  4. Bedienungsanleitung für Matter
    6.5k
41 Beiträge 5 Kommentatoren 3.2k Aufrufe 7 Beobachtet
  • DuffyD Offline
    DuffyD Offline
    Duffy
    schrieb am zuletzt editiert von Duffy
    Also alles noch mal wie zuvor gemacht nur mit den neuen Wlan Daten im BLE Inbetriebnahme Reiter.
    Wie immer, erfolglos. Das Konfigurationsfenster Rödelt jetzt knapp 30 min.
    Trotzdem noch mal das Protokoll:
    matter.0
    	2025-11-18 18:52:33.490	debug	Unsubscribe from 1763486568407-system.adapter.admin.0-gui
    matter.0
    	2025-11-18 18:52:33.487	debug	Client "1763486568407-system.adapter.admin.0-gui: disconnect
    matter.0
    	2025-11-18 18:51:33.256	debug	2025-11-18 18:51:33.256 DEBUG MdnsScanner Added 4 IPs for commissionable device FAAB14EAA5D4C3C4._matterc._udp.local to cache (interface eth0): type: udp ip: fe80::3e6a:d2ff:fe27:a59%eth0 port: 5540 type: udp ip: 2001:9e8:a2cf:9c00:3e6a:d2ff:fe27:a59 port: 5540 type: udp ip: fd1f:745f:6930:0:3e6a:d2ff:fe27:a59 port: 5540 type: udp ip: 192.168.178.151 port: 5540
    matter.0
    	2025-11-18 18:46:40.429	debug	2025-11-18 18:46:40.429 DEBUG MdnsScanner Added 4 IPs for commissionable device FAAB14EAA5D4C3C4._matterc._udp.local to cache (interface eth0): type: udp ip: fe80::3e6a:d2ff:fe27:a59%eth0 port: 5540 type: udp ip: 2001:9e8:a2cf:9c00:3e6a:d2ff:fe27:a59 port: 5540 type: udp ip: fd1f:745f:6930:0:3e6a:d2ff:fe27:a59 port: 5540 type: udp ip: 192.168.178.151 port: 5540
    matter.0
    	2025-11-18 18:46:40.428	debug	2025-11-18 18:46:40.428 DEBUG MdnsScanner Found commissionable device FAAB14EAA5D4C3C4._matterc._udp.local with data: T: 0 DT: 266 PH: 36 ICD: 0 VP: 5010+262 DN: Smart Wi-Fi Plug RI: 02003025CD69021760B3B22A219FBFE662E4 PI:
    matter.0
    	2025-11-18 18:46:40.388	debug	2025-11-18 18:46:40.388 DEBUG MdnsScanner Removing commissionable device FAAB14EAA5D4C3C4._matterc._udp.local from cache (interface eth0) because of ttl=0
    matter.0
    	2025-11-18 18:45:44.171	debug	2025-11-18 18:45:44.171 DEBUG MdnsScanner Added 4 IPs for commissionable device FAAB14EAA5D4C3C4._matterc._udp.local to cache (interface eth0): type: udp ip: fe80::3e6a:d2ff:fe27:a59%eth0 port: 5540 type: udp ip: 2001:9e8:a2cf:9c00:3e6a:d2ff:fe27:a59 port: 5540 type: udp ip: fd1f:745f:6930:0:3e6a:d2ff:fe27:a59 port: 5540 type: udp ip: 192.168.178.151 port: 5540
    matter.0
    	2025-11-18 18:36:40.453	debug	2025-11-18 18:36:40.452 DEBUG MdnsScanner Added 4 IPs for commissionable device FAAB14EAA5D4C3C4._matterc._udp.local to cache (interface eth0): type: udp ip: fe80::3e6a:d2ff:fe27:a59%eth0 port: 5540 type: udp ip: 2001:9e8:a2cf:9c00:3e6a:d2ff:fe27:a59 port: 5540 type: udp ip: fd1f:745f:6930:0:3e6a:d2ff:fe27:a59 port: 5540 type: udp ip: 192.168.178.151 port: 5540
    matter.0
    	2025-11-18 18:36:40.452	debug	2025-11-18 18:36:40.452 DEBUG MdnsScanner Found commissionable device FAAB14EAA5D4C3C4._matterc._udp.local with data: T: 0 DT: 266 PH: 36 ICD: 0 VP: 5010+262 DN: Smart Wi-Fi Plug RI: 02003025CD69021760B3B22A219FBFE662E4 PI:
    matter.0
