  4. s7 Adapter funktioniert nicht mehr noch node update
    6.5k
60 Beiträge 7 Kommentatoren 4.2k Aufrufe 4 Beobachtet
  • Basti97B Basti97
    Ich wollte mein Nodejs aktualisieren mit dem Befehl iob nodejs-update aber irgendwie funktioniert das bei diesen Adapter nicht alle anderen laufen nach dem update.
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[1]: Node.js v22.21.0
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: }
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1706:14) {
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: at require (node:internal/modules/helpers:147:16)
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:328:14)
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: at Object..node (node:internal/modules/cjs/loader:1865:18)
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: NODE_MODULE_VERSION 127. Please try re-compiling or re-installing
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: NODE_MODULE_VERSION 115. This version of Node.js requires
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: was compiled against a different Node.js version using
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node'
    host.SmartHomeMira
    2025-11-09 16:41:08.287 error Caught by controller[0]: ^
    host.SmartHomeMira
    2025-11-09 16:41:08.286 error Caught by controller[0]: throw e;
    host.SmartHomeMira
    2025-11-09 16:41:08.286 error Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
    host.SmartHomeMira
    2025-11-09 16:41:07.842 info instance system.adapter.s7.0 in version "1.4.3" started with pid 5406
    Ro75R Offline
    Ro75R Offline
    Ro75
    @basti97 wenn ich das aus vorherigen Posts richtig gesehen habe, ist dein OS uralt.
    Ro75.
    • Ro75R Ro75
      Ro75.
      @ro75 sagte in s7 Adapter funktioniert nicht mehr noch node update:
      Nee, die Postings sind uralt...
      Basti97B 1 Antwort Letzte Antwort
      • Basti97B Offline
        Basti97B Offline
        Basti97
        2025-11-09 17:04:20.278 - error: host.SmartHomeMira Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
        2025-11-09 17:04:20.278 - error: host.SmartHomeMira Caught by controller[0]: throw err;
        2025-11-09 17:04:20.278 - error: host.SmartHomeMira Caught by controller[0]: ^
        2025-11-09 17:04:20.278 - error: host.SmartHomeMira Caught by controller[0]: Error: Could not locate the bindings file. Tried:
        2025-11-09 17:04:20.278 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/node_snap7.node
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Release/node_snap7.node
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/compiled/22.21.0/linux/x64/node_snap7.node
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-x64/node_snap7.node
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at Object. (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1706:14)
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1839:10)
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:328:14)
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at require (node:internal/modules/helpers:147:16) {
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: tries: [
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/node_snap7.node',
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node',
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node',
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node',
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node',
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node',
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Release/node_snap7.node',
        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node',
        2025-11-09 17:04:20.280 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/compiled/22.21.0/linux/x64/node_snap7.node',
        2025-11-09 17:04:20.280 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node',
        2025-11-09 17:04:20.280 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node',
        2025-11-09 17:04:20.280 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node',
        2025-11-09 17:04:20.280 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-x64/node_snap7.node'
        2025-11-09 17:04:20.280 - error: host.SmartHomeMira Caught by controller[0]: ]
        2025-11-09 17:04:20.280 - error: host.SmartHomeMira Caught by controller[0]: }
        2025-11-09 17:04:20.280 - error: host.SmartHomeMira Caught by controller[1]: Node.js v22.21.0
        2025-11-09 17:04:20.280 - error: host.SmartHomeMira instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2025-11-09 17:04:20.280 - info: host.SmartHomeMira Rebuild for adapter system.adapter.s7.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: throw err;
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: ^
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: Error: Could not locate the bindings file. Tried:
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/node_snap7.node
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Release/node_snap7.node
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/compiled/22.21.0/linux/x64/node_snap7.node
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-x64/node_snap7.node
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at Object. (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1706:14)
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1839:10)
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:328:14)
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at require (node:internal/modules/helpers:147:16) {
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: tries: [
        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/node_snap7.node',
        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node',
        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node',
        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node',
        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node',
        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node',
        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Release/node_snap7.node',
        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node',
        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/compiled/22.21.0/linux/x64/node_snap7.node',
        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node',
        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node',
        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node',
        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-x64/node_snap7.node'
        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: ]
        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: }
        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: Node.js v22.21.0
        2025-11-09 17:04:20.345 - error: host.SmartHomeMira instance system.adapter.s7.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2025-11-09 17:04:20.345 - info: host.SmartHomeMira Rebuild for adapter system.adapter.s7.1 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production"
        Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
          Basti97B Offline
          Basti97B Offline
          Basti97
          @thomas-braun so hier wenn ich den Adapter lösche dann sind ja die Konfigurrationen auch weg. Denn in dem S7 Adapter kann man leider die konfigurrationen so nicht sichern wie bei den anderen
          host.SmartHomeMira
          2025-11-09 17:03:45.915 error Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
          host.SmartHomeMira
          2025-11-09 17:03:45.915 error Caught by controller[0]: throw err;
          host.SmartHomeMira
          2025-11-09 17:03:45.915 error Caught by controller[0]: ^
          host.SmartHomeMira
          2025-11-09 17:03:45.915 error Caught by controller[0]: Error: Could not locate the bindings file. Tried:
          host.SmartHomeMira
          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Release/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/compiled/22.21.0/linux/x64/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-x64/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1706:14)
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1839:10)
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:328:14)
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: at require (node:internal/modules/helpers:147:16) {
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: tries: [
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Release/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/compiled/22.21.0/linux/x64/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-x64/node_snap7.node'
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: ]
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: }
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error Caught by controller[0]: Node.js v22.21.0
          host.SmartHomeMira
          2025-11-09 17:03:45.916 error instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.SmartHomeMira
          2025-11-09 17:03:45.916 info Adapter system.adapter.s7.0 needs rebuild and will be restarted afterwards.
