    6.5k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.4m Aufrufe 260 Beobachtet
  • W welli
    @marc-berg
    Habe 15.0.1 drauf bekomme aber jetzt die Fehlermeldung wenn ich den TFT 5.0.2 flashe.
    7:59:13.965 FLH: Something has gone wrong flashing display firmware [bytes('9EE11E14E70F010D0000E1FDF77FFAFDDFFFB6F97F0FFEEEC002FFBFDFF6A000...')]
    17:59:14.066 FLH: Something has gone wrong flashing display firmware [bytes('2EFFD7F75F7FDF6B3BD110DB22C80694EFFFEFFCB415DDFF87CF8FD102FB36EF...')]
    17:59:14.171 FLH: Something has gone wrong flashing display firmware [bytes('B4FF1C56C0B4AD0158677273F8F710F20F078D000061DD8FEFFD7D97FF2C01FF...')]
    17:59:14.267 FLH: Something has gone wrong flashing display firmware [bytes('3EFBDFF9FDFDDCBAFBFEFFFBFFC97F2FFBF7BD19821F54860A0CFFFEDEBFC568...')]
    17:59:14.366 FLH: Something has gone wrong flashing display firmware [bytes('7BE3BE43AAB4E1FBF72F249EC4FBEDA98134D77C39D25FFF20EF0F27E201C17B...')]
    17:59:14.467 FLH: Something has gone wrong flashing display firmware [bytes('5EFFEBB7DBFE943BDD77FFFBBF4305FB36EF564EBFFDF48BA402FB36EF564EBF...')]
    17:59:14.566 FLH: Something has gone wrong flashing display firmware [bytes('163F14B46C5FEF1AC2FB030F0000CC0170FF52F7FFFDFAF7FD6D01FFDFFDFB67...')]
    17:59:14.666 FLH: Something has gone wrong flashing display firmware [bytes('D47FDFFB7DFBAFD940BDFD69013E23860AFAC8BF3FFBFEB409DDFF8B97675647...')]
    17:59:14.766 FLH: Something has gone wrong flashing display firmware [bytes('D4FB03070D0000F0FFD8DFDFFAFFFF7EFF9DADF7BBBB2DFEFDB9FDBB7FECBF7D...')]
    17:59:14.866 FLH: Something has gone wrong flashing display firmware [bytes('C2D6A9BC7DFF9DFFEDFEFA3FBFCB2B9312060628C817FDDDF7ED640EDDFF7D97...')]
    17:59:14.966 FLH: Something has gone wrong flashing display firmware [bytes('BA7C5DEF1DB07903030D01E1EFE7DFFAFD2BB603FFDF8FFF7DD102FDBFDFCF8A...')]
    17:59:15.066 FLH: Something has gone wrong flashing display firmware [bytes('F37D008005978C014F1DD710C0CB314000802B7166F2F7FB9FFAFC7F7FFFD9EE...')]
    17:59:15.172 FLH: Something has gone wrong flashing display firmware [bytes('7AA7DAB3A98478FD07149CA73FE41E42DF1B01B4000000F0FF73FFDFED07FFDF...')]
    17:59:15.267 FLH: Something has gone wrong flashing display firmware [bytes('FCDBE48EDFFF000FCE00B22D66F69BB76B7FDA3BDBFFF3DBCEA0027B32578B02...')]
    17:59:15.366 FLH: Something has gone wrong flashing display firmware [bytes('4FFFFEFA7CA43189F5AE12BEDFF41F712518FE0DB069705FBF26CB3917F20141...')]
    17:59:15.483 FLH: Something has gone wrong flashing display firmware [bytes('D40EDD773FF9797FEAF4F63ECC5501BFFDF48BA402FB36EF564EBFFDF48BA402...')]
    17:59:15.566 FLH: Something has gone wrong flashing display firmware [bytes('1E0C01C1FF7BFFED7CDFDFD875FF87FE5BD102FFBFDFF6A00000
    T Nicht stören
    T Nicht stören
    ticaki
    #7724
    @welli
    Panel stromlos machen
    Spenden
    W 1 Antwort Letzte Antwort
    • T ticaki
      @welli
      W Offline
      W Offline
      welli
      #7725
      @ticaki
      Danke Jungs jetzt get es.
