    6.5k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.4m Aufrufe 260 Beobachtet
  • M mschmidt
    SONOFF NSPanel mit Lovelace UI - Scriptupdate 4.7.12 --> 5.0.0.1
    Hi, nachdem ja Accuwetter keinen free Account mehr anbietet, wollte ich auch das Script auf die aktuelle Version anpassen.
    Nach einigen Schwierigkeiten mit der TFT Firmware sehe ich am Panel wieder die Serviceseite. Nachdem Start des Scripts läuft einstmal der MQTT Check:
    javascript.0 12:13:03.650 info Compiling TypeScript source script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001
    javascript.0 12:13:04.605 info source code did not change, using cached compilation result...
    javascript.0 12:13:04.960 info --- start of NsPanelTs: 0_userdata.0.NSPanels.NSPanel-UG-KZ. ---
    javascript.0 12:13:05.067 info setObjects enabled - create Alias Channels possible
    javascript.0 12:13:05.069 info weather alias for pirate-weather.0. already exists
    javascript.0 12:13:05.097 info registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    javascript.0 12:13:05.100 info No Updates for NSPanel available
    javascript.0 12:13:05.303 info Desired TFT Firmware: 59 / v5.0.0
    javascript.0 12:13:05.303 info Installed TFT Firmware: 59 / v5.0.0
    javascript.0 12:13:05.467 info Debug mode disabled
    javascript.0 12:13:06.548 info Desired TFT Firmware: 59 / v5.0.0
    javascript.0 12:13:06.549 info Installed TFT Firmware: 59 / v5.0.0
    javascript.0 12:13:06.673 info hidden Cards disabled
    javascript.0 12:13:08.286 info Start MQTT-Port-Check -------------------------------------
    javascript.0 12:13:08.286 info -- admin.0 - 8081
    javascript.0 12:13:08.286 info -- hm-rpc.0 - 1870
    javascript.0 12:13:08.286 info -- hm-rpc.1 - 1200
    javascript.0 12:13:08.286 info -- hm-rpc.2 - 1201
    javascript.0 12:13:08.286 info -- hue.0 - 443
    javascript.0 12:13:08.286 info -- influxdb.0 - 8086
    javascript.0 12:13:08.286 info -- mqtt.0 - 1887
    javascript.0 12:13:08.286 info -- node-red.0 - 1880
    javascript.0 12:13:08.286 info -- shelly.0 - 1886
    javascript.0 12:13:08.286 info -- telegram.0 - 8443
    javascript.0 12:13:08.286 info -- web.0 - 8082
    javascript.0 12:13:08.287 info - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1887
    javascript.0 12:13:08.287 info End MQTT-Port-Check ---------------------------------------
    Leider kommen dann nach einer kurzen Pause jede Menge Warnungen:
    javascript.0 12:13:35.143 warn at HandleScreensaverUpdate (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:14315:31)
    javascript.0 12:13:35.143 warn at Object.<anonymous> (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:4226:17)
    javascript.0 12:13:35.143 warn at step (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:33:23)
    usw.
    Ich habe dann versucht noch meine Pages aus dem alten Script wieder einzufügen. Leider ohne Erfolg! Wird nur das Servicemenü angezeigt.
    Bin für jeden Hinweis dankbar.
    VG MS
    T Nicht stören
    T Nicht stören
    ticaki
    #7658
    @mschmidt
    das usw. wäre schon interessant bis zur ersten wiederholung :)
    Spenden
    • T ticaki
      @mschmidt
      mschmidt
      #7659
      @ticaki
      javascript.0 14:01:01.030 warn at HandleScreensaverUpdate (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:14315:31)
      javascript.0 14:01:01.031 warn at HandleScreensaver (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:13894:5)
      javascript.0 14:01:01.031 warn at HandleMessage (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:5771:21)
      javascript.0 14:01:01.031 warn at script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:5458:21
      javascript.0 14:01:01.031 warn at step (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:33:23)
      javascript.0 14:01:01.031 warn at Object.next (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:14:53)
      javascript.0 14:01:01.031 warn at script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:8:71
      javascript.0 14:01:01.031 warn at HandleScreensaverUpdate (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:14315:31)
      javascript.0 14:01:01.032 warn at HandleScreensaverUpdate (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:14315:31)
      javascript.0 14:01:01.032 warn at HandleScreensaver (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:13894:5)
      javascript.0 14:01:01.032 warn at HandleMessage (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:5771:21)
      javascript.0 14:01:01.032 warn at script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:5458:21
      javascript.0 14:01:01.032 warn at step (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:33:23)
      javascript.0 14:01:01.032 warn at Object.next (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:14:53)
      javascript.0 14:01:01.032 warn at script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:8:71
      Dann wiederholt es sich etwa jede Minute.
