  4. npm error bei "iob diag" nach Upgrade auf Debian 13 Trixie
    6.5k
35 Beiträge 3 Kommentatoren 2.3k Aufrufe 3 Beobachtet
    @meute
    Das ist kein Log, das ist Quark.
    Das log kann man sich per
    iob logs
    anschauen.
    meuteM Offline
    meuteM Offline
    meute
    @thomas-braun sagte in npm error bei "iob diag" nach Upgrade auf Debian 13 Trixie:
    iob logs
    anschauen.
    Dann hier das richtige Log mit iob logs.
    2025-10-13 12:08:50.391  - info: host.iobroker84 stopInstance system.adapter.echarts.0 (force=false, process=true)
    2025-10-13 12:08:50.399  - info: echarts.0 (1850) Got terminate signal TERMINATE_YOURSELF
    2025-10-13 12:08:50.441  - info: host.iobroker84 stopInstance system.adapter.echarts.0 send kill signal
    2025-10-13 12:08:50.918  - info: echarts.0 (1850) terminating
    2025-10-13 12:08:50.919  - info: echarts.0 (1850) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-10-13 12:08:51.441  - info: host.iobroker84 stopInstance timeout system.adapter.echarts.0 killing pid 1850
    2025-10-13 12:08:51.478  - info: host.iobroker84 instance system.adapter.echarts.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-10-13 12:08:54.802  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 3802
    2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
    2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]:   throw err;
    2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]:   ^
    2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
    2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]: Require stack:
    2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
    2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
    2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
    2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
    2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
    2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
    2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
    2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
    2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
    2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
    2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
    2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
    2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
    2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]:   ]
    2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]: }
    2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
    2025-10-13 12:08:55.729  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-10-13 12:08:55.729  - info: host.iobroker84 Adapter system.adapter.echarts.0 needs rebuild and will be restarted afterwards.
    2025-10-13 12:08:55.730  - info: host.iobroker84 system.adapter.echarts.0 will be rebuilt
    2025-10-13 12:08:55.730  - warn: host.iobroker84 adapter "echarts" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
    2025-10-13 12:08:55.731  - info: host.iobroker84 iobroker rebuild
    2025-10-13 12:08:56.624  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules ...
    2025-10-13 12:09:14.147  - info: admin.0 (1598) ==> Connected system.user.admin from ::ffff:192.168.23.27
    2025-10-13 12:09:20.769  - info: host.iobroker84 iobroker npm-rebuild: rebuilt dependencies successfully
    2025-10-13 12:09:20.796  - info: host.iobroker84 iobroker npm-rebuild:
    2025-10-13 12:09:20.797  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules done
    2025-10-13 12:09:21.809  - info: host.iobroker84 iobroker npm-rebuild: exit 0
    2025-10-13 12:09:22.198  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4060
    2025-10-13 12:09:23.079  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
    2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:   throw err;
    2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:   ^
    2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
    2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]: Require stack:
    2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
    2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
    2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
    2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
    2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
    2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
    2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
    2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
    2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
    2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
    2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
    2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
    2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
    2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:   ]
    2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]: }
    2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
    2025-10-13 12:09:23.081  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-10-13 12:09:23.081  - info: host.iobroker84 Adapter system.adapter.echarts.0 needs rebuild and will be restarted afterwards.
    2025-10-13 12:09:23.082  - info: host.iobroker84 system.adapter.echarts.0 will be rebuilt
    2025-10-13 12:09:23.082  - warn: host.iobroker84 adapter "echarts" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
    2025-10-13 12:09:23.082  - info: host.iobroker84 iobroker rebuild
    2025-10-13 12:09:23.972  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules ...
    2025-10-13 12:09:40.440  - info: host.iobroker84 iobroker npm-rebuild: rebuilt dependencies successfully
    2025-10-13 12:09:40.469  - info: host.iobroker84 iobroker npm-rebuild:
    2025-10-13 12:09:40.469  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules done
    2025-10-13 12:09:41.482  - info: host.iobroker84 iobroker npm-rebuild: exit 0
    2025-10-13 12:09:41.861  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4306
    2025-10-13 12:09:42.771  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
    2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:   throw err;
    2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:   ^
    2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
    2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]: Require stack:
    2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
    2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
    2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
    2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
    2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
    2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
    2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
    2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
    2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
    2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
    2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
    2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
    2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
    2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:   ]
    2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]: }
    2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
    2025-10-13 12:09:42.773  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-10-13 12:09:42.773  - info: host.iobroker84 Adapter system.adapter.echarts.0 needs rebuild and will be restarted afterwards.
    2025-10-13 12:09:42.773  - info: host.iobroker84 system.adapter.echarts.0 will be rebuilt
    2025-10-13 12:09:42.773  - warn: host.iobroker84 adapter "echarts" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
    2025-10-13 12:09:42.774  - info: host.iobroker84 iobroker rebuild
    2025-10-13 12:09:43.649  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules ...
