  5. Link umbauen
    6.3k
Link umbauen
25 Beiträge 4 Kommentatoren 1.1k Aufrufe 3 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    Hallo
    Ich möchte einen Link mit Blockly umbauen, sodass ich ein passendes Bild bekomme.
      <variables>
        <variable id="BXYL{xhaLkN~v2Ldl!%!">text</variable>
      </variables>
      <block type="on" id="/Z2O}ZB#,a]kn33Dz4F$" x="113" y="2388">
        <field name="OID">klipper-moonraker.0.print_stats.filename</field>
        <statement name="STATEMENT">
          <block type="variables_set" id="y[Oc#E_92,_2BKo4(5~[">
            <field name="VAR" id="BXYL{xhaLkN~v2Ldl!%!">text</field>
            <value name="VALUE">
              <block type="get_attr" id="XXR]WqWt.=HMLUr3gR}@">
                <value name="PATH">
                  <shadow type="text" id="rrx*$IEHd@w{;*~Z+8`n">
                    <field name="TEXT">value</field>
                  </shadow>
                </value>
                <value name="OBJECT">
                  <shadow type="get_object" id="^cMzi*_aj{`Pl0P725m~">
                  </shadow>
                  <block type="on_source" id="pgo{+7GzQz;]qj)e34}A">
                  </block>
                </value>
              </block>
            </value>
            <next>
              <block type="update" id="bIOV@RC*Q+u,j_l+cDZ,">
                <field name="OID">0_userdata.0.3DDrucker.Snapmaker_U1.Filename</field>
                  <block type="text_getSubstring" id=";P~^,bl^VhcaeFBrn4B7">
                    <mutation at1="false" at2="true"></mutation>
                    <field name="WHERE1">FIRST</field>
                    <field name="WHERE2">FROM_START</field>
                    <value name="STRING">
                      <block type="variables_get" id=".)~:q(Mh|eeSdPJRu*2!">
                      </block>
                    </value>
                    <value name="AT2">
                      <block type="math_arithmetic" id="~]oa3qPRWU)spG%YB1]]">
                        <value name="A">
                          <shadow type="math_number" id="PqrA)w7#cW-.+R7[s$Ut">
                            <field name="NUM">1</field>
                          </shadow>
                          <block type="text_indexOf" id="r51`DlwiN)v*}8k4q}5p">
                            <field name="END">FIRST</field>
                              <block type="variables_get" id="sqPwTzw6?t1]F1dwmj|P">
                              </block>
                            </value>
                            <value name="FIND">
                              <shadow type="text" id="NN88q$[rF?qy3R1S,=Fk">
                                <field name="TEXT">.gcode</field>
                              </shadow>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          <shadow type="math_number" id="Gp.#K1A?Y{{b4u]f,mK_">
                          </shadow>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                  <block type="update" id="v~`h#IPc]?2X#3=M{X[a">
                    <field name="OID">0_userdata.0.3DDrucker.Snapmaker_U1.Thumbnail</field>
                      <block type="text_join" id="=uC)c{XD(`=yL3+qnM$/">
                        <value name="ADD0">
                          <block type="text" id="+hu6Z]DDV49vxZEG3^KI">
                            <field name="TEXT">http://10.0.1.244:80/server/files/gcodes/.thumbs/</field>
                          </block>
                        </value>
                        <value name="ADD1">
                          <block type="text_getSubstring" id=".jX}L{b`]tqX[lP+wIR2">
                              <block type="variables_get" id="ZUXf!~C]B[?oTqjrU3mF">
                              </block>
                            </value>
                            <value name="AT2">
                              <block type="math_arithmetic" id="rArUrH5JD`!U0PI6`=Lt">
                                <value name="A">
                                  </shadow>
                                  <block type="text_indexOf" id="Gji4dA%oP(rS[%9W%X(m">
                                      <block type="variables_get" id="i=BXKzmS]z$x=!47DA!B">
                                      </block>
                                    </value>
                                    <value name="FIND">
                                      <shadow type="text" id="nTgAoKx?A/?1e#g9JTXQ">
                                      </shadow>
                                    </value>
                                  </block>
                                </value>
                                <value name="B">
                                  <shadow type="math_number" id="u3_-Ii7/U+4%YQw8Az@I">
                                  </shadow>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="ADD2">
                          <block type="text" id="sn3+k)T(}R(KvqNhQ6;v">
                            <field name="TEXT">-300x300.png</field>
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
    </xml>
    klipper-moonraker.0.print_stats.filename enthält den Dateinamen der Druckdatei (zB Emely_2.gcode)
    http://10.0.1.244/server/files/gcodes/.thumbs/Emely_2-300x300.png wäre dann der richtige Pfad.
    0_userdata.0.3DDrucker.Snapmaker_U1.print_stats.Filename & 0_userdata.0.3DDrucker.Snapmaker_U1.print_stats.Thumbnail sind jeweils als String angelegt.
