  4. Hilfestellung Raspi4: Zigbee2Mqtt, InfluxDB, Grafana
    6.4k
75 Beiträge 8 Kommentatoren 6.9k Aufrufe 7 Beobachtet
  • M marcelinho
    @thomas-braun bringt er mir irgendwie immer Fehler:
    pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/influx*
    sudo rm /etc/apt/keyrings/influx*
    curl --silent --location -O https://repos.influxdata.com/influxdata-archive.key
    gpg --show-keys --with-fingerprint --with-colons ./influxdata-archive.key 2>&1 | grep -q '^fpr:\+24C975CBA61A024EE1B631787C3D57159FC2F927:$' && cat influxdata-archive.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive.gpg > /dev/null
    echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
    rm influxdata-archive.key
    rm: cannot remove '/etc/apt/keyrings/influx*': No such file or directory
    pi@raspberrypi:~ $ sudo apt install influxdb2-cli
    Package influxdb2-cli is not available, but is referred to by another package.
    This may mean that the package is missing, has been obsoleted, or
    is only available from another source
    Error: Package 'influxdb2-cli' has no installation candidate
    pi@raspberrypi:~ $
    @marcelinho
    Weil du mit deinem Paketmanager nicht umgehen kannst...
    sudo apt update
    apt policy influxdb2-cli
    Wenn es dann einen Installationskandidaten gibt:
      marcelinho
      @thomas-braun bringt er mir das:
      pi@raspberrypi:~ $ sudo apt update
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://deb.debian.org/debian trixie-updates InRelease
      Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
      Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
      Get:5 https://repos.influxdata.com/debian stable InRelease [6,913 B]
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_24.x nodistro InRelease
      Get:8 https://repos.influxdata.com/debian stable/main arm64 Packages [23.9 kB]
      Get:9 https://repos.influxdata.com/debian stable/main armhf Packages [9,701 B]
      Fetched 40.5 kB in 0s (107 kB/s)
      1 package can be upgraded. Run 'apt list --upgradable' to see it.
      Warning: https://deb.nodesource.com/node_24.x/dists/nodistro/InRelease: Policy will reject signature w        ithin a year, see --audit for details
      influxdb2-cli:
        Installed: (none)
        Candidate: 2.7.5-3
        Version table:
           2.7.5-3 500
              500 https://repos.influxdata.com/debian stable/main arm64 Packages
           2.7.5-2 500
           2.7.5-1 500
           2.7.3-1 500
           2.7.1-2 500
           2.6.1 500
           2.6.0 500
           2.5.0 500
           2.4.0 500
           2.3.0 500
      lines 1-23...skipping...
      influxdb2-cli:
        Installed: (none)
        Candidate: 2.7.5-3
        Version table:
           2.7.5-3 500
           2.7.5-2 500
           2.7.5-1 500
           2.7.3-1 500
           2.7.1-2 500
           2.6.1 500
           2.6.0 500
           2.5.0 500
           2.4.0 500
           2.3.0 500
      und dann folgendes:
      Installing:
        influxdb2-cli
      Installing dependencies:
        influxdata-archive-keyring
      Summary:
        Upgrading: 0, Installing: 2, Removing: 0, Not Upgrading: 1
        Download size: 11.0 MB
        Space needed: 24.7 MB / 20.9 GB available
      Continue? [Y/n] y
      Get:1 https://repos.influxdata.com/debian stable/main arm64 influxdata-archive-keyring all 2026.01.09 [10.7 kB]
      Get:2 https://repos.influxdata.com/debian stable/main arm64 influxdb2-cli arm64 2.7.5-3 [11.0 MB]
      Fetched 11.0 MB in 5s (2,364 kB/s)
      Selecting previously unselected package influxdata-archive-keyring.
      (Reading database ... 115719 files and directories currently installed.)
      Preparing to unpack .../influxdata-archive-keyring_2026.01.09_all.deb ...
      Unpacking influxdata-archive-keyring (2026.01.09) ...
      Selecting previously unselected package influxdb2-cli.
