  4. Wir empfehlen: Node.js 22.x
    6.8k
370 Beiträge 53 Kommentatoren 92.7k Aufrufe 53 Beobachtet
    @DarkDevil
    Du machst deutlich zu selten Updates. Vermutlich nie.
    sudo apt full-upgrade
    sagt?
    D Online
    D Online
    DarkDevil
    #240
    @Thomas-Braun
    pi@iobroker-produktiv:~$ sudo apt full-upgrade
    Reading package lists... Done
    Calculating upgrade... Done
    The following package was automatically installed and is no longer required:
      libllvm13
    Use 'sudo apt autoremove' to remove it.
    Get more security updates through Ubuntu Pro with 'esm-apps' enabled:
      libzvbi-common liburiparser1 libopusfile0 libavdevice58 ffmpeg libpostproc55
      libavcodec58 libavutil56 libswscale5 libswresample3 libavformat58 libzvbi0
      libavfilter7
    Learn more about Ubuntu Pro at https://ubuntu.com/pro
    The following NEW packages will be installed:
      libxcb-randr0 ubuntu-pro-client ubuntu-pro-client-l10n
    The following packages will be upgraded:
      apparmor apt apt-utils bind9-dnsutils bind9-host bind9-libs binutils
      binutils-common binutils-x86-64-linux-gnu cifs-utils cpp-10 cpp-11 curl
      dirmngr distro-info-data dpkg dpkg-dev g++-11 gcc-10 gcc-10-base gcc-11
      gcc-11-base gcc-12-base gir1.2-gdkpixbuf-2.0 git git-man gnupg gnupg-l10n
      gnupg-utils gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf gpgsm gpgv
      iputils-ping iputils-tracepath libapparmor1 libapt-pkg6.0 libarchive13
      libasan6 libatomic1 libavahi-client-dev libavahi-client3
      libavahi-common-data libavahi-common-dev libavahi-common3
      libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libbinutils libc-bin
      libc-dev-bin libc6 libc6-dev libcc1-0 libctf-nobfd0 libctf0 libcurl3-gnutls
      libcurl4 libdpkg-perl libgbm1 libgcc-10-dev libgcc-11-dev libgcc-s1
      libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin
      libgdk-pixbuf2.0-common libgfortran5 libgl1-amber-dri libgl1-mesa-dri
      libglapi-mesa libglib2.0-0 libglib2.0-bin libglib2.0-data libglib2.0-dev
      libglib2.0-dev-bin libglx-mesa0 libgnutls30 libgomp1 libgssapi-krb5-2
      libitm1 libk5crypto3 libkrb5-3 libkrb5support0 liblsan0 libnss-systemd
      libopenjp2-7 libpam-modules libpam-modules-bin libpam-runtime libpam-systemd
      libpam0g libpam0g-dev libperl5.34 libpq5 libpython3.10-minimal
      libpython3.10-stdlib libquadmath0 libsqlite3-0 libssh-4 libssh-gcrypt-4
      libssl3 libstdc++-11-dev libstdc++6 libsystemd0 libtiff-dev libtiff5
      libtiffxx5 libtsan0 libubsan1 libudev-dev libudev1 libunbound8 libvpx7
      libwbclient0 libxml2 libxslt1.1 linux-libc-dev locales net-tools nodejs
      openssl perl perl-base perl-modules-5.34 powermgmt-base python-apt-common
      python3-apt python3-pkg-resources python3-update-manager python3.10
      python3.10-minimal sudo systemd systemd-hwe-hwdb systemd-sysv tzdata
      ubuntu-advantage-tools udev update-manager-core
    142 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
    105 standard LTS security updates
    Need to get 204 MB of archives.
    After this operation, 45.3 MB of additional disk space will be used.
    Do you want to continue? [Y/n]
    • D DarkDevil
      @Thomas-Braun
        libllvm13
        libavfilter7
      #241
      @DarkDevil sagte in Wir empfehlen: Node.js 22.x:
      Ja, willst du.
      Und das ganze künftig selber und regelmäßig machen.
      • D Online
        D Online
        DarkDevil
        #242
        super vielen Dank, jetzt läuft's
        • D DarkDevil
          #243
          @DarkDevil
          Kiste mal ordentlich neugestartet?
