  3. Einsteigerfragen
  4. Installation
  5. Fehler bei update
    2.7k
    2.9k
Fehler bei update
15 Beiträge 3 Kommentatoren 1.0k Aufrufe 2 Beobachtet
  • marcel-drzalM Offline
    marcel-drzal
    ich habe das Problem, das ich bei update immer eine Meldung erhalte. Was kann ich tun?
    Debian GNU/Linux 11 iobroker tty1
    iobroker login: root
    Password:
    Linux iobroker 6.17.2-2-pve #1 SMP PREEMPT_DYNAMIC PMX 6.17.2-2 (2025-11-26T12:33Z) x86_64
    permitted by applicable law.
    Last login: Fri Aug 22 15:20:46 CEST 2025 from 10.10.10.166 on pts/3
    You have new mail.
    root@iobroker:~# apt update
    Get:1 http://security.debian.org/debian-security trixie-security InRelease [43.4 kB]
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Get:3 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB]
    Err:4 https://dl.yarnpkg.co m/debian InRelease
      Could not resolve 'dl.yarnpkg.co'
    Get:5 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
    Get:6 http://security.debian.org/debian-security trixie-security/main amd64 Packages [81.6 kB]
    Get:7 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
    Get:8 http://security.debian.org/debian-security trixie-security/main Translation-en [51.8 kB]
    Err:5 https://repos.influxdata.com/debian buster InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Get:9 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages [8605 B]
    Fetched 258 kB in 0s (743 kB/s)
    Reading package lists... Done
    471 packages can be upgraded. Run 'apt list --upgradable' to see them.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not resolve 'dl.yarnpkg.co'
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    root@iobroker:~#
    • marcel-drzalM marcel-drzal
      Password:
      You have new mail.
      root@iobroker:~#
      @marcel-drzal sagte in Fehler bei update:
      Linux 11
      ist tot!
      schon lange.
      die Repos sind für Linux 13
        marcel-drzal
        Do you want to continue? [Y/n] Y
        Reading changelogs... Done
        Extracting templates from packages: 100%
        Preconfiguring packages ...
        (Reading database ... 43860 files and directories currently installed.)
        Preparing to unpack .../base-files_13.8+deb13u2_amd64.deb ...
        • The base-files package cannot be installed because
        • /bin is a directory, but should be a symbolic link.
        • Please install the usrmerge package to convert this system to merged-/usr.
        • For more information please read https://wiki.debian.org/UsrMerge.
        dpkg: error processing archive /var/cache/apt/archives/base-files_13.8+deb13u2_amd64.deb (--unpack):
        new base-files package pre-installation script subprocess returned error exit status 1
        Errors were encountered while processing:
        E: Sub-process /usr/bin/dpkg returned an error code (1)
        root@iobroker:~#
          root@iobroker:~#
          @marcel-drzal
          Wie immer: NICHT als root herumhampeln.
          System regelmäßiger updaten.
          usrmerge installieren:
          sudo apt install usrmerge
          Siehe auch:
          https://www.debian.org/releases/bookworm/amd64/release-notes/ch-information.en.html#a-merged-usr-is-now-required
          Wie alt ist denn das Grundsystem? Ist das Buster / Debian 11 gewesen?
          Du kannst/solltest ohnehin keine Releases überspringen.
          Und die Paketquellen für die Fremdpakete musst du auch aufräumen/anpassen. yarn kann komplett raus, influx muss neuangelegt werden. Fehlt grafana oder setzt du das nicht ein?
            @marcel-drzal
            Siehe auch:
            @Thomas-Braun sagte in Fehler bei update:
            so sieht's aus
              marcel-drzal
              habe es nun geschafft und habe das System neu aufgesetzt. Nun habe ich nur das Problem, das ich 22.21.0 auf 22.21.1 nicht bekomme
                https://github.com/nodesource/distributions/issues/1897
                  marcel-drzal
                  wie gehe ich das im iObroker vor das er sich die Datei zieht?
                    Im ioBroker besser gar nicht. Software wird über deinen Pakemanager verwaltet.
                    Halte die Kiste regelmäßig auf Stand, dann kommt schon irgendwann ein update vorbeigeschwommen.
                    sudo apt update
                    sudo apt full-upgrade
                      marcel-drzal
                      schrieb am zuletzt editiert von marcel-drzal
                      wie und wo stelle ich das ein?
                      marcel@PiObroker:~$ sudo apt update
                      [sudo] password for marcel:
                      Hit:1 http://deb.debian.org/debian trixie InRelease
                      Hit:2 http://security.debian.org trixie-security InRelease
                      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                      Fetched 47.3 kB in 0s (311 kB/s)
                      All packages are up to date.
                      Warning: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                      Summary:
                        Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 0
                      marcel@PiObroker:~$
                        Summary:
                        marcel@PiObroker:~$
                        Das ist alles okay. Nix einstellen. Die 22.21.1 ist einfach im nodesource-Repo nicht vorhanden. Siehe auch:
                          marcel-drzal
                          ok danke dir.
                          das Warning hat mich irritiert
                            ok danke dir.
                            @marcel-drzal
                            Insgesamt scheint das Repo Probleme zu haben. Auch zum key gibt es seit Monaten ein offenes Issue:
                            https://github.com/nodesource/distributions/issues/1882
                            • Thomas BraunT Online
                              Man könnte statt nodejs auch nsolid verwenden. Das meldet sich mit aktueller Version, würde aber z. B. von 'iob diag' nicht gefunden. Das ganze würde ich daher als inoffiziellen, experimentellen Handstrick bezeichnen.
                              Wer es 'für die Optik' probieren will:
                              iob stop
                              sudo apt update && sudo apt install nsolid
                              iob start
                              Aber ich würde weiterhin einfach auf ein Update von nodejs warten.
                                marcel-drzal
                                ok mache ich danke
