  4. RPI2 Adapter kann nicht installiert werden
    6.4k
167 Beiträge 11 Kommentatoren 13.2k Aufrufe 10 Beobachtet
  • G Gonzokalle
    @Thomas-Braun
    Hallo, ich habe seit heute Trixi auf dem 5er Raspi.
    RPI2 über Adapter ging nicht zu installieren.
    RPI2 über Adapter / von NPM ginge es ebenfalls nicht zu installieren.
    Nun bin ich etwas ratlos.
    host.RaspberryPi-Iobroker
    2025-12-26 15:55:06.761	error	iobroker No alive host found which has the adapter rpi2 installed! No upload possible. Skipped.
    2025-12-26 15:55:04.676	error	iobroker host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 7
    2025-12-26 15:55:04.675	error	iobroker npm warn deprecated npmlog@4.1.2: This package is no longer supported.npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supportednpm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supportednpm warn deprecated gauge@2.7.4: This package is no longer supported.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:12607) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblegyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:12623) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:12637) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensorgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:12651) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error code 7npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-26T14_54_50_500Z-debug-0.log
    2025-12-26 15:49:53.299	error	iobroker No alive host found which has the adapter rpi2 installed! No upload possible. Skipped.
    2025-12-26 15:49:51.273	error	iobroker host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 7
    @Gonzokalle
    Was genau wie installiert?
    Bitte das richtige Log anschauen, nicht den unvollständigen, chronologischen Kram aus dem Admin.
    Findet sich unter
    iob logs
    G 1 Antwort Letzte Antwort
    • mcm1957M mcm1957
      @Meister-Mopper sagte in RPI2 Adapter kann nicht installiert werden:
      @Thomas-Braun
      Bin etwas irritiert, bei mir läuft der Adapter v2.4.0 auf einem RPI 4B mit 8 GB fehlerfrei. Hat das etwas mit dem RPI 5 zu tun?
      Bin nicht sicher auf was du da rückgefragt hast.
      ABER der RPI 2 V3.x.x. ist für PI-OS TRIXIE während die V2.x.x für ältere OS vorgesehen ist.
      https://github.com/iobroker-community-adapters/ioBroker.rpi2#300-2025-11-28
      HomoranH Offline
      HomoranH Offline
      @gonzokalle
      @mcm1957 sagte in RPI2 Adapter kann nicht installiert werden:
      und was hast du?
        @Gonzokalle
        Findet sich unter
        iob logs
        Gonzokalle
        @Thomas-Braun
        Wenn ich im stable über Adapter rpi2 2.4.0 installiere kommt das:
        Jetzt richtig?
        $ iobroker add rpi2 auto --host RaspberryPi-Iobroker --debug
        NPM version: 10.9.4
        Installing iobroker.rpi2@2.4.0... (System call)
        > iobroker.rpi2@2.4.0 preinstall> sudo apt-get install -y libgpiod-dev || exit 0
        Paketlisten werden gelesen…
        Abhängigkeitsbaum wird aufgebaut…
        Statusinformationen werden eingelesen…
        libgpiod-dev ist schon die neueste Version (2.2.1-2+deb13u1).0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
        > @stoprocent/noble@1.19.1 install> node-gyp-build
        (node:15733) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
        > authenticate-pam@1.0.5 install> node-gyp rebuild
        (node:15748) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
        > node-dht-sensor@0.4.5 install> node-gyp configure
        (node:15762) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
        > opengpio@1.0.18 install> node-gyp rebuild
        (node:15776) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
        npm error code 7
        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-26T15_51_37_460Z-debug-0.log
        npm warn deprecated npmlog@4.1.2: This package is no longer supported.npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supportednpm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supportednpm warn deprecated gauge@2.7.4: This package is no longer supported.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:15733) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblegyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:15748) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:15762) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensorgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:15776) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error code 7npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-26T15_51_37_460Z-debug-0.log
        host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@2.4.0: 7
        ERROR: Process exited with code 25
          @gonzokalle
          und was hast du?
          Gonzokalle
          @Homoran
          Die 2.4.0 wird mir im stable angeboten.
          Über von NPM keine Ahnung welche Version.
          • G Gonzokalle
            @Homoran
            @Gonzokalle sagte in RPI2 Adapter kann nicht installiert werden:
            Ist die Version aus dem Latest/Beta-Repository.
            Du solltest diese Version installieren:
            latest: 3.0.2 for 25 days
              Gonzokalle
              @Thomas-Braun
              Ich hatte mich hieran gehalten.
