  4. Test Adapter eusec v2.0.x
    6.8k
eusecmcm1957
96 Beiträge 21 Kommentatoren 11.6k Aufrufe 20 Beobachtet
    @niiccooo1
    Dann lösch den ring-Adapter mal komplett aus dem System und installier den dann nochmal neu.
    Denn eigentlich muss da die ring-client-api 14.1.0 gezogen werden (und die passt zu nodejs@22):
    echad@chet:/opt/iobroker $ iob add ring --debug
    NPM version: 11.6.2
    Installing iobroker.ring@6.4.0... (System call)
    npm error code EBADENGINE
    npm error engine Unsupported engine
    npm error engine Not compatible with your version of node/npm: ring-client-api@14.1.0
    npm error notsup Not compatible with your version of node/npm: ring-client-api@14.1.0
    npm error notsup Required: {"node":"^20 || ^22 || ^24"}
    npm error notsup Actual:   {"npm":"11.6.2","node":"v25.1.0"}
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-02T15_47_04_628Z-debug-0.log
    N Offline
    N Offline
    niiccooo1
    @thomas-braun Alles klar.
    Zum löschen über die admin Oberfläche reicht oder lieber über die Konsole?
    • N niiccooo1
      @niiccooo1
      Ich bevorzuge in jedem Fall das Terminal.
      iob del ring --debug
      iob update
      Und fertig.
      N 1 Antwort Letzte Antwort
        @niiccooo1
        iob update
        Und fertig.
        N Offline
        N Offline
        niiccooo1
        schrieb am zuletzt editiert von niiccooo1
        root@iobroker:~# iob del ring --debug
        Delete adapter "ring"
        host.iobroker Counted 1 instances of ring
        host.iobroker Counted 2 meta of ring
        host.iobroker Counted 1 adapter for ring
        host.iobroker Counted 2 devices of ring
        host.iobroker Counted 6 channels of ring
        host.iobroker Counted 44 states of ring
        host.iobroker Counted 14 states of system.adapter.ring
        host.iobroker Counted 44 states (io.ring.*) from states
        host.iobroker Counted 15 states (system.adapter.ring.*) from states
        host.iobroker file ring.admin deleted
        host.iobroker file ring.0 deleted
        host.iobroker object ring deleted
        host.iobroker object ring.admin deleted
        host.iobroker Deleting 71 object(s).
        host.iobroker Deleting 59 state(s).
        Error deleting adapter ring from disk: host.iobroker: Cannot uninstall iobroker.ring: 1
        You might have to delete it yourself!
        Die Instanz ist weg, jedoch der Adapter lässt sich nicht deinstallieren
        • N niiccooo1
          @niiccooo1
          iob list adapters | grep ring
            @niiccooo1
            N Offline
            N Offline
            niiccooo1
            @thomas-braun said in Test Adapter eusec 2.0.x:
            root@iobroker:~# iob list adapters | grep ring
            host.iobroker Deleting 1 object(s).