    	2025-11-18 18:36:40.381	debug	2025-11-18 18:36:40.381 DEBUG MdnsScanner Removing commissionable device FAAB14EAA5D4C3C4._matterc._udp.local from cache (interface eth0) because of ttl=0
    matter.0
    	2025-11-18 18:34:57.816	debug	2025-11-18 18:34:57.815 DEBUG MdnsScanner Added 4 IPs for commissionable device FAAB14EAA5D4C3C4._matterc._udp.local to cache (interface eth0): type: udp ip: fe80::3e6a:d2ff:fe27:a59%eth0 port: 5540 type: udp ip: 2001:9e8:a2cf:9c00:3e6a:d2ff:fe27:a59 port: 5540 type: udp ip: fd1f:745f:6930:0:3e6a:d2ff:fe27:a59 port: 5540 type: udp ip: 192.168.178.151 port: 5540
    matter.0
    	2025-11-18 18:31:45.071	debug	2025-11-18 18:31:45.071 DEBUG MdnsScanner Added 4 IPs for commissionable device FAAB14EAA5D4C3C4._matterc._udp.local to cache (interface eth0): type: udp ip: fe80::3e6a:d2ff:fe27:a59%eth0 port: 5540 type: udp ip: 2001:9e8:a2cf:9c00:3e6a:d2ff:fe27:a59 port: 5540 type: udp ip: fd1f:745f:6930:0:3e6a:d2ff:fe27:a59 port: 5540 type: udp ip: 192.168.178.151 port: 5540
    matter.0
    	2025-11-18 18:31:45.070	debug	2025-11-18 18:31:45.070 DEBUG MdnsScanner Found commissionable device FAAB14EAA5D4C3C4._matterc._udp.local with data: T: 0 DT: 266 PH: 36 ICD: 0 VP: 5010+262 DN: Smart Wi-Fi Plug RI: 02003025CD69021760B3B22A219FBFE662E4 PI:
    matter.0
    	2025-11-18 18:31:45.030	debug	2025-11-18 18:31:45.029 DEBUG MdnsScanner Removing commissionable device FAAB14EAA5D4C3C4._matterc._udp.local from cache (interface eth0) because of ttl=0
    matter.0
    	2025-11-18 18:26:45.147	debug	2025-11-18 18:26:45.147 DEBUG MdnsScanner Added 4 IPs for commissionable device FAAB14EAA5D4C3C4._matterc._udp.local to cache (interface eth0): type: udp ip: fe80::3e6a:d2ff:fe27:a59%eth0 port: 5540 type: udp ip: 2001:9e8:a2cf:9c00:3e6a:d2ff:fe27:a59 port: 5540 type: udp ip: fd1f:745f:6930:0:3e6a:d2ff:fe27:a59 port: 5540 type: udp ip: 192.168.178.151 port: 5540
    matter.0
    	2025-11-18 18:26:45.147	debug	2025-11-18 18:26:45.146 DEBUG MdnsScanner Found commissionable device FAAB14EAA5D4C3C4._matterc._udp.local with data: T: 0 DT: 266 PH: 36 ICD: 0 VP: 5010+262 DN: Smart Wi-Fi Plug RI: 02003025CD69021760B3B22A219FBFE662E4 PI:
    matter.0
    	2025-11-18 18:26:45.105	debug	2025-11-18 18:26:45.105 DEBUG MdnsScanner Removing commissionable device 5690D4DCE45B9E62._matterc._udp.local from cache (interface eth0) because of ttl=0
    matter.0
    	2025-11-18 18:26:44.318	debug	2025-11-18 18:26:44.318 DEBUG MdnsScanner Added 4 IPs for commissionable device 5690D4DCE45B9E62._matterc._udp.local to cache (interface eth0): type: udp ip: fe80::3e6a:d2ff:fe27:a59%eth0 port: 5540 type: udp ip: 2001:9e8:a2cf:9c00:3e6a:d2ff:fe27:a59 port: 5540 type: udp ip: fd1f:745f:6930:0:3e6a:d2ff:fe27:a59 port: 5540 type: udp ip: 192.168.178.151 port: 5540
    matter.0
    	2025-11-18 18:26:44.317	debug	2025-11-18 18:26:44.317 DEBUG MdnsScanner Found commissionable device 5690D4DCE45B9E62._matterc._udp.local with data: T: 0 DT: 266 PH: 36 ICD: 0 VP: 5010+262 DN: Smart Wi-Fi Plug RI: 01002401BB06F301F81F49A861DF63035824 PI:
    matter.0