              Wie kann ich denn die 3.0.2 installieren?
              -1
              • G Gonzokalle
                @Thomas-Braun
                In dem du genau die Version aus deinem obigen Schreenshot ranziehst.
                  Gonzokalle
                  @Thomas-Braun
                  Bitte mal etwas genauer über welchen Weg ich die 3.0.2 ranziehe.
                  Wenn ich es wüsste, hätte ich mir die Frage gerne gespart.
                  • G Gonzokalle
                    @Thomas-Braun
                    @Gonzokalle
                    • G Gonzokalle
                      @Thomas-Braun
                      HomoranH Offline
                      HomoranH Offline
                      @Thomas-Braun
                      was ist hier noch inverständlich?
                        @Gonzokalle
                        Gonzokalle
                        @Thomas-Braun
                        So hatte ich es schon gemacht.
                        Dachte nur, es währe falsch von mir, weil hier auch der Fehler auftritt wie mit der 2.4.0
                        2025-12-26 17:49:33.255 - info: host.RaspberryPi-Iobroker iobroker url iobroker.rpi2@latest --host RaspberryPi-Iobroker --debug
                        2025-12-26 17:49:34.066 - info: host.RaspberryPi-Iobroker iobroker install iobroker.rpi2@latest
                        2025-12-26 17:49:34.180 - info: host.RaspberryPi-Iobroker iobroker NPM version: 10.9.4
                        2025-12-26 17:49:34.182 - info: host.RaspberryPi-Iobroker iobroker Installing iobroker.rpi2@latest... (System call)
                        2025-12-26 17:49:36.779 - info: host.RaspberryPi-Iobroker iobroker npm warn deprecated npmlog@4.1.2: This package is no longer supported.npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                        2025-12-26 17:49:36.781 - info: host.RaspberryPi-Iobroker iobroker npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
                        2025-12-26 17:49:36.783 - info: host.RaspberryPi-Iobroker iobroker npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                        2025-12-26 17:49:36.800 - info: host.RaspberryPi-Iobroker iobroker npm warn deprecated gauge@2.7.4: This package is no longer supported.
                        2025-12-26 17:49:36.919 - info: host.RaspberryPi-Iobroker iobroker > iobroker.rpi2@3.0.2 preinstall
                        2025-12-26 17:49:36.920 - info: host.RaspberryPi-Iobroker iobroker > bash ./preinstall-check.sh
                        2025-12-26 17:49:36.927 - info: host.RaspberryPi-Iobroker iobroker Checking package: libgpiod-dev >= 2.2
                        2025-12-26 17:49:36.944 - info: host.RaspberryPi-Iobroker iobroker libgpiod-dev version OK: 2.2.1-2+deb13u1
                        2025-12-26 17:49:36.950 - info: host.RaspberryPi-Iobroker iobroker > @stoprocent/noble@1.19.1 install> node-gyp-build
                        2025-12-26 17:49:37.094 - info: host.RaspberryPi-Iobroker iobroker gyp info it worked if it ends with ok
                        2025-12-26 17:49:37.095 - info: host.RaspberryPi-Iobroker iobroker gyp info using node-gyp@7.1.2
                        2025-12-26 17:49:37.096 - info: host.RaspberryPi-Iobroker iobroker gyp info using node@22.21.0 | linux | arm64
                        2025-12-26 17:49:37.141 - info: host.RaspberryPi-Iobroker iobroker (node:19334) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
                        2025-12-26 17:49:37.182 - info: host.RaspberryPi-Iobroker iobroker gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
                        2025-12-26 17:49:37.358 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblegyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                        2025-12-26 17:49:37.363 - info: host.RaspberryPi-Iobroker iobroker
                        2025-12-26 17:49:37.364 - info: host.RaspberryPi-Iobroker iobroker > authenticate-pam@1.0.5 install> node-gyp rebuild
                        2025-12-26 17:49:37.432 - info: host.RaspberryPi-Iobroker iobroker gyp info it worked if it ends with ok
                        2025-12-26 17:49:37.433 - info: host.RaspberryPi-Iobroker iobroker gyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64
                        2025-12-26 17:49:37.477 - info: host.RaspberryPi-Iobroker iobroker (node:19348) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
                        2025-12-26 17:49:37.561 - info: host.RaspberryPi-Iobroker iobroker gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
                        2025-12-26 17:49:37.723 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! UNCAUGHT EXCEPTION
                        2025-12-26 17:49:37.723 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)
                        2025-12-26 17:49:37.724 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                        2025-12-26 17:49:37.728 - info: host.RaspberryPi-Iobroker iobroker > node-dht-sensor@0.4.5 install
                        2025-12-26 17:49:37.728 - info: host.RaspberryPi-Iobroker iobroker > node-gyp configure
                        2025-12-26 17:49:37.790 - info: host.RaspberryPi-Iobroker iobroker gyp info it worked if it ends with ok
                        2025-12-26 17:49:37.791 - info: host.RaspberryPi-Iobroker iobroker gyp info using node-gyp@7.1.2
                        2025-12-26 17:49:37.793 - info: host.RaspberryPi-Iobroker iobroker gyp info using node@22.21.0 | linux | arm64
