  4. Fehler bei Aufruf vom adapter- menü im iorboker
    6.1k
21 Beiträge 5 Kommentatoren 1.1k Aufrufe 4 Beobachtet
  • S Salzmicha
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Raspbian GNU/Linux 11 (bullseye)
       Static hostname: iobroker
             Icon name: computer
                Kernel: Linux 6.1.21-v7+
          Architecture: arm
    OS is similar to: debian
    Model           : Raspberry Pi 2 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     17:54:02 up 31 min,  1 user,  load average: 2.76, 1.92, 1.03
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-11-26 17:54:03 CET
               Universal time: Wed 2025-11-26 16:54:03 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    salzmicha
    HOME=/home/salzmicha
    GROUPS=salzmicha adm dialout sudo audio video plugdev users iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            921M        575M        101M        0.0K        244M        331M
    Swap:            99M         36M         63M
    Total:          1.0G        611M        165M
    Active iob-Instances:   3
              921 M total memory
              575 M used memory
              227 M active memory
              517 M inactive memory
              101 M free memory
               64 M buffer memory
              180 M swap cache
               99 M total swap
               36 M used swap
               63 M free swap
    top - 17:54:04 up 31 min,  1 user,  load average: 2.76, 1.92, 1.03
    Tasks: 143 total,   1 running, 142 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 25.6 us,  9.3 sy,  0.0 ni, 64.0 id,  0.0 wa,  0.0 hi,  1.2 si,  0.0 st
    MiB Mem :    922.0 total,    101.6 free,    575.4 used,    245.0 buff/cache
    MiB Swap:    100.0 total,     64.0 free,     36.0 used.    331.5 avail Mem
    *** FAILED SERVICES ***
      UNIT               LOAD   ACTIVE SUB    DESCRIPTION
    * networking.service loaded failed failed Raise network interfaces
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       29G   16G   12G  57% /
    devtmpfs       devtmpfs  333M     0  333M   0% /dev
    tmpfs          tmpfs     461M     0  461M   0% /dev/shm
    tmpfs          tmpfs     185M  988K  184M   1% /run
    /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
    /dev/sda1      vfat      2.0G  407M  1.6G  21% /media/usbstick
    tmpfs          tmpfs      93M     0   93M   0% /run/user/1001
    [Wed Nov 26 17:22:28 2025] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=d291f64d-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Nov 26 17:22:32 2025] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Wed Nov 26 17:22:32 2025] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Wed Nov 26 17:22:33 2025] EXT4-fs (mmcblk0p2): recovery complete
    [Wed Nov 26 17:22:33 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Nov 26 17:22:33 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Wed Nov 26 17:22:37 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET            SOURCE         FSTYPE OPTIONS
    /                 /dev/mmcblk0p2 ext4   rw,noatime
    |-/boot           /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/media/usbstick /dev/sda1      vfat   rw,noatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    /var:
    1.7G    /var/
    1.3G    /var/log
    1.1G    /var/log/journal/167fa8959c39415296d5e2faea7832cf
    251M    /var/lib
    Archived and active journals take up 1.0G in the file system.
