  4. Instabiles Zigbee-Netzwerk
    6.4k
100 Beiträge 11 Kommentatoren 6.6k Aufrufe 13 Beobachtet
  • holly200289H holly200289
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-17-pve
        Architecture: x86-64
    OS is similar to:
    model name      : AMD Ryzen 7 5700G with Radeon Graphics
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     20:09:37 up  7:22,  1 user,  load average: 0.80, 0.87, 0.75
    CPU threads: 8
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-12-29 20:09:37 CET
               Universal time: Mon 2025-12-29 19:09:37 UTC
                     RTC time: n/a
    System clock synchronized: no
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    admin
    HOME=/home/admin
    GROUPS=admin adm dialout sudo audio video plugdev users iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/admin
    GROUPS=iobroker tty dialout audio video plugdev bluetooth docker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             26G        7.0G         18G         22M        310M         19G
    Swap:           1.0G          0B        1.0G
    Total:           27G        7.0G         20G
    Active iob-Instances:   85
            25000 M total memory
             6644 M used memory
             6637 M active memory
                0 M inactive memory
            18079 M free memory
                0 M buffer memory
              296 M swap cache
             1000 M total swap
                0 M used swap
             1000 M free swap
    top - 20:09:37 up  7:22,  1 user,  load average: 0.80, 0.87, 0.75
    Tasks: 121 total,   4 running, 117 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 14.5 us,  4.8 sy,  0.0 ni, 79.5 id,  0.0 wa,  0.0 hi,  1.2 si,  0.0 st
    MiB Mem :  25000.0 total,  18073.1 free,   6651.6 used,    296.7 buff/cache
    MiB Swap:   1000.0 total,   1000.0 free,      0.0 used.  18348.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    1 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    Filesystem              Type   Size  Used Avail Use% Mounted on
    daten/subvol-100-disk-0 zfs    230G   19G  212G   9% /
    none                    tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                   tmpfs   16G     0   16G   0% /dev/shm
    tmpfs                   tmpfs  6.2G  176K  6.2G   1% /run
    tmpfs                   tmpfs  5.0M     0  5.0M   0% /run/lock
    tmpfs                   tmpfs   16G   22M   16G   1% /tmp
    tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-networkd.service
    tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/container-getty@1.service
    tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/container-getty@2.service
    tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/console-getty.service
    tmpfs                   tmpfs  3.1G  8.0K  3.1G   1% /run/user/1001
    [Mon Dec 29 12:46:49 2025] EXT4-fs (dm-1): mounted filesystem 8454bac7-7b31-4e6e-a8ae-07a4b96134b1 ro with ordered data mode. Quota mode: none.
    [Mon Dec 29 12:46:49 2025] EXT4-fs (dm-1): re-mounted 8454bac7-7b31-4e6e-a8ae-07a4b96134b1 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE                  FSTYPE OPTIONS
    /      daten/subvol-100-disk-0 zfs    rw,relatime,xattr,posixacl,casesensitive
    /var:
    3.2G    /var/
    1.9G    /var/lib
    1.8G    /var/lib/containerd
    1.2G    /var/log/journal/9626128f51d4471993ebdff830afe042
    Archived and active journals take up 1.1G in the file system.