                        2025-12-26 17:49:37.824 - info: host.RaspberryPi-Iobroker iobroker (node:19363) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
                        2025-12-26 17:49:37.863 - info: host.RaspberryPi-Iobroker iobroker gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
                        2025-12-26 17:49:38.035 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! UNCAUGHT EXCEPTION
                        2025-12-26 17:49:38.035 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)
                        2025-12-26 17:49:38.036 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensorgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                        2025-12-26 17:49:38.041 - info: host.RaspberryPi-Iobroker iobroker > opengpio@2.0.2 install
                        2025-12-26 17:49:38.042 - info: host.RaspberryPi-Iobroker iobroker > node-gyp rebuild
                        2025-12-26 17:49:38.103 - info: host.RaspberryPi-Iobroker iobroker gyp info it worked if it ends with ok
                        2025-12-26 17:49:38.104 - info: host.RaspberryPi-Iobroker iobroker gyp info using node-gyp@7.1.2
                        2025-12-26 17:49:38.104 - info: host.RaspberryPi-Iobroker iobroker gyp info using node@22.21.0 | linux | arm64
                        2025-12-26 17:49:38.143 - info: host.RaspberryPi-Iobroker iobroker (node:19377) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
                        2025-12-26 17:49:38.183 - info: host.RaspberryPi-Iobroker iobroker gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
                        2025-12-26 17:49:38.356 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)
                        2025-12-26 17:49:38.357 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                        2025-12-26 17:49:38.390 - info: host.RaspberryPi-Iobroker iobroker npm error code 7npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuild
                        2025-12-26 17:49:38.392 - info: host.RaspberryPi-Iobroker iobroker npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-26T16_49_34_254Z-debug-0.log
                        2025-12-26 17:49:38.401 - error: host.RaspberryPi-Iobroker iobroker npm warn deprecated npmlog@4.1.2: This package is no longer supported.npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supportednpm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supportednpm warn deprecated gauge@2.7.4: This package is no longer supported.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:19334) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblegyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:19348) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:19363) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensorgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:19377) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error code 7npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-26T16_49_34_254Z-debug-0.log
                        2025-12-26 17:49:38.402 - error: host.RaspberryPi-Iobroker iobroker host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 7
                        2025-12-26 17:49:39.415 - info: host.RaspberryPi-Iobroker iobroker exit 25
                        2025-12-26 17:49:39.603 - info: host.RaspberryPi-Iobroker iobroker upload rpi2 --debug
                        2025-12-26 17:49:40.414 - error: host.RaspberryPi-Iobroker iobroker No alive host found which has the adapter rpi2 installed! No upload possible. Skipped.
                        2025-12-26 17:49:41.327 - info: javascript.0 (10154) script.js.FBH_Steuerung: 388
                        2025-12-26 17:49:41.427 - info: host.RaspberryPi-Iobroker iobroker exit 0
                          @Thomas-Braun
                          Gonzokalle
                          @Homoran
                          Hatte dir ja schon geschrieben, dass ich es über NPM versucht habe.
                          • G Gonzokalle
                            @Thomas-Braun
                            Die Fehlermeldungen kommen aus einer anderen Ecke.
                            Was sagt
                            iob diag
                              Was sagt
                              iob diag
                              Gonzokalle
                              @Thomas-Braun
                              ```bash
                              Script v.2025-08-09
                              *** BASE SYSTEM ***
                              Operating System: Debian GNU/Linux 13 (trixie)
                              Press any key to continue
                               Static hostname: RaspberryPi-Iobroker
                                     Icon name: computer
                                        Kernel: Linux 6.12.47+rpt-rpi-2712
                                  Architecture: arm64
                              OS is similar to:
                              Model           : Raspberry Pi 5 Model B Rev 1.0
                              Docker          : false
                              Virtualization  : none
                              Kernel          : aarch64
                              Userland        : 64 bit
                              Systemuptime and Load:
                               18:06:55 up  3:48,  3 users,  load average: 0.60, 0.50, 0.51
                              CPU threads: 4
                              *** LIFE CYCLE STATUS ***
                              Operating System is the current Debian stable version codenamed 'trixie'!