    /opt/iobroker/backups:
    11G     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    184M    /opt/iobroker/iobroker-data/
    133M    /opt/iobroker/iobroker-data/files
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    45M     /opt/iobroker/iobroker-data/backup-objects
    38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    6.1M    /opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** ZigBee Settings ***
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    nodejs:                 N/A
    /usr/bin/node           v16.20.2
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    /usr/bin/corepack       0.17.0
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 16.20.2-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
     *** 16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u7 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 5.0.19, hostname: iobroker      , alive, uptime: 178)
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     7.8.0
    nodejs modules from github:     0
    Adapter State
      system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.ds18b20.0                : ds18b20               : iobroker                                 -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
      system.adapter.habpanel.0               : habpanel              : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 6.13.16 [Updatable]
    Adapter    "backitup"     : 3.3.10   , installed 2.11.0 [Updatable]
    Adapter    "deconz"       : 1.6.4    , installed 1.4.0  [Updatable]
    Adapter    "discovery"    : 5.0.0    , installed 4.4.0  [Updatable]
    Adapter    "ds18b20"      : 3.1.1    , installed 2.0.5  [Updatable]
    Adapter    "email"        : 2.0.4    , installed 1.2.2  [Updatable]
    Adapter    "fullybrowser" : 3.1.2    , installed 3.0.12 [Updatable]
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "javascript"   : 9.0.11   , installed 7.8.0  [Updatable]
    Controller "js-controller": 7.0.7    , installed 5.0.19 [Updatable]
    Adapter    "mqtt"         : 6.1.4    , installed 5.1.0  [Updatable]
    Adapter    "pushover"     : 4.1.0    , installed 3.0.6  [Updatable]
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.7.1    , installed 6.6.0  [Updatable]
    Adapter    "sonoff"       : 3.2.1    , installed 3.0.3  [Updatable]
    Adapter    "web"          : 7.0.8    , installed 6.2.3  [Updatable]
    Adapter    "ws"           : 2.6.2    , installed 2.6.1  [Updatable]
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 3.1.5    , installed 1.8.24 [Updatable]
    Objects and States
    Objects:        531
    States:         414
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Get:3 https://repos.influxdata.com/debian bullseye InRelease [12.9 kB]
    Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
    Get:5 https://packages.grafana.com/oss/deb stable InRelease [7661 B]
    Err:3 https://repos.influxdata.com/debian bullseye InRelease
    Err:5 https://packages.grafana.com/oss/deb stable InRelease
    Fetched 12.9 kB in 4s (3629 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        1932       580/influxd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       23695      2218/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       23688      2218/iobroker.js-co
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       25692      2344/io.sonoff.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1875       456/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      110        12168      576/grafana-server
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       22990      2267/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       23912      2388/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        12600      580/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1877       456/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14040      575/dhcpcd
    udp        0      0 0.0.0.0:41159           0.0.0.0:*                           108        1803       287/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1801       287/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          12516      575/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        1802       287/avahi-daemon: r
    udp6       0      0 :::33574                :::*                                108        1804       287/avahi-daemon: r
    2025-11-26 17:53:03.911  - info: ds18b20.0 (2381) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.ds18b20, node: v16.20.2, js-controller: 5.0.19
    2025-11-26 17:53:06.321  - info: web.0 (2388) starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.web, node: v16.20.2, js-controller: 5.0.19
    2025-11-26 17:53:07.890  - info: web.0 (2388) socket.io server listening on port 8082
    2025-11-26 17:53:07.960  - info: web.0 (2388) habpanel server listening on port 8082
    2025-11-26 17:53:07.965  - info: web.0 (2388) habpanel web extension - Install extension on /rest/habpanel/
    2025-11-26 17:53:07.969  - info: web.0 (2388) Connect extension "habpanel/lib/habpanelapi.js"
    2025-11-26 17:53:08.024  - info: web.0 (2388) http server listening on port 8082
    2025-11-26 17:53:08.885  - info: zigbee.0 (2337) starting. Version 1.8.24 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.20.2, js-controller: 5.0.19
    2025-11-26 17:53:09.617  - info: zigbee.0 (2337) delete old Backup files. keep only last 10
    2025-11-26 17:53:09.629  - info: zigbee.0 (2337) Starting Zigbee  npm ...
    2025-11-26 17:53:11.162  - info: zigbee.0 (2337) Installed Version: iobroker.zigbee@1.8.24
    2025-11-26 17:53:14.238  - info: zigbee.0 (2337) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
    2025-11-26 17:53:14.256  - info: zigbee.0 (2337) Unable to disable LED, unsupported function.
