  4. Test Adapter BMW/Mini v4.x.x
    6.8k
1.1k Beiträge 103 Kommentatoren 377.7k Aufrufe 89 Beobachtet
  • M MP_Trixi
    @stenmic
    werd ich versuchen
    bei mir ist der Adapter gerade ausgestiegen und hat sich neu gestartet:
    bmw.0
    2025-10-01 14:23:29.921	info	terminating
    bmw.0
    2025-10-01 14:23:29.711	warn	MQTT connection closed
    bmw.0
    2025-10-01 14:23:29.419	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    bmw.0
    2025-10-01 14:23:29.416	info	terminating
    bmw.0
    2025-10-01 14:23:29.355	error	used is not defined
    bmw.0
    2025-10-01 14:23:29.355	error	ReferenceError: used is not defined at Bmw.updateQuotaStates (/opt/iobroker/node_modules/iobroker.bmw/main.js:585:12) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.bmw/main.js:122:11) at listOnTimeout (node:internal/timers:581:17) at processTimers (node:internal/timers:519:7)
    bmw.0
    2025-10-01 14:23:29.352	error	unhandled promise rejection: used is not defined
    bmw.0
    2025-10-01 14:23:29.351	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    bmw.0
    2025-10-01 14:18:37.201	warn	State "bmw.0.xxx.remotev2.force-refresh" has no existing object, this might lead to an error in future versions
    bmw.0
    2025-10-01 14:18:37.192	info	BMW CarData only provides vehicle data, no command functionality
    bmw.0
    2025-10-01 14:18:37.191	warn	Remote controls not available in BMW CarData (read-only API)
    bmw.0
    2025-10-01 14:18:36.293	warn	State "bmw.0.xxx.remotev2.force-refresh" has no existing object, this might lead to an error in future versions
    bmw.0
    2025-10-01 14:18:36.208	info	BMW CarData only provides vehicle data, no command functionality
    bmw.0
    2025-10-01 14:18:36.206	warn	Remote controls not available in BMW CarData (read-only API)
    bmw.0
    2025-10-01 14:14:52.920	info	Cleaning up complete old auth folder from previous version
    bmw.0
    2025-10-01 14:13:29.475	info	BMW MQTT stream connected
    bmw.0
    2025-10-01 14:13:29.352	info	API quota: 50/50 calls remaining
    bmw.0
    2025-10-01 14:13:29.351	info	MQTT streaming: enabled
    bmw.0
    2025-10-01 14:13:29.348	info	BMW CarData adapter startup complete
    bmw.0
    2025-10-01 14:13:29.345	info	Setting up periodic updates every 10 minutes for 1 vehicle(s)
    bmw.0
    2025-10-01 14:13:26.573	error	BMW CarData vehicle discovery failed: used is not defined
    bmw.0
    2025-10-01 14:13:26.571	info	Fetching 8 configured API endpoints for xxx...
    bmw.0
    2025-10-01 14:13:26.047	info	Cleaning old states for xxx (upgrading from previous version)
    bmw.0
    2025-10-01 14:13:26.040	info	Added vehicle: xxx
    bmw.0
    2025-10-01 14:13:26.039	info	Found 1 BMW vehicles
    bmw.0
    2025-10-01 14:13:25.214	info	Starting BMW CarData vehicle discovery...
    bmw.0
    2025-10-01 14:13:25.212	info	BMW CarData authorization successful!
    tombox
    #723
    @mp_trixi 4.0.2 testen
    M S 2 Antworten Letzte Antwort
    • Marc BergM Marc Berg
      @mp_trixi sagte in Test Adapter BMW/Mini v2.0.0:
      @Marc-Berg @stenmic @michiproep
      sieht jemand den erstellten Client auf der BMW Website? Bei mir sieht man nur noch die Daten (user etc) in der Stream Section. Beim Client ist wieder der Button um einen neuen zu erstellen.
      Ist bei mir auf der Website auch wieder verschwunden, es funktioniert aber trotzdem.
      @tombox : Einfach Klasse! Schade, dass ich meinen Mini in drei Wochen abgebe ... :-)
      jrichl
      #724
      Respekt wie schnell hier eine Lösung geschaffen wurde. Ich bekomme momentan noch im iobroker Log die folgende Warning und der stream liefert auch noch keine Daten - aber in Summe geht das in die richtige Richtung
        manny4566
        schrieb am zuletzt editiert von manny4566
        #725
        Hab ich das richtig verstanden, dass man somit pro Auto eine eigene Adapter Instanz braucht ?
