  3. Off Topic
  4. Bluetooth auf Raspberry 5 aktivieren
    1.7k
    2.4k
raspberry 5
12 Beiträge 3 Kommentatoren 622 Aufrufe 4 Beobachtet
    michihorn
    schrieb am zuletzt editiert von michihorn
    Hallo
    Bluetooth war nie ein Thema für meine Raspi, ich möchte aber jetzt Radar2 mal testen.
    Aktuell sieht Bluetooth bei mir so aus:
    pi@rp5:~ $ sudo systemctl enable bluetooth.service
    sudo systemctl start bluetooth.service
    Synchronizing state of bluetooth.service with SysV service script with /lib/systemd/systemd-sysv-install.
    Executing: /lib/systemd/systemd-sysv-install enable bluetooth
    pi@rp5:~ $ blacklist hci_uart
    blacklist btbcm
    -bash: blacklist: command not found
    pi@rp5:~ $ sudo modprobe btusb
    pi@rp5:~ $ sudo systemctl start bluetooth.service
    pi@rp5:~ $ sudo systemctl status bluetooth.service
    ● bluetooth.service - Bluetooth service
         Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; preset: enabled)
         Active: active (running) since Mon 2025-11-24 17:14:06 CET; 33min ago
           Docs: man:bluetoothd(8)
       Main PID: 675 (bluetoothd)
         Status: "Running"
          Tasks: 1 (limit: 19366)
            CPU: 360ms
         CGroup: /system.slice/bluetooth.service
                 └─675 /usr/libexec/bluetooth/bluetoothd
    Nov 24 17:14:06 rp5 bluetoothd[675]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
    Nov 24 17:14:06 rp5 bluetoothd[675]: src/plugin.c:plugin_init() Failed to init mcp plugin
    Nov 24 17:14:06 rp5 bluetoothd[675]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
    Nov 24 17:14:06 rp5 bluetoothd[675]: src/plugin.c:plugin_init() Failed to init bap plugin
    Nov 24 17:14:06 rp5 bluetoothd[675]: Bluetooth management interface 1.23 initialized
    Nov 24 17:14:06 rp5 bluetoothd[675]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
    Nov 24 17:14:06 rp5 bluetoothd[675]: sap-server: Operation not permitted (1)
    Nov 24 17:14:06 rp5 bluetoothd[675]: Failed to set mode: Failed (0x03)
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Static hostname: rp5
          Icon name: computer
             Kernel: Linux 6.12.47+rpt-rpi-2712
       Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
    17:51:34 up 37 min,  2 users,  load average: 1.33, 0.81, 0.91
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                  Local time: Mon 2025-11-24 17:51:34 CET
              Universal time: Mon 2025-11-24 16:51:34 UTC
                    RTC time: Mon 2025-11-24 16:51:34
                 NTP service: active
             RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             17G        4.4G         11G        5.7M        1.6G         12G
    Swap:           209M          0B        209M
    Total:           17G        4.4G         11G
    Active iob-Instances:   46
           16219 M total memory
            4214 M used memory
            4142 M active memory
             934 M inactive memory
           10572 M free memory
             170 M buffer memory
            1387 M swap cache
             199 M total swap
               0 M used swap
             199 M free swap
    top - 17:51:34 up 37 min,  2 users,  load average: 1.33, 0.81, 0.91
    Tasks: 225 total,   1 running, 224 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni, 66.7 id, 33.3 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  16219.1 total,  10572.3 free,   4214.3 used,   1558.2 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.  12004.8 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  7.9G     0  7.9G   0% /dev
    tmpfs          tmpfs     3.2G  5.4M  3.2G   1% /run
    /dev/sda2      ext4       56G   22G   32G  41% /
    tmpfs          tmpfs     8.0G     0  8.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
    [Mon Nov 24 17:13:57 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=88:A2:9E:37:34:B1 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1accb916-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Mon Nov 24 17:14:01 2025] EXT4-fs (sda2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
    [Mon Nov 24 17:14:03 2025] EXT4-fs (sda2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    4.3G    /var/
    3.5G    /var/log/journal/f850b20d47334ae3b5c568afabe7a4f6
    3.5G    /var/log
    409M    /var/cache
    Archived and active journals take up 3.4G in the file system.
