  4. RPI2 Adapter kann nicht installiert werden
    6.4k
167 Beiträge 11 Kommentatoren 13.2k Aufrufe 10 Beobachtet
    Sackbauer100
    Ich fahre V2.0.0 ln Trixie mit Verwendung der GPIO.
      @Sascha-Hartmann
      Adapter -Experten Option - Installation aus NPM
      Gonzokalle
      @Thomas-Braun
      Hallo, ich habe seit heute Trixi auf dem 5er Raspi.
      RPI2 über Adapter ging nicht zu installieren.
      RPI2 über Adapter / von NPM ginge es ebenfalls nicht zu installieren.
      Nun bin ich etwas ratlos.
      host.RaspberryPi-Iobroker
      2025-12-26 15:55:06.761	error	iobroker No alive host found which has the adapter rpi2 installed! No upload possible. Skipped.
      2025-12-26 15:55:04.676	error	iobroker host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 7
      2025-12-26 15:55:04.675	error	iobroker npm warn deprecated npmlog@4.1.2: This package is no longer supported.npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supportednpm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supportednpm warn deprecated gauge@2.7.4: This package is no longer supported.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:12607) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblegyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:12623) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:12637) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensorgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:12651) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error code 7npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-26T14_54_50_500Z-debug-0.log
      2025-12-26 15:49:53.299	error	iobroker No alive host found which has the adapter rpi2 installed! No upload possible. Skipped.
      2025-12-26 15:49:51.273	error	iobroker host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 7
      • G Gonzokalle
        @Thomas-Braun
        @Gonzokalle
        Was genau wie installiert?
        Bitte das richtige Log anschauen, nicht den unvollständigen, chronologischen Kram aus dem Admin.
        Findet sich unter
        iob logs
        G 1 Antwort Letzte Antwort
        • mcm1957M mcm1957
          @Meister-Mopper sagte in RPI2 Adapter kann nicht installiert werden:
          @Thomas-Braun
          Bin etwas irritiert, bei mir läuft der Adapter v2.4.0 auf einem RPI 4B mit 8 GB fehlerfrei. Hat das etwas mit dem RPI 5 zu tun?
          Bin nicht sicher auf was du da rückgefragt hast.
          ABER der RPI 2 V3.x.x. ist für PI-OS TRIXIE während die V2.x.x für ältere OS vorgesehen ist.
          https://github.com/iobroker-community-adapters/ioBroker.rpi2#300-2025-11-28
          @gonzokalle
          @mcm1957 sagte in RPI2 Adapter kann nicht installiert werden:
          und was hast du?
            @Gonzokalle
            Findet sich unter
            iob logs
            Gonzokalle
            @Thomas-Braun
            Wenn ich im stable über Adapter rpi2 2.4.0 installiere kommt das:
            Jetzt richtig?
            $ iobroker add rpi2 auto --host RaspberryPi-Iobroker --debug
            NPM version: 10.9.4
            Installing iobroker.rpi2@2.4.0... (System call)
            > iobroker.rpi2@2.4.0 preinstall> sudo apt-get install -y libgpiod-dev || exit 0
            Paketlisten werden gelesen…
            Abhängigkeitsbaum wird aufgebaut…
            Statusinformationen werden eingelesen…
            libgpiod-dev ist schon die neueste Version (2.2.1-2+deb13u1).0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
            > @stoprocent/noble@1.19.1 install> node-gyp-build
            (node:15733) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
            > authenticate-pam@1.0.5 install> node-gyp rebuild
            (node:15748) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
            > node-dht-sensor@0.4.5 install> node-gyp configure
            (node:15762) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
            > opengpio@1.0.18 install> node-gyp rebuild
            (node:15776) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
            npm error code 7
            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-26T15_51_37_460Z-debug-0.log
            npm warn deprecated npmlog@4.1.2: This package is no longer supported.npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supportednpm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supportednpm warn deprecated gauge@2.7.4: This package is no longer supported.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:15733) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblegyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:15748) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:15762) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensorgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:15776) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error code 7npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-26T15_51_37_460Z-debug-0.log
            host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@2.4.0: 7
            ERROR: Process exited with code 25
              @gonzokalle
              und was hast du?
              Gonzokalle
              @Homoran
              Die 2.4.0 wird mir im stable angeboten.
              Über von NPM keine Ahnung welche Version.
              • G Gonzokalle
                @Homoran
                @Gonzokalle sagte in RPI2 Adapter kann nicht installiert werden:
                Ist die Version aus dem Latest/Beta-Repository.