          Die anderen Meldungen aus iob diag solltest du auch angehen.
          Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
          System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
            skorpil
            #244
            Bei mir wird’s schon seit langem angezeigt, ich solle auf die Version 22.21.1 updaten. Das hat aber bisher irgendwie noch nie funktioniert. Obwohl ich mein System eigentlich immer auf dem Laufenden halte. Woran könnte das liegen?
            • S skorpil
              #245
              @skorpil sagte in Wir empfehlen: Node.js 22.x:
              Das liegt daran, das im nodesource-Repo einfach die 22.21.0 die letzte veröffentlichte Version ist. Warum auch immer.
              Einfach weiter das System über die üblichen Wege (apt update && apt full-upgrade) auf Stand halten, irgendwann wird schon was aktuelleres vorbeischwimmen.
                skorpil
                #246
                @Thomas-Braun danke schön! Ich habe das nur angemerkt, weil die Anzeige schon seit langem da ist. Und ich immer wieder mal mit Sudo apt update & upgrade versuche, das System zu aktualisieren.
                • S skorpil
                  #247
                  @skorpil
                  Siehe:
                  https://github.com/nodesource/distributions/issues/1897
                  • darkbluD Online
                    darkbluD Online
                    darkblu
                    #248
                    Stand heute wird 22.22.0 angezeigt.
                    Geht aber auch nicht.
                    Raspi 4, 4GB für Influxdb 1.8 und Grafana
                    Raspi 5, 8 GB für ioBroker
                    Threadnetzwerk per Apple
                    • darkbluD darkblu
                      #249
                      @darkblu sagte in Wir empfehlen: Node.js 22.x:
                      Weil der Grund sich auch noch nicht geändert hat.
                      Es gibt noch keine Releases der aktuellen Versionen über das nodesource-Repository.
                      • darkbluD Online
                        darkbluD Online
                        darkblu
                        #250
                        hab ich mir schon gedacht :-)
                        • darkbluD darkblu
                          #251
                          @darkblu
                          Davon abgesehen ist die Upstream-Version gerade mal ein paar Stunden alt, der Bau der deb-Pakete braucht auch immer etwas Zeit.
                            @darkblu
                            #252
                            Frische Pakete sind für alle vier Release-Zweige (20, 22, 24 und 25) jetzt verfügbar.
                            Fröhliches updaten!
                            • bergjetB Offline
                              bergjetB Offline
                              bergjet
                              #253
                              Bleibt bei mir auf 22.15.0 obwohl 22.22.0 angezeigt wird als neue Version.
                              homee, ioBroker, iMac, iPhone, Sonos, Alaxa
                              • bergjetB bergjet
                                #254
                                @bergjet sagte in Wir empfehlen: Node.js 22.x:
                                more Input!
                                wie sieht der Rest deiner Installation aus?
                                • bergjetB bergjet
                                  #255
                                  Dann check den von dir verwendeten Paketmanager auf dem von dir verwendeten Betriebssystem.
                                  • bergjetB Offline
                                    bergjetB Offline
                                    bergjet
                                    #256
                                    Habe den Fixer laufen lassen, jetzt passt es.
                                    • bergjetB bergjet
                                      #257
                                      :-D Der macht nur genau gar nichts (direkt) an den Paketquellen.
                                      Zeig mal per
                                      iob diag
                                      wie du da genau unterwegs bist.
                                      bergjetB 1 Antwort Letzte Antwort
                                        Zeig mal per
                                        iob diag
                                        bergjetB Offline
                                        bergjetB Offline
                                        bergjet
                                        #258
                                        @Thomas-Braun ```
                                        Script v.2025-08-09
                                        *** BASE SYSTEM ***
                                        Operating System: Raspbian GNU/Linux 11 (bullseye)
                                           Static hostname: pi4
                                                 Icon name: computer
                                                    Kernel: Linux 6.1.21-v8+
                                              Architecture: arm64
                                        OS is similar to: debian
                                        Model		: Raspberry Pi 4 Model B Rev 1.4
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : aarch64
                                        Userland        : 32 bit
                                        Systemuptime and Load:
                                         19:33:52 up  8:39,  1 user,  load average: 0.36, 0.50, 0.47
                                        CPU threads: 4
                                        *** LIFE CYCLE STATUS ***
                                        Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                        *** TIME AND TIMEZONES ***
                                                       Local time: Thu 2026-01-15 19:33:52 CET
                                                   Universal time: Thu 2026-01-15 18:33:52 UTC
                                                         RTC time: n/a
                                                        Time zone: Europe/Vienna (CET, +0100)
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** Users and Groups ***
                                        User that called 'iob diag':
                                        pi
                                        HOME=/home/pi
                                        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        js-controller is not running
                                        *** DISPLAY-SERVER SETUP ***
                                        Display-Server: 	false
                                        Unit display-manager.service could not be found.
