  4. Test DreameHome: 3D-Visualisierung und Alexa-Steuerung
    6.8k
123 Beiträge 16 Kommentatoren 16.5k Aufrufe 16 Beobachtet
  • H hahne
    @wawyo
    Wie müsste denn die richtige Ordner Struktur aussehen?
    Könntest du mir mal einen Screenshot zur Verfügung stellen?
    Ich hab eben nochmal eine neue Mal über die Dreamehome App generiert und die Räume neu beschriftet + Adapter Neustart.Weiterhin keine Räume zu sehen.
    Wenn ich eine neue Map über den Adapter anfordere schmiert der Adapter ab.
    Hab hier mal den Log angehangen.
    2025-10-16 05:29:59.510 - info: dreamehome.0 (326583) Generate Map
    2025-10-16 05:29:59.820 - info: dreamehome.0 (326583) [SUCCESS] Received data: {"mapstr":[{"id":1,"name":"","angle":"0","map":"eF7tvVmzomq-oJ916uSH6Nu8TiJARusOkNGBUUVOVBCCgICiIjJ4...
    2025-10-16 05:30:00.635 - error: dreamehome.0 (326583) Error: Cannot read properties of undefined (reading 'map')
    2025-10-16 05:30:00.636 - error: dreamehome.0 (326583) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-10-16 05:30:00.636 - error: dreamehome.0 (326583) unhandled promise rejection: Cannot read properties of undefined (reading 'map')
    2025-10-16 05:30:00.638 - error: dreamehome.0 (326583) TypeError: Cannot read properties of undefined (reading 'map')
    at Dreamehome.DH_GenerateMap (/opt/iobroker/node_modules/iobroker.dreamehome/lib/generateMap.js:2032:39)
    at runNextTicks (node:internal/process/task_queues:60:5)
    at process.processImmediate (node:internal/timers:454:9)
    at async Dreamehome.onStateChange (/opt/iobroker/node_modules/iobroker.dreamehome/main.js:7345:11)
    2025-10-16 05:30:00.638 - error: dreamehome.0 (326583) Cannot read properties of undefined (reading 'map')
    2025-10-16 05:30:00.639 - info: dreamehome.0 (326583) Cleaning up resources...
    2025-10-16 05:30:00.639 - info: dreamehome.0 (326583) Resource monitor stopped
    2025-10-16 05:30:00.639 - info: dreamehome.0 (326583) Resource monitoring stopped
    2025-10-16 05:30:00.639 - info: dreamehome.0 (326583) Memory manager stopped
    2025-10-16 05:30:00.639 - info: dreamehome.0 (326583) terminating
    2025-10-16 05:30:00.639 - warn: dreamehome.0 (326583) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2025-10-16 05:30:01.142 - info: dreamehome.0 (326583) terminating
    2025-10-16 05:30:01.178 - error: host.ioBroker instance system.adapter.dreamehome.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2025-10-16 05:30:32.430 - info: dreamehome.0 (337825) starting. Version 1.0.0 (non-npm: spayrosam/ioBroker.dreamehome#7893b33ffe944c9e017b2f64a3667fd98da6ddf1) in /opt/iobroker/node_modules/iobroker.dreamehome, node: v20.19.5, js-controller: 7.0.7
    2025-10-16 05:30:32.445 - info: dreamehome.0 (337825) Login and request Dreame data from cloud
    2025-10-16 05:30:32.474 - info: dreamehome.0 (337825) Profiling 103 whitelisted methods
    2025-10-16 05:30:32.474 - warn: dreamehome.0 (337825) GC not exposed. Start Node with "--expose-gc" for full functionality
    2025-10-16 05:30:32.475 - info: dreamehome.0 (337825) Auto-cleanup enabled (threshold: 300MB)
    2025-10-16 05:30:32.475 - info: dreamehome.0 (337825) Resource monitor started (interval: 0.005s)
    2025-10-16 05:30:32.489 - info: dreamehome.0 (337825) Auto-cleanup enabled (threshold: 300MB)
    2025-10-16 05:30:32.493 - info: dreamehome.0 (337825)
    ===== SYSTEM CONFIGURATION SNAPSHOT =====
    [Admin Configuration]
    - Cleaner Enabled: true
    - Threshold: 300 MB
    - Interval: 5 sec
    - Priority: medium
    - Heap Limit: 200 MB
    [Runtime States]
    - Cleaner Active: true
    - Current Heap: 34.57 MB
    - Heap Status: OK
    [Restart Manager]
    - No restart attempts
    [Process Metrics]
    - Heap Used: 27.62 MB
    - RSS: 106.20 MB
    - Uptime: 0h 0m 1s
    2025-10-16 05:30:32.493 - warn: dreamehome.0 (337825) GARBAGE COLLECTION NOT AVAILABLE! Start Node.js with --expose-gc for proper memory management
    2025-10-16 05:30:32.493 - warn: dreamehome.0 (337825) Current memory cleanup will be very limited in effectiveness
    2025-10-16 05:30:32.495 - info: dreamehome.0 (337825) Log status is set to false
    2025-10-16 05:30:32.673 - info: dreamehome.0 (337825) Login: Set login.access_token to "eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJ0ZW5hbnRfaWQiOiIwMDAwMDAiLCJjb3VudHJ5IjoiREUiLCJpc19uZXdfcmVnaXN0ZXIiOmZhbHNlLCJ1c2VyX25hbWUiOiJDRzMwNDE3OCIsImF1dGhvcml0aWVzIjpbInVzZXIiXSwiY2xpZW50X2lkIjoiZHJlYW1lX2FwcHYxIiwicm9sZV9uYW1lIjoidXNlciIsInVpZCI6IkNHMzA0MTc4IiwidCI6MTc2MDU4NTQzMiwicm9sZV9pZCI6Ii0xIiwidSI6ODU0MzI2NTksInNjb3BlIjpbImFsbCJdLCJ1c2VyX3Rva2VuIjp0cnVlLCJleHAiOjE3NjA1OTI2MzIsImxhbmciOiJkZSIsImRlcHRfaWQiOiItMSIsInJlZ2lvbiI6ImV1IiwianRpIjoiNTk2NWJmYmYtZTQxZC00NWZkLTkxOGUtMGFlOGRjZGMyMDQyIn0.PAOcz59W4STbOfmZREtyWW4tdN0XRiwZ1KWKX7igeV0"
    2025-10-16 05:30:32.678 - info: dreamehome.0 (337825) Login: Set login.token_type to "bearer"
    2025-10-16 05:30:32.682 - info: dreamehome.0 (337825) Login: Set login.refresh_token to "eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.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.k1BgcFlcZigdGyULijxsB-g4puUAf2mTAQ42jnFy2B0"
    2025-10-16 05:30:32.686 - info: dreamehome.0 (337825) Login: Set login.expires_in to 7199
    2025-10-16 05:30:32.691 - info: dreamehome.0 (337825) Login: Set login.scope to "all"
    2025-10-16 05:30:32.694 - info: dreamehome.0 (337825) Login: Set login.tenant_id to "000000"
    2025-10-16 05:30:32.697 - info: dreamehome.0 (337825) Login: Set login.country to "DE"
    2025-10-16 05:30:32.701 - info: dreamehome.0 (337825) Login: Set login.is_new_register to false
    2025-10-16 05:30:32.704 - info: dreamehome.0 (337825) Login: Set login.client_id to "dreame_appv1"
    2025-10-16 05:30:32.707 - info: dreamehome.0 (337825) Login: Set login.role_name to "user"
    2025-10-16 05:30:32.710 - info: dreamehome.0 (337825) Login: Set login.uid to "CG304178"
    2025-10-16 05:30:32.713 - info: dreamehome.0 (337825) Login: Set login.t to 1760585432
    2025-10-16 05:30:32.717 - info: dreamehome.0 (337825) Login: Set login.role_id to "-1"
    2025-10-16 05:30:32.720 - info: dreamehome.0 (337825) Login: Set login.u to 85432659
    2025-10-16 05:30:32.723 - info: dreamehome.0 (337825) Login: Set login.user_token to true
    2025-10-16 05:30:32.726 - info: dreamehome.0 (337825) Login: Set login.lang to "de"