      VG MS
      T M 2 Antworten Letzte Antwort
      • M mschmidt
        @ticaki
        VG MS
        T Nicht stören
        T Nicht stören
        ticaki
        #7660
        @mschmidt sagte in SONOFF NSPanel mit Lovelace UI:
        14315
        Danke - kopiere mir jetzt noch gerade hier rein was bei dir in Zeile 14315 im skript steht - wegen der Nutzer-Konfig ist das immer unterschiedlich.
        Spenden
        • M mschmidt
          usw.
          VG MS
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          Most Active Forum Testing
          #7661
          kein Screensaver?
          Falls da doch ein Screensaver ist, was zeigt der an?
          Hast du im neuen Script auch wieder das Pagearray eingefügt?
          • M mschmidt
            @ticaki
            VG MS
            mameier1234
            #7662
            @mschmidt
            Ich hatte das selbe Problem, da war im Script bei den Screensavern noch openweather. ... anstatt pirate-weather hinterlegt..
            Grüße,
            Martin
            • T ticaki
              14315
              mschmidt
              #7663
              @ticaki
              Zeile 14315 wäre ein Kommentarende. Habe mal die Zeilen davor und danach mit dazugenommen:
              • Determines the icon ID for a given page item based on the provided value thresholds.
              • If the icon3 property is missing or invalid, it immediately returns the fallback icon ID.
              • Otherwise, it delegates to determineStatusIcon, passing the relevant parameters.
              • @param {PageItem} pageItem - Contains icon references (icon, icon2, icon3) and threshold values.
              • @param {number} val - The current value used to evaluate thresholds.
              • @param {string} iconId - The fallback icon ID if no matching icon is found.
              • @param {[string, string, string]} [def] - Optional array of default icons corresponding to threshold levels. [low, high, between]
              • @returns {string} The icon ID determined by value, thresholds, and defaults.
                */ Zeile 14315
                function determinePageItemStatusIcon (pageItem: PageItem, val: number, iconId: string, def?: [string, string, string]): string {
                if (!pageItem.icon3 || typeof pageItem.icon3 !== 'string') {
                return iconId;
                const max = pageItem.maxValueLevel ?? pageItem.maxValue ?? 100;
                const min = pageItem.minValueLevel ?? pageItem.minValue ?? 0;
                return determineStatusIcon(pageItem.icon, pageItem.icon2, pageItem.icon3, val, min, max, iconId, def);
              • Determines an icon for the screensaver based on the provided value and icon configuration.
              • @param {NSPanel.ScreenSaverElement} ss - Object containing the ScreensaverEntityIconSelect array.
              • @param {number} val - The current value used to determine which icon to select.
              • @param {string} iconId - A fallback icon ID if no suitable icon can be retrieved.
              • @returns {string} The icon ID that matches the value thresholds, or the fallback icon ID.
                function determineScreensaverStatusIcon(ss: NSPanel.ScreenSaverElement, val: number, iconId: string): string {
                if (!ss) {
                return iconId;
                if (!ss.ScreensaverEntityIconSelect || !Array.isArray(ss.ScreensaverEntityIconSelect)) {
                return iconId;
                ss.ScreensaverEntityIconSelect = ss.ScreensaverEntityIconSelect.filter((item) => item);
                ss.ScreensaverEntityIconSelect = ss.ScreensaverEntityIconSelect.sort((a, b) => a.value - b.value);
                for (const item of ss.ScreensaverEntityIconSelect) {
                if (val <= item.value) {
                return Icons.GetIcon(item.icon) || iconId;
                return Icons.GetIcon(ss.ScreensaverEntityIconSelect[ss.ScreensaverEntityIconSelect.length - 1].icon) || iconId;
              Bei Screensaver habe ich den standard gelassen, und der wird auch korrekt auf dem Display angezeigt!
              • M mameier1234
                @mschmidt
                mschmidt
                #7664
                @mameier1234
                Meinst du diese Stelle im Script?