                Du solltest diese Version installieren:
                latest: 3.0.2 for 25 days
                  Gonzokalle
                  @Thomas-Braun
                  Ich hatte mich hieran gehalten.
                  Wie kann ich denn die 3.0.2 installieren?
                  -1
                  • G Gonzokalle
                    @Thomas-Braun
                    In dem du genau die Version aus deinem obigen Schreenshot ranziehst.
                      Gonzokalle
                      @Thomas-Braun
                      Bitte mal etwas genauer über welchen Weg ich die 3.0.2 ranziehe.
                      Wenn ich es wüsste, hätte ich mir die Frage gerne gespart.
                      • G Gonzokalle
                        @Thomas-Braun
                        @Gonzokalle
                        • G Gonzokalle
                          @Thomas-Braun
                          @Thomas-Braun
                          was ist hier noch inverständlich?
                            @Gonzokalle
                            Gonzokalle
                            @Thomas-Braun
                            So hatte ich es schon gemacht.
                            Dachte nur, es währe falsch von mir, weil hier auch der Fehler auftritt wie mit der 2.4.0
                            2025-12-26 17:49:33.255 - info: host.RaspberryPi-Iobroker iobroker url iobroker.rpi2@latest --host RaspberryPi-Iobroker --debug
                            2025-12-26 17:49:34.066 - info: host.RaspberryPi-Iobroker iobroker install iobroker.rpi2@latest
                            2025-12-26 17:49:34.180 - info: host.RaspberryPi-Iobroker iobroker NPM version: 10.9.4
                            2025-12-26 17:49:34.182 - info: host.RaspberryPi-Iobroker iobroker Installing iobroker.rpi2@latest... (System call)
                            2025-12-26 17:49:36.779 - info: host.RaspberryPi-Iobroker iobroker npm warn deprecated npmlog@4.1.2: This package is no longer supported.npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                            2025-12-26 17:49:36.781 - info: host.RaspberryPi-Iobroker iobroker npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
                            2025-12-26 17:49:36.783 - info: host.RaspberryPi-Iobroker iobroker npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                            2025-12-26 17:49:36.800 - info: host.RaspberryPi-Iobroker iobroker npm warn deprecated gauge@2.7.4: This package is no longer supported.
                            2025-12-26 17:49:36.919 - info: host.RaspberryPi-Iobroker iobroker > iobroker.rpi2@3.0.2 preinstall
                            2025-12-26 17:49:36.920 - info: host.RaspberryPi-Iobroker iobroker > bash ./preinstall-check.sh
                            2025-12-26 17:49:36.927 - info: host.RaspberryPi-Iobroker iobroker Checking package: libgpiod-dev >= 2.2
                            2025-12-26 17:49:36.944 - info: host.RaspberryPi-Iobroker iobroker libgpiod-dev version OK: 2.2.1-2+deb13u1
                            2025-12-26 17:49:36.950 - info: host.RaspberryPi-Iobroker iobroker > @stoprocent/noble@1.19.1 install> node-gyp-build
                            2025-12-26 17:49:37.094 - info: host.RaspberryPi-Iobroker iobroker gyp info it worked if it ends with ok
                            2025-12-26 17:49:37.095 - info: host.RaspberryPi-Iobroker iobroker gyp info using node-gyp@7.1.2
                            2025-12-26 17:49:37.096 - info: host.RaspberryPi-Iobroker iobroker gyp info using node@22.21.0 | linux | arm64
                            2025-12-26 17:49:37.141 - info: host.RaspberryPi-Iobroker iobroker (node:19334) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
                            2025-12-26 17:49:37.182 - info: host.RaspberryPi-Iobroker iobroker gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
                            2025-12-26 17:49:37.358 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblegyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                            2025-12-26 17:49:37.363 - info: host.RaspberryPi-Iobroker iobroker
                            2025-12-26 17:49:37.364 - info: host.RaspberryPi-Iobroker iobroker > authenticate-pam@1.0.5 install> node-gyp rebuild
                            2025-12-26 17:49:37.432 - info: host.RaspberryPi-Iobroker iobroker gyp info it worked if it ends with ok
                            2025-12-26 17:49:37.433 - info: host.RaspberryPi-Iobroker iobroker gyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64
                            2025-12-26 17:49:37.477 - info: host.RaspberryPi-Iobroker iobroker (node:19348) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
                            2025-12-26 17:49:37.561 - info: host.RaspberryPi-Iobroker iobroker gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
                            2025-12-26 17:49:37.723 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! UNCAUGHT EXCEPTION
                            2025-12-26 17:49:37.723 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)
                            2025-12-26 17:49:37.724 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                            2025-12-26 17:49:37.728 - info: host.RaspberryPi-Iobroker iobroker > node-dht-sensor@0.4.5 install
                            2025-12-26 17:49:37.728 - info: host.RaspberryPi-Iobroker iobroker > node-gyp configure
                            2025-12-26 17:49:37.790 - info: host.RaspberryPi-Iobroker iobroker gyp info it worked if it ends with ok
                            2025-12-26 17:49:37.791 - info: host.RaspberryPi-Iobroker iobroker gyp info using node-gyp@7.1.2
                            2025-12-26 17:49:37.793 - info: host.RaspberryPi-Iobroker iobroker gyp info using node@22.21.0 | linux | arm64