                                        Display-Manager:
                                        Desktop:
                                        Session: 		tty
                                        *** MEMORY ***
                                        Mem:            7.8G         81M        7.1G        1.0M        601M        7.6G
                                        Swap:            99M          0B         99M
                                        Total:          7.9G         81M        7.2G
                                        Active iob-Instances: 	1
                                                 7812 M total memory
                                                   81 M used memory
                                                  184 M active memory
                                                  378 M inactive memory
                                                 7129 M free memory
                                                  116 M buffer memory
                                                  485 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        top - 19:33:53 up  8:39,  1 user,  load average: 0.36, 0.50, 0.47
                                        Tasks: 146 total,   1 running, 145 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  1.5 us,  1.5 sy,  0.0 ni, 97.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   7812.3 total,   7128.5 free,     82.0 used,    601.8 buff/cache
                                        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   7607.4 avail Mem
                                        *** FAILED SERVICES ***
                                          UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                                        * iobroker.service loaded failed failed ioBroker Server
                                        1 loaded units listed.
                                        *** DMESG CRITICAL ERRORS ***
                                        No critical errors detected
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       29G   11G   18G  38% /
                                        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                                        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                        tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
                                        /dev/mmcblk0p1 vfat      255M   52M  204M  21% /boot
                                        tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                                        [Thu Jan 15 10:54:43 2026] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:6F:15:63 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=0167a20d-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Thu Jan 15 10:54:44 2026] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Thu Jan 15 10:54:44 2026] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                        [Thu Jan 15 10:54:47 2026] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                        Show mounted filesystems:
                                        TARGET  SOURCE         FSTYPE OPTIONS
                                        /       /dev/mmcblk0p2 ext4   rw,noatime
                                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                        /var:
                                        2.7G	/var/
                                        1.3G	/var/log/journal/cc5e24afcfff49949c0835065fe598da
                                        1.3G	/var/log
                                        1.3G	/var/cache/apt
                                        Archived and active journals take up 1.2G in the file system.
                                        /opt/iobroker/backups:
                                        144M	/opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        684M	/opt/iobroker/iobroker-data/
                                        384M	/opt/iobroker/iobroker-data/files
                                        139M	/opt/iobroker/iobroker-data/node-red
                                        138M	/opt/iobroker/iobroker-data/node-red/node_modules
                                        111M	/opt/iobroker/iobroker-data/backup-objects
                                        41M	/opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                                        32M	/opt/iobroker/iobroker-data/files/mytime.admin/custom/assets/index-B_3WOu59.js.map
                                        31M	/opt/iobroker/iobroker-data/objects.jsonl
                                        19M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                                        9.9M	/opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js
                                        USB-Devices by-id:
                                        No Devices found 'by-id'
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs 	v22.15.0
                                        /usr/bin/node 		v22.15.0
                                        /usr/bin/npm 		10.9.2
                                        /usr/bin/npx 		10.9.2
                                        /usr/bin/corepack 	0.32.0
                                        nodejs:
                                          Installed: 22.15.0-1nodesource1
                                          Candidate: 22.15.0-1nodesource1
                                          Version table:
                                         *** 22.15.0-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages
                                             22.14.0-1nodesource1 1001
                                             22.13.1-1nodesource1 1001
                                             22.13.0-1nodesource1 1001
                                             22.12.0-1nodesource1 1001
                                             22.11.0-1nodesource1 1001
                                             22.10.0-1nodesource1 1001
                                             22.9.0-1nodesource1 1001
                                             22.8.0-1nodesource1 1001
                                             22.7.0-1nodesource1 1001
                                             22.6.0-1nodesource1 1001
                                             22.5.1-1nodesource1 1001
                                             22.5.0-1nodesource1 1001
                                             22.4.1-1nodesource1 1001
                                             22.4.0-1nodesource1 1001
                                             22.3.0-1nodesource1 1001
                                             22.2.0-1nodesource1 1001
                                             22.1.0-1nodesource1 1001
                                             22.0.0-1nodesource1 1001
                                             12.22.12~dfsg-1~deb11u7 500
                                        No problems detected
                                        Errors in npm tree: 0
                                        The current Node.js version (v22.15.0) is vulnerable to the following CVEs:
                                        CVE-2025-23166(high):  The C++ method SignTraits::DeriveBits() may incorrectly call ThrowException() based on user-supplied inputs when executing in a background thread, crashing the Node.js process. Such cryptographic operations are commonly applied to untrusted inputs. Thus, this mechanism potentially allows an adversary to remotely crash a Node.js runtime.
