Adapter: DasWetter
Der Abruf für Tage und Stunden findet statt und wird scheinbar auch positive beantwortet. Die Werte, die da als Antwort kommen, sind aber genau die von gestern. Vermutlich sind die Daten auf "daswetter" nicht korrekt.
DasWetter_0: Meteored GetForecastDaily response: {"ok":true,"expiracion":1767603600000,"data":{"hash":"0c4bd471c213721742c35b66685ed54a","name":"Jork","url":"https://www.theweather.com/jork.htm","days":[{"start":1767481200000,"symbol":24,"temperature_min":-9.31,"temperature_max":-0.8,"wind_speed":18,"wind_gust":31,"wind_direction":"SW","rain":5.4,"rain_probability":70,"humidity":89,"pressure":1004,"snowline":0,"uv_index_max":0.3,"sun_in":1767512207000,"sun_mid":1767525973000,"sun_out":1767539756000,"moon_in":1767543870000,"moon_out":1767516774000,"moon_symbol":15,"moon_illumination":98.46},{"start":1767567600000,"symbol":24,"temperature_min":-5.71,"temperature_max":-2.04,"wind_speed":17,"wind_gust":28,"wind_direction":"SW","rain":1.4,"rain_probability":60,"humidity":89,"pressure":1009,"snowline":0,"uv_index_max":0.3,"sun_in":1767598584000,"sun_mid":1767612400000,"sun_out":1767626233000,"moon_in":1767635879000,"moon_out":1767604503000,"moon_symbol":16,"moon_illumination":94.31},{"start":1767654000000,"symbol":4,"temperature_min":-9.76,"temperature_max":-3.33,"wind_speed":12,"wind_gust":20,"wind_direction":"S","rain":0,"rain_probability":20,"humidity":93,"pressure":1011,"snowline":0,"uv_index_max":0.3,"sun_in":1767684959000,"sun_mid":1767698827000,"sun_out":1767712713000,"moon_in":1767727583000,"moon_out":1767691798000,"moon_symbol":17,"moon_illumination":88.02},{"start":1767740400000,"symbol":24,"temperature_min":-10.35,"temperature_max":0.09,"wind_speed":26,"wind_gust":45,"wind_direction":"S","rain":0.7,"rain_probability":70,"humidity":86,"pressure":1006,"snowline":0,"uv_index_max":0.3,"sun_in":1767771329000,"sun_mid":1767785253000,"sun_out":1767799195000,"moon_in":1767818949000,"moon_out":1767778859000,"moon_symbol":18,"moon_illumination":80.15},{"start":1767826800000,"symbol":20,"temperature_min":-1.7,"temperature_max":2.32,"wind_speed":26,"wind_gust":48,"wind_direction":"S","rain":2.3,"rain_probability":80,"humidity":92,"pressure":1002,"snowline":0,"uv_index_max":0.4,"sun_in":1767857696000,"sun_mid":1767871678000,"sun_out":1767885680000,"moon_in":1767910060000,"moon_out":1767865802000,"moon_symbol":19,"moon_illumination":71.21}]}} -
Echt komisch, ich bin mir ziemlich sicher das bei mir wirklich aktualisiert wird. Da haben sich ein paar Daten seit gestern defintiv geändert, auch wenn man sich ja nicht jedes Detail der VIS merkt.
Auch entspricht das, was ich draußen sehe, ziemlich genau den Daten die aktuell angezeigt werden.
Ich habe nun aber zusätzlich mal einen Gesamt-Screenshoot gemacht (ist einfacher als den Objektbaum zu vergleichen) und werde das gegen Abend mal gegenchecken. -
Moin!
Bei mir werden die Tageswerte nicht aktualisiert. In Day_1 stehen immer noch die Werte von Sonntag, in Day_2 die Werte von heute usw.
Ich bekomme auch keine Fehlermeldung beim Neustart des Adapters. Laut Statistik auf meteored.com habe ich noch nicht zu oft abgerufen.
Problem bekannt?@Arne-Dieckmann sagte in Adapter: DasWetter:
Moin!
Problem bekannt?...leider bei mir genauso...
@Merlin123 sagte in Adapter: DasWetter:
Ich habe jetzt "meine" Icons einfach mal in das Verzeichnis des Adapers kopiert
wie?
sind die in der vis registriert? -
@Homoran Wie kann ich die da registrieren? Die liegen nicht im VIS Verzeichnis, sondern unter
/daswetter.admin/icons/luna-moon/16.png@Merlin123 sagte in Adapter: DasWetter:
üblicherweise durch einfügen über den vis Dateiupload
hmm, sind die denn im admin unter Dateien zu sehen?
Hab die Adapter-Instanz neu erstellt, dann wurde die Daten wieder aktualisiert für Montag. Bei mir standen auch noch die von Sonntag drinnen.