    /opt/iobroker/backups:
    7.7G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.6G    /opt/iobroker/iobroker-data/
    746M    /opt/iobroker/iobroker-data/files
    512M    /opt/iobroker/iobroker-data/history
    267M    /opt/iobroker/iobroker-data/backup-objects
    82M     /opt/iobroker/iobroker-data/files/vis
    18M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    17M     /opt/iobroker/iobroker-data/history/20241203/history.pi-hole.0.overTimeData10mins.domains_over_time.data-table.json
    17M     /opt/iobroker/iobroker-data/history/20241203/history.pi-hole.0.overTimeData10mins.ads_over_time.data-table.json
    17M     /opt/iobroker/iobroker-data/history/20241202/history.pi-hole.0.overTimeData10mins.domains_over_time.data-table.json
    17M     /opt/iobroker/iobroker-data/history/20241202/history.pi-hole.0.overTimeData10mins.ads_over_time.data-table.json
    USB-Devices by-id:
    No Devices found 'by-id'
    *** ZigBee Settings ***
    HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
    socket
    HINT:
    Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    HINT:
    Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            11.7.0
    /usr/bin/npx            11.7.0
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 600
         22.20.0-1nodesource1 600
         22.19.0-1nodesource1 600
         22.18.0-1nodesource1 600
         22.17.1-1nodesource1 600
         22.17.0-1nodesource1 600
         22.16.0-1nodesource1 600
         22.15.1-1nodesource1 600
         22.15.0-1nodesource1 600
         22.14.0-1nodesource1 600
         22.13.1-1nodesource1 600
         22.13.0-1nodesource1 600
         22.12.0-1nodesource1 600
         22.11.0-1nodesource1 600
         22.10.0-1nodesource1 600
         22.9.0-1nodesource1 600
         22.8.0-1nodesource1 600
         22.7.0-1nodesource1 600
         22.6.0-1nodesource1 600
         22.5.1-1nodesource1 600
         22.5.0-1nodesource1 600
         22.4.1-1nodesource1 600
         22.4.0-1nodesource1 600
         22.3.0-1nodesource1 600
         22.2.0-1nodesource1 600
         22.1.0-1nodesource1 600
         22.0.0-1nodesource1 600
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 4551)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.17
    nodejs modules from github:     18
    +-- @iobroker/plugin-sentry@2.0.4 (git+ssh://git@github.com/ioBroker/plugin-sentry.git#31c593552c25cd0f10e2946589fbc88ad30cc480)
    +-- iobroker.chromecast@4.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.chromecast.git#82249496c21d5d02f073f1db0552eea0901d7f9e)
    +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
    +-- iobroker.mihome@1.4.0 (git+ssh://git@github.com/ioBroker/ioBroker.mihome.git#a1adfe45118047df0896faa952d2d9816a34539d)
    +-- iobroker.nuki-extended@2.7.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#abb720a7a3234d6328d68b1523938c3eace26419)
    +-- iobroker.omada@0.0.7 (git+ssh://git@github.com/TA2k/ioBroker.omada.git#0f6a083c8bf8306ffcb248ad6aa80c495cec438e)
    +-- iobroker.pi-hole2@1.1.1 (git+ssh://git@github.com/oweitman/ioBroker.pi-hole2.git#2e3723101f29c6deaa9811ccd62d84cea5438c90)
    +-- iobroker.roborock@0.6.19 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#4d519d4e5494569fc898affe0d2946722a646efd)
    +-- iobroker.rtspStream@0.0.2 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspStream.git#3891a8545b5566946b89b6f4dbfeac1e2a6527a5)
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
    +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
    +-- iobroker.weblogin@0.1.1 (git+ssh://git@github.com/Vertumnus/ioBroker.weblogin.git#62ad7e95c8b9af53e668a1741d4818e3502892e7)
    +-- JQuery-Snowfall@1.7.1 (git+ssh://git@github.com/loktar00/JQuery-Snowfall.git#d22ba78f76804e21404bc000142c019d6c10973d)
    +-- magic-snowflakes@7.0.1 (git+ssh://git@github.com/hcodes/snowflakes.git#718a2b06c3d590ea89081700d96cfa014074dd4a)
    `-- zigbee-herdsman-converters@25.96.0 (git+ssh://git@github.com/Koenkk/zigbee-herdsman-converters.git#e9132fc65cc0bcbef60a5793976ba192fcc845ac)
    Adapter State
    + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.admin.2                  : admin                 : iobroker                                 -  enabled, port: 8089, bind: 127.0.0.1, run as: admin
    + system.adapter.ai-assistant.0           : ai-assistant          : iobroker                                 -  enabled
    + system.adapter.ai-toolbox.0             : ai-toolbox            : iobroker                                 -  enabled
    + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobroker                                 -  enabled
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
    + system.adapter.bshb.0                   : bshb                  : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
    + system.adapter.espresense.0             : espresense            : iobroker                                 -  enabled
      system.adapter.flexcharts.0             : flexcharts            : iobroker                                 -  enabled
    + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
    + system.adapter.geofency.0               : geofency              : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
      system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
    + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
    + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
      system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: iobroker                                 -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
      system.adapter.icons-freepic.0          : icons-freepic         : iobroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
      system.adapter.icons-smarthome.0        : icons-smarthome       : iobroker                                 -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.lightcontrol.0           : lightcontrol          : iobroker                                 -  enabled
    + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
      system.adapter.material.0               : material              : iobroker                                 - disabled
      system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 0.0.0.0
      system.adapter.minuvis.0                : minuvis               : iobroker                                 - disabled
    + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
    + system.adapter.omada.0                  : omada                 : iobroker                                 -  enabled, port: 8043
      system.adapter.openweathermap.1         : openweathermap        : iobroker                                 -  enabled
    + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
    + system.adapter.philips-air.0            : philips-air           : iobroker                                 -  enabled
    + system.adapter.philips-air.1            : philips-air           : iobroker                                 -  enabled
    + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
    + system.adapter.pi-hole2.0               : pi-hole2              : iobroker                                 -  enabled, port: 80
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.places.0                 : places                : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
    + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
    + system.adapter.rtspStream.0             : rtspStream            : iobroker                                 -  enabled, port: 8083
    + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
    + system.adapter.samsung.1                : samsung               : iobroker                                 -  enabled
    + system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.slideshow.0              : slideshow             : iobroker                                 -  enabled
    + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.250
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 -  enabled
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5001
    + system.adapter.systeminfo.0             : systeminfo            : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
    + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.tr-064.2                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
      system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
      system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.wallpanel.0              : wallpanel             : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
    + system.adapter.webcal.0                 : webcal                : iobroker                                 -  enabled
      system.adapter.weblogin.0               : weblogin              : iobroker                                 - disabled
    + system.adapter.webui.0                  : webui                 : iobroker                                 -  enabled
    + system.adapter.welcome.0                : welcome               : iobroker                                 -  enabled, port: 8080, bind: 192.168.178.250 (SSL), run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
    + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 -  enabled
    + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
    + system.adapter.windows-control.0        : windows-control       : iobroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
      system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
    + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: socket://192.168.178.187:1020
    + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.38:2030
    + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.230:4060
    + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.240:6080
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: patch
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alexa-timer-vis": 2.1.2  , installed 2.1.2
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.10   , installed 3.3.13
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "bshb"         : 0.5.0    , installed 0.5.0
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
    Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
    Adapter    "devices"      : 1.2.8    , installed 1.2.8
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "espresense"   : 0.6.3    , installed 0.6.3
    Adapter    "firetv"       : 2.1.0    , installed 2.1.0
    Adapter    "flexcharts"   : 0.6.1    , installed 0.6.1
    Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "geofency"     : 1.2.4    , installed 1.2.4
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 9.0.11   , installed 9.0.17
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "kisshome-defender": 1.1.13, installed 1.1.13
    Adapter    "lightcontrol" : 1.0.1    , installed 1.0.1
    Adapter    "lovelace"     : 5.0.1    , installed 5.0.3
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "matter"       : 0.5.5    , installed 0.5.6
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-cloud" : 0.1.0    , installed 0.2.2
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.3.0
    Adapter    "minuvis"      : 2.3.3    , installed 2.3.3
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "node-red"     : 5.2.1    , installed 6.0.7
    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "parser"       : 2.2.4    , installed 2.2.4
    Adapter    "philips-air"  : 1.2.0    , installed 1.2.0
    Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
    Adapter    "pi-hole2"     : 1.1.1    , installed 1.1.1
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "places"       : 1.3.0    , installed 1.3.0
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.2
    Adapter    "ring"         : 6.4.0    , installed 6.4.0