    2025-10-13 12:09:59.744  - info: host.iobroker84 iobroker npm-rebuild: rebuilt dependencies successfully
    2025-10-13 12:09:59.773  - info: host.iobroker84 iobroker npm-rebuild:
    2025-10-13 12:09:59.774  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules done
    2025-10-13 12:10:00.790  - info: host.iobroker84 iobroker npm-rebuild: exit 0
    2025-10-13 12:10:01.155  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4536
    2025-10-13 12:10:02.102  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
    2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:   throw err;
    2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:   ^
    2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
    2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]: Require stack:
    2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
    2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
    2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
    2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
    2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
    2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
    2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
    2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
    2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
    2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
    2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
    2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
    2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
    2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:   ]
    2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]: }
    2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
    2025-10-13 12:10:02.104  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-10-13 12:10:02.105  - info: host.iobroker84 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2025-10-13 12:10:06.604  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4543
    2025-10-13 12:10:07.492  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
    2025-10-13 12:10:07.492  - error: host.iobroker84 Caught by controller[0]:   throw err;
    2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:   ^
    2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
    2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]: Require stack:
    2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
    2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
    2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
    2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
    2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
    2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
    2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
    2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
    2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
    2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
    2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
    2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
    2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
    2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]:   ]
    2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]: }
    2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
    2025-10-13 12:10:07.494  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-10-13 12:10:07.494  - info: host.iobroker84 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2025-10-13 12:10:17.295  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4550
    2025-10-13 12:10:18.192  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
    2025-10-13 12:10:18.192  - error: host.iobroker84 Caught by controller[0]:   throw err;
    2025-10-13 12:10:18.192  - error: host.iobroker84 Caught by controller[0]:   ^
    2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
    2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]: Require stack:
    2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
    2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
    2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
    2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
    2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
    2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
    2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
    2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
    2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
    2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
    2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
    2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
    2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
    2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:   ]
    2025-10-13 12:10:18.195  - error: host.iobroker84 Caught by controller[0]: }
    2025-10-13 12:10:18.195  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
    2025-10-13 12:10:18.195  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-10-13 12:10:18.195  - info: host.iobroker84 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2025-10-13 12:10:18.526  - info: host.iobroker84 "system.adapter.echarts.0" disabled
    2025-10-13 12:10:20.582  - info: host.iobroker84 "system.adapter.echarts.0" enabled
    2025-10-13 12:10:21.027  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4557
    2025-10-13 12:10:21.952  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
    2025-10-13 12:10:21.952  - error: host.iobroker84 Caught by controller[0]:   throw err;
    2025-10-13 12:10:21.952  - error: host.iobroker84 Caught by controller[0]:   ^
    2025-10-13 12:10:21.952  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
    2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]: Require stack:
    2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
    2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
    2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
    2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
    2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
    2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
    2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
    2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
    2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
    2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
    2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
    2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
    2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
    2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:   ]
    2025-10-13 12:10:21.955  - error: host.iobroker84 Caught by controller[0]: }
    2025-10-13 12:10:21.955  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
    2025-10-13 12:10:21.955  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-10-13 12:10:21.955  - info: host.iobroker84 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2025-10-13 12:11:04.014  - info: host.iobroker84 "system.adapter.echarts.0" disabled
    2025-10-13 12:14:28.139  - info: host.iobroker84 "system.adapter.echarts.0" enabled
    2025-10-13 12:14:28.607  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4570
    2025-10-13 12:14:29.498  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
    2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]:   throw err;
    2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]:   ^
    2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
    2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]: Require stack:
    2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
    2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
    2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
    2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
    2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
    2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
    2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
    2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
    2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
    2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
    2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
    2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
    2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
    2025-10-13 12:14:29.501  - error: host.iobroker84 Caught by controller[0]:   ]
    2025-10-13 12:14:29.501  - error: host.iobroker84 Caught by controller[0]: }
    2025-10-13 12:14:29.501  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
    2025-10-13 12:14:29.501  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-10-13 12:14:29.501  - info: host.iobroker84 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    fraenk for friends Code: MATF103
    • meuteM meute
      iob logs
      anschauen.
      Thomas BraunT Offline
      @meute sagte in npm error bei "iob diag" nach Upgrade auf Debian 13 Trixie:
      Da kann ein Modul (vermutlich canvas) nicht richtig gebaut werden.
      cd /opt/iobroker && npm ls canvas
      mal anschauen.
      Und dann vielleicht im Verzeichnis des Adapters
      npm install --omit=dev
      ausführen.
      meuteM 1 Antwort Letzte Antwort
        mal anschauen.
        ausführen.
        meuteM Offline
        meuteM Offline
        meute
        schrieb am zuletzt editiert von meute
        mal anschauen.
        Ergebnis:
        $ cd /opt/iobroker && npm ls canvas
        iobroker.inst@3.0.0 /opt/iobroker
        └── (empty)
        ausführen.
        Meinst Du diesen Ordner?
        $ ls -lh /opt/iobroker/iobroker-data/files/echarts
        insgesamt 152K
        -rw-rw-r--+ 1 iobroker iobroker  11K 13. Okt 12:15 asset-manifest.json
        drwxrwxr-x+ 2 iobroker iobroker 4,0K 13. Okt 12:15 assets
        -rw-rw-r--+ 1 iobroker iobroker 4,0K 13. Okt 12:15 _data.json
        -rw-rw-r--+ 1 iobroker iobroker 115K 13. Okt 12:15 favicon.ico
        -rw-rw-r--+ 1 iobroker iobroker  690 13. Okt 12:15 index.html
        -rw-rw-r--+ 1 iobroker iobroker  313 13. Okt 12:15 manifest.json
        drwxrwxr-x+ 4 iobroker iobroker 4,0K 13. Okt 12:15 preview
        drwxrwxr-x+ 4 iobroker iobroker 4,0K  3. Okt 15:03 static
        Hier soll ich npm install --omit=dev ausführen.
        Kann ich mir damit was kaputt machen?
        EDIT:
        Aber eigentlich müsste der npm error doch bei jedem vorhanden sein, der den Adapter echarts installiert hat.
        Oder verstehe ich hier was falsch?
        • meuteM meute
          mal anschauen.
          Ergebnis:
          └── (empty)
          ausführen.
          insgesamt 152K
          EDIT:
          @meute
          Das richtige Verzeichnis ist
          Nein, wenn der Adapter bzw. das Modul gebaut werden kann dann hat man auch keinen Fehler.
          Bei mir ist der Adapter z. B. sauber installiert worden.
          • meuteM meute
            mal anschauen.
            Ergebnis:
            └── (empty)
            ausführen.
            insgesamt 152K
            EDIT:
            @meute
            Da sollte so ähnlich eigentlich aussehen:
            echad@chet:/opt/iobroker $ node -v
            v24.10.0
            echad@chet:/opt/iobroker $ npm ls canvas
            ├─┬ iobroker.echarts@2.0.10
            │ ├── canvas@3.2.0
            │ └─┬ jsdom@26.1.0
            │   └── canvas@3.2.0 deduped
            ├─┬ iobroker.mihome-vacuum@5.3.0
            └─┬ iobroker.parcel@0.2.10
              └─┬ jsdom@25.0.1
                └── canvas@3.2.0 deduped invalid: "^2.11.2" from node_modules/iobroker.parcel/node_modules/jsdom
            npm error code ELSPROBLEMS
            npm error invalid: canvas@3.2.0 /opt/iobroker/node_modules/canvas
            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-10-13T16_27_05_147Z-debug-0.log
            Der Error bei parcel ist was anderes. Aber hier baut canvas sogar mit nodejs@24. Würde aber mit nodejs@22 auch nicht anders aussehen.
              @meute
              meuteM Offline
              meuteM Offline
              meute
              Ich habe npm install --omit=dev ausgeführt.