@mathy sagte in Adapter: DasWetter:
Hm, habe ich jetzt auch gemacht. Die Tage sind nun wieder aktuell. Mal abwarten, was morgen früh passiert.
@Homoran So...
Hab die jetzt in den Vis2 Ordner kopiert.
Der Pfad unter Custom sieht dann so aus:
/vis-2.0/Voelker/moon-icons/
Dann geht es.... -
So, habe gerade bereits durch Zufall größere Veränderungen festgestellt.
Auch wenn es die Probleme einiger hier nicht lösen wird, dennoch der 'Beweis' ;-)
10:41
12:18
@Pedder007 Du magst diese Ansichten nicht zufällig als Export zu Verfügung stellen?
@Merlin123 grundsätzlich gerne, ich stelle mir nur gerade die Frage, wie ich speziell diese Ecke meiner View exklusiv und vollständig aus der Gesamtview herausbekomme?
So, wer suchet der findet. Man kann ja auch einfach nur die Widgets markieren und exportieren. Zumindest hat der Import gerade bei mir (in eine Testview) funktioniert.
(der Hintergrund ist: 'Blue marine')Here we go:
[{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_8.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"41","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","g_images":true,"src_0":"","src_26":"/daswetter.admin/icons/tiempo-weather/galeria7/26.png","src_27":"/daswetter.admin/icons/tiempo-weather/galeria7/27.png","src_28":"/daswetter.admin/icons/tiempo-weather/galeria7/28.png","src_29":"/daswetter.admin/icons/tiempo-weather/galeria7/29.png","src_30":"/daswetter.admin/icons/tiempo-weather/galeria7/30.png","src_31":"/daswetter.admin/icons/tiempo-weather/galeria7/31.png","src_32":"/daswetter.admin/icons/tiempo-weather/galeria7/32.png","src_33":"/daswetter.admin/icons/tiempo-weather/galeria7/33.png","src_34":"/daswetter.admin/icons/tiempo-weather/galeria7/34.png","src_35":"/daswetter.admin/icons/tiempo-weather/galeria7/34.png","src_36":"/daswetter.admin/icons/tiempo-weather/galeria7/36.png","src_37":"/daswetter.admin/icons/tiempo-weather/galeria7/37.png","src_38":"/daswetter.admin/icons/tiempo-weather/galeria7/38.png","src_39":"/daswetter.admin/icons/tiempo-weather/galeria7/39.png","src_40":"/daswetter.admin/icons/tiempo-weather/galeria7/40.png","src_41":"/daswetter.admin/icons/tiempo-weather/galeria7/41.png"},"style":{"left":"780px","top":"62px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"08:00"},"style":{"left":"781px","top":"39px","width":"46px","height":"17px","color":"white","font-style":"","font-weight":"bold","font-family":"","z-index":"2"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"11:00"},"style":{"left":"848px","top":"39px","width":"46px","height":"17px","color":"white","font-style":"","font-weight":"bold","font-family":"","z-index":"2"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"14:00"},"style":{"left":"913.984375px","top":"39px","width":"46px","height":"17px","color":"white","font-style":"","font-weight":"bold","font-family":"","z-index":"2"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"17:00"},"style":{"left":"980px","top":"39px","width":"46px","height":"17px","color":"white","font-style":"","font-weight":"bold","font-family":"","z-index":"2"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"20:00"},"style":{"left":"1045.984375px","top":"39px","width":"46px","height":"17px","color":"white","font-style":"","font-weight":"bold","font-family":"","z-index":"2"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_20.rain_probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" %","locked":false},"style":{"left":"1043px","top":"142px","width":"52px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_17.rain_probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" %","locked":false},"style":{"left":"975px","top":"142px","width":"55px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_14.rain_probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" %","locked":false},"style":{"left":"910px","top":"142px","width":"53px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_11.rain_probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" %","locked":false},"style":{"left":"844.015625px","top":"142px","width":"54px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_8.rain_probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" %","locked":false},"style":{"left":"779px","top":"142px","width":"51px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_11.wind_speed","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" km/h","locked":false},"style":{"left":"844.984375px","top":"159px","width":"52px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_14.wind_speed","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" km/h","locked":false},"style":{"left":"907.984375px","top":"159px","width":"58px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_17.wind_speed","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" km/h","locked":false},"style":{"left":"974px","top":"159px","width":"57px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_20.wind_speed","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" km/h","locked":false},"style":{"left":"1043px","top":"159px","width":"52px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"0_userdata.0.var_Allgem.DayDate","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"938px","top":"11px","width":"90px","height":"20px","color":"white","font-weight":"bold","z-index":"2"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_2.