      Preparing to unpack .../influxdb2-cli_2.7.5-3_arm64.deb ...
      Unpacking influxdb2-cli (2.7.5-3) ...
      dpkg: error processing archive /var/cache/apt/archives/influxdb2-cli_2.7.5-3_arm64.deb (--unpack):
       trying to overwrite '/usr/bin/influx', which is also in package influxdb-client (1.6.7~rc0-2+b12)
      dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
      Errors were encountered while processing:
      Error: Sub-process /usr/bin/dpkg returned an error code (1)
      pi@raspberrypi:~ $
      • M marcelinho
        influxdb2-cli:
          Installed: (none)
          Candidate: 2.7.5-3
          Version table:
             2.7.5-3 500
             2.7.5-2 500
             2.7.5-1 500
             2.7.3-1 500
             2.7.1-2 500
             2.6.1 500
             2.6.0 500
             2.5.0 500
             2.4.0 500
             2.3.0 500
        influxdb2-cli:
          Installed: (none)
          Candidate: 2.7.5-3
          Version table:
             2.7.5-3 500
             2.7.5-2 500
             2.7.5-1 500
             2.7.3-1 500
             2.7.1-2 500
             2.6.1 500
             2.6.0 500
             2.5.0 500
             2.4.0 500
             2.3.0 500
        und dann folgendes:
        Installing:
          influxdb2-cli
        Summary:
        Continue? [Y/n] y
        pi@raspberrypi:~ $
        @marcelinho sagte in Hilfestellung Raspi4: Zigbee2Mqtt, InfluxDB, Grafana:
        influxdb-client
        sudo apt remove influxdb-client
          marcelinho
          @thomas-braun ok danke müsste funktioniert haben, muss ich noch was machen oder einfach mal ein backitup machen lassen:
          pi@raspberrypi:~ $ sudo apt remove influxdb-client
          The following package was automatically installed and is no longer required:
          Use 'sudo apt autoremove' to remove it.
          REMOVING:
            influxdb-client
          Summary:
            Upgrading: 0, Installing: 0, Removing: 1, Not Upgrading: 1
            1 not fully installed or removed.
            Freed space: 6,926 kB
          Continue? [Y/n] y
          (Reading database ... 115734 files and directories currently installed.)
          Removing influxdb-client (1.6.7~rc0-2+b12) ...
          Setting up influxdata-archive-keyring (2026.01.09) ...
          Processing triggers for man-db (2.13.1-1) ...
          Hit:5 https://apt.grafana.com stable InRelease
          Hit:6 https://repos.influxdata.com/debian stable InRelease
          Warning: https://deb.nodesource.com/node_24.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
          influxdb2-cli:
            Installed: (none)
            Candidate: 2.7.5-3
            Version table:
               2.7.5-3 500
               2.7.5-2 500
               2.7.5-1 500
               2.7.3-1 500
               2.7.1-2 500
               2.6.1 500
               2.6.0 500
               2.5.0 500
               2.4.0 500
               2.3.0 500
          Installing:
            influxdb2-cli
          Summary:
            Upgrading: 0, Installing: 1, Removing: 0, Not Upgrading: 1
            Download size: 0 B / 11.0 MB
          (Reading database ... 115727 files and directories currently installed.)
          Setting up influxdb2-cli (2.7.5-3) ...
          pi@raspberrypi:~ $
          • M marcelinho
            REMOVING:
              influxdb-client
            Summary:
            Continue? [Y/n] y
            influxdb2-cli:
              Installed: (none)
              Candidate: 2.7.5-3
              Version table:
                 2.7.5-3 500
                 2.7.5-2 500
                 2.7.5-1 500
                 2.7.3-1 500
                 2.7.1-2 500
                 2.6.1 500
                 2.6.0 500
                 2.5.0 500
                 2.4.0 500
                 2.3.0 500
            Installing:
              influxdb2-cli
            Summary:
            pi@raspberrypi:~ $
            @marcelinho
            Dann schmeiß das andere Update noch drauf.
            sudo apt update
            sudo apt full-upgrade
              marcelinho
              @thomas-braun danke perfekt, bei backitup meckert er wie folgt:
              13:17:13.829INFOguiBackup gestartet ...
