  4. s7 Adapter funktioniert nicht mehr noch node update
    6.5k
60 Beiträge 7 Kommentatoren 4.2k Aufrufe 4 Beobachtet
  • Basti97B Basti97
    @thomas-braun Das komische bevor ich nodejs von 20.x..x auf 22.x.x aktualisiert habe hat es funktoniert. Und es betrifft nur die beiden S7 Adapter.
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 11 (bullseye)
       Static hostname: SmartHomeMira
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
                Kernel: Linux 5.10.0-35-amd64
          Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     17:17:50 up 18 min,  2 users,  load average: 0.35, 0.30, 0.34
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-11-09 17:17:51 CET
               Universal time: Sun 2025-11-09 16:17:51 UTC
                     RTC time: Sun 2025-11-09 16:17:52
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    mira
    HOME=/home/mira
    GROUPS=mira cdrom floppy sudo audio dip video plugdev netdev bluetooth scanner iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev bluetooth
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Display-Manager:        * gdm3.service - LSB: GNOME Display Manager
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            3.9G        2.5G        658M        0.0K        770M        1.2G
    Swap:           974M        0.0K        974M
    Total:          4.9G        2.5G        1.6G
    Active iob-Instances:   26
             3921 M total memory
             2493 M used memory
              422 M active memory
             2624 M inactive memory
              658 M free memory
              164 M buffer memory
              605 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    top - 17:17:51 up 18 min,  2 users,  load average: 0.35, 0.30, 0.34
    Tasks: 136 total,   1 running, 135 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3921.4 total,    657.8 free,   2493.0 used,    770.5 buff/cache
    MiB Swap:    975.0 total,    974.5 free,      0.5 used.   1189.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.9G     0  1.9G   0% /dev
    tmpfs          tmpfs     393M  868K  392M   1% /run
    /dev/sda1      ext4       31G   18G   12G  60% /
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     393M   52K  393M   1% /run/user/1000
    [Sun Nov  9 16:59:21 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Nov  9 16:59:22 2025] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    3.0G    /var/
    1.5G    /var/cache/apt/archives
    1.5G    /var/cache/apt
    1.5G    /var/cache
    1.3G    /var/log/journal/b10d7d2025ff4d469c4f8cc3d666e31e
    Archived and active journals take up 112.0M in the file system.
    /opt/iobroker/backups:
    338M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    748M    /opt/iobroker/iobroker-data/
    349M    /opt/iobroker/iobroker-data/files
    267M    /opt/iobroker/iobroker-data/backup-objects
    68M     /opt/iobroker/iobroker-data/files/vis-2
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    36M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/s7.admin/static/js/main.9f443724.js.map
    18M     /opt/iobroker/iobroker-data/objects.json.migrated
    18M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    12M     /opt/iobroker/iobroker-data/files/admin.0/zip/2024-06-29-scripts.zip
    USB-Devices by-id:
    No Devices found 'by-id'
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 600
         22.20.0-1nodesource1 600
         22.19.0-1nodesource1 600
         22.18.0-1nodesource1 600
         22.17.1-1nodesource1 600
         22.17.0-1nodesource1 600
         22.16.0-1nodesource1 600
         22.15.1-1nodesource1 600
         22.15.0-1nodesource1 600
         22.14.0-1nodesource1 600
         22.13.1-1nodesource1 600
         22.13.0-1nodesource1 600
         22.12.0-1nodesource1 600
         22.11.0-1nodesource1 600
         22.10.0-1nodesource1 600
         22.9.0-1nodesource1 600
         22.8.0-1nodesource1 600
         22.7.0-1nodesource1 600
         22.6.0-1nodesource1 600
         22.5.1-1nodesource1 600
         22.5.0-1nodesource1 600
         22.4.1-1nodesource1 600
         22.4.0-1nodesource1 600
         22.3.0-1nodesource1 600
         22.2.0-1nodesource1 600
         22.1.0-1nodesource1 600
         22.0.0-1nodesource1 600
         12.22.12~dfsg-1~deb11u7 500
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    Media03             Media03 (version: 4.0.21, hostname: Media03       , alive, uptime: 1064)
    Media04             Media04 (version: 7.0.6, hostname: Media04       , alive, uptime: 2810)
    SmartHomeMira       SmartHomeMira (version: 7.0.6, hostname: SmartHomeMira , alive, uptime: 947)
    dns-server-2-emilia dns-server-2-emilia (version: 2.2.9, hostname: dns-server-2-emilia, dead, uptime: 3983)
    raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , dead, uptime: 84743)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.7.19
    javascript:     8.9.2
    nodejs modules from github:     0
    Adapter State
      system.adapter.accuweather.0            : accuweather           : SmartHomeMira                            - disabled
      system.adapter.adguard.0                : adguard               : SmartHomeMira                            - disabled
    + system.adapter.admin.0                  : admin                 : SmartHomeMira                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.admin.1                  : admin                 : SmartHomeMira                            -  enabled, port: 8089, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : SmartHomeMira                            -  enabled
    + system.adapter.asuswrt.1                : asuswrt               : SmartHomeMira                            -  enabled