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_0":"","src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png"},"style":{"left":"790px","top":"220px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_2.Wind_Speed","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" km/h","locked":false},"style":{"left":"787px","top":"307px","width":"50px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"2","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_3.Wind_Speed","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" km/h","locked":false},"style":{"left":"865px","top":"309px","width":"51px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"2","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_4.Wind_Speed","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" km/h","locked":false},"style":{"left":"950px","top":"309px","width":"50px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"2","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_5.Wind_Speed","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" km/h","locked":false},"style":{"left":"1033px","top":"310px","width":"50px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"2","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_3.NameOfDay","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"858px","top":"196px","z-index":"3","color":"white","width":"80px","height":"20px","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_4.NameOfDay","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"941px","top":"196px","z-index":"3","color":"white","width":"80px","height":"20px","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_5.NameOfDay","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"1024px","top":"196px","z-index":"3","color":"white","width":"80px","height":"20px","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_3.Rain_Probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" %","locked":false},"style":{"left":"865px","top":"292px","width":"55px","height":"14px","color":"#ffffff","font-weight":"","font-size":"small","text-align":"center","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_1.NameOfDay","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":","},"style":{"left":"824px","top":"10px","z-index":"2","color":"white","width":"110px","height":"20px","text-align":"right","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_1.Snowline","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"<","visibility-val":"600","visibility-groups-action":"hide","signals-cond-0":"<=","signals-val-0":"400","signals-icon-0":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","signals-icon-size-0":"28","signals-blink-0":false,"signals-horz-0":"-30","signals-vert-0":"-20","signals-hide-edit-0":false,"signals-cond-1":"<=","signals-val-1":"200","signals-icon-1":"/daswetter.admin/icons/tiempo-weather/galeria7/33.png","signals-icon-size-1":"35","signals-blink-1":true,"signals-horz-1":"-30","signals-vert-1":"-60","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" m","signals-oid-0":"daswetter.0.location_1.ForecastDaily.Day_1.Snowline","visibility-oid":"daswetter.0.location_1.ForecastDaily.Day_1.Snowline","visibility-groups":null,"signals-oid-1":"daswetter.0.location_1.ForecastDaily.Day_1.Snowline"},"style":{"left":"1043px","top":"12px","width":"58px","height":"14px","color":"white","text-align":"right","font-weight":"bold","font-size":"small","z-index":"3","overflow-x":"visible","overflow-y":"visible"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_8.temperature","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":false,"factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":" °C","html_append_plural":" °C"},"style":{"left":"782px","top":"119px","color":"#FFFFFF","font-weight":"bold","width":"45px","z-index":"3","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_11.temperature","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":false,"factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":" °C","html_append_plural":" °C"},"style":{"left":"848px","top":"119px","color":"#FFFFFF","font-weight":"bold","width":"45px","z-index":"3","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_14.temperature","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":false,"factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":" °C","html_append_plural":" °C"},"style":{"left":"914px","top":"119px","color":"#FFFFFF","font-weight":"bold","width":"45px","z-index":"3","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_17.temperature","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups- ``` -
[{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_8.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"41","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","g_images":true,"src_0":"","src_26":"/daswetter.admin/icons/tiempo-weather/galeria7/26.png","src_27":"/daswetter.admin/icons/tiempo-weather/galeria7/27.png","src_28":"/daswetter.admin/icons/tiempo-weather/galeria7/28.png","src_29":"/daswetter.admin/icons/tiempo-weather/galeria7/29.png","src_30":"/daswetter.admin/icons/tiempo-weather/galeria7/30.png","src_31":"/daswetter.admin/icons/tiempo-weather/galeria7/31.png","src_32":"/daswetter.admin/icons/tiempo-weather/galeria7/32.png","src_33":"/daswetter.admin/icons/tiempo-weather/galeria7/33.png","src_34":"/daswetter.admin/icons/tiempo-weather/galeria7/34.png","src_35":"/daswetter.admin/icons/tiempo-weather/galeria7/34.png","src_36":"/daswetter.admin/icons/tiempo-weather/galeria7/36.png","src_37":"/daswetter.admin/icons/tiempo-weather/galeria7/37.png","src_38":"/daswetter.admin/icons/tiempo-weather/galeria7/38.png","src_39":"/daswetter.admin/icons/tiempo-weather/galeria7/39.png","src_40":"/daswetter.admin/icons/tiempo-weather/galeria7/40.png","src_41":"/daswetter.admin/icons/tiempo-weather/galeria7/41.png"},"style":{"left":"780px","top":"62px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"08:00"},"style":{"left":"781px","top":"39px","width":"46px","height":"17px","color":"white","font-style":"","font-weight":"bold","font-family":"","z-index":"2"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"11:00"},"style":{"left":"848px","top":"39px","width":"46px","height":"17px","color":"white","font-style":"","font-weight":"bold","font-family":"","z-index":"2"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"14:00"},"style":{"left":"913.984375