      Gruss
      Welli
      • Frederik BussF Frederik Buss
        @ticaki Ich sehe dass die Icons als SVG direkt in der Json codiert sind. Daher frage ich mal anders herum. So sieht meine Haupt Visu aus:
        Hast Du vielleicht eine Idee wie man die Kacheln ähnlich hinbekommt? Die Icons an sich wären OK, mir würde es eher um Kachelfarben gehen, das ist glaube ich so nicht vorgesehen...? Daher war meine Idee das vielleicht mit Icons zu lösen, allerdings sind SVG's nicht unbedingt die beste Lösung.
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        Most Active Forum Testing
        #7726
        @frederik-buss sagte in SONOFF NSPanel mit Lovelace UI:
        nach langem hin und her grübeln und diskutieren haben wir uns erstmals entschieden etwas nicht umzusetzen.
        Es ist machbar die Hintergründe der Icons mit Background-Colors zu versehen, jedoch ist das mit vielen Breaking-Changes, sowohl im Script als auch in der TFT verbunden, so dass wir den anderen Usern diese Änderungen und damit ggfs. auch ein temporäres Fehlverhalten nicht zumuten möchten.
        Jede einzelne Entität im Skript, Definition und jedes Page in der TFT inklusive Änderung des Serial-Protocol rechtfertigen außerdem den Aufwand zur Änderung der Hintergrundfarben nicht wirklich.
        Wir hoffen auf dein Verständnis
        Armilar
        Frederik BussF 1 Antwort Letzte Antwort
        • W Offline
          W Offline
          welli
          #7727
          Habe ein Problem mit einem meiner zwei NSpanels.
          Firmware ,TFT , alles gleich auf den zwei panels nur im script ist 1 und 2 verschieden.
          Bei Panel 1 , bei drücken auf den Bildschrim leuchet er sofort hell aber bleibt im screensaver hängen und schaltet nicht auf mein erste Seite um, auch bei mehrmals drauf drücken , bei Panel 2 schaltet es sofort um.
          Habe jetzt die letze Firmware drauf bei Panel 1 aber das gleiche.
          Einer ne idee was das sein könnte?
          Gruss
          Welli
          T ArmilarA 2 Antworten Letzte Antwort
          • W welli
            Gruss
            Welli
            T Nicht stören
            T Nicht stören
            ticaki
            #7728
            @welli
            drückste auf die indicators? Drück mal 2mal schnell auf die bottoms
            Spenden
            • W welli
              Gruss
              Welli
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #7729
              @welli
              sieh mal nach, ob die
              0_userdata.0.NSPanel.X.Config.Screensaver.screenSaverDoubleClick
              unterschiedlich sind?
              false = Einfachklick
              true = Doppelklick
              • ArmilarA Armilar
                @welli
                true = Doppelklick
                W Offline
                W Offline
                welli
                #7730
                @armilar said in SONOFF NSPanel mit Lovelace UI:
                Habe den Doppelklick auf false gestellt. jetzt dauerts es 20-30sek bis die Anzeige umschaltet , sowie auch die Relais klicken sofort aber nach 20-30sek ändert die Anzeige im Bildschirm von aus auf ein Symbol.
                • W welli
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  #7731
                  @welli
                  Dann gehen da die WLAN/MQTT-Signale in Schleichfahrt zum Router.
                  Schon mal die ioBroker-Büchse durchgestartet?
                  P.S.: Die Relays müssen sofort klicken... Die gehören zur Hardware...
                  • ArmilarA Armilar
                    Armilar
                    Frederik BussF Offline
                    Frederik Buss
                    #7732
                    @armilar Hi Armilar, klar verstehe ich das, auch wenn ich es schade finde - ich bin sicher, dass eine Kacheloptik ein echtes optisches Highlight wäre. Vielleicht finden sich ja in Zukunft mehr Zusprecher :)
                      australien
                      schrieb am zuletzt editiert von australien
                      #7733
                      Ich würde gerne im StandardScreensafer eine eigene Temperatur anzeigen lassen.
