  4. Wir empfehlen: Node.js 22.x
    6.8k
370 Beiträge 53 Kommentatoren 92.7k Aufrufe 53 Beobachtet
  • D Online
    D Online
    DarkDevil
    #234
    Anbei der output aus iob diag:
    [s=]
    c```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Ubuntu 22.04.5 LTS
     Static hostname: iobroker-produktiv
           Icon name: computer-container
             Chassis: container
      Virtualization: lxc
              Kernel: Linux 6.8.12-11-pve
        Architecture: x86-64
    OS is similar to: debian
    model name      : 12th Gen Intel(R) Core(TM) i5-1240P
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     09:41:33 up 16 min,  2 users,  load average: 0.86, 0.87, 0.75
    CPU threads: 8
    *** LIFE CYCLE STATUS ***
    Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-12-10 09:41:33 CET
               Universal time: Wed 2025-12-10 08:41:33 UTC
                     RTC time: n/a
                  NTP service: n/a
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi sudo iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev bluetooth
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            8.2G        1.3G        6.9G        0.0K        1.0M        6.9G
    Swap:             0B          0B          0B
    Total:          8.2G        1.3G        6.9G
    Active iob-Instances:   4
             8192 M total memory
             1320 M used memory
             1271 M active memory
                0 M inactive memory
             6870 M free memory
                0 M buffer memory
                1 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    top - 09:41:33 up 16 min,  2 users,  load average: 0.86, 0.87, 0.75
    Tasks:  38 total,   1 running,  37 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  1.7 us,  1.7 sy,  0.0 ni, 93.3 id,  2.5 wa,  0.0 hi,  0.8 si,  0.0 st
    MiB Mem :   8192.0 total,   6870.9 free,   1319.9 used,      1.2 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6871.9 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                   Type      Size  Used Avail Use% Mounted on
    rpool/data/subvol-201-disk-0 zfs        60G   11G   50G  18% /
    none                         tmpfs     492K  4.0K  488K   1% /dev
    efivarfs                     efivarfs  192K  100K   88K  53% /sys/firmware/efi/efivars
    tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
    tmpfs                        tmpfs     6.2G  136K  6.2G   1% /run
    tmpfs                        tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                        tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
    tmpfs                        tmpfs     3.1G     0  3.1G   0% /run/user/1001
    Show mounted filesystems:
    TARGET SOURCE                       FSTYPE OPTIONS
    /      rpool/data/subvol-201-disk-0 zfs    rw,relatime,xattr,posixacl,casesensitive
    /var:
    1.2G    /var/
    830M    /var/cache
    826M    /var/cache/apt
    754M    /var/cache/apt/archives
    197M    /var/log
    Archived and active journals take up 3.3M in the file system.
    /opt/iobroker/backups:
    394M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    817M    /opt/iobroker/iobroker-data/backup-objects
    114M    /opt/iobroker/iobroker-data/files
    67M     /opt/iobroker/iobroker-data/history
    20M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    41M     /opt/iobroker/iobroker-data/states.jsonl
    26M     /opt/iobroker/iobroker-data/backup-objects/2025-12-10_07-47_states.jsonl.gz
    26M     /opt/iobroker/iobroker-data/backup-objects/2025-12-10_05-47_states.jsonl.gz
    26M     /opt/iobroker/iobroker-data/backup-objects/2025-12-10_03-47_states.jsonl.gz
    26M     /opt/iobroker/iobroker-data/backup-objects/2025-12-10_01-47_states.jsonl.gz
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.2
    /usr/bin/node           v20.19.2
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.2-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
     *** 20.19.2-1nodesource1 100
         12.22.9~dfsg-1ubuntu3.6 500
            500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
            500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker-produktiv  iobroker-produktiv (version: 7.0.7, hostname: iobroker-produktiv, alive, uptime: 16)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     9
    +-- iobroker.bambulab@0.3.4 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#1a690a68b4796f7ee6e685ccf85751566682885f)
    +-- iobroker.cloudless-homeconnect@1.6.3 (git+ssh://git@github.com/eifel-tech/ioBroker.cloudless-homeconnect.git#6d5e4686ff96eef7f617f05d5ac6d4a367ef6a89)
    +-- iobroker.cups@0.0.1 (git+ssh://git@github.com/felixcrafter54/ioBroker.cups.git#fb94931eb265aac5ba332907b806b5d5a4c573a9)
    +-- iobroker.devices@1.2.9 (git+ssh://git@github.com/ioBroker/ioBroker.devices.git#9b236f4f0ce18525b8f0418b71e1153f2e9057a6)
    +-- iobroker.dreamehome@0.1.7 (git+ssh://git@github.com/spayrosam/ioBroker.dreamehome.git#24a7e4a9542cfe1616a50747ec1eaf58bddacdbd)
    +-- iobroker.jarvis@3.1.9-beta.2 (git+ssh://git@github.com/Zefau/ioBroker.jarvis.git#31ad221a4171597a434fff0b41d75dd7d09d6d6c)
    +-- iobroker.mercedesme@0.3.8 (git+ssh://git@github.com/TA2k/ioBroker.mercedesme.git#426508912896a6de0257cee3c07f2a3d3b624aa4)
    +-- iobroker.navimow@0.0.1 (git+ssh://git@github.com/TA2k/ioBroker.navimow.git#f92d4950c454a421747bdab62a34a157f6cf508f)