px","top":"39px","width":"46px","height":"17px","color":"white","font-style":"","font-weight":"bold","font-family":"","z-index":"2"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"17:00"},"style":{"left":"980px","top":"39px","width":"46px","height":"17px","color":"white","font-style":"","font-weight":"bold","font-family":"","z-index":"2"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"20:00"},"style":{"left":"1045.984375px","top":"39px","width":"46px","height":"17px","color":"white","font-style":"","font-weight":"bold","font-family":"","z-index":"2"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_20.rain_probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" %","locked":false},"style":{"left":"1043px","top":"142px","width":"52px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_17.rain_probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" %","locked":false},"style":{"left":"975px","top":"142px","width":"55px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_14.rain_probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" %","locked":false},"style":{"left":"910px","top":"142px","width":"53px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_11.rain_probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" %","locked":false},"style":{"left":"844.015625px","top":"142px","width":"54px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_8.rain_probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" %","locked":false},"style":{"left":"779px","top":"142px","width":"51px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_11.wind_speed","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" km/h","locked":false},"style":{"left":"844.984375px","top":"159px","width":"52px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_14.wind_speed","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" km/h","locked":false},"style":{"left":"907.984375px","top":"159px","width":"58px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_17.wind_speed","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" km/h","locked":false},"style":{"left":"974px","top":"159px","width":"57px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_20.wind_speed","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" km/h","locked":false},"style":{"left":"1043px","top":"159px","width":"52px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"3","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"0_userdata.0.var_Allgem.DayDate","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"938px","top":"11px","width":"90px","height":"20px","color":"white","font-weight":"bold","z-index":"2"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_2.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_0":"","src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png"},"style":{"left":"790px","top":"220px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_2.Wind_Speed","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" km/h","locked":false},"style":{"left":"787px","top":"307px","width":"50px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"2","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_3.Wind_Speed","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" km/h","locked":false},"style":{"left":"865px","top":"309px","width":"51px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"2","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_4.Wind_Speed","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" km/h","locked":false},"style":{"left":"950px","top":"309px","width":"50px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"2","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_5.Wind_Speed","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","html_append":" km/h","locked":false},"style":{"left":"1033px","top":"310px","width":"50px","height":"13px","color":"white","font-variant":"","font-size":"small","z-index":"2","text-align":"center","font-weight":"normal"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_3.NameOfDay","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"858px","top":"196px","z-index":"3","color":"white","width":"80px","height":"20px","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_4.NameOfDay","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"941px","top":"196px","z-index":"3","color":"white","width":"80px","height":"20px","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_5.NameOfDay","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"1024px","top":"196px","z-index":"3","color":"white","width":"80px","height":"20px","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_3.Rain_Probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" %","locked":false},"style":{"left":"865px","top":"292px","width":"55px","height":"14px","color":"#ffffff","font-weight":"","font-size":"small","text-align":"center","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_1.NameOfDay","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":","},"style":{"left":"824px","top":"10px","z-index":"2","color":"white","width":"110px","height":"20px","text-align":"right","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_1.Snowline","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"<","visibility-val":"600","visibility-groups-action":"hide","signals-cond-0":"<=","signals-val-0":"400","signals-icon-0":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","signals-icon-size-0":"28","signals-blink-0":false,"signals-horz-0":"-30","signals-vert-0":"-20","signals-hide-edit-0":false,"signals-cond-1":"<=","signals-val-1":"200","signals-icon-1":"/daswetter.admin/icons/tiempo-weather/galeria7/33.png","signals-icon-size-1":"35","signals-blink-1":true,"signals-horz-1":"-30","signals-vert-1":"-60","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" m","signals-oid-0":"daswetter.0.location_1.ForecastDaily.Day_1.Snowline