          host.SmartHomeMira
          2025-11-09 17:03:45.916 info system.adapter.s7.0 will be rebuilt
          host.SmartHomeMira
          2025-11-09 17:03:45.916 warn adapter "s7" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
          host.SmartHomeMira
          2025-11-09 17:03:45.917 info iobroker rebuild
          host.SmartHomeMira
          2025-11-09 17:03:45.976 error Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
          host.SmartHomeMira
          2025-11-09 17:03:45.976 error Caught by controller[0]: throw err;
          host.SmartHomeMira
          2025-11-09 17:03:45.976 error Caught by controller[0]: ^
          host.SmartHomeMira
          2025-11-09 17:03:45.976 error Caught by controller[0]: Error: Could not locate the bindings file. Tried:
          host.SmartHomeMira
          2025-11-09 17:03:45.976 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.976 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.976 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.976 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Release/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/compiled/22.21.0/linux/x64/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-x64/node_snap7.node
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1706:14)
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1839:10)
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:328:14)
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: at require (node:internal/modules/helpers:147:16) {
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: tries: [
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Release/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/compiled/22.21.0/linux/x64/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node',
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-x64/node_snap7.node'
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: ]
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: }
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error Caught by controller[0]: Node.js v22.21.0
          host.SmartHomeMira
          2025-11-09 17:03:45.977 error instance system.adapter.s7.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
          • Basti97B Basti97
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            host.SmartHomeMira
            @basti97
            Setz das in CodeTags.
            Basti97B 2 Antworten Letzte Antwort
              @basti97
              Basti97B Offline
              Basti97B Offline
              Basti97
              @thomas-braun ok mache
              jetzt ist die Meldung noch gekommen
                @basti97
                Basti97B Offline
                Basti97B Offline
                Basti97
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                host.SmartHomeMira
                   2025-11-09 17:03:45.977	info	Adapter system.adapter.s7.1 needs rebuild and will be restarted afterwards.
                host.SmartHomeMira
                   2025-11-09 17:03:45.977	info	system.adapter.s7.1 will be rebuilt
                • Basti97B Basti97
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  host.SmartHomeMira
                  @basti97
                  Auf einem aktuellen System baut das Ding jedenfalls:
                  echad@chet:~ $ iobroker add s7 --debug
                  NPM version: 11.6.1
                  Installing iobroker.s7@1.5.0... (System call)
                  > node-snap7@1.0.9 install
                  > prebuild-install || node-gyp rebuild
                  (node:231268) [DEP0176] DeprecationWarning: fs.R_OK is deprecated, use fs.constants.R_OK instead
                  (Use `node --trace-deprecation ...` to show where the warning was created)
                  prebuild-install warn install No prebuilt binaries found (target=24.11.0 runtime=node arch=arm64 libc= platform=linux)
                  gyp info it worked if it ends with ok
                  gyp info using node-gyp@11.4.2
                  gyp info using node@24.11.0 | linux | arm64
                  gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
                  gyp http GET https://s3-us-west-2.amazonaws.com/nodesource-public-downloads/24.11.0-ns6.0.2/artifacts/headers/krypton/v6.0.2/nsolid-v6.0.2-headers.tar.gz
                  gyp http 200 https://s3-us-west-2.amazonaws.com/nodesource-public-downloads/24.11.0-ns6.0.2/artifacts/headers/krypton/v6.0.2/nsolid-v6.0.2-headers.tar.gz
                  gyp http GET https://s3-us-west-2.amazonaws.com/nodesource-public-downloads/24.11.0-ns6.0.2/artifacts/headers/krypton/v6.0.2/SHASUMS256.txt
                  gyp http 200 https://s3-us-west-2.amazonaws.com/nodesource-public-downloads/24.11.0-ns6.0.2/artifacts/headers/krypton/v6.0.2/SHASUMS256.txt
                  gyp info spawn /usr/bin/python3
                  gyp info spawn args [
                  gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
                  gyp info spawn args 'binding.gyp',
                  gyp info spawn args '-f',
                  gyp info spawn args 'make',
                  gyp info spawn args '-I',
                  gyp info spawn args '/opt/iobroker/node_modules/node-snap7/build/config.gypi',
                  gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
                  gyp info spawn args '/home/iobroker/.cache/node-gyp/24.11.0/include/node/common.gypi',
                  gyp info spawn args '-Dlibrary=shared_library',
                  gyp info spawn args '-Dvisibility=default',
                  gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/24.11.0',
                  gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
                  gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/24.11.0/<(target_arch)/node.lib',
                  gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-snap7',
                  gyp info spawn args '-Dnode_engine=v8',
                  gyp info spawn args '--depth=.',
                  gyp info spawn args '--no-parallel',
                  gyp info spawn args '--generator-output',
                  gyp info spawn args 'build',
                  gyp info spawn args '-Goutput_dir=.'