    +-- iobroker.schoolfree@1.1.12 (git+ssh://git@github.com/simatec/ioBroker.schoolfree.git#4c820da55212ada269b0008fca1a0b5d117438b5)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-produktiv                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alarm.0                  : alarm                 : iobroker-produktiv                       -  enabled
      system.adapter.alexa2.0                 : alexa2                : iobroker-produktiv                       -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker-produktiv                       -  enabled
      system.adapter.asterisk.0               : asterisk              : iobroker-produktiv                       -  enabled, port: 5038
      system.adapter.backitup.0               : backitup              : iobroker-produktiv                       -  enabled
      system.adapter.bambulab.1               : bambulab              : iobroker-produktiv                       -  enabled, port: 8883
      system.adapter.cloudless-homeconnect.0  : cloudless-homeconnect : iobroker-produktiv                       -  enabled
      system.adapter.cups.0                   : cups                  : iobroker-produktiv                       -  enabled, port: 631
      system.adapter.deconz.0                 : deconz                : iobroker-produktiv                       -  enabled, port: 80
      system.adapter.denon.0                  : denon                 : iobroker-produktiv                       -  enabled
      system.adapter.devices.0                : devices               : iobroker-produktiv                       -  enabled
      system.adapter.dreamehome.0             : dreamehome            : iobroker-produktiv                       -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker-produktiv                       -  enabled
      system.adapter.fakeroku.0               : fakeroku              : iobroker-produktiv                       -  enabled
      system.adapter.flot.0                   : flot                  : iobroker-produktiv                       - disabled
      system.adapter.fullybrowser.0           : fullybrowser          : iobroker-produktiv                       -  enabled
      system.adapter.govee-local.0            : govee-local           : iobroker-produktiv                       -  enabled
      system.adapter.harmony.0                : harmony               : iobroker-produktiv                       -  enabled
    + system.adapter.history.0                : history               : iobroker-produktiv                       -  enabled
      system.adapter.hue.0                    : hue                   : iobroker-produktiv                       -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : iobroker-produktiv                       -  enabled
      system.adapter.iot.0                    : iot                   : iobroker-produktiv                       -  enabled
      system.adapter.iqontrol.0               : iqontrol              : iobroker-produktiv                       -  enabled
      system.adapter.jarvis.0                 : jarvis                : iobroker-produktiv                       -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker-produktiv                       -  enabled
      system.adapter.linux-control.0          : linux-control         : iobroker-produktiv                       -  enabled
      system.adapter.logparser.0              : logparser             : iobroker-produktiv                       -  enabled
      system.adapter.mercedesme.0             : mercedesme            : iobroker-produktiv                       - disabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker-produktiv                       - disabled, port: 54321
      system.adapter.mobile.0                 : mobile                : iobroker-produktiv                       - disabled
      system.adapter.mqtt.0                   : mqtt                  : iobroker-produktiv                       -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.philips-tv.0             : philips-tv            : iobroker-produktiv                       -  enabled
      system.adapter.ping.0                   : ping                  : iobroker-produktiv                       -  enabled
      system.adapter.proxmox.0                : proxmox               : iobroker-produktiv                       -  enabled, port: 8006
      system.adapter.pushover.0               : pushover              : iobroker-produktiv                       -  enabled
      system.adapter.pushover.1               : pushover              : iobroker-produktiv                       -  enabled
      system.adapter.pushover.2               : pushover              : iobroker-produktiv                       -  enabled
      system.adapter.reolink.0                : reolink               : iobroker-produktiv                       -  enabled
      system.adapter.roborock.0               : roborock              : iobroker-produktiv                       -  enabled
      system.adapter.schoolfree.0             : schoolfree            : iobroker-produktiv                       -  enabled
      system.adapter.shelly.0                 : shelly                : iobroker-produktiv                       -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shelly.1                 : shelly                : iobroker-produktiv                       -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.simple-api.0             : simple-api            : iobroker-produktiv                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.sonoff.0                 : sonoff                : iobroker-produktiv                       -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.spotify-premium.0        : spotify-premium       : iobroker-produktiv                       - disabled