              13:17:19.819DEBUGiobrokerhost.raspberrypi 6140 objects saved
              13:17:20.506DEBUGiobrokerhost.raspberrypi 4775 states saved
              13:17:20.514DEBUGiobrokerhost.raspberrypi Validating backup ...
              13:17:20.572DEBUGiobrokerhost.raspberrypi "config.json" is valid
              13:17:20.580DEBUGiobrokerhost.raspberrypi "objects.jsonl" exists
              host.raspberrypi "states.jsonl" exists
              13:17:21.307DEBUGiobrokerhost.raspberrypi JSONL lines are valid
              13:17:21.322DEBUGiobrokerhost.raspberrypi The backup is valid!
              13:17:22.375DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2026_01_10-13_17_13_backupiobroker.tar.gz
              This backup can only be restored with js-controller version 7.0 or higher
              13:17:23.436DEBUGiobrokerdone
              13:17:23.594DEBUGinfluxDBInfluxDB-Backup started ...
              13:17:23.646DEBUGinfluxDBStart InfluxDB Backup ...
              13:17:23.647DEBUGinfluxDBInfluxDB Backup tmp directory created
              13:17:23.986DEBUGinfluxDBTry deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2026_01_10-13_17_23_backupiobroker"
              13:17:23.990DEBUGinfluxDBInfluxDB tmp directory "/opt/iobroker/backups/influxDB_2026_01_10-13_17_23_backupiobroker" successfully deleted
              [DEBUG] [influxDB] -
              13:17:24.072ERRORinfluxDBError: Command failed: influx backup --bucket admin --host http://localhost:8086 -t glsa_WGijBfr5pXcOhQGUa6854B3rQDxteA1a_ce61e1c9 "/opt/iobroker/backups/influxDB_2026_01_10-13_17_23_backupiobroker"
              2026/01/10 13:17:23 INFO: Downloading metadata snapshot
              Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: unauthorized access
              13:17:24.074DEBUGinfluxDBInfluxDB-Backup for is finish
              13:17:24.076DEBUGinfluxDBdone
              13:17:25.026DEBUGzigbee2mqttCreated zigbee2mqtt directory
              13:17:25.037DEBUGzigbee2mqttcompress from Zigbee2MQTT started ...
              13:17:25.059DEBUGzigbee2mqttZigbee2MQTT tmp copy finish
              13:17:25.108DEBUGzigbee2mqttBackup created: /opt/iobroker/backups/zigbee2mqtt_2026_01_10-13_17_24_backupiobroker.tar.gz
              13:17:25.111DEBUGzigbee2mqttTry deleting the old zigbee2mqtt tmp directory: "/opt/iobroker/backups/zigbee2mqtt_tmp"
              13:17:25.155DEBUGzigbee2mqttzigbee2mqtt tmp directory "/opt/iobroker/backups/zigbee2mqtt_tmp" successfully deleted
              13:17:25.209DEBUGzigbee2mqttdone
              13:17:25.227DEBUGgrafanaStart Grafana Backup ...
              13:17:25.231DEBUGgrafanaCreated grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
              13:17:25.238DEBUGgrafanaCreated dashboard directory
              13:17:25.242DEBUGgrafanaCreated folder directory
              13:17:25.243DEBUGgrafanaCreated dashboards_manually_restore directory
              13:17:25.283DEBUGgrafanaCreated datasource directory
              13:17:25.286DEBUGgrafanastart Grafana request ...
              13:17:25.347DEBUGgrafanaGrafana is available ... Status: 200
              13:17:25.638DEBUGgrafanafound Dashboard: home-mathis
              13:17:25.951DEBUGgrafanaSaved dashboard-folder mapping
              13:17:26.014DEBUGgrafanaSave Folder "Shared with me"
              13:17:26.325DEBUGgrafanastart Grafana backup compress ...