    + system.adapter.backitup.0               : backitup              : SmartHomeMira                            -  enabled
    + system.adapter.backitup.1               : backitup              : Media04                                  -  enabled
      system.adapter.cloud.0                  : cloud                 : SmartHomeMira                            - disabled
      system.adapter.daswetter.0              : daswetter             : SmartHomeMira                            -  enabled
      system.adapter.discovery.0              : discovery             : SmartHomeMira                            - disabled
    + system.adapter.ds18b20.0                : ds18b20               : Media04                                  -  enabled
      system.adapter.dwd.0                    : dwd                   : SmartHomeMira                            -  enabled
      system.adapter.email.0                  : email                 : SmartHomeMira                            - disabled
      system.adapter.energiefluss.0           : energiefluss          : SmartHomeMira                            - disabled
      system.adapter.feiertage.0              : feiertage             : SmartHomeMira                            -  enabled
    + system.adapter.hass.0                   : hass                  : SmartHomeMira                            -  enabled, port: 8123
      system.adapter.ical.0                   : ical                  : SmartHomeMira                            - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : SmartHomeMira                            -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : SmartHomeMira                            -  enabled
    + system.adapter.influxdb.0               : influxdb              : SmartHomeMira                            -  enabled, port: 8086
      system.adapter.iot.0                    : iot                   : SmartHomeMira                            - disabled
    + system.adapter.javascript.0             : javascript            : SmartHomeMira                            -  enabled
    + system.adapter.javascript.1             : javascript            : Media04                                  -  enabled
    + system.adapter.javascript.2             : javascript            : SmartHomeMira                            -  enabled
    + system.adapter.linux-control.0          : linux-control         : SmartHomeMira                            -  enabled
      system.adapter.mobile.0                 : mobile                : SmartHomeMira                            -  enabled
    + system.adapter.mqtt-client.0            : mqtt-client           : SmartHomeMira                            -  enabled, port: 8883
      system.adapter.mqtt.1                   : mqtt                  : SmartHomeMira                            - disabled, port: 8883, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : SmartHomeMira                            - disabled
      system.adapter.nina.0                   : nina                  : SmartHomeMira                            - disabled
    + system.adapter.node-red.0               : node-red              : SmartHomeMira                            -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.node-red.1               : node-red              : SmartHomeMira                            - disabled, port: 1881, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : SmartHomeMira                            -  enabled
      system.adapter.radar2.0                 : radar2                : Media04                                  - disabled
      system.adapter.rpi2.0                   : rpi2                  : Media03                                  -  enabled
      system.adapter.rpi2.3                   : rpi2                  : dns-server-2-emilia                      -  enabled
    + system.adapter.rpi2.4                   : rpi2                  : Media04                                  -  enabled
      system.adapter.s7.0                     : s7                    : SmartHomeMira                            -  enabled
      system.adapter.s7.1                     : s7                    : SmartHomeMira                            -  enabled
    + system.adapter.sonoff.0                 : sonoff                : SmartHomeMira                            -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : SmartHomeMira                            -  enabled
    + system.adapter.telegram.0               : telegram              : SmartHomeMira                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.vis-2.0                  : vis-2                 : SmartHomeMira                            -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : SmartHomeMira                            -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : SmartHomeMira                            -  enabled
      system.adapter.vis-history.0            : vis-history           : SmartHomeMira                            -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : SmartHomeMira                            -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : SmartHomeMira                            -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : SmartHomeMira                            -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : SmartHomeMira                            -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : SmartHomeMira                            -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : SmartHomeMira                            -  enabled
      system.adapter.vis-metro.0              : vis-metro             : SmartHomeMira                            -  enabled
