  4. Instabiles Zigbee-Netzwerk
    6.4k
100 Beiträge 11 Kommentatoren 6.6k Aufrufe 13 Beobachtet
  • holly200289H holly200289
    Wenn ich Zigbee 1 und 2 abschalte kommt es trotzdem zu diesem Problem, dann machen das Zigbee 3 und 4
    @holly200289
    Du könntest mir einen Gefallen tun und die aktuelle Version von iob diag mal bei dir ausführen:
    cd
    curl -o diag.sh  https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/master/diag.sh && bash diag.sh
    Dann kann ich mal sehen, wie das bei mehreren Instanzen aussieht.
    holly200289H 1 Antwort Letzte Antwort
    • holly200289H Offline
      holly200289
      admin@iobroker:~$ journalctl -p 3 -xb
      Dec 29 12:47:16 iobroker blkmapd[332]: open pipe file /run/rpc_pipefs/nfs/blocklayout failed: No such file or directory
      Dec 29 12:47:17 iobroker login[336]: pam_systemd(login:session): Failed to create session: Seat has no VTs but VT numbe>
      Dec 29 14:11:48 iobroker polkit-agent-helper-1[8103]: pam_unix(polkit-1:auth): conversation failed
      Dec 29 14:11:48 iobroker polkit-agent-helper-1[8103]: pam_unix(polkit-1:auth): auth could not identify password for [ad>
      Dec 29 14:13:11 iobroker polkit-agent-helper-1[8855]: pam_unix(polkit-1:auth): conversation failed
      Dec 29 14:13:11 iobroker polkit-agent-helper-1[8855]: pam_unix(polkit-1:auth): auth could not identify password for [ad>
      lines 1-6/6 (END)
      Dec 29 12:47:17 iobroker login[336]: pam_systemd(login:session): Failed to create session: Seat has no VTs but VT number>
      Dec 29 14:11:48 iobroker polkit-agent-helper-1[8103]: pam_unix(polkit-1:auth): auth could not identify password for [adm>
      Dec 29 14:13:11 iobroker polkit-agent-helper-1[8855]: pam_unix(polkit-1:auth): auth could not identify password for [adm>
      lines 1-6/6 (END)
      Dec 29 12:47:17 iobroker login[336]: pam_systemd(login:session): Failed to create session: Seat has no VTs but VT number >
      Dec 29 14:11:48 iobroker polkit-agent-helper-1[8103]: pam_unix(polkit-1:auth): auth could not identify password for [admi>
      Dec 29 14:13:11 iobroker polkit-agent-helper-1[8855]: pam_unix(polkit-1:auth): auth could not identify password for [admi>
      lines 1-6/6 (END)
      Dec 29 12:47:17 iobroker login[336]: pam_systemd(login:session): Failed to create session: Seat has no VTs but VT number no>
      Dec 29 14:11:48 iobroker polkit-agent-helper-1[8103]: pam_unix(polkit-1:auth): auth could not identify password for [admin]
      Dec 29 14:13:11 iobroker polkit-agent-helper-1[8855]: pam_unix(polkit-1:auth): auth could not identify password for [admin]
      lines 1-6/6 (END)
      Dec 29 12:47:17 iobroker login[336]: pam_systemd(login:session): Failed to create session: Seat has no VTs but VT number not>
      lines 1-6/6 (END)
      Dec 29 12:47:17 iobroker login[336]: pam_systemd(login:session): Failed to create session: Seat has no VTs but VT number not 0
      lines 1-6/6 (END)
      lines 1-6/6 (END)
      lines 1-6/6 (END)
      lines 1-6/6 (END)
      lines 1-6/6 (END)
      lines 1-6/6 (END)
      lines 1-6/6 (END)
      lines 1-6/6 (END)
      lines 1-6/6 (END)
      lines 1-6/6 (END)
      lines 1-6/6 (END)
        holly200289
        Ja klar mache ich, kein Thema
          @holly200289
          cd
          holly200289
          @Thomas-Braun sagte in Instabiles Zigbee-Netzwerk:
          cd
          Script v.2025-12-26
          *** BASE SYSTEM ***
          Operating System: Debian GNU/Linux 13 (trixie)
           Static hostname: iobroker
                 Icon name: computer-container
                   Chassis: container ☐
            Virtualization: lxc
                    Kernel: Linux 6.8.12-17-pve
              Architecture: x86-64
          OS is similar to:
          model name      : AMD Ryzen 7 5700G with Radeon Graphics
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           21:02:08 up  8:14,  2 users,  load average: 0.81, 0.96, 0.93
          CPU threads: 8
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'trixie'!
          *** TIME AND TIMEZONES ***
                         Local time: Mon 2025-12-29 21:02:08 CET
                     Universal time: Mon 2025-12-29 20:02:08 UTC
                           RTC time: n/a
          System clock synchronized: no
                        NTP service: inactive
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          admin
          HOME=/home/admin
          GROUPS=admin adm dialout sudo audio video plugdev users iobroker
          iobroker
          [sudo] password for admin:
          HOME=/home/iobroker
          SUDO_HOME=/home/admin
          GROUPS=iobroker tty dialout audio video plugdev bluetooth docker
          *** DISPLAY-SERVER SETUP ***
          Display-Server:         false
          Unit display-manager.service could not be found.
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Mem:             26G        6.8G         19G         23M        362M         19G
          Swap:           1.0G          0B        1.0G
          Total:           27G        6.8G         20G
          Active iob-Instances:   84
                  25000 M total memory
                   6455 M used memory
                   6495 M active memory
                      0 M inactive memory
                  18220 M free memory
                      0 M buffer memory
                    345 M swap cache
                   1000 M total swap
                      0 M used swap
                   1000 M free swap
          top - 21:02:13 up  8:14,  2 users,  load average: 0.91, 0.98, 0.94
          Tasks: 122 total,   2 running, 120 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 17.5 us,  6.2 sy,  0.0 ni, 76.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  25000.0 total,  18216.1 free,   6460.1 used,    345.9 buff/cache
          MiB Swap:   1000.0 total,   1000.0 free,      0.0 used.  18539.9 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          1 CRITICAL ERRORS DETECTED!
          Check 'sudo dmesg --level=emerg,alert,crit -T' for details
          *** FILESYSTEM ***
          Filesystem              Type   Size  Used Avail Use% Mounted on
          daten/subvol-100-disk-0 zfs    230G   19G  212G   9% /
          none                    tmpfs  492K  4.0K  488K   1% /dev
          tmpfs                   tmpfs   16G     0   16G   0% /dev/shm
          tmpfs                   tmpfs  6.2G  184K  6.2G   1% /run
          tmpfs                   tmpfs  5.0M     0  5.0M   0% /run/lock
          tmpfs                   tmpfs   16G   22M   16G   1% /tmp
          tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
          tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-networkd.service
          tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/container-getty@1.service
          tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/container-getty@2.service
          tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/console-getty.service
          tmpfs                   tmpfs  3.1G  8.0K  3.1G   1% /run/user/1001
          [Mon Dec 29 12:46:49 2025] EXT4-fs (dm-1): mounted filesystem 8454bac7-7b31-4e6e-a8ae-07a4b96134b1 ro with ordered data mode. Quota mode: none.
          [Mon Dec 29 12:46:49 2025] EXT4-fs (dm-1): re-mounted 8454bac7-7b31-4e6e-a8ae-07a4b96134b1 r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET SOURCE                  FSTYPE OPTIONS
          /      daten/subvol-100-disk-0 zfs    rw,relatime,xattr,posixacl,casesensitive
          /var:
          3.2G    /var/
          1.9G    /var/lib
          1.8G    /var/lib/containerd
          1.2G    /var/log/journal/9626128f51d4471993ebdff830afe042
          Archived and active journals take up 1.1G in the file system.