                // DE: Mögliche Wetteradapter 'pirate-weather.0.' oder 'brightsky.0.' oder 'openweathermap.0.' oder 'daswetter.0.' (deprecated) oder 'accuweather.0.' (deprecated)
                // EN: Possible weather adapters 'pirate-weather.0.' or 'brightsky.0.' or 'openweathermap.0.' or 'daswetter.0.' (deprecated) or 'accuweather.0.' (deprecated)
                const weatherAdapterInstance: string = 'pirate-weather.0.';
                T ArmilarA M 3 Antworten Letzte Antwort
                • M mschmidt
                  @mameier1234
                  T Nicht stören
                  T Nicht stören
                  ticaki
                  #7665
                  @mschmidt
                  Ja Mist, da wird das globale Skript davor kopiert, da stimmen die Zeilennummern nicht mehr. AFAIK
                  Gucke mal was Armilar meint, der kennt sich mit dem Skript richtig gut aus. :)
                  Spenden
                  • ArmilarA Armilar
                    kein Screensaver?
                    mschmidt
                    #7666
                    @armilar
                    ok, dein Hinweis mit den Pages hat geholfen, dass ich die Seiten nun wieder aufrufen kann. Das hatte ich in der Tat vergessen! :(
                    Das mit den Warnungen habe ich aber immer noch.
                    Beim Screensaver habe ich alles auf Standard gelassen. (Zeit mit Wettervorhersage der nächsten 4 Tage) Das wird auch angezeigt.
                    Das sind die Warnungen die sich dann immer wieder wiederholen:
                    javascript.0 10:35:04.670 warn at HandleScreensaverUpdate (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:14318:31)
                    javascript.0 10:35:04.670 warn at Object.<anonymous> (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:4229:17)
                    javascript.0 10:35:04.670 warn at step (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:33:23)
                    javascript.0 10:35:04.670 warn at Object.next (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:14:53)
                    javascript.0 10:35:04.670 warn at script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:8:71
                    javascript.0 10:35:04.670 warn at __awaiter (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:4:12)
                    javascript.0 10:35:04.670 warn at Object.<anonymous> (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:4225:12)
                    javascript.0 10:35:04.671 warn at HandleScreensaverUpdate (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:14318:31)
                    javascript.0 10:35:04.671 warn at Object.<anonymous> (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:4229:17)
                    javascript.0 10:35:04.671 warn at step (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:33:23)
                    javascript.0 10:35:04.671 warn at Object.next (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:14:53)
                    javascript.0 10:35:04.671 warn at script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:8:71
                    javascript.0 10:35:04.671 warn at __awaiter (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:4:12)
                    javascript.0 10:35:04.671 warn at Object.<anonymous> (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:4225:12)
                    javascript.0 10:35:04.672 warn at __awaiter (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:4:12)
                    javascript.0 10:35:04.672 warn at Object.<anonymous> (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:4225:12)
                    javascript.0 10:35:04.672 warn at HandleScreensaverUpdate (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:14318:31)
                    javascript.0 10:35:04.672 warn at Object.<anonymous> (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:4229:17)
                    javascript.0 10:35:04.672 warn at step (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:33:23)
                    javascript.0 10:35:04.672 warn at Object.next (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:14:53)
                    javascript.0 10:35:04.673 warn at script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:8:71
                    javascript.0 10:35:04.673 warn at __awaiter (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:4:12)
                    javascript.0 10:35:04.673 warn at Object.<anonymous> (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:4225:12)7
                    • M mschmidt
                      @mameier1234
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #7667
                      @mschmidt
                      2 Absätze darunter wird ein Alias durch das Script für den Wetteradapter erstellt. Dieser Alias wird nicht automatisch gelöscht. Am Besten ist, den Alias-Namen umzubenennen:
                      /***** 3. Weather adapter Config *****/
                      // DE: Mögliche Werte: 'Min', 'Max' oder 'MinMax' im Screensaver
                      // EN: Possible values: 'Min', 'Max' or 'MinMax' in the screensaver
                      const weatherScreensaverTempMinMax: string = 'MinMax';
                      // DE: Dieser Alias wird automatisch für den gewählten Wetter erstellt und kann entsprechend angepasst werden
                      // EN: This alias is automatically created for the selected weather and can be adjusted accordingly
                      const weatherEntityPath: string = 'alias.0.PirateWeather'; //Please rename if change weatherAdapterInstance!