    Mit obigem Blockly bringt es mir Fehler.
    javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at processImmediate (node:internal/timers:483:21)
    javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11138:53)
    javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at JavaScript.emit (node:domain:489:12)
    javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at JavaScript.emit (node:events:524:28)
    javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at JavaScript.onStateChange (/opt/iobrokr/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at Object.<anonymous> (script.js.3D-Drucker.Klipper_Thumb:9:81)
    javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: Error: TypeError: Cannot read properties of null (reading 'slice')
    javascript.0 2025-12-27 14:23:54.081	error	script.js.3D-Drucker.Klipper_Thumb: Cannot parse "Emely_2.gcode": SyntaxError: Unexpected token 'E', "Emely_2.gcode" is not valid JSON
    Kann bitte jemand dabei helfen?
    ° Fixer ---> iob fix
    • AsgothianA Offline
      AsgothianA Offline
      Asgothian
      Ersetze bitte die bausteinkombi setze ‘Text’ auf Attribut ‘value’ von objekt Wert durch setze ‘Text’ auf Wert
      A.
      • AsgothianA Asgothian
        A.
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @Asgothian sagte in Link umbauen:
        hat leider nicht funktioniert
        • NegaleinN Negalein
          @Negalein sagte in Link umbauen:
          was kommt jetzt?
            was kommt jetzt?
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            @Homoran sagte in Link umbauen:
            was kommt jetzt?
            keine Fehlermeldung, aber auch nichts in den 2 DP
              was kommt jetzt?
              @Negalein und wie sieht das Blockly jetzt aus?
              was steht in der Variable Text?
                Hallo
                  <variables>
                  </variables>
                            <value name="PATH">
                              </shadow>
                            </value>
                              </shadow>
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                                  </block>
                                </value>
                                <value name="AT2">
                                    <value name="A">
                                      </shadow>
                                          </block>
                                        </value>
                                        <value name="FIND">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="B">
                                      </shadow>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <next>
                                    <value name="ADD0">
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                          </block>
                                        </value>
                                        <value name="AT2">
                                            <value name="A">
                                              </shadow>
                                                  </block>
                                                </value>
                                                <value name="FIND">
                                                  </shadow>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="B">
                                              </shadow>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="ADD2">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </xml>
                CodierknechtC Offline
                Codierknecht
                @Negalein
                Versuch's mal auf die Art:
                HmIP|ZigBee|Tasmota|Unifi
                Zabbix Certified Specialist
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  als JS-Code
                  var text;
                  on({ id: 'klipper-moonraker.0.print_stats.filename' /* Filename of the Print */, change: 'ne' }, async (obj) => {
                    let value = obj.state.val;
                    let oldValue = obj.oldState.val;
                    text = (obj.state ? obj.state.val : '');
                    setState('0_userdata.0.3DDrucker.Snapmaker_U1.Filename' /* Filename */, (text.slice(0, (text.indexOf('.gcode') + 1) - 1)), true);
                    setState('0_userdata.0.3DDrucker.Snapmaker_U1.Thumbnail' /* Thumbnail */, (['http://10.0.1.244:80/server/files/gcodes/.thumbs/',text.slice(0, (text.indexOf('.gcode') + 1) - 1),'-300x300.png'].join('')), true);
                    als JS-Code
                    var text;
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      so?
                        "type": "state",
                        "common": {
                          "name": "Filename of the Print",
                          "type": "string",
                          "role": "value",
                          "read": true,
                          "unit": "",
                          "write": false
                        "from": "system.adapter.klipper-moonraker.0",
                        "user": "system.user.admin",
                        "ts": 1766948194003,
                        "_id": "klipper-moonraker.0.print_stats.filename",
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                          "owner": "system.user.admin",
                      als Wert steht Emely_3.gcode
                        so?
                          "type": "state",
                          "common": {
                            "type": "string",
                            "role": "value",
                            "read": true,
                            "unit": "",
                            "write": false
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                        steht das im DP oder auch tatsächlich in der Variablen??
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          wie seh ich das?
                            wie seh ich das?
                            wie seh ich das?
                            nimm nen debug Baustein und lass dir die Variable Text ausgeben
                              wie seh ich das?
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              so?
                              da kommt nichts im log
                                so?
                                bitte zeigen
                                  bitte zeigen
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  @Homoran
                                  javascript.0 2025-12-29 20:52:26.794	info	script.js.3D-Drucker.Klipper_Thumb: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                  javascript.0 2025-12-29 20:52:26.786	info	script.js.3D-Drucker.Klipper_Thumb: start JavaScript (Blockly)
                                    @Homoran
                                    @Negalein wurde der Wert im DP überhaupt geändert?
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      ah, ok.
                                      javascript.0	21:00:06.519	info	Emely_03.gcode
                                      javascript.0	21:00:59.041	info	Emely_3.gcode
                                        ah, ok.
                                        ah,
                                        und was steht jetzt in den Ziel-DPs?
                                          ah,
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          nichts