","visibility-oid":"daswetter.0.location_1.ForecastDaily.Day_1.Snowline","visibility-groups":null,"signals-oid-1":"daswetter.0.location_1.ForecastDaily.Day_1.Snowline"},"style":{"left":"1043px","top":"12px","width":"58px","height":"14px","color":"white","text-align":"right","font-weight":"bold","font-size":"small","z-index":"3","overflow-x":"visible","overflow-y":"visible"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_8.temperature","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":false,"factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":" °C","html_append_plural":" °C"},"style":{"left":"782px","top":"119px","color":"#FFFFFF","font-weight":"bold","width":"45px","z-index":"3","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_11.temperature","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":false,"factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":" °C","html_append_plural":" °C"},"style":{"left":"848px","top":"119px","color":"#FFFFFF","font-weight":"bold","width":"45px","z-index":"3","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_14.temperature","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":false,"factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":" °C","html_append_plural":" °C"},"style":{"left":"914px","top":"119px","color":"#FFFFFF","font-weight":"bold","width":"45px","z-index":"3","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_17.temperature","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups- ```... und weil der Export länger als 100.000 Zeichen war, hier noch der Rest. Bitte dann einfach untereinander kopieren :-)
action":"hide","is_comma":false,"factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":" °C","html_append_plural":" °C"},"style":{"left":"980px","top":"119px","color":"#FFFFFF","font-weight":"bold","width":"45px","z-index":"3","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_20.temperature","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":false,"factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":" °C","html_append_plural":" °C"},"style":{"left":"1046px","top":"119px","color":"#FFFFFF","font-weight":"bold","width":"45px","z-index":"3","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_3.Temperature_Min","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":"","html_append_plural":""},"style":{"left":"865px","top":"273px","color":"white","font-size":"small","text-align":"right","width":"25px","height":"15px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_3.Temperature_Max","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":"","html_append_plural":"","html_prepend":" - "},"style":{"left":"895px","top":"273px","color":"white","font-size":"small","text-align":"left","width":"25px","height":"15px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_4.Temperature_Min","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":"","html_append_plural":""},"style":{"left":"949px","top":"273px","color":"white","font-size":"small","text-align":"right","width":"25px","height":"15px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_4.Temperature_Max","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":"","html_append_plural":"","html_prepend":" - "},"style":{"left":"979px","top":"273px","color":"white","font-size":"small","text-align":"left","width":"25px","height":"15px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_2.Temperature_Min","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":"","html_append_plural":""},"style":{"left":"782px","top":"273px","color":"white","font-size":"small","text-align":"right","width":"25px","height":"15px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_2.Temperature_Max","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":"","html_append_plural":"","html_prepend":" - "},"style":{"left":"812px","top":"273px","color":"white","font-size":"small","text-align":"left","width":"25px","height":"15px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_2.Snowline","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"<","visibility-val":"600","visibility-groups-action":"hide","signals-cond-0":"<=","signals-val-0":"400","signals-icon-0":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","signals-icon-size-0":"19","signals-blink-0":false,"signals-horz-0":"-2","signals-vert-0":"-20","signals-hide-edit-0":false,"signals-cond-1":"<=","signals-val-1":"200","signals-icon-1":"/daswetter.admin/icons/tiempo-weather/galeria7/33.png","signals-icon-size-1":"19","signals-blink-1":true,"signals-horz-1":"5","signals-vert-1":"-20","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" m","signals-oid-0":"daswetter.0.location_1.ForecastDaily.Day_2.Snowline","visibility-oid":"daswetter.0.location_1.ForecastDaily.Day_2.Snowline","visibility-groups":null,"signals-oid-1":"daswetter.0.location_1.ForecastDaily.Day_2.Snowline"},"style":{"left":"783px","top":"329px","width":"58px","height":"12px","color":"white","text-align":"right","font-weight":"","font-size":"small","z-index":"3","overflow-x":"visible","overflow-y":"visible"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_2.Rain_Probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" %","locked":false},"style":{"left":"787px","top":"292px","width":"55px","height":"14px","color":"#ffffff","font-weight":"","font-size":"small","text-align":"center","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_3.Snowline","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"<","visibility-val":"600","visibility-groups-action":"hide","signals-cond-0":"<=","signals-val-0":"400","signals-icon-0":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","signals-icon-size-0":"19","signals-blink-0":false,"signals-horz-0":"-2","signals-vert-0":"-20","signals-hide-edit-0":false,"signals-cond-1":"<=","signals-val-1":"200","signals-icon-1":"/daswetter.admin/icons/tiempo-weather/galeria7/33.png","signals-icon-size-1":"19","signals-blink-1":true,"signals-horz-1":"5","signals-vert-1":"-20","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" m","signals-oid-0":"daswetter.0.location_1.ForecastDaily.Day_3.Snowline","visibility-oid":"daswetter.0.location_1.ForecastDaily.Day_3.Snowline","visibility-groups":null,"signals-oid-1":"daswetter.0.location_1.ForecastDaily.Day_3.Snowline"},"style":{"left":"864px","top":"329px","width":"58px","height":"12px","color":"white","text-align":"right","font-weight":"","font-size":"small","z-index":"3","overflow-x":"visible","overflow-y":"visible"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_4.Rain_Probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" %","locked":false},"style":{"left":"949px","top":"292px","width":"55px","height":"14px","color":"#ffffff","font-weight":"","font-size":"small","text-align":"center","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_4.Snowline","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"<","visibility-val":"600","visibility-groups-action":"hide","signals-cond-0":"<=","signals-val-0":"400","signals-icon-0":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","signals-icon-size-0":"19","signals-blink-0":false,"signals-horz-0":"-2","signals-vert-0":"-20","signals-hide-edit-0":false,"signals-cond-1":"<=","signals-val-1":"200","signals-icon-1":"/daswetter.admin/icons/tiempo-weather/galeria7/33.png","signals-icon-size-1":"19","signals-blink-1":true,"signals-horz-1":"5","signals-vert-1":"-20","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" m","signals-oid-0":"daswetter.0.location_1.ForecastDaily.Day_4.Snowline","visibility-oid":"daswetter.0.location_1.ForecastDaily.Day_4.Snowline","visibility-groups":null,"signals-oid-1":"daswetter.0.location_1.ForecastDaily.Day_4.Snowline"},"style":{"left":"944px","top":"329px","width":"58px","height":"12px","color":"white","text-align":"right","font-weight":"","font-size":"small","z-index":"3","overflow-x":"visible","overflow-y":"visible"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_5.Rain_Probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" %","locked":false},"style":{"left":"1031px","top":"292px","width":"55px","height":"14px","color":"#ffffff","font-weight":"","font-size":"small","text-align":"center","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_5.Temperature_Min","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":"","html_append_plural":""},"style":{"left":"1031px","top":"273px","color":"white","font-size":"small","text-align":"right","width":"25px","height":"15px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_5.Temperature_Max","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":"","html_append_plural":"","html_prepend":" - "},"style":{"left":"1061px","top":"273px","color":"white","font-size":"small","text-align":"left","width":"25px","height":"15px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_5.Snowline","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"<","visibility-val":"600","visibility-groups-action":"hide","signals-cond-0":"<=","signals-val-0":"400","signals-icon-0":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","signals-icon-size-0":"19","signals-blink-0":false,"signals-horz-0":"-2","signals-vert-0":"-20","signals-hide-edit-0":false,"signals-cond-1":"<=","signals-val-1":"200","signals-icon-1":"/daswetter.admin/icons/tiempo-weather/galeria7/33.png","signals-icon-size-1":"19","signals-blink-1":true,"signals-horz-1":"5","signals-vert-1":"-20","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" m","signals-oid-0":"daswetter.0.location_1.ForecastDaily.Day_5.Snowline","visibility-oid":"daswetter.0.location_1.ForecastDaily.Day_5.Snowline","visibility-groups":null,"signals-oid-1":"daswetter.0.location_1.ForecastDaily.Day_5.Snowline"},"style":{"left":"1032px","top":"329px","width":"58px","height":"12px","color":"white","text-align":"right","font-weight":"","font-size":"small","z-index":"3","overflow-x":"visible","overflow-y":"visible"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_11.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","g_images":true,"src_0":""},"style":{"left":"846px","top":"62px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_14.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","g_images":true,"src_0":""},"style":{"left":"914px","top":"62px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_17.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","g_images":true,"src_0":""},"style":{"left":"978px","top":"62px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_20.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","g_images":true,"src_0":""},"style":{"left":"1044px","top":"62px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_3.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_0":"","src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png"},"style":{"left":"871px","top":"220px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_4.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_0":"","src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png"},"style":{"left":"955px","top":"220px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_5.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_0":"","src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png"},"style":{"left":"1036px","top":"220px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"}] -