    /opt/iobroker/backups:
    750M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    807M    /opt/iobroker/iobroker-data/
    372M    /opt/iobroker/iobroker-data/files
    235M    /opt/iobroker/iobroker-data/history
    139M    /opt/iobroker/iobroker-data/backup-objects
    48M     /opt/iobroker/iobroker-data/files/vis.0
    36M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    23M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
    22M     /opt/iobroker/iobroker-data/states.jsonl
    9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
    USB-Devices by-id:
    No Devices found 'by-id'
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.5
    /usr/bin/node           v20.19.5
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.33.0
    nodejs:
     Installed: 20.19.5-1nodesource1
     Candidate: 20.19.5-1nodesource1
     Version table:
    *** 20.19.5-1nodesource1 1001
           500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
        20.19.4-1nodesource1 1001
        20.19.3-1nodesource1 1001
        20.19.2-1nodesource1 1001
        20.19.1-1nodesource1 1001
        20.19.0-1nodesource1 1001
        20.18.3-1nodesource1 1001
        20.18.2-1nodesource1 1001
        20.18.1-1nodesource1 1001
        20.18.0-1nodesource1 1001
        20.17.0-1nodesource1 1001
        20.16.0-1nodesource1 1001
        20.15.1-1nodesource1 1001
        20.15.0-1nodesource1 1001
        20.14.0-1nodesource1 1001
        20.13.1-1nodesource1 1001
        20.13.0-1nodesource1 1001
        20.12.2-1nodesource1 1001
        20.12.1-1nodesource1 1001
        20.12.0-1nodesource1 1001
        20.11.1-1nodesource1 1001
        20.11.0-1nodesource1 1001
        20.10.0-1nodesource1 1001
        20.9.0-1nodesource1 1001
        20.8.1-1nodesource1 1001
        20.8.0-1nodesource1 1001
        20.7.0-1nodesource1 1001
        20.6.1-1nodesource1 1001
        20.6.0-1nodesource1 1001
        20.5.1-1nodesource1 1001
        20.5.0-1nodesource1 1001
        20.4.0-1nodesource1 1001
        20.3.1-1nodesource1 1001
        20.3.0-1nodesource1 1001
        20.2.0-1nodesource1 1001
        20.1.0-1nodesource1 1001
        20.0.0-1nodesource1 1001
        18.20.4+dfsg-1~deb12u1 500
           500 http://deb.debian.org/debian bookworm/main arm64 Packages
           500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    rp5                 rp5 (version: 7.0.7, hostname: rp5           , alive, uptime: 2241)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     7
    +-- esphome-b2500@0.1.0 (git+ssh://git@github.com/tomquist/esphome-b2500.git#ce2a7064dcf4e4aaf0fe4ef28ee6ec1b0c6634d0)
    +-- iobroker.countdown@3.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.countdown.git#e7682903a091a485d433869b17a6843130863e60)
    +-- iobroker.fullybrowser@3.1.2 (git+ssh://git@github.com/arteck/ioBroker.fullybrowser.git#5ab2d7d12f921a1059e0ad5b4339e92a69cbc727)
    +-- iobroker.onvif@1.1.4 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.onvif.git#618669c8cebb8b3fae6f1155131e3bbfa503fd27)
    +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#fd3b7f9f362a348741cbe18d70a130d2bfee6727)
    +-- iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
    +-- iobroker.vis@1.5.6 (git+ssh://git@github.com/iobroker/ioBroker.vis.git#3265f32a4286763a723ba22bc9c0cbcb448002a8)
    Adapter State
    + system.adapter.admin.0                  : admin                 : rp5                                      -  enabled, compact disabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : rp5                                      -  enabled, compact disabled
    + system.adapter.ankersolix2.0            : ankersolix2           : rp5                                      -  enabled, compact disabled
    + system.adapter.backitup.0               : backitup              : rp5                                      -  enabled, compact disabled
    + system.adapter.countdown.0              : countdown             : rp5                                      -  enabled, compact disabled
     system.adapter.daswetter.0              : daswetter             : rp5                                      -  enabled, compact disabled
     system.adapter.daswetter.1              : daswetter             : rp5                                      -  enabled, compact disabled
    + system.adapter.device-watcher.0         : device-watcher        : rp5                                      -  enabled, compact disabled
     system.adapter.dwd.0                    : dwd                   : rp5                                      -  enabled, compact disabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: rp5                                      -  enabled, compact disabled
     system.adapter.feiertage.0              : feiertage             : rp5                                      -  enabled, compact disabled