                            2025-12-26 17:49:37.824 - info: host.RaspberryPi-Iobroker iobroker (node:19363) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
                            2025-12-26 17:49:37.863 - info: host.RaspberryPi-Iobroker iobroker gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
                            2025-12-26 17:49:38.035 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! UNCAUGHT EXCEPTION
                            2025-12-26 17:49:38.035 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)
                            2025-12-26 17:49:38.036 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensorgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                            2025-12-26 17:49:38.041 - info: host.RaspberryPi-Iobroker iobroker > opengpio@2.0.2 install
                            2025-12-26 17:49:38.042 - info: host.RaspberryPi-Iobroker iobroker > node-gyp rebuild
                            2025-12-26 17:49:38.103 - info: host.RaspberryPi-Iobroker iobroker gyp info it worked if it ends with ok
                            2025-12-26 17:49:38.104 - info: host.RaspberryPi-Iobroker iobroker gyp info using node-gyp@7.1.2
                            2025-12-26 17:49:38.104 - info: host.RaspberryPi-Iobroker iobroker gyp info using node@22.21.0 | linux | arm64
                            2025-12-26 17:49:38.143 - info: host.RaspberryPi-Iobroker iobroker (node:19377) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
                            2025-12-26 17:49:38.183 - info: host.RaspberryPi-Iobroker iobroker gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
                            2025-12-26 17:49:38.356 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)
                            2025-12-26 17:49:38.357 - info: host.RaspberryPi-Iobroker iobroker gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                            2025-12-26 17:49:38.390 - info: host.RaspberryPi-Iobroker iobroker npm error code 7npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuild
                            2025-12-26 17:49:38.392 - info: host.RaspberryPi-Iobroker iobroker npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-26T16_49_34_254Z-debug-0.log
                            2025-12-26 17:49:38.401 - error: host.RaspberryPi-Iobroker iobroker npm warn deprecated npmlog@4.1.2: This package is no longer supported.npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supportednpm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supportednpm warn deprecated gauge@2.7.4: This package is no longer supported.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:19334) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblegyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:19348) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:19363) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensorgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@22.21.0 | linux | arm64(node:19377) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.47+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error code 7npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-26T16_49_34_254Z-debug-0.log
                            2025-12-26 17:49:38.402 - error: host.RaspberryPi-Iobroker iobroker host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 7
                            2025-12-26 17:49:39.415 - info: host.RaspberryPi-Iobroker iobroker exit 25
                            2025-12-26 17:49:39.603 - info: host.RaspberryPi-Iobroker iobroker upload rpi2 --debug
                            2025-12-26 17:49:40.414 - error: host.RaspberryPi-Iobroker iobroker No alive host found which has the adapter rpi2 installed! No upload possible. Skipped.
                            2025-12-26 17:49:41.327 - info: javascript.0 (10154) script.js.FBH_Steuerung: 388
                            2025-12-26 17:49:41.427 - info: host.RaspberryPi-Iobroker iobroker exit 0
                              @Thomas-Braun
                              Gonzokalle
                              @Homoran
                              Hatte dir ja schon geschrieben, dass ich es über NPM versucht habe.
                              • G Gonzokalle
                                @Thomas-Braun
                                Die Fehlermeldungen kommen aus einer anderen Ecke.
                                Was sagt
                                iob diag
                                  Was sagt
                                  iob diag
                                  Gonzokalle
                                  @Thomas-Braun
                                  ```bash
                                  Script v.2025-08-09
                                  *** BASE SYSTEM ***
                                  Operating System: Debian GNU/Linux 13 (trixie)
                                  Press any key to continue
                                   Static hostname: RaspberryPi-Iobroker
                                         Icon name: computer
                                            Kernel: Linux 6.12.47+rpt-rpi-2712
                                      Architecture: arm64
                                  OS is similar to:
                                  Model           : Raspberry Pi 5 Model B Rev 1.0
                                  Docker          : false
                                  Virtualization  : none
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                  Systemuptime and Load:
                                   18:06:55 up  3:48,  3 users,  load average: 0.60, 0.50, 0.51
                                  CPU threads: 4
                                  *** LIFE CYCLE STATUS ***
                                  Operating System is the current Debian stable version codenamed 'trixie'!