              13:17:31.339DEBUGgrafanaBackup created: /opt/iobroker/backups/grafana_2026_01_10-13_17_26_backupiobroker.tar.gz
              13:17:31.344DEBUGgrafanaTry deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
              13:17:31.355DEBUGgrafanaGrafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
              13:17:31.388DEBUGgrafanadone
              13:17:31.839DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
              13:17:31.919DEBUGjavascriptsfound Script: Daikin_PV_Überschuss
              13:17:32.026DEBUGjavascriptsfound Script: Flur_Türsensor_+_Bewegungsmelder
              13:17:32.176DEBUGjavascriptsfound Script: Gaszähler
              13:17:32.326DEBUGjavascriptsfound Script: Hausspeicher_Laden_Entladen
              13:17:32.476DEBUGjavascriptsfound Script: Hausspeicher_gerechnet
              13:17:32.626DEBUGjavascriptsfound Script: Hausspeicher_gespart
              13:17:32.776DEBUGjavascriptsfound Script: Hausverbrauch_aktuell
              13:17:32.925DEBUGjavascriptsfound Script: Heizung_Badezimmer_Keller
              13:17:33.077DEBUGjavascriptsfound Script: Heizung_Kinderzimmer
              13:17:33.226DEBUGjavascriptsfound Script: Heizung_Wohnzimmer
              13:17:33.377DEBUGjavascriptsfound Script: Kosten_Strom_Tag
              13:17:33.525DEBUGjavascriptsfound Script: LEDPanel
              13:17:33.676DEBUGjavascriptsfound Script: Licht_Keller_Kontakt
              13:17:33.827DEBUGjavascriptsfound Script: Licht_Schlafzimmer
              13:17:33.977DEBUGjavascriptsfound Script: Licht_Speisekammer
              13:17:34.128DEBUGjavascriptsfound Script: Licht_Umkleide
              13:17:34.278DEBUGjavascriptsfound Script: Netzeinspeisung
              13:17:34.427DEBUGjavascriptsfound Script: PV_Leistung
              13:17:34.577DEBUGjavascriptsfound Script: PV_Tagesertrag
              13:17:34.728DEBUGjavascriptsfound Script: Rolladen_Auf
              13:17:34.878DEBUGjavascriptsfound Script: Rolladen_Sonnenaufgang
              13:17:35.028DEBUGjavascriptsfound Script: Rolladen_Sonnenuntergang
              13:17:35.178DEBUGjavascriptsfound Script: Rolladen_Zu
              13:17:35.329DEBUGjavascriptsfound Script: Trinkbrunnen
              13:17:35.479DEBUGjavascriptsfound Script: Wasserzähler
              13:17:35.629DEBUGjavascriptsfound Script: Weihnachtsbaum
              13:17:35.779DEBUGjavascriptsfound Script: Wochentage&Wochenende
              13:17:35.945DEBUGjavascriptsTry deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
              13:17:35.988DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
              13:17:35.993DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2026_01_10-13_17_31_backupiobroker.tar.gz
              13:17:35.995DEBUGjavascriptsdone
              13:17:37.455ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
              13:17:37.495DEBUGcleandone
              13:17:37.608DEBUGhistoryHTMLnew history html values created
              13:17:37.701DEBUGhistoryHTMLdone
              13:17:37.875DEBUGhistoryJSONnew history json values created
              13:17:37.880DEBUGhistoryJSONdone
              13:17:40.376DEBUGnotificationAdmin notification will be sent
              13:17:40.417DEBUGnotificationdone
              13:17:40.533INFOguiDas Backup wurde erfolgreich erstellt!
              • M marcelinho
                Falsches Token? Bei influx selber bin ich dann aber raus.
                  marcelinho
                  weiß jemand wieso mein Backitup bei Influxdb nicht geht, habe die Token neu erstellt mit allen rechten aber irgendwie läuft es nicht:
                  19:56:58.888DEBUGinfluxDBInfluxDB-Backup started ...
                  19:56:58.892DEBUGinfluxDBStart InfluxDB Backup ...