              $ cd /opt/iobroker/node_modules/iobroker.echarts/
              /opt/iobroker/node_modules/iobroker.echarts $ npm install --omit=dev
              npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
              npm warn deprecated npmlog@5.0.1: This package is no longer supported.
              npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
              npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
              npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
              npm warn deprecated gauge@3.0.2: This package is no longer supported.
              added 128 packages, and audited 129 packages in 2m
              18 packages are looking for funding
                run `npm fund` for details
              found 0 vulnerabilities
              Ergebnis cd /opt/iobroker && npm ls canvas:
              └─┬ iobroker.echarts@1.9.2
                ├── canvas@2.11.2
                └─┬ jsdom@25.0.1
                  └── canvas@2.11.2 deduped
              Der npm error bei iob diag ist noch größer geworden.
              $ iob diag
              *** iob diag is starting up, please wait ***
              npm error extraneous: @asamuzakjp/css-color@3.2.0 /opt/iobroker/node_modules/@asamuzakjp/css-color
              npm error extraneous: @csstools/color-helpers@5.1.0 /opt/iobroker/node_modules/@csstools/color-helpers
              npm error extraneous: @csstools/css-calc@2.1.4 /opt/iobroker/node_modules/@csstools/css-calc
              npm error extraneous: @csstools/css-color-parser@3.1.0 /opt/iobroker/node_modules/@csstools/css-color-parser
              npm error extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
              npm error extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
              npm error extraneous: aproba@2.1.0 /opt/iobroker/node_modules/aproba
              npm error extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
              npm error extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
              npm error extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
              npm error extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
              npm error extraneous: cssstyle@4.6.0 /opt/iobroker/node_modules/cssstyle
              npm error extraneous: data-urls@5.0.0 /opt/iobroker/node_modules/data-urls
              npm error extraneous: decimal.js@10.6.0 /opt/iobroker/node_modules/decimal.js
              npm error extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
              npm error extraneous: detect-libc@2.1.2 /opt/iobroker/node_modules/detect-libc
              npm error extraneous: echarts@5.6.0 /opt/iobroker/node_modules/echarts
              npm error extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
              npm error extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
              npm error extraneous: html-encoding-sniffer@4.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
              npm error extraneous: http-proxy-agent@7.0.2 /opt/iobroker/node_modules/http-proxy-agent
              npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
              npm error extraneous: jsdom@25.0.1 /opt/iobroker/node_modules/jsdom
              npm error extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
              npm error extraneous: mimic-response@2.1.0 /opt/iobroker/node_modules/mimic-response
              npm error extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
              npm error extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
              npm error extraneous: nwsapi@2.2.22 /opt/iobroker/node_modules/nwsapi
              npm error extraneous: parse5@7.3.0 /opt/iobroker/node_modules/parse5
              npm error extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
              npm error extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
              npm error extraneous: rrweb-cssom@0.7.1 /opt/iobroker/node_modules/rrweb-cssom
              npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
              npm error extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/set-blocking
              npm error extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
              npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
              npm error extraneous: tldts-core@6.1.86 /opt/iobroker/node_modules/tldts-core
              npm error extraneous: tldts@6.1.86 /opt/iobroker/node_modules/tldts
              npm error extraneous: tr46@5.1.1 /opt/iobroker/node_modules/tr46
              npm error extraneous: w3c-xmlserializer@5.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
              npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
              npm error extraneous: whatwg-encoding@3.1.1 /opt/iobroker/node_modules/whatwg-encoding
              npm error extraneous: whatwg-mimetype@4.0.0 /opt/iobroker/node_modules/whatwg-mimetype
              npm error invalid: whatwg-url@14.2.0 /opt/iobroker/node_modules/whatwg-url
              npm error extraneous: whatwg-url@14.2.0 /opt/iobroker/node_modules/whatwg-url
              npm error extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
              npm error extraneous: xml-name-validator@5.0.0 /opt/iobroker/node_modules/xml-name-validator
              npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
              npm error extraneous: zrender@5.6.1 /opt/iobroker/node_modules/zrender
              npm error missing: @csstools/css-parser-algorithms@^3.0.4, required by @asamuzakjp/css-color@3.2.0
              npm error missing: @csstools/css-tokenizer@^3.0.3, required by @asamuzakjp/css-color@3.2.0
              npm error extraneous: lru-cache@10.4.3 /opt/iobroker/node_modules/@asamuzakjp/css-color/node_modules/lru-cache
              npm error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-calc@2.1.4
              npm error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-calc@2.1.4
              npm error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-color-parser@3.1.0
              npm error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-color-parser@3.1.0
              npm error extraneous: agent-base@6.0.2 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/agent-base
              npm error extraneous: debug@4.4.3 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/debug
              npm error extraneous: https-proxy-agent@5.0.1 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/https-proxy-agent
              npm error extraneous: ms@2.1.3 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/ms
              npm error extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/node-fetch
              npm error extraneous: tr46@0.0.3 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/tr46
              npm error extraneous: webidl-conversions@3.0.1 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/webidl-conversions
              npm error extraneous: whatwg-url@5.0.0 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/whatwg-url
              npm error extraneous: rrweb-cssom@0.8.0 /opt/iobroker/node_modules/cssstyle/node_modules/rrweb-cssom
              npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/echarts/node_modules/tslib
              npm error extraneous: debug@4.4.3 /opt/iobroker/node_modules/http-proxy-agent/node_modules/debug
              npm error extraneous: ms@2.1.3 /opt/iobroker/node_modules/http-proxy-agent/node_modules/ms
              npm error extraneous: tough-cookie@5.1.2 /opt/iobroker/node_modules/jsdom/node_modules/tough-cookie
              npm error extraneous: semver@6.3.1 /opt/iobroker/node_modules/make-dir/node_modules/semver
              npm error extraneous: brace-expansion@1.1.12 /opt/iobroker/node_modules/rimraf/node_modules/brace-expansion
              npm error extraneous: glob@7.2.3 /opt/iobroker/node_modules/rimraf/node_modules/glob
              npm error extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/rimraf/node_modules/minimatch
              npm error extraneous: iconv-lite@0.6.3 /opt/iobroker/node_modules/whatwg-encoding/node_modules/iconv-lite
              npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/zrender/node_modules/tslib
              npm error invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
              npm error A complete log of this run can be found in: /home/mf/.npm/_logs/2025-10-13T16_46_12_186Z-debug-0.log
              *** ioBroker Diagnosis ***
              Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
              • meuteM meute
                  ├── canvas@2.11.2
                  └─┬ jsdom@25.0.1
                $ iob diag
                @meute
                Die Einträge mir extraneous sollten mit einem
                npm prune
                verschwinden.