    Adapter    "roborock"     : 0.6.18   , installed 0.6.19
    Adapter    "rssfeed"      : 3.6.1    , installed 3.1.0  [Updatable]
    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
    Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
    Adapter    "shuttercontrol": 2.0.7   , installed 2.0.9
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tinymqttbroker": 0.1.4   , installed 0.1.4
    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.3
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
    Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
    Adapter    "weather-warnings": 0.10.0, installed 0.10.0
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.9
    Adapter    "webcal"       : 1.4.0    , installed 1.4.0
    Adapter    "webui"        : 1.37.0   , installed 1.38.7
    Adapter    "welcome"      : 1.0.2    , installed 1.0.2
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
    Adapter    "wireguard"    : 1.7.0    , installed 1.8.0
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "yahka"        : 1.1.5    , installed 1.1.5
    Adapter    "youtube"      : 6.1.0    , installed 6.0.0  [Updatable]
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
    Objects and States
    Objects:        57073
    States:         45056
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://security.debian.org trixie-security InRelease
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Hit:3 https://download.docker.com/linux/debian trixie InRelease
    Hit:4 http://deb.debian.org/debian trixie-updates InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.250:1886    0.0.0.0:*               LISTEN      1000       18794121   29856/io.sonoff.0
    tcp        0      0 192.168.178.250:8080    0.0.0.0:*               LISTEN      1000       18841162   31583/io.welcome.0
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       18779713   28700/iobroker.js-c
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       18782519   28700/iobroker.js-c
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          20374      318/master
    tcp        0      0 192.168.178.250:9092    0.0.0.0:*               LISTEN      1000       18816745   30574/io.nuki.0
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       18782757   29075/node-red
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       18820174   30469/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       18817073   30355/io.mqtt.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          6551       1/init
    tcp        0      0 127.0.0.1:8089          0.0.0.0:*               LISTEN      1000       18788498   28857/io.admin.2
    tcp6       0      0 :::61991                :::*                    LISTEN      1000       18785122   29463/io.harmony.0
    tcp6       0      0 :::7999                 :::*                    LISTEN      1000       18782902   29418/io.geofency.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       18786037   28828/io.admin.1
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       18822250   30594/io.web.0
    tcp6       0      0 :::8083                 :::*                    LISTEN      1000       18834212   31204/io.rtspStream
    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       18832606   30936/io.socketio.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       18833714   30950/io.simple-api
    tcp6       0      0 :::8091                 :::*                    LISTEN      1000       18820880   31185/io.lovelace.0
    tcp6       0      0 :::6824                 :::*                    LISTEN      1000       19516639   35364/io.roborock.0
    tcp6       0      0 :::1890                 :::*                    LISTEN      1000       18812108   30199/io.espresense
    tcp6       0      0 :::111                  :::*                    LISTEN      0          6552       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13790      1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          20375      318/master
    udp        0      0 0.0.0.0:38794           0.0.0.0:*                           1000       18841022   31465/io.windows-co
    udp        0      0 0.0.0.0:55189           0.0.0.0:*                           1000       18806896   29628/io.samsung.1
    udp        0      0 0.0.0.0:55417           0.0.0.0:*                           1000       18788974   29418/io.geofency.0
    udp        0      0 0.0.0.0:55497           0.0.0.0:*                           1000       18820371   30688/io.zigbee.4
    udp        0      0 0.0.0.0:55548           0.0.0.0:*                           1000       18792908   29729/io.tr-064.2
    udp        0      0 0.0.0.0:55638           0.0.0.0:*                           1000       19076204   33024/io.pi-hole2.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       18812081   30154/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       18812082   30154/io.tuya.0
    udp        0      0 0.0.0.0:56054           0.0.0.0:*                           1000       18812133   30243/io.daikin-clo
    udp        0      0 0.0.0.0:39750           0.0.0.0:*                           1000       18845461   31859/io.ai-assista
    udp        0      0 0.0.0.0:39819           0.0.0.0:*                           1000       18835778   31176/io.parser.0
    udp        0      0 0.0.0.0:40106           0.0.0.0:*                           1000       18834094   31150/io.iqontrol.0
    udp        0      0 0.0.0.0:56834           0.0.0.0:*                           1000       19042741   32896/io.bshb.0
    udp        0      0 0.0.0.0:56854           0.0.0.0:*                           1000       18843672   31398/io.upnp.0
    udp        0      0 0.0.0.0:40504           0.0.0.0:*                           1000       18819559   30719/io.zigbee.2
    udp        0      0 0.0.0.0:40540           0.0.0.0:*                           1000       18820510   30740/io.discovery.