                  gyp info spawn args ]
                  gyp info spawn make
                  gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
                  make: Entering directory '/opt/iobroker/node_modules/node-snap7/build'
                    CXX(target) Release/obj.target/snap7/deps/snap7/src/sys/snap_msgsock.o
                    CXX(target) Release/obj.target/snap7/deps/snap7/src/sys/snap_sysutils.o
                    CXX(target) Release/obj.target/snap7/deps/snap7/src/sys/snap_tcpsrvr.o
                  ../deps/snap7/src/sys/snap_tcpsrvr.cpp: In member function ‘int TCustomMsgServer::StartTo(const char*, word)’:
                  ../deps/snap7/src/sys/snap_tcpsrvr.cpp:429:12: warning: ‘char* strncpy(char*, const char*, size_t)’ specified bound 16 equals destination size [-Wstringop-truncation]
                    429 |     strncpy(FLocalAddress, Address, 16);
                    CXX(target) Release/obj.target/snap7/deps/snap7/src/sys/snap_threads.o
                    CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_client.o
                    CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_isotcp.o
                  ../deps/snap7/src/core/s7_isotcp.cpp: In member function ‘int TIsoTcpSocket::IsoConfirmConnection(u_char)’:
                  ../deps/snap7/src/core/s7_isotcp.cpp:163:17: warning: variable ‘TempRef’ set but not used [-Wunused-but-set-variable]
                    163 |         u_short TempRef;
                    CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_partner.o
                  ../deps/snap7/src/core/s7_partner.cpp: In member function ‘int TConnectionServer::StartTo(const char*)’:
                  ../deps/snap7/src/core/s7_partner.cpp:252:12: warning: ‘char* strncpy(char*, const char*, size_t)’ specified bound 16 equals destination size [-Wstringop-truncation]
                    252 |     strncpy(FLocalAddress,Address,16);
                    CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_peer.o
                    CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_server.o
                  ../deps/snap7/src/core/s7_server.cpp: In member function ‘byte TS7Worker::WriteArea(PReqFunWriteDataItem, PReqFunWriteItem, TEv&)’:
                  ../deps/snap7/src/core/s7_server.cpp:626:5: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
                    626 |     if ((ReqItemPar->Area==S7AreaTM) ^ (ReqItemPar->TransportSize==S7WLTimer))
                  ../deps/snap7/src/core/s7_server.cpp:629:9: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
                    629 |         if ((ReqItemPar->Area==S7AreaCT) ^ (ReqItemPar->TransportSize==S7WLCounter))
                  ../deps/snap7/src/core/s7_server.cpp: In member function ‘void TS7Worker::SZLSystemState()’:
                  ../deps/snap7/src/core/s7_server.cpp:1247:11: warning: ‘void* memcpy(void*, const void*, size_t)’ forming offset [4, 5] is out of the bounds [0, 4] of object ‘SZLNotAvail’ with type ‘byte [4]’ {aka ‘unsigned char [4]’} [-Warray-bounds=]
                   1247 |     memcpy(SZL.ResData,&SZLNotAvail,sizeof(SZLSysState));
                  In file included from ../deps/snap7/src/core/s7_server.cpp:27:
                  ../deps/snap7/src/core/s7_firmware.h:36:8: note: ‘SZLNotAvail’ declared here
                     36 |   byte SZLNotAvail[4] = {
                  ../deps/snap7/src/core/s7_server.cpp: In member function ‘word TS7Worker::ReadArea(PResFunReadItem, PReqFunReadItem, int&, TEv&)’:
                  ../deps/snap7/src/core/s7_server.cpp:454:34: warning: ‘BitIndex’ may be used uninitialized [-Wmaybe-uninitialized]
                    454 |           if ((ByteVal & BitMask[BitIndex])!=0)
                  ../deps/snap7/src/core/s7_server.cpp:332:10: note: ‘BitIndex’ was declared here
                    332 |     byte BitIndex, ByteVal;
                  ../deps/snap7/src/core/s7_server.cpp:698:53: warning: ‘BitIndex’ may be used uninitialized [-Wmaybe-uninitialized]
                    698 |                           *Target=*Target | BitMask[BitIndex];
                  ../deps/snap7/src/core/s7_server.cpp:598:14: note: ‘BitIndex’ was declared here
                    598 |         byte BitIndex;
                    CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_text.o
                  ../deps/snap7/src/core/s7_text.cpp: In function ‘char* EvtSrvText(TSrvEvent&, char*, int)’:
                  ../deps/snap7/src/core/s7_text.cpp:782:5: warning: this ‘else’ clause does not guard... [-Wmisleading-indentation]
                    782 |     else
                  ../deps/snap7/src/core/s7_text.cpp:785:9: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘else’
                    785 |         strncpy(Result, S, TextLen);
                    CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_micro_client.o
                  ../deps/snap7/src/core/s7_micro_client.cpp: In member function ‘void TSnap7MicroClient::SetConnectionParams(const char*, word, word)’:
                  ../deps/snap7/src/core/s7_micro_client.cpp:2675:13: warning: ‘char* strncpy(char*, const char*, size_t)’ specified bound 16 equals destination size [-Wstringop-truncation]
                   2675 |      strncpy(RemoteAddress, RemAddress, 16);
                  ../deps/snap7/src/core/s7_micro_client.cpp: In member function ‘int TSnap7MicroClient::SetSessionPassword(char*)’:
                  ../deps/snap7/src/core/s7_micro_client.cpp:3306:16: warning: ‘char* strncpy(char*, const char*, size_t)’ output truncated before terminating nul copying as many bytes from a string as its length [-Wstringop-truncation]
                   3306 |         strncpy((char*)&opData,Password,L);
                  ../deps/snap7/src/core/s7_micro_client.cpp:3298:26: note: length computed here
                   3298 |         size_t L = strlen(Password);
                    CXX(target) Release/obj.target/snap7/deps/snap7/src/lib/snap7_libmain.o
                  rm -f Release/obj.target/snap7.a Release/obj.target/snap7.a.ar-file-list; mkdir -p `dirname Release/obj.target/snap7.a`
                  ar crs Release/obj.target/snap7.a @Release/obj.target/snap7.a.ar-file-list
                    COPY Release/snap7.a
                    CXX(target) Release/obj.target/node_snap7/src/node_snap7.o
                  In file included from ../src/node_snap7_client.h:11,
                                   from ../src/node_snap7.cpp:6:
                  ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
                  ../../nan/nan.h:1173:36: warning: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ is deprecated: Use WriteUtf8V2 instead. [-Wdeprecated-declarations]
                   1173 |         length_ = string->WriteUtf8(v8::Isolate::GetCurrent(), str_,
                   1174 |                                     static_cast<int>(len), 0, flags);
                  In file included from /home/iobroker/.cache/node-gyp/24.11.0/include/node/v8-object.h:12,
                                   from /home/iobroker/.cache/node-gyp/24.11.0/include/node/v8-array-buffer.h:14,
                                   from /home/iobroker/.cache/node-gyp/24.11.0/include/node/v8.h:24,
                                   from /home/iobroker/.cache/node-gyp/24.11.0/include/node/node.h:74,
                                   from ../src/node_snap7_client.h:10:
                  /home/iobroker/.cache/node-gyp/24.11.0/include/node/v8-primitive.h:212:7: note: declared here
                    212 |   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
                  ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::Encode(const void*, size_t, Encoding)’:
                  ../../nan/nan.h:2418:24: warning: ‘v8::Local<v8::Value> node::Encode(v8::Isolate*, const uint16_t*, size_t)’ is deprecated: Use TryEncode(...) instead [-Wdeprecated-declarations]
                   2418 |     return node::Encode(
                   2419 |         isolate
                   2420 |       , reinterpret_cast<const uint16_t *>(buf)
                   2421 |       , len / 2);
                  /home/iobroker/.cache/node-gyp/24.11.0/include/node/node.h:1189:50: note: declared here
                   1189 |                 NODE_EXTERN v8::Local<v8::Value> Encode(v8::Isolate* isolate,
                  /home/iobroker/.cache/node-gyp/24.11.0/include/node/node.h:117:42: note: in definition of macro ‘NODE_DEPRECATED’
                    117 |     __attribute__((deprecated(message))) declarator
                  ../../nan/nan.h:2423:24: warning: ‘v8::Local<v8::Value> node::Encode(v8::Isolate*, const char*, size_t, encoding)’ is deprecated: Use TryEncode(...) instead [-Wdeprecated-declarations]
                   2423 |     return node::Encode(
                   2424 |         isolate
                   2425 |       , reinterpret_cast<const char *>(buf)
                   2426 |       , len
                   2427 |       , node_enc);
                  /home/iobroker/.cache/node-gyp/24.11.0/include/node/node.h:1181:38: note: declared here
                   1181 |     NODE_EXTERN v8::Local<v8::Value> Encode(v8::Isolate* isolate,
                  ../src/node_snap7.cpp: At global scope:
                  /home/iobroker/.cache/node-gyp/24.11.0/include/node/node.h:1279:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                   1279 |       (node::addon_register_func) (regfunc),                          \
                  /home/iobroker/.cache/node-gyp/24.11.0/include/node/node.h:1313:3: note: in expansion of macro ‘NODE_MODULE_X’
                   1313 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                  ../src/node_snap7.cpp:16:1: note: in expansion of macro ‘NODE_MODULE’
                     16 | NODE_MODULE(node_snap7, InitAll)
                    CXX(target) Release/obj.target/node_snap7/src/node_snap7_client.o
                                   from ../src/node_snap7_client.cpp:6:
                   2419 |         isolate
                   2421 |       , len / 2);
                   2424 |         isolate
                   2426 |       , len
                   2427 |       , node_enc);
                  ../src/node_snap7_client.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_snap7::S7Client::ListBlocksOfType(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/node_snap7_client.cpp:1689:42: warning: expression does not compute the number of elements in this array; element type is ‘word’ {aka ‘short unsigned int’}, not ‘PS7BlocksOfType’ {aka ‘short unsigned int (*)[8192]’} [-Wsizeof-array-div]
                   1689 |   int BlockNum = sizeof(TS7BlocksOfType) / sizeof(PS7BlocksOfType);
                  ../src/node_snap7_client.cpp:1689:44: note: add parentheses around ‘sizeof (PS7BlocksOfType)’ to silence this warning
                    CXX(target) Release/obj.target/node_snap7/src/node_snap7_server.o
                  In file included from ../src/node_snap7_server.h:12,
                                   from ../src/node_snap7_server.cpp:6:
                                   from ../src/node_snap7_server.h:10:
                   2419 |         isolate
                   2421 |       , len / 2);
                   2424 |         isolate
                   2426 |       , len
                   2427 |       , node_enc);
                  ../src/node_snap7_server.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_snap7::S7Server::RWBufferCallback(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/node_snap7_server.cpp:721:56: warning: comparison of integer expressions of different signedness: ‘size_t’ {aka ‘long unsigned int’} and ‘int’ [-Wsign-compare]
                    721 |     if (node::Buffer::Length(info[0].As<v8::Object>()) < size) {
                    CXX(target) Release/obj.target/node_snap7/src/snap7.o
                    SOLINK_MODULE(target) Release/obj.target/node_snap7.node
                    COPY Release/node_snap7.node
                  make: Leaving directory '/opt/iobroker/node_modules/node-snap7/build'
                  gyp info ok
                  added 3 packages in 1m
                  250 packages are looking for funding
                    run `npm fund` for details
                  host.chet install adapter s7
                  upload [5] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/assets/index-B2ytDdn0.js assets/index-B2ytDdn0.js application/javascript
                  upload [4] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/assets/index-Bd3GtHgn.css assets/index-Bd3GtHgn.css text/css
                  upload [3] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                  upload [2] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/index_m.html index_m.html text/html
                  upload [1] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/manifest.json manifest.json application/json
                  upload [0] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/s7.png s7.png image/png
                  host.chet object system.adapter.s7 created/updated
                  Updating objects from io-package.json for adapter "s7" with version "1.5.0"
                  host.chet create instance s7
                  host.chet object system.adapter.s7.0.alive created
                  host.chet object system.adapter.s7.0.connected created
                  host.chet object system.adapter.s7.0.compactMode created
                  host.chet object system.adapter.s7.0.cpu created
                  host.chet object system.adapter.s7.0.cputime created
                  host.chet object system.adapter.s7.0.memHeapUsed created
                  host.chet object system.adapter.s7.0.memHeapTotal created
                  host.chet object system.adapter.s7.0.memRss created
                  host.chet object system.adapter.s7.0.uptime created
                  host.chet object system.adapter.s7.0.inputCount created
                  host.chet object system.adapter.s7.0.outputCount created
                  host.chet object system.adapter.s7.0.eventLoopLag created
                  host.chet object system.adapter.s7.0.sigKill created
                  host.chet object system.adapter.s7.0.logLevel created
                  host.chet object system.adapter.s7.0 created
                  echad@chet:~ $
                    @basti97
                    NPM version: 11.6.1
                    gyp info spawn make
                      782 |     else
                     2419 |         isolate
                     2421 |       , len / 2);
                     2424 |         isolate
                     2426 |       , len
                     2427 |       , node_enc);
                     2419 |         isolate
                     2421 |       , len / 2);
                     2424 |         isolate
                     2426 |       , len
                     2427 |       , node_enc);
                     2419 |         isolate
                     2421 |       , len / 2);
                     2424 |         isolate
                     2426 |       , len
                     2427 |       , node_enc);
                    gyp info ok
                    echad@chet:~ $
                    Basti97B Offline
                    Basti97B Offline
                    Basti97
                    @thomas-braun was kann ich da jetzt machen?