                  @meute
                  npm prune
                  verschwinden.
                  meuteM Offline
                  meuteM Offline
                  meute
                  npm prune
                  verschwinden.
                  $ cd /opt/iobroker
                  /opt/iobroker $ npm prune
                  added 2 packages, and removed 128 packages in 4s
                  108 packages are looking for funding
                  /opt/iobroker $ npm fund
                  iobroker.inst@3.0.0
                  ├── https://github.com/sponsors/epoberezkin
                  │   └── ajv@6.12.6
                  ├─┬ https://opencollective.com/express
                  │ │ └── express@5.1.0
                  │ └── https://github.com/sponsors/sindresorhus
                  │     └── merge-descriptors@2.0.0, is-stream@2.0.1, decompress-response@6.0.0, mimic-response@3.1.0, get-stream@6.0.1, responselike@3.0.0, lowercase-keys@3.0.0, quick-lru@5.1.1, onetime@5.1.2, escape-string-regexp@4.0.0, find-up@5.0.0, locate-path@6.0.0, p-locate@5.0.0, p-limit@3.1.0, yocto-queue@0.1.0, log-symbols@4.1.0, is-unicode-supported@0.1.0, strip-json-comments@3.1.1, camelcase@6.3.0, decamelize@4.0.0, component-emitter@1.3.1
                  ├── https://github.com/sponsors/jaredhanson
                  │   └── passport@0.7.0
                  ├── https://github.com/sponsors/RubenVerborgh
                  │   └── follow-redirects@1.15.6
                  ├── https://github.com/sponsors/ljharb
                  │   └── get-intrinsic@1.3.0, function-bind@1.1.2, gopd@1.2.0, has-symbols@1.1.0, has-tostringtag@1.0.2, qs@6.14.0, side-channel@1.1.0, object-inspect@1.13.4, side-channel-list@1.0.0, side-channel-map@1.0.1, call-bound@1.0.4, side-channel-weakmap@1.0.2, minimist@1.2.8
                  ├── https://github.com/sponsors/panva
                  │   └── jose@4.15.9
                  ├── https://github.com/sponsors/isaacs
                  │   └── glob@8.1.0, minimatch@9.0.5
                  ├── https://github.com/sponsors/feross
                  │   └── buffer@5.7.1, safe-buffer@5.2.1
                  ├── https://github.com/sponsors/AlCalzone
                  │   └── @esm2cjs/got@13.0.0, @esm2cjs/cacheable-lookup@7.0.0, @esm2cjs/cacheable-request@10.2.12, @esm2cjs/mimic-response@4.0.0, @esm2cjs/normalize-url@8.0.0, @esm2cjs/responselike@3.0.0, @esm2cjs/form-data-encoder@2.1.4, @esm2cjs/http-timer@5.0.1, @esm2cjs/is@5.6.0, @esm2cjs/lowercase-keys@3.0.0, @esm2cjs/p-cancelable@3.0.0
                  ├─┬ https://opencollective.com/node-fetch
                  │ │ └── node-fetch@3.3.2
                  │ └── https://github.com/sponsors/jimmywarting
                  │     └── fetch-blob@3.2.0, node-domexception@1.0.0
                  ├── https://opencollective.com/js-sdsl
                  │   └── js-sdsl@4.3.0
                  ├── https://github.com/fb55/entities?sponsor=1
                  │   └── entities@6.0.0
                  ├── https://github.com/sponsors/NaturalIntelligence
                  │   └── fast-xml-parser@4.5.3, strnum@1.1.2
                  ├── https://opencollective.com/serialport/donate
                  │   └── serialport@12.0.0, @serialport/bindings-cpp@12.0.1, @serialport/parser-readline@11.0.0, @serialport/parser-delimiter@11.0.0, @serialport/parser-byte-length@12.0.0, @serialport/parser-cctalk@12.0.0, @serialport/parser-delimiter@12.0.0, @serialport/parser-inter-byte-timeout@12.0.0, @serialport/parser-readline@12.0.0, @serialport/parser-ready@12.0.0, @serialport/parser-regex@12.0.0, @serialport/parser-slip-encoder@12.0.0, @serialport/parser-spacepacket@12.0.0, @serialport/stream@12.0.0
                  ├── https://github.com/inikulin/parse5?sponsor=1
                  │   └── parse5@7.3.0
                  ├── https://github.com/sponsors/csstools
                  │   └── @csstools/css-calc@2.1.4, @csstools/css-color-parser@3.1.0, @csstools/color-helpers@5.1.0
                  ├── https://opencollective.com/ioredis
                  │   └── ioredis@4.30.0
                  ├── https://github.com/sindresorhus/execa?sponsor=1
                  │   └── execa@5.1.1
                  ├── https://paulmillr.com/funding/
                  │   └── chokidar@3.5.3
                  ├── https://github.com/sponsors/sibiraj-s
                  │   └── ci-info@3.9.0
                  ├── https://opencollective.com/sinon
                  │   └── sinon@15.2.0
                  └── https://github.com/chalk/supports-color?sponsor=1
                      └── supports-color@8.1.1
                  npm error bei iob diag:
                  $ iob diag
                  npm error extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                  npm error extraneous: decompress-response@4.2.1 /opt/iobroker/node_modules/simple-get/node_modules/decompress-response
                  npm error A complete log of this run can be found in: /home/mf/.npm/_logs/2025-10-13T17_10_06_760Z-debug-0.log
                  • meuteM meute
                    npm prune
                    verschwinden.
                    $ cd /opt/iobroker
                    iobroker.inst@3.0.0
                    │   └── ajv@6.12.6
                    │   └── jose@4.15.9
                    │   └── js-sdsl@4.3.0
                    │   └── parse5@7.3.0
                    │   └── execa@5.1.1
                    │   └── ci-info@3.9.0
                    │   └── sinon@15.2.0
                    $ iob diag
                    @meute
                    Dann weiß ich es auch nicht.
                    Zeig mal die komplette Ausgabe von
                    iob diag
                      @meute
                      iob diag
                      meuteM Offline
                      meuteM Offline
                      meute
                      ioBroker läuft ja.
                      Vll. verschwindet der Fehler irgendwann von selbst.