          /opt/iobroker/backups:
          7.7G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.6G    /opt/iobroker/iobroker-data/
          746M    /opt/iobroker/iobroker-data/files
          512M    /opt/iobroker/iobroker-data/history
          267M    /opt/iobroker/iobroker-data/backup-objects
          82M     /opt/iobroker/iobroker-data/files/vis
          18M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
          17M     /opt/iobroker/iobroker-data/history/20241203/history.pi-hole.0.overTimeData10mins.domains_over_time.data-table.json
          17M     /opt/iobroker/iobroker-data/history/20241203/history.pi-hole.0.overTimeData10mins.ads_over_time.data-table.json
          17M     /opt/iobroker/iobroker-data/history/20241202/history.pi-hole.0.overTimeData10mins.domains_over_time.data-table.json
          17M     /opt/iobroker/iobroker-data/history/20241202/history.pi-hole.0.overTimeData10mins.ads_over_time.data-table.json
          USB-Devices by-id:
          USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
          please always prefer the links 'by-id':
          No Devices found 'by-id'
          *** ZigBee Settings ***
          ⚠ HINT:
          Your zigbee.1 COM-Port is NOT matching 'by-id'.
          Please check your setting:
          \'socket\'
          ⚠ HINT:
          Your zigbee.2 COM-Port is NOT matching 'by-id'.
          \'tcp\'
          ⚠ HINT:
          Your zigbee.3 COM-Port is NOT matching 'by-id'.
          \'tcp\'
          ⚠ HINT:
          Your zigbee.4 COM-Port is NOT matching 'by-id'.
          \'tcp\'
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v22.21.0
          /usr/bin/node           v22.21.0
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          ✓ Node.js installation is correct
          nodejs:
            Installed: 22.21.0-1nodesource1
            Candidate: 22.21.0-1nodesource1
            Version table:
           *** 22.21.0-1nodesource1 600
               22.20.0-1nodesource1 600
               22.19.0-1nodesource1 600
               22.18.0-1nodesource1 600
               22.17.1-1nodesource1 600
               22.17.0-1nodesource1 600
               22.16.0-1nodesource1 600
               22.15.1-1nodesource1 600
               22.15.0-1nodesource1 600
               22.14.0-1nodesource1 600
               22.13.1-1nodesource1 600
               22.13.0-1nodesource1 600
               22.12.0-1nodesource1 600
               22.11.0-1nodesource1 600
               22.10.0-1nodesource1 600
               22.9.0-1nodesource1 600
               22.8.0-1nodesource1 600
               22.7.0-1nodesource1 600
               22.6.0-1nodesource1 600
               22.5.1-1nodesource1 600
               22.5.0-1nodesource1 600
               22.4.1-1nodesource1 600
               22.4.0-1nodesource1 600
               22.3.0-1nodesource1 600
               22.2.0-1nodesource1 600
               22.1.0-1nodesource1 600
               22.0.0-1nodesource1 600
               20.19.2+dfsg-1 500
                  500 http://deb.debian.org/debian trixie/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 2164)
          Core adapters versions
          js-controller:  7.0.7
          admin:          7.7.19
          javascript:     9.0.17
          nodejs modules from github:     18
          +-- @iobroker/plugin-sentry@2.0.4 (git+ssh://git@github.com/ioBroker/plugin-sentry.git#31c593552c25cd0f10e2946589fbc88ad30cc480)
          +-- iobroker.chromecast@4.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.chromecast.git#82249496c21d5d02f073f1db0552eea0901d7f9e)
          +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
          +-- iobroker.mihome@1.4.0 (git+ssh://git@github.com/ioBroker/ioBroker.mihome.git#a1adfe45118047df0896faa952d2d9816a34539d)
          +-- iobroker.nuki-extended@2.7.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#abb720a7a3234d6328d68b1523938c3eace26419)
          +-- iobroker.omada@0.0.7 (git+ssh://git@github.com/TA2k/ioBroker.omada.git#0f6a083c8bf8306ffcb248ad6aa80c495cec438e)
          +-- iobroker.pi-hole2@1.1.1 (git+ssh://git@github.com/oweitman/ioBroker.pi-hole2.git#2e3723101f29c6deaa9811ccd62d84cea5438c90)
          +-- iobroker.roborock@0.6.19 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#4d519d4e5494569fc898affe0d2946722a646efd)
          +-- iobroker.rtspStream@0.0.2 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspStream.git#3891a8545b5566946b89b6f4dbfeac1e2a6527a5)
          | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
          +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
          +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f)
          | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
          +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
          +-- iobroker.weblogin@0.1.1 (git+ssh://git@github.com/Vertumnus/ioBroker.weblogin.git#62ad7e95c8b9af53e668a1741d4818e3502892e7)
          +-- JQuery-Snowfall@1.7.1 (git+ssh://git@github.com/loktar00/JQuery-Snowfall.git#d22ba78f76804e21404bc000142c019d6c10973d)
          +-- magic-snowflakes@7.0.1 (git+ssh://git@github.com/hcodes/snowflakes.git#718a2b06c3d590ea89081700d96cfa014074dd4a)
          `-- zigbee-herdsman-converters@25.96.0 (git+ssh://git@github.com/Koenkk/zigbee-herdsman-converters.git#e9132fc65cc0bcbef60a5793976ba192fcc845ac)
          Adapter State
          + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          + system.adapter.admin.2                  : admin                 : iobroker                                 -  enabled, port: 8089, bind: 127.0.0.1, run as: admin
          + system.adapter.ai-assistant.0           : ai-assistant          : iobroker                                 -  enabled
          + system.adapter.ai-toolbox.0             : ai-toolbox            : iobroker                                 -  enabled
          + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobroker                                 -  enabled
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
          + system.adapter.bshb.0                   : bshb                  : iobroker                                 -  enabled
          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          + system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
            system.adapter.devices.0                : devices               : iobroker                                 - disabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
          + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
          + system.adapter.espresense.0             : espresense            : iobroker                                 -  enabled
            system.adapter.flexcharts.0             : flexcharts            : iobroker                                 -  enabled
          + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
          + system.adapter.geofency.0               : geofency              : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
            system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
          + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
          + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
          + system.adapter.history.0                : history               : iobroker                                 -  enabled
          + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
            system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: iobroker                                 -  enabled
            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
            system.adapter.icons-freepic.0          : icons-freepic         : iobroker                                 -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
            system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
            system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
            system.adapter.icons-smarthome.0        : icons-smarthome       : iobroker                                 -  enabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.lightcontrol.0           : lightcontrol          : iobroker                                 -  enabled
          + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
            system.adapter.material.0               : material              : iobroker                                 - disabled
            system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 0.0.0.0
            system.adapter.minuvis.0                : minuvis               : iobroker                                 - disabled
          + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
          + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
          + system.adapter.omada.0                  : omada                 : iobroker                                 -  enabled, port: 8043
            system.adapter.openweathermap.1         : openweathermap        : iobroker                                 -  enabled
          + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
          + system.adapter.philips-air.0            : philips-air           : iobroker                                 -  enabled
          + system.adapter.philips-air.1            : philips-air           : iobroker                                 -  enabled
          + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
          + system.adapter.pi-hole2.0               : pi-hole2              : iobroker                                 -  enabled, port: 80
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          + system.adapter.places.0                 : places                : iobroker                                 -  enabled
          + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
            system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
          + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
          + system.adapter.rtspStream.0             : rtspStream            : iobroker                                 -  enabled, port: 8083
          + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
          + system.adapter.samsung.1                : samsung               : iobroker                                 -  enabled
          + system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
          + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.slideshow.0              : slideshow             : iobroker                                 -  enabled
          + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
          + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.250
          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
          + system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 -  enabled
          + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5001
          + system.adapter.systeminfo.0             : systeminfo            : iobroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
          + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.tr-064.2                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
            system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
            system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
            system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
            system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
            system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