                              *** RASPBERRY THROTTLING ***
                              Current issues:
                              Previously detected issues:
                              *** TIME AND TIMEZONES ***
                                             Local time: Fri 2025-12-26 18:06:55 CET
                                         Universal time: Fri 2025-12-26 17:06:55 UTC
                                               RTC time: Fri 2025-12-26 17:06:55
                                            NTP service: active
                                        RTC in local TZ: no
                              *** Users and Groups ***
                              User that called 'iob diag':
                              martin
                              HOME=/home/martin
                              GROUPS=martin adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
                              iobroker
                              HOME=/home/iobroker
                              SUDO_HOME=/home/martin
                              *** DISPLAY-SERVER SETUP ***
                              Display-Server:         true
                              Display-Manager:        * lightdm.service - Light Display Manager
                              Desktop:
                              Session:                tty
                              System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                              *** MEMORY ***
                              Mem:            8.5G        3.9G        1.5G         98M        3.5G        4.6G
                              Swap:           2.1G          0B        2.1G
                              Total:           10G        3.9G        3.6G
                              Active iob-Instances:   30
                                       8063 M total memory
                                       3690 M used memory
                                       3556 M active memory
                                       2322 M inactive memory
                                       1387 M free memory
                                        231 M buffer memory
                                       3062 M swap cache
                                       2047 M total swap
                                          0 M used swap
                                       2047 M free swap
                              top - 18:06:56 up  3:48,  3 users,  load average: 0.60, 0.50, 0.51
                              Tasks: 272 total,   1 running, 271 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  9.3 us,  2.3 sy,  0.0 ni, 88.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   8063.0 total,   1383.8 free,   3693.1 used,   3295.0 buff/cache
                              MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   4369.9 avail Mem
                              *** FAILED SERVICES ***
                              0 loaded units listed.
                              *** DMESG CRITICAL ERRORS ***
                              No critical errors detected
                              *** FILESYSTEM ***
                              udev           devtmpfs  3.9G     0  3.9G   0% /dev
                              tmpfs          tmpfs     1.6G   15M  1.6G   1% /run
                              /dev/nvme0n1p2 ext4      917G  9.9G  870G   2% /
                              tmpfs          tmpfs     4.0G  432K  4.0G   1% /dev/shm
                              tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                              tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                              /dev/nvme0n1p1 vfat      510M   86M  425M  17% /boot/firmware
                              tmpfs          tmpfs     4.0G  9.5M  4.0G   1% /tmp
                              tmpfs          tmpfs     807M  256K  807M   1% /run/user/1000
                              tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                              tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
                              [Fri Dec 26 14:18:18 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 iommu_dma_numa_policy=interleave smsc95xx.macaddr=2C:CF:67:82:17:A3 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=e4c2f3ef-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                              [Fri Dec 26 14:18:19 2025] EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
                              [Fri Dec 26 14:18:19 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6944274-f2f7-4644-96a4-213c3b367f5c ro with ordered data mode. Quota mode: none.
                              [Fri Dec 26 14:18:19 2025] EXT4-fs (nvme0n1p2): re-mounted d6944274-f2f7-4644-96a4-213c3b367f5c r/w.
                              Show mounted filesystems:
                              TARGET           SOURCE         FSTYPE OPTIONS
                              /                /dev/nvme0n1p2 ext4   rw,noatime
                              `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              2.5G    /var/
                              221M    /var/lib
                              216M    /var/cache
                              203M    /var/cache/apt
                              154M    /var/lib/apt
                              Archived and active journals take up 8M in the file system.