            • N niiccooo1
              @niiccooo1
              iob update
                @niiccooo1
                iob update
                N Offline
                N Offline
                niiccooo1
                root@iobroker:~# iob add ring --debug
                host.iobroker install adapter ring
                upload [25] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/admin.d.ts admin.d.ts video/mp2t
                upload [20] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/de.json i18n/de.json application/json
                upload [19] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/en.json i18n/en.json application/json
                upload [18] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/es.json i18n/es.json application/json
                upload [17] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/fr.json i18n/fr.json application/json
                upload [16] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/it.json i18n/it.json application/json
                upload [15] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/nl.json i18n/nl.json application/json
                upload [14] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/pl.json i18n/pl.json application/json
                upload [13] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/pt.json i18n/pt.json application/json
                upload [12] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/ru.json i18n/ru.json application/json
                upload [11] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/uk.json i18n/uk.json application/json
                upload [10] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
                upload [9] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/index_m.html index_m.html text/html
                upload [8] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/jsonConfig.json jsonConfig.json application/json
                upload [7] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/preferences-desktop-notification-bell-3.png preferences-desktop-notification-bell-3.png image/png
                upload [6] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/preferences-system-login.png preferences-system-login.png image/png
                upload [5] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/ring.png ring.png image/png
                upload [4] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/style.css style.css text/css
                upload [3] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/tab_m.html tab_m.html text/html
                upload [2] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/tab_m.js tab_m.js application/javascript
                upload [1] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/tsconfig.json tsconfig.json application/json
                upload [0] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/words.js words.js application/javascript
                host.iobroker object system.adapter.ring created/updated
                Updating objects from io-package.json for adapter "ring" with version "6.4.0"
                host.iobroker create instance ring
                host.iobroker object system.adapter.ring.0.alive created
                host.iobroker object system.adapter.ring.0.connected created
                host.iobroker object system.adapter.ring.0.compactMode created
                host.iobroker object system.adapter.ring.0.cpu created
                host.iobroker object system.adapter.ring.0.cputime created
                host.iobroker object system.adapter.ring.0.memHeapUsed created
                host.iobroker object system.adapter.ring.0.memHeapTotal created
                host.iobroker object system.adapter.ring.0.memRss created
                host.iobroker object system.adapter.ring.0.uptime created
                host.iobroker object system.adapter.ring.0.inputCount created
                host.iobroker object system.adapter.ring.0.outputCount created
                host.iobroker object system.adapter.ring.0.eventLoopLag created
                host.iobroker object system.adapter.ring.0.sigKill created
                host.iobroker object system.adapter.ring.0.logLevel created
                host.iobroker object ring.0 created
                host.iobroker object system.adapter.ring.0 created
                • N niiccooo1
                  @niiccooo1
                  Und jetzt kannste auch eusec in der Beta-Version installieren.
                    @niiccooo1
                    N Offline
                    N Offline
                    niiccooo1
                    STARK!
                    Bei der Einrichtung vom ring Token wurde ich gefragt ob ich auf die ring-client-api 14.1 Update möchte.
                    Ich werde mich morgen dem eisec Adapter widmen.
                    Vielen Dank Thomas!
                    • N niiccooo1
                      STARK!
                      Vielen Dank Thomas!
                      @niiccooo1
                      Ein frisches
                      iob diag
                      kannste aber trotzdem mal posten.
                        @niiccooo1
                        Ein frisches
                        iob diag
                        N Offline
                        N Offline
                        niiccooo1
                        Gestern habe ich die Version 2.0.3 ebenfalls zum Download angeboten bekommen.
                        Ich habe den Adapter erfolgreich installiert, eingerichtet und konnte bis jetzt keine Probleme feststellen.
                        Vielen Dank für eure Arbeit den Adapter weiterhin am Leben zu erhalten!
                          Michael.K 0
                          Hallo mcm1957, hallo Thomas Braun,
                          vielen Dank dass der EUFY Adapter wieder aktiv ist. Und Klasse, dass Du Deine Zeit dafür opferst.
                          Die Version 2.0.3 läuft bei mir fehlerfrei mit der Doorbell T8214.
                          Allerdings habe ich immer noch das Problem, dass der IObroker Adapter nichts mit den Video anfangen kann, wenn die Kamera separat im WLAN angemeldet ist. Wenn die Kamera über die homebase angemeldet ist klappt das.
                          Das Problem kann aber kaum an der separaten WLAN-Verbindung liegen, weil der EUFY-Client im selben WLAN das Video fehlerfrei anzeigt.
                          Da ich bisher (bin in der Testumgebung) kein iptables oder ähnliches installiert habe, sollte das auch nicht die Ursache sein.
                          Übrigens, in der alten Version von brobat war dieses Verhalten gleich.
                          Hast Du oder jemand anderes eine Idee wo die Videodaten verschluckt werden?
                          Meine Testumgebung:
                          Dell Optiplex mit Debian Linux 13.1
                          Doorbell T8214
                          • F Offline
                            Flowski
                            Hi, habe ebenfalls eine T8214 und wollte mal fragen ob man es irgendwie hinbekommt sich Bilder der Cam zukommen zu lassen (Telegram). Die Idee wäre einen sep. Bewegungsmelder zu stellen der den Bereich besser eingrenzt und bei Auslösung ein Bild zu machen und per Telegram zu versenden.