    + system.adapter.fritzbox.0               : fritzbox              : rp5                                      -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : rp5                                      -  enabled, compact disabled
    + system.adapter.ham.0                    : ham                   : rp5                                      -  enabled
    + system.adapter.history.0                : history               : rp5                                      -  enabled, compact disabled
    + system.adapter.hm-rega.0                : hm-rega               : rp5                                      -  enabled, compact disabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : rp5                                      -  enabled, compact disabled
    + system.adapter.hm-rpc.1                 : hm-rpc                : rp5                                      -  enabled, compact disabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : rp5                                      -  enabled, compact disabled, port: 0
    + system.adapter.hue.0                    : hue                   : rp5                                      -  enabled, compact disabled, port: 443
     system.adapter.ical.0                   : ical                  : rp5                                      -  enabled, compact disabled
     system.adapter.icons-material-png.0     : icons-material-png    : rp5                                      - disabled
     system.adapter.icons-mfd-png.0          : icons-mfd-png         : rp5                                      - disabled
    + system.adapter.influxdb.0               : influxdb              : rp5                                      -  enabled, compact disabled, port: 8086
    + system.adapter.iot.0                    : iot                   : rp5                                      -  enabled, compact disabled
    + system.adapter.iot.1                    : iot                   : rp5                                      -  enabled, compact disabled
    + system.adapter.iot.2                    : iot                   : rp5                                      -  enabled, compact disabled
    + system.adapter.javascript.0             : javascript            : rp5                                      -  enabled, compact disabled
    + system.adapter.mqtt-client.1            : mqtt-client           : rp5                                      -  enabled, compact disabled, port: 3145
    + system.adapter.mqtt.1                   : mqtt                  : rp5                                      -  enabled, compact disabled, port: 3020, bind: 0.0.0.0
    + system.adapter.notificationforandroidtv.0: notificationforandroidtv: rp5                                      -  enabled, compact disabled
    + system.adapter.onvif.0                  : onvif                 : rp5                                      -  enabled, compact disabled
    + system.adapter.ping.0                   : ping                  : rp5                                      -  enabled, compact disabled
    + system.adapter.pollenflug.0             : pollenflug            : rp5                                      -  enabled, compact disabled
    + system.adapter.pvforecast.0             : pvforecast            : rp5                                      -  enabled, compact disabled
    + system.adapter.radar2.0                 : radar2                : rp5                                      -  enabled
    + system.adapter.reolink.0                : reolink               : rp5                                      -  enabled, compact disabled
    + system.adapter.ring.0                   : ring                  : rp5                                      -  enabled, compact disabled
    + system.adapter.simple-api.0             : simple-api            : rp5                                      -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartgarden.0            : smartgarden           : rp5                                      -  enabled, compact disabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : rp5                                      -  enabled, compact disabled
    + system.adapter.tahoma.0                 : tahoma                : rp5                                      -  enabled, compact disabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : rp5                                      -  enabled, compact disabled
    + system.adapter.telegram-menu.0          : telegram-menu         : rp5                                      -  enabled, compact disabled
    + system.adapter.telegram.0               : telegram              : rp5                                      -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : rp5                                      -  enabled, compact disabled
    + system.adapter.tuya.1                   : tuya                  : rp5                                      -  enabled, compact disabled
    + system.adapter.vaillant.0               : vaillant              : rp5                                      -  enabled, compact disabled