    	2025-11-18 18:26:44.276	debug	2025-11-18 18:26:44.276 DEBUG MdnsScanner Removing commissionable device 5690D4DCE45B9E62._matterc._udp.local from cache (interface eth0) because of ttl=0
    matter.0
    	2025-11-18 18:26:41.463	debug	2025-11-18 18:26:41.463 DEBUG MdnsScanner Added 2 IPs for commissionable device 5690D4DCE45B9E62._matterc._udp.local to cache (interface eth0): type: udp ip: fe80::3e6a:d2ff:fe27:a59%eth0 port: 5540 type: udp ip: 192.168.178.151 port: 5540
    matter.0
    	2025-11-18 18:26:41.462	debug	2025-11-18 18:26:41.462 DEBUG MdnsScanner Found commissionable device 5690D4DCE45B9E62._matterc._udp.local with data: T: 0 DT: 266 PH: 36 ICD: 0 VP: 5010+262 DN: Smart Wi-Fi Plug RI: 01002401BB06F301F81F49A861DF63035824 PI:
    matter.0
    	2025-11-18 18:26:41.425	debug	2025-11-18 18:26:41.424 DEBUG MdnsScanner Removing commissionable device 5690D4DCE45B9E62._matterc._udp.local from cache (interface eth0) because of ttl=0
    matter.0
    	2025-11-18 18:26:41.403	debug	2025-11-18 18:26:41.403 DEBUG MdnsScanner Added 2 IPs for commissionable device 5690D4DCE45B9E62._matterc._udp.local to cache (interface eth0): type: udp ip: fe80::3e6a:d2ff:fe27:a59%eth0 port: 5540 type: udp ip: 192.168.178.151 port: 5540
    matter.0
    	2025-11-18 18:26:41.402	debug	2025-11-18 18:26:41.401 DEBUG MdnsScanner Found commissionable device 5690D4DCE45B9E62._matterc._udp.local with data: T: 0 DT: 266 PH: 36 ICD: 0 VP: 5010+262 DN: Smart Wi-Fi Plug RI: 01002401BB06F301F81F49A861DF63035824 PI:
    matter.0
    	2025-11-18 18:26:41.368	debug	2025-11-18 18:26:41.368 DEBUG MdnsScanner Removing commissionable device 5690D4DCE45B9E62._matterc._udp.local from cache (interface eth0) because of ttl=0
    matter.0
    	2025-11-18 18:26:41.351	debug	2025-11-18 18:26:41.351 DEBUG MdnsScanner Added 2 IPs for commissionable device 5690D4DCE45B9E62._matterc._udp.local to cache (interface eth0): type: udp ip: fe80::3e6a:d2ff:fe27:a59%eth0 port: 5540 type: udp ip: 192.168.178.151 port: 5540
    matter.0
    	2025-11-18 18:26:41.344	debug	2025-11-18 18:26:41.344 DEBUG MdnsScanner Found commissionable device 5690D4DCE45B9E62._matterc._udp.local with data: T: 0 DT: 266 PH: 36 ICD: 0 VP: 5010+262 DN: Smart Wi-Fi Plug RI: 01002401BB06F301F81F49A861DF63035824 PI:
    matter.0
    	2025-11-18 18:26:41.334	debug	2025-11-18 18:26:41.334 DEBUG MdnsScanner Removing commissionable device 5690D4DCE45B9E62._matterc._udp.local from cache (interface eth0) because of ttl=0
    matter.0
    	2025-11-18 18:26:41.331	debug	2025-11-18 18:26:41.331 DEBUG MdnsScanner Added 2 IPs for commissionable device 5690D4DCE45B9E62._matterc._udp.local to cache (interface eth0): type: udp ip: fe80::3e6a:d2ff:fe27:a59%eth0 port: 5540 type: udp ip: 192.168.178.151 port: 5540
    matter.0
    	2025-11-18 18:26:41.330	debug	2025-11-18 18:26:41.330 DEBUG MdnsScanner Found commissionable device 5690D4DCE45B9E62._matterc._udp.local with data: T: 0 DT: 266 PH: 36 ICD: 0 VP: 5010+262 DN: Smart Wi-Fi Plug RI: 01002401BB06F301F81F49A861DF63035824 PI:
    matter.0
    	2025-11-18 18:26:41.320	debug	2025-11-18 18:26:41.320 DEBUG MdnsScanner Removing commissionable device 5690D4DCE45B9E62._matterc._udp.local from cache (interface eth0) because of ttl=0