                              /opt/iobroker/backups:
                              33M     /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              883M    /opt/iobroker/iobroker-data/
                              497M    /opt/iobroker/iobroker-data/history
                              319M    /opt/iobroker/iobroker-data/files
                              67M     /opt/iobroker/iobroker-data/files/echarts.admin
                              61M     /opt/iobroker/iobroker-data/files/echarts
                              58M     /opt/iobroker/iobroker-data/objects.jsonl
                              26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                              26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                              24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
                              18M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.5fe9c7da.js.map
                              USB-Devices by-id:
                              /dev/serial/by-id/usb-SHK_JeeLink_LaCrosse-if00-port0
                              /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469419-if00
                              *** ZigBee Settings ***
                              HINT:
                              Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v22.21.0
                              /usr/bin/node           v22.21.0
                              /usr/bin/npm            10.9.4
                              /usr/bin/npx            10.9.4
                              /usr/bin/corepack       0.34.0
                              nodejs:
                                Installed: 22.21.0-1nodesource1
                                Candidate: 22.21.0-1nodesource1
                                Version table:
                               *** 22.21.0-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                                   22.20.0-1nodesource1 1001
                                   22.19.0-1nodesource1 1001
                                   22.18.0-1nodesource1 1001
                                   22.17.1-1nodesource1 1001
                                   22.17.0-1nodesource1 1001
                                   22.16.0-1nodesource1 1001
                                   22.15.1-1nodesource1 1001
                                   22.15.0-1nodesource1 1001
                                   22.14.0-1nodesource1 1001
                                   22.13.1-1nodesource1 1001
                                   22.13.0-1nodesource1 1001
                                   22.12.0-1nodesource1 1001
                                   22.11.0-1nodesource1 1001
                                   22.10.0-1nodesource1 1001
                                   22.9.0-1nodesource1 1001
                                   22.8.0-1nodesource1 1001
                                   22.7.0-1nodesource1 1001
                                   22.6.0-1nodesource1 1001
                                   22.5.1-1nodesource1 1001
                                   22.5.0-1nodesource1 1001
                                   22.4.1-1nodesource1 1001
                                   22.4.0-1nodesource1 1001
                                   22.3.0-1nodesource1 1001
                                   22.2.0-1nodesource1 1001
                                   22.1.0-1nodesource1 1001
                                   22.0.0-1nodesource1 1001
                                   20.19.2+dfsg-1 500
                                      500 http://deb.debian.org/debian trixie/main arm64 Packages
                              No problems detected
                              Errors in npm tree: 0
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              RaspberryPi-Iobroker RaspberryPi-Iobroker (version: 7.0.7, hostname: RaspberryPi-Iobroker, alive, uptime: 12512)
                              Core adapters versions
                              js-controller:  7.0.7
                              admin:          7.7.19
                              javascript:     9.0.11
                              nodejs modules from github:     1
                              +-- iobroker.eusec@2.0.3 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.eusec.git#f625cbb12aea40dcf6faf11a17d93328f069b753)
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : RaspberryPi-Iobroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.alexa2.0                 : alexa2                : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.backitup.0               : backitup              : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.device-watcher.0         : device-watcher        : RaspberryPi-Iobroker                     -  enabled
                                system.adapter.devices.0                : devices               : RaspberryPi-Iobroker                     - disabled
                              + system.adapter.echarts.0                : echarts               : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.energiefluss.0           : energiefluss          : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.eusec.0                  : eusec                 : RaspberryPi-Iobroker                     -  enabled
                                system.adapter.flot.0                   : flot                  : RaspberryPi-Iobroker                     - disabled
                              + system.adapter.fullybrowser.0           : fullybrowser          : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.history.0                : history               : RaspberryPi-Iobroker                     -  enabled
                                system.adapter.icons-icons8.0           : icons-icons8          : RaspberryPi-Iobroker                     - disabled
                              + system.adapter.iot.0                    : iot                   : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.iqontrol.0               : iqontrol              : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.iqontrol.1               : iqontrol              : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.javascript.0             : javascript            : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.jeelink.0                : jeelink               : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.mqtt.0                   : mqtt                  : RaspberryPi-Iobroker                     -  enabled, port: 1884, bind: 0.0.0.0
                                system.adapter.netatmo-crawler.0        : netatmo-crawler       : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.opendtu.0                : opendtu               : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.opendtu.1                : opendtu               : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.radar2.0                 : radar2                : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.reolink.0                : reolink               : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.reolink.1                : reolink               : RaspberryPi-Iobroker                     -  enabled
                                system.adapter.reolink.2                : reolink               : RaspberryPi-Iobroker                     - disabled