                      Der npm error kommt nur bei iob diag.
                      iob diag
                      Bitteschön:
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                      Operating System: Debian GNU/Linux 13 (trixie)
                       Static hostname: iobroker84
                             Icon name: computer-container
                               Chassis: container ☐
                        Virtualization: lxc
                                Kernel: Linux 6.14.11-3-pve
                          Architecture: x86-64
                      OS is similar to:
                      model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
                      Docker          : false
                      Virtualization  : lxc
                      Kernel          : x86_64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       19:17:09 up 1 day,  7:03,  1 user,  load average: 0.43, 0.46, 0.47
                      CPU threads: 2
                      *** LIFE CYCLE STATUS ***
                      Operating System is the current Debian stable version codenamed 'trixie'!
                      *** TIME AND TIMEZONES ***
                                     Local time: Mon 2025-10-13 19:17:09 CEST
                                 Universal time: Mon 2025-10-13 17:17:09 UTC
                                       RTC time: n/a
                                    NTP service: inactive
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      mf
                      HOME=/home/mf
                      GROUPS=mf adm sudo users iobroker lxc_shares
                      iobroker
                      HOME=/home/iobroker
                      SUDO_HOME=/home/mf
                      GROUPS=iobroker tty dialout audio video plugdev lxc_shares
                      *** DISPLAY-SERVER SETUP ***
                      Display-Server:         false
                      Unit display-manager.service could not be found.
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Mem:            4.3G        1.5G        1.5G        6.3M        1.4G        2.8G
                      Swap:           536M        278K        536M
                      Total:          4.8G        1.5G        2.0G
                      Active iob-Instances:   15
                               4096 M total memory
                               1427 M used memory
                                623 M active memory
                               1872 M inactive memory
                               1386 M free memory
                                  0 M buffer memory
                               1288 M swap cache
                                512 M total swap
                                  0 M used swap
                                511 M free swap
                      top - 19:17:09 up 1 day,  7:03,  1 user,  load average: 0.43, 0.46, 0.47
                      Tasks:  52 total,   1 running,  51 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  0.0 us,  4.5 sy,  0.0 ni, 90.9 id,  0.0 wa,  0.0 hi,  4.5 si,  0.0 st
                      MiB Mem :   4096.0 total,   1384.7 free,   1428.7 used,   1288.4 buff/cache
                      MiB Swap:    512.0 total,    511.7 free,      0.3 used.   2667.3 avail Mem
                      *** FAILED SERVICES ***
                        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                      Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                              ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                              SUB    -> The low-level unit activation state, values depend on unit type.
                      2 loaded units listed.
                      *** DMESG CRITICAL ERRORS ***
                      dmesg: read kernel buffer failed: Operation not permitted
                      No critical errors detected
                      *** FILESYSTEM ***
                      Filesystem                                  Type      Size  Used Avail Use% Mounted on
                      /dev/mapper/pve-vm--100--disk--0            ext4       12G  7.1G  4.2G  64% /
                      //192.168.23.8/FRITZ.NAS/CT500MX5-00SSD1-01 cifs      467G   50G  417G  11% /mnt/nas8
                      none                                        tmpfs     492K  4.0K  488K   1% /dev
                      udev                                        devtmpfs  9.7G     0  9.7G   0% /dev/tty
                      tmpfs                                       tmpfs     9.7G     0  9.7G   0% /dev/shm
                      tmpfs                                       tmpfs     3.9G  3.3M  3.9G   1% /run
                      tmpfs                                       tmpfs     9.7G  2.8M  9.7G   1% /tmp
                      tmpfs                                       tmpfs     5.0M     0  5.0M   0% /run/lock
                      tmpfs                                       tmpfs     2.0G  8.0K  2.0G   1% /run/user/1000
                      Show mounted filesystems:
                      TARGET      SOURCE                                      FSTYPE OPTIONS
                      /           /dev/mapper/pve-vm--100--disk--0            ext4   rw,relatime,stripe=16
                      `-/mnt/nas8 //192.168.23.8/FRITZ.NAS/CT500MX5-00SSD1-01 cifs   rw,relatime,vers=3.0,cache=strict,upcall_target=app,username=fritznas,uid=100000,forceuid,gid=110000,forcegid,addr=192.168.23.8,file_mode=0770,dir_mode=0770,soft,nounix,mapposix,reparse=nfs,nativesocket,symlink=native,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
                      /var:
                      2.0G    /var/
                      1.3G    /var/log/journal
                      1.3G    /var/log
                      1.2G    /var/log/journal/649cc30af99f46b985202f72e64de40c
                      496M    /var/cache
                      Archived and active journals take up 1.1G in the file system.