                  19:56:58.901DEBUGinfluxDBInfluxDB Backup tmp directory created
                  19:56:59.372ERRORinfluxDBError: Command failed: influx backup --bucket admin --host http://localhost:8086 -t tX9aUgElHh8iiEJKoYay0Zhsxjr1OTuAnSaiR73lfwUAXzYlD3MlJeu_g6_WbjAnLKMFsAPylqSJ2f7Ke4BfZg== "/opt/iobroker/backups/influxDB_2026_01_10-19_56_58_backupiobroker"
                  2026/01/10 19:56:59 INFO: Downloading metadata snapshot
                  Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
                  19:56:59.382DEBUGinfluxDBInfluxDB-Backup for is finish
                  19:56:59.385DEBUGinfluxDBdone
                  Die Tokens stimmen, die Adapter sind grün. Wüsste nicht wo es hakt. Kann es mit Debian 13 zu tun haben bei Influx 2.x ? auf meiner anderen Micro SD mit Debian 12 geht es mit den Einstellungen.
                  HomoranH Thomas BraunT crunchipC 3 Antworten Letzte Antwort
                  • M marcelinho
                    das heisst gar nix!
                    für backitup brauchst du das admin token
                    • M marcelinho
                      #66
                      Nein.
                      • M marcelinho
                        crunchipC Offline
                        crunchipC Offline
                        #67
                        https://docs.influxdata.com/influxdb/v2/admin/backup-restore/backup/
                        The root authorization token (the token created for the first user in the InfluxDB setup process).
                        https://docs.influxdata.com/influxdb/v2/admin/tokens/
                          marcelinho
                          #68
                          versteht jemand warum ich mich beim Backup im Kreis drehe? Bei der InfluxDB Adapter ist grün Daten kommen in Grafana an. Token läuft. Aber wenn ich ein All Access API Token erstelle kommt immer der Fehler:
                          "401 Unauthorized"
                          pi@raspberrypi:~ $ rm influxdb2-client-2.7.5-linux-amd64.tar.gz
                          pi@raspberrypi:~ $ rm -rf ~/.influxdbv2
                          pi@raspberrypi:~ $ rm -f ~/influxdb2-client-*.tar.gz
                          sudo rm -f /usr/bin/influx
                          sudo rm -f /usr/local/bin/influx
                          pi@raspberrypi:~ $ curl -sL https://repos.influxdata.com/influxdata-archive.key | sudo gpg --dearmor -o /usr/share/keyrings/influxdata-archive.gpg
                          echo "deb [signed-by=/usr/share/keyrings/influxdata-archive.gpg] https://repos.influxdata.com/debian stable main" | sudo tee /etc/apt/sources.list.d/influxdata.list
                          sudo apt update
                          File '/usr/share/keyrings/influxdata-archive.gpg' exists. Overwrite? (y/N) y
                          Hit:5 https://repos.influxdata.com/debian stable InRelease
                          All packages are up to date.
                          pi@raspberrypi:~ $ sudo apt install influxdb2-cli -y
                          Installing:
                            influxdb2-cli
                          Summary:
                            Upgrading: 0, Installing: 1, Removing: 0, Not Upgrading: 0
                          (Reading database ... 115732 files and directories currently installed.)
                          pi@raspberrypi:~ $ influx version
                          Influx CLI dev (git: a79a2a1b825867421d320428538f76a4c90aa34c) build_date: 2024-04-16T14:34:26Z
                          pi@raspberrypi:~ $ export INFLUX_TOKEN=xjIUdQBiweNaUi4jNnq7t0QiCRMYahTp1k8O91CNfOHobTWtFNfjI6R3gaeA8msuoxeeouI_eIGu6g7KmRfxew==
                          pi@raspberrypi:~ $ influx org list
                          ID                      Name
                          9fc10391e54f07c7        admin
                          pi@raspberrypi:~ $ mkdir -p /home/pi/influx-backup-test
                          influx backup --org admin /home/pi/influx-backup-test
                          2026/01/13 15:06:54 INFO: Downloading metadata snapshot
                          pi@raspberrypi:~ $ rm -rf /home/pi/influx-backup-test
                          pi@raspberrypi:~ $
                          • M marcelinho
                            "401 Unauthorized"
                            sudo apt update
                            Installing:
                              influxdb2-cli
                            Summary:
                            ID                      Name
                            pi@raspberrypi:~ $
                            Marc BergM Online
                            Marc BergM Online
                            Marc Berg
                            #69
                            Falscher Token-Typ. Schau bitte in die Doku zum Backitup Adapter
                            https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup#operator-token-für-influxdb-2x-wiederherstellen
                              marcelinho
                              #70
                              @marc-berg danke vielmals, hat geklappt.