            system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
            system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
          + system.adapter.wallpanel.0              : wallpanel             : iobroker                                 -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
          + system.adapter.webcal.0                 : webcal                : iobroker                                 -  enabled
            system.adapter.weblogin.0               : weblogin              : iobroker                                 - disabled
          + system.adapter.webui.0                  : webui                 : iobroker                                 -  enabled
          + system.adapter.welcome.0                : welcome               : iobroker                                 -  enabled, port: 8080, bind: 192.168.178.250 (SSL), run as: admin
          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
          + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 -  enabled
          + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
          + system.adapter.windows-control.0        : windows-control       : iobroker                                 -  enabled
          + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
            system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
          + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: socket://192.168.178.187:1020
          + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.38:2030
          + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.230:4060
          + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.240:6080
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: patch
          Installed ioBroker-Adapters
          Used repository: stable
          Adapter    "admin"        : 7.7.19   , installed 7.7.19
          Adapter    "alexa-timer-vis": 2.1.2  , installed 2.1.2
          Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
          Adapter    "alias-manager": 2.0.0    , installed 2.0.0
          Adapter    "backitup"     : 3.3.10   , installed 3.3.13
          Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
          Adapter    "bshb"         : 0.5.0    , installed 0.5.0
          Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
          Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
          Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
          Adapter    "devices"      : 1.2.8    , installed 1.2.8
          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
          Adapter    "email"        : 2.0.4    , installed 2.0.4
          Adapter    "espresense"   : 0.6.3    , installed 0.6.3
          Adapter    "firetv"       : 2.1.0    , installed 2.1.0
          Adapter    "flexcharts"   : 0.6.1    , installed 0.6.1
          Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
          Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
          Adapter    "geofency"     : 1.2.4    , installed 1.2.4
          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
          Adapter    "ham"          : 5.3.1    , installed 5.3.1
          Adapter    "harmony"      : 1.5.0    , installed 1.5.0
          Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
          Adapter    "ical"         : 1.18.1   , installed 1.18.1
          Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
          Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
          Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
          Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
          Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
          Adapter    "iot"          : 5.0.7    , installed 5.0.7
          Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
          Adapter    "javascript"   : 9.0.11   , installed 9.0.17
          Controller "js-controller": 7.0.7    , installed 7.0.7
          Adapter    "kisshome-defender": 1.1.13, installed 1.1.13
          Adapter    "lightcontrol" : 1.0.1    , installed 1.0.1
          Adapter    "lovelace"     : 5.0.1    , installed 5.0.3
          Adapter    "material"     : 1.3.1    , installed 1.3.1
          Adapter    "matter"       : 0.5.5    , installed 0.5.6
          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
          Adapter    "mihome-cloud" : 0.1.0    , installed 0.2.2
          Adapter    "mihome-vacuum": 5.2.0    , installed 5.3.0
          Adapter    "minuvis"      : 2.3.3    , installed 2.3.3
          Adapter    "moma"         : 1.2.9    , installed 1.2.9
          Adapter    "node-red"     : 5.2.1    , installed 6.0.7
          Adapter    "nuki"         : 2.0.0    , installed 2.0.0
          Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "openweathermap": 1.1.2   , installed 1.1.2
          Adapter    "parser"       : 2.2.4    , installed 2.2.4
          Adapter    "philips-air"  : 1.2.0    , installed 1.2.0
          Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
          Adapter    "pi-hole2"     : 1.1.1    , installed 1.1.1
          Adapter    "ping"         : 1.7.9    , installed 1.7.9
          Adapter    "places"       : 1.3.0    , installed 1.3.0
          Adapter    "proxmox"      : 2.4.0    , installed 2.4.2
          Adapter    "ring"         : 6.4.0    , installed 6.4.0
          Adapter    "roborock"     : 0.6.18   , installed 0.6.19
          Adapter    "rssfeed"      : 3.6.1    , installed 3.1.0  [Updatable]
          Adapter    "samsung"      : 0.6.1    , installed 0.6.1
          Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
          Adapter    "shelly"       : 10.4.1   , installed 10.4.1
          Adapter    "shuttercontrol": 2.0.7   , installed 2.0.9
          Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
          Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
          Adapter    "synology"     : 3.1.0    , installed 3.1.0
          Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tinymqttbroker": 0.1.4   , installed 0.1.4
          Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "upnp"         : 1.1.0    , installed 1.1.0
          Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
          Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
          Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.3
          Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
          Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
          Adapter    "vis-material" : 0.2.0    , installed 0.2.0
          Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
          Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
          Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
          Adapter    "weather-warnings": 0.10.0, installed 0.10.0
          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
          Adapter    "web"          : 7.0.8    , installed 7.0.9
          Adapter    "webcal"       : 1.4.0    , installed 1.4.0
          Adapter    "webui"        : 1.37.0   , installed 1.38.7
          Adapter    "welcome"      : 1.0.2    , installed 1.0.2
          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
          Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
          Adapter    "wireguard"    : 1.7.0    , installed 1.8.0
          Adapter    "wled"         : 0.7.2    , installed 0.7.2
          Adapter    "yahka"        : 1.1.5    , installed 1.1.5
          Adapter    "youtube"      : 6.1.0    , installed 6.0.0  [Updatable]
          Adapter    "yr"           : 5.3.0    , installed 5.3.0
          Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
          Objects and States
          Objects:        57014
          States:         44991
          W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
          Hit:1 http://deb.debian.org/debian trixie InRelease
          Hit:2 http://security.debian.org trixie-security InRelease
          Hit:3 http://deb.debian.org/debian trixie-updates InRelease
          Hit:4 https://download.docker.com/linux/debian trixie InRelease
          Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
          Reading package lists... Done
          Pending systemupdates: 0
          *** Listening Ports ***
          tcp        0      0 192.168.178.250:1886    0.0.0.0:*               LISTEN      1000       19765084   38494/io.sonoff.0
          tcp        0      0 192.168.178.250:8080    0.0.0.0:*               LISTEN      1000       19835494   39610/io.welcome.0
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       19758813   37789/iobroker.js-c
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       19758806   37789/iobroker.js-c
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          20374      318/master
          tcp        0      0 192.168.178.250:9092    0.0.0.0:*               LISTEN      1000       19791813   38972/io.nuki.0
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       19765358   37983/node-red
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       19762157   38921/io.shelly.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       19791558   38854/io.mqtt.0
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          6551       1/init
          tcp        0      0 127.0.0.1:8089          0.0.0.0:*               LISTEN      1000       19758968   37828/io.admin.2
          tcp6       0      0 :::61991                :::*                    LISTEN      1000       19760559   38237/io.harmony.0
          tcp6       0      0 :::7999                 :::*                    LISTEN      1000       19765479   38218/io.geofency.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       19758065   37807/io.admin.1
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       19819133   39142/io.web.0
          tcp6       0      0 :::8083                 :::*                    LISTEN      1000       19837255   39432/io.rtspStream
          tcp6       0      0 :::8084                 :::*                    LISTEN      1000       19822867   39150/io.socketio.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       19803037   39156/io.simple-api
          tcp6       0      0 :::8091                 :::*                    LISTEN      1000       19820269   39281/io.lovelace.0
          tcp6       0      0 :::1890                 :::*                    LISTEN      1000       19787553   38741/io.espresense
          tcp6       0      0 :::111                  :::*                    LISTEN      0          6552       1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          13790      1/init
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          20375      318/master
          udp        0      0 0.0.0.0:38793           0.0.0.0:*                           1000       19845366   39811/io.ai-assista
          udp        0      0 0.0.0.0:55216           0.0.0.0:*                           1000       19802414   39086/io.zigbee.3
          udp        0      0 0.0.0.0:38894           0.0.0.0:*                           1000       19761521   38031/io.telegram.0
          udp        0      0 0.0.0.0:38971           0.0.0.0:*                           1000       20130013   41934/io.broadlink2
          udp        0      0 0.0.0.0:39052           0.0.0.0:*                           1000       19788254   38757/io.daikin-clo
          udp        0      0 0.0.0.0:39100           0.0.0.0:*                           1000       19821648   39131/io.discovery.