                                  *** RASPBERRY THROTTLING ***
                                  Current issues:
                                  Previously detected issues:
                                  *** TIME AND TIMEZONES ***
                                                 Local time: Fri 2025-12-26 18:06:55 CET
                                             Universal time: Fri 2025-12-26 17:06:55 UTC
                                                   RTC time: Fri 2025-12-26 17:06:55
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** Users and Groups ***
                                  User that called 'iob diag':
                                  martin
                                  HOME=/home/martin
                                  GROUPS=martin adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
                                  iobroker
                                  HOME=/home/iobroker
                                  SUDO_HOME=/home/martin
                                  *** DISPLAY-SERVER SETUP ***
                                  Display-Server:         true
                                  Display-Manager:        * lightdm.service - Light Display Manager
                                  Desktop:
                                  Session:                tty
                                  System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                                  *** MEMORY ***
                                  Mem:            8.5G        3.9G        1.5G         98M        3.5G        4.6G
                                  Swap:           2.1G          0B        2.1G
                                  Total:           10G        3.9G        3.6G
                                  Active iob-Instances:   30
                                           8063 M total memory
                                           3690 M used memory
                                           3556 M active memory
                                           2322 M inactive memory
                                           1387 M free memory
                                            231 M buffer memory
                                           3062 M swap cache
                                           2047 M total swap
                                              0 M used swap
                                           2047 M free swap
                                  top - 18:06:56 up  3:48,  3 users,  load average: 0.60, 0.50, 0.51
                                  Tasks: 272 total,   1 running, 271 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  9.3 us,  2.3 sy,  0.0 ni, 88.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :   8063.0 total,   1383.8 free,   3693.1 used,   3295.0 buff/cache
                                  MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   4369.9 avail Mem
                                  *** FAILED SERVICES ***
                                  0 loaded units listed.
                                  *** DMESG CRITICAL ERRORS ***
                                  No critical errors detected
                                  *** FILESYSTEM ***
                                  udev           devtmpfs  3.9G     0  3.9G   0% /dev
                                  tmpfs          tmpfs     1.6G   15M  1.6G   1% /run
                                  /dev/nvme0n1p2 ext4      917G  9.9G  870G   2% /
                                  tmpfs          tmpfs     4.0G  432K  4.0G   1% /dev/shm
                                  tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                  tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                                  /dev/nvme0n1p1 vfat      510M   86M  425M  17% /boot/firmware
                                  tmpfs          tmpfs     4.0G  9.5M  4.0G   1% /tmp
                                  tmpfs          tmpfs     807M  256K  807M   1% /run/user/1000
                                  tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                                  tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
                                  [Fri Dec 26 14:18:18 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 iommu_dma_numa_policy=interleave smsc95xx.macaddr=2C:CF:67:82:17:A3 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=e4c2f3ef-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                                  [Fri Dec 26 14:18:19 2025] EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
                                  [Fri Dec 26 14:18:19 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6944274-f2f7-4644-96a4-213c3b367f5c ro with ordered data mode. Quota mode: none.
                                  [Fri Dec 26 14:18:19 2025] EXT4-fs (nvme0n1p2): re-mounted d6944274-f2f7-4644-96a4-213c3b367f5c r/w.
                                  Show mounted filesystems:
                                  TARGET           SOURCE         FSTYPE OPTIONS
                                  /                /dev/nvme0n1p2 ext4   rw,noatime
                                  `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                  /var:
                                  2.5G    /var/
                                  221M    /var/lib
                                  216M    /var/cache
                                  203M    /var/cache/apt
                                  154M    /var/lib/apt
                                  Archived and active journals take up 8M in the file system.