                    • Basti97B Basti97
                      @basti97
                      Wie bist du denn da insgesamt unterwegs?
                      Ausgabe von
                      iob diag
                      mal posten.
                        @basti97
                        Ausgabe von
                        iob diag
                        mal posten.
                        Basti97B Offline
                        Basti97B Offline
                        Basti97
                        @thomas-braun Das komische bevor ich nodejs von 20.x..x auf 22.x.x aktualisiert habe hat es funktoniert. Und es betrifft nur die beiden S7 Adapter.
                        ```bash
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                        Operating System: Debian GNU/Linux 11 (bullseye)
                           Static hostname: SmartHomeMira
                                 Icon name: computer-vm
                                   Chassis: vm
                            Virtualization: kvm
                                    Kernel: Linux 5.10.0-35-amd64
                              Architecture: x86-64
                        OS is similar to:
                        model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
                        Docker          : false
                        Virtualization  : kvm
                        Kernel          : x86_64
                        Userland        : 64 bit
                        Systemuptime and Load:
                         17:17:50 up 18 min,  2 users,  load average: 0.35, 0.30, 0.34
                        CPU threads: 2
                        *** LIFE CYCLE STATUS ***
                        Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
                        *** TIME AND TIMEZONES ***
                                       Local time: Sun 2025-11-09 17:17:51 CET
                                   Universal time: Sun 2025-11-09 16:17:51 UTC
                                         RTC time: Sun 2025-11-09 16:17:52
                                      NTP service: active
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        mira
                        HOME=/home/mira
                        GROUPS=mira cdrom floppy sudo audio dip video plugdev netdev bluetooth scanner iobroker
                        iobroker
                        HOME=/home/iobroker
                        GROUPS=iobroker tty dialout audio video plugdev bluetooth
                        *** DISPLAY-SERVER SETUP ***
                        Display-Server:         false
                        Display-Manager:        * gdm3.service - LSB: GNOME Display Manager
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                        Mem:            3.9G        2.5G        658M        0.0K        770M        1.2G
                        Swap:           974M        0.0K        974M
                        Total:          4.9G        2.5G        1.6G
                        Active iob-Instances:   26
                                 3921 M total memory
                                 2493 M used memory
                                  422 M active memory
                                 2624 M inactive memory
                                  658 M free memory
                                  164 M buffer memory
                                  605 M swap cache
                                  974 M total swap
                                    0 M used swap
                                  974 M free swap
                        top - 17:17:51 up 18 min,  2 users,  load average: 0.35, 0.30, 0.34
                        Tasks: 136 total,   1 running, 135 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   3921.4 total,    657.8 free,   2493.0 used,    770.5 buff/cache
                        MiB Swap:    975.0 total,    974.5 free,      0.5 used.   1189.9 avail Mem
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** DMESG CRITICAL ERRORS ***
                        No critical errors detected
                        *** FILESYSTEM ***
                        udev           devtmpfs  1.9G     0  1.9G   0% /dev
                        tmpfs          tmpfs     393M  868K  392M   1% /run
                        /dev/sda1      ext4       31G   18G   12G  60% /
                        tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                        tmpfs          tmpfs     393M   52K  393M   1% /run/user/1000
                        [Sun Nov  9 16:59:21 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                        [Sun Nov  9 16:59:22 2025] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                        Show mounted filesystems:
                        TARGET SOURCE    FSTYPE OPTIONS
                        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                        /var:
                        3.0G    /var/
                        1.5G    /var/cache/apt/archives
                        1.5G    /var/cache/apt
                        1.5G    /var/cache
                        1.3G    /var/log/journal/b10d7d2025ff4d469c4f8cc3d666e31e
                        Archived and active journals take up 112.0M in the file system.
                        /opt/iobroker/backups:
                        338M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        748M    /opt/iobroker/iobroker-data/
                        349M    /opt/iobroker/iobroker-data/files
                        267M    /opt/iobroker/iobroker-data/backup-objects
                        68M     /opt/iobroker/iobroker-data/files/vis-2
                        47M     /opt/iobroker/iobroker-data/files/admin.admin
                        36M     /opt/iobroker/iobroker-data/objects.jsonl
                        21M     /opt/iobroker/iobroker-data/files/s7.admin/static/js/main.9f443724.js.map
                        18M     /opt/iobroker/iobroker-data/objects.json.migrated
                        18M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                        12M     /opt/iobroker/iobroker-data/files/admin.0/zip/2024-06-29-scripts.zip
                        USB-Devices by-id:
                        No Devices found 'by-id'
                        *** ZigBee Settings ***
                        HINT:
                        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                        /dev/ttyUSB0
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v22.21.0
                        /usr/bin/node           v22.21.0
                        /usr/bin/npm            10.9.4
                        /usr/bin/npx            10.9.4
                        /usr/bin/corepack       0.34.0
                        nodejs:
                          Installed: 22.21.0-1nodesource1
                          Candidate: 22.21.0-1nodesource1
                          Version table:
                         *** 22.21.0-1nodesource1 600
                             22.20.0-1nodesource1 600
                             22.19.0-1nodesource1 600
                             22.18.0-1nodesource1 600
                             22.17.1-1nodesource1 600
                             22.17.0-1nodesource1 600
                             22.16.0-1nodesource1 600
                             22.15.1-1nodesource1 600
                             22.15.0-1nodesource1 600
                             22.14.0-1nodesource1 600
                             22.13.1-1nodesource1 600
                             22.13.0-1nodesource1 600
                             22.12.0-1nodesource1 600
                             22.11.0-1nodesource1 600
                             22.10.0-1nodesource1 600
                             22.9.0-1nodesource1 600
                             22.8.0-1nodesource1 600
                             22.7.0-1nodesource1 600
                             22.6.0-1nodesource1 600
                             22.5.1-1nodesource1 600
                             22.5.0-1nodesource1 600
                             22.4.1-1nodesource1 600
                             22.4.0-1nodesource1 600
                             22.3.0-1nodesource1 600
                             22.2.0-1nodesource1 600
                             22.1.0-1nodesource1 600
                             22.0.0-1nodesource1 600
                             12.22.12~dfsg-1~deb11u7 500
                                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                             12.22.12~dfsg-1~deb11u4 500
                                500 http://deb.debian.org/debian bullseye/main amd64 Packages