                      Und mal kurz dein Page-Array posten (siehe Post vom 8.10.)
                      https://forum.iobroker.net/post/1298989
                      • ArmilarA Armilar
                        @mschmidt
                        mschmidt
                        #7668
                        @armilar
                        const weatherEntityPath: string = 'alias.0.Pirate_Weather'; //Please rename if change weatherAdapterInstance!
                        ok das habe ich gefunden, aber ich stehe ein wenig auf dem Schlauch was ich dort ändern soll?
                        • M mschmidt
                          @armilar
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          #7669
                          @mschmidt
                          Nee ist okay... der ist ja schon umbenannt...
                          Gibt es zwischen den Warnungen auch richtige info Logs? Ich sehe da nur warn und damit kann ich nicht wirklich etwas anfangen...
                          Würde dennoch gerne einen Blick auf die Daten des alias.0.Pirate_Weather werfen:
                          bei mir:
                          Übrigens kannst du wenn du die Infos geschrieben hast den entsprechenden Text markieren und dann auf a1182e43-56de-4d32-a043-665033e3002b-image.png klicken... Dann wird der Inhalt besser formatiert dargestellt...
                          • ArmilarA Armilar
                            @mschmidt
                            bei mir:
                            mschmidt
                            #7670
                            @armilar
                            ausser den Warnungen ist nichts im Log zu sehen
                            • M mschmidt
                              @armilar
                              ArmilarA Offline
                              ArmilarA Offline
                              Armilar
                              #7671
                              Zu den Bildern... Ich hatte mir dabei erhofft, Werte zu sehen... Inhalte aus dem Pirate-Weather Adapter...
                              Hintergrund: In den Warnungen stehen Funktionen mit HandleScreensaverUpdate... Dort wird der Screensaver regelmäßig upgedatet und u.a. die Wetterdaten durchlaufen und aktualisiert. An dieser Stelle funktioniert etwas nicht...
                              Kann alles mögliche sein:
                              • Script ist nicht komplett erneuert und nicht 5.0.0.1 oder 5.0.0.2 (Voraussetzung für Pirate-Weather)
                              • Adapter Pirate-Weather liefert keine Min-Max Temperaturdaten oder Icon oder Zeitstempel
                              • Alias wurde erst umbenannt, dann der Adapter umgestellt --> Dann wären im Alias falsche Adapterdaten
                              • ioBroker nicht aktuell
                              • ioBroker lange nicht restartet
                              • niedrige nodeJS Version
                              • etc. (also alles mögliche)
                              Wenn du nicht minimalistisch mal etwas mehr zeigst, wird jegliche Hilfe sehr kompliziert...
                              • ArmilarA Armilar
                                mschmidt
                                #7672
                                @armilar
                                Script ist nicht komplett erneuert und nicht 5.0.0.1 oder 5.0.0.2 (Voraussetzung für Pirate-Weather) -> noch mal neu erstellt mit der letzten verfügbaren Version von "https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/ioBroker/NsPanelTs.ts"
                                Adapter Pirate-Weather liefert keine Min-Max Temperaturdaten oder Icon oder Zeitstempel ->
                                aktuelle Wetterdaten sind in den Objekten unter pirate-weather zu sehen
                                die Daten die in den Adapterobjekten zu sehen sind stimmen mit den alias Daten überein!
                                ioBroker nicht aktuell --> 7.7.2
                                ioBroker lange nicht restartet --> Uptime < 2h
                                niedrige nodeJS Version -> Node.js: v20.19.5
                                Ich weiß leider nicht was du für Infos benötigt aber bin gerne bereit diese zu teilen wenn ich weiß welche!
                                • M mschmidt
                                  @armilar
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  #7673
                                  @mschmidt
                                  okay passt...
                                  Wenn du den Screensaver ansiehst, ist da etwas falsch dargestellt?
                                  Muss nicht unbedingt nur das Wetter sein, kann auch jeder andere Wert sein... Falls weitere Datenpunkte dargestellt werden, die ggfs. ebenfalls aus anderen Adaptern kommen und evtl. nicht mehr existieren, kann das ebenfalls passieren.
                                  Beispiel: Windgeschwindigkeit aus Accuweather definiert, aber Accuweather deinstalliert?