    udp        0      0 0.0.0.0:57140           0.0.0.0:*                           1000       18788596   28963/io.history.0
    udp        0      0 0.0.0.0:40824           0.0.0.0:*                           1000       18847479   31800/io.broadlink2
    udp        0      0 0.0.0.0:40905           0.0.0.0:*                           1000       18816985   30672/io.zigbee.3
    udp        0      0 0.0.0.0:41324           0.0.0.0:*                           1000       18817115   30410/io.philips-ai
    udp        0      0 0.0.0.0:57776           0.0.0.0:*                           1000       18820637   30936/io.socketio.0
    udp        0      0 0.0.0.0:57784           0.0.0.0:*                           1000       18788526   28912/io.email.0
    udp        0      0 0.0.0.0:57788           0.0.0.0:*                           1000       18797465   30165/io.fullybrows
    udp        0      0 0.0.0.0:41432           0.0.0.0:*                           1000       18789755   29528/io.ping.0
    udp        0      0 0.0.0.0:57900           0.0.0.0:*                           1000       18846128   31619/io.wled.0
    udp        0      0 0.0.0.0:57964           0.0.0.0:*                           1000       18839298   31439/io.vis-invent
    udp        0      0 0.0.0.0:41999           0.0.0.0:*                           1000       18782841   29212/io.influxdb.0
    udp        0      0 0.0.0.0:58465           0.0.0.0:*                           1000       18816064   30333/io.samsung_ti
    udp        0      0 0.0.0.0:58516           0.0.0.0:*                           1000       18792452   29160/io.whatsapp-c
    udp        0      0 0.0.0.0:58683           0.0.0.0:*                           1000       18812665   30574/io.nuki.0
    udp        0      0 0.0.0.0:42351           0.0.0.0:*                           1000       18810455   29813/io.spotify-pr
    udp        0      0 0.0.0.0:58821           0.0.0.0:*                           1000       18786436   28850/io.telegram.1
    udp        0      0 0.0.0.0:59444           0.0.0.0:*                           1000       18807672   30381/io.philips-ai
    udp        0      0 0.0.0.0:43090           0.0.0.0:*                           1000       18847482   31800/io.broadlink2
    udp        0      0 0.0.0.0:43093           0.0.0.0:*                           1000       18783210   29824/io.proxmox.0
    udp        0      0 0.0.0.0:59587           0.0.0.0:*                           1000       18835642   31066/io.fullcalend
    udp        0      0 0.0.0.0:43364           0.0.0.0:*                           1000       19037934   32939/io.iot.0
    udp        0      0 0.0.0.0:43399           0.0.0.0:*                           1000       18816118   30381/io.philips-ai
    udp        0      0 0.0.0.0:60309           0.0.0.0:*                           1000       18790676   29291/io.backitup.0
    udp        0      0 0.0.0.0:60438           0.0.0.0:*                           1000       18842970   31539/io.webui.0
    udp        0      0 0.0.0.0:60575           0.0.0.0:*                           1000       18839498   31568/io.slideshow.
    udp        0      0 0.0.0.0:60727           0.0.0.0:*                           1000       18843074   31583/io.welcome.0
    udp        0      0 0.0.0.0:44561           0.0.0.0:*                           1000       18837936   31274/io.sourceanal
    udp        0      0 0.0.0.0:44723           0.0.0.0:*                           1000       18785233   29561/io.places.0
    udp        0      0 0.0.0.0:44750           0.0.0.0:*                           1000       18843677   31398/io.upnp.0
    udp        0      0 0.0.0.0:44868           0.0.0.0:*                           1000       19073759   29700/io.tr-064.1
    udp        0      0 0.0.0.0:45298           0.0.0.0:*                           1000       18788691   29049/io.node-red.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       18785123   29463/io.harmony.0
    udp        0      0 0.0.0.0:45636           0.0.0.0:*                           1000       18852834   31800/io.broadlink2
    udp        0      0 0.0.0.0:47102           0.0.0.0:*                           1000       18786731   28998/io.javascript
    udp        0      0 0.0.0.0:47509           0.0.0.0:*                           1000       19550463   36105/io.ical.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       18853522   31800/io.broadlink2
    udp        0      0 0.0.0.0:47788           0.0.0.0:*                           1000       18820878   31185/io.lovelace.0
    udp        0      0 0.0.0.0:48131           0.0.0.0:*                           1000       18844294   31769/io.wallpanel.