    2025-10-16 05:30:32.731 - info: dreamehome.0 (337825) Login: Set login.dept_id to "-1"
    2025-10-16 05:30:32.734 - info: dreamehome.0 (337825) Login: Set login.region to "eu"
    2025-10-16 05:30:32.738 - info: dreamehome.0 (337825) Login: Set login.jti to "5965bfbf-e41d-45fd-918e-0ae8dcdc2042"
    2025-10-16 05:30:32.789 - info: dreamehome.0 (337825) Selected device [1]: dreame.vacuum.r2228o (DID: 660831787)
    2025-10-16 05:30:32.789 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.id to "1771573680775221249"
    2025-10-16 05:30:32.792 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.did to "660831787"
    2025-10-16 05:30:32.797 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.model to "dreame.vacuum.r2228o"
    2025-10-16 05:30:32.801 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.subModel to "dreame.vacuum.r2228o"
    2025-10-16 05:30:32.805 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.ver to "4.3.9_3407"
    2025-10-16 05:30:32.809 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.customName to ""
    2025-10-16 05:30:32.812 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.property to "{\"lwt\":1,\"mac\":\"70:C9:32:1C:77:27\"}"
    2025-10-16 05:30:32.815 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.mac to "70:C9:32:1C:77:27"
    2025-10-16 05:30:32.818 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.vendor to ""
    2025-10-16 05:30:32.821 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.master to true
    2025-10-16 05:30:32.825 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.masterUid to "CG304178"
    2025-10-16 05:30:32.828 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.permissions to ""
    2025-10-16 05:30:32.831 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.bindDomain to "10000.mt.eu.iot.dreame.tech:19973"
    2025-10-16 05:30:32.835 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.sharedTimes to 0
    2025-10-16 05:30:32.838 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.sharedStatus to 1
    2025-10-16 05:30:32.841 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.updateTime to "2024-03-23 16:24:14"
    2025-10-16 05:30:32.844 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.devBindTime to 1711211054000
    2025-10-16 05:30:32.848 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.createTime to 1689929749000
    2025-10-16 05:30:32.853 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.productId to "10071"
    2025-10-16 05:30:32.856 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.categoryPath to "/lifeapps/vacuum"
    2025-10-16 05:30:32.860 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.model to "dreame.vacuum.r2228o"
    2025-10-16 05:30:32.863 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.submodel to "dreame.vacuum.r2228o"
    2025-10-16 05:30:32.866 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.remark to ""
    2025-10-16 05:30:32.871 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.feature to "video,fastCommand"
    2025-10-16 05:30:32.874 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.videoDynamicVendor to false
    2025-10-16 05:30:32.877 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.defaultVendors to []
    2025-10-16 05:30:32.881 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.scType to "WIFI_BLE"
    2025-10-16 05:30:32.885 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.extendScType to []
    2025-10-16 05:30:32.889 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.status to "Live"
    2025-10-16 05:30:32.892 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.mainImage.as to "1"
    2025-10-16 05:30:32.895 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.mainImage.caption to "1"
    2025-10-16 05:30:32.899 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.mainImage.height to 0
    2025-10-16 05:30:32.902 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.mainImage.width to 0
    2025-10-16 05:30:32.905 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.mainImage.imageUrl to "https://oss.iot.dreame.tech/dreame-public/prod/products/dreame.vacuum.r2228o/images/176e55352ac1568e63aa3970ab4fd7a6.png"
    2025-10-16 05:30:32.908 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.mainImage.smallImageUrl to ""
    2025-10-16 05:30:32.913 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.popup.as to "1"
    2025-10-16 05:30:32.917 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.popup.caption to "1"
    2025-10-16 05:30:32.921 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.popup.height to 0
    2025-10-16 05:30:32.923 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.popup.width to 0
    2025-10-16 05:30:32.926 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.popup.imageUrl to "https://oss.iot.dreame.tech/dreame-public/prod/products/dreame.vacuum.r2228o/images/71be149e9175b3d323bd39cf789263dc.png"
    2025-10-16 05:30:32.929 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.popup.smallImageUrl to ""
    2025-10-16 05:30:32.932 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.icon.as to "1"
    2025-10-16 05:30:32.935 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.icon.caption to "1"
    2025-10-16 05:30:32.937 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.icon.height to 0
    2025-10-16 05:30:32.940 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.icon.width to 0
    2025-10-16 05:30:32.943 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.icon.imageUrl to "https://oss.iot.dreame.tech/dreame-public/prod/products/dreame.vacuum.r2228o/images/71be149e9175b3d323bd39cf789263dc.png"
    2025-10-16 05:30:32.946 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.icon.smallImageUrl to ""
    2025-10-16 05:30:32.948 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.overlook.as to "1"
    2025-10-16 05:30:32.951 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.overlook.caption to "1"
    2025-10-16 05:30:32.954 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.overlook.height to 0
    2025-10-16 05:30:32.957 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.overlook.width to 0
    2025-10-16 05:30:32.959 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.overlook.imageUrl to "https://oss.iot.dreame.tech/dreame-public/prod/products/dreame.vacuum.r2228o/images/71be149e9175b3d323bd39cf789263dc.png"