        Edit: ne braucht man natürlich nicht :)
        • T tombox
          MP_Trixi
          schrieb am zuletzt editiert von MP_Trixi
          #726
          @tombox
          ist drauf - im api kommen jetzt basicData und Respekt. Hammer reaktiv und tolle Arbeit!
          liegt das access denied noch an einer Einstellung auf BMW Seite oder liegt das an deren Änderung, sprich dass man z.B. nur noch lesen und nicht mehr schreiben kann?
          bmw.0
          2025-10-01 14:34:52.914	info	BMW MQTT stream connected
          bmw.0
          2025-10-01 14:34:52.814	info	API quota: 42/50 calls remaining
          bmw.0
          2025-10-01 14:34:52.814	info	MQTT streaming: enabled
          bmw.0
          2025-10-01 14:34:52.814	info	BMW CarData adapter startup complete
          bmw.0
          2025-10-01 14:34:52.813	info	Setting up periodic updates every 10 minutes for 1 vehicle(s)
          bmw.0
          2025-10-01 14:34:50.387	warn	vehicleState access denied for xxx (403)
          bmw.0
          2025-10-01 14:34:50.343	warn	statistics access denied for xxx (403)
          bmw.0
          2025-10-01 14:34:50.297	warn	location access denied for xxx (403)
          bmw.0
          2025-10-01 14:34:50.252	warn	climateNow access denied for xxx (403)
          bmw.0
          2025-10-01 14:34:50.206	warn	chargingSessions access denied for xxx (403)
          bmw.0
          2025-10-01 14:34:50.159	warn	chargingProfile access denied for xxx (403)
          bmw.0
          2025-10-01 14:34:48.786	info	Updated vehicle name: i4 M50 (xxx)
          bmw.0
          2025-10-01 14:34:47.544	info	Fetching 8 configured API endpoints for xxx...
          bmw.0
          2025-10-01 14:34:47.466	info	Added vehicle: xxx
          bmw.0
          2025-10-01 14:34:47.466	info	Found 1 BMW vehicles
          bmw.0
          2025-10-01 14:34:46.971	info	Starting BMW CarData vehicle discovery...
          bmw.0
          2025-10-01 14:34:43.853	info	Found stored BMW CarData session
          bmw.0
          2025-10-01 14:34:43.561	info	starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.bmw, node: v20.19.5, js-controller: 7.0.7
          bmw.0
          2025-10-01 14:34:12.822	info	terminating
          @stenmic Auto gestartet und stream ist nun gefüllt
          • J jrichl
            jrichl
            #727
            @jrichl said in Test Adapter BMW/Mini v2.0.0:
            die Warning scheint jetzt weg zu sein, inzwischen kommen auch über den Stream Werte rein - ich bin begeistert.
            • H Offline
              Hag-En
              #728
              Mit 4.0.2 kommt bei mir jetzt auch was bei API - aber es kommen auch Fehler:
              • H Hag-En
                stenmic
                schrieb am zuletzt editiert von stenmic
                #729
                V4.0.2
                API basicData wurden befüllt.
                • S stenmic
                  V4.0.2
                  tombox
                  #730
                  @stenmic 4.0.3 testen
                  M H D S 4 Antworten Letzte Antwort
                  • T tombox
                    MP_Trixi
                    #731
                    @tombox
                    bmw.0
                    2025-10-01 14:58:31.464	info	BMW MQTT stream connected
                    bmw.0
                    2025-10-01 14:58:31.351	info	API quota: 24/50 calls remaining
                    bmw.0
                    2025-10-01 14:58:31.349	info	MQTT streaming: enabled
                    bmw.0
                    2025-10-01 14:58:31.347	info	BMW CarData adapter startup complete
                    bmw.0
                    2025-10-01 14:58:31.346	info	Setting up periodic updates every 10 minutes for 1 vehicle(s)
                    bmw.0
                    2025-10-01 14:58:27.388	info	Updated vehicle name: i4 M50 (xxx)
                    bmw.0
                    2025-10-01 14:58:26.522	info	Fetching 2 configured API endpoints for xxx...
                    bmw.0
                    2025-10-01 14:58:26.444	info	Added vehicle: xxx
                    bmw.0
                    2025-10-01 14:58:26.443	info	Found 1 BMW vehicles
                    bmw.0
                    2025-10-01 14:58:25.948	info	Starting BMW CarData vehicle discovery...
                    bmw.0
                    2025-10-01 14:58:17.113	info	Found stored BMW CarData session
                    bmw.0
                    2025-10-01 14:58:16.898	info	starting. Version 4.0.3 in /opt/iobroker/node_modules/iobroker.bmw, node: v20.19.5, js-controller: 7.0.7
                    bmw.0
                    2025-10-01 14:58:02.516	info	terminating
                    • T tombox
                      Hag-En
                      #732
                      @tombox Basic kommt, Bild und Telematik nicht (ich rufe nur die drei ab).
