  3. Off Topic
  4. Pflege des Betriebssystems
  5. Probleme beim Upgrade bookworm -> trixie
    6.8k
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
25 Beiträge 3 Kommentatoren 1.9k Aufrufe 2 Beobachtet
Dieses Thema wurde aufgespalten von Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie' Homoran
    marcelinho
    ich bin verwirrt:
    /opt/iobroker$ systemctl status sshd.service
    Unit sshd.service could not be found.
    /opt/iobroker$ sudo su -
    sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
    sudo: a password is required
    /opt/iobroker$ iob diag
    TERM environment variable not set.
    *** iob diag is starting up, please wait ***
    npm error code ELSPROBLEMS
    npm error invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-01-02T20_16_50_125Z-debug-0.log
    107*** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    * Some output is masked. For full results please use 'iob diag --unmask' *
    Press any key to continue
    /opt/iobroker$
    /opt/iobroker$ sudo apt update
    ```bash
    Script v.2025-08-09
    107*** BASE SYSTEM ***
    Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model        : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
    21:18:05 up 53 min,  1 user,  load average: 0.31, 0.42, 0.59
    CPU threads: 4
    107*** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    107*** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    107*** TIME AND TIMEZONES ***
                   Local time: Fri 2026-01-02 21:18:05 CET
               Universal time: Fri 2026-01-02 20:18:05 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    107*** Users and Groups ***
    User that called 'iob diag':
    iobroker
    HOME=/home/iobroker
    iobroker
    HOME=/home/iobroker
    A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
    A root login is not required in most Linux Distributions.
    Run 'iobroker fix' or use the system tools to create a user.
    107*** DISPLAY-SERVER SETUP ***
    Display-Server:     false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:
    107*** MEMORY ***
    Mem:            4.0G        3.0G        365M        610K        673M        966M
    Swap:           209M        209M        516K
    Total:          4.2G        3.2G        365M
    Active iob-Instances:     28
             3796 M total memory
             2874 M used memory
             1981 M active memory
             1256 M inactive memory
              348 M free memory
               55 M buffer memory
              587 M swap cache
              199 M total swap
              199 M used swap
                0 M free swap
    107*** top - Table Of Processes  ***
    top - 21:18:06 up 54 min,  1 user,  load average: 0.31, 0.42, 0.59
    Tasks: 232 total,   1 running, 231 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 11.1 us, 11.1 sy,  0.0 ni, 66.7 id, 11.1 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3796.9 total,    348.3 free,   2874.9 used,    642.8 buff/cache
    MiB Swap:    200.0 total,      0.5 free,    199.5 used.    922.0 avail Mem
    107*** FAILED SERVICES ***
    0 loaded units listed.
    107*** DMESG CRITICAL ERRORS ***
    No critical errors detected
    107*** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M  1.2M  759M   1% /run
    /dev/mmcblk0p2 ext4       29G   18G  9.3G  66% /
    tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   78M  433M  16% /boot/firmware
    tmpfs          tmpfs     380M   40K  380M   1% /run/user/1000
    sudo
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    Archived and active journals take up 170.2M in the file system.
    /opt/iobroker/backups:
    145M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.8G    /opt/iobroker/iobroker-data/
    1.4G    /opt/iobroker/iobroker-data/history
    236M    /opt/iobroker/iobroker-data/files
    109M    /opt/iobroker/iobroker-data/backup-objects
    47M    /opt/iobroker/iobroker-data/files/admin.admin
    49M    /opt/iobroker/iobroker-data/objects.jsonl
    24M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    9.8M    /opt/iobroker/iobroker-data/files/homekit-controller.admin/static/js/main.f592ece1.js
    9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf33d1a5a7669f5d-if00-port0
    107*** ZigBee Settings ***
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    107*** NodeJS-Installation ***
    /usr/bin/nodejs     v22.21.1
    /usr/bin/node         v22.21.1
    /usr/bin/npm         11.6.4
    /usr/bin/npx         11.6.4
    /usr/bin/corepack     0.34.0
    nodejs:
      Installed: 22.21.1-1nodesource1
      Candidate: 22.21.1-1nodesource1
      Version table:
    *** 22.21.1-1nodesource1 100
    No problems detected
    Errors in npm tree: 0
    107*** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 3217)
    Core adapters versions
    js-controller:     7.0.7
    admin:         7.7.19
    javascript:     9.0.11
    nodejs modules from github:     1
    +-- homebridge-tapo@1.4.17 (git+ssh://git@github.com/apatsufas/homebridge-tapo-p100.git#8d25f8ab9ffc1d7cca1118cd0081d1ba28fd3cd1)
    Adapter State
    + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
    + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
    + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
    + system.adapter.daikin.1                 : daikin                : raspberrypi                              -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
    + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
    + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.myenergi.0               : myenergi              : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
    + system.adapter.sun2000.0                : sun2000               : raspberrypi                              -  enabled, port: 502
    + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              - disabled
    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "daikin"       : 1.5.1    , installed 1.5.1
    Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "homekit-controller": 0.5.11, installed 0.5.11
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "lg-thinq"     : 1.1.3    , installed 1.1.3
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
    Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
    Adapter    "openhab"      : 1.2.0    , installed 1.2.0
    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "sun2000"      : 2.3.5    , installed 2.3.5
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.8
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
    Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
    Objects and States
    Objects:     6475
    States:     5056
    107*** OS-Repositories and Updates ***
    Hit:1 http://archive.raspberrypi.org/debian trixie InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian trixie InRelease
    Reading package lists...
