  4. Visu App macht Probleme
    1.0k
    6.1k
appvisuladeprobleme
35 Beiträge 5 Kommentatoren 3.1k Aufrufe 3 Beobachtet
  • D Dragon
    @crunchip
    Und was mache ich jetzt? Weil ja nur die App Probleme macht. Die Cloudanbindung funktioniert ja, wie ich ja geschrieben hatte.
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)                       Static hostname: ioBroker
           Icon name: computer-vm
             Chassis: vm 🖴
        AF_VSOCK CID: 1                                                   Virtualization: kvm
              Kernel: Linux 6.12.43+deb13-amd64                             Architecture: x86-64
     Hardware Vendor: QEMU                                                Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
       Firmware Date: Tue 2014-04-01
        Firmware Age: 11y 5month 3w 3d
    OS is similar to:
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     19:44:16 up 9 days,  2:42,  1 user,  load average: 0.28, 0.63, 0.80CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    This system needs to be REBOOTED!
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-09-24 19:44:16 CEST
               Universal time: Wed 2025-09-24 17:44:16 UTC
                     RTC time: Wed 2025-09-24 17:44:16
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    brokeradmin
    HOME=/home/brokeradmin
    GROUPS=brokeradmin adm dialout sudo audio video plugdev users iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/brokeradmin
    GROUPS=iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.3G        5.8G        1.6G        2.8M        1.3G        2.5G
    Swap:           1.0G        676M        346M
    Total:          9.4G        6.5G        1.9G
    Active iob-Instances:   73
             7947 M total memory
             5546 M used memory
             4783 M active memory
             1204 M inactive memory
             1496 M free memory
               73 M buffer memory
             1120 M swap cache
              974 M total swap
              644 M used swap
              330 M free swap
    top - 19:44:17 up 9 days,  2:42,  1 user,  load average: 0.28, 0.63, 0.80
    Tasks: 177 total,   1 running, 176 sleeping,   0 stopped,   0 zombie%Cpu(s): 42.9 us,  4.8 sy,  0.0 ni, 47.6 id,  0.0 wa,  0.0 hi,  0.0 si,  4.8 st
    MiB Mem :   7947.8 total,   1496.4 free,   5545.8 used,   1194.4 buff/cache
    MiB Swap:    975.0 total,    330.1 free,    644.9 used.   2402.0 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     795M  560K  795M   1% /run
    /dev/sda1      ext4       31G   25G  4.5G  85% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     3.9G  2.3M  3.9G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     795M  8.0K  795M   1% /run/user/1002
    [Mon Sep 15 17:02:01 2025] EXT4-fs (sda1): mounted filesystem a6df39e5-8210-4c92-b9c8-b4b557b9e693 ro with ordered data mode. Quota mode: none.
    [Mon Sep 15 17:02:02 2025] EXT4-fs (sda1): re-mounted a6df39e5-8210-4c92-b9c8-b4b557b9e693 r/w.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    1.2G    /var/
    834M    /var/log
    804M    /var/log/journal/58d2cc2a97184623922200d7fac194bf
    189M    /var/lib
    Archived and active journals take up 803.1M in the file system.
    /opt/iobroker/backups:
    6.5G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.4G    /opt/iobroker/iobroker-data/
    1.3G    /opt/iobroker/iobroker-data/files
    718M    /opt/iobroker/iobroker-data/history
    301M    /opt/iobroker/iobroker-data/backup-objects
    211M    /opt/iobroker/iobroker-data/files/vis
    58M     /opt/iobroker/iobroker-data/objects.jsonl
    38M     /opt/iobroker/iobroker-data/states.jsonl
    30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.5
    /usr/bin/node           v20.19.5
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.33.0
    nodejs:
      Installed: 20.19.5-1nodesource1
      Candidate: 20.19.5-1nodesource1
      Version table:
     *** 20.19.5-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.4-1nodesource1 1001
         20.19.3-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 787337)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.2
    javascript:     9.0.6
    nodejs modules from github:     4
    +-- iobroker.apsystemsez1@0.0.7 (git+ssh://git@github.com/hefegraphie/ioBroker.apsystemsez1.git#0e771c9d92c4bb4e662b09022820f2aa48358c50)
    +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    +-- iobroker.vis-fancyswitch@1.1.0 (git+ssh://git@github.com/ioBroker/ioBroker.vis-fancyswitch.git#62fe89a9bf646392c6a53e7f91744352409135ae)
    Adapter State
    + system.adapter.adguard.0                : adguard               : ioBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.apsystemsez1.0           : apsystemsez1          : ioBroker                                 -  enabled
    + system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.bambulab.0               : bambulab              : ioBroker                                 -  enabled, port: 8883
    + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
    + system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
    + system.adapter.countdown.0              : countdown             : ioBroker                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
      system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBroker                                 -  enabled
    + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
    + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
      system.adapter.iceroad.0                : iceroad               : ioBroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
      system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: ioBroker                                 -  enabled  system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
      system.adapter.icons-freepic.0          : icons-freepic         : ioBroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
      system.adapter.icons-smarthome.0        : icons-smarthome       : ioBroker                                 -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
    + system.adapter.imap.0                   : imap                  : ioBroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
    + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
    + system.adapter.matter.0                 : matter                : ioBroker                                 -  enabled
    + system.adapter.meross.0                 : meross                : ioBroker                                 -  enabled
    + system.adapter.meross.1                 : meross                : ioBroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1890, bind: 192.168.178.3
    + system.adapter.mytime.0                 : mytime                : ioBroker                                 -  enabled
    + system.adapter.net-tools.0              : net-tools             : ioBroker                                 -  enabled
    + system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
    + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