                        No problems detected
                        Errors in npm tree: 0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        Media03             Media03 (version: 4.0.21, hostname: Media03       , alive, uptime: 1064)
                        Media04             Media04 (version: 7.0.6, hostname: Media04       , alive, uptime: 2810)
                        SmartHomeMira       SmartHomeMira (version: 7.0.6, hostname: SmartHomeMira , alive, uptime: 947)
                        dns-server-2-emilia dns-server-2-emilia (version: 2.2.9, hostname: dns-server-2-emilia, dead, uptime: 3983)
                        raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , dead, uptime: 84743)
                        Core adapters versions
                        js-controller:  7.0.6
                        admin:          7.7.19
                        javascript:     8.9.2
                        nodejs modules from github:     0
                        Adapter State
                          system.adapter.accuweather.0            : accuweather           : SmartHomeMira                            - disabled
                          system.adapter.adguard.0                : adguard               : SmartHomeMira                            - disabled
                        + system.adapter.admin.0                  : admin                 : SmartHomeMira                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                        + system.adapter.admin.1                  : admin                 : SmartHomeMira                            -  enabled, port: 8089, bind: 0.0.0.0 (SSL), run as: admin
                        + system.adapter.alexa2.0                 : alexa2                : SmartHomeMira                            -  enabled
                        + system.adapter.asuswrt.1                : asuswrt               : SmartHomeMira                            -  enabled
                        + system.adapter.backitup.0               : backitup              : SmartHomeMira                            -  enabled
                        + system.adapter.backitup.1               : backitup              : Media04                                  -  enabled
                          system.adapter.cloud.0                  : cloud                 : SmartHomeMira                            - disabled
                          system.adapter.daswetter.0              : daswetter             : SmartHomeMira                            -  enabled
                          system.adapter.discovery.0              : discovery             : SmartHomeMira                            - disabled
                        + system.adapter.ds18b20.0                : ds18b20               : Media04                                  -  enabled
                          system.adapter.dwd.0                    : dwd                   : SmartHomeMira                            -  enabled
                          system.adapter.email.0                  : email                 : SmartHomeMira                            - disabled
                          system.adapter.energiefluss.0           : energiefluss          : SmartHomeMira                            - disabled
                          system.adapter.feiertage.0              : feiertage             : SmartHomeMira                            -  enabled
                        + system.adapter.hass.0                   : hass                  : SmartHomeMira                            -  enabled, port: 8123
                          system.adapter.ical.0                   : ical                  : SmartHomeMira                            - disabled
                          system.adapter.icons-icons8.0           : icons-icons8          : SmartHomeMira                            -  enabled
                          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : SmartHomeMira                            -  enabled
                        + system.adapter.influxdb.0               : influxdb              : SmartHomeMira                            -  enabled, port: 8086
                          system.adapter.iot.0                    : iot                   : SmartHomeMira                            - disabled
                        + system.adapter.javascript.0             : javascript            : SmartHomeMira                            -  enabled
                        + system.adapter.javascript.1             : javascript            : Media04                                  -  enabled
                        + system.adapter.javascript.2             : javascript            : SmartHomeMira                            -  enabled
                        + system.adapter.linux-control.0          : linux-control         : SmartHomeMira                            -  enabled
                          system.adapter.mobile.0                 : mobile                : SmartHomeMira                            -  enabled
                        + system.adapter.mqtt-client.0            : mqtt-client           : SmartHomeMira                            -  enabled, port: 8883
                          system.adapter.mqtt.1                   : mqtt                  : SmartHomeMira                            - disabled, port: 8883, bind: 0.0.0.0
                          system.adapter.netatmo-crawler.0        : netatmo-crawler       : SmartHomeMira                            - disabled
                          system.adapter.nina.0                   : nina                  : SmartHomeMira                            - disabled
                        + system.adapter.node-red.0               : node-red              : SmartHomeMira                            -  enabled, port: 1880, bind: 0.0.0.0
                          system.adapter.node-red.1               : node-red              : SmartHomeMira                            - disabled, port: 1881, bind: 0.0.0.0
                        + system.adapter.ping.0                   : ping                  : SmartHomeMira                            -  enabled
                          system.adapter.radar2.0                 : radar2                : Media04                                  - disabled
                          system.adapter.rpi2.0                   : rpi2                  : Media03                                  -  enabled
                          system.adapter.rpi2.3                   : rpi2                  : dns-server-2-emilia                      -  enabled
                        + system.adapter.rpi2.4                   : rpi2                  : Media04                                  -  enabled
                          system.adapter.s7.0                     : s7                    : SmartHomeMira                            -  enabled
                          system.adapter.s7.1                     : s7                    : SmartHomeMira                            -  enabled
                        + system.adapter.sonoff.0                 : sonoff                : SmartHomeMira                            -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.sourceanalytix.0         : sourceanalytix        : SmartHomeMira                            -  enabled
                        + system.adapter.telegram.0               : telegram              : SmartHomeMira                            -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.vis-2.0                  : vis-2                 : SmartHomeMira                            -  enabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : SmartHomeMira                            -  enabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : SmartHomeMira                            -  enabled
                          system.adapter.vis-history.0            : vis-history           : SmartHomeMira                            -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : SmartHomeMira                            -  enabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : SmartHomeMira                            -  enabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : SmartHomeMira                            -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : SmartHomeMira                            -  enabled
                          system.adapter.vis-justgage.0           : vis-justgage          : SmartHomeMira                            -  enabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : SmartHomeMira                            -  enabled