     system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : rp5                                      - disabled
     system.adapter.vis-colorpicker.0        : vis-colorpicker       : rp5                                      - disabled
     system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : rp5                                      - disabled
     system.adapter.vis-google-fonts.0       : vis-google-fonts      : rp5                                      -  enabled, compact disabled
     system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : rp5                                      - disabled
     system.adapter.vis-icontwo.0            : vis-icontwo           : rp5                                      -  enabled, compact disabled
     system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : rp5                                      - disabled
     system.adapter.vis-justgage.0           : vis-justgage          : rp5                                      - disabled
     system.adapter.vis-materialdesign.0     : vis-materialdesign    : rp5                                      - disabled
     system.adapter.vis-metro.0              : vis-metro             : rp5                                      - disabled
     system.adapter.vis-owl.0                : vis-owl               : rp5                                      - disabled
     system.adapter.vis-timeandweather.0     : vis-timeandweather    : rp5                                      - disabled
     system.adapter.vis.0                    : vis                   : rp5                                      -  enabled, compact disabled
    + system.adapter.web.0                    : web                   : rp5                                      -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : rp5                                      -  enabled, compact disabled
    + system.adapter.zigbee.0                 : zigbee                : rp5                                      -  enabled, compact disabled, port: tcp://192.168.178.68:3334
    + system.adapter.zigbee.1                 : zigbee                : rp5                                      -  enabled, compact disabled, port: tcp://192.168.178.151:3333
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "ankersolix2"  : 2.4.1    , installed 2.3.0  [Updatable]
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "countdown"    : 3.0.0    , installed 3.0.0
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.6
    Adapter    "device-watcher": 2.13.1  , installed 2.13.1
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "espresense"   : 0.6.3    , installed 0.6.3
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hm-rpc"       : 2.0.2    , installed 3.0.1
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "javascript"   : 8.9.2    , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "ping"         : 1.6.2    , installed 1.7.9
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
    Adapter    "radar2"       : 2.4.0    , installed 2.4.0
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "ring"         : 6.4.0    , installed 6.4.0
    Adapter    "simple-api"   : 2.8.0    , installed 3.0.7
    Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "tahoma"       : 0.10.4   , installed 0.10.4
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram-menu": 3.2.0    , installed 3.2.0
    Adapter    "tuya"         : 3.16.0   , installed 3.17.0
    Adapter    "vis-hqwidgets": 1.5.1    , installed 1.6.0
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "web"          : 7.0.8    , installed 7.0.9
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "zigbee"       : 3.1.5    , installed 3.1.6
    Objects and States
    Objects:        42351
    States:         35285
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 https://repos.influxdata.com/debian stable InRelease
    Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 2
    *** Listening Ports ***
    tcp        0      0 192.168.178.191:8701    0.0.0.0:*               LISTEN      1001       9644       1424/io.hm-rpc.1
    tcp        0      0 192.168.178.191:2010    0.0.0.0:*               LISTEN      1001       8774       1432/io.hm-rpc.2
    tcp        0      0 192.168.178.191:2001    0.0.0.0:*               LISTEN      1001       10718      1397/io.hm-rpc.0
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      106        4918       941/influxd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5037       988/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6035       988/iobroker.js-con
    tcp        0      0 0.0.0.0:3020            0.0.0.0:*               LISTEN      1001       9117       1637/io.mqtt.1
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7302       801/sshd: /usr/sbin
    tcp6       0      0 :::8086                 :::*                    LISTEN      106        8040       941/influxd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       13847      2120/io.simple-api.