    2025-10-16 05:30:32.963 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.overlook.smallImageUrl to ""
    2025-10-16 05:30:32.966 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.images to []
    2025-10-16 05:30:32.969 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.extensionId to "1020"
    2025-10-16 05:30:32.972 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.updatedAt to "1714387601950"
    2025-10-16 05:30:32.975 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.createdAt to "1650959623874"
    2025-10-16 05:30:32.978 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.releaseAt to "-1"
    2025-10-16 05:30:32.982 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.quickConnectStatus to -1
    2025-10-16 05:30:32.985 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.quickConnects.10254 to "dreame.vacuum.r2228z"
    2025-10-16 05:30:32.989 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.permit to ""
    2025-10-16 05:30:32.993 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.firmwareDevelopType to "SINGLE_PLATFORM"
    2025-10-16 05:30:32.996 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.bindType to ""
    2025-10-16 05:30:32.998 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.deviceInfo.displayName to "L10s Ultra"
    2025-10-16 05:30:33.003 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.online to true
    2025-10-16 05:30:33.008 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.latestStatus to 13
    2025-10-16 05:30:33.011 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.battery to 100
    2025-10-16 05:30:33.014 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.videoStatus to "{\"operType\":\"end\",\"operation\":\"monitor\",\"result\":0,\"status\":0}"
    2025-10-16 05:30:33.017 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.featureCode to -1
    2025-10-16 05:30:33.019 - info: dreamehome.0 (337825) Get listV2: Set 660831787.general.featureCode2 to 7
    2025-10-16 05:30:33.054 - info: dreamehome.0 (337825) Fetching obj_name: ali_dreame/CG304178/660831787/9
    2025-10-16 05:30:33.097 - info: dreamehome.0 (337825) Get and update State value to: "13"
    2025-10-16 05:30:33.134 - info: dreamehome.0 (337825) Get and update Error value to: "0"
    2025-10-16 05:30:33.168 - info: dreamehome.0 (337825) Get and update Battery level value to: "100"
    2025-10-16 05:30:33.204 - info: dreamehome.0 (337825) Get and update Charging status value to: "1"
    2025-10-16 05:30:33.237 - info: dreamehome.0 (337825) Get and update Status value to: "14"
    2025-10-16 05:30:33.237 - info: dreamehome.0 (337825) =======> DH_NowStatus (S4P1) Set to : 14
    2025-10-16 05:30:33.272 - info: dreamehome.0 (337825) Get and update Cleaning time value to: "0"
    2025-10-16 05:30:33.310 - info: dreamehome.0 (337825) Get and update Cleaned area value to: "0"
    2025-10-16 05:30:33.347 - info: dreamehome.0 (337825) Get and update Suction level value to: "0"
    2025-10-16 05:30:33.379 - info: dreamehome.0 (337825) Get and update Water volume value to: "1"
    2025-10-16 05:30:33.413 - info: dreamehome.0 (337825) Get and update Water tank value to: "1"
    2025-10-16 05:30:33.449 - info: dreamehome.0 (337825) Get and update Task status value to: "0"
    2025-10-16 05:30:33.455 - info: dreamehome.0 (337825) =======> DH_NowTaskStatus (S4P7) Set to : 0
    2025-10-16 05:30:33.581 - info: dreamehome.0 (337825) Get and update Resume cleaning value to: "0"
    2025-10-16 05:30:33.614 - info: dreamehome.0 (337825) Get and update Carpet boost value to: "1"
    2025-10-16 05:30:33.767 - info: dreamehome.0 (337825) Get and update Cleaning paused value to: "0"
    2025-10-16 05:30:33.800 - info: dreamehome.0 (337825) Get and update Faults value to: "0"
    2025-10-16 05:30:33.860 - info: dreamehome.0 (337825) Get and update Relocation status value to: "0"
    2025-10-16 05:30:33.929 - info: dreamehome.0 (337825) Get and update Ai detection value to: "567"
    2025-10-16 05:30:33.971 - info: dreamehome.0 (337825) Get and update Cleaning mode value to: "134146"
    2025-10-16 05:30:34.002 - info: dreamehome.0 (337825) Get and update Upload map value to: "1"
    2025-10-16 05:30:34.034 - info: dreamehome.0 (337825) Get and update Self wash base status value to: "0"
    2025-10-16 05:30:34.066 - info: dreamehome.0 (337825) Get and update Customized cleaning value to: "0"
    2025-10-16 05:30:34.098 - info: dreamehome.0 (337825) Get and update Child lock value to: "0"
    2025-10-16 05:30:34.130 - info: dreamehome.0 (337825) Get and update Carpet sensitivity value to: "2"
    2025-10-16 05:30:34.165 - info: dreamehome.0 (337825) Get and update Tight mopping value to: "0"
    2025-10-16 05:30:34.226 - info: dreamehome.0 (337825) Get and update Y clean value to: "0"
    2025-10-16 05:30:34.289 - info: dreamehome.0 (337825) Get and update Carpet recognition value to: "1"
    2025-10-16 05:30:34.321 - info: dreamehome.0 (337825) Get and update Self clean value to: "1"
    2025-10-16 05:30:34.354 - info: dreamehome.0 (337825) Get and update Warn status value to: "101"
    2025-10-16 05:30:34.387 - info: dreamehome.0 (337825) Get and update Carpet avoidance value to: "2"
    2025-10-16 05:30:34.420 - info: dreamehome.0 (337825) Get and update Auto add detergent value to: "1"
    2025-10-16 05:30:34.453 - info: dreamehome.0 (337825) Get and update Capability value to: "-1"
    2025-10-16 05:30:34.486 - info: dreamehome.0 (337825) Get and update Save water tips value to: "0"
    2025-10-16 05:30:34.518 - info: dreamehome.0 (337825) Get and update Drying time value to: "2"
    2025-10-16 05:30:34.550 - info: dreamehome.0 (337825) Get and update Low water warning value to: "0"
    2025-10-16 05:30:34.582 - info: dreamehome.0 (337825) Get and update Auto mount mop value to: "0"
    2025-10-16 05:30:34.615 - info: dreamehome.0 (337825) Get and update Mop wash level value to: "1"
    2025-10-16 05:30:34.647 - info: dreamehome.0 (337825) Get and update Scheduled clean value to: "0"
    2025-10-16 05:30:34.678 - info: dreamehome.0 (337825) Get and update Quick command value to: "[]"