                          system.adapter.vis-metro.0              : vis-metro             : SmartHomeMira                            -  enabled
                          system.adapter.vis-players.0            : vis-players           : SmartHomeMira                            -  enabled
                          system.adapter.vis-plumb.0              : vis-plumb             : SmartHomeMira                            -  enabled
                          system.adapter.vis-rgraph.0             : vis-rgraph            : SmartHomeMira                            -  enabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : SmartHomeMira                            -  enabled
                          system.adapter.vis.0                    : vis                   : SmartHomeMira                            -  enabled
                          system.adapter.volumio.0                : volumio               : SmartHomeMira                            - disabled
                        + system.adapter.web.0                    : web                   : SmartHomeMira                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          system.adapter.web.1                    : web                   : SmartHomeMira                            - disabled, port: 8090, bind: 0.0.0.0 (SSL), run as: benutzer
                        + system.adapter.wled.0                   : wled                  : SmartHomeMira                            -  enabled
                          system.adapter.yr.0                     : yr                    : SmartHomeMira                            - disabled
                        + system.adapter.zigbee.0                 : zigbee                : Media04                                  -  enabled, port: /dev/ttyUSB0
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Upgrade policy: none
                        Installed ioBroker-Adapters
                        Used repository: stable
                        Adapter    "accuweather"  : 2.1.1    , installed 2.1.1
                        Adapter    "adguard"      : 1.0.1    , installed 1.0.1
                        Adapter    "admin"        : 7.7.19   , installed 7.7.19
                        Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                        Adapter    "asuswrt"      : 1.0.1    , installed 1.0.1
                        Adapter    "backitup"     : 3.3.10   , installed 3.3.5  [Updatable]
                        Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                        Adapter    "email"        : 2.0.4    , installed 2.0.4
                        Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                        Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
                        Adapter    "hass"         : 1.4.0    , installed 1.4.0
                        Adapter    "ical"         : 1.17.0   , installed 1.17.0
                        Adapter    "iot"          : 5.0.7    , installed 3.3.0  [Updatable]
                        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                        Controller "js-controller": 7.0.7    , installed 7.0.6  [Updatable]
                        Adapter    "linux-control": 1.1.5    , installed 1.1.5
                        Adapter    "mqtt"         : 6.1.4    , installed 6.1.2  [Updatable]
                        Adapter    "mqtt-client"  : 3.0.0    , installed 2.1.0  [Updatable]
                        Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
                        Adapter    "nina"         : 0.0.25   , installed 0.0.25
                        Adapter    "node-red"     : 5.2.1    , installed 6.0.7
                        Adapter    "radar2"       : 2.4.0    , installed 2.4.0
                        Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                        Adapter    "s7"           : 1.5.0    , installed 1.4.3  [Updatable]
                        Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                        Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                        Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
                        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                        Adapter    "volumio"      : 0.2.0    , installed 0.2.0
                        Adapter    "web"          : 7.0.8    , installed 7.0.8
                        Adapter    "wled"         : 0.7.2    , installed 0.7.2
                        Adapter    "yr"           : 5.3.0    , installed 5.3.0
                        Objects and States
                        Objects:        16950
                        States:         16323
                        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:2 http://deb.debian.org/debian bullseye InRelease
                        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          47735      7649/sshd: /usr/sbi
                        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       27158      4123/node-red
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       28978      4620/io.sonoff.0
                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       25435      3885/iobroker.js-co
                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       25430      3885/iobroker.js-co
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1440       1/init
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          47737      7649/sshd: /usr/sbi
                        tcp6       0      0 :::8089                 :::*                    LISTEN      1001       25539      3907/io.admin.1
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          1444       1/init
                        tcp6       0      0 :::80                   :::*                    LISTEN      1001       27160      4123/node-red
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26700      3952/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28568      5005/io.web.0
                        udp        0      0 192.168.1.10:1900       0.0.0.0:*                           1001       27161      4123/node-red
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1441       1/init
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       31220      5643/io.wled.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           109        13062      347/avahi-daemon: r
                        udp        0      0 0.0.0.0:42322           0.0.0.0:*                           109        13064      347/avahi-daemon: r
                        udp6       0      0 :::111                  :::*                                0          1447       1/init
                        udp6       0      0 fe80::a8d9:8dff:fee:546 :::*                                0          13868      361/NetworkManager
                        udp6       0      0 :::5353                 :::*                                109        13063      347/avahi-daemon: r
                        udp6       0      0 :::55042                :::*                                109        13065      347/avahi-daemon: r
                        2025-11-09 17:08:54.031  - info: linux-control.0 (5431) getting data from AIDA_Luna (192.168.1.47:22)
                        2025-11-09 17:08:57.005  - info: linux-control.0 (5431) [getConnection] Host 'Media03_WZ_Radio' (192.168.1.33:22) seems not to be online
                        2025-11-09 17:08:57.100  - info: linux-control.0 (5431) [getConnection] Host 'AIDA_Luna' (192.168.1.47:22) seems not to be online
                        2025-11-09 17:09:19.662  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_DBs_in_virtuelle: BWM neu: Bewegung erkannt
                        2025-11-09 17:09:19.665  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_weißer_Ring_Ein__Aus_(Test): Ring weiß Aus (timeout stop)
                        2025-11-09 17:09:52.797  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_DBs_in_virtuelle: BWM neu: Bewegung nicht mehr
                        2025-11-09 17:10:27.007  - info: host.SmartHomeMira instance system.adapter.daswetter.0 in version "3.2.3" started with pid 6745
                        2025-11-09 17:10:27.540  - info: daswetter.0 (6745) Sets unsupported
                        2025-11-09 17:10:27.801  - info: daswetter.0 (6745) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v22.21.0, js-controller: 7.0.6
                        2025-11-09 17:10:30.128  - info: daswetter.0 (6745) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                        2025-11-09 17:10:30.633  - info: daswetter.0 (6745) cleaned everything up...