                                        Patched versions: ^20.19.2 || ^22.15.1 || ^23.11.1 || ^24.0.2
                                        CVE-2025-55130(high): A flaw in Node.js’s Permissions model allows attackers to bypass `--allow-fs-read` and `--allow-fs-write` restrictions using crafted relative symlink paths. By chaining directories and symlinks, a script granted access only to the current directory can escape the allowed path and read sensitive files. This breaks the expected isolation guarantees and enables arbitrary file read/write, leading to potential system compromise.
                                        This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
                                        Patched versions: ^20.20.0 || ^22.22.0 || ^24.13.0 || ^25.3.0
                                        CVE-2025-55131(high): A flaw in Node.js's buffer allocation logic can expose uninitialized memory when allocations are interrupted, when using the `vm` module with the timeout option. Under specific timing conditions, buffers allocated with `Buffer.alloc` and other `TypedArray` instances like `Uint8Array` may contain leftover data from previous operations, allowing in-process secrets like tokens or passwords to leak or causing data corruption. While exploitation typically requires precise timing or in-process code execution, it can become remotely exploitable when untrusted input influences workload and timeouts, leading to potential confidentiality and integrity impact.
                                        CVE-2025-55132(low): A flaw in Node.js's permission model allows a file's access and modification timestamps to be changed via `futimes()` even when the process has only read permissions. Unlike `utimes()`, `futimes()` does not apply the expected write-permission checks, which means file metadata can be modified in read-only directories. This behavior could be used to alter timestamps in ways that obscure activity, reducing the reliability of logs. This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
                                        CVE-2025-59465(high): A malformed `HTTP/2 HEADERS` frame with oversized, invalid `HPACK` data can cause Node.js to crash by triggering an unhandled `TLSSocket` error `ECONNRESET`. Instead of safely closing the connection, the process crashes, enabling a remote denial of service. This primarily affects applications that do not attach explicit error handlers to secure sockets, for example:
                                        server.on('secureConnection', socket => {
                                        socket.on('error', err => {
                                        console.log(err)
                                        CVE-2025-59466(medium): We have identified a bug in Node.js error handling where "Maximum call stack size exceeded" errors become uncatchable when `async_hooks.createHook()` is enabled. Instead of reaching `process.on('uncaughtException')`, the process terminates, making the crash unrecoverable. Applications that rely on `AsyncLocalStorage` (v22, v20) or `async_hooks.createHook()` (v24, v22, v20) become vulnerable to denial-of-service crashes triggered by deep recursion under specific conditions.
                                        CVE-2026-21637(medium): A flaw in Node.js TLS error handling allows remote attackers to crash or exhaust resources of a TLS server when `pskCallback` or `ALPNCallback` are in use. Synchronous exceptions thrown during these callbacks bypass standard TLS error handling paths (tlsClientError and error), causing either immediate process termination or silent file descriptor leaks that eventually lead to denial of service. Because these callbacks process attacker-controlled input during the TLS handshake, a remote client can repeatedly trigger the issue. This vulnerability affects TLS servers using PSK or ALPN callbacks across Node.js versions where these callbacks throw without being safely wrapped.
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        iobroker is not running on this host.