                                  Bitte den Debug im Skript mal auf true stellen und das Log senden
                                  • W Offline
                                    W Offline
                                    welli
                                    #7674
                                    Hallo
                                    Bekomme seit einigen Tagen diese Info im Protokoll Fenster.
                                    Hat jemand ein Idee wie was das sein könnte?
                                    mqtt.0
                                    2025-10-10 18:32:45.158 info Client [DVES_0B8CD4] connection closed: Error: read ECONNRESET
                                    mqtt.0
                                    2025-10-10 18:30:47.717 info Client [DVES_0B8CD4] publishOnSubscribe send all known states
                                    mqtt.0
                                    mqtt.0
                                    2025-10-10 18:30:47.715 info Client [DVES_0B8CD4] publishOnSubscribe send all known states
                                    mqtt.0
                                    2025-10-10 18:30:47.516 info Client [DVES_0B8CD4] subscribes on "cmnd/DVES_0B8CD4_fb/#" with regex /^mqtt.0.cmnd.DVES_0B8CD4_fb..*/
                                    mqtt.0
                                    2025-10-10 18:30:47.516 info Client [DVES_0B8CD4] subscribes on "cmnd/DVES_0B8CD4_fb/#" with regex /^cmnd.DVES_0B8CD4_fb..*/
                                    mqtt.0
                                    2025-10-10 18:30:47.516 info Client [DVES_0B8CD4] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^mqtt.0.SmartHome.tasmotas.cmnd..*/
                                    mqtt.0
                                    2025-10-10 18:30:47.516 info Client [DVES_0B8CD4] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome.tasmotas.cmnd..*/
                                    mqtt.0
                                    2025-10-10 18:30:47.516 info Client [DVES_0B8CD4] subscribes on "SmartHome/NSPanel_2/cmnd/#" with regex /^mqtt.0.SmartHome.NSPanel_2.cmnd..*/
                                    mqtt.0
                                    2025-10-10 18:30:47.516 info Client [DVES_0B8CD4] subscribes on "SmartHome/NSPanel_2/cmnd/#" with regex /^SmartHome.NSPanel_2.cmnd..*/
                                    mqtt.0
                                    2025-10-10 18:30:47.463 info Client [DVES_0B8CD4] connected with secret 1760113847461_6512
                                    mqtt.0
                                    2025-10-10 18:30:47.277 info Client [DVES_0B8CD4] connection closed: Error: Cannot parse topic
                                    mqtt.0
                                    2025-10-10 18:30:47.277 info Client [DVES_0B8CD4] Received pubrel for unknown message ID: 25964
                                    mqtt.0
                                    mqtt.0
                                    mqtt.0
                                    2025-10-10 18:30:42.684 info Client [DVES_0B8CD4] Received pubrel for unknown message ID: 25964
                                    mqtt.0
                                    2025-10-10 18:30:42.558 info Client [DVES_0B8CD4] Received pubrel for unknown message ID: 25964
                                    mqtt.0
                                    2025-10-10 18:30:42.268 info Client [DVES_0B8CD4] Received pubrel for unknown message ID: 25964
                                    • W welli
                                      Hallo
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      ArmilarA Offline
                                      ArmilarA Offline
                                      Armilar
                                      #7675
                                      @welli
                                      Sieh mal nach, ob da ein Haken bei "Ausgabe jeder Nachricht loggen (debug)" gesetzt ist. Falls ja, entfernen...
                                      Mir quatscht der MQTT-Adapter sowieso zu viel... Habe den Log-Level auf warn eingestellt. Dann kommt nur noch das wichtige...
                                      W 1 Antwort Letzte Antwort
                                      • ArmilarA Armilar
                                        @mschmidt
                                        okay passt...
                                        mschmidt
                                        #7676
                                        @armilar
                                        Hier das log im Debug Mode:
                                        debug.log
                                        debug_2.log
                                        Was mir aufgefallen ist, das die Anzeige des Datum/Uhrzeit immer noch bei Freitag 15:05 Uhr stehen geblieben ist
                                        • M mschmidt
                                          @armilar
                                          debug.log
                                          debug_2.log
                                          TT-Tom
                                          #7677
                                          @mschmidt
                                          Du wirst ein Problem mit Deiner MQTT Verbindung haben. Hast Du am MQTT Adapter oder am Panel in Tasmota was angepasst???
                                          Gruß Tom
                                          Public Transport
                                          NSPanel Adapter Wiki