                        2025-11-09 17:10:30.642  - info: host.SmartHomeMira instance system.adapter.daswetter.0 having pid 6745 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2025-11-09 17:13:22.953  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_DBs_in_virtuelle: BWM neu: Bewegung erkannt
                        2025-11-09 17:13:22.956  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_weißer_Ring_Ein__Aus_(Test): Ring weiß Aus (timeout stop)
                        2025-11-09 17:13:57.010  - info: linux-control.0 (5431) getting data from Media03_WZ_Radio (192.168.1.33:22)
                        2025-11-09 17:13:57.106  - info: linux-control.0 (5431) getting data from AIDA_Luna (192.168.1.47:22)
                        2025-11-09 17:13:57.751  - info: javascript.0 (3988) script.js.Wohnung.Motion_Detection.Flur_DBs_in_virtuelle: BWM neu: Bewegung nicht mehr
                        2025-11-09 17:14:00.076  - info: linux-control.0 (5431) [getConnection] Host 'Media03_WZ_Radio' (192.168.1.33:22) seems not to be online
                        2025-11-09 17:14:00.172  - info: linux-control.0 (5431) [getConnection] Host 'AIDA_Luna' (192.168.1.47:22) seems not to be online
                        2025-11-09 17:15:27.009  - info: host.SmartHomeMira instance system.adapter.daswetter.0 in version "3.2.3" started with pid 7247
                        2025-11-09 17:15:27.535  - info: daswetter.0 (7247) Sets unsupported
                        2025-11-09 17:15:27.818  - info: daswetter.0 (7247) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v22.21.0, js-controller: 7.0.6
                        2025-11-09 17:15:30.163  - info: daswetter.0 (7247) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                        2025-11-09 17:15:30.668  - info: daswetter.0 (7247) cleaned everything up...
                        2025-11-09 17:15:30.677  - info: host.SmartHomeMira instance system.adapter.daswetter.0 having pid 7247 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        iob diag has finished.
                        mira@SmartHomeMira:~$
                        Ro75R Thomas BraunT 2 Antworten Letzte Antwort
                        • Basti97B Basti97
                          ```bash
                          Script v.2025-08-09
                          *** BASE SYSTEM ***
                                     Chassis: vm
                              Virtualization: kvm
                          OS is similar to:
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                          CPU threads: 2
                                        NTP service: active
                                    RTC in local TZ: no
                          mira
                          HOME=/home/mira
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                                   3921 M total memory
                                   2493 M used memory
                                    422 M active memory
                                    658 M free memory
                                    164 M buffer memory
                                    605 M swap cache
                                    974 M total swap
                                      0 M used swap
                                    974 M free swap
                          *** FILESYSTEM ***
                          /var:
                          3.0G    /var/
                          1.5G    /var/cache/apt
                          1.5G    /var/cache
                          USB-Devices by-id:
                          HINT:
                          /dev/ttyUSB0
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.9.4
                          /usr/bin/npx            10.9.4
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.7.19
                          javascript:     8.9.2
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        16950
                          States:         16323
                          Pending Updates: 0
                          Ro75R Offline
                          Ro75R Offline
                          Ro75
                          @basti97 sagte in s7 Adapter funktioniert nicht mehr noch node update:
                          Doch richtig gelesen - uralt.
                          Ro75.
                          Basti97B 1 Antwort Letzte Antwort
                            @basti97
                            Ausgabe von
                            iob diag
                            mal posten.
                            Basti97B Offline
                            Basti97B Offline
                            Basti97
                            mira@SmartHomeMira:~$ ========== Start marking the full check here ===========
                            ```bash
                            Script v.2025-08-09
                            *** BASE SYSTEM ***
                                       Chassis: vm
                                Virtualization: kvm
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            mira@SmartHomeMira:~$.l here for C&P =============DAPTER_REQUESTED_TERMINATIO
                            • Ro75R Ro75
                              Ro75.
                              Basti97B Offline
                              Basti97B Offline
                              Basti97
                              @ro75 Naja aber bevor ich nodejs aktualisiert habe hat es auch funktoniert und es betrifft ja nur den S7 Adapter zwei mal
                              • Basti97B Basti97
                                ```bash
                                Script v.2025-08-09
                                *** BASE SYSTEM ***
                                           Chassis: vm
                                    Virtualization: kvm
                                OS is similar to:
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                CPU threads: 2
                                              NTP service: active
                                          RTC in local TZ: no
                                mira
                                HOME=/home/mira
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Session:                tty
                                *** MEMORY ***
                                         3921 M total memory
                                         2493 M used memory
                                          422 M active memory
                                          658 M free memory
                                          164 M buffer memory
                                          605 M swap cache
                                          974 M total swap
                                            0 M used swap
                                          974 M free swap
                                *** FILESYSTEM ***
                                /var:
                                3.0G    /var/
                                1.5G    /var/cache/apt
                                1.5G    /var/cache
                                USB-Devices by-id:
                                HINT:
                                /dev/ttyUSB0
                                zigbee.X
                                Extended Pan ID:
                                *** MASKED ***
                                Pan ID:
                                *** MASKED ***
                                Channel:
                                *** MASKED ***
                                Network Key:
                                *** MASKED ***
                                /usr/bin/npm            10.9.4
                                /usr/bin/npx            10.9.4
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin:          7.7.19
                                javascript:     8.9.2
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        16950
                                States:         16323
                                Pending Updates: 0
                                Da war es ja auch gegen nodejs@20 gebaut...
                                Jedenfalls ist
                                zu alt. Installier da Debian 13 'Trixie'
                                  Jedenfalls ist
                                  Basti97B Offline
                                  Basti97B Offline
                                  Basti97
                                  @thomas-braun Ok werde ich machen da installiere ich Linux komplett neu. Aber warum ensteht der Fehler nur bei den S7 Adapter und nicht bei allen Adaptern.
                                  • Basti97B Basti97
                                    Dann aber diesmal gleich ohne Desktop.
                                    Das ist kein 'Fehler'. Du brauchst nur ein aktuelles System.
                                    Und andere Adapter haben keine Bestandteile, die kompiliert werden müssen. Deswegen funktionieren die auch mit einer anderen ABI.
                                      Basti97B Offline
                                      Basti97B Offline
                                      Basti97
                                      @thomas-braun Achso ich hatte das ganze immer mit dem Desktop gemacht aber eigentlich braucht man ihn ja wirklich nicht da er ja auch zusätzliche Ressourcen verbraucht.
                                      • Basti97B Basti97
                                        @basti97
                                        Unter anderem auch das...
                                          @basti97
                                          Basti97B Offline
                                          Basti97B Offline
                                          Basti97
                                          @thomas-braun Gibt es noch mehr Vorteile ohne Desktop? Das muss ich ja bei der Installation den Haken bei Desktop rausmachen richtig?