                              Jetzt habe ich alles konfiguriert :) Nur noch eine "Fehlermeldung" ist die zu vernachlässigen?
                              Get:3 http://deb.debian.org/debian-security trixie-security InRelease [43.4 kB]
                              Fetched 43.4 kB in 0s (88.8 kB/s)
                              pi@raspberrypi:~ $
                              • M marcelinho
                                pi@raspberrypi:~ $
                                #71
                                @marcelinho
                                Ja, für den Moment vernachlässigen.
                                In nächster Zeit müssten aber die Schlüssel für das nodesource Repo aktualisiert werden.
                                Die sind aber noch nicht verfügbar.
                                • M marcelinho
                                  @crunchip ich weis nicht genau was du meinst. Ich hatte Mosquitto wohl nur für Testzwecke installiert (damals nur Benutzer und Passwort aufgeschrieben) mqtt Adapter ist auf Server mit 0.0.0.0:1885 eingestellt gewesen. Der Z2M war auf Websocket. Da ich mir meine alte Karte Debian 12 wohl mit Trixie upgrade zerschossen hab und nicht mehr per SSH drauf komme kann ich leider nicht mehr schauen welcher Port Mosquitto war. Die alte Karte geht noch, aber per SSH leider nicht mehr. Ich würde ungern alle meine Geräte neu einbinden müssen. Obwohl ich denke das ich seit 1 Woche schon versuche Yaml, mqtt und z2m anzupassen es schon längst erledigt wäre. Ich versteh glaube ich das ganze Konstrukt nicht wirklich. Wer mit wem kommuniziert und wer was genau braucht. Wenn ich es schaffe die Adapter grün zu bekommen dann bekomme ich nicht die Geräte rein durch das Backup. Irgendwie dreh ich mich leider im Kreis...
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #72
                                  @marcelinho
                                  na was heisst den wer mit wem kommuniziert..
                                  z2m braucht ein mqtt .punkt.,. obs der mosquitto oder der iobroker mqtt server.. oder den startet das z2m nicht
                                  der Adapter z2m hingegen braucht z2m um zu starten. diesen kann st du per WS = websocket oder so dass dieser auf den externen mqtt server horcht einstellen
                                  ODER
                                  du macht per mit diesem adapter einen mqtt server auf.. das gaht auch.. dann musst du z2m auf diesenauch konfigurieren
                                    marcelinho
                                    #73
                                    Guten Morgen zusammen, ist die Meldung kritisch?