                              + system.adapter.reolink.3                : reolink               : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.shelly.0                 : shelly                : RaspberryPi-Iobroker                     -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.smartgarden.0            : smartgarden           : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.sonoff.0                 : sonoff                : RaspberryPi-Iobroker                     -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.telegram.0               : telegram              : RaspberryPi-Iobroker                     -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.terminal.0               : terminal              : RaspberryPi-Iobroker                     -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                              + system.adapter.web.0                    : web                   : RaspberryPi-Iobroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + system.adapter.wled.0                   : wled                  : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.zigbee.0                 : zigbee                : RaspberryPi-Iobroker                     -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469419-if00
                              + instance is alive
                              ioBroker-Repositories
                              Active repo(s): stable
                              Upgrade policy: none
                              Installed ioBroker-Adapters
                              Used repository: stable
                              Adapter    "admin"        : 7.7.19   , installed 7.7.19
                              Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                              Adapter    "backitup"     : 3.3.10   , installed 3.3.10
                              Adapter    "device-watcher": 2.13.1  , installed 2.13.1
                              Adapter    "devices"      : 1.2.8    , installed 1.2.8
                              Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                              Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                              Adapter    "eusec"        : 2.0.3    , installed 2.0.3
                              Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                              Adapter    "iot"          : 5.0.7    , installed 5.0.7
                              Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                              Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                              Adapter    "jeelink"      : 1.2.5    , installed 1.2.5
                              Controller "js-controller": 7.0.7    , installed 7.0.7
                              Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
                              Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                              Adapter    "radar2"       : 2.4.0    , installed 2.4.0
                              Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                              Adapter    "shelly"       : 10.4.1   , installed 10.4.1
                              Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                              Adapter    "socketio"     : 6.7.1    , installed 7.0.8
                              Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                              Adapter    "web"          : 7.0.8    , installed 7.0.8
                              Adapter    "wled"         : 0.7.2    , installed 0.7.2
                              Adapter    "ws"           : 2.6.2    , installed 3.0.19
                              Adapter    "zigbee"       : 3.1.5    , installed 3.2.5
                              Objects and States
                              Objects:        6937
                              States:         5878
                              lease stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                              The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                              https://forum.iobroker.net
                              Just copy and paste the Summary Page, including the ``` characters at start and end.
                              It helps us to help you!
                              * Some output is masked. For full results please use 'iob diag --unmask' *
                              W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                              Hit:1 http://deb.debian.org/debian trixie InRelease
                              Hit:2 http://deb.debian.org/debian trixie-updates InRelease
                              Hit:3 http://archive.raspberrypi.com/debian trixie InRelease
                              Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
                              Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                              Reading package lists...
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5984       1/init
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11320      981/sshd: /usr/sbin
                              tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       46426      10527/io.mqtt.0
                              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       47256      10689/io.shelly.0
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       46720      10707/io.sonoff.0
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       35794      7194/iobroker.js-co
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       38181      7194/iobroker.js-co
                              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11273      955/cupsd
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          2197       1/init
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          11322      981/sshd: /usr/sbin
                              tcp6       0      0 :::21                   :::*                    LISTEN      0          137963     14164/vsftpd
                              tcp6       0      0 :::8554                 :::*                    LISTEN      1001       45422      10444/go2rtc
                              tcp6       0      0 :::8555                 :::*                    LISTEN      1001       45424      10444/go2rtc
                              tcp6       0      0 :::1984                 :::*                    LISTEN      1001       45430      10444/go2rtc
                              tcp6       0      0 :::5900                 :::*                    LISTEN      985        11334      986/wayvnc
                              tcp6       0      0 :::3000                 :::*                    LISTEN      1001       44932      10450/io.fullybrows
                              tcp6       0      0 :::8088                 :::*                    LISTEN      1001       47309      10734/io.terminal.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       46779      10749/io.web.0
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       37290      7220/io.admin.0
                              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11272      955/cupsd