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        pi4                 pi4 (version: 7.0.7, hostname: pi4           , alive, uptime: 30993)
                                        Core adapters versions
                                        js-controller: 	7.0.7
                                        admin: 		7.7.19
                                        javascript: 	8.9.2
                                        nodejs modules from github: 	6
                                        +-- iobroker.bambulab@0.3.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#10f9040fecd5044ccb9825bfb7b1f452deae16d4)
                                        +-- iobroker.husqvarna-automower@0.4.0 (git+ssh://git@github.com/ice987987/ioBroker.husqvarna-automower.git#79e34f134df5a479f40dff73e833a55620cd72c6)
                                        +-- iobroker.smartthings@0.1.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#0921ba9cef4d6b62375f339126457f3429d0448f)
                                        +-- iobroker.trashschedule@4.0.0 (git+ssh://git@github.com/klein0r/ioBroker.trashschedule.git#d640860880666638c94546ca1c4961eca3834347)
                                        +-- iobroker.vis-materialdesign@0.5.76 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#43f3a07d7b48f367612c19ef678935709f718aae)
                                        +-- iobroker.web@7.0.9 (git+ssh://git@github.com/ioBroker/ioBroker.web.git#fdc0ef642f146a592a108deffc53297d0bf16dcb)
                                        Adapter State
                                          system.adapter.admin.0                  : admin                 : pi4                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          system.adapter.alexa2.0                 : alexa2                : pi4                                      -  enabled
                                          system.adapter.backitup.0               : backitup              : pi4                                      -  enabled
                                          system.adapter.bambulab.0               : bambulab              : pi4                                      - disabled, port: 8883
                                          system.adapter.coronavirus-statistics.0 : coronavirus-statistics: pi4                                      - disabled
                                          system.adapter.daswetter.0              : daswetter             : pi4                                      -  enabled
                                          system.adapter.discovery.0              : discovery             : pi4                                      -  enabled
                                          system.adapter.email.0                  : email                 : pi4                                      - disabled
                                          system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: pi4                                      -  enabled
                                          system.adapter.fakeroku.0               : fakeroku              : pi4                                      -  enabled
                                          system.adapter.flot.0                   : flot                  : pi4                                      -  enabled
                                          system.adapter.fritzbox.0               : fritzbox              : pi4                                      -  enabled
                                          system.adapter.fronius-solarweb.0       : fronius-solarweb      : pi4                                      - disabled
                                          system.adapter.fronius.0                : fronius               : pi4                                      -  enabled
                                          system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : pi4                                      -  enabled
                                          system.adapter.geofency.0               : geofency              : pi4                                      -  enabled, port: 7999, bind: 0.0.0.0
                                          system.adapter.harmony.0                : harmony               : pi4                                      -  enabled
                                          system.adapter.history.0                : history               : pi4                                      -  enabled
                                          system.adapter.homee.0                  : homee                 : pi4                                      -  enabled
                                          system.adapter.hue-extended.0           : hue-extended          : pi4                                      -  enabled
                                          system.adapter.hue.0                    : hue                   : pi4                                      -  enabled, port: 443
                                          system.adapter.husqvarna-automower.0    : husqvarna-automower   : pi4                                      -  enabled
                                          system.adapter.ical.0                   : ical                  : pi4                                      -  enabled
                                          system.adapter.ical.1                   : ical                  : pi4                                      -  enabled
                                          system.adapter.ical.2                   : ical                  : pi4                                      -  enabled
                                          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : pi4                                      -  enabled
                                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : pi4                                      -  enabled
                                          system.adapter.iot.0                    : iot                   : pi4                                      -  enabled
                                          system.adapter.javascript.0             : javascript            : pi4                                      -  enabled
                                          system.adapter.lgtv.0                   : lgtv                  : pi4                                      - disabled
                                          system.adapter.material.0               : material              : pi4                                      -  enabled
                                          system.adapter.meross.0                 : meross                : pi4                                      -  enabled
                                          system.adapter.mobile.0                 : mobile                : pi4                                      -  enabled
                                          system.adapter.mqtt.0                   : mqtt                  : pi4                                      -  enabled, port: 1883, bind: 0.0.0.0
                                          system.adapter.mytime.0                 : mytime                : pi4                                      - disabled
                                          system.adapter.netatmo.0                : netatmo               : pi4                                      -  enabled