          udp        0      0 0.0.0.0:39336           0.0.0.0:*                           1000       19820267   39281/io.lovelace.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       19792968   38869/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       19792969   38869/io.tuya.0
          udp        0      0 0.0.0.0:39537           0.0.0.0:*                           1000       19838022   39610/io.welcome.0
          udp        0      0 0.0.0.0:39603           0.0.0.0:*                           1000       19764282   37880/io.email.0
          udp        0      0 0.0.0.0:56030           0.0.0.0:*                           1000       19823264   39432/io.rtspStream
          udp        0      0 0.0.0.0:40301           0.0.0.0:*                           1000       19793069   38921/io.shelly.0
          udp        0      0 0.0.0.0:56689           0.0.0.0:*                           1000       19827261   39557/io.rssfeed.0
          udp        0      0 0.0.0.0:40318           0.0.0.0:*                           1000       19768660   38300/io.places.0
          udp        0      0 0.0.0.0:40481           0.0.0.0:*                           1000       19772414   38822/io.samsung_ti
          udp        0      0 0.0.0.0:56992           0.0.0.0:*                           1000       19838292   39726/io.alexa-time
          udp        0      0 0.0.0.0:40614           0.0.0.0:*                           1000       19760557   38237/io.harmony.0
          udp        0      0 0.0.0.0:57004           0.0.0.0:*                           1000       19819111   39156/io.simple-api
          udp        0      0 0.0.0.0:40928           0.0.0.0:*                           1000       19834786   39796/io.vw-connect
          udp        0      0 0.0.0.0:40932           0.0.0.0:*                           1000       19830107   39592/io.slideshow.
          udp        0      0 0.0.0.0:57523           0.0.0.0:*                           1000       19768686   38318/io.samsung.0
          udp        0      0 0.0.0.0:57762           0.0.0.0:*                           1000       19837988   39575/io.webui.0
          udp        0      0 0.0.0.0:57993           0.0.0.0:*                           1000       19842152   39662/io.lightcontr
          udp        0      0 0.0.0.0:58349           0.0.0.0:*                           1000       19765518   38282/io.ping.0
          udp        0      0 0.0.0.0:41983           0.0.0.0:*                           1000       19767135   38527/io.systeminfo
          udp        0      0 0.0.0.0:41989           0.0.0.0:*                           1000       19787699   38905/io.wifilight.
          udp        0      0 0.0.0.0:58505           0.0.0.0:*                           1000       19793018   38887/io.bshb.0
          udp        0      0 0.0.0.0:58591           0.0.0.0:*                           1000       19771875   38509/io.homeconnec
          udp        0      0 0.0.0.0:58635           0.0.0.0:*                           1000       19780901   38719/io.fullybrows
          udp        0      0 0.0.0.0:58647           0.0.0.0:*                           1000       20111297   41934/io.broadlink2
          udp        0      0 0.0.0.0:42377           0.0.0.0:*                           1000       19821812   39246/io.iot.0
          udp        0      0 0.0.0.0:42407           0.0.0.0:*                           1000       20111311   41934/io.broadlink2
          udp        0      0 0.0.0.0:42668           0.0.0.0:*                           1000       19837745   39829/io.ai-toolbox
          udp        0      0 0.0.0.0:59167           0.0.0.0:*                           1000       19766550   38126/io.influxdb.0
          udp        0      0 0.0.0.0:59770           0.0.0.0:*                           1000       19761597   38185/io.alexa2.0
          udp        0      0 0.0.0.0:43618           0.0.0.0:*                           1000       20154351   41934/io.broadlink2
          udp        0      0 0.0.0.0:43973           0.0.0.0:*                           1000       19827481   39628/io.wled.0
          udp        0      0 0.0.0.0:60611           0.0.0.0:*                           1000       19798079   39033/io.zigbee.1
          udp        0      0 0.0.0.0:60685           0.0.0.0:*                           1000       19838456   39759/io.wallpanel.
          udp        0      0 0.0.0.0:60957           0.0.0.0:*                           1000       20045862   41264/io.pi-hole2.0
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       19760560   38237/io.harmony.0
          udp        0      0 0.0.0.0:45889           0.0.0.0:*                           1000       19822414   39521/io.vis-invent
          udp        0      0 0.0.0.0:46091           0.0.0.0:*                           1000       20111317   41934/io.broadlink2
          udp        0      0 0.0.0.0:46423           0.0.0.0:*                           1000       19788429   38957/io.cloud.0
          udp        0      0 0.0.0.0:46525           0.0.0.0:*                           1000       19791726   38972/io.nuki.0
          udp        0      0 0.0.0.0:46970           0.0.0.0:*                           1000       19819098   39142/io.web.0
          udp        0      0 0.0.0.0:46980           0.0.0.0:*                           1000       19792171   38939/io.webcal.0
          udp        0      0 0.0.0.0:47718           0.0.0.0:*                           1000       19772301   38774/io.spotify-pr
          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       20113129   41934/io.broadlink2
          udp        0      0 0.0.0.0:47888           0.0.0.0:*                           1000       20119194   41934/io.broadlink2
          udp        0      0 0.0.0.0:48412           0.0.0.0:*                           1000       19824152   39451/io.sourceanal
          udp        0      0 0.0.0.0:48782           0.0.0.0:*                           1000       19792229   38989/io.philips-ai
          udp        0      0 0.0.0.0:48829           0.0.0.0:*                           1000       19761473   37907/io.history.0
          udp        0      0 0.0.0.0:49254           0.0.0.0:*                           1000       19808216   39117/io.zigbee.2
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          276        1/init
          udp        0      0 0.0.0.0:49337           0.0.0.0:*                           1000       19760292   37957/io.node-red.0
          udp        0      0 0.0.0.0:49411           0.0.0.0:*                           1000       19826942   39386/io.parser.0
          udp        0      0 0.0.0.0:33109           0.0.0.0:*                           1000       19796226   39006/io.philips-ai
          udp        0      0 0.0.0.0:33327           0.0.0.0:*                           1000       19766525   38111/io.whatsapp-c
          udp        0      0 0.0.0.0:33569           0.0.0.0:*                           1000       20111329   41934/io.broadlink2
          udp        0      0 0.0.0.0:50329           0.0.0.0:*                           1000       19842782   39865/io.omada.0
          udp        0      0 0.0.0.0:50410           0.0.0.0:*                           1000       19768996   38494/io.sonoff.0
          udp        0      0 0.0.0.0:50575           0.0.0.0:*                           1000       20111323   41934/io.broadlink2
          udp        0      0 0.0.0.0:50662           0.0.0.0:*                           1000       19824417   39487/io.upnp.0
          udp        0      0 0.0.0.0:34342           0.0.0.0:*                           1000       20111332   41934/io.broadlink2
          udp        0      0 0.0.0.0:34375           0.0.0.0:*                           1000       19771810   38476/io.proxmox.0
          udp        0      0 0.0.0.0:50826           0.0.0.0:*                           1000       19764616   38337/io.samsung.1
          udp        0      0 0.0.0.0:34526           0.0.0.0:*                           1000       19761631   38218/io.geofency.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       19823610   39487/io.upnp.0
          udp        0      0 0.0.0.0:34716           0.0.0.0:*                           1000       19788350   38869/io.tuya.0
          udp        0      0 0.0.0.0:51315           0.0.0.0:*                           1000       20111300   41934/io.broadlink2
          udp        0      0 0.0.0.0:51418           0.0.0.0:*                           1000       19772245   38741/io.espresense