    + system.adapter.notificationforandroidtv.0: notificationforandroidtv: ioBroker                                 -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : ioBroker                                 -  enabled
    + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
      system.adapter.octoprint.0              : octoprint             : ioBroker                                 - disabled
      system.adapter.odl.0                    : odl                   : ioBroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
      system.adapter.parcel.0                 : parcel                : ioBroker                                 - disabled
    + system.adapter.philips-tv.0             : philips-tv            : ioBroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
    + system.adapter.pushsafer.0              : pushsafer             : ioBroker                                 -  enabled
      system.adapter.rickshaw.0               : rickshaw              : ioBroker                                 - disabled
    + system.adapter.ring.0                   : ring                  : ioBroker                                 -  enabled
    + system.adapter.samsung.0                : samsung               : ioBroker                                 -  enabled
      system.adapter.sayit.0                  : sayit                 : ioBroker                                 - disabled
      system.adapter.schoolfree.0             : schoolfree            : ioBroker                                 -  enabled
      system.adapter.schoolfree.1             : schoolfree            : ioBroker                                 -  enabled
    + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
    + system.adapter.signal-cmb.0             : signal-cmb            : ioBroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 192.168.178.3
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
      system.adapter.telegram-menu.0          : telegram-menu         : ioBroker                                 - disabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.2               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.3               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.4               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.5               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
    + system.adapter.text2command.1           : text2command          : ioBroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: ioBroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker                                 - disabled
      system.adapter.vis-lcars.0              : vis-lcars             : ioBroker                                 - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker                                 - disabled
      system.adapter.vis-material.0           : vis-material          : ioBroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
    + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 -  enabled
    + system.adapter.windows-control.0        : windows-control       : ioBroker                                 -  enabled
    + system.adapter.wireguard.0              : wireguard             : ioBroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
    + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: tcp://192.168.178.222:6638
    + instance is alive
    ioBroker-Repositories
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "adguard"      : 1.0.1    , installed 1.0.1
    Adapter    "admin"        : 7.7.2    , installed 7.7.2
    Adapter    "awtrix-light" : 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "countdown"    : 3.0.0    , installed 3.0.0
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.13.1  , installed 2.13.1
    Adapter    "devices"      : 1.2.8    , installed 1.2.8
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "followthesun" : 0.5.2    , installed 0.5.2
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
    Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
    Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
    Adapter    "imap"         : 0.3.0    , installed 0.3.0
    Adapter    "iot"          : 3.3.0    , installed 3.5.2
    Adapter    "javascript"   : 8.9.2    , installed 9.0.6
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
    Adapter    "matter"       : 0.5.2    , installed 0.5.2
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mytime"       : 1.4.7    , installed 1.4.7
    Adapter    "net-tools"    : 1.1.2    , installed 1.2.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.26
    Adapter    "notification-manager": 1.3.0, installed 1.3.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "odl"          : 5.0.0    , installed 5.0.0
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
    Adapter    "ping"         : 1.6.2    , installed 1.7.9
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "pushsafer"    : 1.1.0    , installed 1.1.0
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "ring"         : 6.4.0    , installed 6.3.0  [Updatable]
    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "schoolfree"   : 1.1.12   , installed 1.1.12
    Adapter    "shuttercontrol": 2.0.5   , installed 2.0.5
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram-menu": 2.4.4    , installed 2.4.4
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 3.3.0    , installed 4.0.0
    Adapter    "tuya"         : 3.16.0   , installed 3.17.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.1
    Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-2-widgets-weather-and-heating": 1.1.3, installed 1.1.3
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
    Adapter    "weather-warnings": 0.7.4 , installed 0.7.4
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "wireguard"    : 1.7.0    , installed 1.8.0
    Adapter    "wled"         : 0.7.2    , installed 0.7.3
    Adapter    "zigbee"       : 3.0.5    , installed 3.0.5
    Objects and States
    Objects:        32011
    States:         27020
    W: https://deb.nodesource.com/node_20.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://security.debian.org/debian-security trixie-security InRelease
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.3:1883      0.0.0.0:*               LISTEN      1000       10257      1823/io.sonoff.0
    tcp        0      0 192.168.178.3:1890      0.0.0.0:*               LISTEN      1000       9885       1561/io.mqtt.0
    tcp        0      0 192.168.178.3:1891      0.0.0.0:*               LISTEN      1000       9886       1561/io.mqtt.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       7270       609/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       7265       609/iobroker.js-con
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7366       884/exim4
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6346       643/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          372        1/init
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       15444      2932/io.simple-api.