    2025-10-16 05:30:34.741 - info: dreamehome.0 (337825) Get and update Auto switch settings value to: "[{\"k\":\"AutoDry\",\"v\":1},{\"k\":\"CleanType\",\"v\":0},{\"k\":\"FillinLight\",\"v\":1},{\"k\":\"FluctuationConfirmResult\",\"v\":0},{\"k\":\"FluctuationTestResult\",\"v\":0},{\"k\":\"HotWash\",\"v\":1},{\"k\":\"LessColl\",\"v\":1},{\"k\":\"MaterialDirectionClean\",\"v\":0},{\"k\":\"MeticulousTwist\",\"v\":-1},{\"k\":\"MonitorHumanFollow\",\"v\":0},{\"k\":\"MopScalable\",\"v\":1},{\"k\":\"PetPartClean\",\"v\":0},{\"k\":\"SmartAutoMop\",\"v\":0},{\"k\":\"SmartAutoWash\",\"v\":0},{\"k\":\"SmartCharge\",\"v\":1},{\"k\":\"SmartDrying\",\"v\":0},{\"k\":\"SmartHost\",\"v\":0},{\"k\":\"StainIdentify\",\"v\":1},{\"k\":\"SuctionMax\",\"v\":0}]"
    2025-10-16 05:30:34.772 - info: dreamehome.0 (337825) Get and update Auto water refilling value to: "0"
    2025-10-16 05:30:34.803 - info: dreamehome.0 (337825) Get and update Mop in station value to: "0"
    2025-10-16 05:30:34.835 - info: dreamehome.0 (337825) Get and update Mop pad installed value to: "0"
    2025-10-16 05:30:35.167 - info: dreamehome.0 (337825) Get and update Object name value to: "ali_dreame/CG304178/660831787/0"
    2025-10-16 05:30:35.286 - info: dreamehome.0 (337825) Get and update Multi floor map value to: "1"
    2025-10-16 05:30:35.318 - info: dreamehome.0 (337825) Get and update Map list value to: "{\"obj_name\":\"ali_dreame/CG304178/660831787/9\",\"md5\":\"ca9f68dc50b24986a76e83c1d0617cf4\"}"
    2025-10-16 05:30:35.527 - info: dreamehome.0 (337825) Get and update Volume value to: "90"
    2025-10-16 05:30:35.591 - info: dreamehome.0 (337825) Get and update Voice change status value to: "{\"id\":\"DE\",\"state\":\"success\",\"progress\":100}"
    2025-10-16 05:30:35.652 - info: dreamehome.0 (337825) Get and update Timezone value to: "Europe/Berlin"
    2025-10-16 05:30:35.685 - info: dreamehome.0 (337825) Get and update Schedule value to: "3-0-07:45-0000000-0-1-0-9216-0;2-0-08:30-0000000-0-1-0-9728-0;4-0-10:30-0000000-0-1-0-8704-0;5-0-11:00-0111111-1-1-0-9216-0;1-0-12:00-0000000-0-1-0-9984-0"
    2025-10-16 05:30:35.806 - info: dreamehome.0 (337825) Get and update Main brush time left value to: "247"
    2025-10-16 05:30:35.837 - info: dreamehome.0 (337825) Get and update Main brush left value to: "82"
    2025-10-16 05:30:35.868 - info: dreamehome.0 (337825) Get and update Side brush time left value to: "147"
    2025-10-16 05:30:35.898 - info: dreamehome.0 (337825) Get and update Side brush left value to: "73"
    2025-10-16 05:30:35.930 - info: dreamehome.0 (337825) Get and update Filter left value to: "65"
    2025-10-16 05:30:35.959 - info: dreamehome.0 (337825) Get and update Filter time left value to: "97"
    2025-10-16 05:30:36.141 - info: dreamehome.0 (337825) Get and update Auto dust collecting value to: "1"
    2025-10-16 05:30:36.252 - info: dreamehome.0 (337825) Get and update Dust collection value to: "1"
    2025-10-16 05:30:36.288 - info: dreamehome.0 (337825) Get and update Auto empty status value to: "0"
    2025-10-16 05:30:36.320 - info: dreamehome.0 (337825) Get and update Sensor left value to: "28"
    2025-10-16 05:30:36.351 - info: dreamehome.0 (337825) Get and update Sensor time left value to: "8"
    2025-10-16 05:30:36.420 - info: dreamehome.0 (337825) Get and update Mop pad left value to: "93"
    2025-10-16 05:30:36.450 - info: dreamehome.0 (337825) Get and update Mop pad time left value to: "74"
    2025-10-16 05:30:36.540 - info: dreamehome.0 (337825) Get and update Detergent left value to: "31"
    2025-10-16 05:30:36.572 - info: dreamehome.0 (337825) Get and update Detergent time left value to: "5"
    2025-10-16 05:30:36.722 - info: dreamehome.0 (337825) Get and update Stream status value to: "{\"operType\":\"end\",\"operation\":\"monitor\",\"result\":0,\"status\":0}"
    2025-10-16 05:30:36.930 - info: dreamehome.0 (337825) Get and update Camera light value to: "0"
    2025-10-16 05:30:37.226 - info: dreamehome.0 (337825) Get OTCInfo: Set 660831787.general.otcInfo.partner_id to ""
    2025-10-16 05:30:37.229 - info: dreamehome.0 (337825) Get OTCInfo: Set 660831787.general.otcInfo.params.hw_ver to "Linux"
    2025-10-16 05:30:37.232 - info: dreamehome.0 (337825) Get OTCInfo: Set 660831787.general.otcInfo.params.fw_ver to "4.3.9_3407"
    2025-10-16 05:30:37.235 - info: dreamehome.0 (337825) Get OTCInfo: Set 660831787.general.otcInfo.params.ap.siid to "2.4G"
    2025-10-16 05:30:37.238 - info: dreamehome.0 (337825) Get OTCInfo: Set 660831787.general.otcInfo.params.ap.bssid to "9c:05:d6:20:ac:49"
    2025-10-16 05:30:37.240 - info: dreamehome.0 (337825) Get OTCInfo: Set 660831787.general.otcInfo.params.ap.rssi to -61
    2025-10-16 05:30:37.242 - info: dreamehome.0 (337825) Get OTCInfo: Set 660831787.general.otcInfo.params.netif.localIp to "192.168.0.27"
    2025-10-16 05:30:37.244 - info: dreamehome.0 (337825) Get OTCInfo: Set 660831787.general.otcInfo.params.netif.mask to "255.255.255.0"
    2025-10-16 05:30:37.248 - info: dreamehome.0 (337825) Get OTCInfo: Set 660831787.general.otcInfo.params.netif.gw to "192.168.0.1"
    2025-10-16 05:30:37.252 - info: dreamehome.0 (337825) Get OTCInfo: Set 660831787.general.otcInfo.params.model to "dreame.vacuum.r2228o"
    2025-10-16 05:30:37.370 - info: dreamehome.0 (337825) [SUCCESS] Received data: {"mapstr":[{"id":1,"name":"","angle":"0","map":"eF7tvVmzomq-oJ916uSH6Nu8TiJARusOkNGBUUVOVBCCgICiIjJ4...
    2025-10-16 05:30:37.954 - info: dreamehome.0 (337825)
    - Threshold: 300 MB
    - Interval: 5 sec
    - Priority: medium
    [Runtime States]
    - Current Heap: 58.92 MB
    - Heap Status: OK
    [Restart Manager]
    [Process Metrics]
    - Heap Used: 61.71 MB
    - RSS: 152.72 MB
    - Uptime: 0h 0m 6s
    2025-10-16 05:30:37.956 - info: dreamehome.0 (337825) Die aktuell eingestellte Standard-Kartennummer ist eingestellt auf 1
    2025-10-16 05:30:37.998 - warn: dreamehome.0 (337825) No rooms found in DH_Map.
    2025-10-16 05:30:38.000 - warn: dreamehome.0 (337825) CustomMap is not set to 1.
    2025-10-16 05:30:38.001 - info: dreamehome.0 (337825) Alexa ist aktiv, und der Roboter akzeptiert Sprachbefehle. Du kannst einfach sagen: "Alexa, Hilfe für den Roboter" oder "Alexa, Unterstützung für den Staubsauger" oder "Alexa, Anleitung für den Saugroboter" oder "Alexa, Assistenz für den Reinigungsroboter".
    2025-10-16 05:30:38.003 - info: dreamehome.0 (337825) Speak on both voice and input - Alexa will speak.