      system.adapter.vis-players.0            : vis-players           : SmartHomeMira                            -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : SmartHomeMira                            -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : SmartHomeMira                            -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : SmartHomeMira                            -  enabled
      system.adapter.vis.0                    : vis                   : SmartHomeMira                            -  enabled
      system.adapter.volumio.0                : volumio               : SmartHomeMira                            - disabled
    + system.adapter.web.0                    : web                   : SmartHomeMira                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.web.1                    : web                   : SmartHomeMira                            - disabled, port: 8090, bind: 0.0.0.0 (SSL), run as: benutzer
    + system.adapter.wled.0                   : wled                  : SmartHomeMira                            -  enabled
      system.adapter.yr.0                     : yr                    : SmartHomeMira                            - disabled
    + system.adapter.zigbee.0                 : zigbee                : Media04                                  -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "accuweather"  : 2.1.1    , installed 2.1.1
    Adapter    "adguard"      : 1.0.1    , installed 1.0.1
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "asuswrt"      : 1.0.1    , installed 1.0.1
    Adapter    "backitup"     : 3.3.10   , installed 3.3.5  [Updatable]
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "ical"         : 1.17.0   , installed 1.17.0
    Adapter    "iot"          : 5.0.7    , installed 3.3.0  [Updatable]
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.6  [Updatable]
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.2  [Updatable]
    Adapter    "mqtt-client"  : 3.0.0    , installed 2.1.0  [Updatable]
    Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "node-red"     : 5.2.1    , installed 6.0.7
    Adapter    "radar2"       : 2.4.0    , installed 2.4.0
    Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
    Adapter    "s7"           : 1.5.0    , installed 1.4.3  [Updatable]
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "volumio"      : 0.2.0    , installed 0.2.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        16950
    States:         16323
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          47735      7649/sshd: /usr/sbi
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       27158      4123/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       28978      4620/io.sonoff.0
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       25435      3885/iobroker.js-co
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       25430      3885/iobroker.js-co
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1440       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          47737      7649/sshd: /usr/sbi
    tcp6       0      0 :::8089                 :::*                    LISTEN      1001       25539      3907/io.admin.1
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1444       1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      1001       27160      4123/node-red
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26700      3952/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28568      5005/io.web.0
    udp        0      0 192.168.1.10:1900       0.0.0.0:*                           1001       27161      4123/node-red
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1441       1/init
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       31220      5643/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           109        13062      347/avahi-daemon: r
    udp        0      0 0.0.0.0:42322           0.0.0.0:*                           109        13064      347/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          1447       1/init
    udp6       0      0 fe80::a8d9:8dff:fee:546 :::*                                0          13868      361/NetworkManager
    udp6       0      0 :::5353                 :::*                                109        13063      347/avahi-daemon: r
    udp6       0      0 :::55042                :::*                                109        13065      347/avahi-daemon: r
    2025-11-09 17:08:54.031  - info: linux-control.0 (5431) getting data from AIDA_Luna (192.168.1.47:22)
    2025-11-09 17:08:57.005  - info: linux-control.0 (5431) [getConnection] Host 'Media03_WZ_Radio' (192.168.1.33:22) seems not to be online
    2025-11-09 17:08:57.100  - info: linux-control.0 (5431) [getConnection] Host 'AIDA_Luna' (192.168.1.47:22) seems not to be online
    2025-11-09 17:09:19.662  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_DBs_in_virtuelle: BWM neu: Bewegung erkannt
    2025-11-09 17:09:19.665  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_weißer_Ring_Ein__Aus_(Test): Ring weiß Aus (timeout stop)
    2025-11-09 17:09:52.797  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_DBs_in_virtuelle: BWM neu: Bewegung nicht mehr
    2025-11-09 17:10:27.007  - info: host.SmartHomeMira instance system.adapter.daswetter.0 in version "3.2.3" started with pid 6745
    2025-11-09 17:10:27.540  - info: daswetter.0 (6745) Sets unsupported
    2025-11-09 17:10:27.801  - info: daswetter.0 (6745) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v22.21.0, js-controller: 7.0.6
    2025-11-09 17:10:30.128  - info: daswetter.0 (6745) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-11-09 17:10:30.633  - info: daswetter.0 (6745) cleaned everything up...