                              udp        0      0 0.0.0.0:58196           0.0.0.0:*                           101        888        696/avahi-daemon: r
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       47310      10768/io.wled.0
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        886        696/avahi-daemon: r
                              udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       48164      10587/io.radar2.0
                              udp        0      0 0.0.0.0:36940           0.0.0.0:*                           1001       44911      10429/io.eusec.0
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2196       1/init
                              udp6       0      0 :::5353                 :::*                                101        887        696/avahi-daemon: r
                              udp6       0      0 :::45056                :::*                                101        889        696/avahi-daemon: r
                              udp6       0      0 :::111                  :::*                                0          461        1/init
                              udp6       0      0 :::8555                 :::*                                1001       45425      10444/go2rtc
                              2025-12-26 18:04:11.412  - info: javascript.0 (10154) script.js.FBH_Steuerung: 581
                              2025-12-26 18:04:21.346  - info: javascript.0 (10154) script.js.FBH_Steuerung: 591
                              2025-12-26 18:04:29.182  - info: javascript.0 (10154) script.js.Cam_Reo_Alle_Trigger: Datei überschrieben: Terrasse.mp4
                              2025-12-26 18:04:31.291  - info: javascript.0 (10154) script.js.FBH_Steuerung: 584
                              2025-12-26 18:04:33.183  - info: javascript.0 (10154) script.js.Cam_Reo_Alle_Trigger: Datei überschrieben: Terrasse.jpg
                              2025-12-26 18:04:41.424  - info: javascript.0 (10154) script.js.FBH_Steuerung: 574
                              2025-12-26 18:04:51.367  - info: javascript.0 (10154) script.js.FBH_Steuerung: 572
                              2025-12-26 18:05:01.185  - info: javascript.0 (10154) script.js.Cam_Reo_Alle_Trigger: Datei überschrieben: Terrasse.mp4
                              2025-12-26 18:05:01.341  - info: javascript.0 (10154) script.js.FBH_Steuerung: 863
                              2025-12-26 18:05:11.365  - info: javascript.0 (10154) script.js.FBH_Steuerung: 820
                              2025-12-26 18:05:21.387  - info: javascript.0 (10154) script.js.FBH_Steuerung: 622
                              2025-12-26 18:05:31.307  - info: javascript.0 (10154) script.js.FBH_Steuerung: 484
                              2025-12-26 18:05:41.462  - info: javascript.0 (10154) script.js.FBH_Steuerung: 500
                              2025-12-26 18:05:50.011  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 21134
                              2025-12-26 18:05:51.264  - info: javascript.0 (10154) script.js.FBH_Steuerung: 482
                              2025-12-26 18:05:54.244  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 21134 terminated with code 0 (NO_ERROR)
                              2025-12-26 18:06:01.344  - info: javascript.0 (10154) script.js.FBH_Steuerung: 453
                              2025-12-26 18:06:11.384  - info: javascript.0 (10154) script.js.FBH_Steuerung: 446
                              2025-12-26 18:06:21.322  - info: javascript.0 (10154) script.js.FBH_Steuerung: 437
                              2025-12-26 18:06:31.313  - info: javascript.0 (10154) script.js.FBH_Steuerung: 441
                              2025-12-26 18:06:41.436  - info: javascript.0 (10154) script.js.FBH_Steuerung: 442
                              2025-12-26 18:06:51.339  - info: javascript.0 (10154) script.js.FBH_Steuerung: 438
                              2025-12-26 18:07:01.364  - info: javascript.0 (10154) script.js.FBH_Steuerung: 441
                              2025-12-26 18:07:11.454  - info: javascript.0 (10154) script.js.FBH_Steuerung: 450
                              2025-12-26 18:07:21.287  - info: javascript.0 (10154) script.js.FBH_Steuerung: 457
                              iob diag has finished.
                              • G Gonzokalle
                                @Thomas-Braun
                                ```bash
                                Script v.2025-08-09
                                *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                                OS is similar to:
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64 bit
                                CPU threads: 4
                                Current issues:
                                              NTP service: active
                                          RTC in local TZ: no
                                martin
                                HOME=/home/martin
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Session:                tty
                                *** MEMORY ***
                                Swap:           2.1G          0B        2.1G
                                         8063 M total memory
                                         3690 M used memory
                                         1387 M free memory
                                          231 M buffer memory
                                         3062 M swap cache
                                         2047 M total swap
                                            0 M used swap
                                         2047 M free swap
                                *** FILESYSTEM ***
                                /var:
                                2.5G    /var/
                                221M    /var/lib
                                216M    /var/cache
                                203M    /var/cache/apt
                                154M    /var/lib/apt
                                USB-Devices by-id:
                                HINT:
                                zigbee.X
                                Extended Pan ID:
                                *** MASKED ***
                                Pan ID:
                                *** MASKED ***
                                Channel:
                                *** MASKED ***
                                Network Key:
                                *** MASKED ***
                                /usr/bin/npm            10.9.4
                                /usr/bin/npx            10.9.4
                                nodejs:
                                  Version table:
                                     20.19.2+dfsg-1 500
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin:          7.7.19
                                javascript:     9.0.11
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        6937
                                States:         5878
                                Pending Updates: 0
                                Ausschalten.
                                Dann schau dir
                                cd /opt/iobroker && npm ls
                                an.
                                  Ausschalten.
                                  Dann schau dir
                                  an.