    2025-10-16 05:30:38.009 - info: dreamehome.0 (337825) Restored water level: 4500ml (from tankPercent: 100%)
    2025-10-16 05:30:38.083 - info: dreamehome.0 (337825) Connection to MQTT successfully established
    wawyoW Offline
    wawyoW Offline
    wawyo
    schrieb am zuletzt editiert von wawyo
    #67
    @hahne
    Laut deinem Log
    stürzt der Adapter im folgenden Abschnitt ab:
    ${wallsInfo.doors.map(door => {
        const [x1, y1] = toCanvas(door.beg_pt_x, door.beg_pt_y);
        const [x2, y2] = toCanvas(door.end_pt_x, door.end_pt_y);
        return `
            <svg class="door" style="position:absolute;top:0;left:0;width:100%;height:100%;pointer-events:none">
                <line x1="${x1}" y1="${y1}" x2="${x2}" y2="${y2}"
                      stroke="#ffffff" stroke-width="6" stroke-dasharray="8,4"/>
            </svg>`;
    }).join('')}
    Der Fehler tritt auf, weil wallsInfo.doors in deiner Map nicht vorhanden ist.
    Wenn der Sauger keine Türeninformationen liefert, ist doors einfach undefined, und der Aufruf von .map() führt zum Absturz.
    Zum Vergleich: Im Abschnitt für die Teppiche passiert das nicht, da dort mit Object.entries(elements.carpets) gearbeitet wird, was auch funktioniert, wenn keine Teppiche vorhanden sind.
    Das deutet also darauf hin, dass in deiner aktuellen Karte keine Türdaten enthalten sind.
    Schau bitte in der Dreame Home App unter Karten anzeigen ? 3D-Karte, ob dort Türen dargestellt werden.
    Wenn keine zu sehen sind, liefert der Sauger diese Informationen schlichtweg nicht an die API.
    Ich werde den Code in der nächsten Version des Adapters entsprechend absichern, damit der Abschnitt nur ausgeführt wird, wenn wallsInfo.doors auch wirklich existiert.
    Dann läuft der Adapter auch weiter, wenn keine Türen-Daten in der Map enthalten sind.
    • L ltsalvatore
      über die einzelnen Datenpunkte kann ich aktuell zwar Start, Stop und Pause für die allgemeine Reinigung ausführen, aber ich habe noch nicht herausgefunden, wie ich mit dem Adapter (v1.0.0) gezielt einzelne Räume ansteuern kann.
      Unter dreamehome.0.xxx.map.0 sind die einzelnen Zimmer aufgelistet, dort finden sich auch die entsprechenden RoomIDs. Allerdings finde ich keine Dokumentation, welche Befehle es dafür gibt und wo beziehungsweise in welcher Form man diese eintragen muss, um einzelne Zimmer oder mehrere nacheinander zu reinigen.
      Und eine letzte Frage: Wenn ich einfach den Start-Befehl auswähle, welche Art der Reinigung wird dann genau ausgelöst?
      Vielen Dank schon einmal für eure Hilfe!
      wawyoW Offline
      wawyoW Offline
      wawyo
      #68
      @ltsalvatore
      Um eine gezielte Raumreinigung zu starten, hast du aktuell drei Möglichkeiten:
      1. Über den Map-Ordner
      a. Gehe in dreamehome.0.xxxxx.map.0.<Raumname> und passe dort die gewünschten Reinigungseinstellungen (z. B. Saugleistung, Wischintensität, Durchgänge) an.
      b. Setze anschließend dreamehome.0.xxxxx.map.0.<Raumname>.Cleaning auf true.
      c. Wiederhole das für alle Räume, die du reinigen möchtest.
      d. Starte die Reinigung, indem du dreamehome.0.xxxxx.map.StartCleaningByRoomConfig auf true setzt.
      2. Über die VIS-Oberfläche
      a. Räume direkt in der VIS-Karte auswählen (durch Anklicken).
      b. Im Menü die gewünschten Einstellungen ändern.
      c. Unter dem Reinigungsmenü „Selected“ auswählen, um die gewählten Räume zu starten.
      3. Über natürliche Sprache
      Du kannst auch Sprachbefehle über den Datenpunkt
      dreamehome.0.xxxxx.control.NaturalLanguageCommand
      verwenden.
      Beispiel:
      Wohnzimmer stark saugen und Küche feucht wischen
      L 1 Antwort Letzte Antwort
      • M MrHenker27
        ein noch viel größerer BUG ist:
        das der Falsche Robby angesprochen wird.
        meiner hat die ID mit 9x der mit mir geteilte hat eine mit 8x beginnend.
        Bei einem Aufruf des Testsounds ertönt dieser beim ersten, also bei der 8x ! genau so auch beim Befehl zu saugen oO
        wawyoW Offline
        wawyoW Offline
        wawyo
        #69
        @mrhenker27
        Wenn du zwei Roboter hast, brauchst du auch zwei Instanzen des Adapters.
        Bitte konfiguriere in jeder Instanz unter den Einstellungen den Punkt „Bevorzugter Geräteindex“ – dort kannst du festlegen, welcher Roboter von dieser Instanz angesprochen werden soll.
        So stellst du sicher, dass Befehle wie Testsound oder Reinigung starten immer an den richtigen Roboter gesendet werden.
        • M muuulle
          @mrhenker27 said in Test DreameHome: 3D-Visualisierung und Alexa-Steuerung:
          der DP dreamehome.0.xxxxxxxxx.vis.vishtml0 bleibt bei mir leer.
          Moin zusammen,
          bei mir auch (L10s Ultra Heat).
          Vielen Dank für den Adapter
          wawyoW Offline
          wawyoW Offline
          wawyo
          #70
          @muuulle
          Bitte ändere den Datenpunkt dreamehome.0.xxxxx.map.MapNumber auf die richtige Map-Nummer (die deiner aktuellen Karte entspricht).
          Danach setze dreamehome.0.xxxxx.map.NewMap auf true, damit die Karte neu geladen wird.
          Dadurch werden die Daten unter dreamehome.0.xxxxx.vis.vishtml0 generiert und stehen anschließend in der VIS zur Verfügung.
          • wawyoW wawyo
            @muuulle
            MrHenker27
            #71
            @wawyo said in Test DreameHome: 3D-Visualisierung und Alexa-Steuerung:
            @muuulle
            bei mir kann ich nur Map 1 (0) auswählen. Da läd er aber keine Daten, da meiner Meinung nach 0 die falsche ist.
            bei dem anderen Dreme Adapter habe ich MAP 2 .....
            wawyoW 1 Antwort Letzte Antwort
            • M MrHenker27
              @muuulle
              wawyoW Offline
              wawyoW Offline
              wawyo
              #72
              @muuulle
              Bitte trotzdem Map 2 auswählen, dann mit „Wert Setzen“ bestätigen, und danach nochmal auf Map 1 ändern, nachdem der Adapter versucht hat, die Daten herunterzuladen.
                MrHenker27
                schrieb am zuletzt editiert von MrHenker27
                #73
                würd ich gerne aber ich habe nur MAP 1
                • M MrHenker27
                  wawyoW Offline
                  wawyoW Offline
                  wawyo
                  #74
                  @mrhenker27
                  Bitte den Log umgehend löschen, da sensible Daten enthalten sind. Ich melde mich gleich.
