  4. Instabiles Zigbee-Netzwerk
    6.4k
100 Beiträge 11 Kommentatoren 6.6k Aufrufe 13 Beobachtet
  • holly200289H Offline
    holly200289
    Worauf weißt das hin ??
    • holly200289H holly200289
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.12-17-pve
          Architecture: x86-64
      OS is similar to:
      model name      : AMD Ryzen 7 5700G with Radeon Graphics
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       20:09:37 up  7:22,  1 user,  load average: 0.80, 0.87, 0.75
      CPU threads: 8
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** TIME AND TIMEZONES ***
                     Local time: Mon 2025-12-29 20:09:37 CET
                 Universal time: Mon 2025-12-29 19:09:37 UTC
                       RTC time: n/a
      System clock synchronized: no
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      admin
      HOME=/home/admin
      GROUPS=admin adm dialout sudo audio video plugdev users iobroker
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/admin
      GROUPS=iobroker tty dialout audio video plugdev bluetooth docker
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:             26G        7.0G         18G         22M        310M         19G
      Swap:           1.0G          0B        1.0G
      Total:           27G        7.0G         20G
      Active iob-Instances:   85
              25000 M total memory
               6644 M used memory
               6637 M active memory
                  0 M inactive memory
              18079 M free memory
                  0 M buffer memory
                296 M swap cache
               1000 M total swap
                  0 M used swap
               1000 M free swap
      top - 20:09:37 up  7:22,  1 user,  load average: 0.80, 0.87, 0.75
      Tasks: 121 total,   4 running, 117 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 14.5 us,  4.8 sy,  0.0 ni, 79.5 id,  0.0 wa,  0.0 hi,  1.2 si,  0.0 st
      MiB Mem :  25000.0 total,  18073.1 free,   6651.6 used,    296.7 buff/cache
      MiB Swap:   1000.0 total,   1000.0 free,      0.0 used.  18348.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      1 CRITICAL ERRORS DETECTED!
      Check 'sudo dmesg --level=emerg,alert,crit -T' for details
      *** FILESYSTEM ***
      Filesystem              Type   Size  Used Avail Use% Mounted on
      daten/subvol-100-disk-0 zfs    230G   19G  212G   9% /
      none                    tmpfs  492K  4.0K  488K   1% /dev
      tmpfs                   tmpfs   16G     0   16G   0% /dev/shm
      tmpfs                   tmpfs  6.2G  176K  6.2G   1% /run
      tmpfs                   tmpfs  5.0M     0  5.0M   0% /run/lock
      tmpfs                   tmpfs   16G   22M   16G   1% /tmp
      tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-networkd.service
      tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/container-getty@1.service
      tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/container-getty@2.service
      tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/console-getty.service
      tmpfs                   tmpfs  3.1G  8.0K  3.1G   1% /run/user/1001
      [Mon Dec 29 12:46:49 2025] EXT4-fs (dm-1): mounted filesystem 8454bac7-7b31-4e6e-a8ae-07a4b96134b1 ro with ordered data mode. Quota mode: none.
      [Mon Dec 29 12:46:49 2025] EXT4-fs (dm-1): re-mounted 8454bac7-7b31-4e6e-a8ae-07a4b96134b1 r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET SOURCE                  FSTYPE OPTIONS
      /      daten/subvol-100-disk-0 zfs    rw,relatime,xattr,posixacl,casesensitive
      /var:
      3.2G    /var/
      1.9G    /var/lib
      1.8G    /var/lib/containerd
      1.2G    /var/log/journal/9626128f51d4471993ebdff830afe042
      Archived and active journals take up 1.1G in the file system.