                                  /opt/iobroker/backups:
                                  33M     /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  883M    /opt/iobroker/iobroker-data/
                                  497M    /opt/iobroker/iobroker-data/history
                                  319M    /opt/iobroker/iobroker-data/files
                                  67M     /opt/iobroker/iobroker-data/files/echarts.admin
                                  61M     /opt/iobroker/iobroker-data/files/echarts
                                  58M     /opt/iobroker/iobroker-data/objects.jsonl
                                  26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                                  26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                                  24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
                                  18M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.5fe9c7da.js.map
                                  USB-Devices by-id:
                                  /dev/serial/by-id/usb-SHK_JeeLink_LaCrosse-if00-port0
                                  /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469419-if00
                                  *** ZigBee Settings ***
                                  HINT:
                                  Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                  zigbee.X
                                  Extended Pan ID:
                                  *** MASKED ***
                                  Pan ID:
                                  *** MASKED ***
                                  Channel:
                                  *** MASKED ***
                                  Network Key:
                                  *** MASKED ***
                                  *** NodeJS-Installation ***
                                  /usr/bin/nodejs         v22.21.0
                                  /usr/bin/node           v22.21.0
                                  /usr/bin/npm            10.9.4
                                  /usr/bin/npx            10.9.4
                                  /usr/bin/corepack       0.34.0
                                  nodejs:
                                    Installed: 22.21.0-1nodesource1
                                    Candidate: 22.21.0-1nodesource1
                                    Version table:
                                   *** 22.21.0-1nodesource1 1001
                                          500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                                       22.20.0-1nodesource1 1001
                                       22.19.0-1nodesource1 1001
                                       22.18.0-1nodesource1 1001
                                       22.17.1-1nodesource1 1001
                                       22.17.0-1nodesource1 1001
                                       22.16.0-1nodesource1 1001
                                       22.15.1-1nodesource1 1001
                                       22.15.0-1nodesource1 1001
                                       22.14.0-1nodesource1 1001
                                       22.13.1-1nodesource1 1001
                                       22.13.0-1nodesource1 1001
                                       22.12.0-1nodesource1 1001
                                       22.11.0-1nodesource1 1001
                                       22.10.0-1nodesource1 1001
                                       22.9.0-1nodesource1 1001
                                       22.8.0-1nodesource1 1001
                                       22.7.0-1nodesource1 1001
                                       22.6.0-1nodesource1 1001
                                       22.5.1-1nodesource1 1001
                                       22.5.0-1nodesource1 1001
                                       22.4.1-1nodesource1 1001
                                       22.4.0-1nodesource1 1001
                                       22.3.0-1nodesource1 1001
                                       22.2.0-1nodesource1 1001
                                       22.1.0-1nodesource1 1001
                                       22.0.0-1nodesource1 1001
                                       20.19.2+dfsg-1 500
                                          500 http://deb.debian.org/debian trixie/main arm64 Packages
                                  No problems detected
                                  Errors in npm tree: 0
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  RaspberryPi-Iobroker RaspberryPi-Iobroker (version: 7.0.7, hostname: RaspberryPi-Iobroker, alive, uptime: 12512)
                                  Core adapters versions
                                  js-controller:  7.0.7
                                  admin:          7.7.19
                                  javascript:     9.0.11
                                  nodejs modules from github:     1
                                  +-- iobroker.eusec@2.0.3 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.eusec.git#f625cbb12aea40dcf6faf11a17d93328f069b753)
                                  Adapter State
                                  + system.adapter.admin.0                  : admin                 : RaspberryPi-Iobroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  + system.adapter.alexa2.0                 : alexa2                : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.backitup.0               : backitup              : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.device-watcher.0         : device-watcher        : RaspberryPi-Iobroker                     -  enabled
                                    system.adapter.devices.0                : devices               : RaspberryPi-Iobroker                     - disabled
                                  + system.adapter.echarts.0                : echarts               : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.energiefluss.0           : energiefluss          : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.eusec.0                  : eusec                 : RaspberryPi-Iobroker                     -  enabled
                                    system.adapter.flot.0                   : flot                  : RaspberryPi-Iobroker                     - disabled
                                  + system.adapter.fullybrowser.0           : fullybrowser          : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.history.0                : history               : RaspberryPi-Iobroker                     -  enabled
                                    system.adapter.icons-icons8.0           : icons-icons8          : RaspberryPi-Iobroker                     - disabled
                                  + system.adapter.iot.0                    : iot                   : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.iqontrol.0               : iqontrol              : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.iqontrol.1               : iqontrol              : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.javascript.0             : javascript            : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.jeelink.0                : jeelink               : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.mqtt.0                   : mqtt                  : RaspberryPi-Iobroker                     -  enabled, port: 1884, bind: 0.0.0.0