    Pending Updates: 0
    107*** Listening Ports ***
    107*** Log File - Last 25 Lines ***
    2026-01-02 21:11:14.167  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.terminal.0.memHeapTotal created
    2026-01-02 21:11:14.176  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.terminal.0.memRss created
    2026-01-02 21:11:14.188  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.terminal.0.uptime created
    2026-01-02 21:11:14.197  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.terminal.0.inputCount created
    2026-01-02 21:11:14.208  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.terminal.0.outputCount created
    2026-01-02 21:11:14.216  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.terminal.0.eventLoopLag created
    2026-01-02 21:11:14.225  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.terminal.0.sigKill created
    2026-01-02 21:11:14.236  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.terminal.0.logLevel created
    2026-01-02 21:11:14.250  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.terminal.upload created
    2026-01-02 21:11:14.259  - info: host.raspberrypi iobroker host.raspberrypi object terminal.0.info created
    2026-01-02 21:11:14.266  - info: host.raspberrypi iobroker host.raspberrypi object terminal.0.info.connection created
    2026-01-02 21:11:14.274  - info: host.raspberrypi iobroker host.raspberrypi Set default value of terminal.0.info.connection: false
    2026-01-02 21:11:14.285  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.terminal.0 created
    2026-01-02 21:11:15.320  - info: host.raspberrypi iobroker exit 0
    2026-01-02 21:11:17.283  - info: admin.0 (1428) ==> Connected system.user.admin from ::ffff:192.168.2.119
    2026-01-02 21:11:18.266  - info: host.raspberrypi instance system.adapter.terminal.0 in version "1.0.0" started with pid 5426
    2026-01-02 21:11:19.115  - info: admin.0 (1428) <== Disconnect system.user.admin from ::ffff:192.168.2.119
    2026-01-02 21:11:21.606  - info: terminal.0 (5426) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.terminal, node: v22.21.1, js-controller: 7.0.7
    2026-01-02 21:11:21.680  - info: terminal.0 (5426) http server listening on port 8088
    2026-01-02 21:12:13.033  - info: daikin-cloud.0 (1904) Daikin-Cloud tokens updated ...
    2026-01-02 21:12:13.034  - info: daikin-cloud.0 (1904) Daikin token updated in adapter configuration ...
    2026-01-02 21:14:44.067  - info: tuya.0 (1658) 73103057e868e767b347: Connect locally to device
    2026-01-02 21:14:44.068  - info: tuya.0 (1658) 73103057e868e767b347 Init with IP=192.168.2.128, Key=5xJDx8!3L%N;&}6E, Version=3.3
    2026-01-02 21:16:14.359  - info: admin.0 (1428) <== Disconnect system.user.admin from ::ffff:192.168.2.119 admin
    2026-01-02 21:16:17.892  - info: admin.0 (1428) <== Disconnect system.user.admin from ::ffff:192.168.2.119 admin
    iob diag has finished.
    WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
    Building dependency tree...
    Reading state information...
    30 packages can be upgraded. Run 'apt list --upgradable' to see them.
    /opt/iobroker$ apt policy openssh-server
    openssh-server:
    Installed: (none)
    Candidate: (none)
    Version table:
    1:9.2p1-2+deb12u7 -1
    /opt/iobroker$
    /opt/iobroker$ sudo apt update apt policy openssh-server
    E:
    The update command takes no arguments
    /opt/iobroker$
    • M marcelinho
      ich bin verwirrt:
      /opt/iobroker$
      ```bash
      Script v.2025-08-09
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      iobroker
      HOME=/home/iobroker
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:
      107*** MEMORY ***
               3796 M total memory
               2874 M used memory
                348 M free memory
                 55 M buffer memory
                587 M swap cache
                199 M total swap
                199 M used swap
                  0 M free swap
      sudo
      /var:
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm         11.6.4
      /usr/bin/npx         11.6.4
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:         7.7.19
      javascript:     9.0.11
      Adapter State
      + instance is alive
      Objects and States
      Objects:     6475
      States:     5056
      Pending Updates: 0
      openssh-server:
      Installed: (none)
      Candidate: (none)
      Version table:
      /opt/iobroker$
      E:
      /opt/iobroker$
      @marcelinho sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
      sudo su -
      Wer erzählt so einen Unsinn?
        marcelinho
        chat gpt.. ich versuche es gerade eben wieder zum laufen zu bringen und kenne mich nicht so aus.
