das z2m nicht
                                der Adapter z2m hingegen braucht z2m um zu starten. diesen kann st du per WS = websocket oder so dass dieser auf den externen mqtt server horcht einstellen
                                ODER
                                du macht per mit diesem adapter einen mqtt server auf.. das gaht auch.. dann musst du z2m auf diesenauch konfigurieren
                                  marcelinho
                                  #73
                                  Guten Morgen zusammen, ist die Meldung kritisch?
                                  Get:2 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB]
                                  Get:4 http://archive.raspberrypi.com/debian trixie InRelease [54.8 kB]
                                  Hit:6 https://deb.nodesource.com/node_24.x nodistro InRelease
                                  Get:7 https://apt.grafana.com stable InRelease [7,660 B]
                                  Get:8 http://deb.debian.org/debian-security trixie-security/main armhf Packages                              [93.0 kB]
                                  Get:9 http://archive.raspberrypi.com/debian trixie/main arm64 Packages [376 kB]
                                  Err:6 https://deb.nodesource.com/node_24.x nodistro InRelease
                                    Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing                              key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No bin                             ding signature at time 2026-01-19T15:30:12Z   because: Policy rejected non-revoc                             ation signature (PositiveCertification) requiring second pre-image resistance                                because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                                  Get:10 http://deb.debian.org/debian-security trixie-security/main arm64 Packages                              [99.0 kB]
                                  Get:11 https://apt.grafana.com stable/main arm64 Packages [421 kB]
                                  Get:12 http://deb.debian.org/debian-security trixie-security/main Translation-en                              [63.2 kB]
                                  Get:13 http://archive.raspberrypi.com/debian trixie/main armhf Packages [371 kB]
                                  Get:14 https://apt.grafana.com stable/main armhf Packages [491 kB]
                                  Fetched 2,067 kB in 2s (1,108 kB/s)
                                  10 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                  Warning: An error occurred during the signature verification. The repository is                              not updated and the previous index files will be used. OpenPGP signature verific                             ation failed: https://deb.nodesource.com/node_24.x nodistro InRelease: Sub-proce                             ss /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F7                             1F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signat                             ure at time 2026-01-19T15:30:12Z   because: Policy rejected non-revocation signa                             ture (PositiveCertification) requiring second pre-image resistance   because: SH                             A1 is not considered secure since 2026-02-01T00:00:00Z
                                  Warning: Failed to fetch https://deb.nodesource.com/node_24.x/dists/nodistro/InR                             elease  Sub-process /usr/bin/sqv returned an error code (1), error message is: S                             igning key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:                                         No binding signature at time 2026-01-19T15:30:12Z   because: Policy rejected non                             -revocation signature (PositiveCertification) requiring second pre-image resista                             nce   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                                  Warning: Some index files failed to download. They have been ignored, or old one                             s used instead.
                                  pi@raspberrypi:~ $ sudo apt upgrade
                                  Upgrading:
                                    grafana   libc-dev-bin  libc6      libssl3t64  openssl
                                    libc-bin  libc-l10n     libc6-dev  locales     openssl-provider-legacy
                                  Summary:
                                    Upgrading: 10, Installing: 0, Removing: 0, Not Upgrading: 0
                                    Download size: 204 MB
                                    Space needed: 872 kB / 19.0 GB available
                                  Continue? [Y/n] y
                                  Get:1 http://deb.debian.org/debian-security trixie-security/main arm64 openssl-p                             rovider-legacy arm64 3.5.4-1~deb13u2 [307 kB]
                                  Get:2 http://archive.raspberrypi.com/debian trixie/main arm64 libc6-dev arm64 2.                             41-12+rpt1+deb13u1 [2,353 kB]
                                  Get:3 http://deb.debian.org/debian-security trixie-security/main arm64 libssl3t6                             4 arm64 3.5.4-1~deb13u2 [2,750 kB]
                                  Get:4 https://apt.grafana.com stable/main arm64 grafana arm64 12.3.2 [185 MB]
                                  Get:5 http://archive.raspberrypi.com/debian trixie/main arm64 libc-dev-bin arm64                              2.41-12+rpt1+deb13u1 [62.1 kB]
                                  Get:6 http://archive.raspberrypi.com/debian trixie/main arm64 libc6 arm64 2.41-1                             2+rpt1+deb13u1 [5,184 kB]
                                  Get:7 http://archive.raspberrypi.com/debian trixie/main arm64 libc-bin arm64 2.4                             1-12+rpt1+deb13u1 [765 kB]
                                  Get:8 http://archive.raspberrypi.com/debian trixie/main arm64 libc-l10n all 2.41                             -12+rpt1+deb13u1 [1,654 kB]
                                  Get:9 http://archive.raspberrypi.com/debian trixie/main arm64 locales all 2.41-1                             2+rpt1+deb13u1 [5,108 kB]
                                  Get:10 http://deb.debian.org/debian-security trixie-security/main arm64 openssl                              arm64 3.5.4-1~deb13u2 [1,459 kB]
                                  Fetched 204 MB in 1min 58s (1,739 kB/s)
                                  Reading changelogs... Done
                                  Preconfiguring packages ...