      /opt/iobroker/backups:
      7.7G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.6G    /opt/iobroker/iobroker-data/
      746M    /opt/iobroker/iobroker-data/files
      512M    /opt/iobroker/iobroker-data/history
      267M    /opt/iobroker/iobroker-data/backup-objects
      82M     /opt/iobroker/iobroker-data/files/vis
      18M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      17M     /opt/iobroker/iobroker-data/history/20241203/history.pi-hole.0.overTimeData10mins.domains_over_time.data-table.json
      17M     /opt/iobroker/iobroker-data/history/20241203/history.pi-hole.0.overTimeData10mins.ads_over_time.data-table.json
      17M     /opt/iobroker/iobroker-data/history/20241202/history.pi-hole.0.overTimeData10mins.domains_over_time.data-table.json
      17M     /opt/iobroker/iobroker-data/history/20241202/history.pi-hole.0.overTimeData10mins.ads_over_time.data-table.json
      USB-Devices by-id:
      No Devices found 'by-id'
      *** ZigBee Settings ***
      HINT:
      Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
      socket
      HINT:
      Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      HINT:
      Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.21.0
      /usr/bin/node           v22.21.0
      /usr/bin/npm            11.7.0
      /usr/bin/npx            11.7.0
      /usr/bin/corepack       0.34.0
      nodejs:
        Installed: 22.21.0-1nodesource1
        Candidate: 22.21.0-1nodesource1
        Version table:
       *** 22.21.0-1nodesource1 600
           22.20.0-1nodesource1 600
           22.19.0-1nodesource1 600
           22.18.0-1nodesource1 600
           22.17.1-1nodesource1 600
           22.17.0-1nodesource1 600
           22.16.0-1nodesource1 600
           22.15.1-1nodesource1 600
           22.15.0-1nodesource1 600
           22.14.0-1nodesource1 600
           22.13.1-1nodesource1 600
           22.13.0-1nodesource1 600
           22.12.0-1nodesource1 600
           22.11.0-1nodesource1 600
           22.10.0-1nodesource1 600
           22.9.0-1nodesource1 600
           22.8.0-1nodesource1 600
           22.7.0-1nodesource1 600
           22.6.0-1nodesource1 600
           22.5.1-1nodesource1 600
           22.5.0-1nodesource1 600
           22.4.1-1nodesource1 600
           22.4.0-1nodesource1 600
           22.3.0-1nodesource1 600
           22.2.0-1nodesource1 600
           22.1.0-1nodesource1 600
           22.0.0-1nodesource1 600
           20.19.2+dfsg-1 500
              500 http://deb.debian.org/debian trixie/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 4551)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.19
      javascript:     9.0.17
      nodejs modules from github:     18
      +-- @iobroker/plugin-sentry@2.0.4 (git+ssh://git@github.com/ioBroker/plugin-sentry.git#31c593552c25cd0f10e2946589fbc88ad30cc480)
      +-- iobroker.chromecast@4.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.chromecast.git#82249496c21d5d02f073f1db0552eea0901d7f9e)
      +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
      +-- iobroker.mihome@1.4.0 (git+ssh://git@github.com/ioBroker/ioBroker.mihome.git#a1adfe45118047df0896faa952d2d9816a34539d)
      +-- iobroker.nuki-extended@2.7.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#abb720a7a3234d6328d68b1523938c3eace26419)
      +-- iobroker.omada@0.0.7 (git+ssh://git@github.com/TA2k/ioBroker.omada.git#0f6a083c8bf8306ffcb248ad6aa80c495cec438e)
      +-- iobroker.pi-hole2@1.1.1 (git+ssh://git@github.com/oweitman/ioBroker.pi-hole2.git#2e3723101f29c6deaa9811ccd62d84cea5438c90)
      +-- iobroker.roborock@0.6.19 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#4d519d4e5494569fc898affe0d2946722a646efd)
      +-- iobroker.rtspStream@0.0.2 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspStream.git#3891a8545b5566946b89b6f4dbfeac1e2a6527a5)
      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
      +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
      +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f)
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
      +-- iobroker.weblogin@0.1.1 (git+ssh://git@github.com/Vertumnus/ioBroker.weblogin.git#62ad7e95c8b9af53e668a1741d4818e3502892e7)
      +-- JQuery-Snowfall@1.7.1 (git+ssh://git@github.com/loktar00/JQuery-Snowfall.git#d22ba78f76804e21404bc000142c019d6c10973d)
      +-- magic-snowflakes@7.0.1 (git+ssh://git@github.com/hcodes/snowflakes.git#718a2b06c3d590ea89081700d96cfa014074dd4a)
      `-- zigbee-herdsman-converters@25.96.0 (git+ssh://git@github.com/Koenkk/zigbee-herdsman-converters.git#e9132fc65cc0bcbef60a5793976ba192fcc845ac)
      Adapter State
      + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.admin.2                  : admin                 : iobroker                                 -  enabled, port: 8089, bind: 127.0.0.1, run as: admin
      + system.adapter.ai-assistant.0           : ai-assistant          : iobroker                                 -  enabled
      + system.adapter.ai-toolbox.0             : ai-toolbox            : iobroker                                 -  enabled
      + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobroker                                 -  enabled
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
      + system.adapter.bshb.0                   : bshb                  : iobroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      + system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        system.adapter.devices.0                : devices               : iobroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      + system.adapter.espresense.0             : espresense            : iobroker                                 -  enabled
        system.adapter.flexcharts.0             : flexcharts            : iobroker                                 -  enabled
      + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
      + system.adapter.geofency.0               : geofency              : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
        system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
      + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
        system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: iobroker                                 -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
        system.adapter.icons-freepic.0          : icons-freepic         : iobroker                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
        system.adapter.icons-smarthome.0        : icons-smarthome       : iobroker                                 -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.lightcontrol.0           : lightcontrol          : iobroker                                 -  enabled
      + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
        system.adapter.material.0               : material              : iobroker                                 - disabled
        system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 0.0.0.0
        system.adapter.minuvis.0                : minuvis               : iobroker                                 - disabled
      + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
      + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      + system.adapter.omada.0                  : omada                 : iobroker                                 -  enabled, port: 8043
        system.adapter.openweathermap.1         : openweathermap        : iobroker                                 -  enabled
      + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
      + system.adapter.philips-air.0            : philips-air           : iobroker                                 -  enabled
      + system.adapter.philips-air.1            : philips-air           : iobroker                                 -  enabled
      + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
      + system.adapter.pi-hole2.0               : pi-hole2              : iobroker                                 -  enabled, port: 80
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.places.0                 : places                : iobroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
      + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
      + system.adapter.rtspStream.0             : rtspStream            : iobroker                                 -  enabled, port: 8083
      + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
      + system.adapter.samsung.1                : samsung               : iobroker                                 -  enabled
      + system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.slideshow.0              : slideshow             : iobroker                                 -  enabled
      + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
      + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.250
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      + system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 -  enabled
      + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5001
      + system.adapter.systeminfo.0             : systeminfo            : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
      + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.tr-064.2                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
        system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
        system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
        system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
      + system.adapter.wallpanel.0              : wallpanel             : iobroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
      + system.adapter.webcal.0                 : webcal                : iobroker                                 -  enabled
        system.adapter.weblogin.0               : weblogin              : iobroker                                 - disabled
      + system.adapter.webui.0                  : webui                 : iobroker                                 -  enabled
      + system.adapter.welcome.0                : welcome               : iobroker                                 -  enabled, port: 8080, bind: 192.168.178.250 (SSL), run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
      + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 -  enabled
      + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
      + system.adapter.windows-control.0        : windows-control       : iobroker                                 -  enabled
      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
        system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
      + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: socket://192.168.178.187:1020
      + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.38:2030
      + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.230:4060
      + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.240:6080
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: patch
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.7.19   , installed 7.7.19
      Adapter    "alexa-timer-vis": 2.1.2  , installed 2.1.2
      Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.3.10   , installed 3.3.13
      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
      Adapter    "bshb"         : 0.5.0    , installed 0.5.0
      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
      Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
      Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
      Adapter    "devices"      : 1.2.8    , installed 1.2.8
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "email"        : 2.0.4    , installed 2.0.4
      Adapter    "espresense"   : 0.6.3    , installed 0.6.3
      Adapter    "firetv"       : 2.1.0    , installed 2.1.0
      Adapter    "flexcharts"   : 0.6.1    , installed 0.6.1
      Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
      Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
      Adapter    "geofency"     : 1.2.4    , installed 1.2.4
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "harmony"      : 1.5.0    , installed 1.5.0
      Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
      Adapter    "ical"         : 1.18.1   , installed 1.18.1
      Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
      Adapter    "iot"          : 5.0.7    , installed 5.0.7
      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
      Adapter    "javascript"   : 9.0.11   , installed 9.0.17
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "kisshome-defender": 1.1.13, installed 1.1.13
      Adapter    "lightcontrol" : 1.0.1    , installed 1.0.1
      Adapter    "lovelace"     : 5.0.1    , installed 5.0.3
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "matter"       : 0.5.5    , installed 0.5.6
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mihome-cloud" : 0.1.0    , installed 0.2.2
      Adapter    "mihome-vacuum": 5.2.0    , installed 5.3.0
      Adapter    "minuvis"      : 2.3.3    , installed 2.3.3
      Adapter    "moma"         : 1.2.9    , installed 1.2.9
      Adapter    "node-red"     : 5.2.1    , installed 6.0.7
      Adapter    "nuki"         : 2.0.0    , installed 2.0.0
      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "parser"       : 2.2.4    , installed 2.2.4
      Adapter    "philips-air"  : 1.2.0    , installed 1.2.0
      Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