          udp        0      0 0.0.0.0:51485           0.0.0.0:*                           1000       19826371   39469/io.text2comma
          udp        0      0 0.0.0.0:35206           0.0.0.0:*                           1000       19761576   38164/io.backitup.0
          udp        0      0 0.0.0.0:35287           0.0.0.0:*                           1000       19768335   38005/io.scenes.0
          udp        0      0 0.0.0.0:51715           0.0.0.0:*                           1000       19792009   38854/io.mqtt.0
          udp        0      0 0.0.0.0:35436           0.0.0.0:*                           1000       19818469   39263/io.iqontrol.0
          udp        0      0 0.0.0.0:35556           0.0.0.0:*                           1000       19758929   37828/io.admin.2
          udp        0      0 0.0.0.0:35562           0.0.0.0:*                           1000       19759055   38094/io.whatsapp-c
          udp        0      0 0.0.0.0:35570           0.0.0.0:*                           1000       20111314   41934/io.broadlink2
          udp        0      0 0.0.0.0:35696           0.0.0.0:*                           1000       19754980   38079/io.telegram.1
          udp        0      0 0.0.0.0:52164           0.0.0.0:*                           1000       19766457   37925/io.javascript
          udp        0      0 0.0.0.0:35844           0.0.0.0:*                           1000       19835016   39539/io.windows-co
          udp        0      0 0.0.0.0:52353           0.0.0.0:*                           1000       19839787   39884/io.echarts.0
          udp        0      0 0.0.0.0:35974           0.0.0.0:*                           1000       19796189   38989/io.philips-ai
          udp        0      0 0.0.0.0:36231           0.0.0.0:*                           1000       19755871   37789/iobroker.js-c
          udp        0      0 0.0.0.0:52642           0.0.0.0:*                           1000       19765774   38353/io.shuttercon
          udp        0      0 0.0.0.0:36597           0.0.0.0:*                           1000       20111320   41934/io.broadlink2
          udp        0      0 0.0.0.0:36826           0.0.0.0:*                           1000       19821674   39150/io.socketio.0
          udp        0      0 0.0.0.0:53221           0.0.0.0:*                           1000       19844187   39744/io.vis-2.0
          udp        0      0 0.0.0.0:37113           0.0.0.0:*                           1000       19823927   39299/io.moma.0
          udp        0      0 0.0.0.0:37427           0.0.0.0:*                           1000       19758871   37807/io.admin.1
          udp        0      0 0.0.0.0:37491           0.0.0.0:*                           1000       19772588   38252/io.nut.0
          udp        0      0 0.0.0.0:37828           0.0.0.0:*                           1000       19824422   39487/io.upnp.0
          udp        0      0 0.0.0.0:37869           0.0.0.0:*                           1000       19844384   39777/io.smartthing
          udp        0      0 0.0.0.0:37992           0.0.0.0:*                           1000       19806304   39092/io.zigbee.4
          udp        0      0 0.0.0.0:38057           0.0.0.0:*                           1000       19832671   39646/io.philips-tv
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       20124716   41856/io.ham.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       19827476   39628/io.wled.0
          udp        0      0 192.168.178.250:5353    0.0.0.0:*                           1000       19766972   38389/io.tr-064.1
          udp        0      0 0.0.0.0:54565           0.0.0.0:*                           1000       19793145   39006/io.philips-ai
          udp        0      0 0.0.0.0:38225           0.0.0.0:*                           1000       19823639   39230/io.fullcalend
          udp        0      0 0.0.0.0:54863           0.0.0.0:*                           1000       19768778   38407/io.tr-064.2
          udp        0      0 0.0.0.0:55140           0.0.0.0:*                           1000       19915128   38389/io.tr-064.1
          udp6       0      0 :::111                  :::*                                0          9538       1/init
          2025-12-29 21:02:56.830  - debug: zigbee.4 (39092) localConfig:getOptions for a4c1389a68b09f8e : {}
          2025-12-29 21:02:56.833  - silly: zigbee.4 (39092) States user redis pmessage zigbee.4.*/zigbee.4.a4c1389a68b09f8e.link_quality:{"val":180,"ack":true,"ts":1767038576832,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767038576832}
          2025-12-29 21:02:56.833  - silly: zigbee.4 (39092) States user redis pmessage zigbee.4.*/zigbee.4.a4c1389a68b09f8e.msg_from_zigbee:{"val":"{\"type\":\"attributeReport\",\"data\":{\"activePower\":337},\"linkquality\":180,\"groupID\":0,\"cluster\":\"haElectricalMeasurement\",\"meta\":{\"rawData\":{\"type\":\"Buffer\",\"data\":[24,23,10,11,5,41,81,1]},\"zclTransactionSequenceNumber\":23,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}","ack":true,"ts":1767038576832,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767038576832}
          2025-12-29 21:02:56.834  - silly: zigbee.4 (39092) States user redis pmessage zigbee.4.*/zigbee.4.a4c1389a68b09f8e.load_power:{"val":337,"ack":true,"ts":1767038576832,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767038576832}
          2025-12-29 21:02:56.834  - silly: zigbee.4 (39092) States user redis pmessage zigbee.4.*/zigbee.4.a4c1389a68b09f8e.link_quality:{"val":180,"ack":true,"ts":1767038576832,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767038576832}
          2025-12-29 21:02:56.835  - silly: zigbee.4 (39092) States user redis pmessage zigbee.4.*/zigbee.4.a4c1389a68b09f8e.msg_from_zigbee:{"val":"{\"type\":\"attributeReport\",\"data\":{\"activePower\":337},\"linkquality\":180,\"groupID\":0,\"cluster\":\"haElectricalMeasurement\",\"meta\":{\"rawData\":{\"type\":\"Buffer\",\"data\":[24,23,10,11,5,41,81,1]},\"zclTransactionSequenceNumber\":23,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}","ack":true,"ts":1767038576832,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767038576832}
          2025-12-29 21:02:56.835  - silly: zigbee.4 (39092) States user redis pmessage zigbee.4.*/zigbee.4.a4c1389a68b09f8e.link_quality:{"val":180,"ack":true,"ts":1767038576834,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767038576832}
          2025-12-29 21:02:56.835  - silly: zigbee.4 (39092) States user redis pmessage zigbee.4.*/zigbee.4.a4c1389a68b09f8e.msg_from_zigbee:{"val":"{\"type\":\"attributeReport\",\"data\":{\"activePower\":337},\"linkquality\":180,\"groupID\":0,\"cluster\":\"haElectricalMeasurement\",\"meta\":{\"rawData\":{\"type\":\"Buffer\",\"data\":[24,23,10,11,5,41,81,1]},\"zclTransactionSequenceNumber\":23,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}","ack":true,"ts":1767038576834,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767038576832}
          2025-12-29 21:02:56.836  - silly: zigbee.4 (39092) States user redis pmessage zigbee.4.*/zigbee.4.a4c1389a68b09f8e.link_quality:{"val":180,"ack":true,"ts":1767038576834,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767038576832}
          2025-12-29 21:02:56.836  - silly: zigbee.4 (39092) States user redis pmessage zigbee.4.*/zigbee.4.a4c1389a68b09f8e.msg_from_zigbee:{"val":"{\"type\":\"attributeReport\",\"data\":{\"activePower\":337},\"linkquality\":180,\"groupID\":0,\"cluster\":\"haElectricalMeasurement\",\"meta\":{\"rawData\":{\"type\":\"Buffer\",\"data\":[24,23,10,11,5,41,81,1]},\"zclTransactionSequenceNumber\":23,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}","ack":true,"ts":1767038576834,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767038576832}
          2025-12-29 21:02:56.837  - silly: zigbee.4 (39092) States user redis pmessage zigbee.4.*/zigbee.4.a4c1389a68b09f8e.link_quality:{"val":180,"ack":true,"ts":1767038576834,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767038576832}
          2025-12-29 21:02:56.914  - silly: zigbee.4 (39092) States user redis pmessage zigbee.4.*/zigbee.4.a4c1389a68b09f8e.msg_from_zigbee:{"val":"{\"type\":\"attributeReport\",\"data\":{\"activePower\":337},\"linkquality\":180,\"groupID\":0,\"cluster\":\"haElectricalMeasurement\",\"meta\":{\"rawData\":{\"type\":\"Buffer\",\"data\":[24,23,10,11,5,41,81,1]},\"zclTransactionSequenceNumber\":23,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}","ack":true,"ts":1767038576914,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767038576832}
          iob diag has finished.