      system.adapter.text2command.0           : text2command          : iobroker-produktiv                       -  enabled
      system.adapter.tr-064.0                 : tr-064                : iobroker-produktiv                       - disabled
      system.adapter.trashschedule.0          : trashschedule         : iobroker-produktiv                       -  enabled
      system.adapter.tuya.0                   : tuya                  : iobroker-produktiv                       -  enabled
      system.adapter.unifi.0                  : unifi                 : iobroker-produktiv                       -  enabled
      system.adapter.vis.0                    : vis                   : iobroker-produktiv                       -  enabled
      system.adapter.web.0                    : web                   : iobroker-produktiv                       -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wled.0                   : wled                  : iobroker-produktiv                       -  enabled
      system.adapter.yahka.0                  : yahka                 : iobroker-produktiv                       -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alarm"        : 3.7.6    , installed 3.7.6
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "asterisk"     : 2.0.3    , installed 2.0.3
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "deconz"       : 1.6.4    , installed 1.6.4
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "devices"      : 1.2.8    , installed 1.2.9
    Adapter    "fakeroku"     : 0.3.0    , installed 0.3.0
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "govee-local"  : 0.4.5    , installed 0.4.5
    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.2
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "openligadb"   : 1.9.1    , installed 1.9.1
    Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "roborock"     : 0.6.18   , installed 0.6.18
    Adapter    "schoolfree"   : 1.1.12   , installed 1.1.12
    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "yahka"        : 1.1.5    , installed 1.1.5
    Objects and States
    Objects:        22676
    States:         17722
    Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
    Pending Updates:
    *** Listening Ports ***
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        1201080859 101/systemd-resolve
    tcp        0      0 192.168.123.100:9093    0.0.0.0:*               LISTEN      1000       1201197253 2260/io.fakeroku.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1201090704 385/master
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1201083964 1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1201086801 158/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      113        1201086821 127/asterisk
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1201185692 1676/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1201185672 1676/iobroker.js-co
    tcp6       0      0 :::61991                :::*                    LISTEN      1000       1201193411 2342/io.harmony.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1201083966 1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1201086803 158/sshd: /usr/sbin
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1201090705 385/master
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1201183418 1695/io.admin.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1201197254 2260/io.fakeroku.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1201183741 2188/io.deconz.0
    udp        0      0 0.0.0.0:4569            0.0.0.0:*                           113        1201086834 127/asterisk
    udp        0      0 0.0.0.0:5060            0.0.0.0:*                           113        1201086835 127/asterisk
    udp        0      0 0.0.0.0:58911           0.0.0.0:*                           113        1201084188 127/asterisk
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       1201193412 2342/io.harmony.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        1201080858 101/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1201083965 1/init
    udp        0      0 192.168.123.100:123     0.0.0.0:*                           0          1201080887 149/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          1201080885 149/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          1201080881 149/ntpd
    udp6       0      0 :::1900                 :::*                                1000       1201183742 2188/io.deconz.0
    udp6       0      0 :::51428                :::*                                113        1201084189 127/asterisk
    udp6       0      0 :::111                  :::*                                0          1201083967 1/init
    udp6       0      0 fe80::1058:ecff:fe7:123 :::*                                112        1201092692 149/ntpd
    udp6       0      0 ::1:123                 :::*                                0          1201080889 149/ntpd
    udp6       0      0 :::123                  :::*                                0          1201080878 149/ntpd
    2025-12-10 09:41:29.036  - error: roborock.0 (1855) Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects.