                      /opt/iobroker/backups:
                      69M     /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      383M    /opt/iobroker/iobroker-data/
                      300M    /opt/iobroker/iobroker-data/files
                      67M     /opt/iobroker/iobroker-data/files/echarts.admin
                      61M     /opt/iobroker/iobroker-data/files/echarts
                      53M     /opt/iobroker/iobroker-data/backup-objects
                      27M     /opt/iobroker/iobroker-data/objects.jsonl
                      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                      24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                      24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
                      USB-Devices by-id:
                      No Devices found 'by-id'
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v22.20.0
                      /usr/bin/node           v22.20.0
                      /usr/bin/npm            11.6.2
                      /usr/bin/npx            11.6.2
                      /usr/bin/corepack       0.34.0
                      nodejs:
                        Installed: 22.20.0-1nodesource1
                        Candidate: 22.20.0-1nodesource1
                        Version table:
                       *** 22.20.0-1nodesource1 1001
                           22.19.0-1nodesource1 1001
                           22.18.0-1nodesource1 1001
                           22.17.1-1nodesource1 1001
                           22.17.0-1nodesource1 1001
                           22.16.0-1nodesource1 1001
                           22.15.1-1nodesource1 1001
                           22.15.0-1nodesource1 1001
                           22.14.0-1nodesource1 1001
                           22.13.1-1nodesource1 1001
                           22.13.0-1nodesource1 1001
                           22.12.0-1nodesource1 1001
                           22.11.0-1nodesource1 1001
                           22.10.0-1nodesource1 1001
                           22.9.0-1nodesource1 1001
                           22.8.0-1nodesource1 1001
                           22.7.0-1nodesource1 1001
                           22.6.0-1nodesource1 1001
                           22.5.1-1nodesource1 1001
                           22.5.0-1nodesource1 1001
                           22.4.1-1nodesource1 1001
                           22.4.0-1nodesource1 1001
                           22.3.0-1nodesource1 1001
                           22.2.0-1nodesource1 1001
                           22.1.0-1nodesource1 1001
                           22.0.0-1nodesource1 1001
                           20.19.2+dfsg-1 500
                              500 http://deb.debian.org/debian trixie/main amd64 Packages
                      No problems detected
                      Errors in npm tree: 0
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      iobroker84          iobroker84 (version: 7.0.7, hostname: iobroker84    , alive, uptime: 71195)
                      Core adapters versions
                      js-controller:  7.0.7
                      admin:          7.7.2
                      javascript:     8.9.2
                      nodejs modules from github:     0
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : iobroker84                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        system.adapter.alias-manager.0          : alias-manager         : iobroker84                               - disabled
                      + system.adapter.backitup.0               : backitup              : iobroker84                               -  enabled
                      + system.adapter.discovery.0              : discovery             : iobroker84                               -  enabled
                      + system.adapter.echarts.0                : echarts               : iobroker84                               -  enabled
                        system.adapter.ical.0                   : ical                  : iobroker84                               -  enabled
                      + system.adapter.influxdb.0               : influxdb              : iobroker84                               -  enabled, port: 8086
                      + system.adapter.iqontrol.0               : iqontrol              : iobroker84                               -  enabled
                      + system.adapter.javascript.0             : javascript            : iobroker84                               -  enabled
                      + system.adapter.modbus.0                 : modbus                : iobroker84                               -  enabled
                        system.adapter.ping.0                   : ping                  : iobroker84                               - disabled
                      + system.adapter.shelly.0                 : shelly                : iobroker84                               -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.sonoff.0                 : sonoff                : iobroker84                               -  enabled, port: 1885, bind: 0.0.0.0
                      + system.adapter.tr-064.0                 : tr-064                : iobroker84                               -  enabled
                      + system.adapter.trashschedule.0          : trashschedule         : iobroker84                               -  enabled
                      + system.adapter.web.0                    : web                   : iobroker84                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker84                               -  enabled
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Upgrade policy: none
                      Installed ioBroker-Adapters
                      Used repository: stable
                      Adapter    "admin"        : 7.7.2    , installed 7.7.2
                      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                      Adapter    "ical"         : 1.17.0   , installed 1.17.0
                      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                      Controller "js-controller": 7.0.7    , installed 7.0.7
                      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                      Adapter    "shelly"       : 10.2.0   , installed 10.2.0
                      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                      Adapter    "web"          : 7.0.8    , installed 7.0.8
                      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                      Objects and States
                      Objects:        1346
                      States:         1053
                      W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                      Hit:1 http://deb.debian.org/debian trixie InRelease
                      Hit:2 http://deb.debian.org/debian trixie-updates InRelease
                      Hit:3 http://security.debian.org trixie-security InRelease
                      Hit:4 https://repos.influxdata.com/debian stable InRelease
                      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          30476144   255/smbd
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          30471050   1/init
                      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          30476143   255/smbd
                      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       31761702   1730/io.sonoff.0
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31759277   1579/iobroker.js-co
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31758015   1579/iobroker.js-co
                      tcp6       0      0 :::139                  :::*                    LISTEN      0          30476142   255/smbd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          30476526   1/init
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          30471052   1/init
                      tcp6       0      0 :::445                  :::*                    LISTEN      0          30476141   255/smbd
                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        30476154   177/influxd
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31759357   1598/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       31761907   1805/io.web.0
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          30471051   1/init
                      udp        0      0 192.168.23.255:137      0.0.0.0:*                           0          30476030   208/nmbd
                      udp        0      0 192.168.23.84:137       0.0.0.0:*                           0          30476029   208/nmbd
                      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          30476017   208/nmbd
                      udp        0      0 192.168.23.255:138      0.0.0.0:*                           0          30476032   208/nmbd
                      udp        0      0 192.168.23.84:138       0.0.0.0:*                           0          30476031   208/nmbd
                      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          30476018   208/nmbd
                      udp        0      0 192.168.23.84:5353      0.0.0.0:*                           1001       31762800   1775/io.tr-064.0
                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       31762618   1715/io.shelly.0