      Adapter    "pi-hole2"     : 1.1.1    , installed 1.1.1
      Adapter    "ping"         : 1.7.9    , installed 1.7.9
      Adapter    "places"       : 1.3.0    , installed 1.3.0
      Adapter    "proxmox"      : 2.4.0    , installed 2.4.2
      Adapter    "ring"         : 6.4.0    , installed 6.4.0
      Adapter    "roborock"     : 0.6.18   , installed 0.6.19
      Adapter    "rssfeed"      : 3.6.1    , installed 3.1.0  [Updatable]
      Adapter    "samsung"      : 0.6.1    , installed 0.6.1
      Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 10.4.1   , installed 10.4.1
      Adapter    "shuttercontrol": 2.0.7   , installed 2.0.9
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tinymqttbroker": 0.1.4   , installed 0.1.4
      Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "upnp"         : 1.1.0    , installed 1.1.0
      Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
      Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.3
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "vis-material" : 0.2.0    , installed 0.2.0
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
      Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
      Adapter    "weather-warnings": 0.10.0, installed 0.10.0
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 7.0.8    , installed 7.0.9
      Adapter    "webcal"       : 1.4.0    , installed 1.4.0
      Adapter    "webui"        : 1.37.0   , installed 1.38.7
      Adapter    "welcome"      : 1.0.2    , installed 1.0.2
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
      Adapter    "wireguard"    : 1.7.0    , installed 1.8.0
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "yahka"        : 1.1.5    , installed 1.1.5
      Adapter    "youtube"      : 6.1.0    , installed 6.0.0  [Updatable]
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
      Objects and States
      Objects:        57073
      States:         45056
      W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
      Hit:1 http://security.debian.org trixie-security InRelease
      Hit:2 http://deb.debian.org/debian trixie InRelease
      Hit:3 https://download.docker.com/linux/debian trixie InRelease
      Hit:4 http://deb.debian.org/debian trixie-updates InRelease
      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.178.250:1886    0.0.0.0:*               LISTEN      1000       18794121   29856/io.sonoff.0
      tcp        0      0 192.168.178.250:8080    0.0.0.0:*               LISTEN      1000       18841162   31583/io.welcome.0
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       18779713   28700/iobroker.js-c
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       18782519   28700/iobroker.js-c
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          20374      318/master
      tcp        0      0 192.168.178.250:9092    0.0.0.0:*               LISTEN      1000       18816745   30574/io.nuki.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       18782757   29075/node-red
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       18820174   30469/io.shelly.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       18817073   30355/io.mqtt.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          6551       1/init
      tcp        0      0 127.0.0.1:8089          0.0.0.0:*               LISTEN      1000       18788498   28857/io.admin.2
      tcp6       0      0 :::61991                :::*                    LISTEN      1000       18785122   29463/io.harmony.0
      tcp6       0      0 :::7999                 :::*                    LISTEN      1000       18782902   29418/io.geofency.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       18786037   28828/io.admin.1
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       18822250   30594/io.web.0
      tcp6       0      0 :::8083                 :::*                    LISTEN      1000       18834212   31204/io.rtspStream
      tcp6       0      0 :::8084                 :::*                    LISTEN      1000       18832606   30936/io.socketio.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       18833714   30950/io.simple-api
      tcp6       0      0 :::8091                 :::*                    LISTEN      1000       18820880   31185/io.lovelace.0
      tcp6       0      0 :::6824                 :::*                    LISTEN      1000       19516639   35364/io.roborock.0
      tcp6       0      0 :::1890                 :::*                    LISTEN      1000       18812108   30199/io.espresense
      tcp6       0      0 :::111                  :::*                    LISTEN      0          6552       1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13790      1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          20375      318/master
      udp        0      0 0.0.0.0:38794           0.0.0.0:*                           1000       18841022   31465/io.windows-co
      udp        0      0 0.0.0.0:55189           0.0.0.0:*                           1000       18806896   29628/io.samsung.1
      udp        0      0 0.0.0.0:55417           0.0.0.0:*                           1000       18788974   29418/io.geofency.0
      udp        0      0 0.0.0.0:55497           0.0.0.0:*                           1000       18820371   30688/io.zigbee.4
      udp        0      0 0.0.0.0:55548           0.0.0.0:*                           1000       18792908   29729/io.tr-064.2
      udp        0      0 0.0.0.0:55638           0.0.0.0:*                           1000       19076204   33024/io.pi-hole2.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       18812081   30154/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       18812082   30154/io.tuya.0
      udp        0      0 0.0.0.0:56054           0.0.0.0:*                           1000       18812133   30243/io.daikin-clo
      udp        0      0 0.0.0.0:39750           0.0.0.0:*                           1000       18845461   31859/io.ai-assista
      udp        0      0 0.0.0.0:39819           0.0.0.0:*                           1000       18835778   31176/io.parser.0
      udp        0      0 0.0.0.0:40106           0.0.0.0:*                           1000       18834094   31150/io.iqontrol.0
      udp        0      0 0.0.0.0:56834           0.0.0.0:*                           1000       19042741   32896/io.bshb.0
      udp        0      0 0.0.0.0:56854           0.0.0.0:*                           1000       18843672   31398/io.upnp.0
      udp        0      0 0.0.0.0:40504           0.0.0.0:*                           1000       18819559   30719/io.zigbee.2
      udp        0      0 0.0.0.0:40540           0.0.0.0:*                           1000       18820510   30740/io.discovery.