    2025-12-10 09:41:29.041  - error: roborock.0 (1855) Error retrieving or setting clientID: Error: Login returned empty userdata.
        at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:236:11)
        at processTicksAndRejections (node:internal/process/task_queues:95:5)
        at Roborock.initializeRoborockApi (/opt/iobroker/node_modules/iobroker.roborock/main.js:103:21)
        at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:65:34)
    2025-12-10 09:41:29.228  - error: roborock.0 (1855) Failed to get home details: Error: loginApi is not initialized.
        at Roborock.initializeHomeDetails (/opt/iobroker/node_modules/iobroker.roborock/main.js:144:25)
        at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:67:14)
    2025-12-10 09:41:32.238  - info: host.iobroker-produktiv instance system.adapter.alarm.0 in version "3.7.6" started with pid 1891
    2025-12-10 09:41:32.802  - info: alarm.0 (1891) starting. Version 3.7.6 in /opt/iobroker/node_modules/iobroker.alarm, node: v20.19.2, js-controller: 7.0.7
    2025-12-10 09:41:36.209  - info: host.iobroker-produktiv instance system.adapter.alexa2.0 in version "3.27.4" started with pid 2111
    2025-12-10 09:41:36.779  - info: alexa2.0 (2111) starting. Version 3.27.4 in /opt/iobroker/node_modules/iobroker.alexa2, node: v20.19.2, js-controller: 7.0.7
    2025-12-10 09:41:36.795  - info: alexa2.0 (2111) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
    2025-12-10 09:41:36.796  - info: alexa2.0 (2111) Update Device State Interval is too low, set to 349s
    2025-12-10 09:41:39.914  - info: alexa2.0 (2111) Initialize all Device states ...
    2025-12-10 09:41:40.207  - info: host.iobroker-produktiv instance system.adapter.deconz.0 in version "1.6.4" started with pid 2188
    2025-12-10 09:41:40.721  - info: deconz.0 (2188) starting. Version 1.6.4 in /opt/iobroker/node_modules/iobroker.deconz, node: v20.19.2, js-controller: 7.0.7
    2025-12-10 09:41:40.744  - info: deconz.0 (2188) deConz Version: 2.30.2; API version: 1.16.0
    2025-12-10 09:41:44.255  - info: host.iobroker-produktiv instance system.adapter.fakeroku.0 in version "0.3.0" started with pid 2260
    2025-12-10 09:41:44.775  - info: fakeroku.0 (2260) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.fakeroku, node: v20.19.2, js-controller: 7.0.7
    2025-12-10 09:41:48.216  - info: host.iobroker-produktiv instance system.adapter.fullybrowser.0 in version "3.1.2" started with pid 2291
    2025-12-10 09:41:52.235  - info: host.iobroker-produktiv instance system.adapter.harmony.0 in version "1.5.0" started with pid 2342
    2025-12-10 09:41:52.803  - info: harmony.0 (2342) starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v20.19.2, js-controller: 7.0.7
    2025-12-10 09:41:52.814  - info: harmony.0 (2342) [DISCOVER] Searching for Harmony Hubs on 255.255.255.255
    iob diag has finished.
    • mcm1957M Online
      mcm1957M Online
      mcm1957
      #235
      Ubuntu 22 basiert auf Debian Buster - wenn ich richtig informiert bin.
      Kann gut sein, dass da der node.js 22 Support reichlich dünn ist. Buster selbst ist seit Mitte 2024(!) EOL und daher nicht mehr supported.
      @thomas-braun wird das sicher fundiert beantworten können...
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • mcm1957M mcm1957
        BananaJoeB Online
        BananaJoeB Online
        BananaJoe
        #236
        @mcm1957 22.04 ist Jammy, und bekommt bis Juni 2027 noch (Sicherheits-)Updates.
        https://ubuntu.com/about/release-cycle
        Und würde auch noch von nodeJS mit Version 22 (und 24) unterstützt:
        https://nodesource.com/products/distributions
        Zumindest wird da nichts rot wenn ich mir Node.js, Ubuntu und 22.04 zusammenklicke
        Also eigentlich sollte das noch gehen. Aber bevor man das mit Gewalt drauf bügelt, sollte man schauen warum das über iob nicht will.