                      • T tombox
                        Derda 0
                        #733
                        @tombox
                        Warning "vehicleState access denied for WBY..." ist weg mit 4.0.3, aber die MQTT-Werte werden nicht aktualisiert. Log sagt "BMW MQTT stream connected", bmw.0.info.mqttConnected hat den Wert true mit timestamp 15:05, aber bmw.0.WBYxxx.lastStreamUpdate ist Wed Oct 01 2025 14:46:25 GMT+0200 (Central European Summer Time).
                        • T tombox
                          stenmic
                          #734
                          @tombox mit 4.0.3 keine Fehler im Log.
                          Aber bisher nur Werte bei basicData.
                          Der Datenpunkt "apiQuotaUsed" aktualisiert sich nicht bei mir.
                          Im Log beim Start aber schon.
                          • D Derda 0
                            @tombox
                            Marc BergM Online
                            Marc BergM Online
                            Marc Berg
                            #735
                            @derda-0 sagte in Test Adapter BMW/Mini v2.0.0:
                            MQTT Werte aktualisieren sich nur, falls sich am Auto was ändert (Tür geöffnet, km-Stand, ...). Sonst nicht und auch der timestamp aktualisiert sich nicht.
                              Derda 0
                              #736
                              @marc-berg said in Test Adapter BMW/Mini v4.x.x:
                              Danke für den Hinweis, aber der Ladestand hat sich in der Zeit von 69% auf 73% erhöht laut App. Müsste also aktualisieren.
                              Allerdings steht mittlerweile im log eine warning "MQTT connection closed".
                              Marc BergM M Steffe.S.S 3 Antworten Letzte Antwort
                              • D Derda 0
                                Marc BergM Online
                                Marc BergM Online
                                Marc Berg
                                #737
                                Okay, das würde das Verhalten erklären. Bei mir kommt diese Meldung (bisher) nur beim Adapter Neustart.
                                • D Derda 0
                                  manny4566
                                  #738
                                  @derda-0
                                  Kann das verhalten auch bei mir bestätigen.
                                  Selbst nach Türen öffnen kamen dann paar Daten in den Stream rein, aber bis jetzt kein Datenpunkt zum Ladestand. Das Auto lädt ebenfalls gerade bei mir.
                                  EDIT: Sorry, hab jetzt den Datenpunkt gefunden. Mal sehen ob er sich aktualisiert.
                                  • M manny4566
                                    @derda-0
                                    Marc BergM Online
                                    Marc BergM Online
                                    Marc Berg
                                    #739
                                    @manny4566 sagte in Test Adapter BMW/Mini v2.0.0:
                                    Bin auch gerade am Laden. Es scheint so, dass das Auto der MQTT Broker nicht bei jedem Prozent Änderung Updates liefert, sondern nur alle 5%?
                                    • D Derda 0
                                      Steffe.S.S Offline
                                      Steffe.S.S Offline
                                      Steffe.S.
                                      schrieb am zuletzt editiert von Steffe.S.
                                      #740
                                      @derda-0 sagte in Test Adapter BMW/Mini v4.x.x:
                                      "MQTT connection closed" habe ich auch stehen (Auto ist abgeschlossen und steht einfach so da ohne Ladevorgang o.ä.)