          admin@iobroker:~$
            cd
            Script v.2025-12-26
            *** BASE SYSTEM ***
              Virtualization: lxc
            OS is similar to:
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
            CPU threads: 8
                             RTC time: n/a
                      RTC in local TZ: no
            admin
            HOME=/home/admin
            iobroker
            HOME=/home/iobroker
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Swap:           1.0G          0B        1.0G
            Total:           27G        6.8G         20G
                     6455 M used memory
                        0 M inactive memory
                    18220 M free memory
                        0 M buffer memory
                      345 M swap cache
                     1000 M total swap
                        0 M used swap
                     1000 M free swap
            *** FILESYSTEM ***
            /var:
            3.2G    /var/
            1.9G    /var/lib
            USB-Devices by-id:
            ⚠ HINT:
            \'socket\'
            ⚠ HINT:
            \'tcp\'
            ⚠ HINT:
            \'tcp\'
            ⚠ HINT:
            \'tcp\'
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.9.4
            /usr/bin/npx            10.9.4
            nodejs:
              Version table:
                 20.19.2+dfsg-1 500
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.7.19
            javascript:     9.0.17
            Adapter State
            + instance is alive
            Objects and States
            Objects:        57014
            States:         44991
            admin@iobroker:~$
            @holly200289 sagte in Instabiles Zigbee-Netzwerk:
            hmmm, was macht der denn?
              @holly200289
              zigbee.1 und zigbee.2 funken auf dem gleichen Kanal. Das kann/wird zu Problemen führen.
              S Abwesend
              S Abwesend
              Shadowhunter23
              @holly200289
              Bei mir laufen 5 Instanzen und alle laufen auf dem selben Kanal. Keine Probleme. Das hilft hier zwar nicht den Fehler zu beseitigen aber ich kann nicht glauben dass das zu Problemen führt.
              Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
              ioBroker Backup Analyzer
              • S Shadowhunter23
                @holly200289
                @Shadowhunter23 sagte in Instabiles Zigbee-Netzwerk:
                Da frag aber @asgothian mal zu.
                Der sollte sich das eh mal anschauen, zigbee ist jetzt nicht meine Baustelle.
                Die
                sind aber mit Sicherheit auch nicht regulär installiert worden...
                  cd
                  Script v.2025-12-26
                  *** BASE SYSTEM ***
                    Virtualization: lxc
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                  CPU threads: 8
                                   RTC time: n/a
                            RTC in local TZ: no
                  admin
                  HOME=/home/admin
                  iobroker
                  HOME=/home/iobroker
                  Display-Manager:
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Swap:           1.0G          0B        1.0G
                  Total:           27G        6.8G         20G
                           6455 M used memory
                              0 M inactive memory
                          18220 M free memory
                              0 M buffer memory
                            345 M swap cache
                           1000 M total swap
                              0 M used swap
                           1000 M free swap
                  *** FILESYSTEM ***
                  /var:
                  3.2G    /var/
                  1.9G    /var/lib
                  USB-Devices by-id:
                  ⚠ HINT:
                  \'socket\'
                  ⚠ HINT:
                  \'tcp\'
                  ⚠ HINT:
                  \'tcp\'
                  ⚠ HINT:
                  \'tcp\'
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/npm            10.9.4
                  /usr/bin/npx            10.9.4
                  nodejs:
                    Version table:
                       20.19.2+dfsg-1 500
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  admin:          7.7.19
                  javascript:     9.0.17
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        57014
                  States:         44991
                  admin@iobroker:~$
                  Was liefert
                  cd /opt/iobroker/
                  npm ls zigbee-herdsman-converters
                    Die
                    S Abwesend
                    S Abwesend
                    Shadowhunter23
                    Never tatscht ä running system ;) Der Profi muss helfen ist am besten.
                    • AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      zigbee auf dem gleichen Kanal sollte kein Problem machen. Zigbee adapter im 'silly' laufen lassen schon - der logged dann richtig viel. Setz die mal bitte alle zurück auf 'info'.
                      Was noch fehlt sind Fehlermeldungen wenn die Netze instabil werden.
                      Thema JS Controller 7.1 und Zigbee 3.3.0 - weiter oben im Thread steht etwas von Sync Probemen zwischen nvram Backup und shepherd.db. In der Kombination die ich erwähnt habe ist das gelöst.
                      Fragezeichen bei Zigbee 3.3.0 sollten eigentlich nicht kommen, da da neuere Konverter eingesetzt werden - es sei denn du hast sonderkonfigurationen.
                      A.
                      A.
                      • AsgothianA Asgothian
                        A.
                        A.
                        @Asgothian sagte in Instabiles Zigbee-Netzwerk:
                        worauf
                        Möglicherweise hindeutet
                          holly200289
                          Ich würde Morgen neue Post hinzufügen, da ich jetzt Nachtschicht habe,
                          ich sage schonmal herzlichen dank, und bis Morgen.
                            holly200289
                            Guten Morgen,
                            und weiter geht es, in der Zwischenzeit sind auch die Instanzen wieder abgestürzt, als erstes lass ich euch den Fehler log von dem Adapter zukommen und als zweites ( cd /opt/iobroker/
                            npm ls zigbee-herdsman-converters ) was hier drin steht.
                              holly200289
                              zigbee.4
                              Zeit
                              debug
                              Nachricht
                              zigbee.4
                              2025-12-30 08:30:59.663	error	Failed to start Zigbee: no message given
                              zigbee.4
                              2025-12-30 08:30:59.663	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
                              zigbee.4
                              2025-12-30 08:30:59.663	warn	unable to stop zigbee-herdsman after failed startup
                              zigbee.4
                              2025-12-30 08:30:59.660	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:59.660	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:59.511	error	Failed to start Zigbee: no message given
                              zigbee.4
                              2025-12-30 08:30:59.511	error	Starting zigbee-herdsman problem : Error while opening socket
                              zigbee.4
                              2025-12-30 08:30:59.511	warn	unable to stop zigbee-herdsman after failed startup
                              zigbee.4
                              2025-12-30 08:30:59.509	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:59.509	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:59.509	error	Failed to start Zigbee: no message given
                              zigbee.4
                              2025-12-30 08:30:59.509	error	Starting zigbee-herdsman problem : Error while opening socket
                              zigbee.4
                              2025-12-30 08:30:59.509	warn	unable to stop zigbee-herdsman after failed startup
                              zigbee.4
                              2025-12-30 08:30:59.507	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:59.507	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:59.507	error	Failed to start Zigbee: no message given
                              zigbee.4
                              2025-12-30 08:30:59.507	error	Starting zigbee-herdsman problem : Error while opening socket
                              zigbee.4
                              2025-12-30 08:30:59.507	warn	unable to stop zigbee-herdsman after failed startup
                              zigbee.4
                              2025-12-30 08:30:59.504	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:59.504	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:59.186	info	Starting Zigbee-Herdsman
                              zigbee.4
                              2025-12-30 08:30:59.186	info	configured transmit power :
                              zigbee.4
                              2025-12-30 08:30:59.186	info	Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.4.2)
                              zigbee.4
                              2025-12-30 08:30:59.185	info	Starting Adapter npm ...