    matter.0
    	2025-11-18 18:26:41.280	debug	2025-11-18 18:26:41.280 DEBUG MdnsScanner Added 2 IPs for commissionable device 5690D4DCE45B9E62._matterc._udp.local to cache (interface eth0): type: udp ip: fe80::3e6a:d2ff:fe27:a59%eth0 port: 5540 type: udp ip: 192.168.178.151 port: 5540
    matter.0
    	2025-11-18 18:26:41.279	debug	2025-11-18 18:26:41.279 DEBUG MdnsScanner Found commissionable device 5690D4DCE45B9E62._matterc._udp.local with data: T: 0 DT: 266 PH: 36 ICD: 0 VP: 5010+262 DN: Smart Wi-Fi Plug RI: 01002401BB06F301F81F49A861DF63035824 PI:
    matter.0
    	2025-11-18 18:26:41.250	debug	2025-11-18 18:26:41.249 DEBUG MdnsScanner Removing commissionable device 5690D4DCE45B9E62._matterc._udp.local from cache (interface eth0) because of ttl=0
    matter.0
    	2025-11-18 18:26:41.244	debug	2025-11-18 18:26:41.244 DEBUG MdnsScanner Added 2 IPs for commissionable device 5690D4DCE45B9E62._matterc._udp.local to cache (interface eth0): type: udp ip: fe80::3e6a:d2ff:fe27:a59%eth0 port: 5540 type: udp ip: 192.168.178.151 port: 5540
    matter.0
    	2025-11-18 18:26:41.243	debug	2025-11-18 18:26:41.243 DEBUG MdnsScanner Found commissionable device 5690D4DCE45B9E62._matterc._udp.local with data: T: 0 DT: 266 PH: 33 ICD: 0 VP: 5010+262 DN: Smart Wi-Fi Plug RI: 01002401BB06F301F81F49A861DF63035824 PI:
    matter.0
    	2025-11-18 18:26:41.237	debug	2025-11-18 18:26:41.236 DEBUG MdnsScanner Removing commissionable device 5690D4DCE45B9E62._matterc._udp.local from cache (interface eth0) because of ttl=0
    matter.0
    	2025-11-18 18:26:41.227	debug	2025-11-18 18:26:41.227 DEBUG MdnsScanner Added 2 IPs for commissionable device 5690D4DCE45B9E62._matterc._udp.local to cache (interface eth0): type: udp ip: fe80::3e6a:d2ff:fe27:a59%eth0 port: 5540 type: udp ip: 192.168.178.151 port: 5540
    matter.0
    	2025-11-18 18:26:41.226	debug	2025-11-18 18:26:41.225 DEBUG MdnsScanner Found commissionable device 5690D4DCE45B9E62._matterc._udp.local with data: T: 0 DT: 266 PH: 33 ICD: 0 VP: 5010+262 DN: Smart Wi-Fi Plug RI: 01002401BB06F301F81F49A861DF63035824 PI:
    Gruß Duffy
    Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
    Node.js: v22.23.2
    NPM: 10.9.4
    js-controller 7.1.2
    Linux: Trixie
    • FabioF Offline
      FabioF Offline
      Fabio
      schrieb am zuletzt editiert von Fabio
      Ja was soll ich sagen @Duffy ich weiß auch nicht mehr weiter. Am besten du bleibst bei Apple und darüber dann gibst du die Geräte dann in den Controller vom Matter Adapter. Im log steht auch das er den Plug gefunden hat. Das sollte sich dann der Master of Matter mal anschauen. 😉👍 interessant ist auch er fügt den Plug hinzu und dann entfernt er ihn wieder. So lese ich das Log, aber ich habe keine Ahnung 🤷🏼
      Iobroker:
      • Matter over Thread Hilfe
      • DuffyD Offline
        DuffyD Offline
        Duffy
        Wer ist den der „Matter Master“? Der erkennt vermutlich das Problem gleich.
        Danke aber erst mal für deinen Support.
