  4. System & Admin Upgrade "exited with code 25" Start-Schleife?
    6.4k
75 Beiträge 3 Kommentatoren 7.8k Aufrufe 3 Beobachtet
  • A adarof
    @thomas-braun Okay, danke.
    Ich hab ihn nun per "systemctl stop iobroker.service" gestoppet und per "iob start" gestartet.
    Er startet trotzdem wieder nur teilweise - war wieder da und ist wieder weg.
    Hast Du noch eine Idee?
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Ubuntu 22.04.5 LTS
     Static hostname: RoofServer
           Icon name: computer-desktop
             Chassis: desktop
              Kernel: Linux 5.15.0-157-generic
        Architecture: x86-64
    OS is similar to: debian
    model name      : Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     23:40:14 up 28 min,  1 user,  load average: 3.35, 2.87, 2.59
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-10-06 23:40:14 CEST
               Universal time: Mon 2025-10-06 21:40:14 UTC
                     RTC time: Mon 2025-10-06 21:40:14
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    hmersch
    DERBY_HOME=/usr/lib/jvm/java-8-oracle/db
    JAVA_HOME=/usr/lib/jvm/java-8-oracle
    HOME=/home/hmersch
    GROUPS=hmersch dialout sudo sambashare user iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout sudo audio video plugdev bluetooth
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Display-Manager:        * gdm.service - GNOME Display Manager
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             15G        3.6G        7.7G        7.0M        4.5G         11G
    Swap:           2.0G          0B        2.0G
    Total:           17G        3.6G        9.8G
    Active iob-Instances:   17
            15875 M total memory
             3606 M used memory
             2809 M active memory
             4837 M inactive memory
             7733 M free memory
              494 M buffer memory
             4041 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    top - 23:40:15 up 28 min,  1 user,  load average: 3.35, 2.87, 2.59
    Tasks: 232 total,   2 running, 230 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 31.2 us,  7.8 sy,  0.0 ni, 57.8 id,  3.1 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  15875.2 total,   7728.5 free,   3611.3 used,   4535.4 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.  11925.8 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * vncserver@1.service  loaded failed failed Remote desktop service (VNC)
    * wg-quick@VPN.service loaded failed failed WireGuard via wg-quick(8) for VPN
    2 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem     Type     Size  Used Avail Use% Mounted on
    tmpfs          tmpfs    1.6G  3.6M  1.6G   1% /run
    /dev/sdb1      ext4     458G   66G  369G  16% /
    tmpfs          tmpfs    7.8G  616K  7.8G   1% /dev/shm
    tmpfs          tmpfs    5.0M  4.0K  5.0M   1% /run/lock
    /dev/sda1      fuseblk  466G  401G   65G  87% /media/data
    /dev/sdc1      ext4     4.6T  4.0T  308G  93% /media/storage
    tmpfs          tmpfs    1.6G   96K  1.6G   1% /run/user/999
    tmpfs          tmpfs    1.6G  100K  1.6G   1% /run/user/1002
    [Mon Oct  6 23:11:48 2025] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Mon Oct  6 23:11:48 2025] EXT4-fs (sdb1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
    [Mon Oct  6 23:11:51 2025] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    Show mounted filesystems:
    TARGET                           SOURCE      FSTYPE   OPTIONS
    /                                /dev/sdb1   ext4     rw,relatime,errors=remount-ro
    |-/snap/core/17247               /dev/loop0  squashfs ro,nodev,relatime,errors=continue
    |-/snap/core18/2947              /dev/loop1  squashfs ro,nodev,relatime,errors=continue
    |-/snap/core18/2952              /dev/loop2  squashfs ro,nodev,relatime,errors=continue
    |-/snap/bare/5                   /dev/loop3  squashfs ro,nodev,relatime,errors=continue
    |-/snap/core/17212               /dev/loop4  squashfs ro,nodev,relatime,errors=continue
    |-/snap/core20/2599              /dev/loop5  squashfs ro,nodev,relatime,errors=continue
    |-/snap/core22/2111              /dev/loop7  squashfs ro,nodev,relatime,errors=continue
    |-/snap/core20/2669              /dev/loop6  squashfs ro,nodev,relatime,errors=continue
    |-/snap/core24/1196              /dev/loop10 squashfs ro,nodev,relatime,errors=continue
    |-/snap/core24/1151              /dev/loop9  squashfs ro,nodev,relatime,errors=continue
    |-/snap/core22/2133              /dev/loop8  squashfs ro,nodev,relatime,errors=continue
    |-/snap/gnome-3-26-1604/104      /dev/loop11 squashfs ro,nodev,relatime,errors=continue
    |-/snap/gnome-3-26-1604/111      /dev/loop12 squashfs ro,nodev,relatime,errors=continue
    |-/snap/gnome-3-28-1804/194      /dev/loop13 squashfs ro,nodev,relatime,errors=continue
    |-/snap/gnome-3-28-1804/198      /dev/loop14 squashfs ro,nodev,relatime,errors=continue
    |-/snap/gnome-3-34-1804/93       /dev/loop17 squashfs ro,nodev,relatime,errors=continue
    |-/snap/gnome-3-38-2004/140      /dev/loop16 squashfs ro,nodev,relatime,errors=continue
    |-/snap/gnome-3-38-2004/143      /dev/loop18 squashfs ro,nodev,relatime,errors=continue
    |-/snap/gnome-42-2204/202        /dev/loop19 squashfs ro,nodev,relatime,errors=continue
    |-/snap/gnome-42-2204/226        /dev/loop20 squashfs ro,nodev,relatime,errors=continue
    |-/snap/gnome-3-34-1804/90       /dev/loop15 squashfs ro,nodev,relatime,errors=continue
    |-/snap/gnome-46-2404/117        /dev/loop21 squashfs ro,nodev,relatime,errors=continue
    |-/snap/gnome-46-2404/125        /dev/loop22 squashfs ro,nodev,relatime,errors=continue
    |-/snap/gnome-system-monitor/186 /dev/loop24 squashfs ro,nodev,relatime,errors=continue
    |-/snap/gnome-system-monitor/193 /dev/loop23 squashfs ro,nodev,relatime,errors=continue
    |-/snap/gtk-common-themes/1535   /dev/loop26 squashfs ro,nodev,relatime,errors=continue
    |-/snap/snapd/24792              /dev/loop29 squashfs ro,nodev,relatime,errors=continue
    |-/snap/mesa-2404/887            /dev/loop27 squashfs ro,nodev,relatime,errors=continue
    |-/snap/gtk-common-themes/1534   /dev/loop25 squashfs ro,nodev,relatime,errors=continue
    |-/snap/snapd/25202              /dev/loop30 squashfs ro,nodev,relatime,errors=continue
    |-/snap/mesa-2404/912            /dev/loop28 squashfs ro,nodev,relatime,errors=continue
    |-/media/data                    /dev/sda1   fuseblk  rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
    `-/media/storage                 /dev/sdc1   ext4     rw,nosuid,nodev,relatime
    /var:
    27G     /var/
    22G     /var/lib
    6.2G    /var/lib/mysql
    6.1G    /var/lib/snapd
    6.0G    /var/lib/unifi
    Archived and active journals take up 120.0M in the file system.