    tcp6       0      0 :::8086                 :::*                    LISTEN      1000       15581      2978/io.ws.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       15505      2910/io.socketio.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       15627      2880/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       7564       991/io.admin.0
    tcp6       0      0 :::8000                 :::*                    LISTEN      1000       4135600    2853/io.upnp.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7367       884/exim4
    tcp6       0      0 :::51989                :::*                    LISTEN      1000       15244      3342/io.nuki-extend
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6348       643/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          374        1/init
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          373        1/init
    udp        0      0 0.0.0.0:49424           0.0.0.0:*                           1000       14268      2853/io.upnp.0
    udp        0      0 0.0.0.0:50209           0.0.0.0:*                           1000       10652473   1504/io.broadlink2.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       15261      3250/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       15253      3250/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       13131      2908/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       10296      1911/io.chromecast.
    udp        0      0 0.0.0.0:5541            0.0.0.0:*                           1000       15278      3250/io.matter.0
    udp        0      0 0.0.0.0:54888           0.0.0.0:*                           1000       9694       1504/io.broadlink2.
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15677      2853/io.upnp.0
    udp        0      0 0.0.0.0:47532           0.0.0.0:*                           1000       15289      3250/io.matter.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       13879      2323/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       13880      2323/io.tuya.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       9674       1504/io.broadlink2.
    udp6       0      0 :::111                  :::*                                0          375        1/init
    udp6       0      0 :::5353                 :::*                                1000       15264      3250/io.matter.0
    udp6       0      0 :::5353                 :::*                                1000       15256      3250/io.matter.0
    udp6       0      0 :::5541                 :::*                                1000       15269      3250/io.matter.0
    udp6       0      0 :::47532                :::*                                1000       15288      3250/io.matter.0
    2025-09-24 19:30:13.731  - info: host.ioBroker instance system.adapter.odl.0 having pid 648294 terminated with code 0 (NO_ERROR)
    2025-09-24 19:30:16.485  - info: host.ioBroker instance system.adapter.dwd.0 having pid 648310 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-09-24 19:30:16.966  - info: host.ioBroker instance system.adapter.ical.0 having pid 648278 terminated with code 0 (NO_ERROR)
    2025-09-24 19:30:34.369  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
     Garagentoröffner (19:30)
    2025-09-24 19:32:04.375  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
     Garagentoröffner (19:32)
    2025-09-24 19:33:34.370  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
     Garagentoröffner (19:33)
    2025-09-24 19:35:03.018  - info: host.ioBroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 648541
    2025-09-24 19:35:07.405  - info: host.ioBroker instance system.adapter.dwd.0 having pid 648541 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-09-24 19:36:34.374  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
     Garagentoröffner (19:36)
    2025-09-24 19:38:34.382  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
     Garagentoröffner (19:38)
    2025-09-24 19:40:03.011  - info: host.ioBroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 648768
    2025-09-24 19:40:04.441  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
     Garagentoröffner (19:40)
    2025-09-24 19:40:08.258  - info: host.ioBroker instance system.adapter.dwd.0 having pid 648768 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-09-24 19:41:34.386  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
     Garagentoröffner (19:41)
    2025-09-24 19:43:04.385  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
     Garagentoröffner (19:43)
    2025-09-24 19:44:34.393  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
     Garagentoröffner (19:44)
    crunchipC Offline
    crunchipC Offline
    @dragon sagte in Visu App macht Probleme:
    Entsprechende Einstellungen in der App tätigen?