                      udp6       0      0 :::111                  :::*                                0          30471053   1/init
                      2025-10-13 17:32:33.484  - info: web.0 (1805) ==> Connected system.user.admin from ::ffff:192.168.23.186
                      2025-10-13 17:34:19.147  - info: web.0 (1805) <== Disconnect system.user.admin from ::ffff:192.168.23.186 iqontrol.0
                      2025-10-13 17:34:19.705  - info: web.0 (1805) ==> Connected system.user.admin from ::ffff:192.168.23.186
                      2025-10-13 17:35:19.994  - info: web.0 (1805) <== Disconnect system.user.admin from ::ffff:192.168.23.186 iqontrol.0
                      2025-10-13 18:00:00.038  - info: host.iobroker84 instance system.adapter.ical.0 in version "1.17.0" started with pid 5332
                      2025-10-13 18:00:02.030  - info: ical.0 (5332) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.20.0, js-controller: 7.0.7
                      2025-10-13 18:00:02.414  - info: ical.0 (5332) processing URL: Abfuhrkalender https://calendar.google.com/calendar/ical/bd0a1fc1997514e89949bb190399d86de9d17b2640e28a28dbf8f1bf391e5f90%40group.calendar.google.com/private-7d7300d8d092a6268253c104d9f3fdf1/basic.ics
                      2025-10-13 18:00:07.500  - info: ical.0 (5332) Terminated (NO_ERROR): Without reason
                      2025-10-13 18:00:08.027  - info: host.iobroker84 instance system.adapter.ical.0 having pid 5332 terminated with code 0 (NO_ERROR)
                      2025-10-13 18:12:03.795  - info: web.0 (1805) ==> Connected system.user.admin from ::ffff:192.168.23.186
                      2025-10-13 18:12:11.020  - info: web.0 (1805) <== Disconnect system.user.admin from ::ffff:192.168.23.186 iqontrol.0
                      2025-10-13 18:30:00.031  - info: host.iobroker84 instance system.adapter.ical.0 in version "1.17.0" started with pid 5359
                      2025-10-13 18:30:01.837  - info: ical.0 (5359) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.20.0, js-controller: 7.0.7
                      2025-10-13 18:30:02.240  - info: ical.0 (5359) processing URL: Abfuhrkalender https://calendar.google.com/calendar/ical/bd0a1fc1997514e89949bb190399d86de9d17b2640e28a28dbf8f1bf391e5f90%40group.calendar.google.com/private-7d7300d8d092a6268253c104d9f3fdf1/basic.ics
                      2025-10-13 18:30:07.335  - info: ical.0 (5359) Terminated (NO_ERROR): Without reason
                      2025-10-13 18:30:07.859  - info: host.iobroker84 instance system.adapter.ical.0 having pid 5359 terminated with code 0 (NO_ERROR)
                      2025-10-13 18:46:50.115  - info: admin.0 (1598) ==> Connected system.user.admin from ::ffff:192.168.23.27
                      2025-10-13 18:47:13.830  - info: admin.0 (1598) <== Disconnect system.user.admin from ::ffff:192.168.23.27 admin
                      2025-10-13 19:00:00.040  - info: host.iobroker84 instance system.adapter.ical.0 in version "1.17.0" started with pid 6152
                      2025-10-13 19:00:01.904  - info: ical.0 (6152) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.20.0, js-controller: 7.0.7
                      2025-10-13 19:00:02.283  - info: ical.0 (6152) processing URL: Abfuhrkalender https://calendar.google.com/calendar/ical/bd0a1fc1997514e89949bb190399d86de9d17b2640e28a28dbf8f1bf391e5f90%40group.calendar.google.com/private-7d7300d8d092a6268253c104d9f3fdf1/basic.ics
                      2025-10-13 19:00:07.373  - info: ical.0 (6152) Terminated (NO_ERROR): Without reason
                      2025-10-13 19:00:07.903  - info: host.iobroker84 instance system.adapter.ical.0 having pid 6152 terminated with code 0 (NO_ERROR)
                      2025-10-13 19:09:32.661  - info: admin.0 (1598) ==> Connected system.user.admin from ::ffff:192.168.23.27
                      2025-10-13 19:09:43.940  - info: admin.0 (1598) <== Disconnect system.user.admin from ::ffff:192.168.23.27 admin
                      iob diag has finished.
                      • meuteM meute
                        ioBroker läuft ja.
                        iob diag
                        Bitteschön:
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                          Virtualization: lxc
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                        CPU threads: 2
                                         RTC time: n/a
                                  RTC in local TZ: no
                        mf
                        HOME=/home/mf
                        iobroker
                        HOME=/home/iobroker
                        SUDO_HOME=/home/mf
                        Display-Manager:
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                                 4096 M total memory
                                 1427 M used memory
                                  623 M active memory
                                 1386 M free memory
                                    0 M buffer memory
                                 1288 M swap cache
                                  512 M total swap
                                    0 M used swap
                                  511 M free swap
                        *** FILESYSTEM ***
                        /var:
                        2.0G    /var/
                        1.3G    /var/log
                        496M    /var/cache
                        USB-Devices by-id:
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            11.6.2
                        /usr/bin/npx            11.6.2
                        nodejs:
                          Version table:
                             20.19.2+dfsg-1 500
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.7.2
                        javascript:     8.9.2
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        1346
                        States:         1053
                        Pending Updates: 0
                        @meute Nutzt dir zwar nix, aber unter nodejs@22 ist das bei mir alles sauber:
                        v22.20.0
                        │ ├── canvas@3.2.0
                        │ └─┬ jsdom@26.1.0
                          └─┬ jsdom@25.0.1
                            └── canvas@2.11.2
                        ├── iobroker.admin@7.7.3
                        ├── iobroker.alexa2@3.27.3
                        ├── iobroker.alias-manager@2.0.0
                        ├── iobroker.ankersolix2@2.4.1
                        ├── iobroker.awtrix-light@2.0.0
                        ├── iobroker.backitup@3.3.9
                        ├── iobroker.ble@0.14.1
                        ├── iobroker.cloud@5.0.1
                        ├── iobroker.devices@1.2.9
                        ├── iobroker.echarts@2.0.10
                        ├── iobroker.firetv@2.1.0
                        ├── iobroker.followthesun@0.5.2
                        ├── iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
                        ├── iobroker.govee-local@0.2.9
                        ├── iobroker.history@3.0.1
                        ├── iobroker.ical@1.17.0
                        ├── iobroker.iceroad@1.2.1
                        ├── iobroker.iot@4.1.0
                        ├── iobroker.javascript@9.0.11
                        ├── iobroker.js-controller@7.0.7
                        ├── iobroker.mihome-cloud@0.1.1
                        ├── iobroker.mihome-vacuum@5.3.0
                        ├── iobroker.mihome@1.4.0
                        ├── iobroker.mqtt@6.1.4
                        ├── iobroker.nina@0.0.26
                        ├── iobroker.notification-manager@1.3.0
                        ├── iobroker.nuki-extended@2.7.0
                        ├── iobroker.nut@1.7.0
                        ├── iobroker.opendtu@3.1.0
                        ├── iobroker.openweathermap@1.4.0
                        ├── iobroker.parcel@0.2.10
                        ├── iobroker.playstation@0.0.3
                        ├── iobroker.rpi2@2.4.0 (git+ssh://git@github.com/Grothesk242/ioBroker.rpi2.git#c87e9539d89bac8f4d19b266679bcb78ed554f1d)
                        ├── iobroker.sainlogic@0.12.1
                        ├── iobroker.samsung_tizen@1.1.0
                        ├── iobroker.samsung@0.6.1
                        ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#7a05fa59dfc5e3ce8d73018badc4e420996452f8)
                        ├── iobroker.tado@0.8.0
                        ├── iobroker.tankerkoenig@3.4.0
                        ├── iobroker.tr-064@4.3.0
                        ├── iobroker.tradfri@3.1.3
                        ├── iobroker.trashschedule@4.0.1
                        ├── iobroker.tuya@3.17.0
                        ├── iobroker.weather-warnings@0.8.0
                        ├── iobroker.web@7.0.9
                        ├── iobroker.whatsapp-cmb@0.3.0
                        └── iobroker.zigbee@3.1.5
                        echad@chet:/opt/iobroker $ lsb_release -cs
                        trixie
                          v22.20.0
                          │ ├── canvas@3.2.0
                          │ └─┬ jsdom@26.1.0
                            └─┬ jsdom@25.0.1
                              └── canvas@2.11.2
                          trixie
                          meuteM Offline