                                          system.adapter.node-red.0               : node-red              : pi4                                      -  enabled, port: 1880, bind: 0.0.0.0
                                          system.adapter.nuki.0                   : nuki                  : pi4                                      -  enabled
                                          system.adapter.openweathermap.0         : openweathermap        : pi4                                      - disabled
                                          system.adapter.ping.0                   : ping                  : pi4                                      -  enabled
                                          system.adapter.pushover.0               : pushover              : pi4                                      -  enabled
                                          system.adapter.rpi2.0                   : rpi2                  : pi4                                      -  enabled
                                          system.adapter.sayit.0                  : sayit                 : pi4                                      -  enabled
                                          system.adapter.shelly.0                 : shelly                : pi4                                      - disabled, port: 1882, bind: 0.0.0.0
                                          system.adapter.simple-api.0             : simple-api            : pi4                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                          system.adapter.smartthings.0            : smartthings           : pi4                                      - disabled
                                          system.adapter.sonos.0                  : sonos                 : pi4                                      -  enabled
                                          system.adapter.telegram.0               : telegram              : pi4                                      -  enabled, port: 8443, bind: 0.0.0.0
                                          system.adapter.text2command.0           : text2command          : pi4                                      -  enabled
                                          system.adapter.tr-064.0                 : tr-064                : pi4                                      -  enabled
                                          system.adapter.trashschedule.0          : trashschedule         : pi4                                      -  enabled
                                          system.adapter.vis-bars.0               : vis-bars              : pi4                                      -  enabled
                                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : pi4                                      -  enabled
                                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : pi4                                      -  enabled
                                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : pi4                                      -  enabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : pi4                                      -  enabled
                                          system.adapter.vis-icontwo.0            : vis-icontwo           : pi4                                      -  enabled
                                          system.adapter.vis-inventwo.0           : vis-inventwo          : pi4                                      -  enabled
                                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : pi4                                      -  enabled
                                          system.adapter.vis-justgage.0           : vis-justgage          : pi4                                      -  enabled
                                          system.adapter.vis-map.0                : vis-map               : pi4                                      -  enabled
                                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : pi4                                      -  enabled
                                          system.adapter.vis-metro.0              : vis-metro             : pi4                                      -  enabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : pi4                                      -  enabled
                                          system.adapter.vis.0                    : vis                   : pi4                                      -  enabled
                                          system.adapter.weather-warnings.0       : weather-warnings      : pi4                                      -  enabled
                                          system.adapter.web.0                    : web                   : pi4                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          system.adapter.yeelight-2.0             : yeelight-2            : pi4                                      -  enabled
                                          system.adapter.zwave2.0                 : zwave2                : pi4                                      - disabled
                                        + instance is alive
                                        ioBroker-Repositories
                                        Active repo(s): stable
                                        Upgrade policy: none
                                        Installed ioBroker-Adapters
                                        Used repository: stable
                                        Adapter    "admin"        : 7.7.19   , installed 7.7.19
                                        Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                                        Adapter    "backitup"     : 3.3.13   , installed 3.3.13
                                        Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
                                        Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
                                        Adapter    "email"        : 2.0.4    , installed 2.0.4
                                        Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
                                        Adapter    "fakeroku"     : 0.3.0    , installed 0.3.0
                                        Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                                        Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                                        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                                        Adapter    "fuelpricemonitor": 0.4.2 , installed 0.4.2
                                        Adapter    "geofency"     : 1.2.4    , installed 1.2.4
                                        Adapter    "harmony"      : 1.5.0    , installed 1.5.0
                                        Adapter    "homee"        : 1.2.0    , installed 1.2.0
                                        Adapter    "hue"          : 3.16.2   , installed 3.16.2
                                        Adapter    "ical"         : 1.18.1   , installed 1.18.1
                                        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                                        Adapter    "iot"          : 5.0.7    , installed 5.0.7