    Ich selbst nutze das nicht
      Dragon
      schrieb am zuletzt editiert von Dragon
      @crunchip @Thomas-Braun
      Wenn ich ein Update auf nodejs 22 mache verbindet sich der cloud adapter nicht mehr.
      Einstellungen in der App auf was? Sie funktioniert ja hin und wieder. Es liegt also nicht an der App sondern an der Cloudverbindung, es sei denn in der App ist etwas kaputt geupdated worden. Im App Thread scheint es genau um mein Problem zu gehen. Scheine nicht der einzige zu sein.
      Mit dem Update auf nodejs22 warte ich glaub ich lieber noch. wenn dann die cloudanbindung garnicht mehr funktioniert ist das für mich gar keine Lösung.
      Das mit dem System reboot kommt von automatisch gemachten updates. Wenn ich immer sofort neu starte wenn darum gebeten wird bin ich gefühlt täglich am neustarten. Seitdem ist aber auch schon mehrfach neu gestartet worden.
      • D Dragon
        Die Meldung wird eigentlich zurückgesetzt, wenn gebootet wurde. Und die erscheint auch nur bei sehr systemnahen Updates, das sind aber nicht besonders viele.
        • D Dragon
          Hier schon. Was gibt es für Meldungen im Log dazu?
            Dragon
            host.ioBroker
            2025-09-15 15:22:43.253	error	instance system.adapter.cloud.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.ioBroker
            2025-09-15 15:22:43.253	error	Caught by controller[3]: at Socket.onError (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:681:8)
            host.ioBroker
            2025-09-15 15:22:43.253	error	Caught by controller[3]: at Socket.onClose (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:703:20)
            host.ioBroker
            2025-09-15 15:22:43.253	error	Caught by controller[3]: at WS.Transport.close (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:94:10)
            host.ioBroker
            2025-09-15 15:22:43.253	error	Caught by controller[3]: at WS.doClose (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:234:13)
            host.ioBroker
            2025-09-15 15:22:43.253	error	Caught by controller[3]: at WebSocket.close (node:internal/deps/undici/undici:12676:9)
            host.ioBroker
            2025-09-15 15:22:43.253	error	Caught by controller[3]: at closeWebSocketConnection (node:internal/deps/undici/undici:12015:9)
            host.ioBroker
            2025-09-15 15:22:43.253	error	Caught by controller[3]: at failWebsocketConnection (node:internal/deps/undici/undici:11744:9)
            host.ioBroker
            2025-09-15 15:22:43.253	error	Caught by controller[3]: at fireEvent (node:internal/deps/undici/undici:11663:14)
            host.ioBroker
            2025-09-15 15:22:43.253	error	Caught by controller[3]: at WebSocket.dispatchEvent (node:internal/event_target:762:26)
            host.ioBroker
            2025-09-15 15:22:43.253	error	Caught by controller[3]: at WebSocket.[nodejs.internal.kHybridDispatch] (node:internal/event_target:835:9)
            host.ioBroker
            2025-09-15 15:22:43.253	error	Caught by controller[3]: RangeError: Maximum call stack size exceeded
            host.ioBroker
            2025-09-15 15:22:43.253	error	Caught by controller[2]: at Socket.onError (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:681:8)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[2]: at Socket.onClose (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:703:20)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[2]: at WS.Transport.close (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:94:10)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[2]: at WS.doClose (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:234:13)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[2]: at WebSocket.close (node:internal/deps/undici/undici:12676:9)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[2]: at closeWebSocketConnection (node:internal/deps/undici/undici:12015:9)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[2]: at failWebsocketConnection (node:internal/deps/undici/undici:11744:9)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[2]: at fireEvent (node:internal/deps/undici/undici:11663:14)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[2]: at WebSocket.dispatchEvent (node:internal/event_target:762:26)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[2]: at WebSocket.[nodejs.internal.kHybridDispatch] (node:internal/event_target:835:9)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[2]: RangeError: Maximum call stack size exceeded
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[1]: at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[1]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[1]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[1]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[1]: at Intercept (node:internal/deps/undici/undici:7535:20)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[1]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[1]: at new Request (node:internal/deps/undici/undici:2008:27)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[1]: at Channel.publish (node:diagnostics_channel:150:9)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[1]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:192:9)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[1]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:282:39)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[1]: TypeError: request.headers.split is not a function