                                    Get:2 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB]
                                    Get:4 http://archive.raspberrypi.com/debian trixie InRelease [54.8 kB]
                                    Hit:6 https://deb.nodesource.com/node_24.x nodistro InRelease
                                    Get:7 https://apt.grafana.com stable InRelease [7,660 B]
                                    Get:8 http://deb.debian.org/debian-security trixie-security/main armhf Packages                              [93.0 kB]
                                    Get:9 http://archive.raspberrypi.com/debian trixie/main arm64 Packages [376 kB]
                                    Err:6 https://deb.nodesource.com/node_24.x nodistro InRelease
                                      Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing                              key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No bin                             ding signature at time 2026-01-19T15:30:12Z   because: Policy rejected non-revoc                             ation signature (PositiveCertification) requiring second pre-image resistance                                because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                                    Get:10 http://deb.debian.org/debian-security trixie-security/main arm64 Packages                              [99.0 kB]
                                    Get:11 https://apt.grafana.com stable/main arm64 Packages [421 kB]
                                    Get:12 http://deb.debian.org/debian-security trixie-security/main Translation-en                              [63.2 kB]
                                    Get:13 http://archive.raspberrypi.com/debian trixie/main armhf Packages [371 kB]
                                    Get:14 https://apt.grafana.com stable/main armhf Packages [491 kB]
                                    Fetched 2,067 kB in 2s (1,108 kB/s)
                                    10 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                    Warning: An error occurred during the signature verification. The repository is                              not updated and the previous index files will be used. OpenPGP signature verific                             ation failed: https://deb.nodesource.com/node_24.x nodistro InRelease: Sub-proce                             ss /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F7                             1F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signat                             ure at time 2026-01-19T15:30:12Z   because: Policy rejected non-revocation signa                             ture (PositiveCertification) requiring second pre-image resistance   because: SH                             A1 is not considered secure since 2026-02-01T00:00:00Z
                                    Warning: Failed to fetch https://deb.nodesource.com/node_24.x/dists/nodistro/InR                             elease  Sub-process /usr/bin/sqv returned an error code (1), error message is: S                             igning key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:                                         No binding signature at time 2026-01-19T15:30:12Z   because: Policy rejected non                             -revocation signature (PositiveCertification) requiring second pre-image resista                             nce   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                                    Warning: Some index files failed to download. They have been ignored, or old one                             s used instead.
                                    pi@raspberrypi:~ $ sudo apt upgrade
                                    Upgrading:
                                      grafana   libc-dev-bin  libc6      libssl3t64  openssl
                                      libc-bin  libc-l10n     libc6-dev  locales     openssl-provider-legacy
                                    Summary:
                                      Upgrading: 10, Installing: 0, Removing: 0, Not Upgrading: 0
                                      Download size: 204 MB
                                      Space needed: 872 kB / 19.0 GB available
                                    Continue? [Y/n] y
                                    Get:1 http://deb.debian.org/debian-security trixie-security/main arm64 openssl-p                             rovider-legacy arm64 3.5.4-1~deb13u2 [307 kB]
                                    Get:2 http://archive.raspberrypi.com/debian trixie/main arm64 libc6-dev arm64 2.                             41-12+rpt1+deb13u1 [2,353 kB]
                                    Get:3 http://deb.debian.org/debian-security trixie-security/main arm64 libssl3t6                             4 arm64 3.5.4-1~deb13u2 [2,750 kB]
                                    Get:4 https://apt.grafana.com stable/main arm64 grafana arm64 12.3.2 [185 MB]
                                    Get:5 http://archive.raspberrypi.com/debian trixie/main arm64 libc-dev-bin arm64                              2.41-12+rpt1+deb13u1 [62.1 kB]
                                    Get:6 http://archive.raspberrypi.com/debian trixie/main arm64 libc6 arm64 2.41-1                             2+rpt1+deb13u1 [5,184 kB]
                                    Get:7 http://archive.raspberrypi.com/debian trixie/main arm64 libc-bin arm64 2.4                             1-12+rpt1+deb13u1 [765 kB]
                                    Get:8 http://archive.raspberrypi.com/debian trixie/main arm64 libc-l10n all 2.41                             -12+rpt1+deb13u1 [1,654 kB]
                                    Get:9 http://archive.raspberrypi.com/debian trixie/main arm64 locales all 2.41-1                             2+rpt1+deb13u1 [5,108 kB]
                                    Get:10 http://deb.debian.org/debian-security trixie-security/main arm64 openssl                              arm64 3.5.4-1~deb13u2 [1,459 kB]
                                    Fetched 204 MB in 1min 58s (1,739 kB/s)
                                    Reading changelogs... Done
                                    Preconfiguring packages ...
                                    (Reading database ... 115736 files and directories currently installed.)
                                    Preparing to unpack .../libc6-dev_2.41-12+rpt1+deb13u1_arm64.deb ...
                                    Unpacking libc6-dev:arm64 (2.41-12+rpt1+deb13u1) over (2.41-12+rpt1) ...