                  • wawyoW wawyo
                    @mrhenker27
                    MrHenker27
                    #75
                    @mrhenker27
                    erledigt. Dachte ich hatte alles erwischt ;)
                    • M MrHenker27
                      @mrhenker27
                      wawyoW Offline
                      wawyoW Offline
                      wawyo
                      #76
                      @mrhenker27
                      Bitte öffne dreamehome.0.xxxxx.map.MapNumber und schaue nach, was dort unter den States für die verfügbaren Maps steht.
                      • wawyoW wawyo
                        @mrhenker27
                        MrHenker27
                        #77
                        @wawyo
                        ich habe auch schon mal per Hand doe Werte nachgetragen, er springt immer wieder auf Map 1 (0) zurück
                        admin.0
                        	2025-10-28 13:13:12.603	warn	Object dreamehome.0.9xxxxxxxx.map.MapNumber is invalid: Default value has to be type "number" but received type "string" This will throw an error up from js-controller version 7.0.0!
                        dreamehome.0
                        	2025-10-28 13:15:59.593	warn	CustomMap is not set to 1.
                        dreamehome.0
                        	2025-10-28 13:15:59.551	warn	No rooms found in DH_Map.
                        dreamehome.0
                        	2025-10-28 13:15:59.470	warn	Invalid map number, reset to default
                        dreamehome.0
                        	2025-10-28 13:15:59.428	info	State value to set for "dreamehome.0.9xxxxxxxxmap.MapNumber" has to be type "sumber" but received type "string"
                        dreamehome.0
                        	2025-10-28 13:15:59.419	info	[SUCCESS] Received data: {"mapstr":[{"id":0,"name":"","angle":"180","map":"e ..
                        • M MrHenker27
                          @wawyo
                          admin.0
                          dreamehome.0
                          dreamehome.0
                          dreamehome.0
                          dreamehome.0
                          dreamehome.0
                          wawyoW Offline
                          wawyoW Offline
                          wawyo
                          #78
                          @mrhenker27
                          Stimmt, ich habe das Verhalten in Version 0.1.6 geändert, sodass überflüssige Daten jetzt automatisch korrigiert werden.
                          Wir machen jetzt Folgendes: Bitte gehe in die App und erstelle zusätzlich zu deiner ursprünglichen Karte eine neue Map. Der Zweck ist, dass wir erzwingen, dass mehrere Maps unter der Cloud angelegt werden.
                          Danach teste es bitte nochmal.
                          • wawyoW wawyo
                            @mrhenker27
                            MrHenker27
                            #79
                            @wawyo
                            gemacht. Ich habe zwar jetzt MAP die Ordner 0 und 1 aber außer dreamehome.0.xxxxxxxx.map.Y.MapImage mit den passenden Bild is da mehr nicht drin :(
                            die VISHTMLs bleiben auch leer.
                            das passiert wenn ich dann newmapa uf true setze ( danach darf ich den Adapter dann neu starten )
                            host.iobroker
                            	2025-10-28 13:49:34.992	warn	Do not restart adapter system.adapter.dreamehome.0 because restart loop detected
                            host.iobroker
                            	2025-10-28 13:49:34.992	error	instance system.adapter.dreamehome.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            dreamehome.0
                            	2025-10-28 13:49:34.447	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            dreamehome.0
                            	2025-10-28 13:49:34.447	info	terminating
                            dreamehome.0
                            	2025-10-28 13:49:34.447	info	Memory manager stopped
                            dreamehome.0
                            	2025-10-28 13:49:34.447	info	Resource monitoring stopped
                            dreamehome.0
                            	2025-10-28 13:49:34.447	info	Resource monitor stopped
                            dreamehome.0
                            	2025-10-28 13:49:34.447	info	Cleaning up resources...
                            dreamehome.0
                            	2025-10-28 13:49:34.446	error	Cannot read properties of undefined (reading 'map')
                            dreamehome.0
                            	2025-10-28 13:49:34.445	error	TypeError: Cannot read properties of undefined (reading 'map') at Dreamehome.DH_GenerateMap (/opt/iobroker/node_modules/iobroker.dreamehome/lib/generateMap.js:2032:39) at async Dreamehome.onStateChange (/opt/iobroker/node_modules/iobroker.dreamehome/main.js:7345:11)
                            dreamehome.0
                            	2025-10-28 13:49:34.444	error	unhandled promise rejection: Cannot read properties of undefined (reading 'map')
                            dreamehome.0
                            	2025-10-28 13:49:34.444	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            dreamehome.0
                            	2025-10-28 13:49:34.443	error	Error: Cannot read properties of undefined (reading 'map')
                            • M MrHenker27
                              @wawyo
                              host.iobroker
                              host.iobroker
                              dreamehome.0
                              dreamehome.0
                              dreamehome.0
                              dreamehome.0
                              dreamehome.0
                              dreamehome.0
                              dreamehome.0
                              dreamehome.0
                              dreamehome.0
                              dreamehome.0
                              dreamehome.0
                              wawyoW Offline
                              wawyoW Offline
                              wawyo
                              #80
                              @mrhenker27
                              Lade die folgende Datei herunter ( extracktdreameMap.html und pako.js ) und führe die DreameHome JSON Dekompressor.html per Doppelklick aus. Anschließend den Inhalt des Objekts dreamehome.0.xxxxx.map.CloudData entschlüsseln, indem du ihn in „Base64-String eingeben:“ kopierst, um zu prüfen, ob die Struktur wie im Screenshot vorhanden ist.