                              zigbee.4
                              2025-12-30 08:30:59.185	info	Try to reconnect.
                              zigbee.4
                              2025-12-30 08:30:59.184	debug	connected successfully to connect to 192.168.178.240 port 6080
                              zigbee.4
                              2025-12-30 08:30:58.322	error	Failed to start Zigbee: no message given
                              zigbee.4
                              2025-12-30 08:30:58.322	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
                              zigbee.4
                              2025-12-30 08:30:58.321	warn	unable to stop zigbee-herdsman after failed startup
                              zigbee.4
                              2025-12-30 08:30:58.320	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:58.320	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:58.319	error	Failed to start Zigbee: no message given
                              zigbee.4
                              2025-12-30 08:30:58.319	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
                              zigbee.4
                              2025-12-30 08:30:58.319	warn	unable to stop zigbee-herdsman after failed startup
                              zigbee.4
                              2025-12-30 08:30:58.317	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:58.317	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:58.317	error	Failed to start Zigbee: no message given
                              zigbee.4
                              2025-12-30 08:30:58.317	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
                              zigbee.4
                              2025-12-30 08:30:58.317	warn	unable to stop zigbee-herdsman after failed startup
                              zigbee.4
                              2025-12-30 08:30:58.315	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:58.314	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:57.220	debug	attempting to connect to 192.168.178.240 port 6080
                              zigbee.4
                              2025-12-30 08:30:57.220	debug	dns lookup for tcp://192.168.178.240:6080 produced 192.168.178.240
                              zigbee.4
                              2025-12-30 08:30:57.220	debug	attempting dns lookup for 192.168.178.240
                              zigbee.4
                              2025-12-30 08:30:57.220	debug	Test connection for tcp://192.168.178.240:6080
                              zigbee.4
                              zigbee.4
                              zigbee.4
                              zigbee.4
                              2025-12-30 08:30:57.219	debug	Test connection for tcp://192.168.178.240:6080
                              zigbee.4
                              2025-12-30 08:30:57.206	info	Starting Zigbee-Herdsman
                              zigbee.4
                              2025-12-30 08:30:57.206	info	configured transmit power :
                              zigbee.4
                              2025-12-30 08:30:57.206	info	Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.4.2)
                              zigbee.4
                              2025-12-30 08:30:57.204	info	Starting Zigbee-Herdsman
                              zigbee.4
                              2025-12-30 08:30:57.204	info	configured transmit power :
                              zigbee.4
                              2025-12-30 08:30:57.204	info	Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.4.2)
                              zigbee.4
                              2025-12-30 08:30:57.203	info	Starting Adapter npm ...
                              zigbee.4
                              2025-12-30 08:30:57.203	info	Try to reconnect.
                              zigbee.4
                              2025-12-30 08:30:57.202	debug	connected successfully to connect to 192.168.178.240 port 6080
                              zigbee.4
                              2025-12-30 08:30:57.201	info	Starting Adapter npm ...
                              zigbee.4
                              2025-12-30 08:30:57.201	info	Try to reconnect.
                              zigbee.4
                              2025-12-30 08:30:57.200	debug	connected successfully to connect to 192.168.178.240 port 6080
                              zigbee.4
                              2025-12-30 08:30:56.779	error	Failed to start Zigbee: no message given
                              zigbee.4
                              2025-12-30 08:30:56.779	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
                              zigbee.4
                              2025-12-30 08:30:56.779	warn	unable to stop zigbee-herdsman after failed startup
                              zigbee.4
                              2025-12-30 08:30:56.776	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:56.776	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:56.655	error	Failed to start Zigbee: no message given
                              zigbee.4
                              2025-12-30 08:30:56.655	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
                              zigbee.4
                              2025-12-30 08:30:56.655	warn	unable to stop zigbee-herdsman after failed startup
                              zigbee.4
                              2025-12-30 08:30:56.652	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:56.652	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:56.096	debug	attempting to connect to 192.168.178.240 port 6080
                              zigbee.4
                              2025-12-30 08:30:56.096	debug	dns lookup for tcp://192.168.178.240:6080 produced 192.168.178.240
                              zigbee.4
                              2025-12-30 08:30:56.096	debug	attempting dns lookup for 192.168.178.240
                              zigbee.4
                              2025-12-30 08:30:56.095	debug	Test connection for tcp://192.168.178.240:6080
                              zigbee.4
                              2025-12-30 08:30:55.922	info	Starting Zigbee-Herdsman
                              zigbee.4
                              2025-12-30 08:30:55.922	info	configured transmit power :
                              zigbee.4
                              2025-12-30 08:30:55.922	info	Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.4.2)
                              zigbee.4
                              2025-12-30 08:30:55.921	info	Starting Adapter npm ...
                              zigbee.4
                              2025-12-30 08:30:55.921	info	Try to reconnect.
                              zigbee.4
                              2025-12-30 08:30:55.920	debug	connected successfully to connect to 192.168.178.240 port 6080
                              zigbee.4
                              2025-12-30 08:30:55.248	error	Failed to start Zigbee: no message given
                              zigbee.4
                              2025-12-30 08:30:55.248	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
                              zigbee.4
                              2025-12-30 08:30:55.248	warn	unable to stop zigbee-herdsman after failed startup
                              zigbee.4
                              2025-12-30 08:30:55.246	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:55.246	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:55.246	error	Failed to start Zigbee: no message given
                              zigbee.4
                              2025-12-30 08:30:55.246	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
                              zigbee.4
                              2025-12-30 08:30:55.246	warn	unable to stop zigbee-herdsman after failed startup
                              zigbee.4
                              2025-12-30 08:30:55.244	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:55.244	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:55.244	error	Failed to start Zigbee: no message given
                              zigbee.4
                              2025-12-30 08:30:55.244	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
                              zigbee.4
                              2025-12-30 08:30:55.244	warn	unable to stop zigbee-herdsman after failed startup
                              zigbee.4
                              2025-12-30 08:30:55.241	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:55.241	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:54.200	info	Starting Zigbee-Herdsman
                              zigbee.4
                              2025-12-30 08:30:54.200	info	configured transmit power :
                              zigbee.4
                              2025-12-30 08:30:54.200	info	Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.4.2)
                              zigbee.4
                              2025-12-30 08:30:54.198	info	Starting Zigbee-Herdsman
                              zigbee.4
                              2025-12-30 08:30:54.197	info	configured transmit power :
                              zigbee.4
                              2025-12-30 08:30:54.197	info	Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.4.2)
                              zigbee.4
                              2025-12-30 08:30:54.196	info	Starting Zigbee-Herdsman
                              zigbee.4
                              2025-12-30 08:30:54.196	info	configured transmit power :
                              zigbee.4
                              2025-12-30 08:30:54.195	info	Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.4.2)
                              zigbee.4
                              2025-12-30 08:30:54.194	info	Starting Adapter npm ...
                              zigbee.4
                              2025-12-30 08:30:54.194	info	Try to reconnect.
                              zigbee.4
                              2025-12-30 08:30:54.194	debug	connected successfully to connect to 192.168.178.240 port 6080
                              zigbee.4
                              zigbee.4
                              zigbee.4
                              2025-12-30 08:30:54.193	debug	connected successfully to connect to 192.168.178.240 port 6080
                              zigbee.4
                              2025-12-30 08:30:54.193	info	Starting Adapter npm ...