    2025-11-26 17:53:14.359  - info: zigbee.0 (2337)   --> transmitPower : normal
    2025-11-26 17:53:14.402  - info: zigbee.0 (2337) Currently 7 devices are joined:
    2025-11-26 17:53:14.614  - info: zigbee.0 (2337) 0x00158d0008d0731e (addr 14076): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2025-11-26 17:53:14.645  - info: zigbee.0 (2337) 0xa4c1384c5f1dad1e (addr 53945): WHD02 - TuYa Wall switch module (Router)
    2025-11-26 17:53:14.654  - info: zigbee.0 (2337) 0x00158d0008e02765 (addr 1943): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2025-11-26 17:53:14.663  - info: zigbee.0 (2337) 0x00124b002a5d75b5 (addr 33048): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
    2025-11-26 17:53:14.671  - info: zigbee.0 (2337) 0x00158d00093e8cb0 (addr 56553): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2025-11-26 17:53:14.679  - info: zigbee.0 (2337) 0x00158d008b33593a (addr 24120): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2025-11-26 17:53:14.687  - info: zigbee.0 (2337) 0xa4c138f80abe94e8 (addr 62307): WHD02 - TuYa Wall switch module (Router)
    2025-11-26 17:53:14.692  - info: zigbee.0 (2337) Zigbee started
    2025-11-26 17:53:14.957  - info: zigbee.0 (2337) debug devices set to []
    2025-11-26 17:53:18.650  - info: sonoff.0 (2344) Client [DVES_C68049] connected with secret 1764175998619_6999
    iob diag has finished.
    @Salzmicha sagte in Fehler bei Aufruf vom adapter- menü im iorboker:
    Ist tot, kannst du gleich mal neuinstallieren.
    Ob das aber auf einem Raspberry Pi 2 Model B Rev 1.1 Sinn ergibt ist die nächste Frage.
    nodejs muss aktualisert werden:
    Per
    iob nodejs-update
    am besten.
    Der js-controller: 5.0.19 muss auch aktualisiert werden, die ganzen Adapter ohnehin.
    Das influxdb-Repo muss nochmal neuangelegt werden. Siehe:
    https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
      Salzmicha
      ja, aber ich kann ja nichts mehr aktualesieren, da PI2. Ich verstehe nicht das ein Softwarestand der alt ist und mal lief, jetzt nach der installation nicht mehr geht.
      schade
      Thomas BraunT mcm1957M CodierknechtC 3 Antworten Letzte Antwort
      • S Salzmicha
        schade
        Was hindert dich konkret?
        Ich hab so'n Ding nicht mehr, aber noch sollte man da ein aktuelles nodejs drauf bekommen.
        Aber mit nodejs@24 nicht mehr, das wird wohl nicht mehr auf 32Bit laufen.
        Mit dem RPi2 / 1GB RAM ist aber auch heute schon kein Staat mehr zu machen.
          Salzmicha
          aber danke
          • S Salzmicha
            schade
            mcm1957M Offline
            mcm1957M Offline
            mcm1957
            schade
            Was meinst du mit "nach der Installation" ?
            Ich vermute, dass die veraltete Admin Version Daten erwartet die das aktuelle Repo nicht mehr zur Verfügung stellt. Ist aber nur eine Vermutung. Genauer wird das nur leider kaum wer analysieren solange das Problem mit den aktuellen Versionen nicht (mehr) auftritt.
            Support Repositoryverwaltung.
            LESEN - gute Forenbeitrage
              Salzmicha
              wahrscheinlich ist es besser das ich mich um bessere Hardware kümmere. Abschlussfrage, kann ich das jetzige Image auf dem neuen System nutzen.
              • S Salzmicha
                Nein. Installier es von Grund auf neu.
                Allerdings wird auch ein Umzug mittels Backitup-Adapter aus dem versumpften System eher nicht funktionieren, Versionsdelta hast du zu groß werden lassen.
                • S Salzmicha
                  schade
                  CodierknechtC Online
                  Codierknecht
                  schade
                  Windows 95 hat auch mal funktioniert ;-)
                  HmIP|ZigBee|Tasmota|Unifi
                  Zabbix Certified Specialist
                  • CodierknechtC Codierknecht
                    schade
                    @Codierknecht sagte in Fehler bei Aufruf vom adapter- menü im iorboker:
                    Weiß ich nicht... Hat das jemals richtig funktioniert? ;-)
                      Codierknecht
                      @Thomas-Braun sagte in Fehler bei Aufruf vom adapter- menü im iorboker:
                      Die Einen sagen so, die anderen so :-D