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[0]: at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[0]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[0]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[0]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[0]: at Intercept (node:internal/deps/undici/undici:7535:20)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[0]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[0]: at new Request (node:internal/deps/undici/undici:2008:27)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[0]: at Channel.publish (node:diagnostics_channel:150:9)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[0]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:192:9)
            host.ioBroker
            2025-09-15 15:22:43.252	error	Caught by controller[0]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:282:39)
            host.ioBroker
            2025-09-15 15:22:43.251	error	Caught by controller[0]: TypeError: request.headers.split is not a function
            cloud.0
            2025-09-15 15:22:43.060	error	Maximum call stack size exceeded
            cloud.0
            2025-09-15 15:22:43.059	error	RangeError: Maximum call stack size exceeded at WebSocket.[nodejs.internal.kHybridDispatch] (node:internal/event_target:835:9) at WebSocket.dispatchEvent (node:internal/event_target:762:26) at fireEvent (node:internal/deps/undici/undici:11663:14) at failWebsocketConnection (node:internal/deps/undici/undici:11744:9) at closeWebSocketConnection (node:internal/deps/undici/undici:12015:9) at WebSocket.close (node:internal/deps/undici/undici:12676:9) at WS.doClose (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:234:13) at WS.Transport.close (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:94:10) at Socket.onClose (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:703:20) at Socket.onError (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:681:8)
            cloud.0
            2025-09-15 15:22:43.059	error	uncaught exception: Maximum call stack size exceeded
            • D Dragon
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              host.ioBroker
              cloud.0
              cloud.0
              cloud.0
              @dragon
              Welcher Typ ist bei WebSockets eingestellt?
                @dragon
                Dragon
                @thomas-braun in den einstellungen des cloudadapters steht web.0 ist das das was du meintest?
                im web adapter steht das hier:
                Oder war die Frage nach etwas anderem?
                • D Dragon
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @dragon
                  Probiers mal so
                  • haselchenH haselchen
                    @dragon
                    Probiers mal so
                    Dragon
                    @haselchen Was ist mit den anderen Einstellungen? Die in deinem Bild fehlen.
                    • D Dragon
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @dragon
                      Würdest Du sehen, wenn Du es so einstellen würdest ;)
                        @dragon
                        Dragon
                        Einstellung geändert. Die übrigen Infos fehlen trotzdem...
                        • D Dragon
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @dragon
                          Welche Adapter Version von Web.0 hast Du?
                          Wie sehen Deine WS.0 Einstellungen aus?
                          Und Simple Api Einstellungen (hast Du eine Instanz davon installiert?)
                            @dragon
                            Dragon
                            @haselchen Web.0 ist 7.0.8
                            • D Dragon
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              @dragon
                              Im Grunde hast Du auch meine Einstellungen in den 3 Adaptern.
                              Ich bin bei allen im Latest (Beta)
                              Ob dadurch andere Einstellungsmöglichkeiten erscheinen oder nicht mehr erscheinen , kann ich Dir nicht mehr sagen.
                              Bei web.0 jedenfalls habe ich keine anderen Einstellungen mehr wenn ich "ws" angebe.
                              Edit: ich denke mal, dass liegt vermutlich an den Versionen, da Du im Web.0 den Haken für Simple Api hast, trotz "Ws" Auswahl.
                                @dragon
                                Dragon
                                @haselchen ich bin bei allen auf stable. Welche Einstellungen muss ich denn nehmen im webadapter. und bei simple ist ja quasi nichts eingestellt. sollte man da etwas einstellen?
                                • D Dragon
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  @dragon
                                  Ich hab bei Simple Api auch nichts eingestellt.
                                  Bei web, ws, simple api....kommt es ja darauf an , was Du vor hast.
                                  Ich hab das damals so eingestellt, damit Flot und die VISU App funktionieren.
                                    @dragon
                                    Dragon
                                    @haselchen Ich hatte meine Einstellungen gemacht, damit der Fully Browser und die Visu App funktionieren. Noch irgendeine Idee?
                                    • D Dragon
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      @dragon
                                      Ich hab Dir unten auf Seite 1 mal meine Einstellungen gepostet, mit denen das seit Jahren funktioniert.
                                      Kannst es ja zur Probe übernehmen.
                                        @dragon
                                        Dragon
                                        @haselchen Was für eine Seite 1?
                                        • D Dragon
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          @dragon
                                          In der VISU App bei IP und Port gibste dann die IP an, wo Iobroker (VIS) installiert ist .
                                          Z.b. 192.168.178.100:8082