    udp        0      0 0.0.0.0:48224           0.0.0.0:*                           1000       18847485   31800/io.broadlink2
    udp        0      0 0.0.0.0:48759           0.0.0.0:*                           1000       18788779   29201/io.nut.0
    udp        0      0 0.0.0.0:48878           0.0.0.0:*                           1000       18832969   31169/io.moma.0
    udp        0      0 0.0.0.0:49258           0.0.0.0:*                           1000       18838885   31204/io.rtspStream
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          276        1/init
    udp        0      0 0.0.0.0:33024           0.0.0.0:*                           1000       18819102   30355/io.mqtt.0
    udp        0      0 0.0.0.0:33029           0.0.0.0:*                           1000       18810526   29856/io.sonoff.0
    udp        0      0 0.0.0.0:33219           0.0.0.0:*                           1000       19046149   32913/io.cloud.0
    udp        0      0 0.0.0.0:33266           0.0.0.0:*                           1000       18839052   31341/io.text2comma
    udp        0      0 0.0.0.0:33327           0.0.0.0:*                           1000       18864666   31949/io.echarts.0
    udp        0      0 0.0.0.0:49756           0.0.0.0:*                           1000       18860928   31923/io.omada.0
    udp        0      0 0.0.0.0:33518           0.0.0.0:*                           1000       18864337   31833/io.vw-connect
    udp        0      0 0.0.0.0:33894           0.0.0.0:*                           1000       18843261   31642/io.philips-tv
    udp        0      0 0.0.0.0:34119           0.0.0.0:*                           1000       18846509   31740/io.vis-2.0
    udp        0      0 0.0.0.0:50702           0.0.0.0:*                           1000       18788482   28857/io.admin.2
    udp        0      0 0.0.0.0:50864           0.0.0.0:*                           1000       18864539   31878/io.ai-toolbox
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       18844843   31398/io.upnp.0
    udp        0      0 0.0.0.0:34726           0.0.0.0:*                           1000       18790542   29182/io.whatsapp-c
    udp        0      0 0.0.0.0:35122           0.0.0.0:*                           1000       18812453   30469/io.shelly.0
    udp        0      0 0.0.0.0:35126           0.0.0.0:*                           1000       18852837   31800/io.broadlink2
    udp        0      0 0.0.0.0:35575           0.0.0.0:*                           1000       18782606   28806/io.telegram.0
    udp        0      0 0.0.0.0:52048           0.0.0.0:*                           1000       18844134   31711/io.alexa-time
    udp        0      0 0.0.0.0:35700           0.0.0.0:*                           1000       18810272   29669/io.shuttercon
    udp        0      0 0.0.0.0:52106           0.0.0.0:*                           1000       18818408   30594/io.web.0
    udp        0      0 0.0.0.0:52143           0.0.0.0:*                           1000       18848072   31800/io.broadlink2
    udp        0      0 0.0.0.0:35786           0.0.0.0:*                           1000       18852831   31800/io.broadlink2
    udp        0      0 0.0.0.0:35844           0.0.0.0:*                           1000       18797401   29952/io.systeminfo
    udp        0      0 0.0.0.0:36103           0.0.0.0:*                           1000       18811793   30518/io.zigbee.1
    udp        0      0 0.0.0.0:52645           0.0.0.0:*                           1000       19510792   35364/io.roborock.0
    udp        0      0 0.0.0.0:52703           0.0.0.0:*                           1000       18821260   30495/io.webcal.0
    udp        0      0 0.0.0.0:36398           0.0.0.0:*                           1000       18810655   30154/io.tuya.0
    udp        0      0 0.0.0.0:36460           0.0.0.0:*                           1000       18794350   30199/io.espresense
    udp        0      0 0.0.0.0:53118           0.0.0.0:*                           1000       18852852   31800/io.broadlink2
    udp        0      0 0.0.0.0:36865           0.0.0.0:*                           1000       18792688   29425/io.alexa2.0
    udp        0      0 0.0.0.0:37003           0.0.0.0:*                           1000       18859797   31815/io.smartthing
    udp        0      0 0.0.0.0:37253           0.0.0.0:*                           1000       18785994   28828/io.admin.1
    udp        0      0 0.0.0.0:37304           0.0.0.0:*                           1000       18783592   28700/iobroker.js-c
    udp        0      0 0.0.0.0:37398           0.0.0.0:*                           1000       18792846   29594/io.samsung.0
    udp        0      0 0.0.0.0:37419           0.0.0.0:*                           1000       18847017   31671/io.lightcontr
    udp        0      0 0.0.0.0:37607           0.0.0.0:*                           1000       19492177   31800/io.broadlink2
    udp        0      0 0.0.0.0:37658           0.0.0.0:*                           1000       18841057   31510/io.rssfeed.0
    udp        0      0 0.0.0.0:37760           0.0.0.0:*                           1000       18811215   29910/io.homeconnec
    udp        0      0 0.0.0.0:38019           0.0.0.0:*                           1000       18852840   31800/io.broadlink2
    udp        0      0 0.0.0.0:38066           0.0.0.0:*                           1000       18829928   30950/io.simple-api
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       19554002   36169/io.ham.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       18846123   31619/io.wled.0
    udp        0      0 192.168.178.250:5353    0.0.0.0:*                           1000       18805970   29700/io.tr-064.1
    udp        0      0 0.0.0.0:38123           0.0.0.0:*                           1000       18852849   31800/io.broadlink2
    udp        0      0 0.0.0.0:38244           0.0.0.0:*                           1000       18811645   30410/io.philips-ai
    udp        0      0 0.0.0.0:38245           0.0.0.0:*                           1000       18794359   30228/io.wifilight.