                      Wo kann ich diesen DP eintragen? Ohne Pirate Weather hatte ich dieses schon, nun weiß ich aber die Änderung nicht mehr.
                      v5.0.0.1 mit Pirate Wetter
                      • A australien
                        TT-Tom
                        #7734
                        @australien
                        Siehe hier im Wiki https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-ALIAS-Definitionen#wettervorhersage
                        Das sollte funktionieren
                        Gruß Tom
                        Public Transport
                        NSPanel Adapter Wiki
                        • T TT-Tom
                          @australien
                          australien
                          #7735
                          @tt-tom
                          steht da auch drinnen, und hat bis jetzt funktioniert. nur wird jetzt der wert aus dem pirate wetter angezeigt. momentan 7,2 anstatt 3,9
                          mit der Version v4.6.2.1 wird auch noch die richtige Temp genommen.
                          • A australien
                            @tt-tom
                            TT-Tom
                            #7736
                            @australien
                            im Punkt 3 der Config, was steht da bei dir? da musst du deine Temp hinterlegen
                            const weatherEntityPath: string = 'alias.0.Pirate_Weather
                            Edit : welche Script Version hast du jetzt?
                            Gruß Tom
                            Public Transport
                            • T TT-Tom
                              @australien
                              australien
                              #7737
                              @tt-tom said in SONOFF NSPanel mit Lovelace UI:
                              die Version TypeScript v5.0.0.1
                              und es steht
                              // DE: Dieser Alias wird automatisch für den gewählten Wetter erstellt und kann entsprechend angepasst werden
                              // EN: This alias is automatically created for the selected weather and can be adjusted accordingly
                              const weatherEntityPath: string = 'alias.0.Pirate_Weather'; //Please rename if change weatherAdapterInstance!
                              • A australien
                                und es steht
                                TT-Tom
                                #7738
                                @australien
                                dann gehe in den Alias rein und verbinde die TEMP mit deinem Sensor
                                Gruß Tom
                                Public Transport
                                • A australien
                                  @tt-tom
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  #7739
                                  @australien
                                  Für die Anzeige der aktuellen Screensaver-Temperatur wird immer die Konstante weatherEntityPath
                                  genutzt.
                                  Im hinteren selbst definierten Namen des ALIAS-Wetter-Channel (kann ja abweichen), kannst du unter TEMP dann deinen eigenen Sensor zuweisen.
                                  Das hat sich seit Bereitstellung des NSPanel-Skriptes auch nicht geändert...
                                  • ArmilarA Armilar
                                    @australien
                                    genutzt.
                                    australien
                                    #7740
                                    @armilar mein Alias wurde auch nicht geändert, nur durch das script auf die Pirate Weather min und max.
                                    Es ist auch egal wohin ich den temp verweise, das script verwendet immer nur die original pirate weather temp
                                    siehe screenshot oben
                                    wie gesagt, ging es so auch unter den vorherigen Versionen.
                                    • A australien
                                      ArmilarA Offline
                                      ArmilarA Offline
                                      Armilar
                                      #7741
                                      @australien
                                      In deinem Alias (dein Screenshot) steht ja auch der Verweis auf die pirate-weather.0.weather.currently.temp drin. Der müsste dann auf deinen eigenen Sensor zeigen.
                                      • ArmilarA Armilar
                                        @australien
                                        australien
                                        #7742
                                        richtig ist doch das gelbe? oder sehe ich das falsch?
                                          "common": {
                                            "type": "number",
                                            "role": "value.temperature",
                                            "name": "TEMP",
                                            "alias": {
                                              "id": "0_userdata.0.NSPanel.eigen_TEMP"
                                            "unit": "°C",
                                            "read": true,
                                            "write": true
                                          "native": {},
                                          "type": "state",
                                          "_id": "alias.0.Wetter.TEMP",
                                          "acl": {
                                            "object": 1636,
                                            "state": 1636,
                                            "owner": "system.user.admin",
                                          "user": "system.user.admin",
                                          "ts": 1763026764484
                                        • A australien
                                            "common": {
                                              "type": "number",
                                              "name": "TEMP",
                                              "alias": {
                                              "unit": "°C",
                                              "read": true,
                                              "write": true
                                            "native": {},
                                            "type": "state",
                                            "acl": {
                                              "object": 1636,
                                              "state": 1636,
                                            "ts": 1763026764484
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          #7743
                                          @australien
                                          ja, der wäre korrekt, wenn in deinem NSPanel-Script dieser alias.0.Wetter auch eingetragen ist