                              zigbee.4
                              2025-12-30 08:30:54.193	info	Try to reconnect.
                              zigbee.4
                              2025-12-30 08:30:54.192	debug	connected successfully to connect to 192.168.178.240 port 6080
                              zigbee.4
                              2025-12-30 08:30:53.708	error	Failed to start Zigbee: no message given
                              zigbee.4
                              2025-12-30 08:30:53.708	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
                              zigbee.4
                              2025-12-30 08:30:53.708	warn	unable to stop zigbee-herdsman after failed startup
                              zigbee.4
                              2025-12-30 08:30:53.706	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:53.706	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
                              zigbee.4
                              2025-12-30 08:30:53.150	debug	attempting to connect to 192.168.178.240 port 6080
                              zigbee.4
                              2025-12-30 08:30:53.150	debug	dns lookup for tcp://192.168.178.240:6080 produced 192.168.178.240
                              zigbee.4
                              2025-12-30 08:30:53.150	debug	attempting dns lookup for 192.168.178.240
                              zigbee.4
                              2025-12-30 08:30:53.150	debug	Test connection for tcp://192.168.178.240:6080
                              zigbee.4
                              2025-12-30 08:30:53.149	debug	attempting to connect to 192.168.178.240 port 6080
                              zigbee.4
                              2025-12-30 08:30:53.149	debug	dns lookup for tcp://192.168.178.240:6080 produced 192.168.178.240
                              zigbee.4
                              2025-12-30 08:30:53.149	debug	attempting dns lookup for 192.168.178.240
                              zigbee.4
                              2025-12-30 08:30:53.149	debug	Test connection for tcp://192.168.178.240:6080
                              zigbee.4
                              2025-12-30 08:30:53.122	debug	attempting to connect to 192.168.178.240 port 6080
                              zigbee.4
                              2025-12-30 08:30:53.122	debug	dns lookup for tcp://192.168.178.240:6080 produced 192.168.178.240
                              zigbee.4
                              2025-12-30 08:30:53.122	debug	attempting dns lookup for 192.168.178.240
                              zigbee.4
                              2025-12-30 08:30:53.121	debug	Test connection for tcp://192.168.178.240:6080
                              zigbee.4
                              2025-12-30 08:30:53.121	debug	attempting to connect to 192.168.178.240 port 6080
                              zigbee.4
                              2025-12-30 08:30:53.121	debug	dns lookup for tcp://192.168.178.240:6080 produced 192.168.178.240
                              zigbee.4
                              2025-12-30 08:30:53.121	debug	attempting dns lookup for 192.168.178.240
                                holly200289
                                Das geht jetzt immer in der Schleife, der Adapter meldet sich jetzt nicht mehr an .
                                  holly200289
                                  Die Adapter sind jetzt auch wieder auf Info gestellt
                                    Was liefert
                                    cd /opt/iobroker/
                                    holly200289
                                    #66
                                    cd /opt/iobroker/
                                    Das kommt wenn ich den Befehl eingebe ........
                                    Last login: Mon Dec 29 21:01:27 2025 from 192.168.178.175
                                    admin@iobroker:~$ cd /opt/iobroker/
                                    iobroker.inst@3.0.0 /opt/iobroker
                                    +-- iobroker.zigbee@3.1.5
                                    | `-- zigbee-herdsman-converters@25.31.0
                                    admin@iobroker:/opt/iobroker$
                                      cd /opt/iobroker/
                                      #67
                                      @holly200289
                                      Bitte in CodeTags eingebettet posten. Und bitte NICHT aus dem Admin in falscher Chronologie mit zig Leerzeilen. Nimm das Log aus
                                      iob logs
                                      Kannst du mir mal sagen, wo du die ganzen GitHub-Klamotten herziehst? Und warum?
                                      Setz die ganzen Dinger auf reguläre Veröffentlichungen und deinstallier alles, was in der obersten Ebene des npm-Trees nicht mit iobroker. anfängt.
                                      Beispiel von meinem System:
                                      echad@chet:/opt/iobroker $ npm ls
                                      ├── iobroker.admin@7.7.22
                                      ├── iobroker.alexa2@3.27.4
                                      ├── iobroker.alias-manager@2.0.0
                                      ├── iobroker.ankersolix2@2.4.1
                                      ├── iobroker.awtrix-light@3.0.0
                                      ├── iobroker.backitup@3.3.13
                                      ├── iobroker.ble@0.14.1
                                      ├── iobroker.cloud@5.1.2
                                      ├── iobroker.devices@1.2.9
                                      ├── iobroker.echarts@2.0.10 (git+ssh://git@github.com/Grothesk242/ioBroker.echarts.git#7e00a1c9e78e378443ceac4396eeba04f7b7e73f)
                                      ├── iobroker.firetv@2.1.0
                                      ├── iobroker.followthesun@0.5.2
                                      ├── iobroker.govee-app@0.0.10 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#d5e7f1703b520238db36cd1552c54cdfa89c6715)
                                      ├── iobroker.govee-local@0.4.5
                                      ├── iobroker.history@3.0.1
                                      ├── iobroker.ical@1.18.1
                                      ├── iobroker.iceroad@1.2.1
                                      ├── iobroker.iot@5.0.12
                                      ├── iobroker.javascript@9.0.17
                                      ├── iobroker.js-controller@7.1.0
                                      ├── iobroker.mihome-cloud@0.2.2
                                      ├── iobroker.mihome-vacuum@5.3.0
                                      ├── iobroker.mihome@1.4.0
                                      ├── iobroker.mqtt@6.1.4
                                      ├── iobroker.nina@0.0.26
                                      ├── iobroker.notification-manager@1.3.0
                                      ├── iobroker.nuki-extended@2.7.0
                                      ├── iobroker.nut@1.7.0
                                      ├── iobroker.opendtu@3.1.0
                                      ├── iobroker.openweathermap@1.4.0
                                      ├── iobroker.parcel@0.2.10 (git+ssh://git@github.com/Grothesk242/ioBroker.parcel.git#8ab31b96827d3612b4a9dc8dd59ad8858456ce82)
                                      ├── iobroker.playstation@0.0.3
                                      ├── iobroker.rpi2@3.0.2
                                      ├── iobroker.sainlogic@1.1.1
                                      ├── iobroker.samsung_tizen@1.1.0
                                      ├── iobroker.samsung@0.6.1
                                      ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#7a05fa59dfc5e3ce8d73018badc4e420996452f8)
                                      ├── iobroker.tado@0.8.3
                                      ├── iobroker.tr-064@4.3.0
                                      ├── iobroker.tradfri@3.1.3
                                      ├── iobroker.trashschedule@5.2.0
                                      ├── iobroker.tuya@3.17.0
                                      ├── iobroker.weather-warnings@0.10.0
                                      ├── iobroker.web@7.0.9
                                      ├── iobroker.whatsapp-cmb@0.3.0
                                      └── iobroker.zigbee@3.3.0
                                      So sieht ein halbwegs rundes System aus. Die vier GitHub-Installationen erklären sich: 2 sind von mir für nodejs>22 gepatchte Versionen aus meinem eigenen Repo und govee-app undd switchbot-hub sind nie in einem Repo gelandet.
                                        holly200289
                                        #68
                                        Lösche ich die Instanzen ? oder gibt es dafür einen Befehl über SSH ?
                                          #69
                                          @holly200289
                                          Setz zuerst mal alle Adapter wieder auf Repos auf.
                                          Am Beispiel von nuki-extended.
                                          iob upgrade nuki-extended@2.7.0
                                          Wenn das alles bereingt ist schaust du nach dem dann noch vorhandenen Rest.