    udp        0      0 0.0.0.0:38570           0.0.0.0:*                           1000       18852828   31800/io.broadlink2
    udp        0      0 0.0.0.0:55034           0.0.0.0:*                           1000       18785120   29463/io.harmony.0
    udp        0      0 0.0.0.0:55060           0.0.0.0:*                           1000       18786571   29086/io.scenes.0
    udp6       0      0 :::111                  :::*                                0          9538       1/init
    2025-12-29 20:10:07.585  - debug: zigbee.2 (30719) DeviceAvailability:Non-pingable device 0x54ef441000e6c4f4 lumi.sensor_smoke.acn03 was last seen '2819.558' seconds ago.
    2025-12-29 20:10:07.585  - debug: zigbee.2 (30719) localConfig:getOptions for 00158d008b3ccfcc : {}
    2025-12-29 20:10:07.585  - debug: zigbee.2 (30719) DeviceAvailability:Non-pingable device 0x00158d008b3ccfcc lumi.weather was last seen '817.316' seconds ago.
    2025-12-29 20:10:07.585  - debug: zigbee.2 (30719) localConfig:getOptions for 54ef441000e6c4f4 : {}
    2025-12-29 20:10:10.067  - debug: zigbee.4 (30688) localConfig:getOptions for a4c138ef35832ff1 : {}
    2025-12-29 20:10:10.068  - debug: zigbee.4 (30688) localConfig:getOptions for a4c138ef35832ff1 : {}
    2025-12-29 20:10:10.071  - silly: zigbee.4 (30688) States user redis pmessage zigbee.4.*/zigbee.4.a4c138ef35832ff1.link_quality:{"val":114,"ack":true,"ts":1767035410070,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767035162760}
    2025-12-29 20:10:10.071  - silly: zigbee.4 (30688) States user redis pmessage zigbee.4.*/zigbee.4.a4c138ef35832ff1.msg_from_zigbee:{"val":"{\"type\":\"read\",\"data\":[\"localTime\"],\"linkquality\":114,\"groupID\":0,\"cluster\":\"genTime\",\"meta\":{\"rawData\":{\"type\":\"Buffer\",\"data\":[0,112,0,7,0]},\"zclTransactionSequenceNumber\":112,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}","ack":true,"ts":1767035410070,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767035410070}
    2025-12-29 20:10:10.111  - silly: zigbee.4 (30688) States user redis pmessage zigbee.4.*/zigbee.4.a4c138ef35832ff1.link_quality:{"val":114,"ack":true,"ts":1767035410111,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767035162760}
    2025-12-29 20:10:10.112  - silly: zigbee.4 (30688) States user redis pmessage zigbee.4.*/zigbee.4.a4c138ef35832ff1.msg_from_zigbee:{"val":"{\"type\":\"read\",\"data\":[\"localTime\"],\"linkquality\":114,\"groupID\":0,\"cluster\":\"genTime\",\"meta\":{\"rawData\":{\"type\":\"Buffer\",\"data\":[0,112,0,7,0]},\"zclTransactionSequenceNumber\":112,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}","ack":true,"ts":1767035410111,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767035410070}
    2025-12-29 20:10:10.213  - info: shelly.0 (30469) [authEnabled] 192.168.178.110 (shellyplus2pm / shellyplus2pm-30c922740d78 / shellyplus2pm#30c922740d78#1): This device is not protected via restricted login (see adapter documentation for details)
    2025-12-29 20:10:10.686  - silly: zigbee.4 (30688) States user redis pmessage zigbee.4.*/zigbee.4.a4c138e496ecd7f0.load_power:{"val":0,"ack":true,"ts":1767035410686,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767034461533}
    iob diag has finished.
    admin@iobroker:~$
    @holly200289 sagte in Instabiles Zigbee-Netzwerk:
    Würde ich mir mal anschauen.
    iob stop
    sudo apt install --reinstall nodejs
    iob start
    sollte npm und npx wieder auf die passende Version bringen.