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6713       1032/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13892      2075/io.web.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      107        8081       987/grafana
    tcp6       0      0 :::3001                 :::*                    LISTEN      1001       9908       1665/io.fullybrowse
    tcp6       0      0 :::22                   :::*                    LISTEN      0          7304       801/sshd: /usr/sbin
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       33534      3624/io.radar2.0
    udp        0      0 0.0.0.0:35413           0.0.0.0:*                           104        4755       673/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4753       673/avahi-daemon: r
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       15595      1652/io.tuya.1
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       15596      1652/io.tuya.1
    udp6       0      0 fe80::babe:a64d:739:546 :::*                                0          7387       764/NetworkManager
    udp6       0      0 fe80::2a6a:9336:56b:546 :::*                                0          7380       764/NetworkManager
    udp6       0      0 :::42597                :::*                                104        4756       673/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        4754       673/avahi-daemon: r
    2025-11-24 17:52:04.998  - error: host.rp5 Caught by controller[1]:  7: 0x10a2640 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.telegram.0]
    2025-11-24 17:52:04.998  - error: host.rp5 Caught by controller[1]:  8: 0x1081660 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.telegram.0]
    2025-11-24 17:52:04.998  - error: host.rp5 Caught by controller[1]:  9: 0x1072ed8 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [io.telegram.0]
    2025-11-24 17:52:04.998  - error: host.rp5 Caught by controller[1]: 10: 0x10761a0 v8::internal::FactoryBase<v8::internal::Factory>::NewRawTwoByteString(int, v8::internal::AllocationType) [io.telegram.0]
    2025-11-24 17:52:04.998  - error: host.rp5 Caught by controller[1]: 11: 0x14e80f8 v8::internal::IncrementalStringBuilder::Extend() [io.telegram.0]
    2025-11-24 17:52:04.998  - error: host.rp5 Caught by controller[1]: 12: 0x11d56d0 v8::internal::JsonStringifier::SerializeString(v8::internal::Handle<v8::internal::String>) [io.telegram.0]
    2025-11-24 17:52:04.998  - error: host.rp5 Caught by controller[1]: 13: 0x11da348 v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_<false>(v8::internal::Handle<v8::internal::Object>, bool, v8::internal::Handle<v8::internal::Object>) [io.telegram.0]
    2025-11-24 17:52:04.998  - error: host.rp5 Caught by controller[1]: 14: 0x11dbb20 v8::internal::JsonStringify(v8::internal::Isolate*, v8::internal::Handle<v8::internal::Object>, v8::internal::Handle<v8::internal::Object>, v8::internal::Handle<v8::internal::Object>) [io.telegram.0]
    2025-11-24 17:52:04.998  - error: host.rp5 Caught by controller[1]: 15: 0xf3d600 v8::internal::Builtin_JsonStringify(int, unsigned long*, v8::internal::Isolate*) [io.telegram.0]
    2025-11-24 17:52:04.998  - error: host.rp5 Caught by controller[1]: 16: 0x1894964  [io.telegram.0]
    2025-11-24 17:52:04.998  - warn: host.rp5 instance system.adapter.telegram.0 terminated due to SIGABRT
    2025-11-24 17:52:04.998  - info: host.rp5 instance system.adapter.telegram.0 terminated with code null ()
    2025-11-24 17:52:04.998  - info: host.rp5 Restart adapter system.adapter.telegram.0 because enabled
    2025-11-24 17:52:09.770  - info: javascript.0 (1044) script.js.HAUS.Rolladen.Status_Rolladen: 08 Küche 0D Stopped in undefined position
    2025-11-24 17:52:10.209  - info: javascript.0 (1044) script.js.Garten.Teich.Teichpumpe_Abschaltungen: Teichtemp: 5.4°C
    2025-11-24 17:52:10.894  - info: javascript.0 (1044) script.js.SYSTEM.CPU_RP5_Temp: 59.3°C
    2025-11-24 17:52:10.901  - info: javascript.0 (1044) script.js.SYSTEM.CPU_RP5_Temp: 0.87 V
    2025-11-24 17:52:11.802  - info: javascript.0 (1044) script.js.HAUS.Keller.Fernsehkeller.Ambilight_Keller: 85
    2025-11-24 17:52:11.848  - info: alexa2.0 (1456) Ignore update of 62fde734-3295-4e0c-8449-930d7d1e75bf.powerState because it was set too often in the last time (17)
    2025-11-24 17:52:15.207  - info: javascript.0 (1044) script.js.Garten.Teich.Teichpumpe_Abschaltungen: Teichtemp: 5.2°C
    2025-11-24 17:52:16.467  - info: javascript.0 (1044) script.js.SYSTEM.Regen_Erfassung: Auslöser CAM: 2
    2025-11-24 17:52:16.468  - info: javascript.0 (1044) script.js.SYSTEM.Regen_Erfassung: Local: 0
    2025-11-24 17:52:16.468  - info: javascript.0 (1044) script.js.SYSTEM.VIS.BoxShadow: Auslöser CAM: 2
    2025-11-24 17:52:25.947  - info: javascript.0 (1044) script.js.SYSTEM.CPU_RP5_Temp: 58.2°C
    2025-11-24 17:52:25.954  - info: javascript.0 (1044) script.js.SYSTEM.CPU_RP5_Temp: 0.87 V
    Wie bekomme ich das sauber hin?