    2025-11-09 17:10:30.642  - info: host.SmartHomeMira instance system.adapter.daswetter.0 having pid 6745 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-11-09 17:13:22.953  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_DBs_in_virtuelle: BWM neu: Bewegung erkannt
    2025-11-09 17:13:22.956  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_weißer_Ring_Ein__Aus_(Test): Ring weiß Aus (timeout stop)
    2025-11-09 17:13:57.010  - info: linux-control.0 (5431) getting data from Media03_WZ_Radio (192.168.1.33:22)
    2025-11-09 17:13:57.106  - info: linux-control.0 (5431) getting data from AIDA_Luna (192.168.1.47:22)
    2025-11-09 17:13:57.751  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_DBs_in_virtuelle: BWM neu: Bewegung nicht mehr
    2025-11-09 17:14:00.076  - info: linux-control.0 (5431) [getConnection] Host 'Media03_WZ_Radio' (192.168.1.33:22) seems not to be online
    2025-11-09 17:14:00.172  - info: linux-control.0 (5431) [getConnection] Host 'AIDA_Luna' (192.168.1.47:22) seems not to be online
    2025-11-09 17:15:27.009  - info: host.SmartHomeMira instance system.adapter.daswetter.0 in version "3.2.3" started with pid 7247
    2025-11-09 17:15:27.535  - info: daswetter.0 (7247) Sets unsupported
    2025-11-09 17:15:27.818  - info: daswetter.0 (7247) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v22.21.0, js-controller: 7.0.6
    2025-11-09 17:15:30.163  - info: daswetter.0 (7247) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-11-09 17:15:30.668  - info: daswetter.0 (7247) cleaned everything up...
    2025-11-09 17:15:30.677  - info: host.SmartHomeMira instance system.adapter.daswetter.0 having pid 7247 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    iob diag has finished.
    mira@SmartHomeMira:~$
    @basti97 sagte in s7 Adapter funktioniert nicht mehr noch node update:
    Da war es ja auch gegen nodejs@20 gebaut...
    Jedenfalls ist
    zu alt. Installier da Debian 13 'Trixie'
    Basti97B 1 Antwort Letzte Antwort
      Jedenfalls ist
      Basti97B Offline
      Basti97B Offline
      Basti97
      @thomas-braun Ok werde ich machen da installiere ich Linux komplett neu. Aber warum ensteht der Fehler nur bei den S7 Adapter und nicht bei allen Adaptern.
      Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
      • Basti97B Basti97
        Dann aber diesmal gleich ohne Desktop.
        Das ist kein 'Fehler'. Du brauchst nur ein aktuelles System.
        Und andere Adapter haben keine Bestandteile, die kompiliert werden müssen. Deswegen funktionieren die auch mit einer anderen ABI.
          Basti97B Offline
          Basti97B Offline
          Basti97
          @thomas-braun Achso ich hatte das ganze immer mit dem Desktop gemacht aber eigentlich braucht man ihn ja wirklich nicht da er ja auch zusätzliche Ressourcen verbraucht.
          • Basti97B Basti97
            @basti97
            Unter anderem auch das...
              @basti97
              Basti97B Offline
              Basti97B Offline
              Basti97
              @thomas-braun Gibt es noch mehr Vorteile ohne Desktop? Das muss ich ja bei der Installation den Haken bei Desktop rausmachen richtig?
              • Basti97B Basti97
                @basti97
                Du schleppst weniger Sicherheitslücken an (nicht laufender Code kann nicht angegriffen werden),
                das Ding läuft stabiler (nicht laufender Code kann nicht abstürzen),
                das System ist einfacher zu warten (nicht installierte Pakete machen die Abhängigkeiten übersichtlicher),
                Versionsupgrades sind einfacher, weil man weniger Dinge berücksichtigen muss.
                Usw...
                  @basti97
                  Usw...
                  Basti97B Offline
                  Basti97B Offline
                  Basti97
                  @thomas-braun Super vielen Dank da werde ich das ganze in den nächsten Tagen nochmal alles komplett neu installieren und das Iobroker Backup zurück spielen. Für jetzt habe ich erstmal das Snapshot bevor ich angefangen habe zurück gespielt damit derS7 Adapter erstmal wieder läuft.
                  Vielen Dank für deine schnelle und ausführliche Hilfe.
                  Ich wünsche dir noch einen schönen Sonntag
                  • Basti97B Basti97
                    Warum nicht einfach nur nodejs@20 wieder installiert?
                    iob nodejs-update 20
                    und du wärst da gewesen.