    Falls es noch nicht angekommen ist: 'Die Katze'/GitHub ist KEINE REGULÄRE Installationsquelle. Du kannst mir doch nicht erzählen, dass du für 18 Adapter mit dem Paketbetreuer einen Test dieser Alpha-Versionen abgesprochen hast. Installier die Versionen aus einem Repo.
      was kommt denn da?
      CRITICAL ERRORS
        Script v.2025-08-09
        *** BASE SYSTEM ***
          Virtualization: lxc
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 8
                         RTC time: n/a
                  RTC in local TZ: no
        admin
        HOME=/home/admin
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:           1.0G          0B        1.0G
        Total:           27G        7.0G         20G
                 6644 M used memory
                    0 M inactive memory
                18079 M free memory
                    0 M buffer memory
                  296 M swap cache
                 1000 M total swap
                    0 M used swap
                 1000 M free swap
        *** FILESYSTEM ***
        /var:
        3.2G    /var/
        1.9G    /var/lib
        USB-Devices by-id:
        HINT:
        socket
        HINT:
        tcp
        HINT:
        tcp
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            11.7.0
        /usr/bin/npx            11.7.0
        nodejs:
          Version table:
             20.19.2+dfsg-1 500
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.7.19
        javascript:     9.0.17
        Adapter State
        + instance is alive
        Objects and States
        Objects:        57073
        States:         45056
        Pending Updates: 0
        admin@iobroker:~$
        202
        wieso müllst du dur freiwillig das log zu?
        • holly200289H Offline
          holly200289
          ich wollte den Fehler finden ?
            holly200289
            Die Frage ist was den Fehler auslöst ?
              was kommt denn da?
              was kommt denn da?
              was war damit?
                holly200289
                [sudo] password for admin:
                Summary:
                Upgrading: 0, Installing: 0, Reinstalling: 1, Removing: 0, Not Upgrading: 0
                Download size: 37.6 MB
                Space needed: 0 B / 227 GB available
                Get:1 https://deb.nodesource.com/node_22.x nodistro/main amd64 nodejs amd64 22.21.0-1nodesource1 [37.6 MB]
                Fetched 37.6 MB in 1s (27.4 MB/s)
                (Reading database ... 53573 files and directories currently installed.)
                Preparing to unpack .../nodejs_22.21.0-1nodesource1_amd64.deb ...
                Detected old npm client, removing...
                Unpacking nodejs (22.21.0-1nodesource1) over (22.21.0-1nodesource1) ...
                Setting up nodejs (22.21.0-1nodesource1) ...
                Processing triggers for man-db (2.13.1-1) ...
                admin@iobroker:~$
                  holly200289
                  Sorry, okay das mit dem Log werde ich abschalten, aber deswegen kommt ja nicht das Problem mit Zigbee oder ?
                    holly200289
                    Hier werden mit Sicherheit nicht alle Sachen optimal sein, darum Frage ich euch ja, wenn ihr was seht was nicht gut ist, oder das System beeinträchtigt, dann sagt mir das bitte.
                      @holly200289
                      zigbee.1 und zigbee.2 funken auf dem gleichen Kanal. Das kann/wird zu Problemen führen.
                      holly200289H S 2 Antworten Letzte Antwort
                        ...aber du gibst uns ja nicht die Antwort was der kritische Fehler ist
                          Dein Setup hab ich doch oben schon analysiert.
                            @holly200289
                            holly200289
                            @Thomas-Braun ja das weiß ich, nur ist der eine im Keller und ich im 2 OG, da dürfte es keine Probleme oder ?
                              Kann ich dir nicht sagen. Ich kenn die örtlichen Gegebenheiten ja nicht.
                                @holly200289
                                Was spuckt denn nu
                                aus?
                                  holly200289
                                  [Mon Dec 29 12:46:46 2025] Disabling IRQ #7
                                    @holly200289
                                    Was spuckt denn nu
                                    aus?
                                    @Thomas-Braun das hab ich jetzt 4x gefragt!
                                    ist wohl geheim.
                                      holly200289
                                      mehr kommt nicht
                                        Disabling IRQ #7
                                        hmm,
                                        im iob diag werden nur 3 USB Zigbee gefunden.
                                        entweder hat @thomas-braun das Skript nur auf 3 zyklen Programmiert, oder da fehlt 1
                                        Ob der auf irq #7 läuft weiß ich nicht
                                          holly200289
                                          Wenn ich Zigbee 1 und 2 abschalte kommt es trotzdem zu diesem Problem, dann machen das Zigbee 3 und 4