    P.S. Trixi Installation ist in Vorbereitung ;-)
    • M michihorn
      Hallo
      blacklist btbcm
           Status: "Running"
              CPU: 360ms
      Script v.2025-08-09
      *** BASE SYSTEM ***
            Icon name: computer
         Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                   NTP service: active
               RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           209M          0B        209M
      Total:           17G        4.4G         11G
              4214 M used memory
             10572 M free memory
               170 M buffer memory
              1387 M swap cache
               199 M total swap
                 0 M used swap
               199 M free swap
      *** FILESYSTEM ***
      /var:
      4.3G    /var/
      3.5G    /var/log
      409M    /var/cache
      USB-Devices by-id:
      HINT:
      tcp
      HINT:
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
       Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.19
      javascript:     9.0.11
      Adapter State
      + instance is alive
      Objects and States
      Objects:        42351
      States:         35285
      Pending Updates: 2
      @michihorn sagte in Bluetooth auf Raspberry 5 aktivieren:
      Dann schau unter der Trixie per
      rfkill
      mal nach den Schnittstellen.
      • HomoranH Homoran verschob dieses Thema von ioBroker Allgemein am
        rfkill
        michihorn
        @Thomas-Braun sagte in Bluetooth auf Raspberry 5 aktivieren:
        rfkill
        Die aktuelle Maschine spuckt folgendes aus:
        pi@rp5:~ $ rfkill
        ID TYPE      DEVICE      SOFT      HARD
         0 bluetooth hci0   unblocked unblocked
         2 wlan      phy0   unblocked unblocked
        • M michihorn
          Hallo
          blacklist btbcm
               Status: "Running"
                  CPU: 360ms
          Script v.2025-08-09
          *** BASE SYSTEM ***
                Icon name: computer
             Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                       NTP service: active
                   RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:           209M          0B        209M
          Total:           17G        4.4G         11G
                  4214 M used memory
                 10572 M free memory
                   170 M buffer memory
                  1387 M swap cache
                   199 M total swap
                     0 M used swap
                   199 M free swap
          *** FILESYSTEM ***
          /var:
          4.3G    /var/
          3.5G    /var/log
          409M    /var/cache
          USB-Devices by-id:
          HINT:
          tcp
          HINT:
          tcp
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
           Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.19
          javascript:     9.0.11
          Adapter State
          + instance is alive
          Objects and States
          Objects:        42351
          States:         35285
          Pending Updates: 2
          crunchipC Offline
          crunchipC Offline
          Radar2 mal testen.
          hast du folgendes ausgeführt?
          sudo apt-get install -y coreutils libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev net-tools
            Radar2 mal testen.
            michihorn
            @crunchip sagte in Bluetooth auf Raspberry 5 aktivieren:
            Moin, ja hab ich aus der Doku des Adapters
            Michael
            • M michihorn
              Michael
              @michihorn
              Bei mir (allerdings ein RPi4 auf Trixie) werden ganz andere Module geladen:
              echad@chet:~ $ lsmod | grep "blue\|bt"
              btbcm                  24576  1 hci_uart
              bluetooth             651264  29 hci_uart,btbcm,bnep,rfcomm
              ecdh_generic           16384  2 bluetooth
              libaes                 12288  4 aes_arm64,bluetooth,ghash_ce,aes_generic
              rfkill                 32768  4 bluetooth,cfg80211
              echad@chet:~ $
              Wo hast du die Info für deine Einstellungen her?