      udp        0      0 0.0.0.0:57140           0.0.0.0:*                           1000       18788596   28963/io.history.0
      udp        0      0 0.0.0.0:40824           0.0.0.0:*                           1000       18847479   31800/io.broadlink2
      udp        0      0 0.0.0.0:40905           0.0.0.0:*                           1000       18816985   30672/io.zigbee.3
      udp        0      0 0.0.0.0:41324           0.0.0.0:*                           1000       18817115   30410/io.philips-ai
      udp        0      0 0.0.0.0:57776           0.0.0.0:*                           1000       18820637   30936/io.socketio.0
      udp        0      0 0.0.0.0:57784           0.0.0.0:*                           1000       18788526   28912/io.email.0
      udp        0      0 0.0.0.0:57788           0.0.0.0:*                           1000       18797465   30165/io.fullybrows
      udp        0      0 0.0.0.0:41432           0.0.0.0:*                           1000       18789755   29528/io.ping.0
      udp        0      0 0.0.0.0:57900           0.0.0.0:*                           1000       18846128   31619/io.wled.0
      udp        0      0 0.0.0.0:57964           0.0.0.0:*                           1000       18839298   31439/io.vis-invent
      udp        0      0 0.0.0.0:41999           0.0.0.0:*                           1000       18782841   29212/io.influxdb.0
      udp        0      0 0.0.0.0:58465           0.0.0.0:*                           1000       18816064   30333/io.samsung_ti
      udp        0      0 0.0.0.0:58516           0.0.0.0:*                           1000       18792452   29160/io.whatsapp-c
      udp        0      0 0.0.0.0:58683           0.0.0.0:*                           1000       18812665   30574/io.nuki.0
      udp        0      0 0.0.0.0:42351           0.0.0.0:*                           1000       18810455   29813/io.spotify-pr
      udp        0      0 0.0.0.0:58821           0.0.0.0:*                           1000       18786436   28850/io.telegram.1
      udp        0      0 0.0.0.0:59444           0.0.0.0:*                           1000       18807672   30381/io.philips-ai
      udp        0      0 0.0.0.0:43090           0.0.0.0:*                           1000       18847482   31800/io.broadlink2
      udp        0      0 0.0.0.0:43093           0.0.0.0:*                           1000       18783210   29824/io.proxmox.0
      udp        0      0 0.0.0.0:59587           0.0.0.0:*                           1000       18835642   31066/io.fullcalend
      udp        0      0 0.0.0.0:43364           0.0.0.0:*                           1000       19037934   32939/io.iot.0
      udp        0      0 0.0.0.0:43399           0.0.0.0:*                           1000       18816118   30381/io.philips-ai
      udp        0      0 0.0.0.0:60309           0.0.0.0:*                           1000       18790676   29291/io.backitup.0
      udp        0      0 0.0.0.0:60438           0.0.0.0:*                           1000       18842970   31539/io.webui.0
      udp        0      0 0.0.0.0:60575           0.0.0.0:*                           1000       18839498   31568/io.slideshow.
      udp        0      0 0.0.0.0:60727           0.0.0.0:*                           1000       18843074   31583/io.welcome.0
      udp        0      0 0.0.0.0:44561           0.0.0.0:*                           1000       18837936   31274/io.sourceanal
      udp        0      0 0.0.0.0:44723           0.0.0.0:*                           1000       18785233   29561/io.places.0
      udp        0      0 0.0.0.0:44750           0.0.0.0:*                           1000       18843677   31398/io.upnp.0
      udp        0      0 0.0.0.0:44868           0.0.0.0:*                           1000       19073759   29700/io.tr-064.1
      udp        0      0 0.0.0.0:45298           0.0.0.0:*                           1000       18788691   29049/io.node-red.0
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       18785123   29463/io.harmony.0
      udp        0      0 0.0.0.0:45636           0.0.0.0:*                           1000       18852834   31800/io.broadlink2
      udp        0      0 0.0.0.0:47102           0.0.0.0:*                           1000       18786731   28998/io.javascript
      udp        0      0 0.0.0.0:47509           0.0.0.0:*                           1000       19550463   36105/io.ical.0
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       18853522   31800/io.broadlink2
      udp        0      0 0.0.0.0:47788           0.0.0.0:*                           1000       18820878   31185/io.lovelace.0
      udp        0      0 0.0.0.0:48131           0.0.0.0:*                           1000       18844294   31769/io.wallpanel.