                                    system.adapter.netatmo-crawler.0        : netatmo-crawler       : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.opendtu.0                : opendtu               : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.opendtu.1                : opendtu               : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.radar2.0                 : radar2                : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.reolink.0                : reolink               : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.reolink.1                : reolink               : RaspberryPi-Iobroker                     -  enabled
                                    system.adapter.reolink.2                : reolink               : RaspberryPi-Iobroker                     - disabled
                                  + system.adapter.reolink.3                : reolink               : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.shelly.0                 : shelly                : RaspberryPi-Iobroker                     -  enabled, port: 1882, bind: 0.0.0.0
                                  + system.adapter.smartgarden.0            : smartgarden           : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.sonoff.0                 : sonoff                : RaspberryPi-Iobroker                     -  enabled, port: 1883, bind: 0.0.0.0
                                  + system.adapter.telegram.0               : telegram              : RaspberryPi-Iobroker                     -  enabled, port: 8443, bind: 0.0.0.0
                                  + system.adapter.terminal.0               : terminal              : RaspberryPi-Iobroker                     -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                  + system.adapter.web.0                    : web                   : RaspberryPi-Iobroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  + system.adapter.wled.0                   : wled                  : RaspberryPi-Iobroker                     -  enabled
                                  + system.adapter.zigbee.0                 : zigbee                : RaspberryPi-Iobroker                     -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469419-if00
                                  + instance is alive
                                  ioBroker-Repositories
                                  Active repo(s): stable
                                  Upgrade policy: none
                                  Installed ioBroker-Adapters
                                  Used repository: stable
                                  Adapter    "admin"        : 7.7.19   , installed 7.7.19
                                  Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                                  Adapter    "backitup"     : 3.3.10   , installed 3.3.10
                                  Adapter    "device-watcher": 2.13.1  , installed 2.13.1
                                  Adapter    "devices"      : 1.2.8    , installed 1.2.8
                                  Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                                  Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                                  Adapter    "eusec"        : 2.0.3    , installed 2.0.3
                                  Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                                  Adapter    "iot"          : 5.0.7    , installed 5.0.7
                                  Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                                  Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                                  Adapter    "jeelink"      : 1.2.5    , installed 1.2.5
                                  Controller "js-controller": 7.0.7    , installed 7.0.7
                                  Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
                                  Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                                  Adapter    "radar2"       : 2.4.0    , installed 2.4.0
                                  Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                                  Adapter    "shelly"       : 10.4.1   , installed 10.4.1
                                  Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                                  Adapter    "socketio"     : 6.7.1    , installed 7.0.8
                                  Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                                  Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                  Adapter    "web"          : 7.0.8    , installed 7.0.8
                                  Adapter    "wled"         : 0.7.2    , installed 0.7.2
                                  Adapter    "ws"           : 2.6.2    , installed 3.0.19
                                  Adapter    "zigbee"       : 3.1.5    , installed 3.2.5
                                  Objects and States
                                  Objects:        6937
                                  States:         5878
                                  lease stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                                  The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                                  https://forum.iobroker.net
                                  Just copy and paste the Summary Page, including the ``` characters at start and end.
                                  It helps us to help you!
                                  * Some output is masked. For full results please use 'iob diag --unmask' *
                                  W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                                  Hit:1 http://deb.debian.org/debian trixie InRelease
                                  Hit:2 http://deb.debian.org/debian trixie-updates InRelease
                                  Hit:3 http://archive.raspberrypi.com/debian trixie InRelease
                                  Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
                                  Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                                  Reading package lists...
                                  Pending Updates: 0
                                  *** Listening Ports ***
                                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5984       1/init
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11320      981/sshd: /usr/sbin
                                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       46426      10527/io.mqtt.0
                                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       47256      10689/io.shelly.0
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       46720      10707/io.sonoff.0
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       35794      7194/iobroker.js-co
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       38181      7194/iobroker.js-co
                                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11273      955/cupsd
                                  tcp6       0      0 :::111                  :::*                    LISTEN      0          2197       1/init
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          11322      981/sshd: /usr/sbin
                                  tcp6       0      0 :::21                   :::*                    LISTEN      0          137963     14164/vsftpd
                                  tcp6       0      0 :::8554                 :::*                    LISTEN      1001       45422      10444/go2rtc
                                  tcp6       0      0 :::8555                 :::*                    LISTEN      1001       45424      10444/go2rtc
                                  tcp6       0      0 :::1984                 :::*                    LISTEN      1001       45430      10444/go2rtc
                                  tcp6       0      0 :::5900                 :::*                    LISTEN      985        11334      986/wayvnc