        • D DarkDevil
          [s=]
          c```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
                   Chassis: container
            Virtualization: lxc
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 8
                           RTC time: n/a
                        NTP service: n/a
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:
          *** MEMORY ***
          Swap:             0B          0B          0B
                   8192 M total memory
                   1320 M used memory
                      0 M inactive memory
                   6870 M free memory
                      0 M buffer memory
                      1 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          *** FILESYSTEM ***
          /var:
          1.2G    /var/
          830M    /var/cache
          826M    /var/cache/apt
          197M    /var/log
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.19
          javascript:     9.0.11
          Adapter State
          + instance is alive
          Objects and States
          Objects:        22676
          States:         17722
          Pending Updates:
          #237
          @DarkDevil
          iob nodejs-update hat alles richtig gemacht und das korrekte Repo angelegt.
          Allerdings ist deine Paketdatenbank korrupt und deswegen können da keine Updates eingespielt werden, auch kein aktuelles nodejs.
          Entsprechende Meldungen müssen auch in der Ausgabe von nodejs-update aufgetaucht sein, genauso wie es im Output von iob diag ja auch drin steht.
          sudo apt update
          sagt?
            @DarkDevil
            sudo apt update
            sagt?
            D Online
            D Online
            DarkDevil
            #238
            @Thomas-Braun das ist die Anzeige des Befehls sudo apt update:
            pi@iobroker-produktiv:~$ sudo apt update
            Hit:1 https://deb.nodesource.com/node_22.x nodistro InRelease
            Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
            Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
            Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
            Reading package lists... Done
            142 packages can be upgraded. Run 'apt list --upgradable' to see them.
            • D DarkDevil
              #239
              @DarkDevil
              Du machst deutlich zu selten Updates. Vermutlich nie.
              sudo apt full-upgrade
              sagt?
                @DarkDevil
                sagt?
                D Online
                D Online
                DarkDevil
                #240
                @Thomas-Braun
                pi@iobroker-produktiv:~$ sudo apt full-upgrade
                Calculating upgrade... Done
                The following package was automatically installed and is no longer required:
                  libllvm13
                Use 'sudo apt autoremove' to remove it.
                Get more security updates through Ubuntu Pro with 'esm-apps' enabled:
                  libzvbi-common liburiparser1 libopusfile0 libavdevice58 ffmpeg libpostproc55
                  libavcodec58 libavutil56 libswscale5 libswresample3 libavformat58 libzvbi0
                  libavfilter7
                Learn more about Ubuntu Pro at https://ubuntu.com/pro
                The following NEW packages will be installed:
                  libxcb-randr0 ubuntu-pro-client ubuntu-pro-client-l10n
                The following packages will be upgraded:
                  apparmor apt apt-utils bind9-dnsutils bind9-host bind9-libs binutils
                  binutils-common binutils-x86-64-linux-gnu cifs-utils cpp-10 cpp-11 curl
                  dirmngr distro-info-data dpkg dpkg-dev g++-11 gcc-10 gcc-10-base gcc-11
                  gcc-11-base gcc-12-base gir1.2-gdkpixbuf-2.0 git git-man gnupg gnupg-l10n
                  gnupg-utils gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf gpgsm gpgv
                  iputils-ping iputils-tracepath libapparmor1 libapt-pkg6.0 libarchive13
                  libasan6 libatomic1 libavahi-client-dev libavahi-client3
                  libavahi-common-data libavahi-common-dev libavahi-common3
                  libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libbinutils libc-bin
                  libc-dev-bin libc6 libc6-dev libcc1-0 libctf-nobfd0 libctf0 libcurl3-gnutls
                  libcurl4 libdpkg-perl libgbm1 libgcc-10-dev libgcc-11-dev libgcc-s1
                  libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin
                  libgdk-pixbuf2.0-common libgfortran5 libgl1-amber-dri libgl1-mesa-dri
                  libglapi-mesa libglib2.0-0 libglib2.0-bin libglib2.0-data libglib2.0-dev
                  libglib2.0-dev-bin libglx-mesa0 libgnutls30 libgomp1 libgssapi-krb5-2
                  libitm1 libk5crypto3 libkrb5-3 libkrb5support0 liblsan0 libnss-systemd
                  libopenjp2-7 libpam-modules libpam-modules-bin libpam-runtime libpam-systemd
                  libpam0g libpam0g-dev libperl5.34 libpq5 libpython3.10-minimal
                  libpython3.10-stdlib libquadmath0 libsqlite3-0 libssh-4 libssh-gcrypt-4
                  libssl3 libstdc++-11-dev libstdc++6 libsystemd0 libtiff-dev libtiff5
                  libtiffxx5 libtsan0 libubsan1 libudev-dev libudev1 libunbound8 libvpx7
                  libwbclient0 libxml2 libxslt1.1 linux-libc-dev locales net-tools nodejs
                  openssl perl perl-base perl-modules-5.34 powermgmt-base python-apt-common
                  python3-apt python3-pkg-resources python3-update-manager python3.10
                  python3.10-minimal sudo systemd systemd-hwe-hwdb systemd-sysv tzdata
                  ubuntu-advantage-tools udev update-manager-core
                142 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
                105 standard LTS security updates
                Need to get 204 MB of archives.