        • M marcelinho
          ich bin verwirrt:
          /opt/iobroker$
          ```bash
          Script v.2025-08-09
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          iobroker
          HOME=/home/iobroker
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:
          107*** MEMORY ***
                   3796 M total memory
                   2874 M used memory
                    348 M free memory
                     55 M buffer memory
                    587 M swap cache
                    199 M total swap
                    199 M used swap
                      0 M free swap
          sudo
          /var:
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm         11.6.4
          /usr/bin/npx         11.6.4
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:         7.7.19
          javascript:     9.0.11
          Adapter State
          + instance is alive
          Objects and States
          Objects:     6475
          States:     5056
          Pending Updates: 0
          openssh-server:
          Installed: (none)
          Candidate: (none)
          Version table:
          /opt/iobroker$
          E:
          /opt/iobroker$
          Debian GNU/Linux 12 (bookworm)
          Wolltest du nicht Debian 13 installieren?
          Ich weiß nicht welche shell in dem Terminal aufgerufen wird. Scheint mir was altes zu sein.
            marcelinho
            doch ja debian 13, ich war bis zu dem Punkt: sudo apt full-upgrade und dann hab ich den reboot gemacht und jetzt kann ich nicht mehr zugreifen.
            • M marcelinho
              @marcelinho
              Lass BITTE die Finger von ChatGPT. Das nutzt dir nur was, wenn du den Quark auch einordnen kannst, der dir da verklickert wird.
              • M marcelinho
                upgrade bei raspberryOS?
                Das geht doch nicht
                  Das geht doch nicht
                  @Homoran sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                  Das geht doch nicht
                  Doch, von einem sauberen Raspberry12 kommst du auch auf ein sauberes 13.
                  Nur von 11 auf 12 geht es bei Raspberry nicht.
                    marcelinho
                    ich hab hier noch ne micro SD Karte da ich ziehe da neu Debian 13 drauf und würde die Backups einspielen, geht das auch? Ich komme bei der aktuellen Karte zwar nicht mit putty drauf aber könnte mit die Backups neu erstellen (iobroker ist ja erreichbar) und einspielen oder?
                    • M marcelinho
                      @marcelinho
                      Haste keine aktuellen Backups vorher gemacht???
                      Du bist ganz schön blauäugig...
                      Kannst du die letzten Postings bitte separieren? Das hat mit dem Ursprungsthema nicht mehr viel zu tun.
                      geht das auch?
                      Natürlich geht das.
                      • M marcelinho
                        @marcelinho
                        Irgendwo und irgendwie hast du dir die Paketquellen zersemmelt.
                        Denn
                        Pending Updates: 0
                        passt null zu
                        openssh-server:
                        Installed: (none)
                        Candidate: (none)
                        Version table:
                        Auf einem 'gesunden' Trixie muss da das kommen:
                        echad@chet:~ $ apt policy openssh-server
                        openssh-server:
                          Installiert:           1:10.0p1-7
                          Installationskandidat: 1:10.0p1-7
                          Versionstabelle:
                         *** 1:10.0p1-7 500
                                500 http://deb.debian.org/debian trixie/main arm64 Packages
                        echad@chet:~ $
                        Die Basis-Repos sind auch zu dritt:
                        OK:1 http://deb.debian.org/debian trixie InRelease
                        Holen:2 http://deb.debian.org/debian-security trixie-security InRelease [43,4 kB]
                        Holen:3 http://deb.debian.org/debian trixie-updates InRelease [47,3 kB]
                        Bei dir ist da aber gar nix mehr. Und deswegen geht da auch kein Upgrade.
                        Edit: Ich sehe gerade, das fehlte von Anfang an. Hab ich übersehen.
                        Installier es neu.
                          @marcelinho
                          geht das auch?
                          Natürlich geht das.
                          @Thomas-Braun sagte in Probleme beim Upgrade bookworm -> trixie:
                          Kannst du
                          ich habe!
                            marcelinho
                            Guten Morgen, ich hab nun auf eine neue Micro SD Karte alles installiert, sollte soweit auch laufen und alle Adapter sind grün bis auf Zigbee2mqtt und InfluxDB in Verbindung mit Grafana.
                            Momentan hänge ich noch bei Zigbee2mqtt. Ich habe noch die alten Daten der Yaml gespeichert. Der Stick wird erkannt Mosquitto hab ich ebenfalls installiert und ist erreichbar über:
                            mosquitto_sub -h 127.0.0.1 -t "#" -v
                            mosquitto_pub -h 127.0.0.1 -t "test/topic" -m "hello"
                            Er versucht im Sekundentakt den Adapter zu starten aber er bleibt Orange.
                            Adapter Einstellungen sind genauso wie auf der alten MicroSD Karte. Wenn ich die einlege geht alles.
                            Auf der WebUI konnte ich per 192.168.2.198:8080 auch schon zugreifen da kann man aber soweit ich weis alles einstellen was in der Yaml gemacht wird, richtig?
                            Stick wird auch erkannt und wurde nicht umgesteckt:
                            pi@raspberrypi:~ $ ls /dev/serial/by-id/
                            An was könnte es noch liegen?
