  4. Test Adapter Loxone v4.0.x
  • Weihnachtsangebot 2025! 🎄
    1.9k
11 Beiträge 4 Kommentatoren 109 Aufrufe 4 Watching
  • J Offline
    jensmh
    https://github.com/UncleSamSwiss/ioBroker.loxone/issues/735
    UncleSamU 1 Antwort Letzte Antwort
    • J Offline
      JoschiRaab
      Ich kann den Adapter nicht installieren , erhalte diese Fehlermeldung , System neu aufgesetzt und aktuell :
      ERROR: Process exited with code 25
      Weniger Protokolle
      Detailliert
      $ iobroker add loxone --host IoBrokerAttendorn
      NPM version: 10.9.4
      Installing iobroker.loxone@4.0.0... (System call)
      npm error code 1npm error path /opt/iobroker/node_modules/utf-8-validatenpm error command failednpm error command sh -c node-gyp-buildnpm error (node:1737) [DEP0060] DeprecationWarning: The util._extend API is deprecated. Please use Object.assign() instead.npm error (Use node --trace-deprecation ... to show where the warning was created)npm error Traceback (most recent call last):npm error File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module>npm error import gyp # noqa: E402npm error ^^^^^^^^^^npm error File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/init.py", line 9, in <module>npm error import gyp.inputnpm error File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module>npm error from distutils.version import StrictVersionnpm error ModuleNotFoundError: No module named 'distutils'npm error gyp ERR! configure error npm error gyp ERR! stack Error: gyp failed with exit code: 1npm error gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)npm error gyp ERR! stack at ChildProcess.emit (node:events:519:28)npm error gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:293:12)npm error gyp ERR! System Linux 6.12.47+rpt-rpi-v8npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validatenpm error gyp ERR! node -v v22.21.0npm error gyp ERR! node-gyp -v v8.4.1npm error gyp ERR! not oknpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-01-03T19_22_31_898Z-debug-0.log
      host.IoBrokerAttendorn Cannot install iobroker.loxone@4.0.0: 1
      • J JoschiRaab
        Weniger Protokolle
        Detailliert
        NPM version: 10.9.4
        @JoschiRaab
        Installier da
        sudo apt update
        sudo apt install python3-setuptools
        nach.
        Edit: Pakename berichtigt.
        • J Offline
          JoschiRaab
          jr@IoBrokerAttendorn:~ $ sudo apt install python-setuptools
          Package python-setuptools is not available, but is referred to by another package.
          This may mean that the package is missing, has been obsoleted, or
          is only available from another source
          Error: Package 'python-setuptools' has no installation candidate
          • J Offline
            JoschiRaab
            erhalte diese Fehlermeldung beim installieren
            • J JoschiRaab
              @JoschiRaab sagte in Test Adapter Loxone v4.0.x:
              Was läuft da genau für ein System?
              Ausgabe von
              iob diag
              zum Besten geben.
              • J Offline
                JoschiRaab
                Habe es hiermit probiert :
                sudo apt-get install python3-setuptools
                Das hat geklappt . Jetzt funktioniert er .
                Vielen Vielen Dank
                • J jensmh
                  UncleSamU Offline
                  UncleSamU Offline
                  UncleSam
                  @jensmh sagte in Test Adapter Loxone v4.0.x:
                  Wie im GitHub Issue beschrieben, wurde dieser Bug sowohl in js-controller 7.1.0 wie auch in ioBroker.loxone 4.0.1 behoben.
                  @jensmh, kannst du bitte prüfen, ob das Problem mit 4.0.1 gefixt ist?
                  Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
                  ♡-lichen Dank an meine Sponsoren
                  • J Offline
                    JoschiRaab
                    Hallo nochmal , ich habe gerade für einen Freund einen ganz frischen IOBroker aufgesetzt und der Loxone Adapter geht nicht.
                    Erst nach dem Installieren der PY Tools. Ich verstehe aber auch nicht alles was unter dem Link besprochen wird. Will nur helfen.
                    • J JoschiRaab
                      @JoschiRaab
                      Logs wären vermutlich hilfreich..l
                      32.6k
                      82.0k