                                  (Reading database ... 115736 files and directories currently installed.)
                                  Preparing to unpack .../libc6-dev_2.41-12+rpt1+deb13u1_arm64.deb ...
                                  Unpacking libc6-dev:arm64 (2.41-12+rpt1+deb13u1) over (2.41-12+rpt1) ...
                                  Preparing to unpack .../libc-dev-bin_2.41-12+rpt1+deb13u1_arm64.deb ...
                                  Unpacking libc-dev-bin (2.41-12+rpt1+deb13u1) over (2.41-12+rpt1) ...
                                  Preparing to unpack .../libc6_2.41-12+rpt1+deb13u1_arm64.deb ...
                                  Unpacking libc6:arm64 (2.41-12+rpt1+deb13u1) over (2.41-12+rpt1) ...
                                  Setting up libc6:arm64 (2.41-12+rpt1+deb13u1) ...
                                  Preparing to unpack .../libc-bin_2.41-12+rpt1+deb13u1_arm64.deb ...
                                  Unpacking libc-bin (2.41-12+rpt1+deb13u1) over (2.41-12+rpt1) ...
                                  Setting up libc-bin (2.41-12+rpt1+deb13u1) ...
                                  Preparing to unpack .../openssl-provider-legacy_3.5.4-1~deb13u2_arm64.deb ...
                                  Unpacking openssl-provider-legacy (3.5.4-1~deb13u2) over (3.5.4-1~deb13u1+rpt1)                              ...
                                  Setting up openssl-provider-legacy (3.5.4-1~deb13u2) ...
                                  Preparing to unpack .../libssl3t64_3.5.4-1~deb13u2_arm64.deb ...
                                  Unpacking libssl3t64:arm64 (3.5.4-1~deb13u2) over (3.5.4-1~deb13u1+rpt1) ...
                                  Setting up libssl3t64:arm64 (3.5.4-1~deb13u2) ...
                                  Preparing to unpack .../libc-l10n_2.41-12+rpt1+deb13u1_all.deb ...
                                  Unpacking libc-l10n (2.41-12+rpt1+deb13u1) over (2.41-12+rpt1) ...
                                  Preparing to unpack .../locales_2.41-12+rpt1+deb13u1_all.deb ...
                                  Unpacking locales (2.41-12+rpt1+deb13u1) over (2.41-12+rpt1) ...
                                  Preparing to unpack .../grafana_12.3.2_arm64.deb ...
                                  Unpacking grafana (12.3.2) over (12.3.1) ...
                                  Preparing to unpack .../openssl_3.5.4-1~deb13u2_arm64.deb ...
                                  Unpacking openssl (3.5.4-1~deb13u2) over (3.5.4-1~deb13u1+rpt1) ...
                                  Setting up libc-l10n (2.41-12+rpt1+deb13u1) ...
                                  Setting up locales (2.41-12+rpt1+deb13u1) ...
                                  Generating locales (this might take a while)...
                                    en_GB.UTF-8... done
                                  Generation complete.
                                  Setting up libc-dev-bin (2.41-12+rpt1+deb13u1) ...
                                  Setting up openssl (3.5.4-1~deb13u2) ...
                                  Setting up grafana (12.3.2) ...
                                  Restarting grafana-server service... OK
                                  Setting up libc6-dev:arm64 (2.41-12+rpt1+deb13u1) ...
                                  Processing triggers for systemd (257.9-1~deb13u1) ...
                                  Processing triggers for libc-bin (2.41-12+rpt1+deb13u1) ...
                                  Err:7 https://deb.nodesource.com/node_24.x nodistro InRelease
                                  pi@raspberrypi:~ $
                                  • M marcelinho
                                    Upgrading:
                                    Summary:
                                    Continue? [Y/n] y
                                      en_GB.UTF-8... done
                                    pi@raspberrypi:~ $
                                    #74
                                    @marcelinho
                                    Ja, der aktuelle Schlüssel fehlt.
                                    Installier da wieder nodejs@22:
                                    iob nodejs-update
                                    Rückfragen des Skripts mit y beantworten.
                                    Siehe auch:
                                    https://forum.iobroker.net/topic/83744/nodesource-repo-openpgp-signature-verification-failed
                                      marcelinho
                                      #75
                                      @thomas-braun lieben Dank, hat geklappt. Schönen Sonntag noch.