                                    Preparing to unpack .../libc-dev-bin_2.41-12+rpt1+deb13u1_arm64.deb ...
                                    Unpacking libc-dev-bin (2.41-12+rpt1+deb13u1) over (2.41-12+rpt1) ...
                                    Preparing to unpack .../libc6_2.41-12+rpt1+deb13u1_arm64.deb ...
                                    Unpacking libc6:arm64 (2.41-12+rpt1+deb13u1) over (2.41-12+rpt1) ...
                                    Setting up libc6:arm64 (2.41-12+rpt1+deb13u1) ...
                                    Preparing to unpack .../libc-bin_2.41-12+rpt1+deb13u1_arm64.deb ...
                                    Unpacking libc-bin (2.41-12+rpt1+deb13u1) over (2.41-12+rpt1) ...
                                    Setting up libc-bin (2.41-12+rpt1+deb13u1) ...
                                    Preparing to unpack .../openssl-provider-legacy_3.5.4-1~deb13u2_arm64.deb ...
                                    Unpacking openssl-provider-legacy (3.5.4-1~deb13u2) over (3.5.4-1~deb13u1+rpt1)                              ...
                                    Setting up openssl-provider-legacy (3.5.4-1~deb13u2) ...
                                    Preparing to unpack .../libssl3t64_3.5.4-1~deb13u2_arm64.deb ...
                                    Unpacking libssl3t64:arm64 (3.5.4-1~deb13u2) over (3.5.4-1~deb13u1+rpt1) ...
                                    Setting up libssl3t64:arm64 (3.5.4-1~deb13u2) ...
                                    Preparing to unpack .../libc-l10n_2.41-12+rpt1+deb13u1_all.deb ...
                                    Unpacking libc-l10n (2.41-12+rpt1+deb13u1) over (2.41-12+rpt1) ...
                                    Preparing to unpack .../locales_2.41-12+rpt1+deb13u1_all.deb ...
                                    Unpacking locales (2.41-12+rpt1+deb13u1) over (2.41-12+rpt1) ...
                                    Preparing to unpack .../grafana_12.3.2_arm64.deb ...
                                    Unpacking grafana (12.3.2) over (12.3.1) ...
                                    Preparing to unpack .../openssl_3.5.4-1~deb13u2_arm64.deb ...
                                    Unpacking openssl (3.5.4-1~deb13u2) over (3.5.4-1~deb13u1+rpt1) ...
                                    Setting up libc-l10n (2.41-12+rpt1+deb13u1) ...
                                    Setting up locales (2.41-12+rpt1+deb13u1) ...
                                    Generating locales (this might take a while)...
                                      en_GB.UTF-8... done
                                    Generation complete.
                                    Setting up libc-dev-bin (2.41-12+rpt1+deb13u1) ...
                                    Setting up openssl (3.5.4-1~deb13u2) ...
                                    Setting up grafana (12.3.2) ...
                                    Restarting grafana-server service... OK
                                    Setting up libc6-dev:arm64 (2.41-12+rpt1+deb13u1) ...
                                    Processing triggers for systemd (257.9-1~deb13u1) ...
                                    Processing triggers for libc-bin (2.41-12+rpt1+deb13u1) ...
                                    Err:7 https://deb.nodesource.com/node_24.x nodistro InRelease
                                    pi@raspberrypi:~ $
                                    • M marcelinho
                                      Upgrading:
                                      Summary:
                                      Continue? [Y/n] y
                                        en_GB.UTF-8... done
                                      pi@raspberrypi:~ $
                                      #74
                                      @marcelinho
                                      Ja, der aktuelle Schlüssel fehlt.
                                      Installier da wieder nodejs@22:
                                      iob nodejs-update
                                      Rückfragen des Skripts mit y beantworten.
                                      Siehe auch:
                                      https://forum.iobroker.net/topic/83744/nodesource-repo-openpgp-signature-verification-failed
                                        marcelinho
                                        #75
                                        @thomas-braun lieben Dank, hat geklappt. Schönen Sonntag noch.
