  4. Kein Kontakt zur EMMA (Huawei)
    6.5k
38 Beiträge 5 Kommentatoren 2.3k Aufrufe 4 Beobachtet
  • F Offline
    Fibricus
    Hallo Zusammen!
    Heute habe ich den SmartGuart bekommen und damit auch eine EMMA.
    Bisher hatte ich zwei WR und alles lief gut mit dem Adapter.
    Nun, mit der EMMA bekomme ich das einfach nicht hin.
    Die EMMA habe ich entsprechen der Anleitung konfiguriert:
    Den Adapter habe ich so eingerichtet:
    Aber dann das:
    und hier der Log:
    sun2000.0
    	2025-11-14 22:10:09.969	info	Open Connection...
    sun2000.0
    	2025-11-14 22:10:09.969	warn	Error while reading from 192.168.178.131 [Reg: 30380, Len: 31, modbusID: 0] with: Port Not Open
    sun2000.0
    	2025-11-14 22:10:09.969	warn	Consider that only 1 client is allowed to connect to modbus at the same time!
    sun2000.0
    	2025-11-14 22:10:09.968	warn	Has another device interrupted the modbus connection?
    sun2000.0
    	2025-11-14 22:10:09.966	info	Connected Modbus TCP to 192.168.178.131:502
    sun2000.0
    	2025-11-14 22:10:04.809	info	Open Connection...
    sun2000.0
    	2025-11-14 22:10:04.809	warn	Error while reading from 192.168.178.131 [Reg: 30368, Len: 6, modbusID: 0] with: Port Not Open
    sun2000.0
    	2025-11-14 22:10:04.808	warn	Consider that only 1 client is allowed to connect to modbus at the same time!
    sun2000.0
    	2025-11-14 22:10:04.808	warn	Has another device interrupted the modbus connection?
    sun2000.0
    	2025-11-14 22:10:04.806	info	Connected Modbus TCP to 192.168.178.131:502
    sun2000.0
    	2025-11-14 22:09:59.706	info	Open Connection...
    sun2000.0
    	2025-11-14 22:09:59.706	warn	Error while reading from 192.168.178.131 [Reg: 30302, Len: 50, modbusID: 0] with: Port Not Open
    sun2000.0
    	2025-11-14 22:09:59.706	warn	Consider that only 1 client is allowed to connect to modbus at the same time!
    sun2000.0
    	2025-11-14 22:09:59.705	warn	Has another device interrupted the modbus connection?
    sun2000.0
    	2025-11-14 22:09:59.704	info	Connected Modbus TCP to 192.168.178.131:502
    sun2000.0
    	2025-11-14 22:09:54.682	info	Open Connection...
    sun2000.0
    	2025-11-14 22:09:54.682	warn	Error while reading from 192.168.178.131 [Reg: 30222, Len: 20, modbusID: 0] with: Port Not Open
    sun2000.0
    	2025-11-14 22:09:54.681	warn	Consider that only 1 client is allowed to connect to modbus at the same time!
    sun2000.0
    	2025-11-14 22:09:54.681	warn	Has another device interrupted the modbus connection?
    sun2000.0
    	2025-11-14 22:09:54.679	info	Connected Modbus TCP to 192.168.178.131:502
    sun2000.0
    	2025-11-14 22:09:49.664	info	Open Connection...
    Nun bin ich wirklich ratlos und hoffe mal auf Euch!
    Gruß und Dank
    Tobias
    bahnuhrB 2 Antworten Letzte Antwort
    • F Fibricus
      Hallo Zusammen!
      Aber dann das:
      und hier der Log:
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      sun2000.0
      Gruß und Dank
      Tobias
      bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      @fibricus sagte in Kein Kontakt zur EMMA (Huawei):
      Steht doch alles da.
      Du greifst mehrmals auf Emma zu.
      Dein iob ist wohl nicht der/das einzige was Daten von Emma will.
      Modbus Verbindungen gehen nur 1x.
      Danke.
      F 1 Antwort Letzte Antwort
      • F Fibricus
        Hallo Zusammen!
        Aber dann das:
        und hier der Log:
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        sun2000.0
        Gruß und Dank
        Tobias
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        @fibricus
        Nachtrag:
        Ich habe Smartguard inkl. Emma und 2 WR und 2 Batt.
        Funktioniert einwandfrei.
        Welche Geräte hast du ?
        Smartguard und 2 WR (3 und 5), was noch ?
        Danke.
        • bahnuhrB bahnuhr
          Fibricus
          @bahnuhr said in Kein Kontakt zur EMMA (Huawei):
          Und ganau das verstehe ich nicht. Ich habe nur den IOB.