action":"hide","is_comma":false,"factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":" °C","html_append_plural":" °C"},"style":{"left":"980px","top":"119px","color":"#FFFFFF","font-weight":"bold","width":"45px","z-index":"3","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_20.temperature","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":false,"factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":" °C","html_append_plural":" °C"},"style":{"left":"1046px","top":"119px","color":"#FFFFFF","font-weight":"bold","width":"45px","z-index":"3","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_3.Temperature_Min","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":"","html_append_plural":""},"style":{"left":"865px","top":"273px","color":"white","font-size":"small","text-align":"right","width":"25px","height":"15px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_3.Temperature_Max","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":"","html_append_plural":"","html_prepend":" - "},"style":{"left":"895px","top":"273px","color":"white","font-size":"small","text-align":"left","width":"25px","height":"15px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_4.Temperature_Min","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":"","html_append_plural":""},"style":{"left":"949px","top":"273px","color":"white","font-size":"small","text-align":"right","width":"25px","height":"15px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_4.Temperature_Max","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":"","html_append_plural":"","html_prepend":" - "},"style":{"left":"979px","top":"273px","color":"white","font-size":"small","text-align":"left","width":"25px","height":"15px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_2.Temperature_Min","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":"","html_append_plural":""},"style":{"left":"782px","top":"273px","color":"white","font-size":"small","text-align":"right","width":"25px","height":"15px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_2.Temperature_Max","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":"","html_append_plural":"","html_prepend":" - "},"style":{"left":"812px","top":"273px","color":"white","font-size":"small","text-align":"left","width":"25px","height":"15px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_2.Snowline","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"<","visibility-val":"600","visibility-groups-action":"hide","signals-cond-0":"<=","signals-val-0":"400","signals-icon-0":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","signals-icon-size-0":"19","signals-blink-0":false,"signals-horz-0":"-2","signals-vert-0":"-20","signals-hide-edit-0":false,"signals-cond-1":"<=","signals-val-1":"200","signals-icon-1":"/daswetter.admin/icons/tiempo-weather/galeria7/33.png","signals-icon-size-1":"19","signals-blink-1":true,"signals-horz-1":"5","signals-vert-1":"-20","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" m","signals-oid-0":"daswetter.0.location_1.ForecastDaily.Day_2.Snowline","visibility-oid":"daswetter.0.location_1.ForecastDaily.Day_2.Snowline","visibility-groups":null,"signals-oid-1":"daswetter.0.location_1.ForecastDaily.Day_2.Snowline"},"style":{"left":"783px","top":"329px","width":"58px","height":"12px","color":"white","text-align":"right","font-weight":"","font-size":"small","z-index":"3","overflow-x":"visible","overflow-y":"visible"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_2.Rain_Probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" %","locked":false},"style":{"left":"787px","top":"292px","width":"55px","height":"14px","color":"#ffffff","font-weight":"","font-size":"small","text-align":"center","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_3.Snowline","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"<","visibility-val":"600","visibility-groups-action":"hide","signals-cond-0":"<=","signals-val-0":"400","signals-icon-0":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","signals-icon-size-0":"19","signals-blink-0":false,"signals-horz-0":"-2","signals-vert-0":"-20","signals-hide-edit-0":false,"signals-cond-1":"<=","signals-val-1":"200","signals-icon-1":"/daswetter.admin/icons/tiempo-weather/galeria7/33.png","signals-icon-size-1":"19","signals-blink-1":true,"signals-horz-1":"5","signals-vert-1":"-20","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" m","signals-oid-0":"daswetter.0.location_1.ForecastDaily.Day_3.Snowline","visibility-oid":"daswetter.0.location_1.ForecastDaily.Day_3.Snowline","visibility-groups":null,"signals-oid-1":"daswetter.0.location_1.ForecastDaily.Day_3.Snowline"},"style":{"left":"864px","top":"329px","width":"58px","height":"12px","color":"white","text-align":"right","font-weight":"","font-size":"small","z-index":"3","overflow-x":"visible","overflow-y":"visible"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_4.Rain_Probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" %","locked":false},"style":{"left":"949px","top":"292px","width":"55px","height":"14px","color":"#ffffff","font-weight":"","font-size":"small","text-align":"center","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_4.Snowline","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"<","visibility-val":"600","visibility-groups-action":"hide","signals-cond-0":"<=","signals-val-0":"400","signals-icon-0":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","signals-icon-size-0":"19","signals-blink-0":false,"signals-horz-0":"-2","signals-vert-0":"-20","signals-hide-edit-0":false,"signals-cond-1":"<=","signals-val-1":"200","signals-icon-1":"/daswetter.admin/icons/tiempo-weather/galeria7/33.png","signals-icon-size-1":"19","signals-blink-1":true,"signals-horz-1":"5","signals-vert-1":"-20","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" m","signals-oid-0":"daswetter.0.location_1.ForecastDaily.Day_4.Snowline","visibility-oid":"daswetter.0.location_1.ForecastDaily.Day_4.Snowline","visibility-groups":null,"signals-oid-1":"daswetter.0.location_1.ForecastDaily.Day_4.Snowline"},"style":{"left":"944px","top":"329px","width":"58px","height":"12px","color":"white","text-align":"right","font-weight":"","font-size":"small","z-index":"3","overflow-x":"visible","overflow-y":"visible"