backitup Speicherort
Das manuelle Backup ist durch. Mit der Meldung, daß keine Files gelöscht wurden, weil manuell angestoßen.
Der Ordner auf dem Raspi ist trotzdem leer. Vermutlich durch das 8 Uhr Backup.
Ein neues InfluxDB Backup ist aber nicht auf dem NAS in der Backup-Liste zu sehen.letzte Meldungen: 22:58:49.998DEBUGjavascriptsfound Script: ShellySD-Hof-Zeit 22:58:50.219DEBUGjavascriptsTry deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts" 22:58:50.232DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted 22:58:50.264DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2026_01_07-22_58_42_backupiobroker.tar.gz 22:58:50.267DEBUGjavascriptsdone 22:58:51.123DEBUGcifsused copy path: /backup 22:58:51.126DEBUGcifsdone 22:58:51.744WARNcleanNo older backup files are deleted, because this backup was started manually 22:58:51.782DEBUGcleandone 22:58:51.893DEBUGhistoryHTMLnew history html values created 22:58:51.989DEBUGhistoryHTMLdone 22:58:52.193DEBUGhistoryJSONnew history json values created 22:58:52.202DEBUGhistoryJSONdone 22:58:52.352DEBUGumountmount active, umount is started ... 22:58:58.286DEBUGumountumount successfully completed 22:58:58.301DEBUGumountdone 22:59:00.649DEBUGnotificationdone 22:59:00.810INFOguiDas Backup wurde erfolgreich erstellt! -
Ein neues InfluxDB Backup ist aber nicht auf dem NAS in der Backup-Liste zu sehen.letzte Meldungen: 22:58:49.998DEBUGjavascriptsfound Script: ShellySD-Hof-Zeit 22:58:50.219DEBUGjavascriptsTry deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts" 22:58:50.232DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted 22:58:50.264DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2026_01_07-22_58_42_backupiobroker.tar.gz 22:58:50.267DEBUGjavascriptsdone 22:58:51.123DEBUGcifsused copy path: /backup 22:58:51.126DEBUGcifsdone 22:58:51.744WARNcleanNo older backup files are deleted, because this backup was started manually 22:58:51.782DEBUGcleandone 22:58:51.893DEBUGhistoryHTMLnew history html values created 22:58:51.989DEBUGhistoryHTMLdone 22:58:52.193DEBUGhistoryJSONnew history json values created 22:58:52.202DEBUGhistoryJSONdone 22:58:52.352DEBUGumountmount active, umount is started ... 22:58:58.286DEBUGumountumount successfully completed 22:58:58.301DEBUGumountdone 22:59:00.649DEBUGnotificationdone 22:59:00.810INFOguiDas Backup wurde erfolgreich erstellt!@Laser sagte in backitup Speicherort:
nein!
Das ist normal.
in dem lokalen Ordner wird nichts gespeichert wenn der mount funktioniert.
Da dient der Ordner nur als "Link" zum NAS@Laser sagte in backitup Speicherort:
hast du das denn gestartet?
ich kenne das Setup für Influx nicht.
Aber im "log" wird es auch nicht abgearbeitet -
Das habe ich offenbar falsch verstanden. Ich habe geglaubt in dem Ordner werden Infux Backup Dateien erzeugt und dann auf das NAS kopiert. Wenn aber zu Beginn gemountet wird, ist ja sofort das NAS der Zielordner, nicht der Raspi-Ordner.