      udp        0      0 0.0.0.0:48224           0.0.0.0:*                           1000       18847485   31800/io.broadlink2
      udp        0      0 0.0.0.0:48759           0.0.0.0:*                           1000       18788779   29201/io.nut.0
      udp        0      0 0.0.0.0:48878           0.0.0.0:*                           1000       18832969   31169/io.moma.0
      udp        0      0 0.0.0.0:49258           0.0.0.0:*                           1000       18838885   31204/io.rtspStream
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          276        1/init
      udp        0      0 0.0.0.0:33024           0.0.0.0:*                           1000       18819102   30355/io.mqtt.0
      udp        0      0 0.0.0.0:33029           0.0.0.0:*                           1000       18810526   29856/io.sonoff.0
      udp        0      0 0.0.0.0:33219           0.0.0.0:*                           1000       19046149   32913/io.cloud.0
      udp        0      0 0.0.0.0:33266           0.0.0.0:*                           1000       18839052   31341/io.text2comma
      udp        0      0 0.0.0.0:33327           0.0.0.0:*                           1000       18864666   31949/io.echarts.0
      udp        0      0 0.0.0.0:49756           0.0.0.0:*                           1000       18860928   31923/io.omada.0
      udp        0      0 0.0.0.0:33518           0.0.0.0:*                           1000       18864337   31833/io.vw-connect
      udp        0      0 0.0.0.0:33894           0.0.0.0:*                           1000       18843261   31642/io.philips-tv
      udp        0      0 0.0.0.0:34119           0.0.0.0:*                           1000       18846509   31740/io.vis-2.0
      udp        0      0 0.0.0.0:50702           0.0.0.0:*                           1000       18788482   28857/io.admin.2
      udp        0      0 0.0.0.0:50864           0.0.0.0:*                           1000       18864539   31878/io.ai-toolbox
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       18844843   31398/io.upnp.0
      udp        0      0 0.0.0.0:34726           0.0.0.0:*                           1000       18790542   29182/io.whatsapp-c
      udp        0      0 0.0.0.0:35122           0.0.0.0:*                           1000       18812453   30469/io.shelly.0
      udp        0      0 0.0.0.0:35126           0.0.0.0:*                           1000       18852837   31800/io.broadlink2
      udp        0      0 0.0.0.0:35575           0.0.0.0:*                           1000       18782606   28806/io.telegram.0
      udp        0      0 0.0.0.0:52048           0.0.0.0:*                           1000       18844134   31711/io.alexa-time
      udp        0      0 0.0.0.0:35700           0.0.0.0:*                           1000       18810272   29669/io.shuttercon
      udp        0      0 0.0.0.0:52106           0.0.0.0:*                           1000       18818408   30594/io.web.0
      udp        0      0 0.0.0.0:52143           0.0.0.0:*                           1000       18848072   31800/io.broadlink2
      udp        0      0 0.0.0.0:35786           0.0.0.0:*                           1000       18852831   31800/io.broadlink2
      udp        0      0 0.0.0.0:35844           0.0.0.0:*                           1000       18797401   29952/io.systeminfo
      udp        0      0 0.0.0.0:36103           0.0.0.0:*                           1000       18811793   30518/io.zigbee.1
      udp        0      0 0.0.0.0:52645           0.0.0.0:*                           1000       19510792   35364/io.roborock.0
      udp        0      0 0.0.0.0:52703           0.0.0.0:*                           1000       18821260   30495/io.webcal.0
      udp        0      0 0.0.0.0:36398           0.0.0.0:*                           1000       18810655   30154/io.tuya.0
      udp        0      0 0.0.0.0:36460           0.0.0.0:*                           1000       18794350   30199/io.espresense
      udp        0      0 0.0.0.0:53118           0.0.0.0:*                           1000       18852852   31800/io.broadlink2
      udp        0      0 0.0.0.0:36865           0.0.0.0:*                           1000       18792688   29425/io.alexa2.0
      udp        0      0 0.0.0.0:37003           0.0.0.0:*                           1000       18859797   31815/io.smartthing
      udp        0      0 0.0.0.0:37253           0.0.0.0:*                           1000       18785994   28828/io.admin.1
      udp        0      0 0.0.0.0:37304           0.0.0.0:*                           1000       18783592   28700/iobroker.js-c
      udp        0      0 0.0.0.0:37398           0.0.0.0:*                           1000       18792846   29594/io.samsung.0
      udp        0      0 0.0.0.0:37419           0.0.0.0:*                           1000       18847017   31671/io.lightcontr
      udp        0      0 0.0.0.0:37607           0.0.0.0:*                           1000       19492177   31800/io.broadlink2
      udp        0      0 0.0.0.0:37658           0.0.0.0:*                           1000       18841057   31510/io.rssfeed.0
      udp        0      0 0.0.0.0:37760           0.0.0.0:*                           1000       18811215   29910/io.homeconnec
      udp        0      0 0.0.0.0:38019           0.0.0.0:*                           1000       18852840   31800/io.broadlink2
      udp        0      0 0.0.0.0:38066           0.0.0.0:*                           1000       18829928   30950/io.simple-api
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       19554002   36169/io.ham.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       18846123   31619/io.wled.0
      udp        0      0 192.168.178.250:5353    0.0.0.0:*                           1000       18805970   29700/io.tr-064.1
      udp        0      0 0.0.0.0:38123           0.0.0.0:*                           1000       18852849   31800/io.broadlink2
      udp        0      0 0.0.0.0:38244           0.0.0.0:*                           1000       18811645   30410/io.philips-ai
      udp        0      0 0.0.0.0:38245           0.0.0.0:*                           1000       18794359   30228/io.wifilight.