                                        Adapter    "javascript"   : 9.0.11   , installed 8.9.2  [Updatable]
                                        Controller "js-controller": 7.0.7    , installed 7.0.7
                                        Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
                                        Adapter    "material"     : 1.3.1    , installed 1.3.1
                                        Adapter    "meross"       : 1.17.0   , installed 1.17.0
                                        Adapter    "mytime"       : 2.3.0    , installed 2.3.0
                                        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                                        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                                        Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                                        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                                        Adapter    "ping"         : 1.7.9    , installed 1.7.9
                                        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                                        Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                                        Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                                        Adapter    "shelly"       : 10.4.1   , installed 10.4.1
                                        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                                        Adapter    "text2command" : 4.0.0    , installed 3.0.3  [Updatable]
                                        Adapter    "trashschedule": 3.3.0    , installed 4.0.0
                                        Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
                                        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                                        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                                        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.76
                                        Adapter    "weather-warnings": 0.10.0, installed 0.10.0
                                        Adapter    "web"          : 7.0.8    , installed 7.0.9
                                        Adapter    "yeelight-2"   : 1.5.2    , installed 1.5.2
                                        Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
                                        Objects and States
                                        Objects: 	27219
                                        States: 	23420
                                        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                        Hit:3 https://deb.nodesource.com/node_22.x nodistro InRelease
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14979      510/sshd: /usr/sbin
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          14981      510/sshd: /usr/sbin
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12692      377/avahi-daemon: r
                                        udp        0      0 0.0.0.0:60348           0.0.0.0:*                           108        12694      377/avahi-daemon: r
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15100      680/dhcpcd
                                        udp6       0      0 :::37373                :::*                                108        12695      377/avahi-daemon: r
                                        udp6       0      0 :::5353                 :::*                                108        12693      377/avahi-daemon: r
                                        2026-01-15 19:31:49.286  - info: host.pi4 instance system.adapter.discovery.0 terminated with code null ()
                                        2026-01-15 19:31:49.286  - info: host.pi4 All instances are stopped.
                                        2026-01-15 19:31:49.352  - warn: host.pi4 instance system.adapter.web.0 terminated due to SIGKILL
                                        2026-01-15 19:31:49.353  - info: host.pi4 instance system.adapter.web.0 terminated with code null ()
                                        2026-01-15 19:31:49.353  - info: host.pi4 All instances are stopped.
                                        2026-01-15 19:31:49.430  - warn: host.pi4 instance system.adapter.husqvarna-automower.0 terminated due to SIGKILL
                                        2026-01-15 19:31:49.430  - info: host.pi4 instance system.adapter.husqvarna-automower.0 terminated with code null ()
                                        2026-01-15 19:31:49.430  - info: host.pi4 All instances are stopped.
                                        2026-01-15 19:31:49.487  - warn: host.pi4 instance system.adapter.iot.0 terminated due to SIGKILL
                                        2026-01-15 19:31:49.487  - info: host.pi4 instance system.adapter.iot.0 terminated with code null ()
                                        2026-01-15 19:31:49.488  - info: host.pi4 All instances are stopped.
                                        2026-01-15 19:31:49.548  - warn: host.pi4 instance system.adapter.text2command.0 terminated due to SIGKILL
                                        2026-01-15 19:31:49.548  - info: host.pi4 instance system.adapter.text2command.0 terminated with code null ()
                                        2026-01-15 19:31:49.549  - info: host.pi4 All instances are stopped.
                                        2026-01-15 19:31:49.607  - warn: host.pi4 instance system.adapter.weather-warnings.0 terminated due to SIGKILL
                                        2026-01-15 19:31:49.608  - info: host.pi4 instance system.adapter.weather-warnings.0 terminated with code null ()
                                        2026-01-15 19:31:49.608  - info: host.pi4 All instances are stopped.
                                        2026-01-15 19:31:49.665  - warn: host.pi4 instance system.adapter.javascript.0 terminated due to SIGKILL
                                        2026-01-15 19:31:49.665  - info: host.pi4 instance system.adapter.javascript.0 terminated with code null ()
                                        2026-01-15 19:31:49.666  - info: host.pi4 All instances are stopped.
                                        2026-01-15 19:31:49.829  - warn: host.pi4 Cannot get view: Connection is closed.
                                        2026-01-15 19:31:49.831  - warn: host.pi4 instance system.adapter.meross.0 terminated due to SIGKILL
                                        2026-01-15 19:31:49.831  - info: host.pi4 instance system.adapter.meross.0 terminated with code null ()
                                        2026-01-15 19:31:49.831  - info: host.pi4 All instances are stopped.
                                        2026-01-15 19:31:49.886  - info: host.pi4 terminated
                                        iob diag has finished.
                                        pi@pi4:~ $
                                        • bergjetB Offline
                                          bergjetB Offline
                                          bergjet
                                          #259
                                          Jetzt zeigt es mir wieder die Version 22.15.0 an