    /opt/iobroker/backups:
    2.5G    /opt/iobroker/backups/
    4.0K    /opt/iobroker/backups/redistmp
    /opt/iobroker/iobroker-data:
    715M    /opt/iobroker/iobroker-data/
    356M    /opt/iobroker/iobroker-data/files
    230M    /opt/iobroker/iobroker-data/backup-objects
    55M     /opt/iobroker/iobroker-data/files/material
    53M     /opt/iobroker/iobroker-data/files/material/static
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    40M     /opt/iobroker/iobroker-data/objects.jsonl
    28M     /opt/iobroker/iobroker-data/sqlite/sqlite.db
    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    20M     /opt/iobroker/iobroker-data/objects.json.migrated
    USB-Devices by-id:
    No Devices found 'by-id'
    *** ZigBee Settings ***
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.5
    /usr/bin/node           v20.19.5
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.33.0
    nodejs:
      Installed: 20.19.5-1nodesource1
      Candidate: 20.19.5-1nodesource1
      Version table:
     *** 20.19.5-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.4-1nodesource1 1001
         20.19.3-1nodesource1 1001
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.9~dfsg-1ubuntu3.6 500
            500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
            500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    RoofServer          RoofServer (version: 7.0.7, hostname: RoofServer    , alive, uptime: 95)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.2
    javascript:     8.9.2
    nodejs modules from github:     1
    |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
    Adapter State
    + system.adapter.admin.0                  : admin                 : RoofServer                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : RoofServer                               -  enabled
      system.adapter.backitup.0               : backitup              : RoofServer                               -  enabled
      system.adapter.daswetter.0              : daswetter             : RoofServer                               -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : RoofServer                               -  enabled
    + system.adapter.discovery.0              : discovery             : RoofServer                               -  enabled
      system.adapter.dwd.0                    : dwd                   : RoofServer                               -  enabled
      system.adapter.easee.1                  : easee                 : RoofServer                               -  enabled
    + system.adapter.email.0                  : email                 : RoofServer                               -  enabled
    + system.adapter.evcc.0                   : evcc                  : RoofServer                               -  enabled, port: 7070
      system.adapter.flot.0                   : flot                  : RoofServer                               -  enabled
      system.adapter.govee.0                  : govee                 : RoofServer                               -  enabled
    + system.adapter.ham.0                    : ham                   : RoofServer                               -  enabled
    + system.adapter.history.0                : history               : RoofServer                               -  enabled
      system.adapter.hm-rega.0                : hm-rega               : RoofServer                               -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : RoofServer                               -  enabled, port: 18701
      system.adapter.hm-rpc.1                 : hm-rpc                : RoofServer                               -  enabled, port: 12001
      system.adapter.hm-rpc.2                 : hm-rpc                : RoofServer                               -  enabled, port: 0
      system.adapter.homeconnect.0            : homeconnect           : RoofServer                               -  enabled
    + system.adapter.ical.0                   : ical                  : RoofServer                               -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: RoofServer                               -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : RoofServer                               -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : RoofServer                               -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : RoofServer                               -  enabled
      system.adapter.javascript.0             : javascript            : RoofServer                               -  enabled
      system.adapter.klf200.0                 : klf200                : RoofServer                               - disabled
    + system.adapter.lg-thinq.0               : lg-thinq              : RoofServer                               -  enabled
      system.adapter.material.0               : material              : RoofServer                               -  enabled
      system.adapter.matter.0                 : matter                : RoofServer                               -  enabled
      system.adapter.mielecloudservice.0      : mielecloudservice     : RoofServer                               -  enabled
      system.adapter.mobile.0                 : mobile                : RoofServer                               -  enabled
      system.adapter.modbus.0                 : modbus                : RoofServer                               -  enabled
      system.adapter.modbus.1                 : modbus                : RoofServer                               -  enabled
    + system.adapter.modbus.2                 : modbus                : RoofServer                               -  enabled
      system.adapter.nina.0                   : nina                  : RoofServer                               -  enabled
      system.adapter.nut.0                    : nut                   : RoofServer                               -  enabled
    + system.adapter.opendtu.0                : opendtu               : RoofServer                               -  enabled
      system.adapter.parser.0                 : parser                : RoofServer                               -  enabled
      system.adapter.ping.0                   : ping                  : RoofServer                               -  enabled
      system.adapter.pvforecast.0             : pvforecast            : RoofServer                               -  enabled
      system.adapter.rickshaw.0               : rickshaw              : RoofServer                               -  enabled
      system.adapter.simple-api.0             : simple-api            : RoofServer                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : RoofServer                               -  enabled, port: 1883, bind: 192.168.66.75
    + system.adapter.sql.0                    : sql                   : RoofServer                               -  enabled, port: 0
      system.adapter.statistics.0             : statistics            : RoofServer                               -  enabled
      system.adapter.telegram-menu.0          : telegram-menu         : RoofServer                               -  enabled
    + system.adapter.telegram.0               : telegram              : RoofServer                               -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : RoofServer                               - disabled
      system.adapter.tr-064.0                 : tr-064                : RoofServer                               -  enabled
      system.adapter.tuya.0                   : tuya                  : RoofServer                               -  enabled
    + system.adapter.unifi.0                  : unifi                 : RoofServer                               -  enabled
      system.adapter.vis-bars.0               : vis-bars              : RoofServer                               -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : RoofServer                               -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : RoofServer                               -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : RoofServer                               -  enabled
      system.adapter.vis-history.0            : vis-history           : RoofServer                               -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : RoofServer                               -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : RoofServer                               -  enabled
      system.adapter.vis-metro.0              : vis-metro             : RoofServer                               -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : RoofServer                               -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : RoofServer                               -  enabled
      system.adapter.vis.0                    : vis                   : RoofServer                               -  enabled