        Duffy
        Node.js: v22.23.2
        NPM: 10.9.4
        js-controller 7.1.2
        Linux: Trixie
        • DuffyD Duffy
          Duffy
          sigi234S Online
          sigi234S Online
          @Duffy sagte in Bedienungsanleitung für Matter:
          Duffy
          @apollon77
          • DuffyD Offline
            DuffyD Offline
            Duffy
            Ok, danke den hatte ich schon mal erwähnt.
            Vielleicht findet @apollon77 mal Zeit da drauf zu schauen, wäre echt klasse.
            Viele Grüße Duffy
            Node.js: v22.23.2
            NPM: 10.9.4
            js-controller 7.1.2
            Linux: Trixie
            • apollon77A Offline
              Wenn Du die Visu App nutzt dann sollte man an sich im Log sehen das die App - wenn Apple den ersten Teil des Pairings gemacht hat - Nachrichten sendet. die fehlen in deinem Log komplett.Wäre interessant ggf noch das Debug Log des iot Adapters mit zu sehen.
              Für Deinen BLE Versuch fehlen mir auch logs, die du aber bestimmt abgeschnitten hast weil ich behaupte das da kein BLE ist -entweder weil es nicht initialisiert werden konnte oder weil der QR Code den du gescannt hast kein "BlE Flag" enthalten hat.
              Wenn Du APple hast: versuch doch mal das Gerät direkt mit Apple home zu pairen und dann an ioBroker zu übergeben. geht das?
              • DuffyD Offline
                DuffyD Offline
                Duffy
                @apollon77 sagte in Bedienungsanleitung für Matter:
                Wie kann ich das feststellen?
                Muss ich eigenlich im iphone oder ipad das Bluetooth von der Steckdose sehen wenn sie sich im Kopplungsmodus befindet?
                Ich habe heute die ganze Prozedur noch einmal durchgeführt mit eingeschaltetem Debug für Matter und iot. Hier das File aus opt/iobroker/log/ iobroker.2025-11-19.log
                Auch heute ist die Anmeldung misslungen.
                Die Steckdose sollte eigentlich Bluetooth haben:
                Ja das geht!!
                Die Steckdose hatte ich schon erfolgreich mit Apple Home verbunden und auch mit der Tapo App und aus diesen Ökosystemen heraus auch mit dem Matter Adaper. Es ist mir aber leider noch nie gelungen die Steckdose direkt über den Matter Adapter mit dem ioBroker zu verbinden.
                Soll ich vielleicht mal eine andere Steckdose versuchen, wenn ja welche?
                Kannst du, @apollon77, aus dem Log erkennen wo das Problem liegen könnte?
                Kannst du mir bitte weiter helfen? Hier glaube ich ist inzwischen Expertenwissen gefragt.
                VG Duffy
                Node.js: v22.23.2
                NPM: 10.9.4
                js-controller 7.1.2
                Linux: Trixie
                • DuffyD Offline
                  DuffyD Offline
                  Duffy
                  @apollon77
                  Hallo apollon77,
                  Darf ich mich noch mal in Erinnerung rufen bezüglich meines Problems?
                  Kannst mir bitte weiterhelfen?
                  Viele Grüße Duffy
                  Node.js: v22.23.2
                  NPM: 10.9.4
                  js-controller 7.1.2
                  Linux: Trixie
                  • DuffyD Offline
                    DuffyD Offline
                    Duffy
                    So, eine andere Matter Steckdose von Switchbot gekauft und ausprobiert.
                    Die lässt sich auch nicht über die Visu App verbinden.
                    Zur Original Switchbot App ja, lässt sich dort schalten und Stromverbrauch ablesen. Nach einem weiteren Verbinden zu Apple home lässt sie sich nur noch schalten es wird kein Stromverbrauch mehr angezeigt. Bei einem weiteren Verbinden von entweder Switchbot oder Apple home zum Matter Adapter erscheint zwar noch die Steckdose aber da lässt sie sich gar nicht erst schalten ganz zu schweigen von der Stromverbrauchsanzeige. Schöne neue Matter Welt. Hat jemand einen Tipoder ähnliche Erfahrungen?
                    Node.js: v22.23.2
                    NPM: 10.9.4
                    js-controller 7.1.2
                    Linux: Trixie
                    FabioF 1 Antwort Letzte Antwort
                    • DuffyD Duffy
                      FabioF Offline
                      FabioF Offline
                      Fabio
                      ... das wird im Moment noch nicht unterstüzt Matter seitig. Aber es sollen/ werden Updates folgen, dann kannst du auch den Verbrauch ablesen in Apple Home etc.