      udp        0      0 0.0.0.0:38570           0.0.0.0:*                           1000       18852828   31800/io.broadlink2
      udp        0      0 0.0.0.0:55034           0.0.0.0:*                           1000       18785120   29463/io.harmony.0
      udp        0      0 0.0.0.0:55060           0.0.0.0:*                           1000       18786571   29086/io.scenes.0
      udp6       0      0 :::111                  :::*                                0          9538       1/init
      2025-12-29 20:10:07.585  - debug: zigbee.2 (30719) DeviceAvailability:Non-pingable device 0x54ef441000e6c4f4 lumi.sensor_smoke.acn03 was last seen '2819.558' seconds ago.
      2025-12-29 20:10:07.585  - debug: zigbee.2 (30719) localConfig:getOptions for 00158d008b3ccfcc : {}
      2025-12-29 20:10:07.585  - debug: zigbee.2 (30719) DeviceAvailability:Non-pingable device 0x00158d008b3ccfcc lumi.weather was last seen '817.316' seconds ago.
      2025-12-29 20:10:07.585  - debug: zigbee.2 (30719) localConfig:getOptions for 54ef441000e6c4f4 : {}
      2025-12-29 20:10:10.067  - debug: zigbee.4 (30688) localConfig:getOptions for a4c138ef35832ff1 : {}
      2025-12-29 20:10:10.068  - debug: zigbee.4 (30688) localConfig:getOptions for a4c138ef35832ff1 : {}
      2025-12-29 20:10:10.071  - silly: zigbee.4 (30688) States user redis pmessage zigbee.4.*/zigbee.4.a4c138ef35832ff1.link_quality:{"val":114,"ack":true,"ts":1767035410070,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767035162760}
      2025-12-29 20:10:10.071  - silly: zigbee.4 (30688) States user redis pmessage zigbee.4.*/zigbee.4.a4c138ef35832ff1.msg_from_zigbee:{"val":"{\"type\":\"read\",\"data\":[\"localTime\"],\"linkquality\":114,\"groupID\":0,\"cluster\":\"genTime\",\"meta\":{\"rawData\":{\"type\":\"Buffer\",\"data\":[0,112,0,7,0]},\"zclTransactionSequenceNumber\":112,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}","ack":true,"ts":1767035410070,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767035410070}
      2025-12-29 20:10:10.111  - silly: zigbee.4 (30688) States user redis pmessage zigbee.4.*/zigbee.4.a4c138ef35832ff1.link_quality:{"val":114,"ack":true,"ts":1767035410111,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767035162760}
      2025-12-29 20:10:10.112  - silly: zigbee.4 (30688) States user redis pmessage zigbee.4.*/zigbee.4.a4c138ef35832ff1.msg_from_zigbee:{"val":"{\"type\":\"read\",\"data\":[\"localTime\"],\"linkquality\":114,\"groupID\":0,\"cluster\":\"genTime\",\"meta\":{\"rawData\":{\"type\":\"Buffer\",\"data\":[0,112,0,7,0]},\"zclTransactionSequenceNumber\":112,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}","ack":true,"ts":1767035410111,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767035410070}
      2025-12-29 20:10:10.213  - info: shelly.0 (30469) [authEnabled] 192.168.178.110 (shellyplus2pm / shellyplus2pm-30c922740d78 / shellyplus2pm#30c922740d78#1): This device is not protected via restricted login (see adapter documentation for details)
      2025-12-29 20:10:10.686  - silly: zigbee.4 (30688) States user redis pmessage zigbee.4.*/zigbee.4.a4c138e496ecd7f0.load_power:{"val":0,"ack":true,"ts":1767035410686,"q":0,"from":"system.adapter.zigbee.4","user":"system.user.admin","lc":1767034461533}
      iob diag has finished.
      admin@iobroker:~$
      @holly200289 sagte in Instabiles Zigbee-Netzwerk:
      Würde ich mir mal anschauen.
      iob stop
      sudo apt install --reinstall nodejs
      iob start
      sollte npm und npx wieder auf die passende Version bringen.