          Die Instanz tat ja auch wunderbar als ich "nur" auf die WR zugegriffen habe.
          Nun habe ich die EMMA.
          Also habe ich den Adapter neu konfiguriert.
          Ich wüsste nicht, was sonst noch auf den Modbus zugreift / die EMMA abfragt.
          • bahnuhrB bahnuhr
            @fibricus
            Nachtrag:
            Fibricus
            schrieb am zuletzt editiert von Fibricus
            @bahnuhr folgendes habe ich bei mir installiert:
            • Smartguart
            • Map0 (10kW)
            • KTL4-L1
            • Speicher S0 (15kWh)
            Sonst genau nix...
            bahnuhrB Samson71S 2 Antworten Letzte Antwort
            • F Fibricus
              • Smartguart
              • Map0 (10kW)
              • KTL4-L1
              Sonst genau nix...
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              KTL4-L1
              map0 ist WR
              Was ist ktl4-l1 ?
              Edit:
              Ist wohl auch ein WR
              Frage:
              Warum hast du 2 WR für 1 Batt
              Danke.
              • bahnuhrB bahnuhr
                KTL4-L1
                map0 ist WR
                Was ist ktl4-l1 ?
                Edit:
                Frage:
                Samson71S Offline
                Samson71S Offline
                Samson71
                @bahnuhr sagte in Kein Kontakt zur EMMA (Huawei):
                Was ist ktl4-l1 ?
                4kW einphasig.
                Vermutlich weil der 10kW das Ursprungsszenario ist/war, der zugehörige WR ausgeschöpft belegt ist oder keine passenden Panele (mehr) zur Erweiterung der Strings verfügbar sind.
                Ich hatte meinen 12ktl-m5 deswegen auch mit einem 3ktl-l1 ergänzt.
                Markus
                Bitte beachten:
                • Samson71S Samson71
                  Was ist ktl4-l1 ?
                  4kW einphasig.
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  @samson71
                  Ja, das kann sein.
                  Aber dies erzeugt keinen mehrfachen modbus.
                  Habe ja auch 3 WR an der Emma.
                  Danke.
                  • F Fibricus
                    • Smartguart
                    • Map0 (10kW)
                    • KTL4-L1
                    Sonst genau nix...
                    Samson71S Offline
                    Samson71S Offline
                    Samson71
                    @fibricus
                    Hast Du ne Wallbox im Einsatz?
                    Markus
                    Bitte beachten:
                    F bahnuhrB 2 Antworten Letzte Antwort
                      @fibricus
                      Fibricus
                      @samson71 Nein, habe ich (noch) nicht!
                        @fibricus
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        @samson71 sagte in Kein Kontakt zur EMMA (Huawei):
                        Hast du eine Wallbox?
                        Da muss man glaube ich proxy einrichten. Hab ich aber noch nie gemacht.
                        Hast du da mal eine einfache Anleitung wie man sowas macht.
                        Danke.
                        • F Fibricus
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          Irgendwas greift bei dir 2 x auf die emma zu.
                          Nochmal alles durchgehen.
                          Zur Not die IP der Emma mal wechseln.
                          Danke.
                          • bahnuhrB bahnuhr
                            Samson71S Offline
                            Samson71S Offline
                            Samson71
                            Ja, einen Go-e Charger Gemini, gesteuert über den entsprechenden Adapter. Ich habe von Huawei auch inzwischen nichts mehr weiter außer dem 12ktl-m5.
                            Markus
                            Bitte beachten:
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              @samson71
                              Hast du mehr Ahnung von proxy als ich ?
                              Danke.
                              • bahnuhrB bahnuhr
                                @samson71
                                Samson71S Offline
                                Samson71S Offline
                                Samson71
                                Mangels Notwenigkeit bzw. Nutzung leider nein.
                                Markus
                                Bitte beachten:
                                • bahnuhrB bahnuhr
                                  Fibricus
                                  Habe ich gemacht. Leider keine Änderung...
                                  Es ist die exakt gleiche Fehlermeldung, nur eben jetzt mit neuer IP...
                                  • bahnuhrB bahnuhr
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    Danke.
                                    • F Fibricus
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      @fibricus
                                      Hast du noch nen dongle dran ?
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        Fibricus
                                        Ich habe nur den IOB, der auf die EMMA zugreift.
                                        Ich wüsste nicht, was es sonst noch sein könnte...
                                        • bahnuhrB bahnuhr
                                          @fibricus
                                          Fibricus
                                          @fibricus
                                          Nein, Kein Dongle mehr dran. Alle Geräte sind über RS485 angebunden.