                              • wawyoW wawyo
                                @mrhenker27
                                MrHenker27
                                #81
                                dreamehome.0.9xxxxxxxx.map.CloudData
                                {"mapstr":[{"id":1,"name":"","angle":"0","map":"eF7tmE2OI0UQhatrzSm8ns30cm7AGdBoFtCglqBBgGAx8sJxkFmzZ8tx2HAJhCP_42VEZVaW22UN_jT-qch4L95k2WW3v5im6cvJ8e_Dw_Tn9Dh9mo7TH3__9Y-v3rnzeUIMFveiikLzPLuEvHAqkX3XgGiGeJyOA57_ndM9ZPZIx0nqSkh32jsdh5EVn44DinC3l64Mt0s6jlFXbiidfFvkdLMId6F04XKgoHW4dIJXTpftJTkdH8Cixs7p3J3N1dOlk8e3uTyNCtdNR-4CQi6Zv5SIl1nFVdPNmIU4r6hIrpsOOYdds3cAzu2DcMgSK9IB10i3CAYS3NMtgoEEe6eDbwHAvunOl5sTJirZMx1fCsX39ood0_nvMydMVLJbOrdxU07H194iVyjC2E4Ih60kZivSTVOZKxVHIBy3juKb8ikHKXOl4giE89aQN27S0oWP2J3SyT8xcjqfJ370n85Ph9MtfrIvI8KV7wr_kBb4N4yycw3UBQZzCJ-Y7hzM34vV7VQRzBXcNwauJOPbZYAZFtLBvgXiOe3cuvLc4FoNZogSqk6stndTPLn96Rp2kqJbSLDOqHb-ChLARYVgxbf2HnJbyep0q-Ak6Aq_0ggIOl813fnVwg-Vrbl_VLXqdcaw6Idmv1Fg6_7yw14HC0SrUWd0hxUQu_Aj4f4Z3mR0YZ3RHVZAzmZyRtJa966uG4vp2m-yZcj7uOezHK16io6yq1qYOV14FBYrCHoXD38TwV5GthRd1cKc0m3eu3nyvyaVKJ78bgFSV7VSpBs9xV5fWGUUK2yZZTrCtapQmnWQ9dW-KFbQweR0DrkmD1XLRZIevdXTUDYEZBe8r8QRF0Rzm6j3v2EWdqpRXk5AH4k1ccQF2dwk6dFJNYIe5ip7VzmpRtDDFH2v-brLHv4YOyfcGU-ZDtcqNNMlCA0imhFh03xPp4FGfEzYNN9MOuVFzuyULqE15qOOdJSf5eYustJCTZfpSddPNlt0zJwVToj1QEe6jOkSGEnnPuSwHEmG9n8g02rBzSNsqCinKu7ufCxt7ipWpyvRI1woGbMpnc7lwr1GugtyTzfOPd0493Q96Jeh_006P0Ads_DxQVgouVI6961AAzslmM4GlWuAKRnCTompQwiVSJ0_V8wpqUPH1CGEyjIOP7uJdOXJzhSOGuYUwk6JqUNIEcRaE3MKYafE1CGkCGKtiTmFsFNi6hBSBLHWxJxC2CkxdQgpglhrYk4h7JSYOoQUQaw1MacQL_KdjqlDSBHEWhNzCvEi3-mYOoQUQaw1MafQvHg9MnUIKYJY8wviSFbMKcQrdj5Th5AiiDW_II5kpTUlNQItXYIUQaw1aU0hFARaugQpglhr0ppCKAi0dAlSBLHWpDWFUBBo6RKkCGKtSWsKoSDQ0iVIEcRak9YUQkGgpUuQIoi1Fs0hhIpAUxghRRBrLZpDCBWBpjBCiiDW3AV_iUKjkoyApjBCiiDW-l0MkhHQ7UuKINb6XQySEdDtS4og1vpdDJIR0O1LiiDW-l0MkhHQ7UuKINb6XQySEdDtS4og1vpdDJIR0O1LiiDW-l0MkhHQ7Ru_rN1mOudAt5uuvu7TehedZARs8qWLuEz3dFtIRsAmX7qIy7SQrn6t90PJBVdWkoxKiG98N2jvpOPyTDJCbjudZ8yeNqkLopHBmD9tUhdEI4Mxf4rq8TeWJxoZjFlTkg9beJKRzpg1JfmwhScZ6YxZ03YLjzCqGbOm7RYeYRSgfD9m7Q0CYxYeYRSg4in2dxE_Bre_Zxtg_53PiI-H334_vPt4-P755enw7qv3bw4_P339q3_2w48_8ZPjm8MvT999eH75lhvf8t3L0_OH52_Oi4-8-ihKb98fj8f_AHhVxvQ="},{"id":0,"name":"","angle":"180","map":"eF7t2M9u2zYAx3E5iV9EZxmIZLtOC_TaopcN27AWRRAUS-t1xmIn2IKtRZEDbelBdtu179TLLgP2BiMlkSJ_oizqjyUl5RdBIIum-IHkyHaOHMd54cT9N5o6n53A-cu5c_7-8u8_yV6b7eEX8nCglzSU8OSE_tBfbP9WSnlWVyWU_K64kPqORD0J9wJlHxUqT-sqxikGyr4hAlXf8IAn9wvY3iUWNzKjGDC358DAbAVMXt2gYmCj-2KI62Qp56e8YqDT5ISGuI6IvjeEsGtvxUD0VirEdUTqK6y8zoFV0wC3R1v5Ya1CXKd2Mo_dCJW3vuEBIQs0CE1KFmgQmpR6B4bwcRDrGUhv6fSet69egYzHPhEgSq5PIP-et-UWHbU_YHL6WFthkWVpvQGlr8lbYeFbUj0Bs9Pn5IHpN_i07HkVC3HRCqn_ZQBgA5NSGOKy5qnfnwQw-SNpyceEUpGcMjBWSwaVA3EgdyqD7ZRTiAEckcZE7JXWGxAGxjog3KtNXoM7ORzMFxUhcgNjPVC9AZoAj7MMhFERIjcw1gOTa8x-md1ZdjLwuPxcRkWI3MBYD6ya4ssaOrDQl3f0BCy8zFERIjdAi1oQ7tCW1RyYDrI7ZHaEiu0AJW_jc51kLZ2hCBixCZ0CQVAClIpqXm9ZxFDyNj7XqXwGlVoD8l0aYN7XITC-ZWcP9UBctEug9DaS7KwIjHAEauU1uJPf-gyBxqeQ_UkrRzMq88SmzKe9T0e4aJwTLxzhbk1NgZQnHqu--D4W39R0Fe3P1RQop57B9PjKajVqE6iewvT4ymo1OjSwcYcDGr_K9vcVA1u6xu0Cea2dPwokZaFvD5DHgLhQ3SIy2t_DBBa-gVQvQhBWD9j8Bi1CEFYHeIyLNAlBmAWWhSDMAstCEGaBZSEIs8CyEIRZYFkIwjoDsi_pughBkpoGWFwjIK6TRlAE5YHF3Utgdq2knbo6BbJPrGrIydctMNsXIaQoC3QsUJ8F8u4vMAldot6BSQRdoqEACcJ4AwEWn0IL5FmgY4H6vh4gfoTNlc3RRRDGaw-Y7asTQRjPAg0jCONZoGEEYTwLNIwgjPcggbvBAnnSvkEBdVmgBRpGEMZLvzeTutCDA0fpN9LhApPqnsHsf6uHBuIEw4TPAnGCYRIwakQkKIJqAzPhGMcqRVAE1f0jUU4hjlWJoAgiI5xhWFfAUd2rLF1jHKoUQU6umhc58x0ciFPMMv_fwf7EW25xOMX2IPvk_vGn--STe7XaLN0n5-cTf7GYeZO5P_e9iR_Mz-LtxYV3PgkWs1P66HQ69ybBNN2OR_wgoPtm82BBR-g-bzJ9_Ci4uPDc35Zvb-lh6db6-oZt3Hnu78v3b1abn9mqU_br9uMNXfrUc1ebd8sP8dbmpzXd5f4YfHN9-fzZerm-ur189fKjS0eWqzerd_RIc3aoQDd_KuZ_t372qzxnxubMdHMCMef79Qf_7funT-V5gRev5utmzsTMH86-PXsd_HKVU85183wx72Xw-Ppyc3Nz-cq_wpV9b-pR9d3d_5BLD9I="}],"curr_id":2}
                                {"mapstr":[{"id":1,"name":"","angle":"0","map":"xyz"},{"id":0,"name":"","angle":"180","map":"abc"}],"curr_id":2}
                                • M MrHenker27
                                  wawyoW Offline
                                  wawyoW Offline
                                  wawyo
                                  #82
                                  @mrhenker27
                                  Hier ist die entschlüsselte Information:
                                      "id": 1,
                                      "name": "",
                                      "angle": "0",
                                      "map": {
                                        "vw": {
                                          "line": [],
                                          "rect": [],
                                          "mop": []
                                        "seg_inf": {
                                          "1": { "nei_id": [2] },
                                          "2": { "nei_id": [1] }
                                      "id": 0,
                                      "name": "",
                                      "angle": "180",
                                      "map": {
                                        "vw": {
                                          "line": [
                                            [-1774, -5151, -1258, -5157],
                                            [-2740, -5035, -2340, -5037],
                                            [-1225, -4527, -2037, -3962]
                                          "rect": [],
                                          "mop": []
                                        "seg_inf": {
                                          "1": { "type": 0, "index": 4, "name": "S8O8Y2hl", "nei_id": [5] },
                                          "2": { "type": 0, "index": 3, "name": "QmFk", "nei_id": [4] },
                                          "3": { "type": 0, "index": 0, "name": "U2NobGFmemltbWVy", "nei_id": [5] },
                                          "4": { "type": 0, "index": 2, "name": "Rmx1cg==", "nei_id": [2, 5] },
                                          "5": { "type": 0, "index": 1, "name": "V29obnppbW1lcg==", "nei_id": [1, 3, 4] }
                                  Mir ist aber aufgefallen, dass der Abschnitt
                                  "whm": "",
                                  "walls_info": {
                                    "version_flag": 3,
                                    "storeys": [
                                        "rooms": [
                                  fehlt.