      Falls es noch nicht angekommen ist: 'Die Katze'/GitHub ist KEINE REGULÄRE Installationsquelle. Du kannst mir doch nicht erzählen, dass du für 18 Adapter mit dem Paketbetreuer einen Test dieser Alpha-Versionen abgesprochen hast. Installier die Versionen aus einem Repo.
        was kommt denn da?
        CRITICAL ERRORS
          Script v.2025-08-09
          *** BASE SYSTEM ***
            Virtualization: lxc
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 8
                           RTC time: n/a
                    RTC in local TZ: no
          admin
          HOME=/home/admin
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:           1.0G          0B        1.0G
          Total:           27G        7.0G         20G
                   6644 M used memory
                      0 M inactive memory
                  18079 M free memory
                      0 M buffer memory
                    296 M swap cache
                   1000 M total swap
                      0 M used swap
                   1000 M free swap
          *** FILESYSTEM ***
          /var:
          3.2G    /var/
          1.9G    /var/lib
          USB-Devices by-id:
          HINT:
          socket
          HINT:
          tcp
          HINT:
          tcp
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            11.7.0
          /usr/bin/npx            11.7.0
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.19
          javascript:     9.0.17
          Adapter State
          + instance is alive
          Objects and States
          Objects:        57073
          States:         45056
          Pending Updates: 0
          admin@iobroker:~$
          202
          wieso müllst du dur freiwillig das log zu?
            holly200289
            ich wollte den Fehler finden ?
              holly200289
              Die Frage ist was den Fehler auslöst ?
                was kommt denn da?
                was kommt denn da?
                was war damit?
                  holly200289
                  [sudo] password for admin:
                  Summary:
                  Upgrading: 0, Installing: 0, Reinstalling: 1, Removing: 0, Not Upgrading: 0
                  Download size: 37.6 MB
                  Space needed: 0 B / 227 GB available
                  Get:1 https://deb.nodesource.com/node_22.x nodistro/main amd64 nodejs amd64 22.21.0-1nodesource1 [37.6 MB]
                  Fetched 37.6 MB in 1s (27.4 MB/s)
                  (Reading database ... 53573 files and directories currently installed.)
                  Preparing to unpack .../nodejs_22.21.0-1nodesource1_amd64.deb ...
                  Detected old npm client, removing...
                  Unpacking nodejs (22.21.0-1nodesource1) over (22.21.0-1nodesource1) ...
                  Setting up nodejs (22.21.0-1nodesource1) ...
                  Processing triggers for man-db (2.13.1-1) ...
                  admin@iobroker:~$
                    holly200289
                    Sorry, okay das mit dem Log werde ich abschalten, aber deswegen kommt ja nicht das Problem mit Zigbee oder ?
                      holly200289
                      Hier werden mit Sicherheit nicht alle Sachen optimal sein, darum Frage ich euch ja, wenn ihr was seht was nicht gut ist, oder das System beeinträchtigt, dann sagt mir das bitte.
                        @holly200289
                        zigbee.1 und zigbee.2 funken auf dem gleichen Kanal. Das kann/wird zu Problemen führen.
                        holly200289H S 2 Antworten Letzte Antwort
                          ...aber du gibst uns ja nicht die Antwort was der kritische Fehler ist
                            Dein Setup hab ich doch oben schon analysiert.
                              @holly200289
                              holly200289
                              @Thomas-Braun ja das weiß ich, nur ist der eine im Keller und ich im 2 OG, da dürfte es keine Probleme oder ?
                                Kann ich dir nicht sagen. Ich kenn die örtlichen Gegebenheiten ja nicht.
                                  @holly200289
                                  Was spuckt denn nu
                                  aus?
                                    holly200289
                                    [Mon Dec 29 12:46:46 2025] Disabling IRQ #7
                                      @holly200289
                                      Was spuckt denn nu
                                      aus?
                                      @Thomas-Braun das hab ich jetzt 4x gefragt!
                                      ist wohl geheim.
                                        holly200289
                                        mehr kommt nicht
                                          Disabling IRQ #7
                                          hmm,
                                          im iob diag werden nur 3 USB Zigbee gefunden.
                                          entweder hat @thomas-braun das Skript nur auf 3 zyklen Programmiert, oder da fehlt 1
                                          Ob der auf irq #7 läuft weiß ich nicht