                After this operation, 45.3 MB of additional disk space will be used.
                Do you want to continue? [Y/n]
                • D DarkDevil
                  @Thomas-Braun
                    libllvm13
                    libavfilter7
                  #241
                  @DarkDevil sagte in Wir empfehlen: Node.js 22.x:
                  Ja, willst du.
                  Und das ganze künftig selber und regelmäßig machen.
                  • D Online
                    D Online
                    DarkDevil
                    #242
                    super vielen Dank, jetzt läuft's
                    • D DarkDevil
                      #243
                      @DarkDevil
                      Kiste mal ordentlich neugestartet?
                      Die anderen Meldungen aus iob diag solltest du auch angehen.
                        skorpil
                        #244
                        Bei mir wird’s schon seit langem angezeigt, ich solle auf die Version 22.21.1 updaten. Das hat aber bisher irgendwie noch nie funktioniert. Obwohl ich mein System eigentlich immer auf dem Laufenden halte. Woran könnte das liegen?
                        • S skorpil
                          #245
                          @skorpil sagte in Wir empfehlen: Node.js 22.x:
                          Das liegt daran, das im nodesource-Repo einfach die 22.21.0 die letzte veröffentlichte Version ist. Warum auch immer.
                          Einfach weiter das System über die üblichen Wege (apt update && apt full-upgrade) auf Stand halten, irgendwann wird schon was aktuelleres vorbeischwimmen.
                            skorpil
                            #246
                            @Thomas-Braun danke schön! Ich habe das nur angemerkt, weil die Anzeige schon seit langem da ist. Und ich immer wieder mal mit Sudo apt update & upgrade versuche, das System zu aktualisieren.
                            • S skorpil
                              #247
                              @skorpil
                              Siehe:
                              https://github.com/nodesource/distributions/issues/1897
                              • darkbluD Online
                                darkbluD Online
                                darkblu
                                #248
                                Stand heute wird 22.22.0 angezeigt.
                                Geht aber auch nicht.
                                Raspi 4, 4GB für Influxdb 1.8 und Grafana
                                Raspi 5, 8 GB für ioBroker
                                Threadnetzwerk per Apple
                                • darkbluD darkblu
                                  #249
                                  @darkblu sagte in Wir empfehlen: Node.js 22.x:
                                  Weil der Grund sich auch noch nicht geändert hat.
                                  Es gibt noch keine Releases der aktuellen Versionen über das nodesource-Repository.
                                  • darkbluD Online
                                    darkbluD Online
                                    darkblu
                                    #250
                                    hab ich mir schon gedacht :-)
                                    • darkbluD darkblu
                                      #251
                                      @darkblu
                                      Davon abgesehen ist die Upstream-Version gerade mal ein paar Stunden alt, der Bau der deb-Pakete braucht auch immer etwas Zeit.
                                        @darkblu
                                        #252
                                        Frische Pakete sind für alle vier Release-Zweige (20, 22, 24 und 25) jetzt verfügbar.
                                        Fröhliches updaten!
                                        • bergjetB Offline
                                          bergjetB Offline
                                          bergjet
                                          #253
                                          Bleibt bei mir auf 22.15.0 obwohl 22.22.0 angezeigt wird als neue Version.
                                          homee, ioBroker, iMac, iPhone, Sonos, Alaxa