              Bei mir startet der bluetooth.service auf sauber:
              echad@chet:~ $ systemctl status bluetooth.service
                   Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: enabled)
                   Active: active (running) since Thu 2025-11-20 15:30:38 CET; 4 days ago
               Invocation: e86385c2415d4f3980a67edb437c90a2
                 Main PID: 503 (bluetoothd)
                   Status: "Running"
                    Tasks: 1 (limit: 8748)
                      CPU: 14min 58.813s
                           └─503 /usr/libexec/bluetooth/bluetoothd
              Nov 20 15:30:38 chet systemd[1]: Starting bluetooth.service - Bluetooth service...
              Nov 20 15:30:38 chet (uetoothd)[503]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists b>
              Nov 20 15:30:38 chet bluetoothd[503]: Bluetooth daemon 5.82
              Nov 20 15:30:38 chet bluetoothd[503]: Starting SDP server
              Nov 20 15:30:38 chet bluetoothd[503]: Bluetooth management interface 1.23 initialized
              Nov 20 15:30:38 chet bluetoothd[503]: Battery Provider Manager created
              Nov 20 15:30:38 chet systemd[1]: Started bluetooth.service - Bluetooth service.
                michihorn
                Im Prinzip ist bei mir nur eine Zeile Sauber: "Bluetooth management.....
                alles andere will ich weg haben
                • M michihorn
                  @michihorn
                  Bitte CodeTags verwenden.
                  Was sagt
                  hciconfig
                  bluetoothctl
                    michihorn
                    hci0: Type: Primary Bus: UART
                    BD Address: 88:A2:9E:37:34:B3 ACL MTU: 1021:8 SCO MTU: 64:1
                    UP RUNNING
                    RX bytes:4650318 acl:842 sco:0 events:169193 errors:0
                    TX bytes:1497277 acl:831 sco:0 commands:89694 errors:0
                    pi@rp5:~ $ bluetoothctl
                    Agent registered
                    [CHG] Controller 88:A2:9E:37:34:B3 Pairable: yes
                    [CHG] Controller 88:A2:9E:37:34:B3 Powered: yes
                    [DEL] Device 4C:66:A6:8D:BB:1C Galaxy-Micha
                    [bluetooth]#
                    • M michihorn
                      UP RUNNING
                      Agent registered
                      [bluetooth]#
                      @michihorn
                      Läuft doch. Was ist konkret das Problem?
                        michihorn
                        Ich weiß nicht woher die so Einträge kommen wie "Sap driver initialization failed." usw.
                        Es gibt einige Einträge wie z.B. Galaxy-Micha, mal connected mal nicht usw.
                        Das Handy liegt neben mir wir nicht bewegt. Ich denke das wird auch beim Radar2 auffallen, dann ist eine Anwesenheitserkennung schwierig
                        [CHG] Controller 88:A2:9E:37:34:B3 Powered: no
                        [CHG] Controller 88:A2:9E:37:34:B3 Discovering: no
                        [NEW] Device 4C:66:A6:8D:BB:1C Galaxy-Micha
                        [CHG] Device 4C:66:A6:8D:BB:1C Connected: no
                        • M michihorn
                          Die sind wurscht.
                          Edit: Wenn es stört:
                          https://www.heise.de/ratgeber/BlueZ-kann-ominoesen-SAP-Server-nicht-starten-4716249.html
                          Möglicherweise legt das Handy Bluetooth Schlafen, wenn es nicht gebraucht wird.
                          Und BITTE Text aus der Konsole in CODETAGS einbetten...
                          83.2k