                                  tcp6       0      0 :::3000                 :::*                    LISTEN      1001       44932      10450/io.fullybrows
                                  tcp6       0      0 :::8088                 :::*                    LISTEN      1001       47309      10734/io.terminal.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       46779      10749/io.web.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       37290      7220/io.admin.0
                                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11272      955/cupsd
                                  udp        0      0 0.0.0.0:58196           0.0.0.0:*                           101        888        696/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       47310      10768/io.wled.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        886        696/avahi-daemon: r
                                  udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       48164      10587/io.radar2.0
                                  udp        0      0 0.0.0.0:36940           0.0.0.0:*                           1001       44911      10429/io.eusec.0
                                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2196       1/init
                                  udp6       0      0 :::5353                 :::*                                101        887        696/avahi-daemon: r
                                  udp6       0      0 :::45056                :::*                                101        889        696/avahi-daemon: r
                                  udp6       0      0 :::111                  :::*                                0          461        1/init
                                  udp6       0      0 :::8555                 :::*                                1001       45425      10444/go2rtc
                                  2025-12-26 18:04:11.412  - info: javascript.0 (10154) script.js.FBH_Steuerung: 581
                                  2025-12-26 18:04:21.346  - info: javascript.0 (10154) script.js.FBH_Steuerung: 591
                                  2025-12-26 18:04:29.182  - info: javascript.0 (10154) script.js.Cam_Reo_Alle_Trigger: Datei überschrieben: Terrasse.mp4
                                  2025-12-26 18:04:31.291  - info: javascript.0 (10154) script.js.FBH_Steuerung: 584
                                  2025-12-26 18:04:33.183  - info: javascript.0 (10154) script.js.Cam_Reo_Alle_Trigger: Datei überschrieben: Terrasse.jpg
                                  2025-12-26 18:04:41.424  - info: javascript.0 (10154) script.js.FBH_Steuerung: 574
                                  2025-12-26 18:04:51.367  - info: javascript.0 (10154) script.js.FBH_Steuerung: 572
                                  2025-12-26 18:05:01.185  - info: javascript.0 (10154) script.js.Cam_Reo_Alle_Trigger: Datei überschrieben: Terrasse.mp4
                                  2025-12-26 18:05:01.341  - info: javascript.0 (10154) script.js.FBH_Steuerung: 863
                                  2025-12-26 18:05:11.365  - info: javascript.0 (10154) script.js.FBH_Steuerung: 820
                                  2025-12-26 18:05:21.387  - info: javascript.0 (10154) script.js.FBH_Steuerung: 622
                                  2025-12-26 18:05:31.307  - info: javascript.0 (10154) script.js.FBH_Steuerung: 484
                                  2025-12-26 18:05:41.462  - info: javascript.0 (10154) script.js.FBH_Steuerung: 500
                                  2025-12-26 18:05:50.011  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 21134
                                  2025-12-26 18:05:51.264  - info: javascript.0 (10154) script.js.FBH_Steuerung: 482
                                  2025-12-26 18:05:54.244  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 21134 terminated with code 0 (NO_ERROR)
                                  2025-12-26 18:06:01.344  - info: javascript.0 (10154) script.js.FBH_Steuerung: 453
                                  2025-12-26 18:06:11.384  - info: javascript.0 (10154) script.js.FBH_Steuerung: 446
                                  2025-12-26 18:06:21.322  - info: javascript.0 (10154) script.js.FBH_Steuerung: 437
                                  2025-12-26 18:06:31.313  - info: javascript.0 (10154) script.js.FBH_Steuerung: 441
                                  2025-12-26 18:06:41.436  - info: javascript.0 (10154) script.js.FBH_Steuerung: 442
                                  2025-12-26 18:06:51.339  - info: javascript.0 (10154) script.js.FBH_Steuerung: 438
                                  2025-12-26 18:07:01.364  - info: javascript.0 (10154) script.js.FBH_Steuerung: 441
                                  2025-12-26 18:07:11.454  - info: javascript.0 (10154) script.js.FBH_Steuerung: 450
                                  2025-12-26 18:07:21.287  - info: javascript.0 (10154) script.js.FBH_Steuerung: 457
                                  iob diag has finished.
                                  • G Gonzokalle
                                    @Thomas-Braun
                                    ```bash
                                    Script v.2025-08-09
                                    *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                    CPU threads: 4
                                    Current issues:
                                                  NTP service: active
                                              RTC in local TZ: no
                                    martin
                                    HOME=/home/martin
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Session:                tty
                                    *** MEMORY ***
                                    Swap:           2.1G          0B        2.1G
                                             8063 M total memory
                                             3690 M used memory
                                             1387 M free memory
                                              231 M buffer memory
                                             3062 M swap cache
                                             2047 M total swap
                                                0 M used swap
                                             2047 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    2.5G    /var/
                                    221M    /var/lib
                                    216M    /var/cache
                                    203M    /var/cache/apt
                                    154M    /var/lib/apt
                                    USB-Devices by-id:
                                    HINT:
                                    zigbee.X
                                    Extended Pan ID:
                                    *** MASKED ***
                                    Pan ID:
                                    *** MASKED ***
                                    Channel:
                                    *** MASKED ***
                                    Network Key:
                                    *** MASKED ***
                                    /usr/bin/npm            10.9.4
                                    /usr/bin/npx            10.9.4
                                    nodejs:
                                      Version table:
                                         20.19.2+dfsg-1 500
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    admin:          7.7.19
                                    javascript:     9.0.11
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        6937
                                    States:         5878
                                    Pending Updates: 0
                                    Ausschalten.