                              Kuckuckmann
                              ich hab da mal ein Problem.
                              Ich habe zwei SoloCams 220.
                              Im IoBroker werden die Kameras nicht aktualisiert.
                              Heisst, ich habe in der App aktuell eine Kamera die heisst Flur. Im Objektbaum im IoB hab ich nr die alte vom Balkon, die aktuell nicht genutzt wird.
                              Die vom Flur wird aber nicht eingefügt.
                              Ich hab den Adapter auf dem neusten Stand 2.0.3.
                              Das Login funktioniert. Nach der Neuinstallation hab ich eine Loginbestätigung von Eufy bekommen.
                              Wer kann mir helfen?
                              LG
                              NSPanel Dokumentation im GitHub Wiki:
                              • madingM Offline
                                madingM Offline
                                mading
                                Die beiden Cams tauchen in der Eufy App auf dh sie sind sicher in der Cloud hinterlegt?
                                  Kuckuckmann
                                  schrieb am zuletzt editiert von Kuckuckmann
                                  +++ EDIT +++
                                  Ich hab das Problem gefunden und lösen können.
                                  Der Verursacher sitzt vor dem Rechner ;-)
                                  Wenn man mit 2 unterschiedlichen Accounts arbeitet, kann das nix werden.
                                  weissrW 1 Antwort Letzte Antwort
                                  • madingM Offline
                                    madingM Offline
                                    mading
                                    #66
                                    PEBKAC 😂
                                    • AtifanA Offline
                                      AtifanA Offline
                                      Atifan
                                      #67
                                      Hallo, bin gerade auf den Thread hier gestoßen. Ich habe mir ein Eufy Paket bestellt, das aus 2x S330 Kameras und einer S380 Homebase 3 besteht. Nun meine Frage, ist es mit dem Adapter evtl. möglich die Kameras bzw. die Videostreams in Iobroker zu integrieren? Ich würde diese gerne in LovelaceUI anzeigen. Geht das mit dem Adapter?
                                      • AtifanA Offline
                                        AtifanA Offline
                                        Atifan
                                        #68
                                        Hi, habe Eufy S330 Kameras und S380 Homebase und bin jetzt auf den Adapter EuSEC gestoßen.
                                        Die Kameras laufen ja nur über Batterie bzw. werden durch Solar geladen aber verbrauchen sehr wenig Energie und schalten sich nur ein wenn ein Event erkannt wird, d.h. eine Bewegung durch Person.
                                        Habe im Adapter festgestellt, dass man dort RTSP-Stream aktivieren kann und dann darüber auf die Kamera zugreifen kann.
                                        Nun stelle ich mir die frage, was passiert wenn ich das aktiviere. Läuft die Kamera dann dauerhaft? Oder läuft sie nur wenn ich auf den Stream zugreife?
                                        Ich würde gerne falls es irgendwie möglich ist den Kamerastream in mein Dashboard (Lovelace) integrieren.
                                        Ist das irgendwie möglich? Und auch so, dass die Kamera nicht ständig läuft und leer wird?
                                        • AtifanA Atifan
                                          Marc BergM Online
                                          Marc BergM Online
                                          Marc Berg
                                          #69
                                          @Atifan sagte:
                                          Ich habe zwar eine andere Homebase von Eufy, aber ich denke, das wird überall identisch sein:
                                          Sobald du den Datenpunkt eusec.0.xxx.cameras.yyy.rtsp_stream Auf "true" setzt, fängt die Kamera an zu laufen. Ab diesem Zeitpunkt kannst du auf den Stream unter eusec.0.xxx.cameras.yyy.rtsp_stream_url zugreifen. Allerdings wird der Stream nach ca. vier Minuten beendet, ob drauf zugegriffen wurde oder nicht. Danach müsste rtsp_stream nochmal auf true gesetzt werden.