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_5.Rain_Probability","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" %","locked":false},"style":{"left":"1031px","top":"292px","width":"55px","height":"14px","color":"#ffffff","font-weight":"","font-size":"small","text-align":"center","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_5.Temperature_Min","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":"","html_append_plural":""},"style":{"left":"1031px","top":"273px","color":"white","font-size":"small","text-align":"right","width":"25px","height":"15px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_5.Temperature_Max","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"0","html_append_singular":"","html_append_plural":"","html_prepend":" - "},"style":{"left":"1061px","top":"273px","color":"white","font-size":"small","text-align":"left","width":"25px","height":"15px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_5.Snowline","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"<","visibility-val":"600","visibility-groups-action":"hide","signals-cond-0":"<=","signals-val-0":"400","signals-icon-0":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","signals-icon-size-0":"19","signals-blink-0":false,"signals-horz-0":"-2","signals-vert-0":"-20","signals-hide-edit-0":false,"signals-cond-1":"<=","signals-val-1":"200","signals-icon-1":"/daswetter.admin/icons/tiempo-weather/galeria7/33.png","signals-icon-size-1":"19","signals-blink-1":true,"signals-horz-1":"5","signals-vert-1":"-20","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" m","signals-oid-0":"daswetter.0.location_1.ForecastDaily.Day_5.Snowline","visibility-oid":"daswetter.0.location_1.ForecastDaily.Day_5.Snowline","visibility-groups":null,"signals-oid-1":"daswetter.0.location_1.ForecastDaily.Day_5.Snowline"},"style":{"left":"1032px","top":"329px","width":"58px","height":"12px","color":"white","text-align":"right","font-weight":"","font-size":"small","z-index":"3","overflow-x":"visible","overflow-y":"visible"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_11.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","g_images":true,"src_0":""},"style":{"left":"846px","top":"62px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_14.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","g_images":true,"src_0":""},"style":{"left":"914px","top":"62px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_17.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","g_images":true,"src_0":""},"style":{"left":"978px","top":"62px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastHourly.Hour_20.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png","g_images":true,"src_0":""},"style":{"left":"1044px","top":"62px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_3.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_0":"","src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png"},"style":{"left":"871px","top":"220px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_4.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_0":"","src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png"},"style":{"left":"955px","top":"220px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.location_1.ForecastDaily.Day_5.symbol","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"600000","count":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_0":"","src_1":"/daswetter.admin/icons/tiempo-weather/galeria7/1.png","src_2":"/daswetter.admin/icons/tiempo-weather/galeria7/2.png","src_3":"/daswetter.admin/icons/tiempo-weather/galeria7/3.png","src_4":"/daswetter.admin/icons/tiempo-weather/galeria7/4.png","src_5":"/daswetter.admin/icons/tiempo-weather/galeria7/5.png","src_6":"/daswetter.admin/icons/tiempo-weather/galeria7/6.png","src_7":"/daswetter.admin/icons/tiempo-weather/galeria7/7.png","src_8":"/daswetter.admin/icons/tiempo-weather/galeria7/8.png","src_9":"/daswetter.admin/icons/tiempo-weather/galeria7/9.png","src_10":"/daswetter.admin/icons/tiempo-weather/galeria7/10.png","src_11":"/daswetter.admin/icons/tiempo-weather/galeria7/11.png","src_12":"/daswetter.admin/icons/tiempo-weather/galeria7/12.png","src_13":"/daswetter.admin/icons/tiempo-weather/galeria7/13.png","src_14":"/daswetter.admin/icons/tiempo-weather/galeria7/14.png","src_15":"/daswetter.admin/icons/tiempo-weather/galeria7/15.png","src_16":"/daswetter.admin/icons/tiempo-weather/galeria7/16.png","src_17":"/daswetter.admin/icons/tiempo-weather/galeria7/17.png","src_18":"/daswetter.admin/icons/tiempo-weather/galeria7/18.png","src_19":"/daswetter.admin/icons/tiempo-weather/galeria7/19.png","src_20":"/daswetter.admin/icons/tiempo-weather/galeria7/20.png","src_21":"/daswetter.admin/icons/tiempo-weather/galeria7/21.png","locked":false,"src_22":"/daswetter.admin/icons/tiempo-weather/galeria7/22.png","src_23":"/daswetter.admin/icons/tiempo-weather/galeria7/23.png","src_24":"/daswetter.admin/icons/tiempo-weather/galeria7/24.png","src_25":"/daswetter.admin/icons/tiempo-weather/galeria7/25.png"},"style":{"left":"1036px","top":"220px","width":"50px","height":"50px","z-index":"3"},"widgetSet":"basic"}]@Pedder007 Kann ich so irgendwie nicht importieren. Kannst Du das als File anhängen?
NACHTRAG.
im ersten Teil waren am Ende fehlerhafte Zeichen.
Hier das ganze als Datei.Dank Dir!
@Negalein Die sieht auch klasse aus!
Was ist das links unten? Regenradar?Du magst das nicht zufällig auch als Export zu Verfügung stellen?
@Merlin123 sagte in Adapter: DasWetter:
bitte als View (VIS 1) importieren
@1Topf hab schon die 4.3
Das mag ja sein. Du sollst aber kein UpDATE, sondern ein UpLOAD machen:
Alternativ über die Konsole
iobroker upload daswetter. Dann sollten Deine selbst eingefügten Icons auch auftauchen. -
Bekommt mit der aktuellen Version irgendwer eine Deutsche Beschreibung zu den Wetter Symbolen? Bei mir sind die discription Datenpunkte leer.