                          meuteM Offline
                          meute
                          So sieht es bei mir aus:
                          mf@iobroker84:/opt/iobroker $ node -v
                          v22.20.0
                          mf@iobroker84:/opt/iobroker $ npm ls canvas
                          └── (empty)
                          ├── @mapbox/node-pre-gyp@1.0.11 extraneous
                          ├── abbrev@1.1.1 extraneous
                          ├── aproba@2.1.0 extraneous
                          ├── are-we-there-yet@2.0.0 extraneous
                          ├── color-support@1.1.3 extraneous
                          ├── concat-map@0.0.1 extraneous
                          ├── console-control-strings@1.1.0 extraneous
                          ├── delegates@1.0.0 extraneous
                          ├── detect-libc@2.1.2 extraneous
                          ├── gauge@3.0.2 extraneous
                          ├── has-unicode@2.0.1 extraneous
                          ├── iobroker.admin@7.7.2
                          ├── iobroker.backitup@3.3.5
                          ├── iobroker.discovery@5.0.0
                          ├── iobroker.echarts@1.9.2
                          ├── iobroker.influxdb@4.0.2
                          ├── iobroker.iqontrol@3.0.0
                          ├── iobroker.javascript@8.9.2
                          ├── iobroker.modbus@6.3.2
                          ├── iobroker.ping@1.6.2
                          ├── iobroker.shelly@10.2.0
                          ├── iobroker.simple-api@2.8.0
                          ├── iobroker.socketio@6.7.1
                          ├── iobroker.sonoff@3.2.1
                          ├── iobroker.trashschedule@3.3.0
                          ├── iobroker.web@7.0.8
                          ├── iobroker.ws@2.6.2
                          ├── make-dir@3.1.0 extraneous
                          ├── mimic-response@2.1.0 extraneous
                          ├── nopt@5.0.0 extraneous
                          ├── npmlog@5.0.1 extraneous
                          ├── path-is-absolute@1.0.1 extraneous
                          ├── rimraf@3.0.2 extraneous
                          ├── set-blocking@2.0.0 extraneous
                          ├── simple-concat@1.0.1 extraneous
                          ├── simple-get@3.1.1 extraneous
                          └── wide-align@1.1.5 extraneous
                          • meuteM Offline
                            meuteM Offline
                            meute
                            Mir sagt canvas jetzt nicht wirklich was.
                            Benötigt der Adapter echarts canvas?
                            Wenn ja, warum ist es bei mir (empty)?
                            • meuteM meute
                              Ja, einmal als direkte Abhängigkeit und dann braucht jsdom auch canvas. Sieht man hier:
                              │ ├── canvas@3.2.0
                              │ └─┬ jsdom@26.1.0
                              Deduped bedeutet, das es keine doppelte Installation ist sondern das auf das Modul (in gleicher Versionsnummer) auf einer höheren Ebene zurückgegriffen werden kann.
                              Weil es aus irgendwelchen Gründen bei dir nicht gebaut/kompiliert werden kann.
                              • meuteM meute
                                @meute
                                Was spuckt denn ein
                                apt policy build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                                aus?
                                  @meute
                                  Was spuckt denn ein
                                  aus?
                                  meuteM Offline
                                  meuteM Offline
                                  meute
                                  @thomas-braun sagte in npm error bei "iob diag" nach Upgrade auf Debian 13 Trixie:
                                  $ apt policy build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                                  build-essential:
                                    Installiert:           12.12
                                    Installationskandidat: 12.12
                                    Versionstabelle:
                                   *** 12.12 500
                                  libcairo2-dev:
                                    Installiert:           1.18.4-1+b1
                                    Installationskandidat: 1.18.4-1+b1
                                    Versionstabelle:
                                   *** 1.18.4-1+b1 500
                                  libpango1.0-dev:
                                    Installiert:           1.56.3-1
                                    Installationskandidat: 1.56.3-1
                                    Versionstabelle:
                                   *** 1.56.3-1 500
                                  libjpeg-dev:
                                    Installiert:           1:2.1.5-4
                                    Installationskandidat: 1:2.1.5-4
                                    Versionstabelle:
                                   *** 1:2.1.5-4 500
                                  libgif-dev:
                                    Installiert:           5.2.2-1+b1
                                    Installationskandidat: 5.2.2-1+b1
                                    Versionstabelle:
                                   *** 5.2.2-1+b1 500
                                  librsvg2-dev:
                                    Installiert:           2.60.0+dfsg-1
                                    Installationskandidat: 2.60.0+dfsg-1
                                    Versionstabelle:
                                   *** 2.60.0+dfsg-1 500
                                  • meuteM meute
                                    build-essential:
                                      Installiert:           12.12
                                      Versionstabelle:
                                     *** 12.12 500
                                    libcairo2-dev:
                                      Versionstabelle:
                                     *** 1.18.4-1+b1 500
                                    libpango1.0-dev:
                                      Versionstabelle:
                                     *** 1.56.3-1 500
                                    libjpeg-dev:
                                      Versionstabelle:
                                     *** 1:2.1.5-4 500
                                    libgif-dev:
                                      Versionstabelle:
                                     *** 5.2.2-1+b1 500
                                    librsvg2-dev:
                                      Versionstabelle:
                                    @meute
                                    Schau mal ob canvas alleine baut.
                                    cd
                                    npm install canvas
                                    Damit wird das Modul unabhängig vom iobroker in deinem Heimverzeichnis gebaut.
                                    Zeig mal die Meldungen dazu.
                                    [Edit:]
                                    Mit
                                    npm uninstall canvas
                                    im gleichen Verzeichnis wirste das auch wieder los.
                                      @meute
                                      cd
                                      npm install canvas
                                      [Edit:]
                                      Mit
                                      meuteM Offline
                                      meuteM Offline
                                      meute
                                      @meute
                                      cd
                                      npm install canvas
                                      mf@iobroker84:~ $ npm install canvas
                                      added 37 packages in 5s
                                      9 packages are looking for funding
                                      Habs im Home wieder deinstalliert.
                                      • meuteM meute
                                        @meute
                                        cd
                                        npm install canvas
                                        War es denn davor im Baum zu finden?
                                        npm ls
                                        hätte da ein Modul canvas@3.2.0 zeigen müssen.
                                          npm ls
                                          meuteM Offline
                                          meuteM Offline
                                          meute
                                          npm ls
                                          added 37 packages in 4s
                                          mf@iobroker84:~ $ npm ls
                                          mf@ /home/mf
                                          └── canvas@3.2.0
                                          mf@iobroker84:~ $ npm uninstall canvas
                                          removed 37 packages, and audited 1 package in 721ms