                      Basti97B Offline
                      Basti97B Offline
                      Basti97
                      @thomas-braun joa das wäre eigentlich auch eine Möglichkeit aber ist es nicht theoretisch besser wenn dann das Linux neuzumachen. Dann hätte ich erstmal ruhe und ein bisschen Datenmüll weniger von Linux
                      • Basti97B Basti97
                        @basti97
                        Dein OS musst du so oder so auf Stand bringen. Ob du dich über zwei Distributions-Upgrades quälst oder gleich alles 'neumachst' ist mir egal.
                        Ich wollte auch nur darauf hinweisen, das man wegen einem Downgrade von nodejs nicht umständlich ein Snapshot wieder reinrollt. Geht mit dem obigen Befehl meiner Meinung nach viel eleganter.
                        Basti97B 2 Antworten Letzte Antwort
                          @basti97
                          Basti97B Offline
                          Basti97B Offline
                          Basti97
                          @thomas-braun Achso das wusste ich nicht aber danke
                            @basti97
                            Basti97B Offline
                            Basti97B Offline
                            Basti97
                            ich habe das jetzt mal neuinstalliert aber warum möchte iobroker sudo berechtigung bei der Installation haben.
                            mira@SmartHomeMira:~$ curl -sLf https://iobroker.net/install.sh | bash -
                            Your system is booting into 'graphical.target', which means that a user interface or desktop is available. Usually a server is running without a desktop for security reasons and to save RAM. Please run 'iob fix' after the installation to change this.
                            library: loaded
                            Library version=2025-08-09
                                Welcome to the ioBroker installer!
                                Installer version: 2025-02-02
                                You might need to enter your password a couple of times.
                                Installing prerequisites (1/4)
                            [sudo] Passwort für mira:
                            OK:1 https://deb.nodesource.com/node_22.x nodistro InRelease
                            OK:2 http://deb.debian.org/debian trixie InRelease
                            OK:3 http://security.debian.org/debian-security trixie-security InRelease
                            Holen:4 http://deb.debian.org/debian trixie-updates InRelease [47,3 kB]
                            Es wurden 47,3 kB in 1 s geholt (38,7 kB/s).
                            W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                                Creating ioBroker user and directory (2/4)
                            Directory /opt/iobroker created
                                Installing ioBroker (3/4)
                                Finalizing installation (4/4)
                            Enabling autostart...
                            Autostart enabled!
                                ioBroker was installed successfully
                                Open http://192.168.1.70:8081 in a browser and start configuring!
                            You need to re-login before doing anything else on the console!
                                Please run 'iob fix' after the required re-login to fix some common issues.
                            mira@SmartHomeMira:~$ iob fix
                            bash: /home/iobroker/.fix.sh: Keine Berechtigung
                            mira@SmartHomeMira:~$ iobroker fix
                            mira@SmartHomeMira:~$ su iob fix
                            su: user iob does not exist or the user entry does not contain all the required fields
                            mira@SmartHomeMira:~$ su- iob fix
                            -bash: su-: Kommando nicht gefunden.
                            mira@SmartHomeMira:~$ su - iob fix
                            • Basti97B Basti97
                              library: loaded
                              Autostart enabled!
                              Weil z. B. der iobroker.service nur mit root-Rechten angelegt werden kann.
                              Und auch Pakete nur vom root installiert werden können.
                                Basti97B Offline
                                Basti97B Offline
                                Basti97
                                @thomas-braun also ist das richtig aber wiso klappt dann zb iob fix nicht
                                • Basti97B Basti97
                                  library: loaded
                                  Autostart enabled!
                                  Musst du machen, dann gehen auch die Meldungen wie
                                  weg.
                                    weg.
                                    Basti97B Offline
                                    Basti97B Offline
                                    Basti97
                                    @thomas-braun Super da habe ich falsch gelesen
                                    • Basti97B Basti97
                                      Weil du der Anleitung nicht folgst und mira nicht neueinloggst.
                                      Besser noch ist ein kompletter Reboot von der Kiste.
                                        Basti97B Offline
                                        Basti97B Offline
                                        Basti97
                                        @thomas-braun Das habe ich gerade gemacht. Die Installation ist jetzt echt einfach beim letzten mal musste man alles noch einzeln installieren.
                                        • Basti97B Basti97
                                          Dafür wird halt jetzt mehr installiert als ggfls. notwendig. Aber irgendwas ist halt immer, wenn du alle User irgendwo abholen willst.