      system.adapter.vw-connect.0             : vw-connect            : RoofServer                               -  enabled
    + system.adapter.web.0                    : web                   : RoofServer                               -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.wiegand-tcpip.0          : wiegand-tcpip         : RoofServer                               -  enabled, port: 60000, bind: 192.168.66.75
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name      │ url        │ auto upgrade │
    │ 0       │ 'sources' │ 'conf/sources-dist.json'        │ false        │
    │ 1       │ 'online'  │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json' │ false        │
    │ 2       │ 'stable'  │ 'http://download.iobroker.net/sources-dist.json'                                            │ false        │
    │ 3       │ 'beta'    │ 'http://download.iobroker.net/sources-dist-latest.json'                                     │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.2    , installed 7.7.2
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "device-watcher": 2.13.1  , installed 2.13.1
    Adapter    "easee"        : 1.0.10   , installed 1.0.10
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "evcc"         : 0.2.3    , installed 0.2.3
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "ical"         : 1.17.0   , installed 1.17.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "klf200"       : 1.3.5    , installed 1.3.5
    Adapter    "lg-thinq"     : 1.1.2    , installed 1.1.2
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "matter"       : 0.5.2    , installed 0.5.2
    Adapter    "mielecloudservice": 6.5.10, installed 6.5.10
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
    Adapter    "parser"       : 2.2.4    , installed 2.2.4
    Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "telegram-menu": 2.4.4    , installed 2.4.4
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wiegand-tcpip": 0.4.6    , installed 0.4.7
    Objects and States
    Objects:        56520
    States:         48083
    Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 http://security.ubuntu.com/ubuntu jammy-security InRelease
    Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
    Get:5 https://dl.cloudsmith.io/public/tvheadend/tvheadend/deb/ubuntu focal InRelease [11.0 kB]
    Get:6 https://dl.evcc.io/public/evcc/stable/deb/ubuntu jammy InRelease
    Hit:7 https://ppa.launchpadcontent.net/deadsnakes/ppa/ubuntu jammy InRelease
    Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:9 https://gcups-static.greencell.global/deb stable InRelease
    Fetched 22.6 kB in 2s (14.0 kB/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:12001           0.0.0.0:*               LISTEN      1001       95435      14803/io.hm-rpc.1
    tcp        0      0 0.0.0.0:59905           0.0.0.0:*               LISTEN      0          31120      1834/rpc.mountd
    tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          32072      -
    tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      999        33966      2228/pihole-FTL
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        26953      1120/systemd-resolv
    tcp        0      0 0.0.0.0:18701           0.0.0.0:*               LISTEN      1001       93314      14773/io.hm-rpc.0
    tcp        0      0 127.0.0.1:33060         0.0.0.0:*               LISTEN      124        32769      1564/mysqld
    tcp        0      0 0.0.0.0:9981            0.0.0.0:*               LISTEN      0          28331      1856/tvheadend
    tcp        0      0 0.0.0.0:9982            0.0.0.0:*               LISTEN      0          28334      1856/tvheadend
    tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       92718      14713/io.hm-rpc.2
    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      124        28292      1564/mysqld
    tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          28276      1711/upsd
    tcp        0      0 0.0.0.0:631             0.0.0.0:*               LISTEN      0          28038      1435/cupsd
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       90248      14157/iobroker.js-c
    tcp        2      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       88014      14157/iobroker.js-c
    tcp        0      0 127.0.0.1:35747         0.0.0.0:*               LISTEN      0          28141      1454/containerd
    tcp        0      0 0.0.0.0:993             0.0.0.0:*               LISTEN      0          32248      1767/dovecot
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          30737      1517/sshd: /usr/sbi
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          31631      2204/lighttpd
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14822      1/init
    tcp        0      0 0.0.0.0:143             0.0.0.0:*               LISTEN      0          32246      1767/dovecot
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          31538      2176/smbd
    tcp        0      0 127.0.0.1:27117         0.0.0.0:*               LISTEN      126        34043      2263/bin/mongod
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          31537      2176/smbd
    tcp        0      0 0.0.0.0:57815           0.0.0.0:*               LISTEN      128        31079      1810/rpc.statd
    tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN      125        28072      1438/mongod
    tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        33977      2228/pihole-FTL
    tcp        0      0 192.168.66.75:9983      0.0.0.0:*               LISTEN      0          32917      1856/tvheadend
    tcp        0      0 0.0.0.0:46345           0.0.0.0:*               LISTEN      0          31060      1834/rpc.mountd
    tcp        0      0 192.168.66.75:1883      0.0.0.0:*               LISTEN      1001       92606      14696/io.sonoff.0
    tcp        0      0 0.0.0.0:46585           0.0.0.0:*               LISTEN      0          32106      -
    tcp        0      0 0.0.0.0:45669           0.0.0.0:*               LISTEN      0          31097      1834/rpc.mountd
    tcp        0      0 192.168.66.75:53        0.0.0.0:*               LISTEN      999        33964      2228/pihole-FTL
    tcp6       0      0 fd16:f83a:ca:76b2:8e:53 :::*                    LISTEN      999        35842      2228/pihole-FTL
    tcp6       0      0 :::44039                :::*                    LISTEN      0          31127      1834/rpc.mountd
    tcp6       0      0 :::3389                 :::*                    LISTEN      127        31783      1542/xrdp
    tcp6       0      0 :::51825                :::*                    LISTEN      0          31114      1834/rpc.mountd
    tcp6       0      0 fe80::ee2c:259e:69f8:53 :::*                    LISTEN      999        33970      2228/pihole-FTL
    tcp6       0      0 :::2049                 :::*                    LISTEN      0          32094      -
    tcp6       0      0 fd16:f83a:ca:76b2:a0:53 :::*                    LISTEN      999        35084      2228/pihole-FTL
    tcp6       0      0 ::1:4711                :::*                    LISTEN      999        32527      2228/pihole-FTL
    tcp6       0      0 :::8754                 :::*                    LISTEN      997        33911      1992/fr24feed
    tcp6       0      0 :::631                  :::*                    LISTEN      0          28039      1435/cupsd
    tcp6       0      0 :::8843                 :::*                    LISTEN      126        36292      1557/java
    tcp6       0      0 :::8880                 :::*                    LISTEN      126        36919      1557/java
    tcp6       0      0 fd16:f83a:ca:76b2:45:53 :::*                    LISTEN      999        35040      2228/pihole-FTL
    tcp6       0      0 :::993                  :::*                    LISTEN      0          32249      1767/dovecot
    tcp6       0      0 :::22                   :::*                    LISTEN      0          30739      1517/sshd: /usr/sbi
    tcp6       0      0 :::80                   :::*                    LISTEN      0          31630      2204/lighttpd
    tcp6       0      0 :::111                  :::*                    LISTEN      0          18915      1/init
    tcp6       0      0 :::143                  :::*                    LISTEN      0          32247      1767/dovecot
    tcp6       0      0 :::139                  :::*                    LISTEN      0          31536      2176/smbd
    tcp6       0      0 :::8443                 :::*                    LISTEN      126        36289      1557/java
    tcp6       0      0 :::445                  :::*                    LISTEN      0          31535      2176/smbd
    tcp6       0      0 fe80::bee1:cabf:72ba:53 :::*                    LISTEN      999        33968      2228/pihole-FTL
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       91375      14505/io.admin.0
    tcp6       0      0 :::8080                 :::*                    LISTEN      126        36918      1557/java
    tcp6       0      0 :::6789                 :::*                    LISTEN      126        40016      1557/java
    tcp6       0      0 :::7070                 :::*                    LISTEN      141        33714      1770/evcc
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          28007      1469/xrdp-sesman
    tcp6       0      0 fd16:f83a:ca:76b2:87:53 :::*                    LISTEN      999        35070      2228/pihole-FTL
    tcp6       0      0 :::46787                :::*                    LISTEN      0          32109      -
    tcp6       0      0 :::54419                :::*                    LISTEN      128        31091      1810/rpc.statd
    tcp6       0      0 ::1:53                  :::*                    LISTEN      999        33972      2228/pihole-FTL
    tcp6       0      0 :::36907                :::*                    LISTEN      0          31083      1834/rpc.mountd
    udp        0      0 0.0.0.0:46048           0.0.0.0:*                           128        31070      1810/rpc.statd
    udp        0      0 172.16.100.9:5353       0.0.0.0:*                           1001       91737      14751/io.tr-064.0
    udp        0      0 192.168.66.75:5353      0.0.0.0:*                           1001       91736      14751/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           141        33686      1770/evcc
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        27813      1307/avahi-daemon:
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       95557      15293/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       95558      15293/io.tuya.0
    udp        0      0 127.0.0.1:53            0.0.0.0:*                           999        33965      2228/pihole-FTL
    udp        0      0 192.168.66.75:53        0.0.0.0:*                           999        33963      2228/pihole-FTL
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        26952      1120/systemd-resolv
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          32771      1428/dhcpcd
    udp        0      0 0.0.0.0:32874           0.0.0.0:*                           997        81063      1992/fr24feed
    udp        0      0 0.0.0.0:49258           0.0.0.0:*                           0          32105      -
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          18914      1/init
    udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          39525      1782/nmbd
    udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          39524      1782/nmbd
    udp        0      0 192.168.66.255:137      0.0.0.0:*                           0          28529      1782/nmbd
    udp        0      0 192.168.66.75:137       0.0.0.0:*                           0          28528      1782/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          28507      1782/nmbd
    udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          39527      1782/nmbd
    udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          39526      1782/nmbd
    udp        0      0 192.168.66.255:138      0.0.0.0:*                           0          28531      1782/nmbd
    udp        0      0 192.168.66.75:138       0.0.0.0:*                           0          28530      1782/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          28508      1782/nmbd
    udp        0      0 0.0.0.0:57958           0.0.0.0:*                           0          31041      1834/rpc.mountd
    udp        0      0 127.0.0.1:714           0.0.0.0:*                           0          31054      1810/rpc.statd
    udp        0      0 0.0.0.0:33803           0.0.0.0:*                           116        27815      1307/avahi-daemon:
    udp        0      0 0.0.0.0:58414           0.0.0.0:*                           137        36902      1856/tvheadend
    udp        0      0 0.0.0.0:50843           0.0.0.0:*                           0          31117      1834/rpc.mountd
    udp        0      0 239.255.255.250:1900    0.0.0.0:*                           137        36899      1856/tvheadend
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           141        33702      1770/evcc
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           141        33698      1770/evcc
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           141        33694      1770/evcc
    udp        0      0 0.0.0.0:34837           0.0.0.0:*                           0          31094      1834/rpc.mountd
    udp        0      0 192.168.66.75:60001     0.0.0.0:*                           1001       93595      14892/io.wiegand-tc
    udp        0      0 0.0.0.0:60833           0.0.0.0:*                           0          28479      -
    udp6       0      0 :::5353                 :::*                                141        33687      1770/evcc
    udp6       0      0 :::5353                 :::*                                116        27814      1307/avahi-daemon:
    udp6       0      0 192.168.66.75:47634     :::*                                126        39059      1557/java
    udp6       0      0 :::39845                :::*                                128        31088      1810/rpc.statd
    udp6       0      0 172.16.100.9:48512      :::*                                126        39058      1557/java
    udp6       0      0 :::40813                :::*                                0          31111      1834/rpc.mountd
    udp6       0      0 fd16:f83a:ca:76b2:8e:53 :::*                                999        35841      2228/pihole-FTL
    udp6       0      0 fd16:f83a:ca:76b2:a0:53 :::*                                999        35083      2228/pihole-FTL
    udp6       0      0 fd16:f83a:ca:76b2:87:53 :::*                                999        35069      2228/pihole-FTL
    udp6       0      0 fd16:f83a:ca:76b2:45:53 :::*                                999        35039      2228/pihole-FTL
    udp6       0      0 ::1:53                  :::*                                999        33971      2228/pihole-FTL
    udp6       0      0 fe80::ee2c:259e:69f8:53 :::*                                999        33969      2228/pihole-FTL
    udp6       0      0 fe80::bee1:cabf:72ba:53 :::*                                999        33967      2228/pihole-FTL
    udp6       0      0 :::111                  :::*                                0          14823      1/init
    udp6       0      0 :::49339                :::*                                0          31124      1834/rpc.mountd
    udp6       0      0 :::50537                :::*                                0          31073      1834/rpc.mountd
    udp6       0      0 :::10001                :::*                                126        39060      1557/java
    udp6       0      0 :::35238                :::*                                116        27816      1307/avahi-daemon:
    udp6       0      0 :::3478                 :::*                                126        38067      1557/java
    udp6       0      0 :::60833                :::*                                0          28480      -
    udp6       0      0 172.17.0.1:52790        :::*                                126        39057      1557/java
    udp6       0      0 :::36599                :::*                                0          32108      -
    2025-10-06 23:41:28.440  - info: host.RoofServer instance system.adapter.govee.0 in version "0.0.5" started with pid 16344
    2025-10-06 23:41:31.406  - warn: daswetter.0 (16235) slow connection to states DB. Still waiting ...
    2025-10-06 23:41:31.608  - info: ham.0 (15263) stateChange ham.0.Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Temperature.Current-Temperature {"val":19.4,"ack":true,"ts":1759786842504,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1759536915369}
    2025-10-06 23:41:32.613  - info: ham.0 (15263) updateChannel Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Motion-Enabled: name = Blink Hand Kamera Motion Enabled
    2025-10-06 23:41:32.671  - info: sql.0 (14670) changed history configuration to pin detected datatype for modbus.1.holdingRegisters.1088_PV-sensor_power
    2025-10-06 23:41:33.171  - info: host.RoofServer instance system.adapter.device-watcher.0 in version "2.13.1" started with pid 16833
    2025-10-06 23:41:33.676  - info: host.RoofServer instance system.adapter.modbus.2 in version "6.3.2" started with pid 16963
    2025-10-06 23:41:35.248  - info: ham.0 (15263) updateState Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Motion-Enabled.Name: value = Blink Hand Kamera Motion Enabled /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
    2025-10-06 23:41:35.916  - info: host.RoofServer instance system.adapter.easee.1 in version "1.0.10" started with pid 16988
    2025-10-06 23:41:39.336  - warn: evcc.0 (16260) slow connection to states DB. Still waiting ...
    2025-10-06 23:41:41.145  - info: ham.0 (15263) stateChange ham.0.Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Motion-Enabled.Name {"val":"Blink Hand Kamera Motion Enabled","ack":true,"ts":1759786839343,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1757794096554}
    2025-10-06 23:41:41.205  - info: ham.0 (15263) updateState Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Motion-Enabled.On: value = true /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
    2025-10-06 23:41:42.498  - info: host.RoofServer instance system.adapter.parser.0 in version "2.2.4" started with pid 17012
    2025-10-06 23:41:44.982  - info: ham.0 (15263) stateChange ham.0.Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Motion-Enabled.On {"val":true,"ack":true,"ts":1759786842565,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1757794096588}
    2025-10-06 23:41:45.101  - info: host.RoofServer instance system.adapter.discovery.0 in version "5.0.0" started with pid 17038
    2025-10-06 23:41:45.393  - info: ham.0 (15263) updateChannel Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Privacy-Mode: name = Blink Hand Kamera Privacy Mode
    2025-10-06 23:41:46.657  - info: ham.0 (15263) updateState Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Privacy-Mode.Name: value = Blink Hand Kamera Privacy Mode /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
    2025-10-06 23:41:46.802  - info: host.RoofServer instance system.adapter.vw-connect.0 in version "0.6.0" started with pid 17073
    2025-10-06 23:41:47.506  - info: host.RoofServer instance system.adapter.statistics.0 in version "2.4.0" started with pid 17089
    2025-10-06 23:41:48.345  - info: host.RoofServer instance system.adapter.web.0 in version "7.0.8" started with pid 17096
    2025-10-06 23:41:49.664  - info: host.RoofServer instance system.adapter.matter.0 in version "0.5.2" started with pid 17111
    2025-10-06 23:41:49.666  - info: ham.0 (15263) stateChange ham.0.Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Privacy-Mode.Name {"val":"Blink Hand Kamera Privacy Mode","ack":true,"ts":1759786839495,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1757794096658}
    2025-10-06 23:41:50.052  - info: ham.0 (15263) updateState Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Privacy-Mode.On: value = false /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
    2025-10-06 23:41:51.953  - info: tuya.0 (15293) bf918b83061a3f9b54rm6b: Error on Reconnect (1): connection timed out
    2025-10-06 23:41:52.030  - info: host.RoofServer instance system.adapter.telegram-menu.0 in version "2.4.4" started with pid 17129
    adarof
    Korrektur: Nach 2 "Neustarts" scheint es nun zu tun. wunder
    Ich hab den Start-nach-Boot nun durch "sudo systemctl disable iobroker.service" abgemeldet.
    --> Wie sollte ich denn den ioBroker starten beim Booten?
    • A adarof
      Script v.2025-08-09
      *** BASE SYSTEM ***
               Chassis: desktop
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      hmersch
      HOME=/home/hmersch
      iobroker
      HOME=/home/iobroker
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           2.0G          0B        2.0G
               3606 M used memory
               7733 M free memory
                494 M buffer memory
               4041 M swap cache
               2047 M total swap
                  0 M used swap
               2047 M free swap
      *** FILESYSTEM ***
      /var:
      27G     /var/
      22G     /var/lib
      6.2G    /var/lib/mysql
      6.1G    /var/lib/snapd
      6.0G    /var/lib/unifi
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.2
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        56520
      States:         48083
      Pending Updates: 0
      @adarof sagte in System & Admin Upgrade "exited with code 25" Start-Schleife?:
      Die Kiste ist auch gut am rödeln.
      Bring das in nächster Zeit auf Ubuntu 24.04 'Noble'.
      Oder gleich besser auf ein Debian 13 'Trixie'.
      Schmeiß den user iobroker aus der Gruppe sudo raus.
      Setz den user hmersch in die Gruppe adm.
      Läuft da der komplette Gnome Desktop mit? Ausschalten.
      Verwende nodejs@22.
      Schmeiß die komischen ioBroker-Repos namens 'source' und 'online' raus.
      Was ziehst du diir warum aus dem deadsnakes PPA?
      Das macht der eigentlich von selber...
      Es wird natürlich auch da ein systemd Service verwendet.
      (Genau genommen ruft auch ein iob start am Ende ein sudo systemctl start iobroker auf. Aber auch nicht nur.)
      Jag den
      iob fix
      mal drüber.
      Evtl. solltest du die Datenbank auf redis umstellen.
        adarof
        @thomas-braun Ich wollt mich heute ransetzen.
        Die merkwürdigen Repos sind raus. Die weiteren Änderungen nun Schritt für Schritt.
        Es widerstrebt mir aber nun alles "blind" zu machen.
        Nur startet das System wieder nicht mehr bzw startet, stürzt ab und startet wieder usw.
        Ich sehe, dass
        /usr/bin/node /opt/iobroker/node_modules/iobroker.email/build/main.js --instance 0 --loglevel info
        Aufrufe gemacht werden - die dann jeweils in laufenden Prozessen pro Adapter führen.
        Und dann - wenn halt ca 20 Adapter laufen beenden sich auf einmal alle Prozesse.
        iob logs
        scheint mir nicht weit genug in die Vergangenheit zu reichen um an sinnvolle Infos zu kommen.
        Kann ich konfigurieren nur den admin (also Oberfläche) zu starten, aber alle Adpater auf "rot" lassen, damit ich diese dann händisch nach und nach starten kann - vielleicht bekomm ich dann ja genau den einen Adapter mit, der nicht will.
        Gruss - Henning
        • A adarof
          Ich sehe, dass
          iob logs
          Gruss - Henning
          @adarof
          Such dir aus der Liste:
          Adapter State
          die Adapter mit einem Pluszeichen in der ersten Spalte und stop die per
          iob stop ADAPTERNAME
          • A adarof
            Ich sehe, dass
            iob logs
            Gruss - Henning
            @adarof
            iob logs
            geht am laufenden Tag bis 0 Uhr zurück.
            Ältere Logs finden sich in:
            echad@chet:/opt/iobroker/log $ ls -lA
            total 40
            -rw-rw-r--+ 1 iobroker iobroker 1861 Nov  4 00:00 iobroker.2025-11-03.log.gz
            -rw-rw-r--+ 1 iobroker iobroker  881 Nov  5 00:00 iobroker.2025-11-04.log.gz
            -rw-rw-r--+ 1 iobroker iobroker 1878 Nov  6 00:00 iobroker.2025-11-05.log.gz
            -rw-rw-r--+ 1 iobroker iobroker 7191 Nov  7 00:00 iobroker.2025-11-06.log.gz
            -rw-rw-r--+ 1 iobroker iobroker 1187 Nov  8 00:00 iobroker.2025-11-07.log.gz
            -rw-rw-r--+ 1 iobroker iobroker 6515 Nov  9 00:00 iobroker.2025-11-08.log.gz
            -rw-rw-r--+ 1 iobroker iobroker 1323 Nov  9 15:38 iobroker.2025-11-09.log
            -rw-rwxr--+ 1 iobroker iobroker  793 Nov  9 15:38 iobroker-audit.json
            lrwxrwxrwx  1 iobroker iobroker   23 Nov  9 19:11 iobroker.current.log -> iobroker.2025-11-09.log
              @adarof
              Adapter State
              adarof
              Da laufen keine (siehe unten) - aber wie kann ich verhindern, dass sie bei einem iob start alle gestartet werden?
              Sollte nach einem "iob stop" ein "iob start admin" nur den Admin starten?
              Liefert mir weder eine Weboberfläche noch einen Eintrag unter "iob logs"
              iob list instances
              system.adapter.backitup.0               : backitup              : RoofServer                               - disabled
                @adarof
                iob logs
                total 40
                adarof
                schrieb am zuletzt editiert von adarof
                Wunderbar - Danke.
                Ich hab da mal das vom aktuellen Tag gelöscht und einmal neu "iob start" gemacht.
                Siehst Du zufällig was im Log? Zeile 1414 ... da scheint es dann richtung Shutdown zu gehen?
                <gelöscht>
                Dann noch was: Ich habe in Verdacht, dass die javascript Erweiterungen durch installieren beim Starten bei mir Probleme machen - deswegen hab ich alle Erweiterungen rausgenommen aus der Konfig. Nun sehe ich aber
                npm uninstall @iobroker-javascript.0/klf-200-api
                solche Aufrufe, die ganz schön lange laufen.
                Kann ich diese Aufrufe verhindern bzw. manuell vorab ausführen, sodass iob das nicht selber macht?
                Gruss - Henning
                • A adarof
                  Wunderbar - Danke.
                  <gelöscht>
                  Gruss - Henning
                  @adarof
                  Bring das ganze Spiel erstmal auf nodejs@22
                  iob nodejs-update 22
                    @adarof
                    adarof
                    @thomas-braun sagte in System & Admin Upgrade "exited with code 25" Start-Schleife?:
                    Hab ich:
                    added 1 package, removed 92 packages, and changed 1697 packages in 2m
                    209 packages are looking for funding
                      run `npm fund` for details
                    We tried our best to fix your nodejs. Please run iob diag again to verify.
                    *** RESTARTING ioBroker NOW! ***
                    dann wieder Neustart-Schleifen.
                    Neues Logfile:
                    Was könnt ich noch machen?
                    Gruss - Henning
                    • A adarof
                      Hab ich:
                      Neues Logfile:
                      Gruss - Henning
                      @adarof
                      2025-11-09 19:43:16.946  - error: host.RoofServer Caught by controller[0]: Error: Unknown objects type: jsonl: Cannot find module 'graceful-fs'
                      Da klemmt es schon. Das Modul wird auf meiner Kiste von relativ vielen Adaptern verwendet und auch der js-controller hat das auf der Wunschlliste.
                      Ich würde vermutlich ein Backup ziehen und das ganze Ding neuinstallieren. Oder ein Backup einspielen, das diese Probleme noch nicht hatte.
                        @adarof
                        adarof
                        Backups habe ich schon - allerdings ist das Problem ja schon länger da.
                        Also /opt/iobroker zur Seite legen (just in case ;-) , von neuem installieren & backup einspielen?
                        Gibt es eine Beschreibung, wie ich auf einen neuen IObroker das Backup "richtig" einspiele?
                        gruss - Henning
                        • A adarof
                          gruss - Henning
                          @adarof
                          https://github.com/simatec/ioBroker.backitup/wiki
                          Ich würde da aber auch gleich das OS neuinstallieren, bevorzugt kein Schnubbibuntu sondern ein richtiges Debian.
                          • A adarof
                            gruss - Henning
                            @adarof
                            Wie schaut eigentlich der npm tree aus?
                            cd /opt/iobroker
                            npm ls
                            npm ls graceful-fs
                              @adarof
                              adarof
                              Ich würde hoffen, dass das nicht nötig ist - da laufen noch 1001 andere Sachen drauf, die ich alle nurnoch marginal weiss, wie sie zu konfigurieren sind.
                              Gerade läuft er nun wieder nachdem ich den js-controller (mit dependencies) einfach überinstalliert habe
                               sudo -H -u iobroker npm install iobroker.js-controller
                              ...warum auch immer gerade.
                              Ich lass das gerade mal so, wo er läuft und nehme mir das Problem nochmal die Tage vor. Idealerweise wenn auch Zeit ist.
                              Heute also erstmal Dir ein DANKE wieder !!!
                              ...auch wenn bzgl. des Problems leider nicht schlauer geworden bin
                              • A adarof
                                Das ist schlecht. Was machste denn, wenn das Ding aus anderen Gründen die Grätsche macht.
                                Upgraden musste die Kiste eh mal irgendwann.
                                  @adarof
                                  cd /opt/iobroker
                                  npm ls
                                  npm ls graceful-fs
                                  adarof
                                  npm ls npm ls graceful-fs
                                  Oh - das scheint ein guter Ansatz.
                                  hier
                                  iobroker.inst@2.0.2 /opt/iobroker
                                  ├── @iobroker-javascript.0/klf-200-api@npm:klf-200-api@6.0.1
                                  ├── @iobroker-javascript.0/node-fetch@npm:node-fetch@2.7.0
                                  ├── buffer-shims@1.0.0 extraneous
                                  ├── colors@1.4.0
                                  ├── decimal.js@10.6.0 extraneous
                                  ├── fs-extra@7.0.1
                                  ├── futoin-hkdf@1.4.3 extraneous
                                  ├── homebridge-plugin-wrapper@3.2.0 extraneous
                                  ├── iobroker.admin@7.7.2
                                  ├── iobroker.alexa2@3.27.3
                                  ├── iobroker.amazon-dash@1.2.0
                                  ├── iobroker.backitup@3.3.5
                                  ├── iobroker.daswetter@3.2.3
                                  ├── iobroker.device-watcher@2.13.1
                                  ├── iobroker.discovery@5.0.0
                                  ├── iobroker.dwd@2.8.5
                                  ├── iobroker.easee@1.0.10
                                  ├── iobroker.email@2.0.4
                                  ├── iobroker.evcc@0.2.4 invalid: "github:Newan/ioBroker.evcc" from the root project
                                  ├── iobroker.flot@1.12.0
                                  ├── iobroker.govee@0.0.5 invalid: "github:nbuenger/ioBroker.govee#0d983c49135b87ac2f88f9d832a6d632c4889606" from the root project
                                  ├── iobroker.ham@5.3.1
                                  ├── iobroker.history@3.0.1
                                  ├── iobroker.hm-rega@5.1.0
                                  ├── iobroker.hm-rpc@2.0.2
                                  ├── iobroker.homeconnect@1.4.3
                                  ├── iobroker.ical@1.17.0
                                  ├── iobroker.icons-addictive-flavour-png@0.1.0
                                  ├── iobroker.icons-material-png@0.1.0
                                  ├── iobroker.icons-mfd-png@1.2.1
                                  ├── iobroker.icons-mfd-svg@1.2.0
                                  ├── iobroker.javascript@8.9.2
                                  ├── iobroker.js-controller@7.0.7
                                  ├── iobroker.lg-thinq@1.1.2
                                  ├── iobroker.material@1.3.1
                                  ├── iobroker.matter@0.5.5
                                  ├── iobroker.mielecloudservice@6.5.10
                                  ├── iobroker.mobile@1.0.1
                                  ├── iobroker.modbus@6.3.2
                                  ├── iobroker.nina@0.0.25
                                  ├── iobroker.nut@1.6.0
                                  ├── iobroker.opendtu@3.1.0
                                  ├── iobroker.parser@2.2.4
                                  ├── iobroker.ping@1.6.2
                                  ├── iobroker.pvforecast@5.0.0
                                  ├── iobroker.rickshaw@1.0.0
                                  ├── iobroker.simple-api@2.8.0
                                  ├── iobroker.socketio@6.7.1
                                  ├── iobroker.sonoff@3.2.1
                                  ├── iobroker.sql@3.0.1
                                  ├── iobroker.statistics@2.4.0
                                  ├── iobroker.syrconnect@0.1.1 invalid: "github:eifel-tech/ioBroker.syrconnect#f6d0efe93eed9eb985fab54eeda2afd0b66f9f28" from the root project
                                  ├── iobroker.telegram-menu@2.4.4
                                  ├── iobroker.telegram@4.1.0
                                  ├── iobroker.text2command@3.0.3
                                  ├── iobroker.tr-064@4.3.0
                                  ├── iobroker.tuya@3.16.0
                                  ├── iobroker.unifi@0.7.0
                                  ├── iobroker.vis-bars@0.1.4
                                  ├── iobroker.vis-canvas-gauges@1.0.1
                                  ├── iobroker.vis-colorpicker@2.0.3
                                  ├── iobroker.vis-fancyswitch@1.1.0
                                  ├── iobroker.vis-history@1.0.0
                                  ├── iobroker.vis-hqwidgets@1.5.1
                                  ├── iobroker.vis-jqui-mfd@1.1.1
                                  ├── iobroker.vis-metro@1.2.0
                                  ├── iobroker.vis-rgraph@0.0.2
                                  ├── iobroker.vis-timeandweather@1.2.2
                                  ├── iobroker.vis@1.5.6
                                  ├── iobroker.vw-connect@0.6.0
                                  ├── iobroker.waterkotte-easycon@0.0.3 invalid: "github:theknut/ioBroker.waterkotte-easycon#d8c7921fcfde98465e481a4780ad4c0e73375c31" from the root project
                                  ├── iobroker.web@7.0.8
                                  ├── iobroker.wiegand-tcpip@0.4.7
                                  ├── iobroker.ws@2.6.2
                                  ├── iobroker@2.0.3
                                  ├── mock-require@3.0.3 extraneous
                                  ├── node-persist@0.0.11 extraneous
                                  ├── q@1.1.2 extraneous
                                  ├── remove-trailing-separator@1.1.0 extraneous
                                  ├── semver@5.7.2
                                  ├── string-argv@0.3.2 extraneous
                                  └── yargs@7.1.2
                                  npm error code ELSPROBLEMS
                                  npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                                  npm error extraneous: decimal.js@10.6.0 /opt/iobroker/node_modules/decimal.js
                                  npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                                  npm error extraneous: homebridge-plugin-wrapper@3.2.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper
                                  npm error invalid: iobroker.evcc@0.2.4 /opt/iobroker/node_modules/iobroker.evcc
                                  npm error invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
                                  npm error invalid: iobroker.syrconnect@0.1.1 /opt/iobroker/node_modules/iobroker.syrconnect
                                  npm error invalid: iobroker.waterkotte-easycon@0.0.3 /opt/iobroker/node_modules/iobroker.waterkotte-easycon
                                  npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                                  npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                                  npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                                  npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                                  npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
                                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-09T19_07_41_606Z-debug-0.log
                                  /opt/iobroker$ npm ls graceful-fs
                                  ├─┬ fs-extra@7.0.1
                                  │ ├── graceful-fs@4.2.11
                                  │ └─┬ jsonfile@4.0.0
                                  │   └── graceful-fs@4.2.11 deduped
                                  ├─┬ homebridge-plugin-wrapper@3.2.0 extraneous
                                  │ ├─┬ fs-extra@10.1.0 extraneous
                                  │ │ └── graceful-fs@4.2.11 deduped
                                  │ └─┬ jsonfile@6.2.0 extraneous
                                  ├─┬ iobroker.admin@7.7.2
                                  │ └─┬ archiver@7.0.1
                                  │   └─┬ archiver-utils@5.0.2
                                  ├─┬ iobroker.backitup@3.3.5
                                  │ └─┬ fs-extra@11.3.2
                                  │   ├── graceful-fs@4.2.11 deduped
                                  ├─┬ iobroker.ham@5.3.1
                                  │ └─┬ homebridge-plugin-wrapper@3.2.0
                                  │   └─┬ fs-extra@10.1.0
                                  ├─┬ iobroker.js-controller@7.0.7
                                  │ ├─┬ @iobroker/db-objects-file@7.0.7
                                  │ │ ├─┬ @iobroker/db-base@7.0.7
                                  │ │ │ └─┬ fs-extra@11.3.2
                                  │ │ │   ├── graceful-fs@4.2.11 deduped
                                  │ │ │   └─┬ jsonfile@6.2.0
                                  │ │ │     └── graceful-fs@4.2.11 deduped
                                  │ ├─┬ @iobroker/db-objects-jsonl@7.0.7
                                  │ │ ├─┬ @alcalzone/jsonl-db@3.1.1
                                  │ │ │ ├─┬ @alcalzone/proper-lockfile@4.1.3-0
                                  │ │ │ │ └── graceful-fs@4.2.11 deduped
                                  │ │ │ └─┬ fs-extra@10.1.0
                                  │ ├─┬ @iobroker/js-controller-adapter@7.0.7
                                  │ │ ├─┬ @alcalzone/pak@0.8.1
                                  │ ├─┬ @iobroker/js-controller-cli@7.0.7
                                  │ ├─┬ @iobroker/js-controller-common-db@7.0.7
                                  │ ├─┬ @iobroker/js-controller-common@7.0.7
                                  ├─┬ iobroker.matter@0.5.5
                                  │ └─┬ @matter/nodejs-ble@0.15.6
                                  │   └─┬ @stoprocent/bleno@0.11.4
                                  │     └─┬ @stoprocent/bluetooth-hci-socket@2.2.3
                                  │       └─┬ patch-package@8.0.1
                                  │         └─┬ klaw-sync@6.0.0
                                  ├─┬ iobroker.simple-api@2.8.0
                                  │ └─┬ @iobroker/testing@4.1.3
                                  ├─┬ iobroker.sql@3.0.1
                                  │ └─┬ sqlite3@5.1.7
                                  │   └─┬ node-gyp@8.4.1
                                  ├─┬ iobroker.telegram-menu@2.4.4
                                  │ └─┬ nyc@17.1.0
                                  │   └─┬ caching-transform@4.0.0
                                  │     └─┬ package-hash@4.0.0
                                  ├─┬ iobroker.tuya@3.16.0
                                  └─┬ yargs@7.1.2
                                    └─┬ read-pkg-up@1.0.1
                                      └─┬ read-pkg@1.1.0
                                        ├─┬ load-json-file@1.1.0
                                        └─┬ path-type@1.1.0
                                  Da sind ja eingie Fehler. Was kann ich dagegen tun?
                                  Gruss -
                                  • A adarof
                                    hier
                                    ├── colors@1.4.0
                                    ├── fs-extra@7.0.1
                                    ├── iobroker@2.0.3
                                    ├── semver@5.7.2
                                    └── yargs@7.1.2
                                    ├─┬ fs-extra@7.0.1
                                    │ └─┬ sqlite3@5.1.7
                                    │ └─┬ nyc@17.1.0
                                    └─┬ yargs@7.1.2
                                        └─┬ read-pkg@1.1.0
                                          └─┬ path-type@1.1.0
                                    Gruss -
                                    @adarof
                                    Die ganzen als 'invalid' gekennzeichneten Adapter mal ordentlich über ein Repo installieren und halt NICHT aus dem GitHub fischen. Macht man grundsätzlich nicht.
                                      adarof
                                      @thomas-braun Naja - Upgraden & hoffen ... Backups von allem sind schon vorhanden, aber ich muss halt jeweils mich neu einlesen, wenn es eine Neuinstallation ist.
                                        @adarof
                                        adarof
                                        Okay - räume ich auf.
                                        Viele nutze ich garnicht (mehr) ... keine Instanzen vorhanden
                                        Danke für heute erstmal.
                                        Gruss - Henning
                                        • A adarof
                                          Gruss - Henning
                                          @adarof
                                          Ziel sollte es sein, das in der Übersicht nichts anderes als die Adapter auftauchen. So wie hier:
                                          echad@chet:/opt/iobroker $ npm ls
                                          iobroker.inst@3.0.0 /opt/iobroker
                                          ├── iobroker.admin@7.7.19
                                          ├── iobroker.alexa2@3.27.4
                                          ├── iobroker.alias-manager@2.0.0
                                          ├── iobroker.ankersolix2@2.4.1
                                          ├── iobroker.awtrix-light@3.0.0
                                          ├── iobroker.backitup@3.3.10
                                          ├── iobroker.ble@0.14.1
                                          ├── iobroker.cloud@5.1.2
                                          ├── iobroker.devices@1.2.9
                                          ├── iobroker.echarts@2.0.10 (git+ssh://git@github.com/Grothesk242/ioBroker.echarts.git#7e00a1c9e78e378443ceac4396eeba04f7b7e73f)
                                          ├── iobroker.firetv@2.1.0
                                          ├── iobroker.followthesun@0.5.2
                                          ├── iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
                                          ├── iobroker.govee-local@0.4.2
                                          ├── iobroker.ical@1.18.1
                                          ├── iobroker.iceroad@1.2.1
                                          ├── iobroker.iot@5.0.7
                                          ├── iobroker.javascript@9.0.11
                                          ├── iobroker.mihome-cloud@0.1.1 (git+ssh://git@github.com/TA2k/ioBroker.mihome-cloud.git#7b814e73970205d15ad9ba2af459c6a30d20af73)
                                          ├── iobroker.mihome-vacuum@5.3.0
                                          ├── iobroker.mihome@1.4.0
                                          ├── iobroker.mqtt@6.1.4
                                          ├── iobroker.nina@0.0.26
                                          ├── iobroker.notification-manager@1.3.0
                                          ├── iobroker.nuki-extended@2.7.0
                                          ├── iobroker.nut@1.7.0
                                          ├── iobroker.openweathermap@1.4.0
                                          ├── iobroker.parcel@0.2.10 (git+ssh://git@github.com/Grothesk242/ioBroker.parcel.git#e1c8a5a73c93b208eb8cd54015d059a865b87ec9)
                                          ├── iobroker.playstation@0.0.3
                                          ├── iobroker.rpi2@2.4.0 (git+ssh://git@github.com/Grothesk242/ioBroker.rpi2.git#4520729d0399a57717ea36573d39a726b120a048)
                                          ├── iobroker.sainlogic@0.12.1
                                          ├── iobroker.samsung_tizen@1.1.0
                                          ├── iobroker.samsung@0.6.1
                                          ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#7a05fa59dfc5e3ce8d73018badc4e420996452f8)
                                          ├── iobroker.tado@0.8.2
                                          ├── iobroker.tankerkoenig@3.4.0
                                          ├── iobroker.tradfri@3.1.3
                                          ├── iobroker.trashschedule@4.0.1
                                          ├── iobroker.tuya@3.17.0
                                          ├── iobroker.weather-warnings@0.9.0
                                          ├── iobroker.web@7.0.9
                                          ├── iobroker.whatsapp-cmb@0.3.0
                                          └── iobroker.zigbee@3.2.5
                                          Edit: Ja, hier sind auch GitHub-Installationen dabei. Die sind aber bewusst da in genau diesem Zustand drin.