                                    Dann schau dir
                                    cd /opt/iobroker && npm ls
                                    an.
                                      Ausschalten.
                                      Dann schau dir
                                      an.
                                      Gonzokalle
                                      @Thomas-Braun
                                      martin@RaspberryPi-Iobroker:~ $ cd /opt/iobroker && npm ls
                                      iobroker.inst@3.0.0 /opt/iobroker
                                      ├── @iobroker-javascript.0/node-wol@npm:node-wol@0.1.1
                                      ├── @iobroker-javascript.0/wake_on_lan@npm:wake_on_lan@1.0.0
                                      ├── @stoprocent/bluetooth-hci-socket@1.5.2 extraneous
                                      ├── @types/w3c-web-usb@1.0.13 extraneous
                                      ├── @yarnpkg/lockfile@1.1.0 extraneous
                                      ├── chalk@4.1.2 extraneous
                                      ├── find-yarn-workspace-root@2.0.0 extraneous
                                      ├── has-flag@4.0.0 extraneous
                                      ├── iobroker.admin@7.7.19
                                      ├── iobroker.alexa2@3.27.4
                                      ├── iobroker.backitup@3.3.10
                                      ├── iobroker.device-watcher@2.13.1
                                      ├── iobroker.devices@1.2.8
                                      ├── iobroker.echarts@1.9.2
                                      ├── iobroker.energiefluss@3.6.2
                                      ├── iobroker.eusec@2.0.3 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.eusec.git#f625cbb12aea40dcf6faf11a17d93328f069b753)
                                      ├── iobroker.flot@1.12.0
                                      ├── iobroker.fullybrowser@3.1.2
                                      ├── iobroker.history@3.0.1
                                      ├── iobroker.icons-icons8@0.0.1
                                      ├── iobroker.iot@5.0.7
                                      ├── iobroker.iqontrol@3.0.0
                                      ├── iobroker.javascript@9.0.11
                                      ├── iobroker.jeelink@1.2.5
                                      ├── iobroker.js-controller@7.0.7
                                      ├── iobroker.mqtt@6.1.4
                                      ├── iobroker.netatmo-crawler@1.1.0
                                      ├── iobroker.opendtu@3.1.0
                                      ├── iobroker.radar2@2.4.0
                                      ├── iobroker.reolink@1.2.3
                                      ├── iobroker.shelly@10.4.1
                                      ├── iobroker.smartgarden@2.0.1
                                      ├── iobroker.sonoff@3.2.1
                                      ├── iobroker.telegram@4.1.0
                                      ├── iobroker.terminal@1.0.0
                                      ├── iobroker.web@7.0.8
                                      ├── iobroker.wled@0.7.2
                                      ├── iobroker.zigbee@3.2.5
                                      ├── is-docker@2.2.1 extraneous
                                      ├── is-wsl@2.2.0 extraneous
                                      ├── json-stable-stringify@1.3.0 extraneous
                                      ├── jsonify@0.0.1 extraneous
                                      ├── klaw-sync@6.0.0 extraneous
                                      ├── node-addon-api@8.5.0 extraneous
                                      ├── open@7.4.2 extraneous
                                      ├── patch-package@8.0.1 extraneous
                                      ├── slash@2.0.0 extraneous
                                      ├── supports-color@7.2.0 extraneous
                                      ├── tmp@0.2.5 extraneous
                                      ├── usb@2.16.0 extraneous
                                      └── yaml@2.8.2 extraneous
                                      • G Gonzokalle
                                        @Thomas-Braun
                                        @Gonzokalle
                                        Da geht der Build von (mehreren) Paketen in die Hose.
                                        stoprocent/noble:
                                        Ich meine mich erinnern zu können das es damit unlängst auch bei anderen zu Problemen kam. Finde den Thread aber jetzt nicht.
                                        Nächster Build-Error ist bei node-dht-sensor:
                                        1. Build-Error:
                                        npm error code 7
                                        Musste mal schauen, wo diese Module verwendet werden. Den enstprechenden Adapter dann reinstallieren oder neubauen.
                                          noble, dht und opengpio klingen verdächtig nach Raspi