Das Influx ist in der Einstellung im bakitup angehakt.
aber diese Files sind doch noch vorhanden. Gerade nochmal nachgesehen.otto@neuheizung:/opt/iobroker/backups $ ls grafana_2026_01_08-10_09_38_backupiobroker.tar.gz historyDB_2026_01_08-10_01_34_backupiobroker.tar.gz javascripts_2026_01_08-10_09_43_backupiobroker.tar.gzotto@neuheizung:~ $ ls -lAh /opt/iobroker/backups/ total 493M -rw-rw-r--+ 1 iobroker iobroker 26K Jan 8 10:09 grafana_2026_01_08-10_09_38_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 493M Jan 8 10:09 historyDB_2026_01_08-10_01_34_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 19K Jan 8 10:09 javascripts_2026_01_08-10_09_43_backupiobroker.tar.gz -
@thomas-braun zum "splitten" der Datenbank habe ich nur Folgendes gefunden:
strings.split() function Flux 0.18.0+View InfluxDB support Copy page for AI strings.split() splits a string on a specified separator and returns an array of substrings. Function type signature (t: string, v: string) => [string] For more information, see Function type signatures. Parameters v (Required) String value to split. t (Required) String value that acts as the separator. Examples Split a string into an array of substrings import "strings" strings.split(v: "foo, bar, baz, quz", t: ", ")// Returns ["foo", "bar", "baz", "quz"] Related strings.splitAfter() function strings.splitAfterN() function strings.splitN() functionSoll ich das tun?
aber diese Files sind doch noch vorhanden. Gerade nochmal nachgesehen.otto@neuheizung:/opt/iobroker/backups $ ls grafana_2026_01_08-10_09_38_backupiobroker.tar.gz historyDB_2026_01_08-10_01_34_backupiobroker.tar.gz javascripts_2026_01_08-10_09_43_backupiobroker.tar.gzotto@neuheizung:~ $ ls -lAh /opt/iobroker/backups/ total 493M -rw-rw-r--+ 1 iobroker iobroker 26K Jan 8 10:09 grafana_2026_01_08-10_09_38_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 493M Jan 8 10:09 historyDB_2026_01_08-10_01_34_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 19K Jan 8 10:09 javascripts_2026_01_08-10_09_43_backupiobroker.tar.gz@Laser sagte in backitup Speicherort:
und wie ist die Konfiguration davon?
wieso von 10:09???
Warum diese Files vorhanden sind, weiß ich nicht. Gestern waren die nicht vorhanden.
Diese Frage: "und wie ist die Konfiguration davon?"
Was genau und auf welche Art soll ich das zeigen? -
Info- jetzt:
Plattform: linux Betriebssystem: linux Architektur: arm64 CPUs: 4 Geschwindigkeit: 1800 MHz Modell: Cortex-A72 RAM: 7.6 GB System-Betriebszeit: 33 T. 23:39:30 Node.js: v22.21.0 Zeit: 1767808325256 Zeitversatz: -60 NPM: 10.9.4 Adapter-Anzahl: 591 Datenträgergröße: 109.5 GB Freier Festplattenspeicher: 53.6 GB Aktive Instanzen: 25 Pfad: /opt/iobroker/ Betriebszeit: 26 T. 01:17:05 aktiv: trueotto@neuheizung:~ $ timedatectl Local time: Thu 2026-01-08 10:46:11 CET Universal time: Thu 2026-01-08 09:46:11 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no -
Info- jetzt:
Wer soll denn um 10 Uhr etwas starten? NAS: Systemzeit Thu Jan 8 10:55:21 2026
Ich starte jetzt das Backup manuell... -
H Homoran hat dieses Thema am aufgespalten
Irgendwas stimmt mit der Zeit nicht. Habe jetzt die Zeit auf 4 Minuten in der Zukunft gestellt, nichts passiert zu dieser Zeit.!
Zeigen wollte ich meine Zeiteinstellung. Das Bild wird von IO Broker generiert. Was ist denn an dem Bild so Geheimnisvolles?
wo solldie auf dem Bild zu sehen sein?
da sollte dein Wohnort zu sehen sein.
Damit auch die Astrofunktionen klappen.dann eben;
wo hast du welche Zeit auf welche Weise verstellt und was soll wo und wie passieren?
Ich habe die Zeit, zu welcher backitup ein Backup erstellen soll, von 8 Uhr morgens auf jetzt + wenige Minuten verstellt, um ein neues Backup zeitgesteuert zu erstellen.
Backup nur für iobroker und influxDB.