                                  Das deutet darauf hin, dass dein Roboter die Daten in der Cloud anders speichert. Ich werde das weiter analysieren, um herauszufinden, wie ich es schaffen kann, dass die kompletten Dateien heruntergeladen werden.
                                  Ich kann zwar nichts versprechen, aber es ist nur eine Frage der Zeit, bis ich eine Lösung gefunden habe.
                                  An alle:
                                  Wenn jemand Probleme mit der Map hat, bitte zuerst die Datei „DreameHome JSON Dekoder.zip“ herunterladen und – wie oben beschrieben – zuerst testen, bevor ihr weiterarbeitet oder Fehler meldet.
                                  • wawyoW wawyo
                                    @mrhenker27
                                        "id": 1,
                                        "name": "",
                                        "angle": "0",
                                        "map": {
                                          "vw": {
                                            "line": [],
                                            "rect": [],
                                            "mop": []
                                          "seg_inf": {
                                        "id": 0,
                                        "name": "",
                                        "angle": "180",
                                        "map": {
                                          "vw": {
                                            "line": [
                                            "rect": [],
                                            "mop": []
                                          "seg_inf": {
                                    "whm": "",
                                    "walls_info": {
                                      "version_flag": 3,
                                      "storeys": [
                                          "rooms": [
                                    fehlt.
                                    An alle:
                                    MrHenker27
                                    #83
                                    @wawyo
                                    Ich hoffe du findest schnell ne Lösung. Aber die IDs passen, ich habe 5 Räume.
                                    Ist ein dreame D10 Plus Gen 2 falls die Info dir weiter hilft.
                                    • wawyoW wawyo
                                      @ltsalvatore
                                      verwenden.
                                      Beispiel:
                                      ltsalvatore
                                      #84
                                      @wawyo sagte in Test DreameHome: 3D-Visualisierung und Alexa-Steuerung:
                                      @ltsalvatore
                                      verwenden.
                                      Beispiel:
                                      Danke, dass du dir die Zeit genommen hast, mir das etwas genauer zu erklären. Ich denke, damit kann ich mein Vorhaben nun umsetzen.
                                      Nur der Vollständigkeit halber:
                                      Wenn ich z. B. Küche und Wohnzimmer reinigen möchte, setze ich für beide zuerst den Datenpunkt cleaning auf true und starte anschließend mit StartCleaningByRoomConfig die Reinigung der beiden Räume? So könnte ich das Ganze in einem Script hinterlegen und mit einem extra erstellten Objekt über einen physischen Schalter verknüpfen!?
                                      Den NaturalLanguageCommand finde ich auch ganz interessant. Spricht dieser Datenpunkt quasi den von Dreame integrierten Sprachassistenten an? Ich frage mich gerade, wie ich das nutzen kann, um über Alexa die Befehle auszuführen. Braucht man dafür einen extra Alexa-Skill und ein Startwort, so wie bei Dreame mit „OK Dreame“?
                                      • L ltsalvatore
                                        @ltsalvatore
                                        verwenden.
                                        Beispiel:
                                        wawyoW Offline
                                        wawyoW Offline
                                        wawyo
                                        #85
                                        @ltsalvatore
                                        Ja, genau so ist es 👍
                                        Wenn du z. B. Küche und Wohnzimmer reinigen möchtest, setzt du für beide zuerst den Datenpunkt
                                        ...map.0.<Raumname>.Cleaning = true
                                        und startest anschließend mit
                                        ...map.StartCleaningByRoomConfig = true
                                        die Reinigung der beiden Räume.
                                        Zu den Sprachbefehlen:
                                        Das Ganze läuft bei mir über meinen eigenen Code, der auf alle von mir gepflegten Synonyme reagiert.
                                        Ich habe dazu eine ausführliche Anleitung geschrieben:
                                        👉 Anleitung: Sprachbefehle für deinen Dreame Robot Sauger
                                        Wichtig ist, dass du den Alexa-Adapter installiert hast.
                                        Frag einfach mal „Alexa, Roboter Hilfe“ – ich habe den Adapter mit möglichst vielen Infos gefüttert, damit er eigenständig viele Fragen beantworten kann.
                                        Danach kannst du einfach loslegen mit deinen Befehlen im NaturalLanguageCommand-Objekt oder noch einfacher direkt über Alexa.
                                          MrHenker27
                                          #86
                                          moin moin,
                                          was ich bei dem anderem Dreame Adapter noch gesehen habe:
                                          unter "status" sind noch folgende Werte abrufbar:
                                          total-clean-times
                                          total-clean-time
                                          total-clean-area
                                          first-clean-time gibt es auch noch, der muss aber nicht wirklich sein. Ggf. kannst du die Werte ja einbauen. Leider zeigt bei mir CurrentRoomCleaningName und CurrentRoomCleaningNumber nichts an. Liegt wohl bei mir an der nicht lesbaren Karte.
                                          Die Raumreiniegung starte ich über StartCustom
                                           [                 {                     "piid": 1,                     "value": 18                 },                 {                     "piid": 10,                     "value": "{\"selects\":[[XXX,1,1,2,1]]}"                 }             ]
                                          wobei XXX dann die Raum ID ist. Wiederholungen, Saugleistung und Saugen oder wischen lässt sich beim D10 Plus GEN2 nicht übertragen. Da nimmt er die Werte, welche in der APP als "standart" hinterlegt sind.