                      Fabio
                      Iobroker:
                      • FabioF Offline
                        FabioF Offline
                        Fabio
                        @Duffy, ganz ehrlich, ich weiß nicht warum du direkt in dem Matter Adapter willst. Du hast doch Apple, das ist im Moment das beste stabiliste System für Matter.
                        Mach es über den Controller und berichte mir ob das geht.
                        Also erst in Apple einbinden dann Controller starten, in Apple Pairing freigeben, im Controller dann Zahlenkombination eingeben und koppeln. Und ja du hast natürlich Recht da sollte auch im Matter Adapter klappen.
                        Fabio
                        Iobroker:
                        • DuffyD Offline
                          DuffyD Offline
                          Duffy
                          Hi @Fabio,
                          Ich habe die Steckdose zurück gesetzt und dann neu in Apple Home eingebunden.
                          Die Steckdose lässt sich schalten aber der Stromverbrauch wird nicht angezeigt.
                          In Apple Home den Kopplungsmodus gestartet
                          Dann im Matter Adapter in Geräte erkennen und koppeln die Steckdose gefunden und mit dem Code verbunden
                          Die Steckdose erscheint im Matter Adapter aber lässt sich nicht schalten.
                          Da hat es ja mit der Tapo Steckdose noch besser geklappt :-)
                          Ich denke Matter wird bei mir nichts mehr und die Steckdose kann ich der Entsorgung zuführen.
                          Gruß Duffy
                          Node.js: v22.23.2
                          NPM: 10.9.4
                          js-controller 7.1.2
                          Linux: Trixie
                          • simatecS Offline
                            simatecS Offline
                            simatec
                            Was sagt denn dein IPv6 Netzwerk? Hast du v6 aktiv und bekommen dein Handy und iobroker ein v6 Adresse?
                            • Besuche meine Github Seite
                            • HowTo Restore ioBroker
                            DuffyD 1 Antwort Letzte Antwort
                            • simatecS simatec
                              DuffyD Offline
                              DuffyD Offline
                              Duffy
                              @simatec sagte in Bedienungsanleitung für Matter:
                              V6 habe ich aktiv ich weis aber nicht wo ich finden kann ob das iphone im ipV6 drin ist.
                              Ich kann nur sagen das eine Tapo Steckdose über Apple Home in den Matter Adapter eingebunden ist und auch funktioniert.
                              Ist vielelicht das Häckchen bei ipV4 das Problem?
                              Node.js: v22.23.2
                              NPM: 10.9.4
                              js-controller 7.1.2
                              Linux: Trixie
                              • DuffyD Duffy
                                Hi @Fabio,
                                Gruß Duffy
                                FabioF Offline
                                FabioF Offline
                                Fabio
                                bitte den zweiten Reiter im mal Controller nutzen:
                                Gerät per Pairing-Code oder QR-Code hinzufügen und noch mal probieren.
                                Alles wieder auf Anfang bitte. UND NOCH mal Matter, unterstüzt im Moment kein Stromverbrauch ich hoffe du hast das jetzt verstanden.;-)
                                Und manchmal braucht es echt Minuten bis Matter Geräte die neu hinzugefügt worden um die Schaltbefehle auszuführen. Nein IP4 hat nichts damit zu tun.
                                Fabio
                                Iobroker:
                                • FabioF Fabio
                                  Fabio
                                  DuffyD Offline
                                  DuffyD Offline
                                  Duffy
                                  @Fabio sagte in Bedienungsanleitung für Matter:
                                  Hmm, warum ist es dann bei der Tapo da und funktioniert???
                                  Gerät per Pairing-Code oder QR-Code hinzufügen und noch mal probeiren .
                                  Hatte ich auch schon versucht, gleiches Ergebnis.
                                  Gruß Duffy
                                  Node.js: v22.23.2
                                  NPM: 10.9.4
                                  js-controller 7.1.2
                                  Linux: Trixie
                                  • DuffyD Duffy
                                    Gruß Duffy
                                    FabioF Offline
                                    FabioF Offline
                                    Fabio
                                    weil das in der Tapo App so konfiguriert ist und bei Apple Home noch nicht. Man muss wohl geduldig sein und warten wann dann alle auf die neuste Matter Version updaten.
                                    Fabio
                                    Iobroker:
