  4. s7 Adapter funktioniert nicht mehr noch node update
    6.5k
60 Beiträge 7 Kommentatoren 4.2k Aufrufe 4 Beobachtet
    @basti97
    Auf einem aktuellen System baut das Ding jedenfalls:
    echad@chet:~ $ iobroker add s7 --debug
    NPM version: 11.6.1
    Installing iobroker.s7@1.5.0... (System call)
    > node-snap7@1.0.9 install
    > prebuild-install || node-gyp rebuild
    (node:231268) [DEP0176] DeprecationWarning: fs.R_OK is deprecated, use fs.constants.R_OK instead
    (Use `node --trace-deprecation ...` to show where the warning was created)
    prebuild-install warn install No prebuilt binaries found (target=24.11.0 runtime=node arch=arm64 libc= platform=linux)
    gyp info it worked if it ends with ok
    gyp info using node-gyp@11.4.2
    gyp info using node@24.11.0 | linux | arm64
    gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
    gyp http GET https://s3-us-west-2.amazonaws.com/nodesource-public-downloads/24.11.0-ns6.0.2/artifacts/headers/krypton/v6.0.2/nsolid-v6.0.2-headers.tar.gz
    gyp http 200 https://s3-us-west-2.amazonaws.com/nodesource-public-downloads/24.11.0-ns6.0.2/artifacts/headers/krypton/v6.0.2/nsolid-v6.0.2-headers.tar.gz
    gyp http GET https://s3-us-west-2.amazonaws.com/nodesource-public-downloads/24.11.0-ns6.0.2/artifacts/headers/krypton/v6.0.2/SHASUMS256.txt
    gyp http 200 https://s3-us-west-2.amazonaws.com/nodesource-public-downloads/24.11.0-ns6.0.2/artifacts/headers/krypton/v6.0.2/SHASUMS256.txt
    gyp info spawn /usr/bin/python3
    gyp info spawn args [
    gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
    gyp info spawn args 'binding.gyp',
    gyp info spawn args '-f',
    gyp info spawn args 'make',
    gyp info spawn args '-I',
    gyp info spawn args '/opt/iobroker/node_modules/node-snap7/build/config.gypi',
    gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
    gyp info spawn args '/home/iobroker/.cache/node-gyp/24.11.0/include/node/common.gypi',
    gyp info spawn args '-Dlibrary=shared_library',
    gyp info spawn args '-Dvisibility=default',
    gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/24.11.0',
    gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
    gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/24.11.0/<(target_arch)/node.lib',
    gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-snap7',
    gyp info spawn args '-Dnode_engine=v8',
    gyp info spawn args '--depth=.',
    gyp info spawn args '--no-parallel',
    gyp info spawn args '--generator-output',
    gyp info spawn args 'build',
    gyp info spawn args '-Goutput_dir=.'
    gyp info spawn args ]
    gyp info spawn make
    gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
    make: Entering directory '/opt/iobroker/node_modules/node-snap7/build'
      CXX(target) Release/obj.target/snap7/deps/snap7/src/sys/snap_msgsock.o
      CXX(target) Release/obj.target/snap7/deps/snap7/src/sys/snap_sysutils.o
      CXX(target) Release/obj.target/snap7/deps/snap7/src/sys/snap_tcpsrvr.o
    ../deps/snap7/src/sys/snap_tcpsrvr.cpp: In member function ‘int TCustomMsgServer::StartTo(const char*, word)’:
    ../deps/snap7/src/sys/snap_tcpsrvr.cpp:429:12: warning: ‘char* strncpy(char*, const char*, size_t)’ specified bound 16 equals destination size [-Wstringop-truncation]
      429 |     strncpy(FLocalAddress, Address, 16);
      CXX(target) Release/obj.target/snap7/deps/snap7/src/sys/snap_threads.o
      CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_client.o
      CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_isotcp.o
    ../deps/snap7/src/core/s7_isotcp.cpp: In member function ‘int TIsoTcpSocket::IsoConfirmConnection(u_char)’:
    ../deps/snap7/src/core/s7_isotcp.cpp:163:17: warning: variable ‘TempRef’ set but not used [-Wunused-but-set-variable]
      163 |         u_short TempRef;
      CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_partner.o
    ../deps/snap7/src/core/s7_partner.cpp: In member function ‘int TConnectionServer::StartTo(const char*)’:
    ../deps/snap7/src/core/s7_partner.cpp:252:12: warning: ‘char* strncpy(char*, const char*, size_t)’ specified bound 16 equals destination size [-Wstringop-truncation]
      252 |     strncpy(FLocalAddress,Address,16);
      CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_peer.o
      CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_server.o
    ../deps/snap7/src/core/s7_server.cpp: In member function ‘byte TS7Worker::WriteArea(PReqFunWriteDataItem, PReqFunWriteItem, TEv&)’:
    ../deps/snap7/src/core/s7_server.cpp:626:5: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
      626 |     if ((ReqItemPar->Area==S7AreaTM) ^ (ReqItemPar->TransportSize==S7WLTimer))
    ../deps/snap7/src/core/s7_server.cpp:629:9: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
      629 |         if ((ReqItemPar->Area==S7AreaCT) ^ (ReqItemPar->TransportSize==S7WLCounter))
    ../deps/snap7/src/core/s7_server.cpp: In member function ‘void TS7Worker::SZLSystemState()’:
    ../deps/snap7/src/core/s7_server.cpp:1247:11: warning: ‘void* memcpy(void*, const void*, size_t)’ forming offset [4, 5] is out of the bounds [0, 4] of object ‘SZLNotAvail’ with type ‘byte [4]’ {aka ‘unsigned char [4]’} [-Warray-bounds=]
     1247 |     memcpy(SZL.ResData,&SZLNotAvail,sizeof(SZLSysState));
    In file included from ../deps/snap7/src/core/s7_server.cpp:27:
    ../deps/snap7/src/core/s7_firmware.h:36:8: note: ‘SZLNotAvail’ declared here
       36 |   byte SZLNotAvail[4] = {
    ../deps/snap7/src/core/s7_server.cpp: In member function ‘word TS7Worker::ReadArea(PResFunReadItem, PReqFunReadItem, int&, TEv&)’:
    ../deps/snap7/src/core/s7_server.cpp:454:34: warning: ‘BitIndex’ may be used uninitialized [-Wmaybe-uninitialized]
      454 |           if ((ByteVal & BitMask[BitIndex])!=0)
    ../deps/snap7/src/core/s7_server.cpp:332:10: note: ‘BitIndex’ was declared here
      332 |     byte BitIndex, ByteVal;
    ../deps/snap7/src/core/s7_server.cpp:698:53: warning: ‘BitIndex’ may be used uninitialized [-Wmaybe-uninitialized]
      698 |                           *Target=*Target | BitMask[BitIndex];
    ../deps/snap7/src/core/s7_server.cpp:598:14: note: ‘BitIndex’ was declared here
      598 |         byte BitIndex;
      CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_text.o
    ../deps/snap7/src/core/s7_text.cpp: In function ‘char* EvtSrvText(TSrvEvent&, char*, int)’:
    ../deps/snap7/src/core/s7_text.cpp:782:5: warning: this ‘else’ clause does not guard... [-Wmisleading-indentation]
      782 |     else
    ../deps/snap7/src/core/s7_text.cpp:785:9: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘else’
      785 |         strncpy(Result, S, TextLen);
      CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_micro_client.o
    ../deps/snap7/src/core/s7_micro_client.cpp: In member function ‘void TSnap7MicroClient::SetConnectionParams(const char*, word, word)’:
    ../deps/snap7/src/core/s7_micro_client.cpp:2675:13: warning: ‘char* strncpy(char*, const char*, size_t)’ specified bound 16 equals destination size [-Wstringop-truncation]
     2675 |      strncpy(RemoteAddress, RemAddress, 16);
    ../deps/snap7/src/core/s7_micro_client.cpp: In member function ‘int TSnap7MicroClient::SetSessionPassword(char*)’:
    ../deps/snap7/src/core/s7_micro_client.cpp:3306:16: warning: ‘char* strncpy(char*, const char*, size_t)’ output truncated before terminating nul copying as many bytes from a string as its length [-Wstringop-truncation]
     3306 |         strncpy((char*)&opData,Password,L);
    ../deps/snap7/src/core/s7_micro_client.cpp:3298:26: note: length computed here
     3298 |         size_t L = strlen(Password);
      CXX(target) Release/obj.target/snap7/deps/snap7/src/lib/snap7_libmain.o
    rm -f Release/obj.target/snap7.a Release/obj.target/snap7.a.ar-file-list; mkdir -p `dirname Release/obj.target/snap7.a`
    ar crs Release/obj.target/snap7.a @Release/obj.target/snap7.a.ar-file-list
      COPY Release/snap7.a
      CXX(target) Release/obj.target/node_snap7/src/node_snap7.o
    In file included from ../src/node_snap7_client.h:11,
                     from ../src/node_snap7.cpp:6:
    ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
    ../../nan/nan.h:1173:36: warning: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ is deprecated: Use WriteUtf8V2 instead. [-Wdeprecated-declarations]
     1173 |         length_ = string->WriteUtf8(v8::Isolate::GetCurrent(), str_,
     1174 |                                     static_cast<int>(len), 0, flags);
    In file included from /home/iobroker/.cache/node-gyp/24.11.0/include/node/v8-object.h:12,
                     from /home/iobroker/.cache/node-gyp/24.11.0/include/node/v8-array-buffer.h:14,
                     from /home/iobroker/.cache/node-gyp/24.11.0/include/node/v8.h:24,
                     from /home/iobroker/.cache/node-gyp/24.11.0/include/node/node.h:74,
                     from ../src/node_snap7_client.h:10:
    /home/iobroker/.cache/node-gyp/24.11.0/include/node/v8-primitive.h:212:7: note: declared here
      212 |   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
    ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::Encode(const void*, size_t, Encoding)’:
    ../../nan/nan.h:2418:24: warning: ‘v8::Local<v8::Value> node::Encode(v8::Isolate*, const uint16_t*, size_t)’ is deprecated: Use TryEncode(...) instead [-Wdeprecated-declarations]
     2418 |     return node::Encode(
     2419 |         isolate
     2420 |       , reinterpret_cast<const uint16_t *>(buf)
     2421 |       , len / 2);
    /home/iobroker/.cache/node-gyp/24.11.0/include/node/node.h:1189:50: note: declared here
     1189 |                 NODE_EXTERN v8::Local<v8::Value> Encode(v8::Isolate* isolate,
    /home/iobroker/.cache/node-gyp/24.11.0/include/node/node.h:117:42: note: in definition of macro ‘NODE_DEPRECATED’
      117 |     __attribute__((deprecated(message))) declarator
    ../../nan/nan.h:2423:24: warning: ‘v8::Local<v8::Value> node::Encode(v8::Isolate*, const char*, size_t, encoding)’ is deprecated: Use TryEncode(...) instead [-Wdeprecated-declarations]
     2423 |     return node::Encode(
     2424 |         isolate
     2425 |       , reinterpret_cast<const char *>(buf)
     2426 |       , len
     2427 |       , node_enc);
    /home/iobroker/.cache/node-gyp/24.11.0/include/node/node.h:1181:38: note: declared here
     1181 |     NODE_EXTERN v8::Local<v8::Value> Encode(v8::Isolate* isolate,
    ../src/node_snap7.cpp: At global scope:
    /home/iobroker/.cache/node-gyp/24.11.0/include/node/node.h:1279:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
     1279 |       (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/24.11.0/include/node/node.h:1313:3: note: in expansion of macro ‘NODE_MODULE_X’
     1313 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/node_snap7.cpp:16:1: note: in expansion of macro ‘NODE_MODULE’
       16 | NODE_MODULE(node_snap7, InitAll)
      CXX(target) Release/obj.target/node_snap7/src/node_snap7_client.o
                     from ../src/node_snap7_client.cpp:6:
     2419 |         isolate
     2421 |       , len / 2);
     2424 |         isolate
     2426 |       , len
     2427 |       , node_enc);
    ../src/node_snap7_client.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_snap7::S7Client::ListBlocksOfType(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/node_snap7_client.cpp:1689:42: warning: expression does not compute the number of elements in this array; element type is ‘word’ {aka ‘short unsigned int’}, not ‘PS7BlocksOfType’ {aka ‘short unsigned int (*)[8192]’} [-Wsizeof-array-div]
     1689 |   int BlockNum = sizeof(TS7BlocksOfType) / sizeof(PS7BlocksOfType);
    ../src/node_snap7_client.cpp:1689:44: note: add parentheses around ‘sizeof (PS7BlocksOfType)’ to silence this warning
      CXX(target) Release/obj.target/node_snap7/src/node_snap7_server.o
    In file included from ../src/node_snap7_server.h:12,
                     from ../src/node_snap7_server.cpp:6:
                     from ../src/node_snap7_server.h:10:
     2419 |         isolate
     2421 |       , len / 2);
     2424 |         isolate
     2426 |       , len
     2427 |       , node_enc);
    ../src/node_snap7_server.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_snap7::S7Server::RWBufferCallback(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/node_snap7_server.cpp:721:56: warning: comparison of integer expressions of different signedness: ‘size_t’ {aka ‘long unsigned int’} and ‘int’ [-Wsign-compare]
      721 |     if (node::Buffer::Length(info[0].As<v8::Object>()) < size) {
      CXX(target) Release/obj.target/node_snap7/src/snap7.o
      SOLINK_MODULE(target) Release/obj.target/node_snap7.node
      COPY Release/node_snap7.node
    make: Leaving directory '/opt/iobroker/node_modules/node-snap7/build'
    gyp info ok
    added 3 packages in 1m
    250 packages are looking for funding
      run `npm fund` for details
    host.chet install adapter s7
    upload [5] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/assets/index-B2ytDdn0.js assets/index-B2ytDdn0.js application/javascript
    upload [4] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/assets/index-Bd3GtHgn.css assets/index-Bd3GtHgn.css text/css
    upload [3] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [2] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/index_m.html index_m.html text/html
    upload [1] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/manifest.json manifest.json application/json
    upload [0] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/s7.png s7.png image/png
    host.chet object system.adapter.s7 created/updated
    Updating objects from io-package.json for adapter "s7" with version "1.5.0"
    host.chet create instance s7
    host.chet object system.adapter.s7.0.alive created
    host.chet object system.adapter.s7.0.connected created
    host.chet object system.adapter.s7.0.compactMode created
    host.chet object system.adapter.s7.0.cpu created
    host.chet object system.adapter.s7.0.cputime created
    host.chet object system.adapter.s7.0.memHeapUsed created
    host.chet object system.adapter.s7.0.memHeapTotal created
    host.chet object system.adapter.s7.0.memRss created
    host.chet object system.adapter.s7.0.uptime created
    host.chet object system.adapter.s7.0.inputCount created
    host.chet object system.adapter.s7.0.outputCount created
    host.chet object system.adapter.s7.0.eventLoopLag created
    host.chet object system.adapter.s7.0.sigKill created
    host.chet object system.adapter.s7.0.logLevel created
    host.chet object system.adapter.s7.0 created
    echad@chet:~ $
    Basti97B Offline
    Basti97B Offline
    Basti97
    @thomas-braun was kann ich da jetzt machen?
    Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
    • Basti97B Basti97
      @basti97
      Wie bist du denn da insgesamt unterwegs?
      Ausgabe von
      iob diag
      mal posten.
      Basti97B 2 Antworten Letzte Antwort
        @basti97
        Ausgabe von
        iob diag
        mal posten.
        Basti97B Offline
        Basti97B Offline
        Basti97
        @thomas-braun Das komische bevor ich nodejs von 20.x..x auf 22.x.x aktualisiert habe hat es funktoniert. Und es betrifft nur die beiden S7 Adapter.
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
        Operating System: Debian GNU/Linux 11 (bullseye)
           Static hostname: SmartHomeMira
                 Icon name: computer-vm
                   Chassis: vm
            Virtualization: kvm
                    Kernel: Linux 5.10.0-35-amd64
              Architecture: x86-64
        OS is similar to:
        model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         17:17:50 up 18 min,  2 users,  load average: 0.35, 0.30, 0.34
        CPU threads: 2
        *** LIFE CYCLE STATUS ***
        Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
        *** TIME AND TIMEZONES ***
                       Local time: Sun 2025-11-09 17:17:51 CET
                   Universal time: Sun 2025-11-09 16:17:51 UTC
                         RTC time: Sun 2025-11-09 16:17:52
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        mira
        HOME=/home/mira
        GROUPS=mira cdrom floppy sudo audio dip video plugdev netdev bluetooth scanner iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         false
        Display-Manager:        * gdm3.service - LSB: GNOME Display Manager
        Desktop:
        Session:                tty
        *** MEMORY ***
        Mem:            3.9G        2.5G        658M        0.0K        770M        1.2G
        Swap:           974M        0.0K        974M
        Total:          4.9G        2.5G        1.6G
        Active iob-Instances:   26
                 3921 M total memory
                 2493 M used memory
                  422 M active memory
                 2624 M inactive memory
                  658 M free memory
                  164 M buffer memory
                  605 M swap cache
                  974 M total swap
                    0 M used swap
                  974 M free swap
        top - 17:17:51 up 18 min,  2 users,  load average: 0.35, 0.30, 0.34
        Tasks: 136 total,   1 running, 135 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3921.4 total,    657.8 free,   2493.0 used,    770.5 buff/cache
        MiB Swap:    975.0 total,    974.5 free,      0.5 used.   1189.9 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  1.9G     0  1.9G   0% /dev
        tmpfs          tmpfs     393M  868K  392M   1% /run
        /dev/sda1      ext4       31G   18G   12G  60% /
        tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     393M   52K  393M   1% /run/user/1000
        [Sun Nov  9 16:59:21 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
        [Sun Nov  9 16:59:22 2025] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
        Show mounted filesystems:
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        3.0G    /var/
        1.5G    /var/cache/apt/archives
        1.5G    /var/cache/apt
        1.5G    /var/cache
        1.3G    /var/log/journal/b10d7d2025ff4d469c4f8cc3d666e31e
        Archived and active journals take up 112.0M in the file system.
        /opt/iobroker/backups:
        338M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        748M    /opt/iobroker/iobroker-data/
        349M    /opt/iobroker/iobroker-data/files
        267M    /opt/iobroker/iobroker-data/backup-objects
        68M     /opt/iobroker/iobroker-data/files/vis-2
        47M     /opt/iobroker/iobroker-data/files/admin.admin
        36M     /opt/iobroker/iobroker-data/objects.jsonl
        21M     /opt/iobroker/iobroker-data/files/s7.admin/static/js/main.9f443724.js.map
        18M     /opt/iobroker/iobroker-data/objects.json.migrated
        18M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        12M     /opt/iobroker/iobroker-data/files/admin.0/zip/2024-06-29-scripts.zip
        USB-Devices by-id:
        No Devices found 'by-id'
        *** ZigBee Settings ***
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyUSB0
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v22.21.0
        /usr/bin/node           v22.21.0
        /usr/bin/npm            10.9.4
        /usr/bin/npx            10.9.4
        /usr/bin/corepack       0.34.0
        nodejs:
          Installed: 22.21.0-1nodesource1
          Candidate: 22.21.0-1nodesource1
          Version table:
         *** 22.21.0-1nodesource1 600
             22.20.0-1nodesource1 600
             22.19.0-1nodesource1 600
             22.18.0-1nodesource1 600
             22.17.1-1nodesource1 600
             22.17.0-1nodesource1 600
             22.16.0-1nodesource1 600
             22.15.1-1nodesource1 600
             22.15.0-1nodesource1 600
             22.14.0-1nodesource1 600
             22.13.1-1nodesource1 600
             22.13.0-1nodesource1 600
             22.12.0-1nodesource1 600
             22.11.0-1nodesource1 600
             22.10.0-1nodesource1 600
             22.9.0-1nodesource1 600
             22.8.0-1nodesource1 600
             22.7.0-1nodesource1 600
             22.6.0-1nodesource1 600
             22.5.1-1nodesource1 600
             22.5.0-1nodesource1 600
             22.4.1-1nodesource1 600
             22.4.0-1nodesource1 600
             22.3.0-1nodesource1 600
             22.2.0-1nodesource1 600
             22.1.0-1nodesource1 600
             22.0.0-1nodesource1 600
             12.22.12~dfsg-1~deb11u7 500
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        Media03             Media03 (version: 4.0.21, hostname: Media03       , alive, uptime: 1064)
        Media04             Media04 (version: 7.0.6, hostname: Media04       , alive, uptime: 2810)
        SmartHomeMira       SmartHomeMira (version: 7.0.6, hostname: SmartHomeMira , alive, uptime: 947)
        dns-server-2-emilia dns-server-2-emilia (version: 2.2.9, hostname: dns-server-2-emilia, dead, uptime: 3983)
        raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , dead, uptime: 84743)
        Core adapters versions
        js-controller:  7.0.6
        admin:          7.7.19
        javascript:     8.9.2
        nodejs modules from github:     0
        Adapter State
          system.adapter.accuweather.0            : accuweather           : SmartHomeMira                            - disabled
          system.adapter.adguard.0                : adguard               : SmartHomeMira                            - disabled
        + system.adapter.admin.0                  : admin                 : SmartHomeMira                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.admin.1                  : admin                 : SmartHomeMira                            -  enabled, port: 8089, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.alexa2.0                 : alexa2                : SmartHomeMira                            -  enabled
        + system.adapter.asuswrt.1                : asuswrt               : SmartHomeMira                            -  enabled
        + system.adapter.backitup.0               : backitup              : SmartHomeMira                            -  enabled
        + system.adapter.backitup.1               : backitup              : Media04                                  -  enabled
          system.adapter.cloud.0                  : cloud                 : SmartHomeMira                            - disabled
          system.adapter.daswetter.0              : daswetter             : SmartHomeMira                            -  enabled
          system.adapter.discovery.0              : discovery             : SmartHomeMira                            - disabled
        + system.adapter.ds18b20.0                : ds18b20               : Media04                                  -  enabled
          system.adapter.dwd.0                    : dwd                   : SmartHomeMira                            -  enabled
          system.adapter.email.0                  : email                 : SmartHomeMira                            - disabled
          system.adapter.energiefluss.0           : energiefluss          : SmartHomeMira                            - disabled
          system.adapter.feiertage.0              : feiertage             : SmartHomeMira                            -  enabled
        + system.adapter.hass.0                   : hass                  : SmartHomeMira                            -  enabled, port: 8123
          system.adapter.ical.0                   : ical                  : SmartHomeMira                            - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : SmartHomeMira                            -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : SmartHomeMira                            -  enabled
        + system.adapter.influxdb.0               : influxdb              : SmartHomeMira                            -  enabled, port: 8086
          system.adapter.iot.0                    : iot                   : SmartHomeMira                            - disabled
        + system.adapter.javascript.0             : javascript            : SmartHomeMira                            -  enabled
        + system.adapter.javascript.1             : javascript            : Media04                                  -  enabled
        + system.adapter.javascript.2             : javascript            : SmartHomeMira                            -  enabled
        + system.adapter.linux-control.0          : linux-control         : SmartHomeMira                            -  enabled
          system.adapter.mobile.0                 : mobile                : SmartHomeMira                            -  enabled
        + system.adapter.mqtt-client.0            : mqtt-client           : SmartHomeMira                            -  enabled, port: 8883
          system.adapter.mqtt.1                   : mqtt                  : SmartHomeMira                            - disabled, port: 8883, bind: 0.0.0.0
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : SmartHomeMira                            - disabled
          system.adapter.nina.0                   : nina                  : SmartHomeMira                            - disabled
        + system.adapter.node-red.0               : node-red              : SmartHomeMira                            -  enabled, port: 1880, bind: 0.0.0.0
          system.adapter.node-red.1               : node-red              : SmartHomeMira                            - disabled, port: 1881, bind: 0.0.0.0
        + system.adapter.ping.0                   : ping                  : SmartHomeMira                            -  enabled
          system.adapter.radar2.0                 : radar2                : Media04                                  - disabled
          system.adapter.rpi2.0                   : rpi2                  : Media03                                  -  enabled
          system.adapter.rpi2.3                   : rpi2                  : dns-server-2-emilia                      -  enabled
        + system.adapter.rpi2.4                   : rpi2                  : Media04                                  -  enabled
          system.adapter.s7.0                     : s7                    : SmartHomeMira                            -  enabled
          system.adapter.s7.1                     : s7                    : SmartHomeMira                            -  enabled
        + system.adapter.sonoff.0                 : sonoff                : SmartHomeMira                            -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : SmartHomeMira                            -  enabled
        + system.adapter.telegram.0               : telegram              : SmartHomeMira                            -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.vis-2.0                  : vis-2                 : SmartHomeMira                            -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : SmartHomeMira                            -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : SmartHomeMira                            -  enabled
          system.adapter.vis-history.0            : vis-history           : SmartHomeMira                            -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : SmartHomeMira                            -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : SmartHomeMira                            -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : SmartHomeMira                            -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : SmartHomeMira                            -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : SmartHomeMira                            -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : SmartHomeMira                            -  enabled
          system.adapter.vis-metro.0              : vis-metro             : SmartHomeMira                            -  enabled
          system.adapter.vis-players.0            : vis-players           : SmartHomeMira                            -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : SmartHomeMira                            -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : SmartHomeMira                            -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : SmartHomeMira                            -  enabled
          system.adapter.vis.0                    : vis                   : SmartHomeMira                            -  enabled
          system.adapter.volumio.0                : volumio               : SmartHomeMira                            - disabled
        + system.adapter.web.0                    : web                   : SmartHomeMira                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.web.1                    : web                   : SmartHomeMira                            - disabled, port: 8090, bind: 0.0.0.0 (SSL), run as: benutzer
        + system.adapter.wled.0                   : wled                  : SmartHomeMira                            -  enabled
          system.adapter.yr.0                     : yr                    : SmartHomeMira                            - disabled
        + system.adapter.zigbee.0                 : zigbee                : Media04                                  -  enabled, port: /dev/ttyUSB0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "accuweather"  : 2.1.1    , installed 2.1.1
        Adapter    "adguard"      : 1.0.1    , installed 1.0.1
        Adapter    "admin"        : 7.7.19   , installed 7.7.19
        Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
        Adapter    "asuswrt"      : 1.0.1    , installed 1.0.1
        Adapter    "backitup"     : 3.3.10   , installed 3.3.5  [Updatable]
        Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
        Adapter    "email"        : 2.0.4    , installed 2.0.4
        Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
        Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
        Adapter    "hass"         : 1.4.0    , installed 1.4.0
        Adapter    "ical"         : 1.17.0   , installed 1.17.0
        Adapter    "iot"          : 5.0.7    , installed 3.3.0  [Updatable]
        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
        Controller "js-controller": 7.0.7    , installed 7.0.6  [Updatable]
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "mqtt"         : 6.1.4    , installed 6.1.2  [Updatable]
        Adapter    "mqtt-client"  : 3.0.0    , installed 2.1.0  [Updatable]
        Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "node-red"     : 5.2.1    , installed 6.0.7
        Adapter    "radar2"       : 2.4.0    , installed 2.4.0
        Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
        Adapter    "s7"           : 1.5.0    , installed 1.4.3  [Updatable]
        Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
        Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
        Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "volumio"      : 0.2.0    , installed 0.2.0
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Adapter    "wled"         : 0.7.2    , installed 0.7.2
        Adapter    "yr"           : 5.3.0    , installed 5.3.0
        Objects and States
        Objects:        16950
        States:         16323
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          47735      7649/sshd: /usr/sbi
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       27158      4123/node-red
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       28978      4620/io.sonoff.0
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       25435      3885/iobroker.js-co
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       25430      3885/iobroker.js-co
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1440       1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          47737      7649/sshd: /usr/sbi
        tcp6       0      0 :::8089                 :::*                    LISTEN      1001       25539      3907/io.admin.1
        tcp6       0      0 :::111                  :::*                    LISTEN      0          1444       1/init
        tcp6       0      0 :::80                   :::*                    LISTEN      1001       27160      4123/node-red
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26700      3952/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28568      5005/io.web.0
        udp        0      0 192.168.1.10:1900       0.0.0.0:*                           1001       27161      4123/node-red
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1441       1/init
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       31220      5643/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           109        13062      347/avahi-daemon: r
        udp        0      0 0.0.0.0:42322           0.0.0.0:*                           109        13064      347/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          1447       1/init
        udp6       0      0 fe80::a8d9:8dff:fee:546 :::*                                0          13868      361/NetworkManager
        udp6       0      0 :::5353                 :::*                                109        13063      347/avahi-daemon: r
        udp6       0      0 :::55042                :::*                                109        13065      347/avahi-daemon: r
        2025-11-09 17:08:54.031  - info: linux-control.0 (5431) getting data from AIDA_Luna (192.168.1.47:22)
        2025-11-09 17:08:57.005  - info: linux-control.0 (5431) [getConnection] Host 'Media03_WZ_Radio' (192.168.1.33:22) seems not to be online
        2025-11-09 17:08:57.100  - info: linux-control.0 (5431) [getConnection] Host 'AIDA_Luna' (192.168.1.47:22) seems not to be online
        2025-11-09 17:09:19.662  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_DBs_in_virtuelle: BWM neu: Bewegung erkannt
        2025-11-09 17:09:19.665  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_weißer_Ring_Ein__Aus_(Test): Ring weiß Aus (timeout stop)
        2025-11-09 17:09:52.797  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_DBs_in_virtuelle: BWM neu: Bewegung nicht mehr
        2025-11-09 17:10:27.007  - info: host.SmartHomeMira instance system.adapter.daswetter.0 in version "3.2.3" started with pid 6745
        2025-11-09 17:10:27.540  - info: daswetter.0 (6745) Sets unsupported
        2025-11-09 17:10:27.801  - info: daswetter.0 (6745) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v22.21.0, js-controller: 7.0.6
        2025-11-09 17:10:30.128  - info: daswetter.0 (6745) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2025-11-09 17:10:30.633  - info: daswetter.0 (6745) cleaned everything up...
        2025-11-09 17:10:30.642  - info: host.SmartHomeMira instance system.adapter.daswetter.0 having pid 6745 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-11-09 17:13:22.953  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_DBs_in_virtuelle: BWM neu: Bewegung erkannt
        2025-11-09 17:13:22.956  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_weißer_Ring_Ein__Aus_(Test): Ring weiß Aus (timeout stop)
        2025-11-09 17:13:57.010  - info: linux-control.0 (5431) getting data from Media03_WZ_Radio (192.168.1.33:22)
        2025-11-09 17:13:57.106  - info: linux-control.0 (5431) getting data from AIDA_Luna (192.168.1.47:22)
        2025-11-09 17:13:57.751  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_DBs_in_virtuelle: BWM neu: Bewegung nicht mehr
        2025-11-09 17:14:00.076  - info: linux-control.0 (5431) [getConnection] Host 'Media03_WZ_Radio' (192.168.1.33:22) seems not to be online
        2025-11-09 17:14:00.172  - info: linux-control.0 (5431) [getConnection] Host 'AIDA_Luna' (192.168.1.47:22) seems not to be online
        2025-11-09 17:15:27.009  - info: host.SmartHomeMira instance system.adapter.daswetter.0 in version "3.2.3" started with pid 7247
        2025-11-09 17:15:27.535  - info: daswetter.0 (7247) Sets unsupported
        2025-11-09 17:15:27.818  - info: daswetter.0 (7247) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v22.21.0, js-controller: 7.0.6
        2025-11-09 17:15:30.163  - info: daswetter.0 (7247) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2025-11-09 17:15:30.668  - info: daswetter.0 (7247) cleaned everything up...
        2025-11-09 17:15:30.677  - info: host.SmartHomeMira instance system.adapter.daswetter.0 having pid 7247 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        iob diag has finished.
        mira@SmartHomeMira:~$
        Ro75R Thomas BraunT 2 Antworten Letzte Antwort
        • Basti97B Basti97
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
                     Chassis: vm
              Virtualization: kvm
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 2
                        NTP service: active
                    RTC in local TZ: no
          mira
          HOME=/home/mira
          iobroker
          HOME=/home/iobroker
          Desktop:
          Session:                tty
          *** MEMORY ***
                   3921 M total memory
                   2493 M used memory
                    422 M active memory
                    658 M free memory
                    164 M buffer memory
                    605 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          *** FILESYSTEM ***
          /var:
          3.0G    /var/
          1.5G    /var/cache/apt
          1.5G    /var/cache
          USB-Devices by-id:
          HINT:
          /dev/ttyUSB0
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.19
          javascript:     8.9.2
          Adapter State
          + instance is alive
          Objects and States
          Objects:        16950
          States:         16323
          Pending Updates: 0
          Ro75R Offline
          Ro75R Offline
          Ro75
          @basti97 sagte in s7 Adapter funktioniert nicht mehr noch node update:
          Doch richtig gelesen - uralt.
          Ro75.
          Basti97B 1 Antwort Letzte Antwort
            @basti97
            Ausgabe von
            iob diag
            mal posten.
            Basti97B Offline
            Basti97B Offline
            Basti97
            mira@SmartHomeMira:~$ ========== Start marking the full check here ===========
            ```bash
            Script v.2025-08-09
            *** BASE SYSTEM ***
                       Chassis: vm
                Virtualization: kvm
            OS is similar to:
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
            mira@SmartHomeMira:~$.l here for C&P =============DAPTER_REQUESTED_TERMINATIO
            • Ro75R Ro75
              Ro75.
              Basti97B Offline
              Basti97B Offline
              Basti97
              @ro75 Naja aber bevor ich nodejs aktualisiert habe hat es auch funktoniert und es betrifft ja nur den S7 Adapter zwei mal
              • Basti97B Basti97
                ```bash
                Script v.2025-08-09
                *** BASE SYSTEM ***
                           Chassis: vm
                    Virtualization: kvm
                OS is similar to:
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                CPU threads: 2
                              NTP service: active
                          RTC in local TZ: no
                mira
                HOME=/home/mira
                iobroker
                HOME=/home/iobroker
                Desktop:
                Session:                tty
                *** MEMORY ***
                         3921 M total memory
                         2493 M used memory
                          422 M active memory
                          658 M free memory
                          164 M buffer memory
                          605 M swap cache
                          974 M total swap
                            0 M used swap
                          974 M free swap
                *** FILESYSTEM ***
                /var:
                3.0G    /var/
                1.5G    /var/cache/apt
                1.5G    /var/cache
                USB-Devices by-id:
                HINT:
                /dev/ttyUSB0
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm            10.9.4
                /usr/bin/npx            10.9.4
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          7.7.19
                javascript:     8.9.2
                Adapter State
                + instance is alive
                Objects and States
                Objects:        16950
                States:         16323
                Pending Updates: 0
                Da war es ja auch gegen nodejs@20 gebaut...
                Jedenfalls ist
                zu alt. Installier da Debian 13 'Trixie'
                  Jedenfalls ist
                  Basti97B Offline
                  Basti97B Offline
                  Basti97
                  @thomas-braun Ok werde ich machen da installiere ich Linux komplett neu. Aber warum ensteht der Fehler nur bei den S7 Adapter und nicht bei allen Adaptern.
                  • Basti97B Basti97
                    Dann aber diesmal gleich ohne Desktop.
                    Das ist kein 'Fehler'. Du brauchst nur ein aktuelles System.
                    Und andere Adapter haben keine Bestandteile, die kompiliert werden müssen. Deswegen funktionieren die auch mit einer anderen ABI.
                      Basti97B Offline
                      Basti97B Offline
                      Basti97
                      @thomas-braun Achso ich hatte das ganze immer mit dem Desktop gemacht aber eigentlich braucht man ihn ja wirklich nicht da er ja auch zusätzliche Ressourcen verbraucht.
                      • Basti97B Basti97
                        @basti97
                        Unter anderem auch das...
                          @basti97
                          Basti97B Offline
                          Basti97B Offline
                          Basti97
                          @thomas-braun Gibt es noch mehr Vorteile ohne Desktop? Das muss ich ja bei der Installation den Haken bei Desktop rausmachen richtig?
                          • Basti97B Basti97
                            @basti97
                            Du schleppst weniger Sicherheitslücken an (nicht laufender Code kann nicht angegriffen werden),
                            das Ding läuft stabiler (nicht laufender Code kann nicht abstürzen),
                            das System ist einfacher zu warten (nicht installierte Pakete machen die Abhängigkeiten übersichtlicher),
                            Versionsupgrades sind einfacher, weil man weniger Dinge berücksichtigen muss.
                            Usw...
                              @basti97
                              Usw...
                              Basti97B Offline
                              Basti97B Offline
                              Basti97
                              @thomas-braun Super vielen Dank da werde ich das ganze in den nächsten Tagen nochmal alles komplett neu installieren und das Iobroker Backup zurück spielen. Für jetzt habe ich erstmal das Snapshot bevor ich angefangen habe zurück gespielt damit derS7 Adapter erstmal wieder läuft.
                              Vielen Dank für deine schnelle und ausführliche Hilfe.
                              Ich wünsche dir noch einen schönen Sonntag
                              • Basti97B Basti97
                                Warum nicht einfach nur nodejs@20 wieder installiert?
                                iob nodejs-update 20
                                und du wärst da gewesen.
                                  Basti97B Offline
                                  Basti97B Offline
                                  Basti97
                                  @thomas-braun joa das wäre eigentlich auch eine Möglichkeit aber ist es nicht theoretisch besser wenn dann das Linux neuzumachen. Dann hätte ich erstmal ruhe und ein bisschen Datenmüll weniger von Linux
                                  • Basti97B Basti97
                                    @basti97
                                    Dein OS musst du so oder so auf Stand bringen. Ob du dich über zwei Distributions-Upgrades quälst oder gleich alles 'neumachst' ist mir egal.
                                    Ich wollte auch nur darauf hinweisen, das man wegen einem Downgrade von nodejs nicht umständlich ein Snapshot wieder reinrollt. Geht mit dem obigen Befehl meiner Meinung nach viel eleganter.
                                      @basti97
                                      Basti97B Offline
                                      Basti97B Offline
                                      Basti97
                                      @thomas-braun Achso das wusste ich nicht aber danke
                                        @basti97
                                        Basti97B Offline
                                        Basti97B Offline
                                        Basti97
                                        ich habe das jetzt mal neuinstalliert aber warum möchte iobroker sudo berechtigung bei der Installation haben.
                                        mira@SmartHomeMira:~$ curl -sLf https://iobroker.net/install.sh | bash -
                                        Your system is booting into 'graphical.target', which means that a user interface or desktop is available. Usually a server is running without a desktop for security reasons and to save RAM. Please run 'iob fix' after the installation to change this.
                                        library: loaded
                                        Library version=2025-08-09
                                            Welcome to the ioBroker installer!
                                            Installer version: 2025-02-02
                                            You might need to enter your password a couple of times.
                                            Installing prerequisites (1/4)
                                        [sudo] Passwort für mira:
                                        OK:1 https://deb.nodesource.com/node_22.x nodistro InRelease
                                        OK:2 http://deb.debian.org/debian trixie InRelease
                                        OK:3 http://security.debian.org/debian-security trixie-security InRelease
                                        Holen:4 http://deb.debian.org/debian trixie-updates InRelease [47,3 kB]
                                        Es wurden 47,3 kB in 1 s geholt (38,7 kB/s).
                                        W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                                            Creating ioBroker user and directory (2/4)
                                        Directory /opt/iobroker created
                                            Installing ioBroker (3/4)
                                            Finalizing installation (4/4)
                                        Enabling autostart...
                                        Autostart enabled!
                                            ioBroker was installed successfully
                                            Open http://192.168.1.70:8081 in a browser and start configuring!
                                        You need to re-login before doing anything else on the console!
                                            Please run 'iob fix' after the required re-login to fix some common issues.
                                        mira@SmartHomeMira:~$ iob fix
                                        bash: /home/iobroker/.fix.sh: Keine Berechtigung
                                        mira@SmartHomeMira:~$ iobroker fix
                                        mira@SmartHomeMira:~$ su iob fix
                                        su: user iob does not exist or the user entry does not contain all the required fields
                                        mira@SmartHomeMira:~$ su- iob fix
                                        -bash: su-: Kommando nicht gefunden.
                                        mira@SmartHomeMira:~$ su - iob fix
                                        • Basti97B Basti97
                                          library: loaded
                                          Autostart enabled!
                                          Weil z. B. der iobroker.service nur mit root-Rechten angelegt werden kann.
                                          Und auch Pakete nur vom root installiert werden können.