                                  Gonzokalle
                                  @Thomas-Braun
                                  martin@RaspberryPi-Iobroker:~ $ cd /opt/iobroker && npm ls
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  ├── @iobroker-javascript.0/node-wol@npm:node-wol@0.1.1
                                  ├── @iobroker-javascript.0/wake_on_lan@npm:wake_on_lan@1.0.0
                                  ├── @stoprocent/bluetooth-hci-socket@1.5.2 extraneous
                                  ├── @types/w3c-web-usb@1.0.13 extraneous
                                  ├── @yarnpkg/lockfile@1.1.0 extraneous
                                  ├── chalk@4.1.2 extraneous
                                  ├── find-yarn-workspace-root@2.0.0 extraneous
                                  ├── has-flag@4.0.0 extraneous
                                  ├── iobroker.admin@7.7.19
                                  ├── iobroker.alexa2@3.27.4
                                  ├── iobroker.backitup@3.3.10
                                  ├── iobroker.device-watcher@2.13.1
                                  ├── iobroker.devices@1.2.8
                                  ├── iobroker.echarts@1.9.2
                                  ├── iobroker.energiefluss@3.6.2
                                  ├── iobroker.eusec@2.0.3 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.eusec.git#f625cbb12aea40dcf6faf11a17d93328f069b753)
                                  ├── iobroker.flot@1.12.0
                                  ├── iobroker.fullybrowser@3.1.2
                                  ├── iobroker.history@3.0.1
                                  ├── iobroker.icons-icons8@0.0.1
                                  ├── iobroker.iot@5.0.7
                                  ├── iobroker.iqontrol@3.0.0
                                  ├── iobroker.javascript@9.0.11
                                  ├── iobroker.jeelink@1.2.5
                                  ├── iobroker.js-controller@7.0.7
                                  ├── iobroker.mqtt@6.1.4
                                  ├── iobroker.netatmo-crawler@1.1.0
                                  ├── iobroker.opendtu@3.1.0
                                  ├── iobroker.radar2@2.4.0
                                  ├── iobroker.reolink@1.2.3
                                  ├── iobroker.shelly@10.4.1
                                  ├── iobroker.smartgarden@2.0.1
                                  ├── iobroker.sonoff@3.2.1
                                  ├── iobroker.telegram@4.1.0
                                  ├── iobroker.terminal@1.0.0
                                  ├── iobroker.web@7.0.8
                                  ├── iobroker.wled@0.7.2
                                  ├── iobroker.zigbee@3.2.5
                                  ├── is-docker@2.2.1 extraneous
                                  ├── is-wsl@2.2.0 extraneous
                                  ├── json-stable-stringify@1.3.0 extraneous
                                  ├── jsonify@0.0.1 extraneous
                                  ├── klaw-sync@6.0.0 extraneous
                                  ├── node-addon-api@8.5.0 extraneous
                                  ├── open@7.4.2 extraneous
                                  ├── patch-package@8.0.1 extraneous
                                  ├── slash@2.0.0 extraneous
                                  ├── supports-color@7.2.0 extraneous
                                  ├── tmp@0.2.5 extraneous
                                  ├── usb@2.16.0 extraneous
                                  └── yaml@2.8.2 extraneous
                                  • G Gonzokalle
                                    @Thomas-Braun
                                    @Gonzokalle
                                    Da geht der Build von (mehreren) Paketen in die Hose.
                                    stoprocent/noble:
                                    Ich meine mich erinnern zu können das es damit unlängst auch bei anderen zu Problemen kam. Finde den Thread aber jetzt nicht.
                                    Nächster Build-Error ist bei node-dht-sensor:
                                    1. Build-Error:
                                    npm error code 7
                                    Musste mal schauen, wo diese Module verwendet werden. Den enstprechenden Adapter dann reinstallieren oder neubauen.
                                    • HomoranH Offline
                                      HomoranH Offline
                                      noble, dht und opengpio klingen verdächtig nach Raspi
                                        @Gonzokalle
                                        stoprocent/noble:
                                        1. Build-Error:
                                        npm error code 7
                                        Gonzokalle
                                        @Thomas-Braun
                                        Erstmal Danke für deine Hilfe.
                                        Bin verwundert, dass so viel nicht passt.
                                        Wie kann das kommen?
                                        Ich habe heute Mittag Trixie neu aufgespielt und danach mit dem Backup alle Adapter neu erstellen lassen.
                                        Bis auf dem PRI2 habe null Probleme im Log.
                                          Gonzokalle
                                          @Homoran
                                          Meinst du durch den RPI2 Adapter oder das der Raspi einen weg hat?