                                      Update:
                                      1 Minute später :MQTT hat sich selber wieder verbunden
                                        Derda 0
                                        #741
                                        Ich habe den Adapter um 15:39 Uhr noch einmal mit debug gestartet. Danach sieht alles tippi-toppi aus. Im Detail:
                                        2025-10-01 15:39:40.413 - info: host.581b69826838 instance system.adapter.bmw.0 in version "4.0.3" (non-npm: TA2k/ioBroker.bmw) started with pid 26432
                                        2025-10-01 15:39:51.422 - debug: bmw.0 (26432) Subscribed to MQTT topic: XXX...XXX/+
                                        5 Minuten später kamen jede Menge Daten:
                                        2025-10-01 15:44:34.469 - debug: bmw.0 (26432) MQTT message on XXXX/WBYYYYY: {"vin":"WBYYYYYY","entityId":"XXXXX","topic":"WBYYYYYYYY","timestamp":"2025-10-01T13:44:34.052Z","data":{"vehicle.vehicle.preConditioning.activity":{"timestamp":"2025-10-01T13:44:31Z","value":"INACTIVE"}}}
                                        2025-10-01 15:44:34.469 - debug: bmw.0 (26432) MQTT: WBYYYYYYY - 1 data points
                                        Danach in unregelmäßigen Abständen wieder jede Menge:
                                        2025-10-01 15:51:03.738 - debug: bmw.0 (26432) MQTT message on ...
                                        2025-10-01 15:54:57.938 - debug: bmw.0 (26432) MQTT message on ...
                                        2025-10-01 16:06:21.267 - debug: bmw.0 (26432) MQTT message on ...
                                        In dieser Zeit hat das Auto geladen, was um 16:06 beendet wurde.
                                        16:24 hat der Adapter die Verbindung mit einem neuen Token aufgebaut. Die warn-Meldungen "MQTT connection closed" scheinen also harmlos zu sein. @tombox Sollten die dann nicht info sein? Oder sind die doch nicht harmlos?
                                        2025-10-01 16:24:51.206 - debug: bmw.0 (26432) Refreshing BMW CarData tokens
                                        2025-10-01 16:24:51.206 - debug: bmw.0 (26432) Refresh token URL: https://customer.bmwgroup.com/gcdm/oauth/token
                                        2025-10-01 16:24:51.206 - debug: bmw.0 (26432) Client ID: 3174xxxx
                                        2025-10-01 16:24:51.206 - debug: bmw.0 (26432) Refresh request data: {"grant_type":"refresh_token","refresh_token":"XXXXXX","client_id":"3174xxxx"}
                                        2025-10-01 16:24:53.987 - debug: bmw.0 (26432) Tokens refreshed successfully
                                        2025-10-01 16:24:53.987 - debug: bmw.0 (26432) Reconnecting MQTT with new token
                                        2025-10-01 16:24:54.015 - warn: bmw.0 (26432) MQTT connection closed
                                        2025-10-01 16:24:55.989 - debug: bmw.0 (26432) Connecting to BMW MQTT: customer.streaming-cardata.bmwgroup.com:9000
                                        2025-10-01 16:24:55.990 - debug: bmw.0 (26432) MQTT Username: 75XXXXX
                                        2025-10-01 16:24:56.119 - info: bmw.0 (26432) BMW MQTT stream connected
                                        2025-10-01 16:24:56.170 - debug: bmw.0 (26432) Subscribed to MQTT topic: 75XXXXXX/+
                                        17:09 dann wieder ein neues Token.
                                        17:20 habe ich per App das Auto entriegelt. Auch die Daten kamen und wenig später die Info, dass das Auto wieder verschlossen war.
                                        Besten Gruß
                                        Bodo
                                          Derda 0
                                          #742
                                          @tombox
                                          Was aber nicht funktioniert ist die charging history. Dazu bekomme ich jedesmal:
                                          2025-10-01 17:19:51.213 - debug: bmw.0 (26432) Periodic API refresh for WBYYYYYY
                                          2025-10-01 17:19:51.216 - info: bmw.0 (26432) Fetching 2 configured API endpoints for WBYYYYYYYY...
                                          2025-10-01 17:19:51.216 - debug: bmw.0 (26432) Fetching basicData for WBYYYYYY
                                          2025-10-01 17:19:51.802 - info: bmw.0 (26432) Updated vehicle name: iX3 M Sport (WBYYYYYYYYY)
                                          2025-10-01 17:19:51.802 - debug: bmw.0 (26432) ✓ basicData for WBYYYYYYYYYYYYY
                                          2025-10-01 17:19:52.803 - debug: bmw.0 (26432) Fetching chargingHistory for WBYYYYYYYYYYYYYYYY
                                          2025-10-01 17:19:52.864 - debug: bmw.0 (26432) chargingHistory failed for WBYYYYYYYYYYYYY: Request failed with status code 400
                                          T D 2 Antworten Letzte Antwort
